- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-ISSU commands
- 09-Preprovisioning commands
- 10-Device management commands
- 11-Tcl commands
- 12-Python commands
- 13-License management commands
| 09-Preprovisioning commands | 40.89 KB |
display provision failed-config
Use display provision failed-config to display preprovisioned-commands application failure records.
A preprovisioned command cannot be applied if it conflicts with the running configuration.
Use this command to verify the application result of preprovisioned commands except for the following commands:
· duplex
· speed
· sflow
To verify the application result of the listed commands, use the display current-configuration command. The display provision failed-config command might display incorrect application results for the listed commands.
# Display preprovisioned-commands application failure records.
<Sysname> display provision failed-config
Configuration applied at: Sat Jun 14 06:06:00 2014
Slot information: slot 1
Commands that failed to be applied:
interface Twenty-FiveGigE1/0/1
speed 25000
provision
reset provision failed-config
provision
Use provision to enable preprovisioning.
Use undo provision to disable preprovisioning.
provision [ subslot subslot-number ] model model
undo provision [ subslot subslot-number ] model
Preprovisioning is disabled.
Slot view
subslot subslot-number: Specifies a subslot by its subslot number. If you do not specify a subslot, preprovisioning is enabled on the slot. To specify a subslot, you must first enable provisioning on the slot and make sure the provisioned slot has subslots.
model model: Specifies the IRF member device or subcard model to be preprovisioned. To obtain available models, enter a question mark (?) for the model argument.
This command allows you to enable preprovisioning on offline modules, including IRF member devices and subcards.
The device automatically creates interfaces when preprovisioning is enabled for a module. The display interface command will not display these interfaces until the module comes online. However, you can preprovision the interfaces.
When you disable preprovisioning on a slot, the device removes all preconfigured settings for the slot, including the preconfigured settings for the subslots.
When you disable preprovisioning on a subslot, the device removes preconfigured settings for the subslot.
Only the S9850-4C switch supports specifying a subslot for the command.
# Enable preprovisioning for the S6850-56HF device on a slot.
[Sysname] slot 2
[Sysname-slot-2] provision model S6850-56HF
slot
Use reset provision failed-config to clear preprovisioned-commands application failure records.
Preprovisioned modules that repeatedly come online and go offline (or join and leave the IRF fabric) might leave a number of commands that were not applied in memory. To release the occupied memory space, execute the reset provision failed-config command.
# Clear preprovisioned-commands application failure records.
<Sysname> reset provision failed-config
provision
slot
Use slot to select a slot to provision and enter slot view.
slot slot-number
slot-number: Specifies an IRF member device by its member ID.
# Enter the view of a slot.
[Sysname] slot 2
[Sysname-slot-2]
provision
