04-Layer 2 - LAN Switching Command Reference
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command References-Release7951PXX-6W10004-Layer 2 - LAN Switching Command Reference
08-VLAN termination commands
08-VLAN termination commands 74.02 KB
display user-vlan
Use display user-vlan to display user VLAN information.
In standalone mode:
display user-vlan interface interface-type interface-number.subnumber [ slot slot-number ]
In IRF mode:
display user-vlan interface interface-type interface-number.subnumber [ chassis chassis-number slot slot-number ]
interface-number.subnumber: Specifies a subinterface by its number. The interface-number argument specifies the main interface number, and the subnumber argument specifies a subinterface number.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
This command displays user VLAN information on a subinterface only if the following conditions exist:
·          The user-vlan dot1q vid or user-vlan dot1q vid second-dot1q command has been configured on the subinterface.
·          Online users are present on the subinterface.
When you specify the slot slot-number option, following these restrictions and guidelines:
·          To display user VLAN information on a Layer 3 Ethernet subinterface, do not specify this option.
·          If member ports of an aggregation group belong to different cards, user this option to specify a card. If you do not specify this option, the command displays user VLAN information on the card that hosts the aggregation member port with the smallest port number. The Port Number field of the display link-aggregation member-port command output displays the port number of an aggregation member port.
# Display user VLAN information on Layer 3 Ethernet subinterface GigabitEthernet 3/1/1.1.
<Sysname> display user-vlan interface gigabitethernet 3/1/1.1
 Service VLAN  Customer VLAN   Number of online users
 20              100               1
 20              101               10
Number of user VLANs: 2
Service VLAN
Service provider network VLAN:
·         This field indicates the outermost layer VLAN (customer network VLAN) for user VLAN Dot1q termination.
·         This field indicates Layer 1 VLAN for user VLAN QinQ termination.
Customer VLAN
Customer network VLAN:
·         This field displays N/A for user VLAN Dot1q termination.
·         This field indicates Layer 2 VLAN for user VLAN QinQ termination.
Number of online users in the VLAN.
Each online IPoE dual-stack user is calculated as two users in this field.
Number of VLANs that have online users.
user-vlan dot1q vid
dot1q ethernet-type
Use dot1q ethernet-type to set the TPID value in the outermost VLAN tag of packets received and sent by an interface.
Use undo dot1q ethernet-type to restore the default.
dot1q ethernet-type hex-value
The TPID value for the outermost VLAN tag of a VLAN-tagged packet received and sent by the interface is 0x8100.
Layer 3 aggregate/Ethernet interface view
L3VE interface view
VLAN interface view
hex-value: Sets a hexadecimal TPID value in the range of 1 to ffff, excluding the common protocol type values listed in Table 2.
Table 2 Common protocol type values
Protocol
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86DD
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
LLDP
0x88CC
802.1X
0x888E
802.1ag
0x8902
Cluster
0x88A7
Reserved on the device
0xFFFD/0xFFFE/0xFFFF
This command is not available on the following interfaces:
·          Layer 3 Ethernet interfaces on the SPC cards and MPE-1104 cards.
·          Layer 3 aggregate interfaces that have member ports on the SPC cards and MPE-1104 cards.
After you execute this command, only packets whose TPID in the outermost VLAN tag is 0x8100 or the configured value are processed as VLAN-tagged packets.
When sending a packet, the interface sets the TPID value in the outermost VLAN tag to the configured value. If the packet includes two or more layers of VLAN tags, the interface sets the TPID values in the other VLAN tags to 0x8100.
Do not use this command in subinterface view.
Configurations made in the following interface views take effect on all subinterfaces:
·          Layer 3 Ethernet interface view.
·          Layer 3 aggregate interface view.
·          L3VE interface view.
Configurations made in VLAN interface view take effect on the VLAN interface.
For more information about L3VE interfaces, see L2VPN access to L3VPN or IP backbone configuration in MPLS Configuration Guide.
# Set the TPID value to 0x9100 in the outermost VLAN tag of VLAN-tagged packets received and sent by the subinterfaces of GigabitEthernet 3/1/1.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] dot1q ethernet-type 9100
second-dot1q
Use second-dot1q to enable QinQ termination on an interface, and specify the Layer 2 VLAN IDs of the VLAN-tagged packets that can be terminated by the interface.
Use undo second-dot1q to disable QinQ termination on an interface.
second-dot1q { vlan-id-list | any }
undo second-dot1q { vlan-id-list | any }
QinQ termination is disabled on the interface.
VLAN interface view
vlan-id-list: Specifies a space-separated list of up to 10 Layer 2 VLAN ID items. Each item specifies a Layer 2 VLAN ID or a range of Layer 2 VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
any: Specifies all values between 1 and 4094.
When you execute this command, the Layer 1 VLAN ID of VLAN-tagged packets that can be terminated by the interface is the interface number. This Layer 1 VLAN ID is not configurable.
# Configure GigabitEthernet 3/1/1.10 to terminate VLAN-tagged packets with Layer 2 VLAN IDs in the range of 10 to 20.
[Sysname] interface gigabitethernet 3/1/1.10
[Sysname-GigabitEthernet3/1/1.10] second-dot1q 10 to 20
[Sysname-GigabitEthernet3/1/1.10] quit
# Configure GigabitEthernet 3/1/1.12 to terminate VLAN-tagged packets with Layer 2 VLAN ID 100.
[Sysname] interface gigabitethernet 3/1/1.12
[Sysname-GigabitEthernet3/1/1.12] second-dot1q 100
[Sysname-GigabitEthernet3/1/1.12] quit
# Configure GigabitEthernet 3/1/1.100 to terminate VLAN-tagged packets with any Layer 2 VLAN IDs.
[Sysname] interface gigabitethernet 3/1/1.100
[Sysname-GigabitEthernet3/1/1.100] second-dot1q any
The following table describes the configuration results:
Layer 1 VLAN ID of VLAN-tagged packets that the subinterface can terminate
Layer 2 VLAN IDs of VLAN-tagged packets that the subinterface can terminate
10
10–20
12
100
100
1–4094
user-vlan dot1q vid
Use user-vlan dot1q vid to enable user VLAN Dot1q termination on a subinterface, and specify the outermost VLAN IDs in the VLAN-tagged packets that can be terminated by the subinterface.
Use undo user-vlan dot1q vid to disable user VLAN Dot1q termination on a subinterface.
user-vlan dot1q vid vlan-id-list
undo user-vlan dot1q vid vlan-id-list
User VLAN Dot1q termination is disabled on a subinterface.
vlan-id-list: Specifies a space-separated list of up to 10 outermost VLAN ID items. Each item specifies an outermost VLAN ID or a range of outermost VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
This command is not available on the subinterfaces of the following interfaces:
The outermost VLAN ID ranges specified by the vlan-id-list argument for different subinterfaces of a main interface cannot overlap.
This command and the vlan-type dot1q vid command are mutually exclusive on the same subinterface.
# Enable user VLAN Dot1q termination on GigabitEthernet 3/1/1.1, and configure the interface to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 2 to 100.
[Sysname-GigabitEthernet3/1/1.1] user-vlan dot1q vid 2 to 100
display user-vlan
Use user-vlan dot1q vid second-dot1q to enable user VLAN QinQ termination on a subinterface, and specify the outermost two layers of VLAN IDs in VLAN-tagged packets that are terminated by the subinterface.
Use undo user-vlan dot1q vid second-dot1q to disable user VLAN QinQ termination on a subinterface.
user-vlan dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
undo user-vlan dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
User VLAN QinQ termination is disabled on a subinterface.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN ID items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
Two subinterfaces of the same Ethernet interface cannot terminate packets that include the same two layers of VLAN IDs. If you configure the subinterfaces to terminate the same Layer 1 VLAN ID, make sure their Layer 2 VLAN ID ranges do not overlap. If you specify both any and vlan-id-list as the respective Layer 2 VLAN ID ranges of the subinterfaces, the any keyword does not include the VLAN IDs specified by vlan-id-list.
The outermost VLAN IDs cannot overlap if this command and the vlan-type dot1q vid second-dot1q command are configured on subinterfaces of the same main interface.
This command and the vlan-type dot1q vid second-dot1q command are mutually exclusive on the same subinterface.
# Enable user VLAN QinQ termination on GigabitEthernet3/1/1.1. Configure the interface to terminate VLAN-tagged packets with Layer 1 VLAN IDs in the range of 1 to 100 and Layer 2 VLAN IDs in the range of 500 to 600.
[Sysname-GigabitEthernet3/1/1.1] user-vlan dot1q vid 1 to 100 second-dot1q 500 to 600
display user-vlan
vlan-termination broadcast enable
Use vlan-termination broadcast enable to enable an interface to transmit broadcasts and multicasts.
Use undo vlan-termination broadcast enable to disable an interface from transmitting broadcasts and multicasts.
Broadcast and multicast packets are dropped on an interface configured with Dot1q/QinQ termination to terminate packets of multiple VLANs.
Layer 3 aggregate/Ethernet subinterface view
L3VE subinterface view
VLAN interface view
IMPORTANT
IMPORTANT:
This command affects system performance. If system performance is seriously affected by this command, execute the undo form of this command to remove the command configuration.
Use this command when ambiguous Dot1q or QinQ termination is enabled on an interface.
To transmit a broadcast or multicast packet, the interface starts a traversal over all the VLAN IDs specified for Dot1q/QinQ termination. It copies the packet and tags each copy with VLAN IDs, until all combinations of VLAN IDs are traversed.
·          Configure GigabitEthernet 3/1/1.10 to tag a multicast or broadcast packet with each VLAN tag in the range of 10 to 20.
# Enable Dot1q termination on GigabitEthernet 3/1/1.10 to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 10 to 20.
[Sysname-GigabitEthernet3/1/1.10] vlan-type dot1q vid 10 to 20
# Enable GigabitEthernet 3/1/1.10 to transmit broadcast and multicast packets.
[Sysname-GigabitEthernet3/1/1.10] vlan-termination broadcast enable
·          Configure GigabitEthernet 3/1/1.10 to tag a multicast or broadcast packet with each Layer 1 VLAN ID and each Layer 2 VLAN ID. The Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
# Configure GigabitEthernet 3/1/1.10 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
[Sysname-GigabitEthernet3/1/1.10] vlan-type dot1q vid 300 to 400 second-dot1q 500 to 600
vlan-termination broadcast ra
Use vlan-termination broadcast ra to enable an interface to transmit router advertisement (RA) multicast packets.
Use undo vlan-termination broadcast ra to disable an interface from transmitting RA multicast packets.
VLAN interface view
To transmit an RA multicast packet, the interface starts a traversal over all the VLAN IDs specified for Dot1q/QinQ termination. It copies the packet and tags each copy with VLAN IDs, until all combinations of VLAN IDs are traversed.
On an IPv6 network, you must use this command to enable an ambiguous Dot1q or QinQ termination-enabled interface to transmit RA multicast packets. This command prohibits transmission of broadcast packets and other types of multicast packets, and consumes less CPU resources than the vlan-termination broadcast enable command.
·          Configure GigabitEthernet 3/1/1.10 to tag RA multicast packets with each VLAN tag in the range of 10 to 20.
# Enable GigabitEthernet 3/1/1.10 to transmit RA multicast packets.
[Sysname-GigabitEthernet3/1/1.10] vlan-termination broadcast ra
·          Configure GigabitEthernet 3/1/1.10 to tag RA multicast packets with each Layer 1 VLAN ID and each Layer 2 VLAN ID. The Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
vlan-termination user-mode
Use vlan-termination user-mode to enable user mode of VLAN termination.
Use undo vlan-termination user-mode to disable user mode of VLAN termination.
User mode of VLAN termination is disabled.
After you modify VLAN termination on a subinterface, the subinterface automatically restarts. In some networks (for example, networks using IPoE or PPPoE connections), the subinterface restart logs off online users. To prevent the subinterface restart and protect the online user state, enable user mode of VLAN termination before you modify VLAN termination on the subinterface.
After you enable user mode of VLAN termination and modify VLAN termination on a subinterface, clear entries of VLANs that are no longer terminated by the subinterface. For example, use the reset arp interface command in user view to clear all ARP entries for a subinterface after you modify VLAN termination on it. If you do not clear these entries, running services might be affected. For more information about the reset arp command, see ARP commands in Layer 3—IP Services Command Reference.
# Enable user mode of VLAN termination on GigabitEthernet 3/1/1.1.
[Sysname-GigabitEthernet3/1/1.1] vlan-termination user-mode
vlan-type dot1q vid
Use vlan-type dot1q vid to enable Dot1q termination on a subinterface, and specify the outermost VLAN IDs in the VLAN-tagged packets that can be terminated by the subinterface.
Use undo vlan-type dot1q vid to disable Dot1q termination on a subinterface.
vlan-type dot1q vid vlan-id-list
undo vlan-type dot1q vid vlan-id-list
Subinterfaces on the following interfaces terminate only packets whose outermost VLAN ID is the same as the subinterface number:
This command and the user-vlan dot1q vid command are mutually exclusive on the same subinterface.
# Configure GigabitEthernet 3/1/1.1 to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 2 to 100.
[Sysname-GigabitEthernet3/1/1.1] vlan-type dot1q vid 2 to 100
Use vlan-type dot1q vid second-dot1q to enable QinQ termination on a subinterface, and specify the outermost two layers of VLAN IDs of VLAN-tagged packets that can be terminated by the subinterface.
Use undo vlan-type dot1q vid second-dot1q to disable QinQ termination on a subinterface.
vlan-type dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
undo vlan-type dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
Subinterfaces on the following interfaces terminate only packets whose Layer 1 VLAN ID is the same as the subinterface number:
Two subinterfaces of the same main interface cannot terminate packets that include the same two layers of VLAN IDs. If you configure the subinterfaces to terminate the same Layer 1 VLAN ID, make sure their Layer 2 VLAN ID ranges do not overlap. If you specify both any and vlan-id-list as the respective Layer 2 VLAN ID ranges of the subinterfaces, the any keyword does not include the VLAN IDs specified by vlan-id-list.
The outermost VLAN IDs cannot overlap if this command and the user-vlan dot1q vid second-dot1q command are configured on subinterfaces of the same main interface.
This command and the user-vlan dot1q vid second-dot1q command are mutually exclusive on the same subinterface.
# Enable QinQ termination on the Layer 3 Ethernet subinterfaces, and configure each subinterface to terminate VLAN-tagged packets with the specified Layer 1 and Layer 2 VLAN IDs.
·          Configure GigabitEthernet 3/1/1.1 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are both 100.
[Sysname-GigabitEthernet3/1/1.1] vlan-type dot1q vid 100 second-dot1q 100
[Sysname-GigabitEthernet3/1/1.1] quit
·          Configure GigabitEthernet 3/1/1.2 to terminate VLAN-tagged packets with Layer 1 VLAN ID 100 and Layer 2 VLAN IDs in the range of 200 to 300.
[Sysname] interface gigabitethernet 3/1/1.2
[Sysname-GigabitEthernet3/1/1.2] vlan-type dot1q vid 100 second-dot1q 200 to 300
[Sysname-GigabitEthernet3/1/1.2] quit
·          Configure GigabitEthernet 3/1/1.3 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is any value between 1 and 4094.
[Sysname] interface gigabitethernet 3/1/1.3
[Sysname-GigabitEthernet3/1/1.3] vlan-type dot1q vid 100 second-dot1q any
[Sysname-GigabitEthernet3/1/1.3] quit
·          Configure GigabitEthernet 3/1/1.4 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is in the range of 500 to 600.
[Sysname] interface gigabitethernet 3/1/1.4
[Sysname-GigabitEthernet3/1/1.4] vlan-type dot1q vid 100 second-dot1q 500 to 600
[Sysname-GigabitEthernet3/1/1.4] quit
·          Configure GigabitEthernet 3/1/1.5 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 200 and Layer 2 VLAN ID is in the range of 500 to 600.
[Sysname] interface gigabitethernet 3/1/1.5
[Sysname-GigabitEthernet3/1/1.5] vlan-type dot1q vid 200 second-dot1q 500 to 600
[Sysname-GigabitEthernet3/1/1.5] quit
·          Configure GigabitEthernet 3/1/1.6 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is in the range of 300 to 400 and Layer 2 VLAN ID is 100.
[Sysname] interface gigabitethernet 3/1/1.6
[Sysname-GigabitEthernet3/1/1.6] vlan-type dot1q vid 300 to 400 second-dot1q 100
[Sysname-GigabitEthernet3/1/1.6] quit
·          Configure GigabitEthernet 3/1/1.7 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 IDs are in the range of 300 to 400 and 500 to 600, respectively.
[Sysname] interface gigabitethernet 3/1/1.7
[Sysname-GigabitEthernet3/1/1.7] vlan-type dot1q vid 300 to 400 second-dot1q 500 to 600
[Sysname-GigabitEthernet3/1/1.7] quit
·          Configure GigabitEthernet 3/1/1.8 to terminate VLAN-tagged packets with a Layer 1 VLAN ID in the range of 300 to 400 and any Layer 2 VLAN ID.
[Sysname] interface gigabitethernet 3/1/1.8
[Sysname-GigabitEthernet3/1/1.8] vlan-type dot1q vid 300 to 400 second-dot1q any
Layer 1 VLAN IDs of VLAN-tagged packets that the subinterface can terminate
100
100
100
200–300
100
1–99, 101–199, 301–499, and 601–4094
100
500–600
200
500–600
300–400
100
300–400
500–600
300–400
1–99, 101–499, and 601–4094
