| 05-Appendix A Chassis views and technical specifications | 330.77 KB |
Transceiver module, fiber connector, and optical fiber views
Transceiver module specifications
The figures in this document are for illustration only.
Chassis views
Figure 1 Front view
(1) 100/1000Base-T autosensing Ethernet ports (1 to 12) |
(2) 100Base-FX/1000Base-X SFP ports (13 to 24) |
(3) 10GBase-R SFP+ ports (25 to 28) |
(4) 100/1000 Base-T management Ethernet ports |
(5) Console port |
Figure 2 Rear view
(1) Power module slot (PWR1) |
(2) Power module slot (PWR2) |
(3) Expansion slot |
(4) Grounding screw |
Power module views
AC power module
Figure 3 AC power module
(1) Captive screw |
(2) Power switch |
(3) Air outlet vent |
(4) Power receptacle |
DC power module
Figure 4 DC power module
(1) Captive screw |
(2) Power switch |
Use an SFP or SFP+ transceiver module together with an optical fiber with LC-type fiber connector.
Figure 5 SFP transceiver module
Figure 6 SFP+ transceiver module
Figure 7 Optical fiber with LC-type connectors
(1) LC-type connector |
(2) Optical fiber |
Technical specifications
Table 1 Technical specifications
Item |
Specification |
Console port |
One, 9600 bps (default) to 115200 bps |
Gigabit Ethernet port |
12 100/1000 Base-T autosensing Ethernet ports |
SFP port |
12 100Base-FX/1000Base-X SFP ports |
SFP+ port |
Four 10GBase-R SFP+ ports |
Memory |
4 × 2 GB DDR3 |
Storage media |
4 GB CF card |
Dimensions (H × W × D) (without rubber feet and mounting brackets) |
88.1 × 440 × 480 mm (3.47 × 17.32 × 18.90 in) |
Rate AC voltage range |
100 VAC to 240 VAC @ 50 Hz or 60 Hz |
Rate DC voltage range |
–48 VDC to –60 VDC |
System power consumption |
146 W to 260 W |
Weight |
13.3 kg (29.32 lb) (without power modules) |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Relative humidity (noncondensing) |
5% to 95% |
Table 2 AC power module specifications
Item |
Specification |
Model |
PSR300-12A1/PSR300-12A2 |
Rate input voltage range |
Rated power |
300 W |
Table 3 DC power module specifications
Item |
Specification |
Model |
PSR300-12D2 |
Rated power |
300 W |
The transceiver modules whose names contain MM and SM support multi-mode optical fibers and single-mode optical fibers, respectively.
Table 4 SFP-FE-SX-MM1310-A specifications
Item |
Specification |
Central wavelength |
1310 nm |
Transmission distance |
2 km (1.24 miles) |
Transmission rate |
125 Mbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
50 µm |
Transmit power |
–19 to –14 dBm |
Receive sensitivity |
≤ –30 dBm |
Saturation |
≤ –14 dBm |
Table 5 SFP-FE-LX-SM1310-A specifications
Item |
Specification |
1310 nm |
15 km (9.32 miles) |
Transmission rate |
125 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–15 to –8 dBm |
≤ –28 dBm |
Saturation |
≤ –7 dBm |
Table 6 SFP-FE-LH40-SM1310 specifications
Item |
Specification |
1310 nm |
40 km (24.86 miles) |
Transmission rate |
125 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–5 to 0 dBm |
≤ –34 dBm |
Saturation |
≤ –9 dBm |
Table 7 SFP-GE-SX-MM850-A specifications
Item |
Specification |
850 nm |
550 m (1804.46 ft) |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
50 µm |
Transmit power |
–9.5 to 0 dBm |
≤ –17 dBm |
Saturation |
≤ –3 dBm |
Table 8 SFP-GE-LX-SM1310-A specifications
Item |
Specification |
1310 nm |
10 km (6.21 miles) |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–9.5 to –3 dBm |
≤ –20 dBm |
Saturation |
≤ –3 dBm |
Table 9 SFP-GE-LH40-SM1310 specifications
Item |
Specification |
1310 nm |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–2 to +5 dBm |
≤ –22 dBm |
Saturation |
≤ –3 dBm |
Table 10 SFP-GE-LH40-SM1550 specifications
Item |
Specification |
1550 nm |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–4 to +1 dBm |
≤ –21 dBm |
Saturation |
≤ –3 dBm |
Table 11 SFP-GE-LH70-SM1550 specifications
Item |
Specification |
1550 nm |
70 km (43.50 miles) |
Transmission rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–4 to +5 dBm |
≤ –22 dBm |
Saturation |
≤ –3 dBm |
Table 12 SFP-XG-SX-MM850-A specifications
Item |
Specification |
850 nm |
300 m (984.25 ft) |
Transmission rate |
10.3125 Gbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
50 µm |
Transmit power |
–7.3 to –1 dBm |
≤ –9.9 dBm |
Saturation |
≤ 0.5 dBm |
Table 13 SFP-XG-LX220-MM1310 specifications
Item |
Specification |
1310 nm |
220 m (721.78 ft) |
Transmission rate |
10.3125 Gbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
62.5 µm |
Transmit power |
–6.5 to +0.5 dBm |
≤ –6.5 dBm |
Saturation |
≤ 1.5 dBm |
Table 14 SFP-XG-LX-SM1310 specifications
Item |
Specification |
1310 nm |
Transmission rate |
10.3125 Gbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–8.2 to +0.5 dBm |
≤ –14.4 dBm |
Saturation |
≤ 0.5 dBm |
Table 15 SFP-XG-LH40-SM1550 specifications
Item |
Specification |
1550 nm |
Transmission rate |
10.3125 Gbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 µm |
Transmit power |
–4.7 to +4 dBm |
≤ –15.8 dBm |
Saturation |
≤ –1 dBm |
Interface arrangement
The WX5540E provides fixed interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/32:
· GigabitEthernet 1/0/1 through GigabitEthernet 1/0/12—100/1000 Base-T autosensing Ethernet ports. You can identify an interface by its mark.
· GigabitEthernet 1/0/13 through GigabitEthernet 1/0/24—100Base-FX/1000Base-X SFP ports. You can identify an interface by its mark.
· GigabitEthernet 1/0/25 through GigabitEthernet 1/0/28—10GBase-R SFP+ ports. You can identify an interface by its mark.
· GigabitEthernet 1/0/29 through GigabitEthernet 1/0/32—Internal interfaces that are used to connect the controller engine of the WX5540E.
