11-High Availability Command Reference
HomeSupportSwitchesS10500X SeriesReference GuidesCommand ReferencesH3C S10500X Switch Series Command References-Release758X-6W10011-High Availability Command Reference
03-DLDP commands
03-DLDP commands 82.39 KB
DLDP commands
display dldp
Use display dldp to display DLDP configuration.
display dldp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays global and port-specific DLDP configuration.
# Display global and port-specific DLDP configuration.
<Sysname> display dldp
 DLDP global status: Enabled
 DLDP advertisement interval: 5s
 DLDP authentication-mode: Simple
 DLDP authentication-password: ******
 DLDP unidirectional-shutdown mode: Auto
 DLDP delaydown-timer value: 1s
 Number of enabled ports: 2
Interface Ten-GigabitEthernet1/0/1
 DLDP port state: Bidirectional
 DLDP port unidirectional-shutdown mode: None
 DLDP initial-unidirectional-delay: 100s
 Number of the port’s neighbors: 1
  Neighbor MAC address: 0023-8956-3600
  Neighbor port index: 79
  Neighbor state: Confirmed
  Neighbor aged time: 13s
  Neighbor echo time: -
Interface Ten-GigabitEthernet1/0/2
 DLDP port state: Inactive
 Number of the port’s neighbors: 0 (Maximum number ever detected: 1)
# Display the DLDP configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display dldp interface ten-gigabitethernet 1/0/1
DLDP global status
Global DLDP state (Enabled or Disabled).
Interval for sending Advertisement packets (in seconds) to maintain neighbor relations.
DLDP authentication mode (None, Simple, or MD5).
Password for DLDP authentication:
·          ******—The password has been configured.
·          Not configured—The authentication mode has been configured but no password is configured.
Global port shutdown mode (auto, manual, or hybrid) after unidirectional links are detected.
Port shutdown mode for the interface (auto, manual, or hybrid) after unidirectional links are detected. If no port shutdown mode is configured for an interface, this field displays None.
Setting of the DelayDown timer, in seconds.
Number of the DLDP-enabled ports.
Index of a DLDP-enabled port.
DLDP port state
DLDP state on a port:
·          Bidirectional.
·          Inactive.
·          Initial.
·          Unidirectional.
Delay time in seconds for DLDP to block the interface upon an Initial-to-Unidirectional state transition.
Current number of neighbors.
Maximum number of neighbors once detected on the port. This field appears only when the current number of neighbors is different from the maximum number of neighbors once detected.
Bridge MAC address of the device where the neighbor resides.
Neighbor port index
Neighbor port index.
Neighbor state
Neighbor state (Confirmed or Unconfirmed).
Neighbor aged time
Neighbor aging time.
Neighbor echo time
Number of seconds remaining before the Echo timer expires.
The Echo timer starts when the Entry timer expires. The neighbor information is deleted when the Echo timer expires. A hyphen (-) indicates that the Echo timer has not started.
display dldp statistics
Use display dldp statistics to display DLDP packet statistics.
display dldp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays DLDP packet statistics for all interfaces.
# Display DLDP packet statistics for all interfaces.
<Sysname> display dldp statistics
 Packets sent: 6
 Packets received: 5
 Invalid packets received: 2
 Loopback packets received: 0
 Authentication-failed packets received: 0
 Valid packets received: 3
 Packets sent: 7
 Packets received: 7
 Invalid packets received: 3
 Valid packets received: 4
Port index.
Packets sent
Total number of DLDP packets sent.
Packets received
Total number of DLDP packets received.
Number of the invalid packets received.
Loop packets received
Number of the loopback packets received.
Authentication failed packets received
Number of the received packets that failed to pass the authentication.
Number of the valid packets received.
reset dldp statistics
dldp authentication-mode
Use dldp authentication-mode to configure DLDP authentication.
Use undo dldp authentication-mode to restore the default.
dldp authentication-mode { md5 | none | simple }
DLDP authentication mode is none.
md5: Specifies the MD5 authentication mode.
none: Specifies not to perform authentication.
simple: Specifies the plaintext authentication mode.
To enable DLDP to operate correctly, make sure the DLDP authentication modes and the passwords configured on the two ends of a link are the same.
If you do not configure the authentication password after you configure the authentication mode, the authentication mode is none no matter which authentication mode you configure.
# Configure to perform plaintext authentication and set the password to abc (assuming that Device A and Device B are connected by a DLDP link).
·           Configure Device A:
[DeviceA] dldp authentication-mode simple
[DeviceA] dldp authentication-password simple abc
·           Configure Device B:
[DeviceB] dldp authentication-mode simple
[DeviceB] dldp authentication-password simple abc
display dldp
Use dldp authentication-password to configure the password for DLDP authentication.
Use undo dldp authentication-password to restore the default.
dldp authentication-password { cipher | simple } string
No DLDP authentication password is configured.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters.
display dldp
dldp delaydown-timer
Use dldp delaydown-timer to set the DelayDown timer.
Use undo dldp delaydown-timer to restore the default.
dldp delaydown-timer time
The setting of the DelayDown timer is 1 second.
time: Specifies the DelayDown timer in the range of 1 to 5 seconds.
The DelayDown timer configured by using this command applies to all DLDP-enabled ports.
# Set the DelayDown timer to 2 seconds.
[Sysname] dldp delaydown-timer 2
display dldp
dldp enable
Use dldp enable to enable DLDP on a port.
Use undo dldp enable to restore the default.
dldp enable [ initial-unidirectional-delay time ]
undo dldp enable
DLDP is disabled on a port, and when DLDP is enabled, a port is blocked immediately upon an Initial-to-Unidirectional state transition.
initial-unidirectional-delay time: Specifies the delay time for DLDP to block a port upon an Initial-to-Unidirectional state transition. The value range for the time argument is 60 to 300 seconds. If you do not specify this option, DLDP blocks the port immediately upon an Initial-to-Unidirectional state transition.
DLDP can take effect only after you enable it globally and on a port.
When enabling DLDP on a port, you can set the delay time for DLDP to block the port upon an Initial-to-Unidirectional state transition. If the port does not enter Bidirectional state when the delay time expires, DLDP blocks the port.
# Enable DLDP globally, and enable DLDP on Ten-GigabitEthernet 1/0/1 and set a delay time of 100 seconds for DLDP to block the port upon an Initial-to-Unidirectional state transition.
[Sysname] dldp global enable
[Sysname-Ten-GigabitEthernet1/0/1] dldp enable initial-unidirectional-delay 100
display dldp
dldp global enable
dldp global enable
Use dldp global enable to enable DLDP globally.
Use undo dldp global enable to disable DLDP globally.
dldp global enable
DLDP is disabled globally.
# Enable DLDP globally.
display dldp
dldp enable
dldp interval
Use dldp interval to set the interval for sending Advertisement packets.
Use undo dldp interval to restore the default.
dldp interval interval
undo dldp interval
The interval for sending Advertisement packets is 5 seconds.
interval: Specifies Advertisement packets sending interval in the range of 1 to 100 seconds.
This command applies to all DLDP-enabled ports.
To enable DLDP to operate correctly, make sure the intervals for sending Advertisement packets configured on the two ends of a link are the same.
# Set the interval for sending Advertisement packets to 20 seconds.
[Sysname] dldp interval 20
display dldp
dldp port unidirectional-shutdown
Use dldp port unidirectional-shutdown to set the port shutdown mode for an interface.
Use undo dldp port unidirectional-shutdown to restore the default.
dldp port unidirectional-shutdown { auto | hybrid | manual }
The global setting is used.
auto: Specifies the auto mode. In this mode, when DLDP detects a unidirectional link, it shuts down the unidirectional port. When the link becomes bidirectional, DLDP brings up the port that was shut down.
hybrid: Specifies the hybrid mode. In this mode, when DLDP detects a unidirectional link, it shuts down the unidirectional port and stops link detection. To verify the link status, use the undo shutdown command to bring up the port. If the link becomes bidirectional, the port becomes bidirectional.
manual: Specifies the manual mode. In this mode, when DLDP detects a unidirectional link, it does not shut down the involved port. You must manually shut it down. To verify the link status, use the undo shutdown command to bring up the port. If the link becomes bidirectional, the port becomes bidirectional.
If DLDP detects a unidirectional link, you must troubleshoot the interface and cabling faults.
The port shutdown mode setting for an interface takes effect only on the current interface and has priority over the global port shutdown mode setting.
# Set the port shutdown mode to manual for Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dldp port unidirectional-shutdown manual
display dldp
dldp unidirectional-shutdown
Use dldp unidirectional-shutdown to set the global port shutdown mode.
Use undo dldp unidirectional-shutdown to restore the default.
dldp unidirectional-shutdown { auto | hybrid | manual }
The global port shutdown mode is auto mode.
The global port shutdown mode setting takes effect on all interfaces and has lower priority than the port shutdown mode setting for an interface.
# Set the global port shutdown mode to manual mode.
[Sysname] dldp unidirectional-shutdown manual
display dldp
Use reset dldp statistics to clear DLDP packet statistics.
reset dldp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command clears DLDP packet statistics for all interfaces.
# Clear DLDP packet statistics for all interfaces.
<Sysname> reset dldp statistics
