13-High Availability Command Reference
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command References-Release7951PXX-6W10013-High Availability Command Reference
06-Failover group commands
06-Failover group commands 47.55 KB
bind
Use bind to assign a node to a failover group.
Use undo bind to remove a node from a failover group.
In standalone mode:
bind slot slot-number { primary | secondary | vrrp }
undo bind slot slot-number
In IRF mode:
bind chassis chassis-number slot slot-number { primary | secondary | vrrp }
undo bind chassis chassis-number slot slot-number
A failover group has no nodes.
Failover group view
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
primary: Configures a node as the primary node. This keyword is applicable to intra-system service backup.
secondary: Configures a node as the secondary node. This keyword is applicable to intra-system service backup.
vrrp: Configures the status of a node to be determined by a VRRP group. This keyword is applicable to inter-system service backup.
Each failover group contains a maximum of two nodes.
As a best practice, assign two nodes of similar performance on different cards to a failover group to ensure service continuity after a node switchover.
The primary node and the secondary node in a failover group cannot be the same node. Different failover groups cannot share the same primary node.
You can assign only existing nodes to a failover group. For a node that has been uninstalled from the device, you must also use the undo bind command to remove it from the failover group.
# (In IRF mode.) Configure slot 4 as the primary node in failover group group1.
[Sysname] failover group group1
[Sysname-failover-group-group1] bind chassis 1 slot 3 primary
bind-vrrp
Use bind vrrp to bind a failover group to a VRRP group.
Use undo bind vrrp to unbind a failover group from a VRRP group.
bind-vrrp virtual-router-id interface interface-type interface-number
undo bind-vrrp
A failover group is not bound to any VRRP group.
Failover group view
virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255.
interface interface-type interface-number: Specifies an interface by its type and number. The VRRP group is created on the interface.
To back up services for nodes on two independent systems, configure inter-system service backup by binding the failover group to a VRRP group. VRRP determines the status of the nodes in the failover group and backs up services from the node on the master to the node on the backup.
# Bind failover group group1 to VRRP group 1 created on GigabitEthernet 3/1/1.
[Sysname] failover group Group1
[Sysname-failover-group-Group1] bind-vrrp 1 interface gigabitethernet 3/1/1
display failover
Use display failover to display failover group information.
display failover { group [ group-name ] | group-name group-name }
group-name: Specifies a failover group by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a failover group, this command displays information about all failover groups.
You can use either the display failover group [ group-name ] or display failover group-name group-name command to display failover group information. The commands have the same output. To display information about a failover group named >, >>, or |, use the display failover group-name group-name command.
# (In IRF mode.) Display information about all failover groups.
<Sysname> display failover group
Stateful failover group information:
ID Name                             Local    Peer      Active status
3  group3                           1/4      1.1.1.2   Local
Name
Name of the failover group.
Local
The node on the local system.
The format of this field is chassis-number/slot-number. The chassis-number segment represents the member ID of the IRF member device. The slot-number segment represents the slot number of the card. If the primary node is not configured, this field displays N/A.
Peer
IP address of the peer interface on the backup link.
Active Status
The state of the failover group:
·         Primary—The primary node is processing services.
·         Secondary—The secondary node is processing services.
·         Initial—No node in the failover group is processing services.
failover group
Use failover group to create a failover group and enter its view, or enter the view of an existing failover group.
Use undo failover group to delete a failover group.
failover group group-name [ id group-id ]
undo failover group group-name
No failover groups exist.
id group-id: Specifies a failover group by its ID, in the range of 1 to 64. This option is required when you create a failover group. It is optional when you enter failover group view. The group ID and the group name can both identify a failover group. The group name is mainly used to identify a failover group on the local device. The group ID is mainly used to exchange messages between devices in a failover group.
A failover group backs up services (such as NAT) between two CPUs to ensure high availability.
You can execute this command multiple times to create more failover groups.
# Create failover group group1 with ID 1 and enter its view.
[Sysname] failover group group1 id 1
remote-backup
Use remote-backup to specify a backup channel for inter-system service backup.
Use undo remote-backup to remove the backup channel configuration.
remote-backup local ip-address peer peer-ip-address port port-number
undo remote-backup
No backup channel is specified for inter-system service backup.
local ip-address: Specifies a local IP address.
peer peer-ip-address: Specifies a peer IP address.
port port-number: Specifies a port number in the range of 1024 to 55535.
Set up the backup link by using two IP addresses that can reach each other.
This command applies to inter-system service backup. You must execute this command on both of the systems and configure the same port number for them.
As a best practice, use a direct link for backup packets. If the physical interface on the link transmits multiple types of traffic, create a dedicated subinterface for each kind of traffic.
# Specify a backup channel for inter-system service backup. The local IP address is 192.168.2.125, the peer IP address is 192.168.3.142, and the port number is 3000.
[Sysname-failover-group-Group1] remote-backup local 192.168.2.125 peer 192.168.3.142 port 3000
