09-MPLS Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command References-Release795x-6W10009-MPLS Command Reference
06-RSVP commands
06-RSVP commands 222.98 KB
RSVP commands
authentication challenge
Use authentication challenge to enable the RSVP challenge-response handshake feature globally or for an RSVP neighbor.
Use undo authentication challenge to disable the challenge-response handshake feature globally or for an RSVP neighbor.
The RSVP challenge-response handshake feature is disabled.
RSVP view
RSVP neighbor view
To prevent packet replay attacks, RSVP requires received authentication messages to carry incremental sequence numbers. To verify the subsequent messages, RSVP saves the sequence number of the last valid message in a receive-type security association.
However, when RSVP creates a new receive-type security association, it cannot obtain the sequence number of the sender. To successfully establish the receive-type security association, RSVP sets the receive sequence number to 0 by default. Then, the association can receive a message with any sequence number from the peer. Because this introduces a vulnerability to replay attacks, you should execute the authentication challenge command. When RSVP creates a receive-type security association, it will perform a challenge-response handshake to obtain the sequence number of the sender.
RSVP challenge-response handshake can be configured in the following views:
·          RSVP view—Configuration applies to all RSVP security associations.
·          RSVP neighbor view—Configuration applies only to RSVP security associations with the specified neighbor.
·          Interface view—Configuration applies only to RSVP security associations established on the current interface.
The execution of this command affects only security associations established after the execution. To apply the setting to existing security associations, you must execute the reset rsvp authentication command to delete and then re-establish the security associations.
# Enable RSVP challenge-response handshake globally.
[Sysname] rsvp
[Sysname-rsvp] authentication challenge
# Enable challenge-response handshake for RSVP neighbor 1.1.1.9.
[Sysname] rsvp
[Sysname-rsvp] peer 1.1.1.9
[Sysname-rsvp-peer-1.1.1.9] authentication challenge
authentication key
authentication lifetime
authentication window-size
display rsvp authentication
rsvp authentication challenge
rsvp authentication key
rsvp authentication lifetime
rsvp authentication window-size
authentication key
Use authentication key to enable RSVP authentication globally or for an RSVP neighbor, and configure the authentication key.
Use undo authentication key to disable RSVP authentication.
authentication key { cipher | plain } string
RSVP authentication is disabled.
RSVP view
RSVP neighbor view
cipher: Specifies an authentication key in encrypted form.
plain: Specifies an authentication key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the authentication key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters.
RSVP authentication ensures integrity of RSVP messages, and prevents false resource reservation requests from occupying network resources.
With RSVP authentication, the sender uses the MD5 algorithm and the authentication key to calculate a message digest for an RSVP message. The sender inserts the message digest to the RSVP message. When the receiver receives the message, it performs the same calculation and compares the result with the message digest received. If the two digests match, the receiver accepts the message. If the two digests do not match, it drops the message.
RSVP authentication can be configured in the following views:
·          RSVP neighbor view—Configuration applies only to RSVP security associations with the specified RSVP neighbor.
Configurations in RSVP neighbor view, interface view, and RSVP view are in descending order of priority. If RSVP authentication for a neighbor is enabled in both RSVP neighbor view and RSVP view with different authentication keys configured, the key configured in RSVP neighbor view is used.
To re-establish a security association, you must delete the authentication key used by the current security association or delete the current security association (using the reset rsvp authentication command). Then, the device can re-establish a security association by looking up a new authentication key in order of priorities.
After you enable RSVP authentication on the local device, you must also enable RSVP authentication and configure the same authentication key on the RSVP neighbor.
# Enable RSVP authentication globally, and configure the authentication key as a plaintext string of abcdefgh.
[Sysname] rsvp
[Sysname-rsvp] authentication key plain abcdefgh
# Enable RSVP authentication for neighbor 1.1.1.9, and configure the authentication key as a plaintext string of abcdefgh.
[Sysname] rsvp
[Sysname-rsvp-peer-1.1.1.9] authentication key plain abcdefgh
Use authentication lifetime in RSVP view to set the global idle timeout for RSVP security associations.
Use authentication lifetime in RSVP neighbor view to set the idle timeout for RSVP security associations with an RSVP neighbor.
Use undo authentication lifetime to restore the default.
authentication lifetime life-time
The idle timeout for an RSVP security association is 1800 seconds.
RSVP view
RSVP neighbor view
life-time: Specifies the RSVP security association idle timeout in the range of 30 to 86400 seconds.
When RSVP authentication is enabled, the device dynamically establishes security associations when receiving and sending RSVP messages.
To release memory resources, each security association has an idle timeout. When a security association is idle for the specified timeout time, the device deletes the security association. When the device sends or receives an authenticated RSVP message, it resets the idle timeout timer for the corresponding security association.
The RSVP authentication idle timeout can be configured in the following views:
An RSVP security association established by using the authentication key configured in a view uses the idle timeout configured in the same view.
A modification to the idle timeout affects only security associations established after the modification. To apply the new setting to existing security associations, you must execute the reset rsvp authentication command to delete and then re-establish the security associations.
# Set the global idle timeout to 100 seconds for RSVP security associations.
[Sysname] rsvp
[Sysname-rsvp] authentication lifetime 100
# Set the idle timeout to 100 seconds for the security associations with RSVP neighbor 1.1.1.9.
[Sysname] rsvp
[Sysname-rsvp-peer-1.1.1.9] authentication lifetime 100
authentication key
Use authentication window-size in RSVP view to set the global RSVP authentication window size, which is the maximum number of authenticated RSVP messages that can be received out of sequence.
Use authentication window-size in RSVP neighbor view to set the RSVP authentication window size for an RSVP neighbor.
Use undo authentication window-size to restore the default.
authentication window-size number
Only one authenticated RSVP message can be received out of sequence.
RSVP view
RSVP neighbor view
number: Specifies the maximum number of authenticated RSVP messages that can be received out of sequence, in the range of 1 to 64.
To protect against replay attacks, the sender places a unique sequence number in each RSVP message that contains authentication information. The sender increases the value of the sequence number by one each time it sends an RSVP message. If the sequence number of a received message is in the specified authentication window size, the receiver accepts the message. If it is not in the specified authentication window size, the receiver discards the message.
When the receiver receives an RSVP message, it compares the sequence number of the last accepted RSVP message with the sequence number of the newly received RSVP message.
·          If the new sequence number is greater than the last sequence number, RSVP accepts the message and updates the last sequence number with the new sequence number.
·          If the new sequence number equals the last sequence number, RSVP regards the message a replay message and discards the message.
·          If the new sequence number is smaller, the receiver compares the new sequence number with the authentication window size.
¡  If the new sequence number is greater and has never been received before, RSVP accepts the message. If the new sequence number has been received before, RSVP regards the message a replay message and discards the message.
¡  If the new sequence number is not greater, RSVP regards the message invalid and discards the message.
By default, the authentication window size is 1. If the sequence number of a newly received RSVP message is smaller than that of the last accepted message, the device discards the message. However, if the sender sends multiple RSVP messages in a short time, these messages might arrive at the neighbor out of sequence. If you use the default window size, the out-of-sequence messages will be discarded. To solve this problem, you can use the authentication window-size command to configure a correct window size.
A security association established by using the authentication key configured in a view uses the window size configured in that view.
A modification to the window size affects only security associations established after the modification. To apply the new setting to existing security associations, you must execute the reset rsvp authentication command to delete and then re-establish the security associations.
# In RSVP view, set the maximum number of out-of-sequence authenticated RSVP messages that can be received to 10.
[Sysname] rsvp
[Sysname-rsvp] authentication window-size 10
# In RSVP neighbor view, set the maximum number of out-of-sequence authenticated RSVP messages that can be received from RSVP neighbor 1.1.1.9 to 10.
[Sysname] rsvp
[Sysname-rsvp-peer-1.1.1.9] authentication window-size 10
authentication key
display rsvp
Use display rsvp to display RSVP information.
display rsvp [ interface [ interface-type interface-number ] ]
interface: Displays RSVP information on interfaces. If you do not specify this keyword, the command displays global RSVP information.
interface-type interface-number: Displays RSVP information on the interface specified by its type and number. If you do not specify this argument, the command displays RSVP information for all interfaces.
# Display global RSVP information.
<Sysname> display rsvp
LSR ID: 50.0.0.1                       Fast Reroute time: 300 sec
Refresh interval: 30 sec               Keep multiplier: 3
Hello interval: 3 sec                  Hello lost: 4
Graceful Restart: Disabled             DSCP value: 48
Authentication: Enabled
  Lifetime: 300 sec
  Window size: 64
  Challenge: Enabled
P2P statistics:
  PSB number: 5                        RSB number: 5
  LSP number: 5                        Request number: 5
  Peer number: 5                       SA number: 5
P2MP statistics:
  PSB number: 0                        RSB number: 0
  LSP number: 0                        Request number: 0
  Peer number: 0                       SA number: 0
Fast Reroute time
Interval for detecting whether a better bypass CRLSP is available for a primary CRLSP, in seconds.
Refresh interval
Interval for refreshing Path and Resv messages, in seconds.
Keep multiplier
PSB and RSB timeout multiplier.
Hello interval
Interval for sending hello requests, in seconds.
Hello lost
Maximum number of consecutive lost or erroneous hellos allowed.
DSCP value
DSCP value for outgoing RSVP packets.
Authentication
RSVP authentication state.
Lifetime
Idle timeout for RSVP security associations, in seconds.
Window size
Maximum number of out-of-sequence authenticated RSVP messages that can be received.
Challenge
State of the challenge-response handshake feature.
P2P statistics
RSVP P2P statistics.
PSB number
Total number of PSBs.
RSB number
Total number of RSBs.
LSP number
Total number of LSPs established by RSVP.
Request number
Total number of RSVP request data blocks.
Peer number
Total number of RSVP neighbors.
SA number
Total number of security associations.
P2MP statistics
RSVP P2MP statistics.
# Display RSVP information for all interfaces.
<Sysname> display rsvp interface
Interface: GE3/1/1                     Logical interface handle: 0x3
State: Up                              IP address: 50.1.0.1
MPLS TE: Enabled                       RSVP: Enabled
Hello: Enabled                         BFD: Enabled
Summary refresh: Enabled               Reliability: Disabled
Retransmit interval: 500 ms            Retransmit increment: 1
  Lifetime: 300 sec
  Window size: 64
  Challenge: Enabled
Bypass tunnels: Tunnel0
Interface: GE3/1/2                     Logical interface handle: 0x67
State: Up                              IP address: 50.2.0.1
Summary refresh: Disabled              Reliability: Disabled
  Lifetime: 300 sec
  Window size: 64
  Challenge: Enabled
Bypass tunnels: Tunnel0, Tunnel1, Tunnel2
Logical interface handle, used to distinguish logical outgoing interfaces on the RSVP interface.
Interface state recorded by RSVP: UP or Down.
IP address
IP address of the current interface used by RSVP.
MPLS TE
MPLS TE state on the interface.
RSVP
RSVP state on the interface.
Hello
State of RSVP hello on the interface.
BFD
BFD state on the interface.
Summary refresh
State of the summary refresh feature on the interface.
Reliability
State of the reliable RSVP message delivery feature on the interface.
Retransmit interval
Initial retransmission interval for reliable RSVP message delivery, in milliseconds.
Retransmission increment value for reliable RSVP message delivery.
Authentication
RSVP authentication state on the interface.
Lifetime
Window size
Challenge
State of the challenge-response handshake feature on the interface.
Bypass tunnels
Bypass tunnels configured on the interface for fast reroute (FRR). If no bypass tunnels are configured, this field displays None.
Use display rsvp authentication to display information about the security associations established with RSVP neighbors.
display rsvp authentication [ from ip-address ] [ to ip-address ] [ verbose ]
from ip-address: Displays information about the security associations with the specified source IP address.
to ip-address: Displays information about the security associations with the specified destination IP address.
verbose: Displays detailed information about RSVP security associations. If you do not specify this keyword, the command displays brief information about RSVP security associations.
After RSVP authentication is enabled, the device automatically establishes security associations when sending and receiving RSVP messages. A security association includes the following information:
·          IP address of the authentication source node.
·          IP address of the authentication destination node.
·          Authentication direction.
·          Authentication type.
·          Authentication key.
·          Authentication expiration time.
The device obtains the RSVP authentication source and destination IP addresses from the IP header or RSVP message objects, as shown in Table 3.
Table 3 How to get RSVP authentication source and destination IP addresses
Message type received or sent
Authentication source IP
Authentication destination IP
Path
Address in the HOP object of the RSVP message.
Address in the SESSION object of the RSVP message.
PathTear
PathError
Source IP address in the IP header
Destination IP address in the IP header
Resv
ResvTear
ResvError
ResvConfirm
Address in the CONFIRM object of the RSVP message.
ACK
Srefresh
Hello
If you do not specify the from ip-address to ip-address options, this command displays information about the security associations established with all RSVP neighbors.
# Display brief information about the security associations established with all RSVP neighbors.
<Sysname> display rsvp authentication
From            To              Mode    Type      Key-ID       Expiration
57.10.10.1      57.10.10.2      Receive Interface 000103000000 280s
57.10.10.2      57.10.10.1      Send    Interface 000103000000 280s
From
RSVP authentication source IP address.
To
RSVP authentication destination IP address.
Mode
Direction of the security association:
·         Receive—Receive security association, used to authenticate messages received from an RSVP neighbor.
·         Send—Send security association, used to authenticate messages sent to an RSVP neighbor.
Type of the security association:
·         Peer—Security association established in RSVP neighbor view.
·         Interface—Security association established in interface view.
·         Global—Security association established in RSVP view.
Key-ID
Key ID of the security association.
·         For a send security association, this field displays the local key ID.
·         For a receive security association, this field displays the key ID received from the peer.
Expiration
Idle timeout remaining time of the security association, in seconds.
# Display detailed information about the security associations established with all RSVP neighbors.
<Sysname> display rsvp authentication verbose
From: 20.1.1.1                            To: 4.4.4.9
Mode: Send                                Type: Interface
Challenge: Supported                      Peer: 20.1.1.2
Local key ID: 0x000104000000              Peer key ID: 0x0
Lifetime: 1800 sec                        Expiration time: 1781 sec
Window size: 1
Last sent sequence number:
  5781735195480686593
From: 20.1.1.2                            To: 20.1.1.1
Mode: Receive                             Type: Interface
Challenge: Not configured                 Peer: 20.1.1.2
Local key ID: 0x0                         Peer key ID: 0x000104000000
Lifetime: 1800 sec                        Expiration time: 1798 sec
Window size: 1
Received sequence numbers:
  5781742445385482241
Table 5 Command output
From
To
Mode
Challenge
State of the authentication challenge-response feature:
·         Not configured—The challenge-response handshake feature is disabled locally. (For a receive security association.)
·         Configured—The challenge-response handshake feature is enabled locally. (For a receive security association.)
·         In progress—The local device has sent an Integrity Challenge message to the peer and is waiting for the Integrity Response message from the peer.
·         Completed—The local device has received an Integrity Response message from the peer and the message has passed the authentication.
·         Failed—The Failed state is displayed when one of the following events occurs:
¡  The local device has received an Integrity Response message from the peer but the message failed the authentication.
¡  The local device has not received any valid Integrity Response after sending three Integrity Challenge messages to the peer.
¡  The challenge-response feature is disabled on the peer.
·         Supported—The local device supports the challenge-response feature. (For a send security association.)
Peer
IP address of the authentication neighbor.
Local key ID
Local key ID, for a send security association.
Peer key ID
Peer key ID, for a receive security association.
Lifetime
Idle timeout of the security association, in seconds.
Expiration time
Window size
Sequence numbers of the received messages. This field can display the sequence numbers for a maximum of window-size messages.
Sequence number of the last sent message.
authentication key
display rsvp lsp
Use display rsvp lsp to display information about CRLSPs established by RSVP.
display rsvp lsp [ destination ip-address ] [ source ip-address ] [ tunnel-id tunnel-id ] [ lsp-id lsp-id ] [ verbose ]
destination ip-address: Displays information about the CRLSP with the specified tunnel destination address.
source ip-address: Displays information about the CRLSP with the specified tunnel source address. The tunnel source address is the extended tunnel ID in the Session object of an RSVP message.
tunnel-id tunnel-id: Displays information about the CRLSP with the specified tunnel ID in the range of 0 to 65535.
lsp-id lsp-id: Displays information about the CRLSP with the specified LSP ID in the range of 0 to 65535.
verbose: Displays detailed information about CRLSPs. If you do not specify this keyword, the command displays brief information about CRLSPs.
If you do not specify any parameters, this command displays brief information about all CRLSPs established by RSVP.
# Display brief information about all CRLSPs established by RSVP.
<Sysname> display rsvp lsp
Destination     Source          Tunnel-ID LSP-ID Direction  Tunnel-name
50.0.0.1        50.0.0.3        0         1      Uni        Sysname_t0
Table 6 Command output
Destination
Tunnel destination address.
Source
Tunnel source address.
Direction
Tunnel direction:
·         Uni—Unidirectional tunnel.
Tunnel-name
Tunnel name. The tunnel ingress node generates the name and notifies other nodes of the name through a Path message.
When the ingress node is an H3C device, the tunnel name is Sysname_ttunnel-ID, where Sysname represents the device name, and tunnel-ID represents the ID of the tunnel. You can configure the device name by executing the sysname command in system view.
This field contains a maximum of 80 characters, and displays the first 77 characters and three dots (.) if the name contains more than 80 characters.
# Display detailed information about all CRLSPs established by RSVP.
<Sysname> display rsvp lsp verbose
Tunnel name: Sysname_t1
Destination: 3.3.3.9                      Source: 1.1.1.9
Tunnel ID: 1                              LSP ID: 5
LSR type: Transit                         Direction: Unidirectional
Setup priority: 7                         Holding priority: 7
In-Label: 1146                            Out-Label: 3
In-Interface: GE3/1/2                     Out-Interface: GE3/1/4
Nexthop: 57.20.20.1                       Exclude-any: 0
Include-Any: 0                            Include-all: 0
Mean rate (CIR): 0.00 kbps                Mean burst size (CBS): 1000.00 bytes
Path MTU: 1500                            Class type: CT0
RRO number: 8
  57.10.10.1/32      Flag: 0x00 (No FRR)
  57.10.10.2/32      Flag: 0x40 (No FRR/In-Int)
  1146               Flag: 0x01 (Global label)
  2.2.2.9/32         Flag: 0x20 (No FRR/Node-ID)
  57.20.20.2/32      Flag: 0x00 (No FRR)
  57.20.20.1/32      Flag: 0x40 (No FRR/In-Int)
  3                  Flag: 0x01 (Global label)
  3.3.3.9/32         Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: Ready
  FRR inner label: 3           Bypass tunnel: Tunnel253
Table 7 Command output
Tunnel name
Destination
Source
Direction
Tunnel direction:
·         Unidirectional—Unidirectional tunnel.
Exclude-any
Affinity representing a set of attribute filters. Matching any filter renders a link unacceptable.
Include-any
Affinity representing a set of attribute filters. Matching any filter renders a link acceptable.
Include-all
Affinity representing a set of attribute filters. All filters must be present for a link to be acceptable.
Class type
CT of the LSP.
RRO number
Number of Record Route Objects (RROs). If the number is not 0, the subsequent output displays the IP addresses or labels recorded in the RROs.
The RRO information is displayed only when route recording is configured on the tunnel interface.
Flag
Flag value and its meaning in an RRO:
·         No FRR—FRR is not configured.
·         FRR Avail—FRR is available.
·         In use—FRR has occurred.
·         BW—Bandwidth protection.
·         Node-Prot—Node protection.
·         Node-ID—The IP address in the RRO is the LSR ID of the node.
·         In-Int—The IP address in the RRO is address of the incoming interface.
·         Global label—Per-platform label space.
Whether the tunnel has been bound to an FRR bypass tunnel:
·         None—Not bound to a bypass tunnel.
·         Ready—Bound to a bypass tunnel. No FRR has occurred.
·         Active—Bound to a bypass tunnel. An FRR has occurred.
FRR inner label
Incoming label of the FRR bypass tunnel.
This field is displayed only when a bypass tunnel is bound.
Bypass tunnel
Name of the bypass tunnel.
display rsvp request
display rsvp reservation
display rsvp sender
display rsvp p2mp lsp
Use display rsvp p2mp lsp to display information about RSVP P2MP CRLSPs.
display rsvp p2mp lsp [ destination ip-address ] [ source ip-address ] [ tunnel-id tunnel-id ] [ lsp-id lsp-id ] [ verbose ]
source ip-address: Displays information about the CRLSP with the specified tunnel source address. The tunnel source address is the extended tunnel ID in the P2MP Session object of an RSVP message.
If you do not specify any parameters, this command displays brief information about all RSVP P2MP CRLSPs.
# Display brief information about all RSVP P2MP CRLSPs.
<Sysname> display rsvp p2mp lsp
Source          Tunnel-ID  P2MP-ID      LSP-ID  Destination    Tunnel-name
1.1.1.9         1          0x1010109    44470   2.2.2.9        Tunnel1
1.1.1.9         1          0x1010109    44470   3.3.3.9        Tunnel1
Table 8 Command output
Source
Destination
Tunnel-name
# Display detailed information about all RSVP P2MP CRLSPs.
<Sysname> display rsvp p2mp lsp verbose
Tunnel name: Tunnel1
Source: 1.1.1.9                           Tunnel ID: 1
P2MP ID: 0x1010109                        LSP ID: 44470
Exclude-any: 0                            Include-any: 0
Include-all: 0                            Mean rate (CIR): 0 kbps
Mean burst size (CBS): 1000.00 bytes      Class type: CT0
In-Transit-Label: 2174                    In-Egress-Label: 2175
Sub-LSPs:
  Destination: 2.2.2.9
  Out-Interface: -                        Nexthop: -
  Out-Label: -
  RRO number: 4
    12.0.0.1/32        Flag: 0x00 (No FRR)
    12.0.0.2/32        Flag: 0x00 (No FRR)
    2175               Flag: 0x01 (Global label)
  Fast Reroute protection: None
  Out-Interface: GE3/1/3                  Nexthop: 23.0.0.3
  Out-Label: 1151
  RRO number: 8
    2174               Flag: 0x01 (Global label)
    2.2.2.9/32         Flag: 0x21 (FRR Avail/Node-ID)
    23.0.0.2/32        Flag: 0x01 (FRR Avail)
    23.0.0.3/32        Flag: 0x00 (No FRR)
    1151               Flag: 0x01 (Global label)
    FRR inner label: 1151           Bypass tunnel: Tunnel10
Table 9 Command output
Tunnel name
Source
Exclude-any
Include-any
Include-all
Class type
CT of the P2MP LSP.
In-Transit-Label
Incoming label when the device acts as a transit node.
In-Egress-Label
Incoming label when the device acts as an egress node.
In-Interface
Incoming interface of the tunnel.
Sub-LSPs
Sub-LSPs of the P2MP LSP.
Destination
Out-Interface
Outgoing interface of the tunnel.
Nexthop
Next hop of the tunnel.
Out-Label
Outgoing label of the tunnel.
RRO number
Flag
·         In-Int—The IP address in the RRO is that of the incoming interface.
·         None—Not bound to an FRR bypass tunnel.
·         Ready—Bound to an FRR bypass tunnel. No FRR has occurred.
·         Active—Bound to an FRR bypass tunnel. An FRR has occurred.
FRR inner label
Bypass tunnel
display rsvp p2mp request
Use display rsvp p2mp request to display information about RSVP P2MP resource reservation requests sent to upstream devices.
display rsvp p2mp request [ destination ip-address ] [ source ip-address ] [ tunnel-id tunnel-id ] [ prevhop ip-address ] [ verbose ]
destination ip-address: Displays information about the RSVP P2MP resource reservation requests with the specified tunnel destination address.
source ip-address: Displays information about the RSVP P2MP resource reservation requests with the specified tunnel source address. The tunnel source address is the extended tunnel ID in the P2MP Session object of an RSVP message.
tunnel-id tunnel-id: Displays information about the RSVP P2MP resource reservation requests with the specified tunnel ID. The value range for a tunnel ID is 0 to 65535.
prevhop ip-address: Displays information about the RSVP P2MP resource reservation requests sent to the specified upstream device. The ip-address argument is the address of the destination device of the RSVP P2MP resource reservation requests, which is the address of the previous hop on the tunnel.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
If you do not specify any parameters, this command displays brief information about all RSVP P2MP resource reservation requests.
# Display brief information about all RSVP P2MP resource reservation requests.
<Sysname> display rsvp p2mp request
Source          Tunnel-ID  P2MP-ID      Destination    Previous-hop      Style
1.1.1.9         1          0x1010109    2.2.2.9        12.0.0.1          SE
1.1.1.9         1          0x1010109    2.3.3.9        12.0.0.1          SE
1.1.1.9         1          0x1010109    2.4.4.9        12.0.0.1          SE
Table 10 Command output
Source
Destination
Style
Resource reservation style:
·         SE—Shared-explicit style.
·         FF—Fixed-filter style.
# Display detailed information about all RSVP P2MP resource reservation requests.
<Sysname> display rsvp p2mp request verbose
P2MP ID: 0x1010109                         Style: SE
Previous hop: 12.0.0.1                     Previous hop LIH: 0x2
QoS service: Controlled-Load
Sub-LSPs:
    Sender address: 1.1.1.9                LSP ID: 29764
    Sub-Group OID: 0x2020209               Sub-Group ID: 2
    Sent message epoch: -                  Sent message ID: -
    Out-Interface: GE3/1/1                 Refresh interval: -
    Path MTU: -
    Sub-Group OID: 0x2020209               Sub-Group ID: 3
    Out-Interface: GE3/1/2                 Refresh interval: -
    Path MTU: -
  Destination: 4.4.4.9
    Sub-Group OID: 0x2020209               Sub-Group ID: 1
    Out-Interface: GE3/1/3                 Refresh interval: -
    Path MTU: -
Table 11 Command output
Source
LSR ID of the tunnel source end.
Style
Previous hop LIH
Logical interface handle of the previous hop.
QoS service
QoS service type: Controlled-Load or Guaranteed.
Sub-LSPs
Destination
Sender address
Sender address identifies the tunnel source end.
Sub-Group OID
Sub-group originator ID, which is the LSR ID of the local node.
Sub-Group ID
Sub-group ID that is globally unique.
Sent message epoch
Value of the Epoch field in the Message ID object of the sent message. This field is not supported in the current software version.
Sent message ID
Message ID in the sent message. This field is not supported in the current software version.
Out-Interface
Outgoing interface of the message.
Refresh interval
Refresh interval for Path and Resv messages, in milliseconds. This field is not supported in the current software version.
Path MTU
display rsvp p2mp reservation
Use display rsvp p2mp reservation to display information about RSVP P2MP resource reservation states.
display rsvp p2mp reservation [ destination ip-address ] [ source ip-address ] [ tunnel-id tunnel-id ] [ nexthop nexthop ] [ verbose ]
destination ip-address: Displays information about the RSVP P2MP resource reservation states with the specified tunnel destination address.
source ip-address: Displays information about the RSVP P2MP resource reservation states with the specified tunnel source address. The tunnel source address is the extended tunnel ID in the P2MP Session object of an RSVP message.
tunnel-id tunnel-id: Displays information about the RSVP P2MP resource reservation states with the specified tunnel ID. The value range for a tunnel ID is 0 to 65535.
nexthop nexthop: Displays information about the RSVP P2MP resource reservation states received from the specified downstream device. The ip-address argument is the address of the device that sent the resource reservation states, which is the address of the next hop on the tunnel.
If you do not specify any parameters, this command displays brief information about all RSVP P2MP resource reservation states.
# Display brief information about all RSVP P2MP resource reservation states.
<Sysname> display rsvp p2mp reservation
Source          Tunnel-ID    P2MP-ID      Destination  Nexthop           Style
1.1.1.9         1            0x1010109    2.2.2.9      12.0.0.2          SE
1.1.1.9         1            0x1010109    3.3.3.9      12.0.0.2          SE
1.1.1.9         1            0x1010109    4.4.4.9      12.0.0.2          SE
Table 12 Command output
Source
Destination
Style
# Display detailed information about all RSVP P2MP resource reservation states.
<Sysname> display rsvp p2mp reservation verbose
Sub-LSPs:
    Sub-Group OID: 1.1.1.9                Sub-Group ID: 2
    Nexthop: 12.0.0.2                     Nexthop LIH: 0x2
    Received message epoch: -             Received message ID: -
    In-Interface: GE3/1/1                 Path MTU: -
    Label: 2154
    Unknown object number: 0
    RRO number: 3
      2154             Flag: 0x01 (Global label)
    Sub-Group OID: 0x1010109              Sub-Group ID: 1
    Label: 2155
    RRO number: 7
      2155             Flag: 0x01 (Global label)
      23.0.0.2/32      Flag: 0x00 (No FRR)
      1141             Flag: 0x01 (Global label)
    Sub-Group OID: 0x1010109              Sub-Group ID: 3
    Label: 2155
    RRO number: 7
      24.0.0.2/32        Flag: 0x00 (No FRR)
      24.0.0.4/32        Flag: 0x00 (No FRR)
      4.4.4.9/32         Flag: 0x20 (No FRR/Node-ID)
Table 13 Command output
Source
Style
QoS service
Sub-LSPs
Destination
Sender address
Sub-Group OID
Sub-Group ID
Nexthop LIH
Logical interface handle of the local outgoing interface for the next hop.
Value of the Epoch field in the Message ID object of the received message. This field is not supported in the current software version.
Received message ID
Message ID in the received message. This field is not supported in the current software version.
In-Interface
Incoming interface of the message.
Path MTU
Label
Outgoing label of the LSP.
Number of unknown objects.
RRO number
Number of RROs.
Flag
display rsvp p2mp sender
Use display rsvp p2mp sender to display information about RSVP P2MP path states.
display rsvp p2mp sender [ destination ip-address ] [ source ip-address ] [ tunnel-id tunnel-id ] [ lsp-id lsp-id ] [ verbose ]
destination ip-address: Displays information about the RSVP P2MP path states with the specified tunnel destination address.
source ip-address: Displays information about the RSVP P2MP path states with the specified tunnel source address. The tunnel source address is the extended tunnel ID in the P2MP Session object of an RSVP message.
tunnel-id tunnel-id: Displays information about the RSVP P2MP path states with the specified tunnel ID. The value range for a tunnel ID is 0 to 65535.
lsp-id lsp-id: Displays information about the RSVP P2MP path states with the specified LSP ID. The lsp-id argument specifies the ID of a P2MP LSP, in the range of 0 to 65535.
If you do not specify any parameters, this command displays brief information about all RSVP P2MP path states.
# Display brief information about all RSVP P2MP path states.
<Sysname> display rsvp p2mp sender
Source          Tunnel-ID P2MP-ID      LSP-ID    Destination     Style   Bitrate
1.1.1.9         1         0x1010109    29764     2.2.2.9         SE      0.00
1.1.1.9         1         0x1010109    29764     3.3.3.9         SE      0.00
1.1.1.9         1         0x1010109    29764     4.4.4.9         SE      0.00
Table 14 Command output
Source
Destination
Style
Bitrate
Tunnel bandwidth in kbps.
# Display detailed information about all RSVP P2MP path states.
<Sysname> display rsvp p2mp sender verbose
FRR desired: Yes                          BW protection desired: No
Previous hop: -                           Previous hop LIH: -
In-Interface: -                           Local LIH: -
Sub-LSPs:
    Sub-Group OID: 0x1010109              Sub-Group ID: 2
    Out-Interface: GE3/1/1                Nexthop: 12.0.0.2
    Local address: 12.0.0.1               Refresh interval: -
    MTU: -
    Received Sender Template:
    Received ERO number: 0
    Sent ERO number: 2
      12.0.0.2/32        Strict
      2.2.2.9/32         Strict
    XRO number: 0
    RRO number: 0
    Fast Reroute PLR: Ready
      FRR inner label: 2155               Bypass tunnel: Tunnel100
      Sender Template:
        Sender address: 12.1.1.1          LSP ID: 29764
      FRR ERO number: 0
    Fast Reroute MP: None
    MTU: -
    Sent ERO number: 4
      12.0.0.2/32        Strict
      2.2.2.9/32         Strict
      23.0.0.2/32        Strict
      23.0.0.3/32        Strict
    XRO number: 0
    RRO number: 0
      Sender Template:
      FRR ERO number: 0
    MTU: -
    Sent ERO number: 4
      12.0.0.2/32        Strict
      2.2.2.9/32         Strict
      24.0.0.2/32        Strict
      24.0.0.4/32        Strict
    XRO number: 0
    RRO number: 0
    Fast Reroute PLR: None
      Sender Template:
      FRR ERO number: 0
Table 15 Command output
Source
Style
FRR desired
State of FRR: Yes or No.
State of bandwidth protection: Yes or No.
Previous hop LIH
Received message Epoch
Received message ID
In-Interface
Local LIH
Local logical interface handle.
QoS service
Sub-LSPs
Destination
Sender address
Sub-Group OID
Sub-Group ID
Out-Interface
Local address
IP address of the outgoing interface of the Path message.
Refresh interval
Sent message epoch
Sent message ID
MTU
Sender template in the received Path message.
Received ERO number
Number of received Explicit Route Objects (EROs) and the ERO information.
ERO information includes the addresses of the nodes on the explicit path, and whether the current node is a loose or strict next hop.
Sent ERO number
Number of sent EROs and the ERO information.
XRO number
Number of Exclude Route Objects (XROs).
If the number is not 0, the subsequent output displays the IP addresses in the XROs.
The IP addresses are the addresses of interfaces or the LSR IDs of the nodes that are to be excluded from routes. The addresses in the XROs are non-sequenced.
RRO number
Flag
Fast Reroute PLR
Point of Local Repair (PLR) information:
FRR inner label
Incoming label of the FRR bypass tunnel. Only the PLR node displays this field.
Bypass tunnel
Name of the bypass tunnel. Only the PLR node displays this field.
Sender Template
Sender template sent after an FRR.
After an FRR, the sender address becomes the IP address for the outgoing interface of the bypass tunnel on the PLR node.
FRR ERO number
Number of EROs for the MP.
Fast Reroute MP
Merge Point (MP) information:
·         Active—The node is an MP and an FRR has occurred.
·         None—The node is not an MP, or the node is an MP but no FRR has occurred.
display rsvp peer
Use display rsvp peer to display RSVP neighbor information.
display rsvp peer [ interface interface-type interface-number ] [ ip ip-address ] [ verbose ]
interface interface-type interface-number: Displays information about RSVP neighbors connected to the interface specified by its type and number.
ip ip-address: Displays information about the RSVP neighbor specified by its IP address.
verbose: Displays detailed information about RSVP neighbors. If you do not specify this keyword, the command displays brief information about RSVP neighbors.
If you do not specify any parameters, this command displays brief information about all RSVP neighbors.
# Display brief information about all RSVP neighbors.
<Sysname> display rsvp peer
Peer             Interface                State    Type     Summary refresh
57.10.10.1       GE3/1/1                  Idle     Active   Enabled
57.20.20.1       GE3/1/2                  Init     Passive  Disabled
Table 16 Command output
Peer
Address of the RSVP neighbor.
Interface connected to the RSVP neighbor.
Local hello state:
·         Idle—RSVP hello is disabled.
·         Init—RSVP hello is enabled. The local device failed to exchange hellos with the neighbor or hello exchanges are in progress.
·         Up—RSVP hello is enabled. The local device successfully exchanged hellos with the neighbor.
Role of the local device in the neighbor relationship:
·         Active—The local device actively sends hello requests to the neighbor.
·         Passive—The local end passively receives hello requests from the neighbor and replies with hello ACK messages.
Summary refresh
State of the Srefresh feature on the neighbor: Enabled or Disabled.
# Display detailed information about all RSVP neighbors.
<Sysname> display rsvp peer verbose
Peer: 57.10.10.1                          Interface: GE3/1/2
Hello state: Idle                         Hello type: Active
P2P PSB count: 0                          P2P RSB count: 3
P2MP PSB count: 0                         P2MP RSB count: 0
Src instance: 0x32e                       Dst instance: 0x0
Summary refresh: Enabled                  Graceful Restart state: Invalid
Peer GR restart time: 0 ms                Peer GR recovery time: 0 ms
Peer: 57.20.20.1                          Interface: GE3/1/4
Hello state: Init                         Hello type: Active
P2P PSB count: 0                          P2P RSB count: 1
Summary refresh: Disabled                 Graceful Restart state: Ready
Table 17 Command output
Peer
Hello state
Local hello state:
·         Idle—RSVP hello is disabled locally.
·         Init—RSVP hello is enabled locally. The local device failed to exchange hellos with the neighbor or hello exchanges are in progress.
·         Up—RSVP hello is enabled locally. The local device successfully exchanged hellos with the neighbor.
Hello type
·         Passive—The local device passively receives hello requests from the neighbor and replies with hello ACK messages.
P2P PSB count
Number of PSBs for the P2P neighbor.
P2P RSB count
Number of RSBs for P2P the neighbor.
P2MP PSB count
Number of PSBs for the P2MP neighbor.
P2MP RSB count
Number of RSBs for the P2MP neighbor.
Src instance
Local device instance carried in the hello sent to the neighbor.
Dst instance
Neighbor device instance carried in the last hello received from the neighbor.
Summary refresh
GR state of the neighbor:
·         Invalid—Neighbor is not GR capable, or GR is disabled locally.
·         Ready—Neighbor is GR capable.
·         Restarting—Neighbor is restarting.
·         Recovering—Neighbor is recovering.
GR restart period of the neighbor, in milliseconds.
GR recovery period of the neighbor, in milliseconds.
Use display rsvp request to display information about RSVP resource reservation requests sent to upstream devices.
display rsvp request [ destination ip-address ] [ source ip-address ] [ tunnel-id tunnel-id ] [ prevhop ip-address ] [ verbose ]
destination ip-address: Displays information about the RSVP resource reservation requests with the specified tunnel destination address.
source ip-address: Displays information about the RSVP resource reservation requests with the specified tunnel source address. The tunnel source address is the extended tunnel ID in the Session object of an RSVP message.
tunnel-id tunnel-id: Displays information about the RSVP resource reservation requests with the specified tunnel ID. The value range for a tunnel ID is 0 to 65535.
prevhop ip-address: Displays information about the RSVP resource reservation requests sent to the specified upstream device. The ip-address argument is the address of the destination device of the RSVP resource reservation requests, which is the address of the previous hop on the tunnel.
If you do not specify any parameters, this command displays brief information about all RSVP resource reservation requests sent to upstream devices.
# Display brief information about the RSVP resource reservation requests sent to all upstream devices.
<Sysname> display rsvp request
Destination     Source          Tunnel-ID Previous-hop      Style
3.3.3.9         1.1.1.9         1         57.10.10.1        SE
Table 18 Command output
Destination
Source
Style
# Display detailed information about the RSVP resource reservation requests sent to all upstream devices.
<Sysname> display rsvp request verbose
Tunnel ID: 1                              Style: SE
Previous hop: 57.10.10.1                  Previous hop LIH: 0xf0008
Sent message epoch: 0                     Sent message ID: 0
Out-Interface: GE3/1/2                    Refresh interval: 30000 ms
Flow descriptor 1:
  Flow specification:
    Mean rate (CIR): 50.00 kbps           Mean burst size (CBS): 1000.00 bytes
    Path MTU: 1500                        QoS service: Controlled-Load
  Filter specification 1:
    Sender address: 1.1.1.9               LSP ID: 23
    Label: 1110
Table 19 Command output
Destination
Source
Style
Previous hop LIH
Sent message epoch
Sent message ID
Out-Interface
Refresh interval
QoS service
Sender address
Label
Incoming label of the LSP.
display rsvp lsp
display rsvp sender
Use display rsvp reservation to display information about RSVP resource reservation states.
display rsvp reservation [ destination ip-address ] [ source ip-address ] [ tunnel-id tunnel-id ] [ nexthop ip-address ] [ verbose ]
destination ip-address: Displays information about the RSVP resource reservation states with the specified tunnel destination address.
source ip-address: Displays information about the RSVP resource reservation states with the specified tunnel source address. The tunnel source address is the extended tunnel ID in the Session object of an RSVP message.
tunnel-id tunnel-id: Displays information about the RSVP resource reservation states with the specified tunnel ID. The value range for a tunnel ID is 0 to 65535.
nexthop ip-address: Displays information about the RSVP resource reservation states received from the specified downstream device. The ip-address argument is the address of the device that sent the RSVP resource reservation states, which is the address of the next hop on the tunnel.
If you do not specify any parameters, this command displays brief information about all RSVP resource reservation states.
# Display brief information about all RSVP resource reservation states.
<Sysname> display rsvp reservation
Destination     Source          Tunnel-ID Nexthop           Style
3.3.3.9         1.1.1.9         1         57.20.20.1        SE
Table 20 Command output
Destination
Source
Style
# Display detailed information about all RSVP resource reservation states.
<Sysname> display rsvp reservation verbose
Nexthop: 57.20.20.1                       Nexthop LIH: 0x35
Received message epoch: 0                 Received message ID: 0
In-Interface: GE3/1/4                     Unknown object number: 0
Flow descriptor 1:
  Flow specification:
    Label: 3
    RRO number: 3
Table 21 Command output
Destination
Source
Style
Nexthop LIH
Received message ID
In-Interface
QoS service
Sender address
Label
RRO number
Number of RROs.
Flag
display rsvp lsp
display rsvp sender
display rsvp sender
Use display rsvp sender to display information about RSVP path states.
display rsvp sender [ destination ip-address ] [ source ip-address ] [ tunnel-id tunnel-id ] [ lsp-id lsp-id ] [ verbose ]
destination ip-address: Displays information about the RSVP path states with the specified tunnel destination address.
source ip-address: Displays information about the RSVP path states with the specified tunnel source address. The tunnel source address is the extended tunnel ID in the Session object of an RSVP message.
tunnel-id tunnel-id: Displays information about the RSVP path states with the specified tunnel ID. The value range for a tunnel ID is 0 to 65535.
lsp-id lsp-id: Displays information about the RSVP path states with the specified LSP ID. The lsp-id argument specifies the ID of a CRLSP, in the range of 0 to 65535.
If you do not specify any parameters, this command displays brief information about all RSVP path states.
# Display brief information about all RSVP path states.
<Sysname> display rsvp sender
Destination     Source          Tunnel-ID LSP-ID  Style     Bitrate
3.3.3.9         1.1.1.9         1         5       SE        0.00
3.3.3.9         2.2.2.9         253       17767   SE        125.00
Table 22 Command output
Destination
Source
Style
Bitrate
# Display detailed information about all RSVP path states.
<Sysname> display rsvp sender verbose
Sender address: 1.1.1.9                   LSP ID: 5
FRR desired: Yes                          BW protection desired: Yes
Received upstream label: 1051             Sent upstream label: 1051
MTU: 1500                                 Qos service: Controlled-Load
In-Interface: GE3/1/2                     Local LIH: 0x35
Local address: 57.20.20.2                 Refresh interval: 30000 ms
Out-Interface: GE3/1/4                    Nexthop: 57.20.20.1
Received ERO number: 2
  57.10.10.2/32      Strict
  57.20.20.1/32      Loose
XRO number: 2
  67.10.10.1/32
  67.20.20.1/32
Sent ERO number: 1
  57.20.20.1/32      Loose
RRO number: 1
Fast Reroute PLR: Active
  Sender Template:
    Sender address: 10.11.112.140         LSP ID: 5
  FRR ERO number: 1
    3.3.3.9/32         Strict
Destination: 3.3.3.9                      Source: 2.2.2.9
Tunnel ID: 253                            Style: SE
Sender address: 2.2.2.9                   LSP ID: 17767
Received upstream label: 1115             Sent upstream label: 1115
Mean rate (CIR): 125.00 kbps              Mean burst size (CBS): 0.00 bytes
In-Interface: GE3/1/2                     Local LIH: 0x67
Local address: 10.11.112.140              Refresh interval: 30000 ms
Out-Interface: GE3/1/3                    Nexthop: 10.11.112.135
Received ERO number: 5
  2.2.2.9/32         Strict
  10.11.112.140/32   Strict
  10.11.112.135/32   Strict
  57.40.40.3/32      Strict
  57.40.40.1/32      Strict
Sent ERO number: 3
XRO number: 1
  67.40.40.1/32
RRO number: 0
Fast Reroute MP: Active
  Sender Template:
Table 23 Command output
Destination
Source
LSR ID of the device at the tunnel source end.
Style
Sender address
FRR desired
Backward LSP label received from the upstream device.
Sent upstream label
Backward LSP label sent to the downstream device.
Previous hop LIH
QoS service
Received message ID
Sent message epoch
Sent message ID
In-Interface
Local LIH
Local address
Refresh interval
Out-Interface
Received ERO number
Sent ERO number
XRO number
RRO number
Flag
Fast Reroute PLR
FRR inner label
Bypass tunnel
Sender address
Address of the Path message sender after an FRR. The value of this field is the address of the outgoing interface of the bypass tunnel on the PLR node.
LSP ID
LSP ID carried in the Path message after an FRR.
Fast Reroute MP
In-Interface
display rsvp lsp
display rsvp statistics
Use display rsvp statistics to display RSVP statistics.
display rsvp statistics [ interface [ interface-type interface-number ] ]
interface: Displays RSVP statistics on interfaces. If you do not specify this keyword, the command displays global RSVP statistics.
interface-type interface-number: Displays RSVP statistics on the interface specified by its type and number. If you do not specify this argument, the command displays RSVP statistics on all RSVP-enabled interfaces.
# Display global RSVP statistics.
<Sysname> display rsvp statistics
P2P statistics:
Object                 Added            Deleted
  PSB                  3                1
  RSB                  3                1
  LSP                  3                1
P2MP statistics:
  PSB                  0                0
  RSB                  0                0
  LSP                  0                0
Packet                 Received         Sent
  Path                 5                5
  Resv                 5                5
  PathError            0                0
  ResvError            0                0
  PathTear             0                0
  ResvTear             0                0
  ResvConf             0                0
  Bundle               0                0
  Ack                  0                0
  Srefresh             0                0
  Hello                0                0
  Challenge            0                0
  Response             0                0
  Error                0                0
# Display RSVP statistics on interfaces.
<Sysname> display rsvp statistics interface
GE3/1/2:
  Path                 2                2
  Resv                 2                2
  PathError            0                0
  ResvError            0                0
  PathTear             0                0
  ResvTear             0                0
  ResvConf             0                0
  Bundle               0                0
  Ack                  0                0
  Srefresh             0                0
  Hello                0                0
  Challenge            0                0
  Response             0                0
  Error                0                0
GE3/1/4:
  Path                 3                3
  Resv                 3                3
  PathError            0                0
  ResvError            0                0
  PathTear             0                0
  ResvTear             0                0
  ResvConf             0                0
  Bundle               0                0
  Ack                  0                0
  Srefresh             0                0
  Hello                0                0
  Challenge            0                0
  Response             0                0
  Error                0                0
Table 24 Command output
PSB
Number of added/deleted PSBs.
RSB
Number of added/deleted RSBs.
LSP
Number of added/deleted LSPs.
Path
Number of received/sent Path messages.
Resv
Number of received/sent Resv messages.
PathError
Number of received/sent Path Error messages.
ResvError
Number of received/sent Resv Error messages.
PathTear
Number of received/sent Path Tear messages.
ResvTear
Number of received/sent Resv Tear messages.
ResvConf
Number of received/sent Resv Conf messages.
Bundle
Number of received/sent Bundle messages.
Ack
Number of received/sent Ack messages.
Srefresh
Number of received/sent Srefresh messages.
Hello
Number of received/sent Hello messages.
Challenge
Number of received/sent Integrity Challenge messages.
Response
Number of received/sent Integrity Response messages.
Error
Number of received/sent error messages.
reset rsvp statistics
dscp
Use dscp to set a DSCP value for outgoing RSVP packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value for outgoing RSVP packets is 48.
RSVP view
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value of an IP packet specifies the priority level of the packet and affects the transmission priority of the packet.
# Set the DSCP value for outgoing RSVP packets to 56.
[Sysname] rsvp
[Sysname-rsvp] dscp 56
display rsvp
graceful-restart enable
Use graceful-restart enable to enable RSVP GR.
Use undo graceful-restart enable to disable RSVP GR.
RSVP GR is disabled.
RSVP view
RSVP supports only the GR helper feature. The device is not able to perform GR, but it can help neighbor devices to perform GR.
Nonstop forwarding (NSF) is implemented between active and standby processes on the device.
The local device can act as a GR helper for the RSVP neighbor connected to an interface only after the following features are enabled on that interface:
·          RSVP GR (configured by the graceful-restart enable command).
·          RSVP hello (configured by the rsvp hello enable or hello node-session command).
# Enable RSVP GR globally.
[Sysname] rsvp
[Sysname-rsvp] graceful-restart enable
hello node-session
rsvp hello enable
hello interval
Use hello interval to set the interval for sending hello requests.
Use undo hello interval to restore the default.
hello interval interval
undo hello interval
Hello request messages are sent at an interval of 5 seconds.
RSVP view
interval: Specifies the interval at which RSVP sends hello requests, in the range of 1 to 60 seconds.
If no hello request is received from a neighbor within the hello interval, the device sends a hello request to the neighbor. If the device receives a hello request from a neighbor within the interval, it immediately replies the neighbor with a hello ACK message.
The hello interval command takes effect only on interfaces that have RSVP hello enabled (by using the rsvp hello enable or hello node-session command).
# Set the interval for sending hello request messages to 10 seconds.
[Sysname] rsvp
[Sysname-rsvp] hello interval 10
hello lost
hello node-session
rsvp hello enable
hello lost
Use hello lost to set the maximum number of consecutive lost or erroneous hellos.
Use undo hello lost to restore the default.
hello lost times
undo hello lost
The maximum number of consecutive lost or erroneous hellos is 4.
RSVP view
times: Specifies the maximum number of consecutive lost or erroneous hellos, in the range of 3 to 10.
When a device sends a hello to a neighbor but the device does not receive any replies within an interval, the hello is lost. The device determines that the neighbor fails when the number of consecutive lost hellos or erroneous hellos from the neighbor reaches the maximum (configured by this command).
If RSVP GR is enabled, the local device acts as a GR helper to help the neighbor to perform GR. If RSVP GR is disabled but FRR is enabled on the local device, it performs an FRR.
This command takes effect only after RSVP hello has been enabled by using the rsvp hello enable or hello node-session command.
If the maximum number is too big, neighbor failures cannot be promptly detected. If the maximum number is too small, an operating neighbor might be regarded failed.
# Set the maximum number of consecutive lost or erroneous hellos to 6.
[Sysname] rsvp
[Sysname-rsvp] hello lost 6
hello interval
hello node-session
rsvp hello enable
hello node-session
Use hello node-session to create an RSVP hello neighbor.
Use undo hello node-session to delete an RSVP hello neighbor.
hello node-session lsr-id
undo hello node-session lsr-id
No RSVP hello neighbors exist.
RSVP view
lsr-id: Specifies the LSR ID of the peer device, in dotted decimal notation.
To establish an RSVP hello neighbor relationship, you must configure this command on both the local and peer devices. With this command configured, a device sends and receives hello messages to detect the neighbor status.
You can use this command to establish an RSVP hello neighbor relationship between two indirectly connected nodes.
# Establish an RSVP hello neighbor relationship between the local device (LSR ID 1.1.1.9) and peer device (LSR ID 2.2.2.9).
·          On the local device:
[Sysname] rsvp
[Sysname-rsvp] hello node-session 2.2.2.9
·          On the peer device:
[Sysname] rsvp
[Sysname-rsvp] hello node-session 1.1.1.9
display rsvp peer
keep-multiplier
Use keep-multiplier to set the PSB and RSB timeout multiplier.
Use undo keep-multiplier to restore the default.
keep-multiplier number
The PSB and RSB timeout multiplier is 3.
RSVP view
number: Specifies the PSB and RSB timeout multiplier in the range of 3 to 255.
The PSB and RSB timeout is computed in this formula: Timeout = (keep-multiplier+0.5) × 1.5 × refresh-time. Refresh-time is the interval at which the peer device advertises the Path and Resv messages to the local device. You can use the refresh interval command to set the interval.
To prevent too many PSBs and RSBs from occupying system resources, the device removes a PSB or RSB if no Path or Resv message is received within the timeout interval.
# Set the PSB and RSB timeout multiplier to 5.
[Sysname] rsvp
[Sysname-rsvp] keep-multiplier 5
refresh interval
peer
Use peer to create an RSVP authentication neighbor and enter its view, or enter the view of an existing RSVP authentication neighbor.
Use undo peer to delete an RSVP authentication neighbor.
peer ip-address
undo peer ip-address
No RSVP authentication neighbors exist.
RSVP view
ip-address: Specifies an RSVP authentication neighbor by its IP address.
After this command is executed, you can configure RSVP authentication information for the specified RSVP neighbor, such as the authentication key and idle timeout of the security association.
After the device receives an RSVP message with an authentication object, it checks whether it has an RSVP authentication neighbor that matches one of the following addresses:
·          The IP address in PHOP of the message (Path or Path Tear message).
·          The source IP address in the message (message other than Path and Path Tear).
If a matching neighbor exists and an authentication key has been configured for the neighbor, the device verifies the validity of the message according to the key. If no authentication key is configured for the neighbor, the device uses the authentication key configured in interface view or RSVP view to verify the message validity. If no authentication key is configured in any view, the device ignores the authentication object carried in the message and accepts the message.
When sending an RSVP message, the device checks whether it has a matching authentication neighbor according to the next hop address for the destination address in the RSVP message. If a matching neighbor exists and an authentication key has been configured for the neighbor, the device sets the authentication object of the message according to the key. If no authentication key is configured for the neighbor, the device uses the authentication key configured in interface view or RSVP view to set the authentication object. If no authentication key is configured in any view, the device does not add an authentication object in the message.
If an FRR occurs, the downstream authentication neighbor of the PLR node is the destination IP address of the bypass tunnel. The upstream authentication neighbor of the MP node is the IP address of the physical outgoing interface of the bypass tunnel on the PLR.
# Create RSVP authentication neighbor 1.1.1.1, enter RSVP neighbor view, and configure a plaintext authentication key of abcdfegh for the neighbor.
[Sysname] rsvp
[Sysname-rsvp] peer 1.1.1.1
[Sysname-rsvp-peer-1.1.1.1] authentication key plain abcdfegh
authentication key
refresh interval
Use refresh interval to set the refresh interval for Path and Resv messages.
Use undo refresh interval to restore the default.
refresh interval interval
The refresh interval for Path and Resv messages is 30 seconds.
RSVP view
interval: Specifies the interval at which RSVP refreshes Path and Resv messages, in the range of 10 to 65535 seconds.
This command performs the following operations:
·          Determines the interval for sending Path and Resv messages.
·          Adds the locally configured refresh interval in the sent Path and Resv messages, so the peer device can use this value to calculate the PSB and RSB timeout.
# Set the refresh interval for Path and Resv messages to 60 seconds.
[Sysname] rsvp
[Sysname-rsvp] refresh interval 60
keep-multiplier
reset rsvp
Use reset rsvp to re-establish RSVP-TE sessions and CRLSPs.
reset rsvp
This command clears and then re-establishes all RSVP-TE sessions and CRLSPs on the device, causing MPLS TE tunnel flapping. Use this command only when necessary.
# Re-establish RSVP-TE sessions and CRLSPs.
<Sysname> reset rsvp
Use reset rsvp authentication to clear RSVP security associations.
reset rsvp authentication [ from ip-address to ip-address ]
from ip-address: Clears the RSVP security associations with the specified authentication source IP address.
to ip-address: Clears the RSVP security associations with the specified authentication destination IP address.
If you do not specify the from ip-address to ip-address options, this command clears the security associations established with all RSVP neighbors.
# Clear all RSVP security associations.
<Sysname> reset rsvp authentication
# Clear the RSVP security association sourced from 1.1.1.1 to 2.2.2.2.
<Sysname> reset rsvp authentication from 1.1.1.1 to 2.2.2.2
Use reset rsvp statistics to clear RSVP statistics.
reset rsvp statistics [ interface [ interface-type interface-number ] ]
interface: Clears RSVP statistics on interfaces. If you do not specify this keyword, the command clears global RSVP statistics.
interface-type interface-number: Clears RSVP statistics on the interface specified by its type and number. If you specify the interface keyword without this argument, the command clears RSVP statistics on all RSVP-enabled interfaces.
# Clear global RSVP statistics.
<Sysname> reset rsvp statistics
# Clear RSVP statistics on all RSVP-enabled interfaces.
<Sysname> reset rsvp statistics interface
rsvp
Use rsvp to enable RSVP globally and enter RSVP view.
Use undo rsvp to disable RSVP globally.
rsvp
undo rsvp
RSVP is disabled globally.
To enable global RSVP, you must enable both global RSVP (by using the rsvp command) and global MPLS TE (by using the mpls te command).
# Enable RSVP globally and enter RSVP view.
[Sysname] rsvp
[Sysname-rsvp]
mpls te
rsvp enable
Use rsvp authentication challenge to enable RSVP challenge-response handshake on an interface.
Use undo rsvp authentication challenge to disable RSVP challenge-response handshake on an interface.
RSVP challenge-response handshake is disabled on an interface.
Interface view
To prevent packet replay attacks, RSVP requires received authentication messages to carry incremental sequence numbers. RSVP saves the sequence number of the last valid message in a receive-type security association to verify the subsequent messages. However, when RSVP creates a new receive-type security association, it cannot obtain the sequence number of the sender. To successfully establish the receive-type security association, RSVP sets the receive sequence number to 0 by default. Then, the association can receive a message with any sequence number from the peer. Because this introduces a vulnerability to replay attacks, you should execute the authentication challenge command. When RSVP creates a receive-type security association, it will perform a challenge-response handshake to obtain the sequence number of the sender.
RSVP challenge-response handshake can be configured in the following views:
·          RSVP view—Configuration applies to all RSVP security associations.
·          Interface view—Configuration applies only to RSVP security associations established on the current interface.
# Enable RSVP challenge-response handshake on GigabitEthernet 3/1/1.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] rsvp authentication challenge
authentication key
rsvp authentication key
rsvp authentication lifetime
rsvp authentication window-size
Use rsvp authentication key to enable RSVP authentication on an interface and configure the authentication key.
Use undo rsvp authentication key to disable RSVP authentication on an interface.
rsvp authentication key { cipher | plain } string
RSVP authentication is disabled.
Interface view
cipher: Specifies an authentication key in encrypted form.
plain: Specifies an authentication key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the authentication key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters.
RSVP authentication ensures integrity of RSVP messages, preventing fake resource reservation requests from occupying network resources.
RSVP uses MD5 to calculate a digest for the authentication key and the message body, adds the digest to the message, and sends the message. When the peer receives the message, it performs the same calculation and compares the calculated digest with the digest in the message. If the two digests are the same, the message passes the RSVP authentication and is accepted. If the two digests are different, the peer device discards the message.
RSVP authentication can be configured in the following views:
·          RSVP neighbor view—Configuration applies only to RSVP security associations with the specified RSVP neighbor.
Configurations in RSVP neighbor view, interface view, and RSVP view are in descending order of priority. If RSVP authentication for a neighbor is enabled in both RSVP neighbor view and RSVP view, the authentication key configured in RSVP neighbor view is used.
To re-establish a security association, you must delete the authentication key used by the current security association or delete the current security association (using the reset rsvp authentication command). Then, the device can re-establish a security association by looking up a new authentication key in order of priorities.
After RSVP authentication is enabled on the local device, you must also enable RSVP authentication and configure the same authentication key on the RSVP neighbor.
# Enable RSVP authentication and configure an authentication key of abcdefgh on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] rsvp authentication key plain abcdefgh
authentication key
Use rsvp authentication lifetime to set the idle timeout for RSVP security associations on an interface.
Use undo rsvp authentication lifetime to restore the default.
rsvp authentication lifetime life-time
The idle timeout for RSVP security associations is 1800 seconds on an interface.
Interface view
life-time: Specifies the RSVP security association idle timeout in the range of 30 to 86400 seconds.
When RSVP authentication is enabled, the device dynamically establishes security associations when receiving and sending RSVP messages to record the message sequence numbers, which are used in RSVP authentication.
To release memory resources, each security association has an idle timeout. When a security association is idle for the specified timeout time, the device deletes the security association. When the device sends or receives an authenticated RSVP message, it resets the idle timeout timer for the corresponding security association.
The RSVP authentication idle timeout can be configured in the following views:
An RSVP security association established by using the authentication key configured in a view uses the idle timeout configured in the same view.
A modification to the idle timeout affects only security associations established after the modification. To apply the modification to existing security associations, you must execute the reset rsvp authentication command to delete and then re-establish the security associations.
# Set the idle timeout for RSVP security associations to 100 seconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] rsvp authentication lifetime 100
authentication key
Use rsvp authentication window-size to set the RSVP authentication window size, which is the maximum number of authenticated RSVP messages that can be received out of sequence on an interface.
Use undo rsvp authentication window-size to restore the default.
rsvp authentication window-size number
Only one authenticated RSVP message can be received out of sequence on an interface.
Interface view
number: Specifies the maximum number of authenticated RSVP messages that can be received out of sequence, in the range of 1 to 64.
To protect against replay attacks, the sender places a unique sequence number in each RSVP message that contains authentication information. The sender increases the value of the sequence number by one each time it sends an RSVP message. If the sequence number of a received message is in the specified authentication window size, the receiver accepts the message. If it is not in the specified authentication window size, the receiver discards the message.
When the receiver receives an RSVP message, it compares the sequence number of the last accepted RSVP message with the sequence number of the newly received RSVP message.
·          If the new sequence number is greater than the last sequence number, RSVP accepts the message and updates the last sequence number with the new sequence number.
·          If the received sequence number equals the last sequence number, RSVP regards the message a replay message and discards the message.
·          If the new sequence number is smaller, the receiver compares the new sequence number with the authentication window size.
¡  If the new sequence number is greater, and has never been received before, RSVP accepts the message. If the new sequence number has been received before, RSVP regards the message a replay message and discards the message.
¡  If the new sequence number is not greater, RSVP regards the message invalid and discards the message.
By default, the authentication window size is 1. If the sequence number of a newly received RSVP message is smaller than that of the last accepted message, the device discards the message.
If the sender sends multiple RSVP messages in a short time, these messages might arrive at the neighbor out of sequence. If you use the default window size, the out-of-sequence messages will be discarded. To solve this problem, you can use the rsvp authentication window-size command to configure a correct window size.
A security association established by using the authentication key configured in a view uses the window size configured in that view.
A modification to the window size affects only security associations established after the modification. To apply the new setting to existing security associations, you must execute the reset rsvp authentication command to delete and then re-establish the security associations.
# Set the maximum number of out-of-sequence authenticated RSVP messages that can be received on GigabitEthernet 3/1/1 to 10.
[Sysname-GigabitEthernet3/1/1] rsvp authentication window-size 10
authentication key
rsvp bfd enable
Use rsvp bfd enable to enable BFD for RSVP on an interface.
Use undo rsvp bfd enable to restore the default.
rsvp bfd enable
RSVP-TE does not use BFD to detect the link status to an RSVP neighbor.
Interface view
By sending hellos, RSVP cannot promptly detect neighbor status. By executing this command on an interface, a BFD session is established to detect the link status to the RSVP neighbor on the interface. When the neighbor fails, BFD can quickly detect the failure and notify RSVP of the failure so RSVP can respond as configured, for example, performs an FRR.
# Enable BFD to detect the link status to the RSVP neighbor on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] rsvp bfd enable
rsvp enable
Use rsvp enable to enable RSVP on an interface.
Use undo rsvp enable to disable RSVP on an interface.
rsvp enable
undo rsvp enable
RSVP is disabled on an interface.
Interface view
Before you enable RSVP on an interface, you must first enable RSVP globally by using the rsvp command in system view.
# Enable RSVP on GigabitEthernet 3/1/1.
[Sysname] rsvp
[Sysname-rsvp] quit
[Sysname-GigabitEthernet3/1/1] rsvp enable
rsvp
rsvp hello enable
Use rsvp hello enable to enable RSVP hello on an interface.
Use undo rsvp hello enable to disable RSVP hello on an interface.
rsvp hello enable
RSVP hello is disabled on an interface.
Interface view
With RSVP hello enabled, an interface sends and receives hello messages to detect the neighbor status.
# Enable RSVP hello on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] rsvp hello enable
hello interval
hello lost
hello node-session
rsvp reduction retransmit increment
Use rsvp reduction retransmit increment to set the RSVP message retransmission increment value.
Use undo rsvp reduction retransmit increment to restore the default.
rsvp reduction retransmit increment increment-value
The RSVP message retransmission increment is 1.
Interface view
increment-value: Specifies the RSVP message retransmission increment in the range of 1 to 10.
After the rsvp reduction srefresh reliability command is executed, the retransmission increment and retransmission interval together determine the time for the next transmission of the RSVP message. For more information, see the usage guidelines in the rsvp reduction srefresh command.
# On GigabitEthernet 3/1/1, set the RSVP message retransmission increment value to 2.
[Sysname-GigabitEthernet3/1/1] rsvp reduction retransmit increment 2
rsvp reduction retransmit interval
Use rsvp reduction retransmit interval to set the RSVP message retransmission interval.
Use undo rsvp reduction retransmit interval to restore the default.
rsvp reduction retransmit interval interval
The RSVP message retransmission interval is 500 milliseconds.
Interface view
interval: Specifies the RSVP message retransmission interval in the range of 500 to 3000 milliseconds.
# On GigabitEthernet 3/1/1, set the RSVP message retransmission interval to 1000 milliseconds.
[Sysname-GigabitEthernet3/1/1] rsvp reduction retransmit interval 1000
Use rsvp reduction srefresh to enable summary refresh and reliable RSVP message delivery.
Use undo rsvp reduction srefresh to disable summary refresh and reliable RSVP message delivery.
rsvp reduction srefresh [ reliability ]
Summary refresh and reliable RSVP message delivery are disabled.
Interface view
reliability: Enables reliable RSVP message delivery. If you do not specify this keyword, the command enables only the summary refresh feature.
RSVP sends Path and Resv messages with the same states and objects to maintain the path and reservation states at intervals (configured by the refresh interval command). These messages are collectively referred to as refresh messages. Refresh messages are used to synchronize the path and reservation states on RSVP neighbors and to recover from lost RSVP messages.
When multiple RSVP sessions exist on a network, the periodically sent refresh messages can cause network degradation. In this case, the refreshing interval of Path and Resv messages should not be too short. However, delay sensitive applications want to recover from lost RSVP messages through the refresh messages as soon as possible. In this case, the refreshing interval should not be too long. You can use the summary refresh (Srefresh) and the reliable RSVP message delivery features to find the appropriate balance.
Srefresh is implemented by adding a Message_ID object to a Path or Resv message to uniquely identify the message. To refresh Path and Resv states, RSVP does not need to send standard Path and Resv messages. Instead, it can send a summary refresh message at regular intervals (configured by the refresh interval command). The message carries a set of Message_ID objects that identify the Path and Resv states to be refreshed. The Srefresh feature reduces the number of refresh messages on the network and speeds up the refresh message processing.
Reliable RSVP message delivery requires the peer device to acknowledge each RSVP message received from the local device. If no acknowledgment is received, the local device retransmits the message.
To implement reliable RSVP message delivery, a node sends an RSVP message that includes a Message_ID object in which the ACK_Desired flag is set. The receiver needs to confirm the delivery by sending back a message that includes the Message_ID_ACK object. If the sender does not receive a Message_ID_ACK within the retransmission interval (Rf), it performs the following operations:
·          Retransmits the message when Rf expire.
·          Sets the next transmission interval to (1 + delta) × Rf.
The sender repeats this process until it receives the Message_ID_ACK before the retransmission time expires or it has transmitted the message three times.
The initial value of Rf is configured by the rsvp reduction retransmit interval command. The delta value is configured by the rsvp reduction retransmit increment command.
After the summary refresh is enabled, RSVP maintains the path and reservation states by sending Srefresh messages rather than standard refresh messages.
# On GigabitEthernet 3/1/1, enable summary refresh and reliable RSVP message delivery.
[Sysname-GigabitEthernet3/1/1] rsvp reduction srefresh reliability
refresh interval
