11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5560S-EI&S5560S-SI&S5500V3-SI Switch Series Command References-R612x-6W10211-Network Management and Monitoring Command Reference
16-Cloud connection commands
16-Cloud connection commands 41.91 KB
cloud-management keepalive
Use cloud-management keepalive to set the keepalive interval for the local device to send keepalive packets to the H3C cloud server.
Use undo cloud-management keepalive to restore the default.
cloud-management keepalive interval
The keepalive interval is 180 seconds.
interval: Specifies the keepalive interval in the range of 180 to 600 seconds.
If the device does not receive a response from the H3C cloud server within three keepalive intervals, the device sends a registration request to re-establish the cloud connection.
# Set the keepalive interval to 360 seconds.
[Sysname] cloud-management keepalive 360
cloud-management server domain
Use cloud-management server domain to configure the domain name of the H3C cloud server.
Use undo cloud-management server domain to restore the default.
cloud-management server domain domain-name
The domain name of the H3C cloud server is not configured.
domain-name: Specifies the domain name of the H3C cloud server, a case-sensitive string of 1 to 253 characters.
Before you configure the domain name of the H3C cloud server, make sure a DNS server has been configured to translate the domain name.
If you execute the command multiple times, the most recent configuration takes effect.
# Configure the domain name of the H3C cloud server as abc.com.
[Sysname] cloud-management server domain abc.com
display cloud-management state
Use display cloud-management state to display cloud connection state information.
# Display cloud connection state information.
<Sysname> display cloud-management state
Cloud connection state   : Established
Device state             : Request_success
Cloud server address     : 10.1.1.1
Cloud server domain name : abc.com
Cloud server port        : 443
Connected at             : Wed Jan  27 14:18:40 2016
Duration                 : 00d 00h 02m 01s
Process state            : Message received
Failure reason           : N/A
Cloud connection state: Unconnected, Request, and Established.
Device state
Local device state:
·         Idle—In idle state.
·         Connecting—Connecting to the H3C cloud server.
·         Request_CAS_url—Sent a central authentication service (CAS) URL request.
·         Request_CAS_url_success—Requesting CAS URL succeeded.
·         Request_CAS_TGT—Sent a ticket granting ticket (TGT) request.
·         Request_CAS_TGT_success—Requesting TGT succeeded.
·         Request_CAS_ST—Sent a service ticket (ST) request.
·         Request_CAS_ST_success—Requesting ST succeeded.
·         Request_cloud_auth—Sent an authentication request.
·         Request_cloud_auth_success—Authentication succeeded.
·         Register—Sent a registration request.
·         Register_success—Registration succeeded.
·         Request—Sent a handshake request.
·         Request_success—Handshake succeeded.
IP address of the H3C cloud server.
Domain name of the H3C cloud server.
Cloud server port
TCP port number used to establish cloud connections.
Connected at
Time when the cloud connection was established.
Duration
Duration since the establishment of the cloud connection.
Process state
Cloud connection processing state:
·         DNS not parsed.
·         DNS parsed.
·         Message not sent.
·         Message sent.
·         Message not received.
·         Message received.
Failure reason
Cloud connection failure reason:
·         DNS parse failed.
·         Socket connection failed.
·         SSL creation failed.
·         Sending CAS url request failed.
·         Sending CAS TGT failed.
·         Sending CAS ST failed.
·         Sending cloud auth request failed.
·         Sending registration request failed.
·         Processing CAS URL response failed.
·         Processing CAS TGT response failed.
·         Processing CAS ST response failed.
·         Processing cloud auth response failed.
·         Processing registration response failed.
·         Sending handshake request failed.
·         Processing handshake failed.
·         Sending websocket request failed.
·         Processing websocket packet failed.
reset cloud-management tunnel
Use reset cloud-management tunnel to re-establish the cloud connection to the H3C cloud server.
# Re-establish the cloud connection to the H3C cloud server.
<Sysname> reset cloud-management tunnel
