03-Interface Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command References-Release795x-6W10003-Interface Command Reference
05-CPOS interface commands
05-CPOS interface commands 100.46 KB
alarm-detect
Use alarm-detect to configure the action to take when an RDI, SD, or SF alarm occurs on an interface.
Use undo alarm-detect to restore the default.
alarm-detect { rdi | sd | sf } action link-down
undo alarm-detect { rdi | sd | sf }
The device does not take any actions on the interface when an RDI, SD, or SF alarm occurs.
CPOS interface view
rdi: Specifies remote defect indication (RDI) alarms.
sd: Specifies signal degrade (SD) alarms.
sf: Specifies signal fail (SF) alarms.
action: Specifies the action to take when the specified alarm is detected on the interface.
link-down: Places the interface in down state.
An RDI alarm occurs if the device receives multiplexer section remote defect indication (MS-RDI) signals from the remote end.
An SD or SF alarm occurs if the bit error rate of incoming packets crosses the SD or SF alarm threshold. To set the SD or SF alarm threshold, use the threshold command.
# Configure CPOS 2/2/1 to go down when an SD alarm occurs.
[Sysname] controller cpos 2/2/1
[Sysname-Cpos2/2/1] alarm-detect sd action link-down
Threshold
clock
Use clock to set the clock mode for a CPOS interface.
Use undo clock to restore the default.
clock { master | slave }
undo clock
The clock mode of a CPOS interface is slave.
CPOS interface view
master: Sets the clock mode to master.
slave: Sets the clock mode to slave.
When the clock mode of a CPOS interface is master, it uses the internal clock source.
When the clock mode of a CPOS interface is slave, it uses the line clock source.
When connected to a SONET/SDH device, the CPOS interface must use the slave clock mode. The SONET/SDH network clock is more precise.
When two CPOS interfaces are directly connected, you must configure the two ends with different clock modes.
# Set the clock mode to master for CPOS 2/2/1.
[Sysname-Cpos2/2/1] clock master
controller cpos
Use controller cpos to enter CPOS interface view.
controller cpos cpos-number
cpos-number: Specifies a CPOS interface by its number.
# Enter the interface view of CPOS 2/2/1.
[Sysname-Cpos2/2/1]
default
Use default to restore the default settings for a CPOS interface.
default
CPOS interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
# Restore the default settings for CPOS 2/2/1.
[Sysname-Cpos2/2/1] default
description
The interface description uses the interface name Interface format, for example, Cpos2/2/1 Interface.
CPOS interface view
text: Specifies the description, a case-sensitive string of 1 to 255 characters.
# Configure the description of CPOS 2/2/1 as CPOS-interface.
[Sysname-Cpos2/2/1] description CPOS-interface
display controller cpos
Use display controller cpos to display status information for CPOS interfaces.
display controller [ cpos [ cpos-number ] ]
cpos [ cpos-number ]: Specifies a CPOS interface by its number. If you do not specify the cpos keyword, this command displays information about all CPOS interfaces and CE1 interfaces. If you specify the cpos keyword without specifying an interface, this command displays information about all CPOS interfaces.
This command also displays alarms and errors that occurred to the regenerator section, multiplex section, and higher-order path.
The following table lists the possible error types in the command output.
Table 1 Possible output error types
FRED
Receive loss of basic frame alignment, or receive frames with red alarm errors.
COFA
Change of frame alignment.
SEF
Severely error frame. Four consecutive frame synchronization errors generate one SEF.
FERR
Framing Bit Error. It refers to frames with the Ft/Fs/FPS/FAS error.
CERR
CRC error.
FEBE
Far end block error. This error occurs when the E1 channel uses the CRC4 framing format.
BERR
PRBS bit error (pseudo-random binary sequence bit error, for test purposes only).
BIP
Bit-interleaved parity.
REI
Remote error indication.
In this table, FRED, COFA, and SEF are called alarm errors (AERRs).
# Display CPOS 2/2/1 status information.
<Sysname> display controller cpos 2/2/1
Cpos2/2/1
Current state: DOWN
Description: Cpos2/2/1 Interface
Current system time:2013-02-20 12:56:36
Last time when physical state changed to up:-
Last time when physical state changed to down:2013-02-19 12:06:46
Port connector type: No connector
Physical layer is packet over SDH
Port speed type: STM-1
Multiplex mode: AU-4
Loopback is not set
Clock source: Slave
Clock grade: Quality unknown(existing synchronization network)
BER thresholds:
    SD: 10e-6    SF: 10e-4
Regenerator section layer:
    J0(TX): "CR16000"
            43 52 31 36 30 30 30 00 00 00 00 00 00 00 00 00
    J0(RX): ""
            00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Alarm: LOS
    Error: 0 BIP(B1)
Multiplex section layer:
    Alarm: None
    Error: 0 BIP(B2), 0 REI(M1)
Higher order path layer:
    C2(TX): 0x2    C2(RX): 0xff
    S1S0(TX): 0x2    S1S0(RX): -
    J1(TX): "CR16000"
    J1(RX): ""
    Alarm: AIS TIM RDI SLM
    Error: 0 BIP(B3), 0 REI(G1)
           0 PJE, 0 NJE
Cpos2/2/1 CE1 1 (C12 1-1-1-1) is DOWN
  Frame-format NO-CRC4, clock slave, loopback not set
(some CE1 channel information omitted)
Port statistic:start time: 2013-02-19 12:06:46
UP time: 0 H 0 M 0 S
Section: ES        0   SES        0   SEFS        0
Line   : ES        0   SES        0   UAS         0   FE-ES        0
Path1  : ES        0   SES        0   UAS         0   FE-ES        0
Current state
Physical link state of the interface:
·         Administratively DOWN—The interface has been shut down by using the shutdown command.
·         DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·         UP—The interface is both administratively and physically up.
Description of the interface.
The most recent time that the reset counters interface pos command was executed. This field displays Never if the command has not been executed on the interface since device startup.
Current system time
Current system time in the YYYY-MM-DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY-MM-DD HH:MM:SS UTC±HH:MM:SS format.
Last time when physical state of the interface changed to up.
A hyphen (-) indicates that the physical state of the interface has not changed to up.
Last time when physical state of the interface changed to down.
A hyphen (-) indicates that the physical state of the interface has not changed to down.
Port connector type
Type of the transceiver module on the interface.
Physical layer
Physical interface.
Port speed type
Interface transmission rate.
Multiplex mode
Multiplexing path for the AUG of the CPOS interface.
Loopback is not set
Loopback is disabled.
Clock source
Clock mode.
BER thresholds
SD threshold and SF threshold of the CPOS interface.
Alarm and error statistics for the regenerator section.
J0(TX)
Transmitted overhead bytes.
J0(RX)
Received overhead bytes.
Alarm
Alarm statistics.
Error
Error statistics.
Alarm and error statistics for the multiplex section.
Alarm and error statistics for the higher order path. The multiplex path is AU-4. There is only one VC-4 for STM-1.
C2(TX)
Transmitted C2 bytes.
C2(RX)
Received C2 bytes.
J1(TX)
Transmitted J1 trace message value.
J1(RX)
Received J1 trace message value.
S1S0(TX)
Transmitted S1S0 bytes.
S1S0(RX)
Received S1S0 bytes.
The physical state of E1 channel 1 is down.
Physical layer information for the E1 channel:
·         The framing format is no-CRC4.
·         The clock mode is slave.
·         Loopback is disabled.
Starting time for interface statistics.
UP time
Time when the interface was brought up.
Section
Alarm seconds for the regenerator section:
·         Error Seconds (ES)—Minor error alarm seconds.
·         Serious Error Seconds (SES)—Sever error alarm seconds.
·         Serious Error Frame Seconds (SEFS)—Sever frame error alarm seconds.
Line
Alarm seconds for the multiplex section:
·         Unavailable Seconds (UAS)—Unavailable alarm seconds. This field value starts to count after 10 seconds of continuous SES.
·         FE-ES (Far End Errored Seconds)—Alarm seconds for remote errors. This field value starts to count when the peer end sends an REI RDI alarm.
·         ES (Error Seconds)—Alarm seconds for general errors.
·         SES (Serious Error Seconds)—Alarm seconds for serious errors.
Path1
Alarm seconds for higher-order path 1:
display controller cpos e1
Use display controller cpos e1 to display status information for an E1 channel on a CPOS interface.
display controller [ cpos cpos-number e1 e1-number ]
cpos cpos-number: Specifies a CPOS interface by its number.
e1 e1-number: Specifies the number of an E1 channel on the CPOS interface, in the range of 1 to 63.
If you do not specify the cpos cpos-number e1 e1-number option, this command displays status information for CPOS interfaces. If you specify the cpos cpos-number e1 e1-number option, this command displays errors and alarms that occurred to lower-order paths and E1 frames.
# Display the status information of E1 channel 1 on CPOS 2/2/1.
<Sysname> display controller cpos 2/2/1 e1 1
Cpos2/2/1
Current state: DOWN
Current system time:2017-12-20 13:59:33
Last time when physical state changed to down:2017-12 -20 12:40:39
Loopback is not set
Clock source: Slave
BER thresholds:
    SD: 10e-6    SF: 10e-4
    J0(TX): "CR16000"
    J0(RX): ""
    Alarm: LOS
    Error: 0 BIP(B1)
    Alarm: None
    J1(TX): "CR16000"
    J1(RX): ""
           0 PJE, 0 NJE
Lower order path layer (C12 1-1-1-1):
  C2(TX): 0x02    C2(RX): 0x07
  J2(TX): "CR16000"
  J2(RX): ""
  Alarm: AIS RDI TIM
  Error: 0 BIP
  Alarm: AIS
Port statistic:start time: 2017-12 -20 12:40:38
For the command output description, see Table 2.
e1 channel-set
Use e1 channel-set to bundle timeslots on an E1 channel into one channel set.
Use undo e1 channel-set to remove a channel set.
e1 e1-number channel-set set-number timeslot-list range
undo e1 e1-number channel-set set-number
No channel sets exist.
CPOS interface view
e1-number: Specifies the number of an E1 channel on the CPOS interface. The value range for this argument is 1 to 63.
set-number: Specifies a channel set number in the range of 0 to 30.
timeslot-list range: Specifies a comma-separated list of timeslot items. An item can be an individual timeslot or a timeslot range. Use a hyphen (-) to separate the start and end timeslot numbers of a range. The value range for the timeslot number is 1 to 31.
When the E1 channel is channelized, timeslot 0 is used for synchronization. The other 31 timeslots can be bundled to form one or multiple channel sets. For each channel set, the system automatically creates a serial interface numbered in the format interface number/channel number:channel set number.
For successful communication, make sure the local end has the same timeslot bundling settings as the remote end.
# Bundle timeslots 1 to 31 into a channel set on E1 channel 63.
[Sysname-Cpos2/2/1] e1 63 channel-set 1 timeslot-list 1-31
# Enter the view of the serial interface created for the channel set.
[Sysname-Cpos2/2/1] quit
[Sysname] interface serial 2/2/1/63:1
[Sysname-Serial2/2/1/63:1]
e1 unframed
e1 clock
Use e1 clock to set the clock mode of an E1 channel.
Use undo e1 clock to restore the default clock mode of an E1 channel.
e1 e1-number clock { master | slave }
undo e1 e1-number clock
The clock mode of an E1 channel is slave.
CPOS interface view
The clock mode settings of E1 channels on a CPOS interface are independent of one another.
Set the clock mode on an E1 channel depending on its connected device.
·          If the connected device is a SONET/SDH device, enable the slave clock mode on the channel. The SONET/SDH network clock is more precise than the clock provided by the device.
·          If the E1 channel is directly connected to a router, make sure the E1 channel uses a different clock mode than the peer end.
# Set the clock mode to master on E1 channel 1.
[Sysname-Cpos2/2/1] e1 1 clock master
e1 flag
Use e1 flag to set the C2 or J2 overhead byte for an E1 channel.
Use undo e1 flag to restore the default C2 or J2 overhead byte for an E1 channel.
e1 e1-number flag { c2 c2-value | j2 { sdh | sonet } j2-string }
undo e1 e1-number flag { c2 | j2 { sdh | sonet } }
The C2 byte value is 2 (hexadecimal).
The cyclic value for the J2 byte is CR16000.
CPOS interface view
e1-number: Specifies an E1 channel by its number. The value range for this argument is 1 to 63.
c2: Specifies the low-order channel signal tag byte (C2).
c2-value: Specifies the value of the C2 byte. The value range is 0 to 7 (except 5) in hexadecimal notation.
j2: Specifies the low-order channel trace byte (J2).
sdh: Specifies the trace byte in SDH format.
sonet: Specifies the trace byte in SONET format.
j2-string: Specifies the string filled in the J2 byte, a string of 1 to 15 characters for SDH or a string of 1 to 62 characters for SONET.
# Set the C2 byte to 7 (hexadecimal) for E1 channel 3 on CPOS 2/2/1.
[Sysname-Cpos2/2/1] e1 3 flag c2 7
e1 frame-format
Use e1 frame-format to set the framing format of an E1 channel.
Use undo e1 frame-format to restore the default framing format of an E1 channel.
e1 e1-number frame-format { crc4 | no-crc4 }
undo e1 e1-number frame-format
The framing format of an E1 channel is no-CRC4.
CPOS interface view
crc4: Sets the framing format to CRC4.
no-crc4: Sets the framing format to no-CRC4.
# Set the framing format to CRC4 for E1 channel 1.
[Sysname-Cpos2/2/1] e1 1 set frame-format crc4
e1 loopback
Use e1 loopback to set the loopback mode for an E1 channel.
Use undo e1 loopback to disable loopback for an E1 channel.
e1 e1-number loopback { local | remote }
undo e1 e1-number loopback
Loopback is disabled on an E1 channel.
CPOS interface view
local: Enables internal loopback.
remote: Enables external loopback.
You can test E1 channels by using the loopback command with different keywords.
·          In an internal loopback, the sender's data is directly looped to the receiver.
·          In an external loopback, data received by the receiver is looped back directly without passing through the E1 framer.
# Enable external loopback on E1 channel 1.
[Sysname-Cpos2/2/1] e1 1 set loopback remote
e1 shutdown
Use e1 shutdown to shut down an E1 channel.
Use undo e1 shutdown to bring up an E1 channel.
e1 e1-number shutdown
undo e1 e1-number shutdown
E1 channels are up.
CPOS interface view
When you shut down an E1 channel, its associated serial interfaces are also shut down.
# Shut down E1 channel 1.
[Sysname-Cpos2/2/1] e1 1 shutdown
e1 unframed
Use e1 unframed to configure an E1 channel on a CPOS interface to operate in unframed mode.
Use undo e1 unframed to restore the default operating mode of an E1 channel on a CPOS interface.
e1 e1-number unframed
undo e1 e1-number unframed
E1 channels on a CPOS interface operate in framed mode.
CPOS interface view
E1 channels on CPOS interfaces support the unframed (clear channel) mode and the framed (channelized) mode.
·          In unframed mode, an E1 channel can form a 2.048 Mbps serial interface without timeslot division. It is numbered in the format of interface-number/channel-number:0.
·          In framed mode, all timeslots except timeslot 0 on the E1 channel can be bundled randomly to form serial interfaces.
# Set E1 channel 3 on CPOS 2/2/1 to operate in unframed mode.
[Sysname-Cpos2/2/1] e1 3 unframed
flag
Use flag to set an overhead byte for SONET/SDH frames.
Use undo flag to restore the default of the specified overhead byte for SONET/SDH frames.
flag { c2 path-number c2-value | s1 s1-value | s1s0 path-number s1s0-value }
undo flag { c2 path-number | s1 | s1s0 path-number }
flag { j0 | j1 path-number } { sdh | sonet } flag-value
undo flag { j0 | j1 path-number } { sdh | sonet }
·          The C2 byte value is 2 (hexadecimal).
·          The S1 byte value is f (hexadecimal).
·          The value of S1S0 is 0 (hexadecimal) for SONET and 2 (hexadecimal) for SDH.
·          The J0 byte value is 1 (hexadecimal) for SONET. The J0 byte value for SDH is CR16000..
·          The J1 byte value for SONET and the J1 byte value for SDH are both CR16000.
CPOS interface view
c2 path-number c2-value: Specifies the number of a path and the path signal label byte. The value range for the c2-value argument is 0 to ff in hexadecimal notation.
s1 s1-value: Specifies the synchronization status byte.
s1s0 path-number s1s0-value: Specifies the number of a path and the AU type and TU type.
j0: Specifies the regenerator section trace message, which is a section overhead byte used to detect the continuity of the connection between two interfaces at the section layer.
j1 path-number: Specifies the path trace message, which is a higher-order path overhead byte used to detect the continuity of the connection between two interfaces at the path layer.
sdh: Specifies the SDH framing format.
sonet: Specifies the SONET framing format.
flag-value: Specifies the flag value for SDH or SONET frames. In SDH frames, the flag value is a string of 1 to 15 characters for both the J0 and J1 bytes. In SONET frames, the flag value is in the range of 0 to ff (hexadecimal) for the J0 byte and a string of 1 to 62 characters for the J1 byte.
SONET/SDH frames provide a variety of overhead bytes for operation and maintenance (OAM) such as layered management on transmission networks.
J1, J0 and C2 are used to support interoperability between devices from different countries, areas, and vendors.
J0 is a section overhead byte used for detecting the continuity of the connection between two interfaces at the section layer. J1 and C2 are higher-order path overhead bytes. The J1 byte is used for detecting the continuity of the connection between two interfaces at the path layer. The C2 byte is used for indicating the multiplexing structure of a VC frame and the property of payload.
S1 is the synchronization status byte used to transfer ITU-T clock quality information. A smaller value indicates higher clock precision.
S1S0 are two bits in the H1 byte. They are used by ITU to indicate the AU-n/TU-n type. S1S0 must be set to 2 for AU-4, AU-3, and TU-3.
# Set the J0 byte to aa on CPOS 2/2/1.
[Sysname-Cpos2/2/1] flag j0 sdh aa
frame-format
Use frame-format to set the framing format on a CPOS interface.
Use undo frame-format to restore the default framing format on a CPOS interface.
frame-format { sdh | sonet }
undo frame-format
The framing format on a CPOS interface is SDH.
CPOS interface view
# Set the framing format to SONET on CPOS 2/2/1.
[Sysname-Cpos2/2/1] frame-format sonet
link-delay
Use link-delay to set the physical state change suppression interval on a CPOS interface.
Use undo link-delay to restore the default.
link-delay seconds
undo link-delay
The physical state change suppression interval is 1 second on a CPOS interface.
CPOS interface view
seconds: Sets the physical state change suppression interval in the range of 0 to 30 seconds.
When the physical state changes, a CPOS interface reports the event to the upper-layer modules, and generates log and SNMP notification messages. To reduce system overhead caused by frequent physical state changes, use this command to suppress physical state changes within an interval. The interface will ignore any changes that occur during each suppression interval. When the suppression interval expires, the interface will not report the change event or generate messages if the change is removed.
For example, the suppression interval starts when the interface changes from up to down. The interface reports the change event and generates messages if it is still down when the interval expires. The interface does not report the change event or generate messages if it is up when the interval expires.
# Set the physical state change suppression interval to 8 seconds on CPOS 2/2/1.
[Sysname-Cpos2/2/1] link-delay 8
loopback
Use loopback to enable loopback on a CPOS interface.
Use undo loopback to disable loopback on a CPOS interface.
undo loopback
Loopback is disabled on a CPOS interface.
CPOS interface view
local: Enables internal loopback to test the physical interface.
remote: Enables external loopback to test the cable connected to the interface.
Loopback is intended for testing only. Disable the feature when the interface is operating correctly.
# Enable external loopback testing on CPOS 2/2/1.
[Sysname-Cpos2/2/1] loopback remote
multiplex mode
Use multiplex mode to set AUG multiplexing mode for a CPOS interface.
Use undo multiplex mode to restore the default AUG multiplexing mode for a CPOS interface.
multiplex mode { au-3 | au-4 }
undo multiplex mode
The AUG multiplexing mode is au-4 on a CPOS interface in SDH mode.
The AUG multiplexing mode is au-3 on a CPOS interface in SONET mode.
CPOS interface view
au-3: Gets AUG through AU-3.
au-4: Gets AUG through AU-4.
SDH provides the following payload mapping/multiplexing solutions:
·          ANSI—Uses the AU-3 multiplexing scheme. This scheme multiplexes the lower-order payload to the VC-3 higher-order path. VC-3 plus an AU pointer forms AU-3. Three such AU-3s can be synchronized and multiplexed to form one AUG.
·          ETSI—Uses the AU-4 multiplexing scheme. This scheme multiplexes the lower-order payload to the VC-4 higher-order path. VC-4 plus an AU pointer forms an AU-4. This AU-4 can be synchronized and multiplexed to form one AUG.
When the CPOS interface is operating in SDH mode, you can multiplex AUG to AU-4 or AU-3 by using the multiplex mode command.
When the CPOS interface is operating in SONET mode, AUG can be multiplexed only to AU-3, which cannot be modified.
Countries and regions use different multiplexing schemes. You must use the same multiplexing scheme as the peer device. For example, the AU-4 multiplexing scheme is used in China.
# In SDH mode, multiplex AUG to AU-3.
[Sysname-Cpos2/2/1] frame-format sdh
[Sysname-Cpos2/2/1] multiplex mode au-3
frame-format
reset counters controller cpos
Use reset counters controller cpos to clear CPOS interface statistics.
reset counters controller cpos [ interface-number ]
cpos [ interface-number ]: Specifies a CPOS interface by its number. If you do not specify a CPOS interface, this command clears statistics for all CPOS interfaces.
Use this command to clear history statistics before you collect traffic statistics for a time period.
To display CPOS interface statistics, use the display controller cpos command.
# Clear statistics for CPOS 2/2/1.
<Sysname> reset counters controller cpos 2/2/1
shutdown
Use shutdown to shut down a CPOS physical interface.
Use undo shutdown to bring up a CPOS physical interface.
shutdown
The CPOS physical interface is up.
CPOS interface view
The shutdown command on the CPOS physical interface shuts down all E1 channels and serial interfaces formed by timeslot bundles. As a result, they stop transmitting and receiving data. To bring them up, use the undo shutdown command on the CPOS physical interface.
# Shut down CPOS 2/2/1.
[Sysname-Cpos2/2/1] shutdown
threshold
Use threshold to configure the power for setting the SD or SF alarm threshold on a CPOS interface.
Use undo threshold to restore the default power for setting the SD or SF alarm threshold on a CPOS interface.
threshold { sd sdvalue | sf sfvalue } *
undo threshold [ sd | sf ]
The SD alarm threshold is 10e-6 and the SF alarm threshold is 10e-4.
CPOS interface view
sd: Specifies the SD alarm threshold.
sdvalue: Specifies the power for setting the SD alarm threshold. The threshold is 10e to the power of negative sdvalue (10e–sdvalue). The value range for this argument is 3 to 9. The greater the value, the lower the SD alarm threshold.
sf: Specifies the SF alarm threshold. The SF alarm threshold must be higher than the SD alarm threshold.
sfvalue: Specifies the power for setting the SF alarm threshold. The threshold is 10e to the power of negative sdvalue (10e–sfvalue). The value range for this argument is 3 to 9. The greater the value, the lower the SF alarm threshold.
SD and SF alarms indicate line performance. SF alarms are more severe than SD alarms.
·          An SD alarm occurs if the bit error rate reaches the SD alarm threshold.
·          An SF alarm occurs if the bit error rate reaches the SF alarm threshold.
# Set the SD threshold to 10e to the power of negative 4 (10e–4) on CPOS 2/2/1.
[Sysname] interface cpos 2/2/1
[Sysname-Cpos2/2/1] threshold sd 4
