- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Public key management commands
- 10-PKI commands
- 11-IPsec commands
- 12-SSH commands
- 13-SSL commands
- 14-Attack detection and prevention commands
- 15-TCP attack prevention commands
- 16-IP source guard commands
- 17-ARP attack protection commands
- 18-ND attack defense commands
- 19-uRPF commands
- 20-SAVI commands
- 21-MFF commands
- 22-Crypto engine commands
- 23-FIPS commands
- 24-802.1X client commands
| 20-SAVI commands | 30.91 KB |
SAVI commands
ipv6 savi down-delay
Use ipv6 savi down-delay to set the entry deletion delay.
Use undo ipv6 savi down-delay to restore the default.
ipv6 savi down-delay delay-time
The entry deletion delay is 30 seconds.
delay-time: Specifies the entry deletion delay in the range of 0 to 21474836 seconds.
The entry deletion delay is the period of time that the device waits before deleting the DHCPv6 snooping entries and ND snooping entries for a down port.
# Set the entry deletion delay to 100 seconds.
[Sysname] ipv6 savi down-delay 100
ipv6 savi strict
Use ipv6 savi strict to enable Source Address Validation Improvement (SAVI).
Use undo ipv6 savi strict to disable SAVI.
ipv6 savi strict
SAVI is disabled.
# Enable SAVI.
[Sysname] ipv6 savi strict
ipv6 verify source
