13-High Availability Configuration Guide
HomeSupportRoutersH3C SR8800-F Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-F Routers Configuration Guides-Release7951PXX-6W10013-High Availability Configuration Guide
06-Service instance group configuration
06-Service instance group configuration 36.43 KB
Configuring service instance groups
About service instance groups
Associated with a failover group, a service instance group helps back up service data for specific service modules (such as NAT), and guarantee correct operation of specific services. For more information about failover groups, see "Configuring failover groups."
Restrictions and guidelines: Service instance group configuration
A service instance group can be associated with only one failover group. A failover group can be associated with only one service instance group.
If the NAT instance with a service instance group specified has NAT entries, you are not allowed to perform the following operations:
·          Delete the service instance group.
·          Cancel the association between the service instance group and failover group.
Configuring a service instance group
1.        Enter system view.
2.        Create a service instance group and enter its view.
service-instance-group service-instance-group-name
3.        Associate a failover group with the service instance group.
failover-group failover-group-name
By default, a service instance group is not associated with any failover groups.
Display and maintenance commands for service instance groups
Display service instance group information.
display service-instance-group [ service-instance-group-name ]
