02-Virtual Technologies Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5130S-SI[LI]&S5120V2-SI[LI]&S5110V2-SI&S5000V3-EI&S5000E-X&S3100V3-SI Configuration Guides-R612x-6W10202-Virtual Technologies Configuration Guide
00-Preface
00-Preface 91.92 KB
Preface
This configuration guide describes how to set up an IRF fabric of multiple switches, including:
·          Plan the switch roles in the IRF fabric.
·          Connect the IRF links.
·          Detect IRF splits and maintain the IRF fabric.
·          Audience.
·          Conventions.
·          Documentation feedback.
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
