04-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5130S-HI[EI]&S5110V2&S3100V3-EI Switch Series Configuration Guides-R612x-6W10304-Layer 3—IP Services Configuration Guide
08-UDP helper configuration
08-UDP helper configuration 71.73 KB
Configuring UDP helper
About UDP helper
UDP helper can provide the following packet conversion for packets with specific UDP destination port numbers:
·          Convert broadcast to unicast, and forward the unicast packets to specific destinations.
·          Convert broadcast to multicast, and forward the multicast packets.
Configuring UDP helper to convert broadcast to unicast
About broadcast to unicast conversion
You can configure UDP helper to convert broadcast packets with specific UDP port numbers to unicast packets.
Upon receiving a UDP broadcast packet, UDP helper uses the configured UDP ports to match the UDP destination port number of the packet.
·          If a match is found, UDP helper duplicates the packet and modifies the destination IP address of the copy to the configured unicast address. Then UDP helper forwards the unicast packet to the unicast address.
·          If no match is found, UDP helper does not process the packet.
1.        Enter system view.
2.        Enable UDP helper.
udp-helper enable
By default, UDP helper is disabled.
3.        Specify a UDP port number for UDP helper.
By default, no UDP port numbers are specified for UDP helper.
Do not set UDP ports 67 and 68 for UDP helper, because UDP helper cannot forward DHCP broadcast packets.
You can specify a maximum of 256 UDP ports for UDP helper.
4.        Enter interface view.
5.        Specify a destination server for UDP helper to convert broadcast to unicast.
udp-helper server ip-address
By default, no destination servers are specified.
Use this command on the interface that receives broadcast packets.
You can specify a maximum of 20 unicast and multicast addresses for UDP helper to convert broadcast packets on an interface.
Configuring UDP helper to convert broadcast to multicast
About broadcast to multicast conversion
You can configure UDP helper to convert broadcast packets with specific UDP port numbers to multicast packets.
·          If a match is found, UDP helper duplicates the packet and modifies the destination IP address of the copy to the configured multicast address. Then UDP helper forwards the packet to the multicast group.
udp-helper enable
5.        Specify a destination multicast address for UDP helper to convert broadcast to multicast.
udp-helper broadcast-map multicast-address [ acl acl-number ]
By default, no destination multicast addresses are specified for UDP helper.
Display and maintenance commands for UDP helper
Execute display command in any view and reset commands in user view.
Display information about broadcast to unicast conversion by UDP helper on an interface.
display udp-helper interface interface-type interface-number
Clear packet statistics for UDP helper.
reset udp-helper statistics
UDP helper configuration examples
Example: Configuring UDP helper to convert broadcast to unicast
As shown in Figure 1, configure UDP helper to convert broadcast to unicast on VLAN-interface 1 of Switch A. This feature enables Switch A to forward broadcast packets with UDP destination port number 55 to the destination server 10.2.1.1/16.
Figure 1 Network diagram
Make sure Switch A can reach the subnet 10.2.0.0/16.
# Enable UDP helper.
[SwitchA] System-view
[SwitchA] udp-helper enable
# Enable the UDP port 55 for UDP helper.
[SwitchA] udp-helper port 55
# Assign 10.110.1.1/16 to VLAN-interface 1 and enable the interface to forward directed broadcast packets destined for the directly connected network.
[SwitchA-Vlan-interface1] ip address 10.110.1.1 16
[SwitchA-Vlan-interface1] ip forward-broadcast
# Specify the destination server 10.2.1.1 for UDP helper to convert broadcast to unicast on VLAN-interface 1.
[SwitchA-Vlan-interface1] udp-helper server 10.2.1.1
# Display information about broadcast to unicast conversion by UDP helper on VLAN-interface 1.
[SwitchA-Vlan-interface1] display udp-helper interface vlan-interface 1
Interface                Server VPN instance           Server address Packets sent
Vlan-interface1          N/A                           10.2.1.1       5
Example: Configuring UDP helper to convert broadcast to multicast
As shown in Figure 2, VLAN-interface 1 of Switch B can receive multicast packets destined to 225.1.1.1.
Configure UDP helper to convert broadcast to multicast on VLAN-interface 1 of Switch A. This feature enables Switch A to forward broadcast packets with UDP destination port number 55 to the multicast group 225.1.1.1.
Figure 2 Network diagram
# Configure UDP helper to convert broadcast packets to multicast packets destined for 225.1.1.1.
[SwitchA-Vlan-interface1] udp-helper broadcast-map 225.1.1.1
# Enable IP multicast routing globally.
[SwitchA] multicast routing
[SwitchA-mrib] quit
Enable PIM-DIM and IGMP on VLAN-interface 1.
[SwitchA-Vlan-interface1] pim dm
[SwitchA-Vlan-interface1] igmp enable
# Configure VLAN-interface 1 as a static member of the multicast group 225.1.1.1.
[SwitchA-Vlan-interface1] igmp static-group 225.1.1.1
# Enable PIM-DIM and IGMP on VLAN-interface 2.
[SwitchA-Vlan-interface2] pim dm
[SwitchA-Vlan-interface2] igmp enable
# Configure VLAN-interface 2 as a static member of the multicast group 225.1.1.1.
[SwitchA-Vlan-interface2] igmp static-group 225.1.1.1
Verify that you can capture multicast packets from Switch A on Switch B.
