H3C UniServer R4700 G3 Server User Guide-6W101
HomeSupportServersH3C UniServer R4700 G3Install & UpgradeInstallation GuidesH3C UniServer R4700 G3 Server User Guide-6W101
01-Text
01-Text 10.12 MB
Safety information· 1
Safety sign conventions· 1
Power source recommendations· 1
Installation safety recommendations· 2
General operating safety· 2
Electrical safety· 2
Rack mounting recommendations· 2
ESD prevention· 3
Cooling performance· 3
Battery safety· 3
Preparing for installation· 5
Rack requirements· 5
Installation site requirements· 6
Space and airflow requirements· 6
Temperature and humidity requirements· 7
Equipment room height requirements· 7
Cleanliness requirements· 7
Grounding requirements· 8
Installation tools· 8
Installing or removing the server 10
Installing the server 10
Installing rails· 10
Rack-mounting the server 10
Installing cable management brackets· 11
Connecting external cables· 12
Cabling guidelines· 12
Connecting a mouse, keyboard, and monitor 12
Connecting an Ethernet cable· 13
Connecting a USB device· 14
Connecting the power cord· 15
Securing cables· 19
Removing the server from a rack· 19
Powering on and powering off the server 21
Important information· 21
Powering on the server 21
Prerequisites· 21
Procedure· 21
Powering off the server 22
Guidelines· 22
Procedure· 22
Configuring the server 23
Configuration flowchart 23
Powering on the server 23
Configuring basic BIOS settings· 24
Setting the server boot order 24
Setting the BIOS passwords· 24
Configuring RAID·· 24
Installing the operating system and hardware drivers· 24
Installing the operating system·· 24
Installing hardware drivers· 24
Updating firmware· 24
Installing hardware options· 26
Installing the security bezel 26
Installing SAS/SATA drives· 26
Installing NVMe drives· 28
Installing power supplies· 30
Installing riser cards and PCIe modules· 31
Installing storage controllers and power fail safeguard modules· 34
Guidelines· 34
Prerequisites· 35
Installing a Mezzanine storage controller and a power fail safeguard module· 35
Installing a standard storage controller and a power fail safeguard module· 39
Installing GPU modules· 41
Installing Ethernet adapters· 43
Guidelines· 43
Installing an mLOM Ethernet adapter 43
Installing a PCIe Ethernet adapter 44
Installing SATA M.2 SSDs· 45
Guidelines· 45
Installing SATA M.2 SSDs at the server front (4LFF server) 45
Installing SATA M.2 SSDs at the server front (8SFF server) 47
Installing SATA M.2 SSDs at the server rear 49
Installing SD cards· 50
Installing an NVMe SSD expander module· 51
Installing the NVMe VROC module· 52
Installing the 2SFF drive cage· 53
Installing the front 2SFF drive cage (8SFF server) 53
Installing the rear 2SFF drive cage (4LFF/10SFF server) 55
Installing the front media module (VGA and USB 2.0 connectors) 56
Installing the front media module (4LFF server) 56
Installing the front media module (8SFF/10SFF server) 58
Installing an optical drive· 60
Preparing for the installation· 60
Installing a SATA optical drive· 60
Installing a diagnostic panel 61
Installing fans· 62
Installing processors· 64
Installing DIMMs· 68
Installing and setting up a TCM or TPM·· 72
Installation and setup flowchart 72
Installing a TCM or TPM·· 72
Enabling the TCM or TPM from the BIOS· 74
Configuring encryption in the operating system·· 74
Replacing hardware options· 75
Replacing the security bezel 75
Replacing a SAS/SATA drive· 75
Replacing an NVMe drive· 76
Replacing the access panel 77
Removing the access panel 77
Installing the access panel 78
Replacing a power supply· 79
Replacing air baffles· 82
Removing air baffles· 82
Installing air baffles· 83
Replacing a riser card and a PCIe module· 84
Replacing a storage controller 86
Guidelines· 86
Preparing for replacement 86
Replacing the Mezzanine storage controller 86
Replacing a standard storage controller 87
Replacing the power fail safeguard module· 88
Replacing the power fail safeguard module for the Mezzanine storage controller 88
Replacing the power fail safeguard module for a standard storage controller 90
Replacing a GPU module· 91
Replacing an Ethernet adapter 92
Replacing an mLOM Ethernet adapter 92
Replacing a PCIe Ethernet adapter 93
Replacing the M.2 transfer module and an SATA M.2 SSD·· 94
Replacing the front M.2 transfer module and an SATA M.2 SSD (4LFF server) 94
Replacing the front M.2 transfer module and an SATA M.2 SSD (8SFF server) 95
Replacing the rear M.2 transfer module and a SATA M.2 SSD·· 97
Replacing an SD card· 97
Replacing the dual SD card extended module· 98
Replacing an NVMe SSD expander module· 99
Replacing the NVMe VROC module· 100
Replacing a fan· 101
Replacing a processor 102
Guidelines· 102
Prerequisites· 102
Removing a processor 103
Installing a processor 104
Verifying the replacement 105
Replacing a DIMM·· 105
Removing the system battery· 107
Installing the system battery· 107
Verifying the replacement 108
Replacing the system board· 108
Guidelines· 108
Removing the system board· 108
Installing the system board· 110
Replacing the drive expander module (10SFF server) 111
Replacing drive backplanes· 112
Removing drive backplanes· 112
Installing drive backplanes· 114
Verifying the replacement 116
Replacing the SATA optical drive· 116
Replacing the diagnostic panel 117
Replacing the chassis-open alarm module· 117
Removing the chassis-open alarm module· 117
Installing the chassis-open alarm module· 118
Verifying the replacement 119
Replacing the front media module· 119
Removing the front media module (4LFF server) 119
Removing the front media module (8SFF/10SFF server) 121
Replacing the air inlet temperature sensor 121
Replacing the front I/O component 123
Replacing the front I/O component (4LFF server) 123
Replacing the front I/O component (8SFF/10SFF server) 124
Replacing chassis ears· 126
Replacing the TPM/TCM·· 128
Connecting internal cables· 129
Connecting drive cables· 129
4LFF server 129
8SFF server 131
10SFF server 139
Connecting the flash card and supercapacitor of the power fail safeguard module· 141
Connecting the flash card on the Mezzanine storage controller 141
Connecting the flash card on a standard storage controller 142
Connecting the power cord of a GPU module· 143
Connecting the SATA M.2 SSD cable· 143
Connecting the front SATA M.2 SSD cable (4LFF server) 143
Connecting the front SATA M.2 SSD cable (8SFF server) 144
Connecting the rear SATA M.2 SSD cable· 145
Connecting the SATA optical drive cable· 146
Connecting the front I/O component cable assembly· 147
Connecting the front media module cable· 148
Connecting the NCSI cable for a PCIe Ethernet adapter 149
Maintenance· 151
Guidelines· 151
Maintenance tools· 151
Maintenance tasks· 151
Observing LED status· 151
Monitoring the temperature and humidity in the equipment room·· 151
Examining cable connections· 152
Technical support 152
Safety information
To avoid bodily injury or damage to the server or its components, make sure you are familiar with the safety signs on the server chassis or its components.
Table 1 Safety signs
Sign
Circuit or electricity hazards are present. Only H3C authorized or professional server engineers are allowed to service, repair, or upgrade the server.
WARNING WARNING!
To avoid bodily injury or damage to circuits, do not open any components marked with the electrical hazard sign unless you have authorization to do so.
Electrical hazards are present. Field servicing or repair is not allowed.
WARNING WARNING!
To avoid bodily injury, do not open any components with the field-servicing forbidden sign in any circumstances.
The RJ-45 ports on the server can be used only for Ethernet connections.
WARNING WARNING!
To avoid electrical shocks, fire, or damage to the equipment, do not connect an RJ-45 port to a telephone.
The surface or component might be hot and present burn hazards.
WARNING WARNING!
To avoid being burnt, allow hot surfaces or components to cool before touching them.
The server or component is heavy and requires more than one people to carry or move.
WARNING WARNING!
To avoid bodily injury or damage to hardware, do not move a heavy component alone. In addition, observe local occupational health and safety requirements and guidelines for manual material handling.
The server is powered by multiple power supplies.
WARNING WARNING!
To avoid bodily injury from electrical shocks, make sure you disconnect all power supplies if you are performing offline servicing.
Power instability or outage might cause data loss, service disruption, or damage to the server in the worst case.
To protect the server from unstable power or power outage, use uninterrupted power supplies (UPSs) to provide power for the server.
To avoid bodily injury or damage to the server, read the following information carefully before you operate the server.
To avoid bodily injury or damage to the server, follow these guidelines when you operate the server:
·          Only H3C authorized or professional server engineers are allowed to install, service, repair, operate, or upgrade the server.
·          Place the server on a clean, stable table or floor for servicing.
·          Make sure all cables are correctly connected before you power on the server.
·          To avoid being burnt, allow the server and its internal modules to cool before touching them.
Electrical safety
WARNING
WARNING!
If you put the server in standby mode (system power LED in amber) with the power on/standby button on the front panel, the power supplies continue to supply power to some circuits in the server. To remove all power for servicing safety, you must first press the button, wait for the system to enter standby mode, and then remove all power cords from the server.
To avoid bodily injury or damage to the server, follow these guidelines:
·          Always use the power cords that came with the server.
·          Do not use the power cords that came with the server for any other devices.
·          Power off the server when installing or removing any components that are not hot swappable.
To avoid bodily injury or damage to the equipment, follow these guidelines when you rack mount a server:
·          Mount the server in a standard 19-inch rack.
·          Make sure the leveling jacks are extended to the floor and the full weight of the rack rests on the leveling jacks.
·          Couple the racks together in multi-rack installations.
·          Load the rack from the bottom to the top, with the heaviest hardware unit at the bottom of the rack.
·          Get help to lift and stabilize the server during installation or removal, especially when the server is not fastened to the rails. As a best practice, a minimum of two people are required to safely load or unload a rack. A third person might be required to help align the server if the server is installed higher than check level.
·          For rack stability, make sure only one unit is extended at a time. A rack might get unstable if more than one server unit is extended.
·          Make sure the rack is stable when you operate a server in the rack.
·          To maintain correct airflow and avoid thermal damage to the server, use blank panels to fill empty rack units.
ESD prevention
Electrostatic charges that build up on people and tools might damage or shorten the lifespan of the system board and electrostatic-sensitive components.
Preventing electrostatic discharge
To prevent electrostatic damage, follow these guidelines:
·          Transport or store the server with the components in antistatic bags.
·          Keep the electrostatic-sensitive components in separate antistatic bags until they arrive at an ESD-protected area.
·          Place the components on a grounded surface before removing them from their antistatic bags.
·          Avoid touching pins, leads, or circuitry.
Grounding methods to prevent electrostatic discharge
The following are grounding methods that you can use to prevent electrostatic discharge:
·          Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
·          Take adequate personal grounding measures, including wearing antistatic clothing and static dissipative shoes.
·          Use conductive field service tools.
·          Use a portable field service kit with a folding static-dissipating work mat.
Cooling performance
Poor cooling performance might result from improper airflow and poor ventilation and might cause damage to the server.
To ensure good ventilation and proper airflow, follow these guidelines:
·          Install blanks if the following module slots are empty:
¡  Drive bays.
¡  Fan bays.
¡  PCIe slots.
¡  Power supply slots.
·          Do not block the ventilation openings in the server chassis.
·          To avoid thermal damage to the server, do not operate the server for long periods in any of the following conditions:
¡  Access panel open or uninstalled.
¡  Air baffles uninstalled.
¡  PCIe slots, drive bays, fan bays, or power supply slots empty.
Battery safety
The server's system board contains a system battery, which is designed with a lifespan of 5 to 10 years.
If the server no longer automatically displays the correct date and time, you might need to replace the battery. When you replace the battery, follow these safety guidelines:
·          Do not attempt to recharge the battery.
·          Do not expose the battery to a temperature higher than 60°C (140°F).
·          Do not disassemble, crush, puncture, short external contacts, or dispose of the battery in fire or water.
·          Dispose of the battery at a designated facility. Do not throw the battery away together with other wastes.
Prepare a rack that meets the rack requirements and plan an installation site that meets the requirements for space and airflow, temperature, humidity, equipment room height, cleanliness, and grounding.
Rack requirements
IMPORTANT
IMPORTANT:
As a best practice to avoid affecting the server chassis, install power distribution units (PDUs) with the outputs facing backwards. If you install PDUs with the outputs facing the inside of the server, please perform onsite survey to make sure the cables won't affect the server rear.
The server is 1U high. The rack for installing the server must meet the following requirements:
·          A standard 19-inch rack.
·          A clearance of more than 50 mm (1.97 in) between the rack front posts and the front rack door.
·          A minimum of 1200 mm (47.24 in) in depth as a best practice. For installation limits for different rack depth, see Table 2.
Table 2 Installation limits for different rack depths
Rack depth
Installation limits
1000 mm (39.37 in)
·         The H3C cable management arm (CMA) is not supported.
·         A clearance of 60 mm (2.36 in) is reserved from the server rear to the rear rack door for cabling.
·         The slide rails and PDUs might hinder each other. Perform onsite survey to determine the PDU installation location and the proper PDUs. If the PDUs hinder the installation and movement of the slide rails anyway, use other methods to support the server, a tray for example.
1100 mm (43.31 in)
Make sure the CMA does not hinder PDU installation at the server rear before installing the CMA. If the CMA hinders PDU installation, use a deeper rack or change the installation locations of PDUs.
1200 mm (47.24 in)
Make sure the CMA does not hinder PDU installation or cabling. If the CMA hinders PDU installation or cabling, change the installation locations of PDUs.
For detailed installation suggestions, see Figure 1.
Figure 1 Installation suggestions for a 1200 mm deep rack (top view)
(1) 1200 mm (47.24 in) rack depth
(2) A minimum of 50 mm (1.97 in) between the front rack posts and the front rack door
(3) 790 mm (31.10 in) between the front rack posts and the rear of the chassis, including power supply handles at the server rear (not shown in the figure)
(4) 810 mm (31.89 in) server depth, including chassis ears
(5) 960 mm (37.80 in) between the front rack posts and the CMA
(6) 860 mm (33.86 in) between the front rack posts and the rear ends of the slide rails
For convenient maintenance and heat dissipation, make sure the following requirements are met:
·          A minimum clearance of 635 mm (25 in) is reserved in front of the rack.
·          A minimum clearance of 762 mm (30 in) is reserved behind the rack.
·          A minimum clearance of 1219 mm (47.99 in) is reserved between racks.
·          A minimum clearance of 2 mm (0.08 in) is reserved between the server and its adjacent units in the same rack.
Figure 2 Airflow through the server
(1) and (2) Directions of the airflow into the chassis and power supplies
(3) Direction of the airflow out of the power supplies
(4) to (7) Directions of the airflow out of the chassis
To ensure correct operation of the server, make sure the room temperature and humidity meet the requirements as described in "Appendix A  Server specifications."
To ensure correct operation of the server, make sure the equipment room height meets the requirements as described in "Appendix A  Server specifications."
Mechanically active substances buildup on the chassis might result in electrostatic adsorption, which causes poor contact of metal components and contact points. In the worst case, electrostatic adsorption can cause communication failure.
Table 3 Mechanically active substance concentration limit in the equipment room
Substance
Particle diameter
Concentration limit
Dust particles
≥ 5 µm
≤ 3 x 104 particles/m3
(No visible dust on desk in three days)
Dust (suspension)
≤ 75 µm
≤ 0.2 mg/m3
Dust (sedimentation)
75 µm to 150 µm
≤ 1.5 mg/(m2h)
Sand
≥ 150 µm
≤ 30 mg/m3
The equipment room must also meet limits on salts, acids, and sulfides to eliminate corrosion and premature aging of components, as shown in Table 4.
Table 4 Harmful gas limits in an equipment room
Gas
Maximum concentration (mg/m3)
SO2
0.2
H2S
0.006
NO2
0.04
NH3
0.05
Cl2
0.01
Correctly connecting the server grounding cable is crucial to lightning protection, anti-interference, and ESD prevention. The server can be grounded through the grounding wire of the power supply system and no external grounding cable is required.
Installation tools
Table 5 lists the tools that you might use during installation.
Table 5 Installation tools
Name
T25 Torx screwdriver
Installs or removes screws inside chassis ears, including screw rack mount ears or multifunctional rack mount ears.
T30 Torx screwdriver
Installs or removes captive screws on processor heatsinks.
T15 Torx screwdriver (shipped with the server)
Installs or removes screws on access panels.
T10 Torx screwdriver (shipped with the server)
Installs or removes screws on the front media module.
Flat-head screwdriver
Installs or removes captive screws inside multifunctional rack mount ears or replaces system batteries.
Phillips screwdriver
Installs or removes screws on SATA M.2 SSDs.
Cage nut insertion/extraction tool
Inserts or extracts the cage nuts in rack posts.
Diagonal pliers
Clips insulating sleeves.
Tape measure
Measures distance.
Multimeter
Measures resistance and voltage.
ESD wrist strap
Prevents ESD when you operate the server.
Antistatic gloves
Antistatic clothing
Ladder
Supports high-place operations.
Interface cable (such as an Ethernet cable or optical fiber)
Connects the server to an external network.
Monitor (such as a PC)
Displays the output from the server.
As a best practice, install hardware options as needed to the server before installing the server in the rack. For more information about how to install hardware options, see "Installing hardware options."
Installing rails
Install the inner rails to the server and the middle-outer rails to the rack. For information about installing the rails, see the document shipped with the rails.
WARNING
WARNING!
To avoid bodily injury, slide the server into the rack with caution for the sliding rails might squeeze your fingers.
1.        Slide the server into the rack. For more information about how to slide the server into the rack, see the document shipped with the rails.
Figure 3 Rack-mounting the server
2.        Secure the server:
If the server is installed with multifunctional rack mount ears, perform the following steps:
a.    Push the server until the multifunctional rack mount ears are flush against the rack front posts, as shown by callout 1 in Figure 4.
b.    Unlock the latches of the multifunctional rack mount ears, as shown by callout 2 in Figure 4.
c.    Fasten the captive screws inside the chassis ears and lock the latches, as shown by callout 3 in Figure 4.
Figure 4 Securing the server
If the server is installed with screw rack mount ears, perform the following steps:
a.    Push the server until the screw rack mount ears are flush against the rack front posts, as shown by callout 2 in Figure 5.
b.    Fasten the captive screws on the screw rack mount ears, as shown by callout 2 in Figure 5.
Figure 5 Securing the server
Install cable management brackets if the server is shipped with cable management brackets. For information about how to install cable management brackets, see the installation guide shipped with the brackets.
Cabling guidelines
WARNING
WARNING!
To avoid electric shock, fire, or damage to the equipment, do not connect communication equipment to RJ-45 Ethernet ports on the server.
·          For heat dissipation, make sure no cables block the inlet or outlet air vents of the server.
·          To easily identify ports and connect/disconnect cables, make sure the cables do not cross.
·          Label the cables for easy identification of the cables.
·          Wrap unused cables onto an appropriate position on the rack.
·          To avoid damage to cables when extending the server out of the rack, do not route the cables too tight if you use cable management brackets.
Perform this task before you configure BIOS, HDM, FIST, or RAID on the server or enter the operating system of the server.
The server provides a maximum of two DB15 VGA connectors for connecting a monitor.
·          One on the front panel if the server is installed with a front media module.
·          One on the rear panel.
The server is not shipped with a standard PS2 mouse and keyboard. To connect a PS2 mouse and keyboard, you must prepare a USB-to-PS2 adapter.
1.        Connect one plug of a VGA cable to a VGA connector on the server, and fasten the screws on the plug.
Figure 6 Connecting a VGA cable
2.        Connect the other plug of the VGA cable to the VGA connector on the monitor, and fasten the screws on the plug.
3.        Connect the mouse and keyboard.
¡  For a USB mouse and keyboard, directly connect the USB connectors of the mouse and keyboard to the USB connectors on the server.
¡  For a PS2 mouse and keyboard, insert the USB connector of the USB-to-PS2 adapter to a USB connector on the server. Then, insert the PS2 connectors of the mouse and keyboard into the PS2 receptacles of the adapter.
Figure 7 Connecting a PS2 mouse and keyboard by using a USB-to-PS2 adapter
Perform this task before you set up a network environment or log in to the HDM management interface through the HDM network port to manage the server.
1.        Determine the network port on the server.
¡  To connect the server to the external network, use the Ethernet port on the Ethernet adapter.
¡  To log in to the HDM management interface, use the HDM dedicated or shared network port on the server.
HDM shared network port is available only if an NCSI-capable mLOM or PCIe Ethernet adapter is installed.
For the position of the HDM dedicated network port, see "Rear panel view." For the position of the HDM shared network port on an mLOM or PCIe Ethernet adapter, see "Installing Ethernet adapters."
2.        Determine type of the Ethernet cable.
Verify the connectivity of the cable by using a link tester.
If you are replacing the Ethernet cable, make sure the new cable is the same type or compatible with the old cable.
3.        Label the Ethernet cable by filling in the names and numbers of the server and the peer device on the label.
As a best practice, use labels of the same kind for all cables.
If you are replacing the Ethernet cable, label the new cable with the same number as the number of the old cable.
4.        Connect one end of the Ethernet cable to the network port on the server and the other end to the peer device.
Figure 8 Connecting an Ethernet cable
5.        Verify network connectivity.
After powering on the server, use the ping command to test the network connectivity. If the connection between the server and the peer device fails, verify that the Ethernet cable is securely connected.
6.        Secure the Ethernet cable. For information about how to secure cables, see "Securing cables."
Perform this task before you install the operating system of the server or transmit data through a USB device.
The server provides a maximum of six USB connectors.
·          Two USB 2.0 connectors on the front panel if the server is installed with a front media module..
·          Two USB 3.0 connectors on the rear panel.
·          Two internal USB 3.0 connectors for connecting USB devices that are not designed to be installed and removed very often.
Guidelines
Before connecting a USB device, make sure the USB device can operate correctly and then copy data to the USB device.
USB devices are hot swappable.
As a best practice for compatibility, purchase USB devices from H3C.
1.        Remove the access panel if you need to connect the USB device to an internal USB connector. For information about how to remove the access panel, see "Removing the access panel."
2.        Connect the USB device to the USB connector, as shown in Figure 9.
Figure 9 Connecting a USB device to an internal USB connector
3.        Install the access panel. For information about how to install the access panel, see "Installing the access panel."
4.        Verify that the server can identify the USB device.
If the server fails to identify the USB device, download and install the driver of the USB device. If the server still fails to identify the USB device after the driver is installed, replace the USB device.
Guidelines
WARNING
WARNING!
To avoid damage to the equipment or even bodily injury, use the power cord that ships with the server.
Before connecting the power cord, make sure the server and components are installed correctly.
Connecting the AC power cord for an AC or 240 V high-voltage DC power supply
1.        Insert the power cord plug into the power receptacle of a power supply at the rear panel, as shown in Figure 10.
Figure 10 Connecting the AC power cord
2.        Connect the other end of the power cord to the power source, for example, the power strip on the rack.
3.        Secure the power cord to avoid unexpected disconnection of the power cord.
a.    If the cable clamp is positioned too near the power cord that it blocks the power cord plug connection, press down the tab on the cable mount and slide the clip backward.
Figure 11 Sliding the cable clamp backward
b.    Open the cable clamp, place the power cord through the opening in the cable clamp, and then close the cable clamp, as shown by callouts 1, 2, 3, and 4 in Figure 12.
Figure 12 Securing the AC power cord
c.    Slide the cable clamp forward until it is flush against the edge of the power cord plug, as shown in Figure 13.
Figure 13 Sliding the cable clamp forward
Connecting the DC power cord for a –48 VDC power supply
WARNING
WARNING!
Provide a circuit breaker for each power cord. Make sure the circuit breaker is switched off before you connect a DC power cord.
To connect the DC power cord for a –48 VDC power supply:
1.        Connect the power cord plug to the power receptacle of a –48 VDC power supply at the rear panel, as shown in Figure 14.
Figure 14 Connecting the DC power cord
2.        Fasten the screws on the power cord plug to secure it into place, as shown in Figure 15.
Figure 15 Securing the DC power cord
3.        Connect the other end of the power cord to the power source, as shown in 错误!未找到引用源。.
The DC power cord contains three wires: –48V GND, –48V, and PGND. Connect the three wires to the corresponding terminals of the power source. The wire tags in the figure are for illustration only.
Figure 16 Three wires at the other end of the DC power cord
Securing cables
Securing cables to cable management brackets
For information about how to secure cables to cable management brackets, see the installation guide shipped with the brackets.
Securing cables to slide rails by using cable straps
You can secure cables to either left slide rails or right slide rails. As a best practice for cable management, secure cables to left slide rails.
When multiple cable straps are used in the same rack, stagger the strap location, so that the straps are adjacent to each other when viewed from top to bottom. This positioning will enable the slide rails to slide easily in and out of the rack.
To secure cables to slide rails by using cable straps:
1.        Hold the cables against a slide rail.
2.        Wrap the strap around the slide rail and loop the end of the cable strap through the buckle.
3.        Dress the cable strap to ensure that the extra length and buckle part of the strap are facing outside of the slide rail.
Figure 17 Securing cables to a slide rail
1.        Power down the server. For more information, see "Powering off the server."
2.        Disconnect all peripheral cables from the server.
3.        Extend the server from the rack.
a.    Open the latches of the multifunctional rack mount ears, as shown by callout 1 in Figure 18.
b.    Loosen the captive screws inside the multifunctional rack mount ears, as shown by callout 2 in Figure 18.
c.    Slide the server out of the rack, as shown by callout 3 in Figure 18.
Figure 18 Extending the server from the rack
If the server is installed with screw rack mount ears, loosen the captive screws on the screw rack mount ears and then slide the server out of the rack.
4.        Place the server on a clean, stable surface.
If the server is connected to external storage devices, make sure the server is the first device to power off and then the last device to power on. This restriction prevents the server from mistakenly identifying the external storage devices as faulty devices.
Before you power on the server, you must complete the following tasks:
·          Install the server and internal components correctly.
·          Connect the server to a power source.
Powering on the server by pressing the power on/standby button
Press the power on/standby button to power on the server.
The server exits standby mode and supplies power to the system. The system power LED changes from steady amber to flashing green and then to steady green. For information about the position of the system power LED, see "LEDs and buttons."
Powering on the server from the HDM Web interface
1.        Log in to the HDM.
For information about how to log in to HDM, see the firmware update guide for the server.
2.        Power on the server.
For more information, see HDM online help.
Powering on the server from the remote console interface
1.        Log in to HDM.
2.        Log in to a remote console and then power on the server.
For information about how to log in to a remote console, see HDM online help.
Configuring automatic power-on
You can configure automatic power-on from HDM or the BIOS.
To configure automatic power-on from HDM:
1.        Log in to HDM.
2.        Enable automatic power-on for the server.
To configure automatic power-on from the BIOS, set AC Restore Settings to Always Power On. For more information, see the BIOS user guide for the server.
Guidelines
Before powering off the server, you must complete the following tasks:
·          Back up all critical data.
·          Make sure all services have stopped or have been migrated to other servers.
Powering off the server from its operating system
1.        Connect a monitor, mouse, and keyboard to the server.
2.        Shut down the operating system of the server.
3.        Disconnect all power cords from the server.
Powering off the server by pressing the power on/standby button
1.        Press the power on/standby button and wait for the system power LED to turn into steady amber.
2.        Disconnect all power cords from the server.
Powering off the server forcedly by pressing the power on/standby button
IMPORTANT
IMPORTANT:
This method forces the server to enter standby mode without properly exiting applications and the operating system. Use this method only when the server system crashes. For example, a process gets stuck.
1.        Press and hold the power on/standby button until the system power LED turns into steady amber.
Powering off the server from the HDM Web interface
1.        Log in to HDM.
2.        Power off the server.
Powering off the server from the remote console interface
1.        Log in to HDM.
2.        Log in to a remote console and then power off the server.
The following information describes the procedures to configure the server after the server installation is complete.
Figure 19 Configuration flowchart
1.        Power on the server. For information about the procedures, see "Powering on the server."
2.        Verify that the health LED on the front panel is steady green, which indicates that the system is operating correctly. For more information about the health LED status, see "LEDs and buttons."
You can set the server boot order and the BIOS user and administrator passwords from the BIOS setup utility of the server.
The server has a default boot order and you can change the server boot order from the BIOS. For more information about changing the server boot order, see the BIOS user guide for the server.
For more information about setting the BIOS passwords, see the BIOS user guide for the server.
Configuring RAID
Configure physical and logical drives (RAID arrays) for the server.
The supported RAID levels and RAID configuration methods vary by storage controller model. For more information, see the storage controller user guide for the server.
Install a compatible operating system on the server by following the procedures described in the operating system installation guide for the server.
For information about the operating system compatibility, see the operating system compatibility matrix for the server.
IMPORTANT
IMPORTANT:
In case an update failure causes hardware unavailability, always back up the drivers before you update them.
For newly installed hardware to operate correctly, the operating system must have the required hardware drivers.
To install a hardware driver, see the operating system installation guide for the server.
Updating firmware
IMPORTANT
IMPORTANT:
Verify the hardware and software compatibility before firmware upgrade. For information about the hardware and software compatibility, see the software release notes.
You can update the following firmware from FIST or HDM:
·          HDM.
·          BIOS.
·          CPLD.
For information about the update procedures, see the firmware update guide for the server.
If you are installing multiple hardware options, read their installation procedures and identify similar steps to streamline the entire installation procedure.
1.        Press the right edge of the security bezel into the groove in the right chassis ear on the server, as shown by callout 1 in Figure 20.
2.        Press the latch at the other end, close the security bezel, and then release the latch to secure the security bezel into place. See callouts 2 and 3 in Figure 20.
3.        Insert the key provided with the bezel into the lock on the bezel and lock the security bezel, as shown by callout 4 in Figure 20. Then, pull out the key and keep it safe.
CAUTION
CAUTION:
To avoid damage to the lock, hold down the key while you are turning the key.
Figure 20 Installing the security bezel
Guidelines
The drives are hot swappable. If you hot swap an HDD repeatedly within 30 seconds, the system might fail to identify the drive.
If you are using the drives to create a RAID, follow these restrictions and guidelines:
·          To build a RAID (or a logical drive) successfully, make sure all drives in the RAID are the same type (HDDs or SSDs) and have the same connector type (SAS or SATA).
·          For efficient use of storage, use drives that have the same capacity to build a RAID. If the drives have different capacities, the lowest capacity is used across all drives in the RAID. If you use one physical drive to create multiple logical drives for storage efficiency, RAID performance might decrease in addition to increased maintenance complexities.
·          If the installed drive contains RAID information, you must clear the information before configuring RAIDs. For more information, see the storage controller user guide for the server.
1.        Remove the security bezel, if any. For more information, see "Replacing the security bezel."
2.        Press the latch on the drive blank inward, and pull the drive blank out of the slot, as shown in Figure 21.
Figure 21 Removing the drive blank
3.        Install the drive:
a.    Press the button on the drive panel to release the locking lever.
Figure 22 Releasing the locking lever
b.    Insert the drive into the slot and push it gently until you cannot push it further.
c.    Close the locking lever until it snaps into place.
Figure 23 Installing a drive
4.        Install the removed security bezel. For more information, see "Installing the security bezel."
Verifying the installation
Use the following methods to verify that the drive is installed correctly:
·          Verify the drive properties (including capacity) by using one of the following methods:
¡  Log in to HDM. For more information, see HDM online help.
¡  Access the BIOS. For more information, see the storage controller user guide for the server.
¡  Access the CLI or GUI of the server.
·          Observe the drive LEDs to verify that the drive is operating correctly. For more information, see "Drive LEDs."
Guidelines
The NVMe drives support hot insertion and managed hot removal.
Only one NVMe drive can be hot inserted at a time. To hot insert multiple NVMe drives, wait a minimum of 60 seconds for the previously installed NVMe drive to be identified before hot inserting another NVMe drive.
·          For efficient use of storage, use drives that have the same capacity to build a RAID. If the drives have different capacities, the lowest capacity is used across all drives in the RAID. A drive with extra capacity cannot be used to build other RAIDs.
2.        Push the latch on the drive blank, and pull the drive blank out of the slot, as shown in Figure 24.
Figure 24 Removing the drive blank
Figure 25 Releasing the locking lever
b.    Insert the drive into the bay and push it gently until you cannot push it further.
Figure 26 Installing a drive
¡  Access HDM. For more information, see HDM online help.
¡  Access the BIOS. For more information, see the BIOS user guide for the server.
Guidelines
·          The power supplies are hot swappable.
·          Make sure the installed power supplies are the same model. HDM will perform power supply consistency check and generate an alarm if the power supply models are different.
·          To avoid hardware damage, do not use third-party power supplies.
1.        As shown in Figure 27, remove the power supply blank from the target power supply slot.
Figure 27 Removing the power supply blank
2.        Align the power supply with the slot, with its fan on the left.
3.        Push the power supply into the slot until it snaps into place.
Figure 28 Installing a power supply
4.        Connect the power cord. For more information, see "Connecting the power cord."
Use one of the following methods to verify that the power supply is installed correctly:
·          Observe the power supply LED to verify that the power supply is operating correctly. For more information about the power supply LED, see "Rear panel."
·          Log in to HDM to verify that the power supply is operating correctly. For more information, see HDM online help.
The server provides two PCIe riser connectors on the system board to connect riser cards. Each riser card has one PCIe slot for holding a PCIe module.
For more information about the connector locations, see "System board components."
Guidelines
You can install a PCIe module in a PCIe slot with a larger size. For example, an LP PCIe module can be installed in an FHFL PCIe slot.
A PCIe slot can supply power to the installed PCIe module if the maximum power consumption of the module does not exceed 75 W. If the maximum power consumption exceeds 75 W, a power cord is required. Among PCIe modules available for the server, only the GPU-M4000-1-X GPU module requires a power cord. For more information about connecting the power cord, see "Connecting the power cord of a GPU module."
The riser card installation procedure is the same for PCIe riser connectors 1 and 2. This procedure uses PCIe riser connector 1 as an example.
To install a riser card and PCIe module:
1.        Power off the server. For more information, see "Powering off the server."
2.        Remove the server from the rack. For more information, see "Removing the server from a rack."
3.        Remove the access panel. For more information, see "Removing the access panel."
4.        If a fastening screw retains a PCIe module blank on the riser card, remove and then re-install that screw as follows:
a.    Open the retaining latch on the riser card and then remove the fastening screw, as shown in Figure 29.
Figure 29 Removing the fastening screw from the riser card
b.    Re-install the fastening screw upside down, as shown in Figure 30.
Figure 30 Re-install the fastening screw to the riser card
5.        Install the PCIe module to the riser card:
a.    Open the retaining latch on the riser card, and then pull the PCIe module blank out of the slot, as shown in Figure 31.
Figure 31 Removing the PCIe module blank
b.    Insert the PCIe module into the slot along the guide rails and close the retaining latch to secure the PCIe module into place, as shown in Figure 32.
Figure 32 Installing the PCIe module
6.        Remove the blank on PCIe riser connector 1, as shown in Figure 33.
Figure 33 Removing the riser card blank on PCIe riser connector 1
7.        Install the riser card on the PCIe riser connector, with the two tabs on the card aligned with the notches in the chassis, as shown in Figure 34.
IMPORTANT
IMPORTANT:
Make sure the riser card is securely installed. The server cannot be powered up if the connection is loose.
Figure 34 Installing the riser card
8.        (Optional.) Connect PCIe module cables.
9.        Install the access panel. For more information, see "Installing the access panel."
10.     Rack-mount the server. For more information, see "Rack-mounting the server."
11.     Connect the power cord. For more information, see "Connecting the power cord."
12.     Power on the server. For more information, see "Powering on the server."
To prevent data loss when power outage occurs, you can use a power fail safeguard module.
A power fail safeguard module provides a flash card and a supercapacitor. When a system power failure occurs, this supercapacitor provides power for a minimum of 20 seconds. During this interval, the storage controller transfers data from DDR memory to the flash card, where the data remains indefinitely or until the controller retrieves the data.
Guidelines
The supercapacitor might have a low charge after the power fail safeguard module is installed. If the system displays that the supercapacitor has low charge, no action is required. The system will charge the supercapacitor automatically. You can view the status of the supercapacitor from the BIOS.
Each supercapacitor has a short supercapacitor cable attached to it and requires an extension cable for storage controller connection. The required extension cable varies by supercapacitor model and storage controller model. Use Table 6 to determine the extension cable to use.
Table 6 Supercapacitor extension cable selection
Storage controller type
Storage controller model
Supercapacitor
Extension cable P/N
·         RAID-P430-M1
·         RAID-P430-M2
Supercapacitor of the Flash-PMC-G2 power fail safeguard module
N/A
The cable does not have a P/N.
RAID-P460-M2
BAT-PMC-G3
0404A0TG
RAID-P460-M4
BAT-PMC-G3
0404A0TG
RAID-L460-M4
BAT-LSI-G3
0404A0XH
Standard storage controller
·         RAID-LSI-9361-8i(1G)-A1-X
·         RAID-LSI-9361-8i(2G)-1-X
Supercapacitor of the Flash-LSI-G2 power fail safeguard module
0404A0SV
·         RAID-LSI-9460-8i(2G)
·         RAID-LSI-9460-8i(4G)
BAT-LSI-G3
0404A0VC
RAID-P460-B2
BAT-PMC-G3
0404A0TG
RAID-P460-B4
BAT-PMC-G3
0404A0TG
·          Identify the type of the storage controller.
·          If you are installing a power fail safeguard module, make sure it is compatible with the storage controller. For information about storage controllers and their compatibility matrices, see "Storage controllers."
4.        Remove the power supply air baffles if it hinders storage controller installation. For more information, see "Removing air baffles."
5.        Remove a riser card if it hinders storage controller installation. For more information, see "Replacing a riser card and a PCIe module."
6.        Align the pin holes in the Mezzanine storage controller with the guide pins on the system board. Insert the guide pins into the pin holes, and then fasten the three captive screws to secure the controller onto the system board, as shown in Figure 35.
The installation method for all Mezzanine storage controllers is the same. This figure is for illustration only.
Figure 35 Installing a Mezzanine storage controller
7.        Install the flash card of the power fail safeguard module to the storage controller:
IMPORTANT
IMPORTANT:
Skip this step if no power fail safeguard module is required or the storage controller has a built-in flash card. For more information about storage controllers with a built-in flash card, see "Storage controllers."
a.    Install the two internal threaded studs supplied with the power fail safeguard module on the Mezzanine storage controller, as shown in Figure 36.
Figure 36 Installing the internal threaded studs
b.    Use screws to secure the flash card onto the storage controller, as shown in Figure 37.
Figure 37 Installing the flash card
8.        (Optional.) Install the supercapacitor:
a.    Install the supercapacitor holder. Place the supercapacitor holder in the chassis and then slide it until it snaps into place, as shown in Figure 38.
The server comes with a supercapacitor holder in the chassis. If the built-in supercapacitor holder is incompatible with the supercapacitor to be installed, remove the holder and install a compatible one. For more information about removing a supercapacitor holder, see "Replacing the power fail safeguard module for the Mezzanine storage controller."
The installation method for different supercapacitor holders is the same. This figure is for illustration only.
Figure 38 Installing the supercapacitor holder
b.    Install the supercapacitor. Insert the cableless end of the supercapacitor into the supercapacitor holder, pull the clip on the holder, insert the cable end of the supercapacitor into the holder, and then release the clip, as shown in Figure 39.
·      For simplicity, the figure does not show the cable attached to the supercapacitor.
·      The installation method for different supercapacitors is the same. This figure is for illustration only.
Figure 39 Installing the supercapacitor
c.    Connect the storage controller to the supercapacitor. Connect one end of the supercapacitor extension cable to the supercapacitor and the other end to the Mezzanine storage controller. For more information about the connection method, see "Connecting the flash card and supercapacitor of the power fail safeguard module."
CAUTION
CAUTION:
Make sure the extension cable is the correct one. For more information, see Table 6.
9.        Connect front drive data cables to the Mezzanine storage controller. For more information, see "Connecting drive cables."
10.     Install the removed riser cards. For more information, see "Installing riser cards and PCIe modules."
11.     Install the removed power supply air baffle. For more information, see "Installing air baffles."
12.     Install the access panel. For more information, see "Installing the access panel."
13.     Rack-mount the server. For more information, see "Rack-mounting the server."
14.     Connect the power cord. For more information, see "Connecting the power cord."
15.     Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the Mezzanine storage controller, flash card, and supercapacitor are operating correctly. For more information, see HDM online help.
4.        Install the flash card of the power fail safeguard module to the storage controller:
IMPORTANT
IMPORTANT:
Skip this step if no power fail safeguard module is required or the storage controller has a built-in flash card. For information about storage controllers with a built-in flash card, see "Storage controllers."
a.    Install the two internal threaded studs supplied with the power fail safeguard module on the storage controller, as shown in Figure 40.
Figure 40 Installing the internal threaded studs
b.    Slowly insert the flash card connector into the socket and use screws to secure the flash card on the storage controller, as shown in Figure 41.
Figure 41 Installing the flash card
5.        Connect one end of the supercapacitor extension cable to the flash card.
CAUTION
CAUTION:
¡  If the storage controller is installed with an external flash card, connect the supercapacitor extension cable to the flash card, as shown in Figure 42.
Figure 42 Connecting the supercapacitor extension cable to the flash card
¡  If the storage controller uses a built-in flash card, connect the supercapacitor extension cable to the supercapacitor connector on the storage controller.
6.        Install the storage controller to the server by using a riser card. For more information, see "Installing riser cards and PCIe modules."
7.        (Optional.) Install the supercapacitor, and then connect the other end of the supercapacitor extension cable to the supercapacitor. For more information, see "Installing a Mezzanine storage controller and a power fail safeguard module."
8.        Connect the data cables of front drives to the storage controller. For more information, see "Connecting drive cables."
Log in to HDM to verify that the standard storage controller, flash card, and supercapacitor are operating correctly. For more information, see HDM online help.
Guidelines
A riser card is required for GPU module installation.
A GPU module comes with a GPU support bracket if it requires a power cord, as shown in Figure 43. This support bracket is required for secure installation on some server models. On an R4700 server, you do not need to install this support bracket.
The GPU-M4000-1-X GPU module requires a power cord (P/N 0404A0M3).
Figure 43 GPU support bracket
The GPU module installation procedure is the same for PCIe slots 1 and 2. This procedure uses PCIe slot 1 as an example.
To install a GPU module:
4.        Remove the PCIe module blank from PCIe slot 1. Make sure its fastening screw is re-installed upside down. For more information, see "Installing riser cards and PCIe modules."
5.        Install the GPU module in PCIe slot 1:
¡  If the GPU module does not require a power cord, open the retaining latch on the riser card, and then insert the GPU module into the slot, as shown in Figure 44.
Figure 44 Installing a GPU module (GPU-M4-1 GPU module)
¡  If the GPU module requires a power cord, open the retaining latch on the riser card and insert the GPU module into the slot. Then, connect the 6-pin connector of the GPU power cord to the GPU module and connect the other end of the power cord to the riser card.
Figure 45 Installing a GPU module (GPU-M4000-1-X GPU module)
6.        Install the riser card on PCIe riser connector 1. For more information, see "Installing riser cards and PCIe modules."
7.        Connect cables for the GPU module as needed.
8.        Install fans. To guarantee cooling performance, you must install fans in all the fan bays. For more information, see "Installing fans."
Log in to HDM to verify that the GPU module is operating correctly. For more information, see HDM online help.
Guidelines
You can install an mLOM Ethernet adapter only in the mLOM Ethernet adapter connector on the system board. For more information about the connector location, see "System board components."
A riser card is required for PCIe Ethernet adapter installation. For more information about PCIe Ethernet adapter and riser card compatibility, see "Riser cards."
The server supports one HDM shared network port for out-of-band HDM management, which is available if an NCSI-capable mLOM or PCIe Ethernet adapter is installed. By default, port 1 on the mLOM Ethernet adapter (if any) is used as the HDM shared network port. If no mLOM Ethernet adapter is installed, port 1 on the PCIe Ethernet adapter is used. You can change the HDM shared network port as needed from the HDM Web interface.
2.        Install the mLOM Ethernet adapter:
a.    Insert the flathead screwdriver supplied with the server into the opening between the mLOM Ethernet adapter blank and its handle, and pull the blank out of the chassis with the screwdriver, as shown in Figure 46.
Figure 46 Removing the mLOM Ethernet adapter blank
b.    Insert the mLOM Ethernet adapter into the slot along the guide rails, and then fasten the captive screws to secure the Ethernet adapter into place, as shown in Figure 47.
Some mLOM Ethernet adapters have only one captive screw. This example uses an mLOM with two captive screws.
Figure 47 Installing an mLOM Ethernet adapter
3.        Connect network cables to the mLOM Ethernet adapter.
Log in to HDM to verify that the mLOM Ethernet adapter is operating correctly. For more information, see HDM online help.
4.        Install the PCIe Ethernet adapter. For more information, see "Installing riser cards and PCIe modules."
5.        If the adapter is NCSI-capable and is intended to provide an HDM shared network port, connect the NCSI cable for the PCIe Ethernet adapter. For more information, see "Connecting the NCSI cable for a PCIe Ethernet adapter."
6.        Connect network cables to the PCIe Ethernet adapter.
7.        Install the access panel. For more information, see "Installing the access panel."
8.        Rack-mount the server. For more information, see "Rack-mounting the server."
9.        Connect the power cord. For more information, see "Connecting the power cord."
10.     Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the PCIe Ethernet adapter is operating correctly. For more information, see HDM online help.
Guidelines
If you are installing two SATA M.2 SSDs, install two SATA M.2 SSDs of the same model to ensure high availability.
As a best practice, use SATA M.2 SSDs to install the operating system.
You can use the following methods to install SATA M.2 SSDs:
·          Install SATA M.2 SSDs at the front of a 4LFF or 8SFF server. For more information about the installation location, see "Front panel view."
·          Install SATA M.2 SSDs at the server rear by using a riser card.
4.        Install the SATA M.2 SSD on the M.2 transfer module:
CAUTION
CAUTION:
If you are installing only one SATA M.2 SSD, install it in the socket shown in Figure 48.
a.    Insert the connector of the SSD into the socket, and push down the other end of the SSD. Then, fasten the screw supplied with the transfer module to secure the SSD into place, as shown in Figure 48.
Figure 48 Installing a SATA M.2 SSD on the M.2 transfer module
b.    Connect the SATA M.2 SSD cable to the M.2 transfer module, as shown in Figure 49.
If only one SATA M.2 SSD is installed, use the cable marked with P/N 0404A0ST. If two SATA M.2 SSDs are installed, use the cable marked with P/N 0404A0TH.
Figure 49 Connecting the SATA M.2 SSD cable
5.        Remove the blank from the M.2 transfer module slot, as shown in Figure 50:
a.    Press the clip on the right side of the blank. The blank pops out partially.
b.    Pull the blank out of the slot.
Figure 50 Removing the blank from the M.2 transfer module slot
6.        Install the M.2 transfer module in the slot. The installation procedure is the same for an M.2 module and a SATA optical drive. For more information, see "Installing a SATA optical drive."
7.        Disconnect the drive backplane power cord, as shown in Figure 51.
Figure 51 Disconnecting the drive backplane power cord
8.        Connect the SATA M.2 SSD cable to the system board. The connection method depends on the drive configuration. For more information about how to connect the SATA M.2 SSD cable, see "Connecting the SATA M.2 SSD cable."
4.        Install the SATA M.2 SSD on the M.2 transfer module. For more information, see "Installing SATA M.2 SSDs at the server front (4LFF server)."
5.        Install the M.2 transfer module into the drive enablement option:
a.    Press the clip on the right side of the blank in the enablement option, as shown by callout 1 in Figure 52. The blank pops out partially from the enablement option.
b.    Pull the blank out of the enablement option, as shown by callout 2 in Figure 52.
Figure 52 Removing the blank in the enablement option
c.    Insert the M.2 transfer module into the enablement option and fasten the screw to secure it into place, as shown in Figure 53.
Figure 53 Inserting the M.2 transfer module into the enablement option
6.        Install the enablement option in the front upper right slot of the server:
a.    Remove the fastening screws on the blank in the slot, and then push the blank out of the chassis from the inside of the chassis, as shown in Figure 54.
Figure 54 Removing the blank in the front upper right slot of the server
b.    Insert the enablement option into the slot and use screws to secure it into place, as shown in Figure 55.
Figure 55 Installing the enablement option
7.        Connect the SATA M.2 SSD cable to the system board. The connection method depends on the drive configuration. For more information about how to connect the SATA M.2 SSD cable, see "Connecting the SATA M.2 SSD cable."
8.        Install the access panel. For more information, see "Installing the access panel."
9.        Rack-mount the server. For more information, see "Rack-mounting the server."
10.     Connect the power cord. For more information, see "Connecting the power cord."
11.     Power on the server. For more information, see "Powering on the server."
4.        Install the SATA M.2 SSD to the M.2 transfer module:
a.    Insert the connector of the SSD into the socket, and push down the other end of the SSD. Then, fasten the screw supplied with the transfer module to secure the SSD into place, as shown in Figure 56.
CAUTION
CAUTION:
To install only one SATA M.2 SSD, install it in the socket marked with J4.
b.    Connect the SATA M.2 SSD cable to the M.2 transfer module, as shown in Figure 56.
Figure 56 Installing a SATA M.2 SSD to the M.2 transfer module
5.        Install the transfer module to a riser card and then install the riser card on a PCIe riser connector. For more information, see "Installing riser cards and PCIe modules."
6.        Connect the SATA M.2 SSD cable to the system board. For more information about connecting the SATA M.2 SSD cable, see "Connecting the rear SATA M.2 SSD cable."
Installing SD cards
Guidelines
SD card installation requires a dual SD card extended module.
The SD cards are hot swappable.
To gain redundancy and storage efficiency, install two same capacity SD cards.
4.        Insert the SD card into a slot in the dual SD card extended module, with its gold-plated edge facing downward, as shown in Figure 57.
Figure 57 Installing an SD card
5.        Align the two blue clips on the expansion module with the bracket on the power supply bay, and slowly slide the module downwards until it snaps into place, as shown in Figure 58.
Figure 58 Installing the dual SD card extended module
6.        Install the access panel. For more information, see "Installing the access panel."
7.        Rack-mount the server. For more information, see "Rack-mounting the server."
8.        Connect the power cord. For more information, see "Connecting the power cord."
9.        Power on the server. For more information, see "Powering on the server."
Guidelines
A riser card is required for NVMe SSD expander module installation.
An NVMe SSD expander module is required only when NVMe drives are installed. For configurations that require an NVMe expander module, see "Drive configurations and numbering."
The procedure is the same for installing a 4-port NVMe SSD expander module and an 8-port NVMe SSD expander module. The following procedure uses a 4-port NVMe SSD expander module as an example.
To install an NVMe SSD expander module:
4.        Remove the power supply air baffle if it hinders the installation. For more information, see "Removing air baffles."
5.        Connect the four NVMe data cables to the NVMe SSD expander module, as shown in Figure 59.
Make sure you connect ports on the NVMe SSD expander module with the correct NVMe data cables. For more information, see "8SFF server."
Figure 59 Connecting an NVMe data cable to the NVMe SSD expander module
6.        Install the NVMe SSD expander module to the server by using a PCIe riser card. For more information, see "Installing riser cards and PCIe modules."
7.        Connect the NVMe data cables to the drive backplane. Make sure you connect ports on the drive backplane with the correct NVMe data cables. For more information, see "Connecting internal cables."
8.        Install the removed power supply air baffle. For more information, see "Installing air baffles."
Log in to HDM to verify that the NVMe SSD expander module is operating correctly. For more information, see HDM online help.
1.        Identify the NVMe VROC module connector on the system board. For more information, see "System board components."
2.        Power off the server. For more information, see "Powering off the server."
3.        Remove the server from the rack. For more information, see "Removing the server from a rack."
4.        Remove the access panel. For more information, see "Removing the access panel."
5.        Remove the power supply air baffle. For more information, see "Removing air baffles."
6.        Insert the NVMe VROC module onto the NVMe VROC module connector on the system board, as shown in Figure 60.
Figure 60 Installing the NVMe VROC module
7.        Install the removed power supply air baffle. For more information, see "Installing air baffles."
Only the 8SFF server supports installing a front 2SFF drive cage.
To install the front 2SFF drive cage:
4.        Remove the screws that secure the drive cage blank, and then pull the blank out of the chassis, as shown in Figure 61.
Figure 61 Removing the drive cage blank
5.        Insert the 2SFF drive cage into the slot and then use screws to secure it into place, as shown in Figure 64.
Figure 62 Installing the 2SFF drive blank
6.        Connect the AUX signal cable, data cable, and power cord to the front 2SFF drive backplane. For more information about cable connection to the front 2SFF SAS/SATA drive backplane and the front 2SFF NVMe drive backplane, see Figure 163 and Figure 169, respectively.
7.        Install drives in the front 2SFF drive cage. For more information, see "Installing SAS/SATA drives."
Log in to HDM to verify that the installed drives are operating correctly. For more information, see HDM online help.
Guidelines
Only the 4LFF and 10SFF servers support installing a rear 2SFF drive cage.
If drives are installed in the rear drive cage, make sure all the seven fans are present before you power on the server. For more information about installing fans, see "Installing fans."
4.        Remove the power supply air baffle. For more information, see "Removing air baffles."
5.        Remove the blanks on PCIe riser connectors 1 and 2, as shown in Figure 63.
Figure 63 Removing the blanks on PCIe riser connectors 1 and 2
6.        Install the 2SFF rear drive cage:
a.    Align the three tabs on the cage with the three notches on the chassis, and place the drive cage in the chassis, as shown by callout 1 in Figure 64.
b.    Fasten the captive screw to secure the drive cage, as shown in Figure 64.
Figure 64 Installing the 2SFF rear drive cage
7.        For the 4LFF server, disconnect the existing 1-to-1 SAS/SATA data cable from the front drive backplane.
8.        Connect the AUX signal cable, 1-to-2 data cable, and power cord to the 2SFF rear drive backplane. For more information, see "Connecting drive cables."
9.        Install drives in the 2SFF rear drive cage. For more information, see "Installing SAS/SATA drives."
10.     Install the removed power supply air baffle. For more information, see "Installing air baffles."
11.     Install the access panel. For more information, see "Installing the access panel."
12.     Rack-mount the server. For more information, see "Rack-mounting the server."
13.     Connect the power cord. For more information, see "Connecting the power cord."
14.     Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the rear drives are operating correctly. For more information, see HDM online help.
Installing the front media module (VGA and USB 2.0 connectors)
A front media module provides a VGA connector and two USB 2.0 connectors.
Installing the front media module (4LFF server)
1.        Identify the installation location. For more information, see "Front panel view."
4.        Remove the security bezel, if any. For more information, see "Replacing the security bezel."
5.        Remove the access panel. For more information, see "Removing the access panel."
6.        Pull the front media module blank out of the slot, as shown in Figure 65.
Figure 65 Removing the front media module blank
7.        Place the front media module inside the chassis and push the module toward the front of the server until the connector on the module protrudes out of the front panel of the server, as shown in Figure 66. Then, use screws to secure the module into place.
Figure 66 Installing the front media module
8.        Connect the front media module cable to the system board:
a.    Remove the factory pre-installed chassis-open alarm module, if any. For more information, see "Removing the chassis-open alarm module."
b.    Install the chassis-open alarm module attached to the front media module. For more information, see "Installing the chassis-open alarm module."
c.    Connect the front media cable to the system board. For more information, see "Connecting the front media module cable."
9.        Connect the external VGA and USB 2.0 cable to the front media module, and then fasten the captive screws, as shown in Figure 67.
Figure 67 Connecting the external VGA and USB 2.0 cable to the front media module
10.     Install the access panel. For more information, see "Installing the access panel."
11.     Rack-mount the server. For more information, see "Rack-mounting the server."
12.     Connect the power cord. For more information, see "Connecting the power cord."
13.     Power on the server. For more information, see "Powering on the server."
Installing the front media module (8SFF/10SFF server)
6.        Remove the front I/O module from the slot shared with the front media module, and then remove the I/O component from the front I/O module. For more information, see "Replacing the front I/O component (8SFF/10SFF server)."
Figure 68 Slot shared by the front I/O module and the front media module
7.        Install the removed front I/O component in the front media module, as shown in Figure 69.
For simplicity, this figure does not show the front media module component.
Figure 69 Installing the front I/O component in the front media module
8.        Insert the front media module in the front media module slot, and then use a screw to secure it into place, as shown in Figure 70.
Figure 70 Installing the front media module
9.        Connect the front media module cable to the system board:
a.    Remove the factory pre-installed chassis-open alarm module. For more information about the removal procedure, see "Removing the chassis-open alarm module."
c.    Connect the front media module cable to the system board. For more information, see "Connecting the front media module cable."
10.     Connect the external VGA and USB 2.0 cable to the front media module, and then fasten the captive screws, as shown in "Installing the front media module (4LFF server)."
11.     Connect the front I/O component cable assembly. For more information, see "Connecting the front I/O component cable assembly."
Installing an optical drive
Preparing for the installation
Use Table 7 to determine the location of the optical drive you are installing depending on the type of the optical drive.
Table 7 Optical drive installation locations
Optical drive
Installation location
USB 2.0 optical drive
Connect the optical drive to a USB 2.0 or USB 3.0 connector on the server.
SATA optical drive
·         4LFF server: Optical drive slot.
·         8SFF server: Optical drive slot.
·         10SFF server: Not supported.
For the location of the optical drive slot, see "Front panel view."
5.        Install the SATA optical drive:
¡  On the 4LFF server, remove the blank from the optical drive slot (see "Installing SATA M.2 SSDs at the server front (4LFF server)"). Install the drive in the slot, with the guide pins on the chassis aligned with the two holes in one side of the optical drive. Then, use the screw supplied with the SATA optical drive to secure the optical drive into place, as shown in Figure 71.
Figure 71 Installing the SATA optical drive for the 4LFF server
¡  On the 8SFF server, install the optical drive by using a drive enablement option. For more information, see "Installing SATA M.2 SSDs at the server front (8SFF server)."
6.        Connect the SATA optical drive cable. For more information, see "Connecting the front SATA M.2 SSD cable (8SFF server)."
7.        Install the removed security bezel. For more information, see "Installing the security bezel."
Installing a diagnostic panel
Verify that the diagnostic panel is compatible with your drive configuration, as follows:
·          Use an SFF diagnostic panel for 8SFF and 10SFF servers.
·          Use an LFF diagnostic panel for the 4LFF server.
For the installation location of the diagnostic panel, see "Front panel view."
Identify the diagnostic panel cable before you install the diagnostic panel. The PN for the cable is 0404A0SP.
The installation procedure is the same for SFF and LFF diagnostic panels. This procedure uses an SFF diagnostic panel as an example.
To install a diagnostic panel:
2.        Remove the security bezel, if any. For more information, see "Replacing the security bezel."
3.        Remove the blank or drive from the slot in which the diagnostic panel will be installed.
For more information about removing the blank, see "Installing SAS/SATA drives."
For more information about removing the drive, see "Replacing a SAS/SATA drive."
4.        Install the diagnostic panel:
a.    Connect the diagnostic panel cable to the diagnostic panel, as shown in Figure 72.
Figure 72 Connecting the diagnostic panel cable to the diagnostic panel
b.    Push the diagnostic panel into the slot until it snaps into place, as shown in Figure 73.
Figure 73 Installing the SFF diagnostic panel
5.        Install the removed security bezel. For more information, see "Installing the security bezel."
6.        Connect the power cord. For more information, see "Connecting the power cord."
7.        Power on the server. For more information, see "Powering on the server."
Installing fans
Guidelines
The fans are hot swappable. If sufficient space is available for installation, you can install fans without powering off the server or removing the server from the rack. The following procedure is provided based on the assumption that no sufficient space is available for replacement.
The server provides seven fan bays. You must install fans in all fan bays in any of the following conditions:
·          Two processors are present.
·          One processor is present and a GPU module is installed.
·          One processor is present and an NVMe SSD is installed at the front.
·          On the 4LFF/10SFF server, one processor is present and a drive is installed at the rear of the server.
In any other conditions, you must install fans in fan bays 4 through 7 and the remaining fan bays can be empty. If a fan bay is empty, make sure a fan blank is installed. For the locations of fans in the server, see "Fans."
The server will be powered off gracefully if any of its sensors detects that the temperature has reached the critical threshold. If the temperature of a critical component, such as a processor, exceeds the overtemperature threshold, the server is powered off immediately. You can view the detected temperatures and thresholds from the HDM Web interface.
4.        Remove the chassis air baffles. For more information, see "Removing air baffles."
5.        Lift the fan blank to remove it, as shown in Figure 74.
Figure 74 Removing a fan blank
6.        Install the fan in the fan bay, as shown in Figure 75.
Figure 75 Installing a fan
7.        Install the chassis air baffles. For more information, see "Installing air baffles."
Log in to HDM to verify that the fan is operating correctly. For more information, see HDM online help.
Installing processors
Guidelines
·          To avoid damage to the processors or system board, only H3C-authorized personnel and professional server engineers are allowed to install a processor.
·          Make sure the processors are the same model if two processors are installed.
·          The pins in the processor socket are very fragile. Make sure a processor socket cover is installed on an empty processor socket.
·          For the server to operate correctly, make sure processor 1 is in position. For more information about processor locations, see "System board components."
·          To avoid ESD damage, put on an ESD wrist strap before performing this task, and make sure the wrist strap is reliably grounded.
1.        Back up all server data.
5.        Remove the chassis air baffle. For more information, see "Removing air baffles."
6.        Install a processor onto the retaining bracket, as shown in Figure 76:
CAUTION
CAUTION:
To avoid damage to the processor, always hold the processor by its edges. Never touch the gold contacts on the processor bottom.
a.    As shown by callout 1 in the figure, align the small triangle on the processor with the alignment triangle in the retaining bracket, and align the guide pin on the bracket with the notch on the triangle side of the processor.
b.    As shown by callout 2 in the figure, lower the processor gently and make sure the guide pins on the opposite side of the bracket fit snugly into the notches on the processor.
Figure 76 Installing a processor onto the retaining bracket
7.        Install the retaining bracket onto the heatsink:
CAUTION
CAUTION:
When you remove the protective cover over the heatsink, be careful not to touch the thermal grease on the heatsink.
a.    Lift the cover straight up until it is removed from the heatsink, as shown in Figure 77.
Figure 77 Removing the protective cover
b.    Install the retaining bracket onto the heatsink. As shown in Figure 78, align the alignment triangle on the retaining bracket with the cut-off corner of the heatsink. Place the bracket on top of the heatsink, with the four corners of the bracket clicked into the four corners of the heatsink.
Figure 78 Installing the processor onto the heatsink
8.        Remove the processor socket cover.
CAUTION
CAUTION:
·      Take adequate ESD preventive measures when you remove the processor socket cover.
·      Be careful not to touch the pins on the processor socket, which are very fragile. Damage to pins will incur system board replacement.
·      Keep the pins on the processor socket clean. Make sure the socket is free from dust and debris.
Hold the cover by the notches on its two edges and lift it straight up and away from the socket. Put the cover away for future use.
Figure 79 Removing the processor socket cover
9.        Install the retaining bracket and heatsink onto the server as shown in Figure 80.
a.    Place the heatsink on the processor socket. Make sure the alignment triangle on the retaining bracket and the pin holes in the heatsink are aligned with the cut-off corner and guide pins of the processor socket, respectively, as shown by callout 1.
b.    Fasten the captive screws on the heatsink in the sequence shown by callouts 2 through 5.
CAUTION
CAUTION:
To avoid poor contact between the processor and the system board or damage to the pins in the processor socket, tighten the screws to a torque value of 1.4 Nm (12 in-lbs).
Figure 80 Attaching the retaining bracket and heatsink to the processor socket
10.     Install fans. For more information, see "Installing fans."
11.     Install DIMMs. For more information, see "Installing DIMMs."
12.     Install the chassis air baffle. For more information, see "Installing air baffles."
13.     Install the access panel. For more information, see "Installing the access panel."
14.     Rack-mount the server. For more information, see "Rack-mounting the server."
15.     Connect the power cord. For more information, see "Connecting the power cord."
16.     Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the processor is operating correctly. For more information, see HDM online help.
Installing DIMMs
The server supports DCPMMs and DRAM DIMMs (both LRDIMM and RDIMM supported). Compared with DRAM DIMMs, DCPMMs provide larger capacity and can protect data from getting lost in case of unexpected system failures.
Both DCPMMs and DRAM DIMMs are referred to as DIMMs in this document, unless otherwise stated.
Guidelines
WARNING
WARNING!
The DIMMs are not hot swappable.
You can install a maximum of 12 DIMMs for each processor, six DIMMs per memory controller. For more information about DIMMs, see "DIMM slots."
For a DIMM to operate at 2933 MHz, make sure the following conditions are met:
·          Use Cascade Lake processors that support 2933 MHz data rate.
·          Use DIMMs with a maximum of 2933 MHz data rate.
·          Install a maximum of one DIMM per channel.
The supported DIMMs vary by processor model, as shown in Table 8.
Table 8 Supported DIMMs of a processor
Processor
Supported DIMMs
Skylake
Only DRAM DIMMs.
Cascade Lake
·         Only DRAM DIMMs.
·         Mixture of DCPMM and DRAM DIMMs.
Jintide-C series
Only DRAM DIMMs.
Guidelines for installing only DRAM DIMMs
When you install only DRAM DIMMs, follow these restrictions and guidelines:
·          Make sure all DRAM DIMMs installed on the server have the same specifications.
·          Make sure the corresponding processor is present before powering on the server.
·          For the memory mode setting to operate correctly, make sure the following installation requirements are met when you install DRAM DIMMs for a processor:
Memory mode
DIMM requirements
Independent
·         If only one processor is present, see Figure 81.
·         If two processors are present, see Figure 82.
Mirror
Partial Mirror
·         A minimum of two DIMMs for a processor.
·         This mode does not support DIMM population schemes that are not recommended in Figure 81 and Figure 82.
·         DIMM installation scheme:
¡  If only processor 1 is present, see Figure 81.
¡  If two processors are present, see Figure 82.
Memory Rank Sparing
·         A minimum of 2 ranks per channel.
¡  If only one processor is present, see Figure 81.
If the DIMM configuration does not meet the requirements in the configured memory mode, the system uses the default memory mode (Independent mode). For more information about memory modes, see the BIOS user guide for the server.
Figure 81 DIMM population schemes (one processor present)
Figure 82 DIMM population schemes (two processors present)
Guidelines for mixture installation of DCPMMs and DRAM DIMMs
When you install DRAM DIMMs and DCPMMs on the server, follow these restrictions and guidelines:
·          Make sure the corresponding processors are present before powering on the server.
·          Make sure all DRAM DIMMs have the same product code and all DCPMMs have the same product code.
·          As a best practice to increase memory bandwidth, install DRAM and DCPMM DIMMs in different channels.
·          A channel supports a maximum of one DCPMM.
·          As a best practice, install DCPMMs symmetrically across the two memory processing units for a processor.
·          To install both DRAM DIMM and DCPMM in a channel, install the DRAM DIMM in the white slot and the DCPMM in the black slot. To install only one DIMM in a channel, install the DIMM in the white slot if the DIMM is DCPMM.
4.        Remove the chassis air baffle. For more information, see "Removing air baffles."
5.        Install a DIMM:
a.    Identify the location of the DIMM slot.
Figure 83 DIMM slots numbering
b.    Open the DIMM slot latches.
c.    Align the notch on the DIMM with the connector key in the DIMM slot and press the DIMM into the socket until the latches lock the DIMM in place, as shown in Figure 84.
To avoid damage to the DIMM, do not force the DIMM into the socket when you encounter resistance. Instead, re-align the notch with the connector key, and then re-insert the DIMM.
Figure 84 Installing a DIMM
6.        Install the chassis air baffle. For more information, see "Installing air baffles."
Use one of the following methods to verify that the memory size is correct:
·          Access the GUI or CLI of the server:
¡  In the GUI of a windows OS, click the Start icon in the bottom left corner, enter msinfo32 in the search box, and then click the msinfo32 item.
¡  In the CLI of a Linux OS, execute the cat /proc/meminfo command.
·          Log in to HDM. For more information, see HDM online help.
·          Access the BIOS. For more information, see the BIOS user guide for the server.
If the memory size is incorrect, re-install or replace the DIMM.
It is normal that the CLI or GUI of the server OS displays a smaller memory size than the actual size if the mirror, partial mirror, or memory rank sparing memory mode is enabled. In this situation, verify the memory size from HDM or BIOS.
Installing and setting up a TCM or TPM
Installation and setup flowchart
Figure 85 TCM/TPM installation and setup flowchart
Installing a TCM or TPM
Guidelines
·          Do not remove an installed TCM or TPM. Once installed, the module becomes a permanent part of the system board.
·          When installing or replacing hardware, H3C service providers cannot enable the TCM or TPM or the encryption technology. For security reasons, only the customer can enable these features.
·          When replacing the system board, do not remove the TCM or TPM from the system board. H3C will provide a TCM or TPM with the spare system board for system board or module replacement.
·          Any attempt to remove an installed TCM or TPM from the system board breaks or disfigures the TCM or TPM security rivet. Upon locating a broken or disfigured rivet on an installed TCP or TPM, administrators should consider the system compromised and take appropriate measures to ensure the integrity of the system data.
·          H3C is not liable for blocked data access caused by improper use of the TCM or TPM. For more information, see the encryption technology feature documentation provided by the operating system.
The installation procedure is the same for a TPM and a TCM. The following information uses a TPM to show the procedure.
To install a TPM:
4.        Remove the PCIe modules that might hinder TPM installation. For more information, see "Replacing a riser card and a PCIe module."
5.        Install the TPM:
a.    Press the TPM into the TPM connector on the system board, as shown in Figure 86.
Figure 86 Installing a TPM
b.    Insert the rivet pin as shown by callout 1 in Figure 87.
c.    Insert the security rivet into the hole in the rivet pin and press the security rivet until it is firmly seated, as shown by callout 2 in Figure 87.
Figure 87 Installing the security rivet
6.        Install the removed PCIe modules. For more information, see "Installing riser cards and PCIe modules."
Enabling the TCM or TPM from the BIOS
By default, the TCM and TPM are enabled for a server. For more information about configuring the TCM or TPM from the BIOS, see the BIOS user guide for the server.
You can log in to HDM to verify that the TCM or TPM is operating correctly. For more information, see HDM online help.
Configuring encryption in the operating system
For more information about this task, see the encryption technology feature documentation that came with the operating system.
The recovery key/password is generated during BitLocker setup, and can be saved and printed after BitLocker is enabled. When using BitLocker, always retain the recovery key/password. The recovery key/password is required to enter Recovery Mode after BitLocker detects a possible compromise of system integrity or firmware or hardware change.
For security purposes, follow these guidelines when retaining the recovery key/password:
·          Always store the recovery key/password in multiple locations.
·          Always store copies of the recovery key/password away from the server.
·          Do not save the recovery key/password on the encrypted hard drive.
For more information about Microsoft Windows BitLocker drive encryption, visit the Microsoft website at http://technet.microsoft.com/en-us/library/cc732774.aspx.
Replacing hardware options
If you are replacing multiple hardware options, read their replacement procedures and identify similar steps to streamline the entire replacement procedure.
1.        Insert the key provided with the bezel into the lock on the bezel and unlock the security bezel, as shown by callout 1 in Figure 88.
CAUTION
CAUTION:
2.        Press the latch at the left end of the bezel, open the security bezel, and then release the latch, as shown by callouts 2 and 3 in Figure 88.
3.        Pull the right edge of the security bezel out of the groove in the right chassis ear to remove the security bezel, as shown by callout 4 in Figure 88.
Figure 88 Removing the security bezel
4.        Install a new security bezel. For more information, see "Installing the security bezel."
Guidelines
The SAS/SATA drives are hot swappable.
To configure RAID settings after the drive is replaced, see the storage controller user guide for the server.
For more information about the guidelines for installing a drive, see "Installing SAS/SATA drives."
To replace a drive in a non-redundancy RAID array, back up data in the RAID array.
2.        Observe the drive LEDs to verify that the drive is not selected by the storage controller and is not performing a RAID migration or rebuilding. For more information about drive LEDs, see "HDDs and SSDs."
3.        Remove the drive, as shown in Figure 89:
¡  To remove an SSD, press the button on the drive panel to release the locking lever, and then hold the locking lever and pull the drive out of the slot.
¡  To remove an HDD, press the button on the drive panel to release the locking lever. Pull the drive 3 cm (1.18 in) out of the slot. Wait for a minimum of 30 seconds for the drive to stop rotating, and then pull the drive out of the slot.
Figure 89 Removing a drive
4.        Install a new drive. For more information, see "Installing SAS/SATA drives."
5.        Install the removed security bezel, if any. For more information, see "Installing the security bezel."
Verifying the replacement
Use one of the following methods to verify that the drive has been replaced correctly:
¡  Log in to HDM and access the System Info > Hardware Summary > Storage page. For more information, see HDM online help.
·          Observe the drive LEDs to verify that the Present/Active LED on the drive is lighted. For more information, see "Drive LEDs."
Replacing an NVMe drive
Guidelines
1.        Identify the NVMe drive to be removed and perform managed hot removal for the drive. For more information about managed hot removal, see "Appendix C  Managed hot removal of NVMe drives."
3.        Remove the drive, as shown in Figure 90:
b.    Hold the locking lever and pull the drive out of the slot.
Figure 90 Removing a drive
4.        Install a new drive. For more information, see "Installing NVMe drives."
·          Verify the drive properties (including its capacity) by using one of the following methods:
·          Observe the drive LEDs to verify that the drive is operating correctly. For more information about drive LEDs, see "Drive LEDs."
Replacing the access panel
WARNING
WARNING!
To avoid bodily injury from hot surfaces, allow the server and its internal modules to cool before touching them.
CAUTION
CAUTION:
To avoid thermal damage to the server, do not operate the server for long periods with the access panel open or uninstalled.
If you are replacing a hot-swappable component in the chassis and sufficient space is available for replacement, you can replace the access panel without powering off the server or removing the server from the rack. The following procedure is provided based on the assumption that no sufficient space is available for replacement.
3.        Remove the access panel as shown in Figure 91:
a.    If the locking lever on the access panel is locked, unlock the locking lever. Use a T15 Torx screwdriver to turn the screw on the lever 90 degree anticlockwise, as shown by callout 1.
b.    Press the latch on the locking lever, pull the locking lever upward, and then release the latch, as shown by callouts 2 and 3. The access panel will automatically slide to the rear of the server chassis.
c.    Hold the access panel by its sides and lift it from the chassis, as shown by callout 4.
Figure 91 Removing the access panel
1.        Use a T15 Torx screwdriver to unlock the locking lever.
2.        Press the latch on the locking lever, pull the lever upward, and then release the latch, as shown in Figure 92.
Figure 92 Opening the locking lever
3.        Install the access panel as shown in Figure 93:
a.    Place the access panel on top of the server chassis, with the guide pin in the chassis aligned with the pin hole in the locking lever area, as shown by callout 1.
b.    Close the locking lever, as shown by callout 2. The access panel automatically slides toward the server front to secure itself into place.
c.    (Optional.) Lock the locking lever. Use a T15 Torx screwdriver to turn the screw on the lever 90 degree clockwise, as shown by callout 3.
Figure 93 Installing the access panel
Replacing a power supply
If two power supplies are installed and sufficient space is available for replacement, you can replace a power supply without powering off or removing the server from the rack.
3.        To remove the AC power cord from an AC power supply or a 240 V high-voltage DC power supply:
a.    Press the tab to disengage the ratchet from the tie mount, slide the cable clamp outward, and then release the tab, as shown by callouts 1 and 2.
b.    Open the cable clamp and remove the power cord out of the clamp, as shown by callouts 3 and 4.
c.    Unplug the power cord, as shown by callout 5.
Figure 94 Removing the power cord
4.        To remove the DC power cord from a –48 VDC power supply:
a.    Loosen the captive screws on the power cord plug, as shown in Figure 95.
Figure 95 Loosening the captive screws
b.    Pull the power cord plug out of the power receptacle, as shown in Figure 96.
Figure 96 Pulling out the DC power cord
5.        Holding the power supply by its handle with your left hand and pressing the retaining latch with your thumb, pull the power supply slowly out of the slot, as shown in Figure 97.
Figure 97 Removing the power supply
6.        Install a new power supply. For more information, see "Installing power supplies."
IMPORTANT
IMPORTANT:
If the server has only one power supply, you must install the power supply in slot 2.
Use the following methods to verify that the power supply has been replaced correctly:
·          Observe the power supply LED to verify that the power supply LED is steady or flashing green. For more information about the power supply LED, see "Rear panel."
·          Log in to HDM to verify that the power supply status is correct. For more information, see HDM online help.
Replacing air baffles
WARNING
WARNING!
4.        Remove air baffles:
¡  To remove the chassis air baffle, hold the air baffle, and lift the air baffle out of the chassis, as shown in Figure 98.
Figure 98 Removing the chassis air baffle
¡  To remove the power supply air baffle, pull outward the two clips that secure the air baffle, and lift the air baffle out of the slot, as shown in Figure 99.
Figure 99 Removing the power supply air baffle
1.        Install air baffles:
¡  Install the chassis air baffle as shown in Figure 100. Make sure the standouts at both ends of the air baffle aligned with the notches on the chassis edges.
Figure 100 Installing the chassis air baffle
¡  Install the power supply air baffle as shown in Figure 101. Make sure the groove in the air baffle is aligned with the system board handle. In addition, make sure the extended narrow side indicated by the arrow mark makes close contact with the clip on the system board.
Figure 101 Removing the power supply air baffle
WARNING
WARNING!
The replacement procedure is the same for riser cards on PCIe riser connector 1 and PCIe riser connector 2. This procedure uses the riser card on PCIe riser connector 1 as an example.
To replace a riser card and a PCIe module:
4.        Disconnect cables that might hinder the replacement.
5.        Lift the riser card slowly out of the chassis, as shown in Figure 102.
Figure 102 Removing the riser card on PCIe riser connector 1
6.        Open the retaining latch on the riser card, and then pull the PCIe module out of the slot, as shown in Figure 103.
Figure 103 Removing a PCIe module
7.        Install a new riser card and PCIe module. For more information, see "Installing riser cards and PCIe modules."
8.        Reconnect the removed cables.
Replacing a storage controller
Guidelines
WARNING
WARNING!
If you are replacing the storage controller with a different model controller, you must reconfigure RAID after the replacement. For more information, see the storage controller user guide for the server.
If you are replacing the storage controller with a same model controller, make sure the following configurations remain the same after the replacement:
·          Storage controller operating mode.
·          Storage controller firmware version.
·          BIOS boot mode.
·          First boot option in Legacy mode.
For more information, see the storage controller user guide for the server and the BIOS user guide for the server.
Preparing for replacement
To replace the storage controller with a same model controller, identify the following information before the replacement:
·          Storage controller location and cabling.
·          Storage controller model, operating mode, and firmware version.
·          BIOS boot mode.
To replace the storage controller with a different model controller, back up data in drives managed by the controller and then clear RAID information before the replacement.
Replacing the Mezzanine storage controller
4.        Disconnect all cables from the Mezzanine storage controller.
5.        Remove the riser cards that might hinder the replacement. For more information, see "Replacing a riser card and a PCIe module."
6.        Loosen the captive screws on the Mezzanine storage controller, and then lift the storage controller to remove it, as shown in Figure 104.
Figure 104 Removing the Mezzanine storage controller
7.        Remove the flash card installed on the Mezzanine storage controller, if any. For more information, see "Replacing the power fail safeguard module for the Mezzanine storage controller."
8.        Install a new Mezzanine storage controller. For more information, see "Installing a Mezzanine storage controller and a power fail safeguard module."
9.        Install the removed riser cards. For more information, see "Installing riser cards and PCIe modules."
Log in to HDM to verify that the Mezzanine storage controller is in a correct state. For more information, see HDM online help.
Replacing a standard storage controller
4.        Disconnect all cables from the storage controller.
5.        Remove the storage controller. For more information, see "Replacing a riser card and a PCIe module."
6.        Remove the flash card installed on the storage controller, if any. For more information, see "Replacing the power fail safeguard module for the Mezzanine storage controller."
7.        Install a new standard storage controller. For more information, see "Installing a standard storage controller and a power fail safeguard module."
Log in to HDM to verify that the standard storage controller is in a correct state. For more information, see HDM online help.
WARNING
WARNING!
CAUTION
CAUTION:
To avoid server errors, do not replace the power fail safeguard module when a drive is performing RAID migration or rebuilding. The Fault/UID LED is off and the Present/Active LED is flashing green on a drive if the drive is performing migration or rebuilding.
4.        Disconnect the supercapacitor cable from the storage controller.
5.        Remove the external flash card installed on the storage controller, if any, as shown in Figure 105.
Figure 105 Removing the flash card on the Mezzanine storage controller
6.        Pull the clip on the supercapacitor holder, take the supercapacitor out of the holder, and then release the clip, as shown in Figure 106. The removal procedure is the same for all types of supercapacitors.
Figure 106 Removing the supercapacitor
7.        Lift the retaining latch at the bottom of the supercapacitor holder, slide the holder to remove it, and then release the retaining latch, as shown in Figure 107.
Figure 107 Removing the supercapacitor holder
8.        Install a new power fail safeguard module. For more information, see "Installing a Mezzanine storage controller and a power fail safeguard module."
9.        Connect the removed cables.
Log in to HDM to verify that the flash card and the supercapacitor are in a correct state. For more information, see HDM online help.
Replacing the power fail safeguard module for a standard storage controller
CAUTION
CAUTION:
5.        Remove the storage controller. For more information, see "Replacing a standard storage controller."
6.        Disconnect cables from the storage controller.
7.        Remove the external flash card installed on the storage controller, if any, as shown in Figure 108.
Figure 108 Removing the flash card on a standard storage controller
8.        Remove the supercapacitor. For more information, see "Replacing the power fail safeguard module for the Mezzanine storage controller."
9.        Remove the supercapacitor holder. For more information, see "Replacing the power fail safeguard module for the Mezzanine storage controller."
10.     Install a new power fail safeguard module. For more information, see "Installing a standard storage controller and a power fail safeguard module."
11.     Connect the removed cables.
Replacing a GPU module
WARNING
WARNING!
To replace a GPU module:
4.        Remove the riser card that holds the GPU module. For more information, see "Replacing a riser card and a PCIe module."
5.        Remove the GPU module:
¡  If the GPU module is not connected with a power cord, open the retaining latch on the riser card, and pull the GPU module out of the slot, as shown in Figure 109.
Figure 109 Removing a GPU module that is not connected with a power cord (GPU-M4-1 GPU module)
¡  If the GPU module is connected with a power cord, disconnect the power cord from the GPU module. Then, open the retaining latch on the riser card, pull the GPU module out of the slot, and disconnect the power cord from the riser card, as shown in Figure 110.
Figure 110 Removing a GPU module that is connected with a power cord (GPU-M4000-1-X GPU module)
6.        Install a new GPU module. For more information, see "Installing GPU modules."
Replacing an Ethernet adapter
Replacing an mLOM Ethernet adapter
2.        Disconnect cables from the Ethernet adapter.
3.        Loosen the captive screws and then pull the Ethernet adapter out of the slot, as shown in Figure 111.
Some mLOM Ethernet adapters have only one captive screw. This example uses an Ethernet adapter with two screws.
Figure 111 Removing an mLOM Ethernet adapter
4.        Install a new mLOM Ethernet adapter. For more information, see "Installing an mLOM Ethernet adapter."
5.        Connect cables for the mLOM Ethernet adapter.
Log in to HDM to verify that the mLOM Ethernet adapter is in a correct state. For more information, see HDM online help.
Replacing a PCIe Ethernet adapter
WARNING
WARNING!
4.        Disconnect cables from the PCIe Ethernet adapter.
5.        Remove the PCIe Ethernet adapter. For more information, see "Replacing a riser card and a PCIe module."
6.        Install a new PCIe Ethernet adapter. For more information, see "Installing riser cards and PCIe modules."
7.        Connect cables for the PCIe Ethernet adapter.
Log in to HDM to verify that the PCIe Ethernet adapter is in a correct state. For more information, see HDM online help.
Replacing the M.2 transfer module and an SATA M.2 SSD
WARNING
WARNING!
Replacing the front M.2 transfer module and an SATA M.2 SSD (4LFF server)
3.        Remove the security bezel, if any. For more information, see "Replacing the security bezel."
5.        Disconnect the cable that connects the SATA M.2 SSD to the system board.
6.        Remove the M.2 transfer module. The removal procedure is the same for the M.2 transfer module and the SATA optical drive. For more information, see "Replacing the SATA optical drive."
7.        Remove a SATA M.2 SSD:
a.    Remove the screw that secures the SSD on the transfer module.
b.    Tilt the SSD by the screw-side edge, and then pull the SSD out of the connector, as shown in Figure 112.
Figure 112 Removing a SATA M.2 SSD
8.        Install a new SATA M.2 SSD. For more information, see "Installing SATA M.2 SSDs."
9.        Install the removed security bezel, if any. For more information, see "Replacing the security bezel."
Replacing the front M.2 transfer module and an SATA M.2 SSD (8SFF server)
1.        Power off the server. For more information, see "Powering off the server."
2.        Remove the server from the rack. For more information, see "Removing the server from a rack."
6.        Remove the fastening screws that secure the drive enablement option, and push the drive enablement option out of the chassis from the inside of the chassis, as shown in Figure 113.
Figure 113 Removing the drive enablement option
7.        Remove the screw that secures the M.2 transfer module. Then, push the transfer module out of the enablement option from the inside of the drive enablement option, as shown in Figure 114.
Figure 114 Removing the M.2 transfer module
8.        Remove a SATA M.2 SSD:
b.    Tilt the SSD by the screw-side edge, and then pull the SSD out of the connector, as shown in Figure 115.
Figure 115 Removing a SATA M.2 SSD
9.        Install a new SATA M.2 SSD. For more information, see "Installing SATA M.2 SSDs."
10.     Install the removed security bezel, if any. For more information, see "Replacing the security bezel."
Replacing the rear M.2 transfer module and a SATA M.2 SSD
3.        Remove the access panel. For more information, see "Removing the access panel."
4.        Disconnect the SATA M.2 SSD cable from the system board.
5.        Remove the riser card that holds the M.2 transfer module. For more information, see "Replacing a riser card and a PCIe module."
6.        Remove the M.2 transfer module from the riser card. For more information, see "Replacing a riser card and a PCIe module."
7.        Remove the SATA M.2 SSD as shown in Figure 116:
a.    Disconnect the SATA M.2 SSD cable from the M.2 transfer module, as shown by callout 1.
b.    Remove the screw that secures the SSD on the expander module. Tilt the SSD by the screw-side edge, and then pull the SSD out of the connector.
Figure 116 Removing a SATA M.2 SSD
Replacing an SD card
WARNING
WARNING!
CAUTION
CAUTION:
The SD cards are hot swappable. If sufficient space is available for replacement, you can replace an SD card without powering off the server or removing the server from the rack. The following procedure is provided based on the assumption that no sufficient space is available for replacement.
To replace an SD card:
4.        Press the SD card to release it, and then pull the SD card out of the slot, as shown in Figure 117.
Figure 117 Removing an SD card
5.        Install a new SD card. For more information, see "Installing SD cards."
Replacing the dual SD card extended module
WARNING
WARNING!
To replace the dual SD card extended module:
4.        Press the blue clip on the dual SD card extended module, as shown by callout 1 in Figure 118. Pull the module out of the connector, and then release the clip.
Figure 118 Removing the dual SD card extended module
5.        Remove the SD cards installed on the extended module, as shown in Figure 117.
6.        Install a new dual SD card extended module and the removed SD cards. For more information, see "Installing SD cards."
Replacing an NVMe SSD expander module
WARNING
WARNING!
The procedure is the same for replacing a 4-port NVMe SSD expander module and an 8-port NVMe SSD expander module. The following procedure uses a 4-port NVMe SSD expander module as an example.
To replace an NVMe SSD expander module:
4.        Remove the NVMe SSD expander module:
a.    Disconnect the expander module from the front drive backplanes by removing the cables from the front drive backplane.
b.    Remove the PCIe riser card that holds the NVMe SSD expander module. For more information, see "Replacing a riser card and a PCIe module."
c.    Disconnect cables from the NVMe SSD expander module, as shown in Figure 119.
Figure 119 Disconnecting cables from an NVMe SSD expander module
5.        Install a new NVMe SSD expander module. For more information, see "Installing an NVMe SSD expander module."
Log in to HDM to verify that the NVMe expander module is in a correct state. For more information, see HDM online help.
Replacing the NVMe VROC module
WARNING
WARNING!
To remove the NVMe VROC module:
5.        Hold the pull-ring of the NVMe VROC module with a finger, and then pull the module out of the chassis, as shown in Figure 120.
Figure 120 Removing the NVMe VROC module
6.        Install a new NVMe VROC module. For more information, see "Installing the NVMe VROC module."
Replacing a fan
WARNING
WARNING!
CAUTION
CAUTION:
The fans are hot swappable. If sufficient space is available for replacement, you can replace a fan without powering off the server or removing the server from the rack. The following procedure is provided based on the assumption that no sufficient space is available for replacement.
4.        Pull the fan out of the fan bay, as shown in Figure 121.
Figure 121 Removing a fan
5.        Install a new fan. For more information, see "Installing fans."
Log in to HDM to verify that the fan is in a correct state. For more information, see HDM online help.
Replacing a processor
WARNING
WARNING!
Guidelines
·          To avoid damage to a processor or the system board, only H3C authorized or professional server engineers can install, replace, or remove a processor.
·          Make sure the processors on the server are the same model.
·          Do not touch the pins in the processor sockets, which are very fragile and prone to damage. Install a protective cover if a processor socket is empty.
To avoid ESD damage, wear an ESD wrist strap before performing this task, and make sure the wrist strap is reliably grounded.
Removing a processor
5.        Remove the processor heatsink:
a.    Loosen the captive screws in the same sequence as shown by callouts 1 to 4 in Figure 122.
b.    Lift the heatsink slowly to remove it, as shown by callout 5 in Figure 122.
Figure 122 Removing a processor heatsink
6.        Remove the processor retaining bracket from the heatsink, as shown in Figure 123:
a.    Insert a flat-head tool (such as a flat-head screwdriver) into the notch marked with TIM BREAKER to pry open the retaining bracket, as shown by callout 1.
b.    Press the four clips in the four corners of the bracket to release the retaining bracket.
You must press the clip shown by callout 2 and its cater-cornered clip outward, and press the other two clips inward as shown by callout 3.
c.    Lift the retaining bracket to remove it from the heatsink, as shown by callout 4.
Figure 123 Removing the processor retaining bracket
7.        Separate the processor from the retaining bracket with one hand pushing down and the other hand tilting the processor, as shown in Figure 124.
Figure 124 Separating the processor from the retaining bracket
1.        Install the processor onto the retaining bracket. For more information, see "Installing processors."
2.        Smear thermal grease onto the processor:
a.    Clean the processor and heatsink with isopropanol wipes. Allow the isopropanol to evaporate before you continue with the subsequent steps.
b.    Use the thermal grease injector to inject 0.6 ml of thermal grease to the five dots on the processor, 0.12 ml for each dot, as shown in Figure 125.
Figure 125 Smearing thermal grease onto the processor
3.        Install the retaining bracket onto the heatsink. For more information, see "Installing processors."
4.        Install the heatsink onto the server. For more information, see "Installing processors."
5.        Past bar code label supplied with the processor over the original processor label on the heatsink.
IMPORTANT
IMPORTANT:
This step is required for you to obtain H3C's processor servicing.
Log in to HDM to verity that the processor is operating correctly. For more information, see HDM online help.
Replacing a DIMM
WARNING
WARNING!
5.        Open the DIMM slot latches and pull the DIMM out of the slot, as shown in Figure 126.
Figure 126 Removing a DIMM
6.        Install a new DIMM. For more information, see "Installing DIMMs."
7.        Install the chassis air baffle. For more information, see "Installing air baffles."
During server startup, you can access the BIOS to configure the memory mode of the newly installed DIMM. For more information, see the BIOS user guide for the server.
Replacing the system battery
WARNING
WARNING!
The server comes with a system battery (Panasonic BR2032) installed on the system board, which supplies power to the real-time clock and has a lifespan of 5 to 10 years. If the server no longer automatically displays the correct date and time, you might need to replace the battery. As a best practice, use a new Panasonic BR2032 battery to replace the old one.
The BIOS will restore to the default settings after the replacement. You must reconfigure the BIOS to have the desired settings, including the system date and time. For more information, see the BIOS user guide for the server.
Removing the system battery
4.        (Optional.) Remove PCIe modules that might hinder system battery removal. For more information, see "Replacing a riser card and a PCIe module."
5.        Gently tilt the system battery to remove it from the battery holder, as shown in Figure 127.
CAUTION
CAUTION:
Do not use excessive force when removing the system battery. If you use excessive force, the system battery might flip out of the battery holder and cause damage to the holder or system board.
Figure 127 Removing the system battery
For environment protection purposes, dispose of the used-up system battery at a designated site.
Installing the system battery
1.        Orient the system battery with the plus-sign (+) side facing up, and place the system battery into the system battery holder, as shown by callout 1 in Figure 128.
2.        Press the system battery to seat it in the holder, as shown by callout 2 in Figure 128.
Figure 128 Installing the system battery
3.        (Optional.) Install the removed PCIe modules. For more information, see "Installing riser cards and PCIe modules."
4.        Install the access panel. For more information, see "Installing the access panel."
5.        Rack-mount the server. For more information, see "Rack-mounting the server."
8.        Access the BIOS to reconfigure the system date and time. For more information, see system date and time setting in the BIOS user guide for the server.
Verify that the system date and time is displayed correctly on HDM or the connector monitor.
Replacing the system board
WARNING
WARNING!
Guidelines
To prevent electrostatic discharge, place the removed parts on an antistatic surface or in antistatic bags.
Removing the system board
3.        Remove the power supplies. For more information, see "Replacing a power supply."
5.        Remove the air baffles. For more information, see "Removing air baffles."
6.        Disconnect all cables connected to the system board.
7.        Removed the installed rear 2SFF drive cage, if any. To remove the drive cage, loosen the captive screw, and then lift the drive cage out of the slot, as shown in Figure 129.
Figure 129 Removing the rear 2SFF drive cage
8.        Remove the Mezzanine storage controller, if any. For more information, see "Replacing the Mezzanine storage controller."
9.        Remove the NVMe VROC module, if any. For more information, see "Replacing the NVMe VROC module."
10.     Remove the PCIe riser cards and PCIe modules, if any. For more information, see "Replacing a riser card and a PCIe module."
11.     Remove the mLOM Ethernet adapter, if any. For more information, see "Replacing an mLOM Ethernet adapter."
12.     Removed the DIMMs. For more information, see "Replacing a DIMM."
13.     Remove the processors and heatsinks. For more information, see " Replacing a processor."
14.     Remove the system board:
a.    Loosen the two captive screws on the system board, as shown by callout 1 in Figure 130.
b.    Hold the system board by its handle and slide the system board toward the server front. Then, lift the system board to remove it from the chassis, as shown in callout 2 in Figure 130.
Figure 130 Removing the system board
Installing the system board
1.        Hold the system board by its handle and slowly place the system board in the chassis. Then, slide the system board toward the server rear until the connectors (for example, USB connectors and the Ethernet port) on it are securely seated, as shown by callout 1 in Figure 131.
The connectors are securely seated if you cannot use the system board handle to lift the system board.
2.        Fasten the two captive screws on the system board, as shown by callout 2 in Figure 131.
Figure 131 Installing the system board
3.        Install the removed processors and heatsinks. For more information, see "Installing processors."
4.        Install the removed DIMMs. For more information, see "Installing DIMMs."
5.        Install the removed mLOM Ethernet adapter. For more information, see "Installing an mLOM Ethernet adapter."
6.        Install the removed PCIe riser cards and PCIe modules. For more information, see "Installing riser cards and PCIe modules."
7.        Install the removed NVMe VROC module. For more information, see "Installing the NVMe VROC module."
8.        Install the removed Mezzanine storage controller. For more information, see "Installing a Mezzanine storage controller and a power fail safeguard module."
9.        Install the removed rear 2SFF drive cage. For more information, see "Installing the 2SFF drive cage."
10.     Connect cables to the system board.
11.     Install the air baffles. For more information, see "Installing air baffles."
12.     Install the access panel. For more information, see "Installing the access panel."
13.     Install the removed power supplies. For more information, see "Installing power supplies."
Log in to HDM to verify that each part is operating correctly and no alert is generated. For more information, see HDM online help.
Replacing the drive expander module (10SFF server)
WARNING
WARNING!
4.        Disconnect cables from the expander module.
5.        Loosen the captive screws that secure the expander module, and then lift the module out of the chassis, as shown in Figure 132.
Figure 132 Removing a 10SFF drive expander module
6.        Place a new expander module in the chassis and fasten the captive screws.
7.        Connect cables to the drive expander module.
Log in to HDM to verity that the 10SFF drive expander module is in a correct state. For more information, see HDM online help.
Replacing drive backplanes
WARNING
WARNING!
Removing drive backplanes
4.        Remove the security bezel if you are removing the front drive backplane and the server is installed with a security bezel. For more information, see "Installing the security bezel."
5.        Remove the drives attached to the backplane. For more information, see "Replacing a SAS/SATA drive."
6.        Disconnect cables from the backplane.
7.        Remove the drive backplanes:
¡  To remove the front drive backplane from the 4LFF server, push the clip as shown by callout 1 in Figure 133, slide the backplane rightward, and then pull the backplane out of the chassis.
Figure 133 Removing the front drive backplane (4LFF server)
¡  To remove the front drive backplane from the 8SFF/10SFF server, open the clip as shown by callout 1 in Figure 134, slide the backplane leftward, and then pull the backplane out of the chassis.
The removal procedure is the same for the front 8SFF and 10SFF servers. This procedure uses the 8SFF SAS/SATA drive backplane in the 8SFF server as an example.
Figure 134 Removing a front drive backplane (8SFF server)
¡  To remove the front or rear 2SFF drive backplane, open the clip as shown by callout 1 in Figure 135, slide the backplane rightward, and then pull the backplane out of the chassis.
The removal procedure is the same for the front 2SFF SAS/SATA drive backplane, front 2SFF NVMe drive backplane, and rear 2SFF drive backplane. This procedure uses the rear 2SFF drive backplane.
Figure 135 Removing the rear 2SFF drive backplane
Installing drive backplanes
1.        Install drive backplanes:
¡  To install the front drive backplane for the 4LFF server, place the backplane in the slot. Then, slide the backplane leftward until the clip snaps into place, as shown in Figure 136.
Figure 136 Installing the front drive backplane (4LFF server)
¡  To install the front drive backplane for the 8SFF/10SFF server, place the backplane in the slot. Then, slide the backplane rightward until the clip snaps into place, as shown in Figure 137.
The installation procedure is the same for the front 8SFF and 10SFF servers. This procedure uses the 8SFF SAS/SATA drive backplane in the 8SFF server as an example.
Figure 137 Installing the front drive backplane (8SFF server)
¡  To install the front or rear 2SFF drive backplane, place the backplane in the slot, slide the backplane rightward until it snaps into place, as shown in Figure 138.
The installation procedure is the same for the front 2SFF SAS/SATA drive backplane, front 2SFF NVMe drive backplane, and rear 2SFF drive backplane. This procedure uses the rear 2SFF drive backplane.
Figure 138 Installing the rear 2SFF drive backplane
2.        Connect cables to the drive backplane. For more information, see "Connecting drive cables."
3.        Installed the removed drives. For more information, see "Installing SAS/SATA drives."
4.        Install the removed security bezel. For more information, see "Installing the security bezel."
5.        Install the access panel. For more information, see "Installing the access panel."
6.        Rack-mount the server. For more information, see "Rack-mounting the server."
7.        Connect the power cord. For more information, see "Connecting the power cord."
8.        Power on the server. For more information, see "Powering on the server."
Log in to HDM to verity that the drive backplane is in a correct state. For more information, see HDM online help.
WARNING
WARNING!
To replace the SATA optical drive:
5.        Disconnect the cable from the optical drive.
6.        Remove the SATA optical drive:
¡  To remove the SATA optical drive from the 4LFF server, remove the screw that secures the optical drive, lift the optical drive by its right side, and then pull the optical drive out of the chassis, as shown in Figure 139.
Figure 139 Removing the SATA optical drive
¡  To remove the SATA optical drive from the 8SFF server, remove the drive enablement option that holds the optical drive. Then, remove the optical drive from the drive enablement option. For more information, see "Replacing the M.2 transfer module and an SATA M.2 SSD."
7.        Install a new SATA optical drive. For more information, see "Installing a SATA optical drive."
8.        Connect the optical drive cable.
9.        Install the removed security bezel. For more information, see "Replacing the security bezel."
12.     Power on the server. For more information, see "Powering on the server."
Replacing the diagnostic panel
WARNING
WARNING!
To replace the diagnostic panel:
3.        Remove the diagnostic panel as shown in Figure 140:
a.    Press the release button on the diagnostic panel, as shown by callout 1. The diagnostic panel pops out.
b.    Hold the diagnostic panel by its front edge to pull it out of the slot, as shown by callout 2.
Figure 140 Removing the diagnostic panel
4.        Install a new diagnostic panel. For more information, see "Installing a diagnostic panel."
5.        Install the removed security bezel. For more information, see "Replacing the security bezel."
Replacing the chassis-open alarm module
WARNING
WARNING!
The server supports the following types of chassis-open alarm modules:
·          Independent chassis-open alarm module.
·          Chassis-open alarm module attached to the front media module.
4.        Remove the chassis-open alarm module as shown in Figure 141:
a.    Disconnect the chassis-open alarm module cable from the chassis-open alarm module connector on the system board, as shown by callout 1.
b.    Open the module retaining clip and pull the chassis-open alarm module out of the chassis, as shown by callouts 2 and 3.
Figure 141 Removing the chassis-open alarm module
The removal procedure is the same for all types of chassis-open alarm modules. This figure uses the chassis-open alarm module attached to the front media module as an example.
5.        Disconnect the chassis-open alarm module cable from the front media module if the chassis-open alarm module is attached to the front media module. For more information, see "Replacing the front media module."
1.        Connect the chassis-open alarm signal cable to the front media module
2.        Install the chassis-open alarm module as shown in Figure 142:
a.    Press the chassis-open alarm module into the slot until it snaps into place.
b.    Connect the chassis-open alarm signal cable to the chassis-open alarm module connector on the system board.
Figure 142 Installing the chassis-open alarm module
Log in to HDM to verity that the chassis-open alarm module is in a correct state. For more information, see HDM online help.
WARNING
WARNING!
Removing the front media module (4LFF server)
4.        Loosen the captive screws on the plug of the VGA and USB 2.0 cable, and then disconnect the cable from the front media module, as shown in Figure 143.
Figure 143 Disconnecting the VGA and USB 2.0 cable
5.        Disconnect the chassis-open alarm signal cable from the system board, and remove the chassis-open alarm module attached to the front media module. For more information, see "Replacing the chassis-open alarm module."
6.        Remove the front media module, as shown in Figure 144.
Figure 144 Removing the front media module
7.        Install a new front media module. For more information, see "Installing the front media module (VGA and USB 2.0 connectors)."
8.        Install the access panel. For more information, see "Installing the access panel."
9.        Rack-mount the server. For more information, see "Rack-mounting the server."
10.     Connect the power cord. For more information, see "Connecting the power cord."
11.     Power on the server. For more information, see "Powering on the server."
Removing the front media module (8SFF/10SFF server)
4.        Loosen the captive screws on the plug of the VGA and USB 2.0 cable, and then disconnect the cable from the front media module.
5.        Disconnect the front I/O component cable assembly. For more information, see "Replacing the front I/O component (8SFF/10SFF server)."
6.        Disconnect the chassis-open alarm signal cable from the system board, and then remove the chassis-open alarm module attached to the front media module. For more information, see "Replacing the chassis-open alarm module."
7.        Remove the front media module, as shown in Figure 145.
Figure 145 Removing the front media module
8.        Remove the front I/O component from the front media module. For more information, see "Replacing the front I/O component (8SFF/10SFF server)."
9.        Install a new front media module. For more information, see "Installing the front media module (VGA and USB 2.0 connectors)."
Replacing the air inlet temperature sensor
WARNING
WARNING!
5.        Remove the air inlet temperature sensor:
¡  On a 4LFF server, disconnect the temperature sensor cable from the system board. Then, open the sensor retaining clasp and remove the temperature sensor, as shown in Figure 146.
Figure 146 Removing a temperature sensor (4LFF server)
¡  On an 8SFF/10SFF server, disconnect the temperature sensor cable from the system board. Then, pull the temperature sensor out of the slot, as shown in Figure 147.
Figure 147 Removing a temperature sensor (8SFF/10SFF server)
6.        Install a new temperature sensor:
¡  On a 4LFF server, secure the temperature sensor with the retaining clasp on the system board. Then, connect the temperature sensor cable to the temperature sensor connector on the system board. For locations of the clasp and connector, see Figure 146.
¡  On an 8SFF/10SFF server, insert the temperature sensor into the temperature sensor slot. Then, connect the temperature sensor cable to the temperature sensor connector on the system board. For locations of the slot and connector, see Figure 147.
Log in to HDM to verity that the air inlet temperature sensor is in a correct state. The air inlet temperature sensor is named Inlet Temp in HDM. For more information, see HDM online help.
WARNING
WARNING!
Replacing the front I/O component (4LFF server)
4.        Disconnect the front I/O component cable assembly from the system board, as shown in Figure 148.
Figure 148 Disconnecting the front I/O component cable assembly
5.        Remove the front I/O component, as shown in Figure 149.
Figure 149 Remove the front I/O component
6.        Install a new front I/O component. Use a screw to secure the front I/O component on the system board. Then, connect the front I/O component assembly to the front I/O connector on the system board. For more information, see "Connecting the front I/O component cable assembly."
7.        Install the access panel. For more information, see "Installing the access panel."
8.        Rack-mount the server. For more information, see "Rack-mounting the server."
9.        Connect the power cord. For more information, see "Connecting the power cord."
10.     Power on the server. For more information, see "Powering on the server."
Power on the server and verify that the front I/O component LEDs are in a correct state. For more information about the LEDs, see "LEDs and buttons."
The 8SFF/10SFF server supports the following types of front I/O components:
·          Independent front I/O component.
·          Front I/O component attached to the front media module.
The replacement procedure is the same for all types of front I/O components. This procedure uses an independent front I/O component as an example.
4.        Disconnect the front I/O component cable assembly from the system board, as shown in Figure 150.
Figure 150 Disconnecting the front I/O component cable assembly
5.        Remove the screw that secures the front I/O module, and then pull the front I/O module out of the slot, as shown in Figure 151.
Figure 151 Removing the front I/O module that holds the front I/O component
6.        Remove the front I/O component from the front I/O module, as shown in Figure 152.
Figure 152 Removing the front I/O component from the front I/O module
7.        Install a new front I/O component in the front I/O module, and then install the front I/O module to the server. Then, connect the front I/O component cable assembly to the front I/O component connector on the system board. For more information, see "Connecting the front I/O component cable assembly."
Power on the server and verify that the front I/O component LEDs is in a correct state. For more information, see "LEDs and buttons."
Replacing chassis ears
WARNING
WARNING!
The replacement procedure is the same for the left and right chassis ears. This procedure uses the right chassis ear as an example.
To replace a chassis ear:
3.        Remove a chassis ear:
¡  To remove a screw rack mount ear, remove the screws that secure the ear, and then pull the screw rack mount ear out of the slot, as shown in Figure 153.
Figure 153 Removing a screw rack mount ear
¡  To remove a multifunctional rack mount ear, remove the security bezel, if any. Then, remove the screws that secure the multifunctional rack mount ear, and pull the multifunctional rack mount ear out of the slot, as shown in Figure 154. For more information about removing the security bezel, see "Replacing the security bezel."
Figure 154 Removing a multifunctional rack mount ear
4.        Install a new chassis ear. Insert the chassis ear into the slot and then use screws to secure the chassis ear.
Replacing the TPM/TCM
To avoid system damage, do not remove the installed TPM/TCM.
If the installed TPM/TCM is faulty, remove the system board, and contact Technical Support for system board or TPM/TCM replacement.
Connecting internal cables
Properly route the internal cables and make sure they are not squeezed.
For more information about storage controller configurations, see "Drive configurations and numbering."
4LFF server
Front 4LFF SAS/SATA drive cabling
Use Table 9 to select the method for connecting the 4LFF SAS/SATA drive backplane to the storage controller depending on the controller type.
Table 9 4LFF SAS/SATA drive cabling methods
Storage controller
Cabling method
Embedded RSTe RAID controller
See Figure 155.
See Figure 156.
Standard storage controller
See Figure 157.
Figure 155 4LFF SATA drive connected to the embedded RSTe RAID controller
(1) Power cord
(2) AUX signal cable
(3) Data cable
Figure 156 4LFF SAS/SATA drive connected to the Mezzanine storage controller
(1) Power cord
(3) Data cable
Figure 157 4LFF SAS/SATA drive connected to a standard storage controller
(1) Power cord
(3) Data cable
Install the standard storage controller in PCIe slot 1.
Front 4LFF SAS/SATA and rear 2SFF SAS/SATA drive cabling
Use Table 10 to identify the method for connecting the front 4LFF and rear 2SFF SAS/SATA drive backplanes to the storage controller depending on the controller type.
Table 10 Front 4LFF SAS/SATA and rear 2SFF SAS/SATA drive cabling methods
Storage controller
Cabling method
See Figure 158.
See Figure 159.
Figure 158 Front 4LFF SATA/rear 2SFF SATA drive to embedded RSTe RAID controller
(1) Power cord (front 4LFF)
(2) AUX signal cable (front 4LFF)
(3) SATA data cable
(4) Power cord (rear 2SFF)
(5) AUX signal cable (rear 2SFF)
Figure 159 Front 4LFF SATA/rear 2SFF SAS/SATA drive to Mezzanine storage controller
(3) SAS/SATA data cable
8SFF server
Front 8SFF SAS/SATA drive cabling
Use Table 11 to identify the method for connecting the 8SFF SAS/SATA drive backplane to the storage controller depending on the controller type.
Table 11 8SFF SAS/SATA drive cabling methods
Storage controller
Cabling method
See Figure 160.
See Figure 161.
See Figure 162.
Figure 160 8SFF SATA drive to embedded RSTe RAID controller
(1) AUX signal cable
(2) Power cord
(3) Data cable
Figure 161 8SFF SAS/SATA drive to Mezzanine storage controller
(2) Power cord
(3) Data cable
Figure 162 8SFF SAS/SATA drive to standard storage controller
(2) Power cord
(3) Data cable
Front 8SFF and 2SFF SAS/SATA drive cabling
Use Table 12 to identify the method for connecting the front 8SFF and 2SFF SAS/SATA drive backplanes to the storage controller depending on the controller type.
Table 12 Front 8SFF and 2SFF SAS/SATA drive cabling methods
Storage controller
Front 8SFF drive cabling method
Front 2SFF drive cabling method
·         Mezzanine storage controller for front 8SFF drives
·         Embedded RSTe RAID controller for front 2SFF drives
See Figure 161.
See Figure 163.
·         Standard storage controller for front 8SFF drives
See Figure 162.
See Figure 163.
Figure 163 Front 2SFF SAS/SATA drive backplane to embedded RSTe RAID controller
(1) Power cord
Front 4SFF SAS/SATA and 4SFF NVMe drive cabling
For the 4SFF NVMe drive configuration, you must install a 4-port NVMe SSD expander module. Install the expander module in PCIe slot 1 if the embedded RAID controller or Mezzanine storage controller is used, and in PCIe slot 2 if a standard storage controller is used.
Use Table 13 to identify the front drive cabling method depending on the controller type.
Table 13 Front 4SFF SAS/SATA and 4SFF NVMe drive cabling methods
Storage controller
Cabling method
See Figure 164.
See Figure 165.
See Figure 166.
When connecting NVMe data cables, use Table 14 to determine the ports to be connected and the cable to use.
Figure 164 Front 4SFF SAS/SATA and 4SFF NVMe drive cabling (embedded RAID controller and 4-port NVMe SSD expander module)
(2) Power cord
(3) SATA data cable
(4) NVMe data cables
Figure 165 Front 4SFF SAS/SATA and 4SFF NVMe drive cabling (Mezzanine storage controller and 4-port NVMe SSD expander module)
(2) Power cord
(3) SATA data cable
Figure 166 Front 4SFF SAS/SATA and 4SFF NVMe drive cabling (standard storage controller and 4-port NVMe SSD expander module)
(1) AUX signal cables
(2) and (3) Power cords
(5) SAS/SATA data cable
Install the standard storage controller in PCIe slot 1 and the NVMe SSD expander module in PCIe slot 2.
Table 14 NVMe data cable and peer ports between the drive backplane and 4-port NVMe SSD expander module
Mark on the NVMe data cable end
Port on the drive backplane
Port on the 4-port NVMe SSD expander module
NVMe 1
NVMe A1
NVMe A1
NVMe 2
NVMe A2
NVMe A2
NVMe 3
NVMe A3
NVMe A3
NVMe 4
NVMe A4
NVMe A4
Front 8SFF NVMe drive cabling
For 8SFF NVMe drive configuration, you must install two 4-port NVMe SSD expander modules in PCIe slots 1 and 2 or one 8-port NVMe SSD expander module in PCIe slot 1.
Use Table 15 to identify the front drive cabling method depending on the type of NVMe SSD expander module.
Table 15 8SFF NVMe drive cabling methods
Cabling method
One 8-port NVMe SSD expander module
See Figure 167.
Two 4-port NVMe SSD expander modules
See Figure 168.
When connecting NVMe data cables, make sure you connect the peer ports with the correct NVMe data cable. For 4-port and 8-port NVMe SSD expander modules, use Table 16 and Table 17, respectively, to determine the ports to be connected and the cable to use.
Figure 167 8SFF NVMe drive cabling (one 8-port NVMe SSD expander module)
(2) Power cord
(3) NVMe data cables
Figure 168 8SFF NVMe drive cabling (two 4-port NVMe SSD expander modules)
(2) Power cord
Table 16 NVMe data cable and peer ports between the drive backplane and 4-port NVMe SSD expander modules
Port on the 4-port NVMe SSD expander modules
NVMe 1
NVMe A1
NVMe A1 (NVMe SSD expander module in PCIe slot 1)
NVMe 2
NVMe A2
NVMe A2 (NVMe SSD expander module in PCIe slot 1)
NVMe 3
NVMe A3
NVMe A3 (NVMe SSD expander module in PCIe slot 1)
NVMe 4
NVMe A4
NVMe A4 (NVMe SSD expander module in PCIe slot 1)
NVMe 1
NVMe B1
NVMe A1 (NVMe SSD expander module in PCIe slot 2)
NVMe 2
NVMe B2
NVMe A2 (NVMe SSD expander module in PCIe slot 2)
NVMe 3
NVMe B3
NVMe A3 (NVMe SSD expander module in PCIe slot 2)
NVMe 4
NVMe B4
NVMe A4 (NVMe SSD expander module in PCIe slot 2)
Table 17 NVMe data cable and peer ports between the drive backplane and 8-port NVMe SSD expander module
Port on the 8-port NVMe SSD expander module
NVMe 1
NVMe A1
NVMe A1
NVMe 2
NVMe A2
NVMe A2
NVMe 3
NVMe A3
NVMe A3
NVMe 4
NVMe A4
NVMe A4
NVMe 1
NVMe B1
NVMe B1
NVMe 2
NVMe B2
NVMe B2
NVMe 3
NVMe B3
NVMe B3
NVMe 4
NVMe B4
NVMe B4
Front 8SFF NVMe and rear 2SFF SAS/SATA drive cabling
For the 8SFF NVMe drive configuration, you must install two 4-port NVMe SSD expander modules in PCIe slots 1 and 2 or an 8-port NVMe SSD expander module in PCIe slot 1.
Use Table 18 to identify the front drive cabling method depending on the type of the NVMe SSD expander module.
Table 18 Front 8SFF NVMe and rear 2SFF SAS/SATA drive cabling methods
Storage controller
Rear 2SFF drive cabling method
·         One 8-port NVMe SSD expander module for the front NVMe drives
·         Embedded RSTe RAID controller for the rear SAS/SATA drives
See Figure 167.
See Figure 163.
·         Two 4-port NVMe SSD expander modules for the front NVMe drives
See Figure 168.
See Figure 163.
Front 8SFF SAS/SATA and 2SFF NVMe drive cabling
To install 2SFF NVMe drives at the server front, you must install a 4-port NVMe SSD expander module in PCIe slot 1.
Use Table 19 to identify the method for connecting the front 8SFF SAS/SATA and 2SFF NVMe drive backplanes to the storage controller depending on the controller type.
Table 19 Front 8SFF SAS/SATA and 2SFF NVMe drive cabling methods
Storage controller
Front 8SFF SAS/SATA drive cabling method
Front 2SFF NVMe drive cabling method
See Table 11Figure 160.
See Figure 169.
See Table 11Figure 161.
See Figure 169.
Standard storage controller (in PCIe slot 2)
See Figure 162.
See Figure 169.
Figure 169 2SFF NVMe drive backplane to the 4-port NVMe SSD expander module
(2) Power cord
When connecting NVMe data cables, make sure you connect the peer ports with the correct NVMe data cable, as shown in Table 20.
Table 20 NVMe data cable and peer ports between the drive backplane and 4-port NVMe SSD expander module
NVMe 1
NVMe A1
NVMe A1
NVMe 2
NVMe A2
NVMe A2
10SFF server
10SFF SAS/SATA drive cabling
Use Table 21 to identify the method for connecting the 10SFF SAS/SATA drive backplane to a storage controller depending on the type of the storage controller.
Table 21 10SFF SAS/SATA drive cabling methods
Storage controller
Cabling method
See Figure 170.
See Figure 171.
Figure 170 10SFF SAS/SATA drive to Mezzanine storage controller
(2) Power cord
(3) Data cable
Figure 171 10SFF SAS/SATA drive to standard storage controller
(2) Power cord
(3) Data cable
Front 10SFF and rear 2SFF SAS/SATA drive cabling
Figure 172 Front 10SFF and rear 2SFF SAS/SATA drive to Mezzanine storage controller
(1) AUX signal cable (front 10SFF)
(2) Power cord (front 10SFF)
(3) SAS/SATA data cable to the Mezzanine storage controller
(4) Rear 2SFF drive SAS/SATA data cable to the drive expander module
(5) Power cord (rear 2SFF)
(6) AUX signal cable (rear 2SFF)
Connecting the flash card and supercapacitor of the power fail safeguard module
The flash card of the power fail safeguard module can be installed on a Mezzanine storage controller or on a standard storage controller. Choose the connection procedure depending on the location of the flash card.
Connecting the flash card on the Mezzanine storage controller
Connect the flash card on the Mezzanine storage controller to the supercapacitor as shown in Figure 173.
Figure 173 Connecting the flash card on the Mezzanine storage controller
(1) Supercapacitor extension cable
(2) Supercapacitor cable
Connecting the flash card on a standard storage controller
The cabling method is similar for the standard storage controllers in PCIe slots 1 and 2. The cabling method depends on the location of the standard storage controller:
·          For a standard storage controller installed in PCIe slot 1, route the cable as shown in Figure 174.
·          For a standard storage controller installed in PCIe slot 2, route the cable as shown in Figure 175.
Figure 174 Connecting the flash card on the standard storage controller in PCIe slot 1
(1) Supercapacitor cable
(2) Supercapacitor extension cable
Figure 175 Connecting the flash card on the standard storage controller in PCIe slot 2
(1) Flash card cable
Connecting the power cord of a GPU module
Only the GPU-M4000-1-X GPU module requires a power cord. Connect the power cord as shown in Figure 176.
Figure 176 Connecting the power cord of a GPU module
Connecting the SATA M.2 SSD cable
Connecting the front SATA M.2 SSD cable (4LFF server)
The front SATA M.2 SSD cabling method depends on the number of SATA M.2 SSDs to be installed.
·          If you are installing only one SATA M.2 SSD, connect the cable as shown in Figure 177.
·          If you are installing two SATA M.2 SSDs, connect the cable as shown in Figure 178.
Figure 177 Connecting the front SATA M.2 SSD cable (one SATA M.2 SSD)
Figure 178 Connecting the front SATA M.2 SSD cable (two SATA M.2 SSDs)
Connecting the front SATA M.2 SSD cable (8SFF server)
·          If you are installing only one SATA M.2 SSD, connect the cable as shown in Figure 179.
·          If you are installing two SATA M.2 SSDs, connect the cable as shown in Figure 180.
Figure 179 Connecting the front SATA M.2 SSD cable (one SATA M.2 SSD)
Figure 180 Connecting the front SATA M.2 SSD cable (two SATA M.2 SSDs)
Connecting the rear SATA M.2 SSD cable
The rear SATA M.2 SSD cabling method depends on the number of SATA M.2 SSDs to be installed.
·          If you are installing only one SATA M.2 SSD, connect the cable as shown in Figure 181.
·          If you are installing two SATA M.2 SSDs, connect the cable as shown in Figure 182.
Figure 181 Connecting the rear SATA M.2 SSD cable (one SATA M.2 SSD)
Figure 182 Connecting the rear SATA M.2 SSD cable (two SATA M.2 SSDs)
Connecting the SATA optical drive cable
The cabling method depends on the server model:
·          Connect the SATA optical drive cable for the 4LFF server as shown in Figure 183.
·          Connect the SATA optical drive cable for the 8SFF server as shown in Figure 184.
Figure 183 Connecting the SATA optical drive cable for the 4LFF server
Figure 184 Connecting the SATA optical drive cable for the 8SFF server
·          Connect the front I/O component cable assembly for the 4LFF server as shown in Figure 185.
·          Connect the front I/O component cable assembly for the 8SFF and 10SFF servers as shown in Figure 186.
Figure 185 Connecting the front I/O component cable assembly (4LFF server)
Figure 186 Connecting the front I/O component cable assembly (8SFF/10SFF server)
Connecting the front media module cable
·          Connect the front media module cable for the 4LFF server as shown in Figure 187.
·          Connect the front media module cable for the 8SFF and 10SFF servers as shown in Figure 186.
Figure 187 Connecting the front media module cable (4LFF server)
Figure 188 Connecting the front media module cable (8SFF/10SFF server)
Connecting the NCSI cable for a PCIe Ethernet adapter
The cabling method is the same for standard storage controllers in PCIe slots 1 and 2. Figure 189 uses PCIe slot 1 to show the cabling method.
Figure 189 Connecting the NCSI cable for a PCIe Ethernet adapter
Maintenance
The following information describes the guidelines and tasks for daily server maintenance.
Guidelines
·          Keep the equipment room clean and tidy. Remove unnecessary devices and objects from the equipment room.
·          Make sure the temperature and humidity in the equipment room meet the server operating requirements.
·          Regularly check the server from HDM for operating health issues.
·          Keep the operating system and software up to date as required.
·          Make a reliable backup plan:
¡  Back up data regularly.
¡  If data operations on the server are frequent, back up data as needed in shorter intervals than the regular backup interval.
¡  Check the backup data regularly for data corruption.
·          Stock spare components on site in case replacements are needed. After a spare component is used, prepare a new one.
·          Keep the network topology up to date to facilitate network troubleshooting.
Maintenance tools
The following are major tools for server maintenance:
·          Hygrothermograph—Monitor the operating environment of the server.
·          HDM and FIST—Monitor the operating status of the server.
Maintenance tasks
Observing LED status
Observe the LED status on the front and rear panels of the server to verify that the server modules are operating correctly. For more information about the status of the front and rear panel LEDs, see front panel and rear panel in "Appendix A  Server specifications."
Monitoring the temperature and humidity in the equipment room
Use a hygrothermograph to monitor the temperature and humidity in the equipment room.
The temperature and humidity in the equipment room must meet the server requirements described in "Appendix A  Server specifications."
Examining cable connections
Verify that the cables and power cords are correctly connected.
Guidelines
·          Do not use excessive force when connecting or disconnecting cables.
·          Do not twist or stretch the cables.
·          Organize the cables appropriately. For more information, see "Cabling guidelines."
Checklist
·          The cable type is correct.
·          The cables are correctly and firmly connected and the cable length is appropriate.
·          The cables are in good condition and are not twisted or corroded at the connection point.
Technical support
If you encounter any complicated problems during daily maintenance or troubleshooting, contact Technical Support.
Before contacting Technical Support, collect the following server information to facilitate troubleshooting:
·          Log and sensor information:
¡  Log information:
-      Event logs, HDM logs, and SDS logs in HDM.
-      Logs in iFIST.
¡  Sensor information in HDM.
·          Product serial number.
·          Product model and name.
·          Screenshots of error messages and descriptions.
·          Hardware change history, including installation, replacement, insertion, and removal of hardware.
·          Third-party software installed on the server.
·          Operating system type and version.
