- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Device management configuration
- 10-Tcl configuration
- 11-Python configuration
- 12-License management
- 13-Automatic configuration
| 08-ISSU configuration | 239.78 KB |
Restrictions and guidelines: ISSU
Logging in to the device through the console port
Identifying availability of ISSU·
Verifying the device operating status
Verifying the device configuration
Determining the upgrade procedure
Adjusting and saving the running configuration
Performing an ISSU by using issu commands·
Performing a compatible upgrade on a multichassis IRF fabric
Performing an incompatible upgrade on a multichassis IRF fabric
Performing an incremental upgrade on a single-chassis IRF fabric
Performing a reboot or incompatible upgrade on a single-chassis IRF fabric
Performing an ISSU by using install commands
Installing or upgrading software images
Rolling back the running software images
Aborting a software activate or deactivate operation
Deleting inactive software images
Terminating the ongoing ISSU process forcibly
Display and maintenance commands for ISSU
Examples of using issu commands for ISSU
Example: Upgrading the system software to a compatible version
Example: Upgrading the system software to an incompatible version
Example: Rolling back the system software·
Examples of using install commands for ISSU
Example: Rolling back a feature
Performing an ISSU
About ISSU
The In-Service Software Upgrade (ISSU) feature upgrades the Comware software with a minimum amount of downtime.
Unless otherwise stated, the term "upgrade" refers to both software upgrade and downgrade in ISSU.
ISSU advantages
The Comware software includes the boot image, the system image, and feature images. ISSU supports upgrading the images individually.
When you use ISSU to upgrade a feature, only the related feature images are affected. Other features can continue to provide services.
ISSU supports installing patch images to fix system bugs without a system reboot.
ISSU methods
ISSU methods are determined at software release depending on the compatibility between software versions.
ISSU supports the following upgrade types:
· Compatible upgrade—The new software version is compatible with the running software version. This upgrade type supports the ISSU methods in Table 1.
· Incompatible upgrade—The new software version is incompatible with the running software version. The two versions cannot run concurrently.
This upgrade type supports only one upgrade method (also called incompatible upgrade). This method requires a cold reboot to upgrade both control and data planes. Incompatible upgrade disrupts service if hardware redundancy is not available.
For information about identifying the ISSU method, see "Identifying the ISSU method."
Table 1 ISSU methods for compatible upgrade
ISSU method |
Incremental upgrade: · Service Upgrade · File Upgrade |
Upgrades only user mode processes that have differences between the new and old software versions. Backup processes and a main/backup process switchover are required for service continuity. · Service upgrade—Upgrades service features. The upgrade does not affect the operation of the features that are not being upgraded. · File upgrade—Upgrades hidden system program files. The system can provide services during the upgrade. |
Reboot |
The Reboot method disrupts service if hardware redundancy is not available. As a best practice, schedule the downtime carefully to minimize the upgrade impact on the services. Reboots member devices to complete the software upgrade. While one member device is rebooting, the other member devices can provide services. |
ISSU commands
ISSU includes the install and issu command sets. After you identify the recommended ISSU method, use Table 2 to choose the command set you want to use.
Table 2 Command set comparison
Item |
issu commands |
install commands |
Upgrade types |
· Compatible. · Incompatible. |
Compatible. |
Impact on the system |
Large. |
Small. |
Technical skill requirements |
Low. As a best practice, use this command set. |
High. Administrators must have extensive system knowledge and understand the impact of each upgrade task on the network. |
CAUTION: Do not move the .bin images in the startup software image list from flash memory to other storage devices or delete them. If you move or delete them, the device cannot restart. |
During an ISSU, follow these restrictions and guidelines:
· Do not perform any of the following tasks:
¡ Reboot member devices.
¡ Execute commands that are irrelevant to the ISSU.
¡ Modify, delete, or rename image files.
· You cannot use both install and issu commands for the same ISSU. For more information, see "Display and maintenance commands for ISSU."
· For service continuity, strictly follow the recommended ISSU procedure. Make sure a step is completed before you proceed to the next step.
· Before executing the following commands, use the display system stable state command to verify that the system is stable:
¡ issu commands—issu load, issu run switchover, and issu commit.
¡ install commands—install activate and install deactivate.
If the System State field displays Stable, the system is stable.
· You can use issu commands to upgrade all or some of the software images. If you are upgrading only some of the images, make sure the new images are compatible with the images that are not to be upgraded. The upgrade will fail if a conflict exists.
After an ISSU, perform the following tasks:
· You must log in to the device again before you can use the changed or added commands.
· Use the display boot-loader command to verify that the startup software images have been upgraded.
Preparing for ISSU
To perform a successful ISSU, make sure all the preparation requirements are met.
Log in to the device through the console port. If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
Read the software release notes to identify support of the device for ISSU between the current software version and the new software version.
Verify that the system and all its components are operating correctly.
1. Verify that the system is operating correctly as a whole:
Command |
Verification item |
display device |
Verify that all components are operating correctly. |
display irf |
Verify that all IRF member devices are operating correctly. |
2. Verify that the hardware resources are sufficient without alarms:
Command |
Verification item |
display cpu-usage |
Verify that no CPU usage alarms are present. As a best practice, verify that the CPU usage is lower than the CPU usage recovery threshold on each component. |
display memory display memory-threshold |
Verify that no memory alarms are present. As a best practice, verify that the free memory is greater than the normal state threshold on each component. |
3. Verify that the system operating environment is normal:
Command |
Verification item |
display fan |
Verify that all fans are in Normal state. |
display power |
Verify that all power supplies are in Normal state. |
display environment |
Verify that the temperature of each component is lower than the high-temperature warning threshold. |
4. Verify that all interfaces are operating correctly:
Command |
Verification item |
display counters rate inbound interface |
Verify that all interfaces are forwarding packets correctly. |
display interface | include CRC |
Preparing the upgrade images
1. Use the dir command to verify that every file system has sufficient free storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete /unreserved file-url command. If the files to be deleted will be used, back up the files before deleting them. You will be unable to restore a deleted file if the /unreserved keyword is used. For more information, see "Managing file systems."
2. Use FTP or TFTP to transfer upgrade image files (in .bin or .ipe) to the root directory of a file system on the master device.
1. Execute the display version comp-matrix file command to display the recommended ISSU methods.
¡ If a compatible upgrade is required, check the Upgrade Way field to identify the recommended ISSU method.
¡ If an incompatible upgrade is required, check the end of command output for the Incompatible upgrade string.
For more information about ISSU methods, see Table 1.
For a successful ISSU reboot or incompatible upgrade and the IRF fabric integrity during the ISSU, a set of features must have the same configuration as expected after the upgrade. The following are the features and commands for you to change and verify feature settings:
· System operating mode.
system-working-mode
display system-working-mode
For more information about system operating mode, see device management in Fundamentals Configuration Guide.
· Maximum number of ECMP routes.
max-ecmp-num
display max-ecmp-num
For more information about ECMP routes, see basic IP routing configuration in Layer 3—IP Routing Configuration Guide.
· Packet loss prevention for OpenFlow forwarding.
openflow lossless enable
display current-configuration
For more information about packet loss prevention for OpenFlow forwarding, see OpenFlow Configuration Guide.
Verifying feature status
For service continuity during an ISSU, configure the following feature settings:
Feature |
Setting requirements |
GR and NSR |
Enable GR or NSR for protocols including LDP, RSVP, OSPF, ISIS, BGP, and FSPF. |
BFD |
Disable BFD for protocols including LDP, RSVP, OSPF, ISIS, RIP, BGP, VRRP, and NQA. |
Ethernet link aggregation |
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups. |
IRF |
Before performing an incompatible upgrade for the IRF fabric, verify that IRF MAD is disabled. To use IRF MAD, enable IRF MAD after finishing the upgrade. Configure IRF bridge MAC persistence as follows: · Compatible upgrade—Configure the irf mac-address persistent timer or irf mac-address persistent always command. · Incompatible upgrade—Configure the irf mac-address persistent always command if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command. |
1. Use Table 2 to choose an upgrade command set, depending on the ISSU method.
2. Identify the hardware redundancy condition.
ISSU can maintain service continuity only when the following conditions are met:
¡ The IRF fabric has multiple members and uses the ring topology.
IMPORTANT: If hardware redundancy is not available, service discontinuity is not avoidable during a reboot upgrade or an incompatible upgrade. Make sure you understand the impact of the upgrade on the network. |
3. Choose the correct procedure from the procedures described in "Performing an ISSU by using issu commands" or "Performing an ISSU by using install commands."
1. Remove the configured commands that the new software version does not support.
2. Use the save command to save the running configuration.
Upgrade a subordinate member device first. Then, upgrade the remaining member devices, including the original master.
1. (Optional.) Configure automatic rollback:
a. Enter system view.
b. Set the automatic rollback timer.
issu rollback-timer minutes
By default, the automatic rollback timer is set to 45 minutes.
The automatic rollback timer starts when you execute the issu run switchover command.
c. Return to user view.
2. Verify that the system is stable.
The system is stable if the System State field displays Stable. For a successful ISSU, you must make sure the system is stable before you proceed to the next step.
3. Load the upgrade images as startup images on a subordinate member.
¡ Use .bin files:
issu load file { boot filename | system filename | feature filename&<1-30> | patch filename&<1-16> } * slot slot-number&<1-9> [ reboot ]
¡ Use an .ipe file:
issu load file ipe ipe-filename [ patch filename&<1-16> ] slot slot-number&<1-9> [ reboot ]
4. Verify that the system is stable.
The system is stable if the System State field displays Stable. For a successful ISSU, you must make sure the system is stable before you proceed to the next step. If the system reported an error in the previous step, verify that the system is stable and then use the issu rollback command to roll back the upgrade.
5. Perform an ISSU switchover.
issu run switchover
This command also starts the automatic rollback timer. When the timer expires, the system automatically rolls back to the original software images.
6. (Optional.) Accept the upgrade and delete the automatic rollback timer.
issu accept
Execute this command before the automatic rollback timer expires.
7. Verify that the system is stable.
The system is stable if the System State field displays Stable. For a successful ISSU, you must make sure the system is stable before you proceed to the next step. If the system reported an error in the previous two steps, verify that the system is stable and then use the issu rollback command to roll back the upgrade.
8. Upgrade the remaining members to complete the ISSU.
issu commit slot slot-number
Execute this command before the automatic rollback timer expires. After using this command for one member, wait for the member to restart and join the IRF fabric. Then, repeat the previous step and this step to upgrade the remaining member devices one by one, including the original master.
9. Verify that the ISSU is finished.
display issu state
If the ISSU state field displays Init, the ISSU is finished.
Upgrade one or more subordinate member devices first. Then, upgrade the remaining member devices, including the original master.
To perform an incompatible upgrade on a multichassis IRF fabric, execute the following commands in user view:
1. Verify that the system is stable.
2. Load the upgrade images as startup images on subordinate members.
¡ Use .bin files:
¡ Use an .ipe file:
As a best practice on a ring-topology IRF fabric, specify half of the subordinate members for this command to reduce service interruption. Make sure the specified subordinate members are physically connected.
3. Verify that the system is stable.
4. Perform an ISSU switchover to complete the ISSU process.
issu run switchover
This command upgrades the remaining members.
5. Verify that the ISSU is finished.
display issu state
To perform an incremental upgrade on a single-chassis IRF fabric, execute the following commands in user view:
2. Load the upgrade images as startup images.
¡ Use .bin files:
issu load file { boot filename | system filename | feature filename&<1-30> | patch filename&<1-16> } * slot slot-number [ reboot ]
¡ Use an .ipe file:
issu load file ipe ipe-filename [ patch filename&<1-16> ] slot slot-number [ reboot ]
4. Complete the ISSU process.
display issu state
2. Load the parent device's upgrade images as startup images on subordinate members.
¡ Use .bin files:
¡ Use an .ipe file:
3. Verify that the ISSU is finished.
display issu state
ISSU tasks at a glance
1. (Optional.) Decompressing an .ipe file
2. Installing or upgrading software images
3. (Optional.) Deactivating software images
4. (Optional.) Rolling back the running software images
5. (Optional.) Aborting a software activate or deactivate operation
6. (Optional.) Verifying software images
7. Committing software changes
8. (Optional.) Deleting inactive software images
1. (Optional.) Identify images that are included in the .ipe file.
display install ipe-info
2. Decompress the .ipe file.
install add ipe-filename filesystem
About software image installation and upgrade
Use this task to install new features or upgrade the boot, system, or feature images.
Software image installation/upgrade methods
Use one of the following methods to install or upgrade software images:
· Slot by slot—Activate all the images on one slot, and then move to the next slot.
· Image by image—Activate one image on all slots before activating another image.
To install an image, you must begin with the master device. To upgrade an image, you must begin with a subordinate device.
To use the image by image method to activate software images, first read the release notes to identify the compatibility between the upgrade images and the running images. If the upgrade images are not compatible with the running images, you cannot use the image by image method to activate software images.
An activate operation for an incremental upgrade or patch images updates only the current software image list unless you use the install activate patch filename all command. For the image changes to take effect after a reboot, you must perform a commit operation to update the main startup image list.
Installing or upgrading boot, system, and feature images
To install or upgrade boot, system, and feature images, execute the following commands in user view:
2. (Optional.) Identify the recommended ISSU method and the possible impact of the upgrade.
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number test
3. Activate images.
Installing patch images
To install patch images, execute the following commands in user view:
The system is stable if the System State field displays Stable. For a successful installation, you must make sure the system is stable before you proceed to the next step.
2. Activate patch images.
install activate patch filename { all | slot slot-number }
You can deactivate only feature and patch images.
The deactivate operation only removes images from the current software image list unless you use the install deactivate patch filename all command. For the image changes to take effect after a reboot, you must perform a commit operation to remove the images from the main startup image list.
Deactivated images are still stored on the storage medium. To permanently delete the images, execute the install remove command. For more information, see "Deleting inactive software images."
Deactivating feature images
To deactivate feature images, execute the following commands in user view:
The system is stable if the System State field displays Stable. For a successful deactivate operation, you must make sure the system is stable before you proceed to the next step.
2. Deactivate feature images.
install deactivate feature filename&<1-30> slot slot-number
Deactivating patch images
To deactivate patch images, execute the following commands in user view:
2. Deactivate patch images.
install deactivate patch filename { all | slot slot-number }
About software image rollback
During an incremental upgrade, the system creates a rollback point for each activate or deactivate operation of a boot, system, or feature image. The system can maintain a maximum of 50 rollback points. If this limit has been reached when a rollback point is created, the system removes the earliest rollback point. You can roll back the software to any of the rollback points.
During a reboot upgrade, the system does not create rollback points. After a reboot upgrade, you can roll back the software only to the status before any activate or deactivate operations were performed.
During an incremental upgrade, you can perform this task only before committing software changes. A commit operation deletes all rollback points.
For an incremental upgrade rollback to take effect after a reboot, you must perform a commit operation to update the main startup image list.
To roll back the running software images, execute the following commands in user view:
1. (Optional.) Display available rollback points.
display install rollback
2. Roll back the software.
install rollback to { point-id | original }
About aborting a software activate or deactivate operation
While the system is activating or deactivating a software image for a service upgrade or file upgrade, you can abort the activate or deactivate operation. After an operation is aborted, the system runs with the software images that it was running with before the operation.
To abort a software activate or deactivate operation, use one of the following methods:
· Execute the install abort [ job-id ] command in user view.
· Press Ctrl+C.
About committing software changes
When you activate or deactivate images for an incremental upgrade, or activate or deactivate patch images, the main startup image list does not update with the changes. The software changes are lost at reboot. For the changes to take effect after a reboot, you must commit the changes.
To commit software changes, execute the following command in user view:
install commit
About software image verification
Perform this task to verify the following items:
· Integrity—Verify that the boot, system, and feature images are integral.
· Consistency—Verify that the same active images are running across the entire system.
· Software commit status—Verify that the active images are committed as needed.
To verify software images, execute the following commands in user view:
1. Verify software images.
install verify
2. Activate or deactivate images as required.
install { activate | deactivate }
3. Commit the software changes.
install commit
About deleting inactive software images
After completing an ISSU, you can use this task to delete old image files permanently.
This task delete image files permanently. You cannot use the install rollback to command to revert the operation, or use the install abort command to abort the operation.
To delete inactive software image files, execute the following command in user view:
install remove [ slot slot-number ] { filename | inactive }
About terminating the ongoing ISSU process forcibly
Use this command to terminate the ISSU process if one of the following exceptions occurs and you cannot perform an upgrade or rollback:
· The ISSU status is not Init but the upgrade has stopped.
· The ISSU status is Init but the upgrade has not completed.
1. Enter system view.
2. Terminate the ongoing ISSU process forcibly.
issu quit
Unless otherwise stated, the display and reset commands can be used during an ISSU, regardless of whether the install or issu commands are used.
Task |
Command |
Remarks |
Display active software images. |
display install active [ slot slot-number ] [ verbose ] |
N/A |
Display backup startup software images. |
display install backup [ slot slot-number ] [ verbose ] |
N/A |
Display main startup software images. |
display install committed [ slot slot-number ] [ verbose ] |
N/A |
Display inactive software images in the root directories of file systems. |
display install inactive [ slot slot-number ] [ verbose ] |
N/A |
Display the software images included in an .ipe file. |
display install ipe-info ipe-filename |
N/A |
Display ongoing ISSU activate, deactivate, and rollback operations. |
display install job |
N/A |
Display ISSU log entries. |
display install log [ log-id ] [ verbose ] |
N/A |
Display software image file information. |
display install package { filename | all } [ verbose ] |
N/A |
Display rollback point information. |
display install rollback [ point-id ] |
The system does not record rollback points during an ISSU that uses issu commands. |
Display the software image file that includes a specific component or file. |
display install which { component name | file filename } [ slot slot-number ] |
N/A |
Display automatic rollback timer information. |
N/A |
Display ISSU status information. |
display issu state |
This command applies only to an ISSU that uses issu commands. |
Display the recommended ISSU methods. |
display version comp-matrix file { boot filename | system filename | feature filename&<1-30> | patch filename&<1-16> } * display version comp-matrix file ipe ipe-filename [ patch filename&<1-16> ] |
N/A |
Clear ISSU log entries. |
reset install log-history oldest log-number |
N/A |
Clear ISSU rollback points. |
reset install rollback oldest point-id |
N/A |
As shown in Figure 1, the IRF fabric has two members.
Upgrade the boot, system, and feature images from T0001015 to T0001016. The two versions are compatible.
# Download the upgrade image files from the TFTP server.
<Sysname> tftp 2.2.2.2 get boot-t0001016.bin
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 6078464 100 6078464 0 0 764 0 --:--:-- --:--:-- --:--:-- 810
Writing file...Done.
<Sysname> tftp 2.2.2.2 get system-t0001016.bin
100 97750016 100 97750016 0 0 764 0 --:--:-- --:--:-- --:--:-- 810
<Sysname> tftp 2.2.2.2 get feature-t0001016.bin
100 1008640 100 1008640 0 0 764 0 --:--:-- --:--:-- --:--:-- 810
# Display active software images.
<Sysname> display install active
Active packages on slot 1:
flash:/boot-t0001015.bin
flash:/system-t0001015.bin
flash:/feature-t0001015.bin
Active packages on slot 2:
# Identify the recommended ISSU methods.
<Sysname> display version comp-matrix file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin
Verifying the file flash:/boot-t0001016.bin on slot 1.......................Done.
Verifying the file flash:/system-t0001016.bin on slot 1................. .................Done.
Verifying the file flash:/feature-t0001016.bin on slot 1.................Done.
Identifying the upgrade methods....Done.
Slot Upgrade Way
1 Reboot
2 Reboot
The output shows that reboot upgrades are recommended.
# Save the running configuration.
<Sysname> save
# Upgrade the system software on the subordinate member.
<Sysname> i issu load file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin slot 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Copying file flash:/boot-t0001016.bin to slot2#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to slot2#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to slot2#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on slot 2...Done.
Verifying the file flash:/system-t0001016.bin on slot 2............Done.
Verifying the file flash:/feature-t0001016.bin on slot 2...Done.
Identifying the upgrade methods….Done.
Running Version New Version
Test 0001015 Test 0001016
Slot Upgrade Way
2 Reboot
This operation might take several minutes, please wait...Done.
# Verify that the ISSU is in a stable state.
<Sysname> display issu state
ISSU state: Loaded
Compatibility: Compatible
Work state: Normal
Upgrade method: Card by card
Upgraded slot:
slot 2
Current upgrading slot: None
Previous version list:
boot: 7.1.070, Test 0001015
system: 7.1.070, Test 0001015
feature: 7.1.070, Test 0001015
Previous software images:
Upgrade version list:
boot: 7.1.070, Test 0001016
system: 7.1.070, Test 0001016
feature: 7.1.070, Test 0001016
Upgrade software images:
The Loaded state is a stable state, which indicates that the system is waiting for a master/subordinate switchover. Slot 2 has completed the upgrade, and slot 1 has not.
# Perform a master/subordinate switchover.
<Sysname> issu run switchover
Slot Switchover Way
1 Master subordinate switchover
This operation might take several minutes, please wait.........
ISSU state: Switchover
Work state: Normal
Upgraded slot:
slot 2
The Switchover state is a stable state, which indicates that the system has completed the master/subordinate switchover and is waiting for a commit operation to upgrade slot 1.
# Upgrade the system software on the original master.
<Sysname> issu commit slot 1
Slot Upgrade Way
1 Reboot
Verifying the upgrade
# Verify that the ISSU is finished.
ISSU state: Init
Compatibility: Unknown
Work state: Normal
Upgraded slot: None
Current version list:
Current software images:
The ISSU state field displays Init, which indicates that the ISSU is finished.
# Verify that both members are running the new software images.
As shown in Figure 2, the IRF fabric has two members.
Upgrade the boot, system, and feature images from T0001015 to T0001017, which is an incompatible version.
<Sysname> tftp 2.2.2.2 get boot-t0001017.bin
<Sysname> tftp 2.2.2.2 get system-t0001017.bin
<Sysname> tftp 2.2.2.2 get feature-t0001017.bin
<Sysname> display version comp-matrix file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin
Verifying the file flash:/boot-t0001017.bin on slot 1.......................Done.
Verifying the file flash:/system-t0001017.bin on slot 1................. .................Done.
Verifying the file flash:/feature-t0001017.bin on slot 1.................Done.
Incompatible upgrade.
The output shows that an incompatible upgrade is recommended.
<Sysname> save
<Sysname> issu load file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin slot 2
Copying file flash:/boot-t0001017.bin to slot2#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to slot2#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to slot2#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on slot 2...Done.
Verifying the file flash:/system-t0001017.bin on slot 2............Done.
Verifying the file flash:/feature-t0001017.bin on slot 2...Done.
Test 0001015 Test 0001017
Slot Upgrade Way
2 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
ISSU state: Loaded
Compatibility: Incompatible
Work state: Normal
Upgraded slot:
slot 2
boot: 7.1.070, Test 0001017
system: 7.1.070, Test 0001017
feature: 7.1.070, Test 0001017
Slot Switchover Way
ISSU state: Init
Work state: Normal
Upgraded slot: None
As shown in Figure 3, the IRF fabric has two members.
Roll back the boot, system, and feature images from T0001016 to T0001015 after upgrading them from T0001015 to T0001016. T0001016 and T0001015 are compatible.
Verifying the file flash:/all.ipe on slot 1................. .................Done.
Slot Upgrade Way
1 Reboot
2 Reboot
<Sysname> save
<Sysname> issu load file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin slot 2
Slot Upgrade Way
2 Reboot
ISSU state: Loaded
Work state: Normal
Upgraded slot:
slot 2
Slot Switchover Way
Work state: Normal
Upgraded slot:
slot 2
# Roll back the software images to T0001015.
<Sysname> issu rollback
This command will quit the ISSU process and roll back to the previous version. Continue? [Y/N]:Y
Verifying the rollback
# Verify that the rollback is finished.
ISSU state: Init
Work state: Normal
Upgraded slot: None
The ISSU state field displays Init, which indicates that the rollback is finished.
# Verify that both members are running the old software images.
Example: Upgrading a feature
Upgrade requirements
As shown in Figure 4, the IRF fabric has two members.
Upgrade the Feature1 feature from T0001015 to T0001016. The two versions are compatible.
Upgrade procedure
# Download the .ipe file that contains the T0001016 Feature1 feature image from the TFTP server.
<Sysname> tftp 2.2.2.2 get feature1-t0001016.ipe
100 256 100 256 0 0 764 0 --:--:-- --:--:-- --:--:-- 810
# Decompress the .ipe file.
<Sysname> install add flash:/feature1-t0001016.ipe flash:
Verifying the file flash:/feature1-t0001016.ipe on slot 1...Done.
Decompressing file feature1-t0001016.bin to flash:/feature1-t0001016.bin.......................Done.
flash:/feature1-t0001015.bin
# Identify the recommended ISSU methods and possible impact of the upgrade.
<Sysname> install activate feature flash:/feature1-t0001016.bin slot 2 test
Copying file flash:/feature1-t0001016.bin to slot2#flash:/feature1-t0001016.bin......Done.
Verifying the file flash:/feature1-t0001016.bin on slot 2...Done.
Slot Upgrade Way
2 Service Upgrade
Influenced service according to following table on slot 2:
Feature1
<Sysname> install activate feature flash:/feature1-t0001016.bin slot 1 test
Verifying the file flash:/feature1-t0001016.bin on slot 1...Done.
Slot Upgrade Way
1 Service Upgrade
Influenced service according to following table on slot 1:
Feature1
The output shows that both members need a service upgrade and the Feature1 module will be rebooted during the upgrade.
# Activate the new Feature1 image to upgrade the Feature1 feature.
flash:/feature1-t0001016.bin already exists on slot 2.
Overwrite it?[Y/N]:y
Slot Upgrade Way
2 Service Upgrade
Slot Upgrade Way
1 Service Upgrade
# Commit the software changes.
<Sysname> install commit
This operation will take several minutes, please wait...........................Done.
The current software images have been saved as the startup software images.
Current software images on slot 1:
Current software images on slot 2:
Rollback requirement
As shown in Figure 4, the IRF fabric has two members. The Feature1 feature has been upgraded from T0001015 to T0001016. However, the software change has not been committed.
Roll back the Feature1 feature from T0001016 to T0001015.
Rollback procedure
Active packages on slot2:
# Display available rollback points.
<Sysname> display install rollback
Install rollback information 1 on slot 1:
Updating from flash:/feature1-t0001015.bin
Install rollback information 2 on slot 2:
# Roll back the Feature1 feature to T0001015.
<Sysname> install rollback to original
# Verify that the IRF members are running the old Feature1 image.
Current software images on slot 0:
