- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Target configuration management commands
- 09-Device management commands
- 10-Tcl commands
- 11-Python commands
| 09-Device management commands | 367.28 KB |
display cpu-usage configuration
display cpu-usage overload summary
display device manuinfo chassis-only
display diagnostic-information
display hardware-failure-detection
display hardware-failure-protection
display non-stop-routing status
display power-off high-temp-board
hardware-failure-protection aggregation
hardware-failure-protection auto-down
power-off high-temp-board clear
card-mode
Use card-mode to set the operating mode for an interface subcard.
In standalone mode:
card-mode slot slot-number subslot subslot-number mode-name
In IRF mode:
card-mode chassis chassis-number slot slot-number subslot subslot-number mode-name
A MIC-SP4L subcard operates in oc-3-pos mode.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
subslot subslot-number: Specifies a subcard by its subslot number.
mode-name: Specifies an operating mode.
· oc-12-atm: Specifies the oc-12-atm mode. All interfaces on the interface subcard act as ATM OC-12c/STM-4 interfaces and use SONET/SDH for data transmission.
· oc-12-pos: Specifies the oc-12-pos mode. All interfaces on the interface subcard act as 622 Mbps POS interfaces.
· oc-3-atm: Specifies the oc-3-atm mode. All interfaces on the interface subcard act as ATM OC-3c/STM-1 interfaces and use SONET/SDH for data transmission.
· oc-3-pos: Specifies the oc-3-pos mode. All interfaces on the interface subcard act as 155 Mbps POS interfaces.
This command is supported only on MIC-SP4L subcards.
The oc-3-atm and oc-12-atm modes are supported only on MIC-SP4L subcards installed on the following cards: MPE-1104, CSPEX-1104-E, CSPEX-1304X/CSPEX-1304S, CSPEX-1404X/CSPEX-1404S, and CSPEX-1504X/CSPEX-1504S.
On a subcard operating in oc-12-atm or oc-12-pos mode, only the first interface is available.
If you change the operating mode for an interface subcard, the subcard reboots to operate in the new operating mode.
For more information about interface types, see Interface Configuration Guide.
# (In standalone mode.) Set the operating mode to oc-12-atm for a subcard.
[Sysname] card-mode slot 2 subslot 1 oc-12-atm
clock datetime
Use clock datetime to set the system time.
clock datetime time date
The device uses the factory-default system time.
time: Specifies the time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies the date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
For the device to use the local system time, execute the clock protocol none command and this command in turn. The specified system time takes effect immediately. Then, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
If you set the time zone or daylight saving time after you configure this command, the device recalculates the system time. To view the system time, use the display clock command.
# Set the system time to 08:08:08 01/01/2012.
<Sysname> clock datetime 8:8:8 1/1/2012
# Set the system time to 08:10:00 01/01/2012.
<Sysname> clock datetime 8:10 2012/1/1
clock protocol
clock summer-time
clock timezone
display clock
clock protocol
Use clock protocol to specify the system time source.
Use undo clock protocol to restore the default.
clock protocol { none | { ntp | ptp } mdc mdc-id }
undo clock protocol
The device uses the NTP time source .
none: Uses the local system time, which is set by using the clock datetime command.
ptp: Uses PTP to obtain the UTC time. You must configure PTP correctly. For more information about PTP, see Network Management and Monitoring Configuration Guide. This keyword is not supported on SR8800-X-S routers.
ntp: Uses NTP to obtain the UTC time. You must configure NTP correctly. For more information about NTP, see Network Management and Monitoring Configuration Guide.
mdc mdc-id: Specifies the MDC to be used for time synchronization.
· If you configure the clock protocol none command, the device uses the locally set system time. The device then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
· If you configure the clock protocol { ntp | ptp } command, the device obtains the UTC time through NTP or PTP and calculates the system time. The device then periodically synchronizes the UTC time and recalculates the system time.
The system time calculated by using the UTC time from an NTP or PTP time source is more precise.
# Configure the device to use the local system time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to set the daylight saving time.
Use undo clock summer-time to restore the default.
The daylight saving time is not set.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
· MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
· month week day, where:
¡ month—Takes January, February, March, April, May, June, July, August, September, October, November, or December.
¡ week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡ day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
¡ month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
clock datetime
clock timezone
display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The UTC time zone is used.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time or local system time.
minus: Decreases the UTC time or local system time by an offset.
zone-offset: Specifies the offset in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time or local system time.
[Sysname] clock timezone Z5 add 5
clock datetime
clock summer-time
display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order of their command IDs.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to the backupconfig job to back up the startup.cfg file to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to the shutdownGE job to shut down GigabitEthernet 3/1/1.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 3/1/1
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
copyright-info enable
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
# Enable copyright statement display.
[Sysname] copyright-info enable
The device will display the following statement when a user logs in:
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
display alarm
Use display alarm to display alarm information.
In standalone mode:
display alarm [ slot slot-number ]
In IRF mode:
display alarm [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays alarm information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays alarm information for all cards. (In IRF mode.)
# (In standalone mode.) Display alarm information.
<Sysname> display alarm
Slot CPU Level Info
1 0 ERROR faulty
Slot |
Slot that generated the alarm. If the alarm was generated by the chassis, this field displays a hyphen (-). |
Level |
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order. |
Info |
Detailed alarm information: · faulty—The slot is starting up or faulty. · Fan n is absent—The specified fan is absent. · Power n is absent—The specified power supply is absent. · The temperature of sensor n exceeds the lower limit—The temperature of the specified sensor is lower than the low-temperature threshold. · The temperature of sensor n exceeds the upper limit—The temperature of the specified sensor is higher than the high-temperature warning threshold. |
display clock
Use display clock to display the system time, date, time zone, and daylight saving time.
display clock
# Display the system time and date when the time zone is not specified.
<Sysname> display clock
10:09:00 UTC Fri 03/16/2012
# Display the system time and date when the time zone Z5 is specified.
15:10:00 Z5 Fri 03/16/2012
Time Zone : Z5 add 05:00:00
# Display the system time and date when the time zone Z5 and daylight saving time PDT are specified.
15:11:00 Z5 Fri 03/16/2012
clock datetime
clock timezone
clock summer-time
display copyright
Use display copyright to display the copyright statement.
# Display the copyright statement.
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
In standalone mode:
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display cpu-usage [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
control-plane: Displays CPU usage statistics for the control plane. If you do not specify this keyword or the data-plane keyword, the command displays CPU usage statistics for the control plane.
data-plane: Displays CPU usage statistics for the data plane. If you do not specify this keyword or the control-plane keyword, the command displays CPU usage statistics for the control plane.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays CPU usage statistics for all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number.
core { core-number | all }: Displays CPU core usage statistics. The core-number: argument specifies a CPU core by its number. The all keyword specifies all CPU cores.
# (In standalone mode.) Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# (In standalone mode.) Display the current CPU usage statistics in table form.
Slot CPU Last 5 sec Last 1 min Last 5 min
1 0 17% 29% 28%
x% in last 5 seconds Last 5 sec |
Average CPU usage during the most recent 5-second interval. |
y% in last 1 minute Last 1 min |
Average CPU usage during the most recent 1-minute interval. |
z% in last 5 minutes Last 5 min |
Average CPU usage during the most recent 5-minute interval. |
Use display cpu-usage configuration to display CPU usage monitoring settings.
In standalone mode:
In IRF mode:
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage monitoring settings for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the CPU usage monitoring settings for the global active MPU. (In IRF mode.)
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 79%.
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
display cpu-usage history
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
In standalone mode:
In IRF mode:
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id: Specifies a process by its ID. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies a card by its slot number. If you specify a process but do not specify a card, this command displays the statistics for the process on the active MPU. If you do not specify any options, this command displays the statistics for all processes on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you specify a process but do not specify a card, this command displays the statistics for the process on the global active MPU. If you do not specify any options, this command displays the statistics for all processes on all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
· The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
· The horizontal axis represents the time.
· Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# (In standalone mode.) Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
· Process name. The name SYSTEM represents the entire system.
· CPU that is holding the process: CPU 0 in slot 1.
· Historical CPU usage statistics for the entire system during the last 60 minutes.
¡ 12 minutes ago—Approximately 5%.
¡ 13 minutes ago—Approximately 10%.
¡ 14 minutes ago—Approximately 15%.
¡ 15 minutes ago—Approximately 10%.
¡ 16 and 17 minutes ago—Approximately 5%.
¡ 18 minutes ago—Approximately 10%.
¡ 19 minutes ago—Approximately 5%.
¡ Other time—2% or lower.
Use display cpu-usage overload to display CPU overload records.
In standalone mode:
display cpu-usage overload show-number [ stack-info ] slot slot-number [ cpu cpu-number ]
In IRF mode:
display cpu-usage overload show-number [ stack-info ] chassis chassis-number slot slot-number [ cpu cpu-number ]
show-number: Specifies the number of CPU overload records to be displayed, in the range of 1 to 10.
stack-info: Displays the stack information about the top three CPU resource-intensive processes. If you do not specify this keyword, the command does not display stack information.
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
# Display the most recent CPU overload record of a slot, excluding the stack information about the top three CPU resource-intensive processes.
<Sysname> display cpu-usage overload 1 slot 2 cpu 0
CPU overload summary information:
Slot/CPU Time Overload status Processes
2/0 2019-02-27 14:14:50:441 Recovered 243
2019-02-27 14:13:50:475 Minor alarm 243
2019-02-27 14:08:50:476 Minor alarm 243
2019-02-27 14:03:50:475 Minor alarm 243
2019-02-27 13:58:50:478 Minor alarm 243
2019-02-27 13:53:50:961 Recovered 243
2019-02-27 13:53:50:474 Minor alarm 243
2019-02-27 13:52:50:484 Severe alarm 243
2019-02-27 13:50:50:471 Minor alarm 243
2019-02-27 13:45:50:475 Minor alarm 243
CPU overload history on overload time 2019-02-27 14:14:50:441.
CPU utilization in recent 5 secs: 3.4%; 1 min: 3.24%; 5 mins: 3.16%.
Top processes in recent 5 secs:
JID PID PPID CPU State Mem 5sec 1min 5min Name
192 192 192 5 R 0K 2.0% 2.2% 2.1% [RxShaper]
237 237 237 6 D 0K 0.3% 0.3% 0.3% [NAT0]
239 239 239 7 D 0K 0.3% 0.3% 0.3% [NAT1]
155 155 155 0 D 0K 0.0% 0.0% 0.0% [bLK0]
243 243 243 1 R 11508K 0.0% 0.0% 0.0% diagd
182 182 182 3 D 0K 0.0% 0.0% 0.0% [bRX_CleanUp]
152 152 152 0 D 0K 0.0% 0.0% 0.0% [bC.0]
226 226 226 3 S 0K 0.0% 0.0% 0.0% [IbcCntRcd]
161 161 161 0 S 0K 0.0% 0.0% 0.0% [DQIT]
217 217 217 0 S 0K 0.0% 0.0% 0.0% [sock/1]
176 176 176 0 D 0K 0.0% 0.0% 0.0% [SCAR]
109 109 109 3 D 0K 0.0% 0.0% 0.0% [RECV]
106 106 106 0 D 0K 0.0% 0.0% 0.0% [TMTH]
133 133 133 0 D 0K 0.0% 0.0% 0.0% [DTIM]
147 147 147 2 D 0K 0.0% 0.0% 0.0% [bPAR]
163 163 163 0 S 0K 0.0% 0.0% 0.0% [FMCK]
282 282 282 0 S 64532K 0.0% 0.0% 0.0% pppd
166 166 166 0 S 0K 0.0% 0.0% 0.0% [mIPC]
162 162 162 0 S 0K 0.0% 0.0% 0.0% [STAT]
164 164 164 0 D 0K 0.0% 0.0% 0.0% [OMA]
# Display the most recent two CPU overload records of a card, including the stack information about the top three CPU resource-intensive processes.
<Sysname> display cpu-usage overload 2 stack-info slot 2 cpu 0
Stack information of process 155 ([bLK0]):
Kernel stack:
[<8038efb0>] schedule+0x960/0x12b0
[<8038fb78>] schedule_timeout+0x68/0xf0
[<e68cb4f8>] sal_sem_take+0x1c8/0x250 [system]
[<e68cb878>] sal_mutex_give+0x108/0x1f0 [system]
[<e680b0b8>] soc_schan_op+0x468/0x1130 [system]
[<e681b39c>] soc_reg64_read+0x14c/0x3e0 [system]
Stack information of process 243 (diagd):
Thread LWP 243:
Switches: 361247
User stack:
Kernel stack:
[<8038fbb0>] schedule_timeout+0xa0/0xf0
[<802251b4>] sys_epoll_wait+0x474/0x530
[<80102c78>] stack_done_ra+0x0/0x1c
Thread LWP 338796:
Switches: 1
User stack:
Kernel stack:
[<80126c9c>] save_stack_trace_tsk+0x8c/0xd0
[<8023e660>] proc_pid_stack+0x60/0xd0
[<802402a8>] proc_single_show+0x68/0xe0
[<80208b30>] seq_read+0x90/0x420
[<801e2728>] vfs_read+0xb8/0x160
[<801e28c0>] sys_read+0x50/0x90
Stack information of process 152 ([bC.0]):
Kernel stack:
[<e68aee58>] soc_counter_thread+0x248/0x17f0 [system]
[<8016ecac>] kthread+0xfc/0x140
[<8011ee20>] kernel_thread_helper+0x10/0x20
CPU overload history on overload time 2019-02-27 14:13:50:475.
CPU utilization in recent 5 secs: 4.45%; 1 min: 3.6%; 5 mins: 3.16%.
192 192 192 5 R 0K 3.0% 2.1% 2.1% [RxShaper]
239 239 239 7 R 0K 0.4% 0.2% 0.3% [NAT1]
237 237 237 6 D 0K 0.4% 0.3% 0.3% [NAT0]
155 155 155 0 D 0K 0.1% 0.0% 0.0% [bLK0]
169 169 169 0 S 0K 0.0% 0.0% 0.0% [T_SI]
Kernel stack:
[<e6c4c108>] _bcm_esw_linkscan_thread+0x288/0x650 [system]
Thread LWP 243:
Switches: 361208
User stack:
Kernel stack:
[<80100b94>] work_resched+0x8/0x40
Thread LWP 338795:
Switches: 1
User stack:
Kernel stack:
Kernel stack:
Time |
Time when the overload event occurred. If no overload events occurred, this field displays 0000-00-00 00:00:00:000. |
Overload status |
Overload status: · No overloaded—The CPU is not overloaded. This state is the initial state. · Minor alarm—The CPU load exceeded the minor alarm threshold. · Severe alarm—The CPU load exceeded the severe alarm threshold. · Recovered—The CPU load dropped below the CPU overload alarm-removed threshold. |
Processes |
Number of processes when the overload event occurred. If no overload events occurred, this field displays NA. |
CPU overload history on overload time 2018-11-12 10:00:00:000: |
Detailed CPU overload information. If no overload events occurred, this field displays No CPU overload history. |
Overload time |
Top processes in recent 5 secs |
Top CPU resource-intensive processes in recent 5 seconds, in descending order. |
JID |
Job ID. A job ID uniquely identifies a process and does not change after a process reboot. |
PID |
Process ID. |
PPID |
ID of the parent process. |
CPU |
CPU where the process was running when it was most recently scheduled. |
State |
Process status: · R—The process is running or in the run queue. · S—The process is in interruptible sleeping state. · T—The process is in traced or stopped state. · D—The process is in uninterruptible sleeping state. · Z—The process is in zombie state. |
Mem |
Memory space used by the process. For a kernel thread, this field displays 0. |
5sec |
CPU utilization in the last 5 seconds. |
1min |
CPU utilization in the last minute. |
5min |
CPU utilization in the last 5 minutes. |
Name |
Process name. For a kernel thread, this field displays the name in a pair of brackets ([ ]). |
Stack information of process PID (process name): |
Stack information of a process. The PID indicates the process ID. |
Thread LWP 1: |
Child process of a traced process. |
Switches |
Total number of switches. |
User stack |
User space stack information. This field is displayed only for a process in the user space. |
Kernel stack |
Kernel space stack information. |
Use display cpu-usage overload summary to display summary CPU overload information.
# Display summary CPU overload information.
<Sysname> display cpu-usage overload summary
0/0 2019-02-27 14:32:59:831 Recovered 356
2019-02-27 14:31:59:884 Severe alarm 356
2019-02-27 14:30:59:848 Severe alarm 358
2019-02-27 14:29:59:868 Severe alarm 358
2019-02-27 14:28:59:840 Severe alarm 358
2019-02-27 14:27:59:862 Severe alarm 356
2019-02-27 14:26:59:830 Severe alarm 356
2019-02-27 14:25:59:857 Severe alarm 356
2019-02-27 14:24:59:838 Severe alarm 356
2019-02-27 14:23:59:867 Severe alarm 356
3/0 0000-00-00 00:00:00:000 No overloaded NA
For information about the fields in the command output, see Table 3.
display device
Use display device to display device information.
In standalone mode:
display device [ cf-card | sd-card ] [ slot slot-number [ subslot subslot-number ] | verbose ]
In IRF mode:
display device [ cf-card | sd-card ] [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ]
cf-card: Specifies the CF cards.
sd-card: Specifies the SD cards. This keyword is supported only on SR05SRP1P3 cards.
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays hardware information for all member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays hardware information for all cards.
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subcard, this command does not display information about any subcards.
verbose: Displays detailed hardware information. If you do not specify this keyword, the command displays brief information, and does not display firewall card information.
If you do not specify the cf-card or sd-card keyword, this command displays information about cards.
# Display device information.
<Sysname> display device
Brd Type |
Hardware type of the card. |
Brd Status |
Card status: · Standby—The card is the standby MPU. · Master—The card is the active MPU. · Absent—The slot is not installed with a card. · Fault—The card is faulty and cannot start up. · Normal—The card is an interface card and is operating correctly. · Off—The card is not powered on. · Illegal—The card is not supported in the current software version and cannot operate correctly. · Offline—The card is isolated. |
Subslot Num |
Maximum number of subcards that the card supports. |
Software version |
Software version of the card. |
Use display device manuinfo to display electronic label information for the device.
In standalone mode:
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
In IRF mode:
display device manuinfo [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays electronic label information for all member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays electronic label information of all cards.
An electronic label contains the permanent configuration information, including the card serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during card debugging or testing. This command displays only part of the electronic label information.
# (In standalone mode.) Display electronic label information for the device.
<Sysname> display device manuinfo
Table 5 Command output
DEVICE_NAME |
Device name. |
DEVICE_SERIAL_NUMBER |
Serial number. |
MAC_ADDRESS |
MAC address. |
MANUFACTURING_DATE |
Manufacturing date. |
VENDOR_NAME |
Vendor name. |
Use display device manuinfo chassis-only to display electronic label information for the backplane.
In standalone mode:
In IRF mode:
display device manuinfo chassis chassis-number chassis-only
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
# (In standalone mode.) Display electronic label information for the backplane.
<Sysname> display device manuinfo chassis-only
Table 6 Command output
DEVICE_NAME |
Device name. |
Serial number. |
MAC_ADDRESS |
MAC address. |
VENDOR_NAME |
Vendor name. |
display device manuinfo fan
Use display device manuinfo fan to display electronic label information for a fan tray.
In standalone mode:
display device manuinfo fan fan-id
In IRF mode:
display device manuinfo chassis chassis-number fan fan-id
fan-id: Specifies a fan tray by its ID.
This command is not supported on SR8800-X-S routers.
# (In standalone mode.) Display electronic label information for a fan tray.
<Sysname> display device manuinfo fan 0
Table 7 Command output
DEVICE_NAME |
Device name. |
Serial number. |
MAC_ADDRESS |
MAC address. |
VENDOR_NAME |
Vendor name. |
display device manuinfo power
Use display device manuinfo power to display electronic label information for a power supply.
In standalone mode:
display device manuinfo power power-id
In IRF mode:
display device manuinfo chassis chassis-number power power-id
power-id: Specifies a power supply by its ID.
On SR8800-X-S routers, only PSR2500-12D and PSR2500-12AHD power supplies support this command.
# (In standalone mode.) Display electronic label information for a power supply.
<Sysname> display device manuinfo power 1
Table 8 Command output
DEVICE_NAME |
Device name. |
Serial number. |
MAC_ADDRESS |
MAC address. |
VENDOR_NAME |
Vendor name. |
Use display diagnostic-information to display or save operating information for features and hardware modules.
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware: Specifies hardware-related operating information.
infrastructure: Specifies operating information for the fundamental features.
l2: Specifies operating information for the Layer 2 features.
l3: Specifies operating information for the Layer 3 features.
service: Specifies operating information for Layer 4 and upper-layer features.
key-info: Displays or saves only critical operating information. The device might have a large amount of operating information if an exception occurs or after the device runs a long period of time. Specifying this keyword reduces the command execution time and helps you focus on critical operating information. If you do not specify this keyword, the command displays or saves both critical and non-critical operating information.
filename: Saves the information to a file. The filename argument must use the .tar.gz suffix. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
You can use one of the following methods to collect operating statistics for diagnostics and troubleshooting:
· Use separate display commands to collect operating information feature by feature or module by module.
· Use the display diagnostic-information command to collect operating information for multiple or all features and hardware modules.
To save storage space, the display diagnostic-information command automatically compresses information before saving information to a file. To view the file content:
1. Use the tar extract command to extract the file.
2. Use the gunzip command to decompress the extracted file.
3. Use the more command to view the content of the decompressed file.
If you abort the display diagnostic-information command, the gunzip command might not be able to decompress the extracted file. To decompress the extracted file, export the extracted file to a PC that is running Linux, and use the gunzip -c command.
If you do not specify any feature parameters, this command displays or saves the operating information for all features and modules.
If you do not specify a file name for the command, the system prompts you to choose whether to display or save the information. If you choose to save the information, the system automatically assigns a file name and displays the file name in brackets. For file name uniqueness, the file name includes the device name and the current system time. If the device name contains any of the following special characters, the system uses an underscore (_) to replace each special character: forward slashes (/), backward slashes (\), colons (:), asterisks (*), question marks (?), less than signs (<), greater than signs (>), and pipeline signs (|). For example, if the device name is A/B, the device name in the file name will be A_B, as in flash:/diag_A_B_20160101-000438.tar.gz.
This command does not support the |, >, or >> option.
While the device is executing this command, do not execute any other commands. Executing other commands might affect the collected operating information.
# Display the operating information for all features and modules.
14:03:55 UTC Thu 01/05/2012
# Save the operating information for all features and modules to the default file.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
Press Enter when the system prompts you to enter the file name.
# Save the operating information for all features and modules to the test.tar.gz file.
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
gunzip
more
tar extract
display environment
Use display environment to display temperature information.
In standalone mode:
In IRF mode:
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays temperature information for all member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards.
(In standalone mode.) This command displays information about all temperature sensors on the device if you do not specify a card.
(In IRF mode.) This command displays information about all temperature sensors in the IRF fabric if you do not specify an IRF member device. If you specify an IRF member device but do not specify a card, this command displays information about all sensors on the member device.
# (In standalone mode.) Display information about all temperature sensors on the device.
<Sysname> display environment
System temperature information (degree centigrade):
Slot Sensor Temperature Lower Warning Alarm Shutdown
0 inflow 1 25 0 48 60 NA
0 hotspot 1 31 0 80 95 NA
2 inflow 1 29 0 80 97 NA
2 outflow 1 26 0 80 97 NA
2 hotspot 1 31 0 80 97 NA
2 hotspot 2 42 0 80 97 NA
3 inflow 1 31 0 80 97 NA
3 outflow 1 32 0 80 97 NA
3 hotspot 1 47 0 80 97 NA
3 hotspot 2 38 0 80 97 NA
4 hotspot 1 30 0 75 90 NA
6 hotspot 1 41 0 88 100 110
· SR8800-X-S
0 inflow 1 29 0 80 97 NA
0 hotspot 1 37 0 80 97 NA
0 hotspot 2 26 0 80 97 NA
0 hotspot 3 32 0 80 97 NA
1 inflow 1 28 0 80 97 NA
1 hotspot 1 37 0 80 97 NA
1 hotspot 2 26 0 80 97 NA
1 hotspot 3 30 0 80 97 NA
2 hotspot 1 30 0 75 90 NA
7 inflow 1 38 0 80 97 NA
7 outflow 1 37 0 80 97 NA
7 hotspot 1 59 0 80 97 NA
7 hotspot 2 47 0 80 97 NA
Table 9 Command output
System Temperature information (degree centigrade) |
Temperature information (°C). |
sensor |
Temperature sensor: · hotspot—Hotspot sensor. · inflow—Air inlet sensor. · outflow—Air outlet sensor. |
Slot |
Sensor position. For a sensor on the chassis or fan tray, this field displays Vent. |
Temperature |
Current temperature. |
LowerLimit |
Lower temperature limit. |
WarningLimit |
Warning temperature threshold. |
AlarmLimit |
Alarming temperature threshold. |
ShutdownLimit |
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system automatically shuts down some cards. |
display fan
Use display fan to display fan tray operating status information.
In standalone mode:
display fan [ fan-id ]
In IRF mode:
display fan [ chassis chassis-number [ fan-id ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fan tray operating status information for all member devices. (In IRF mode.)
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
Fan Frame 0 State: Normal
Fan Frame |
Fan tray ID. |
State |
Status of the fan tray: · Normal—The fan tray is operating correctly. · Absent—No fan tray is installed in the fan tray slot. · Fault—The fan tray is faulty. |
display fan-speed
Use display fan-speed to display the current fan operating mode and the speeds of fans.
In standalone mode:
display fan-speed
In IRF mode:
display fan-speed [ chassis chassis-number ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices. (In IRF mode.)
On an SR8800-X-S router, this command displays only the current fan operating mode.
# Display the current fan operating mode and the speeds of fans.
· SR8800-X
[Sysname] display fan-speed
Current fan speed mode is auto
Frame 0 fan 1 speed is 2414 (R.P.M)
Frame 0 fan 2 speed is 2406 (R.P.M)
Frame 0 fan 3 speed is 3364 (R.P.M)
Frame 0 fan 4 speed is 3342 (R.P.M)
Frame 0 fan 5 speed is 3357 (R.P.M)
Frame 0 fan 6 speed is 3324 (R.P.M)
Frame 0 fan 7 speed is 3361 (R.P.M)
Frame 0 fan 8 speed is 3288 (R.P.M)
· SR8800-X-S
The device doesn't support displaying fan speeds.
Use display hardware-failure-detection to display the hardware failure detection settings and the latest 10 fix records for each card.
In standalone mode, the fix records are stored on the active MPU. You can use this command to display the records for a card even if the card is removed or replaced. The fix records are lost only when you remove or power cycle the active MPU.
In IRF mode, the fix records are stored on the local active MPU. You can use this command to display the records for a card even if the card is removed or replaced. The fix records are lost only when you remove or power cycle the local active MPU.
# (In standalone mode.) Display hardware failure detection settings and fix records.
<Sysname> display hardware-failure-detection
Current level:
forwarding : warning
Recent record:
--------------------------Slot 0 executed records:-----------------------------
--------------------------Slot 0 trapped records:-----------------------------
Table 11 Command output
Current level |
Fix actions specified for hardware failures. |
forwarding |
Fix action for hardware failures on the forwarding plane. |
Recent record |
Recent failure fix records. |
xxx executed records |
Fix records stored on an MPU. |
xxx trapped records |
Trap records stored on an MPU. |
Use display hardware-failure-protection to display the hardware failure detection settings and the latest 10 fix records for each card.
display hardware-failure-protection [ aggregation | port { auto-down | interface-type interface-number } ]
aggregation: Displays the hardware failure protection settings for aggregation groups.
port: Displays the hardware failure protection settings for interfaces.
auto-down: Displays the interfaces on which hardware failure protection is enabled.
interface-type interface-number: Displays the hardware failure protection settings for an interface.
If you do not specify any option, the command displays all hardware failure protection settings on the device.
# Display all hardware failure protection settings.
<Sysname> display hardware-failure-protection
Aggregation: on
Port: GE3/1/1 GE3/1/2
# Display the interfaces on which hardware failure protection is enabled.
<Sysname> display hardware-failure-protection port auto-down
# Display whether hardware failure protection is enabled for interface GigabitEthernet 3/1/2.
<Sysname> display hardware-failure-protection port gigabitethernet 3/1/2
Hardware failure protection is enabled on the interface. The system will shut down the interface when it detects a hardware failure on the interface.
Table 12 Command output
Aggregation |
Whether hardware failure protection is enabled for aggregation groups. |
Port |
Interfaces on which hardware failure protection is enabled. |
display health
Use display health to display CPU and memory usage.
In standalone mode:
display health [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display health [ chassis chassis-number [ slot slot-number [ cpu cpu-number ] ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays CPU and memory usage on all member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays CPU and memory usage on all cards.
# (In standalone mode.) Display the CPU and memory usage on a card.
<Sysname> display health
Slot CPU Role CPU Usage(%) Memory Usage(%) Used/Total(MB)
1 0 MPU(Master) 7 23 1902504/8130012
2 0 LPU 9 48 963064/1991292
3 0 LPU 7 47 1913916/4052524
5 0 LPU 4 18 1538196/8158684
6 0 SFU 3 36 361296/984332
7 0 SFU 6 36 361348/984332
Table 13 Command output
Role |
Role of the card: · MPU(Master)—The card is the active MPU. (In standalone mode.) · MPU(Standby)—The card is the standby MPU. (In standalone mode.) · MPU(Master)—The card is the global active MPU. (In IRF mode.) · MPU(Standby)—The card is a global standby MPU. (In IRF mode.) · LPU—The card is an interface card. · BLADE—The card is a blade card. |
CPU Usage(%) |
Average CPU usage during the most recent 5 seconds. |
Memory Usage(%) |
Current memory usage in percentage. |
Used/Total(MB) |
Current memory usage and total memory size in MB. |
display memory
Use display memory to display memory usage information.
In standalone mode:
In IRF mode:
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays memory usage for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays memory usage for all MPUs. (In IRF mode.)
# (In standalone mode.) Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 984504 576428 408076 0 12 131056 41.5%
-/+ Buffers/Cache: 445360 539144
Swap: 0 0 0
LowMem: 739768 352152 387616 -- -- -- 52.4%
HighMem: 244736 224276 20460 -- -- -- 8.4%
# (In standalone mode.) Display brief memory usage information.
<Sysname> display memory summary
Slot CPU Total Used Free Buffers Caches FreeRatio
1 0 984504 576428 408076 12 131056 41.4%
Low memory statistics are measured in KB:
1 0 739768 352152 387616 -- -- 52.4%
High memory statistics are measured in KB:
1 0 244736 224276 20460 -- -- 8.4%
Table 14 Command output
Mem |
Memory usage information. |
Total |
Total size of the physical memory space that can be allocated. The memory space is virtually divided into two parts. Part 1 is solely used for kernel code and kernel management. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1. |
Used |
Used physical memory. |
Free |
Free physical memory. |
Shared |
Physical memory shared by processes. |
Buffers |
Physical memory used for buffers. |
Cached Caches |
Physical memory used for caches. |
FreeRatio |
Free memory ratio. |
-/+ Buffers/Cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications. -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications. |
Swap |
Swap memory. |
display memory-threshold
Use display memory-threshold to display memory alarm thresholds and statistics.
In standalone mode:
In IRF mode:
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the memory usage thresholds and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the memory usage thresholds and statistics for the global active MPU. (In IRF mode.)
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
Minor: 64M
Severe: 48M
Critical: 32M
Normal: 96M
Current memory state: Normal
Event statistics:
[Back to normal state]
First notification: 2012-5-15 09:21:35.546
Latest notification: 2012-5-15 09:21:35.546
Total number of notifications sent: 1
[Enter minor low-memory state]
First notification at: 2012-5-15 09:07:05.941
Latest notification at: 2012-5-15 09:07:05.941
[Back to minor low-memory state]
First notification at: 0.0
Latest notification at: 0.0
Total number of notifications sent: 0
[Enter severe low-memory state]
[Back to severe low-memory state]
[Enter critical low-memory state]
Use display non-stop-routing status to display nonstop routing (NSR) status information for modules that support the NSR feature.
# Display NSR status information for modules that support the NSR feature.
<Sysname> display non-stop-routing status
System NSR status: Not ready
Module name(instance name/process ID) Status
MSDP Not ready
OSPF(1) Ready
OSPF(2) Ready
BGP(default) Ready
BGP(aaa) Ready
PIM Not configured
Table 15 Command output
System NSR status |
Global NSR status: · Ready—NSR is in stable state for all NSR-enabled modules. · Not ready—NSR is not in stable state for one or more NSR-enabled modules. · Not configured—NSR is not enabled for any modules. · No standby—No backup hardware exists for NSR. |
Module name(instance name/process ID) |
Name of an NSR-capable module and the instance name or process ID, for example, BGP(default) and OSPF(1). If there is no instance name or process, this field displays only the module name. |
Status |
NSR status: · Ready—NSR is in stable state status for the module. · Not ready—NSR is not in stable state for the module. You cannot perform a process switchover or active/standby switchover. · Not configured—NSR is not enabled for the module. You cannot perform a process switchover or active/standby switchover. |
display power
Use display power to display power supply information.
In standalone mode:
display power [ power-id ]
In IRF mode:
display power [ chassis chassis-number [ power-id ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays power supply information for all member devices. (In IRF mode.)
power-id: Specifies a power supply by its ID. If you do not specify a power supply, this command displays information about all power supplies at the specified position.
# Display power supply information.
<Sysname> display power
Power 0 State: Normal
Power 1 State: Absent
Power 2 State: Absent
Power 3 State: Absent
· SR8800-X-S
Power 1 State: Normal
Table 16 Command output
State |
Status of the power supply: · Normal—The power supply is operating correctly. · Absent—The power supply is not in postion. · Error—The power supply is faulty. |
display power-information
Use display power-information to display power information about power supplies and cards.
In standalone mode:
display power-information [ verbose ]
In IRF mode:
display power-information [ chassis chassis-number ] [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# (In standalone mode.) Display power information about power supplies and cards.
· SR8800-X
[Sysname] display power-information
Power control mode: strict
Device power: 2500W
Surplus power: 1296W (contain 100W reserve power)
Fan power: 300W
Slot No. Power(W)
0 100 reserve for mainboard
1 100 reserve for mainboard
3 95
4 300
5 164
6 65
7 80
· SR8800-X-S
Power supply policy: balance
Device power: 1190W
Surplus power: 752W (contain 0W reserve power)
Fan power: 28W
Slot No. Power(W)
0 60 reserve for mainboard
1 60 reserve for mainboard
2 95
3 195
Table 17 Command output
Device Power |
Rated power of the device. |
Power control mode |
Card power-on control mode: · loose—Loose mode. · strict—Strict model. This field is displayed only on an SR8800-X router. |
Power supply policy |
Power supply operating mode. This field is supported only on SR8800-X-S routers. The value of this field is fixed at balance. |
Surplus power |
Remaining power of the device. |
Fan Power |
Maximum power of the fans. |
Use display power-off high-temp-board to display whether the overtemperature auto shutdown feature is enabled.
This command is supported on the following cards:
· SPC cards that have an interface capacity greater than 80 Gbps. The interface capacity of a card is the sum of speeds of all interfaces on the card. For example, the interface capacity of a SPC-XP24LCX card is 240 Gbps (24 x 10 Gbps).
· MPE-1104 cards and IM-MSUX cards.
· CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, SPEX cards, CSPEX cards, and CEPC cards.
· Switching fabric modules.
# Display whether the overtemperature auto shutdown feature is enabled.
<Sysname> display power-off high-temp-board
Power off high temperature board mode: Enable
display scheduler job
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a job, this command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
vlan 100
// The output shows that the device has three jobs: the first has one command, the second does not have any commands, and the third has two commands. Jobs are separated by blank lines.
display scheduler logfile
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name : shutdown
Schedule name : shutdown
Execution time : Tue Dec 27 10:44:42 2011
Completion time : Tue Dec 27 10:44:47 2011
<Sysname>system-view
[Sysname]interface rang gigabitethernet 3/1/1 to gigabitethernet 3/1/3
[Sysname-if-range]shutdown
Table 18 Command output
Logfile Size |
Size of the log file, in bytes. |
Schedule name |
Schedule to which the job belongs. |
Execution time |
Time when the job was started. |
Completion time |
Time when the job was completed. If the job has never been executed or the job does not have any commands, this field is blank. |
Job output |
Commands in the job and their output. |
reset scheduler logfile
display scheduler reboot
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
scheduler reboot at
scheduler reboot delay
display scheduler schedule
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a schedule, this command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type : Run once after 0 hours 2 minutes
Start time : Tue Dec 27 10:44:42 2011
Last execution time : Tue Dec 27 10:44:42 2011
Last completion time : Tue Dec 27 10:44:47 2011
Execution counts : 1
Job name Last execution status
shutdown Successful
Table 19 Command output
Schedule type |
Execution time setting of the schedule. If no execution time is specified, this field is not displayed. |
Start time |
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed. |
Last execution time |
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field. |
Last completion time |
Last time when the schedule was completed. If no execution time is specified, this field is not displayed. |
Execution counts |
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed. |
Job name |
Name of a job under the schedule. |
Last execution status |
Result of the most recent execution: · Successful. · Failed. · Waiting—The device is executing the schedule and the job is waiting to be executed. · In process—The job is being executed. · -NA-—The execution time has not arrived yet. To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command. |
display service-mode status
Use display service-mode status to display the current operating modes of cards.
In standalone mode:
In IRF mode:
display service-mode status chassis chassis-number
# (In standalone mode.) Display the current operating modes of cards.
<Sysname> display service-mode status
Slot No. Service-mode
1 MIX-BRIDGING-ROUTING
4 ROUTING
5 NONE
6 NONE
14 NONE
Table 20 Command output
Service-mode |
Operating mode of the card. · MIX-BRIDGING-ROUTING—Extended hybrid mode.. · ROUTING—Extended routing mode. · NONE—The card does not support setting the operating mode. |
service-mode
display system stable state
Use display system stable state to display system stability and status information.
The device or card startup takes some time. If the values of the status fields do not change to Stable, execute this command multiple times to identify the devices or cards that are not in Stable state. You can also use other commands to identify the faulty components. For example:
· Use the display device command to identify the device operating status.
· Use the display ha service-group command to display the status of HA service groups and identify the groups in batch backup state.
· Use the display system internal process state command in probe view to display service operating status.
# (In standalone mode.) Display system stability and status information.
<Sysname> display system stable state
System state : Stable
Redundancy state: Stable
Slot CPU Role State
* 1 0 Active Stable
Table 21 Command output
System state |
System status: · Stable—The system is operating stably. · Not ready—The system is not operating stably. |
Redundancy state |
System redundancy status: · Stable—Both MPUs are operating stably. You can perform a switchover. · No redundance—The system has only one MPU. You cannot perform a switchover. · Not ready—The system is not operating stably. You cannot perform a switchover. |
Role |
Role of the card in the system: · Active—The card is the active MPU. · Standby—The card is the standby MPU. · Other—The card is a service module. |
State |
Card status: · Stable—The card is operating stably. · Board inserted—The card has just been installed. · Kernel initiating—Card kernel is being initialized. · Service starting—Services are starting. · Service stopping—Services are stopping. · HA Batch backup—An HA batch backup is going on. · Interface data batch backup—An interface data batch backup is in progress. |
The object is not operating stably. |
display device
display ha service-group (High Availability Command Reference)
display system-working-mode
Use display system-working-mode to display system operating mode information.
# Display system operating mode information.
<Sysname> display system-working-mode
The current system working mode is standard.
The system working mode for next startup is standard.
system-working-mode
display transceiver alarm
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 22 shows the common transceiver alarm components. If no error occurs, "None" is displayed.
Table 22 Common transceiver alarm components
APD |
Avalanche photo diode |
PCS |
Physical coding sublayer |
PHY XS |
PHY extended sublayer |
PMA/PMD |
Physical medium attachment/physical medium dependent |
power |
Optical power |
REFCLK |
Reference clock |
RX |
Receive |
TEC |
Thermoelectric cooler |
Temp |
Temperature |
TX |
Transmit |
WIS |
WAN interface sublayer |
# Display the alarms present on the transceiver module in interface GigabitEthernet 3/1/1.
<Sysname> display transceiver alarm interface gigabitethernet 3/1/1
GigabitEthernet3/1/1 transceiver current alarm information:
RX loss of signal
RX power low
Table 23 Command output
transceiver current alarm information |
Alarms present on the transceiver module. |
RX loss of signal |
Received signals are lost. |
RX power low |
Received power is low. |
display transceiver diagnosis
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface GigabitEthernet 3/1/1.
<Sysname> display transceiver diagnosis interface gigabitethernet 3/1/1
GigabitEthernet3/1/1 transceiver diagnostic information:
Temp(°C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
Temp(°C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
Table 24 Command output
transceiver diagnostic information |
Digital diagnosis information for the transceiver module in the interface. |
Temp.(°C) |
Temperature in °C, accurate to 1°C. |
Voltage(V) |
Voltage in V, accurate to 0.01 V. |
Bias(mA) |
Bias current in mA, accurate to 0.01 mA. |
RX power(dBm) |
Receive power in dBm, accurate to 0.01 dBm. |
TX power(dBm) |
Transmit power in dBm, accurate to 0.01 dBm. |
display transceiver interface
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface GigabitEthernet 3/1/1.
<Sysname> display transceiver interface gigabitethernet 3/1/1
GigabitEthernet3/1/1 transceiver information:
Transceiver Type : 1000_BASE_SX_SFP
Connector Type : LC
Wavelength(nm) : 850
Transfer Distance(m) : 550(50um),275(62.5um)
Digital Diagnostic Monitoring : YES
Vendor Name : H3C
Table 25 Command output
Connector Type |
Connector types: · SC—Fiber connector developed by NTT. · LC—1.25 mm/RJ-45 fiber connector developed by Lucent. · RJ-45. · CX 4. |
Wavelength(nm) |
Central wavelength (in nm) of the transmit laser. If the transceiver supports multiple wavelengths, every two wavelength values are separated by a comma. For a copper cable, this field displays N/A. |
Transfer Distance(xx) |
Transmission distance, where xx indicates the distance unit: · km—Kilometers, for single-mode transceiver modules. · m—Meters, for other transceiver modules. If the transceiver module supports multiple types of transmission media, this field displays the transmission distance for each type, in the form of transmission distance (medium type). Transmission medium types include: · 9 um—9/125 µm single-mode fiber. · 50 um—50/125 µm multimode fiber. · 62.5 um—62.5/125 µm multimode fiber. · TP—Twisted pair. · CX4—CX4 cable. |
Digital Diagnostic Monitoring |
Support for digital diagnosis: · YES—Supported. · NO—Not supported. |
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for the transceiver modules on all interfaces.
# Display electronic label information for the transceiver module on interface GigabitEthernet 3/1/1.
<Sysname> display transceiver manuinfo interface gigabitethernet 3/1/1
GigabitEthernet3/1/1 transceiver manufacture information:
Manu. Serial Number : 213410A0000054000251
Manufacturing Date : 2012-09-01
Vendor Name : H3C
Table 26 Command output
Manu. Serial Number |
Serial number generated during production of the transceiver module. |
Manufacturing Date |
Date when the electronic label information was written to the transceiver module. |
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
display version-update-record
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1 (updated on Sep 30 2 at 08:35:21):
Version : 7.1.075 Beta 7603
Compile time: Aug 22 2016 16:00:00
Record n |
Number of the startup software image upgrade record. Record 1 is the most recent record. |
Name |
Software image file name. |
The software image version changed during the upgrade. |
reset version-update-record
fabric load-sharing algorithm
Use fabric load-sharing algorithm to specify a load sharing algorithm for a service module.
Use undo fabric load-sharing algorithm to restore the default.
In standalone mode:
fabric load-sharing algorithm algorithm-number slot slot-number
undo fabric load-sharing algorithm algorithm-number slot slot-number
In IRF mode:
fabric load-sharing algorithm algorithm-number chassis chassis-number slot slot-number
undo fabric load-sharing algorithm algorithm-number chassis chassis-number slot slot-number
No load sharing algorithm is specified for a service module.
algorithm-number: Specifies a load sharing algorithm, in the range of 1 to 9.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
This command is supported only on SPC cards except SPC-CP2LB and SPC-CP2LA that have an interface capacity greater than 80 Gbps. The interface capacity of a card is the total speed of the interfaces on the card. For example, the interface capacity of a SPC-XP24LCX card is 240 Gbps (24 × 10 Gbps).
# (In standalone mode.) Specify load sharing algorithm 3 for a card.
[Sysname] fabric load-sharing algorithm 3 slot 2
fabric load-sharing mode
Use fabric load-sharing mode to specify load sharing modes for a service module.
Use undo fabric load-sharing mode to restore the default.
In standalone mode:
fabric load-sharing mode { { destination-ip | destination-mac | source-ip | source-mac } * | flexible } slot slot-number
undo fabric load-sharing mode [ { destination-ip | destination-mac | source-ip | source-mac } * | flexible ] slot slot-number
In IRF mode:
fabric load-sharing mode { { destination-ip | destination-mac | source-ip | source-mac } * | flexible } chassis chassis-number slot slot-number
undo fabric load-sharing mode [ { destination-ip | destination-mac | source-ip | source-mac } * | flexible ] chassis chassis-number slot slot-number
Load sharing for a service module is performed based on ingress interface.
destination-ip: Balances load based on destination IP address.
destination-mac: Balances load based on destination MAC address.
source-ip: Balances load based on source IP address.
source-mac: Balances load based on source MAC address.
flexible: Selects a balance mode based on packet type (for example, Layer 2 packet or IPv4 packet).
This command is supported on MPE-1104 cards and SPC cards except SPC-CP2LB and SPC-CP2LA.
On SPC and MPE-1104 cards, the flexible mode takes effect only for uplink interfaces, including IRF physical interfaces.
If a service module does not support the specified mode, the command displays an error message.
If you do not specify any keywords for the undo fabric load-sharing mode command, the command deletes all load sharing modes for the specified card.
# (In standalone mode.) Set the load sharing mode to destination-mac for a card.
[Sysname] fabric load-sharing mode destination-mac slot 2
fan-speed
Use fan-speed to set the fan operating mode.
In standalone mode:
fan-speed { auto | high | middle | low }
In IRF mode:
fan-speed [ chassis chassis-number ] { auto | high | middle | low }
Fans operate in auto mode.
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command set the fan operating mode for all member devices. (In IRF mode.)
auto: Operates at an adjustable speed. The device adjusts the speed automatically based on the card temperature. As a best practice, use this mode.
high: Operates at a higher speed to provide better cooling service.
middle: Operates at a middle speed.
low: Operates at a lower speed to reduce the noise at the cost of lower cooling service quality. This mode applies to noise-sensitive environments.
# (In standalone mode.) Set the fan operating mode to auto.
[Sysname] fan-speed auto
Fan speed changed successfully!
forwarding bandwidth
Use forwarding bandwidth to set the forwarding bandwidth allocation mode for service modules.
Use undo forwarding bandwidth to restore the default.
forwarding bandwidth { balanced | inter | intra }
The forwarding bandwidth allocation mode is inter for service modules.
balanced: Allocates 50% of the forwarding bandwidth to each type of forwarding operation.
inter: Allocates 66.7% of the forwarding bandwidth to traffic forwarding between service modules.
intra: Allocates 66.7% of the forwarding bandwidth to traffic forwarding within a service module.
Contact H3C Support before executing this command. Changing the forwarding bandwidth allocation mode for service modules might cause packet loss.
This command is supported only on CSPEX cards (except CSPEX-1204) installed on an SR8802-X-S router.
The forwarding bandwidth on the device is shared by the following types of operations:
· Traffic forwarding within a service module.
· Traffic forwarding between service modules.
You can perform this task to adjust the amount of forwarding bandwidth allocated to each type of operation.
# Set the forwarding bandwidth allocation mode for service modules to intra.
[Sysname] forwarding bandwidth intra
This command might cause packet loss. Continue? [Y/N]:y
forward-path-detection enable
Use forward-path-detection enable to enable data forwarding path failure detection.
Use undo forward-path-detection enable to disable data forwarding path failure detection.
Data forwarding path failure detection is enabled.
You can enable the device to automatically detect data forwarding path failures and output log information for notification.
# Enable data forwarding path failure detection.
[Sysname] forward-path-detection enable
Use hardware-failure-detection to specify the action to be taken in response to hardware failures.
Use undo hardware-failure-detection to restore the default.
hardware-failure-detection forwarding { isolate | off | reset | warning }
undo hardware-failure-detection forwarding
The system takes the action of warning in response to hardware failures on the forwarding plane.
forwarding: Specifies failures on the forwarding plane (including services and other relevant items).
isolate: Takes one or more of the following actions:
· Shuts down the relevant ports.
· Prohibits loading software for the relevant cards.
· Isolates the relevant cards.
· Powers off the relevant cards to reduce impact from the failures.
off: Takes no action.
reset: Restarts the relevant components or cards to recover from failures.
warning: Sends traps to notify you of the failures.
The device automatically detects hardware failures on the forwarding plane. You can specify the actions to be taken in response to detected failures.
# Configure the device to send traps in response to failures on the forwarding plane.
[Sysname] hardware-failure-detection forwarding warning
hardware-failure-protection aggregation
Use hardware-failure-protection aggregation to enable hardware failure protection for aggregation groups.
Use undo hardware-failure-protection aggregation to disable hardware failure protection for aggregation groups.
Hardware failure protection is disabled for aggregation groups.
This command takes effect only when the hardware-failure-detection forwarding isolate command is configured.
When the hardware-failure-protection aggregation command is configured, the system uses the following rules when it detects a hardware failure on an aggregation group member interface:
· If the undo hardware-failure-protection auto-down command is configured on the member interface and the member interface is the only member in up state in the group, the system does not shut down the interface.
· If the undo hardware-failure-protection auto-down command is configured on the member interface and the member interface is not the only member in up state in the group, the system shuts down the interface.
· If the hardware-failure-protection auto-down command is configured on the member interface, the system shuts down the interface, whether or not the member interface is the only member in up state in the group.
This command does not take effect on a member interface in the following situations:
· Loopback testing is enabled (using the loopback { external | internal } command).
· The interface is forcibly brought up (using the port up-mode command).
· The interface is a physical IRF port.
· The undo hardware-failure-protection auto-down command is not configured on the interface.
# Enable hardware failure protection for aggregation groups.
[Sysname] hardware-failure-protection aggregation
Use hardware-failure-protection auto-down to enable hardware failure protection for an interface.
Use undo hardware-failure-protection auto-down to disable hardware failure protection for an interface.
Hardware failure protection is enabled for an interface.
Ethernet interface view
To ensure service continuity, verify that the interface has a backup link before configuring this command.
After you enable hardware failure protection on an interface, the system automatically shuts down the interface when it detects a hardware failure on the interface. An interface shut down this way is in Protect Down state. After the failure on an interface is removed, bring the interface up by using the undo shutdown command.
This command does not take effect on an interface in the following situations:
# Enable hardware failure protection on interface GigabitEthernet 3/1/1.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] hardware-failure-protection auto-down
header
Use header to configure a banner.
Use undo header to delete a banner.
header { incoming | legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
No banners exist.
incoming: Configures the banner to be displayed before a modem dial-in user accesses user view. If authentication is required, the incoming banner appears after the authentication is passed.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a non-modem dial-in user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see Fundamentals Configuration Guide.
# Configure the legal banner.
[Sysname] header legal
Welcome to use the legal banner%
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign the save-job job to the saveconfig schedule.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
scheduler job
scheduler schedule
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the defaults.
In standalone mode:
memory-threshold [ slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Minor alarm threshold: 96 MB.
Severe alarm threshold: 64 MB.
Critical alarm threshold: 48 MB.
Normal state threshold: 128 MB.
minor minor-value: Specifies the minor alarm threshold. This threshold must be equal to or less than the normal state threshold. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. This threshold must be equal to or less than the minor alarm threshold. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. This threshold must be equal to or less than the severe alarm threshold. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. This threshold must be equal to or less than the total memory size.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets free-memory thresholds for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command sets free-memory thresholds for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space exceeds a free-memory threshold, the system generates an alarm notification and sends it to affected service modules or processes. For more information about the thresholds, see Fundamentals Configuration Guide.
For slots that support low memory, the system monitors only the amount of free low-memory space. You can use the display memory command to display memory usage information. If the LowMem field is displayed for a slot, the slot supports low memory.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
In standalone mode:
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the memory usage threshold for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command sets the memory usage threshold for the global active MPU. (In IRF mode.)
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
monitor cpu-usage enable
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
In standalone mode:
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command enables CPU usage monitoring for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command enables CPU usage monitoring for the global active MPU. (In IRF mode.)
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
display cpu-usage configuration
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
In standalone mode:
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the interval for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command sets the interval for the global active MPU. (In IRF mode.)
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage threshold
Use monitor cpu-usage threshold to set the CPU usage threshold.
Use undo monitor cpu-usage threshold to restore the default.
In standalone mode:
monitor cpu-usage threshold cpu-threshold [ minor-threshold minor-threshold ] [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold minor-threshold ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage threshold cpu-threshold [ minor-threshold minor-threshold ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold minor-threshold ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The severe CPU usage alarm threshold is 99%. The minor CPU usage alarm threshold is 79%.
cpu-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range is 1 to the severe CPU usage alarm threshold minus 1. If you do not specify this option, the minor CPU usage alarm threshold is severe-threshold * 0.8.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the CPU usage threshold for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command sets the CPU usage threshold for the global active MPU. (In IRF mode.)
The device samples CPU usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the severe CPU usage alarm threshold to 80%.
[Sysname] monitor cpu-usage threshold 80
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
To access the device configuration without authentication, you must connect to the active MPU and access the BootWare menu while the active MPU is starting up.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
power control-mode
Use power control-mode to set the card power-on control mode.
Use undo power control-mode to restore the default.
power control-mode { loose | strict }
The card power-on control mode is strict.
loose: Specifies the loose mode.
strict: Specifies the strict mode.
This command is not supported on SR8800-X-S routers.
When you install a service module or switching fabric module, the device calculates the following items:
· Total power reserved for fans and MPUs.
· Total maximum power of all service modules and switching fabric modules, including the newly installed module.
In strict mode, the device powers on the newly installed module only if the sum of the two items is equal to or less than the rated power of the device.
In loose mode, the device powers on the newly installed module as long as the sum of the two items is equal to or less than the rated power of the device * 1.2.
# Set the card power-on control mode to loose.
[Sysname] power control-mode loose
power-off high-temp-board clear
Use power-off high-temp-board clear to restore power supply for cards shut down because of overtemperature.
When the temperature on a card reaches the shutdown temperature threshold, the overtemperature auto shutdown feature automatically shuts down the card. You can use this command to power on the card as appropriate.
· SPC cards with an interface capacity greater than 80 Gbps. The interface capacity of a card is the sum of speeds of all interfaces on the card. For example, the interface capacity of a SPC-XP24LCX card is 240 Gbps (24 x 10 Gbps).
# Restore power supply for cards shut down because of overtemperature.
[Sysname] power-off high-temp-board clear
power-off high-temp-board enable
Use power-off high-temp-board enable to enable the overtemperature auto shutdown feature.
undo power-off high-temp-board enable
The overtemperature auto shutdown feature is enabled.
# Enable the overtemperature auto shutdown feature.
[Sysname] power-off high-temp-board enable
reboot
Use reboot to reboot the device.
In standalone mode:
reboot [ slot slot-number [ subslot subslot-number ] ] [ force ]
In IRF mode:
reboot [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] ] [ force ]
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. (In standalone mode.) (In IRF mode.)
subslot subslot-number: Specifies a subcard by its subslot number.
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first identifies whether the reboot might result in data loss or a system failure. For example, the system identifies whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION: · A reboot might interrupt network services. · Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection. |
If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
In standalone mode:
To reboot the entire device, do not specify the slot number option.
To reboot a card, specify the slot number and do not specify a subslot number.
To reboot the active MPU, first perform the following tasks:
· Identify whether the standby MPU is installed and operating correctly.
· Use the display system stable state command to display system stability and status information.
If the standby MPU is not installed, the entire device will be rebooted. If the standby MPU is installed and is operating correctly, a switchover will occur.
IMPORTANT: To ensure correct operation of the system and cards, do not trigger a switchover by rebooting the active MPU if the status of a card is not Stable. |
In IRF mode:
To reboot all IRF member devices, do not specify the member ID option.
To reboot an IRF member device, specify only the member ID.
To reboot a card, specify both the member ID and the slot number.
To reboot the global active MPU, first perform the following tasks:
· Identify whether the IRF fabric has global standby MPUs and whether the global standby MPUs are operating correctly.
If the IRF fabric has only one MPU, the IRF fabric will be rebooted. If the IRF fabric has a global standby MPU and the MPU is operating correctly, a switchover will occur.
IMPORTANT: To ensure correct operation of the IRF fabric and MPUs, do not trigger a switchover by rebooting the global active MPU if the status of a card is not Stable. |
# Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to flash successfully.
Now rebooting, please wait...
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION: This command is disruptive. Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario. |
The command takes effect after the device reboots.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
scheduler job
Use scheduler job to create a job and enter its view, or enter the view of an existing job.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
command
scheduler schedule
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Specifies the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION: Device reboot interrupts network services. |
When the date argument is not specified, the system uses the following rules to determine the reboot time:
· If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
· If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and scheduler reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
For data security, the system does not reboot at the reboot time if a file operation is being performed.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2011.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2011 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and schedule reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2011.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2011(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter its view, or enter the view of an existing schedule.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1. Use the scheduler job command to create a job and enter job view.
2. Use the command command to assign commands to the job.
3. Use the scheduler schedule command to create a schedule and enter schedule view.
4. Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5. Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6. Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
job
time at
time once
service-mode
Use switch-mode to specify an operating mode for a service module.
Use undo switch-mode to restore the default.
In standalone mode:
service-mode { routing | mix-bridging-routing } slot slot-number
undo service-mode slot slot-number
In IRF mode:
service-mode { routing | mix-bridging-routing } chassis chassis-number slot slot-number
undo service-mode chassis chassis-number slot slot-number
A service module operates in mix-bridging-routing mode.
routing: Specifies the extended routing mode.
mix-bridging-routing: Specifies the extended hybrid mode.
This command is supported only on the following cards:
· SPC cards that have an interface capacity of less than or equal to 80 Gbps.
· MPE-1104 cards.
The interface capacity of a card is the total speed of interfaces on the card. For example, the interface capacity of the SPC-GP24XP2LB card is 44 Gbps (2 x 10 Gbps + 24 x 1 Gbps).
Change to the operating mode of a service module takes effect after you save the running configuration and reboot the service module.
Changing the operating mode for a service module changes only the performance of the service module. The performance of the device is not affected.
# (In standalone mode.) Set the operating mode to routing for the service module in slot 3.
[Sysname] service-mode routing slot 3
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. To disable port status detection, set this argument to 0.
The device starts a port status detection timer when a port is shut down by a protocol. Once the timer expires, the device brings up the port so the port status reflects the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
· If T < T1, the port will be brought up after T1 – T seconds.
· If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
switch-fabric isolate
Use switch-fabric isolate to isolate a switching fabric module or channel.
Use undo switch-fabric isolate to restore the default.
In standalone mode:
switch-fabric isolate slot slot-number [ channel channel-number ]
undo switch-fabric isolate slot slot-number [ channel channel-number ]
In IRF mode:
switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
undo switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
A switching fabric module is not isolated from the forwarding plane and forwards traffic.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. (In IRF mode.)
channel channel-number: Specifies a switching fabric channel by its number. If you do not specify a switching fabric channel, the command isolates the switching fabric module. This option is not supported in the current software version.
CAUTION: · Isolating the only switching fabric module of the device disables the forwarding feature. · Do not reboot the device when a switching fabric module is isolated. |
This command does not take effect for CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, CSPEX-1104-E, and SPEX-1204 cards. Traffic of the cards go through an isolated switching fabric module or channel as normal.
Use this command only if required. If the device has multiple switching fabric modules, isolating a switching fabric module or channel decreases the forwarding bandwidth and reduces the forwarding performance.
Do not leave a switching fabric module isolated for a long time. If you do not want to use the module, remove the module after isolating the module. To use the module, use the undo switch-fabric isolate command to cancel the isolation.
An isolated switching fabric module continues to communicate with the MPU, and can forward traffic immediately after the isolation is cancelled. The isolation does not affect protocol packet parsing and protocol calculation on the control panel.
# (In standalone mode.) Isolate switching fabric channel 1 on the switching fabric module in slot 10.
[Sysname] switch-fabric isolate slot 10 channel 1
The command will isolate the channel of the switch fabric from the system. Continue? [Y/N]y
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
system-working-mode
Use system-working-mode to set the system operating mode.
Use undo system-working-mode to restore the default.
system-working-mode { sdn-wan | standard }
The system operating mode is standard.
sdn-wan: Specifies WAN SDN mode.
standard: Specifies standard mode.
Supported features vary by system operating mode. For more information, see device management in Fundamentals Configuration Guide.
A system operating mode change takes effect after a device reboot.
# Set the system operating mode to WAN SDN mode.
[Sysname] system-working-mode sdn-wan
Do you want to change the system working mode? [Y/N]:y
System working mode changed. For the change to take effect, save the running configuration and reboot the device.
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
In standalone mode:
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
In IRF mode:
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
The temperature alarm thresholds depend on the device model. To view the default temperature alarm thresholds, use the undo temperature-limit command to restore the default and execute the display environment command.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically near the chip that generates a great amount of heat and used to monitor the chip.
inflow: Configures temperature alarm thresholds for inlet sensors. An inlet sensor is near the air inlet and used for monitoring ambient temperature.
outflow: Configures temperature alarm thresholds for outlet sensors. An outlet sensor is near the air outlet for monitoring device temperature.
sensor-number: Specifies a sensor by its number, an integer starting from 1. Each number represents a temperature sensor on the device.
lowlimit: Specifies the low-temperature threshold in Celsius degrees.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the high-temperature warning threshold.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
· Sends log messages and traps.
· Sets LEDs on the device panel.
# (In standalone mode.) Set temperature alarm thresholds for inlet sensor 1 in a slot.
[Sysname] temperature-limit slot 1 inflow 1 -10 70 100
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite each other. The most recently configured command takes effect.
# Configure the device to execute the saveconfig schedule at 01:01 a.m. on May 11, 2011.
[Sysname-schedule-saveconfig] time at 1:1 2011/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute the saveconfig schedule once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute the saveconfig schedule once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute the saveconfig schedule at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute the saveconfig schedule after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval: Specifies the execution time interval in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval command configures the device to execute a schedule at an interval from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite each other, whichever is configured most recently takes effect.
# Configure the device to execute the saveconfig schedule once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute the saveconfig schedule at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute the saveconfig schedule at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute the saveconfig schedule at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute the saveconfig schedule at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
# Assign the rolename user role to the test schedule.
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
command
scheduler schedule
