03-WLAN Command References
HomeSupportConfigure & DeployConfiguration GuidesH3C Unified Wired and Wireless Access Controller User Manual (R5417P03)-6W10303-WLAN Command References
16-AC hierarchy commands
16-AC hierarchy commands 81.47 KB
display wlan ac-role
Use display wlan ac-role to display the current AC role.
Only central ACs support this command.
# Display the current AC role.
<Sysname> display wlan ac-role
Current AC role: Central AC
Current AC role
AC role:
·         Common.
·         Central AC.
·         Local AC.
·         Unknown.
display wlan client
Use display wlan client to display client information.
display wlan client distributed-sys [ verbose ]
distributed-sys: Specifies the AC hierarchical network.
verbose: Displays detailed client information. If you do not specify this keyword, the command displays brief client information.
# Display brief information about all clients.
<Sysname> display wlan client distributed-sys
Total number of clients: 3
MAC address    Username         AP name       RID   IPv4 address        VLAN
000f-e265-6400 N/A              ap1           1     1.1.1.1             100
000f-e265-6401 user             ap2           1     3.0.0.3             200
84db-ac14-dd08 N/A              ap1           1     5.5.5.3             1
MAC address
Client MAC address.
Username
Client username:
·         The field displays the client username if the client uses 802.1X or MAC authentication.
·         The field displays N/A if the client does not use 802.1X or MAC authentication.
If the client uses portal authentication, this field does not display the portal username of the client.
AP name
Name of the AP that the client is associated with.
RID
ID of the radio that the client is associated with.
IPv4 address
IPv4 address of the client.
VLAN ID
ID of the VLAN to which the client belongs.
# Display detailed information about all clients.
<Sysname> display wlan client distributed-sys verbose
Total number of clients: 1
MAC address                        : 000f-e265-6400
IPv4 address                       : 10.1.1.114
IPv6 address                       : 2001::1234:5678:0102:0304
Username                           : N/A
AID                                : 1
AP ID                              : 1
AP name                            : ap1
Radio ID                           : 1
SSID                               : office
BSSID                              : 0026-3e08-1150
VLAN ID                            : 3
Sleep count                        : 3
Wireless mode                      : 802.11ac
Channel bandwidth                  : 80MHz
SM power save                      : Enabled
SM power save mode                 : Dynamic
Short GI for 20MHz                 : Supported
Short GI for 40MHz                 : Supported
Short GI for 80MHz                 : Supported
Short GI for 160/80+80MHz          : Not supported
STBC RX capability                 : Not supported
STBC TX capability                 : Not supported
LDPC RX capability                 : Not supported
SU beamformee capability           : Not supported
MU beamformee capability           : Not supported
Beamformee STS capability          : N/A
Block Ack                          : TID 0 In
Supported VHT-MCS set              : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8
Supported HT MCS set                 : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15, 16, 17, 18, 19, 20,
                                     21, 22, 23
Supported rates                    : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
QoS mode                           : WMM
Listen interval                    : 10
RSSI                               : 62
Rx/Tx rate                         : 130/195 Mbps
Authentication method              : Open system
Security mode                      : PRE-RSNA
AKM mode                           : Not configured
Cipher suite                       : N/A
User authentication mode           : Bypass
Authorization ACL ID               : 3001(Not effective)
Authorization user profile         : N/A
Roam status                        : N/A
Key derivation                     : SHA1
PMF status                         : Enabled
Forward policy name                : Not configured
Online time                        : 0days 0hours 1minutes 13seconds
FT status                          : Inactive
MAC address
Client MAC address.
IPv4 address
Client IPv4 address.
IPv6 address
Client IPv6 address.
Username
Client username:
AID
Association ID.
AP ID
ID of the AP that the client is associated with.
AP name
Radio ID
SSID
SSID with which the client is associated.
VLAN ID
Sleep count
Client sleep times.
Wireless mode
Wireless mode:
·         802.11a.
·         802.11b.
·         802.11g.
·         802.11gn.
·         802.11an.
·         802.11ac.
Channel bandwidth
Channel bandwidth:
·         20 MHz.
·         40 MHz.
·         80 MHz.
·         160 MHz.
SM Power Save
SM Power Save status:
·         Enabled—Only one antenna of the client operates in active state, and others operate in sleep state to save power.
·         Disabled.
SM power save mode
Power saving mode:
·         Dynamic.
·         Static.
Short GI for 20MHz
Whether the client supports short GI when its channel bandwidth is 20 MHz:
·         Supported.
·         Not supported.
Short GI for 40MHz
Whether the client supports short GI when its channel bandwidth is 40 MHz:
·         Supported.
·         Not supported.
Short GI for 80MHz
Whether the client supports short GI when its channel bandwidth is 80 MHz:
·         Supported.
·         Not supported.
Whether the client supports short GI when its channel bandwidth is 160 MHz or 80 + 80 MHz:
·         Supported.
·         Not supported.
STBC Rx Capability
Client STBC receive capability;
·         Not Supported.
·         Supported.
STBC Tx Capability
Client STBC transmission capability:
·         Not Supported.
·         Supported.
LDPC Rx capability
Client LDPC receive capability;
·         Not Supported.
·         Supported.
Client SU beamformee capability:
·         Not Supported.
·         Supported.
This field is supported only by 802.11ac radios.
Client MU beamformee capability:
·         Not Supported.
·         Supported.
Client beamformee STS capability. This field displays N/A if the feature is not supported.
Block Ack
Negotiation result of Block ACK with TID:
·         TID 0 In—Sends Block ACK for inbound traffic.
·         TID 0 Out—Sends Block ACK for outbound traffic.
·         TID 0 Both—Sends Block ACK for both inbound and outbound traffic.
·         N/A—Does not send Block ACK for both inbound and outbound traffic.
VHT-MCS supported by the client.
QoS mode
QoS mode:
·         N/A—WMM is not supported.
·         WMM—WMM is supported.
WMM information is negotiated between an AP and a client that both support WMM.
Listen interval
Interval at which the client wakes up to listen for beacon frames. It is counted by beacon interval.
RSSI
Received signal strength indication. This value indicates the client signal strength detected by the AP.
Rx/Tx rate
Sending and receiving rates of data, management, and control frames.
Authentication method:
·         Open system.
·         Shared key.
Security mode
Security mode:
·         RSN—Beacons and probe responses carry RSN IE.
·         WPA—Beacons and probe responses carry WPA IE.
·         PRE-RSNA—Beacons and probe responses do not carry RSN IE or WPA IE.
AKM mode
AKM mode:
·         802.1X.
·         PSK.
·         Not configured.
Cipher suite
Cipher suite:
·         N/A.
·         WEP40.
·         WEP104.
·         WEP128.
·         CCMP.
·         TKIP.
User authentication mode:
·         Bypass—No client authentication.
·         MAC.
·         802.1X.
·         OUI.
Authorized ACL number:
·         This field displays the ACL number if the authorization ACL takes effect.
·         This field displays ACL number(Not effective) if the authorization ACL does not take effect.
·         This field displays N/A if the authentication server is configured without any authorization ACL.
Name of the authorization user profile:
·         This field displays the authorized user profile name if the authorization user profile takes effect.
·         This field displays authorized user profile name + Not effective if the authorization user profile does not take effect.
·         This field displays N/A if the authentication server is configured without any authorization user profile.
Roam status
Roam status:
·         Roaming in progress.
·         Inter-AC slow roaming.
·         Inter-AC fast roaming.
·         Intra-AC slow roaming.
·         Intra-AC fast roaming.
·         This field displays N/A if the client stays in one BSS after coming online.
Key derivation
Key derivation type:
·         SHA1—Uses the HMAC-SHA1 hash algorithm.
·         SHA256—Uses the HMAC-SHA256 hash algorithm.
·         N/A—No key derivation algorithm is involved for the authentication type.
PMF status
PMF status:
·         Enabled—Management frame protection is enabled.
·         Disabled—Management frame protection is disabled.
·         N/A—Management frame protection is not involved.
Forward policy name
WLAN forwarding policy name:
·         Not configured.
·         Policy-name.
Online time
Client online duration.
FT status
Fast BSS transition (FT):
·         Active—FT is enabled.
·         Inactive—FT is disabled.
display wlan local-ac (on local ACs)
Use display wlan local-ac to display local AC information on the local AC.
If you specify a central AC and enable the local AC feature, this command displays both local AC and central AC information.
# Display local AC information on the local AC.
<Sysname> display wlan local-ac
Local AC information:
  Model                          : WA4320H
  Serial ID                      : 219801A0YG8165E00001
  MAC address                    : 00EF-003C-0001
  Local AC address               : 1.1.1.55
  H/W version                    : Ver.A
  S/W version                    : c5419
  Boot version                   : 1.01
  Static central AC IPv4 address : 1.1.1.5
  Static central AC IPv6 address : 10::1
Central AC information:
  Central AC address             : 1.1.1.5
  State                          : Run
  Sent control packets           : 100
  Received control packets       : 100
Local AC address
IP address of the local AC. This field displays N/A if the local AC has not established a tunnel with a central AC.
H/W version
Hardware version of the local AC.
S/W version
Software version of the local AC.
Boot version
BootWare version of the local AC.
Static IPv4 address of the central AC. This field displays Not configured if it is not configured.
Static IPv6 address of the central AC. This field displays Not configured if it is not configured.
Tunnel state:
·         Idle.
·         Sulking—The local AC fails to discover the central AC.
·         Discovery—The local AC is discovering the central AC.
·         Join—The local AC sends a join request to the central AC to establish the tunnel.
·         Image Download—The local AC is downloading a version from the central AC.
·         Config—The local AC is downloading initial configuration from the central AC.
·         Data Check—The local AC is checking data.
·         Run—The tunnel has been established successfully.
·         N/A—The local AC cannot come online for specific reasons such as local AC feature disabled.
Number of control packets sent by the central AC in Run state.
Number of control packets received by the central in Run state.
display wlan local-ac connection-record
Use display wlan local-ac connection-record to display local AC connection records on the central AC.
display wlan local-ac { all | name local-ac-name } connection-record
all: Specifies all local ACs.
name local-ac-name: Specifies a local AC by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display connection records of all local ACs on the central AC.
<Sysname> display wlan local-ac all connection-record
Local AC Information
 State : D = Discovery,       J  = Join,       O = Offline,    R = Run
AC name                         IP address       State      State changed at
bac                             192.168.100.27   R          01-06 09:06:40
Table 5 Command output
Local AC state:
·         D—The local AC discovered the central AC.
·         J—The management tunnel has been established.
·         O—The local AC has been disconnected from the central AC.
·         R—The local AC is operating. It indicates that the local AC and the central AC have established a CAPWAP tunnel successfully.
State changed at
Time at which the local AC entered the current state.
display wlan local-ac online-time
Use display wlan local-ac online-time to display the online duration of an online local AC on the central AC.
display wlan local-ac { all | name local-ac-name } online-time
all: Specifies all online local ACs.
name local-ac-name: Specifies an online local AC by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display the online duration of all online local ACs on the central AC.
<Sysname> display wlan local-ac all online-time
AC name              IP address        Time
bac1                 1.1.1.10          1 days 2 hours 13 minutes 39 seconds
bac2                 100:100:100::12   0 days 3 hours 10 minutes 20 seconds
Table 6 Command output
AC name
Name of the local AC.
IP address
Time
Online duration of the local AC.
location (AP group view)
Use location to assign a location identifier to an AP group.
Use undo location to restore the default.
location location-name
undo location
The default location identifier default-location is assigned to an AP group.
AP group view
location-name: Specifies a location identifier, a case-insensitive string of 1 to 31 characters. It can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
After you assign a location identifier to an AP group, the AP group will be assigned to that location.
An administrator can view and manage only an AP group whose location identifier is accessible to his user role when he logs in to the central AC from the CLI and the Web interface.
# Assign location identifier area1 to AP group g1.
[Sysname] wlan ap-group g1
[Sysname-wlan-ap-group-g1] location area1
wlan location
location (RRM holddown group view)
Use location to assign a location identifier to an RRM holddown group.
undo location
The default location identifier default-location is assigned to an RRM holddown group.
After you assign a location identifier to an RRM holddown group, the RRM holddown group will be assigned to that location.
An administrator can view and manage only an RRM holddown group whose location identifier is accessible to his or her user role when the administrator logs in to the central AC from the CLI and the Web interface.
# Assign location identifier area1 to RRM holddown group 1.
[Sysname] wlan rrm-calibration-group 1
[Sysname-wlan-rrm-calibration-group-1] location area1
wlan location
location (service template view)
Use location to assign a location identifier to a service template.
undo location
The default location identifier default-location is assigned to a service template.
Service template view
After you assign a location identifier to a service template, the service template will be assigned to that location.
An administrator can view and manage only a service template whose location identifier is accessible to his user role when he logs in to the central AC from the CLI and the Web interface.
# Assign location identifier area1 to service template 1.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] location area1
wlan location
reset wlan local-ac
Use reset wlan local-ac to reboot the specified local AC or all local ACs.
reset wlan local-ac { all | name ac-name }
name ac-name: Specifies the name of a local AC, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), righ brackets (]), forward slashes (/), and hyphens (-).
Rebooting a local AC logs off all the online APs associated with the local AC. If the central AC has other connected local ACs, the offline APs will come online again from these local ACs.
# Reboot local AC local-ac1.
<Sysname> reset wlan local-ac name local-ac1
wlan local-ac name
roam central-ac-auth enable
Use roam central-ac-auth enable to enable client roaming when the central AC acts as the authenticator.
Use undo roam central-ac-auth enable to disable client roaming when the central AC acts as the authenticator.
Client roaming is enabled when the central AC acts as the authenticator.
In AC hierarchy network, clients cannot perform inter- or intra-local AC roaming when the central AC acts as the authenticator because roaming entries are generated only on the central AC. Perform this task to enable local ACs to generate roaming entries when the central AC is specified as the authenticator and enable clients to perform roaming.
When the central AC acts as the authenticator, RSN + 802.1X clients cannot perform fast roaming even if this feature is enabled.
Make sure the service template is disabled before you execute this command.
# Enable client roaming when the central AC acts as the authenticator.
[Sysname-wlan-st-service1] roam central-ac-auth enable
wlan central-ac
Use wlan central-ac to specify a central AC for a local AC.
Use undo wlan central-ac to delete an IP address of a central AC.
wlan central-ac { ip ipv4-address | ipv6 ipv6-address }
undo wlan central-ac { ip [ ipv4-address ] | ipv6 [ ipv6-address ] }
No central AC is specified for a local AC.
ip ipv4-address: Specifies an IPv4 address of a central AC.
ipv6 ipv6-address: Specifies an IPv6 address of a central AC.
Only local ACs support this command.
You can specify a maximum of three IPv4 addresses and three IPv6 addresses.
If you do not specify any keywords when executing the undo command, the command deletes all IP addresses.
# Specify the central AC with IP address 192.168.100.11 for the local AC.
[Sysname] wlan central-ac ip 192.168.100.11
wlan local-ac capwap source-vlan
Use wlan local-ac capwap source-vlan to specify a VLAN that the local AC uses to establish a tunnel with the central AC.
Use undo wlan local-ac capwap source-vlan to restore the default.
wlan local-ac capwap source-vlan vlan-id
A local AC uses VLAN 1 to establish a tunnel with the central AC.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
# Configure the local AC to use VLAN 2 to establish a tunnel with the central AC.
[Sysname] wlan local-ac capwap source-vlan 2
wlan local-ac enable
Use wlan local-ac enable to enable the local AC feature.
Use undo wlan local-ac enable to disable the local AC feature.
The local AC feature is disabled.
Only common ACs and local ACs support this command.
After you enable the local AC feature on the AC and specify a central AC, the AC acts as a local AC to establish a CAPWAP tunnel with the central AC.
The undo command terminates the CAPWAP tunnel between the local AC and the central AC.
# Enable the local AC feature.
[Sysname] wlan local-ac enable
wlan location
Use wlan location to create a location identifier.
Use undo wlan location to delete a location identifier.
wlan location location-name
undo wlan location location-name
The default location identifier default-location exists.
The default location identifier is accessible to all user roles and cannot be deleted.
You can create a maximum of 512 location identifiers.
# Create location identifier area1.
[Sysname] wlan location area1
