07-ACL and QoS Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5130S-HI[EI]&S5110V2&S3100V3-EI Switch Series Command References-R612x-6W10307-ACL and QoS Command Reference
02-QoS commands
02-QoS commands 221.41 KB
QoS policy commands· 1
Traffic class commands· 1
description· 1
display traffic classifier 1
if-match· 2
traffic classifier 5
Traffic behavior commands· 6
accounting· 6
car 6
display traffic behavior 8
filter 9
nest top-most 10
redirect 10
remark dot1p· 11
remark dscp· 12
remark local-precedence· 13
remark service-vlan-id· 14
traffic behavior 15
QoS policy commands· 15
classifier behavior 15
display qos policy· 16
display qos policy global 17
display qos policy interface· 19
display qos policy user-profile· 21
display qos vlan-policy· 23
qos apply policy (interface view) 24
qos apply policy (user profile view) 25
qos apply policy global 25
qos policy· 26
qos vlan-policy· 27
reset qos policy global 27
reset qos vlan-policy· 28
Priority mapping commands· 29
Priority map commands· 29
display qos map-table· 29
import 30
qos map-table· 30
Priority trust mode commands· 31
display qos trust interface· 31
qos trust 32
Port priority commands· 32
qos priority· 32
GTS and rate limit commands· 34
GTS commands· 34
display qos gts interface· 34
qos gts· 34
Rate limit commands· 35
display qos lr interface· 35
qos lr 36
Congestion management commands· 38
Common commands· 38
display qos queue interface· 38
SP commands· 39
display qos queue sp interface· 39
qos sp· 39
WRR commands· 40
display qos queue wrr interface· 40
qos wrr 41
qos wrr weight 41
qos wrr group sp· 42
Queue scheduling profile commands· 43
display qos qmprofile configuration· 43
display qos qmprofile interface· 45
qos apply qmprofile· 45
qos qmprofile· 46
queue· 47
Queue-based accounting commands· 48
display qos queue-statistics interface outbound· 48
Aggregate CAR commands· 50
car name· 50
display qos car name· 50
qos car 51
reset qos car name· 53
QoS policy commands
description
Use description to configure a description for a traffic class.
No description is configured for a traffic class.
Traffic class view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as classifier for traffic class class1.
[Sysname-classifier-class1] description classifier
Use display traffic classifier to display traffic classes.
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the traffic classes for the master device.
# Display all user-defined traffic classes.
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
Classifier
Traffic class name and its match criteria.
Operator
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria.
Rule(s)
Match criteria.
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option
acl [ ipv6 | mac ] { acl-number | name acl-name }
Matches an ACL.
The value range for the acl-number argument is as follows:
·         2000 to 3999 for IPv4 ACLs.
·         2000 to 3999 for IPv6 ACLs.
·         4000 to 4999 for Layer 2 MAC ACLs.
The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all.
any
Matches all packets.
destination-mac mac-address
Matches a destination MAC address.
This option takes effect only on Ethernet interfaces.
dscp dscp-value&<1-8>
Matches DSCP values.
The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 4.
protocol protocol-name
Matches a protocol.
The protocol-name argument can be ip or ipv6.
service-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in outer VLAN tags.
The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
service-vlan-id vlan-id-list
Matches VLAN IDs in outer VLAN tags.
The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
You can use this option to match single-tagged packets.
source-mac mac-address
Matches a source MAC address.
In a traffic class with the logical OR operator, you can configure multiple if match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
·          You can specify up to eight values for any of the following match criteria in one if-match command:
¡  802.1p priority.
¡  DSCP.
¡  VLAN ID.
·          If a packet matches one of the specified values, it matches the if-match command.
·          To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
When you configure ACL-based match criteria, follow these restrictions and guidelines:
·          The ACL must already exist.
·          The ACL is used for classification only and the permit/deny actions in ACL rules are ignored. Actions taken on matching packets are defined in traffic behaviors.
You can use both AND and OR operators to define the match relationships between the criteria for a class. For example, you can define relationships among three match criteria in traffic class classA as follows:
traffic classifier classB operator and
if-match criterion 1
if-match criterion 2
traffic classifier classA operator or
if-match criterion 3
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to restore the default.
accounting { byte | packet }
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in the range of 8 to 160000000 kbps, in increments of 8.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the peak information rate (PIR) in the range of 8 to 160000000 kbps, in increments of 8.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
·          discard: Drops the packet.
·          pass: Permits the packet to pass through.
·          remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
·          remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63.
·          remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database.
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
Use display traffic behavior to display traffic behaviors.
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the traffic behaviors for the master device.
# Display all user-defined traffic behaviors.
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Redirecting:
        Redirect to the CPU
    Behavior: 3 (ID 102)
      -none-
Behavior
Name and contents of a traffic behavior.
Marking
Information about priority marking.
Remark dscp
Action of setting the DSCP value for packets.
Information about the CAR action.
Green action
Action to take on green packets.
Yellow action
Action to take on yellow packets.
Red action
Action to take on red packets.
Accounting enable
Class-based accounting action.
Filter enable
Traffic filtering action.
Redirecting
Information about traffic redirecting.
Mirroring
Information about traffic mirroring.
none
No other traffic behavior is configured.
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets.
# Configure a traffic filtering action as deny in traffic behavior database.
nest top-most
Use nest top-most to configure an outer VLAN tag adding action in a traffic behavior.
Use undo nest top-most to restore the default.
nest top-most vlan vlan-id
undo nest top-most
No outer VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the VLAN ID to be added in the outer VLAN tag, in the range of 1 to 4094.
If a QoS policy contains an outer VLAN tag adding action, apply it only to the incoming traffic of an interface.
If you execute the nest top-most command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior b1 to add an outer VLAN tag with VLAN ID 123.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to restore the default.
redirect { cpu | interface interface-type interface-number }
undo redirect { cpu | interface interface-type interface-number }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface specified by its type and number.
If you execute the redirect command multiple times in the same traffic behavior, the most recent configuration takes effect.
A traffic redirecting action takes effect only when the QoS policy is applied to the inbound direction.
For traffic redirecting to an access port, make sure the PVID of the interfaces to which the QoS policy is applied is the same as the PVID of the access port. Otherwise, the access port drops redirected packets.
For traffic redirecting to a trunk port, make sure the PVID of the interfaces to which the QoS policy is applied is in the allowed VLAN list of the trunk port. Otherwise, the trunk port drops redirected packets.
If a QoS policy applied to a user profile contains the redirect interface action, make sure the interface and the incoming interface of packets are in the same VLAN.
# Configure redirecting traffic to GigabitEthernet 1/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface gigabitethernet 1/0/1
classifier behavior
qos policy
traffic behavior
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action or an inner-to-outer tag priority copying action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
No 802.1p priority marking action or inner-to-outer tag priority copying action is configured.
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
customer-dot1p-trust: Copies the 802.1p priority value in the inner VLAN tag to the outer VLAN tag.
The remark dot1p and remark dot1p customer-dot1p-trust commands override each other in the same traffic behavior. The remark dot1p customer-dot1p-trust command does not take effect on single-tagged packets.
If you execute the remark dot1p command multiple times for the same color, the most recent configuration takes effect.
An 802.1p priority marking action takes effect only when the QoS policy is applied to the inbound direction.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
# Configure an inner-to-outer tag priority copying action in traffic behavior database.
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to restore the default.
undo remark [ green | red | yellow ] dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 4.
Table 4 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
# Configure traffic behavior database to mark matching traffic with DSCP 6.
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to restore the default.
remark local-precedence local-precedence-value
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
A local precedence marking action takes effect only when the QoS policy is applied to the inbound direction.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to restore the default.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [  insert-before before-classifier-name ]
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
display qos policy
Use display qos policy to display QoS policies.
user-defined: Specifies user-defined QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the QoS policies for the master device.
# Display all user-defined QoS policies.
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
     Behavior: 2
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
Table 5 Command output
Information about a user-defined QoS policy.
System-defined QoS policy information
Information about a system-defined QoS policy.
For the description of other fields, see Table 1 and Table 3.
Use display qos policy global to display QoS policies applied globally.
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays global QoS policies for the master device.
If you do not specify a direction, this command displays both inbound and outbound global QoS policies.
# Display QoS policies applied globally.
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Yellow packets: 0 (Packets) 0 (Bytes)
        Red packets   : 0 (Packets) 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 6 Command output
Direction
Direction in which the QoS policy is applied.
Green packets
Statistics about green packets.
Yellow packets
Statistics about yellow packets.
Red packets
Statistics about red packets.
Use display qos policy interface to display the QoS policies applied to interfaces.
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied to incoming traffic.
outbound: Specifies the QoS policy applied to outgoing traffic.
If you do not specify a direction, this command displays the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
# Display the QoS policy applied to the incoming traffic of GigabitEthernet 1/0/1.
<Sysname> display qos policy interface gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Matched : 0 (Packets) 0 (Bytes)
     5-minute statistics:
      Forwarded: 0/0 (pps/bps)
      Dropped  : 0/0 (pps/bps)
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display the QoS policies applied to all interfaces.
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: GigabitEthernet1/0/2
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Interface: GigabitEthernet1/0/3
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: GigabitEthernet1/0/4
        Green action  : pass
Table 7 Command output
Direction
Matched
Number of matching packets.
Forwarded
Average rate of successfully forwarded matching packets in a statistics collection period.
Dropped
Average rate of dropped matching packets in a statistics collection period.
Green packets
Traffic statistics for green packets.
Yellow packets
Traffic statistics for yellow packets.
Red packets
Traffic statistics for red packets.
Use display qos policy user-profile to display QoS policies applied to user profiles.
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter and must be unique. If you do not specify a user profile, this command displays QoS policies applied to all user profiles.
user-id user-id: Specifies an online user by a system-assigned, hexadecimal ID in the range of 0 to fffffffe. If you do not specify an online user, this command displays QoS policies applied to user profiles for all online users.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies applied to user profiles for all member devices.
inbound: Specifies QoS policies applied to incoming traffic.
outbound: Specifies QoS policies applied to outgoing traffic.
If you do not specify a direction, this command displays QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Display the QoS policy applied to user profile abc for a global user.
<Sysname> display qos policy user-profile name abc user-id 30000000 inbound
User-Profile: abc
  User ID: 0x30000000(global)
    Direction: Inbound
    Policy: p1
     Classifier: default-class
       Operator: AND
       Rule(s) :
        If-match any
       Behavior: be
        -none-
# Display the QoS policy applied to user profile abc for a local user.
<Sysname> display qos policy user-profile name abc user-id 30000001 inbound
User-Profile: abc
  slot 2:
    User ID: 0x30000001(local)
      Direction: Inbound
      Policy: p1
         Operator: AND
         Rule(s) :
          If-match any
         Behavior: be
          -none-
Table 8 Command output
global
Indicates a global user, who comes online from a global interface such as an aggregate interface.
local
Indicates a local user, who comes online from a physical interface.
Matched
Number of packets that meet match criteria.
Direction
Green packets
Yellow packets
Red packets
Use display qos vlan-policy to display QoS policies applied to VLANs.
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
inbound: Displays QoS policies applied to incoming traffic.
outbound: Displays QoS policies applied to outgoing traffic.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies applied to VLANs for the master device.
If you do not specify a direction, this command displays QoS policies applied to VLANs in both the inbound and outbound directions.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 9 Command output
Direction
Use qos apply policy to apply a QoS policy to an interface.
Use undo qos apply policy to remove an applied QoS policy.
undo qos apply policy policy-name { inbound | outbound }
No QoS policy is applied.
inbound: Applies the QoS policy to incoming traffic.
outbound: Applies the QoS policy to outgoing traffic.
# Apply QoS policy USER1 to the outgoing traffic of GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos apply policy USER1 outbound
Use qos apply policy to apply a QoS policy to a user profile.
Use undo qos apply policy to remove a QoS policy applied to a user profile.
No QoS policy is applied to a user profile.
User profile view
inbound: Applies the QoS policy to the incoming traffic of the device (traffic sent by online users).
outbound: Applies the QoS policy to the outgoing traffic of the device (traffic received by online users).
Deleting a user profile also removes the QoS policies applied to the user profile.
For a user profile to be active, the QoS policy applied in user profile view cannot be empty. A user profile supports only the car and accounting actions in a QoS policy.
# Apply QoS policy test to incoming traffic of user profile user.
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
undo qos apply policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
inbound: Applies the QoS policy to the incoming packets on all interfaces.
outbound: Applies the QoS policy to the outgoing packets on all interfaces.
A global QoS policy takes effect on all incoming or outgoing traffic depending on the direction in which the QoS policy is applied.
# Globally apply QoS policy user1 to the incoming traffic.
[Sysname] qos apply policy user1 global inbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos policy policy-name
undo qos policy policy-name
No QoS policies exist.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a QoS policy named user1.
classifier behavior
qos apply policy
qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
Use reset qos policy global to clear the statistics of a global QoS policy.
inbound: Clears the statistics of the global QoS policy applied to incoming traffic globally.
outbound: Clears the statistics of the global QoS policy applied to outgoing traffic globally.
If you do not specify a direction, this command clears the statistics of the global QoS policies in both directions.
# Clear the statistics of the global QoS policy applied to the incoming traffic globally.
<Sysname> reset qos policy global inbound
Use reset qos vlan-policy to clear the statistics for QoS policies applied to VLANs.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
If you do not specify a direction, this command clears the statistics of the QoS policies in both directions of the VLAN.
# Clear the statistics of QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-lp | dscp-dot1p | dscp-dscp ]
The device provides the following types of priority map.
Table 10 Priority maps
Priority mapping
dot1p-lp
802.1p-local priority map.
dscp-dot1p
DSCP-802.1p priority map.
dscp-dscp
DSCP-DSCP priority map.
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 11 Command output
MAP-TABLE NAME
Name of the priority map.
TYPE
Type of the priority map.
IMPORT
Input values of the priority map.
EXPORT
Output values of the priority map.
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local priority 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table{ dot1p-lp | dscp-dot1p | dscp-dscp }
For the description of keywords, see Table 10.
# Enter 802.1p-local priority map view.
import
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of GigabitEthernet 1/0/1.
<Sysname> display qos trust interface gigabitethernet 1/0/1
 Port priority trust information
  Port priority:4
  Port priority trust type: dscp
Table 12 Command output
Interface type and interface number.
Port priority
Port priority set for the interface.
Priority trust mode on the interface:
·         dot1p—Uses the 802.1p priority of received packets for mapping.
·         dscp—Uses the DSCP precedence of received IP packets for mapping.
·         none—Trusts no packet priority.
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
An interface does not trust any packet priority and uses the port priority as the 802.1p priority for mapping.
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
# Set the priority trust mode to 802.1p priority on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos trust dot1p
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority priority-value
undo qos priority
The port priority is 0.
priority-value: Specifies a port priority value in the range of 0 to 7.
# Set the port priority of GigabitEthernet 1/0/1 to 2.
[Sysname-GigabitEthernet1/0/1] qos priority 2
GTS commands
Use display qos gts interface to display the GTS configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration for all interfaces.
# Display the GTS configuration for all interfaces.
 Rule: If-match queue 1
  CIR 512 (kbps), CBS 51200 (Bytes)
Table 13 Command output
Interface name, including the interface type and interface number.
Rule
Match criteria.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos gts
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
undo qos gts queue queue-id
No GTS parameters are configured.
queue queue-id: Shapes the packets in a queue specified by its ID. The value range for queue-id is 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 102400 for 100-Mbps interfaces, 8 to 1048576 for GE interfaces, and 8 to 10485760 for 10-GE interfaces. The specified value must be an integral multiple of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 16777216, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 16777216 is converted to 16777216.
# Shape the packets of queue 1 on GigabitEthernet 1/0/1. The GTS parameters are as follows:
·          The CIR is 6400 kbps.
·          The CBS is 51200 bytes.
[Sysname-GigabitEthernet1/0/1] qos gts queue 1 cir 6400 cbs 51200
Rate limit commands
Use display qos lr interface to display the rate limit configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration for all interfaces.
# Display the rate limit configuration for all interfaces.
 Direction: Outbound
  CIR 2000 (kbps), CBS 20480 (Bytes)
Table 14 Command output
Direction
Direction in which the rate limit configuration is applied.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos lr
Use qos lr to configure rate limiting on an interface.
Use undo qos lr to delete the rate limit configuration on an interface.
undo qos lr { inbound | outbound }
No rate limit is configured.
inbound: Limits the rate of incoming packets.
outbound: Limits the rate of outgoing packets.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 134217728, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 134217728 is converted to 134217728.
# Limit the rate of outgoing packets on GigabitEthernet 1/0/1, with CIR 256 kbps and CBS 51200 bytes.
[Sysname-GigabitEthernet1/0/1] qos lr outbound cir 256 cbs 51200
Common commands
Use display qos queue interface to display the queuing information for interfaces.
display qos queue interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queuing information for all interfaces.
# Display the queuing information for all interfaces.
<Sysname> display qos queue interface
Output queue: Strict Priority queuing
Interface: GigabitEthernet1/0/4
Interface: GigabitEthernet1/0/5
Interface: GigabitEthernet1/0/6
Table 15 Command output
Output queue
Type of the current output queue.
Group
Number of the group that holds the queue.
Weight
Packet-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
SP commands
Use display qos queue sp interface to display the SP queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of GigabitEthernet 1/0/1.
<Sysname> display qos queue sp interface gigabitethernet 1/0/1
Table 16 Command output
Output queue
qos sp
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses packet-count WRR queuing.
# Enable SP queuing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos sp
WRR commands
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of GigabitEthernet 1/0/1.
<Sysname> display qos queue wrr interface gigabitethernet 1/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Queue name      Group           Weight
 0               be              1               1
 1               af1             1               1
 2               af2             1               1
 3               af3             1               1
 4               af4             1               1
 5               ef              1               1
 6               cs6             1               1
 7               cs7             sp              N/A
Table 17 Command output
Output queue
Group
ID of the group a queue is assigned to.
Weight
Packet-count queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
qos wrr
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to restore the default.
qos wrr weight
undo qos wrr weight
weight: Allocates bandwidth to queues in packets.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable packet-count WRR queuing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wrr weight
qos wrr weight
Use qos wrr weight to configure the WRR queuing parameters for a queue on an interface.
qos wrr queue-id group 1 weight schedule-value
undo qos wrr queue-id
All queues on a WRR-enabled interface are in WRR group 1, and queues 0 through 7 have a weight of 1, 2, 3, 4, 5, 9, 13, and 15, respectively.
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7 or keywords in Table 18.
Table 18 The number-keyword map for the queue-id argument
Number
Keyword
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
group 1: Specifies WRR group 1. Only WRR group 1 is supported in the current software version.
schedule-value: Specifies a scheduling weight. The value range for this argument is 1 to 15.
# Enable packet-based WRR queuing on GigabitEthernet 1/0/1, assign queue 0 to WRR group 1, and specify scheduling weight 10 for queue 0.
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group 1 weight 10
qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to remove a queue from the SP group.
qos wrr queue-id group sp
All queues on a WRR-enabled interface are in WRR group 1.
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
A queue in the SP group is not scheduled if the queue has the lowest priority among all queues with traffic load on the interface.
# Enable WRR queuing on GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group sp
qos wrr
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the queue scheduling profile configuration for the master device.
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID  Type  Group   Schedule   Schedule  Min         Max
                        unit       value     bandwidth   bandwidth
be        SP    N/A     N/A        N/A       N/A         N/A
af1       SP    N/A     N/A        N/A       N/A         N/A
af2       SP    N/A     N/A        N/A       N/A         N/A
af3       SP    N/A     N/A        N/A       N/A         N/A
af4       SP    N/A     N/A        N/A       N/A         N/A
ef        SP    N/A     N/A        N/A       N/A         N/A
cs6       SP    N/A     N/A        N/A       N/A         N/A
cs7       SP    N/A     N/A        N/A       N/A         N/A
Table 19 Command output
Queue scheduling profile name.
Queue scheduling type:
·         SP.
·         WRR.
Group
Priority group to which the queue belongs.
The value can only be 1. N/A indicates this field is ignored.
Schedule unit
Scheduling unit, which can only be weight..
N/A indicates that this field is ignored.
Schedule value
This field indicates the number of packets scheduled each time.
Min bandwidth
Minimum guaranteed bandwidth for the queue. N/A indicates that this field is ignored.
Max bandwidth
This field is not supported in the current software version. Maximum allowed bandwidth for the queue. N/A indicates that this field is ignored.
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to GigabitEthernet 1/0/1.
<Sysname> display qos qmprofile interface gigabitethernet 1/0/1
Direction: Outbound
Table 20 Command output
Direction
Direction in which the queue scheduling profile is applied.
Name of the queue scheduling profile applied to the interface.
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to the outbound direction of an interface.
Use undo qos apply qmprofile to restore the default.
No queue scheduling profile is applied to an interface.
You can apply only one queue scheduling profile to an interface.
# Apply queue scheduling profile myprofile to the outbound direction of GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-created queue scheduling profiles exist.
profile-name: Specifies a name for the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an object, first remove it from the object.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile]
queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to delete queue scheduling parameter settings.
queue queue-id { sp | wrr group group-id weight schedule-value }
undo queue queue-id
All queues in a queue scheduling profile use SP queuing.
Queue scheduling profile view
sp: Enables SP for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WRR group by its ID. The group ID can only be 1.
schedule-value: Specifies a scheduling weight in the range of 1 to 15.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
·          The WRR queuing is used.
·          The WRR group is group 1.
·          The scheduling weight is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
qos qmprofile
Use display qos queue-statistics interface outbound to display queue-based outgoing traffic statistics for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue-based outgoing traffic statistics for all interfaces.
# Display queue-based outgoing traffic statistics for GigabitEthernet 1/0/1.
<Sysname> display qos queue-statistics interface gigabitethernet 1/0/1 outbound
 Direction: outbound
 Forwarded: 0 packets, 0 bytes
 Dropped: 0 packets, 0 bytes
 Queue 0
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Current queue length: 0 packets
 Queue 1
 Queue 2
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
Table 21 Command output
Interface for which queue-based traffic statistics are displayed.
Direction
Direction of traffic for which statistics are collected.
Forwarded
Counts forwarded traffic both in packets and in bytes.
Dropped
Counts dropped traffic both in packets and in bytes.
Number of packets in the queue.
reset counters interface (Interface Command Reference)
car name
Use car name to use an aggregate CAR action in a traffic behavior.
car name car-name
undo car
No aggregate CAR action is configured in a traffic behavior.
car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
Use display qos car name to display information about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command displays information about all aggregate CAR actions.
# Display information about all aggregate CAR actions.
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
   Green action  : pass
  Slot 0:
   Green packets : 0 (Packets), 0 (Bytes)
   Yellow packets: 0 (Packets), 0 (Bytes)
   Red packets   : 0 (Packets), 0 (Bytes)
  Slot 1:
  Slot 2:
   Apply failed
Table 22 Command output
Name
Name of the aggregate CAR action.
Mode
Type of the CAR action, which can be aggregative.
CIR  CBS  PIR  EBS
Parameters for the CAR action.
Green action
Action to take on green packets:
·         discard—Drops the packets.
·         pass—Permits the packets to pass through.
Yellow action
Action to take on yellow packets:
Red action
Action to take on red packets:
Green packet
Yellow packet
Red packet
qos car
Use qos car aggregative to configure an aggregate CAR action.
Use undo qos car to delete an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
No aggregate CAR action is configured.
car-name: Specifies the name of the aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
cir committed-information-rate: Specifies the CIR in kbps, which is an average traffic rate. The value range for committed-information-rate is 8 to 160000000.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 8 to 160000000.
green action: Specifies the action to take on packets that conform to CIR. The default setting is pass.
red action: Specifies the action to take on the packet that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to PIR but not to CIR. The default setting is pass.
action: Specifies the action to take on packets:
·          remark-dscp-pass new-dscp: Remarks the packet with a new DSCP value and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
An aggregate CAR action takes effect only after it is used in a QoS policy.
A QoS policy configured with an aggregate CAR action cannot be applied to the outbound direction.
To use two rates for aggregate CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for aggregate CAR, configure the qos car command without the pir peak-information-rate option.
# Configure aggregate CAR action aggcar-1.
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name
Use reset qos car name to clear the statistics about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command clears statistics for all aggregate CAR actions.
# Clear the statistics about aggregate CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
