07-MPLS Configuration Guide
HomeSupportSwitchesS12500X-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500X-AF Switch Series Configuration Guides(R26xx)-6W10207-MPLS Configuration Guide
Table of Contents
Related Documents
00-Preface
Download Book  (81.07 KB)
Preface
This configuration guide describes MPLS fundamentals and configuration procedures. It covers basic and extended MPLS features, including basic MPLS, LDP, MPLS TE, MPLS L3VPN, and MCE.
·          Audience.
·          Conventions.
·          Documentation feedback.
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators working with the S12500X-AF switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
Wireless terminator unit.
Wireless terminator.
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card.
We appreciate your comments.
