| 13-IPoE commands | 675.83 KB |
display ip subscriber abnormal-logout
display ip subscriber chasten user auth-failed
display ip subscriber chasten user quiet
display ip subscriber interface-leased
display ip subscriber interface-leased statistics
display ip subscriber interface-leased user
display ip subscriber interface-leased user ip-type
display ip subscriber l2vpn-leased
display ip subscriber l2vpn-leased statistics
display ip subscriber offline statistics
display ip subscriber session statistics
display ip subscriber session statistics ip-type
display ip subscriber subnet-leased
display ip subscriber subnet-leased statistics
display ip subscriber subnet-leased user
display ip subscriber subnet-leased user ip-type
display ip subscriber tcp-connection
ip subscriber access-line-id circuit-id trans-format
ip subscriber access-line-id remote-id trans-format
ip subscriber access-trigger loose
ip subscriber access-user log enable
ip subscriber authentication chasten
ip subscriber authentication-method
ip subscriber captive-bypass enable
ip subscriber dhcp domain include
ip subscriber dhcp max-session
ip subscriber dhcp option60 match
ip subscriber dhcpv6 max-session
ip subscriber dhcpv6 password option16
ip subscriber http-fast-reply enable
ip subscriber initiator arp enable
ip subscriber initiator dhcp enable
ip subscriber initiator dhcpv6 enable
ip subscriber initiator ndrs enable
ip subscriber initiator nsna enable
ip subscriber initiator unclassified-ip enable
ip subscriber initiator unclassified-ipv6 enable
ip subscriber lease-end-time original
ip subscriber nas-port-id format
ip subscriber nas-port-id interface
ip subscriber nas-port-id nasinfo-insert
ip subscriber ndrs max-session
ip subscriber service-identify
ip subscriber session static (interface view)
ip subscriber session static (system view)
ip subscriber static-session request-online interval
ip subscriber unclassified-ip domain
ip subscriber unclassified-ip ip match
ip subscriber unclassified-ip ipv6 match
ip subscriber unclassified-ip max-session
ip subscriber unclassified-ip username
ip subscriber unclassified-ipv6 max-session
ip subscriber user-detect ipv6
ip subscriber user-policy interface-down
reset ip subscriber abnormal-logout
reset ip subscriber interface-leased
reset ip subscriber interface-leased user
reset ip subscriber interface-leased user ip-type
reset ip subscriber offline statistics
reset ip subscriber subnet-leased
reset ip subscriber subnet-leased user
reset ip subscriber subnet-leased user ip-type
snmp-agent trap enable slot-user-warning-threshold
IPoE commands
This feature is available only when the system operates in standard mode. For more information about the system operating modes, see device management in Fundamentals Configuration Guide.
Only SPEX/CSPEX (except CSPEX-1104-E)/CEPC cards support IPoE.
Use display ip subscriber abnormal-logout to display information about abnormally logged out DHCP users.
In standalone mode:
display ip subscriber abnormal-logout [ interface interface-type interface-number ] [ { mac mac-address | ip-type ipv4 } } * | ip ipv4-address ] [ verbose ] [ slot slot-number ]
In IRF mode:
display ip subscriber abnormal-logout [ interface interface-type interface-number ] [ { mac mac-address | ip-type ipv4 } } * | ip ipv4-address } ] [ verbose ] [ chassis chassis-number slot slot-number ]
mac-address mac-address: Specifies a MAC address in the format of H-H-H.
ip-type: Specifies an IP address type.
ipv4: Specifies IPv4 addresses.
ip ipv4-address: Specifies an IPv4 address.
verbose: Specifies detailed user information.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays information about abnormally logged out DHCP users for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about abnormally logged out DHCP users for all cards. (In IRF mode.)
# (In standalone mode.) Display brief information about abnormally logged out DHCP users on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber abnormal-logout interface gigabitethernet 3/1/1
Slot 3:
Interface IP address MAC address
GE3/1/1 1.1.1.1 000d-88f8-0eab
Name of the interface where the user resides. |
IP address |
IP address of the user. |
MAC address |
MAC address of the user. |
# (In standalone mode.) Display detailed information about abnormally logged out DHCP users on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber abnormal-logout verbose
Slot 3:
IP address : 1.1.1.1
MAC address : 000d-88f8-0eab
Service-VLAN/Customer-VLAN : -/-
Access interface : GE3/1/1
Offline reason : Admin reset
Aging : May 9 10:05:29 2017
IP address |
MAC address |
Service-VLAN/Customer-VLAN |
SVLAN and CVLAN of the user. If the user traffic does not carry a SVLAN or CVLAN tag, this field displays a hyphen (-) for the SVLAN or CVLAN part. |
Access interface |
Interface that connects the user. |
Offline reason |
Reason why the user is abnormally logged out. For more information, see the log manual for IPoE logins and logouts. |
Aging |
Time when the entry for the abnormally logged out user will age out. N/A means that the entry never ages out. |
Use display ip subscriber chasten user auth-failed to display information about IPoE individual users with authentication failure records that have not met the blocking conditions.
In standalone mode:
display ip subscriber chasten user auth-failed [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | user-type { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 | static } ] [ slot slot-number ]
In IRF mode:
display ip subscriber chasten user auth-failed [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | user-type { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 | static } ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information for all interfaces.
ip ip-address: Specifies the source IPv4 address of an IPoE individual user.
ipv6 ipv6-address: Specifies the source IPv6 address of an IPoE individual user.
mac mac-address: Specifies the MAC address of an IPoE individual user, in the format of H-H-H.
user-type: Specifies a user type. If you do not specify a user type, this command displays information about all types of IPoE individual users.
dhcp: Specifies DHCPv4 users.
dhcpv6: Specifies DHCPv6 users.
ndrs: Specifies IPv6 ND RS users.
unclassified-ip: Specifies unclassified-IPv4 users.
unclassified-ipv6: Specifies unclassified-IPv6 users.
static: Specifies static individual users.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for all cards. (In IRF mode.)
# Display brief information about the IPoE individual users with authentication failure records that have not met the blocking conditions on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber chasten user auth-failed interface gigabitethernet 3/1/1
Interface IP address MAC address SVLAN/CVLAN Failures
GE3/1/1 6.6.6.2 248c-c3d1-0406 -/- 7
IP address |
MAC address |
SVLAN/CVLAN |
Failures |
Number of consecutive authentication failures of the user. N/A indicates the entry is to age out. |
ip subscriber timer quiet
Use display ip subscriber chasten user quiet to display information about blocked IPoE individual users.
In standalone mode:
display ip subscriber chasten user quiet [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | user-type { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 | static } ] [ verbose ] [ slot slot-number ]
In IRF mode:
display ip subscriber chasten user quiet [ interface interface-type interface-number ] [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | user-type { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 | static } ] [ verbose ] [ chassis chassis-number slot slot-number ]
ip ip-address: Specifies the source IPv4 address of a blocked IPoE individual user.
ipv6 ipv6-address: Specifies the source IPv6 address of a blocked IPoE individual user.
mac mac-address: Specifies the MAC address of a blocked IPoE individual user, in the format of H-H-H.
verbose: Displays detailed information about blocked IPoE individual users. If this keyword is not specified, this command displays brief information about blocked IPoE individual users.
# Display brief information about the blocked IPoE individual users on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber chasten user quiet interface gigabitethernet 3/1/1
Type: D-DHCP S-Static U-Unclassified-IP N-NDRS
Interface IP address MAC address Type Aging(s)
GE3/1/1 6.6.6.2 248c-c3d1-0406 U 7
IP address |
MAC address |
Type |
IPoE user type: · D—DHCP user. · S—Static individual user. · U—Unclassified-IP user. · N—IPv6 ND RS user. |
Aging(s) |
Remaining aging time in seconds for the user. |
# (In standalone mode.) Display detailed information about all blocked IPoE individual users.
<Sysname> display ip subscriber chasten user quiet verbose
Username : 1.1.1.10
Domain : dm0
IP address : 1.1.1.10
MAC address : 4649-e2cf-0216
Service node : Slot 3 CPU 0
Access Type : Unclassified-IP
Aging : 41 sec
Table 5 Command output
Username |
Username for authentication. |
Domain |
ISP domain of the user for authentication. |
IP address |
MAC address |
Access interface |
Service node |
Slot number and CPU number of the card that connects the user. |
Access Type |
IPoE user type: · DHCP—DHCP user. · Unclassified-IP—Unclassified-IP user. · NDRS—IPv6 ND RS user. · Static—Static individual user. |
Aging |
Remaining aging time for the user, in seconds. |
Use display ip subscriber interface-leased to display interface-leased user session information.
In standalone mode:
display ip subscriber interface-leased [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display ip subscriber interface-leased [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
# (In standalone mode.) Display interface-leased user session information on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber interface-leased interface gigabitethernet 3/1/1
Basic:
VPN instance : N/A
Username : a
User ID : 0x30060000
State : Online
Domain : radius
Login time : May 14 20:04:42 2014
Online time (hh:mm:ss) : 00:16:37
IPv4 total users : 10
IPv6 total users : 10
AAA:
ITA policy name : ipoe
IP pool : N/A
IPv6 pool : N/A
Primary DNS server : N/A
Secondary DNS server : N/A
Primary IPv6 DNS server : N/A
Secondary IPv6 DNS server : N/A
Session idle cut : N/A
Session duration : N/A, remaining: N/A
Traffic quota : N/A
Traffic remained : N/A
Acct start-fail action : Online
Acct update-fail action : Online
Acct quota-out action : Offline
Dual-stack accounting mode : Merge
Max IPv4 multicast addresses : 4
IPv4 multicast address list : N/A
Max IPv6 multicast addresses : 4
IPv6 multicast address list : N/A
QoS:
User profile : abc (active)
Session group profile : N/A
User group ACL : N/A
Inbound CAR : CIR 1000kbps PIR 2000kbps CBS 4100bytes (active)
Outbound CAR : CIR 3000kbps PIR 4000kbps CBS 4100bytes (active)
Inbound user priority : 1 (active)
Outbound user priority : 1 (active)
Flow statistic:
Uplink packets/bytes : 0/0
Downlink packets/bytes : 0/0
IPv6 uplink packets/bytes : 0/0
IPv6 downlink packets/bytes : 0/0
ITA:
Acct merge : Disabled
Denied level : None
Level-1 Inbound CAR : CIR 126976000kbps PIR 126976000kbps (active)
Outbound CAR : N/A
Traffic separate : Disabled
Traffic quota : N/A
Level-2 Inbound CAR : N/A
Outbound CAR : N/A
Traffic quota : N/A
Table 6 Command output
Basic |
Basic session information. |
Access interface |
VPN instance |
MPLS L3VPN instance of the user. If the user is not in a VPN, this field displays N/A. |
Username |
User ID |
User ID assigned after the user came online. If no user ID is assigned, this field displays 0xffffffff. |
State |
User session state: · Init—The user is being initiated. · Offline—The user is going offline. · Auth—The user is being authenticated. · AuthFail—The user failed authentication. · AuthPass—The user passed authentication. · AssignedIP—The user has an IP address. · Online—The user is online. · Backup—The user is backed up to the local end from the peer end. |
Service node |
Domain |
Login time |
Time when the user passed authentication and logged in, in the format of MM DD hh:mm:ss YYYY. |
Online time (hh:mm:ss) |
Online duration of the user. |
IPv4 total users |
Total number of IPv4 interface-leased subusers. |
IPv6 total users |
Total number of IPv6 interface-leased subusers. |
Failure reason |
Reason for failing to issue the session to the driver (this field is displayed only when the session fails to be issued to the driver): · Not support—The driver does not support the session. · No resource—The hardware resources are insufficient. · Unknown—The failure reason is unknown. |
AAA |
AAA authorization information. |
ITA policy name |
AAA-authorized ITA policy name. If no ITA policy name is authorized, this field displays N/A. |
IP pool |
AAA-authorized DHCPv4 address pool. If no DHCPv4 address pool is authorized, this field displays N/A. |
IP pool group |
AAA-authorized DHCPv4 address pool group. This field is displayed only when AAA has authorized a DHCPv4 address pool group and has not authorized a DHCPv4 address pool. This field will not be displayed at the same time as the IP pool field. |
IPv6 pool |
AAA-authorized DHCPv6 address pool. If no DHCPv6 address pool is authorized, this field displays N/A. |
IPv6 pool group |
AAA-authorized DHCPv6 address pool group. This field is displayed only when AAA has authorized a DHCPv6 address pool group and has not authorized a DHCPv6 address pool. This field will not be displayed at the same time as the IPv6 pool field. |
Primary DNS server |
AAA-authorized primary IPv4 DNS server address. If no primary IPv4 DNS server address pool is authorized, this field displays N/A. |
Secondary DNS server |
AAA-authorized secondary IPv4 DNS server address. If no secondary IPv4 DNS server address pool is authorized, this field displays N/A. |
Primary IPv6 DNS server |
AAA-authorized primary IPv6 DNS server address. If no primary IPv6 DNS server address is authorized, this field displays N/A. |
Secondary IPv6 DNS server |
AAA-authorized secondary IPv6 DNS server address. If no secondary IPv6 DNS server address is authorized, this field displays N/A. |
Session idle cut |
Period and traffic threshold for idle cut. If traffic does not reach the threshold in bytes within the period in seconds, the user is logged out. If the user can remain idle without being logged out, this field displays N/A. |
direction |
Direction of traffic to be used by idle cut: · Both—Inbound and outbound traffic. · Inbound—Inbound traffic. · Outbound—Outbound traffic. |
Session duration |
AAA-authorized IPoE session duration in seconds: · N/A—No IPoE session duration is authorized. · Unlimited—The IPoE session duration is unlimited. |
remaining |
Remaining AAA-authorized IPoE session duration. If no session duration is authorized, this field displays N/A. For users on Layer 3 Ethernet interfaces and subinterfaces, this field displays the remaining time or Unlimited. For users on Layer 3 aggregate interfaces and subinterfaces, this field displays the remaining time or Unlimited only when the slot or interface is specified. If you do not specify the slot or interface, this field displays N/A. |
Traffic quota |
AAA-authorized traffic in bytes. If no traffic is authorized, this field displays N/A. |
Traffic remained |
Remaining AAA-authorized traffic in bytes. If no traffic is authorized or the authorized traffic has been used out, this field displays N/A. |
Acct start-fail action |
Actions to take after accounting fails to start: · Online—Keeps the user online. · Offline—Forces the user offline. |
Acct update-fail action |
Actions to take after accounting fails to update: · Online—Keeps the user online. · Offline—Forces the user offline. |
Acct quota-out action |
Actions to take after the traffic quota is exhausted: · Online—Keeps the user online. · Offline—Forces the user offline. |
Dual-stack accounting mode |
Accounting mode of dual-stack users: · Merge—Reports the IPv4 and IPv6 traffic of dual-stack users as a whole to the accounting server. · Separate—Reports the IPv4 and IPv6 traffic of dual-stack users to the accounting server separately. · N/A—No dual-stack accounting mode is authorized. |
Max IPv4 multicast addresses |
Maximum number of AAA-authorized IPv4 multicast groups that a user can join. |
IPv4 multicast address list |
List of AAA-authorized IPv4 multicast group addresses. If no IPv4 multicast group is authorized, this field displays N/A. |
Max IPv6 multicast addresses |
Maximum number of AAA-authorized IPv6 multicast groups that a user can join. |
IPv6 multicast address list |
List of AAA-authorized IPv6 multicast group addresses. If no IPv6 multicast group is authorized, this field displays N/A. |
QoS |
QoS information. |
User profile |
Name of the AAA-authorized user profile. N/A means that no user profile is authorized. The user profile has the following states: · inactive—User profile authorization failed or the user profile does not exist on the BRAS. · active—The user profile is authorized successfully. If the authorization result has not been updated, nothing is displayed. |
Session group profile |
Name of the AAA-authorized session group profile. N/A means that no session group profile is authorized. The session group profile has the following states: · inactive—Session group profile authorization failed or the session group profile does not exist on the BRAS. · active—The session group profile is authorized successfully. If the authorization result has not been updated, nothing is displayed. |
User group ACL |
Name of the AAA-authorized user group ACL. N/A means that no user group ACL is authorized. The user group ACL has the following states: · active—The user group ACL is authorized successfully. · inactive—User group ACL authorization failed or the user group ACL does not exist on the BRAS. If the authorization result has not been updated, nothing is displayed. |
Inbound CAR |
Inbound CIR and PIR in kbps, and CBS in bytes. N/A means that no inbound CAR is authorized. The inbound CAR has the following states: · inactive—Inbound CAR is not authorized successfully. · active—Inbound CAR is authorized successfully. |
Outbound CAR |
Outbound CIR and PIR in kbps, and CBS in bytes. N/A means that no outbound CAR is authorized. The outbound CAR has the following states: · inactive—Outbound CAR is not authorized successfully. · active—Outbound CAR is authorized successfully. |
Inbound user priority |
AAA-authorized inbound user priority, which can be a number in the range of 0 to 7, 15, and N/A. N/A or 15 means that no inbound user priority is authorized. The inbound user priority has the following states: · inactive—Inbound user priority is not authorized successfully. · active—Inbound user priority is authorized successfully. |
Outbound user priority |
AAA-authorized outbound user priority, which can be a number in the range of 0 to 7, 15, and N/A. N/A or 15 means that no outbound user priority is authorized. The outbound user priority has the following states: · inactive—Outbound user priority is not authorized successfully. · active—Outbound user priority is authorized successfully. |
Flow statistic |
Session flow statistics. |
Uplink packets/bytes |
Total number and size of uplink packets. This field displays the total number and size of uplink IPv4 and IPv6 packets in Merge accounting mode. Otherwise, this field displays the total number and size of uplink IPv4 packets. |
Downlink packets/bytes |
Total number and size of downlink packets. This field displays the total number and size of downlink IPv4 and IPv6 packets in Merge accounting mode. Otherwise, this field displays the total number and size of downlink IPv4 packets. |
IPv6 uplink packets/bytes |
Total number and size of uplink IPv6 packets. |
IPv6 downlink packets/bytes |
Total number and size of downlink IPv6 packets. |
ITA |
ITA information. |
Acct merge |
ITA state: · Enabled. · Disabled. |
Denied level |
Level of the traffic being denied. If no traffic is denied, this field displays None. Traffic is classified into 8 levels (from 1 to 8). |
Level-n Inbound CAR |
AAA-authorized uplink CIR and PIR in kbps for level n traffic (n is in the range of 1 to 8). Inbound CAR state: · active—Inbound CAR is authorized successfully. · inactive—Inbound CAR is not authorized successfully. · N/A—Inbound CAR is not authorized. |
Outbound CAR |
AAA-authorized downlink CIR and PIR in kbps for level n traffic (n is in the range of 1 to 8). Outbound CAR state: · active—Outbound CAR is authorized successfully. · inactive—Outbound CAR is not authorized successfully. · N/A—Outbound CAR is not authorized. |
Traffic separate |
State of separating ITA service traffic from the overall traffic for accounting: · Enabled · Disabled |
ip subscriber enable
Use display ip subscriber interface-leased statistics to display interface-leased user session statistics.
In standalone mode:
display ip subscriber interface-leased statistics [ domain domain-name ] [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display ip subscriber interface-leased statistics [ domain domain-name ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
domain domain-name: Specifies an ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays interface-leased user session statistics for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays interface-leased user session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays interface-leased user session statistics for all cards. (In IRF mode.)
# Display IPoE session statistics for all interface-leased users on the BRAS.
<Sysname> display ip subscriber interface-leased statistics
Total sessions : 100
Init : 0
Authenticating : 20
Authenticate fail : 0
Authenticate pass : 20
Assigned IP : 10
Online : 50
Backup : 0
Table 7 Command output
Total sessions |
Total number of sessions on the interface. |
Init |
Number of sessions that were being initiated. |
Authenticating |
Number of sessions being authenticated. |
Authenticate fail |
Number of sessions that failed authentication. |
Authenticate pass |
Number of sessions that passed authentication. |
Assigned IP |
Number of sessions that have IP addresses. |
Online |
Number of online sessions. |
Backup |
Number of sessions whose information was backed up. |
Use display ip subscriber interface-leased user to display interface-leased subuser session information.
In standalone mode:
display ip subscriber interface-leased user [ interface interface-type interface-number [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ verbose ] [ slot slot-number ]
In IRF mode:
display ip subscriber interface-leased user [ interface interface-type interface-number [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays interface-leased subuser session information for all interfaces.
ip ipv4-address: Specifies the source IPv4 address of an interface-leased subuser.
ipv6 ipv6-address: Specifies the source IPv6 address of an interface-leased subuser.
mac mac-address: Specifies the source MAC address of an interface-leased subuser, in the format of H-H-H.
s-vlan svlan-id: Specifies the service provider VLAN ID of an interface-leased subuser. The value range for the svlan-id argument is 1 to 4094.
c-vlan cvlan-id: Specifies the customer VLAN ID of an interface-leased subuser. The value range for the cvlan-id argument is 1 to 4094.
vxlan vxlan-id: Specifies the VXLAN ID of an interface-leased subuser. The value range for the vxlan-id argument is 0 to 16777215.
verbose: Displays detailed information about interface-leased subusers. If this keyword is not specified, this command displays brief information about interface-leased subusers.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays interface-leased subuser session information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays interface-leased subuser session information for all cards. (In IRF mode.)
This command takes effect only in Layer 2 access mode.
# Display brief session information about the interface-leased subusers on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber interface-leased user interface gigabitethernet 3/1/1
Interface IP address MAC address SVLAN/CVLAN User ID
GE3/1/1 100.1.1.3 0010-9400-0003 -/- 0x380800b5
GE3/1/1 100::1 0010-9400-0004 -/- 0x380800b6
Table 8 Command output
Interface that connects the subuser. |
IP address |
IP address of the subuser. |
MAC address |
MAC address of the subuser. |
SVLAN/CVLAN |
SVLAN and CVLAN of the subuser. If the subuser traffic does not carry a SVLAN or CVLAN tag, this field displays a hyphen (-) for the SVLAN or CVLAN part. |
User ID |
Subuser ID assigned after the subuser came online. If no subuser ID is assigned, this field displays 0xffffffff. |
# (In standalone mode.) Display detailed session information about the interface-leased subusers on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber interface-leased user interface gigabitethernet 3/1/1 verbose
Interface: Gigabitethernet 3/1/1
IP address : 100.1.1.3
MAC address : 0010-9400-0003
User ID : 0x380800b5
VPN instance : vpn1
VPI/VCI(for ATM) : -/-
DNS servers : N/A
DHCP lease : 86400 sec
DHCP remain lease : 86380 sec
Login time : May 9 08:56:29 2014
Type : DHCP
QoS:
IP address : 100::1
MAC address : 0010-9400-0004
User ID : 0x380800b6
VPN instance : vpn1
DNS servers : N/A
Login time : May 9 09:00:02 2014
Type : DHCP
QoS:
Table 9 Command output
IP address |
MAC address |
User ID |
VPN instance |
MPLS L3VPN instance of the subuser. If the subuser is not in a VPN, this field displays N/A. |
VPI/VCI(for ATM) |
ATM PVC information of the subuser. If the subuser traffic does not have PVC information, this field displays a hyphen (-). |
DNS servers |
DNS server addresses assigned to the subuser. · When the number of the assigned addresses is 0, this field displays N/A, which indicates no DNS server addresses are assigned. · When the number of the assigned addresses is 1 or 2, this field displays the actual DNS server addresses. · When the number of the assigned addresses is greater than 2, this field displays only the first two DNS server addresses. |
DHCP-authorized IP lease in seconds: · N/A—No IP lease is authorized. Unlimited—The IP lease is unlimited. |
Remaining DHCP-authorized IP lease in seconds. This field is displayed only on the card that connects the subuser. On other cards, this field displays N/A. |
Time when the subuser passed authentication and logged in, in the format of MM DD hh:mm:ss YYYY. |
Slot number and CPU number of the card that connects the subuser. |
Type |
Subuser type: · Unclassified-IP—Unclassified-IP subuser. · DHCP—DHCP subuser. · NDRS—IPv6 ND RS subuser. |
QoS |
QoS information. |
User profile |
User group ACL |
Use display ip subscriber interface-leased user ip-type to display interface-leased subuser session information of the specified IP protocol type.
In standalone mode:
display ip subscriber interface-leased user ip-type { ipv4 | ipv6 } [ interface interface-type interface-number [ mac mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ verbose ] [ slot slot-number ]
In IRF mode:
display ip subscriber interface-leased user ip-type { ipv4 | ipv6 } [ interface interface-type interface-number [ mac mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
ipv4: Specifies IPv4 interface-leased subusers.
ipv6: Specifies IPv6 interface-leased subusers.
verbose: Displays detailed session information about interface-leased subusers. If this keyword is not specified, this command displays brief session information about interface-leased subusers.
# Display brief session information about the IPv4 interface-leased subusers on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber interface-leased user ip-type interface gigabitethernet 3/1/1
<Sysname> display ip subscriber interface-leased user ip-type ipv4
Table 10 Command output
IP address |
MAC address |
SVLAN/CVLAN |
User ID |
# (In standalone mode.) Display detailed session information about the IPv4 interface-leased subusers on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber interface-leased user ip-type ipv4 interface gigabitethernet 3/1/1 verbose
VPN instance : vpn1
DNS servers : N/A
Type : DHCP
QoS:
Inbound user priority : N/A
Outbound user priority : N/A
Table 11 Command output
IP address |
MAC address |
User ID |
VPN instance |
Access interface |
VPI/VCI(for ATM) |
DNS servers |
DNS server addresses assigned to the subuser. · When the number of the assigned addresses is 0, this field displays N/A which indicates no DNS server addresses are assigned. · When the number of the assigned addresses is 1 or 2, this field displays the actual DNS server addresses. · When the number of the assigned addresses is greater than 2, this field displays only the first two DNS server addresses. |
DHCP lease |
DHCP remain lease |
Remaining DHCP-authorized IP lease in seconds. |
Login time |
Service node |
Type |
QoS |
QoS information. |
User profile |
User group ACL |
AAA-authorized inbound subuser priority, which can be a number in the range of 0 to 7, 15, and N/A. N/A or 15 means that no inbound subuser priority is authorized. The inbound subuser priority has the following states: · inactive—Inbound subuser priority is not authorized successfully. · active—Inbound subuser priority is authorized successfully. |
AAA-authorized outbound subuser priority, which can be a number in the range of 0 to 7, 15, and N/A. N/A or 15 means that no outbound subuser priority is authorized. The outbound subuser priority has the following states: · inactive—Outbound subuser priority is not authorized successfully. · active—Outbound subuser priority is authorized successfully. |
Use display ip subscriber l2vpn-leased to display L2VPN-leased user session information.
In standalone mode:
display ip subscriber l2vpn-leased [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display ip subscriber l2vpn-leased [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays L2VPN-leased user session information for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays L2VPN-leased user session information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays L2VPN-leased user session information for all cards. (In IRF mode.)
# (In standalone mode.) Display L2VPN-leased user session information on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber l2vpn-leased interface gigabitethernet 3/1/1
Basic:
VPN instance : N/A
Username : a
User ID : 0x30000000
State : Online
Domain : radius
AAA:
IP pool : N/A
IPv6 pool : N/A
Traffic quota : N/A
Dual-stack accounting mode : N/A
Max IPv4 multicast addresses: 0
Max IPv6 multicast addresses: 0
QoS:
Flow statistic:
ITA:
Acct merge : Enabled
Denied level : N/A
Outbound CAR : N/A
Traffic quota : N/A
Outbound CAR : N/A
Traffic quota : N/A
Table 12 Command output
Basic |
Access interface |
VPN instance |
MPLS L3VPN instance of the user. This field displays N/A for L2VPN-leased users because the users do not support MPLS L3VPN instances. |
Username |
User ID |
State |
Service node |
Domain |
Login time |
Failure reason |
AAA |
AAA authorization information of IPoE sessions. |
ITA policyname |
IP pool |
IP pool group |
IPv6 pool |
IPv6 pool group |
AAA-authorized primary IPv4 DNS server address. If no primary IPv4 DNS server address is authorized, this field displays N/A. |
AAA-authorized secondary IPv4 DNS server address. If no secondary IPv4 DNS server address is authorized, this field displays N/A. |
Session idle cut |
Period and traffic threshold for idle cut. If traffic does not reach the threshold in bytes within the period in seconds, the user is logged out. If the user can remain idle without being logged out, this field displays N/A. This field displays N/A for L2VPN-leased users because the users do not support idle cut. |
direction |
Session duration |
remaining |
Traffic quota |
Traffic remained |
This field displays N/A for L2VPN-leased users because the users do not support dual-stack accounting. |
User profile |
User group ACL |
Inbound CAR |
Outbound CAR |
Outbound CIR and PIR in kbps, and CBS in bytes: · N/A—Outbound CAR is not authorized. · inactive—Outbound CAR is not authorized successfully. · active—Outbound CAR is authorized successfully. |
Flow statistic |
This field displays the total number and size of uplink IPv4 packets because L2VPN-leased users do not support dual-stack accounting. |
This field displays the total number and size of downlink IPv4 packets because L2VPN interface-leased users do not support dual-stack accounting. |
Total number and size of downlink IPv6 packets . |
Acct merge |
Denied level |
Outbound CAR |
Traffic separate |
Use display ip subscriber l2vpn-leased statistics to display L2VPN-leased user session statistics.
In standalone mode:
display ip subscriber l2vpn-leased statistics [ domain domain-name ] [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display ip subscriber l2vpn-leased statistics [ domain domain-name ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays L2VPN-leased user session statistics for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays L2VPN-leased user session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays L2VPN-leased user session statistics for all cards. (In IRF mode.)
# Display L2VPN-leased user session statistics on the BRAS.
<Sysname> display ip subscriber l2vpn-leased statistics
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
Table 13 Command output
Total sessions |
Init |
Authenticating |
Authenticate fail |
Authenticate pass |
Assigned IP |
Online |
Backup |
Use display ip subscriber offline statistics to display offline statistics for IPoE user sessions.
display ip subscriber offline statistics [ bind | web [ pre-auth ] ] [ ip-type { ipv4 | ipv6 } ] [ interface interface-type interface-number ]
bind: Specifies the bind authentication method.
web: Specifies the Web authentication method and Web MAC authentication method.
pre-auth: Specifies the preauthentication before the Web authentication. If this keyword is not specified, this command displays offline statistics for IPoE user sessions in both the preauthentication and Web authentication phases.
ip-type: Specifies an IP protocol type. If this keyword is not specified, this command displays offline statistics for IPoE user sessions of all IP protocol types.
ipv4: Specifies the IPv4 IPoE user sessions.
ipv6: Specifies the IPv6 IPoE user sessions.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays offline statistics for IPoE user sessions for all interfaces.
Both the Web authentication process and the Web MAC authentication process include two phases: preauthentication and Web authentication.
If you do not specify an authentication method, this command displays offline statistics for IPoE user sessions using any authentication methods.
# Display offline statistics for IPoE user sessions on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber offline statistics interface gigabitethernet 3/1/1
IP-type : IPv4
Bind:
User request : 0
DHCP lease expire : 0
AAA lease expire : 0
Command cut : 80
AAA terminate : 0
Authorization fail : 0
Idle timeout : 10
Detect fail : 10
Not enough resource : 0
Interface down : 0
Interface shutdown : 0
VSRP event : 0
DHCP notify : 0
User Group notify : 0
NAT notify : 0
Other : 0
Web pre-auth:
Total sessions : 0
User request : 0
Command cut : 0
AAA terminate : 0
Idle timeout : 0
Detect fail : 0
Interface down : 0
VSRP event : 0
DHCP notify : 0
NAT notify : 0
Other : 0
Web:
Total sessions : 0
User request : 0
Command cut : 0
AAA terminate : 0
Idle timeout : 0
Detect fail : 0
Interface down : 0
VSRP event : 0
DHCP notify : 0
NAT notify : 0
Portal notify : 0
Other : 0
IP-type : IPv6
Bind:
User request : 0
Command cut : 80
AAA terminate : 0
Idle timeout : 10
Detect fail : 10
Interface down : 0
VSRP event : 0
DHCP notify : 0
NAT notify : 0
Other : 0
Web pre-auth:
Total sessions : 0
User request : 0
Command cut : 0
AAA terminate : 0
Idle timeout : 0
Detect fail : 0
Interface down : 0
VSRP event : 0
DHCP notify : 0
NAT notify : 0
Other : 0
Web:
Total sessions : 0
User request : 0
Command cut : 0
AAA terminate : 0
Idle timeout : 0
Detect fail : 0
Interface down : 0
VSRP event : 0
DHCP notify : 0
NAT notify : 0
Portal notify : 0
Other : 0
Table 14 Command output
IP-type |
IP protocol type: · IPv4—IPv4 IPoE user sessions. · IPv4—IPv6 IPoE user sessions. |
Bind |
Offline statistics for bind authentication. |
Web pre-auth |
Offline statistics in the Web preauthentication phase. |
Web |
Offline statistics in the Web authentication phase. |
Total sessions |
Total number of offline sessions. |
User request |
Number of sessions requesting to go offline. |
DHCP lease expire |
Number of sessions with expired DHCP leases. |
AAA lease expire |
Number of sessions with expired AAA leases. |
Command cut |
Number of sessions logged out by commands. |
AAA terminate |
Number of sessions logged out by AAA. |
Authenticate fail |
Number of sessions who failed authentication. |
Authorization fail |
Number of sessions who failed authorization. |
Idle timeout |
Number of sessions with an expired idle timeout timer. |
Detect fail |
Number of sessions who failed online detection. |
Not enough resource |
Number of sessions with insufficient hardware resources. |
Interface down |
Number of sessions on an interface that went down. |
Interface shutdown |
Number of sessions on an interface that was shut down. |
VSRP event |
Number of sessions disconnected by the VSRP event. This field is not supported in the current software version. |
DHCP notify |
Number of sessions disconnected by DHCP. |
User Group notify |
Number of sessions disconnected by the user group. |
NAT notify |
Number of sessions disconnected by NAT. |
Portal notify |
Number of sessions disconnected by portal. |
Other |
Number of sessions disconnected from the network because of unknown causes. |
Use display ip subscriber session to display IPoE individual session information.
In standalone mode:
display ip subscriber session [ interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ { { domain domain-name | mac mac-address | static | username name | auth-type { bind | web [ pre-auth | mac-auth | mac-trigger ] } } | ip-type { ipv4 | ipv6 | dual-stack } } * | { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ verbose ] [ slot slot-number ]
In IRF mode:
display ip subscriber session [ interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ { { domain domain-name | mac mac-address | static | username name | auth-type { bind | web [ pre-auth | mac-auth | mac-trigger ] } } | ip-type { ipv4 | ipv6 | dual-stack } } * | { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ verbose ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPoE individual session information for all interfaces.
s-vlan svlan-id: Specifies the service provider VLAN ID of an IPoE dynamic individual session. The value range for the svlan-id argument is 1 to 4094.
c-vlan cvlan-id: Specifies the customer VLAN ID of an IPoE dynamic individual session. The value range for the cvlan-id argument is 1 to 4094.
vxlan vxlan-id: Specifies the VXLAN ID of an IPoE individual session. The value range for the vxlan-id argument is 0 to 16777215.
mac mac-address: Specifies the MAC address of an IPoE individual session, in the format of H-H-H.
static: Specifies IPoE static sessions. If this keyword is not specified, this command displays information about static and dynamic individual sessions.
username name: Specifies a username for authentication, a case-sensitive string of 1 to 255 characters.
auth-type: Specifies an authentication type for IPoE individual users.
web: Specifies the Web authentication method. If none of the pre-auth, mac-auth, and mac-trigger keywords is specified, this command displays information about all IPoE individual sessions during the Web authentication phase of all Web authentication methods (including common Web authentication, Web MAC authentication, and MAC-trigger authentication).
pre-auth: Specifies the preauthentication phase.
mac-auth: Specifies the Web authentication phase of Web MAC authentication.
mac-trigger: Specifies the Web authentication phase of MAC-trigger authentication.
ip-type: Specifies an IP protocol type for IPoE individual users.
ipv4: Specifies the IPv4 IPoE individual sessions.
ipv6: Specifies the IPv6 IPoE individual sessions.
dual-stack: Specifies the dual-stack IPoE individual sessions.
ip ipv4-address: Specifies the source IPv4 address of an IPoE individual session.
ip ipv6-address: Specifies the source IPv6 address of an IPoE individual session.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPoE individual session information on the public network.
verbose: Displays detailed IPoE individual session information. If this keyword is not specified, this command displays brief session information.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays IPoE individual session information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPoE individual session information for all cards. (In IRF mode.)
# Display brief IPoE individual session information on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber session interface gigabitethernet 3/1/1
Interface IP address MAC address Type State
IPv6 address SVLAN/CVLAN VXLAN
Username
GE3/1/1 1.1.1.1 000d-88f8-0eab D/U Online
1::1 -/- -
User1
GE3/1/1 1.1.1.2 001d-88f8-0eab D/U Online
1::2 -/- -
User2
Table 15 Command output
Username |
IP address |
IPv4 address of the user. A hyphen (-) indicates that no IPv4 user is online. |
IPv6 address |
IPv6 address of the user. A hyphen (-) indicates that no IPv6 user is online. For an ND RS user that comes online through prefix authorization by an ND prefix pool, this field displays the IPv6 ND prefix in the brief information and is not displayed in the detailed information. |
MAC address |
SVLAN/CVLAN |
Type |
VXLAN |
VXLAN ID of the user. A hyphen (-) indicates that the user has no VXLAN information. |
state |
# (ITA) (In standalone mode.) Display detailed IPoE individual session information.
<Sysname> display ip subscriber session verbose
Basic:
Description : -
Username : abc
Domain : radius
VPN instance : vpn1
IPv6 address : 1::1
User address type : private-ipv4
VSI Index : -
VSI link ID : -
VXLAN ID : -
DNS servers : N/A
IPv6 DNS servers : N/A
DHCP lease : N/A
DHCP remain lease : N/A
DHCPv6 lease : N/A
DHCPv6 remain lease : N/A
Access time : May 9 08:56:29 2014
Authentication type : Bind
IPv4 access type : DHCP
IPv6 access type : DHCP
IPv4 detect state : N/A
IPv6 detect state : N/A
State : Online
AAA:
IP pool : N/A
IPv6 pool : N/A
Traffic quota : N/A
Max IPv4 multicast addresses: 4
Max IPv6 multicast addresses: 4
Accounting start time : May 9 08:56:29 2014
Subscriber ID : -
QoS:
NAT:
Global IP address : 111.8.0.234
Port block : 1024-1033
Extended port block : 2024-2033/3024-3033/4024-4033/5024-5033/6024-6033
Flow statistic:
ITA:
Denied level : None
Outbound CAR : N/A
Traffic quota : N/A
Outbound CAR : N/A
Traffic quota : N/A
# (EDSG) (In standalone mode.) Display detailed IPoE individual session information.
Basic:
Description : -
Username : abc
Domain : radius
VPN instance : vpn1
IPv6 address : 1::1
VSI Index : -
VSI link ID : -
VXLAN ID : -
DNS servers : N/A
DHCP lease : N/A
DHCPv6 lease : N/A
State : Online
AAA:
ITA policy name : N/A
IP pool : N/A
IPv6 pool : N/A
Traffic quota : N/A
Subscriber ID : -
QoS:
NAT:
Flow statistic:
Service policy: s2m
Service ID : 1
Username(EDSG) : 200.1.1.1
Service rate-limit mode : Merge
Traffic statistics mode : Separate
Dual-stack rate limit mode : Merge
Traffic quota : N/A
Quota-out action : Service deactivate
Priority : 0
Inbound CAR : CIR 1000kbps PIR 2000kbps CBS 4100bytes EBS 200bytes (active)
Outbound CAR : CIR 1000kbps PIR 2000kbps CBS 4100bytes EBS 200bytes (active)
Table 16 Command output
Basic |
Description of the session. A hyphen (-) indicates that the session has no description. |
Username |
Domain |
ISP domain of the user. |
VPN instance |
IP address |
IP address of the user. For dynamic individual sessions, this field is displayed for only online IPv4 users. For static individual sessions, this field is displayed depending on the configuration. |
IPv6 address |
IPv6 address of the user. For dynamic individual sessions, this field is displayed for only online IPv6 users. For static individual sessions, this field is displayed depending on the configuration. For an ND RS user that comes online through prefix authorization by an ND prefix pool, this field displays the IPv6 ND prefix in the brief information and is not displayed in the detailed information. |
IPv6 ND Prefix |
IPv6 ND prefix of the user. This field is displayed only for an ND RS user that comes online through prefix authorization by an ND prefix pool. |
IPv6 PD Prefix |
IPv6 prefix binding information. This field is displayed only when DHCPv6 is used to create prefix binding information for the allocated prefix. |
User address type |
AAA-authorized user address type: · private-ds—Private dual-stack address. · private-ipv4—Private IPv4 address. · public-ds—Public dual-stack address. · public-ipv4—Public IPv4 address. · ds-lite—Lite dual-stack address. · ipv6—IPv6 address. · nat64—NAT64 address. · N/A—If no IPv4 user address type is authorized, this field displays N/A. |
MAC address |
Access interface |
User ID |
VPI/VCI(for ATM) |
ATM PVC information of the user. If the user traffic does not have PVC information, this field displays a hyphen (-). |
VSI Index |
VSI ID. |
DNS servers |
DNS server addresses assigned to the user. · When the number of the assigned addresses is 0, this field displays N/A which indicates no DNS server addresses are assigned. · When the number of the assigned addresses is 1 or 2, this field displays the actual DNS server addresses. · When the number of the assigned addresses is greater than 2, this field displays only the first two DNS server addresses. |
IPv6 DNS servers |
IPv6 DNS server addresses assigned to the user. · When the number of the assigned addresses is 0, this field displays N/A which indicates no IPv6 DNS server addresses are assigned. · When the number of the assigned addresses is 1 or 2, this field displays the actual IPv6 DNS server addresses. · When the number of the assigned addresses is greater than 2, this field displays only the first two IPv6 DNS server addresses. |
DHCP lease |
DHCPv4-authorized IP lease in seconds: · N/A—No IP lease is authorized. · Unlimited—The IP lease is unlimited. |
DHCP remain lease |
Remaining DHCPv4-authorized IP lease in seconds. This field is displayed only on the card that connects the user. On other cards, this field displays N/A. |
DHCPv6 lease |
DHCPv6-authorized IP lease in seconds: · N/A—No IP lease is authorized. · Unlimited—The IP lease is unlimited. |
DHCPv6 remain lease |
Remaining DHCPv6-authorized IP lease in seconds. This field is displayed only on the card that connects the user. On other cards, this field displays N/A. |
Access time |
Time when a DHCP user obtained the DHCP allocated IP address, or time when a non-DHCP user passed authentication and logged in. |
Failure reason |
Service node |
Authentication type |
Authentication types: · Bind—Bind authentication. · Web pre-auth—Preauthentication before Web authentication. · Web—Common Web authentication. · Web mac-auth—Web MAC authentication. · Web mac-trigger—MAC-trigger authentication. |
IPv4 access type |
IPv4 IPoE individual session initiation method: · DHCP—DHCP packet initiation. · Unclassified-IP—Unclassified-IP packet initiation. · Static—Static configuration. For dynamic individual sessions, this field is displayed for only online IPv4 users. For static individual sessions, this field is always displayed. |
IPv6 access type |
IPv6 IPoE individual session initiation method: · DHCP—DHCP packet initiation. · Unclassified-IP—Unclassified-IP packet initiation. · Static—Static configuration. · NDRS—IPv6 ND RS packet initiation. For dynamic individual sessions, this field is displayed for only online IPv6 users. For static individual sessions, this field is always displayed. |
IPv4 detect state |
IPv4 IPoE detection state: · Detecting—Detecting. · Failed—Detection failed. · N/A—Detection is not performed. For dynamic individual sessions, this field is displayed for only online IPv4 users. For static individual sessions, this field is displayed is always displayed. |
IPv6 detect state |
IPv6 IPoE detection state: · Detecting—Detecting.. · Failed—Detection failed. · N/A—Detection is not performed. For dynamic individual sessions, this field is displayed for only online IPv6 users. For static individual sessions, this field is displayed is always displayed. |
State |
AAA |
ITA policy name |
IP pool |
IP pool group |
IPv6 pool |
IPv6 pool group |
Session idle cut |
direction |
Session duration |
remaining |
Traffic quota |
Traffic remained |
Accounting start time |
Time when the accounting starts. |
Redirect URL |
This field is displayed only for Web authentication. If no URL is authorized or users cannot be redirected to the authorized URL, this field displays N/A. · In the Web preauthentication phase, this field indicates the authorized Web server URL. · In the Web authentication phase, this field indicates the authorized redirect URL, which pushes a Web page to users. For example, the redirect URL can push an advertisement or notification page to a user that accesses the network for the first time after passing authentication. |
Subscriber ID |
Subscriber ID authorized to the user. If no subscriber ID is authorized, this field displays a hyphen (-). |
QoS |
QoS information. |
User profile |
User group ACL |
Inbound CAR |
Outbound CAR |
NAT |
Session NAT information. This field is available only for IPoE-NAT collaboration. |
Global IP address |
Public network IP address. |
Port block |
Port block in the format of start port number-end port number. |
Extended port block |
Extended port block, which contains multiple port blocks in the format of start port number-end port number. These port blocks are separated by using slashes (/). This field is displayed only when dynamic port block mapping is used and extended port blocks are configured. |
Flow statistic |
ITA |
ITA information. |
Acct merge |
Denied level |
Outbound CAR |
Traffic separate |
Service policy |
Name of the EDSG service policy. |
Service ID |
ID of the EDSG service policy. |
Username (EDSG) |
Username for EDSG service authentication. |
Service rate-limit mode |
Traffic rate limit mode of the EDSG service: · Merge—Performs rate limit on EDSG service traffic and common service traffic, and preferentially forwards the EDSG service. · Separate—Performs rate limit on EDSG service traffic independently without affecting the bandwidth of common service traffic. |
Traffic statistics mode |
Traffic statistics mode of the EDSG service: · Merge—Counts EDSG service traffic and common service traffic as a whole in the total user traffic. · Separate—Counts EDSG service traffic and common service traffic separately, and excludes EDSG service traffic in the total user traffic. |
Dual-stack rate limit mode |
Traffic rate limit mode of the EDSG dual-stack service: · Merge—Merges IPv4 traffic and IPv6 traffic and performs rate limit on them as a whole. · Separate—Performs rate limit on IPv4 traffic and IPv6 traffic separately. |
Session duration |
AAA-authorized EDSG session duration in seconds: · N/A—No EDSG session duration is authorized. · Unlimited—The EDSG session duration is unlimited. |
Quota-out action |
Actions to take after the traffic quota is exhausted: · Service deactivate—Deactivates the service. Only this action is supported in the current software version. · Redirect—Redirects packets. · Flow drop—Drops packets. · Flow forward—Forwards packets. |
Priority |
EDSG service priority in the range of 0 to 7. The bigger the number, the higher the priority. In the current software version, the EDSG service priority is fixed at 0. |
Use display ip subscriber session statistics to display IPoE individual session statistics.
In standalone mode:
display ip subscriber session statistics [ bind [ session-type { dhcp | dhcpv6 | ndrs | static | unclassified-ip | unclassified-ipv6 } ] | web [ pre-auth | mac-auth | mac-trigger ] ] [ domain domain-name ] [ interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ slot slot-number ]
In IRF mode:
display ip subscriber session statistics [ bind [ session-type { dhcp | dhcpv6 | ndrs | static | unclassified-ip | unclassified-ipv6 } ] | web [ pre-auth | mac-auth | mac-trigger ] ] [ domain domain-name ] [ interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ chassis chassis-number slot slot-number ]
session-type: Specifies a user type. If you do not specify a user type, this command displays session statistics for all types of IPoE individual sessions.
static: Specifies static users.
web: Specifies the Web authentication method. If none of the pre-auth, mac-auth, and mac-trigger keywords is specified, this command displays all IPoE individual session statistics during the preauthentication phase or Web authentication phase of all Web authentication methods (including common Web authentication, Web MAC authentication, and MAC-trigger authentication).
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPoE individual session statistics for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays IPoE individual session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPoE individual session statistics for all cards. (In IRF mode.)
Both the Web authentication process and Web MAC authentication process include two phases: preauthentication and Web authentication.
If you do not specify an authentication method, this command displays IPoE individual session statistics of any authentication methods.
# Display IPoE individual session statistics on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber session statistics interface gigabitethernet 3/1/1
Bind:
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
Web pre-auth:
Init : 0
Authenticating : 0
Authenticate pass : 0
Assigned IP : 0
Online : 0
Backup : 0
Web:
Init : 0
Authenticating : 0
Assigned IP : 0
Online : 0
Backup : 0
# Display IPoE individual session statistics during the Web authentication phase of Web MAC authentication.
<Sysname> display ip subscriber session statistics web mac-auth
Web mac-auth:
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
# Display IPoE individual session statistics during the Web authentication phase of MAC-trigger authentication.
<Sysname> display ip subscriber session statistics web mac-trigger
Web mac-trigger:
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
Table 17 Command output
Total sessions |
Total number of individual sessions on the interface. |
Bind |
Individual session statistics for bind authentication. |
Web pre-auth |
Individual session statistics in the Web preauthentication phase. |
Web |
Individual session statistics in the Web authentication phase of all Web authentication methods. |
Web mac-auth |
Individual session statistics in the Web authentication phase of Web MAC authentication. |
Web mac-trigger |
Individual session statistics in the Web authentication phase of MAC-trigger authentication. |
Init |
Number of individual sessions being initiated. |
Authenticating |
Number of individual sessions being authenticated. |
Authenticate fail |
Number of individual sessions who failed authentication. |
Authenticate pass |
Number of individual sessions who passed authentication. |
Assigned IP |
Number of individual sessions who have IP addresses. |
Online |
Number of online individual sessions. |
Backup |
Number of individual sessions whose information was backed up. |
reset ip subscriber session
display ip subscriber session statistics ip-type
Use display ip subscriber session statistics ip-type to display IPoE individual session statistics of the specified IP protocol type.
In standalone mode:
display ip subscriber session statistics ip-type { ipv4 | ipv6 | dual-stack } [ bind | web [ pre-auth | mac-auth | mac-trigger ] ] [ domain domain-name ] [ interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ slot slot-number ]
In IRF mode:
display ip subscriber session statistics ip-type { ipv4 | ipv6 | dual-stack } [ bind | web [ pre-auth | mac-auth | mac-trigger ] ] [ domain domain-name ] [ interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ chassis chassis-number slot slot-number ]
ipv4: Displays IPv4 IPoE individual session statistics.
ipv6: Displays IPv6 IPoE individual session statistics.
dual-stack: Displays dual-stack IPoE individual session statistics.
# Display IPv4 IPoE individual session statistics on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber session statistics ip-type ipv4 interface gigabitethernet 3/1/1
Bind:
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
Web pre-auth:
Init : 0
Authenticating : 0
Assigned IP : 0
Online : 0
Backup : 0
Web:
Init : 0
Authenticating : 0
Assigned IP : 0
Online : 0
Backup : 0
# Display IPv4 IPoE individual session statistics during the Web authentication phase of Web MAC authentication.
<Sysname> display ip subscriber session statistics ip-type ipv4 web mac-auth
Web mac-auth:
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
# Display IPv4 IPoE individual session statistics during the Web authentication phase of MAC-trigger authentication.
<Sysname> display ip subscriber session statistics ip-type ipv4 web mac-trigger
Web mac-trigger:
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
Table 18 Command output
Total sessions |
Bind |
Web pre-auth |
Web |
Web mac-auth |
Web mac-trigger |
Init |
Authenticating |
Authenticate fail |
Authenticate pass |
Assigned IP |
Online |
Backup |
reset ip subscriber session ip-type
display ip subscriber subnet-leased
Use display ip subscriber subnet-leased to display IPoE subnet-leased user session information.
In standalone mode:
display ip subscriber subnet-leased [ interface interface-type interface-number ] [ ip ipv4-address mask-length | ipv6 ipv6-address prefix-length | ip-type { ipv4 | ipv6 } ] [ slot slot-number ]
In IRF mode:
display ip subscriber subnet-leased [ interface interface-type interface-number ] [ ip ipv4-address mask-length | ipv6 ipv6-address prefix-length | ip-type { ipv4 | ipv6 } ] [ chassis chassis-number slot slot-number ]
ip ipv4-address mask-length: Specifies an IPv4 subnet by an IPv4 address and a mask length in the range of 1 to 31.
ipv6 ipv6-address prefix-length: Specifies an IPv6 subnet by an IPv6 address and a prefix length in the range of 1 to 127.
ipv4: Specifies the IPv4 IPoE subnet-leased users.
ipv6: Specifies the IPv6 IPoE subnet-leased users.
# (In standalone mode.) Display IPoE subnet-leased user session information on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber subnet-leased interface gigabitethernet 3/1/1
Basic:
Access interface : GE3/1/1
VPN instance : N/A
Username : a
Network : 11.11.11.0/24
User ID : 0x30060001
State : Online
Domain : radius
Login time : May 14 20:08:35 2014
AAA:
IP pool : N/A
Traffic quota : N/A
QoS:
User profile : cc (active)
Flow statistic:
ITA:
Denied level : None
Outbound CAR : N/A
Traffic quota : N/A
Outbound CAR : N/A
Traffic quota : N/A
Basic:
VPN instance : N/A
Username : a
Network : 11::/64
User ID : 0x30040002
State : Online
Domain : radius
AAA:
IPv6 pool : N/A
Traffic quota : N/A
QoS:
Flow statistic:
ITA:
Denied level : None
Outbound CAR : N/A
Traffic quota : N/A
Outbound CAR : N/A
Traffic quota : N/A
Table 19 Command output
Basic |
Access interface |
Interface that connects the user. |
VPN instance |
Username |
Network |
Subnet of the user. |
User ID |
State |
Service node |
Domain |
Login time |
IPv4 total users |
Total number of IPv4 subnet-leased subusers. |
IPv6 total users |
Total number of IPv6 subnet-leased subusers. |
Failure reason |
AAA |
ITA policy name |
IP pool |
IP pool group |
IPv6 pool |
IPv6 pool group |
Session idle cut |
direction |
Session duration |
remaining |
Traffic quota |
Traffic remained |
This field displays N/A for subnet-leased users because the users do not support dual-stack accounting. |
QoS |
QoS information. |
User profile |
Name of the AAA-authorized user profile. N/A means that no user profile is authorized. The user profile has the following states: · inactive—User profile authorization failed or the user profile does not exist on the BRAS. · active—The user profile is authorized successfully. · N/A—On a CP in IPoE session entry control mode, the authorized user profile is insignificant. The state of the user profile is always displayed as N/A. If the authorization result has not been updated, nothing is displayed. |
Name of the AAA-authorized session group profile. N/A means that no session group profile is authorized. The session group profile has the following states: · inactive—Session group profile authorization failed or the session group profile does not exist on the BRAS. · active—The session group profile is authorized successfully. · N/A—On a CP in IPoE session entry control mode, the authorized session group profile is insignificant. The state of the session group profile is always displayed as N/A. If the authorization result has not been updated, nothing is displayed. |
User group ACL |
Name of the AAA-authorized user group ACL. N/A means that no user group ACL is authorized. The user group ACL has the following states: · active—The user group ACL is authorized successfully. · inactive—User group ACL authorization failed or the user group ACL does not exist on the BRAS. · N/A—On a CP in IPoE session entry control mode, the authorized user group ACL is insignificant. The state of the user group ACL is always displayed as N/A. If the authorization result has not been updated, nothing is displayed. |
Inbound CAR |
Inbound CIR and PIR in kbps, and CBS in bytes. N/A means that no inbound CAR is authorized. The inbound CAR has the following states: · inactive—Inbound CAR is not authorized successfully. · active—Inbound CAR is authorized successfully. · N/A—On a CP in IPoE session entry control mode, the authorized inbound CAR is insignificant. The state of the inbound CAR is always displayed as N/A. |
Outbound CAR |
Outbound CIR and PIR in kbps, and CBS in bytes. N/A means that no outbound CAR is authorized. The outbound CAR has the following states: · inactive—Outbound CAR is not authorized successfully. · active—Outbound CAR is authorized successfully. · N/A—On a CP in IPoE session entry control mode, the authorized outbound CAR is insignificant. The state of the outbound CAR is always displayed as N/A. |
AAA-authorized inbound user priority, which can be a number in the range of 0 to 7, 15, and N/A. N/A or 15 means that no inbound user priority is authorized. The inbound user priority has the following states: · inactive—Inbound user priority is not authorized successfully. · active—Inbound user priority is authorized successfully. · N/A—On a CP in IPoE session entry control mode, the authorized inbound user priority is insignificant. The state of the inbound user priority is always displayed as N/A. |
AAA-authorized outbound user priority, which can be a number in the range of 0 to 7, 15, and N/A. N/A or 15 means that no outbound user priority is authorized. The outbound user priority has the following states: · inactive—Outbound user priority is not authorized successfully. · active—Outbound user priority is authorized successfully. · N/A—On a CP in IPoE session entry control mode, the authorized outbound user priority is insignificant. The state of the outbound user priority is always displayed as N/A. |
Flow statistic |
This field displays the total number and size of uplink IPv4 packets because subnet-leased users do not support dual-stack accounting. |
This field displays the total number and size of downlink IPv4 packets because subnet-leased users do not support dual-stack accounting. |
ITA |
ITA information. |
Acct merge |
Denied level |
Outbound CAR |
Traffic separate |
display ip subscriber subnet-leased statistics
Use display ip subscriber subnet-leased statistics to display IPoE subnet-leased user session statistics.
In standalone mode:
display ip subscriber subnet-leased statistics [ domain domain-name ] [ ip-type { ipv4 | ipv6 } ] [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display ip subscriber subnet-leased statistics [ domain domain-name ] [ ip-type { ipv4 | ipv6 } ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
ip-type: Specifies an IP protocol type. If this keyword is not specified, this command displays statistics of all IP protocol types.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays statistics for all cards. (In IRF mode.)
# Display IPoE subnet-leased user session statistics on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber subnet-leased statistics interface gigabitethernet 3/1/1
IP-type : IPv4
Total sessions : 1
Bind:
Init : 1
Authenticating : 0
Assigned IP : 0
Online : 0
Backup : 0
IP-type : IPv6
Total sessions : 1
Bind:
Init : 1
Authenticating : 0
Assigned IP : 0
Online : 0
Backup : 0
Table 20 Command output
IP-type |
IP protocol type: · IPv4—IPv4 IPoE subnet-leased users. · IPv6—IPv6 IPoE subnet-leased users. |
Total sessions |
Total number of IPoE subnet-leased user sessions. |
Bind |
Subnet-leased user session statistics for bind authentication. |
Init |
Number of sessions being initiated. |
Authenticating |
Authenticate fail |
Authenticate pass |
Number of sessions who passed authentication. |
Assigned IP |
Number of sessions who have IP addresses. |
Online |
Backup |
display ip subscriber subnet-leased user
Use display ip subscriber interface-leased user to display IPoE subnet-leased subuser session information.
In standalone mode:
display ip subscriber subnet-leased user [ interface interface-type interface-number [ ip { ipv4-address mask-length | ipv4-address } | ipv6 { ipv6-address prefix-length | ipv6-address } | s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ verbose ] [ slot slot-number ]
In IRF mode:
display ip subscriber subnet-leased user [ interface interface-type interface-number [ ip { ipv4-address mask-length | ipv4-address } | ipv6 { ipv6-address prefix-length | ipv6-address } | s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information for all interfaces.
ip ipv4-address: Specifies the source IPv4 address of a subnet-leased subuser.
ipv6 ipv6-address: Specifies the source IPv6 address of a subnet-leased subuser.
s-vlan svlan-id: Specifies the service provider VLAN ID of a subnet-leased subuser. The value range for the svlan-id argument is 1 to 4094.
c-vlan cvlan-id: Specifies the customer VLAN ID of a subnet-leased subuser. The value range for the cvlan-id argument is 1 to 4094.
vxlan vxlan-id: Specifies the VXLAN ID of a subnet-leased subuser. The value range for the vxlan-id argument is 0 to 16777215.
verbose: Displays detailed information of subnet-leased subusers. If this keyword is not specified, this command displays brief information.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for all cards. (In IRF mode.)
# Display brief session information about IPoE subnet-leased subusers on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber subnet-leased user interface gigabitethernet 3/1/1
GE3/1/1 100::4 0010-9400-0004 -/- 0x380800b6
Table 21 Command output
IP address |
MAC address |
SVLAN/CVLAN |
User ID |
# (In standalone mode.) Display detailed session information about the IPoE subnet-leased subusers on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber subnet-leased user interface gigabitethernet 3/1/1 verbose
VPN instance : vpn1
Service-VLAN/Customer-VLAN : -/-
DNS servers : N/A
DHCP lease : N/A
Service node : Slot 3 CPU 0
Type : Unclassified-IP
QoS:
User profile : abc (active)
Session group profile : N/A
User group ACL : N/A
Inbound user priority : 1 (active)
Outbound user priority : 1 (active)
IP address : 100::4
VPN instance : vpn1
Service-VLAN/Customer-VLAN : 100/-
DNS servers : N/A
DHCP lease : N/A
QoS:
Table 22 Command output
IP address |
MAC address |
User ID |
VPN instance |
Service-VLAN/Customer-VLAN |
Access interface |
VPI/VCI(for ATM) |
DNS servers |
DHCP lease |
DHCP-authorized IP lease in seconds: · N/A—No IP lease is authorized. · Unlimited—The IP lease is unlimited. |
DHCP remain lease |
Remaining DHCP-authorized IP lease. This field is displayed only on the card that connects the subuser. On other cards, this field displays N/A. |
Login time |
Service node |
Type |
Subuser type. The value of Unclassified-IP indicates that the subuser is an unclassified-IP subuser. |
QoS |
QoS information. |
User profile |
User group ACL |
display ip subscriber subnet-leased user ip-type
Use display ip subscriber interface-leased user ip-type to display IPoE subnet-leased subuser session information of the specified IP protocol type.
In standalone mode:
display ip subscriber subnet-leased user ip-type { ipv4 | ipv6 } [ interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ verbose ] [ slot slot-number ]
In IRF mode:
display ip subscriber subnet-leased user ip-type { ipv4 | ipv6 } [ interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
ipv4: Specifies IPv4 IPoE subnet-leased subusers.
ipv6: Specifies IPv6 IPoE subnet-leased subusers.
# Display brief session information about IPv4 IPoE subnet-leased subusers on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber subnet-leased user ip-type ipv4 interface gigabitethernet 3/1/1
GE3/1/1 100.1.1.4 0010-9400-0004 -/- 0x380800b6
Table 23 Command output
IP address |
MAC address |
SVLAN/CVLAN |
User ID |
# (In standalone mode.) Display detailed session information about the IPv4 IPoE subnet-leased subusers on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber subnet-leased user ip-type ipv4 interface gigabitethernet 3/1/1 verbose
VPN instance : vpn1
DNS servers : N/A
DHCP lease : N/A
QoS:
Table 24 Command output
IP address |
MAC address |
User ID |
VPN instance |
Access interface |
VPI/VCI(for ATM) |
DNS servers |
DHCP lease |
DHCP remain lease |
Login time |
Service node |
Type |
QoS |
QoS information. |
User profile |
Name of the AAA-authorized user profile. N/A means that no user profile is authorized. The user profile has the following states: · inactive—User profile authorization failed or the user profile does not exist on the BRAS. · active—The user profile is authorized successfully. If the authorization result has not been updated, nothing is displayed. |
Session group profile |
Name of the AAA-authorized session group profile. N/A means that no session group profile is authorized. The session group profile has the following states: · inactive—Session group profile authorization failed or the session group profile does not exist on the BRAS. · active—The session group profile is authorized successfully. If the authorization result has not been updated, nothing is displayed. |
User group ACL |
Name of the AAA-authorized user group ACL. N/A means that no user group ACL is authorized. The user group ACL has the following states: · active—The user group ACL is authorized successfully. · inactive—User group ACL authorization failed or the user group ACL does not exist on the BRAS. If the authorization result has not been updated, nothing is displayed. |
Inbound user priority |
display ip subscriber tcp-connection
Use display ip subscriber tcp-connection to display the number of TCP connections established by IPoE users.
display ip subscriber tcp-connection interface interface-type interface-number session-id session-id
session-id session-id: Specifies a session by its ID in the range of 1 to ffffffff.
# Display the number of TCP connections established by users with session ID 1 on GigabitEthernet 3/1/1.
<Sysname> display ip subscriber tcp-connection interface gigabitethernet 3/1/1 session-id 1
Total uplink TCP connections: 0
Total downlink TCP connections: 0
Table 25 Command output
Total uplink TCP connections |
Total number of uplink TCP connections established by IPoE users. |
Total downlink TCP connections |
Total number of downlink TCP connections established by IPoE users. |
display trace access-user
Use display trace access-user to display service tracing object configuration information.
display trace access-user [ object object-id ]
object object-id: Specifies a service tracing object by its ID, in the range of 1 to 5. If you do not specify a tracing object, this command displays configuration information for all service tracing objects.
This command displays configuration information for only service tracing objects whose tracing time has not expired.
# Display configuration information for service tracing object 1.
<Sysname> display trace access-user object 1
Object ID: 1
Access mode: IPoE
User name: aaa
Access interface: GigabitEthernet3/1/1.1
IP address: 1.1.1.2
MAC address: 0001-0002-0003
Service VLAN: 3
Customer VLAN: 2
Output direction: VTY
Aging time: 0 min
Table 26 Command output
Object ID |
ID of the service tracing object. |
Access mode |
Access mode of the service tracing object. |
User name |
Username of the access user. |
Access interface |
Access interface of the access user. |
IP address |
IP address of the access user. |
MAC address |
MAC address of the access user. |
Service VLAN |
Outer VLAN ID of the access user. |
Customer VLAN |
Inner VLAN ID of the access user. |
Output direction |
Location to which the service tracing object information is output. |
Aging time |
Tracing time of the service tracing object. |
trace access-user
ip subscriber 8021p
Use ip subscriber 8021p to bind an ISP domain to IPoE users who send IP packets with the specified 802.1p values.
Use undo ip subscriber 8021p to remove the binding between an ISP domain and IPoE users who send IP packets with the specified 802.1p values.
ip subscriber 8021p 8021p-list domain domain-name
undo ip subscriber 8021p 8021p-list
No ISP domain is bound to IPoE users who send IP packets with the specified 802.1p values.
L3VE subinterface view
8021p-list: Specifies a space-separated list of up to eight 802.1p value items. Each item specifies a 802.1p value or a range of 802.1p values in the form of start-802.1p-value to end-802.1p-value. The 802.1p value is in the range of 0 to 7.
domain domain-name: Specifies an ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
For this command, IPoE users include DHCP users, unclassified-IP users, and static individual users.
For the ip subscriber 8021p command to take effect, you must first execute the ip subscriber service-identify 8021p command to configure the 802.1p priority as the service identifier.
For how an authentication domain is selected for a DHCP user, see the ip subscriber dhcp domain command.
For how an authentication domain is selected for an unclassified-IP user, see the ip subscriber unclassified-ip domain command.
For how an authentication domain is selected for a static IPoE user, see the ip subscriber session static command.
For how an authentication domain is selected for an IPoE subnet-leased user, see the ip subscriber subnet-leased command.
For how an authentication domain is selected for an IPoE interface-leased user, see the ip subscriber interface-leased command.
For how an authentication domain is selected for an IPoE L2VPN-leased user, see the ip subscriber l2vpn-leased command.
# Configure ISP domain 1pdm for IPoE users who send IP packets with 802.1p values 2 to 5 on GigabitEthernet 3/1/1.100.
[Sysname] interface gigabitethernet 3/1/1.100
[Sysname-GigabitEthernet3/1/1.100] ip subscriber service-identify 8021p second-vlan
[Sysname-GigabitEthernet3/1/1.100] ip subscriber 8021p 2 to 5 domain 1pdm
ip subscriber access-block
Use ip subscriber access-block to forbid IPoE users from coming online.
Use undo ip subscriber access-block to restore the default.
In standalone mode:
ip subscriber access-block [ interface interface-type interface-number | slot slot-number ]
undo ip subscriber access-block [ interface interface-type interface-number | slot slot-number ]
In IRF mode:
ip subscriber access-block [ interface interface-type interface-number | chassis chassis-number slot slot-number ]
undo ip subscriber access-block [ interface interface-type interface-number | chassis chassis-number slot slot-number ]
IPoE users are allowed to come online.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
With this command configured, the device directly drops received online request packets of IPoE users to forbid new IPoE users from coming online through this interface.
This command does not affect existing IPoE users, including IPoE Web users in online state during the preauthentication phase.
If you do not specify any parameter for this command, this command forbids all new IPoE users from coming online.
# Forbid IPoE users on interface GigabitEthernet 3/1/1 from coming online.
[Sysname] ip subscriber access-block interface gigabitethernet 3/1/1
ip subscriber access-delay
Use ip subscriber access-delay to set the response delay time for IPoE users on an interface.
Use undo ip subscriber access-delay to restore the default.
ip subscriber access-delay delay-time [ even-mac | odd-mac ]
No response delay time is set for IPoE users on an interface.
Layer 3 aggregate interface/subinterface view
Layer 3 Ethernet interface/subinterface view
L3VE interface/subinterface view
delay-time: Specifies the response delay time for IPoE users, in the range of 10 to 25500 milliseconds.
even-mac: Specifies users with even MAC addresses.
odd-mac: Specifies users with odd MAC addresses.
With this command configured, the system delays response to the IPoE user online requests according to the configured delay time.
You can separately specify different response delay times for even-MAC users and odd-MAC users.
If you do not specify any keyword, this command sets the response delay time for all users that come online through this interface.
If you first configure this command with the even-mac or odd-mac keyword specified and then configure this command without specifying any keyword, the latter configuration takes effect, and vice versa.
This command takes effect only on IPoE users on interfaces in Layer 2 access mode. More specifically:
· On an interface using bind authentication, this command takes effect only on IPoE individual users and leased subusers.
· On an interface using Web authentication, this command takes effect only on users in the preauthentication phase and does not take effect on users in the Web authentication phase.
# Set the response delay time for IPoE users to 1000 milliseconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber access-delay 1000
ip subscriber access-line-id circuit-id trans-format
Use ip subscriber access-line-id circuit-id trans-format command to configure the IPoE parsing format for the circuit ID in the DHCP option.
Use undo ip subscriber access-line-id circuit-id trans-format to restore the default.
ip subscriber access-line-id circuit-id trans-format { ascii | hex }
The IPoE parsing format for the circuit ID in the DHCP option is ASCII.
ascii: Specifies the ASCII parsing format.
hex: Specifies the hex parsing format.
For IPoE to correctly parse information in the circuit ID, use this command to set a proper parsing format according to the format of the circuit ID information sent by downstream devices.
The ip subscriber access-line-id circuit-id trans-format command configuration takes effect only after the ip subscriber trust command is configured to trust the specified option.
# Set the IPoE parsing format for the circuit ID in the DHCP option to hex.
[Sysname-GigabitEthernet3/1/1] ip subscriber access-line-id circuit-id trans-format hex
ip subscriber access-line-id remote-id trans-format
ip subscriber trust
Use ip subscriber access-line-id remote-id trans-format command to configure the IPoE parsing format for the remote ID in the DHCP option.
Use undo ip subscriber access-line-id remote-id trans-format to restore the default.
ip subscriber access-line-id remote-id trans-format { ascii | hex }
The IPoE parsing format for the remote ID in the DHCP option is ASCII.
For IPoE to correctly parse information in the remote ID, use this command to set a proper parsing format according to the format of the remote ID information sent by downstream devices.
The ip subscriber access-line-id remote-id trans-format command configuration takes effect only after the ip subscriber trust command is configured to trust the specified option.
# Set the IPoE parsing format for the remote ID in the DHCP option to hex.
[Sysname-GigabitEthernet3/1/1] ip subscriber access-line-id remote-id trans-format hex
ip subscriber trust
ip subscriber access-out
Use ip subscriber access-out to enable IPoE access-out authentication for IPoE users.
Use undo ip subscriber access-out to restore the default.
IPoE access-out authentication is disabled for IPoE users.
In a dual-authentication network, one device performs access-in authentication and another device performs access-out authentication. Users who pass access-in authentication can access the intranet and users who pass access-out authentication can access the extranet.
# Enable IPoE access-out authentication for IPoE users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber access-out
ip subscriber access-trigger loose
Use ip subscriber access-trigger loose to specify the loose access duration for the IPoE users after the system or the slot where the access interface resides is rebooted.
Use undo ip subscriber access-trigger loose to restore the default.
ip subscriber access-trigger loose { loose-time | all-time }
IPoE users cannot access in loose mode after the system or the slot where the access interface resides is rebooted.
loose-time: Specifies the loose access duration for the IPoE users after the system or the slot where the access interface resides is rebooted, in the range of 1 to 4294967295 minutes.
all-time: Specifies that the IPoE users can access in loose mode all time after the system or the slot where the access interface resides is rebooted.
When the sessions of online IPoE users are deleted because the system or the slot where the access interface resides is rebooted, DHCP users will not send DHCP packets to trigger access again because these user cannot sense the reboot. As a result, the access device cannot regenerate DHCP sessions for these users. To solve this problem, you can specify IPoE users to access in loose mode.
For users accessing in loose mode through a global interface or physical interface, the definition of reboot is different as follows:
· For users accessing through a global interface: After the system is rebooted, IPoE users can use IP packets and ARP packets to trigger access and generating DHCP sessions within the duration specified by the loose-time argument or all time.
· For users accessing through a physical interface: After the slot where the physical interface resides is rebooted, IPoE users can use IP packets and ARP packets to trigger access and generating DHCP sessions within the duration specified by the loose-time argument or all time.
IPoE DHCP users can access in loose mode only when all the following conditions exist:
· The Layer 2 access mode is configured on the access interface.
· DHCPv4 packet initiation is enabled on the access interface.
· A DHCPv4 address pool is assigned to users through the authentication domain or AAA server.
· To use IP packet initiation, you must configure the ip subscriber initiator unclassified-ip enable command on the access interface, and as a best practice, specify the matching-user keyword.
· To use ARP packet initiation, you must configure the ip subscriber initiator arp enable command and the ip subscriber initiator unclassified-ip enable command on the access interface, and as a best practice, specify the matching-user keyword.
In the current software version, only dynamic IPv4 IPoE users can access in loose mode.
For IPoE Web authentication users that access in loose mode, only the sessions in the preauthentication domain can be regenerated. To come online in the Web authentication phase, these users must follow the normal Web authentication procedure.
For IPoE to operate properly when IPoE users access in loose mode, do not configure portal on access interfaces of these IPoE users.
# Specify the loose access duration as 300 minutes for the IPoE users after the system or the slot where the access interface resides is rebooted
[Sysname] ip subscriber access-trigger loose 300
ip subscriber dhcp password
ip subscriber dhcp username
ip subscriber initiator dhcp enable
ip subscriber access-user log enable
Use ip subscriber access-user log enable to enable logging for IPoE users.
Use undo ip subscriber access-user log enable to disable logging for IPoE users.
ip subscriber access-user log enable [ successful-login | failed-login | logout [ normal ] [ abnormal ] ] *
undo ip subscriber access-user log enable [ successful-login | failed-login | logout [ normal ] [ abnormal ] ] *
Logging is disabled for IPoE users.
successful-login: Specifies login success logs.
failed-login: Specifies login failure logs.
logout: Specifies logout logs.
normal: Specifies normal logout logs.
abnormal: Specifies abnormal logout logs.
IMPORTANT: As a best practice, disable this feature to prevent excessive IPoE log output. |
The IPoE logging feature enables the device to generate IPoE logs and send them to the information center. Logs are generated after a user comes online successfully, fails to come online, normally goes offline, or abnormally goes offline. A log entry contains information such as the username, IP address, interface name, inner VLAN, outer VLAN, MAC address, and failure causes. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
When you configure this command without specifying any keyword, this command enables or disables logging for login successes, login failures, normal logouts, and abnormal logouts.
# Enable logging for IPoE users.
[Sysname] ip subscriber access-user log enable
ip subscriber authentication chasten
Use ip subscriber authentication chasten to configure the authentication failure limit in the specified authentication period.
Use undo ip subscriber authentication chasten to restore the default.
ip subscriber authentication chasten auth-failure auth-period
One authentication failure immediately triggers the quiet timer for the user.
auth-failure: Specifies the maximum number of consecutive authentication failures in the specified authentication period that triggers the quiet timer. The value range is 1 to 10000.
auth-period: Specifies an authentication period in the range of 1 to 3600 seconds.
If this command is used, the quiet timer starts when the number of authentication failures of a user reaches the limit in the specified authentication period. During the quiet time, packets from the user are dropped. After the quiet timer expires, IPoE performs authentication upon receiving a packet from the user. This command prevents password attacks.
If a dual-stack IPoE session is generated for a dual-stack user, the authentication failures of the two protocol stacks are counted together. The dual-stack user is quieted when the number of consecutive authentication failures reaches the limit in the specified period.
This command takes effect only after the ip subscriber timer quiet command is executed on the interface.
# Configure GigabitEthernet 3/1/1 to block an IPoE user on the interface for 100 seconds if the user fails authentication for five consecutive times within one minute.
[Sysname-GigabitEthernet3/1/1] ip subscriber timer quiet 100
[Sysname-GigabitEthernet3/1/1] ip subscriber authentication chasten 5 60
display ip subscriber chasten user auth-failed
display ip subscriber chasten user quiet
ip subscriber authentication-method
Use ip subscriber authentication-method to configure an IPoE authentication method.
Use undo ip subscriber authentication-method to restore the default.
ip subscriber authentication-method { bind | web [ mac-auth ] }
IPoE uses bind authentication.
bind: Specifies the bind authentication method.
mac-auth: Specifies the Web MAC authentication method.
When using bind authentication, the BRAS automatically generates usernames and passwords for users based on the user access location. Users are not required to enter usernames and passwords.
When using Web authentication, the BRAS requires users to enter usernames and passwords on the Web authentication page.
When using Web MAC authentication, a user needs to enter the username and password only for the first login. Then, the user can access the network without entering the username and password.
When you switch the authentication method from bind authentication to Web authentication or Web MAC authentication, the device performs operations depending on the session type:
· For IPoE dynamic individual sessions, the device deletes all IPoE dynamic individual sessions on the interface and logs out users.
· For interface-level IPoE static individual sessions:
? the device initializes all IPoE static individual sessions on the interface and logs out users.
· For global IPoE static individual sessions, the device deletes all global IPoE static individual sessions on the interface and logs out users.
· For IPoE leased sessions:
? the device initializes all IPoE leased sessions on the interface and logs out users.
When you switch the authentication method from Web authentication or Web MAC authentication to bind authentication or between Web authentication and Web MAC authentication on an interface, the device performs the following operations:
· Deletes DHCP dynamic individual sessions and global static individual sessions on the interface and initializes the static individual sessions on the interface.
· Logs out users.
# Configure the Web authentication method for IPoE users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber authentication-method web
The operation may cut all users on this interface. Continue?[Y/N]:y
ip subscriber enable
ip subscriber captive-bypass enable
Use ip subscriber captive-bypass enable to enable the captive-bypass feature.
Use undo ip subscriber captive-bypass enable to disable the captive-bypass feature.
ip subscriber captive-bypass enable [ android | ios ] [ optimize ]
The captive-bypass feature is disabled.
android: Specifies Android users.
ios: Specifies iOS users.
optimize: Enables captive-bypass optimization.
By default, the device automatically pushes the Web authentication page to the iOS devices and some Android devices when they are connected to the network with IPoE Web authentication enabled. With the captive-bypass feature enabled, the device does not automatically push the Web authentication page to iOS devices and some Android devices when they are connected to the network. The device pushes the Web authentication page only when the user accesses the Internet by using a browser.
The captive-bypass optimization feature takes effect only on iOS users and does not take effect on Android users.
With the captive-bypass optimization feature enabled, when an iOS user uses a browser to access the Internet, the Web authentication page automatically opens. When the user does not perform authentication and presses the home button to return to the home screen, the Wi-Fi connection is not disconnected.
When you execute this command without specifying any keyword, this command enables the captive-bypass feature for both Android users and iOS users. If you specify only the optimize keyword, this command enables the captive-bypass feature for Android users and the captive-bypass optimization feature for iOS users.
When you execute the undo form of this command, this command disables the captive-bypass feature for both Android users and iOS users.
# Enable the captive-bypass feature.
[Sysname-GigabitEthernet3/1/1] ip subscriber captive-bypass enable
# Enable the captive-bypass optimization feature for iOS users.
[Sysname-GigabitEthernet3/1/1] ip subscriber captive-bypass enable ios optimize
# Enable the captive-bypass feature for Android users.
[Sysname-GigabitEthernet3/1/1] ip subscriber captive-bypass enable android
Use ip subscriber dhcp domain to configure an ISP domain for DHCP users.
Use undo ip subscriber dhcp domain to restore the default.
ip subscriber dhcp domain domain-name [ force ]
No ISP domain is configured for DHCP users.
force: Specifies the ISP domain as the forced domain with the highest priority. If this keyword is not specified, the ISP domain is a non-forced domain.
This command configures an ISP domain for DHCP users. The specified ISP domain must exist on the BRAS.
For IPoE to operate properly when IPoE users access in loose mode, do not configure portal on access interfaces of these IPoE users. When DHCPv4 packet initiation is enabled on an interface, the ISP domains are used in the following order:
1. Forced ISP domain specified by using this command. If the ISP domain does not exist, proceed with step 4.
2. Service-specific ISP domain. If the ISP domain does not exist, proceed with step 4.
3. Non-forced ISP domain specified by this command. If the ISP domain does not exist, proceed with step 4.
4. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
A DHCPv4 user accessing in non-loose mode can obtain an ISP domain in various ways. For how an ISP domain is determined when DHCPv4 packet initiation is enabled and portal authentication is configured, see "ip subscriber dhcp option60 match."
For users accessing in non-loose mode, if DHCPv4 packet initiation is enabled, portal authentication is not configured, and multiple ISP domains are available, the ISP domains are used in the following order:
1. Forced ISP domain specified by using this command. If the ISP domain does not exist, proceed with step 9.
2. ISP domain generated based on the domain name generation rule configured by the ip subscriber dhcp domain include command if the following conditions exist:
? The string selected from Option 60 contains the trusted domain.
? The BRAS trusts Option 60.
? The interface is configured with the ip subscriber dhcp domain include command.
If the ISP domain does not exist, proceed with step 7.
3. Trusted ISP domain configured by the ip subscriber dhcp option60 match command if the following conditions exist:
? The interface is not configured with the ip subscriber dhcp domain include command.
4. ISP domain selected according to the rule for packets that do not carry Option 60 if the following conditions exist:
? The string selected from Option 60 does not contain the trusted domain.
In this case, the contents of Option 60 are ignored and not used for generating a domain name.
5. ISP domain generated based on the domain name generation rule configured by the ip subscriber dhcp domain include command if the following conditions exist:
? The interface is not configured with the ip subscriber dhcp option60 match command.
? Option 60 does not contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
6. ISP domain automatically selected from Option 60 if the following conditions exist:
? The interface is not configured with the ip subscriber dhcp option60 match or ip subscriber dhcp domain include command.
? All information in Option 60 does not contain invalid characters.
Invalid characters include the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), and right angle bracket (>).
7. Service-specific ISP domain. If the ISP domain does not exist, proceed with step 9.
8. Non-forced ISP domain specified by this command. If the ISP domain does not exist, proceed with step 9.
9. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
For users to pass authentication successfully, make sure the ISP domains selected for users exist on the device and are completely configured.
When the contents in an option are used as ISP domains, make sure the ISP domain names exist on the device. Otherwise, these ISP domains are considered as unavailable.
Make sure Option 60 does not contain null terminators or non-printable characters.
A DHCPv6 user can obtain an ISP domain in various ways.
Option 16 and Option 17 use the same processing mechanism to match the trusted domain. The following information uses Option 16 as an example.
For how an ISP domain is determined when DHCPv6 packet initiation is enabled and portal authentication is configured, see "ip subscriber dhcpv6 match."
If DHCPv6 packet initiation is enabled, portal authentication is not configured, and multiple ISP domains are available, the ISP domains are used in the following order:
1. Forced ISP domain specified by using this command. If the ISP domain does not exist, proceed with step 7.
2. Trusted ISP domain configured by the ip subscriber dhcpv6 option16 match command if the following conditions exist:
? The string selected from Option 16 contains the trusted domain.
? The BRAS trusts Option 16.
If the ISP domain does not exist, proceed with step 5.
3. ISP domain selected according to the case that the packets do not carry Option 16 if the following conditions exist:
? The interface is configured with the ip subscriber dhcpv6 option16 match command, but the specified string cannot be matched in the specified position of Option 16.
4. ISP domain automatically selected from Option 16 if the following conditions exist:
? The interface is not configured with the ip subscriber dhcpv6 option16 match command.
? All information in Option 16 does not contain invalid characters.
5. Service-specific ISP domain. If the ISP domain does not exist, proceed with step 7.
6. Non-forced ISP domain specified by this command. If the ISP domain does not exist, proceed with step 7.
7. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
Make sure Option 16 does not contain null terminators or non-printable characters.
# Configure ISP domain dm1 for DHCPv4 users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcp domain dm1
ip subscriber trust
Use ip subscriber dhcp domain include to configure a domain name generation rule for DHCPv4 users.
Use undo ip subscriber dhcp domain include to restore the default.
ip subscriber dhcp domain include vendor-class [ separator separator ] { second-vlan [ separator separator ] | string string [ separator separator ] | vlan [ separator separator ] } *
No domain name generation rule for DHCPv4 users is configured.
vendor-class: Uses the Option 60 information in DHCPv4 packets for generating a domain name.
separator separator: Specifies a case-insensitive character for separating an option and the option that follows. It cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
second-vlan: Uses the inner VLAN in authentication packets for generating a domain name.
string string: Specifies a case-sensitive string of 1 to 64 characters for generating a domain name. It cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
vlan: Uses the outer VLAN in authentication packets for generating a domain name.
You can configure this command when the following conditions exist:
· DHCP users use the information in Option 60 as ISP domains.
· Differentiated authentication is required for DHCP users that have the same Option 60 and come online through the same interface.
For example, user A and user B belong to different VLANs but have the same Option 60 and come online through the same interface. To assign user A and user B to different ISP domains and authorize different address pools based on ISP domains, configure this command to generate ISP domain names by using the Option 60 + VLAN combination.
If this command is configured when the DHCP users use information in Option 60 as the ISP domains, the generated ISP domain name is as follows: String selected from the Option 60 as an ISP domain + parameters configured by using this command. For information about selecting ISP domains, see "ip subscriber dhcp domain."
This command takes effect only when DHCP users use information in the Option 60 as ISP domains.
For the device to parse information in Option 60 correctly and generate correct ISP domain names, make sure Option 60 does not contain null terminators or non-printable characters.
# Configure a domain name generation rule on GigabitEthernet 3/1/1.1 as follows: trusted string from the Option 60 field in DHCP packets (ipoe) + separator (#) + customer VLAN (suppose the customer VLAN is 10). The finally generated domain name is ipoe#10.
[Sysname-GigabitEthernet3/1/1.1] ip subscriber trust option60
[Sysname-GigabitEthernet3/1/1.1] ip subscriber dhcp option60 match ipoe
[Sysname-GigabitEthernet3/1/1.1] ip subscriber dhcp domain include vendor-class separator # vlan
# Configure a domain name generation rule on GigabitEthernet 3/1/1.1 as follows: the whole Option 60 field in DHCP packets (suppose all information in Option 60 is domain123456) + separator (#) + customer VLAN (suppose the customer VLAN is 10). The finally generated domain name is domain123456#10.
ip subscriber trust
ip subscriber dhcp max-session
Use ip subscriber dhcp max-session to set the IPoE session limit for DHCPv4 packet initiation on an interface.
Use undo ip subscriber dhcp max-session to restore the default.
ip subscriber dhcp max-session max-number
The IPoE session limit for DHCPv4 packet initiation on an interface is not set.
max-number: Specifies the IPoE session limit for DHCPv4 packet initiation in the range of 1 to 64000.
If the IPoE session limit for DHCPv4 packet initiation is reached, no more IPoE session can be initiated by DHCPv4 packets. IPoE sessions initiated by DHCPv4 packets include IPv4 single-stack sessions and dual-stack sessions.
In a dual-stack IPoE network, as a best practice, configure the same IPoE session limit by using this command and the ip subscriber dhcpv6 max-session command.
If the configured limit is smaller than the number of existing sessions on an interface, the configuration succeeds and the existing sessions are not affected. However, new sessions cannot be initiated on the interface.
When this command is configured together with the ip subscriber max-session command, the two commands both take effect. The two commands control sessions in different perspectives, and the number of sessions is controlled by both commands. A new session can be established only when neither limit is reached.
# Set the IPoE session limit to 100 for DHCPv4 packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcp max-session 100
Use ip subscriber dhcp option60 match to configure trusted ISP domains for DHCPv4 users.
Use undo ip subscriber dhcp option60 match to restore the default.
ip subscriber dhcp option60 match string [ offset offset ] [ length length ]
undo ip subscriber dhcp option60 match string
No trusted ISP domains are configured for DHCPv4 users.
string: Specifies a trusted ISP domain by its name, a case-insensitive string of 1 to 255 characters. The string cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
offset offset: Specifies an offset for the string starting byte, in the range of 1 to 63. If you do not specify this option, the first byte of the option is the starting byte.
length length: Specifies the length of the string, in the range of 1 to 63. If you do not specify this option, all bytes following the starting byte are used to match the trusted ISP domain.
A DHCPv4 user can obtain an ISP domain in various ways. For how an ISP domain is determined when DHCPv4 packet initiation is enabled and portal authentication is not configured, see "ip subscriber dhcp domain."
If DHCPv4 packet initiation is enabled and portal authentication is configured, the following situations occur:
· If the string selected from Option 60 contains the trusted ISP domain, DHCPv4 packet initiation triggers IPoE authentication and selects an ISP domain for IPoE authentication in the following order:
a. Forced ISP domain configured by using the ip subscriber dhcp domain command. If the ISP domain does not exist, proceed with step d.
b. If the string selected from Option 60 contains the trusted ISP domain:
- When the interface is configured with the subscriber dhcp domain include command, the ISP domain name generated according to the domain name generation rule is used for authentication.
- When the interface is not configured with the subscriber dhcp domain include command, the DHCPv4 user uses the trusted ISP domain for IPoE authentication.
c. When the interface is not configured to trust Option 60 in DHCPv4 packets, for how to select an ISP domain, see "ip subscriber dhcp domain."
d. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
· If the string selected from Option 60 does not contain the trusted ISP domain, DHCPv4 packet initiation triggers portal authentication. For more information about portal authentication, see portal configuration in BRAS Services Configuration Guide.
Make sure Option 60 does not include null terminators or non-printable characters.
You can use this command multiple times.
# On GigabitEthernet3/1/1, configure trusted ISP domain ipoe to match the string with an offset of 1 and a length of 10 bytes from Option 60.
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcp option60 match ipoe offset 1 length 10
ip subscriber trust
Use ip subscriber dhcp password to specify a string from DHCPv4 packets as the password for DHCPv4 users.
Use undo ip subscriber dhcp password to restore the default.
ip subscriber dhcp password { circuit-id mac | option60 [ offset offset ] [ length length ] | user-class }
The BRAS does not use the password specified in DHCPv4 packets for DHCPv4 users.
circuit-id: Specifies the DHCPv4 Option82 sub-option1 field in DHCPv4 packets.
mac: Uses the MAC address in the Circuit-ID (Option82 sub-option1) field as the password.
option60: Uses a string from Option 60 in DHCPv4 packets as the password.
offset offset: Specifies an offset for the password starting byte, in the range of 1 to 63. If you do not specify this option, the first byte of the option is the starting byte.
length length: Specifies the length of the password string, in the range of 1 to 63. If you do not specify this option, all bytes following the starting byte are used as the password.
user-class: Uses a string from Option 77 in DHCPv4 packets as the password.
Passwords configured by the ip subscriber dhcp password command are used for authentication, and must be the same as those configured on the AAA server.
A DHCPv4 user can obtain a password in various ways.
For a DHCPv4 user accessing in loose mode, the passwords are used in the following order:
1. Password configured by using the ip subscriber password command.
2. Default password: vlan.
For a DHCPv4 user accessing in non-loose mode, the passwords are used in the following order:
1. Password configured by using the ip subscriber dhcp password user-class command if the following conditions exist:
? The ip subscriber dhcp password user-class command is configured.
? The ip subscriber trust option77 command is configured. Option 77 does not contain null terminators or non-printable characters.
2. Password configured by using the ip subscriber dhcp password option60 command if the BRAS trusts Option 60 and Option 60 does not contain null terminators or non-printable characters.
3. Password configured by using the ip subscriber dhcp password circuit-id mac command if the BRAS trusts Option 82 and the MAC address in the Circuit-ID carried in DHCPv4 packets does not contain null terminators or non-printable characters.
4. Password configured by using the ip subscriber password command.
5. Default password: vlan.
# Specify the string with an offset of 10 and a length of 20 bytes from Option 60 as the password for DHCPv4 users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcp password option60 offset 10 length 20
ip subscriber trust
Use ip subscriber dhcp username to configure an authentication user naming convention for DHCP users.
Use undo ip subscriber dhcp username to restore the default.
ip subscriber dhcp username include { circuit-id [ mac ] [ separator separator ] | client-id [ separator separator ] | hostname [ original ] [ separator separator ] | nas-port-id [ separator separator ] | port [ separator separator ] | remote-id [ separator separator ] | second-vlan [separator separator ] | slot [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | string string [ separator separator ] | subslot [separator separator ] | sysname [separator separator ] | vendor-class [ absent-replace | original ] * [ separator separator ] | vendor-specific [ separator separator ] | vlan [separator separator ] } *
No authentication user naming convention is configured for DHCP users.
circuit-id: Includes the DHCPv4 Option 82 sub-option 1 or DHCPv6 Option 18 information in a username.
mac: Includes the MAC address in the Circuit-ID (Option82 sub-option1) field in the username. If this keyword is not specified, all information in the Circuit-ID (Option82 sub-option1) field is included in the username.
client-id: Includes the DHCPv4 Option 61 or DHCPv6 Option 1 information in a username.
hostname: Includes the DHCPv4 Option12 in a username.
nas-port-id: Includes the NAS-Port-ID attribute carried in the authentication request packet in a username.
port: Includes the number of the port that receives the user packets in a username.
remote-id: Includes the DHCPv4 Option 82 sub-option 2 or DHCPv6 Option 37 information in a username.
second-vlan: Includes the inner VLAN ID in a username.
slot: Includes the number of the slot that receives the user packets in a username.
source-mac: Includes the source MAC address in a username.
address-separator address-separator: Specifies any printable character as the separator for the MAC address. For example, if you specify a hyphen (-) as the separator, the username is the hyphen-separated MAC address (xxxx-xxxx-xxxx). If you do not specify a separator, the username is the non-separated MAC address (xxxxxxxxxxxx). Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
string string: Includes the specified string in a username, a case-sensitive string of 1 to 64 characters. The string cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
subslot: Includes the number of the subslot that receives the user packets in a username.
sysname: Includes the name of the device that receives the user packets in a username.
vendor-class: Includes the DHCPv4 Option 60 or DHCPv6 Option 16 information in a username.
absent-replace: Uses the authentication domain name of a user to replace the inexistent option in the username when the DHCPv4 Option60 or DHCPv6 Option16 field does not exist in DHCP packets. If you do not specify this keyword, the option part in the username is empty.
vendor-specific: Includes the DHCPv4 Option 82 sub-option 9 or DHCPv6 Option 17 information in a username.
vlan: Includes the outer VLAN ID in a username.
original: Directly uses the original information in the DHCPv4 Option 12, the DHCPv4 Option 60, or DHCPv6 Option 16 field in DHCP packets as the username and passes it to the authentication server for authentication. If this keyword is not specified, when Option 12, Option 60, or Option 16 contains non-printable characters, the device will translate the non-printable characters into printable characters and then passes the translated information to the authentication server for authentication.
separator separator: Specifies a character for separating an option and the option that follows. Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
Usernames obtained based on the naming convention are used for authentication, authorization, and accounting, and must be the same as those configured on the AAA server.
For DHCPv4 users accessing in loose mode, the packets do not carry DHCP Option information. Therefore, the circuit-id, mac, client-id, remote-id, vendor-class, absent-replace, original, or vendor-specific keyword does not take effect. Even these keywords are specified, usernames are generated according to the situation where these keywords are not specified. DHCPv6 users cannot access in loose mode.
You can specify one or more keywords in a naming convention. If you use a combination of keywords, a username obtained based on the naming convention includes the specified options in the configuration order.
Options used as the username information cannot include null terminators or non-printable characters.
# Configure information carried in the Client Identifier Option as the authentication usernames for DHCP users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcp username include client-id
# Configure an authentication user naming convention for DHCP users on GigabitEthernet 3/1/1. Each username contains the device name, slot number, subslot number, port number, and outer VLAN, separated by the pound sign (#).
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcp username include sysname separator # slot separator # subslot separator # port separator # vlan
ip subscriber initiator dhcpv6 enable
ip subscriber trust
Use ip subscriber dhcpv6 match to configure trusted ISP domains for DHCPv6 users.
Use undo ip subscriber dhcpv6 match to restore the default.
ip subscriber dhcpv6 { option16 | option17 } match string [ offset offset ] [ length length ]
undo ip subscriber dhcpv6 { option16 | option17 } match string
No trusted ISP domains are configured for DHCPv6 users.
option16: Specifies Option 16 in DHCPv6 packets.
option17: Specifies Option 17 in DHCPv6 packets.
For how an ISP domain is determined when DHCPv6 packet initiation is enabled and portal authentication is not configured, see "ip subscriber dhcp domain."
If DHCPv6 packet initiation is enabled and portal authentication is configured, the following situations occur:
· If the string selected from Option 16 contains the trusted ISP domain, DHCPv6 packet initiation triggers IPoE authentication and selects an ISP domain for IPoE authentication in the following order:
b. Trusted string when the interface is configured to trust Option 16 in DHCPv6 packets.
c. When the interface is not configured to trust Option 16 in DHCPv6 packets, for how to select an ISP domain, see "ip subscriber dhcp domain."
· If the string selected from Option 16 does not contain the trusted ISP domain, DHCPv6 packet initiation triggers portal authentication. For more information about portal authentication, see portal configuration in BRAS Services Configuration Guide.
Make sure Option 16 does not include null terminators or non-printable characters.
You can only select a string from the first 255 characters of Option 16 to match the trusted ISP domain. If the selected string contains characters that do not belong to the first 255 characters, the match fails.
# On GigabitEthernet3/1/1, configure trusted ISP domain ipoe to match the string with an offset of 1 and a length of 10 bytes from Option 16.
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcpv6 option16 match ipoe offset 1 length 10
ip subscriber dhcpv6 domain
ip subscriber trust
Use ip subscriber dhcpv6 max-session to set the IPoE session limit for DHCPv6 packet initiation on an interface.
ip subscriber dhcpv6 max-session max-number
undo ip subscriber dhcpv6 max-session
The IPoE session limit for DHCPv6 packet initiation on an interface is not set.
max-number: Specifies the IPoE session limit for DHCPv6 packet initiation, in the range of 1 to 64000.
If the IPoE session limit for DHCPv6 packet initiation is reached, no more IPoE session can be initiated by DHCPv6 packets. IPoE sessions initiated by DHCPv6 packets include IPv6 single-stack sessions and dual-stack sessions.
In a dual-stack IPoE network, as a best practice, configure the same IPoE session limit by using this command and the ip subscriber dhcp max-session command.
# Set the IPoE session limit to 100 for DHCPv6 packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcpv6 max-session 100
display ip subscriber session
reset ip subscriber session
ip subscriber dhcpv6 password option16
Use ip subscriber dhcpv6 password option16 to specify a string from Option 16 or Option 17 as the password for DHCPv6 users.
Use undo ip subscriber dhcpv6 password option16 to restore the default.
ip subscriber dhcpv6 password option16 [ offset offset ] [ length length ]
The BRAS does not use the password specified in Option 16 or Option 17 for DHCPv6 users.
offset offset: Specifies an offset for the password starting byte, in the range of 1 to 63. If you do not specify this option, the first byte of Option 16 or Option 17 is the starting byte.
Passwords configured by using this command are used for authentication, and must be the same as those configured on the AAA server.
A DHCPv6 user can obtain a password in various ways. If multiple passwords are available for an DHCPv6 user, the passwords are used in the following order:
1. Password configured by using this command if the BRAS trusts Option 16 or Option 17 and Option 16 or Option 17 does not contain null terminators or non-printable characters.
2. Password configured by using the ip subscriber password command.
3. Default password: vlan.
# Specify the string with an offset of 10 and a length of 20 bytes from Option 16 or Option 17 as the password for DHCPv6 users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber dhcpv6 password option16 offset 10 length 20
ip subscriber trust
ip subscriber dscp
Use ip subscriber dscp to bind an ISP domain to IPoE users who send IP packets with the specified DSCP values.
Use undo ip subscriber dscp to remove the binding between an ISP domain and IPoE users who send IP packets with the specified DSCP values.
ip subscriber dscp dscp-value-list domain domain-name
undo ip subscriber dscp dscp-value-list
No ISP domain is bound to IPoE users who send IP packets with the specified DSCP values.
dscp-value-list: Specifies a space-separated list of up to eight DSCP value items. Each item specifies a DSCP value or a range of DSCP values in the form of start-DSCP-value to end-DSCP-value. The DSCP value is in the range of 0 to 63.
For the ip subscriber dscp command to take effect, you must first execute the ip subscriber service-identify dscp command to configure the DSCP value as the service identifier.
# Configure ISP domain dscpdm for IPoE users who send IP packets with DSCP values 1 to 4 on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber service-identify dscp
[Sysname-GigabitEthernet3/1/1] ip subscriber dscp 1 to 4 domain dscpdm
Use ip subscriber enable to enable IPoE and configure an IPoE access mode for users.
Use undo ip subscriber enable to disable IPoE for users.
ip subscriber { l2-connected | routed } enable [ ipv4 | ipv6 ]
undo ip subscriber { l2-connected | routed } enable
IPoE is disabled for users.
l2-connected: Specifies the Layer 2 access mode.
routed: Specifies the Layer 3 access mode.
ipv4: Enables IPoE for the IPv4 protocol stack.
ipv6: Enables IPoE for the IPv6 protocol stack.
If you do not specify the ipv4 or ipv6 keyword, this command enables IPoE for both IPv4 and IPv6 protocol stacks.
IPoE configurations for the IPv4 or IPv6 protocol stack take effect on an interface only when IPoE is enabled on the interface for the IPv4 or IPv6 protocol stack. For interface-leased users, L2VPN-leased users, and dual-stack static users to come online, you must enable IPoE for both IPv4 and IPv6 protocol stacks.
To change the IPoE access mode on an interface, you must disable IPoE, and then enable IPoE with a new IPoE access mode.
If you do not change the IPoE access mode, you can execute this command multiple times to modify the protocol stack for IPoE as follows:
· Single to dual—No matter whether the current protocol stack has online IPoE sessions, you can execute this command to modify the current protocol stack from single to dual.
· Dual to single/IPv4 to IPv6/IPv6 to IPv4 (without IPoE sessions in the current stack)—If the current protocol stack does not have IPoE sessions, you can execute this command directly to modify the current protocol stack to the specified protocol stack.
· Dual to single/IPv4 to IPv6/IPv6 to IPv4 (with IPoE sessions in the current stack)—If the current protocol stack has online IPoE sessions, perform the following tasks:
a. Execute the ip subscriber access-block command to forbid IPoE users from coming online.
b. For individual users, execute the corresponding reset commands to reset or delete all IPoE sessions in the current protocol stack. For leased users, execute the corresponding undo commands to delete leased user configuration.
c. Execute the ip subscriber enable command to enable IPoE for the specified protocol stack.
d. Execute the undo ip subscriber access-block command to allow IPoE users to come online.
When you change dual stack or IPv6 single stack to IPv4 single stack on an interface, IPoE sessions exist in the current protocol stack if one of the following conditions exists:
· Interface-leased, L2VPN-leased, IPv6 subnet-leased, IPv6 dynamic individual (including dual-stack), or IPv6 global static individual (including dual-stack) sessions in any state exist.
· IPv6 interface-level static individual sessions (including dual-stack) in a state other than Init exist.
When you change dual stack or IPv4 single stack to IPv6 single stack on an interface, IPoE sessions exist in the current protocol stack if one of the following conditions exists:
· Interface-leased, L2VPN-leased, IPv4 subnet-leased, IPv4 dynamic individual (including dual-stack), or IPv4 global static individual (including dual-stack) sessions in any state exist.
· IPv4 interface-level static individual sessions (including dual-stack) in a state other than Init exist.
To ensure successful traffic statistics in aggregate interface view, use the service command to specify a service card for traffic statistics. For more information about the service command, see Layer 2—LAN Switching Command Reference.
For IPoE configuration to take effect on an interface, make sure the qos apply user-profile command has not been executed on the interface. For more information about the qos apply user-profile command, see user profiles commands in BRAS Services Command Reference.
# Enable IPoE and configure the Layer 2 access mode for both IPv4 and IPv6 protocol stacks on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber l2-connected enable
qos apply user-profile (BRAS Services Command Reference)
reset ip subscriber interface-leased
reset ip subscriber subnet-leased
service (Layer 2—LAN Switching Command Reference)
ip subscriber http-fast-reply enable
Use ip subscriber http-fast-reply enable to enable HTTP packet fast reply on an interface.
Use undo ip subscriber http-fast-reply enable to disable HTTP packet fast reply on an interface.
HTTP packet fast reply is disabled.
This command is available only on CSPEX (except CSPEX-1104-E) and CEPC cards.
When a user using a browser to perform Web authentication does not access the portal Web server, the access device will redirect the HTTP requests to the CPU. Then, the CPU pushes the Web authentication page of the portal Web server to the user. If an attacker sends a large number of HTTP requests to the device, the device suffers DoS attacks.
With this feature enabled on an interface, the device uses hardware to recognize HTTP requests and automatically responds with HTTP replies. This feature reduces the workload of the CPU and prevents DoS attacks.
This feature does not immediately take effect on users that have passed preauthentication and come online before this feature is enabled. This feature takes effect only when these users go offline and come online again after passing preauthentication or return to the preauthentication domain after passing Web authentication.
With both this feature and transparent authentication configured, a user first attempts to come online through transparent authentication. The hardware responds and pushes the Web authentication page if the user fails to come online through transparent authentication for one of the following reasons:
· Transparent authentication binding query request times out.
· The portal server returns a message showing that the user is not bound.
· The AAA server returns authentication failure.
# Enable HTTP packet fast replay on interface GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber http-fast-reply enable
ip subscriber if-match
Use ip subscriber if-match to configure a match rule for IPoE URL redirection.
Use undo ip subscriber if-match to delete an IPoE URL redirection match rule.
ip subscriber if-match { original-url url-string redirect-url url-string [ url-param-encryption { aes | des } key { cipher | simple } string ] | user-agent user-agent redirect-url url-string }
undo ip subscriber if-match { original-url url-string | user-agent user-agent }
No IPoE URL redirection match rule is configured.
original-url url-string: Specifies a URL string to match the URL in Web access requests. The specified URL must be a complete URL starting with http:// or https://, a case-sensitive string of 1 to 256 characters.
user-agent user-agent: Specifies a user agent string to match the User-Agent string in HTTP or HTTPS requests. The user agent string is a case-sensitive string of 1 to 255 characters. The User-Agent string in HTTP or HTTPS requests includes information about hardware manufacturer, operating system, browser, and search engine.
redirect-url url-string: Specifies the URL to which the user is redirected. The specified URL must be a complete URL starting with http:// or https://, a case-sensitive string of 1 to 256 characters.
url-param-encryption: Specifies an encryption algorithm to encrypt the parameters carried in the redirection URL. If you do not specify an encryption algorithm, the parameters carried in the redirection URL are not encrypted.
aes: Specifies the AES algorithm.
des: Specifies the DES algorithm.
key: Specifies a key for encryption.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the case-sensitive key string. The string length varies by the selected encryption method:
· If des cipher is specified, the string length is 41 characters.
· If des simple is specified, the string length is 8 characters.
· If aes cipher is specified, the string length is 1 to 73 characters.
· If aes simple is specified, the string length is 1 to 31 characters.
A URL redirection match rule matches HTTP or HTTPS requests by user-requested URL or User-Agent information, and redirects the matching HTTP or HTTPS requests to the specified redirection URL.
For a user to successfully access the redirection URL, configure a preauthentication domain user group ACL to allow HTTP or HTTPS requests destined for the redirection URL to pass.
You can configure the web-server url command in an ISP domain and the ip subscriber if-match command for URL redirection. The web-server url command redirects all HTTP or HTTPS requests from unauthenticated users to the Web server for authentication. The ip subscriber if-match command allows for flexible URL redirection by redirecting specific HTTP or HTTPS requests to specific redirection URLs. If both commands are executed, the ip subscriber if-match command takes priority to perform URL redirection.
# Configure a match rule to redirect HTTP requests destined for the URL http://www.abc.com.cn to the URL http://192.168.0.1 and use DES to encrypt the parameters carried in this redirection URL.
[Sysname-GigabitEthernet3/1/1] ip subscriber if-match original-url http://www.abc.com.cn redirect-url http://192.168.0.1 url-param-encryption des key simple 12345678
# Configure a match rule to redirect HTTP requests that carry the user agent string 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 to the URL http://192.168.0.1.
[Sysname-GigabitEthernet3/1/1] ip subscriber if-match user-agent 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 redirect-url http://192.168.0.1
web-server url (BRAS Services Command Reference)
Use ip subscriber initiator arp enable to enable ARP packet initiation.
Use undo ip subscriber initiator arp enable to disable ARP packet initiation.
ARP packet initiation is disabled.
With ARP packet initiation enabled, a BRAS allows static IPoE users to initiate IPoE sessions by using ARP packets and records abnormally logged out DHCP users. When the BRAS receives ARP packets from abnormally logged out DHCP users, the BRAS can restore the IPoE sessions for these users based on the recorded information.
A DHCP user is abnormally logged out if the IPoE session of the user is deleted for a reason except the user actively releases its IP address.
When an interface receives ARP packets from a user, the interface processes the packets in the following order:
1. If the ARP packets match a configured IPoE static session, the user is processed as a static user.
2. If the ARP packets match abnormally logged out DHCP user records, the interface restores the session information for the abnormally logged out DHCP user according to the recorded information.
3. If the ARP packets match a roaming-capable user, the user is processed as a roaming user.
4. The user accesses in loose mode. (Applicable only when the loose mode takes effect.)
5. If the ARP packets match neither of the above information, the ARP packets are dropped and the user cannot initiate a session by using ARP packets.
For a static individual user to initiate sessions by using ARP packets, make sure the following requirements are met:
· ARP packet initiation is enabled.
· The gateway IP address allocated to the static individual users must be one of the following IP addresses:
? The IP address of the access interface.
? A gateway address from the gateway address list specified by using the gateway-list export-route command.
Disabling ARP packet initiation does not affect online ARP-initiated static individual sessions.
# Enable ARP packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber initiator arp enable
ip subscriber initiator unclassified-ipv6 enable
ip subscriber initiator ndrs enable
ip subscriber roaming enable
Use ip subscriber initiator dhcp enable to enable DHCPv4 packet initiation.
Use undo ip subscriber initiator dhcp enable to disable DHCPv4 packet initiation.
DHCPv4 packet initiation is disabled.
If you enable DHCPv4 packet initiation on an interface, the first DHCP Discover or the DHCP Request packet initiates the IPoE session. If you disable DHCPv4 packet initiation on an interface, DHCPv4 packets cannot initiate IPoE sessions, but existing IPoE sessions initiated by DHCPv4 packets are not deleted.
You can enable DHCPv4 packet initiation and unclassified-IPv4 packet initiation on the same interface.
# Enable DHCPv4 packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber initiator dhcp enable
Use ip subscriber initiator dhcpv6 enable to enable DHCPv6 packet initiation.
Use undo ip subscriber initiator dhcpv6 enable to disable DHCPv6 packet initiation.
DHCPv6 packet initiation is disabled.
If you enable DHCPv6 packet initiation on an interface, the first DHCP Solicitor or the DHCP Request packet initiates the IPoE session. If you disable DHCPv6 packet initiation on an interface, DHCPv6 packets cannot initiate IPoE sessions, but existing IPoE sessions initiated by DHCPv6 packets are not deleted.
You can enable DHCPv6 packet initiation, IPv6 ND RS packet initiation, and unclassified-IPv6 packet initiation on the same interface.
# Enable DHCPv6 packet initiation on GigabitEthernet 3/1/1.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] ip subscriber initiator dhcpv6 enable
Use ip subscriber initiator ndrs enable to enable IPv6 ND RS packet initiation.
Use undo ip subscriber initiator ndrs enable to disable IPv6 ND RS packet initiation.
IPv6 ND RS packet initiation is disabled.
If you enable IPv6 ND RS packet initiation on an interface, the first IPv6 ND RS packet initiates the IPoE session. If you disable IPv6 ND RS packet initiation on an interface, ND RS packets cannot initiate IPoE sessions. However, existing IPoE sessions initiated by ND RS packets are not deleted.
# Enable IPv6 ND RS packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber initiator ndrs enable
ip subscriber initiator nsna enable
Use ip subscriber initiator nsna enable to enable NS/NA packet initiation.
Use undo ip subscriber initiator nsna enable to disable NS/NA packet initiation.
NS/NA packet initiation is disabled.
With this command executed, when the interface receives NS packets with the source IP address as a global unicast address or NA packets with the source or target address as a global unicast address from a user, the interface processes the packets in the following order:
1. If the packets match a configured static IPoE session, the user is processed as a static user.
2. If the packets match a roaming user, the user is processed as a roaming user.
3. If the packets match neither of the above information, the user cannot initiate a session by using NS/NA packets.
For a user to initiate a session by using NS/NA packets, execute one of the following commands:
· Execute the ip subscriber initiator unclassified-ipv6 enable command to enable unclassified-IPv6 packet initiation.
· Execute the ip subscriber initiator nsna enable command to enable NS/NA packet initiation.
When both commands are configured, the following rules apply:
· In Layer 2 access mode, if the source IPv6 address of received NS or NA packets is a global unicast address and the target IPv6 address is a non-multicast address, unclassified-IP packet initiation is used. Otherwise, matching NS or NA packets can initiate sessions, and unmatching NS or NA packets are dropped.
· In Layer 3 access mode, NS or NA packets can only initiate sessions by using the NS/NA packet initiation method and cannot initiate sessions by using the unclassified-IPv6 initiation method.
With this feature disabled on an interface, the users that have come online by using the NS/NA packet initiation method on the interface are still online and not affected.
# Enable NS/NA packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber initiator nsna enable
Use ip subscriber initiator unclassified-ip enable to enable unclassified-IPv4 packet initiation.
Use undo ip subscriber initiator unclassified-ip enable to disable unclassified-IPv4 packet initiation.
ip subscriber initiator unclassified-ip enable [ matching-user ]
Unclassified-IPv4 packet initiation is disabled.
Layer 3 aggregate interface/subinterface view
Layer 3 Ethernet interface/subinterface view
L3VE interface/subinterface view
matching-user: Allows only matching static users, abnormally logged out DHCP users, roaming users, and users accessing in loose mode to log in.
With unclassified-IPv4 packet initiation enabled, a BRAS allows IPoE users to initiate IPoE sessions by using unclassified-IP packets and records abnormally logged out DHCP users. When the BRAS receives IP packets from abnormally logged out DHCP users, the BRAS can restore the IPoE sessions for these users based on the recorded information.
If the matching-user keyword is specified, an interface processes the IP packets received from a user in the following order:
1. If the IP packets match a configured IPoE static session, the user is processed as a static user.
2. If the IP packets match abnormally logged out DHCP user records, the interface restores the session information for the abnormally logged out DHCP user according to the recorded information.
3. If the IP packets match a roaming-capable user, the user is processed as a roaming user.
5. If the IP packets match neither of the above information, the IP packets are dropped and the user cannot initiate a session by using unclassified-IP packets.
If the matching-user keyword is not specified, an interface processes the packets received from a user in the following order:
5. If the IP packets match neither of the above information, the user initiates a session by using unclassified-IP packets.
If you disable unclassified-IPv4 packet initiation on an interface, existing IPoE sessions initiated by unclassified-IPv4 packets are not deleted.
# Enable unclassified-IPv4 packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber initiator unclassified-ip enable
Use ip subscriber initiator unclassified-ipv6 enable to enable unclassified-IPv6 packet initiation.
Use undo ip subscriber initiator unclassified-ipv6 enable to disable unclassified-IPv6 packet initiation.
ip subscriber initiator unclassified-ipv6 enable [ matching-user ]
Unclassified-IPv6 packet initiation is disabled.
matching-user: Allows only matching static users and roaming users to log in.
With unclassified-IPv6 packet initiation enabled, a BRAS allows IPoE users to initiate IPoE sessions by using unclassified-IPv6 packets. The function of recording abnormally logged out DHCPv6 users is not supported in the current software version.
If the matching-user keyword is specified, the interface processes the IPv6 packets received from a user in the following order:
1. If the IPv6 packets match a configured IPoE static session, the user is processed as a static user.
2. If the IPv6 packets match a roaming-capable user, the user is processed as a roaming user.
3. If the IPv6 packets do not match a configured IPoE static session, the user cannot initiate a session by using unclassified-IPv6 packets.
If the matching-user keyword is not specified, the interface processes the IPv6 packets received from a user in the following order:
3. If the IPv6 packets do not match a configured IPoE static session, the user initiates a session by using unclassified-IPv6 packets.
For the processing procedure when the interface receives NS/NA packets, see the ip subscriber initiator nsna enable command.
If you disable unclassified-IPv6 packet initiation on an interface, existing IPoE sessions initiated by unclassified-IPv6 packets are not deleted.
# Enable unclassified-IPv6 packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber initiator unclassified-ipv6 enable
Use ip subscriber interface-leased to configure an interface-leased user.
Use undo ip subscriber interface-leased to restore the default.
ip subscriber interface-leased username name password { ciphertext | plaintext } string [ domain domain-name ]
No interface-leased user exists.
username name: Specifies a username for authentication, a case-sensitive string of 1 to 255 characters.
password ciphertext string: Specifies a ciphertext password, a case-sensitive string of 1 to 117 characters.
password plaintext string: Specifies a plaintext password, a case-sensitive string of 1 to 63 characters. For security purposes, the password specified in plaintext form will be stored in encrypted form.
domain domain-name: Specifies an ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@). If you do not specify an ISP domain, the default system domain is used. For more information about the default system domain, see BRAS Services Configuration Guide.
An interface-leased user represents all access users of the interface.
With IPoE enabled for both IPv4 and IPv6 protocol stacks on an interface in up state, the BRAS creates an IPoE interface-leased session based on the ip subscriber interface-leased command configuration. After the session is set up, the session does not need to be initiated by user traffic. The BRAS actively initiates authentication by using the configured username and password. After the authentication succeeds for users, traffic of all users on the interface is permitted, and the users share one IPoE session. The BRAS performs interface-level authorization and accounting for all users on the interface.
You can configure only one interface-leased user on each interface. To change the parameters of an existing interface-leased user, use the undo form to delete the user, and then reconfigure it with new parameter settings.
You cannot configure an interface-leased user on an interface configured with individual users, a subnet-leased users, or an L2VPN-leased user.
An ISP domain is selected for an IPoE interface-leased user in the following order:
1. Service-specific ISP domain. If the ISP domain does not exist, proceed with step 4.
2. ISP domain specified by using the domain domain-name option in this command. If the ISP domain does not exist, proceed with step 4.
3. ISP domain specified by using the ip subscriber unclassified-ip domain command. If the ISP domain does not exist, proceed with step 4.
# Configure an interface-leased user with a username of intuser and a plaintext password of pw123 on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber interface-leased username intuser password plaintext pw123
display ip subscriber interface-leased
ip subscriber l2vpn-leased
Use ip subscriber l2vpn-leased to configure an L2VPN-leased user.
Use undo ip subscriber l2vpn-leased to restore the default.
ip subscriber l2vpn-leased username name password { ciphertext | plaintext } string [ domain domain-name ]
No L2VPN-leased user exists.
An L2VPN-leased user is a group of hosts that rent the same interface and share the same IPoE session on an L2VPN network. The BRAS authenticates, authorizes, and accounts all hosts of the same L2VPN-leased user.
For L2VPN-leased users to come online, you must enable IPoE for both IPv4 and IPv6 protocol stacks.
You can configure only one L2VPN-leased user on one interface. To change the parameters of an existing L2VPN-leased user, use the undo form to delete the user, and then reconfigure it with new parameter settings.
You cannot configure an L2VPN-leased user on an interface configured with individual users, an interface-leased user, or a subnet-leased user.
On a Layer 3 Ethernet or aggregate subinterface, the IPoE L2VPN-leased user configuration is mutually exclusive with the packet statistics collection feature. For more information about packet statistics collection on Layer 3 Ethernet interfaces, see Ethernet interface configuration in Interface Configuration Guide. For more information about packet statistics collection on Layer 3 aggregate subinterfaces, see Ethernet link aggregation configuration in Layer 2—LAN Switching Configuration Guide.
An ISP domain is selected for an IPoE L2VPN-leased user in the following order:
1. Service-specific ISP domain. If the ISP domain does not exist, proceed with step 3.
2. ISP domain specified by using the domain domain-name option in this command. If the ISP domain does not exist, proceed with step 3.
3. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
# Configure an L2VPN-leased user with a username of intuser and a plaintext password of pw123 on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber l2vpn-leased username intuser password plaintext pw123
ip subscriber lease-end-time original
Use ip subscriber lease-end-time original to configure the lease expiration time as the time when the user is logged out when the abnormally logged out user logs in again.
Use undo subscriber lease-end-time original to restore the default.
undo ip subscriber lease-end-time original
The lease expiration time is renewed when the abnormally logged out user logs in again.
By default, the lease expiration time is renewed when the abnormally logged out user logs in again. With this command configured, when an abnormally logged out client recovers and logs in again, the lease expiration time is the same as the time recorded in the client.
# Configure the lease expiration time as the lease expiration time when the user is logged out when the abnormally logged out user logs in again
[Sysname-GigabitEthernet3/1/1] ip subscriber lease-end-time original
display ip subscriber abnormal-logout
ip subscriber mac-auth domain
Use ip subscriber mac-auth domain to configure the domain for MAC authentication.
Use undo ip subscriber mac-auth domain to restore the default.
ip subscriber mac-auth domain domain-name
No domain is configured for MAC authentication.
When Web MAC authentication is configured with multiple types of domains, a domain is selected in the following order during the Web authentication phase:
1. If the ip subscriber mac-auth domain command is used to specify a MAC authentication domain, the device first obtains the domain in the username and operates as follows:
? If the username carries a domain and the carried domain exists, the domain carried in the username is used. If the domain does not exist, proceed with step 3.
? If the username does not carry a domain, the MAC authentication domain specified by using the ip subscriber mac-auth domain command is used. If the specified domain does not exist, proceed with step 3.
2. If the ip subscriber web-auth domain command is used to specify a Web authentication domain, the device first obtains the domain in the username and operates as follows:
? If the username does not carry a domain, the Web authentication domain specified by using the ip subscriber web-auth domain command is used. If the specified domain does not exist, proceed with step 3.
For how an ISP domain is selected during the Web authentication phase when Web authentication is used, see the ip subscriber web-auth domain command.
The ISP domain for MAC authentication is used for transparent MAC authentication during the Web authentication phase for only individual users using Web MAC authentication.
The ISP domain modification for MAC authentication takes effect only on new users.
# Specify ISP domain dm1 for MAC authentication on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber mac-auth domain dm1
Use ip subscriber max-session to set the maximum number of individual sessions and leased subuser sessions on an interface.
Use undo ip subscriber max-session to restore the default.
ip subscriber max-session max-number
The maximum number of individual sessions and leased subuser sessions is not set on an interface.
max-number: Specifies the maximum number of individual sessions and leased subuser sessions allowed on an interface. The value range for this argument is 1 to 64000.
When the number of individual sessions and leased subuser sessions on an interface has reached the limit, new IPoE sessions cannot be established. The number of IPoE sessions created includes the number of IPv4 single-stack users, the number of IPv6 single-stack users, and the number of dual-stack sessions. A single-stack user occupies one session resource, and a dual-stack user occupies one session resource. If a single-stack user has come online successfully, the other stack of the same user can directly come online, and the two stacks share one session resource.
When this command is configured together with the ip subscriber { dhcp | dhcpv6 | ndrs | unclassified-ip | unclassified-ipv6 } max-session command, the two commands both take effect. The two commands control sessions in different perspectives, and the number of sessions is controlled by both commands. A new session can be established only when neither limit is reached.
# Set the maximum number of individual sessions and leased subuser sessions on GigabitEthernet 3/1/1 to 100.
[Sysname-GigabitEthernet3/1/1] ip subscriber max-session 100
ip subscriber ndrs max-session
ip subscriber unclassified-ip max-session
ip subscriber unclassified-ipv6 max-session
ip subscriber nas-port-id format
Use ip subscriber nas-port-id format to configure the NAS-Port-ID format for IPoE users.
Use undo ip subscriber nas-port-id format to restore the default.
ip subscriber nas-port-id format cn-telecom { version1.0 | version2.0 | version3.0 | version4.0 }
NAS-Port-IDs for IPoE users are encapsulated in the version 1.0 format.
version1.0: Specifies the China Telecom format.
· The version 1.0 format varies by interface type.
Interface type |
Encapsulation format |
Layer 3 Ethernet interface and Layer 3 aggregate interface |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vlanid=0 |
Layer 3 Ethernet subinterface and Layer 3 aggregate subinterface (single VLAN tag) |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vlanid=vlan_id |
Layer 3 Ethernet subinterface and Layer 3 aggregate subinterface (Dual VLAN tags) |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vlanid=inner-vlan;vlanid2=outer-vlan |
· Version 1.0 format parameters
Table 28 Version 1.0 format parameter description
Parameter |
NAS_slot |
Specifies the slot number of the access interface on the BRAS. |
NAS_subslot |
Specifies the subslot number of the access interface on the BRAS. |
NAS_port |
Specifies the port number of the access interface on the BRAS. |
vlan_id |
Specifies the ID of the user's VLAN. |
inner-vlan |
Specifies the ID of the inner VLAN. |
outer-vlan |
Specifies the ID of the outer VLAN. |
vpi |
Specifies the VPI of the access interface on the BRAS. |
vci |
Specifies the VCI of the access interface on the BRAS. |
If the aaa nas-port-id vlanid uppercase command has not been executed, vlanid and vlanid2 in Table 27 are lower case. If the aaa nas-port-id vlanid uppercase command has been executed, vlanid and vlanid2 in Table 27 are upper case, VLANID and VLANID2. For more information about the aaa nas-port-id vlanid uppercase command, see AAA commands in BRAS Services Command Reference.
version2.0: Specifies the format described in YDT 2275-2011 Subscriber Access Loop (Port) Identification in Broadband Access Networks.
When the received DHCPv4 packets carry Option 82 Circuit-ID and Option 82 is trusted or the received DHCPv6 packets carry Option 18 and Option 18 is trusted, see "ip subscriber nas-port-id nasinfo-insert" for the version 2.0 format. Otherwise, the version 2.0 format is {eth|trunk|atm} NAS_slot/NAS_subslot/NAS_port:svlan.cvlan AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port. The NAS information (NAS_slot/NAS_subslot/NAS_port:svlan.cvlan) and AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port (modified to 0/0/0/0/0/0) are encapsulated in the NAS-Port-ID field. Table 29 describes the version 2.0 format parameters.
· Version 2.0 format:
· Version 2.0 format parameters:
Table 29 Version 2.0 format parameter description
Parameter |
{eth|trunk|atm} |
Specifies the type of the access interface on the BRAS as Ethernet, trunk, or ATM. |
NAS_slot |
NAS_subslot |
NAS_port |
svlan |
Specifies the ID of the user's SVLAN. |
cvlan |
Specifies the ID of the user's CVLAN. |
AccessNodeIdentifier |
Specifies the identifier of the access node. |
ANI_rack |
Specifies the rack number of the access node. |
ANI_frame |
Specifies the frame number of the access node. |
ANI_slot |
Specifies the slot number of the access node. |
ANI_subslot |
Specifies the subslot number of the access node. |
ANI_port |
Specifies the port number of the access node. |
In the version 2.0 format, for users accessing without VLAN tags, both svlan and cvlan are fixed at 4096. For users accessing with a single layer of VLAN tags, svlan is fixed at 4096 and cvlan is the actual VLAN carried. For more information, see the examples.
version3.0: Specifies the version 3.0 format SlotID/00/IfNO/VlanID, where the forward slash (/) is not displayed. Table 30 describes the meaning of each field.
Table 30 Version 3.0 encapsulation format
Parameter |
SlotID |
ID of the slot that the user accesses. A minimum of two bits. The empty bits are padded with 0s in the front. |
00 |
Specific field required by the specification. |
IFNO |
Interface number of the user. A minimum of three bits. The empty bits are padded with 0s in the front. |
VlanID |
VLAN ID of the user. A minimum of nine bits. The empty bits are padded with 0s in the front. |
In the version 3.0 format, for users accessing without VLAN tags, VlanID is fixed at 0. For users accessing with a single layer of VLAN tags, VlanID is the actual VLAN carried. For users with two layers of VLAN tags, VlanID is the actual CVLAN carried. For more information, see the examples.
version4.0: Specifies the version 4.0 format. The format adds the following information to the NAS-Port-ID in version 3.0.
· For IPv4 users, the DHCP Option 82 Circuit-ID is added. The encapsulation format is SlotID/00/IfNO/VlanID/Option82 Circuit-ID, where the forward slash (/) is not displayed.
· For IPv6 users, the DHCP Option18 is added. The encapsulation format is SlotID/00/IfNO/VlanID/Option18, where the forward slash (/) is not displayed.
Version 1.0 format
· Access without VLAN tags
# Configure Layer 3 aggregate interface 1 to use the version 1.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. The users access without VLAN tags.
[Sysname-Route-Aggregation1] ip subscriber nas-port-id format cn-telecom version1.0
[Sysname-Route-Aggregation1] quit
[Sysname] display ip subscriber session
Type: D-DHCP S-Static U-Unclassified-IP N-NDRS
Interface IP address MAC address Type State
IPv6 address SVLAN/CVLAN VXLAN
Username
RAGG1 4.4.4.4 1a65-c9ac-0206 S/- Online
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="slot=0;subslot=0;port=1;vlanid=0;"
· Access with a single layer of VLAN tags
# Configure GigabitEthernet 3/1/1.2 to use the version 1.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access with a single layer of VLAN tags.
[Sysname] interface gigabitethernet 3/1/1.2
[Sysname-GigabitEthernet3/1/1.2] ip subscriber nas-port-id format cn-telecom version1.0
[Sysname-GigabitEthernet3/1/1.2] quit
Username
GE3/1/1.2 4.4.4.4 1a65-c9ac-0209 S/- Online
- 400/- -
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="slot=3;subslot=1;port=1;vlanid=400;"
· Access with two layers of VLAN tags
# Configure GigabitEthernet 3/1/1.2 to use the version 1.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access with two layers of VLAN tags.
Username
- 400/500 -
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="slot=3;subslot=1;port=1;vlanid=500;vlanid2=400;"
version 2.0 format
? Access through a Layer 3 aggregate interface
# Configure Layer 3 aggregate interface 1 to use the version 2.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access without VLAN tags.
[Sysname-Route-Aggregation1] ip subscriber nas-port-id format cn-telecom version2.0
Username
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="trunk 0/0/1:4096.4096 0/0/0/0/0/0"
? Access through a Layer 3 Ethernet interface
# Configure GigabitEthernet 3/1/1 to use the version 2.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access without VLAN tags.
[Sysname-GigabitEthernet3/1/1] ip subscriber nas-port-id format cn-telecom version2.0
[Sysname-GigabitEthernet3/1/1] quit
Username
GE3/1/1 4.4.4.4 1a65-c9ac-0209 S/- Online
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="eth 3/1/1:4096.4096 0/0/0/0/0/0"
# Configure GigabitEthernet 3/1/1.2 to use the version 2.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access with a single layer of VLAN tags.
[Sysname-GigabitEthernet3/1/1.2] ip subscriber nas-port-id format cn-telecom version2.0
[Sysname]display ip subscriber session
Username
- 400/- -
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="eth 3/1/1:4096.400 0/0/0/0/0/0"
# Configure GigabitEthernet 3/1/1.2 to use the version 2.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access with two layers of VLAN tags.
Username
- 400/500 -
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="eth 3/1/1:400.500 0/0/0/0/0/0"
version 3.0 format
# Configure Layer 3 aggregate interface 1 to use the version 3.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access without VLAN tags.
[Sysname-Route-Aggregation1] ip subscriber nas-port-id format cn-telecom version3.0
Username
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="0000001000000000"
# Configure GigabitEthernet 3/1/1.2 to use the version 3.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access with a single layer of VLAN tags.
[Sysname-GigabitEthernet3/1/1.2] ip subscriber nas-port-id format cn-telecom version3.0
Username
- 400/- -
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="0300001000000400"
# Configure GigabitEthernet 3/1/1.2 to use the version 3.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access with two layers of VLAN tags.
Username
- 400/500 -
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="0300001000000500"
version 4.0 format
# Configure GigabitEthernet 3/1/1.2 to use the version 4.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access with two layers of VLAN tags, and DHCP packets carry Option82 Circuit-ID as aaa be cd ef g.
[Sysname-GigabitEthernet3/1/1.2] ip subscriber nas-port-id format cn-telecom version4.0
Username
- 400/500 -
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID="0300001000000500aaa be cd ef g"
aaa nas-port-id vlanid-uppercase (BRAS Services Command Reference)
dp (Security Command Reference)
ip subscriber trust
ip subscriber nas-port-id interface
Use ip subscriber nas-port-id interface to configure the device to use information of the specified interface to fill in the NAS-Port-ID attribute.
Use undo ip subscriber nas-port-id interface to restore the default.
ip subscriber nas-port-id interface interface-type interface-number
The device uses information of the interface through which the user comes online to fill in the NAS-Port-ID attribute.
interface interface-type interface-number: Specifies an interface by its type and number. The specified interface must be the IPoE user's access interface. In the current software version, the interface number can contain one, two, three, or four tiers. In each tier, the number is in the range of 0 to 65534. For example, for a 3-tier interface number, the minimum interface number is 0/0/0, and the maximum interface number is 65534/65534/65534. Specify the interface number according to the actual conditions.
A device uses information about the interface through which a user comes online to fill in the NAS-Port-ID attribute and sends it to the RADIUS server by default. In some special applications, when you need to manually specify the access interface information to be filled in the NAS-Port-ID attribute, you can use this command. For example, suppose the RADIUS server restricts user A's access to only interface A. When user A accesses through interface B and you do not want to modify the RADIUS server configuration, you can configure this command to use information about interface A to fill in the NAS-Port-ID attribute for user A and send the attribute to the RADIUS server.
When version 1.0 is specified as the NAS-Port-ID format, information of the specified access interface will be used to fill in the access interface information chassis=NAS_chassis;slot=NAS_slot;subslot=NAS_subslot;port=NAS_port.
When version 2.0 is specified as the NAS-Port-ID format, information of the specified access interface will be used to fill in the NAS information {eth|trunk|atm} NAS_chassis/NAS_slot/NAS_subslot/NAS_port.
When version 3.0 is specified as the NAS-Port-ID format, information of the specified access interface will be used to fill in the NAS information SlotID/IfNO.
When version 4.0 is specified as the NAS-Port-ID format, information of the specified access interface will be used to fill in the following NAS information:
· For IPv4 users: SlotID/IfNO/Option82.
· For IPv6 users: SlotID/IfNO/Option18.
# Configure the device to use information of GigabitEthernet 3/1/1.2 to fill in the NAS-Port-ID attribute. Configure GigabitEthernet 3/1/1.2 to use the version 1.0 format to encapsulate the NAS-Port-ID attribute for RADIUS. Users access with a single layer of VLAN tags.
[Sysname] interface gigabitethernet 3/1/2.1
[Sysname-GigabitEthernet3/1/2.1] ip subscriber nas-port-id interface gigabitethernet 3/1/1.2
[Sysname-GigabitEthernet3/1/2.1] ip subscriber nas-port-id format cn-telecom version1.0
[Sysname-GigabitEthernet3/1/2.1] quit
Username
- 400/- -
4.4.4.4
Use ip subscriber nas-port-id nasinfo-insert to include NAS information and information obtained from DHCPv4 Option 82 or DHCPv6 Option 18 in the NAS-Port-ID.
Use undo ip subscriber nas-port-id nasinfo-insert to restore the default.
The BRAS uses information obtained from DHCPv4 Option 82 or DHCPv6 Option 18 as the NAS-Port-ID.
Configure version 2.0 format and the trusted DHCP option before you use this command.
· If DHCPv4 packets contain Option 82 Circuit-ID, this command parses Option 82 Circuit-ID, extracts information from Circuit-ID (ignoring the first two spaces), and encapsulates the extracted information and NAS information in the NAS-Port-ID in the version 2.0 format. If the information cannot be extracted, the NAS-Port-ID is encapsulated in the version 2.0 format in the way when the packets do not contain Option 82 Circuit-ID. This command does not affect Option 82.
· If DHCPv6 packets contain Option 18, this command parses Option 18, extracts information from Option 18 (ignoring the first two spaces), and encapsulates the extracted information and NAS information in the NAS-Port-ID in the version 2.0 format. If the information cannot be extracted, the NAS-Port-ID is encapsulated in the version 2.0 format in the way when the packets do not contain Option 18. This command does not affect Option 18.
· If DHCPv4 packets do not contain Option 82 Circuit-ID, this command includes NAS information in the NAS-Port-ID and sets non-NAS parts to zeros in the following format:
NAS_slot/NAS_subslot/NAS_port:svlan.cvlan 0/0/0/0/0/0
· If DHCPv6 packets do not contain Option 18, this command includes NAS information in the NAS-Port-ID and sets non-NAS parts to zeros in the following format:
# Configure Layer 3 aggregate interface 1 to include NAS information and information extracted from DHCPv4 Option 82 in the NAS-Port-ID, encapsulate the NAS-Port-ID in the version 2.0 format, and trust Option 82. The DHCP packets carry Option 82 Circuit-ID aaa be cd ef g.
[Sysname-Route-Aggregation1] ip subscriber nas-port-id nasinfo-insert
[Sysname-Route-Aggregation1] ip subscriber trust option82
Username
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID=" trunk 0/0/1:4096.4096 cd ef g"
# Configure Layer 3 aggregate interface 1 to include information extracted from DHCPv4 Option 82 in the NAS-Port-ID, encapsulate the NAS-Port-ID in the version 2.0 format, and trust Option 82. The DHCP packets carry Option 82 Circuit-ID aaa be cd ef g.
[Sysname-Route-Aggregation1] undo ip subscriber nas-port-id nasinfo-insert
Username
4.4.4.4
In the RADIUS debugging information, NAS-Port-ID=" aaa be cd ef g"
ip subscriber initiator dhcpv4 enable
ip subscriber trust
ip subscriber nas-port-type
Use ip subscriber nas-port-type to configure the NAS-Port-Type for an interface.
Use undo ip subscriber nas-port-type to restore the default.
ip subscriber nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax | hdlc | idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
The NAS-Port-Type for an interface is Ethernet.
802.11: Specifies the port type complying with Wireless-IEEE 802.11. The type ID is 19.
adsl-cap: Specifies the ADSL-CAP port type, including Asymmetric DSL and Carrierless Amplitude Phase Modulation. The type ID is 12.
adsl-dmt: Specifies the ADSL-DMT port type, including Asymmetric DSL and Discrete Multi-Tone. The type ID is 13.
async: Specifies the Async port type with a type ID of 0.
cable: Specifies the Cable port type with a type ID of 17.
ethernet: Specifies the Ethernet port type with a type ID of 15.
g.3-fax: Specifies the G.3 Fax port type with a type ID of 10.
hdlc: Specifies the HDLC port type with a type ID of 7.
idsl: Specifies the IDSL port type with a type ID of 14.
isdn-async-v110: Specifies the ISDN Async V.110 port type with a type ID of 4.
ISDN Async V.110: Specifies the ISDN Async V.120 port type with a type ID of 3.
isdn-sync: Specifies the ISDN Sync port type with a type ID of 2.
piafs: Specifies the port type complying with PIAFS. The type ID is 6.
sdsl: Specifies the SDSL port type with a type ID of 11.
sync: Specifies the Sync port type with a type ID of 1.
virtual: Specifies the Virtual port type with a type ID of 5.
wireless-other: Specifies the Wireless-other port type with a type ID of 18.
x.25: Specifies the X.25 port type with a type ID of 8.
x.75: Specifies the X.75 port type with a type ID of 9.
xdsl: Specifies the XDSL port type with a type ID of 16.
The NAS-Port-Type attribute carries information about the access interface. The BRAS includes the configured NAS-Port-Type in RADIUS requests sent to the RADIUS server.
# Configure the port type as sdsl for GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber nas-port-type sdsl
ip subscriber ndrs domain
Use ip subscriber ndrs domain to configure an ISP domain for IPv6 ND RS users.
Use undo ip subscriber ndrs domain to restore the default.
ip subscriber ndrs domain domain-name
No ISP domain is specified for IPv6 ND RS users.
This command specifies an ISP domain for IPv6 ND RS users. The specified ISP domain must exist on the BRAS.
An IPv6 ND RS user can obtain ISP domains in multiple ways. An ISP domain is selected for an IPv6 ND RS user in the following order:
1. ISP domain specified by using the ip subscriber ndrs domain command. If the ISP domain does not exist, proceed with step 2.
2. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
# Configure ISP domain ipoe for IPv6 ND RS users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber ndrs domain ipoe
Use ip subscriber ndrs max-session to set the IPoE session limit for IPv6 ND RS packet initiation on an interface.
Use undo ip subscriber ndrs max-session to restore the default.
ip subscriber ndrs max-session max-number
The IPoE session limit for IPv6 ND RS packet initiation on an interface is not set.
max-number: Specifies the IPoE session limit for IPv6 ND RS packet initiation in the range of 1 to 64000.
If the IPoE session limit for IPv6 ND RS packet initiation is reached, no more IPoE session can be initiated by IPv6 ND RS packets. IPoE sessions initiated by IPv6 ND RS packets include the single-stack IPv6 sessions and dual-stack sessions.
If the configured limit is smaller than the number of existing sessions on an interface, the configuration succeeds and the existing sessions are not affected. However, new sessions cannot be initiated on the interface.
When this command is configured together with the ip subscriber max-session command, the two commands both take effect. The two commands control sessions in different perspectives, and the number of sessions is controlled by both commands. A new session can be established only when neither limit is reached.
# Set the IPoE session limit to 100 for IPv6 ND RS packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber ndrs max-session 100
ip subscriber ndrs username
Use ip subscriber ndrs username to configure an authentication user naming convention for IPv6 ND RS users.
Use undo ip subscriber ndrs username to restore the default.
ip subscriber ndrs username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [ separator separator ] | string string [ separator separator ] | slot [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
No authentication user naming convention is configured for IPv6 ND RS users.
nas-port-id: Includes the NAS-Port-ID attribute in a username.
port: Includes the number of the port that receives the user packets in a username.
second-vlan: Includes the inner VLAN ID in a username.
slot: Includes the number of the slot that receives the user packets in a username.
source-mac: Includes the source MAC address in a username.
address-separator address-separator: Specifies any printable character as the separator for the MAC address. For example, if you specify a hyphen (-) as the separator, the username is the hyphen-separated MAC address (xxxx-xxxx-xxxx). If you do not specify a separator, the username is the non-separated MAC address (xxxxxxxxxxxx). Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
string string: Includes the specified string in a username, a case-sensitive string of 1 to 64 characters. The string cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
subslot: Includes the number of the subslot that receives the user packets in a username.
sysname: Includes the name of the device that receives the user packets in a username.
vlan: Includes the outer VLAN ID in a username.
separator separator: Specifies a character for separating an option and the option that follows. Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
Usernames obtained based on the naming convention are used for authentication and must be the same as those configured on the AAA server.
You can specify one or more keywords in a naming convention. If you use a combination of keywords, a username obtained based on the naming convention includes the specified options in the configuration order.
# Configure the source MAC addresses as the authentication usernames for IPv6 ND RS users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber ndrs username include source-mac
# Configure an authentication user naming convention for IPv6 ND RS users on GigabitEthernet 3/1/1. Each username contains the device name, slot number, subslot number, port number, and outer VLAN, separated by the pound sign (#).
[Sysname-GigabitEthernet3/1/1] ip subscriber ndrs username include sysname separator # slot separator # subslot separator # port separator # vlan
Use ip subscriber password to set the password for individual users.
Use undo ip subscriber password to restore the default.
ip subscriber password { mac-address [ address-separator address-separator ] [ lowercase | uppercase ] | { ciphertext | plaintext } string
No password is set for individual users.
mac-address: Uses a MAC address as the username. The MAC address of the user is preferentially used. If the user MAC address cannot be obtained, the source MAC address of packets is used. By default, the letters in a MAC address are lower-case and a MAC address do not have hyphens.
lowercase: Specifies the letters in the MAC address as lower-case.
uppercase: Specifies the letters in the MAC address as upper-case.
To avoid configuring passwords for each initiation method separately when multiple individual session initiation methods are configured on an interface, you can use this command to uniformly configure authentication passwords for all individual users on an interface.
For individual users using bind authentication, passwords are selected in the following order:
1. Password obtained by using the ip subscriber dhcp password and ip subscriber dhcpv6 password option16 commands. (Applicable to only DHCP users.)
2. User MAC address when the password mac keyword is specified in the ip subscriber session static command. (Applicable to only static users.)
3. Password configured by using the ip subscriber password command.
4. The string vlan.
For Web authentication and Web MAC authentication in the preauthentication phase, passwords are selected for individual users in the same order passwords are selected for individual users using bind authentication.
For Web authentication in the Web authentication phase, passwords are selected in the following order for individual users:
1. Password that the user enters when logging in.
3. The string vlan.
For Web MAC authentication in the Web authentication phase, passwords are selected in the following order for individual users:
1. Password configured by using the ip subscriber password command.
2. The string vlan.
# Configure the plaintext password as 123 for individual users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber password plaintext 123
ip subscriber dhcp username
ip subscriber unclassified-ip username
ip subscriber pre-auth domain
Use ip subscriber pre-auth domain to specify a preauthentication domain.
Use ip subscriber pre-auth domain to restore the default.
ip subscriber pre-auth domain domain-name
undo ip subscriber pre-auth domain
No preauthentication domain is specified.
This command takes effect only for DHCP users and static individual users using the Web authentication method and the Web MAC authentication method.
You can modify the preauthentication domain. By default, a preauthentication domain is selected in the following order:
· For dynamic DHCP users:
a. Service-specific domain. If the domain does not exist, proceed with step c.
b. Preauthentication domain configured by using the ip subscriber pre-auth domain command. If the domain does not exist, proceed with step c.
c. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
· For static users:
a. Authentication domain configured by using the ip subscriber session static command. If the domain does not exist, proceed with step e.
b. Preauthentication domain configured by using the ip subscriber pre-auth domain command. If the domain does not exist, proceed with step e.
c. Service-specific domain. If the domain does not exist, proceed with step e.
d. Domain configured by using the ip subscriber unclassified-ip domain command. If the domain does not exist, proceed with step e.
e. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
If you specify a preauthentication domain, users must pass the preauthentication before obtaining IP addresses (applicable to only DHCP users) and authorization attributes configured for the preauthentication domain. Users will obtain new authorization information after passing the Web authentication.
For Web authentication users, preauthentication is required every time they come online. The user information is deleted upon a preauthentication failure.
New settings in the preauthentication domain do not take effect for users who have passed the preauthentication.
You must configure the Web server URL and user group authorization attributes in the preauthentication domain for redirecting users to the Web authentication page. For more information about the Web server URL and user group, see AAA configuration in BRAS Services Configuration Guide.
# Specify ISP domain dm1 as the preauthentication domain on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber pre-auth domain dm1
authorization-attribute user-group (BRAS Services Command Reference)
domain default enable (BRAS Services Command Reference)
ip subscriber authentication-method
ip subscriber pre-auth track
Use ip subscriber pre-auth track to associate a fail-permit user group with a track entry.
Use undo ip subscriber pre-auth track to restore the default.
ip subscriber pre-auth track track-entry-number fail-permit user-group group-name
A fail-permit user group is not associated with a track entry.
track track-entry-number: Specifies a track entry by its ID in the range of 1 to 1024.
user-group group-name: Specifies a fail-permit user group by its name, a case-insensitive string of 1 to 32 characters.
With this command configured, when the device detects that the Web authentication server or AAA server is unreachable, the device allows users to access network resources without Web authentication. This process is called Web authentication fail-permit.
You can implement Web authentication fail-permit by associating a fail-permit user group with a track entry.
By default, the Web authentication users that come online in the preauthentication domain belong to the user group authorized by AAA or authorized in the ISP domain when the users come online. After a fail-permit user group is associated with a track entry, the following rules apply:
· When the status of the track entry becomes Negative, the access device moves all online users in the current preauthentication domain from the authorized user group to the fail-permit user group. Then, the users can access network resources according to the privilege of the fail-permit user group.
· When the status of the track entry becomes Positive, the access device will move all online users in the current preauthentication domain back to the authorized user group. Then, the users can access network resources only after passing Web authentication.
To monitor the status of multiple servers, you can configure the tracked object list. For more information about track, see track configuration in High Availability Configuration Guide.
This command takes effect only on users in the preauthentication domain.
# Associate fail-permit user group web with track entry 1 on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber pre-auth track 1 fail-permit user-group web
Use ip subscriber roaming enable to enable roaming for IPoE individual users on an interface.
Use ip subscriber roaming enable to disable roaming for IPoE individual users on an interface.
ip subscriber roaming enable [ roam-group roam-group-name ]
undo ip subscriber roaming enable
Roaming is disabled for IPoE individual users.
roam-group roam-group-name: Specifies a roaming group by its name, a case-sensitive string of 1 to 15 characters. The name cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@). If you do not specify this option, all roaming-enabled interfaces belong to the default roaming group, which does not have a name.
Online IPoE individual users can roam between different interfaces or different VLANs of the same subinterface.
To reduce roaming users' impact on other users, you can limit the roaming range by using a roaming group. An online user can roam only within the roaming group of the interface through which the user comes online. For example, user A and user B both use the IP address 1.1.1.1/24 and belong to the same VPN instance. User A first comes online on interface A through unclassified-IP packet initiation. Both interface A and interface B are enabled with roaming but not configured with roaming groups. In this case, when user B comes online on interface B through unclassified-packet initiation, the device will log off user A. For user A and user B to come online simultaneously, you can configure different roaming groups for interface A and interface B. This configuration isolates the roaming range of user A from the roaming range of user B.
In a DHCP relay agent network, you must execute the dhcp select relay proxy command on the DHCP relay agent interface to enable DHCP server proxy on the relay agent. For more information about DHCP relay agents, see DHCP configuration in BRAS Services Configuration Guide.
Make sure the user access interfaces before and after the roaming have IPoE enabled for the same protocol stacks and are configured with the same IPoE authentication method, authentication domain, and roaming group.
The following events might lead to failures in the process of roaming:
· The user IP address that the user belongs to is changed.
· The target interface is not configured with the same IPoE session initiation method as the interface before roaming. For example, suppose interface A is configured with DHCP packet initiation. For roaming between interface A and interface B to succeed, interface B must be configured with DHCP packet initiation.
· The target interface and the current interface are not in the same roaming group.
· For dynamic individual users:
? A VPN instance is authorized to the roaming user. The target interface is bound to a different VPN instance.
? No VPN instance is authorized to the roaming user. The interface before roaming is bound to a VPN instance. The target interface is bound to a different VPN instance.
· For global static individual users:
? A VPN instance is authorized to the roaming user, and no VPN instance is specified in the static session. The target interface is bound to a VPN instance different from the authorized VPN instance.
? No VPN instance is authorized to the roaming user, and no VPN instance is specified in the static session. The interface before roaming is bound to a VPN instance. The target interface is bound to a different VPN instance.
If the roaming fails, the user must perform authentication again on the destination interface in order to come online.
For static individual users, roaming takes effect as follows:
· For interface-level static individual users, roaming is supported only when you configure IPoE static sessions in subinterface view by using the ip subscriber session static command without specifying a VLAN. In this case, only roaming across different VLANs of the subinterface is supported.
· For global static individual users, when you configure the ip subscriber session static command in system view, the following rules apply:
? If a user access interface is specified but no VLAN is specified, roaming across different VLANs of the interface is supported.
? If no user access interface is specified and a user comes online through a roaming-enabled interface, roaming across all roaming-enabled interfaces.
# Enable roaming for IPoE individual users and specify roaming group roam1 on subinterface GigabitEthernet 3/1/1.1.
[Sysname] interface gigabitethernet 3/1/1.1
[Sysname-GigabitEthernet3/1/1.1] ip subscriber roaming enable roam-group roam1
ip subscriber service-identify
Use ip subscriber service-identify to configure the service identifier for users.
Use undo ip subscriber service-identify to restore the default.
Layer 3 Ethernet interface view, Layer 3 aggregate interface view, L3VE interface view:
ip subscriber service-identify dscp
Layer 3 Ethernet subinterface view, Layer 3 aggregate subinterface view, L3VE subinterface view:
ip subscriber service-identify { 8021p { second-vlan | vlan } | dscp | second-vlan | vlan }
No service identifier is configured for users.
8021p second-vlan: Specifies the 802.1p value of the inner VLAN tag in QinQ mode as the service identifier.
8021p vlan: Specifies the 802.1p value of the VLAN tag or the 802.1p value of the outer VLAN tag in QinQ mode as the service identifier.
dscp: Specifies the DSCP value as the service identifier.
second-vlan: Specifies the inner VLAN ID in QinQ mode as the service identifier.
vlan: Specifies the VLAN ID or the outer VLAN ID in QinQ mode as the service identifier.
Users include DHCPv4 users, DHCPv6 users, unclassified-IP users, and static individual users.
You must specify an identifier for a service before you bind an ISP domain to the service. Otherwise, the binding does not take effect.
Users whose IP packets contain the specified service identifier will be assigned a service-specific ISP domain.
For DHCPv4 users, the trusted Option 60 configuration takes precedence over the global service identifier configuration.
For DHCPv6 users, the trusted Option 16 or Option 17 configuration takes precedence over the global service identifier configuration.
You can configure only one service identifier on each interface.
# Configure the DSCP value as the service identifier for users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber service-identify dscp
ip subscriber 8021p
ip subscriber dscp
ip subscriber vlan
ip subscriber session static (interface view)
Use ip subscriber session static to configure IPoE static individual sessions on an interface.
Use undo ip subscriber session static to delete IPoE static individual sessions on an interface.
IPv4:
ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] [ vlan vlan-id [ second-vlan vlan-id ] ] [ mac mac-address ] [ domain domain-name ] [ password mac ] [ request-online ] [ description string ] [ gateway ip ipv4-address ] [ vpn-instance vpn-instance-name ] [ keep-online ]
undo ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] [ vpn-instance vpn-instance-name ]
IPv6:
ip subscriber session static ipv6 start-ipv6-address [ end-ipv6-address ] [ vlan vlan-id [ second-vlan vlan-id ] ] [ mac mac-address ] [ domain domain-name ] [ password mac ] [ request-online ] [ description string ] [ gateway ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ] [ keep-online ]
undo ip subscriber session static ipv6 start-ipv6-address [ end-ipv6-address ] [ vpn-instance vpn-instance-name ]
Dual-stack:
ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] ipv6 start-ipv6-address [ end-ipv6-address ] [ vlan vlan-id [ second-vlan vlan-id ] ] [ mac mac-address ] [ domain domain-name ] [ password mac ] [ request-online { ip | ipv6 } ] [ description string ] [ gateway { ip ipv4-address | ipv6 ipv6-address } * ] [ vpn-instance vpn-instance-name ] [ keep-online ]
undo ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] ipv6 start-ipv6-address [ end-ipv6-address ] [ vpn-instance vpn-instance-name ]
No IPoE static individual sessions exist on an interface.
start-ipv4-address: Specifies a start user IPv4 address.
end-ipv4-address: Specifies an end user IPv4 address, which cannot be lower than the start-ipv4-address argument. All users with IP addresses between start-ipv4-address and end-ipv4-address are specified as static users. If you do not specify the end-ipv4-address argument or the specified end-ipv4-address argument is the same as the start-ipv4-address argument, only one IP address is specified.
start-ipv6-address: Specifies a start user IPv6 address.
end-ipv6-address: Specifies an end user IPv6 address, which cannot be lower than the start-ipv6-address argument. All users with IPv6 addresses between start-ipv6-address and end-ipv6-address are specified as static users. If you do not specify the end-ipv6-address argument or the specified end-ipv6-address argument is the same as the start-ipv6-address argument, only one IPv6 address is specified.
vlan vlan-id: Specifies an outer VLAN ID of the user packet, in the range of 1 to 4094. This option is available only for subinterfaces.
second-vlan vlan-id: Specifies an inner VLAN ID of the user packet, in the range of 1 to 4094. This option is available only for subinterfaces.
mac mac-address: Specifies a user MAC address in the form of H-H-H.
password: Specifies the password used for user authentication.
mac: Uses the user MAC address as the authentication password in the format of HH:HH:HH:HH:HH:HH.
request-online: Specifies the device to actively send ARP, ICMP, ND NS, or ICMPv6 requests to request users to come online. If this keyword is not specified, a user must actively send ARP, ND NS, IPv4, or IPv6 packets to come online.
ip: Specifies the device to actively send IPv4 packets to request users to come online. In Layer 2 access mode, ARP packets are sent. In Layer 3 access mode, ICMP packets are sent.
ipv6: Specifies the device to actively send IPv6 packets to request users to come online. In Layer 2 access mode, ND NS packets are sent. In Layer 3 access mode, ICMPv6 packets are sent.
description string: Specifies the static session description, a case-insensitive string of 1 to 31 characters. If this option is not specified, the static session does not have a description. The description cannot contain the following characters: forward slashes (/), backslashes (\), vertical bars (|), quotation marks ("), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), and at signs (@).
gateway: Specifies the gateway address for users. When the device actively sends online requests to users, the device preferentially uses the address as the source IP address of online requests. If you do not specify this keyword, the device uses the default gateway address as the source IP address of online requests. This keyword takes effect only when the request-online keyword is specified.
ip ipv4-address: Specifies the gateway address for the IPv4 protocol stack. For the device to actively send requests to request users to come online, make sure the address is the IPv4 address of the access interface or the gateway address specified by using the gateway-list export-route command for a DHCPv4 address pool.
ipv6 ipv6-address: Specifies the gateway address for the IPv6 protocol stack. For the device to actively send requests to request users to come online, make sure the address is the global unicast address or link-local address of the access interface in Layer 2 access mode or the global unicast address of the access interface in Layer 3 access mode.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to be bound to static users by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the static users are in the public network. Support for this option depends on the device model.
keep-online: Performs no online detection for users even when online detection is enabled. If you do not specify this keyword, users are forced to go offline when online detection fails for users.
For dual-stack static users to come online, you must enable IPoE for both IPv4 and IPv6 protocol stacks.
IPoE static sessions have higher priority than IPoE dynamic sessions. If a user IP packet matches a IPoE static session, the IPoE static session overwrites the existing IPoE dynamic session.
When the IP addresses specified for a static session overlap with the assignable IP addresses in the DHCP pool, follow these guidelines:
· For a DHCPv4 pool, use the dhcp server forbidden-ip or forbidden-ip command to exclude the overlapping IP addresses from dynamic allocation.
· For a DHCPv6 pool, use the ipv6 dhcp server forbidden-address command to exclude the overlapping IPv6 addresses from dynamic allocation.
For more information about excluding IP addresses from dynamic allocation, see DHCP commands and DHCPv6 commands in BRAS Services Command Reference.
In the public network or the same VPN instance, a maximum of one IPoE session can be configured for one IP address. You cannot use the ip subscriber session static command to modify an IPoE static session configured with the mac, domain, or request-online keyword. To modify such an IPoE session, use the undo form of the command to delete the session, and then reconfigure it with new parameter settings.
For interface-level static sessions and global static sessions with interfaces specified, the IP address and interface combination of an IPoE static session must be unique in the public network and all VPN instances.
You cannot configure an IPoE static individual user on an interface configured with an interface-leased, subnet-leased user, or L2VPN-leased user.
When a session is configured with an IP address range, the system automatically converts the configuration into multiple static session configurations, each with a separate IP address.
For the device to automatically request users to come online, you must configure a static session with the request-online keyword on an interface. Then, the following rules apply:
· For single-stack IPv4 static users:
? In Layer 2 access mode, the device uses ARP packets to requests users to come online. In this case, you must enable ARP packet initiation.
? In Layer 3 access mode, the device uses ICMP packets to request users to come online. In this case, you must enable unclassified-IPv4 packet initiation and configure an IPv4 address for the access interface of the user.
· For single-stack IPv6 static users:
? In Layer 2 access mode, the device uses ND NS packets to requests users to come online. In this case, you must enable unclassified-IPv6 packet initiation or NS/NA packet initiation.
? In Layer 3 access mode, the device uses ICMPv6 packets to request users to come online. In this case, you must enable unclassified-IPv6 packet initiation and configure an IPv6 address for the access interface of the user.
· For dual-stack static users:
? If a dual-stack static user is configured with the request-online ip keywords:
- In Layer 2 access mode, the device uses ARP packets to request users to come online. In this case, you must enable ARP packet initiation.
- In Layer 3 access mode, the device uses ICMP packets to request users to come online. In this case, you must enable unclassified-IPv4 packet initiation and configure an IPv4 address for the access interface of the user.
? If a dual-stack static user is configured with the request-online ipv6 keywords:
- In Layer 2 access mode, the device uses ND NS packets to requests users to come online. In this case, you must enable unclassified-IPv6 packet initiation or NS/NA packet initiation.
- In Layer 3 access mode, the device uses ICMPv6 packets to request users to come online. In this case, you must enable unclassified-IPv6 packet initiation and configure an IPv6 address for the access interface of the user.
· For static users on a subinterface configured with ambiguous Dot1q termination or ambiguous QinQ termination, for the device to properly request the static users to come online, you must specify VLANs when configuring static sessions or configure the vlan-termination broadcast enable command on the subinterface. As a best practice, specify VLANs when configuring static sessions.
To perform unified accounting for dual-stack users, you must configure the IPv4 addresses and IPv6 addresses of these dual-stack users in one ip subscriber session-static command. The IPv4 addresses and IPv6 addresses must be in one-to-one mapping relationship. After the configuration, the device forms the first dual-stack static individual session by using the first IPv4 address and the first IPv6 address. The device forms the second dual-stack static individual session by using the second IPv4 address and the second IPv6 address, and so on.
If you configure multiple ISP domains for a static individual user, an ISP domain is selected for the user in the following order:
· When bind authentication is used:
a. ISP domain specified by using the domain domain-name option in this command. If the domain does not exist, proceed with step d.
b. Service-specific domain. If the domain does not exist, proceed with step d.
c. ISP domain configured by using the ip subscriber unclassified-ip domain command. If the domain does not exist, proceed with step d.
d. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
· When Web authentication is used:
? For how an ISP domain is selected in the preauthentication phase, see the ip subscriber pre-auth domain command.
? For how an ISP domain is selected in the Web authentication phase, see the ip subscriber web-auth domain command.
If you configure multiple passwords for a static individual user, the passwords are used in the following order:
1. MAC address if the password mac option is specified in this command.
2. Password specified by using the ip subscriber password command.
3. Default password: vlan.
You can bind static IPoE users to VPN instances by using one of the following methods:
· Method 1: Specify the vpn-instance parameter in this command.
· Method 2: Authorize VPN instances to users by using AAA.
· Method 3: Use the ip binding vpn-instance command to bind a VPN instance to the interface through which users come online.
When methods 1 and 2 are both configured, for users to come online successfully, make sure you specify the same VPN instance. If the VPN instance specified by using method 1 or 2 is different from the VPN instance specified by using method 3, the VPN instance specified by using method 1 or 2 is used.
# Configure an IPv4 IPoE static session with an IP address of 1.1.1.1 and an ISP domain of dm1 on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber session static ip 1.1.1.1 domain dm1
ip subscriber initiator arp enable
ip subscriber initiator unclassified-ip enable
ip subscriber static-session request-online interval
ip subscriber session static (system view)
Use ip subscriber session static to configure global IPoE static individual sessions.
Use undo ip subscriber session static to delete global IPoE static individual sessions.
IPv4:
ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] [ mac mac-address ] [ domain domain-name ] [ password mac ] [ interface interface-type interface-number [ vlan vlan-id [ second-vlan vlan-id ] ] [ request-online ] ] [ description string ] [ gateway ip ipv4-address ] [ vpn-instance vpn-instance-name ] [ keep-online ]
undo ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] [ interface interface-type interface-number ] [ vpn-instance vpn-instance-name ]
IPv6:
ip subscriber session static ipv6 start-ipv6-address [ end-ipv6-address ] [ mac mac-address ] [ domain domain-name ] [ password mac ] [ interface interface-type interface-number [ vlan vlan-id [ second-vlan vlan-id ] ] [ request-online ] ] [ description string ] [ gateway ipv6 ipv6-address ] [ vpn-instance vpn-instance-name ] [ keep-online ]
undo ip subscriber session static ipv6 start-ipv6-address [ end-ipv6-address ] [ interface interface-type interface-number ] [ vpn-instance vpn-instance-name ]
Dual-stack:
ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] ipv6 start-ipv6-address [ end-ipv6-address ] [ mac mac-address ] [ domain domain-name ] [ password mac ] [ interface interface-type interface-number [ vlan vlan-id [ second-vlan vlan-id ] ] [ request-online { ip | ipv6 } ] ] [ description string ] [ gateway { ip ipv4-address | ipv6 ipv6-address } * ] [ vpn-instance vpn-instance-name ] [ keep-online ]
undo ip subscriber session static ip start-ipv4-address [ end-ipv4-address ] ipv6 start-ipv6-address [ end-ipv6-address ] [ interface interface-type interface-number ] [ vpn-instance vpn-instance-name ]
No global IPoE static individual sessions exist.
domain domain-name: Specifies an ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@). If you do not specify an ISP domain, the default system domain is used. For more information about the default system domain, see BRAS Services Configuration Guide.
interface interface-type interface-number: Specifies an interface by its type and number. If you specify an interface, an IPoE static session is initiated only when packets from the specified interface match the manually configured IPoE static session. If you do not specify an interface, an IPoE static session is initiated when packets from any interfaces match the manually configured IPoE static session.
request-online: Specifies the device to actively send ARP or ICMP requests to request users to come online. If this keyword is not specified, a user must actively send ARP or IP packets to come online.
In the public network or the same VPN instance, a maximum of one IPoE static session can be configured for one IP address. You cannot use the ip subscriber session static command to modify an IPoE static session configured with the mac, domain, interface, or request-online keyword. To modify such an IPoE session, use the undo form of the command to delete the session, and then reconfigure it with new parameter settings.
For global static sessions without interfaces specified, the IP address of a global IPoE static session must be unique in the public network and all VPN instances.
To delete a session, the IP address or range in the undo form must be the same as that in the ip subscriber session static command. To delete sessions for an IP address or range that belongs to an IP address range, delete the sessions for the entire address range.
Interface-level IPoE static sessions take precedence over global IPoE static sessions.
For the device to automatically request users to come online, you must configure a static session with the request-online and interface keywords. Then, the following rules apply:
To perform unified accounting for dual-stack users, you must configure the IPv4 addresses and IPv6 addresses of these dual-stack users in one ip subscriber session-static command. The IPv4 addresses and IPv6 addresses must be in one-to-one mapping relationship. After the configuration, the device forms the first static dual-stack individual session by using the first IPv4 address and the first IPv6 address. The device forms the second dual-stack static individual session by using the second IPv4 address and the second IPv6 address, and so on.
# Configure a global IPoE static session with an IP address of 1.1.1.1 and an ISP domain of dm1.
[Sysname] ip subscriber session static ip 1.1.1.1 domain dm1
Use ip subscriber static-session request-online interval to configure the interval at which the device sends online requests to IPoE static individual users.
Use undo ip subscriber static-session request-online interval to restore the default.
ip subscriber static-session request-online interval seconds
The interval at which the device sends online requests to IPoE static individual users is 180 seconds.
seconds: Specifies the interval at which the device sends online requests to IPoE static individual users. The value range is 60 to 3600 seconds.
Set the request interval when the device actively sends ARP, ICMP, ND NS, or ICMPv6 packets to request IPoE static individual users to come online. To configure the device to actively send online requests, use the ip subscriber session static command in system or interface view.
# Set the interval at which the device sends online requests to IPoE static individual users to 60 seconds.
[Sysname] ip subscriber static-session request-online interval 60
ip subscriber subnet-leased
Use ip subscriber subnet-leased to configure a subnet-leased user.
Use undo ip subscriber subnet-leased to delete a subnet-leased user.
ip subscriber subnet-leased ip ipv4-address { mask | mask-length } username name password { ciphertext | plaintext } string [ domain domain-name ]
undo ip subscriber subnet-leased ip ipv4-address { mask | mask-length }
ip subscriber subnet-leased ipv6 ipv6-address prefix-length username name password { ciphertext | plaintext } string [ domain domain-name ]
undo ip subscriber subnet-leased ipv6 ipv6-address prefix-length
No subnet-leased user exists.
Layer 3 aggregate interface/subinterface view
Layer 3 Ethernet interface/subinterface view
L3VE interface/subinterface view
ip ipv4-address: Specifies a user IPv4 address.
mask: Specifies an IPv4 address mask in dotted decimal notation.
mask-length: Specifies a mask length, an integer in the range of 1 to 31.
ipv6 ipv6-address: Specifies a user IPv6 address.
prefix-length: Specifies the IPv6 prefix length in the range of 1 to 127.
username name: Specifies a username for authentication, a case-sensitive string of 1 to 255 characters.
password: Specifies a password for authentication.
ciphertext string: Specifies a ciphertext password, a case-sensitive string of 1 to 117 characters.
plaintext string: Specifies a plaintext password, a case-sensitive string of 1 to 63 characters. For security purposes, the password specified in plaintext form will be stored in encrypted form.
A subnet-leased user represents all access users in a subnet of the interface.
With IPoE enabled for both IPv4 and IPv6 protocol stacks on an interface in up state, the BRAS creates an IPoE subnet-leased session based on the ip subscriber subnet-leased command configuration. After the session is set up, the session does not need to be initiated by user traffic. The BRAS initiates authentication by using the configured username and password. After the authentication succeeds, traffic of all users in the subnet of the interface is permitted, and the users share one IPoE session. The BRAS performs authorization and accounting for all users in the subnet.
You can configure only one subnet-leased user on each subnet.
You cannot configure a subnet-leased user on an interface configured with individual users, an interface-leased user, or an L2VPN-leased user.
An ISP domain is selected for an IPoE subnet-leased user in the following order:
1. Service-specific ISP domain. If the ISP domain does not exist, proceed with step 4.
2. ISP domain specified by using the domain domain-name option in this command. If the ISP domain does not exist, proceed with step 4.
3. ISP domain specified by using the ip subscriber unclassified-ip domain command. If the ISP domain does not exist, proceed with step 4.
4. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
# Configure a subnet-leased user for subnet 1.1.1.1/24 with a username of netuser and a plaintext password of pw123 on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber subnet-leased ip 1.1.1.1 24 username netuser password plaintext pw123
display ip subscriber subnet-leased
ip subscriber timer quiet
Use ip subscriber timer quiet to enable the quiet timer and set the quiet time period for users.
Use undo ip subscriber timer quiet to restore the default.
ip subscriber timer quiet time
The quite timer is disabled for users.
time: Specifies the quiet timer period in the range of 10 to 3600 seconds.
With this command configured, IPoE starts the quiet timer after the number of consecutive authentication failures of a user reaches the limit in the specified period. The BRAS drops packets from the user during the quiet timer period. After the quiet timer expires, the BRAS performs authentication upon receiving a packet from the user.
When a user that comes online through a global interface is blocked and the slot where the session of the blocked user resides is switched, the device will initiate authentication again for the user. If the user successfully passes authentication before reaching the maximum number of consecutive authentication failures, the user will be unblocked. Otherwise, the user will be blocked again.
# Enable the quiet timer and set the quiet timer period to 100 seconds for users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber timer quiet 100
display ip subscriber chasten user auth-failed
display ip subscriber chasten user quiet
ip subscriber authentication chasten
ip subscriber timer traffic
Use ip subscriber timer traffic to set the traffic statistics update timer for IPoE sessions.
Use undo ip subscriber timer traffic to restore the default.
ip subscriber timer traffic value
The traffic statistics update timer for IPoE sessions is 1000 milliseconds.
value: Specifies the traffic statistics update timer for IPoE sessions, a multiple of 100 in the range of 100 to 1200000 milliseconds.
When the timer times out, IPoE updates traffic statistics for static and dynamic sessions.
Updating traffic statistics for IPoE sessions consumes certain system resources. As a best practice, use the default traffic statistics update timer. You can set the traffic statistics update timer for IPoE sessions based on the statistic frequency requirement.
When the network has a large number of online users authorized with the idle-cut attribute, adjust the traffic statistics update timer according to the authorized idle-cut attribute to prevent users from being logged out because the idle timer times out.
# Set the traffic statistics update timer for IPoE sessions to 300 milliseconds.
[Sysname] ip subscriber timer traffic 300
ip subscriber trust
Use ip subscriber trust to configure a trusted option for DHCP users.
Use undo ip subscriber trust to cancel a trusted option.
ip subscriber trust { option12 | option60 | option77 | option82 | option16 | option17 | option18 | option37 }
undo ip subscriber trust { option12 | option60 | option77 | option82 | option16 | option17 | option18 | option37 }
No trusted options are configured for DHCP users.
option12: Specifies Option 12 as the trusted option.
option60: Specifies Option 60 as the trusted option.
Option77: Specifies Option 77 as the trusted option.
option82: Specifies Option 82 as the trusted option.
option16: Specifies Option 16 as the trusted option.
option17: Specifies Option 17 as the trusted option.
option18: Specifies Option 18 as the trusted option.
option37: Specifies Option 37 as the trusted option.
In a DHCP relay agent network, the BRAS can obtain the Option 60 information from DHCP Discover packets. If the BRAS trusts Option 60 and the ip subscriber dhcp domain or ip subscriber dhcp option60 match command is not configured, the following information is used as the ISP domain:
· All information in Option 60 if the option does not contain invalid characters or the at sign (@).
Invalid characters include the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), and right angle bracket (>).
· Information that follows the last at sign (@) if the option contains at signs (@) and does not contain invalid characters.
When the string selected by using the ip subscriber trust option60 command is used as the ISP domain for authentication and the ip subscriber dhcp domain include command is configured, the domain name generated according to the domain name generation rule is used. For more information about the domain name generation rules, see "ip subscriber dhcp domain include."
For more information about how an ISP domain is determined when the ip subscriber dhcp domain command is configured, see "ip subscriber dhcp domain."
For more information about how an ISP domain is determined when the ip subscriber dhcp option60 match command is configured, see "ip subscriber dhcp option60 match."
For more information about how an ISP domain is determined when the BRAS does not trust DHCPv4 Option 60, see "ip subscriber dhcp domain."
In a DHCP relay agent network, the BRAS can obtain the Option 82 information from DHCP Discover packets. If the BRAS trusts DHCPv4 Option 82, it obtains the following information from the option, parses the information in the configured parsing format (ASCII by default), and uses the information to encapsulate RADIUS attributes:
· Obtains the Circuit-ID information and uses it to encapsulate NAS-Port-ID that adopts version 2.0 as the encapsulation format.
· Obtains the Circuit-ID information and uses it to encapsulate DSL_AGENT_CIRCUIT_ID.
· Obtains the Remote-ID information and uses it to encapsulate DSL_AGENT_REMOTE_ID.
If the BRAS does not trust DHCPv4 Option 82, it does not use the Option 82 to encapsulate RADIUS attributes.
In a DHCPv6 network, the BRAS can obtain the ISP domain information from Option 16 or Option 17. Option 16 and Option 17 use the same processing mechanism to match the trusted domain. The following information uses Option 16 as an example.
If the BRAS trusts Option 16 and the ip subscriber dhcp domain or ip subscriber dhcpv6 option16 match command is not configured, the following information is used as the ISP domain:
· All information in Option 16 if the option does not contain invalid characters or the at sign (@).
For more information about how an ISP domain is determined when the ip subscriber dhcpv6 option16 match command is configured, see "ip subscriber dhcp domain."
For more information about how an ISP domain is determined when the BRAS does not trust DHCPv6 Option 16, see "ip subscriber dhcp domain."
In a DHCP relay agent network, the BRAS can obtain the specified Option information from DHCPv6 packets. If the BRAS trusts DHCPv6 Option 18 or Option 37, it obtains the following information from the option, parses the information in the configured parsing format (ASCII by default), and uses the information to encapsulate RADIUS attributes:
· Obtains information from Option 18 and uses it to encapsulate NAS-Port-ID that uses the version 2.0 encapsulation format.
· Obtains information from Option 18 and uses it to encapsulate DSL_AGENT_CIRCUIT_ID.
· Obtains information from Option 37 and uses it to encapsulate DSL_AGENT_REMOTE_ID.
On the same interface, you can execute this command multiple times to configure multiple trusted options. However, you cannot configure the interface to trust both Option 16 and Option 17. For example, if you have configured Option 16 as a trusted option, you cannot configure Option 17 as a trusted option.
# Configure DHCPv4 Option 82 as a trusted option on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber trust option82
ip subscriber access-line-id circuit-id trans-format
ip subscriber access-line-id remote-id trans-format
ip subscriber dhcpv6 match
ip subscriber initiator dhcp enable
Use ip subscriber unclassified-ip domain to configure an ISP domain for users.
Use undo ip subscriber unclassified-ip domain to restore the default.
ip subscriber unclassified-ip domain domain-name
No ISP domain is configured for users.
This command configures an ISP domain for unclassified-IP users, static individual users, and subnet/interface-leased users.
An ISP domain is selected for an unclassified-IP user in the following order:
1. Service-specific ISP domain. If the ISP domain does not exist, proceed with step 3.
2. ISP domain specified by using the ip subscriber unclassified-ip domain command. If the ISP domain does not exist, proceed with step 3.
3. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
For how an ISP domain is selected for an IPoE static user, see the ip subscriber session static command.
For how an ISP domain is selected for an IPoE subnet-leased user, see the ip subscriber subnet-leased command.
For how an ISP domain is selected for an IPoE interface-leased user, see the ip subscriber interface-leased command.
# Configure ISP domain dm1 for users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber unclassified-ip domain dm1
ip subscriber unclassified-ip ip match
Use ip subscriber unclassified-ip ip match to configure trusted source IPv4 addresses for unclassified-IPv4 users.
Use undo ip subscriber unclassified-ip ip match to restore the default.
ip subscriber unclassified-ip ip match start-ip-address [ end-ip-address ]
undo ip subscriber unclassified-ip ip match start-ip-address [ end-ip-address ]
No trusted source IPv4 addresses are configured. When unclassified-IPv4 packet initiation is enabled on an interface, all unclassified-IPv4 packets can initiate IPoE authentication.
start-ip-address: Specifies the start IPv4 address.
end-ip-address: Specifies the end IPv4 address. The end IPv4 address must be higher than the start IPv4 address. If you specify this option, IPv4 addresses in the IPv4 address range are used as the source IPv4 addresses. If you do not specify this option or the end IPv4 address and start IPv4 address are the same, the start IPv4 address is used as the source IPv4 address.
When unclassified-IPv4 packet initiation is enabled and portal authentication is configured, a user comes online as a static IPoE user if the unclassified-IPv4 packets match a static IPoE session. Otherwise, the following rules apply:
· If this command is configured, IPoE authentication is available only for unclassified-IPv4 users who send packets with the trusted source IPv4 addresses. Portal authentication is available for unclassified-IPv4 users who send packets with untrusted source IPv4 addresses.
· If this command is not configured, all unclassified-IPv4 users use portal authentication.
For more information about portal authentication, see BRAS Services Configuration Guide.
If unclassified-IPv4 packet initiation is enabled but portal authentication is not configured on an interface, a user comes online as a static IPoE user if the unclassified-IPv4 packets match a static IPoE session. Otherwise, the following rules apply:
· If this command is configured, unclassified-IPv4 packets with untrusted source IPv4 addresses are dropped. Only unclassified-IPv4 packets with trusted source IPv4 addresses can initiate IPoE authentication.
· If this command is not configured, the user comes online as an unclassified-IPv4 user.
To cancel trust configuration for an IPv4 address or range belonging to a trusted IPv4 address range, cancel trust configuration for the entire IPv4 address range.
You can use this command multiple times to configure multiple trusted IPv4 addresses or IPv4 address ranges.
# Configure a trusted IPv4 address range of 192.168.1.10 to 192.168.1.100 for IPv4 users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber unclassified-ip ip match 192.168.1.10 192.168.1.100
ip subscriber unclassified-ip ipv6 match
Use ip subscriber unclassified-ip ipv6 match to configure trusted source IPv6 addresses for unclassified-IPv6 users.
Use undo ip subscriber unclassified-ip ipv6 match to restore the default.
ip subscriber unclassified-ip ipv6 match start-ipv6-address [ end-ipv6-address ]
undo ip subscriber unclassified-ip ipv6 match start-ipv6-address [ end-ipv6-address ]
No trusted source IPv6 addresses are configured. When unclassified-IPv6 packet initiation is enabled on an interface, all unclassified-IPv6 packets can initiate IPoE authentication.
start-ipv6-address: Specifies the start IPv6 address.
end-ipv6-address: Specifies the end IPv6 address. The end IPv6 address must be higher than the start IPv6 address. If you specify this option, IPv6 addresses in the IPv6 address range are used as the source IPv6 addresses. If you do not specify this option, the start IPv6 address is used as the source IPv6 address.
If unclassified-IPv6 packet initiation is enabled and portal authentication is configured, the following rules apply:
· If this command is configured, IPoE authentication is available only for unclassified-IPv6 users who send packets with the trusted source IPv6 addresses. Portal authentication is available for unclassified-IPv6 users who send packets with untrusted source IPv6 addresses.
· If this command is not configured, all unclassified-IPv6 users use portal authentication.
If unclassified-IPv6 packet initiation is enabled but portal authentication is not configured on an interface, unclassified-IPv6 packets with untrusted source IPv6 addresses are dropped. Only unclassified-IPv6 packets with trusted source IPv6 addresses can initiate IPoE authentication.
To cancel trust configuration for an IPv6 address or range belonging to a trusted IPv6 address range, cancel trust configuration for the entire IPv6 address range.
You can use this command multiple times to configure multiple trusted IPv6 addresses or IPv6 address ranges.
# Configure a trusted IPv6 address range of 2001::1:10 to 2001::1:100 for unclassified-IPv6 users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber unclassified-ip ipv6 match 2001::1:10 2001::1:100
ip subscriber initiator unclassified-ipv6 enable
ip subscriber unclassified-ip max-session
Use ip subscriber unclassified-ip max-session to set the IPoE session limit for unclassified-IPv4 packet initiation on an interface.
Use undo ip subscriber unclassified-ip max-session to restore the default.
ip subscriber unclassified-ip max-session max-number
The IPoE session limit for unclassified-IPv4 packet initiation on an interface is not set.
max-number: Specifies the IPoE session limit for unclassified-IPv4 packet initiation, in the range of 1 to 64000.
If the IPoE session limit for unclassified-IPv4 packet initiation is reached, no more IPoE session can be initiated by unclassified-IPv4 packets. IPoE sessions initiated by unclassified-IPv4 packets include single-stack IPv4 sessions and dual-stack sessions.
In a dual-stack IPoE network, as a best practice, configure the same IPoE session limit by using this command and the ip subscriber unclassified-ipv6 max-session command.
# Set the IPoE session limit to 100 for unclassified-IPv4 packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber unclassified-ip max-session 100
display ip subscriber session
reset ip subscriber session
Use ip subscriber unclassified-ip username to configure an authentication user naming convention for unclassified-IP users and static individual users.
Use undo ip subscriber unclassified-ip username to restore the default.
ip subscriber unclassified-ip username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [separator separator ] | slot [ separator separator ] | source-ip [ address-separator address-separator ] [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | string string [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
No authentication user naming convention is configured for unclassified-IP users and static individual users.
source-ip: Includes the source IP address in a username.
address-separator address-separator: Specifies any printable character as the separator for the IPv4 address. For example, if you specify a hyphen (-) as the separator, the username is the hyphen-separated IPv4 address (xxxx-xxxx-xxxx) or colon-separated IPv6 address (x::x:x). If you do not specify a separator, the username is the dot-separated IP address (x.x.x.x). Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
# Configure the source IP address as the authentication usernames for unclassified-IP users and static individual users on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber unclassified-ip username include source-ip
# Configure an authentication user naming convention for unclassified-IP users and static individual users on GigabitEthernet 3/1/1. Each username contains the device name, slot number, subslot number, port number, and outer VLAN, separated by the pound sign (#).
[Sysname-GigabitEthernet3/1/1] ip subscriber unclassified-ip username include sysname separator # slot separator # subslot separator # port separator # vlan
Use ip subscriber unclassified-ipv6 max-session to set the IPoE session limit for unclassified-IPv6 packet initiation on an interface.
Use undo ip subscriber unclassified-ipv6 max-session to restore the default.
ip subscriber unclassified-ipv6 max-session max-number
The IPoE session limit for unclassified-IPv6 packet initiation on an interface is not set.
max-number: Specifies the IPoE session limit for unclassified-IPv6 packet initiation, in the range of 1 to 64000.
If the IPoE session limit for unclassified-IPv6 packet initiation is reached, no more IPoE session can be initiated by unclassified-IPv6 packets. IPoE sessions initiated by unclassified-IPv6 packets include single-stack IPv6 sessions and dual-stack IPoE sessions.
In a dual-stack IPoE network, as a best practice, configure the same IPoE session limit by using this command and the ip subscriber unclassified-ip max-session command.
# Set the IPoE session limit to 100 for unclassified-IPv6 packet initiation on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber unclassified-ipv6 max-session 100
ip subscriber username
Use ip subscriber username to configure the username for an IPoE individual user.
Use undo ip subscriber username to restore the default.
ip subscriber username { mac-address [ address-separator address-separator ] [ lowercase | uppercase ] | string string }
No username is configured for an IPoE individual user.
string string: Uses the specified string as the username, a case-sensitive string of 1 to 64 characters. The string cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
To avoid configuring usernames for each initiation method separately when multiple individual session initiation methods are configured on an interface, you can use this command to uniformly configure authentication usernames for all individual users on an interface.
For individual users using bind authentication, usernames are selected in the following order:
1. Username configured by using the command specific to the users.
? For DHCP users, username obtained by using the ip subscriber dhcp username command.
? For ND RS users, username obtained by using the ip subscriber ndrs username command.
? For unclassified-IP users and static individual users, username obtained by using the ip subscriber unclassified-ip username command.
2. Username configured by using the ip subscriber username command.
3. Default user name.
? For DHCP users, MAC address of the user. If the user MAC address cannot be obtained, the source MAC address of packets is used.
? For ND RS users, source MAC address of packets.
? For unclassified-IP users and static individual users, source IP address of packets.
For Web authentication and Web MAC authentication in the preauthentication phase, usernames are selected for individual users in the order usernames are selected for individual users using bind authentication.
For Web authentication in the Web authentication phase, usernames are selected in the following order for individual users:
1. Username that the user enters when logging in.
? For static individual users, source IP address of packets.
For Web MAC authentication in the Web authentication phase, usernames are selected in the following order for individual users:
1. Username configured by using the ip subscriber username command.
2. Default user name.
# Use the MAC address of an IPoE individual user as the username on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber username mac-address
ip subscriber user-detect ip
Use ip subscriber user-detect ip to configure online detection for IPv4 protocol stack users.
Use undo ip subscriber user-detect ip to restore the default.
ip subscriber user-detect ip { arp | icmp } retry retries interval interval [ no-datacheck ]
For leased subusers, no matter whether user uplink traffic is updated within a detection timer period, the BRAS sends packets to detect the online status of users after the detection timer expires.
For other users, no detection packets are sent after the detection timer expires if user uplink traffic is updated within a detection timer period. If user uplink traffic is not updated within a detection timer period, the BRAS uses the ARP request packets to detect IPv4 protocol stack users.
The BRAS performs a maximum of five detection attempts after the first detection failure. The detection timer is 120 seconds.
arp: Specifies the ARP request packet as detection packets.
icmp: Specifies the icmp request packet as detection packets.
retry retries: Specifies the maximum number of detection attempts following the first detection attempt, in the range of 2 to 255.
interval interval: Configures the detection timer for each attempt, in the range of 30 to 1200 seconds.
no-datacheck: Specifies sending detection packets after the detection timer expires no matter whether user uplink traffic is updated within a detection timer period. If this keyword is not specified, no detection packets are sent after the detection timer expires if user uplink traffic is updated within a detection timer period. Otherwise, detection packets are sent. When the accounting mode is merge for dual-stack users, the sum of IPv4 uplink traffic and IPv6 uplink traffic is used to determine whether the user uplink traffic is updated. This keyword does not take effect on leased subusers.
Online detection enables the BRAS to periodically detect the status of an IPv4 protocol stack user. It uses ARP or ICMP requests to detect IPv4 protocol stack users. If IPv4 protocol stack users and the interface are in different subnets, only ICMP request packets can be used for detection.
After you configure online detection, the BRAS starts a detection timer to detect online users. If the BRAS does not receive user packets before the detection timer expires, it sends a detection packet to the user.
· If the BRAS receives user packets within the maximum detection attempts, the BRAS assumes that the user is online. It resets the detection timer, and starts the next detection attempt.
· If the BRAS receives no user packets after detection attempts reach the maximum, the BRAS assumes the user is offline and deletes the session.
Do not configure both ARP and ICMP detection methods to detect the IPv4 protocol stack users.
The IPv4 protocol stack in this command includes the single IPv4 protocol stack and the IPv4 stack in the dual stack. For the single IPv4 protocol stack, this feature supports only leased subusers in Layer 2 access mode and individual users. For the dual stack, this feature supports only individual users.
# Configure online detection for IPv4 protocol stack users on GigabitEthernet 3/1/1. The maximum number of detection attempts is 5 after the first failure, the detection timer is 100 seconds, and the detection packet type is ARP.
[Sysname-GigabitEthernet3/1/1] ip subscriber user-detect ip arp retry 5 interval 100
ip subscriber enable
ip subscriber user-detect ipv6
Use ip subscriber user-detect ipv6 to configure online detection for IPv6 protocol stack users.
Use undo ip subscriber user-detect ipv6 to disable online detection for IPv6 protocol stack users.
ip subscriber user-detect ipv6 { icmp | nd } retry retries interval interval [ no-datacheck ]
For other users, no detection packets are sent after the detection timer expires if user uplink traffic is updated within a detection timer period. If user uplink traffic is not updated within a detection timer period, the BRAS uses the ND NS packets to detect IPv6 protocol stack users.
icmp: Specifies the ICMPv6 request packet as detection packets. For detection to succeed when this keyword is specified, you must configure a global unicast address on the access interface.
nd: Specifies the NS packets of the ND protocol as detection packets.
interval interval: Configures the detection timer in the range of 30 to 1200 seconds.
Online detection enables the BRAS to periodically detect the status of an IPv6 protocol stack user. It uses NS packets of the ND protocol or ICMPv6 requests to detect IPv6 protocol stack users. If IPv6 protocol stack users and the interface are in different subnets, only ICMPv6 request packets can be used for detection.
Do not configure both ICMPv6 and ND detection methods to detect the IPv6 protocol stack users.
The IPv6 protocol stack in this command includes the single IPv6 protocol stack and the IPv6 stack in the dual stack. For the single IPv6 protocol stack, this feature supports only leased subusers in Layer 2 access mode and individual users. For the dual stack, this feature supports only individual users.
# Configure online detection for IPv6 protocol stack users on GigabitEthernet 3/1/1. The maximum number of detection attempts is 3 after the first failure, the detection timer is 50 seconds, and the detection packet type is ND.
[Sysname-GigabitEthernet3/1/1] ip subscriber user-detect ipv6 nd retry 3 interval 50
ip subscriber user-policy interface-down
Use ip subscriber user-policy interface-down to configure the interface-down policy for IPoE users on an interface.
Use undo ip subscriber user-policy interface-down to restore the default.
ip subscriber user-policy interface-down online [ no-user-detect ]
IPoE users on an interface are forced to go offline after the interface goes down.
online: Keeps the users online after the interface goes down.
no-user-detect: Disables online detection when the interface goes down. If you do not specify this keyword, online detection still takes effect when the interface goes down and forces users to go offline when the detection fails.
To prevent users from frequently coming online and going offline because the interface frequently comes up and goes down, you can use this command to keep users online after the interface goes down.
To prevent users from being forced to go offline because online detection fails during the period of restoring a down interface to the up state, specify the no-user-detect keyword in this command.
# Allow IPoE users on GigabitEthernet 3/1/1 to keep online after the interface goes down.
[Sysname-GigabitEthernet3/1/1] ip subscriber user-policy interface-down online
ip subscriber vlan
Use ip subscriber vlan to bind an ISP domain to IPoE users who send packets with the specified VLAN IDs.
Use undo ip subscriber vlan to remove the binding between an ISP domain and IPoE users who send packets with the specified VLAN IDs.
ip subscriber vlan vlan-list domain domain-name
undo ip subscriber vlan vlan-list
No ISP domain is bound to IPoE users who send packets with the specified VLAN IDs.
vlan-list: Specifies a space-separated list of up to 10 VLAN ID items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-VLAN-ID to end-VLAN-ID. The VLAN ID is in the range of 1 to 4094.
This command configures an ISP domain for DHCP users, unclassified-IP users, and static individual users who send IP packets with the specified VLAN IDs.
For how an ISP domain is selected for a DHCP user, see the ip subscriber dhcp domain command.
For how an ISP domain is selected for an unclassified-IP user, see the ip subscriber unclassified-ip domain command.
For how an ISP domain is selected for an IPoE L2VPN-leased user, see the ip subscriber l2vpn-leased command.
For the ip subscriber vlan command to take effect, you must first execute the ip subscriber service-identify { second-vlan | vlan } command to configure the corresponding service identifier.
# Configure an ISP domain for users who send IP packets with VLAN IDs 2 to 100 on GigabitEthernet 3/1/1.100.
[Sysname] interface gigabitethernet 3/1/1.100
[Sysname-GigabitEthernet3/1/1.100] ip subscriber service-identify second-vlan
[Sysname-GigabitEthernet3/1/1.100] ip subscriber vlan 2 to 100 domain vlandm
Use ip subscriber web-auth domain to configure the domain for Web authentication.
Use undo ip subscriber web-auth domain to restore the default.
ip subscriber web-auth domain domain-name
No domain is configured for Web authentication.
When Web MAC authentication is configured with multiple types of domains, a domain is selected in the following order during the Web authentication phase:
1. If the ip subscriber web-auth domain command is used to specify a Web authentication domain, the device first obtains the domain in the username and operates as follows:
? If the username carries a domain and the carried domain exists, the domain carried in the username is used. If the domain does not exist, proceed with step 2.
? If the username does not carry a domain, the Web authentication domain specified by using the ip subscriber web-auth domain command is used. If the specified domain does not exist, proceed with step 2.
If no domain is specified for Web authentication, proceed with step 2.
2. ISP domain selected by the AAA module. For more information, see AAA configuration in BRAS Services Configuration Guide.
For how an ISP domain is selecting during the Web authentication phase when Web MAC authentication is used, see the ip subscriber mac-auth domain command.
The ISP domain configured for Web authentication applies to only individual users using Web authentication and Web MAC authentication during the Web authentication phase.
The ISP domain modification for Web authentication takes effect only on new users.
# Specify ISP domain dm1 for Web authentication on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ip subscriber web-auth domain dm1
ip subscriber authentication-method
reset ip subscriber abnormal-logout
Use reset ip subscriber abnormal-logout command to clear information about abnormally logged out DHCP users.
In standalone mode:
reset ip subscriber abnormal-logout [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
reset ip subscriber abnormal-logout [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears information about abnormally logged out DHCP users for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command clears information about abnormally logged out DHCP users for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears information about abnormally logged out DHCP users for all cards. (In IRF mode.)
This command clears information about abnormally logged out DHCP users. If you do not specify any option, this command clears information about all abnormally logged out DHCP users
# Clears information about abnormally logged out DHCP users on GigabitEthernet 3/1/1.
<Sysname> reset ip subscriber abnormal-logout interface gigabitethernet 3/1/1
display ip subscriber abnormal-logout
reset ip subscriber interface-leased
Use reset ip subscriber interface-leased to initialize or delete interface-leased user sessions and log out users.
reset ip subscriber interface-leased [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command initializes or deletes interface-leased user sessions for all interfaces.
This command initializes interface-leased user sessions and logs out users on the interface. The BRAS automatically reauthenticates the users by the usernames and passwords configured by using the ip subscriber interface-leased command.
# Initialize or delete interface-leased user sessions and log out the users on GigabitEthernet 3/1/1.
<Sysname> reset ip subscriber interface-leased interface gigabitethernet 3/1/1
display ip subscriber interface-leased
reset ip subscriber interface-leased user
Use reset ip subscriber interface-leased user to delete interface-leased subuser sessions and log out the subusers.
reset ip subscriber interface-leased user [ interface interface-type interface-number [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command deletes interface-leased subuser sessions for all interfaces.
ip ipv4-address: Specifies the source IPv4 address of an IPv4 interface-leased subuser.
ipv6 ipv6-address: Specifies the source IPv6 address of an IPv6 interface-leased subuser.
mac mac-address: Specifies the source MAC address of an interface-leased subuser, in the format of H-H-H.
s-vlan svlan-id: Specifies the service provider VLAN ID of an interface-leased user. The value range for the svlan-id argument is 1 to 4094.
c-vlan cvlan-id: Specifies the customer VLAN ID of an interface-leased user. The value range for the cvlan-id argument is 1 to 4094.
vxlan vxlan-id: Specifies the VXLAN ID of an interface-leased user. The value range for the vxlan-id argument is 0 to 16777215.
This command takes effect only in Layer 2 access mode.
If you do not specify any parameters, this command deletes interface-leased subuser sessions and logs out subusers.
# Delete interface-leased subuser sessions and log out the subusers on GigabitEthernet 3/1/1.
<Sysname> reset ip subscriber interface-leased user interface gigabitethernet 3/1/1
display ip subscriber interface-leased user
reset ip subscriber interface-leased user ip-type
Use reset ip subscriber interface-leased user ip-type to delete interface-leased subuser sessions of the specified IP protocol type and log out the subusers.
reset ip subscriber interface-leased user ip-type { ipv4 | ipv6 } [ interface interface-type interface-number [ mac mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ]
ipv4: Specifies IPv4 IPoE interface-leased subusers.
ipv6: Specifies IPv6 IPoE interface-leased subusers.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command deletes interface-leased subuser sessions of the specified IP protocol type for all interfaces.
mac mac-address: Specifies the source MAC address of an interface-leased subuser, in the format of H-H-H. If you do not specify a MAC address, this command deletes all interface-leased subuser sessions of the specified IP protocol type on the specified interface.
s-vlan svlan-id: Specifies the service provider VLAN ID of an interface-leased subuser. The value range for the svlan-id argument is 1 to 4094.
c-vlan cvlan-id: Specifies the customer VLAN ID of an interface-leased subuser. The value range for the cvlan-id argument is 1 to 4094.
vxlan vxlan-id: Specifies the VXLAN ID of an interface-leased subuser. The value range for the vxlan-id argument is 0 to 16777215.
If you do not specify any parameters, this command deletes interface-leased subuser sessions of the specified IP protocol type and logs out subusers.
# Delete IPv4 interface-leased subuser sessions and log out the subusers on GigabitEthernet 3/1/1.
<Sysname> reset ip subscriber interface-leased user ip-type ipv4 interface gigabitethernet 3/1/1
reset ip subscriber offline statistics
Use reset ip subscriber offline statistics to remove offline statistics for users.
reset ip subscriber offline statistics [ ip-type { ipv4 | ipv6 } ] [ interface interface-type interface-number ]
ip-type: Specifies an IP protocol type. If you do not specify an IP protocol type, this command removes offline statistics for users of any IP protocol type.
ipv4: Specifies IPv4 IPoE users.
ipv6: Specifies IPv6 IPoE users.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command removes offline statistics for users for all interfaces.
# Remove offline statistics for all users on GigabitEthernet 3/1/1.
<Sysname> reset ip subscriber offline statistics interface gigabitethernet 3/1/1
display ip subscriber offline statistics
Use reset ip subscriber session to delete IPoE dynamic individual sessions and global static individual sessions, initialize interface-level static individual sessions, and log out users.
reset ip subscriber session [ interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ] [ { { domain domain-name | mac mac-address | username name } | ip-type { ipv4 | ipv6 | dual-stack } } * | { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command performs the operation for all interfaces.
s-vlan svlan-id: Specifies the service provider VLAN ID of the IPoE sessions to be deleted. The value range for the svlan-id argument is 1 to 4094.
c-vlan cvlan-id: Specifies the customer VLAN ID of the IPoE sessions to be deleted. The value range for the cvlan-id argument is 1 to 4094.
vxlan vxlan-id: Specifies the VXLAN ID of the IPoE sessions to be deleted. The value range for the vxlan-id argument is 0 to 16777215.
mac mac-address: Specifies the MAC address of an IPoE session to be deleted, in the format of H-H-H.
username name: Specifies the username of the IPoE session to be deleted, a case-sensitive string of 1 to 255 characters.
ip-type: Specifies the IP protocol type of the IPoE sessions to be deleted. If you do not specify an IP protocol, this command performs the operation for sessions of any IP protocol type.
ipv4: Specifies IPv4 sessions.
ipv6: Specifies IPv6 sessions.
dual-stack: Specifies dual-stack sessions.
ip ipv4-address: Specifies the IPv4 address of an IPoE session to be deleted.
ipv6 ipv6-address: Specifies the IPv6 address of an IPoE session to be deleted.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command performs the operation on the public network.
This command deletes dynamic individual sessions and global static individual sessions, initializes interface-level static individual sessions, and logs out the users. If you do not specify any parameters, this command deletes all dynamic individual sessions and global static individual sessions and initializes all interface-level static individual sessions.
# Delete dynamic individual sessions and global static individual sessions, initialize interface-level static individual sessions on GigabitEthernet 3/1/1, and log out the users.
<Sysname> reset ip subscriber session interface gigabitethernet 3/1/1
reset ip subscriber subnet-leased
Use reset ip subscriber subnet-leased to initialize or delete subnet-leased user sessions.
reset ip subscriber subnet-leased [ interface interface-type interface-number ] [ ip ipv4-address mask-length | ipv6 ipv6-address prefix-length } | ip-type { ipv4 | ipv6 } ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command initializes or deletes subnet-leased user sessions for all interfaces.
ip ipv4-address mask-length: Specifies an IPv4 subnet by an IPv4 address and its mask length. The mask length is in the range of 1 to 31.
ipv6 ipv6-address prefix-length: Specifies an IPv6 subnet by an IPv6 address and its prefix length. The prefix length is in the range of 1 to 127.
ip-type: Specifies an IP protocol type. If you do not specify an IP protocol type, this command initializes or deletes IPoE subnet-leased user sessions of any IP protocol type.
ipv4: Specifies IPv4 IPoE subnet-leased users.
ipv6: Specifies IPv6 IPoE subnet-leased users.
This command initializes subnet-leased user sessions and logs out the users. The BRAS automatically reauthenticates the users by the usernames and passwords configured by using the ip subscriber subnet-leased command.
# Initialize or delete subnet-leased user sessions and log out the users on GigabitEthernet 3/1/1.
<Sysname> reset ip subscriber subnet-leased interface gigabitethernet 3/1/1
reset ip subscriber subnet-leased user
Use reset ip subscriber subnet-leased user to delete IPoE subnet-leased subuser sessions and log out the subusers.
reset ip subscriber subnet-leased user [ interface interface-type interface-number [ ip { ipv4-address mask-length | ipv4-address } | ipv6 { ipv6-address prefix-length | ipv6-address } | s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command deletes IPoE subnet-leased subuser sessions for all interfaces.
ip ipv4-address mask-length: Specifies an IPv4 subnet by an IPv4 address and a mask length in the range of 1 to 31.
ip ipv4-address: Specifies the source IPv4 address of an IPv4 subnet-leased subuser.
ipv6 ipv6-address prefix-length: Specifies an IPv6 subnet by an IPv6 address and a prefix length in the range of 1 to 127.
ipv6 ipv6-address: Specifies the source IPv6 address of an IPv6 subnet-leased subuser.
s-vlan svlan-id: Specifies the service provider VLAN ID of a subnet-leased subuser. The value range for the svlan-id argument is 1 to 4094.
c-vlan cvlan-id: Specifies the customer VLAN ID of a subnet-leased subuser. The value range for the cvlan-id argument is 1 to 4094.
vxlan vxlan-id: Specifies the VXLAN ID of a subnet-leased subuser. The value range for the vxlan-id argument is 0 to 16777215.
If you do not specify any parameters, this command deletes subnet-leased subuser sessions and logs out subusers.
# Delete subnet-leased subuser sessions and log out the subusers on GigabitEthernet 3/1/1.
<Sysname> reset ip subscriber subnet-leased user interface gigabitethernet 3/1/1
display ip subscriber subnet-leased user
reset ip subscriber subnet-leased user ip-type
Use reset ip subscriber subnet-leased user ip-type to delete IPoE subnet-leased subuser sessions of the specified IP protocol type and log out the subusers.
reset ip subscriber subnet-leased user ip-type { ipv4 | ipv6 } [ interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] ] [ vxlan vxlan-id ]
# Delete IPv4 subnet-leased subuser sessions and log out the subusers on GigabitEthernet 3/1/1.
<Sysname> reset ip subscriber subnet-leased user ip—type ipv4 interface gigabitethernet 3/1/1
display ip subscriber subnet-leased user ip-type
slot-user-warning-threshold
Use slot-user-warning-threshold to configure the per-slot user count alarm threshold.
Use undo slot-user-warning-threshold to restore the default.
slot-user-warning-threshold threshold-value
The per-slot user count alarm threshold is 100.
threshold-value: Specifies the per-slot user count alarm threshold in percentage (the percentage of the user count on a slot to the per-slot maximum user count allowed), in the range of 1 to 100.
You can use this command to set the per-slot user count alarm threshold. When the user count on a slot exceeds the threshold, an alarm is triggered automatically. Then, the administrator can promptly know the online user conditions of the network.
This feature counts only the number of IPoE users and PPPoE users.
· A dual-stack PPPoE user is counted as one user.
· A dual-stack IPoE user is counted as two users.
· For IPoE leased users, one interface-leased user is counted as two users, and one subnet-leased user is counted as one user.
· For IPoE leased subusers, one subuser is counted as one user.
Suppose the per-slot maximum user count allowed is a and the per-slot user count alarm threshold is b. The following rules apply:
· When the user count on a slot exceeds a×b, the alarm information is output.
· When the user count on a slot drops within the normal range, the alarm clearing information is output.
In some special cases, the user count on a slot frequently changes in the critical range, which causes frequent output of alarm information and alarm clearing information. To avoid this problem, the system introduces a buffer area when the user count on a slot drops below the threshold. The buffer area size is 10% of the threshold set. Suppose the buffer area size is c. Then, c=a×b÷10. When the user count on a slot drops below a×b-c, the alarm clearing information is output.
For example, suppose a is 1000 and b is 80%. Then, c= a×b÷10=1000×80%÷10=80.
· When the user count on a slot exceeds a×b=1000×80%=800, the alarm information is output.
· When the user count on a slot drops below a×b-c=800-80=720, the alarm clearing information is output.
The alarm information and alarm clearing information output both contain the logs and traps. For traps to be correctly sent to the NMS host, you must execute the snmp-agent trap enable slot-user-warning-threshold command in addition to configuring the SNMP alarm feature correctly.
# Set the per-slot user count threshold to 80.
[Sysname] slot-user-warning-threshold 80
Use snmp-agent trap enable slot-user-warning-threshold to enable the per-slot user count trap feature.
Use undo snmp-agent trap enable slot-user-warning-threshold to disable the per-slot user count trap feature.
The per-slot user count trap feature is disabled.
With the per-slot user count trap feature enabled, when the user count on a slot exceeds the set threshold or drops within the normal range, a trap is generated. The generated trap will be sent to the SNMP module of the device. You can set the trap sending parameters in SNMP to determine how the traps are output. For more information about traps, see Network Management and Monitoring Configuration Guide.
This feature takes effect only when the per-slot user count alarm threshold is set.
# Enable the per-slot user count trap feature.
[Sysname] snmp-agent trap enable slot-user-warning-threshold
trace access-user
Use trace access-user to create a service tracing object.
Use undo trace access-user to delete a service tracing object.
trace access-user object object-id { access-mode ipoe | c-vlan vlan-id | interface interface-type interface-number | ip-address ip-address | mac-address mac-address | s-vlan vlan-id | username user-name } * [ aging time | output { file file-name | syslog-server server-ip-address | vty } ] *
undo trace access-user { all | object object-id }
No service tracing object exists.
object object-id: Specifies a service tracing object ID, in the range of 1 to 5.
access-mode ipoe: Creates a service tracing object based on the IPoE access mode.
c-vlan vlan-id: Creates a service tracing object based on an inner VLAN ID in the range of 1 to 4094.
interface interface-type interface-number: Creates a service tracing object based on the specified interface. With this option specified, the service tracing object becomes ineffective when the slot or subslot that hosts the specified interface is rebooted.
ip-address ip-address: Creates a service tracing object based an IP address.
mac-address mac-address: Creates a service tracing object based on a MAC address.
s-vlan vlan-id: Creates a service tracing object based on an outer VLAN ID in the range of 1 to 4094.
username user-name: Creates a service tracing object based on a username, a case-sensitive string of 1 to 253 characters.
aging time: Specifies the maximum length of the tracing time in the range of 0 to 60 minutes. The default is 15. The tracing time is calculated from the time when this command is configured. The service object is no longer traced after the tracing time expires. The value of 0 indicates that the tracing time never expires and the device will always trace the service object. To stop tracing a service object, delete the service tracing object by using the undo form or shut down the VTY where the command is executed.
output: Specifies the location to which the service tracing object information is output. By default, the service tracing object information is output to the VTY monitor terminal.
file file-name: Outputs the service tracing information to a file in the root directory of the flash storage medium on the device. The file-name argument represents the name of the file storing the service tracing information in the storage medium, a case-sensitive string of 1 to 63 characters.
syslog-server server-ip-address: Outputs the service tracing information to the log server specified by its IP address.
vty: Outputs the service tracing information to the current VTY monitor terminal.
all: Specifies all service tracing objects.
You can create service tracing objects to trace access user information, such as login and logout information. By specifying match parameters, you can trace the specific access users.
This command is resource intensive. As a best practice, use this command only when troubleshooting devices.
When the syslog-server server-ip-address option is specified, make sure the device and the specified log server can reach each other and the log server configuration is correct.
An active/standby switchover causes the command to be ineffective.
# Create service tracing object 1.
[Sysname] trace access-user object 1 access-mode ipoe interface gigabitethernet 3/1/1.1 ip-address 1.1.1.2 mac-address 1-2-3 c-vlan 2 s-vlan 3
display trace access-user
