| 00-Preface | 59.73 KB |
Preface
This command reference describes network management and monitoring commands. It covers commands for system maintenance and debugging, NQA, NTP, SNMP, RMON, NETCONF, EAA, process monitoring and maintenance, PoE, flow log, packet capture, information center, and mirroring.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
