H3C Fixed Port Campus Switches Configuration Examples-B70D029-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-B70D029-6W100
Table of Contents
Related Documents
38-CFD Configuration Examples
38-CFD Configuration Examples 122.84 KB
Introduction
This document provides CFD configuration examples.
CFD is used for link connectivity detection, fault verification, and fault location in Layer 2 networks.
This document assumes that you have basic knowledge of CFD.
Example: Configuring CFD
As shown in Figure 1, Device B and Device C reside in the central equipment room of a company. Device A, Device D, and Device E reside in other areas.
·     Research and development department users in VLAN 20 access the enterprise network through Device A and Device D.
·     Marketing department users in VLAN 30 access the enterprise network through Device A and Device E.
Configure CFD to verify and locate link faults.
Figure 1 Network diagram
Analysis
To accurately locate link faults, assign the enterprise network to MD_A (level 5) and the central equipment room network to MD_B (level 3). MD_A nests MD_B.
To effectively implement CFD, assign MAs based on the VLANs of service traffic:
·     Assign VLAN 20 in MD_A to MA_A_1.
·     Assign VLAN 30 in MD_A to MA_A_2.
·     Assign VLAN 20 in MD_B to MA_B_1.
·     Assign VLAN 30 in MD_B to MA_A_2.
To verify link connectivity, configure MEPs on the interfaces located at the boundary of MAs, for example, MA_B_1:
·     Configure MEPs on interface XGE1/0/1 of Device B and Device D to allow CFD packets from VLAN 20 to pass through the following interfaces:
¡     XGE1/0/1 and XGE1/0/2 of Device B.
¡     XGE1/0/1 and XGE1/0/2 of Device C.
¡     XGE1/0/1 of Device D.
·     Configure XGE1/0/1 of Device B as an inward-facing MEP because CFD packets are forwarded through other interfaces on the device.
·     Configure XGE1/0/1 of Device D as an outward-facing MEP because CFD packets are forwarded through the interface.
To accurately locate link faults between Device B and Device D, configure the default MIP generation rule on Device C.
To detect connectivity among MEPs, configure CC on the MEPs.
To verify link faults detected through CC, use LB. To trace faulty paths or locate link faults, use LT after the status information of the entire network is obtained.
Figure 2 shows a CFD configuration diagram based on the previous analysis.
Figure 2 CFD configuration diagram
Hardware
Software version
S6520X-HI switch series
S6520X-EI switch series
Supported in Release 1110P01
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
When you configure CFD, follow these restrictions and guidelines:
·     You cannot create a MEP if the MEP ID is not included in the MEP list of the service instance.
·     You can configure multiple MAs in an MD as needed. An MA serves only one VLAN.
·     Configure the same CCM interval field value for all MEPs in the same MA. In this example, the MEPs use the default CCM interval field value.
Procedures
Enabling CFD
# Enable CFD on Device A.
[DeviceA] cfd enable
# Enable CFD on Device B through Device E. (Details not shown.)
Creating VLANs and assigning interfaces to the VLANs
1.     Configure Device A:
[DeviceA] vlan 20
[DeviceA-vlan20] quit
[DeviceA] vlan 30
[DeviceA-vlan30] quit
[DeviceA-Ten-GigabitEthernet1/0/1] port access vlan 20
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] port access vlan 30
[DeviceA-Ten-GigabitEthernet1/0/2] quit
[DeviceA] interface ten-gigabitethernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/0/3] port trunk permit vlan 20 30
[DeviceA-Ten-GigabitEthernet1/0/3] quit
2.     Configure Device B:
[DeviceB] vlan 20
[DeviceB-vlan20] quit
[DeviceB] vlan 30
[DeviceB-vlan30] quit
[DeviceB-Ten-GigabitEthernet1/0/1] port link-type trunk
[DeviceB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 20 30
[DeviceB] interface ten-gigabitethernet 1/0/2
[DeviceB-Ten-GigabitEthernet1/0/2] port link-type trunk
[DeviceB-Ten-GigabitEthernet1/0/2] port trunk permit vlan 20
[DeviceB-Ten-GigabitEthernet1/0/2] quit
[DeviceB] interface ten-gigabitethernet 1/0/3
[DeviceB-Ten-GigabitEthernet1/0/3] port link-type trunk
[DeviceB-Ten-GigabitEthernet1/0/3] port trunk permit vlan 30
[DeviceB-Ten-GigabitEthernet1/0/3] quit
3.     Configure Device C:
[DeviceC] vlan 20
[DeviceC-vlan20] quit
[DeviceC] interface ten-gigabitethernet 1/0/1
[DeviceC-Ten-GigabitEthernet1/0/1] port link-type trunk
[DeviceC-Ten-GigabitEthernet1/0/1] port trunk permit vlan 20
[DeviceC-Ten-GigabitEthernet1/0/1] quit
[DeviceC] interface ten-gigabitethernet 1/0/2
[DeviceC-Ten-GigabitEthernet1/0/2] port link-type trunk
[DeviceC-Ten-GigabitEthernet1/0/2] port trunk permit vlan 20
[DeviceC-Ten-GigabitEthernet1/0/2] quit
4.     Configure Device D:
[DeviceD] vlan 20
[DeviceD-vlan20] quit
[DeviceD] interface ten-gigabitethernet 1/0/1
[DeviceD-Ten-GigabitEthernet1/0/1] port link-type trunk
[DeviceD-Ten-GigabitEthernet1/0/1] port trunk permit vlan 20
[DeviceD-Ten-GigabitEthernet1/0/1] quit
[DeviceD] interface ten-gigabitethernet 1/0/2
[DeviceD-Ten-GigabitEthernet1/0/2] port access vlan 20
[DeviceD-Ten-GigabitEthernet1/0/2] quit
5.     Configure Device E:
[DeviceE] vlan 30
[DeviceE-vlan30] quit
[DeviceE] interface ten-gigabitethernet 1/0/1
[DeviceE-Ten-GigabitEthernet1/0/1] port access vlan 30
[DeviceE-Ten-GigabitEthernet1/0/1] quit
[DeviceE] interface ten-gigabitethernet 1/0/2
[DeviceE-Ten-GigabitEthernet1/0/2] port link-type trunk
[DeviceE-Ten-GigabitEthernet1/0/2] port trunk permit vlan 30
[DeviceE-Ten-GigabitEthernet1/0/2] quit
Configuring service instances
Based on the MAs to which the MEPs belong, perform the configurations as described in the following table:
Device
MD
MD level
MA
VLAN
Service instance
Device A
MD_A
5
MA_A_1
20
1
MA_A_2
30
2
Device B
MD_B
3
MA_B_1
20
3
MA_B_2
30
4
Device C
MD_B
3
MA_B_1
20
3
Device D
MD_A
5
MA_A_1
20
1
MD_B
3
MA_B_1
20
3
Device E
MD_A
5
MA_A_2
30
2
MD_B
3
MA_B_2
30
4
# Create MD_A (level 5).
[DeviceA] cfd md MD_A level 5
# Create service instance 1, in which the MA named MA_A_1 serves VLAN 20.
[DeviceA] cfd service-instance 1 ma-id string MA_A_1 md MD_A vlan 20
# Create service instance 2, in which the MA named MA_A_2 serves VLAN 30.
[DeviceA] cfd service-instance 2 ma-id string MA_A_2 md MD_A vlan 30
Configure Device B through Device E in the same way Device A is configured.
[DeviceB] cfd md MD_B level 3
[DeviceB] cfd service-instance 3 ma-id string MA_B_1 md MD_B vlan 20
[DeviceB] cfd service-instance 4 ma-id string MA_B_2 md MD_B vlan 30
[DeviceC] cfd md MD_B level 3
[DeviceC] cfd service-instance 3 ma-id string MA_B_1 md MD_B vlan 20
[DeviceD] cfd md MD_A level 5
[DeviceD] cfd service-instance 1 ma-id string MA_A_1 md MD_A vlan 20
[DeviceD] cfd md MD_B level 3
[DeviceD] cfd service-instance 3 ma-id string MA_B_1 md MD_B vlan 20
[DeviceE] cfd md MD_A level 5
[DeviceE] cfd service-instance 2 ma-id string MA_A_2 md MD_A vlan 30
[DeviceE] cfd md MD_B level 3
[DeviceE] cfd service-instance 4 ma-id string MA_B_2 md MD_B vlan 30
Configuring MEPs
Assign MEP IDs as described in the following table:
Service instance
Device
MEP ID
MEP type
1
Device A
Ten-GigabitEthernet 1/0/1
1001
Inward-facing MEP
Device D
Ten-GigabitEthernet 1/0/2
1002
Inward-facing MEP
2
Device A
2001
Inward-facing MEP
Device E
2002
Inward-facing MEP
3
Device B
3001
Inward-facing MEP
Device D
3002
Outward-facing MEP
4
Device B
4001
Inward-facing MEP
Device E
4002
Outward-facing MEP
# Configure a MEP list in service instances 1 and 2.
[DeviceA] cfd meplist 1001 1002 service-instance 1
[DeviceA] cfd meplist 2001 2002 service-instance 2
# Create inward-facing MEP 1001 in service instance 1 on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] cfd mep 1001 service-instance 1 inbound
# Create inward-facing MEP 2001 in service instance 2 on Ten-GigabitEthernet 1/0/2.
[DeviceA-Ten-GigabitEthernet1/0/2] cfd mep 2001 service-instance 2 inbound
Configure Device B, Device D, and Device E in the same way Device A is configured.
[DeviceB] cfd meplist 3001 3002 service-instance 3
[DeviceB] cfd meplist 4001 4002 service-instance 4
[DeviceB-Ten-GigabitEthernet1/0/1] cfd mep 3001 service-instance 3 inbound
[DeviceB-Ten-GigabitEthernet1/0/1] cfd mep 4001 service-instance 4 inbound
3.     Configure Device D:
[DeviceD] cfd meplist 1001 1002 service-instance 1
[DeviceD] cfd meplist 3001 3002 service-instance 3
[DeviceD-Ten-GigabitEthernet1/0/2] cfd mep 1002 service-instance 1 inbound
[DeviceD-Ten-GigabitEthernet1/0/1] cfd mep 3002 service-instance 3 outbound
4.     Configure Device E:
[DeviceE] cfd meplist 2001 2002 service-instance 2
[DeviceE] cfd meplist 4001 4002 service-instance 4
[DeviceE-Ten-GigabitEthernet1/0/1] cfd mep 2002 service-instance 2 inbound
[DeviceE-Ten-GigabitEthernet1/0/2] cfd mep 4002 service-instance 4 outbound
Configuring a MIP generation rule
# Configure the MIP generation rule in service instance 3 on Device C as default.
[DeviceC] cfd mip-rule default service-instance 3
Configuring CC on MEPs
# Enable the sending of CCM frames for MEP 1001 in service instance 1 on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] cfd cc service-instance 1 mep 1001 enable
# Enable the sending of CCM frames for MEP 2001 in service instance 2 on Ten-GigabitEthernet 1/0/2.
[DeviceA-Ten-GigabitEthernet1/0/2] cfd cc service-instance 2 mep 2001 enable
[DeviceB-Ten-GigabitEthernet1/0/1] cfd cc service-instance 3 mep 3001 enable
[DeviceB-Ten-GigabitEthernet1/0/1] cfd cc service-instance 4 mep 4001 enable
[DeviceD-Ten-GigabitEthernet1/0/1] cfd cc service-instance 3 mep 3002 enable
[DeviceD-Ten-GigabitEthernet1/0/2] cfd cc service-instance 1 mep 1002 enable
[DeviceE-Ten-GigabitEthernet1/0/1] cfd cc service-instance 2 mep 2002 enable
[DeviceE-Ten-GigabitEthernet1/0/2] cfd cc service-instance 4 mep 4002 enable
In this example, the MAC addresses of Device A through Device E are 0010-FC01-6511, 0010-FC02-6512, 0010-FC03-6513, 0010-FC04-6514, and 0010-FC05-6515, respectively.
1.     Verify the configuration when the network is operating correctly:
# Display information about remote MEP 1001 in service instance 1 on Device A.
[DeviceA] display cfd remote-mep service-instance 1 mep 1001
MEP ID   MAC address      State        Time                  MAC status
1002     0010-fc04-6514   OK           2018/07/26 12:54:52   UP
The output shows that the remote MEP is operating correctly.
# Enable LB on Device A to verify the status of the link between MEP 1001 and MEP 1002 in service instance 1.
[DeviceA] cfd loopback service-instance 1 mep 1001 target-mep 1002
Loopback to MEP 1002 with the sequence number start from 1001-43404:
Reply from 0010-fc04-6514: sequence number=1001-43404 Time=5ms
Reply from 0010-fc04-6514: sequence number=1001-43405 Time=5ms
Reply from 0010-fc04-6514: sequence number=1001-43406 Time=5ms
Reply from 0010-fc04-6514: sequence number=1001-43407 Time=5ms
Reply from 0010-fc04-6514: sequence number=1001-43408 Time=5ms
Sent: 5        Received: 5        Lost: 0
The output shows that no link fault occurs on the link between MEP 1001 and MEP 1002 in service instance 1.
2.     Verify the configuration when a link fault occurs:
1002     0010-fc04-6514   FAILED       2018/07/26 13:01:52   DOWN
The output shows that the remote MEP is operating incorrectly.
Loopback to MEP 1002 with the sequence number start from 1001-43904:
Sent: 5        Received: 0        Lost: 5
The output shows that a link fault occurs on the link between MEP 1001 and MEP 1002 in service instance 1.
# Identify the path between MEP 3001 and MEP 3002 in service instance 3 on Device B.
[DeviceB] cfd linktrace service-instance 3 mep 3001 target-mep 3002
Linktrace to MEP 3002 with the sequence number 3001-43862:
MAC Address               TTL     Last Mac         Relay Action
0010-fc03-6513            63      0010-fc02-6512   MPDB
The output shows that MEP 3001 receives only the LTR messages from the MIP. No LTR messages are sent from MEP 3002 (Ten-GigabitEthernet 1/0/1 on Device D). The link between Device C and Device D fails, and you do not need to troubleshoot the network outside MD_B.
Configuration files
·     Device A:
 cfd enable
 cfd md MD_A index 1 level 5
 cfd service-instance 1 ma-id string MA_A_1 ma-index 1 md MD_A vlan 20
 cfd meplist 1001 to 1002 service-instance 1
 cfd service-instance 2 ma-id string MA_A_2 ma-index 1 md MD_A vlan 30
 cfd meplist 2001 to 2002 service-instance 2
vlan 20
vlan 30
 port link-mode bridge
 port access vlan 20
 port access vlan 30
·     Device B:
 cfd enable
 cfd md MD_B index 1 level 3
 cfd service-instance 3 ma-id string MA_B_1 ma-index 1 md MD_B vlan 20
 cfd meplist 3001 to 3002 service-instance 3
 cfd service-instance 4 ma-id string MA_B_2 ma-index 2 md MD_B vlan 30
 cfd meplist 4001 to 4002 service-instance 4
vlan 20
vlan 30
·     Device C:
 cfd enable
vlan 20
·     Device D:
 cfd enable
 cfd md MD_B index 2 level 3
vlan 20
 port access vlan 20
·     Device E:
 cfd enable
vlan 30
 port access vlan 30
