06-IP Multicast Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5560S-EI&S5560S-SI&S5500V3-SI Switch Series Configuration Guides-R612x-6W10206-IP Multicast Configuration Guide
07-PIM configuration
07-PIM configuration 693.35 KB
Configuring PIM·· 1
About PIM·· 1
PIM modes· 1
PIM-DM·· 1
PIM-SM·· 3
Administrative scoping· 9
PIM-SSM·· 10
Relationship among PIM protocols· 12
Protocols and standards· 12
Configuring PIM-DM·· 12
PIM-DM tasks at a glance· 12
Prerequisites for PIM-DM·· 13
Enabling PIM-DM·· 13
Configuring the state refresh feature· 13
Setting the PIM-DM graft retry timer 14
Configuring PIM-SM·· 15
PIM-SM tasks at a glance· 15
Prerequisites for PIM-SM·· 15
Enabling PIM-SM·· 15
Configuring static RPs· 16
Configuring C-RPs· 16
Configuring C-BSRs· 17
Configuring a PIM domain border 18
Disabling BSM semantic fragmentation·· 18
Disabling the device from forwarding BSMs out of their incoming interfaces· 18
Enabling Auto-RP listening· 19
Configuring Anycast RP·· 19
Configuring multicast source registration·· 20
Configuring the switchover to SPT· 21
Configuring PIM-SSM·· 21
PIM-SSM tasks at a glance· 21
Prerequisites for PIM-SSM·· 21
Enabling PIM-SM·· 21
Configuring the SSM group range· 22
Configuring common PIM features· 22
Common PIM feature tasks at a glance· 22
Configuring a multicast source policy· 23
Configuring a PIM hello policy· 23
Configuring PIM hello message options· 23
Dropping hello messages without the Generation ID option·· 25
Configuring common PIM timers· 25
Setting the maximum size of a join or prune message· 27
Setting the DSCP value for outgoing PIM protocol packets· 27
Enabling BFD for PIM·· 27
Enabling PIM passive mode· 28
Enabling PIM NSR·· 28
Enabling SNMP notifications for PIM·· 29
Display and maintenance commands for PIM·· 29
PIM configuration examples· 30
Example: Configuring PIM-DM·· 30
Example: Configuring non-scoped PIM-SM·· 33
Example: Configuring admin-scoped PIM-SM·· 35
Example: Configuring PIM-SSM·· 40
Troubleshooting PIM·· 43
A multicast distribution tree cannot be correctly built 43
Multicast data is abnormally terminated on an intermediate device· 44
An RP cannot join an SPT in PIM-SM·· 44
An RPT cannot be built or multicast source registration fails in PIM-SM·· 44
Configuring PIM
About PIM
Protocol Independent Multicast (PIM) provides IP multicast forwarding by leveraging unicast static routes or unicast routing tables generated by any unicast routing protocol. PIM uses the underlying unicast routing to generate a multicast routing table without relying on any particular unicast routing protocol. PIM uses the RPF mechanism to implement multicast forwarding. For more information about RPF, see "Configuring multicast routing and forwarding."
PIM modes
Based on the implementation mechanism, PIM includes the following modes:
·          Protocol Independent Multicast–Dense Mode (PIM-DM).
·          Protocol Independent Multicast–Sparse Mode (PIM-SM).
·          Protocol Independent Multicast Source-Specific Multicast (PIM-SSM).
In this document, a PIM domain refers to a network that contains PIM devices.
PIM-DM
PIM-DM uses the push mode for multicast forwarding, and is suitable for small-sized networks with densely distributed multicast members.
PIM-DM assumes that all downstream nodes want to receive multicast data from a source, so multicast data is flooded to all downstream nodes on the network. Branches without downstream receivers are pruned from the forwarding trees. When a pruned branch has new receivers, the graft mechanism turns the pruned branch into a forwarding branch.
In PIM-DM, the multicast forwarding paths for a multicast group constitutes a forwarding tree. The forwarding tree is rooted at the multicast source and has multicast group members as its "leaves." Because the forwarding tree consists of the shortest paths from the multicast source to the receivers, it is also called a "shortest path tree (SPT)."
PIM-DM mechanisms include neighbor discovery, SPT building, graft, and assert.
Neighbor discovery
In a PIM domain, each PIM interface on a device periodically multicasts PIM hello messages to all other PIM devices (identified by the address 224.0.0.13) on the local subnet. Through the exchanging of hello messages, all PIM devices on the subnet determine their PIM neighbors, maintain PIM neighboring relationship with other devices, and build and maintain SPTs.
SPT building
The process of building an SPT is the flood-and-prune process:
1.        In a PIM-DM domain, the multicast data from the multicast source S to the multicast group G is flooded throughout the domain. A device performs an RPF check on the multicast data. If the RPF check succeeds, the device creates an (S, G) entry and forwards the data to all downstream nodes on the network. In the flooding process, all the devices in the PIM-DM domain create the (S, G) entry.
2.        The nodes without downstream receivers are pruned. A device that has no downstream receivers multicasts a prune message to all PIM devices on the subnet. When an upstream node receives the prune message, it removes the receiving interface from the (S, G) entry. In this way, the upstream stream node stops forwarding subsequent packets addressed to that multicast group down to this node.
An (S, G) entry contains a multicast source address S, a multicast group address G, an outgoing interface list, and an incoming interface.
A prune process is initiated by a leaf device. As shown in Figure 1, the device interface that does not have any downstream receivers initiates a prune process by sending a prune message toward the multicast source. This prune process goes on until only necessary branches are left in the PIM-DM domain, and these necessary branches constitute an SPT.
Figure 1 SPT building
The pruned state of a branch has a finite holdtime timer. When the timer expires, multicast data is again forwarded to the pruned branch. The flood-and-prune cycle takes place periodically to maintain the forwarding branches.
Graft
A previously pruned branch might have new downstream receivers. To reduce the latency for resuming the forwarding capability of this branch, a graft mechanism is used as follows:
1.        The node that needs to receive the multicast data sends a graft message to its upstream node, telling it to rejoin the SPT.
2.        After receiving this graft message on an interface, the upstream node adds the receiving interface to the outgoing interface list of the (S, G) entry. It also sends a graft-ack message to the graft sender.
3.        If the graft sender receives a graft-ack message, the graft process finishes. Otherwise, the graft sender continues to send graft messages at a graft retry interval until it receives an acknowledgment from its upstream node.
Assert
On a subnet with more than one multicast device, the assert mechanism shuts off duplicate multicast flows to the network. It does this by electing a unique multicast forwarder for the subnet.
Figure 2 Assert mechanism
As shown in Figure 2, after Device A and Device B receive an (S, G) packet from the upstream node, they both forward the packet to the local subnet. As a result, the downstream node Device C receives two identical multicast packets. In addition, both Device A and Device B, on their downstream interfaces, receive a duplicate packet forwarded by the other. After detecting this condition, both devices send an assert message to all PIM devices (224.0.0.13) on the local subnet through the interface that received the packet. The assert message contains the multicast source address (S), the multicast group address (G), and the metric preference and metric of the unicast route/MBGP route/static multicast route to the multicast source. By comparing these parameters, either Device A or Device B becomes the unique forwarder of the subsequent (S, G) packets on the shared-media LAN. The comparison process is as follows:
1.        The device with a higher metric preference to the multicast source wins.
2.        If both devices have the same metric preference, the device with a smaller metric wins.
3.        If both devices have the same metric, the device with a higher IP address on the downstream interface wins.
PIM-SM
PIM-DM uses the flood-and-prune cycles to build SPTs for multicast data forwarding. Although an SPT has the shortest paths from the multicast source to the receivers, it is built with a low efficiency. Therefore, PIM-DM is not suitable for large and medium-sized networks. PIM-SM uses the pull mode for multicast forwarding, and it is suitable for large- and medium-sized networks with sparsely and widely distributed multicast group members.
PIM-SM assumes that no hosts need multicast data. A multicast receiver must express its interest in the multicast data for a multicast group before the data is forwarded to it. A rendezvous point (RP) is the core of a PIM-SM domain. Relying on the RP, SPTs and rendezvous point trees (RPTs) are established and maintained to implement multicast data forwarding. An SPT is rooted at the multicast source and has the RPs as its leaves. An RPT is rooted at the RP and has the receiver hosts as its leaves.
PIM-SM mechanisms include neighbor discovery, DR election, RP discovery, Anycast RP, RPT building, multicast source registration, switchover to SPT, and assert.
Neighbor discovery
PIM-SM uses the same neighbor discovery mechanism as PIM-DM does. For more information, see "Neighbor discovery."
DR election
A designated router (DR) is required on both the source-side network and receiver-side network. A source-side DR acts on behalf of the multicast source to send register messages to the RP. The receiver-side DR acts on behalf of the multicast receivers to send join messages to the RP.
PIM-DM does not require a DR. However, if IGMPv1 runs on any shared-media LAN in a PIM-DM domain, a DR must be elected to act as the IGMPv1 querier for the LAN. For more information about IGMP, see "Configuring IGMP."
IMPORTANT
IMPORTANT:
IGMP must be enabled on the device that acts as the receiver-side DR. Otherwise, the receiver hosts attached to the DR cannot join any multicast groups.
Figure 3 DR election
As shown in Figure 3, the DR election process is as follows:
1.        The devices on the shared-media LAN send hello messages to one another. The hello messages contain the DR priority for DR election. The device with the highest DR priority is elected as the DR.
2.        The device with the highest IP address wins the DR election under one of following conditions:
¡  All the devices have the same DR election priority.
¡  A device does not support carrying the DR priority in hello messages.
If the DR fails, its PIM neighbor lifetime expires and the other devices will initiate to elect a new DR.
RP discovery
An RP is the core of a PIM-SM domain. A multicast group can have only one RP for multicast forwarding, and an RP can be designated to multiple multicast groups. RPs can be statically configured or dynamically elected through bootstrap router (BSR) mechanism. The BSM mechanism lessens the RP burden and optimizes the topological structure of the RPT.
BSR mechanism includes the following roles:
·          Candidate-RPs (C-RPs)—An RP is dynamically elected from C-RPs to provide services to a multicast group.
·          BSR—A BSR is the core of the administrative core of the PIM-SM domain. It is responsible for collecting and advertising RP information in the whole domain. A PIM-SM domain has only one BSR, and the BSR is elected from C-BSRs.
·          Candidate-BSRs (C-BSRs)—Any devices in the PIM-SM domain can act as C-BSRs and the BSR is elected from the C-BSRs. Once the BSR fails, a new BSR is elected from the C-BSRs to avoid multicast traffic interruption.
Figure 4 Information exchange between C-RPs and BSR
As shown in Figure 4, an RP is elected as follows:
1.        Each C-BSR sends a bootstrap message (BSM) to other devices in the PIM-SM domain.
2.        When a C-BSR receives a BSM from another C-BSR, it compares its own priority with the priority carried in the message. The C-BSR with a higher priority wins the BSR election. If a tie exists in the priority, the C-BSR with a higher IP address wins. The loser uses the winner's BSR address to replace its own BSR address and no longer regards itself as the BSR. The winner retains its own BSR address and continues to regard itself as the BSR.
3.        Each C-RP periodically unicasts an advertisement message to the BSR. An advertisement message contains the address of the advertising C-RP and the multicast group range to which it is designated.
4.        The BSR collects these advertisement messages and organizes the C-RP information into an RP-set, which is a database of mappings between multicast groups and RPs. The BSR encapsulates the RP-set information in the bootstrap messages (BSMs) and floods the BSMs to the entire PIM-SM domain.
5.        All devices in the PIM-SM domain select an RP for a multicast group based on the following rules:
a.    The C-RP that is designated to the smallest multicast group range wins.
b.    If the C-RPs are designated to the same group ranges, the C-RP with the highest priority wins.
c.    If the C-RPs have the same priority, the C-RP with the largest hash value wins. The hash value is calculated through the hash algorithm.
d.    If the C-RPs have the same hash value, the C-RP with the highest IP address wins.
Anycast RP
PIM-SM requires only one active RP to serve each multicast group. If the active RP fails, the multicast traffic might be interrupted. The Anycast RP mechanism enables redundancy backup among RPs by configuring multiple RPs with the same IP address. A multicast source registers with the closest RP or a receiver joins the closest RP to implement source information synchronization.
Anycast RP has the following benefits:
·          Optimal RP path—A multicast source registers with the closest RP to build an optimal SPT. A receiver joins the closest RP to build an optimal RPT.
·          Redundancy backup among RPs—When an RP fails, the RP-related sources will register with the closest available RPs and the receiver-side DRs will join the closest available RPs. This provides redundancy backup among RPs.
Anycast RP is implemented in either of the following methods:
·          Anycast RP through MSDP—In this method, you can configure multiple RPs with the same IP address for one multicast group and configure MSDP peering relationships between them. For more information about Anycast RP through MSDP, see "Configuring MSDP."
·          Anycast RP through PIM-SM—In this method, you can configure multiple RPs for one multicast group and add them to an Anycast RP set. This method introduces the following concepts:
¡  Anycast RP set—A set of RPs that are designated to the same multicast group.
¡  Anycast RP member—Each RP in the Anycast RP set.
¡  Anycast RP member address—IP address of each Anycast RP member for communication among the RP members.
¡  Anycast RP address—IP address of the Anycast RP set for communication within the PIM-SM domain. It is also known as RPA.
As shown in Figure 5, RP 1, RP 2, and RP 3 are members of an Anycast RP set.
Figure 5 Anycast RP through PIM-SM
The following describes how Anycast RP through PIM-SM is implemented:
a.    RP 1 receives a register message destined to RPA. Because the message is not from other Anycast RP members (RP 2 or RP 3), RP 1 considers that the register message is from the DR. RP 1 changes the source IP address of the register message to its own address and sends the message to the other members (RP 2 and RP 3).
If a device acts as both a DR and an RP, it creates a register message, and then forwards the message to the other RP members.
b.    After receiving the register message, RP 2 and RP 3 find out that the source address of the register message is an Anycast RP member address. They stop forwarding the message to other devices.
In Anycast RP implementation, an RP must forward the register message from the DR to other Anycast RP members to synchronize multicast source information.
RPT building
Figure 6 RPT building in a PIM-SM domain
As shown in Figure 6, the process of building an RPT is as follows:
1.        When a receiver wants to join the multicast group G, it uses an IGMP message to inform the receiver-side DR.
2.        After getting the receiver information, the DR sends a join message, which travels hop by hop to the RP for the multicast group.
3.        The devices along the path from the DR to the RP form an RPT branch. Each device on this branch adds to its forwarding table a (*, G) entry, where the asterisk (*) represents any multicast source. The RP is the root of the RPT, and the DR is a leaf of the RPT.
When the multicast data addressed to the multicast group G reaches the RP, the RP forwards the data to the DR along the established RPT, and finally to the receiver.
When a receiver is no longer interested in the multicast data addressed to the multicast group G, the receiver-side DR sends a prune message. The prune message goes hop by hop along the RPT to the RP. After receiving the prune message, the upstream node deletes the interface that connects to this downstream node from the outgoing interface list. At the same time, the upstream device checks for the existence of receivers for that multicast group. If no receivers for the multicast group exist, the device continues to forward the prune message to its upstream device.
Multicast source registration
The multicast source uses the registration process to inform an RP of its presence.
Figure 7 Multicast source registration
As shown in Figure 7, the multicast source registers with the RP as follows:
1.        The multicast source S sends the first multicast packet to the multicast group G. When receiving the multicast packet, the source-side DR encapsulates the packet into a PIM register message and unicasts the message to the RP.
2.        After the RP receives the register message, it decapsulates the register message and forwards the register message down to the RPT. Meanwhile, it sends an (S, G) source-specific join message toward the multicast source. The devices along the path from the RP to the multicast source constitute an SPT branch. Each device on this branch creates an (S, G) entry in its forwarding table.
3.        The subsequent multicast data from the multicast source are forwarded to the RP along the established SPT. When the multicast data reaches the RP along the SPT, the RP forwards the data to the receivers along the RPT. Meanwhile, it unicasts a register-stop message to the source-side DR to prevent the DR from unnecessarily encapsulating the data.
Switchover to SPT
This section takes a router as an example. As compared with the switchover to SPT on a router, switchover to SPT is implemented in a simpler way on a switch.
In a PIM-SM domain, only one RP and one RPT provide services for a specific multicast group. Before the switchover to SPT occurs, the source-side DR encapsulates all multicast data in register messages and sends them to the RP. After receiving these register messages, the RP decapsulates them and forwards them to the receiver-side DR along the RPT.
Multicast forwarding along the RPT has the following weaknesses:
·          Encapsulation and decapsulation are complex on the source-side DR and the RP.
·          The path for a multicast packet might not be the shortest one.
·          The RP might be overloaded by multicast traffic bursts.
To eliminate these weaknesses, PIM-SM allows an RP or the receiver-side DR to initiate the switchover to SPT when the RP or DR receives multicast traffic.
·          The RP initiates the switchover to SPT:
If the RP receives multicast traffic, it sends an (S, G) source-specific join message toward the multicast source. The routers along the path from the RP to the multicast source constitute an SPT. The subsequent multicast data is forwarded to the RP along the SPT without being encapsulated into register messages.
For more information about the switchover to SPT initiated by the RP, see "Multicast source registration."
·          The receiver-side DR initiates the switchover to SPT:
If the receiver-side DR receives multicast traffic, it initiates the switchover to SPT as follows:
a.    The receiver-side DR sends an (S, G) source-specific join message toward the multicast source. The routers along the path create an (S, G) entry in their forwarding table to constitute an SPT branch.
b.    When the multicast packets reach the router where the RPT and the SPT branches, the router drops the multicast packets that travel along the RPT. It then sends a prune message with the RP bit toward the RP.
c.    After receiving the prune message, the RP forwards it toward the multicast source (supposed only one receiver exists). Thus, the switchover to SPT is completed. The subsequent multicast packets travel along the SPT from the multicast source to the receiver hosts.
With the switchover to SPT, PIM-SM builds SPTs more economically than PIM-DM does.
Assert
PIM-SM uses a similar assert mechanism as PIM-DM does. For more information, see "Assert."
Typically, a PIM-SM domain contains only one BSR, which is responsible for advertising RP-set information within the entire domain. The information about all multicast groups is forwarded within the network that the BSR administers. This is called the "non-scoped BSR mechanism."
Administrative scoping mechanism
To implement refined management, you can divide a PIM-SM domain into a global-scoped zone and multiple administratively-scoped zones (admin-scoped zones). This is called the "administrative scoping mechanism."
The administrative scoping mechanism effectively releases stress on the management in a single-BSR domain and enables provision of zone-specific services through private group addresses.
Admin-scoped zones are divided for multicast groups. Zone border devices (ZBRs) form the boundary of an admin-scoped zone. Each admin-scoped zone maintains one BSR for multicast groups within a specific range. Multicast protocol packets, such as assert messages and BSMs, for a specific group range cannot cross the boundary of the admin-scoped zone for the group range. Multicast group ranges that are associated with different admin-scoped zones can have intersections. However, the multicast groups in an admin-scoped zone are valid only within the local zone, and theses multicast groups are regarded as private group addresses.
The global-scoped zone maintains a BSR for the multicast groups that do not belong to any admin-scoped zones.
Relationship between admin-scoped zones and the global-scoped zone
The global-scoped zone and each admin-scoped zone have their own C-RPs and BSRs. These devices are effective only on their respective zones, and the BSR election and the RP election are implemented independently. Each admin-scoped zone has its own boundary. The multicast information within a zone cannot cross this boundary in either direction. You can have a better understanding of the global-scoped zone and admin-scoped zones based on geographical locations and multicast group address ranges.
·          In view of geographical locations:
An admin-scoped zone is a logical zone for particular multicast groups. The multicast packets for such multicast groups are confined within the local admin-scoped zone and cannot cross the boundary of the zone.
Figure 8 Relationship in view of geographical locations
As shown in Figure 8, for the multicast groups in a specific group address range, the admin-scoped zones must be geographically separated and isolated. A device cannot belong to multiple admin-scoped zones. An admin-scoped zone cannot contain a device that belongs to any other admin-scoped zone. However, the global-scoped zone includes all devices in the PIM-SM domain. Multicast packets that do not belong to any admin-scoped zones are forwarded in the entire PIM-SM domain.
·          In view of multicast group address ranges:
Each admin-scoped zone is designated to specific multicast groups, of which the multicast group addresses are valid only within the local zone. The multicast groups of different admin-scoped zones might have intersections. All the multicast groups other than those of the admin-scoped zones use the global-scoped zone.
Figure 9 Relationship in view of multicast group address ranges
As shown in Figure 9, the admin-scoped zones 1 and 2 have no intersection, but the admin-scoped zone 3 is a subset of the admin-scoped zone 1. The global-scoped zone provides services for all the multicast groups that are not covered by the admin-scoped zones 1 and 2, G−G1−G2 in this case.
PIM-SSM
The ASM model includes PIM-DM and PIM-SM. The SSM model can be implemented by leveraging part of the PIM-SM technique. It is also called "PIM-SSM."
The SSM model provides a solution for source-specific multicast. It maintains the relationship between hosts and devices through IGMPv3.
In actual applications, part of IGMPv3 and PIM-SM techniques are adopted to implement the SSM model. In the SSM model, because receivers have located a multicast source, no RP or RPT is required. Multicast sources do not register with the RP, and the MSDP is not needed for discovering multicast sources in other PIM domains.
PIM-SSM mechanisms include neighbor discovery, DR election, and SPT building.
Neighbor discovery
PIM-SSM uses the same neighbor discovery mechanism as PIM-SM. For more information, see "Neighbor discovery."
DR election
PIM-SSM uses the same DR election mechanism as PIM-SM. For more information, see "DR election."
SPT building
The decision to build an RPT for PIM-SM or an SPT for PIM-SSM depends on whether the multicast group that the receiver joins is in the SSM group range. The SSM group range reserved by IANA is 232.0.0.0/8.
Figure 10 SPT building in PIM-SSM
As shown in Figure 10, Host B and Host C are receivers. They send IGMPv3 report messages to their DRs to express their interest in the multicast information that the multicast source S sends to the multicast group G.
After receiving a report message, the DR first checks whether the group address in this message is in the SSM group range and does the following:
·          If the group address is in the SSM group range, the DR sends a subscribe message hop by hop toward the multicast source S. All devices along the path from the DR to the source create an (S, G) entry to build an SPT. The SPT is rooted at the multicast source S and has the receivers as its leaves. This SPT is the transmission channel in PIM-SSM.
·          If the group address is not in the SSM group range, the receiver-side DR sends a (*, G) join message to the RP. The multicast source registers with the source-side DR.
In PIM-SSM, the term "subscribe message" refers to a join message.
In a PIM network, PIM-DM cannot run together with PIM-SM, BIDIR-PIM, or PIM-SSM. However, PIM-SM, BIDIR-PIM, and PIM-SSM can run together. (BIDIR-PIM is not supported in the current software version.) Figure 11 shows how the device selects one protocol from among them for a receiver trying to join a group.
For more information about IGMP SSM mapping, see "Configuring IGMP."
Figure 11 Relationship among PIM protocols
·          RFC 3973, Protocol Independent Multicast-Dense Mode (PIM-DM): Protocol Specification(Revised)
·          RFC 4601, Protocol Independent Multicast-Sparse Mode (PIM-SM): Protocol Specification (Revised)
·          RFC 4610, Anycast-RP Using Protocol Independent Multicast (PIM)
·          RFC 5015, Bidirectional Protocol Independent Multicast (BIDIR-PIM)
·          RFC 5059, Bootstrap Router (BSR) Mechanism for Protocol Independent Multicast (PIM)
·          RFC 4607, Source-Specific Multicast for IP
·          Draft-ietf-ssm-overview-05, An Overview of Source-Specific Multicast (SSM)
Configuring PIM-DM
To configure PIM-DM, perform the following tasks:
1.        Enabling PIM-DM
2.        (Optional.) Configuring the state refresh feature
3.        (Optional.) Setting the PIM-DM graft retry timer
4.        (Optional.) Configuring common PIM timers
Before you configure PIM-DM, complete the following tasks:
·          Configure a unicast routing protocol so that all devices in the domain can interoperate at the network layer.
·          Enable IP multicast routing.
Enabling PIM-DM
About enabling PIM-DM
With PIM-DM enabled on interfaces, devices can establish PIM neighbor relationship and process PIM messages from their PIM neighbors.
As a best practice, enable PIM-DM on all non-border interfaces of the devices when you deploy a PIM-DM domain.
1.        Enter system view.
2.        Enable IP multicast routing and enter MRIB view.
multicast routing
By default, IP multicast routing is disabled.
For more information about this command, see IP Multicast Command Reference.
3.        Return to system view.
4.        Enter interface view.
5.        Enable PIM-DM.
pim dm
By default, PIM-DM is disabled.
About the state refresh feature
·          State refresh capability—Enables the PIM device directly connected to the source to periodically send state refresh messages. It also enables other PIM devices to refresh pruned state timers after receiving the state refresh messages. It prevents the pruned interfaces from resuming multicast forwarding.
·          State refresh interval—Determines the interval at which a device sends state refresh messages.
·          Wait time before accepting a new state refresh message—A device might receive duplicate state refresh messages within a short time. To prevent this situation, you can configure the time that the device must wait to accept a new state refresh message. If the device receives a new state refresh message before the timer expires, it discards the message. If the device receives a new state refresh message after the timer expires, it accepts the message, refreshes its own PIM-DM state, and resets the waiting timer.
·          TTL value of state refresh messages—The TTL value of a state refresh message decrements by 1 whenever it passes a device before it is forwarded to the downstream node. The state refresh message is not forwarded when the TTL value comes down to 0. A state refresh message with a large TTL value might cycle on a small network.
To effectively control the propagation scope of state refresh messages, configure an appropriate TTL value based on the network size on the device directly connected with the multicast source.
Perform this task on all devices in the PIM-DM domain.
2.        Enter interface view.
3.        Enable the state refresh feature.
pim state-refresh-capable
By default, the state refresh feature is enabled.
4.        Return to system view.
5.        Enter PIM view.
pim
6.        Set the state refresh interval.
The default setting is 60 seconds.
Perform this task on the device directly connected to the multicast source.
7.        Set the amount of time that the device must wait to accept a new state refresh message.
state-refresh-rate-limit time
The default setting is 30 seconds.
8.        Set the TTL value of state refresh messages.
state-refresh-ttl ttl-value
The default setting is 255.
About setting the PIM-DM graft retry timer
Perform this task to adjust the interval at which the device retransmits a graft message if it does not receive a graft-ack message from the upstream device.
3.        Set the graft retry timer.
pim timer graft-retry interval
The default setting is 3 seconds.
Configuring PIM-SM
To configure PIM-SM, perform the following tasks:
1.        Enabling PIM-SM
2.        Configuring static RPs
As a best practice, configure a static RP when only one dynamic RP exists in the network.
3.        Configuring dynamic RPs
¡  Configuring C-RPs
¡  Configuring C-BSRs
¡  (Optional.) Configuring a PIM domain border
¡  (Optional.) Disabling BSM semantic fragmentation
¡  (Optional.) Disabling the device from forwarding BSMs out of their incoming interfaces
As a best practice, configure dynamic RPs when multiple PIM devices exist in the network.
You can configure static RPs, dynamic RPs, or both.
4.        (Optional.) Enabling Auto-RP listening
5.        (Optional.) Configuring Anycast RP
6.        (Optional.) Configuring multicast source registration
7.        (Optional.) Configuring the switchover to SPT
8.        (Optional.) Configuring common PIM features
Before you configure PIM-SM, complete the following tasks:
Enabling PIM-SM
About enabling PIM-SM
With PIM-SM enabled on interfaces, devices can establish PIM neighbor relationship and process PIM messages from their PIM neighbors.
As a best practice, enable PIM-SM on all non-border interfaces of devices when you deploy a PIM-SM domain.
multicast routing
5.        Enable PIM-SM.
pim sm
By default, PIM-SM is disabled.
About static RPs
If only one dynamic RP exists on a network, you can configure a static RP to avoid communication interruption caused by single-point failures. The static RP can also avoid waste of bandwidth because of frequent message exchanges between C-RPs and the BSR.
In a PIM-SM domain, you can configure the same static RP for different multicast groups by using the same RP address but different ACLs.
You do not need to enable PIM for an interface to be configured as a static RP.
If you configure multiple static RPs for a multicast group, only the static RP with the highest IP address takes effect.
The static RP configuration must be the same on all devices in the PIM-SM domain.
2.        Enter PIM view.
pim
3.        Configure a static RP.
static-rp rp-address [ ipv4-acl-number | preferred ] *
When both a static RP and a dynamically elected RP exist on the network, you can specify the preferred keyword to give priority to the static RP. The dynamic RP is used only when the static RP fails. If you do not specify the preferred keyword, the dynamic RP takes priority and the static RP is used only when the dynamic RP fails.
Configuring C-RPs
About C-RP configuration
To avoid C-RP spoofing, configure a C-RP policy to filter C-RP advertisement messages by using an ACL that specifies the packet source address range and multicast group addresses.
Configure C-RPs on devices that reside in the backbone network.
Because the RP and other devices exchange a large amount of information in the PIM-SM domain, reserve a large bandwidth between C-RPs and other devices.
You must configure the same C-RP policy on all C-BSRs in the PIM-SM domain because every C-BSR might become the BSR.
2.        Enter PIM view.
pim
3.        Configure a C-RP.
c-rp ip-address [ advertisement-interval adv-interval | group-policy ipv4-acl-number | holdtime hold-time | priority priority ] *
4.        (Optional.) Configure a C-RP policy.
crp-policy ipv4-acl-number
By default, no C-RP policies are configured. All C-RP advertisement messages are regarded as legal.
Configuring C-BSRs
About C-BSRs
You must configure C-BSRs when you configure dynamic RP election.
To prevent a legal BSR from being replaced by a malicious host, configure a BSR policy to filter BSR messages by using an ACL that specifies the legal BSR addresses. It is used to prevent the legal BSR from being replaced by a malicious host.
Configure C-BSRs on devices that reside in the backbone network.
Because the BSR and other devices exchange a large amount of information in the PIM-SM domain, reserve a large bandwidth between C-BSRs and other devices.
The C-BSR configuration on the devices in the PIM-SM domain must be the same.
For a successful RPF check, configure static multicast routes to ensure that the next hop to a C-BSR is a tunnel interface when C-BSRs connect to other PIM devices through tunnels. For more information about static multicast routes, see "Configuring multicast routing and forwarding."
2.        Enter PIM view.
pim
3.        Configure a C-BSR.
c-bsr ip-address [ scope group-address { mask-length | mask } ] [ hash-length hash-length | priority priority ] *
4.        (Optional.) Configure a BSR policy.
bsr-policy ipv4-acl-number
By default, no BSR policies are configured. All bootstrap messages are regarded as legal.
About PIM domain borders
A PIM domain border determines the transmission boundary of bootstrap messages. Bootstrap messages cannot cross the domain border in either direction. A number of PIM domain border interfaces partition a network into different PIM-SM domains.
3.        Configure a PIM domain border.
pim bsr-boundary
By default, an interface is not a PIM domain border.
About BSM semantic fragmentation
BSM semantic fragmentation enables a BSR to split a BSM into multiple BSM fragments (BSMFs) if the BSM exceeds the MTU. In this way, a non-BSR device can update the RP-set information for a group range after receiving all BSMFs for the range. The loss of one BSMF only affects the RP-set information of the group ranges that the fragment contains.
If a device does not support BSM semantic fragmentation, it regards a BSMF as a BSM and updates the RP-set information each time it receives a BSMF. It learns only part of the RP-set information, which further affects the RP election. Therefore, if such a device exists in the PIM-SM domain, you must disable BSM semantic fragmentation on all C-BSRs.
2.        Enter PIM view.
pim
3.        Disable BSM semantic fragmentation.
undo bsm-fragment enable
By default, BSM semantic fragmentation is enabled.
About disabling the device from forwarding BSMs out of their incoming interfaces
By default, the device forwards BSMs out of their incoming interfaces. This default setting ensures that all devices on the subnet can receive BSMs even when they have inconsistent routing information. However, this default setting results in duplicated multicast traffic. If you are sure that all the devices on the subnet have consistent routing information, you can disable the device from forwarding BSMs out of their incoming interfaces.
2.        Enter PIM view.
pim
3.        Disable the device from forwarding BSMs out of their incoming interfaces.
undo bsm-reflection enable
About Auto-RP listening
This feature enables the device to receive Auto-RP announcement and discovery messages and learn RP information. The destination IP addresses for Auto-RP announcement and discovery messages are 224.0.1.39 and 224.0.1.40, respectively.
2.        Enter PIM view.
pim
3.        Enable Auto-RP listening.
auto-rp enable
By default, Auto-RP listening is disabled.
To prevent the other Anycast RP member devices from discarding the BSM sent by the BSR, make sure the Anycast RP address is different from the BSR address.
As a best practice to ensure network performance, configure a maximum of 16 Anycast RP members for an Anycast RP set.
As a best practice, configure the IP address of a loopback interface as the RP member address.
If you configure IP addresses of multiple interfaces on the same device as RP member addresses, the lowest IP address takes effect. The rest of the interface addresses become backup RP member addresses.
An Anycast RP address must be a host address with subnet mask 255.255.255.255.
You must add the device where the Anycast RP resides as an RP member to the Anycast RP set.
You must configure a static RP or C-RPs in the PIM-SM domain before you configure the Anycast RP. Use the address of the static RP or the dynamically elected RP as the Anycast RP address.
2.        Enter PIM view.
pim
3.        Configure Anycast RP.
anycast-rp anycast-rp-address member-rp-address
By default, Anycast RP is not configured.
You can repeat this command to add multiple RP member addresses to the Anycast RP set.
About multicast source registration
·          PIM register policy—A PIM register policy enables an RP to filter register messages by using an ACL that specifies the multicast sources and groups. The policy limits the multicast groups to which the RP is designated. If a register message is denied by the ACL or does not match the ACL, the RP discards the register message and sends a register-stop message to the source-side DR. The registration process stops.
·          Checksum computing method for register messages—For information integrity of a register message, you can configure the device to calculate the checksum based on the entire register message. If a device cannot calculate the checksum based on the entire register message, you can configure the device to calculate the checksum based on the register message header.
·          Register suppression time—The source-side DR stops sending register messages encapsulated with IPv6 multicast data and starts a register-stop timer upon receiving a register-stop message from the RP. Before the register-stop timer expires, the DR sends a null register message (a register message without encapsulated multicast data) to the RP and starts a register probe timer. If the DR receives a register-stop message before the register probe timer expires, it resets its register-stop timer. Otherwise, the DR starts sending register messages with encapsulated data again.
The register-stop timer is set to a random value chosen uniformly from (0.5 × register_suppression_time minus register_probe_time) to (1.5 × register_suppression_time minus register_probe_time). The register_probe_time is fixed to 5 seconds. You can adjust the register suppression time.
On all C-RP devices, configure a PIM register policy and the checksum computing method for register messages.
On all devices that might become the source-side DR, set the register suppression time.
2.        Enter PIM view.
pim
3.        Configure a PIM register policy.
register-policy ipv4-acl-number
By default, no PIM register policy is configured. All PIM register messages are regarded as legal.
4.        Configure the device to calculate the checksum based on the entire register message.
register-whole-checksum
By default, the device calculates the checksum based on the header of a register message.
5.        Set the register suppression time.
Some devices cannot encapsulate multicast data in register messages destined to the RP. As a best practice to avoid multicast data forwarding failures, do not disable the switchover to SPT on C-RPs that might become the RP.
2.        Enter PIM view.
pim
3.        Configure RPT to SPT switchover.
spt-switch-threshold { immediacy | infinity } [ group-policy ipv4-acl-number ]
By default, the first multicast data packet triggers the RPT to SPT switchover.
Configuring PIM-SSM
To configure PIM-SSM, perform the following tasks:
1.        Enabling PIM-SM
2.        (Optional.) Configuring the SSM group range
3.        (Optional.) Configuring common PIM features
Before you configure PIM-SSM, complete the following tasks:
·          Enable PIM-SM.
·          Enable IGMPv3 on PIM devices that connect to multicast receivers.
Enabling PIM-SM
As a best practice, enable IPv6 PIM-SM on all non-border interfaces of devices when you deploy an IPv6 PIM-SSM domain.
2.        Enable multicast routing and enter MRIB view.
multicast routing
By default, multicast routing is disabled.
5.        Enable PIM-SM.
pim sm
About the SSM-group range
When a PIM-SM enabled interface receives a multicast packet, it checks whether the multicast group address of the packet is in the SSM group range. If the multicast group address is in this range, the PIM mode for this packet is PIM-SSM. If the multicast group address is not in this range, the PIM mode is PIM-SM.
Configure the same SSM group range on all devices in the entire PIM-SSM domain. Otherwise, multicast information cannot be delivered through the SSM model.
When a member of a multicast group in the SSM group range sends an IGMPv1 or IGMPv2 report message, the device does not trigger a (*, G) join.
2.        Enter PIM view.
pim
3.        Configure the SSM group range.
ssm-policy ipv4-acl-number
By default, the SSM group range is 232.0.0.0/8.
All the following tasks are optional.
·          Configuring a multicast source policy
·          Configuring a PIM hello policy
·          Configuring PIM hello message options
·          Dropping hello messages without the Generation ID option
·          Configuring common PIM timers
·          Setting the maximum size of a join or prune message
·          Setting the DSCP value for outgoing PIM protocol packets
·          Enabling BFD for PIM
·          Enabling PIM passive mode
·          Enabling PIM NSR
·          Enabling SNMP notifications for PIM
About multicast source policies
This feature enables the device to filter multicast data by using an ACL that specifies the multicast sources and the optional groups. It filters not only data packets but also register messages with multicast data encapsulated. It controls the information available to downstream receivers.
2.        Enter PIM view.
pim
3.        Configure a multicast source policy.
source-policy ipv4-acl-number
By default, no multicast source policy is configured. The device does not filter multicast data packets.
About PIM hello policies
This feature enables the device to filter PIM hello messages by using an ACL that specifies the packet source addresses. It is used to guard against PIM message attacks and to establish correct PIM neighboring relationships.
If hello messages of an existing PIM neighbor are filtered out by the policy, the neighbor is automatically removed when its aging timer expires.
3.        Configure a PIM hello policy.
pim neighbor-policy ipv4-acl-number
By default, no PIM hello policy is configured on an interface. All PIM hello messages are regarded as legal.
About PIM hello message options
In either a PIM-DM domain or a PIM-SM domain, hello messages exchanged among devices contain the following configurable options:
·          DR_Priority (for PIM-SM only)—Priority for DR election. The device with the highest priority wins the DR election. You can configure this option for all the devices in a shared-media LAN that directly connects to the multicast source or the receivers.
·          Holdtime—PIM neighbor lifetime. If a device does not receive a hello message from a neighbor when the neighbor lifetime expires, it regards the neighbor failed or unreachable.
·          LAN_Prune_Delay—Delay of pruning a downstream interface on a shared-media LAN. This option has the LAN delay field, the override interval field, and the T bit.
The LAN delay defines the PIM message propagation delay. The override interval defines a period for a device to override a prune message. The T bit specifies the capability of tracking downstream device status on upstream devices.
On the shared-media LAN, the propagation delay and override interval are used as follows:
¡  If a device receives a prune message on its upstream interface, it means that there are downstream devices on the shared-media LAN. If this device still needs to receive multicast data, it must send a join message to override the prune message within the override interval.
¡  When a device receives a prune message from its downstream interface, it does not immediately prune this interface. Instead, it starts a timer (the propagation delay plus the override interval). If interface receives a join message before the timer expires, the device does not prune the interface. Otherwise, the device prunes the interface.
·          Neighbor tracking—If you enable neighbor tracking on an upstream device, this device can track the states of the downstream nodes for which the joined state holdtime timer has not expired. All join messages from downstream devices are accepted.
If the propagation delay or override interval on different PIM devices on a shared-media LAN are different, the largest ones apply.
If you want to enable neighbor tracking, you must enable it on all PIM devices on a shared-media LAN. Otherwise, the upstream device cannot track join messages from every downstream devices.
You can configure hello message options for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
Configuring hello message options globally
2.        Enter PIM view.
pim
3.        Set the DR priority.
The default setting is 1.
4.        Set the neighbor lifetime.
hello-option holdtime time
The default setting is 105 seconds.
5.        Set the PIM message propagation delay for a shared-media LAN.
hello-option lan-delay delay
The default setting is 500 milliseconds.
6.        Set the override interval.
The default setting is 2500 milliseconds.
7.        Enable neighbor tracking.
hello-option neighbor-tracking
By default, neighbor tracking is disabled.
Configuring hello message options on an interface
pim hello-option dr-priority priority
pim hello-option holdtime time
5.        Set the PIM message propagation delay.
pim hello-option lan-delay delay
pim hello-option override-interval interval
pim hello-option neighbor-tracking
About dropping hello messages without the Generation ID option
A device generates a generation ID for hello messages when an interface is enabled with PIM. The generation ID is a random value, but it changes only when the status of the device changes. If a PIM device finds that the generation ID in a hello message from the upstream device has changed, it assumes that the status of the upstream device has changed. In this case, it sends a join message to the upstream device for status update. You can configure an interface to drop hello messages without the generation ID options to promptly know the status of an upstream device.
3.        Enable the interface to drop hello messages without the Generation ID option.
pim require-genid
By default, an interface accepts hello messages without the Generation ID option.
About common PIM timers
The following are common PIM timers:
·          Hello interval—Interval at which a PIM device sends hello messages to discover PIM neighbors, and maintain PIM neighbor relationship.
·          Triggered hello delay—Maximum delay for sending a hello message to avoid collisions caused by simultaneous hello messages. After receiving a hello message, a PIM device waits for a random time before sending a hello message. This random time is in the range of 0 to the triggered hello delay.
·          Join/Prune interval—Interval at which a PIM device sends join/prune messages to its upstream devices for state update.
·          Joined/Pruned state holdtime—Time for which a PIM device keeps the joined/pruned state for the downstream interfaces. This joined/pruned state holdtime is specified in a join/prune message.
·          Multicast source lifetime—Lifetime that a PIM device maintains for a multicast source. If a device does not receive subsequent multicast data from the multicast source S when the timer expires, it deletes the (S, G) entry for the multicast source.
To prevent upstream neighbors from aging out, set the join/prune interval to be less than the join/pruned state holdtime.
You can configure common PIM timers for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
As a best practice, use the defaults for a network without special requirements.
Configuring common PIM timers globally
2.        Enter PIM view.
pim
3.        Set the hello interval.
timer hello interval
4.        Set the join/prune interval.
timer join-prune interval
This configuration takes effect after the current interval ends.
5.        Set the joined/pruned state holdtime.
holdtime join-prune time
The default setting is 210 seconds.
6.        Set the multicast source lifetime.
source-lifetime time
Configuring common PIM timers on an interface
pim timer hello interval
4.        Set the triggered hello delay.
pim triggered-hello-delay delay
The default setting is 5 seconds.
5.        Set the join/prune interval.
pim timer join-prune interval
6.        Set the joined/pruned state holdtime.
pim holdtime join-prune time
About setting the maximum size of a join or prune message
The loss of an oversized join or prune message might result in loss of massive information. You can set a small value for the size of a join or prune message to reduce the impact.
2.        Enter PIM view.
pim
3.        Set the maximum size of a join or prune message.
jp-pkt-size size
The default setting is 1200 bytes.
About the DSCP value for outgoing PIM protocol packets
The DSCP value determines the packet transmission priority. A greater DSCP value represents a higher priority.
2.        Enter PIM view.
pim
3.        Set the DSCP value for outgoing PIM protocol packets.
dscp dscp-value
By default, the DSCP value is 48 for outgoing PIM protocol packets.
About enabling BFD for PIM
If a DR on a shared-media network fails, a new DR election process does not start until the DR ages out. In addition, it might take a long period of time before other devices detect the link failures and trigger a new DR election. To start a new DR election process immediately after the original DR fails, enable BFD for PIM to detect link failures among PIM neighbors.
You must enable BFD for PIM on all PIM devices on a shared-media network. For more information about BFD, see High Availability Configuration Guide.
3.        Enable BFD for PIM.
pim bfd enable
By default, BFD is disabled for PIM.
About PIM passive mode
To guard against PIM hello spoofing, you can enable PIM passive mode on a receiver-side interface. The PIM passive interface cannot receive or forward PIM protocol messages (excluding register, register-stop, and C-RP-Adv messages), and it acts as the DR on the subnet. In BIDIR-PIM, it also acts as the DF.
To avoid duplicate multicast data transmission and flow loop, do not enable this feature on a shared-media LAN with multiple PIM devices.
3.        Enable PIM passive mode on the interface.
pim passive
By default, PIM passive mode is disabled on an interface.
Enabling PIM NSR
About PIM NSR
This feature enables PIM to back up protocol state information and data, including PIM neighbor information and routes, from the active process to the standby process. The standby process immediately takes over when the active process fails. Use this feature to avoid route flapping and forwarding interruption for PIM when an active/standby switchover occurs.
2.        Enable PIM NSR.
pim non-stop-routing
By default, PIM NSR is disabled.
About SNMP notifications for PIM
To report critical PIM events to an NMS, enable SNMP notifications for PIM. For PIM event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
2.        Enable SNMP notifications for PIM.
snmp-agent trap enable pim [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
By default, SNMP notifications for PIM are enabled.
Display register-tunnel interface information.
display interface [ register-tunnel [ interface-number ] ] [ brief [ description | down ] ]
Display BSR information in the PIM-SM domain.
display pim bsr-info
Display information about the routes used by PIM.
display pim claimed-route [ source-address ]
Display C-RP information in the PIM-SM domain.
display pim c-rp [ local ]
Display PIM information on an interface.
display pim interface [ interface-type interface-number ] [ verbose ]
Display PIM neighbor information.
display pim neighbor [ neighbor-address | interface interface-type interface-number | verbose ] *
Display PIM routing entries.
display pim routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number | proxy ] *
Display RP information in the PIM-SM domain.
display pim rp-info [ group-address ]
Display statistics for PIM packets.
display pim statistics
As shown in Figure 12:
·          OSPF runs on the network.
·          VOD streams are sent to receiver hosts in multicast. The receiver groups of different organizations form stub networks, and one or more receiver hosts exist on each stub network.
·          The entire PIM domain operates in the dense mode.
·          Host A and Host C are multicast receivers on two stub networks.
·          IGMPv2 runs between Switch A and N1, and between Switch B, Switch C, and N2.
Figure 12 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
10.110.1.1/24
Switch C
Vlan-int102
192.168.3.1/24
Switch A
Vlan-int103
192.168.1.1/24
Switch D
Vlan-int300
10.110.5.1/24
Switch B
Vlan-int200
10.110.2.1/24
Switch D
Vlan-int103
192.168.1.2/24
Switch B
Vlan-int101
192.168.2.1/24
Switch D
Vlan-int101
192.168.2.2/24
Switch C
Vlan-int200
10.110.2.2/24
Switch D
Vlan-int102
192.168.3.2/24
1.        Assign an IP address and subnet mask for each interface, as shown in Figure 12. (Details not shown.)
2.        Configure OSPF on the switches in the PIM-DM domain. (Details not shown.)
3.        Enable IP multicast routing, IGMP, and PIM-DM:
# On Switch A, enable IP multicast routing.
[SwitchA] multicast routing
[SwitchA-mrib] quit
# Enable IGMP on VLAN-interface 100 (the interface that connects to the stub network).
[SwitchA-Vlan-interface100] igmp enable
# Enable PIM-DM on VLAN-interface 103.
# Enable IP multicast routing, IGMP, and PIM-DM on Switch B and Switch C in the same way Switch A is configured. (Details not shown.)
# On Switch D, enable IP multicast routing, and enable PIM-DM on each interface.
<SwitchD> system-view
[SwitchD] multicast routing
[SwitchD-mrib] quit
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] pim dm
[SwitchD-Vlan-interface300] quit
[SwitchD-Vlan-interface103] pim dm
[SwitchD] interface vlan-interface 101
[SwitchD-Vlan-interface101] pim dm
[SwitchD-Vlan-interface101] quit
[SwitchD] interface vlan-interface 102
[SwitchD-Vlan-interface102] pim dm
[SwitchD-Vlan-interface102] quit
# Display PIM information on Switch D.
[SwitchD] display pim interface
 Interface           NbrCnt HelloInt   DR-Pri     DR-Address
 Vlan300             0      30         1          10.110.5.1     (local)
 Vlan103             1      30         1          192.168.1.2    (local)
 Vlan101             1      30         1          192.168.2.2    (local)
 Vlan102             1      30         1          192.168.3.2    (local)
# Display PIM neighboring relationships on Switch D.
[SwitchD] display pim neighbor
 Total Number of Neighbors = 3
 Neighbor        Interface           Uptime   Expires  Dr-Priority Mode
 192.168.1.1     Vlan103             00:02:22 00:01:27 1
 192.168.2.1     Vlan101             00:00:22 00:01:29 3
 192.168.3.1     Vlan102             00:00:23 00:01:31 5
# Send an IGMP report from Host A to join multicast group 225.1.1.1. (Details not shown.)
# Send multicast data from multicast source 10.110.5.100/24 to multicast group 225.1.1.1. (Details not shown.)
# Display PIM routing entries on Switch A.
[SwitchA] display pim routing-table
 (*, 225.1.1.1)
     Protocol: pim-dm, Flag: WC
     UpTime: 00:04:25
     Upstream interface: NULL
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: Vlan-interface100
             Protocol: igmp, UpTime: 00:04:25, Expires: -
 (10.110.5.100, 225.1.1.1)
     Protocol: pim-dm, Flag: ACT
     UpTime: 00:06:14
         Upstream neighbor: 192.168.1.2
         RPF prime neighbor: 192.168.1.2
             Protocol: pim-dm, UpTime: 00:04:25, Expires: -
# Display PIM routing entries on Switch D.
[SwitchD] display pim routing-table
     UpTime: 00:03:27
     Upstream interface: Vlan-interface300
     Total number of downstreams: 2
         1: Vlan-interface103
             Protocol: pim-dm, UpTime: 00:03:27, Expires: -
         2: Vlan-interface102
·          Switches on the SPT path (Switch A and Switch D) have the correct (S, G) entries.
·          Switch A has the correct (*, G) entry.
As shown in Figure 13:
·          VOD streams are sent to receiver hosts in multicast. The receivers of different subnets form stub networks, and a minimum of one receiver host exist on each stub network.
·          The entire PIM-SM domain contains only one BSR.
·          Host A and Host C are multicast receivers on two stub networks N1 and N2.
·          Specify VLAN-interface 102 on Switch E as a C-BSR and a C-RP. The C-RP is designated to multicast group range 225.1.1.0/24. Specify VLAN-interface 101 of Switch D as the static RP on all the switches to back up the dynamic RP.
Figure 13 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
10.110.1.1/24
Switch D
Vlan-int300
10.110.5.1/24
Switch A
Vlan-int101
192.168.1.1/24
Switch D
Vlan-int101
192.168.1.2/24
Switch A
Vlan-int102
192.168.9.1/24
Switch D
Vlan-int105
192.168.4.2/24
Switch B
Vlan-int200
10.110.2.1/24
Switch E
Vlan-int104
192.168.3.2/24
Switch B
Vlan-int103
192.168.2.1/24
Switch E
Vlan-int103
192.168.2.2/24
Switch C
Vlan-int200
10.110.2.2/24
Switch E
Vlan-int102
192.168.9.2/24
Switch C
Vlan-int104
192.168.3.1/24
Switch E
Vlan-int105
192.168.4.1/24
1.        Assign an IP address and subnet mask to each interface, as shown in Figure 13. (Details not shown.)
2.        Configure OSPF on all switches in the PIM-SM domain. (Details not shown.)
3.        Enable IP multicast routing, and enable IGMP and PIM-SM:
[SwitchA-mrib] quit
# Enable PIM-SM on the other interfaces.
[SwitchA-Vlan-interface102] pim sm
# Enable IP multicast routing, IGMP, and PIM-SM on Switch B and Switch C in the same way Switch A is configured. (Details not shown.)
# Enable IP multicast routing and PIM-SM on Switch D and Switch E in the same way Switch A is configured. (Details not shown.)
4.        Configure C-BSRs, C-RPs, and the static RP:
# On Switch E, configure the service scope of RP advertisements.
<SwitchE> system-view
[SwitchE] acl basic 2005
[SwitchE-acl-ipv4-basic-2005] rule permit source 225.1.1.0 0.0.0.255
[SwitchE-acl-ipv4-basic-2005] quit
# Configure VLAN-interface 102 as a C-BSR and a C-RP.
[SwitchE] pim
[SwitchE-pim] c-bsr 192.168.9.2
[SwitchE-pim] c-rp 192.168.9.2 group-policy 2005
# Configure VLAN-interface 101 of Switch D as the static RP.
[SwitchE-pim] static-rp 192.168.1.2
[SwitchE-pim] quit
# On Switch A, configure VLAN-interface 101 of Switch D as the static RP.
[SwitchA] pim
[SwitchA-pim] static-rp 192.168.1.2
[SwitchA-pim] quit
# Configure the static RP on Switch B, Switch C, and Switch D in the same way Switch A is configured. (Details not shown.)
# Display PIM information on Switch A.
[SwitchA] display pim interface
 Vlan101             1      30         1          192.168.1.2
 Vlan102             1      30         1          192.168.9.2
# Display BSR information on Switch A.
[SwitchA] display pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:01:44
     Elected BSR address: 192.168.9.2
       Priority: 64
       Hash mask length: 30
       Uptime: 00:11:18
# Display BSR information on Switch E.
[SwitchE] display pim bsr-info
 Scope: non-scoped
     State: Elected
       Priority: 64
       Uptime: 00:11:18
     Candidate BSR address: 192.168.9.2
       Priority: 64
# Display RP information on Switch A.
[SwitchA] display pim rp-info
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: 225.1.1.0/24
       RP address               Priority  HoldTime  Uptime    Expires
       192.168.9.2              192       180       00:51:45  00:02:22
Static RP information:
       RP address               ACL   Mode    Preferred
       192.168.1.2              ----  pim-sm  No
Example: Configuring admin-scoped PIM-SM
As shown in Figure 14:
·          VOD streams are sent to receiver hosts in multicast. The entire PIM-SM domain is divided into admin-scoped zone 1, admin-scoped zone 2, and the global-scoped zone. Switch B, Switch C, and Switch D are ZBRs of the three zones, respectively.
·          Source 1 and Source 2 send different multicast data to the multicast group 239.1.1.1. Host A receives the multicast data only from Source 1, and Host B receives the multicast data only from Source 2. Source 3 sends multicast data to multicast group 224.1.1.1. Host C is a multicast receiver for the multicast group 224.1.1.1.
·          VLAN-interface 101 of Switch B acts as a C-BSR and a C-RP for admin-scoped zone 1, and VLAN-interface 105 of Switch D acts as a C-BSR and a C-RP for admin-scoped zone 2. Both of the two interfaces are designated to multicast group range 239.0.0.0/8. VLAN-interface 109 of Switch F acts as a C-BSR and a C-RP for the global-scoped zone, and is designated to all the multicast groups that are not in the range 239.0.0.0/8.
·          IGMPv2 runs between Switch A, Switch E, Switch I, and the receivers that directly connect to them, respectively.
Figure 14 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int100
192.168.1.1/24
Switch D
Vlan-int105
10.110.5.2/24
Switch A
Vlan-int101
10.110.1.1/24
Switch D
Vlan-int108
10.110.7.1/24
Switch B
Vlan-int200
192.168.2.1/24
Switch D
Vlan-int107
10.110.8.1/24
Switch B
Vlan-int101
10.110.1.2/24
Switch E
Vlan-int400
192.168.4.1/24
Switch B
Vlan-int103
10.110.2.1/24
Switch E
Vlan-int104
10.110.4.2/24
Switch B
Vlan-int102
10.110.3.1/24
Switch E
Vlan-int108
10.110.7.2/24
Switch C
Vlan-int300
192.168.3.1/24
Switch F
Vlan-int109
10.110.9.1/24
Switch C
Vlan-int104
10.110.4.1/24
Switch F
Vlan-int107
10.110.8.2/24
Switch C
Vlan-int105
10.110.5.1/24
Switch F
Vlan-int102
10.110.3.2/24
Switch C
Vlan-int103
10.110.2.2/24
Switch G
Vlan-int500
192.168.5.1/24
Switch C
Vlan-int106
10.110.6.1/24
Switch G
Vlan-int109
10.110.9.2/24
Switch H
Vlan-int110
10.110.10.1/24
Source 1
192.168.2.10/24
Switch H
Vlan-int106
10.110.6.2/24
Source 2
192.168.3.10/24
Switch I
Vlan-int600
192.168.6.1/24
Source 3
192.168.5.10/24
Switch I
Vlan-int110
10.110.10.2/24
1.        Assign an IP address and subnet mask to each interface, as shown in Figure 14. (Details not shown.)
[SwitchA-mrib] quit
# Enable IGMP on the receiver-side interface (VLAN-interface 100).
# Enable PIM-SM on VLAN-interface 101.
# Enable IP multicast routing, IGMP, and PIM-SM on Switch E and Switch I in the same way Switch A is configured. (Details not shown.)
# On Switch B, enable IP multicast routing, and enable PIM-SM on each interface.
[SwitchB] multicast routing
[SwitchB-mrib] quit
[SwitchB-Vlan-interface200] pim sm
[SwitchB-Vlan-interface101] pim sm
[SwitchB-Vlan-interface102] pim sm
[SwitchB] interface vlan-interface 103
[SwitchB-Vlan-interface103] pim sm
[SwitchB-Vlan-interface103] quit
# Enable IP multicast routing and PIM-SM on Switch C, Switch D, Switch F, Switch G, and Switch H in the same way Switch B is configured. (Details not shown.)
4.        Configure admin-scoped zone boundaries:
# On Switch B, configure VLAN-interface 102 and VLAN-interface 103 as the boundaries of admin-scoped zone 1.
[SwitchB-Vlan-interface102] multicast boundary 239.0.0.0 8
[SwitchB-Vlan-interface103] multicast boundary 239.0.0.0 8
# On Switch C, configure VLAN-interface 103 and VLAN-interface 106 as the boundaries of admin-scoped zone 2.
[SwitchC] interface vlan-interface 103
[SwitchC-Vlan-interface103] multicast boundary 239.0.0.0 8
[SwitchC-Vlan-interface103] quit
[SwitchC] interface vlan-interface 106
[SwitchC-Vlan-interface106] multicast boundary 239.0.0.0 8
[SwitchC-Vlan-interface106] quit
# On Switch D, configure VLAN-interface 107 as the boundary of admin-scoped zone 2.
[SwitchD] interface vlan-interface 107
[SwitchD-Vlan-interface107] multicast boundary 239.0.0.0 8
[SwitchD-Vlan-interface107] quit
5.        Configure C-BSRs and C-RPs:
# On Switch B, configure the service scope of RP advertisements.
[SwitchB] acl basic 2001
[SwitchB-acl-ipv4-basic-2001] rule permit source 239.0.0.0 0.255.255.255
[SwitchB-acl-ipv4-basic-2001] quit
# Configure VLAN-interface 101 as a C-BSR and a C-RP for admin-scoped zone 1.
[SwitchB] pim
[SwitchB-pim] c-bsr 10.110.1.2 scope 239.0.0.0 8
[SwitchB-pim] c-rp 10.110.1.2 group-policy 2001
[SwitchB-pim] quit
# On Switch D, configure the service scope of RP advertisements.
[SwitchD] acl basic 2001
[SwitchD-acl-ipv4-basic-2001] rule permit source 239.0.0.0 0.255.255.255
[SwitchD-acl-ipv4-basic-2001] quit
# Configure VLAN-interface 105 as a C-BSR and a C-RP for admin-scoped zone 2.
[SwitchD] pim
[SwitchD-pim] c-bsr 10.110.5.2 scope 239.0.0.0 8
[SwitchD-pim] c-rp 10.110.5.2 group-policy 2001
[SwitchD-pim] quit
# On Switch F, configure VLAN-interface 109 as a C-BSR and a C-RP for the global-scoped zone.
<SwitchF> system-view
[SwitchF] pim
[SwitchF-pim] c-bsr 10.110.9.1
[SwitchF-pim] c-rp 10.110.9.1
[SwitchF-pim] quit
# Display BSR information on Switch B.
[SwitchB] display pim bsr-info
 Scope: non-scoped
     Elected BSR address: 10.110.9.1
       Priority: 64
       Uptime: 00:01:45
 Scope: 239.0.0.0/8
     State: Elected
     Bootstrap timer: 00:00:06
     Elected BSR address: 10.110.1.2
       Priority: 64
       Uptime: 00:04:54
     Candidate BSR address: 10.110.1.2
       Priority: 64
# Display BSR information on Switch D.
[SwitchD] display pim bsr-info
 Scope: non-scoped
       Priority: 64
       Uptime: 00:01:45
 Scope: 239.0.0.0/8
     State: Elected
     Bootstrap timer: 00:01:12
     Elected BSR address: 10.110.5.2
       Priority: 64
       Uptime: 00:03:48
     Candidate BSR address: 10.110.5.2
       Priority: 64
# Display BSR information on Switch F.
[SwitchF] display pim bsr-info
 Scope: non-scoped
     State: Elected
     Bootstrap timer: 00:00:49
       Priority: 64
       Uptime: 00:11:11
     Candidate BSR address: 10.110.9.1
       Priority: 64
# Display RP information on Switch B.
[SwitchB] display pim rp-info
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: 224.0.0.0/4
       10.110.9.1               192       180       00:03:39  00:01:51
   Scope: 239.0.0.0/8
     Group/MaskLen: 239.0.0.0/8
       10.110.1.2 (local)       192       180       00:07:44  00:01:51
# Display RP information on Switch D.
[SwitchD] display pim rp-info
 BSR RP information:
   Scope: non-scoped
       10.110.9.1               192       180       00:03:42  00:01:48
   Scope: 239.0.0.0/8
       10.110.5.2 (local)       192       180       00:06:54  00:02:41
# Display RP information on Switch F.
[SwitchF] display pim rp-info
 BSR RP information:
   Scope: non-scoped
       10.110.9.1 (local)       192       180       00:00:32  00:01:58
Example: Configuring PIM-SSM
As shown in Figure 15:
·          The receivers receive VOD information through multicast. The receiver groups of different organizations form stub networks, and one or more receiver hosts exist on each stub network.
·          The entire PIM domain operates in the SSM mode.
·          The SSM group range is 232.1.1.0/24.
·          IGMPv3 runs between Switch A and N1, and between Switch B, Switch C, and N2.
Figure 15 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int100
10.110.1.1/24
Switch D
Vlan-int300
10.110.5.1/24
Switch A
Vlan-int101
192.168.1.1/24
Switch D
Vlan-int101
192.168.1.2/24
Switch A
Vlan-int102
192.168.9.1/24
Switch D
Vlan-int105
192.168.4.2/24
Switch B
Vlan-int200
10.110.2.1/24
Switch E
Vlan-int104
192.168.3.2/24
Switch B
Vlan-int103
192.168.2.1/24
Switch E
Vlan-int103
192.168.2.2/24
Switch C
Vlan-int200
10.110.2.2/24
Switch E
Vlan-int102
192.168.9.2/24
Switch C
Vlan-int104
192.168.3.1/24
Switch E
Vlan-int105
192.168.4.1/24
1.        Assign an IP address and subnet mask to each interface, as shown in Figure 15. (Details not shown.)
2.        Configure OSPF on the switches in the PIM-SSM domain. (Details not shown.)
3.        Enable IP multicast routing, IGMP, and PIM-SM:
[SwitchA-mrib] quit
# Enable IGMPv3 on VLAN-interface 100 (the interface that connects to the stub network).
[SwitchA-Vlan-interface100] igmp version 3
4.        Configure the SSM group range:
# Configure the SSM group range 232.1.1.0/24 on Switch A.
[SwitchA] acl basic 2000
[SwitchA-acl-ipv4-basic-2000] rule permit source 232.1.1.0 0.0.0.255
[SwitchA] pim
[SwitchA-pim] ssm-policy 2000
[SwitchA-pim] quit
# Configure the SSM group range on Switch B, Switch C, Switch D and Switch E in the same way Switch A is configured. (Details not shown.)
# Send an IGMPv3 report from Host A to join the multicast source and group (10.110.5.100/24, 232.1.1.1). (Details not shown.)
# Display the PIM routing table on Switch A.
 (10.110.5.100, 232.1.1.1)
     Protocol: pim-ssm, Flag: ACT
     UpTime: 00:13:25
     Upstream interface: Vlan-interface101
             Protocol: igmp, UpTime: 00:13:25, Expires: 00:03:25
# Display the PIM routing table on Switch D.
     Protocol: pim-ssm, Flag: LOC
     UpTime: 00:12:05
         1: Vlan-interface105
             Protocol: pim-ssm, UpTime: 00:12:05, Expires: 00:03:25
The output shows that switches on the SPT path (Switch A and Switch D) have generated the correct (S, G) entries.
Troubleshooting PIM
A multicast distribution tree cannot be correctly built
Symptom
No multicast forwarding entries are established on the devices (including devices directly connected with multicast sources or receivers) in a PIM network. This means that a multicast distribution tree cannot be built correctly.
Solution
To resolve the problem:
1.        Use display ip routing-table to verify that a unicast route to the multicast source or the RP is available.
2.        Use display pim interface to verify PIM information on each interface, especially on the RPF interface. If PIM is not enabled on the interfaces, use pim dm or pim sm to enable PIM-DM or PIM-SM for the interfaces.
3.        Use display pim neighbor to verify that the RPF neighbor is a PIM neighbor.
4.        Verify that PIM and IGMP are enabled on the interfaces that directly connect to the multicast sources or the receivers.
5.        Use display pim interface verbose to verify that the same PIM mode is enabled on the RPF interface on a device and the connected interface of the device's RPF neighbor.
6.        Use display current-configuration to verify that the same PIM mode is enabled on all devices. For PIM-SM, verify that the BSR and C-RPs are correctly configured.
7.        If the problem persists, contact H3C Support.
Multicast data is abnormally terminated on an intermediate device
Symptom
An intermediate device can receive multicast data successfully, but the data cannot reach the last-hop device. An interface on the intermediate device receives multicast data but does not create an (S, G) entry in the PIM routing table.
Solution
1.        Use display current-configuration to verify the multicast forwarding boundary settings. Use multicast boundary to change the multicast forwarding boundary settings to make the multicast packet able to cross the boundary.
2.        Use display current-configuration to verify the multicast source policy. Change the ACL rule defined in the source-policy command so that the source/group address of the multicast data can pass ACL filtering.
3.        If the problem persists, contact H3C Support.
An RP cannot join an SPT in PIM-SM
Symptom
An RPT cannot be correctly built, or an RP cannot join the SPT toward the multicast source.
Solution
1.        Use display ip routing-table to verify that a unicast route to the RP is available on each device.
2.        Use display pim rp-info to verify that the dynamic RP information is consistent on all devices.
3.        Use display pim rp-info to verify that the same static RPs are configured on all devices on the network.
4.        If the problem persists, contact H3C Support.
An RPT cannot be built or multicast source registration fails in PIM-SM
Symptom
The C-RPs cannot unicast advertisement messages to the BSR. The BSR does not advertise BSMs containing C-RP information and has no unicast route to any C-RP. An RPT cannot be correctly established, or the source-side DR cannot register the multicast source with the RP.
Solution
1.        Use display ip routing-table on each device to view routing table information. Verify that unicast routes to the C-RPs and the BSR are available on each device and that a route is available between each C-RP and the BSR.
2.        Use display pim bsr-info to verify that the BSR information exists on each device.
3.        Use display pim rp-info to verify that the RP information is correct on each device.
4.        Use display pim neighbor to verify that PIM neighboring relationship has been correctly established among the devices.
5.        If the problem persists, contact H3C Support.
