H3C VCFC-DC Controller Kubernetes Plug-In Installation Guide-E31xx-5W100
HomeSupportAD-NET(SDN)H3C SeerEngine-DCConfigure & DeployInteroperability GuidesH3C VCFC-DC Controller Kubernetes Plug-In Installation Guide-E31xx-5W100
01-Text
01-Text 58.32 KB
Overview
Kubernetes is an open-source container orchestration platform for automated deployment, scaling, and management of containerized applications.
Pods are the smallest deployable units of computing in Kubernetes. A Pod is a group of one or more tightly coupled containers. The containers share the networking resources, file system, and specifications for how to run the containers.
Installation of the VCF Kubernetes plug-in allows interconnection between the Kubernetes platform and the VCFC-DC controller. The VCFC-DC controller can monitor traffic, deploy security policies, and provide networking services for Pods in Kubernetes.
Preparing for installation
Hardware requirements
Table 1 shows the minimum hardware requirements for installing the VCF Kubernetes plug-in on a physical server or virtual machine.
Table 1 Minimum hardware requirements
CPU
Memory size
Disk size
Quad-core
8 GB
50 GB
Software requirements
Table 2 shows the software requirements for installing the VCF Kubernetes plug-in.
Table 2 Software requirements
Item
Supported versions
Kubernetes
Kubernetes 1.9/1.10
vSwitch
·     Host-based overlay—For the vSwitch version information, see the release notes for the VCFC-DC controller
·     Network-based overlay—Open vSwitch 2.9 and later
Configuring the Kubernetes nodes
You must configure basic settings for Kubernetes nodes before installing the VCF Kubernetes plug-in.
Configuring a node in host-based overlay model
1.     Install the S1020V vSwitch. For the installation procedure, see H3C S1020V Installation Guide.
2.     Configure a VDS on the VCFC-DC controller and add the VDS configuration to the node.
In the following example, vds1-br is the vSwitch name, eth1 is the uplink interface of  the vSwitch, vxlan_vds1-br is the VXLAN tunnel name, and 100.0.100.100 is the VTEP's IP.
$ ovs-vsctl add-br vds1-br
$ ovs-vsctl add-port vds1-br eth1
$ ovs-vsctl add-port vds1-br vxlan_vds1-br -- set interface vxlan_vds1-br type=vxlan options:remote_ip=flow options:local_ip=100.0.100.100 options:key=flow
3.     Configure a KVM-type compute domain on the controller and associate the domain with the VDS.
4.     Add the node to the hosts in the compute domain.
Configuring a node in network-based overlay model
1.     Install the Open vSwitch.
$ yum install -y openvswitch
$ systemctl enable openvswitch.service
$ systemctl start openvswitch.service
2.     Install and start lldpad
$ yum install -y lldpad
$ systemctl enable lldpad.service
$ systemctl start lldpad.service
3.     Enable LLDP message sending on the uplink interface (eno2 for example).
$ lldptool set-lldp -i eno2 adminStatus=rxtx;
$ lldptool -T -i eno2 -V sysName enableTx=yes;
$ lldptool -T -i eno2 -V portDesc enableTx=yes;
$ lldptool -T -i eno2 -V sysDesc enableTx=yes;
$ lldptool -T -i eno2 -V sysCap enableTx=yes;
4.     Add an Open vSwitch bridge (br-eno2 for example) on the node, specify the OpenFlow version, and set the fail mode to secure.
$ ovs-vsctl add-br br-eno2
$ ovs-vsctl set bridge br-eno2 protocols=OpenFlow13
$ ovs-vsctl set-fail-mode br-eno2 secure
5.     Add an uplink interface (eno2 for example) to the Open vSwitch bridge and configure the interface settings.
$ ovs-vsctl add-port br-eno2 eno2
$ ovs-vsctl br-set-external-id br-eno2 uplinkInterface eno2
Installing the VCF Kubernetes plug-in
Loading the plug-in Docker image
Follow these steps to load the plug-in Docker image on the master and nodes, respectively:
1.     Obtain the VCF Kubernetes plug-in Docker image. Then copy the image to the installation directory on the server or virtual machine, or upload it to the installation directory through FTP, TFTP, or SFTP.
The name of the image is in the VCFC_DC_NET_PLUGIN-version.tar format, where version represents the image version number.
CAUTION
CAUTION:
To avoid damaging the image, use the binary mode when you upload the image through FTP or TFTP.
2.     Load the Docker image.
$ docker load -i VCFC_DC_NET_PLUGIN-E3103.tar
Installing the plug-in
You must install the plug-in on the master.
To install the plug-in:
1.     Obtain the configuration file of the VCF Kubernetes plug-in. The configuration file name is in the VCFC_DC_NET_PLUGIN-version.yaml format, where version represents the version number.
2.     Copy the file to the installation directory of the master, or upload it to the installation directory through FTP, TFTP, or SFTP.
CAUTION
CAUTION:
3.     Modify the configuration file.
a.     Use the vi editor to open the configuration file.
$ vi VCFC_DC_NET_PLUGIN-E3103.yaml
b.     Press I to switch to insert mode, and then modify the configuration file. For information about the parameters, see Table 3.
kind: ConfigMap
apiVersion: v1
metadata:
  namespace: kube-system
data:
  etcd_servers: "http://192.168.0.10:2379"
  k8s_api_server: "https://192.168.0.20:6443"
  k8s_ca: "/etc/vcfc-net-plugin/ca.crt"
  k8s_key: "/etc/vcfc-net-plugin/client.key"
  k8s_cert: "/etc/vcfc-net-plugin/client.crt"
  k8s_token: ""
kind: ConfigMap
apiVersion: v1
metadata:
data:
  vcfc_url: https://192.168.0.32:8443
  vcfc_username: "sdn"
  vcfc_password: "sdn123456"
  vcfc_domain: "sdn"
  vcfc_client_timeout: "1800"
  vcfc_client_retry: "10"
  netoverlay_vlan_ranges: "node01:1:100,node02:101:200"
  log_dir: "/var/log/vcfc-net-plugin/"
  log_level: "1"
  bind_host: "0.0.0.0"
  bind_port: "9797"
  protocol: "http"
kind: ConfigMap
apiVersion: v1
metadata:
data:
  net_masters: "auto"
  net_master_app_name: "vcfc-net-master"
  net_master_app_namespace: "kube-system"
  net_master_protocol: "http"
  net_master_port: "9797"
  overlay_mode: "auto"
  log_level: "1"
  default_security_policy: "permit"
4.     Install the plug-in.
$ kubectl create -f VCFC_DC_NET_PLUGIN-E3103.yaml
5.     Verify the installation. If the Pods are in Running state, the plug-in is installed correctly.
$ kubectl get pods -n kube-system | grep vcfc
vcfc-net-agent-mtwkl 1/1 Running 0 5d7h
vcfc-net-agent-rt2s6 1/1 Running 0 5d7h
vcfc-net-master-79bc68885c-2s9jm 1/1 Running 0 5d7h
The following table describes parameters in the configuration file of the VCF Kubernetes plug-in.
Table 3 Parameters in the configuration file of the VCF Kubernetes plug-in
Parameter
etcd_servers
etcd service API address.
k8s_api_server
K8s API server interface address.
k8s_ca
Client CA file of the K8s API server. This parameter is valid only when the value of the k8s_api_server parameter is an HTTPS address.
k8s_key
Client X.509 certificate private key file of the K8s API server. This parameter is valid only when the value of the k8s_api_server parameter is an HTTPS address. It is used together with k8s_cert.
This parameter is not required when k8s_token authentication is used.
k8s_cert
Client X.509 certificate file of the K8s API server. This parameter is valid only when the value of the k8s_api_server parameter is an HTTPS address.
This parameter is not required when k8s_key and k8s_cert authentication is used.
k8s_token
Client authentication token of the K8s API server. This parameter is valid only when the value of the k8s_api_server parameter is an HTTPS address.
vcfc_url
HTTPS URL address of the VCFC-DC controller.
vcfc_username
Username for logging in to the VCFC-DC controller.
vcfc_password
Password for logging in to the VCFC-DC controller.
vcfc_domain
Name of the domain where the VCFC-DC controller resides.
vcfc_client_timeout
The amount of time waiting for a response from the VCFC-DC controller, in seconds.
vcfc_client_retry
Maximum transmissions of connection requests to the VCFC-DC controller.
VLAN range for the node in network-based overlay mode, in the format of VLAN_min:VLAN_max. For more than one VLAN range, use a comma to separate them.
log_dir
Log directory.
log_level
Log level.
bind_host
API-bound address.
bind_port
API-bound port number. As a best practice, bind the API to the net_master_port.
protocol
API protocol. Only HTTP is supported.
net_masters
IP address of the VCFC network master. auto means automatically obtaining the IP address.
net_master_app_name
Application name of the VCFC network master.
Application namespace of the VCFC network master.
net_master_protocol
API protocol of the VCFC network master.
net_master_port
API port number of the VCFC network master.
overlay_mode
Overlay mode of the node:
·     net—Network-based overlay
·     host—Host-based overly
·     auto—Automatic selection of overlay mode based on the open vSwitch configuration
Default security policy. This parameter takes effect only in network-based overlay mode.
·     permit
·     deny
Removing the plug-in
To remove the plug-in, execute the following command:
$ kubectl delete -f VCFC_DC_NET_PLUGIN-E3103.yaml
Upgrading the plug-in
1.     Install the plug-in Docker image. For the installation procedure, see "Loading the plug-in Docker image."
2.     Upload and modify the plug-in configuration file. For the procedure, see "Installing the plug-in."
3.     Upgrade the plug-in.
$ kubectl apply -f VCFC_DC_NET_PLUGIN-E3104.yaml
Configuration example
Installation of the VCF Kubernetes plug-in allows interconnection between the VCFC-DC controller and the Kubernetes platform. The following example describes the configuration procedure for Pods to be managed by the VCFC-DC controller.
For the Pods to be managed by the VCFC-DC controller:
1.     Create tenants, virtual link layer networks, subnets, security policies, and network policies on the controller.
2.     Create and modify a Pod configuration file, postgres-pod.yaml for example.
$ vi postgres-pod.yaml
apiVersion: v1
kind: Pod
metadata:
  labels:
    h3c.io/network_id: 9e9af886-e038-4c94-8573-11b89079196d
    h3c.io/tenant_id: 14ac7fc1-50d4-409a-ad76-4a0c35f429f3
    h3c.io/qos_policy_id: 38b51db9-cc1d-4b07-872e-cf2644bfc057
    h3c.io/security_group_id: 39b70d60-8bfd-4b27-bb4d-4b8f8955a2e6
spec:
  containers:
  - name: postgres
image: postgres
Parameter description:
¡     h3c.io/network_id—UUID of the VCFC-DC virtual network. This parameter is required.
¡     h3c.io/tenant_id—UUID of the VCFC-DC tenants. This parameter is required.
¡     h3c.io/qos_policy_id—UUID of the VCFC-DC network policy. This parameter is optional.
¡     h3c.io/security_group_id—UUID of the VCFC-DC security policy. This parameter is optional.
3.     Use the configuration file to create a Pod.
$ kubectl create -f postgres-pod.yaml
4.     Verify that the Pod is displayed and manageable on the Virtual Port page on the VCFC-DC controller.
