08-IP Multicast Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command References-Release795x-6W10008-IP Multicast Command Reference
06-PIM commands
06-PIM commands 211.49 KB
PIM commands· 1
anycast rp (PIM view) 1
auto-rp enable (PIM view) 1
bsm-fragment enable (PIM view) 2
bsm-reflection enable (PIM view) 2
bsr-policy (PIM view) 3
c-bsr (PIM view) 4
c-rp (PIM view) 5
crp-policy (PIM view) 6
display interface register-tunnel 7
display pim bsr-info· 9
display pim claimed-route· 10
display pim c-rp· 12
display pim interface· 13
display pim neighbor 15
display pim routing-table· 17
display pim rp-info· 21
display pim statistics· 23
dscp· 24
hello-option dr-priority (PIM view) 25
hello-option holdtime (PIM view) 25
hello-option lan-delay (PIM view) 26
hello-option neighbor-tracking (PIM view) 27
hello-option override-interval (PIM view) 27
holdtime join-prune (PIM view) 28
jp-pkt-size (PIM view) 29
pim·· 29
pim bfd enable· 30
pim bsr-boundary· 31
pim dm·· 31
pim hello-option dr-priority· 32
pim hello-option holdtime· 33
pim hello-option lan-delay· 33
pim hello-option neighbor-tracking· 34
pim hello-option override-interval 35
pim holdtime join-prune· 36
pim join-policy· 36
pim neighbor-policy· 38
pim non-stop-routing· 38
pim passive· 39
pim require-genid· 39
pim sm·· 40
pim state-refresh-capable· 40
pim timer graft-retry· 41
pim timer hello· 42
pim timer join-prune· 42
pim triggered-hello-delay· 43
register-policy (PIM view) 44
register-suppression-timeout (PIM view) 44
register-whole-checksum (PIM view) 45
snmp-agent trap enable pim·· 45
source-lifetime (PIM view) 46
source-policy (PIM view) 47
spt-switch-threshold (PIM view) 48
ssm-policy (PIM view) 49
state-refresh-interval (PIM view) 50
state-refresh-rate-limit (PIM view) 50
state-refresh-ttl (PIM view) 51
static-rp (PIM view) 51
timer hello (PIM view) 53
timer join-prune (PIM view) 53
PIM commands
Use anycast-rp to add an anycast RP member to an Anycast RP set.
Use undo anycast-rp to remove an anycast RP member from an Anycast RP set.
anycast-rp anycast-rp-address member-address
undo anycast-rp anycast-rp-address member-address
No Anycast RP sets exist.
PIM view
anycast-rp-address: Specifies an Anycast RP address. It must be a legal unicast IP address that is not in the range of 127.0.0.0/8.
member-address: Specifies an Anycast RP member address. It must be a legal unicast IP address that is not in the range of 127.0.0.0/8 and must be different from the Anycast RP address.
To add multiple RP member addresses to an Anycast RP set, execute this command multiple times with the same Anycast RP address but different RP member addresses.
To configure multiple Anycast RP sets, execute this command multiple times with different Anycast RP addresses.
# Add Anycast RP members 1.1.0.1 and 1.2.0.1 to Anycast RP set 1.1.0.0 on the public network.
[Sysname] pim
[Sysname-pim] anycast-rp 1.1.0.0 1.1.0.1
[Sysname-pim] anycast-rp 1.1.0.0 1.2.0.1
display pim rp-info
Use auto-rp enable to enable Auto-RP listening.
Use undo auto-rp enable to disable Auto-RP listening.
auto-rp enable
undo auto-rp enable
Auto-RP listening is disabled.
PIM view
# Enable Auto-RP listening on the public network.
[Sysname] pim
[Sysname-pim] auto-rp enable
Use bsm-fragment enable to enable bootstrap message (BSM) semantic fragmentation.
Use undo bsm-fragment enable to disable BSM semantic fragmentation.
bsm-fragment enable
BSM semantic fragmentation is enabled.
PIM view
Disable BSM semantic fragmentation if the PIM-SM domain contains a device that does not support BSM semantic fragmentation.
# Disable BSM semantic fragmentation on the public network.
[Sysname] pim
[Sysname-pim] undo bsm-fragment enable
Use bsm-reflection enable to enable the device to forward BSMs out of their incoming interfaces.
Use undo bsm-reflection enable to disable the device from forwarding BSMs out of their incoming interfaces.
The device forwards BSMs out of their incoming interfaces.
PIM view
Disable this feature if all the devices in the PIM-SM domain have consistent routing information.
# Disable the device from forwarding BSMs out of their incoming interfaces on the public network.
[Sysname] pim
[Sysname-pim] undo bsm-reflection enable
Use bsr-policy to configure a BSR policy.
Use undo bsr-policy to restore the default.
bsr-policy ipv4-acl-number
undo bsr-policy
No BSR policy exists, and all bootstrap messages are regarded as legal.
PIM view
ipv4-acl-number: Specifies an IPv4 basic ACL by its number in the range of 2000 to 2999.
A BSR policy filters bootstrap messages to guard against BSR spoofing.
When you configure a rule in the IPv4 basic ACL, follow these restrictions and guidelines:
·          For the rule to take effect, do not specify the vpn-instance vpn-instance option.
·          The source source-address source-wildcard option specifies a BSR address.
·          Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
# Configure a BSR policy on the public network so that only the devices on subnet 10.1.1.0/24 can act as the BSR.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 10.1.1.0 0.0.0.255
[Sysname] pim
[Sysname-pim] bsr-policy 2000
c-bsr (PIM view)
c-bsr (PIM view)
Use c-bsr to configure a candidate-BSR (C-BSR).
Use undo c-bsr to remove the configuration of a C-BSR.
c-bsr ip-address [ scope group-address { mask-length | mask } ] [ hash-length hash-length | priority priority ] *
undo c-bsr ip-address [ scope group-address { mask-length | mask } ]
No C-BSRs exist.
PIM view
ip-address: Specifies the IP address of a C-BSR. You must specify the IP address of a local PIM interface.
scope group-address: Specifies a multicast group by its IP address in the range of 239.0.0.0 to 239.255.255.255. If you do not specify a multicast group, this command designates the C-BSR to the global-scoped zone.
mask-length: Specifies an address mask length in the range of 8 to 32.
mask: Specifies an address mask.
hash-length hash-length: Specifies a hash mask length in the range of 0 to 32. The default setting is 30.
priority priority: Specifies a C-BSR priority in the range of 0 to 255. The default setting is 64. The greater the value, the higher the priority.
If you execute this command for a zone multiple times, the most recent configuration takes effect.
You can configure the same C-BSR for different zones.
# Configure the interface with IP address 1.1.1.1 as a C-BSR for the global-scoped zone on the public network.
[Sysname] pim
[Sysname-pim] c-bsr 1.1.1.1
c-rp (PIM view)
Use c-rp to configure a candidate-RP (C-RP).
Use undo c-rp to remove the configuration of a C-RP.
c-rp ip-address [ advertisement-interval adv-interval | group-policy ipv4-acl-number | holdtime hold-time | priority priority ] *
undo c-rp ip-address
No C-RPs exist.
PIM view
ip-address: Specifies the IP address of a C-RP. You must specify the IP address of a local PIM interface.
advertisement-interval adv-interval: Specifies a C-RP advertisement interval in the range of 1 to 65535 seconds. The default value is 60 seconds.
group-policy ipv4-acl-number: Specifies an IPv4 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, this command designates the C-RP to IPv4 multicast groups in C-RP advertisement messages that the ACL permits. The C-RP is designated to all IPv4 multicast groups when one of the following conditions exists:
·          You do not specify an ACL.
·          The specified ACL does not exist.
·          The specified ACL does not have valid rules.
holdtime hold-time: Specifies a C-RP lifetime in the range of 1 to 65535 seconds. The default value is 150 seconds.
priority priority: Specifies a C-RP priority in the range of 0 to 255. The default setting is 192. The greater the value, the lower the priority.
To designate a C-RP to multiple multicast group ranges, create multiple rules that specify different multicast group ranges in the ACL.
·          The source source-address source-wildcard option specifies a multicast group range.
If you execute this command by using the same C-RP address multiple times, the most recent configuration takes effect.
# Configure the interface with IP address 1.1.1.1 as a C-RP for multicast group ranges 225.1.0.0/16 and 226.2.0.0/16 and set its priority to 10 on the public network.
[Sysname-acl-ipv4-basic-2000] rule permit source 225.1.0.0 0.0.255.255
[Sysname-acl-ipv4-basic-2000] rule permit source 226.2.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] c-rp 1.1.1.1 group-policy 2000 priority 10
Use crp-policy to configure a C-RP policy.
Use undo crp-policy to restore the default.
crp-policy ipv4-acl-number
undo crp-policy
No C-RP policy exists, and all C-RP messages are regarded as legal.
PIM view
ipv4-acl-number: Specifies an IPv4 advanced ACL number in the range of 3000 to 3999.
A C-RP policy filters C-RP advertisement messages to guard against C-RP spoofing.
The device uses only the prefixes of the multicast group ranges in advertisement messages to match the destination field in ACL rules. For example, the multicast group range in an advertisement message is 224.1.0.0/16. If the prefix 224.1.0.0 is in the range specified by the destination field of an ACL rule, the specified C-RPs are designated to this multicast group range.
When you configure a rule in the IPv4 advanced ACL, follow these restrictions and guidelines:
·          The source source-address source-wildcard option specifies an RP address.
·          The destination dest-address dest-wildcard option specifies a multicast group address.
# Configure a C-RP policy on the public network so that only devices in the range of 1.1.1.1/24 can be C-RPs for the groups in the range of 225.1.1.0/24.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source 1.1.1.1 0.0.0.255 destination 225.1.1.0 0.0.0.255
[Sysname] pim
[Sysname-pim] crp-policy 3000
c-rp (PIM view)
Use display interface register-tunnel to display register-tunnel interface information.
display interface [ register-tunnel [ interface-number ] ] [ brief [ description | down ] ]
register-tunnel [ interface-number ]: Specifies a register-tunnel interface by its number. The device has only one register-tunnel interface, Register-Tunnel 0. If you specify the register-tunnel keyword, this command displays information about Register-Tunnel 0 regardless of whether you specify an interface number. If you do not specify the register-tunnel keyword, this command displays information about all interfaces.
brief: Displays brief information. If you do not specify this keyword, the command displays detailed information.
description: Displays the full interface description. If you do not specify this keyword, the command displays only the first 27 characters of the interface description.
down: Displays information about the interfaces in down state and the reasons why the interfaces are down. If you do not specify this keyword, the command displays information about interfaces in all states.
The register-tunnel interface is a virtual interface that is automatically created by the system. You cannot configure it or delete it, but you can display the interface information by using this command.
In the initial stage of multicast source registration, the register-tunnel interface is used to establish a channel between the source-side DR and the RP to transmit multicast register messages. The process of initial source registration is as follows:
1.        After receiving the first multicast data from the source, the source-side DR encapsulates the multicast data into a register message. Then, it forwards the message to the RP through the register-tunnel interface.
2.        The register message reaches RP on the register-tunnel interface on the RP. The RP decapsulates the register message and forwards the multicast data to the receiver hosts. At the same time, the RP learns the IP address of the multicast source.
3.        The RP sends a join message toward the multicast source to build an SPT.
4.        After the SPT is built, the multicast data travels to the RP along the SPT rather than through the register-tunnel interface.
# Display detailed information about Register-Tunnel 0.
<Sysname> display interface register-tunnel 0
Register-Tunnel0
Current state: UP
Line protocol state: DOWN
Description: Register-Tunnel0 Interface
Maximum transmission unit: 1536
Physical: Unknown
# Display brief information about Register-Tunnel 0.
<Sysname> display interface register-tunnel 0 brief
Protocol: (s) - spoofing
REG0                 UP   --       --
Current state
Physical link state of the interface. This field always displays UP.
Line protocol state
Data link layer state of interface. This field always displays DOWN.
Description of the interface. It is not configurable.
MTU of the register-tunnel interface. It is not configurable.
The interface is not assigned an IP address and cannot process IP packets.
Physical
Physical type of the interface. This field always displays Unknown, because the physical type of the interface is unknown.
Average incoming rate in the last 300 seconds. This field always displays 0.
Average outgoing rate in the last 300 seconds. This field always displays 0.
Input
Number of incoming packets, incoming bytes, and discarded packets. This field always displays 0.
Output
Number of outgoing packets, outgoing bytes, and discarded packets. This field always displays 0.
Brief information about Layer 3 interfaces.
Link
Protocol
Data link layer protocol state of the interface. This field always displays two hyphens (--) because the interface does not support a data link layer protocol.
Primary IP
Primary IP address of the interface. This field always displays two hyphens (--) because the interface does not have a primary IP address.
Cause
Cause for the physical link state of an interface to be DOWN. This field always displays Not connected because no physical connection exists.
Description of the interface. This field is empty because the interface cannot be configured with a description.
Related command
reset counters interface register-tunnel
Use display pim bsr-info to display BSR information.
display pim [ vpn-instance vpn-instance-name ] bsr-info
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BSR information on the public network.
# Display BSR information on the public network.
<Sysname> display pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:01:44
     Elected BSR address: 12.12.12.1
       Priority: 64
       Hash mask length: 30
       Uptime: 00:21:56
 Scope: 239.4.0.0/16
     State: Accept Any
     Scope-zone expiry timer: 00:21:12
 Scope: 239.1.0.0/16
     State: Elected
     Bootstrap timer: 00:00:26
     Elected BSR address: 17.1.11.1
       Priority: 64
       Uptime: 02:53:37
     Candidate BSR address: 17.1.11.1
       Priority: 64
 Scope: 239.2.2.0/24
     State: Candidate
     Bootstrap timer: 00:01:56
     Elected BSR address: 61.2.37.1
       Priority: 64
       Uptime: 02:53:32
     Candidate BSR address: 17.1.12.1
       Priority: 64
 Scope: 239.3.3.0/24
     State: Pending
     Bootstrap timer: 00:00:07
     Candidate BSR address: 17.1.13.1
       Priority: 64
Bootstrap timer
Aging timer for the BSR.
Aging timer for the scoped zone.
Elected BSR address
Address of the elected BSR.
Address of the C-BSR.
Priority
BSR priority.
Uptime
Length of time the BSR has been up.
Use display pim claimed-route to display information about all routes that PIM uses.
display pim [ vpn-instance vpn-instance-name ] claimed-route [ source-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about all routes that PIM uses on the public network.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays information about all routes that PIM uses.
# Display information about all routes that PIM uses on the public network.
<Sysname> display pim claimed-route
 RPF-route selecting rule: longest-match
 Route/mask: 7.11.0.0/16 (unicast (direct))
     RPF interface: GigabitEthernet3/1/1, RPF neighbor: 8.0.0.2
     Total number of (S,G) or (*,G) dependent on this route entry: 4
     (7.11.0.10, 225.1.1.1)
     (7.11.0.10, 226.1.1.1)
     (7.11.0.10, 227.1.1.1)
     (*, 228.1.1.1)
 Route/mask: 7.12.0.0/16 (multicast static)
     RPF interface: GigabitEthernet3/1/2, RPF neighbor: 8.0.0.3,
     Config NextHop: 8.0.0.5
     Total number of (S,G) or (*,G) dependent on this route entry: 2
     (7.12.0.10, 226.1.1.1)
     (7.12.0.10, 225.1.1.1)
Route/mask
Route entry. Route types in parentheses include:
·         igp—IGP unicast route.
·         egp—EGP unicast route.
·         unicast (direct)—Direct unicast route.
·         unicast—Other unicast route, such as static unicast route.
·         mbgp—MBGP route.
·         multicast static—Static multicast route.
RPF interface
Name of the RPF interface.
RPF neighbor
IP address of the RPF neighbor.
Config NextHop
Address of the configured next hop. This field is displayed only when the static multicast route is configured with a next hop.
Total number of (S, G) or (*, G) entries associated with the RPF route and the entry list.
display pim c-rp
Use display pim c-rp to display C-RP information.
display pim [ vpn-instance vpn-instance-name ] c-rp [ local ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about learned C-RPs on the public network.
local: Specifies local C-RPs. If you do not specify this keyword, the command displays information about all C-RPs.
You can view information about learned C-RPs only on the BSR. On other devices, you can view information about the locally configured C-RPs.
# Display information about learned C-RPs on the public network.
<Sysname> display pim c-rp
 Scope: non-scoped
     Group/MaskLen: 224.0.0.0/4
       C-RP address             Priority  HoldTime  Uptime    Expires
       1.1.1.1 (local)          192       150       03:01:36  00:02:29
       2.2.2.2                  192       150       1d:13h    00:02:02
# Display information about the locally configured C-RPs.
<Sysname> display pim c-rp local
 Candidate RP: 12.12.12.9(Loop1)
     Priority: 192
     HoldTime: 150
     Advertisement interval: 60
     Next advertisement scheduled at: 00:00:48
Group/MaskLen
Multicast group to which the C-RP is designated.
C-RP address
IP address of the C-RP. If the C-RP resides on the device where the command is executed, this field displays (local) after the address.
Priority
Priority of the C-RP.
HoldTime
Lifetime of the C-RP.
Uptime
Length of time the C-RP has been up:
·         w—Weeks.
·         d—Days.
·         h—Hours.
Expires
Remaining lifetime for the C-RP and the multicast group.
Candidate RP
IP address of the locally configured C-RP.
Interval between two advertisement messages sent by the locally configured C-RP.
Remaining time for the locally configured C-RP to send the next advertisement message.
Use display pim interface to display PIM information for interfaces.
display pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays PIM information for interfaces on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays PIM information for all interfaces.
verbose: Displays detailed PIM information. If you do not specify this keyword, the command displays brief PIM information.
# Display brief PIM information for all interfaces on the public network.
<Sysname> display pim interface
 Interface         NbrCnt  HelloInt  DR-Pri     DR-Address
 GE3/1/1           1       30        1          10.1.1.2
 GE3/1/2           0       30        1          172.168.0.2    (local)
 GE3/1/3           1       30        1          20.1.1.2
Table 5 Command output
NbrCnt
Number of PIM neighbors.
HelloInt
Interval for sending hello messages.
DR-Pri
Priority for DR election.
DR-Address
IP address of the DR. If the DR resides on the device where the command is executed, this field displays (local) after the address.
# Display detailed PIM information for GigabitEthernet 3/1/1 on the public network.
<Sysname> display pim interface gigabitethernet 3/1/1 verbose
 Interface: GigabitEthernet3/1/1, 10.1.1.1
     PIM version: 2
     PIM mode: Sparse
     PIM DR: 10.1.1.2
     PIM DR Priority (configured): 1
     PIM neighbors count: 1
     PIM hello interval: 30 s
     PIM LAN delay (negotiated): 500 ms
     PIM LAN delay (configured): 500 ms
     PIM override interval (negotiated): 2500 ms
     PIM override interval (configured): 2500 ms
     PIM neighbor tracking (negotiated): disabled
     PIM neighbor tracking (configured): disabled
     PIM generation ID: 0xF5712241
     PIM require generation ID: disabled
     PIM hello hold interval: 105 s
     PIM assert hold interval: 180 s
     PIM triggered hello delay: 5 s
     PIM J/P interval: 60 s
     PIM J/P hold interval: 210 s
     PIM BSR domain border: disabled
     PIM BFD: disabled
     PIM passive: disabled
     Number of routers on network not using DR priority: 0
     Number of routers on network not using LAN delay: 0
     Number of routers on network not using neighbor tracking: 2
Table 6 Command output
PIM version
Version of the PIM protocol.
PIM mode
PIM mode: dense or sparse.
PIM DR
Configured priority for DR election.
PIM neighbors count
Total number of PIM neighbors.
PIM hello interval
Interval between two hello messages.
Negotiated PIM message propagation delay.
Configured PIM message propagation delay.
Negotiated interval for overriding prune messages.
Configured interval for overriding prune messages.
Negotiated neighbor tracking status: enabled or disabled.
Configured neighbor tracking status: enabled or disabled.
Whether the feature of discarding hello messages without Generation_ID is enabled.
PIM neighbor lifetime.
Assert holdtime timer.
Maximum delay for sending hello messages.
PIM J/P interval
Interval between two join/prune messages.
Joined/pruned state holdtime timer.
Whether a PIM domain border is configured.
PIM BFD
Whether PIM is enabled to work with BFD.
PIM passive
Whether PIM passive mode is enabled on the interface.
Number of routers that do not use the DR priority field on the subnet where the interface resides.
Number of routers that do not use the LAN delay field on the subnet where the interface resides.
Number of routers that are not enabled with neighbor tracking on the subnet where the interface resides.
Use display pim neighbor to display PIM neighbor information.
display pim [ vpn-instance vpn-instance-name ] neighbor [ neighbor-address | interface interface-type interface-number | verbose ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays PIM neighbor information on the public network.
neighbor-address: Specifies a PIM neighbor by its IP address. If you do not specify a PIM neighbor, this command displays information about all PIM neighbors.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays PIM neighbor information on all interfaces.
verbose: Displays detailed PIM neighbor information. If you do not specify this keyword, the command displays brief PIM neighbor information.
# Display brief information about all PIM neighbors on the public network.
<Sysname> display pim neighbor
 Total Number of Neighbors = 2
 Neighbor        Interface           Uptime   Expires  DR-Priority Mode
 20.1.1.2        GE3/1/2             02:49:39 00:01:42 1           P
# Display detailed information about the PIM neighbor with IP address 11.110.0.20 on the public network.
<Sysname> display pim neighbor 11.110.0.20 verbose
 Neighbor: 11.110.0.20
     Interface: GigabitEthernet3/1/3
     Uptime: 00:00:10
     Expiry time: 00:00:30
     DR Priority: 1
     Generation ID: 0x2ACEFE15
     Holdtime: 105 s
     LAN delay: 500 ms
     Override interval: 2500 ms
     State refresh interval: 60 s
     Neighbor tracking: Disabled
     RPF proxy vector: Enabled
Table 7 Command output
Neighbor
IP address of the PIM neighbor.
Interface that connects to the PIM neighbor.
Uptime
Length of time the PIM neighbor has been up.
Expires/Expiry time
Remaining lifetime for the PIM neighbor. If the PIM neighbor is always up and reachable, this field displays never.
DR-Priority/DR Priority
Priority of the PIM neighbor.
Mode
PIM mode. , which indicates that the :
This field display P if the RPF proxy vector is enabled.
This field is empty if the RPF vector is disabled.
Generation ID
Generation ID of the PIM neighbor. (A random value represents a status change of the PIM neighbor.)
Holdtime
Lifetime of the PIM neighbor. If the PIM neighbor is always up and reachable, this field displays forever.
LAN delay
PIM message propagation delay on a shared-media LAN.
Override interval
Interval for overriding prune messages.
Interval for refreshing state. This field is displayed only when the PIM neighbor operates in the PIM-DM mode and the state refresh capability is enabled.
Neighbor tracking
Neighbor tracking status: enabled or disabled.
RPF proxy vector
Whether the RPF vector feature is enabled.
For more information about the RPF proxy vector feature, see multicast VPN in IP Multicast Configuration Guide.
Use display pim routing-table to display PIM routing entries.
display pim [ vpn-instance vpn-instance-name ] routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number | proxy ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays PIM routing entries on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.0.0 to 239.255.255.255. If you do not specify a multicast group, this command displays PIM routing entries for all multicast groups.
mask-length: Specifies an address mask length in the range of 0 to 32. The default value is 32.
mask: Specifies an address mask. The default value is 255.255.255.255.
flags flag-value: Specifies a flag. If you do not specify a flag, this command displays PIM routing entries that contain all flags. The following lists the values for the flag-value argument and their meanings:
·          2msdp: Specifies PIM routing entries to be contained in the next SA message to notify an MSDP peer.
·          2mvpn: Specifies PIM routing entries that are to be advertised to MVPN.
·          act: Specifies PIM routing entries that have been used for routing data.
·          del: Specifies PIM routing entries to be deleted.
·          exprune: Specifies PIM routing entries containing outgoing interfaces pruned by other multicast routing protocols.
·          ext: Specifies PIM routing entries containing outgoing interfaces provided by other multicast routing protocols.
·          loc: Specifies PIM routing entries on the devices that reside on the same subnet as the multicast source.
·          msdp: Specifies PIM routing entries learned from MSDP SA messages.
·          niif: Specifies PIM routing entries containing unknown incoming interfaces.
·          nonbr: Specifies PIM routing entries with PIM neighbor lookup failure.
·          rc: Specifies PIM routing entries that have received C-Multicast route information.
·          rpt: Specifies PIM routing entries on the RPT branches where (S, G) prunes have been sent to the RP.
·          rq: Specifies PIM routing entries of the receiving side of the data-MDT switchover.
·          sc: Specifies PIM routing entries that are to advertise C-multicast A-D route information to MVPN.
·          spt: Specifies PIM routing entries on the SPT.
·          sq: Specifies PIM routing entries of the originator side of data-MDT switchover.
·          src-act: Specifies PIM routing entries that have received Source Active A-D route information.
·          swt: Specifies PIM routing entries in the process of RPT-to-SPT switchover.
·          vxlan: Specifies VXLAN overlay entries maintained by PIM.
·          wc: Specifies PIM routing entries with wildcards.
fsm: Displays detailed information about the finite state machine.
incoming-interface interface-type interface-number: Specifies an incoming interface. If you do not specify an incoming interface, this command displays PIM routing entries that contain all incoming interfaces.
mode mode-type: Specifies a PIM mode. If you do not specify a PIM mode, this command displays PIM routing entries in all PIM modes. The available PIM modes include:
·          dm: Specifies PIM-DM.
·          sm: Specifies PIM-SM.
·          ssm: Specifies PIM-SSM.
outgoing-interface { exclude | include | match } interface-type interface-number: Specifies an outgoing interface. If you do not specify an outgoing interface, this command displays PIM routing entries that contain all outgoing interfaces. Whether an outgoing interface is contained in the PIM routing table depends on the following conditions:
·          If you specify an excluded interface, this command displays PIM routing entries that do not contain the specified outgoing interface.
·          If you specify an included interface, this command displays PIM routing entries that contain the specified outgoing interface.
·          If you specify a matching interface, this command displays PIM routing entries that contain only the specified outgoing interface.
proxy: Displays information about the RPF vector used by PIM routing entries.
# Display PIM routing entries on the public network.
<Sysname> display pim routing-table
 Total 0 (*, G) entries; 1 (S, G) entries
 (172.168.0.12, 227.0.0.1)
     RP: 2.2.2.2
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: GigabitEthernet3/1/1
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: GigabitEthernet3/1/2
             Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
Table 8 Command output
Total number of (*, G) entries, and the total number of (S, G) entries.
(S, G) entry.
Protocol
PIM mode.
Flag
Flag of the (S, G) entry or (*, G) entry:
·         2MSDP—The entry is to be advertised by the MSDP module in the next (S, A) message.
·         2MVPN—The entry is to be advertised to MVPN.
·         ACT—The entry has been used for routing data.
·         DEL—The entry is to be removed.
·         EXPRUNE—Some outgoing interfaces are pruned by other multicast routing protocols.
·         EXT—The entry contains outgoing interfaces provided by other multicast routing protocols.
·         LOC—The entry is on a router directly connected to the same subnet with the multicast source.
·         MSDP—The entry is learned from an MSDP (S, A) message.
·         NIIF—The entry contains unknown incoming interfaces.
·         NONBR—The entry has a PIM neighbor lookup failure.
·         RC—The entry has received C-Multicast route information.
·         RPT—The entry is on an RPT branch where (S, G) prunes have been sent to the RP.
·         SC—The entry is to advertise C-multicast A-D route information to MVPN.
·         SPT—The entry is on the SPT.
·         SQ—The entry triggers the default-MDT to data-MDT switchover.
·         SRC-ACT—The entry has received Source Active A-D route information.
·         SWT—The entry is in the process of RPT-to-SPT switchover.
·         VXLAN—The entry is a VXLAN overlay entry.
·         WC—The entry contains a wildcard.
Uptime
Length of time for which the (S, G) entry or (*, G) entry has been up.
Upstream interface
Upstream (incoming) interface of the (S, G) entry or (*, G) entry.
Upstream neighbor
Upstream neighbor of the (S, G) entry or (*, G) entry.
RPF prime neighbor
RPF neighbor of the (S, G) or (*, G) entry:
·         For a (*, G) entry, if the RPF neighbor is the RP, the field displays NULL.
·         For an (S, G) entry, if the RPF neighbor is a router that directly connects to the multicast source, this field displays NULL.
RPF proxy vector
RPF vector.
This field is displayed only on MD VPN inter-AS option B network. For more information about MD VPN inter-AS option B, see multicast VPN in IP Multicast Configuration Guide.
Information about the downstream interfaces:
·         Total number of downstream interfaces.
·         Names of the downstream interfaces.
·         Protocol type on the downstream interfaces.
·         Uptime of the downstream interfaces.
·         Expiration time of the downstream interfaces.
# Display information about the RPF vector used by the public network PIM routing entries on a PE device.
<Sysname> display pim routing-table proxy
 (100.0.0.8, 232.1.1.1)
    Proxy: 10:1/192.168.0.4
    Assigner: 0.0.0.0         Origin: BGP MDT
    Uptime: 02:08:18          Expires: Off
# Display information about the RPF vector used by the public network PIM routing entries on a P device.
    Assigner: 1.0.3.1         Origin: PIM
    Uptime: 02:19:33          Expires: 00:02:12
# Display information about the RPF vector used by the public network PIM routing entries on an ASBR.
(100.0.0.1, 232.1.1.1)
    Proxy: 10:1/local
    Assigner: 1.0.5.9         Origin: PIM
    Uptime: 02:22:04          Expires: 00:02:35
    Proxy: 10:1/local
    Assigner: 1.0.4.1         Origin: PIM
    Uptime: 02:21:10          Expires: 00:02:35
Table 9 Command output
Proxy
RPF vector, including the RD and the IP address of the RPF vector. If the RPF vector resides on the device where the command is executed, this field displays (local) after the IP address.
Assigner
IP address of the device from which the RPF vector is obtained:
·         On PE devices, the RPF vector is obtained from a BGP MDT routing entry. This field displays 0.0.0.0.
·         On non-PE devices, the RPF vector is obtained from the PIM join message sent by a downstream PIM neighbor. This field displays the IP address of the downstream PIM neighbor.
Origin
Protocol that origins the RPF vector:
·         On PE devices, the RPF vector is obtained from a BGP MDT routing entry. This field displays BGP MDT.
·         On non-PE devices, the RPF vector is obtained from the PIM join message sent by a downstream PIM neighbor. This field displays PIM.
Uptime
Length of time since the RPF vector is originated.
Expires
Remaining timeout time for the RPF vector, where Off means that the timer is disabled.
display pim rp-info
Use display pim rp-info to display PIM RP information.
display pim [ vpn-instance vpn-instance-name ] rp-info [ group-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays RP information on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays RP information for all multicast groups.
# Display RP information for multicast group 224.0.1.1 on the public network.
<Sysname> display pim rp-info 224.0.1.1
 BSR RP address is: 2.2.2.2
     Priority: 192
     HoldTime: 180
     Uptime: 03:01:10
     Expires: 00:02:30
 Static RP address is: 3.3.3.5
     Preferred: Yes
     Configured ACL: 2003
 RP mapping for this group is: 3.3.3.5
 Anycast-RP 3.3.3.5 members:
     Member address           State
     1.1.0.1                  Active
     1.2.0.2                  Local
     1.2.0.1                  Remote
# Display RP information for all multicast groups on the public network.
 BSR RP information:
   Scope: non-scoped
       1.1.1.1 (local)          192       180       03:01:36  00:02:29
       2.2.2.2                  192       180       1d:13h    00:02:02
 Static RP information:
       RP address               ACL   Mode    Preferred
       3.3.3.1                  2000  pim-sm  No
       3.3.3.3                  2002  pim-sm  No
       3.3.3.4                        pim-sm  No
       3.3.3.5                  2002  pim-sm  Yes
 Anycast-RP information:
       RP address               Member address           State
       3.3.3.5                  1.1.0.1                  Active
       3.3.3.5                  1.1.0.2                  Local
       3.3.3.5                  1.2.0.1                  Remote
Table 10 Command output
BSR RP address is
IP address of the RP.
BSR RP information
Information about the RP.
Group/MaskLen
Multicast group to which the RP is designated.
RP address
IP address of the RP. If the RP resides on the device where the command is executed, this field displays (local) after the address.
Priority
Priority of the RP.
HoldTime
RP lifetime.
Uptime
Length of time the RP has been up.
Expires
Remaining lifetime for the RP.
Preferred
Whether the static RP is preferred.
Configured ACL/ACL
ACL defining the multicast groups to which the static RP is designated.
Mode
RP service mode, PIM-SM.
IP address of the RP that provides services for the multicast group.
Members of Anycast RP 3.3.3.5.
Member address
IP address of the Anycast RP member.
State of the interface from which the member address originates:
·         Active—Activated local interface.
·         Local—Inactivated local interface.
·         Remote—Remote interface.
Use display pim statistics to display statistics for PIM packets.
# Display statistics for PIM packets.
<Sysname> display pim statistics
 Received PIM packets: 3295
 Sent PIM packets    : 5975
                Valid       Invalid        Succeeded   Failed
     Hello    : 3128        0              4333        0
     Reg      : 14          0              0           0
     Reg-stop : 0           0              0           0
     JP       : 151         0              561         0
     BSM      : 0           0              1081        0
     Assert   : 0           0              0           0
     Graft    : 0           0              0           0
     Graft-ACK: 0           0              0           0
     C-RP     : 0           0              0           0
     SRM      : 0           0              0           0
     DF       : 0           0              0           0
     AutoRP   : 0           0              0           0
Table 11 Command output
Total number of received PIM protocol packets.
Sent PIM packets
Total number of sent PIM protocol packets.
Valid
Number of received legal PIM protocol packets.
Invalid
Number of received illegal PIM protocol packets.
Succeeded
Number of PIM protocol packets that were sent successfully.
Failed
Number of PIM protocol packets that failed to be sent.
Hello
Hello message statistics.
Reg
Register message statistics.
Reg-stop
Register-stop message statistics.
JP
Join/prune message statistics.
BSM
Bootstrap message statistics.
Assert
Assert message statistics.
Graft
Graft message statistics.
Graft-ACK
Graft-ACK message statistics.
C-RP
C-RP message statistics.
SRM
State refresh message statistics.
DF
Designated forwarder statistics.
AutoRP
Auto-RP message statistics.
dscp
Use dscp to set a DSCP value for outgoing PIM messages.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value for outgoing PIM messages is 48.
PIM view
dscp-value: Specifies the DSCP value for outgoing PIM messages, in the range of 0 to 63. The greater the value, the higher the DSCP priority.
# Set the DSCP value for outgoing PIM messages to 63.
[Sysname] pim
[Sysname-pim] dscp 63
Use hello-option dr-priority to set the DR priority globally.
Use undo hello-option dr-priority to restore the default.
The DR priority is 1.
PIM view
priority: Specifies a DR priority in the range of 0 to 4294967295. The greater the value, the higher the priority.
You can set the DR priority globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global DR priority to 3 on the public network.
[Sysname] pim
[Sysname-pim] hello-option dr-priority 3
Use hello-option holdtime to set the PIM neighbor lifetime globally.
Use undo hello-option holdtime to restore the default.
hello-option holdtime time
The PIM neighbor lifetime is 105 seconds.
PIM view
time: Specifies a PIM neighbor lifetime in the range of 1 to 65535 seconds. If you set the value to 65535 seconds, PIM neighbors are always reachable.
You can set the PIM neighbor lifetime globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global PIM neighbor lifetime to 120 seconds on the public network.
[Sysname] pim
[Sysname-pim] hello-option holdtime 120
Use hello-option lan-delay to set the PIM message propagation delay on a shared-media LAN globally.
Use undo hello-option lan-delay to restore the default.
hello-option lan-delay delay
The PIM message propagation delay on a shared-media LAN is 500 milliseconds.
PIM view
delay: Specifies a PIM message propagation delay on a shared-media LAN, in the range of 1 to 32767 milliseconds.
You can set the PIM message propagation delay globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global PIM message propagation delay on a shared-media LAN to 200 milliseconds on the public network.
[Sysname] pim
[Sysname-pim] hello-option lan-delay 200
Use hello-option neighbor-tracking to enable neighbor tracking globally.
Use undo hello-option neighbor-tracking to disable neighbor tracking globally.
Neighbor tracking is disabled.
PIM view
You can enable neighbor tracking globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Enable neighbor tracking globally on the public network.
[Sysname] pim
[Sysname-pim] hello-option neighbor-tracking
Use hello-option override-interval to set the override interval globally.
Use undo hello-option override-interval to restore the default.
The override interval is 2500 milliseconds.
PIM view
interval: Specifies an override interval in the range of 1 to 65535 milliseconds.
You can set the override interval globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global override interval to 2000 milliseconds on the public network.
[Sysname] pim
[Sysname-pim] hello-option override-interval 2000
Use holdtime join-prune to set the joined/pruned state holdtime globally.
Use undo holdtime join-prune to restore the default.
holdtime join-prune time
The joined/pruned state holdtime is 210 seconds.
PIM view
time: Specifies a joined/pruned state holdtime in the range of 1 to 65535 seconds.
You can set the joined/pruned state holdtime globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
To prevent the upstream neighbors from aging out, you must set the join/prune interval to be less than the joined/pruned state holdtime.
# Set the global joined/pruned state holdtime to 280 seconds on the public network.
[Sysname] pim
[Sysname-pim] holdtime join-prune 280
Use jp-pkt-size to set the maximum size of a join or prune message.
Use undo jp-pkt-size to restore the default.
jp-pkt-size size
undo jp-pkt-size
The maximum size of a join or prune message is 1200 bytes.
PIM view
size: Specifies the maximum size of a join or prune message, in the range of 100 to 8100 bytes.
# Set the maximum size of a join or prune message to 1500 bytes on the public network.
[Sysname] pim
[Sysname-pim] jp-pkt-size 1500
pim
Use pim to enter PIM view.
Use undo pim to remove all configurations in PIM view.
undo pim [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, you enter public network PIM view.
# Enable IP multicast routing on the public network and enter PIM view of the public network.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname] pim
[Sysname-pim]
# Enable IP multicast routing for VPN instance mvpn and enter PIM view of VPN instance mvpn.
[Sysname-mrib-mvpn] quit
[Sysname] pim vpn-instance mvpn
[Sysname-pim-mvpn]
multicast routing-enable
pim bfd enable
Use pim bfd enable to enable BFD for PIM.
Use undo pim bfd enable to disable BFD for PIM.
pim bfd enable
undo pim bfd enable
BFD is disabled for PIM.
Interface view
This command takes effect only when PIM-DM or PIM-SM is enabled on the interface.
# Enable IP multicast routing on the public network. Then, enable PIM-DM on GigabitEthernet 3/1/1, and enable BFD for PIM on the interface.
[Sysname-mrib] quit
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] pim dm
[Sysname-GigabitEthernet3/1/1] pim bfd enable
pim dm
pim sm
pim bsr-boundary
Use pim bsr-boundary to configure a PIM-SM domain border (a bootstrap message boundary).
Use undo pim bsr-boundary to restore the default.
pim bsr-boundary
An interface is not a PIM-SM domain border.
Interface view
# Configure GigabitEthernet 3/1/1 as a PIM-SM domain border.
[Sysname-GigabitEthernet3/1/1] pim bsr-boundary
c-bsr (PIM view)
multicast boundary
pim dm
Use pim dm to enable PIM-DM.
Use undo pim dm to disable PIM-DM.
pim dm
undo pim dm
PIM-DM is disabled.
Interface view
This command takes effect only when IP multicast routing is enabled on the public network or for the VPN instance to which the interface belongs.
# Enable IP multicast routing on the public network, and enable PIM-DM on GigabitEthernet 3/1/1.
[Sysname-mrib] quit
multicast routing
Use pim hello-option dr-priority to set the DR priority on an interface.
Use undo pim hello-option dr-priority to restore the default.
pim hello-option dr-priority priority
Interface view
You can set the DR priority for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the DR priority to 3 on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] pim hello-option dr-priority 3
Use pim hello-option holdtime to set the PIM neighbor lifetime on an interface.
Use undo pim hello-option holdtime to restore the default.
pim hello-option holdtime time
Interface view
time: Specifies a PIM neighbor lifetime in the range of 1 to 65535 seconds. If you set the value to 65535 seconds, the PIM neighbor is always reachable.
You can set the PIM neighbor lifetime for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the PIM neighbor lifetime to 120 seconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] pim hello-option holdtime 120
Use pim hello-option lan-delay to set the PIM message propagation delay on a shared-media LAN for an interface.
Use undo pim hello-option lan-delay to restore the default.
pim hello-option lan-delay delay
Interface view
delay: Specifies a PIM message propagation delay on a shared-media LAN in the range of 1 to 32767 milliseconds.
You can set the PIM message propagation delay for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the PIM message propagation delay on a shared-media LAN to 200 milliseconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] pim hello-option lan-delay 200
Use pim hello-option neighbor-tracking to enable neighbor tracking on an interface.
Use pim hello-option neighbor-tracking disable to disable neighbor tracking on an interface when neighbor tracking is enabled globally.
Use undo pim hello-option neighbor-tracking to restore neighbor tracking setting on an interface to be consistent with the global setting.
Neighbor tracking is disabled on an interface.
Interface view
You can enable neighbor tracking for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Enable neighbor tracking on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] pim hello-option neighbor-tracking
# Disable neighbor tracking on GigabitEthernet 3/1/1 when neighbor tracking is enabled globally on the public network.
[Sysname] pim
[Sysname-pim] quit
[Sysname-GigabitEthernet3/1/1] pim hello-option neighbor-tracking disable
Use pim hello-option override-interval to set the override interval on an interface.
Use undo pim hello-option override-interval to restore the default.
pim hello-option override-interval interval
Interface view
You can set the override interval for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the override interval to 2000 milliseconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] pim hello-option override-interval 2000
Use pim holdtime join-prune to set the joined/pruned state holdtime on an interface.
Use undo pim holdtime join-prune to restore the default.
pim holdtime join-prune time
Interface view
You can set the joined/pruned state holdtime for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
To prevent the upstream neighbors from aging out, you must configure the join/prune interval to be less than the joined/pruned state holdtime.
# Set the joined/pruned state holdtime to 280 seconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] pim holdtime join-prune 280
pim join-policy
Use pim join-policy to configure a PIM join policy to filter joined multicast sources and groups in PIM join/prune messages on an interface.
Use undo pim join-policy to restore the default.
pim join-policy { ipv4-acl-number | [ asm ipv4-acl-number | ssm ipv4-acl-number ] * }
No PIM join policy is configured and joined multicast sources and groups in PIM join/prune messages are not filtered.
Interface view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL by its number. The value range is 2000 to 2999 for an IPv4 basic ACL and 3000 to 3999 for an IPv4 advanced ACL. If the ACL does not exist or does not have valid rules, all joined multicast sources and groups in PIM join/prune messages are filtered out.
asm ipv4-acl-number: Specifies an ACL for filtering joined multicast groups in the ASM range. The value range for the ipv4-acl-number argument is 2000 to 2999 for an IPv4 basic ACL and 3000 to 3999 for an IPv4 advanced ACL. If you do not specify an ACL, or the specified ACL does not exist or does not have valid rules, all multicast groups in the ASM range are filtered out.
ssm ipv4-acl-number: Specifies an ACL for filtering joined multicast groups in the SSM range. The value range for the ipv4-acl-number argument is 2000 to 2999 for an IPv4 basic ACL and 3000 to 3999 for an IPv4 advanced ACL. If you do not specify an ACL, or the specified ACL does not exist or does not have valid rules, all multicast groups in the SSM range are filtered out.
This command does not take effect on PIM-DM.
The PIM join policy filters joined multicast sources and groups in PIM join/prune messages to protect the device against invalid PIM join/prune message attacks. The policy identifies valid joined multicast source and groups in PIM join/prune messages and filters out invalid joined multicast source and groups. The device creates (*, G) or (S, G) entries only for valid joined multicast sources and groups.
·          The source source-address source-wildcard option specifies the multicast group address range in the PIM join/prune messages.
·          The source source-address source-wildcard option specifies a multicast source address range. To match join information of (*, G) entries, set the source IP address to 0.0.0.0.
·          The destination dest-address dest-wildcard option specifies a multicast group range.
# On GigabitEthernet 3/1/1, configure a PIM join policy to permit join information only for multicast group addresses in the range of 225.1.1.1/16.
[Sysname] acl basic 2005
[Sysname-acl-ipv4-basic-2005] rule permit source 225.1.1.1 0.0.255.255
[Sysname-acl-ipv4-basic-2005] quit
[Sysname-GigabitEthernet3/1/1] pim join-policy 2005
pim neighbor-policy
Use pim neighbor-policy to configure a PIM hello policy.
Use undo pim neighbor-policy to restore the default.
pim neighbor-policy ipv4-acl-number
No PIM hello policy exists on an interface, and all PIM hello messages are regarded as legal.
Interface view
ipv4-acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999.
A PIM hello policy filters PIM hello messages to guard against hello message spoofing.
·          The source source-address source-wildcard option specifies a source IP address.
# Configure a PIM hello policy on GigabitEthernet 3/1/1 so that only the devices on subnet 10.1.1.0/24 can become PIM neighbors of this router.
[Sysname-GigabitEthernet3/1/1] pim neighbor-policy 2000
Use pim non-stop-routing to enable PIM NSR.
Use undo pim non-stop-routing to disable PIM NSR.
PIM NSR is disabled.
# Enable PIM NSR.
[Sysname] pim non-stop-routing
pim passive
Use pim passive to enable PIM passive mode on an interface.
Use undo pim passive to disable PIM passive mode on an interface.
pim passive
undo pim passive
PIM passive mode is disabled on an interface.
Interface view
# Enable IP multicast routing on the public network. Then, enable PIM-DM and enable PIM passive mode on GigabitEthernet 3/1/1.
[Sysname-mrib] quit
[Sysname-GigabitEthernet3/1/1] pim passive
pim require-genid
Use pim require-genid to enable dropping hello messages without the generation ID options.
Use undo pim require-genid to restore the default.
pim require-genid
Hello messages without the generation ID options are accepted.
Interface view
# Enable GigabitEthernet 3/1/1 to drop hello messages without the generation ID options.
[Sysname-GigabitEthernet3/1/1] pim require-genid
pim sm
Use pim sm to enable PIM-SM.
Use undo pim sm to disable PIM-SM.
pim sm
undo pim sm
PIM-SM is disabled.
Interface view
# Enable IP multicast routing on the public network, and enable PIM-SM on GigabitEthernet 3/1/1.
[Sysname-mrib] quit
[Sysname-GigabitEthernet3/1/1] pim sm
multicast routing
Use pim state-refresh-capable to enable the state refresh feature on an interface.
Use undo pim state-refresh-capable to disable the state refresh feature.
The state refresh feature is enabled.
Interface view
# Disable the state refresh feature on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] undo pim state-refresh-capable
Use pim timer graft-retry to set a graft retry timer.
Use undo pim timer graft-retry to restore the default.
pim timer graft-retry interval
The graft retry timer is 3 seconds.
Interface view
interval: Specifies a graft retry timer in the range of 1 to 65535 seconds.
# Set the graft retry timer to 80 seconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] pim timer graft-retry 80
pim timer hello
Use pim timer hello to set the hello interval on an interface.
Use undo pim timer hello to restore the default.
pim timer hello interval
The hello interval is 30 seconds.
Interface view
interval: Specifies a hello interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the interface does not send hello messages.
You can set the hello interval for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the hello interval to 40 seconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] pim timer hello 40
Use pim timer join-prune to set the join/prune interval on an interface.
Use undo pim timer join-prune to restore the default.
pim timer join-prune interval
The join/prune interval is 60 seconds.
Interface view
interval: Specifies a join/prune interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the interface does not send join or prune messages.
You can set the join/prune interval for an interface in interface view or globally for all interfaces in PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
The configuration takes effect after the current interval ends.
# Set the join/prune interval to 80 seconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] pim timer join-prune 80
Use pim triggered-hello-delay to set the triggered hello delay (maximum delay for sending a hello message).
Use undo pim triggered-hello-delay to restore the default.
pim triggered-hello-delay delay
The triggered hello delay is 5 seconds.
Interface view
delay: Specifies a triggered hello delay in the range of 1 to 60 seconds.
# Set the triggered hello delay to 3 seconds on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] pim triggered-hello-delay 3
Use register-policy to configure a PIM register policy.
Use undo register-policy to restore the default.
register-policy ipv4-acl-number
No PIM register policy exists, and all PIM register messages are regarded as legal.
PIM view
A PIM register policy enables an RP to filter PIM register messages so that the RP is designated only to multicast groups permitted by the ACL.
·          The source source-address source-wildcard option specifies a multicast source address.
# Configure a PIM register policy on the public network. Then, the device accepts only register messages from the sources on the subnet 10.10.0.0/16 to the groups on the subnet 225.1.0.0/16.
[Sysname-acl-ipv4-adv-3000] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] register-policy 3000
Use register-suppression-timeout to set the register suppression time.
Use undo register-suppression-timeout to restore the default.
The register suppression time is 60 seconds.
PIM view
interval: Specifies a register suppression time in the range of 1 to 65535 seconds.
# Set the register suppression time to 70 seconds on the public network.
[Sysname] pim
[Sysname-pim] register-suppression-timeout 70
register-whole-checksum (PIM view)
Use register-whole-checksum to configure the device to calculate the checksum based on an entire register message.
Use undo register-whole-checksum to restore the default.
The device calculates the checksum based on the register message header.
PIM view
# Configure the device to calculate the checksum based on an entire register message on the public network.
[Sysname] pim
[Sysname-pim] register-whole-checksum
snmp-agent trap enable pim
Use snmp-agent trap enable pim to enable SNMP notifications for PIM.
Use undo snmp-agent trap enable pim to disable SNMP notifications for PIM.
snmp-agent trap enable pim [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
undo snmp-agent trap enable pim [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
SNMP notifications for PIM are enabled.
candidate-bsr-win-election: Specifies notifications about winning the BSR election.
elected-bsr-lost-election: Specifies notifications about losing the BSR election.
neighbor-loss: Specifies notifications about losing neighbors.
If you do not specify an optional keyword, this command enables or disables PIM to generate SNMP notifications.
To report critical PIM events to an NMS, enable SNMP notifications for PIM. For PIM event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for PIM.
[Sysname] undo snmp-agent trap enable pim
source-lifetime (PIM view)
Use source-lifetime to set the multicast source lifetime.
Use undo source-lifetime to restore the default.
source-lifetime time
The multicast source lifetime is 210 seconds.
PIM view
time: Specifies a multicast source lifetime in the range of 0 to 31536000 seconds. If you set the value to 0 seconds, multicast sources never age out.
# Set the multicast source lifetime to 200 seconds on the public network.
[Sysname] pim
[Sysname-pim] source-lifetime 200
source-policy (PIM view)
Use source-policy to configure a multicast source policy.
Use undo source-policy to restore the default.
source-policy ipv4-acl-number
undo source-policy
No multicast source policy exists. The device does not filter multicast data packets.
PIM view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL number in the range of 2000 to 3999.
A multicast source policy filters multicast data packets to control information available to downstream receivers.
When you configure a rule in the IPv4 ACL, follow these restrictions and guidelines:
·          In a basic ACL, the source source-address source-wildcard option specifies a source IP address.
·          In an advanced ACL, the source source-address source-wildcard option specifies a source IP address. The destination dest-address dest-wildcard option specifies a multicast group address.
# Configure a multicast source policy on the public network to accept multicast data from source 10.10.1.2 and to deny multicast data from source 10.10.1.1.
[Sysname-acl-ipv4-basic-2000] rule permit source 10.10.1.2 0
[Sysname-acl-ipv4-basic-2000] rule deny source 10.10.1.1 0
[Sysname] pim
[Sysname-pim] source-policy 2000
spt-switch-threshold (PIM view)
Use spt-switch-threshold to configure a criterion for an RPT-to-SPT switchover.
Use undo spt-switch-threshold to remove criteria for RPT-to-SPT switchovers.
spt-switch-threshold { immediacy | infinity } [ group-policy ipv4-acl-number ]
undo spt-switch-threshold [ immediacy | infinity ] [ group-policy ipv4-acl-number ]
The first multicast packet triggers an RPT-to-STP switchover.
PIM view
immediacy: Triggers an RPT-to-STP switchover immediately.
infinity: Disables RPT-to-STP switchover.
group-policy ipv4-acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. If you specify an ACL, the configuration applies to the multicast groups that the ACL permits. The configuration applies to all multicast groups when one of the following conditions exists:
CAUTION
CAUTION:
If the device is an RP, disabling RPT-to-STP switchover might cause multicast traffic forwarding failures on the source-side DR. When disabling RPT-to-SPT switchover, make sure you fully understand its impact on your network.
When you configure a rule in the IPv4 basic ACL, follow these restrictions and guidelines:
·          For the rule to take effect, do not specify the vpn-instance vpn-instance option.
·          The source source-address source-wildcard option specifies a multicast group address.
·          Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
You can configure multiple RPT-to-STP switchover criteria by executing this command multiple times. However, if you specify the same ACL in the command, the most recent configuration takes effect. If multiple RPT-to-STP switchover criteria are configured for the same multicast group, the first configuration takes effect.
# Disable RPT-to-STP switchover on a receiver-side DR on the public network.
[Sysname] pim
[Sysname-pim] spt-switch-threshold infinity
ssm-policy (PIM view)
Use ssm-policy to configure the SSM group range.
Use undo ssm-policy to restore the default.
ssm-policy ipv4-acl-number
undo ssm-policy
The SSM group range is 232.0.0.0/8.
PIM view
This command defines a multicast group range that is used by PIM-SSM. For multicast packets that are permitted by the ACL, the PIM-SSM mode is used. For multicast packets that are not permitted by the ACL, the PIM-SM mode is used.
# Configure the SSM group range as 232.1.0.0/16.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 232.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] ssm-policy 2000
state-refresh-interval (PIM view)
Use state-refresh-interval to set the state refresh interval.
Use undo state-refresh-interval to restore the default.
The state refresh interval is 60 seconds.
PIM view
interval: Specifies a state refresh interval in the range of 1 to 255 seconds.
# Set the state refresh interval to 70 seconds on the public network.
[Sysname] pim
[Sysname-pim] state-refresh-interval 70
state-refresh-rate-limit (PIM view)
state-refresh-ttl (PIM view)
Use state-refresh-rate-limit to set the waiting time to accept a new state refresh message.
Use undo state-refresh-rate-limit to restore the default.
state-refresh-rate-limit time
The device waits 30 seconds before it accepts a new state refresh message.
PIM view
time: Specifies the waiting time to accept a new refresh message, in the range of 1 to 65535 seconds.
# Set the waiting time to 45 seconds to accept a new state refresh message on the public network.
[Sysname] pim
[Sysname-pim] state-refresh-rate-limit 45
Use state-refresh-ttl to set the TTL value for state refresh messages.
Use undo state-refresh-ttl to restore the default.
state-refresh-ttl ttl-value
The TTL value for state refresh messages is 255.
PIM view
ttl-value: Specifies the TTL value for state refresh messages, in the range of 1 to 255.
# Set the TTL value to 45 for state refresh messages on the public network.
[Sysname] pim
[Sysname-pim] state-refresh-ttl 45
pim state-refresh-capable (PIM view)
static-rp (PIM view)
Use static-rp to configure a static RP.
Use undo static-rp to delete a static RP.
static-rp rp-address [ ipv4-acl-number | preferred ] *
undo static-rp rp-address
No static RPs exist.
PIM view
rp-address: Specifies the IP address of the static RP. The IP address must be valid and cannot be on the subnet 127.0.0.0/8. For a static PIM-SM RP, you must specify a used IP address.
ipv4-acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. If you specify an ACL, the static RP is designated only to multicast groups that the ACL permits. The static RP is designated to all multicast groups when one of the following conditions exists:
·          You do not specify an ACL.
·          The specified ACL does not exist.
·          The specified ACL does not have valid rules.
preferred: Gives priority to the static RP if a dynamic RP also exists on the network. The dynamic RP takes effect only when the static RP fails. If you do not specify this keyword, the dynamic RP has priority, and the static RP takes effect only when the dynamic RP fails.
You do not need to enable PIM on an interface that acts as a static RP.
When rules in the ACL used by a static RP change, new RPs are dynamically elected for all multicast groups.
You can configure multiple static RPs by using this command multiple times. However, if you specify the same static RP address or use the same ACL in the command, the most recent configuration takes effect. If you configure multiple static RPs for the same multicast group, the static RP with the highest IP address is used.
# Configure the interface with IP address 11.110.0.6 as a static RP for multicast group range 225.1.1.0/24 and give priority to this static RP on the public network.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname] pim
[Sysname-pim] static-rp 11.110.0.6 2001 preferred
display pim rp-info
timer hello (PIM view)
Use timer hello to set the hello interval globally.
Use undo timer hello to restore the default.
undo timer hello
PIM view
interval: Specifies a hello interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the device does not send hello messages.
You can set the hello interval globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global hello interval to 40 seconds on the public network.
[Sysname] pim
[Sysname-pim] timer hello 40
pim timer hello
timer join-prune (PIM view)
Use timer join-prune to set the join/prune interval globally.
Use undo timer join-prune to restore the default.
PIM view
interval: Specifies a join/prune interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the device does not send join or prune messages.
You can set the join/prune interval globally for all interfaces in PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
To prevent the upstream neighbors from expiring, you must set the join/prune interval to be less than the joined/pruned state holdtime.
# Set the global join/prune interval to 80 seconds on the public network.
[Sysname] pim
[Sysname-pim] timer join-prune 80
holdtime join-prune (PIM view)
