06-Layer 3 - IP Services Configuration Guide
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-X Routers Configuration Guides-Release7951PXX-6W10006-Layer 3 - IP Services Configuration Guide
01-ARP configuration
01-ARP configuration 280.49 KB
Configuring ARP·· 1
About ARP·· 1
ARP message format 1
ARP operating mechanism·· 1
ARP entry types· 2
ARP tasks at a glance· 3
Configuring a static ARP entry· 3
Configuring a short static ARP entry· 4
Configuring a long static ARP entry· 4
Configuring features for dynamic ARP entries· 4
Setting the dynamic ARP learning limit for a device· 4
Setting the dynamic ARP learning limit for an interface· 5
Setting the aging timer for dynamic ARP entries· 5
Enabling dynamic ARP entry check· 6
Performing ARP entry synchronization·· 6
Enabling ARP safe-guard· 6
Enabling ARP logging· 7
Display and maintenance commands for ARP·· 7
ARP configuration examples· 8
Example: Configuring a long static ARP entry· 8
Example: Configuring a short static ARP entry· 9
Configuring gratuitous ARP·· 11
About gratuitous ARP·· 11
IP conflict detection·· 11
Gratuitous ARP packet learning· 11
Periodic sending of gratuitous ARP packets· 11
Gratuitous ARP tasks at a glance· 12
Enabling IP conflict notification·· 12
Enabling gratuitous ARP packet learning· 13
Enabling periodic sending of gratuitous ARP packets· 13
Enabling sending gratuitous ARP packets for ARP requests with sender IP address on a different subnet 13
Configuring proxy ARP·· 15
About proxy ARP·· 15
Enabling common proxy ARP·· 15
Enabling local proxy ARP·· 15
Display and maintenance commands for proxy ARP·· 16
Common proxy ARP configuration example· 16
Example: Configuring common proxy ARP·· 16
Configuring ARP direct route advertisement 18
About ARP direct route advertisement 18
Mechanism of ARP direct route advertisement 18
Cooperation with BGP·· 18
Application in L2VPN access to L3VPN networks· 18
Enabling ARP direct route advertisement 19
Configuring ARP
About ARP
ARP resolves IP addresses into MAC addresses on Ethernet networks.
ARP message format
ARP uses two types of messages: ARP request and ARP reply. Figure 1 shows the format of ARP request/reply messages. Numbers in the figure refer to field lengths.
Figure 1 ARP message format
·          Hardware type—Hardware address type. The value 1 represents Ethernet.
·          Protocol type—Type of the protocol address to be mapped. The hexadecimal value 0x0800 represents IP.
·          Hardware address length and protocol address length—Length, in bytes, of a hardware address and a protocol address. For an Ethernet address, the value of the hardware address length field is 6. For an IPv4 address, the value of the protocol address length field is 4.
·          OP—Operation code, which describes the type of ARP message. The value 1 represents an ARP request, and the value 2 represents an ARP reply.
·          Sender hardware address—Hardware address of the device sending the message.
·          Sender protocol address—Protocol address of the device sending the message.
·          Target hardware address—Hardware address of the device to which the message is being sent.
·          Target protocol address—Protocol address of the device to which the message is being sent.
As shown in Figure 2, Host A and Host B are on the same subnet. Host A sends a packet to Host B as follows:
1.        Host A looks through the ARP table for an ARP entry for Host B. If one entry is found, Host A uses the MAC address in the entry to encapsulate the IP packet into a data link layer frame. Then Host A sends the frame to Host B.
2.        If Host A finds no entry for Host B, Host A buffers the packet and broadcasts an ARP request. The payload of the ARP request contains the following information:
¡  Sender IP address and sender MAC address—Host A's IP address and MAC address.
¡  Target IP address—Host B's IP address.
¡  Target MAC address—An all-zero MAC address.
All hosts on this subnet can receive the broadcast request, but only the requested host (Host B) processes the request.
3.        Host B compares its own IP address with the target IP address in the ARP request. If they are the same, Host B operates as follows:
a.    Adds the sender IP address and sender MAC address into its ARP table.
b.    Encapsulates its MAC address into an ARP reply.
c.    Unicasts the ARP reply to Host A.
4.        After receiving the ARP reply, Host A operates as follows:
a.    Adds the MAC address of Host B into its ARP table.
b.    Encapsulates the MAC address into the packet and sends the packet to Host B.
Figure 2 ARP address resolution process
If Host A and Host B are on different subnets, Host A sends a packet to Host B as follows:
1.        Host A broadcasts an ARP request where the target IP address is the IP address of the gateway.
2.        The gateway responds with its MAC address in an ARP reply to Host A.
3.        Host A uses the gateway's MAC address to encapsulate the packet, and then sends the packet to the gateway.
4.        If the gateway has an ARP entry for Host B, it forwards the packet to Host B directly. If not, the gateway broadcasts an ARP request, in which the target IP address is the IP address of Host B.
5.        After the gateway gets the MAC address of Host B, it sends the packet to Host B.
ARP entry types
An ARP table stores dynamic, static, OpenFlow, and Rule ARP entries.
Dynamic ARP entry
ARP automatically creates and updates dynamic entries. A dynamic ARP entry is removed when its aging timer expires or the output interface goes down. In addition, a dynamic ARP entry can be overwritten by a static ARP entry.
Static ARP entry
A static ARP entry is manually configured and maintained. It does not age out and cannot be overwritten by any dynamic ARP entry.
Static ARP entries protect communication between devices because attack packets cannot modify the IP-to-MAC mapping in a static ARP entry.
The device supports the following types of static ARP entries:
·          Long static ARP entry—It is directly used for forwarding packets. A long static ARP entry contains the IP address, MAC address, and one of the following combinations:
¡  VLAN and output interface.
¡  Input and output interfaces.
·          Short static ARP entry—It contains only the IP address and MAC address.
¡  If the output interface is a Layer 3 Ethernet interface, the short ARP entry can be directly used to forward packets.
¡  If the output interface is a VLAN interface, the device sends an ARP request whose target IP address is the IP address in the short entry. If the sender IP and MAC addresses in the received ARP reply match the short static ARP entry, the device performs the following operations:
-      Adds the interface that received the ARP reply to the short static ARP entry.
-      Uses the resolved short static ARP entry to forward IP packets.
To communicate with a host by using a fixed IP-to-MAC mapping, configure a short static ARP entry on the device. To communicate with a host by using a fixed IP-to-MAC mapping through an interface in a VLAN, configure a long static ARP entry on the device.
OpenFlow ARP entry
ARP creates OpenFlow ARP entries by learning from the OpenFlow module. An OpenFlow ARP entry does not age out, and it cannot be updated. An OpenFlow ARP entry can be used directly to forward packets. For more information about OpenFlow, see OpenFlow Configuration Guide.
Rule ARP entry
ARP creates Rule ARP entries by learning from the IPoE, portal, and VXLAN modules. A Rule ARP entry does not age out, and it cannot be updated. It can be overwritten by a static ARP entry. A Rule ARP entry can be used directly to forward packets.
For more information about IPoE and portal, see BRAS Services Configuration Guide. For more information about VXLAN, see VXLAN Configuration Guide.
All ARP tasks are optional.
·          Configuring a static ARP entry
¡  Configuring a short static ARP entry
¡  Configuring a long static ARP entry
·          Configuring features for dynamic ARP entries
¡  Setting the dynamic ARP learning limit for a device
¡  Setting the dynamic ARP learning limit for an interface
¡  Setting the aging timer for dynamic ARP entries
¡  Enabling dynamic ARP entry check
·          Performing ARP entry synchronization
·          Enabling ARP safe-guard
·          Enabling ARP logging
Static ARP entries are effective when the device functions correctly.
A resolved short static ARP entry becomes unresolved upon certain events, for example, when the resolved output interface goes down, or the corresponding VLAN or VLAN interface is deleted.
1.        Enter system view.
2.        Configure a static ARP entry.
arp static ip-address mac-address [ vpn-instance vpn-instance-name ]
About long static ARP entries
Long static ARP entries can be effective or ineffective. Ineffective long static ARP entries cannot be used for packet forwarding. A long static ARP entry is ineffective when any of the following conditions exists:
·          The corresponding VLAN interface or output interface is down.
·          The IP address in the entry conflicts with a local IP address.
·          No local interface has an IP address in the same subnet as the IP address in the ARP entry.
A long static ARP entry in a VLAN is deleted if the VLAN or VLAN interface is deleted.
arp static ip-address mac-address [ vlan-id interface-type interface-number | interface-type interface-number interface-type interface-number | vsi-interface vsi-interface-id tunnel number vsi vsi-name | vsi-interface vsi-interface-id interface-type interface-number service-instance instance-id vsi vsi-name ]
About the dynamic ARP learning limit for a device
A device can dynamically learn ARP entries. To prevent a device from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the device can learn. When the limit is reached, the device stops ARP learning.
If you set a value lower than the number of existing dynamic ARP entries, the device does not delete the existing entries unless they age out.
2.        Set the dynamic ARP learning limit for the device.
In standalone mode:
arp max-learning-number max-number slot slot-number
In IRF mode:
arp max-learning-number max-number chassis chassis-number slot slot-number
By default, the device dynamic ARP learning limit varies by maximum remaining resources on the device.
To disable the device from dynamic ARP learning, set the value to 0.
About setting the dynamic ARP learning limit for an interface
An interface can dynamically learn ARP entries. To prevent an interface from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the interface can learn. When the limit is reached, the interface stops ARP learning.
You can set limits for both a Layer 2 interface and the VLAN interface for a permitted VLAN on the Layer 2 interface. The Layer 2 interface learns an ARP entry only when neither limit is reached.
The total dynamic ARP learning limit for all interfaces will not be higher than the dynamic ARP learning limit for the device.
2.        Enter interface view.
3.        Set the dynamic ARP learning limit for the interface.
arp max-learning-num max-number
By default, the interface dynamic ARP learning limit varies by maximum remaining resources on the device.
To disable the interface from dynamic ARP learning, set the value to 0.
About the aging timer for dynamic ARP entries
Each dynamic ARP entry in the ARP table has a limited lifetime, called an aging timer. The aging timer of a dynamic ARP entry is reset each time the dynamic ARP entry is updated. A dynamic ARP entry that is not updated before its aging timer expires is deleted from the ARP table.
2.        Set the aging timer for dynamic ARP entries.
arp timer aging aging-time
The default setting is 20 minutes.
About dynamic ARP entry check
The dynamic ARP entry check feature disables the device from supporting dynamic ARP entries that contain multicast MAC addresses. The device cannot learn dynamic ARP entries containing multicast MAC addresses. You cannot manually add static ARP entries containing multicast MAC addresses.
When dynamic ARP entry check is disabled, ARP entries containing multicast MAC addresses are supported. The device can learn dynamic ARP entries containing multicast MAC addresses obtained from the ARP packets sourced from a unicast MAC address. You can also manually add static ARP entries containing multicast MAC addresses.
2.        Enable dynamic ARP entry check.
arp check enable
By default, dynamic ARP entry check is enabled.
About ARP entry synchronization
This task ensures that all cards on the device have the same ARP entries.
To synchronize ARP entries across all cards in a timely manner, you can schedule the device to automatically execute the arp smooth command. For information about scheduling a task, see the device management in Fundamentals Configuration Guide.
To synchronize ARP entries from the active MPU to all other cards, execute the following command in user view:
arp smooth
About ARP safe-guard
The ARP safe-guard feature prevents traffic-intensive ARP packet attacks on a device. After you enable this feature, the device operates as follows:
·          The device sends replies to all incoming ARP requests but do not generate corresponding ARP entries, which prevents gateway spoofing attacks.
·          The device generates ARP entries for incoming ARP replies that the device requests.
·          The device drops incoming ARP replies that are not requested by the device, which ensures that the device can learn correct ARP entries.
Hardware and feature compatibility
This feature is supported only on CSPEX (excluding the CSPEX-1104-E card) and CEPC cards.
3.        Enable the ARP safe-guard feature.
arp safe-guard enable
By default, the ARP safe-guard feature is disabled.
About ARP logging
This feature enables a device to log ARP events when ARP cannot resolve IP addresses correctly. The device can log the following ARP events:
·          On a proxy ARP-disabled interface, the target IP address of a received ARP packet is not one of the following IP addresses:
¡  The IP address of the receiving interface.
¡  The virtual IP address of the VRRP group.
¡  The public IP address after NAT.
·          The sender IP address of a received ARP reply conflicts with one of the following IP addresses:
The device sends ARP log messages to the information center. You can use the info-center source command to specify the log output rules for the information center. For more information about information center, see Network Management and Monitoring Configuration Guide.
2.        Enable ARP logging.
arp check log enable
By default, ARP logging is disabled.
IMPORTANT
IMPORTANT:
Clearing ARP entries from the ARP table might cause communication failures. Make sure the entries to be cleared do not affect current communications.
(In standalone mode.) Display ARP entries.
display arp [ [ all | dynamic | static ] [ slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ]
(In IRF mode.) Display ARP entries.
display arp [ [ all | dynamic | static ] [ chassis chassis-number slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ]
(In standalone mode.) Display the ARP entry for an IP address.
display arp ip-address [ slot slot-number ] [ verbose ]
(In IRF mode.) Display the ARP entry for an IP address.
display arp ip-address [ chassis chassis-number slot slot-number ] [ verbose ]
Display the maximum number of ARP entries that a device supports.
display arp entry-limit
Display the ARP entries for a VPN instance.
display arp vpn-instance vpn-instance-name [ count ]
Display the aging timer of dynamic ARP entries.
display arp timer aging
(In standalone mode.) Display ARP safe-guard statistics.
display arp safe-guard statistics slot slot-number
(In IRF mode.) Display ARP safe-guard statistics.
display arp safe-guard statistics chassis chassis-number slot slot-number
(In standalone mode.) Clear ARP entries from the ARP table.
reset arp { all | dynamic | interface interface-type interface-number | slot slot-number | static }
(In IRF mode.) Clear ARP entries from the ARP table.
reset arp { all | chassis chassis-number slot slot-number | dynamic | interface interface-type interface-number | static }
(In standalone mode.) Clear ARP safe-guard statistics.
reset arp safe-guard statistics { all | slot slot-number }
(In IRF mode.) Clear ARP safe-guard statistics.
reset arp safe-guard statistics { all | chassis chassis-number slot slot-number }
As shown in Figure 3, hosts are connected to Device B. Device B is connected to Device A through interface GigabitEthernet 3/1/1 in VLAN 10.
To ensure secure communications between Device A and Device B, configure a long static ARP entry for Device A on Device B.
Figure 3 Network diagram
# Create VLAN 10.
[DeviceB] vlan 10
[DeviceB-vlan10] quit
# Add interface GigabitEthernet 3/1/1 to VLAN 10.
[DeviceB] interface gigabitethernet 3/1/1
[DeviceB-GigabitEthernet3/1/1] port access vlan 10
[DeviceB-GigabitEthernet3/1/1] quit
# Create VLAN-interface 10 and configure its IP address.
[DeviceB] interface vlan-interface 10
[DeviceB-vlan-interface10] ip address 192.168.1.2 8
[DeviceB-vlan-interface10] quit
# Configure a long static ARP entry that has IP address 192.168.1.1, MAC address 00e0-fc01-0000, and output interface GigabitEthernet 3/1/1 in VLAN 10.
[DeviceB] arp static 192.168.1.1 00e0-fc01-0000 10 gigabitethernet 3/1/1
# Verify that Device B has a long static ARP entry for Device A.
[DeviceB] display arp static
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP address       MAC address    VLAN/VSI name Interface                Aging Type
192.168.1.1      00e0-fc01-0000 10            GE3/1/1                  --    S
As shown in Figure 4, hosts are connected to Device B. Device B is connected to Device A through interface GigabitEthernet 3/1/2.
To ensure secure communications between Device A and Device B, configure a short static ARP entry for Device A on Device B.
Figure 4 Network diagram
# Configure an IP address for GigabitEthernet 3/1/2.
[DeviceB] interface gigabitethernet 3/1/2
[DeviceB-GigabitEthernet3/1/2] ip address 192.168.1.2 24
[DeviceB-GigabitEthernet3/1/2] quit
# Configure a short static ARP entry that has IP address 192.168.1.1 and MAC address 00e0-fc01-001f.
[DeviceB] arp static 192.168.1.1 00e0-fc01-001f
# Verify that Device B has a short static ARP entry for Device A
192.168.1.1      00e0-fc01-001f --            --                       --    S
In a gratuitous ARP packet, the sender IP address and the target IP address are the IP address of the sending device.
A device sends a gratuitous ARP packet for either of the following purposes:
·          Determine whether its IP address is already used by another device. If the IP address is already used, the device is informed of the conflict by an ARP reply.
·          Inform other devices of a MAC address change.
When an interface obtains an IP address, the device broadcasts gratuitous ARP packets in the LAN where the interface resides. If the device receives an ARP reply, its IP address conflicts with the IP address of another device in the LAN. The device displays a log message about the conflict and informs the administrator to change the IP address. The device will not use the conflicting IP address. If no ARP reply is received, the device uses the IP address.
This feature enables a device to create or update ARP entries by using the sender IP and MAC addresses in received gratuitous ARP packets.
When this feature is disabled, the device uses received gratuitous ARP packets to update existing ARP entries only. ARP entries are not created based on the received gratuitous ARP packets, which saves ARP table space.
Periodic sending of gratuitous ARP packets helps downstream devices update ARP entries or MAC entries in a timely manner.
This feature can implement the following functions:
·          Prevent gateway spoofing.
Gateway spoofing occurs when an attacker uses the gateway address to send gratuitous ARP packets to the hosts on a network. The traffic destined for the gateway from the hosts is sent to the attacker instead. As a result, the hosts cannot access the external network.
To prevent such gateway spoofing attacks, you can enable the gateway to send gratuitous ARP packets at intervals. Gratuitous ARP packets contain the primary IP address and manually configured secondary IP addresses of the gateway, so hosts can learn correct gateway information.
·          Prevent ARP entries from aging out.
If network traffic is heavy or if the host CPU usage is high, received ARP packets can be discarded or are not promptly processed. Eventually, the dynamic ARP entries on the receiving host age out. The traffic between the host and the corresponding devices is interrupted until the host re-creates the ARP entries.
To prevent this problem, you can enable the gateway to send gratuitous ARP packets periodically. Gratuitous ARP packets contain the primary IP address and manually configured secondary IP addresses of the gateway, so the receiving hosts can update ARP entries in a timely manner.
·          Prevent the virtual IP address of a VRRP group from being used by a host.
The master router of a VRRP group can periodically send gratuitous ARP packets to the hosts on the local network. The hosts can then update local ARP entries and avoid using the virtual IP address of the VRRP group. The sender MAC address in the gratuitous ARP packet is the virtual MAC address of the virtual router. For more information about VRRP, see High Availability Configuration Guide.
·          Update MAC entries of devices in the VLANs having ambiguous Dot1q or QinQ termination configured.
In VRRP configuration, if ambiguous Dot1q or QinQ termination is configured for multiple VLANs and VRRP groups, interfaces configured with VLAN termination must be disabled from transmitting broadcast/multicast packets. Also, a VRRP control VLAN must be configured so that VRRP advertisements can be transmitted within the control VLAN only. In such cases, you can enable periodic sending of gratuitous ARP packets containing the following addresses:
¡  The VRRP virtual IP address.
¡  The primary IP address or a manually configured secondary IP address of the sending interface on the subinterfaces.
When a VRRP failover occurs, devices in the VLANs can use the gratuitous ARP packets to update their corresponding MAC entries in a timely manner. For more information about ambiguous Dot1q or QinQ termination, see Layer 2—LAN Switching Configuration Guide.
All gratuitous ARP tasks are optional. If all of the following features are disabled, gratuitous ARP still provides the IP conflict detection function.
·          Enabling IP conflict notification
·          Enabling gratuitous ARP packet learning
·          Enabling periodic sending of gratuitous ARP packets
·          Enabling sending gratuitous ARP packets for ARP requests with sender IP address on a different subnet
About IP conflict notification
Upon detecting an IP conflict, the device will sends a gratuitous ARP request. By default, the device displays an error message only after it receives an ARP reply. You can enable this feature to allow the device to display an error message immediately upon detecting an IP conflict.
2.        Enable IP conflict notification.
arp ip-conflict log prompt
By default, IP conflict notification is disabled.
2.        Enable gratuitous ARP packet learning.
gratuitous-arp-learning enable
By default, gratuitous ARP packet learning is enabled.
·          You can enable periodic sending of gratuitous ARP packets on a maximum of 1024 interfaces.
·          Periodic sending of gratuitous ARP packets takes effect on an interface only when the following conditions are met:
¡  The data link layer state of the interface is up.
¡  The interface has an IP address.
·          If you change the sending interval for gratuitous ARP packets, the configuration takes effect at the next sending interval.
·          The sending interval for gratuitous ARP packets might be much longer than the specified sending interval in any of the following circumstances:
¡  This feature is enabled on multiple interfaces.
¡  Each interface is configured with multiple secondary IP addresses.
¡  A small sending interval is configured when the previous two conditions exist.
3.        Enable periodic sending of gratuitous ARP packets.
arp send-gratuitous-arp [ interval interval ]
By default, periodic sending of gratuitous ARP packets is disabled.
2.        Enable the device to send gratuitous ARP packets upon receiving ARP requests whose sender IP address belongs to a different subnet.
gratuitous-arp-sending enable
By default, a device does not send gratuitous ARP packets upon receiving ARP requests whose sender IP address belongs to a different subnet.
About proxy ARP
Proxy ARP enables a device on one network to answer ARP requests for an IP address on another network. With proxy ARP, hosts on different broadcast domains can communicate with each other as they would on the same broadcast domain.
Proxy ARP includes common proxy ARP and local proxy ARP.
·          Common proxy ARP—Allows communication between hosts that connect to different Layer 3 interfaces and reside in different broadcast domains.
·          Local proxy ARP—Allows communication between hosts that connect to the same Layer 3 interface and reside in different broadcast domains.
The following interface types are supported:
¡  VLAN interface.
¡  Layer 3 Ethernet interface.
¡  Layer 3 Ethernet subinterface.
¡  Layer 3 aggregate interface.
¡  Layer 3 aggregate subinterface.
3.        Enable common proxy ARP.
proxy-arp enable
By default, common proxy ARP is disabled.
¡  VLAN interface.
3.        Enable local proxy ARP.
local-proxy-arp enable [ ip-range start-ip-address to end-ip-address ]
By default, local proxy ARP is disabled.
Display common proxy ARP status.
display proxy-arp [ interface interface-type interface-number ]
Display local proxy ARP status.
display local-proxy-arp [ interface interface-type interface-number ]
As shown in Figure 5, Host A and Host D have the same prefix and mask, but they are located on different subnets. No default gateway is configured on Host A and Host D.
Configure common proxy ARP on the router to ensure communication between Host A and Host D.
Figure 5 Network diagram
# Configure the IP address of GigabitEthernet 3/1/2.
<Router> system-view
[Router] interface gigabitethernet 3/1/2
[Router-GigabitEthernet3/1/2] ip address 192.168.10.99 255.255.255.0
# Enable common proxy ARP on GigabitEthernet 3/1/2.
[Router-GigabitEthernet3/1/2] proxy-arp enable
[Router-GigabitEthernet3/1/2] quit
# Configure the IP address of GigabitEthernet 3/1/1.
[Router] interface gigabitethernet 3/1/1
[Router-GigabitEthernet3/1/1] ip address 192.168.20.99 255.255.255.0
# Enable common proxy ARP on GigabitEthernet 3/1/1.
[Router-GigabitEthernet3/1/1] proxy-arp enable
[Router-GigabitEthernet3/1/1] quit
# Verify that Host A and Host D can ping each other.
The ARP direct route advertisement feature advertises host routes instead of advertising the network route.
As shown in Figure 6, this feature can cooperate with BGP in an EVPN network. The Layer 3 Ethernet interfaces that directly connect a leaf node and a spine node borrow IP addresses with the subnet mask 255.255.255.255, for example, from loopback interfaces. For communication, the leaf node and the spine node learn the ARP entry of each other through LLDP.
Because the IP addresses of the interfaces that directly connect the spine node and the leaf node belong to different subnets, one node does not have the direct route to the other node. If BGP is used to transmit underlay network routes, BGP cannot perform correct route recursion. To resolve this problem, enable ARP direct route advertisement on the Layer 3 Ethernet interfaces that directly connect the spine node and the leaf node. One node generates a direct route to the other node and BGP can perform correct route recursion.
For information about EVPN, see EVPN Configuration Guide. For information about LLDP, see Layer 2—LAN Switching Configuration Guide. For information about BGP, see Layer 3—IP Routing Configuration Guide.
Figure 6 ARP direct route with BGP
‌As shown in Figure 7, the ARP direct route feature is configured on PE-aggs to advertise host routes to the connected PEs in the L3VPN.
The PE in the L3VPN has ECMP routes destined to a base station in the L2VPN. Traffic from the PE in the L3VPN to the base station can be load shared by PE-agg 1 and PE-agg 2. If PE-agg 1 fails, the PE uses the host route through PE-agg 2 to forward traffic.
For information about L2VPN access to L3VPN, see MPLS Configuration Guide.
Figure 7 Typical application
3.        Enable the ARP direct route advertisement feature.
arp route-direct advertise
By default, the ARP direct route advertisement feature is disabled.
