07-IP Multicast Command Reference
HomeSupportSwitchesS10500X SeriesReference GuidesCommand ReferencesH3C S10500X Switch Series Command References-Release758X-6W10007-IP Multicast Command Reference
09-MLD snooping commands
09-MLD snooping commands 339.53 KB
MLD snooping commands· 1
display ipv6 l2-multicast fast-forwarding cache· 1
display ipv6 l2-multicast ip· 2
display ipv6 l2-multicast ip forwarding· 4
display ipv6 l2-multicast mac· 6
display ipv6 l2-multicast mac forwarding· 8
display mld-snooping· 9
display mld-snooping group· 12
display mld-snooping host-tracking· 15
display mld-snooping router-port 17
display mld-snooping static-group· 19
display mld-snooping static-router-port 20
display mld-snooping statistics· 21
dot1p-priority (MLD-snooping view) 23
drop-unknown (MLD-snooping view) 23
dscp· 24
enable (MLD-snooping view) 25
entry-limit (MLD-snooping view) 25
fast-leave (MLD-snooping view) 26
global-enable (MLD-snooping view) 27
group-policy (MLD-snooping view) 27
host-aging-time (MLD-snooping view) 29
host-tracking (MLD-snooping view) 30
last-listener-query-interval (MLD-snooping view) 30
max-response-time (MLD-snooping view) 31
mld-snooping· 32
mld-snooping done source-ip· 32
mld-snooping dot1p-priority· 33
mld-snooping drop-unknown· 34
mld-snooping { disable | enable } 35
mld-snooping fast-leave· 36
mld-snooping general-query source-ip· 37
mld-snooping group-limit 38
mld-snooping group-policy· 39
mld-snooping host-aging-time· 40
mld-snooping host-join· 42
mld-snooping host-tracking· 43
mld-snooping last-listener-query-interval 43
mld-snooping max-response-time· 44
mld-snooping overflow-replace· 46
mld-snooping proxy enable· 46
mld-snooping querier 47
mld-snooping querier-election· 48
mld-snooping query-interval 49
mld-snooping report source-ip· 50
mld-snooping router-aging-time· 51
mld-snooping router-port-deny· 52
mld-snooping source-deny· 53
mld-snooping special-query source-ip· 54
mld-snooping static-group· 55
mld-snooping static-router-port 56
mld-snooping version· 56
overflow-replace (MLD-snooping view) 57
report-aggregation (MLD-snooping view) 58
reset ipv6 l2-multicast fast-forwarding cache· 59
reset mld-snooping group· 60
reset mld-snooping router-port 60
reset mld-snooping statistics· 61
router-aging-time (MLD-snooping view) 61
send-query enable· 62
source-deny (MLD-snooping view) 63
version (MLD-snooping view) 63
Use display ipv6 l2-multicast fast-forwarding cache to display Layer 2 IPv6 multicast fast forwarding entries.
In standalone mode:
display ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] [ ipv6-source-address | ipv6-group-address ] * [ slot slot-number ]
In IRF mode:
display ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] [ ipv6-source-address | ipv6-group-address ] * [ chassis chassis-number slot slot-number ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094.
ipv6-source-address: Specifies an IPv6 multicast source address. If you do not specify an IPv6 multicast source, this command displays Layer 2 IPv6 multicast forwarding entries for all IPv6 multicast sources.
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays Layer 2 IPv6 multicast forwarding entries for all IPv6 multicast groups.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays Layer 2 IPv6 multicast fast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays Layer 2 IPv6 multicast fast forwarding entries for the global active MPU. (In IRF mode.)
# Display Layer 2 IPv6 multicast fast forwarding entries.
<Sysname> display ipv6 l2-multicast fast-forwarding cache
Total 1 entries, 1 matched
(1::6, FF1E::2)
      Status      : Enable                VLAN            : 1
      Source port : 9876                  Destination port: 5432
      Protocol    : 17                    Flag            : 0x2
      Ingress port: Ten-GigabitEthernet1/0/2
      List of 1 egress ports:
           Ten-GigabitEthernet1/0/3
           Status: Enable                Flag: 0x10
Total number of (S, G) entries in the Layer 2 IPv6 multicast fast forwarding table, and the total number of matching entries.
(1::6, FF1E::2)
(S, G) entry in the Layer 2 IPv6 multicast fast forwarding table.
Protocol
Protocol number.
VLAN
VLAN ID.
Flag
Flag for the (S, G) entry or the outgoing port.
This field displays one flag or the sum of multiple flags. In this example, the value 0x2 means that the entry has only one flag 0x2.
The following flags are available for an entry:
·          0x1—The entry is created because of packets passed through between cards.
·          0x2—The entry is added by multicast forwarding.
The following flags are available for an outgoing interface:
·          0x1—The port is added to the entry because of packets passed through between cards.
·          0x2—The port is added to an existing entry.
·          0x10—The port is associated with the entry.
·          0x20—The port is to be deleted.
Status
Status of the (S, G) entry or the outgoing port:
·          Enabled—Available.
·          Disabled—Unavailable.
Ingress port
Incoming port of the (S, G) entry.
List of outgoing ports of the (S, G) entry.
reset ipv6 l2-multicast fast-forwarding cache all
Use display ipv6 l2-multicast ip to display information about Layer 2 IPv6 multicast groups.
In standalone mode:
display ipv6 l2-multicast ip [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
In IRF mode:
display ipv6 l2-multicast ip [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ]
group ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. If you do not specify an IPv6 multicast group, this command displays information about all Layer 2 IPv6 multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays information about Layer 2 IPv6 multicast groups for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about Layer 2 IPv6 multicast groups for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about Layer 2 IPv6 multicast groups for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about Layer 2 IP multicast groups for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about Layer 2 IP multicast groups for the global active MPU. (In IRF mode.)
# Display information about Layer 2 IPv6 multicast groups for VLAN 2.
<Sysname> display ipv6 l2-multicast ip vlan 2
Total 1 entries.
VLAN 2: Total 1 entries.
   (::, FF1E::101)
    Attribute: static, success
    Host ports (1 in total):
      XGE1/0/1                              (S, SUC)
# Display information about Layer 2 IPv6 multicast groups for VSI bbb.
<Sysname> display ipv6 l2-multicast ip vsi bbb
Total 2 entries.
VSI bbb: Total 2 entries.
  (::, FF1E::101)
    Attribute: dynamic, success
    Host ports (2 in total):
      XGE1/0/3 (Link ID 0)                  (D, SUC)
      Tun1 (VXLAN ID 0)                    (D, SUC)
  (1::1, FF1E::101)
      XGE1/0/3 (Link ID 0)                  (DE)
      Tun1 (VXLAN ID 0)                    (DE)
Total 1 entries
Total number of Layer 2 IPv6 multicast groups.
Total number of Layer 2 IPv6 multicast groups in VLAN 2.
VSI aaa: Total 1 entries
Total number of Layer 2 IPv6 multicast groups in VSI aaa.
(::, FF1E::101)
(S, G) entry, where a double colon (::) in the S position means all IPv6 multicast sources.
Attribute
Entry attribute:
·          dynamic—The entry is created by a dynamic protocol.
·          static—The entry is created by a static protocol.
·          pim—The entry is created by IPv6 PIM.
·          kernel—The entry is obtained from the kernel.
·          success—Processing has succeeded.
·          fail—Processing has failed.
Member ports and total number of member ports.
(S, SUC)
Port attribute:
·          D—Dynamic port.
·          DE—Dynamic member port in Exclude mode.
·          S—Static port.
·          P—IPv6 PIM port.
·          K—Port obtained from the kernel.
·          R—Port learned from (*, *) entries.
·          W—Port learned from (*, G) entries.
·          SUC—Processing has succeeded.
·          F—Processing has failed.
·          BC—The port is a TRILL port that floods IPv6 multicast data after the topology changes.
AC and its link ID.
Tun1 (VXLAN ID 0)
VXLAN tunnel and its VXLAN ID.
Use display ipv6 l2-multicast ip forwarding to display Layer 2 IPv6 multicast IP forwarding entries.
In standalone mode:
display ipv6 l2-multicast ip forwarding [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
In IRF mode:
display ipv6 l2-multicast ip forwarding [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ]
group ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. If you do not specify an IPv6 multicast group, this command displays Layer 2 IPv6 multicast IP forwarding entries for all IPv6 multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays Layer 2 IPv6 multicast IP forwarding entries for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays Layer 2 IPv6 multicast IP forwarding entries for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays Layer 2 IPv6 multicast IP forwarding entries for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the Layer 2 IPv6 multicast IP forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays Layer 2 IPv6 multicast IP forwarding entries for the global active MPU. (In IRF mode.)
# Display Layer 2 IPv6 multicast IP forwarding entries for VLAN 2.
<Sysname> display ipv6 l2-multicast ip forwarding vlan 2
Total 1 entries.
   (::, FF1E::101)
    Host ports (3 in total):
      Ten-GigabitEthernet1/0/1
# Display Layer 2 IPv6 multicast IP forwarding entries for VSI bbb.
<Sysname> display ipv6 l2-multicast ip forwarding vsi bbb
Total 1 entries.
VSI bbb: Total 1 entries.
  (::, FF1E::101)
      Ten-GigabitEthernet1/0/3 (Link ID 0)
      Tunnel1 (VXLAN ID 0)
Total 1 entries
Total number of Layer 2 IPv6 multicast IP forwarding entries.
Total number of Layer 2 IPv6 multicast IP forwarding entries in VLAN 2.
Total number of Layer 2 IPv6 multicast IP forwarding entries in VSI aaa.
(::, FF1E::101)
AC and its link ID.
Use display ipv6 l2-multicast mac to display information about Layer 2 IPv6 multicast MAC multicast groups.
In standalone mode:
display ipv6 l2-multicast mac [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
In IRF mode:
display ipv6 l2-multicast mac [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ]
mac-address: Specifies an IPv6 multicast MAC address. If you do not specify an IPv6 multicast MAC address, this command displays information about all Layer 2 IPv6 multicast MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about Layer 2 IPv6 multicast MAC multicast groups for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about Layer 2 IPv6 multicast MAC multicast groups for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about the Layer 2 IPv6 multicast MAC multicast groups for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about Layer 2 IPv6 multicast MAC multicast groups for the global active MPU. (In IRF mode.)
# Display information about Layer 2 IPv6 multicast MAC multicast groups for VLAN 2.
<Sysname> display ipv6 l2-multicast mac vlan 2
Total 1 entries.
  MAC group address: 3333-0000-0101
    Attribute: success
      XGE1/0/1
# Display information about Layer 2 IPv6 MAC multicast groups for VSI bbb.
<Sysname> display ipv6 l2-multicast mac vsi bbb
Total 1 entries.
  MAC group address: 0100-5e01-0101
    Attribute: success
      XGE1/0/3 ( Link ID 0)
      Tun1 (VXLAN ID 0)
Total 1 entries
Total number of Layer 2 IPv6 MAC multicast groups.
Total number of Layer 2 IPv6 MAC multicast groups in VLAN 2.
Total number of Layer 2 IPv6 MAC multicast groups in VSI aaa.
MAC group address
IPv6 address of the Layer 2 IPv6 MAC multicast group.
Attribute
Entry attribute:
AC and its link ID.
Tun1 (VXLAN ID 0)
Use display ipv6 l2-multicast mac forwarding to display Layer 2 IPv6 multicast MAC forwarding entries.
In standalone mode:
display ipv6 l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
In IRF mode:
display ipv6 l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ]
mac-address: Specifies an IPv6 MAC multicast group by its IPv6 MAC address. If you do not specify an IPv6 MAC multicast group, this command displays Layer 2 IPv6 multicast MAC forwarding entries for all IPv6 MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays Layer 2 IPv6 multicast MAC forwarding entries for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays Layer 2 IPv6 multicast MAC forwarding entries for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays Layer 2 IPv6 multicast MAC forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays Layer 2 IPv6 multicast MAC forwarding entries for the global active MPU. (In IRF mode.)
# Display Layer 2 IPv6 multicast MAC forwarding entries for VLAN 2.
<Sysname> display ipv6 l2-multicast mac forwarding vlan 2
Total 1 entries.
# Display Layer 2 IPv6 multicast MAC forwarding entries for VSI bbb.
<Sysname> display ipv6 l2-multicast mac forwarding vsi bbb
Total 1 entries.
Table 5 Command output
Total 1 MAC entries
Total number of Layer 2 IPv6 multicast MAC forwarding entries.
Total number of Layer 2 IPv6 multicast MAC forwarding entries in VLAN 2.
Total number of Layer 2 IPv6 multicast MAC forwarding entries in VSI aaa.
MAC group address
Address of the IPv6 MAC multicast group.
Member ports, and the total number of member ports.
AC and its link ID.
Use display mld-snooping to display MLD snooping status.
display mld-snooping [ global | vlan vlan-id | vsi vsi-name ]
global: Displays the global MLD snooping status.
If you do not specify any parameters, this command displays the global MLD snooping status and the MLD snooping status in all VLANs and VSIs.
# Display the global MLD snooping status and the MLD snooping status for all VLANs and VSIs.
<Sysname> display mld-snooping
MLD snooping information: Global
  Global-enable: Enabled
 Drop-unknown: Disabled
 Host-aging-time: 260s
 Router-aging-time: 260s
 Max-response-time: 10s
 Last-listener-query-interval: 1s
 Report-aggregation: Enabled
 Host-tracking: Disabled
 Dot1p-priority: --
MLD snooping information: VLAN 1
 MLD snooping: Enabled
 Version: 1
 Querier: Enabled (IP: FE80::2FF:FFFF:FE00:1, Expires: 00:02:05)
 Querier-election: Enabled
 Query-interval: 125s
 General-query source IP: FE80::2FF:FFFF:FE00:1
 Special-query source IP: FE80::2FF:FFFF:FE00:1
 Report source IP: FE80::2FF:FFFF:FE00:2
 Done source IP: FE80::2FF:FFFF:FE00:3
 Dot1p-priority: 2
 Proxy: Disabled
MLD snooping information: VLAN 10
 Drop-unknown: Enabled
 Version: 1
 Dot1p-priority: --
 Proxy: Disabled
MLD snooping information: VSI aaa
 Version: 1
 Querier: Disabled
 Querier-election: Disabled
 Proxy: Disabled
Table 6 Command output
Global-enable
Global MLD snooping status:
·          Enabled.
·          Disabled.
MLD snooping
MLD snooping status in a VLAN or VSI:
·          Enabled.
·          Disabled.
·          Globally enabled.
·          InactiveMLD snooping configuration does not take effect.
Drop-unknown
Status of dropping unknown IPv6 multicast data:
·          Enabled.
·          Disabled.
·          Globally enabled.
Version
MLD snooping version.
Host-aging-time
Aging timer for the dynamic member port.
Router-aging-time
Aging timer for the dynamic router port.
Max-response-time
Maximum time for responding to MLD general queries.
Interval for sending MLD multicast-address-specific queries.
Report-aggregation
Status of MLD report suppression:
·          Enabled.
·          Disabled.
Dot1p-priority
802.1p priority for MLD messages. This field displays two hyphens (--) if the 802.1p priority is not configured.
Querier
Status of MLD snooping querier:
·          Enabled.
·          Disabled.
MLD snooping querier information:
·          IP—IP address of the MLD snooping querier.
·          Expire—Remaining aging time for the MLD snooping querier.
This field is not displayed if MLD snooping querier election is disabled.
Querier-election
Status of MLD snooping querier election:
·          Enabled.
·          Disabled.
Query-interval
Interval for sending MLD general queries.
Source IPv6 address of MLD general queries.
Source IPv6 address of MLD multicast-address-specific queries.
Report source IP
Source IPv6 address of MLD reports.
Done source IP
Source IPv6 address of MLD done messages.
Host-tracking
Status of host tracking:
·          Enabled.
·          Disabled.
·          Globally enabled.
Proxy
Status of MLD snooping proxying:
·          Enabled.
·          Disabled.
Use display mld-snooping group to display information about dynamic MLD snooping group entries.
In standalone mode:
display mld-snooping group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ interface interface-type interface-number | [ verbose ] [ slot slot-number  ] ]
In IRF mode:
display mld-snooping group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ interface interface-type interface-number | [ verbose ] [ chassis chassis-number slot slot-number  ] ]
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays information about all dynamic MLD snooping group entries.
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays information about dynamic MLD snooping group entries for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about dynamic MLD snooping group entries for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about dynamic MLD snooping group entries for all VSIs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays brief information about dynamic MLD snooping group entries for all interfaces.
verbose: Displays detailed information about dynamic MLD snooping group entries. If you do not specify this keyword, the command displays brief information about dynamic MLD snooping group entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about dynamic MLD snooping group entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about dynamic MLD snooping group entries for the global active MPU. (In IRF mode.)
# Display brief information about dynamic MLD snooping group entries for Ten-GigabitEthernet 1/0/1.
<Sysname> display mld-snooping group interface
Total 1 entries.
XGE1/0/1:
   (::,FF1E::101)                    (00:03:23)
# Display detailed information about dynamic MLD snooping group entries for VLAN 2.
<Sysname> display mld-snooping group vlan 2 verbose
Total 2 entries.
VLAN 2: Total 2 entries.
  (::,FF1E::101)
    Attribute: local port
    FSM information: normal
    Host slots (0 in total):
      XGE1/0/2                             (00:03:23)
  (12::, FF1E::101)
      XGE1/0/2                            (00:04:02)
    Exclude host ports (1 in total):
      XGE1/0/2                             (00:03:23)
# Display detailed information about dynamic MLD snooping group entries for VSI bbb.
<Sysname> display mld-snooping group vsi bbb verbose
Total 2 entries.
  (::,FF1E::101)
    Attribute: global port
      XGE1/0/3 (Link ID 0)                        (00:03:35)
        VLAN pairs (1 in total):
          Outer VLAN 5     Inner VLAN 2          (00:03:35)
      Tun1 (VXLAN ID 0)                          (00:03:35)
  (1::1,FF1E::101)
    Exclude host ports (2 in total):
      XGE1/0/3 (Link ID 1)                        (00:03:35)
Table 7 Command output
Total 1 entries
Total number of dynamic MLD snooping group entries.
Total number of dynamic MLD snooping group entries in VLAN 2.
Total number of dynamic MLD snooping group entries in VSI aaa.
(::, FF1E::101)
Attribute
Entry attribute:
·          global port—The entry has a global port.
·          local port—The entry has a port that resides on the card for which the information is displayed.
·          slot—The entry has ports that reside on other cards, but not on the card for which the information is displayed.
FSM information
Finite state machine information of the entry:
·          delete—The entry attributes have been deleted.
·          dummy—The entry is a new temporary entry.
·          no info—The entry does not exist.
·          normal—The entry is a correct entry.
(In standalone mode.) Slot numbers and total number of the cards that have member ports, except for the specified card or the MPU when no card is specified.
(In IRF mode.) Chassis numbers, slot numbers, and total number of the cards that have member ports, except for the specified card or the global active MPU when no card is specified.
Member ports in Exclude mode and their count.
(00:03:23)
Remaining aging time for the dynamic member port.
This field is always displayed for a global port (such as Layer 2 aggregate interfaces and ACs).
(In standalone mode.) For a non-global port, this field is displayed when one of the following conditions exists:
·          The port is on the specified card.
·          The port is on the MPU and no card is specified.
(In IRF mode.) For a non-global port, this field is displayed when one of the following conditions exists:
·          The port is on the global active MPU and no card is specified.
AC and its link ID.
Tun1 (VXLAN ID 0)
VLAN pairs and total number of VLAN pairs.
Outer VLAN ID and inner VLAN ID.
Use display mld-snooping host-tracking to display host tracking information.
In standalone mode:
display mld-snooping host-tracking vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ slot slot-number ]
In IRF mode:
display mld-snooping host-tracking vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ chassis chassis-number slot slot-number ]
group ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for the ipv6-group-address argument is FFxy::/16, where "x" and "y" represent any hexadecimal numbers in the range of 0 to F.
source ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this commands displays host tracking information for all IPv6 multicast sources.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays host tracking information for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays host tracking information for the global active MPU. (In IRF mode.)
# Display tracking information for hosts that have joined IPv6 multicast group FF1E::2 in VLAN 2.
<Sysname> display mld-snooping host-tracking vlan 2 group FF1E::2
VLAN 2
 (1::6, FF1E::2)
    Port: XGE1/0/1
      Host                                    Uptime          Expires
      1::2                                    00:02:20        00:00:40
      1::3                                    00:02:21        00:00:39
Table 8 Command output
VLAN
VLAN ID.
(1::6, FF1E::2)
(S, G) entry, where 0::0 in the S position means any IPv6 multicast sources.
Port
Member port.
Host
IPv6 address of the host.
Uptime
Length of time elapsed since the host joined the IPv6 multicast group.
Expires
Remaining timeout time for the host. The host timeout time is the same as the aging timer of the port. The timer is reset when the port receives an MLD report from the host.
This field displays timeout if the host times out.
mld-snooping enable
Use display mld-snooping router-port to display dynamic router port information.
In standalone mode:
display mld-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ slot slot-number ]
In IRF mode:
display mld-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ chassis chassis-number slot slot-number ]
verbose: Displays detailed information about dynamic router ports. If you do not specify this keyword, the command displays brief information about dynamic router ports.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays dynamic router port information for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays dynamic router port information for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays dynamic router port information for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays dynamic router port information for the global active MPU. (In IRF mode.)
# Display brief information about dynamic router ports for VLAN 2.
<Sysname> display mld-snooping router-port vlan 2
VLAN 2:
  Router ports (2 in total):
    XGE1/0/1                              (00:01:30)
    XGE1/0/2                              (00:00:23)
# Display detailed information about dynamic router ports for VLAN 2.
<Sysname> display mld-snooping router-port vlan 2 verbose
VLAN 2:
  Router slots (0 in total):
    XGE1/0/1                             (00:01:30)
    XGE1/0/2                             (00:00:23)
# Display detailed information about dynamic router ports for VSI bbb.
<Sysname> display mld-snooping router-port vsi bbb verbose
VSI bbb:
Table 9 Command output
VLAN 2
VLAN ID.
VSI aaa
VSI name.
(In standalone mode.) Slot numbers and total number of the cards that have dynamic router ports, except for the specified card or the MPU when no card is specified.
(In IRF mode.) Chassis numbers, slot numbers, and total number of the cards that have dynamic router ports, except for the specified card or the global active MPU when no card is specified.
Dynamic router ports and total number of dynamic router ports.
(00:01:30)
Remaining aging time for the dynamic router port.
This field is always displayed for a global port (including Layer 2 aggregate interfaces).
AC and its link ID.
Tun1 (VXLAN ID 0)
Name of the VXLAN tunnel and the VXLAN ID.
Use display mld-snooping static-group to display information about static MLD snooping group entries.
In standalone mode:
display mld-snooping static-group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
In IRF mode:
display mld-snooping static-group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays information about static MLD snooping group entries for all IPv6 multicast groups.
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays information about static MLD snooping group entries for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about static MLD snooping group entries for all VLANs.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about static MLD snooping group entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about static MLD snooping group entries for the global active MPU. (In IRF mode.)
# Display detailed information about static MLD snooping group entries for VLAN 2.
<Sysname> display mld-snooping static-group vlan 2 verbose
Total 1 entries.
  (::,FF1E::101)
    FSM information: dummy
      XGE1/0/2
Table 10 Command output
Total 1 entries
Total number of static MLD snooping group entries.
Total number of static MLD snooping group entries in VLAN 2.
(::, FF1E::101)
Attribute
Entry attribute:
FSM information
Use display mld-snooping static-router-port to display static router port information.
In standalone mode:
display mld-snooping static-router-port [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
In IRF mode:
display mld-snooping static-router-port [ vlan vlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
verbose: Displays detailed information about static router ports. If you do not specify this keyword, the command displays brief information about static router ports.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays static router port information for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays static router port information for the global active MPU. (In IRF mode.)
# Display brief information about static router ports for VLAN 2.
<Sysname> display mld-snooping static-router-port vlan 2
VLAN 2:
    XGE1/0/1
    XGE1/0/2
# Display detailed information about static router ports for VLAN 2.
<Sysname> display mld-snooping static-router-port vlan 2 verbose
VLAN 2:
    XGE1/0/1
    XGE1/0/2
Table 11 Command output
VLAN 2
VLAN ID.
(In standalone mode.) Slot numbers and total number of the cards that have static router ports, except for the specified card or the MPU when no card is specified.
(In IRF mode.) Chassis numbers, slot numbers, and total number of the cards that have static router ports, except for the specified card or the global active MPU when no card is specified.
Static router ports and total number of static router ports.
Use display mld-snooping statistics to display statistics for the MLD messages and IPv6 PIM hello messages learned through MLD snooping.
# Display statistics for the MLD messages and IPv6 PIM hello messages learned through MLD snooping.
<Sysname> display mld-snooping statistics
Received MLD general queries:  0
Received MLDv1 specific queries:  0
Received MLDv1 reports:  0
Received MLD dones:  0
Sent     MLDv1 specific queries:  0
Received MLDv2 reports:  0
Received MLDv2 reports with right and wrong records:  0
Received MLDv2 specific queries:  0
Received MLDv2 specific sg queries:  0
Sent     MLDv2 specific queries:  0
Sent     MLDv2 specific sg queries:  0
Received IPv6 PIM hello:  0
Received error MLD messages:  0
Table 12 Command output
general queries
Number of MLD general queries.
specific queries
Number of MLD multicast-address-specific queries.
reports
Number of MLD reports.
dones
Number of MLD done messages.
Number of MLD reports with correct and incorrect records.
specific sg queries
Number of MLD multicast-address-and-source-specific queries.
IPv6 PIM hello
Number of IPv6 PIM hello messages.
error MLD messages
Number of MLD messages with errors.
Use dot1p-priority to set the 802.1p priority for MLD messages globally.
Use undo dot1p-priority to restore the default.
dot1p-priority priority
undo dot1p-priority
The global 802.1p priority for MLD messages is 6.
MLD-snooping view
priority: Specifies an 802.1p priority for MLD messages, in the range of 0 to 7. The greater the value, the higher the priority.
You can set the 802.1p priority globally for all VLANs in MLD-snooping view or for a VLAN in VLAN view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# Set the 802.1p priority for MLD messages to 3 globally.
[Sysname] mld-snooping
[Sysname-mld-snooping] dot1p-priority 3
Use drop-unknown to enable dropping unknown IPv6 multicast data packets globally.
Use undo drop-unknown to disable dropping unknown IPv6 multicast data packets globally.
drop-unknown
undo drop-unknown
Dropping unknown IPv6 multicast data packets is disabled, and unknown IPv6 multicast data packets are flooded.
MLD-snooping view
You can enable this feature globally for all VLANs (not for any VSIs)in MLD-snooping view, for a VSI in VSI view, or for a VLAN in VLAN view.
The mld-snooping drop-unknown command and the drop-unknown command in MLD-snooping view are mutually exclusive. You cannot configure them on the same device.
# Enable dropping unknown IPv6 multicast data packets globally.
[Sysname-mld-snooping] drop-unknown
dscp
Use dscp to set the DSCP value for outgoing MLD protocol packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value is 48 for outgoing MLD protocol packets.
MLD-snooping view
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value is carried in the Traffic Class field of an IPv6 packet to determine the transmission priority of the packet. A greater DSCP value represents a higher priority.
# Set the DSCP value to 63 for outgoing MLD protocol packets.
[Sysname-mld-snooping] dscp 63
Use enable to enable MLD snooping for VLANs.
Use undo enable to disable MLD snooping for VLANs.
enable vlan vlan-list
undo enable vlan vlan-list
The MLD snooping status in a VLAN is consistent with the global MLD snooping status.
MLD-snooping view
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094.
You must enable the MLD snooping feature by using the mld-snooping command before you enable MLD snooping for VLANs.
You can enable MLD snooping for multiple VLANs by using this command in MLD-snooping view or for a VLAN by using the mld-snooping enable command in VLAN view. The configuration in VLAN view has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
# Enable the MLD snooping feature, and then enable MLD snooping for VLAN 2 through VLAN 10.
[Sysname-mld-snooping] enable vlan 2 to 10
mld-snooping
mld-snooping enable
Use entry-limit to globally set the maximum number of MLD snooping forwarding entries, including dynamic entries and static entries.
Use undo entry-limit to restore the default.
entry-limit limit
undo entry-limit
The maximum number of MLD snooping forwarding entries is 4294967295.
MLD-snooping view
limit: Specifies the maximum number of MLD snooping forwarding entries, in the range of 0 to 4294967295.
# Set the global maximum number of MLD snooping forwarding entries to 512.
[Sysname-mld-snooping] entry-limit 512
Use fast-leave to enable fast-leave processing globally.
Use undo fast-leave to disable fast-leave processing globally.
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled.
MLD-snooping view
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you do not specify a VLAN, this command takes effect for all VLANs and VSIs.
The fast-leave processing feature enables the device to immediately remove a port from the forwarding entry for an IPv6 multicast group when the port receives a done message.
You can enable fast-leave processing globally for all ports in MLD-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Globally enable MLD snooping fast-leave processing for VLAN 2.
[Sysname-mld-snooping] fast-leave vlan 2
Use global-enable to enable MLD snooping globally.
Use undo global-enable to disable MLD snooping globally.
global-enable
undo global-enable
MLD snooping is disabled globally.
MLD-snooping view
To configure other MLD snooping features for VLANs or VSIs, you must enable MLD snooping for the specific VLANs or VSIs even though MLD snooping is enabled globally.
# Enable MLD snooping globally.
[Sysname-mld-snooping] global-enable
mld-snooping
mld-snooping disable
mld-snooping enable
Use group-policy to globally configure an IPv6 multicast group policy to control the IPv6 multicast groups that hosts can join.
Use undo group-policy to globally delete IPv6 multicast group policies.
undo group-policy [ vlan vlan-list ]
No IPv6 multicast group policies exist. Hosts can join any IPv6 multicast groups.
MLD-snooping view
ipv6-acl-number: Specifies an IPv6 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts can join only IPv6 multicast groups that the ACL permits. If the ACL does not exist or does not have valid rules, hosts cannot join IPv6 multicast groups.
An IPv6 multicast group policy filters MLD reports to control the IPv6 multicast groups that hosts can join.
This command does not take effect on static member ports, because static member ports do not send MLD reports.
You can configure an IPv6 multicast group policy globally for all ports in MLD-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
When you configure a rule in the IPv6 ACL, follow these restrictions and guidelines:
·           For the rule to take effect, do not specify the vpn-instance vpn-instance option.
·           In a basic ACL, the source source-address source-prefix option specifies an IPv6 multicast group address.
·           In an advanced ACL, the source source-address source-prefix option specifies an IPv6 multicast source address. The destination dest-address dest-prefix option specifies an IPv6 multicast group address.
To match MLDv1 reports and MLDv2 IS_EX and MLDv2 TO_EX reports that do not carry IPv6 multicast source addresses, set the source source-address source-prefix option to 0::0.
·           Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
You can configure different ACLs for all ports in different VLANs. If you configure multiple ACLs for all ports in the same VLAN, the most recent configuration takes effect.
# Configure an IPv6 multicast group policy for VLAN 2 so that hosts in VLAN 2 can join only IPv6 multicast group FF03::101.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source ff03::101 128
[Sysname-mld-snooping] group-policy 2000 vlan 2
Use host-aging-time to set the aging timer for dynamic member ports globally.
Use undo host-aging-time to restore the default.
host-aging-time seconds
The aging timer for dynamic member ports is 260 seconds.
MLD-snooping view
seconds: Specifies an aging timer for dynamic member ports, in the range of 1 to 8097894 seconds.
You can set the timer globally for all VLANs and VSIs in MLD-snooping view, for a VSI in VSI view, or for a VLAN in VLAN view. For a VSI, the VSI-specific configuration takes priority over the global configuration. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
To avoid mistakenly deleting IPv6 multicast group members, set the aging timer for dynamic member ports to be greater than the value calculated by using the following formula:
[ MLD general query interval ] + [ maximum response time for MLD general queries ]
As a best practice, set the aging timer of dynamic member ports to the value calculated by using the following formula:
[ MLD general query interval ] × 2 + [ maximum response time for MLD general queries ]
# Set the global aging timer for dynamic member ports to 300 seconds.
[Sysname-mld-snooping] host-aging-time 300
Use host-tracking to enable host tracking globally.
Use undo host-tracking to disable host tracking globally.
host-tracking
undo host-tracking
Host tracking is disabled.
MLD-snooping view
You can enable host tracking globally for all VLANs in MLD-snooping view or for a VLAN in VLAN view. For a VLAN, the global configuration has the same priority as the VLAN-specific configuration.
# Enable host tracking globally.
[Sysname-mld-snooping] host-tracking
Use last-listener-query-interval to set the MLD last listener query interval globally.
Use undo last-listener-query-interval to restore the default.
The MLD last listener query interval is 1 second.
MLD-snooping view
interval: Specifies an MLD last listener query interval in the range of 1 to 25 seconds.
You can set the interval for a VLAN in VLAN view, for a VSI in VSI view, or globally for all VLANs and VSIs in MLD-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration. For a VSI, the VSI-specific configuration takes priority over the global configuration.
# Set the global MLD last listener query interval to 3 seconds.
[Sysname-mld-snooping] last-listener-query-interval 3
Use max-response-time to set the maximum response time for MLD general queries globally.
Use undo max-response-time to restore the default.
max-response-time seconds
The maximum response time for MLD general queries is 10 seconds.
MLD-snooping view
seconds: Specifies the maximum response time for MLD general queries, in the range of 1 to 3174 seconds.
You can set the time globally for all VLANs and VSIs in MLD-snooping view, for a VSI in VSI view, or for a VLAN in VLAN view. For a VSI, the VSI-specific configuration takes priority over the global configuration. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
To avoid mistakenly deleting IPv6 multicast group members, set the maximum response time for MLD general queries to be less than the MLD general query interval.
# Set the global maximum response time for MLD general queries to 5 seconds.
[Sysname-mld-snooping] max-response-time 5
mld-snooping
Use mld-snooping to enable the MLD snooping feature and enter MLD-snooping view.
Use undo mld-snooping to disable the MLD snooping feature.
mld-snooping
undo mld-snooping
The MLD snooping feature is disabled.
If you disable the MLD snooping feature, MLD snooping is disabled in all VLANs and VSIs.
# Enable the MLD snooping feature and enter MLD-snooping view.
mld-snooping enable
Use mld-snooping done source-ip to configure the source IPv6 address for MLD done messages.
Use undo mld-snooping done source-ip to restore the default.
In a VLAN, the source IPv6 address of MLD done messages is the IPv6 link-local address of the current VLAN interface. If the current VLAN interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001.
In a VSI, the source IPv6 address of MLD done messages is the IPv6 link-local address of the gateway interface for the VSI. If the gateway interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001.
VLAN view
VSI view
ipv6-address: Specifies the source IPv6 address for MLD done messages.
You must enable MLD snooping for a VLAN before you execute this command.
# In VLAN 2, enable MLD snooping, and specify FE80:0:0:1::1 as the source IPv6 address of MLD done messages.
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] mld-snooping done source-ip fe80:0:0:1::1
# In VSI aaa, enable MLD snooping, and specify FE80:0:0:1::1 as the source IPv6 address of MLD done messages.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping enable
[Sysname-vsi-aaa] mld-snooping done source-ip fe80:0:0:1::1
mld-snooping enable
Use mld-snooping dot1p-priority to set the 802.1p priority for MLD messages in a VLAN.
Use undo mld-snooping dot1p-priority to restore the default.
The 802.1p priority is 6 for MLD messages in a VLAN.
VLAN view
You can set the 802.1p priority for a VLAN in VLAN view or globally for all VLANs in MLD-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable MLD snooping, and set the 802.1p priority for MLD messages to 3.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping dot1p-priority 3
mld-snooping enable
Use mld-snooping drop-unknown to enable dropping unknown IPv6 multicast data packets for a VLAN or VSI.
Use undo mld-snooping drop-unknown to disable dropping unknown IPv6 multicast data packets for a VLAN or VSI.
Dropping unknown IPv6 multicast data packets is disabled. Unknown IPv6 multicast data packets are flooded.
VLAN view
VSI view
You must enable MLD snooping for a VLAN or VSI before you execute this command.
You can enable this feature for a VLAN in VLAN view, for a VSI in VSI view, or globally for all VLANs (not for any VSIs) in MLD-snooping view.
# In VLAN 2, enable MLD snooping, and enable dropping unknown IPv6 multicast data packets.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping drop-unknown
# In VSI aaa, enable MLD snooping, and enable dropping unknown IPv6 multicast data packets.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping drop-unknown
mld-snooping enable
Use mld-snooping enable to enable MLD snooping for a VLAN or VSI.
Use mld-snooping disable to disable MLD snooping for a VLAN or VSI.
Use undo mld-snooping to restore the MLD snooping status in a VLAN or VSI to the global MLD snooping status.
undo mld-snooping
The MLD snooping status in a VLAN or VSI is consistent with the global MLD snooping status.
VLAN view
VSI view
You must enable the MLD snooping feature by using the mld-snooping command before you enable MLD snooping for a VLAN or VSI.
You can enable MLD snooping for a VLAN by using this command in VLAN view or for multiple VLANs by using the enable command. The configuration in VLAN view has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
# Enable the MLD snooping feature, and then enable MLD snooping for VLAN 2.
[Sysname] vlan 2
# Disable MLD snooping for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping disable
# Enable the MLD snooping feature, and then enable MLD snooping for VSI aaa.
[Sysname] vsi aaa
# Disable MLD snooping for VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping disable
mld-snooping
Use mld-snooping fast-leave to enable fast-leave processing on a port.
Use undo mld-snooping fast-leave to disable fast-leave processing on a port.
undo mld-snooping fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled on a port.
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you do not specify a VLAN, this command takes effect on all VLANs.
You can enable fast-leave processing for a port in interface view or globally for all ports in MLD-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# Enable fast-leave processing for VLAN 2 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mld-snooping fast-leave vlan 2
Use mld-snooping general-query source-ip to configure the source IPv6 address for MLD general queries.
Use undo mld-snooping general-query source-ip to restore the default.
In a VLAN, the source IPv6 address for MLD general queries is the IPv6 link-local address of the current VLAN interface. If the current VLAN interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001.
In a VSI, the source IPv6 address for MLD general queries is the IPv6 link-local address of the gateway interface for the VSI. If the gateway interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001.
VLAN view
VSI view
ipv6-address: Specifies the source IPv6 address for MLD general queries.
# In VLAN 2, enable MLD snooping, and specify FE80:0:0:1::1 as the source IPv6 address for MLD general queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping general-query source-ip fe80:0:0:1::1
# In VSI aaa, enable MLD snooping, and specify FE80:0:0:1::1 as the source IPv6 address for MLD general queries.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping general-query source-ip fe80:0:0:1::1
mld-snooping enable
Use mld-snooping group-limit to set the maximum number of IPv6 multicast groups that a port can join.
Use undo mld-snooping group-limit to remove the limit on the maximum number of IPv6 multicast groups that a port can join.
undo mld-snooping group-limit [ vlan vlan-list ]
No limit is placed on the maximum number of IPv6 multicast groups that a port can join.
limit: Specifies the maximum number of multicast groups that a port can join, in the range of 0 to 4294967295.
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you do not specify a VLAN, this command takes effect for all VLANs.
This command takes effect only on the IPv6 multicast groups that a port joins dynamically.
# On Ten-GigabitEthernet 1/0/1, set the maximum number to 10 for IPv6 multicast groups that the port can join in VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] mld-snooping group-limit 10 vlan 2
Use mld-snooping group-policy to configure an IPv6 multicast group policy on a port to control the IPv6 multicast groups that hosts attached to the port can join.
Use undo mld-snooping group-policy to delete IPv6 multicast group policies on a port.
undo mld-snooping group-policy [ vlan vlan-list ]
No IPv6 multicast group policies exist. Hosts attached to the port can join any IPv6 multicast groups.
ipv6-acl-number: Specifies an IPv6 basic or advanced ACL number in the range of 2000 to 3999. Hosts can join only the IPv6 multicast groups that the ACL permits. If the ACL does not exist or does not have valid rules, hosts cannot join IPv6 multicast groups.
You can configure an IPv6 multicast group policy for a port in interface view or globally for all ports in MLD-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
To match MLDv1 reports and MLD IS_EX and MLDv2 TO_EX reports that do not carry IPv6 multicast source addresses, set the source source-address source-prefix option to 0::0.
You can configure different ACLs for different VLANs on a port. If you configure multiple ACLs for the same VLANs on a port, the most recent configuration takes effect.
# On Ten-GigabitEthernet 1/0/1, configure an IPv6 multicast group policy for VLAN 2 so that hosts attached to the port in VLAN 2 can join only the group FF03::101.
[Sysname-Ten-GigabitEthernet1/0/1] mld-snooping group-policy 2000 vlan 2
Use mld-snooping host-aging-time to set the aging timer for dynamic member ports in a VLAN or VSI.
Use undo mld-snooping host-aging-time to restore the default.
VLAN view
VSI view
You can set the timer for a VLAN in VLAN view, for a VSI in VSI view, or globally for all VLANs and VSIs in MLD-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration. For a VSI, the VSI-specific configuration takes priority over the global configuration.
# In VLAN 2, enable MLD snooping, and set the aging timer for dynamic member ports in the VLAN to 300 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-aging-time 300
# In VSI aaa, enable MLD snooping, and set the aging timer for dynamic member ports in the VSI to 300 seconds.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping host-aging-time 300
mld-snooping enable
Use mld-snooping host-join to configure a port as a simulated member host for an IPv6 multicast group or an IPv6 multicast source and group.
Use undo mld-snooping host-join to remove the configuration of a simulated member host for an IPv6 multicast group.
undo mld-snooping host-join { ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id | all }
A port is not a simulated member host of any IPv6 multicast groups or any IPv6 multicast sources and groups.
source-ip ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you specify an IPv6 multicast source, this command configures the port as a simulated member host for an IPv6 multicast source and group. If you do not specify an IPv6 multicast source, this command configures the port as a simulated member host for an IPv6 multicast group. This option takes effect on MLDv2 snooping devices.
all: Specifies all IPv6 multicast groups and all IPv6 multicast sources and groups.
The version of MLD running on a simulated member host is the same as the version of MLD snooping running on the port. The port ages out in the same way as a dynamic member port.
# Configure Ten-GigabitEthernet 1/0/1 as a simulated member host for the IPv6 multicast group (*, FF3E::101) in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Ten-GigabitEthernet1/0/1] mld-snooping host-join ff3e::101 vlan 2
Use mld-snooping host-tracking to enable host tracking for a VLAN.
Use undo mld-snooping host-tracking to disable host tracking for a VLAN.
VLAN view
You must enable MLD snooping for a VLAN before you execute this command for the VLAN.
You can enable host tracking for a VLAN in VLAN view or globally for all VLANs in MLD-snooping view. For a VLAN, the VLAN-specific configuration has the same priority as the global configuration.
# In VLAN 2, enable MLD snooping, and then enable host tracking.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-tracking
mld-snooping enable
Use mld-snooping last-listener-query-interval to set the MLD last listener query interval for a VLAN or VSI.
Use undo mld-snooping last-listener-query-interval to restore the default.
VLAN view
VSI view
# In VLAN 2, enable MLD snooping, and set the MLD last listener query interval to 3 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping last-listener-query-interval 3
# In VSI aaa, enable MLD snooping, and set the MLD last listener query interval to 3 seconds.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping last-listener-query-interval 3
enable (MLD-snooping view)
last-listener-query-interval (MLD-snooping view)
mld-snooping enable
mld-snooping max-response-time
Use mld-snooping max-response-time to set the maximum response time for MLD general queries in a VLAN or VSI.
Use undo mld-snooping max-response-time to restore the default.
VLAN view
VSI view
You can set the time for a VLAN in VLAN view, for a VSI in VSI view, or globally for all VLANs and VSIs in MLD-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration. For a VSI, the VSI-specific configuration takes priority over the global configuration.
# In VLAN 2, enable MLD snooping, and set the maximum response time for MLD general queries to 5 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping max-response-time 5
# In VSI aaa, enable MLD snooping, and set the maximum response time for MLD general queries to 5 seconds.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping max-response-time 5
max-response-time (MLD-snooping view)
mld-snooping enable
mld-snooping query-interval
mld-snooping overflow-replace
Use mld-snooping overflow-replace to enable the IPv6 multicast group replacement feature on a port.
Use undo mld-snooping overflow-replace to disable the multicast group replacement feature on a port.
undo mld-snooping overflow-replace [ vlan vlan-list ]
The IPv6 multicast group replacement feature is disabled.
You can enable the IPv6 multicast group replacement feature for a port in interface view or globally for all ports in MLD-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# On Ten-GigabitEthernet 1/0/1, enable the IPv6 multicast group replacement feature for VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] mld-snooping overflow-replace vlan 2
overflow-replace (MLD-snooping view)
mld-snooping proxy enable
Use mld-snooping proxy enable to enable MLD snooping proxying for a VLAN or VSI.
Use undo mld-snooping proxy enable to disable MLD snooping proxying for a VLAN or VSI.
VLAN view
VSI view
This command does not take effect on a VLAN that is a sub-VLAN of an IPv6 multicast VLAN.
# In VLAN 2, enable MLD snooping, and enable MLD snooping proxying.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping proxy enable
# In VSI aaa, enable MLD snooping, and enable MLD snooping proxying.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping proxy enable
mld-snooping enable
subvlan (IPv6 multicast-VLAN view)
mld-snooping querier
Use mld-snooping querier to enable the MLD snooping querier.
Use undo mld-snooping querier to disable the MLD snooping querier.
The MLD snooping querier is disabled.
VLAN view
VSI view
For a sub-VLAN of an IPv6 multicast VLAN, this command takes effect only after you remove the VLAN from the IPv6 multicast VLAN.
# In VLAN 2, enable MLD snooping, and enable the MLD snooping querier.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier
# In VSI aaa, enable MLD snooping, and enable the MLD snooping querier.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping querier
mld-snooping enable
mld-snooping querier-election
Use mld-snooping querier-election to enable MLD snooping querier election for a VLAN or VSI.
Use undo mld-snooping querier-election to disable MLD snooping querier election for a VLAN or VSI.
VLAN view
VSI view
For MLD snooping querier election to take effect, you must enable the MLD snooping querier.
# In VLAN 2, enable MLD snooping, and enable MLD snooping querier election.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier-election
# In VSI aaa, enable MLD snooping, and enable MLD snooping querier election.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping querier-election
Use mld-snooping query-interval to set the MLD general query interval for a VLAN or VSI.
Use undo mld-snooping query-interval to restore the default.
The MLD general query interval is 125 seconds.
VLAN view
VSI view
interval: Specifies an MLD general query interval, in the range of 2 to 31744 seconds.
You must enable MLD snooping for a VLAN or VSI before you execute this command for the VLAN.
To avoid mistakenly deleting IPv6 multicast group members, set the MLD general query interval to be greater than the maximum response time for MLD general queries.
# In VLAN 2, enable MLD snooping, and set the MLD general query interval to 20 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping query-interval 20
# In VSI aaa, enable MLD snooping, and set the MLD general query interval to 20 seconds.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping query-interval 20
max-response-time
mld-snooping enable
mld-snooping report source-ip
Use mld-snooping report source-ip to configure the source IPv6 address for MLD reports.
Use undo mld-snooping report source-ip to restore the default.
In a VLAN, the source IPv6 address for MLD reports is the IPv6 link-local address of the current VLAN interface. If the current VLAN interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001.
In a VSI, the source IPv6 address for MLD reports is the IPv6 link-local address of the gateway interface for the VSI. If the gateway interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001.
VLAN view
VSI view
ipv6-address: Specifies the source IPv6 address for MLD reports.
# In VLAN 2, enable MLD snooping, and specify FE80:0:0:1::1 as the source IPv6 address for MLD reports.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping report source-ip fe80:0:0:1::1
# In VSI aaa, enable MLD snooping, and specify FE80:0:0:1::1 as the source IPv6 address for MLD reports.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping report source-ip fe80:0:0:1::1
mld-snooping enable
mld-snooping router-aging-time
Use mld-snooping router-aging-time to set the aging timer for dynamic router ports in a VLAN or VSI.
Use undo mld-snooping router-aging-time to restore the default.
The aging timer for dynamic router ports is 260 seconds.
VLAN view
VSI view
seconds: Specifies an aging timer for dynamic router ports, in the range of 1 to 8097894 seconds.
# In VLAN 2, enable MLD snooping, and set the aging timer for dynamic router ports in the VLAN to 100 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping router-aging-time 100
# In VSI aaa, enable MLD snooping, and set the aging timer for dynamic router ports in the VSI to 100 seconds.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping router-aging-time 100
mld-snooping enable
router-aging-time (MLD-snooping view)
mld-snooping router-port-deny
Use mld-snooping router-port-deny to disable a port from becoming a dynamic router port.
Use undo mld-snooping router-port-deny to allow a port to become a dynamic router port.
undo mld-snooping router-port-deny [ vlan vlan-list ]
A port is allowed to become a dynamic router port.
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you specify VLANs, this command takes effect only when the port belongs to the specified VLANs. If you do not specify a VLAN, this command takes effect on all VLANs.
# Disable Ten-GigabitEthernet 1/0/1 from becoming a dynamic router port in VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] mld-snooping router-port-deny vlan 2
mld-snooping source-deny
Use mld-snooping source-deny to enable IPv6 multicast source port filtering on a port to discard all IPv6 multicast data packets.
Use undo mld-snooping source-deny to disable IPv6 multicast source port filtering on a port.
IPv6 multicast source port filtering is disabled.
You can enable this feature for a port in interface view or for the specified ports in MLD-snooping view. For a port, the configuration in interface view has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
# Enable source port filtering for IPv6 multicast data on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mld-snooping source-deny
source-deny (MLD-snooping view)
mld-snooping special-query source-ip
Use mld-snooping special-query source-ip to configure the source IPv6 address for MLD multicast-address-specific queries.
Use undo mld-snooping special-query source-ip to restore the default.
In a VLAN, the source IPv6 address of MLD multicast-address-specific queries is one of the following:
·           The source address of MLD general queries if the MLD snooping querier of the VLAN has received MLD general queries.
·           The IPv6 link-local address of the current VLAN interface if the MLD snooping querier does not receive an MLD general query.
·           FE80::02FF:FFFF:FE00:0001 if the MLD snooping querier does not receive an MLD general query and the current VLAN interface does not have an IPv6 link-local address.
In a VSI, the source IPv6 address of MLD multicast-address-specific queries is one of the following:
·           The source address of MLD general queries if the MLD snooping querier of the VSI has received MLD general queries.
·           The IPv6 link-local address of the gateway interface for the VSI if the MLD snooping querier does not receive an MLD general query.
·           FE80::02FF:FFFF:FE00:0001 if the gateway interface does not have an IPv6 link-local address.
VLAN view
VSI view
ipv6-address: Specifies the source IPv6 address for MLD multicast-address-specific queries.
# In VLAN 2, enable MLD snooping, and specify FE80:0:0:1::1 as the source IPv6 address of MLD multicast-address-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping special-query source-ip fe80:0:0:1::1
# In VSI aaa, enable MLD snooping, and specify FE80:0:0:1::1 as the source IPv6 address of MLD multicast-address-specific queries.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping special-query source-ip fe80:0:0:1::1
mld-snooping enable
Use mld-snooping static-group to configure a port as a static member port of an IPv6 multicast group or an IPv6 multicast source and group.
Use undo mld-snooping static-group to delete the configuration of static member ports.
undo mld-snooping static-group { ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id | all }
A port is not a static member port of IPv6 multicast groups.
source-ip ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you specify an IPv6 multicast source, this command configures the port as a static member port of an IPv6 multicast source and group. If you do not specify an IPv6 multicast source, this command configures the port as a static member port of an IPv6 multicast group. This option takes effect on MLDv2 snooping devices.
# Configure Ten-GigabitEthernet 1/0/1 as a static member port for the IPv6 multicast group (*, FF3E::101) in VLAN 2.
[Sysname] vlan 2
[Sysname-Ten-GigabitEthernet1/0/1] mld-snooping static-group ff3e::101 vlan 2
Use mld-snooping static-router-port to configure a port as a static router port.
Use undo mld-snooping static-router-port to remove the configuration of static router ports.
undo mld-snooping static-router-port { all | vlan vlan-id }
A port is not a static router port.
all: Specifies all VLANs.
# Configure Ten-GigabitEthernet 1/0/1 as a static router port in VLAN 2.
[Sysname-Ten-GigabitEthernet1/0/1] mld-snooping static-router-port vlan 2
mld-snooping version
Use mld-snooping version to specify an MLD snooping version for a VLAN or VSI.
Use undo mld-snooping version to restore the default.
The MLD snooping version in a VLAN or VSI is 1.
VLAN view
VSI view
version-number: Specifies an MLD snooping version, 1 or 2.
You must enable MLD snooping for a VLAN or VSI before you configure this command.
You can specify the version for a VLAN in VLAN view or for the specified VLANs in MLD-snooping view. The VLAN-specific configuration has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
# In VLAN 2, enable MLD snooping, and specify MLD snooping version 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping version 2
# In VSI aaa, enable MLD snooping, and specify MLD snooping version 2.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping version 2
mld-snooping enable
version (MLD-snooping view)
Use overflow-replace to enable the IPv6 multicast group replacement feature globally.
Use undo overflow-replace to disable the IPv6 multicast group replacement feature globally.
undo overflow-replace [ vlan vlan-list ]
MLD-snooping view
You can enable IPv6 multicast group replacement globally for all ports in MLD-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Globally enable the IPv6 multicast group replacement feature for VLAN 2.
[Sysname-mld-snooping] overflow-replace vlan 2
report-aggregation (MLD-snooping view)
Use report-aggregation to enable MLD report suppression.
Use undo report-aggregation to disable MLD report suppression.
report-aggregation
MLD report suppression is enabled.
MLD-snooping view
# Disable MLD report suppression.
[Sysname-mld-snooping] undo report-aggregation
reset ipv6 l2-multicast fast-forwarding cache
Use reset ipv6 l2-multicast fast-forwarding cache to clear Layer 2 IPv6 multicast fast forwarding entries.
In standalone mode:
reset ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] { { ipv6-source-address | ipv6-group-address } * | all } [ slot slot-number ]
In IRF mode:
reset ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] { { ipv6-source-address | ipv6-group-address } * | all } [ chassis chassis-number slot slot-number ]
ipv6-source-address: Specifies an IPv6 multicast source address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears Layer 2 IPv6 multicast fast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears Layer 2 IPv6 multicast fast forwarding entries for the global active MPU. (In IRF mode.)
all: Specifies all Layer 2 IPv6 multicast fast forwarding entries.
# Clear all Layer 2 IPv6 multicast fast forwarding entries.
<Sysname> reset ipv6 l2-multicast fast-forwarding cache all
# Clear the Layer 2 IPv6 multicast fast forwarding entry for the IPv6 group (*, FF1E::2).
<Sysname> reset ipv6 l2-multicast fast-forwarding cache FF1E::2
display ipv6 l2-multicast fast-forwarding cache
reset mld-snooping group
Use reset mld-snooping group to clear information about dynamic MLD snooping group entries.
reset mld-snooping group { ipv6-group-address [ ipv6-source-address ] | all } [ vlan vlan-id | vsi vsi-name ]
ipv6-source-address: Specifies an IPv6 multicast source address. If you do not specify an IPv6 multicast source, this command clears information about dynamic MLD snooping group entries for all IPv6 multicast sources.
all: Specifies all IPv6 multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command clears information about dynamic MLD snooping group entries for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears information about dynamic MLD snooping group entries for all VSIs.
# Clear information about all dynamic MLD snooping group entries.
<Sysname> reset mld-snooping group all
reset mld-snooping router-port
Use reset mld-snooping router-port to clear dynamic router port information.
reset mld-snooping router-port { all | vlan vlan-id | vsi vsi-name }
all: Specifies all dynamic router ports.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command clears dynamic router port information for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears dynamic router port information for all VSIs.
# Clear information about all dynamic router ports.
<Sysname> reset mld-snooping router-port all
reset mld-snooping statistics
Use reset mld-snooping statistics to clear statistics for MLD messages and IPv6 PIM hello messages learned through MLD snooping.
# Clear statistics for all MLD messages and IPv6 PIM hello messages learned through MLD snooping.
<Sysname> reset mld-snooping statistics
Use router-aging-time to set the aging timer for dynamic router ports globally.
Use undo router-aging-time to restore the default.
MLD-snooping view
# Set the global aging timer for dynamic router ports to 100 seconds.
[Sysname-mld-snooping] router-aging-time 100
send-query enable
Use send-query enable to enable the device to send MLD general queries upon a path change.
Use undo send-query enable to restore the default.
send-query enable
The device does not send MLD general queries upon a path change.
MLD-snooping view
Use this command to enable the device to immediately send an MLD general query to all ports in the affected VLAN or VSI when the path changes. This feature ensures that the device can update the member port information in IPv6 multicast forwarding entries and switch IPv6 multicast traffic to the new path promptly.
# Enable the device to send MLD general queries upon a path change.
[Sysname-mld-snooping] send-query enable
mld-snooping
Use source-deny to enable IPv6 multicast source port filtering on ports to discard all IPv6 multicast data packets.
Use undo source-deny to disable IPv6 multicast source port filtering on ports.
undo source-deny port interface-list
MLD-snooping view
port interface-list: Specifies a space-separated list of port items. Each item specifies a port by its port type and number or a range of ports in the form of start-interface-type interface-number to end-interface-type interface-number.
You can enable this feature for the specified ports in MLD-snooping view or for a port in interface view. For a port, the configuration in MLD-snooping view has the same priority as the configuration in interface view, and the most recent configuration takes effect.
# Enable source port filtering for IPv6 multicast data on ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4.
[Sysname-mld-snooping] source-deny port ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
Use version to specify an MLD snooping version for VLANs.
Use undo version to restore the default.
undo version vlan vlan-list
The MLD snooping version in a VLAN is 1.
MLD-snooping view
You must enable MLD snooping for the specified VLANs before you execute this command.
You can specify the version for the specified VLANs in MLD-snooping view or for a VLAN in VLAN view. The VLAN-specific configuration has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
# Enable MLD snooping for VLAN 2 through VLAN 10, and specify MLD snooping version 2 for these VLANs.
[Sysname-mld-snooping] version 2 vlan 2 to 10
mld-snooping enable
