10-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5130S-HI[EI]&S5110V2&S3100V3-EI Switch Series Configuration Guides-R612x-6W10310-Network Management and Monitoring Configuration Guide
17-SmartMC configuration
17-SmartMC configuration 187.48 KB
Configuring SmartMC· 1
About SmartMC·· 1
SmartMC network framework· 1
SmartMC network establishment 1
SmartMC features· 2
Restrictions: Hardware compatibility with SmartMC·· 5
Restrictions: Software version compatibility with SmartMC·· 5
Restrictions and guidelines: SmartMC configuration· 5
SmartMC tasks at a glance· 5
Prerequisites for SmartMC·· 6
Enabling SmartMC·· 7
Setting the FTP server information· 7
Configuring an outgoing interface for the SmartMC network· 8
Enabling automatic Ethernet link aggregation· 8
Modifying the password of the default user for members· 8
Creating a SmartMC group· 9
Creating a VLAN for members· 10
Deploying a batch file to members· 10
Configuring a batch file for ports connecting APs or IP phones· 10
Backing up configuration files· 11
Configuring resource monitoring· 11
Upgrading the startup software and configuration file on members· 12
About upgrading the startup software and configuration file on members· 12
Restrictions and guidelines for startup software and configuration file upgrade· 12
Prerequisites· 12
Upgrading the startup software and configuration file on all members in SmartMC groups· 13
Managing the network topology· 14
Refreshing the network topology· 14
Saving the network topology· 14
Replacing faulty members· 15
Display and maintenance commands for SmartMC·· 15
SmartMC configuration examples· 16
Example: Configuring SmartMC·· 16
Configuring SmartMC
About SmartMC
Smart Management Center (SmartMC) centrally manages and maintains dispersed network devices at network edges. In a SmartMC network, only one device acts as the commander and the remaining devices all act as members. SmartMC provides the following features for you to manage the members from the commander:
·          Configuration file backup and download.
·          Software upgrade.
·          Configuration deployment.
·          Faulty member replacement.
Figure 1 shows the basic framework of a SmartMC network.
Figure 1 SmartMC network framework
The SmartMC network contains the following elements:
·          Commander—Also called topology master (TM), which manages all members in the SmartMC network.
·          Member—Also called topology client (TC), which is managed by the commander.
·          FTP server—Stores startup software images and configuration files for the commander and members.
A SmartMC network can be established automatically or manually. In an automatically established SmartMC network, the commander obtains member information through NETCONF sessions to form the network topology. The member information includes port information, LLDP neighbor information, STP information, device type, and software version. In a manually established SmartMC network, the commander obtains member's LLDP neighbor information through NETCONF sessions and member's hardware information through SNMP Get operations.
Automatic SmartMC network establishment
The commander and members use the following procedure to establish a SmartMC network:
1.        After SmartMC is enabled, the commander broadcasts a SmartMC packet at an interval of 15 seconds to detect members in the network. The SmartMC packet contains information of the commander, such as its bridge MAC address and the IP address of VLAN-interface 1.
2.        When a member receives the packet, it records the commander information, and returns a response packet to the commander. The response packet contains information of the member, such as its bridge MAC address and the IP address of VLAN-interface 1.
3.        When the commander receives the response packet, it initiates a NETCONF session to the member with the default username admin and the default password admin. The commander then obtains detailed information about the member through the session, including port information, LLDP neighbor information, STP information, device type, and software version.
4.        The commander establishes a connection to the member for tracking the liveliness of the member, and adds the member to the SmartMC network.
5.        Based on the LLDP neighbor information obtained from all members, the commander forms a SmartMC topology.
After the SmartMC network is established, the commander and members check for the existence of each other by exchanging SmartMC packets.
·          When a member receives a SmartMC broadcast packet from the commander, it compares the bridge MAC address in the packet with the recorded bridge MAC address. If the two bridge MAC addresses are the same, the member returns a response packet to the commander. If the member does not receive a broadcast packet from the commander within the time limit, the member determines that the commander does not exist in the network anymore. Then, the member clears the commander information. The time limit is a random value in the range of 60 to 120 seconds.
·          When the commander receives a response packet from a member, it compares the bridge MAC address in the packet with the recorded bridge MAC address. If the two bridge MAC addresses are the same, the commander determines that the member still exists in the network. If the commander does not receive a response packet from a member within 150 seconds, the commander determines that the member is offline. Then, the commander sets the status of the member to offline.
Manual SmartMC network establishment
You can log in to the Web interface of the commander, and enter the IP address, username, and password of the members to manually add them to the network. The members can join the network without exchanging SmartMC packets with the commander. For more information, see Comware 7 Web-Based Products User Guide.
After you specify the information of a member on the commander, the commander performs the following operations to add the member to the network:
·          Verify that the member can be accessed through Telnet.
·          Obtain basic member information, including LLDP neighbor information through NETCONF.
·          Obtain hardware information through SNMP Get operations.
SmartMC features
Bulk configuration deployment for members
This feature allows you to deploy multiple command lines to members from the commander, eliminating the need to log in to members and configure the command one by one.
The procedure for bulk configuration deployment is as follows:
1.        The commander acts as a Telnet client and establishes Telnet connections to the members.
2.        The commander deploys a batch file to the members through Telnet connections. The batch file is created on the commander and contains command lines to be deployed.
3.        The members run the command lines in the file.
Bulk configuration deployment for ports connecting APs and IP phones
You can specify a batch file to deploy to ports connecting APs or IP phones. When the commander detects that an AP or IP phone comes online on a port, it obtains the access device type through LLDP and deploys the command lines in the specified file to the port. If no batch file is specified for the device type, configuration on the port remains unchanged.
If the AP or IP phone disconnects from the port, the configurations on the port remain. When a new device comes online from the port, configurations used by the port depend on the new device type.
·          If the new device is an AP or IP phone but has a different type as the disconnected device, the commander deploys new configurations to the port based on the device type. If no batch file is specified for the device type, configuration on the port remains unchanged.
·          If the new device has the same device type as the disconnected device or is neither an AP nor an IP phone, configuration on the port remains unchanged.
You can use the following methods to back up the next-startup configuration file on the commander and members:
·          Automatic backup—Enable this feature for the commander and all members in the network to immediately perform a backup. After that, the commander and members back up the configuration file at a user-specified interval.
·          Manual backup—Manually trigger a backup on specified members or SmartMC groups.
The commander instructs the members to back up the next-startup configuration file by unicasting a SmartMC packet to them. When a member receives the packet, it saves the running configuration to the next-startup configuration file and uploads the file to the FTP server.
Startup software and configuration file upgrade
This feature enables users to upgrade startup software and the configuration file of member devices from the commander.
Before upgrade, you must upload the upgrade files from the commander to the FTP server and specify the upgrade files on the FTP server for the members to download.
The procedure for startup software and configuration file upgrade is as follows:
1.        The commander instructs the members (or SmartMC group) to download the upgrade files from the FTP server.
2.        The members download the upgrade files from the FTP server.
3.        The members upgrade the startup software and configuration file as follows:
?  Startup software upgrade—Performs an ISSU with the upgrade startup software files. The members might be restarted during the upgrade process.
?  Configuration file upgrade—Replaces the current configuration file with the upgrade configuration file. The members will not be restarted during the upgrade process.
You can use the following methods to replace a faulty member:
·          Automatic replacement—Enables the commander to record the positions of all members in the topology for replacement. When the commander discovers that the new member has physically replaced the faulty member, it compares the new member with the faulty one. The commander performs a replacement if the following requirements are met:
?  The new member is deployed at the same topological position as the faulty one.
?  The models of the new member and faulty member are the same.
The commander then instructs the new member to download the configuration file of the faulty member from the FTP server. After downloading the configuration file, the new member runs the configuration file to complete the replacement.
·          Manual replacement—After the faulty member is physically replaced, you manually trigger a configuration replacement. The new member will download the configuration file of the faulty member from the FTP server and run the file to complete the replacement.
Outgoing interface for a SmartMC network
The outgoing interface feature allows hosts connecting to an outgoing interface to access all the members in a SmartMC network. You can configure multiple outgoing interfaces for a SmartMC network.
As shown in Figure 2, the host is connected to port 1 on the TM and TC 1 and TC 2 are in a different network segment than the host. The host can access the Web interface of the TM but cannot access the Web interface of any member.
If port 1 on the TM is configured as the outgoing interface, the system mirrors the IP address of each member to a new address. The new address contains the IP address of the outgoing interface and the port number assigned by the commander to the member in the format of IP address:Port number. This enables the host to access the Web interfaces of members from the Web interface of the TM.
To access the Web interface of a member, enter the Web interface of the commander, and click Visibility from the navigation pane. Then, click the Topology tab, select the target member, and click Login to Web interface.
Figure 2 SmartMC network
Automatic link aggregation
Automatic link aggregation automatically bundles multiple physical Ethernet links between two members into one logical link, called an aggregate link. This feature provides increased link bandwidth and improved link reliability.
·      Automatic link aggregation cannot be performed between the commander and a member. You can aggregate the links between the commander and a member manually. For more information about manual link aggregation, see Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide.
·      If a member enabled with automatic link aggregation joins a SmartMC network whose commander is disabled with the aggregation feature, the feature will be disabled for the member as well. This might affect service traffic forwarding on the member.
VLAN creation for members
To simplify configuration and management, you can create a VLAN for members. Then, all access ports on a member that are not connected to other members or the commander are assigned to the VLAN.
If a member has access ports that are connected to offline devices, you must remove the offline devices before creating a VLAN for the member.
The VLAN creation fails for a member if one or more access ports cannot be assigned to the VLAN. If the VLAN creation fails, the VLAN memberships for the access ports are restored to the state before the VLAN was created.
The failure to create a VLAN for a member does not affect the VLAN creation for other members.
Resource monitoring
Resource monitoring allows you to view resource usage of commanders and members on the commander, such as CPU usage, memory usage, and temperature information.
The S5110V2 switch series does not support SmartMC.
The S5130S-HI[EI] and S3100V3-EI switch series cannot act as the commander.
SmartMC is supported only in Release 6127 and later.
You need to enable SmartMC on both the commander and members and perform all the other tasks only on the commander.
The following features take effect only on members added to the SmartMC network automatically:
·          Configuration file backup.
·          Startup software and configuration file upgrade.
·          Automatic link aggregation.
A SmartMC network is established in VLAN 1. For the network to work correctly, do not configure security settings in VLAN 1.
To configure SmartMC, perform the following tasks:
1.        Enabling SmartMC
2.        Setting the FTP server information
This task is required for configuring automatic configuration file backup, replacing faulty members, and upgrading the startup software and configuration file on members.
3.        (Optional.) Configuring an outgoing interface for the SmartMC network
4.        (Optional.) Enabling automatic Ethernet link aggregation
5.        (Optional.) Modifying the password of the default user for members
6.        Creating a SmartMC group
This task is required for upgrading the startup software and configuration file on members and deploying a batch file to a SmartMC group.
7.        (Optional.) Deploying and managing configuration
?  Creating a VLAN for members
?  Deploying a batch file to members
?  Configuring a batch file for ports connecting APs or IP phones
?  Backing up configuration files
8.        (Optional.) Monitoring and maintaining the SmartMC network
?  Configuring resource monitoring
?  Upgrading the startup software and configuration file on members
?  Managing the network topology
?  Replacing faulty members
Before you configure SmartMC, perform the following tasks on the commander and members:
·          Enable the Telnet service, and configure scheme authentication for VTY user lines. For information about Telnet service and VTY user lines, see CLI login configuration in Fundamentals Configuration Guide.
·          Configure a local user.
?  Specify the username and password.
-      On the commander, the username and password must be the same as the username and password configured by using the smartmc tm username username password { cipher | simple } string enable command.
-      On a member, both the username and password are admin. You can use the smartmc tc password command to modify the username and password after SmartMC network establishment.
?  Specify the Telnet, HTTP, and HTTPS services for the user.
?  Set the RBAC role of the local user to network-admin.
For information about local users, see AAA configuration in Security Configuration Guide. For information about user roles, see RBAC configuration in Fundamentals Configuration Guide.
·          Enable NETCONF over SOAP over HTTP. For information about NETCONF over SOAP, see NETCONF configuration in Network Management and Monitoring Configuration Guide.
·          Enable LLDP globally. For information about LLDP, see Layer 2—LAN Switching Configuration Guide.
·          To manage the commander and members through a Web interface, you must enable the HTTP and HTTPS services, and set the service type to HTTP and HTTPS for the local user. For information about Web login, HTTP, and HTTPS, see Fundamentals Configuration Guide.
·          To manually establish a SmartMC network, you must configure the snmp-agent community read public and snmp-agent sys-info version v2c commands on the members. For information about SNMP, see Network Management and Monitoring Configuration Guide.
Enabling SmartMC
About SmartMC
Enable this feature on both the commander and members to enable management of members from the commander.
A SmartMC network must have one and only one commander.
If you change the role of the commander to member or disable SmartMC on the commander, all SmartMC settings in its running configuration will be cleared.
SmartMC fails to be enabled if ACL resources are insufficient. If ACL resources are insufficient, use the undo acl command to delete unnecessary ACLs and then enable SmartMC. You can execute the display acl command to view ACL configuration and match statistics. For more information about ACLs, see ACL and QoS Configuration Guide.
SmartMC fails to be enabled if ports 80 and 443 have been used.
1.        Enter system view.
2.        Enable SmartMC and set the device role.
smartmc { tc | tm username username password { cipher | simple } string } enable
By default, SmartMC is disabled.
About files stored on the FTP server
In a SmartMC network, an FTP server is used to store the following files:
·          Upgrade startup software files and upgrade configuration file for members.
·          Backup configuration files of the commander and members.
You can use the following methods to specify an FTP server:
·          Specify the IP address of an FTP server.
·          Specify the IP address of the commander. The commander will act as an FTP server.
To configure the commander to act as an FTP server, make sure the commander has enough storage space for storing the files required by members. For information about FTP, see Fundamentals Configuration Guide.
To use an independent FTP server, connect the FTP server to the commander instead of the members as a best practice. The FTP server uses VLAN 1 to communicate with the SmartMC network. If you connect the FTP server to members, creating a VLAN for members will assign member interfaces connecting to the FTP server to the created VLAN, causing FTP server disconnection. For more information about member VLAN creation, see "Creating a VLAN for members."
2.        Set the FTP server information.
smartmc ftp-server server-address username username password { cipher | simple } string
By default, no FTP server information is set.
VLAN interface 1 cannot be used as an outgoing interface, because the SmartMC network is established in VLAN 1.
2.        Enter VLAN interface view or Layer 3 Ethernet interface view.
?  Enter VLAN interface view.
interface vlan interface-number
?  Enter Layer 3 Ethernet interface view.
3.        Configure the interface as an outgoing interface.
smartmc outbound
By default, no interface is used as an outgoing interface.
Enabling or disabling automatic link aggregation might cause network flapping, and the members might go offline for a short period of time.
2.        Enable automatic Ethernet link aggregation.
smartmc auto-link-aggregation enable
By default, automatic Ethernet link aggregation is disabled.
About modifying the password of the default user for members
During SmartMC network establishment, the commander uses the default username and password to establish NETCONF sessions to members automatically added to the network. The default username and password of the members for NETCONF session establishment are admin and admin.
To enhance security, you can perform this task to change the password for the default user admin of the members after the commander adds the members to the network.
Do not modify the password for members that are manually added to the SmartMC network. If you modify the password for a manually added member, you will not be able to manage that member from the commander.
You can use the display smartmc tc verbose command to identify the method used to add the members.
2.        Modify the password of the default user for members.
smartmc tc password string
About SmartMC groups
This feature allows you to create a SmartMC group on the commander and add members to the group. When you perform the following operations, you can specify a SmartMC group to apply the operations to all members in the group:
·          Startup software upgrade.
·          Configuration file upgrade.
2.        Create a SmartMC group and enter its view.
smartmc group group-name
3.        (Optional.) Display predefined device types.
match device-type ?
If the device type of the members is not predefined on the commander, you must manually add the device type to the commander. This enables members of an undefined type to join a SmartMC group created on the commander.
4.        Set a match criterion.
match { device-type device-type | ip-address ip-address { ip-mask-length | ip-mask } | mac-address mac-address mac-mask-length }
By default, no match criterion is set.
5.        Return to system view.
6.        (Optional.) Add a device type to the commander.
smartmc tc sysoid sysoid device-type device-type
The device type added to the commander cannot be the same as any predefined type on the commander.
To obtain the SYSOID of a member, execute the display smartmc tc verbose command.
If you perform this task multiple times to create a VLAN for members, the most recent configuration takes effect.
2.        Creating a VLAN for members and assign access ports on the members to the VLAN.
smartmc vlan vlan-id { group group-name-list | tc tc-id-list }
1.        Execute the following command in user view to create a batch file and edit the command lines to be deployed to members.
create batch-file cmd-filename
Each command occupies a line in the batch file. When you finish editing, enter a percent sign (%) to return to user view.
Make sure the command lines that you enter are correct because the system does not verify whether the command lines are correct.
2.        Enter system view.
3.        Deploy the batch file to a list of members or SmartMC groups.
smartmc batch-file cmd-filename deploy { group group-name-list | tc tc-id-list }
All commands in the batch file must be commands used in interface view.
The size of the batch file cannot exceed 8190 characters.
Make sure the file name is correct when specifying the batch file because the system does not verify whether the file name is correct. After specifying the batch file, do not delete the file or rename the file.
1.        (Optional.) Execute the following command in user view to create a batch file and edit the command lines to be deployed to members.
3.        Specify the batch file for ports connecting APs or IP phones.
smartmc batch-file batch-file-name apply { ap | phone }
About backing up configuration files
Configuration files automatically backed up to the FTP server are named in the format of device bridge MAC address_backup.cfg.
When you change the commander in the SmartMC network, make sure the backup configuration file of the original commander on the FTP server is deleted. If the file still exists, the new commander might download the file and run the settings. This will cause a conflict in the network.
The maximum number of members that can perform automatic configuration at the same time is limited by the performance of the FTP server. If automatic configuration backup fails, set the maximum number of members to a smaller value.
Before performing this task, you must set the FTP server information (see "Setting the FTP server information").
2.        Set the maximum number of members that can perform configuration file backup at the same time.
smartmc backup configuration max-number max-number
By default, a maximum of five members can perform automatic configuration backup at the same time.
3.        Back up configuration files.
Choose one option as needed:
?  Enable automatic configuration file backup and set the backup interval.
smartmc backup startup-configuration interval interval-time
By default, automatic configuration file backup is disabled.
?  Manually back up the configuration file on members.
smartmc backup configuration { group group-name-list | tc [ tc-id-list ] }
2.        Set the interval for the commander to obtain resource monitoring information.
smartmc resource-monitor interval interval
The default setting is 1 minute.
3.        Set the aging time for resource monitoring information.
smartmc resource-monitor max-age max-age
The default setting is 24 hours.
4.        Enable resource monitoring.
smartmc resource-monitor [ cpu | memory | temperature ] * [ group group-name-list | tc { tc-id-list | mac-address mac-address } | tm ]
By default, resource monitoring is disabled.
If you do not specify a resource type, this command enables resource monitoring for all resource types.
If you do not specify a device to monitor (member or commander), this command enables resource monitoring on the commander and all members.
You can use the following methods to upgrade the startup software and configuration file on members:
·          Schedule an upgrade by specifying an upgrade time or upgrade delay.
·          Upgrade immediately by not specifying an upgrade time or upgrade delay.
A member can perform only one upgrade task at a time.
An immediate upgrade cannot be cancelled. If you specify a delay time or upgrade time to perform a scheduled upgrade, the upgrade operation can be cancelled by using the undo smartmc upgrade command before it starts.
Upgrading the startup software and configuration file in one step
2.        Upgrade the startup software on members in one step.
smartmc upgrade boot-loader tc { tc-id-list { boot boot-filename system system-filename | file ipe-filename } }&<1-40> [ delay delay-time | time in-time ]
3.        Upgrade the configuration file on members in one step.
smartmc upgrade startup-configuration tc { tc-id-list cfg-filename }&<1-40> [ delay delay-time | time in-time ]
Configuring startup software and configuration file upgrade step by step
2.        Configure startup software upgrade for members step by step:
a.    Specify the upgrade startup software files.
smartmc tc tc-id boot-loader { ipe-filename | boot boot-filename system system-filename }
b.    Upgrade the startup software on members.
smartmc upgrade boot-loader tc tc-id-list
3.        Configure configuration file upgrade for members step by step:
a.    Specify the upgrade configuration file.
smartmc tc tc-id startup-configuration cfg-filename
b.    Upgrade the configuration file on members.
smartmc upgrade startup-configuration tc tc-id-list
2.        Upgrade the startup software on all members in SmartMC groups in one step.
smartmc upgrade boot-loader group { group-name-list [ boot boot-filename system system-filename | file ipe-filename ] }&<1-40> [ delay minutes | time in-time ]
3.        Upgrade the configuration file on all members in SmartMC groups in one step.
smartmc upgrade startup-configuration group { group-name-list cfg-filename }&<1-40> [ delay minutes | time in-time ]
2.        Enter SmartMC group view.
3.        Specify the upgrade startup software files for the SmartMC group.
boot-loader file { ipe-filename | boot boot-filename system system-filename }
By default, no upgrade startup software files are specified for a SmartMC group.
4.        Specify the upgrade configuration file for the SmartMC group.
startup-configuration cfgfile
By default, no upgrade configuration file is specified for a SmartMC group.
6.        Upgrade the startup software and configuration file on all members in the SmartMC group.
?  Upgrade the startup software.
smartmc upgrade boot-loader group group-name-list [ delay minutes | time in-time ]
?  Upgrade the configuration file.
smartmc upgrade startup-configuration group group-name-list [ delay minutes | time in-time ]
About refreshing the network topology
You can use the following methods to refresh the network topology:
·          Automatic topology refresh—Specify the refresh interval to allow the commander to refresh the network topology periodically.
·          Manual topology refresh—Execute the smartmc topology-refresh command to manually refresh the network topology.
The topology refresh time depends on the number of members in the network.
·          Manually refresh the network topology in any view.
·          Configure automatic network topology refresh.
a.    Enter system view.
b.    Set the automatic topology refresh interval.
smartmc topology-refresh interval interval
By default, the automatic topology refresh interval is 60 seconds.
About saving the network topology
This task allows you to save the current network topology to the topology.dba file in the flash memory. After the commander reboots, it uses the topology.dba file to restore the network topology.
2.        Save the network topology.
smartmc topology-save
Make sure the new member for replacement and the faulty member have the same neighbor relationship, device model, and IRF member ID.
Make sure the new member has a different member ID than all the members in the SmartMC network, including offline members. Faulty members are considered offline.
Before you replace a faulty member, perform the following tasks:
1.        Set the FTP server information (see "Setting the FTP server information").
2.        Install the new member at the location where the faulty member was installed.
3.        Connect all cables to the new member.
2.        Replace faulty members.
?  Enable automatic faulty member replacement.
smartmc auto-replace enable
By default, automatic faulty member replacement is disabled.
?  Manually replace a faulty member.
smartmc replace tc tc-id1 faulty-tc tc-id2
Display the backup status on members.
display smartmc backup configuration status
Display the batch file execution results.
display smartmc batch-file status [ ap | last number | phone ]
Display SmartMC configuration.
display smartmc configuration
Display connections between the devices in the SmartMC network.
display smartmc device-link
Display SmartMC group information.
display smartmc group [ group-name ] [ verbose ]
Display the faulty member replacement status.
display smartmc replace status
Display resource monitoring information.
display smartmc resource-monitor [ cpu | memory | temperature ] * [ tc tc-id | tm ]
Display resource monitoring configuration.
display smartmc resource-monitor configuration
Display member information.
display smartmc tc [ tc-id ] [ verbose ]
Display log information in the log buffer on a member.
display smartmc tc tc-id log buffer [ module module-name [ mnemonic mnemonic-value ] ]
Display restart log information for a member.
display smartmc tc tc-id log restart
Display VLAN creation results for members.
display smartmc vlan
Display member upgrade status.
display smartmc upgrade status
As shown in Figure 3, member 1, member 2, and member 3 belong to the same device type: S5130S-HI series. The IP address of the FTP server is 192.168.2.1. The FTP username is admin and the FTP password is admin.
Perform the following tasks to establish a SmartMC network and upgrade the configuration file on the members:
1.        Configure the commander and members to automatically establish a SmartMC network.
2.        Configure interface GigabitEthernet 1/0/1 as the outgoing interface for the SmartMC network.
3.        Create a SmartMC group and add the members to the group.
4.        Upgrade the configuration file on all members in the SmartMC group.
5.        Save configuration file startup.cfg on the FTP server.
Figure 3 Network diagram
1.        Configure TC 1:
# Configure VLAN-interface 1.
<TC1> system-view
[TC1] interface vlan-interface 1
[TC1-Vlan-interface1] ip address 192.168.2.3 24
[TC1-Vlan-interface1] quit
# Enable HTTP and HTTPS.
[TC1] ip http enable
[TC1] ip https enable
# Enable the Telnet service.
[TC1] telnet server enable
# Enable NETCONF over SOAP over HTTP.
[TC1] netconf soap http enable
# Enable LLDP globally.
[TC1] lldp global enable
# Create a user. Set the username and password to admin, add the telnet, http, and https service types, and authorize the user to use the network-admin user role.
[TC1] local-user admin
[TC1-luser-manage-admin] password simple admin
[TC1-luser-manage-admin] service-type telnet http https
[TC1-luser-manage-admin] authorization-attribute user-role network-admin
[TC1-luser-manage-admin] quit
# Set scheme authentication for VTY user lines 0 to 63.
[TC1] line vty 0 63
[TC1-line-vty0-63] authentication-mode scheme
[TC1-line-vty0-63] quit
# Enable SmartMC and set the device role to tc.
[TC1] smartmc tc enable
2.        Configure TC 2 and TC 3 in the same way TC 1 is configured. (Details not shown.)
3.        Configure the TM:
# Configure GigabitEthernet 1/0/1.
<TM> system-view
[TM] interface gigabitethernet 1/0/1
[TM-GigabitEthernet1/0/1] port link-mode route
[TM-GigabitEthernet1/0/1] ip address 192.168.52.2 24
[TM-GigabitEthernet1/0/1] quit
[TM] interface vlan-interface 1
[TM-Vlan-interface1] ip address 192.168.2.2 24
[TM-Vlan-interface1] quit
[TM] ip http enable
[TM] ip https enable
[TM] telnet server enable
[TM] netconf soap http enable
[TM] lldp global enable
[TM] local-user admin
[TM-luser-manage-admin] password simple admin
[TM-luser-manage-admin] service-type telnet http https
[TM-luser-manage-admin] authorization-attribute user-role network-admin
[TM-luser-manage-admin] quit
[TM] line vty 0 63
[TM-line-vty0-63] authentication-mode scheme
[TM-line-vty0-63] quit
# Enable SmartMC, set the device role to commander, and set both the username and password (plaintext) to admin.
[TM] smartmc tm username admin password simple admin enable
# Specify GigabitEthernet 1/0/1 as the outgoing interface.
[TM-GigabitEthernet1/0/1] smartmc outbound
# Set the FTP server IP address, username, and plaintext password to 192.168.2.1, admin, and admin, respectively.
[TM] smartmc ftp-server 192.168.2.1 username admin password simple admin
# Create SmartMC group S1 and enter its view.
[TM] smartmc group S1
# Create an IP address match criterion to add all members in the specified network segment to SmartMC group S1.
[TM-smartmc-group-S1] match ip-address 192.168.2.0 24
# Specify the upgrade configuration file startup.cfg for SmartMC group S1.
[TM-smartmc-group-S1] startup-configuration startup.cfg
[TM-smartmc-group-S1] quit
# Upgrade the configuration file on all members in SmartMC group S1.
[TM] smartmc upgrade startup-configuration group S1 startup.cfg
# Display brief information about all members after the SmartMC network is established.
[TM] display smartmc tc
TCID DeviceType Sysname  IpAddress       MacAddress     Status   Version
1    S5130S-HI  TC1      192.168.2.3     201c-e7c3-0300 Normal   COMWAREV700R001
2    S5130S-HI  TC2      192.168.2.4     201c-e7c3-0301 Normal   COMWAREV700R001
3    S5130S-HI  TC3      192.168.2.5     201c-e7c3-0302 Normal   COMWAREV700R001
# Display the configuration file upgrade status on the members.
<TM> display smartmc upgrade status
ID    IpAddress        MacAddress      Status      UpdateTime        UpdateFile
1     192.168.2.3      201c-e7c3-0300  Finished    Immediately       startup.cfg
2     192.168.2.4      201c-e7c3-0301  Finished    Immediately       startup.cfg
3     192.168.2.5      201c-e7c3-0302  Finished    Immediately       startup.cfg
