10-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5130S-SI[LI]&S5120V2-SI[LI]&S5110V2-SI&S5000V3-EI&S5000E-X&S3100V3-SI Command References-R612x-6W10210-Network Management and Monitoring Command Reference
04-PoE commands
04-PoE commands 98.92 KB
PoE commands
apply poe-profile
Use apply poe-profile to apply a PoE profile to a power interface (PI).
Use undo apply poe-profile to restore the default.
apply poe-profile { index index | name profile-name }
undo apply poe-profile { index index | name profile-name }
No PoE profile is applied to PIs.
PI view
index index: Specifies a PoE profile by its index number in the range of 1 to 100.
name profile-name: Specifies a PoE profile by its name, a case-sensitive string of 1 to 15 characters.
# Apply the PoE profile named forIPphone to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] apply poe-profile name forIPphone
apply poe-profile interface
display poe-profile
Use apply poe-profile interface to apply a PoE profile to PIs.
Use undo apply poe-profile interface to remove the PoE profile application from PIs.
apply poe-profile { index index | name profile-name } interface interface-range
undo apply poe-profile { index index | name profile-name } interface interface-range
No PoE profile is applied to a PI.
interface-range: Specifies a range of Ethernet interfaces in the form of interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number represents the interface type and interface number. The start interface number must be smaller than the end interface number. If an interface in the specified range does not support PoE, it is ignored when the PoE profile is applied.
[Sysname] apply poe-profile name forIPphone interface gigabitethernet 1/0/1
# Apply the PoE profile with index number 1 to PIs GigabitEthernet 1/0/2 to GigabitEthernet 1/0/6.
[Sysname] apply poe-profile index 1 interface gigabitethernet 1/0/2 to gigabitethernet 1/0/6
apply poe-profile
display poe-profile interface
display poe device
Use display poe device to display general PSE information.
display poe device [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays general PSE information about all PSEs in the IRF fabric.
# Display general PSE information.
<Sysname> display poe device
Slot  1:
 PSE ID    Slot No.  SSlot No. PortNum   MaxPower(W)    State   Model
 4          1          0           48         600.0           Off      LSPPSE48A
PSE ID
ID of the PSE.
Slot No.
Slot number of the PSE.
SSlot No.
Sub-slot number of the PSE.
PortNum
Number of PIs on the PSE.
MaxPower(W)
Maximum power of the PSE.
PSE status:
·         On—The PSE is supplying power.
·         Off—The PSE is not supplying power.
·         Faulty—The PSE has failed.
Model
PSE model.
display poe interface
Use display poe interface to display power supplying information for PIs.
display poe interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power supplying information for all PIs.
# Display power supplying information for GigabitEthernet 1/0/1.
<Sysname> display poe interface gigabitethernet 1/0/1
 PoE Status                         : Enabled
 Power Priority                    : Critical
 Oper                                : On
 IEEE Class                         : 1
 Detection Status                  : Delivering power
 Power Mode                         : Signal
 Current Power                      : 11592    mW
 Average Power                      : 11610    mW
 Peak Power                          : 11684    mW
 Max Power                           : 15400    mW
 Electric Current                   : 244      mA
 Voltage                              : 51.7     V
 PD Description                      : IP Phone For Room 101
PoE Status
PoE status:
·         Enabled.
·         Disabled.
Power Priority
Power supply priority of the PI:
·         Critical (highest).
·         High.
·         Low.
Oper
Operating status of a PI:
·         Off—PoE is disabled.
·         On—Power is being supplied to the PI correctly.
·         Power-lack—Remaining guaranteed power is insufficient for a critical PI.
·         Power-deny—The PSE refuses to supply power. The power required by the PD is higher than the configured power.
·         Power-itself—The PD is using another power supply.
·         Power-limit—The PSE is supplying power to the PD based on the configured power though the PD requires more power than the configured power.
IEEE Class
PD power class: 0, 1, 2, 3, or 4.
If the PSE does not support PD classification, this field displays a hyphen (-).
Detection Status
Power detection status of a PI:
·         Disabled—The PoE function is disabled.
·         Searching—The PI is searching for the PD.
·         Delivering power—The PI is supplying power to the PD.
·         Fault—A fault occurred during the test.
·         Test—The PI is undergoing a test.
·         Other fault—A fault has caused the PSE to enter the idle status.
·         PD disconnected—The PD is disconnected.
Power Mode
Power transmission mode of a PI:
·         Signal—Power is being supplied over signal cables.
·         Spare—Power is being supplied over spare cables.
Current Power
Current power of a PI, including PD consumption power and transmission loss.
Average Power
Average power of a PI.
Peak Power
Peak power of a PI.
Max Power
Maximum power of a PI.
Electric Current
Current of a PI.
Voltage
Voltage of a PI.
PD Description
Type and location description for the PD connected to the PI.
# Display power supplying information for all PIs.
 Interface    PoE       Priority  CurPower  Oper    IEEE  Detection
                                     (W)                  Class Status
 GE1/0/1      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/2      Enabled   Low       0.0       Off       0     Searching
 GE1/0/3      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/4      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/5      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/6      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/7      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/8      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/9      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/10     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/11     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/12     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/13     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/14     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/15     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/16     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/17     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/18     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/19     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/20     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/21     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/22     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/23     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/24     Disabled  Low       0.0       Off       0     Disabled
   ---  On State Ports: 0; Used: 0.0(W); Remaining: 370.0(W)  ---
Interface name of a PI.
PoE
PoE status:
·         Enabled.
·         Disabled.
Priority
Power priority of a PI:
·         High.
·         Low.
CurPower
Current power of a PI.
Oper
IEEE Class
Detection Status
·         Disabled—PoE function is disabled.
·         Delivering Power—The PI is supplying power for the PD.
On State Ports
Number of PIs that are supplying power.
Used
Power consumed by the current PI.
Remaining
Total remaining power of the system.
display poe interface power
Use display poe interface power to display power information for PIs.
display poe interface power [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power information for all PIs.
# Display power information for GigabitEthernet 1/0/1.
<Sysname> display poe interface power gigabitethernet 1/0/1
Interface    Current   Peak      Max       PD Description
               (W)       (W)       (W)
 GE1/0/1        15.0      15.3      30.0      Access Point on Room 509 for Peter
# Display power information for all PIs.
              (W)       (W)       (W)
 GE1/0/1      0.0       0.0       30.0
 GE1/0/2      0.0       0.0       30.0
 GE1/0/3      0.0       0.0       30.0
 GE1/0/4      0.0       0.0       30.0
 GE1/0/5      0.0       0.0       30.0
 GE1/0/6      0.0       0.0       30.0
 GE1/0/7      0.0       0.0       30.0
 GE1/0/8      0.0       0.0       30.0
 GE1/0/9      0.0       0.0       30.0
 GE1/0/10     0.0       0.0       30.0
 GE1/0/11     0.0       0.0       30.0
 GE1/0/12     0.0       0.0       30.0
 GE1/0/13     0.0       0.0       30.0
 GE1/0/14     0.0       0.0       30.0
 GE1/0/15     0.0       0.0       30.0
 GE1/0/16     0.0       0.0       30.0
 GE1/0/17     0.0       0.0       30.0
 GE1/0/18     0.0       0.0       30.0
 GE1/0/19     0.0       0.0       30.0
 GE1/0/20     0.0       0.0       30.0
 GE1/0/21     0.0       0.0       30.0
 GE1/0/22     0.0       0.0       30.0
 GE1/0/23     0.0       0.0       30.0
 GE1/0/24     0.0       0.0       30.0
CurPower
PeakPower
Peak power of a PI.
MaxPower
PD Description
Type and location description for the PD connected to a PI.
Ports On
Used
Power consumed by all PIs.
Remaining
display poe pse
Use display poe pse to display detailed PSE information.
display poe pse [ pse-id ]
pse-id: Specifies a PSE by its ID. If you do not specify a PSE, this command displays detailed PSE information about all PSEs.
# Display detailed PSE information.
<Sysname> display poe pse
 PSE ID                            : 4
 Slot No.                          : 1
 SSlot No.                         : 0
 PSE Model                         : LSPPSE48A
 PSE Status                        : Enabled
 Power Priority                   : Low
 Current Power                    : 0.0      W
 Average Power                    : 0.0      W
 Peak Power                        : 0.0      W
 Max Power                         : 600.0    W
 Remaining Guaranteed Power     : 600.0    W
 PSE CPLD Version                 : -
 PSE Software Version             : 172
 PSE Hardware Version             : 0
 Legacy PD Detection              : Disabled
 Power Utilization Threshold    : 80
 PD Power Policy                  : Priority
 PD Disconnect-Detection Mode   : DC
Table 5 Command output
PSE ID
ID of the PSE.
SSlot No.
Sublsot number of the PSE.
PSE Status
PoE status of the PSE:
·         Enabled.
·         Disabled.
Power Priority
Power priority of the PSE.
Current Power
Current power of the PSE.
Average Power
Average power of the PSE.
Peak Power
Peak power of the PSE.
Max Power
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE.
PSE CPLD Version
PSE CPLD version number.
PSE software version number.
PSE hardware version number.
Legacy PD Detection
Nonstandard PD detection status:
·         Enabled.
·         Disabled.
PSE power alarm threshold.
PD Power Policy
PD power management policy mode.
PD disconnection detection mode.
display poe pse interface
Use display poe pse interface to display the PoE status of all PIs on a PSE.
display poe pse pse-id interface
pse pse-id: Specifies a PSE ID. To display PSE ID and slot mappings, use the display poe device command.
# Display the status of all PIs on PSE 4.
<Sysname> display poe pse 4 interface
                                     (W)                  Class Status
Table 6 Command output
PoE
PoE status of a PI:
·         Enabled.
·         Disabled.
Priority
Priority of a PI:
·         High.
·         Low.
CurPower
Oper
IEEE Class
Detection Status
·         Delivering Power—The PI is supplying power to the PD.
·         Other Fault—A fault has caused the PSE to enter the idle status.
·         PD Disconnected—The PD is disconnected.
On State Ports
Used
Power consumed by PIs on the PSE.
Remaining
Remaining power on the PSE.
display poe pse interface power
Use display poe pse interface power to display power information for PIs on a PSE.
display poe pse pse-id interface power
pse pse-id: Specifies a PSE by its ID. To display PSE ID and slot mappings, use the display poe device command.
# Display power information for PIs on PSE 4.
<Sysname> display poe pse 4 interface power
              (W)       (W)       (W)
Table 7 Command output
Current
Peak
Peak power of a PI.
Max
PD Description
Type and location description for the PD connected with a PI.
Ports On
Used
Remaining
display poe-profile
Use display poe-profile to display information about the PoE profile.
display poe-profile [ index index | name profile-name ]
If you do not specify a profile, the command displays information about all PoE profiles.
# Display information about all PoE profiles.
<Sysname> display poe-profile
 PoE Profile     Index   ApplyNum  Interfaces     Configuration
 forIPphone      1        4           GE1/0/1        poe enable
                                        GE1/0/2           poe priority critical
                                        GE1/0/3
                                        GE1/0/4
 forAP            2        2           GE1/0/5         poe enable
                                        GE1/0/6         poe max-power 14000
   ---  Total PoE profiles: 2, total ports: 6  ---
# Display information about the PoE profile with index number 1.
<Sysname> display poe-profile index 1
 forIPphone      1        6          GE1/0/1         poe enable
                                       GE1/0/3
                                       GE1/0/4
                                       GE1/0/5
                                       GE1/0/6
   ---  Total ports: 6  ---
Table 8 Command output
PoE Profile
Name of the PoE profile.
Index
Index number of the PoE profile.
ApplyNum
Number of PIs to which the PoE profile is applied.
Interfaces
Interface name of the PI to which the PoE configuration is applied.
Configuration
Configurations of the PoE profile.
Total PoE profiles
Number of PoE profiles.
Total ports
Number of PIs to which all PoE profiles are applied.
Use display poe-profile interface to display information about the PoE profile on a PI.
display poe-profile interface interface-type interface-number
# Display information about the PoE profile on GigabitEthernet 1/0/1.
<Sysname> display poe-profile interface gigabitethernet 1/0/1
 PoEProfile     Index   ApplyNum  Interface   Effective configuration
The Effective configuration field displays the configurations that have taken effect. For the descriptions of other fields, see Table 8.
poe detection-mode
Use poe detection-mode to configure a PD detection mode.
Use undo poe detection-mode to restore the default.
This command is supported only in Release 6127 and later.
poe detection-mode { none | simple | strict }
The strict PD detection mode applies.
PI view
none: Enables the device to supply power to PDs that are correctly connected to the device without causing short circuit.
simple: Enables the device to supply power to PDs that comply with basic requirements of 802.3af or 802.3at.
strict: Enables the device to supply power to PDs that comply with all requirements of 802.3af or 802.3at.
CAUTION
CAUTION:
A non-PD device might be damaged when power is supplied to it. To avoid device damage, do not specify the none keyword when the PI connects to a non-PD device.
To configure the detection mode for nonstandard PDs, first execute the poe legacy enable command to enable detection for nonstandard PDs.
# Configure the simple detection mode for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] poe detection-mode simple
poe legacy enable
poe enable
Use poe enable to enable PoE on a PI.
Use undo poe enable to disable PoE on a PI.
poe enable
undo poe enable
In R6126P12, PoE is disabled on a PI.
In R6126P20 and later versions:
·          PoE is enabled on a PI when the device starts up with factory defaults.
·          PoE is disabled on a PI when the device starts up with initial configuration.
For more information about startup with factory defaults and initial configuration, see configuration file management in Fundamentals Configuration Guide.
PI view
PoE profile view
If a PoE profile has been applied to a PI, remove the application before configuring the PI in PoE profile view.
If a PI has been configured, remove the configuration before configuring the PI in PI view.
# Enable PoE on a PI in PI view.
[Sysname-GigabitEthernet1/0/1] poe enable
# Enable PoE on a PI in PoE profile view.
[Sysname] poe-profile abc
[Sysname-poe-profile-abc-1] poe enable
poe-profile
poe legacy enable
Use poe legacy enable to enable the PSE to detect nonstandard PDs.
Use undo poe legacy enable to disable the PSE from detecting nonstandard PDs.
poe legacy enable pse pse-id
undo poe legacy enable pse pse-id
Nonstandard PD detection is disabled.
# Enable PSE 4 to detect nonstandard PDs.
[Sysname] poe legacy enable pse 4
display poe pse
poe max-power
Use poe max-power to set the maximum PI power.
Use undo poe max-power to restore the default.
poe max-power max-power
undo poe max-power
The maximum PI power is 30000 W.
PI view
PoE profile view
max-power: Sets the maximum PI power in milliwatts. The value range is 1000 to 30000.
# Set the maximum PI power to 12000 milliwatts in PI view.
[Sysname-GigabitEthernet1/0/1] poe max-power 12000
# Set the maximum PI power to 12000 milliwatts in PoE profile view.
[Sysname-poe-profile-abc-1] poe max-power 12000
poe pd-description
Use poe pd-description to configure a description for the PD that connects to a PI.
Use undo poe pd-description to restore the default.
poe pd-description text
No description is configured for the PD that connects to a PI.
PI view
text: Configures a description for the PD connected to the PI, a case-sensitive string of 1 to 80 characters.
# Configure the description for the PD as IP Phone for Room 101.
[Sysname-GigabitEthernet1/0/1] poe pd-description IP Phone For Room 101
poe pd-policy priority
Use poe pd-policy priority to enable PI power management.
Use undo poe pd-policy priority to restore the default.
PI power management is disabled.
If PI power management is disabled, the PSE does not supply power to new PDs when PSE power overload occurs.
If PI power management is enabled, when a PSE is overloaded, the PSE allocates power to PDs based on the priority of their PIs.
# Enable PI power management.
[Sysname] poe pd-policy priority
poe priority
poe priority
Use poe priority to set the power supply priority for a PI.
Use undo poe priority to restore the default.
poe priority { critical | high | low }
undo poe priority
The power supply priority of a PI is low.
PI view
PoE profile view
critical: Sets the power supply priority to critical. The PI with critical power priority operates in guaranteed mode. Power is first supplied to the PD connected to the critical PI.
high: Sets the power supply priority to high.
low: Sets the power supply priority to low.
When the PoE power is insufficient, power is first supplied to PIs with higher priority.
For PIs with same power supply priority, the PI with the smallest ID is allocated with power first.
# Set the power supply priority of the PI to critical in PI view.
[Sysname-GigabitEthernet1/0/1] poe priority critical
# Set the power supply priority of the PI to critical in PoE profile view.
[Sysname-poe-profile-abc-1] poe priority critical
[Sysname-poe-profile-abc-1] quit
[Sysname-GigabitEthernet1/0/1] apply poe-profile name abc
poe reset enable
Use poe reset enable to enable PI power cycling upon a system warm reboot.
Use undo poe pse-policy priority to disable PI power cycling upon a system warm reboot.
poe reset enable
undo poe reset enable
PI power cycling upon a system warm reboot is disabled.
During the system warm reboot process (upon execution of the reboot command), the PIs continue supplying power to the PDs but data connections between the PDs and the device are interrupted. After the system reboots, PDs might not re-initiate data connections with the device. Power cycling PIs upon a system warm reboot allows the PDs to re-establish data connections with the device.
# Enable PI power cycling upon a system warm reboot.
[Sysname] poe reset enable
poe update
Use poe update to upgrade the PSE firmware when the device is operating.
poe update { full | refresh } filename [ pse pse-id ]
full: Upgrades the PSE firmware in full mode.
refresh: Upgrades the PSE firmware in refresh mode.
filename: Specifies the name of the upgrade file, a case-insensitive string of 1 to 64 characters. The specified file must be in the root directory of the file system of the device.
pse pse-id: Specifies a PSE by its ID. If you do not specify a PSE, all PSEs are upgraded.
You can upgrade the PSE firmware in service in either of the following modes:
·          Refresh mode—Updates the PSE firmware without deleting it. You can use the refresh mode in most cases.
·          Full mode—Deletes the current PSE firmware and reloads a new one. Use the full mode if the PSE firmware is damaged and you cannot execute any PoE commands.
# Upgrade the firmware of PSE 4 in service.
[Sysname] poe update refresh POE-168.bin pse 4
poe utilization-threshold
Use poe utilization-threshold to configure a power alarm threshold for the PSE.
Use undo poe utilization-threshold to restore the default power alarm threshold of the PSE.
poe utilization-threshold value pse pse-id
undo poe utilization-threshold pse pse-id
The power alarm threshold for the PSE is 80%.
value: Specifies alarm threshold as a percentage of 1 to 99.
If PSE power usage crosses the threshold multiple times in succession, the system sends notification messages only for the first crossing. For more information, see "Configuring SNMP."
# Set the power alarm threshold of PSE 4 to 90%.
[Sysname] poe utilization-threshold 90 pse 4
poe-profile
Use poe-profile to create a PoE profile and enter its view, or enter the view of an existing PoE profile.
Use undo poe-profile to delete a PoE profile.
poe-profile profile-name [ index ]
undo poe-profile { index index | name profile-name }
No PoE profiles exist.
profile-name: Specifies a PoE profile name, a case-sensitive string of 1 to 15 characters. A PoE configuration file name begins with a letter and must not contain reserved keywords including undo, all, name, interface, user, poe, disable, max-power, mode, priority, or enable.
index: Specifies the index number of a PoE profile, in the range of 1 to 100.
To configure PIs in batches, use the PoE profile.
If you do not specify a profile index, the system automatically assigns an index (starting from 1) to the PoE profile.
If a PoE profile is applied, use the undo apply poe-profile command to remove the application before deleting the PoE profile.
# Create a PoE profile, name it abc, and specify the index number as 3.
[Sysname] poe-profile abc 3
[Sysname-poe-profile-abc-3]
# Create a PoE profile and name it def. Do not specify the index number.
[Sysname] poe-profile def
[Sysname-poe-profile-def-1]
apply poe-profile
poe enable
poe max-power
poe priority
