05-Layer 3 - IP Services Configuration Guide
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release758X-6W10005-Layer 3 - IP Services Configuration Guide
11-UDP Helper configuration
11-UDP Helper configuration 81.19 KB
Configuring UDP helper
Overview
UDP helper can provide the following packet conversion for packets with specific UDP destination port numbers:
·     Convert broadcast to unicast, and forward the unicast packets to specific destinations.
·     Convert broadcast to multicast, and forward the multicast packets.
When you configure UDP helper, follow these restrictions and guidelines:
·     Do not set UDP ports 67 and 68 for UDP helper, because UDP helper cannot forward DHCP broadcast packets.
·     You can specify a maximum of 256 UDP ports for UDP helper.
·     You can specify a maximum of 20 unicast and multicast addresses for UDP helper to convert broadcast packets on an interface.
Configuring UDP helper to convert broadcast to unicast
You can configure UDP helper to convert broadcast packets with specific UDP port numbers to unicast packets.
Upon receiving a UDP broadcast packet, UDP helper uses the configured UDP ports to match the UDP destination port number of the packet.
·     If a match is found, UDP helper duplicates the packet and modifies the destination IP address of the copy to the configured unicast address. Then UDP helper forwards the unicast packet to the unicast address.
·     If no match is found, UDP helper does not process the packet.
To configure UDP helper to convert broadcast to unicast:
Step
Remarks
N/A
2.     Enable UDP helper.
udp-helper enable
By default, UDP helper is disabled.
3.     Specify a UDP port number.
By default, no UDP port numbers are specified.
4.     Enter interface view.
N/A
5.     Specify a destination server for UDP helper to convert broadcast to unicast.
udp-helper server ip-address [ global | vpn-instance vpn-instance-name ]
By default, no destination server is specified.
If you specify multiple destination servers, UDP helper creates one copy for each server.
Use this command on the interface that receives broadcast packets.
Configuring UDP helper to convert broadcast to multicast
You can configure UDP helper to convert broadcast packets with specific UDP port numbers to multicast packets.
·     If a match is found, UDP helper duplicates the packet and modifies the destination IP address of the copy to the configured multicast address. Then UDP helper forwards the packet to the multicast group.
To configure UDP helper to convert broadcast to multicast:
Step
Remarks
N/A
udp-helper enable
N/A
5.     Specify a destination multicast address for UDP helper to convert broadcast to multicast.
udp-helper broadcast-map multicast-address [ acl acl-number ]
By default, no destination multicast address is specified for UDP helper.
If you specify multiple multicast addresses, UDP helper creates one copy for each address.
Displaying and maintaining UDP helper
Execute display command in any view and reset commands in user view.
Display information about broadcast to unicast conversion by UDP helper on an interface.
display udp-helper interface interface-type interface-number
Clear packet statistics for UDP helper.
reset udp-helper statistics
UDP helper configuration examples
Network requirements
As shown in Figure 1, configure UDP helper to convert broadcast to unicast on VLAN-interface 1 of Switch A. This feature enables Switch A to forward broadcast packets with UDP destination port number 55 to the destination server 10.2.1.1/16.
Figure 1 Network diagram
Configuration procedure
Make sure Switch A can reach the subnet 10.2.0.0/16.
# Enable UDP helper.
[SwitchA] System-view
[SwitchA] udp-helper enable
# Enable the UDP port 55 for UDP helper.
[SwitchA] udp-helper port 55
# Specify the destination server 10.2.1.1 for UDP helper to convert broadcast to unicast on VLAN-interface 1.
[SwitchA-Vlan-interface1] ip address 10.110.1.1 16
[SwitchA-Vlan-interface1] udp-helper server 10.2.1.1
# Display information about broadcast to unicast conversion by UDP helper on VLAN-interface 1.
[SwitchA-Vlan-interface1] display udp-helper interface vlan-interface 1
Interface                Server VPN instance           Server address Packets sent
Vlan-interface1          N/A                           10.2.1.1       5
As shown in Figure 2, VLAN-interface 1 of Switch B can receive multicast packets destined to 225.1.1.1.
Configure UDP helper to convert broadcast to multicast on VLAN-interface 1 of Switch A. This feature enables Switch A to forward broadcast packets with UDP destination port number 55 to the multicast group 225.1.1.1.
Figure 2 Network diagram
1.     Configure Switch A:
# Configure UDP helper to convert broadcast packets to multicast packets destined for 225.1.1.1.
[SwitchA-Vlan-interface1] udp-helper broadcast-map 225.1.1.1
# Enable IP multicast routing globally.
[SwitchA] multicast routing
[SwitchA-mrib] quit
Enable PIM-DM on VLAN-interface 1.
[SwitchA-Vlan-interface1] pim dm
# Enable PIM-DM and IGMP on VLAN-interface 2.
[SwitchA-Vlan-interface2] pim dm
[SwitchA-Vlan-interface2] igmp enable
# Configure VLAN-interface 2 as a static member of multicast group 225.1.1.1.
[SwitchA-Vlan-interface2] igmp static-group 225.1.1.1
2.     Configure Switch B:
[SwitchB] multicast routing
[SwitchB-mrib] quit
# Enable PIM-DM and IGMP on VLAN-interface 1.
[SwitchB] interface vlan-interface 1
[SwitchB-Vlan-interface1] pim dm
[SwitchB-Vlan-interface1] igmp enable
# Configure VLAN-interface 1 as a static member of multicast group 225.1.1.1.
[SwitchB-Vlan-interface1] igmp static-group 225.1.1.1
Verify that you can capture multicast packets from Switch A on Switch B.
