- 12-High Availability Command Reference
- 01-Interface backup commands
- 02-DLDP commands
- 03-Monitor Link commands
- 04-VRRP commands
- 05-Load balancing commands
- 06-Reth interface and redundancy group commands
- 07-BFD commands
- 08-Track commands
- 09-Process placement commands
- 10-Interface collaboration commands
| 05-Load balancing commands | 1005.42 KB |
arp-nd interface (SNAT address pool view)
arp-nd interface (virtual server view)
bandwidth busy-protection enable (transparent DNS proxy view)
bandwidth busy-protection enable (virtual server view)
bandwidth busy-rate (link view)
bandwidth busy-rate (real server view)
bandwidth interface statistics enable
connection-limit max (link group member view)
connection-limit max (link view)
connection-limit max (real server view)
connection-limit max (server farm member view)
connection-limit max (virtual server view)
connection-sync enable (transparent DNS proxy view)
connection-sync enable (virtual server view)
display loadbalance connections
display loadbalance dns-proxy statistics·
display loadbalance dns-server
display loadbalance dns-server statistics
display loadbalance dns-server-pool
display loadbalance hot-backup statistics
display loadbalance limit-policy
display loadbalance link out-interface statistics
display loadbalance link statistics
display loadbalance link-group
display loadbalance probe-template
display real-server statistics
display virtual-server statistics
dns-server (DNS server pool view)
dns-server-pool (LB action view)
dns-server-pool (DNS server view)
fail-action (server farm view)
fallback-action response raw-file
header delete request accept-encoding
inherit vpn-instance disable (link view)
inherit vpn-instance disable (real server view)
ip address (transparent DNS proxy view)
ip range (SNAT address pool view)
ipv6 address (transparent DNS proxy view)
ipv6 address (DNS server view)
ipv6 address (real server view)
keepalive retransmission interval
lb-policy (transparent DNS proxy view)
lb-policy (virtual server view)
loadbalance dns-cache aging-time
loadbalance isp auto-update enable
loadbalance isp auto-update frequency
loadbalance isp auto-update whois-server
loadbalance log enable bandwidth-busy
loadbalance schedule-test ipv6
max-bandwidth (real server view)
port (transparent DNS proxy view)
predictor (DNS server pool view)
priority (DNS server pool member view)
priority (link group member view)
priority (server farm member view)
probe (DNS server pool member view)
probe (link group member view)
probe (server farm member view)
proximity enable (link group view)
proximity enable (server farm view)
rate-limit bandwidth (link view)
rate-limit bandwidth (real server view)
rate-limit bandwidth (virtual server view)
rate-limit connection (link group member view)
rate-limit connection (link view)
rate-limit connection (real server view)
rate-limit connection (server farm member view)
rate-limit connection (virtual server view)
real-server (server farm view)
recover-from-auto-shutdown (real server view)
recover-from-auto-shutdown (server farm member view)
redirect relocation (LB action view)
redirect relocation (virtual server view)
redirect return-code (LB action view)
redirect return-code (virtual server view)
reset loadbalance dns-proxy statistics·
reset loadbalance dns-server statistics
reset loadbalance hot-backup statistics
reset loadbalance link statistics
reset loadbalance local-dns-server parse-fail-record
reset virtual-server statistics
selected-server (DNS server pool view)
selected-server (server farm view)
server-farm (real server view)
service enable (transparent DNS proxy view)
service enable (virtual server view)
set ip tos (parameter profile view)
shutdown (link group member view)
slow-online (server farm view)
slow-shutdown enable (link group member view)
slow-shutdown enable (link view)
slow-shutdown enable (real server view)
slow-shutdown enable (server farm member view)
snmp-agent trap enable loadbalance
ssl-client-policy (LB action view)
ssl-client-policy (virtual server view)
sticky-sync enable (transparent DNS proxy view)
sticky-sync enable (virtual server view)
success-criteria (DNS server pool member view)
success-criteria (DNS server pool view)
success-criteria (DNS server view)
success-criteria (link group member view)
success-criteria (link group view)
success-criteria (real server view)
success-criteria (server farm member view)
success-criteria (server farm view)
transparent enable (link group view)
transparent enable (server farm view)
virtual-server (virtual server pool view)
vpn-instance (real server view)
vpn-instance (transparent DNS proxy view)
vpn-instance (virtual server view)
weight (DNS server pool member view)
weight (link group member view)
activate (link group view)
Use activate to set the criteria to determine whether a link group is available.
Use undo activate to restore the default.
activate lower lower-percentage upper upper-percentage
undo activate
A link group is available when a minimum of one link is available.
Link group view
lower lower-percentage: Specifies the lower percentage value in the range of 1 to 99.
upper upper-percentage: Specifies the upper percentage value in the range of 1 to 99. The upper percentage value must be greater than or equal to the lower percentage value.
When the percentage of available links in a primary link group is smaller than the lower percentage value, the primary link group becomes unavailable. Then the backup link group takes over. When the percentage of available links in a primary link group is greater than the upper percentage value, the primary link group becomes available again to process services.
If no backup link group is configured on the virtual server, this configuration does not take effect.
# Set the lower percentage value to 20 and upper percentage value to 80 for the link group lg.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] activate lower 20 upper 80
activate (server farm view)
Use activate to set the criteria to determine whether a server farm is available.
undo activate
A server farm is available when a minimum of one real server is available.
Server farm view
lower lower-percentage: Specifies the lower percentage value in the range of 1 to 99. When the percentage of available real servers in the primary server farm is lower than the lower percentage value, the primary server farm becomes unavailable. Then the backup server farm takes over.
upper upper-percentage: Specifies the upper percentage value in the range of 1 to 99. The upper percentage value must be higher than or equal to the lower percentage value. When the percentage of available real servers in the primary server farm is higher than the upper percentage value, the primary server farm becomes available again to process services.
If no backup server farm is configured on the virtual server, this configuration does not take effect.
# Set the lower percentage value to 20 and upper percentage value to 80 for the server farm sf.
[Sysname] server-farm sf
[Sysname-sfarm-sf] activate lower 20 upper 80
application-mode enable
Use application-mode enable to configure a TCP virtual server to operate at Layer 7.
Use undo application-mode enable to restore the default.
A TCP virtual server operates at Layer 4.
TCP virtual server view
# Configure TCP virtual server vs to operate at Layer 7.
[Sysname] virtual-server vs type tcp
[Sysname-vs-tcp-vs] application-mode enable
Use arp-nd interface to specify an interface for sending gratuitous ARP packets and ND packets.
Use undo arp-nd interface to disable an interface from sending gratuitous ARP packets and ND packets.
arp-nd interface interface-type interface-number
undo arp-nd interface interface-type interface-number
No interface is specified for sending gratuitous ARP packets and ND packets. No interface can send gratuitous ARP packets or ND packets.
You can execute this command multiple times to specify multiple interfaces for one SNAT address pool.
# For SNAT address pool lbsp, specify GigabitEthernet 1/0 as the interface for sending gratuitous ARP packets and ND packets.
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] arp-nd interface gigabitethernet 1/0
Virtual server view
You can execute this command multiple times to specify multiple interfaces for one virtual server.
# For virtual server vs3, specify GigabitEthernet 1/0 as the interface for sending gratuitous ARP packets and ND packets.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] arp-nd interface gigabitethernet 1/0
auto-alloc address
Use auto-alloc address to enable the device to automatically obtain the IP address of a DNS server.
Use undo auto-alloc address to disable the device from automatically obtaining the IP address of a DNS server.
auto-alloc address
The device is disabled from automatically obtaining the IP address of a DNS server.
DNS server view
This command is mutually exclusive with the ip address and ipv6 address commands.
Before configuring this command, you must configure the router interface command. Otherwise, the IP address of the DNS server cannot be obtained.
If the device obtains multiple DNS server IP addresses, it uses the smallest available IP address.
# Enable the device to automatically obtain the IP address of DNS server ds1.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] auto-alloc address
auto-shutdown recovery-time
Use auto-shutdown recovery-time to set the automatic recovery time for intelligent monitoring.
Use undo auto-shutdown recovery-time to restore the default.
auto-shutdown recovery-time recovery-time
The automatic recovery time is 0 minutes.
Server farm view
recovery-time: Specifies the automatic recovery time in the range of 0 to 15300 minutes. The value of 0 means that a server farm member placed in Auto shutdown state does not automatically recover.
Use this command to enable automatic recovery for a real server that is shut down by intelligent monitoring.
If health monitoring is not configured, a recovered real server is set to Unknown state.
If health monitoring is configured and succeeds, a recovered real server is set to Active state. If health monitoring fails, a recovered real server is set to Probe-failed state.
# Set the automatic recovery time to 5 minutes for server farm sf.
[Sysname-sfarm-sf] auto-shutdown recovery-time 5
Use bandwidth busy-protection enable to enable the link protection feature for a transparent DNS proxy.
Use undo bandwidth busy-protection enable to disable the link protection feature for a transparent DNS proxy.
The link protection feature is disabled for a transparent DNS proxy.
Transparent DNS proxy view
This feature enables a transparent DNS proxy to select a DNS server from the DNS server pool based on the link bandwidth ratio. If the bandwidth ratio of a link exceeds the specified value, the corresponding DNS server is not selected.
If the link bandwidth ratio of all DNS servers in the DNS server pool exceeds the specified value, the link protection feature is automatically disabled. If the link bandwidth ratio of any DNS server drops below the specified value, the link protection feature is automatically enabled, and the corresponding DNS server is selected.
# Enable the link protection feature for transparent DNS proxy dns-proxy1.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] bandwidth busy-protection enable
Use bandwidth busy-protection enable to enable the link protection feature.
Use undo bandwidth busy-protection enable to disable the link protection feature.
The link protection feature is disabled.
Virtual server view
The link protection feature takes effect only when bandwidth statistics collection by interfaces is enabled.
# Enable the link protection feature for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] bandwidth busy-protection enable
Use bandwidth busy-rate to set the bandwidth ratio for an LB link.
Use undo bandwidth busy-rate to restore the default.
bandwidth [ inbound | outbound ] busy-rate busy-rate-number [ recovery recovery-rate-number ]
undo bandwidth [ inbound | outbound ] busy-rate
The bandwidth ratio is 70.
LB link view
inbound: Specifies the inbound bandwidth ratio.
outbound: Specifies the outbound bandwidth ratio.
busy-rate-number: Specifies bandwidth ratio in the range of 1 to 100.
recovery recovery-rate-number: Specifies bandwidth recovery ratio in the range of 1 to 100. By default, if the bandwidth ratio is greater than 10, the bandwidth recovery ratio equals the bandwidth ratio minus 10; if the bandwidth ratio is smaller than or equal to 10, the bandwidth recovery ratio equals the bandwidth ratio.
If the bandwidth of an LB link exceeds the maximum expected bandwidth multiplied by the bandwidth ratio, the LB link is busy and will not be selected. If the bandwidth of the LB link drops below the maximum expected bandwidth multiplied by the bandwidth recovery ratio, the LB link participates in scheduling again.
If you do not specify the inbound or outbound keyword, this command sets the total bandwidth ratio.
The bandwidth ratio equals the current bandwidth divided by the maximum bandwidth of the LB link. If the maximum bandwidth is not limited, the supported maximum bandwidth is used for calculating the bandwidth ratio.
The bandwidth recovery ratio must be smaller than or equal to the bandwidth ratio of an LB link.
This command takes effect only on new sessions and does not take effect on existing sessions.
# Set the total bandwidth ratio and bandwidth recovery ratio for the LB link lk1 to 90 and 85.
[Sysname] loadbalance link lk1
[Sysname-lb-link-link1] bandwidth busy-rate 90 recovery 85
max-bandwidth (link view)
Use bandwidth busy-rate to set the bandwidth ratio for a real server.
Real server view
busy-rate-number: Specifies the bandwidth ratio for the real server, in the range of 1 to 100.
recovery recovery-rate-number: Specifies bandwidth recovery ratio for the real server, in the range of 1 to 100. By default, if the bandwidth ratio is greater than 10, the bandwidth recovery ratio equals the bandwidth ratio minus 10; if the bandwidth ratio is smaller than or equal to 10, the bandwidth recovery ratio equals the bandwidth ratio.
If the traffic volume on the link to a real server exceeds the maximum expected bandwidth multiplied by the bandwidth ratio, the real server is busy and will not be selected. If the traffic volume drops below the maximum expected bandwidth multiplied by the bandwidth recovery ratio, the real server participates in scheduling again.
The bandwidth ratio equals the current bandwidth divided by the maximum bandwidth of the link. If the maximum bandwidth is not limited, the supported maximum bandwidth is used for calculating the bandwidth ratio.
The bandwidth recovery ratio must be smaller than or equal to the bandwidth ratio of a real server.
# Set the total bandwidth ratio and bandwidth recovery ratio for the real server rs to 20 and 10.
[Sysname] real-server rs
[Sysname-rserver-rs] bandwidth busy-rate 20 recovery 10
display real-server
Use bandwidth interface statistics enable to enable bandwidth statistics collection by interfaces.
Use undo bandwidth interface statistics enable to disable bandwidth statistics collection by interfaces.
Bandwidth statistics collection by interfaces is disabled.
Virtual server view
# Enable bandwidth statistics collection by interfaces for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] bandwidth interface statistics enable
bandwidth weight
Use bandwidth weight to set the bandwidth weight for proximity calculation.
Use undo bandwidth weight to restore the default.
bandwidth { inbound | outbound } weight bandwidth-weight
undo bandwidth { inbound | outbound } weight
The inbound or outbound bandwidth weight for proximity calculation is 100.
Proximity view
inbound: Specifies the inbound bandwidth weight.
outbound: Specifies the outbound bandwidth weight.
bandwidth-weight: Specifies the bandwidth weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher bandwidth weight.
# Set the inbound bandwidth weight for proximity calculation to 200.
[Sysname] loadbalance proximity
[Sysname-lb-proximity] bandwidth inbound weight 200
# Set the outbound bandwidth weight for proximity calculation to 200.
[Sysname-lb-proximity] bandwidth outbound weight 200
busy-action
Use busy-action to configure the action to take when a server farm is busy.
Use undo busy-action to restore the default.
busy-action { drop | enqueue length length timeout timeout-value | force }
undo busy-action
The default action is drop.
Server farm view
drop: Stops assigning client requests to the server farm.
enqueue: Assigns new client requests to a wait queue.
length length: Specifies the maximum number of client requests allowed in the wait queue, in the range of 1 to 100000. When the queue is full, new client requests are dropped.
timeout timeout-value: Specifies the aging time for the wait queue, in the range of 1 to 60 seconds.
force: Forcibly assigns client requests to all real servers in the server farm.
For the drop action, if the LB policy for the server farm contains the action of matching the next rule, the device compares client requests with the next rule. Otherwise, the device drops the client requests.
# Configure the action to take when a server farm is busy as force.
[Sysname-sfarm-sf] busy-action force
busy-action continue
Use busy-action continue to configure the action of matching the next rule when all links or DNS servers are busy.
undo busy-action
The device assigns packets to links or DNS servers regardless of whether they are busy.
Link-generic LB action view
DNS server LB action view
# Configure link-generic LB action a1 to match the next rule when all links or DNS servers are busy.
[Sysname] loadbalance action a1 type link-generic
[Sysname-lba-link-generic-a1] busy-action continue
case-insensitive
Use case-insensitive to disable case sensitivity for matching character strings.
Use undo case-insensitive to restore the default.
case-insensitive
Case sensitivity is enabled for matching character strings.
HTTP parameter profile view
This command affects the following content:
· HTTP header value, HTTP cookie name and value, and URL for matching classes.
· Header value, URL, and key value used for generating sticky entries for the HTTP header sticky method.
· Cookie name and value and key value used for generating sticky entries for the cookie get sticky method.
# Disable case sensitivity for the HTTP-type parameter profile pp1.
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] case-insensitive
check all-packet
Use check all-packet to enable checking for all packets.
Use undo check all-packet to restore the default.
check all-packet
Checking for all packets is disabled.
HTTP cookie sticky group view
If the sticky method is cookie get, use this command to get cookies from all HTTP response packets. If this command is not configured, the device gets only the Set-Cookie from the first response packet of a connection.
If the sticky method is cookie rewrite, use this command to rewrite cookies in all HTTP response packets. If this command is not configured, the device rewrites only the Set-Cookie in the first response packet of a connection.
If the sticky method is cookie insert, use this command to insert cookies to all HTTP response packets. If this command is not configured, the device inserts only the Set-Cookie to the first response packet of a connection.
# Enable checking for all packets in the HTTP cookie sticky group sg3.
[Sysname] sticky-group sg3 type http-cookie
[Sysname-sticky-http-cookie-sg3] check all-packet
class
Use class to specify an LB action for the specified LB class.
Use undo class to delete an LB class.
class class-name [ insert-before before-class-name ] action action-name
undo class class-name
No LB action is specified for the LB class.
LB policy view
class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters.
insert-before before-class-name: Inserts the target class before an LB class (which must already be referenced by the current LB policy), a case-insensitive string of 1 to 63 characters.
action-name: Specifies an LB action by its name, a case-insensitive string of 1 to 63 characters.
This command sets an LB action for packets matching the specified LB class.
You can specify an LB action for different LB classes.
A DNS LB policy can reference DNS LB actions only; a generic LB policy can reference generic LB classes and generic LB actions only. This rule does not apply to HTTP LB policies.
# Specify the LB action lba1 for the LB class lbc1 in the generic LB policy lbp1, and insert lbc1 before the LB class lbc0.
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1] class lbc1 insert-before lbc0 action lba1
compression level
Use compression level to set the compression level for response packets.
Use undo compression level to restore the default.
compression level level
The compression level for response packets is 1.
HTTP-compression parameter profile view
level: Specifies the compression level in the range of 1 to 9. A larger value indicates a lower compression speed and a higher compression ratio.
# Create the HTTP-compression parameter profile pa1, and set the compression level to 6.
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] compression level 6
Use connection-limit max to set the maximum number of connections of a link group member.
Use undo connection-limit max to restore the default.
connection-limit max max-number
The maximum number of connections of a link is 0, which means the number is not limited.
Link group member view
max-number: Specifies the maximum number of connections, in the range of 0 to 4294967295. If the value of this argument takes 0, the number is not limited.
# Set the maximum number of connections of the link group member lk1 to 10000.
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a link.
Link view
# Set the maximum number of connections of the link lk to 10000.
[Sysname-lb-link-lk] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a real server.
The maximum number of connections of a real server is 0, which means the number is not limited.
Real server view
# Set the maximum number of connections of the real server rs to 10000.
[Sysname-rserver-rs] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a server farm member.
Server farm member view
# Set the maximum number of connections of the server farm member rs1 to 10000.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname -sfarm-sf-#member#-rs1-port-80] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a virtual server.
The maximum number of connections of a virtual server is 0, which means the number is not limited.
Virtual server view
# Set the maximum number of connections for the IP-type virtual server vs3 to 10000.
[Sysname-vs-ip-vs3] connection-limit max 10000
Use connection-sync enable to enable session extension information synchronization for a transparent DNS proxy.
Use undo connection-sync enable to disable session extension information synchronization for a transparent DNS proxy.
Session extension information synchronization is disabled for a transparent DNS proxy.
This command can back up session information to ensure service continuity during a master and backup switchover in hot backup mode.
# Enable session extension information synchronization for the transparent DNS proxy dns_proxy1.
<Sysname>system-view
[Sysname-lb-dp-udp-dns-proxy1] connection-sync enable
Use connection-sync enable to enable session extension information synchronization for a virtual server.
Use undo connection-sync enable to disable session extension information synchronization for a virtual server.
Session extension information synchronization is disabled for a virtual server.
Virtual server view
This command is not supported by the virtual servers of the HTTP type.
# Enable session extension information synchronization for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] connection-sync enable
content
Use content to configure the HTTP entity sticky method.
Use undo content to delete the HTTP entity sticky method.
content [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo content
No sticky methods exist.
HTTP entity sticky group view
offset offset: Specifies the offset value of the entity based on the start of the HTTP packet, in the range of 0 to 1000. The default is 0.
start start-string: Specifies the regular expression that marks the start of the entity, a string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the entity, a string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the entity, in the range of 0 to 1000. The default is 0, which indicates all lengths.
Use this command to obtain the HTTP entity information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
The HTTP entity sticky method applies only to contents within the entity. The HTTP entity sticky method does not apply to chunk and multipart entity content.
The HTTP entity sticky method is not supported by the virtual servers of the fast HTTP type.
# Configure the HTTP entity sticky method for the HTTP entity sticky group sg2: Starting from the 30th byte of start of the HTTP packet, use the 20-byte HTTP entity with abc as the start string to generate sticky entries.
[Sysname] sticky-group sg2 type http-content
[Sysname-sticky-http-content-sg2] content offset 30 start abc length 20
content length-threshold
Use content length-threshold to set the minimum length of HTTP response content for compression.
Use undo content length-threshold to restore the default.
content length-threshold length
The minimum length of HTTP response content for compression is 1024 bytes.
length: Specifies the minimum length of HTTP response content for compression, in the range of 0 to 4294967295 bytes.
If an HTTP response packet contains the Content-Length header, the packet content is compressed only when its length reaches the minimum length of HTTP response content for compression. If the HTTP response packet does not contain the Content-Length header, the configuration does not take effect. The packet content is compressed regardless of its length.
# Create the HTTP-compression parameter profile http1, and set the minimum length of HTTP response content for compression to 2000 bytes.
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] content length-threshold 2000
content maxparse-length
Use content maxparse-length to set the maximum length of HTTP entities that can be parsed.
Use undo content maxparse-length to restore the default.
content maxparse-length length
The maximum length of HTTP entities that can be parsed is 4096.
length: Specifies the maximum length of HTTP entities that can be parsed, in the range of 1 to 65535.
This command is not supported by the virtual servers of the fast HTTP type.
# Set the maximum length of HTTP entities that can be parsed to 8192 for the HTTP parameter profile pp1.
[Sysname-para-http-pp1] content maxparse-length 8192
content rewrite
Use content rewrite to rewrite the content of HTTP responses.
Use undo content rewrite to restore the default.
content rewrite value value replace replace-string
The content of HTTP responses is not rewritten.
HTTP LB action view
value value: Specifies the HTTP packet content to be rewritten, a string of 1 to 127 characters. The string cannot contain question marks (?).
replace replace-string: Specifies the content after rewrite, a string of 1 to 127 characters.
This command applies only to the HTTP response packets in the format of text/*.
If the target packet content length exceeds 4096 bytes, this command does not take effect.
If you specify the replace-string argument as %[1-9], the matching packet content value will be replaced by the content in the corresponding pair of brackets. For example, if you execute the content rewrite value (Wel)(co)(me) replace %2 command, the content Welcome will be replaced by the content co in the second pair of brackets.
If you execute the content rewrite command multiple times, the most recent configuration takes effect.
# Create the HTTP LB action named replace, and replace the content 2000::1 in HTTP response packets with 2.3.4.5.
[Sysname] loadbalance action replace type http
[Sysname- lba-http-replace] content rewrite value 2000::1 replace 2.3.4.5
cookie
Use cookie to configure the HTTP cookie sticky method.
Use undo cookie to restore the default.
cookie { get name cookie-name [ offset offset ] [ start start-string] [ end end-string | length length ] | { insert | rewrite } [ name cookie-name ] }
undo cookie { get | insert | rewrite }
No HTTP cookie sticky methods exist.
get: Specifies the cookie get sticky method that gets the Set-Cookie field in the HTTP response packets sent by the server.
cookie-name: Specifies an HTTP cookie by its name, a case-sensitive string of 1 to 63 characters.
offset offset: Specifies the offset value of the cookie based on the start of the HTTP packet, in the range of 0 to 1000. The default is 0.
start start-string: Specifies the regular expression that marks the start of the cookie, a string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the cookie, a string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the cookie, in the range of 0 to 1000. The default is 0, which indicates all lengths.
insert: Specifies the cookie insert sticky method that inserts the Set-Cookie field to the HTTP response packets sent by the server.
rewrite: Specifies the cookie rewrite sticky method that rewrites the Set-Cookie field in the HTTP response packets sent by the server.
name cookie-name: Specifies an HTTP cookie by its name, a case-sensitive string of 1 to 63 characters. The default name is X-LB.
Use the cookie get command to obtain the HTTP cookie information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
If the sticky method is cookie rewrite, the Set-Cookie field of the specified cookie must be available in the HTTP response packets sent by the server. The system modifies only the cookie name and value in the Set-Cookie field without modifying other attributes such as Expires.
If the sticky method is cookie insert or cookie rewrite and the timeout timer for sticky entries is 0, the system adds the Expires field after the inserted or rewritten value. If the HTTP response packets sent by the server carry this attribute, the load balancing module does not modify the attribute. Instead, it adds the user-configured Expires information after the value. As a best practice, do not carry any timeout attribute in the Set-Cookie header on the server when you configure the cookie rewrite sticky method.
# Configure the cookie get sticky method for the HTTP cookie sticky group sg3: Starting from the 10th byte of start of the HTTP packet, use the 32-byte HTTP cookie named user to generate sticky entries.
[Sysname-sticky-http-cookie-sg3] cookie get name user offset 10 length 32
# Configure the cookie insert sticky method for the HTTP cookie sticky group sg3.
[Sysname-sticky-http-cookie-sg3] cookie insert
cookie secondary name
Use cookie secondary name to specify the name of the secondary cookie to be searched in the URI.
Use undo cookie secondary name to restore the default.
cookie secondary name value
The name of the secondary cookie to be searched in the URI is not specified.
value: Specifies the name of the secondary cookie, a case-sensitive token string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
This command applies only to the cookie get sticky method. Executing this command enables the system to locate the secondary cookie in the URI when it fails to locate the specified cookie in the HTTP request packet header.
# Specify the name of the secondary cookie to be searched in the URI as sid for the HTTP cookie sticky group sg3.
[Sysname-sticky-http-cookie-sg3] cookie secondary name sid
cost
Use cost to set the link cost for proximity calculation.
Use undo cost to restore the default.
cost cost-value
The link cost for proximity calculation is 0.
Link view
cost-value: Specifies the link cost for proximity calculation, in the range of 0 to 10240.
# Set the link cost for proximity calculation to 200 for the link lk1.
[Sysname-lb-link-lk1] cost 200
cost weight
Use cost weight to set the cost weight for proximity calculation.
Use undo cost weight to restore the default.
cost weight cost-weight
The cost weight for proximity calculation is 100.
Proximity view
cost-weight: Specifies the cost weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher cost weight.
# Set the cost weight for proximity calculation to 200.
[Sysname-lb-proximity] cost weight 200
default dns-server-pool
Use default dns-server-pool to specify the default (primary) DNS server pool for a transparent DNS proxy.
Use undo default dns-server-pool to restore the default.
default dns-server-pool pool-name [ sticky sticky-name ]
No default DNS server pool is specified for a transparent DNS proxy.
pool-name: Specifies a primary DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
sticky sticky-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a sticky group, the DNS server pool does not correspond to any sticky group.
If you execute the default dns-server-pool command multiple times, the most recent configuration takes effect.
# Specify the primary DNS server pool dns-pool1 and the sticky group st1 for the transparent DNS proxy dns-proxy1.
[Sysname-lb-dp-udp-dns-proxy1] default dns-server-pool dns-pool1 sticky st1
default link-group
Use default link-group to specify the default (primary) link group.
Use undo default link-group to restore the default.
default link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
No default link group is specified.
Link-IP virtual server view
link-group-name: Specifies a primary link group by its name, a case-insensitive string of 1 to 63 characters.
backup backup-link-group-name: Specifies a backup link group by its name, a case-insensitive string of 1 to 63 characters.
When the primary link group is available (contains links), the virtual server forwards packets through the primary link group. When the primary link group is not available, the virtual server forwards packets through the backup link group.
# Specify the primary link group link1, the backup link group link2, and the sticky group sg1 for the link-IP-type virtual server vs3.
[Sysname] virtual-server vs3 type link-ip
[Sysname--vs-link-ip-vs3] default link-group link1 backup link2 sticky sg1
default server-farm
Use default server-farm to specify the default (primary) server farm.
Use undo default server-farm to restore the default.
default server-farm server-farm-name [ backup backup-server-farm-name ] [ sticky sticky-name ]
No default server farm is specified.
Fast HTTP virtual server view
UDP virtual server view
server-farm-name: Specifies a primary server farm by its name, a case-insensitive string of 1 to 63 characters.
backup backup-server-farm-name: Specifies a backup server farm by its name, a case-insensitive string of 1 to 63 characters.
When the primary server farm is available (contains real servers), the virtual server forwards packets through the primary server farm. When the primary server farm is not available, the virtual server forwards packets through the backup server farm.
# Specify the primary server farm sf, the backup server farm sfb, and the sticky group sg1 for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] default server-farm sf backup sfb sticky sg1
default-class action
Use default-class action to specify the default LB action.
Use undo default-class to restore the default.
default-class action action-name
undo default-class
No default LB action is specified.
LB policy view
This command sets the default LB action for packets that fail to match any LB class.
A DNS LB policy can reference DNS LB actions only; a generic LB policy can reference generic LB actions only. This rule does not apply to HTTP LB policies.
# Specify the default LB action lba1 for the generic LB policy lbp1.
[Sysname-lbp-generic-lbp1] default-class action lba1
description
Use description to configure a description.
No description is configured.
ISP view
LB action view
LB class view
LB policy view
LB connection limit policy view
Parameter profile view
Real server view
Server farm view
Sticky group view
Virtual server view
Link group view
Link view
DNS server view
Statistics node view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description LB action LBA1 for the generic LB action lba1.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] description LB action LBA1
display loadbalance action
Use display loadbalance action to display LB action information.
display loadbalance action [ name action-name ]
name action-name: Specifies an LB action by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all LB actions.
# Display information about all LB actions.
<Sysname> display loadbalance action
LB action: lba1
Description:
Type: Generic
State: Inactive
Forward type: Drop
IP ToS:
Fallback-action: Disabled
Busy-action: Force
LB action: lba2
Description:
Type: HTTP
State: Active
Forward type: Server farm
Server farm: sf (in use)
Backup server farm: sfb
Sticky: sg3
IP ToS: 20
SSL client policy:
Content rewrite:
Value:
Replacement:
Redirect relocation:
Redirect return-code: 302
Header delete:
Direction: Request
Header insert:
Value: 1234567890123456789012345678901234567890123456789012345678901234567890
Direction: Both
Header insert:
Value: dd
Direction: Request
Header rewrite:
Value: dd
Replacement: ff
Direction: Response
SSL URL rewrite:
Value: 12
Clear port: 12
SSL port: 123
LB action: lba3
Description: sina
Type: Link-generic
State: Active
Forward type: link group
Link group: lg1 (in use)
Backup link group: lg2
Sticky:
IP ToS:
Fallback-action: None
LB action: lba4
Description: xx
Type: DNS
State: Active
Forward type: DNS server pool
DNS server pool: dsp1
Sticky: st
IP ToS:
Busy-action: Force
LB action: lba5
Description:
Type: HTTP
State: Active
Forward type: Redirect
IP ToS:
Fallback-action: Continue
SSL client policy:
Content rewrite:
Value:
Replacement:
Redirect relocation: www.h3c.com
LB action: lba6
Description:
Type: HTTP
State: Active
Forward type: Response
IP ToS:
Fallback-action: Response
Raw file name: 301.raw
SSL client policy:
Content rewrite:
Value:
Replacement:
Response file:
File: index.html
URL: /index/css
Response file:
File name: subsys_intf.js
URL: /index/subsys
Response file:
File name: subsys.js
URL: /subsys.js
Response zip file:
Zip file name: subsys.zip
Working path: /
LB action |
LB action name. |
Description for the LB action. |
Type |
LB action type: · DNS. · Generic. · HTTP. · Link-generic. · RADIUS. |
State |
LB action state: · Active. · Inactive. |
Forward type |
Packet forwarding mode of the LB action: · Drop—Discards packets. · Drop(FIN-close)—Closes TCP connections by sending FIN packets (applicable to generic and HTTP LB actions). · Drop(RST-close)—Closes TCP connections by sending RST packets (applicable to generic and HTTP LB actions). · Forward—Forwards packets. · Server farm—Forwards packets through the server farm (applicable to generic, HTTP, and RADIUS LB actions). · Link group—Forwards packets through the link group (applicable to link-generic LB actions). · DNS server pool—Forwards packets through the DNS server pool (applicable to DNS LB actions). · Skip current DNS proxy (applicable to DNS LB actions). · Redirect—Redirects packets. · Response—Responds to client requests by using a file. |
Server farm |
Primary server farm name. (in use) indicates the server farm is in use. This field is displayed only when the packet forwarding mode is server farm. |
Backup server farm |
Backup server farm name. (in use) indicates the server farm is in use. This field is displayed only when the packet forwarding mode is server farm. |
Link group |
Default link group name. (in use) indicates the link group is in use. |
Backup link group |
Backup link group name. (in use) indicates the link group is in use. |
Sticky |
Sticky group name. This field is displayed only when the packet forwarding mode is server farm or DNS server pool. |
IP ToS |
ToS field value of IP packets. |
Fallback-action |
Action taken upon load balancing failure: · None—Does not take any action. · Continue—Matches the next rule. · Response—Responds to client requests by using a file. · Drop(FIN-close)—Closes TCP connections by sending FIN packets (applicable to generic and HTTP LB actions). · Drop(RST-close)—Closes TCP connections by sending RST packets (applicable to generic and HTTP LB actions). |
Busy-action |
Action taken upon busyness: · Continue—Matches the next rule. · Force—Assigns packets to links or DNS servers regardless of whether they are busy. |
SSL client policy |
SSL client policy name. This field is displayed for HTTP LB actions only. |
Content rewrite |
HTTP content rewrite configuration: · Value—Specifies the HTTP packet content to be rewritten. · Replacement—Specifies the content after rewrite. This field is displayed only for an HTTP-type LB action. |
Redirect relocation |
Redirection URL. This field is displayed only for HTTP-type LB actions. |
Redirect return-code |
Status code in the redirection packets. This field is displayed only for HTTP-type LB actions. |
Header delete |
Deletes the HTTP header. · Name—Name of the HTTP packet header. · Direction—Specifies HTTP requests, HTTP responses, or both. This field is displayed only when the header delete command is configured. |
Header insert |
Inserts the HTTP header. · Name—Name of the HTTP packet header. · Value—Content of the HTTP packet header. · Direction—Specifies HTTP requests, HTTP responses, or both. This field is displayed only when the header insert command is configured. |
Header rewrite |
Rewrites the HTTP header. · Name—Name of the HTTP packet header. · Value—Content of the HTTP packet header to be rewritten. · Replacement—Content after rewrite. · Direction—Specifies HTTP requests, HTTP responses, or both. This field is displayed only when the header rewrite command is configured. |
SSL URL rewrite |
Rewrites the URL in the Location header of HTTP response packets sent by the server. · Value—Regular expression for the location header URL. · Clear port—HTTP port number to be rewritten. · SSL port—SSL port number after rewrite. This field is displayed only when the ssl url rewrite command is configured. |
DNS server pool |
DNS server pool name. This field is displayed only when the packet forwarding mode is DNS server pool. |
Response file |
Responds to client requests by using an uncompressed file. |
File name |
Name of the uncompressed file. |
URL |
URL path used to match client requests. |
Response zip file |
Responds to client requests by using a compressed file. |
Zip file name |
Name of the compressed file. |
Working path |
Working path used to match client requests. |
Raw file name |
Response file used upon load balancing failure. |
display loadbalance alg
Use display loadbalance alg to display the ALG status for all protocols.
# Display the ALG status for all protocols.
<Sysname> display loadbalance alg
LB ALG:
DNS : Enable
FTP : Enable
H323 : Disabled
ICMP-ERROR : Enable
ILS : Disabled
MGCP : Disabled
NBT : Disabled
PPTP : Enable
RSH : Disabled
RTSP : Enable
SCCP : Disabled
SIP : Disabled
SQLNET : Disabled
TFTP : Disabled
XDMCP : Disabled
display loadbalance class
Use display loadbalance class to display LB class information.
display loadbalance class [ name class-name ]
name class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all LB classes.
# Display information about all LB classes.
<Sysname> display loadbalance class
LB class: lbc1
Description:
Type: HTTP
Match type: Match-all
Match rule:
match 1 source ip address 1.2.3.0 24
match 2 source ipv6 address 1::2
match 3 cookie abc value 123
match 4 header def value 12
match 5 method ext xde
match 6 method rfc CONNECT
match 7 class cla2
match 8 url 2q3
match 9 acl ipv4 number 2000
match 10 acl ipv6 number 2001
match 11 acl ipv4 name aaa
match 12 acl ipv6 name bbb
match 13 isp name isp1
LB class: lbc2
Description:
Type: Generic
Match type: Match-any
Match rule:
match 1 class cla2
match 2 source ip address 1.2.23.0 24
match 3 source ipv6 address 1::12
match 4 acl ipv4 number 3000
match 5 acl ipv6 number 3001
match 6 acl ipv4 name ccc
match 7 acl ipv6 name ddd
match 8 isp name isp2
match 9 payload orcl
LB class: lbc3
Description:
Type: Link-generic
Match rule:
match 1 class cla3
match 2 source ip address 1.2.3.0 24
match 4 acl ipv4 number 3002
match 5 acl ipv6 number 3003
match 9 user u1
match 10 user-group lb-group
match 11 interface GE1/0
LB class: lbc4
Description:
Type: DNS
Match rule:
match 1 class cla2
match 8 destination ip address 1.2.3.0 24
match 9 destination ipv6 address 1::12
match 10 domain-name www.h3c.com
LB class |
LB class name. |
Description for the LB class. |
Type |
LB class type: · DNS. · Generic. · HTTP. · Link-generic. · RADIUS. |
Match type |
Match type for the LB class: · Match-all—Requires matching all rules of the LB class. · Match-any—Requires matching any rule of the LB class. |
Match rule |
Match rules for the LB class. |
Use display loadbalance connections to display information about Layer 7 LB TCP connections.
display loadbalance connections [ client-side{ ipv4 | ipv6 } [ cs-client-ip ip-address [ cs-client-port port-number ] ] [ cs-server-ip ip-address [ cs-server-port port-number ] ] ] [ server-side { ipv4 | ipv6 } [ ss-client-ip ip-address [ ss-client-port port-number ] ] [ ss-server-ip ip-address [ ss-server-port port-number ] ] ]
In IRF mode:
display loadbalance connections [ client-side{ ipv4 | ipv6 } [ cs-client-ip ip-address [ cs-client-port port-number ] ] [ cs-server-ip ip-address [ cs-server-port port-number ] ] ] [ server-side { ipv4 | ipv6 } [ ss-client-ip ip-address [ ss-client-port port-number ] ] [ ss-server-ip ip-address [ ss-server-port port-number ] ] ] [ slot slot-number ]
client-side: Displays client-side connections.
server-side: Displays server-side connections.
ipv4: Specifies IPv4 connections.
ipv6: Specifies IPv6 connections.
cs-client-ip ip-address: Specifies a client by its IP address on the client side.
cs-client-port port-number: Specifies the port number of the client on the client side, in the range of 0 to 65535. 0 means any port number.
ss-client-ip ip-address: Specifies a client by its IP address on the server side.
ss-client-port port-number: Specifies the port number of the client on the server side, in the range of 0 to 65535. 0 means any port number.
cs-server-ip ip-address: Specifies a server by its IP address on the client side.
cs-server-port port-number: Specifies the port number of the server on the client side, in the range of 0 to 65535. 0 means any port number.
ss-server-ip ip-address: Specifies a server by its IP address on the server side.
ss-server-port port-number: Specifies the port number of the server on the server side, in the range of 0 to 65535. 0 means any port number.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about Layer 7 LB TCP connections for all member devices. (In IRF mode.)
If you do not specify any parameters, this command displays information about all Layer 7 LB TCP connections.
# Display information about all Layer 7 LB TCP connections.
<Sysname> display loadbalance connections
Client side: State Server side: State
192.168.56.1 <--> 8.8.8.8/80 ESTB 192.168.56.1 <--> 2.2.2.2/80 ESTB
/50168 /1026
Any <-->Any CLOSED 192.168.56.1 <--> 2.2.2.2/80 TIMEWT
/1027
State |
TCP connection state: · LISTEN. · SYNSNT—SYN_SENT. · SYNRCV—SYN_RECEIVED. · ESTB—ESTABLISHED. · FINWT1—FIN_WAIT_1. · FINWT2—FIN_WAIT_2. · CLOWAT—CLOSE_WAIT. · CLOSING. · LASACK—LAST_ACK. · TIMEWT—TIME_WAIT. · CLOSED. For more information about these states, see RFC 793. |
display loadbalance dns-cache
Use display loadbalance dns-cache to display DNS cache information.
In standalone mode:
display loadbalance dns-cache [ domain-name domain-name ]
In IRF mode:
display loadbalance dns-cache [ domain-name domain-name ] [ slot slot-number ]
domain-name domain-name: Specifies a domain name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays DNS cache information for all domain names.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DNS cache information for all member devices. (In IRF mode.)
DNS cache information records mappings between domain names and IP addresses.
# Display all DNS cache information.
<Sysname> display loadbalance dns-cache
Slot 1:
Domain name: www.aaa.com
Aging time: 20 min
IPv4 addresses: 6.3.5.2
4.5.6.3
192.169.41.8
IPv6 addresses: 4:4:4::7
Domain name: www.bbb.com
Aging time: 20 min
IPv4 addresses: 5.5.5.5
3.4.5.9
Use display loadbalance dns-proxy to display transparent DNS proxy information.
display loadbalance dns-proxy [ brief | name dns-proxy-name ]
brief: Displays brief transparent DNS proxy information. If you do not specify this keyword, the command displays detailed transparent DNS proxy information.
name dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all transparent DNS proxies.
# Display brief information about all transparent DNS proxies.
<Sysname> display loadbalance dns-proxy brief
DNS proxy State Type VPN instance IP address Port
dns-proxy1 Active UDP 1.2.3.0/24 53
dns-proxy2 Inactive UDP -- 5353
# Display information about transparent DNS proxy dns-proxy1.
<Sysname> display loadbalance dns-proxy name dns-proxy1
DNS proxy: dns-proxy1
Type: UDP
State: Active
Service state: Enabled
VPN instance:
IPv4 address: 1.2.3.0/24
IPv6 address: --
Port: 53
DNS server pool: dns-pool1
Sticky: st
LB policy: dns-policy1
Connection synchronization: Enabled
Sticky synchronization: Enabled
Bandwidth busy protection: Disabled
DNS proxy |
Transparent DNS proxy name. |
Type |
Transparent DNS proxy type. Only UDP is supported. |
State |
Transparent DNS proxy state: · Active—The transparent DNS proxy is available. · Inactive—The transparent DNS proxy is unavailable for any reason except that the transparent DNS proxy feature is disabled. · Inactive (disabled)—The transparent DNS proxy is unavailable because the transparent DNS proxy feature is disabled. |
Service state |
Transparent DNS proxy state: Enabled or Disabled. |
DNS server pool |
Default DNS server pool used by the transparent DNS proxy. |
Sticky |
Sticky group used by the transparent DNS proxy. |
Connection synchronization |
Session extension information synchronization state: Enabled or Disabled. |
Sticky synchronization |
Sticky entry synchronization state: Enabled or Disabled. |
Bandwidth busy protection |
Link protection state: Enabled or Disabled. |
Use display loadbalance dns-proxy statistics to display transparent DNS proxy statistics.
In standalone mode:
display loadbalance dns-proxy statistics [ name dns-proxy-name ]
In IRF mode:
display loadbalance dns-proxy statistics [ name dns-proxy-name ] [ slot slot-number ]
name dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all transparent DNS proxies.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays transparent DNS proxy statistics for all member devices. (In IRF mode.)
# Display statistics for the transparent DNS proxy dns-proxy1.
<Sysname> display loadbalance dns-proxy statistics name dns-proxy1
Received requests: 100
Dropped requests: 2
Received responses: 98
Dropped responses: 0
Table 5 Command output
DNS proxy |
Received requests |
Number of DNS requests received by the transparent DNS proxy. |
Dropped requests |
Number of DNS requests dropped by the transparent DNS proxy. |
Received responses |
Number of DNS responses received by the transparent DNS proxy. |
Dropped responses |
Number of DNS responses dropped by the transparent DNS proxy. |
Use display loadbalance dns-server to display DNS server information or DNS server pool member information.
display loadbalance dns-server [ brief | name dns-server-name ]
display loadbalance dns-server dns-server-pool dns-server-pool-name [ name dns-server-name port port-number ]
brief: Displays brief DNS server information. If you do not specify this keyword, the command displays detailed DNS server information.
name dns-server-name: Displays detailed information about a DNS server. The dns-server-name argument specifies a DNS server by its name, a case-insensitive string of 1 to 63 characters.
dns-server-pool dns-server-pool-name: Displays information about members of a DNS server pool. The dns-server-pool-name argument specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
dns-server dns-server-name port port-number: Displays information about a DNS server pool member. The dns-server-name argument specifies a DNS server pool member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the DNS server pool member, in the range of 0 to 65535. If you do not specify this option, the command displays information about all members of a DNS server pool.
If you do not specify any parameter, the command displays detailed information about all DNS servers.
If no health monitoring method is specified, the device determines that all obtained DNS server IP addresses are available. If a health monitoring method is specified, the device determines that only the DNS server IP addresses that pass health monitoring are available.
# Display brief information about all DNS servers.
<Sysname> display loadbalance dns-server brief
(*) – Auto-alloc address using
DNS server Address Port Link State DNS server pool
ds1 10.150.100.100(*) 0 link1 Active dns_pool
ds2 20.150.100.100 5353 link2 Probe-failed dns_pool
ds3 -- 0 link3 Inactive dns_pool
ds4 --(*) 0 link3 Inactive dns_pool
# Display detailed information about DNS server ds1.
<Sysname> display loadbalance dns-server name ds1
dns-server: ds1
Description:
State: Active
Auto-alloc address: Enabled
IPv4 address: 10.150.100.100(*)
10.160.100.1
10.154.60.2
IPv6 address: --
Port: 0 (port number in original packet)
Link: link1
Weight: 100
Priority: 4
Probe information:
Probe success criteria: All
Probe method State
t4 Succeeded
# Display information about all members of DNS server pool dsp1.
<Sysname> display loadbalance dns-server dns-server-pool dsp1
dns-server: ds1
Description: DNS server 1
Parent state: Inactive
State: Inactive
Weight: 2
Priority: 2
Probe method State
icmp Failed
dns-server: rs2
Description: DNS server 2
State: Inactive
Port: 53
Weight: 100
Priority: 4
Probe information:
Probe method State
DNS Failed
Table 6 Command output
DNS server |
DNS server name. |
Address |
IP address of the DNS server. The asterisk (*) indicates that the IP address is automatically obtained and is being used. If all obtained IP addresses are unavailable, this field displays --(*). If no IP address is obtained and no IP address is manually configured, this field displays two hyphens (--). |
Link |
Link of the DNS server. |
Parent state/State |
DNS server state/DNS server pool member state: · Active—The DNS server is available. · Busy—The DNS server is busy. When the DNS server is in Active state and enabled with the link protection feature, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The DNS server is unavailable, because the configuration is not complete or the server is not referenced. · Probe-failed—Health monitoring has failed. · Unknown—Health monitoring is not configured. |
Description for the DNS server. |
Auto-alloc address |
Whether the device is enabled to automatically obtain the IP address of a DNS server: Disabled or Enabled. |
IPv4 address |
IPv4 address of the DNS server. |
IPv6 address |
IPv6 address of the DNS server. |
Port |
Port number of the DNS server. 0 means the port number in the packet is used. |
Weight |
Weight of the DNS server. |
Priority |
Priority of the DNS server. |
Probe information |
Detailed health monitoring information for the DNS server. |
Probe success criteria |
Health monitoring success criteria for the DNS server: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least—Health monitoring succeeds when a specified minimum number of health monitoring methods succeed. |
Probe method |
Name of the NQA template used by the health monitoring method. |
State |
State of the health monitoring method: · Failed—Health monitoring has failed. · In progress—Health monitoring is in progress. · Invalid—Health monitoring is unavailable (because the configuration of the NQA template is not complete), or the DNS server is unavailable. · Succeeded—Health monitoring has succeeded. |
display loadbalance dns-server statistics
Use display loadbalance dns-server statistics to display DNS server statistics or DNS server pool member statistics.
In standalone mode:
display loadbalance dns-server statistics [ name dns-server-name ]
display loadbalance dns-server statistics dns-server-pool dns-server-pool-name [ name dns-server-name port port-number ]
In IRF mode:
display loadbalance dns-server statistics [ name dns-server-name ] [ slot slot-number ]
display loadbalance dns-server statistics dns-server-pool dns-server-pool-name [ name dns-server-name port port-number ] [ slot slot-number ]
name dns-server-name: Specifies a DNS server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all DNS servers.
dns-server-pool dns-server-pool-name: Displays statistics for members of a DNS server pool. The dns-server-pool-name argument specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
dns-server dns-server-name port port-number: Displays statistics for a DNS server pool member. The dns-server-name argument specifies a DNS server pool member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the DNS server pool member, in the range of 0 to 65535. If you do not specify this option, the command displays statistics for all members of a DNS server pool.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DNS server statistics for all member devices. (In IRF mode.)
# Display statistics for the DNS server ds1.
<Sysname> display loadbalance dns-server statistics name ds1
DNS server: ds1
Send requests: 98
Dropped requests: 2
Send responses: 98
# Display statistics for all members of DNS server pool dsp1.
<Sysname> display loadbalance dns-server statistics dns-server-pool dsp1
DNS server (port: 20): ds1
Dropped requests: 2
Sent responses: 98
DNS server (port: 28): ds2
Dropped requests: 0
Sent responses: 100
Table 7 Command output
DNS server |
DNS server name. |
Received requests |
Number of DNS requests received by the DNS server. |
Send requests |
Number of DNS requests sent by the DNS server. |
Dropped requests |
Number of DNS requests dropped by the DNS server. |
Number of DNS responses received by the DNS server. |
Send responses |
Number of DNS responses sent by the DNS server. |
Dropped responses |
Number of DNS responses dropped by the DNS server. |
display loadbalance dns-server-pool
Use display loadbalance dns-server-pool to display DNS server pool information.
display loadbalance dns-server-pool [ brief | name pool-name ]
brief: Displays brief DNS server pool information. If you do not specify this keyword, the command displays detailed DNS server pool information.
name pool-name: Displays detailed information about a DNS server pool. The pool-name argument specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify any parameter, the command displays detailed information about all DNS server pools.
# Display brief information about all DNS server pools.
<Sysname> display loadbalance dns-server-pool brief
Predictor: RR - Round robin, RD - Random,
BW - Bandwidth, MBW - Max bandwidth,
IBW - Inbound bandwidth, OBW - Outbound bandwidth,
MIBW - Max inbound bandwidth, MOBW - Max outbound bandwidth,
HASH(SIP) - Hash address source IP,
HASH(DIP) - Hash address destination IP,
HASH(SIP-PORT) - Hash address source IP-port
DNS server pool Predictor Total Active
dns-pool RR 3 2
dns-pool1 RR 0 0
dns-pool2 RD 3 0
# Display detailed information about DNS server pool dns-pool.
<Sysname> display loadbalance dns-server-pool name dns-pool
Description:
Predictor: Round robin
Selected server: Enabled
Min servers: 3
Max servers: 5
Probe information:
Probe success criteria: At-least 2
Probe method: t4
Total DNS servers: 3
Active DNS servers: 0
DNS server list:
Name State Address port Link Weight Priority
ds1 Active 10.150.100.100 0 link1 100 4
ds2 Probe-failed 20.150.100.100 5353 link2 100 4
ds3 Inactive -- 0 link3 100 4
Table 8 Command output
Predictor |
Scheduling algorithm of the DNS server pool: · RR—Weighted round robin algorithm. · RD—Random algorithm. · BW—Bandwidth algorithm. · IBW—Inbound bandwidth algorithm. · OBW—Outbound bandwidth algorithm. · MBW—Maximum bandwidth algorithm. · MIBW—Maximum inbound bandwidth algorithm. · MOBW—Maximum outbound bandwidth algorithm. · HASH(SIP)—Hash algorithm based on source IP address. · HASH(DIP)—Hash algorithm based on destination IP address. · HASH(SIP-PORT)—Hash algorithm based on source IP address and port number. |
DNS server pool |
DNS server pool name. |
Total |
Total number of DNS servers. |
Active |
Number of active DNS servers. |
Description for the DNS server pool. |
Selected server |
State of DNS server limit to participate in scheduling: disabled or enabled. If the state is enabled, the following fields are displayed: · Min servers—Minimum number of DNS servers that can participate in scheduling. · Max servers—Maximum number of DNS servers that can participate in scheduling. |
Probe information |
Detailed health monitoring information for the DNS server pool. |
Health monitoring success criteria for the DNS server pool: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least—Health monitoring succeeds when a specified minimum number of health monitoring methods succeed. |
Probe method |
Total DNS servers |
Active DNS servers |
Name |
DNS server name. |
State |
DNS server state: · Active—The DNS server is available. · Busy—The DNS server is busy. When the DNS server is in Active or Ramp state and enabled with link protection, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The DNS server is unavailable, because the configuration is not complete or the server is not referenced. · Probe-failed—Health monitoring has failed. |
Address |
Port |
Port number of the DNS server. |
Link |
Name of the link corresponding to the DNS server. |
Weight |
Priority |
display loadbalance hot-backup statistics
Use display loadbalance hot-backup statistics to display LB hot backup statistics.
In IRF mode:
display loadbalance hot-backup statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays LB hot backup statistics for all member devices. (In IRF mode.)
# Display LB hot backup statistics.
<Sysname> display loadbalance hot-backup statistics
Slot 2:
TryAdd TryDel AckDel AckOK AckNO NotSpt
StiSnd 1 0 0 0 0 0
StiRcv 0 0 0 0 0 0
StiSndFail 0 0 0 0 0 0
StiRcvFail 0 0 0 0 0 0
MsgSnd 1 0 0 0 0 0
MsgRcv 0 0 0 0 0 0
MsgSndFail 0 0 0 0 0 0
MsgRcvFail 0 0 0 0 0 0
MAllocFail 0 0 0 0 0 0
SesBkTotal : 0
SesBkFail : 0
SesResTotal: 0
SesResFail : 0
SesUpdate : 0
Table 9 Command output
Message for adding sticky entries. |
Message for deleting sticky entries. |
Message for acknowledging the deletion of sticky entries. |
Message indicating the sticky entries that can be deleted. |
Message indicating the sticky entries that cannot be deleted. |
Message indicating the unsupported sticky entries. |
Number of sent sticky entries. |
Number of received sticky entries. |
Number of sticky entry sending failures. |
Number of sticky entry receiving failures. |
Number of sent messages. |
Number of received messages. |
Number of message sending failures. |
Number of message receiving failures. |
MAllocFail |
Number of memory application failures. |
Number of session backups. |
Number of session backup failures. |
Number of session restorations. |
Number of session restoration failures. |
Number of session updates. |
display loadbalance isp
Use display loadbalance isp to display ISP information.
display loadbalance isp [ ip ipv4-address | ipv6 ipv6-address | name isp-name ]
ip ipv4-address: Specifies an IPv4 address. If you do not specify this option, the command displays information about all ISPs.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify this option, the command displays information about all ISPs.
name isp-name: Specifies an ISP by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all ISPs.
# Display information about all ISPs.
<Sysname> display loadbalance isp
(*) - User-defined object
Last successful auto update time: 04:09:00 UTC Fri 03/16/2012
Last auto update time: 04:09:00 UTC Fri 03/16/2012
Last auto update result: Successful
ISP update count: 1
LB ISP: isp1
Whois maintainer object name:
MAINT-CHINANET
Description: ISP1
IPv4 address/Mask length: --
IPv6 address/Prefix length: --
LB ISP: isp2(*)
Description:
1.2.3.0/32(*) 1.2.3.4/32 3.3.3.6/32(*)
192.168.6.131/32(*) 192.168.195.189/32(*)
1::2/128
FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF/128(*)
# Display information about the ISP corresponding to the IP address 1.2.3.0.
<Sysname> display loadbalance isp ip 1.2.3.0
ISP name Source IPv4 address/Mask length
isp2 user-set 1.2.3.0/28
isp2 user-set 1.2.3.0/29
isp2 user-set 1.2.3.0/30
isp2 file-load 1.2.3.0/31
auto-update
isp2 user-set 1.2.3.0/32
file-load
# Display information about the ISP corresponding to the IPv6 address 1::1234.
<Sysname> display loadbalance isp ipv6 1::1234
ISP name Source IPv6 address/Prefix length
isp2 user-set 1::1234/126
isp2 user-set 1::1234/127
isp2 file-load 1::1234/128
Table 10 Command output
(*) indicates that the ISP information is manually configured. If the ISP information is also imported from a file, (*) is not displayed. |
Last successful auto update time |
Time of the most recent successful update. |
Last auto update time |
Time of the most recent update. |
Last auto update result |
Result of the most recent auto update: · Successful. · Failed to connect to WHOIS server. · Connection failed. · Failed to query DNS (which means failed to send DNS requests). |
ISP update count |
Number of ISPs in the most recent update. |
ISP name. |
Description for the ISP. |
Source of the ISP: · user-set—Manually configured. · file-load—Imported from a file. · auto-update—ISP auto update. |
display loadbalance limit-policy
Use display loadbalance limit-policy to display LB connection limit policy information.
display loadbalance limit-policy [ name policy-name ]
policy-name: Specifies an LB connection limit policy by its name, a case-insensitive string of 1 to 63 characters.
# Display information about the LB connection limit policy lptest.
<Sysname> display loadbalance limit-policy name lptest
Limit-policy: lptest
Description:
Limit rule:
limit lptest acl 3000 amount 10 10
display loadbalance link
Use display loadbalance link to display LB link information or link group member information.
display loadbalance link [ brief | name link-name ]
display loadbalance link link-group link-group-name [ name link-name ]
brief: Displays brief information about all LB links. If you do not specify this keyword, the command displays detailed LB link information.
name link-name: Displays detailed information about the specified LB link. The link-name argument specifies an LB link name, a case-insensitive string of 1 to 63 characters.
link-group link-group-name: Displays information about members of a link group. The link-group-name argument specifies a link group by its name, a case-insensitive string of 1 to 63 characters.
name link-name: Displays information about a link group member. The link-name argument specifies a link group member by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all members of a link group.
If you do not specify the brief keyword or the name link-name option, the command displays detailed information about all LB links.
# Display brief information about all LB links.
<Sysname> display loadbalance link brief
Link Router IP/Interface State VPN instance Link group
Lk1 192.168.1.1 Busy vpn1 lg
Lk2 192.168.2.1 Active vpn1 lg
Lk3 Dialer0 Inactive vpn1 lg
# Display detailed information about the LB link lk.
<Sysname> display loadbalance link name lk
Link: lk
Description: lk
State: Busy
VPN instance: vpn1 (Inherit)
Inherit VPN: Enabled
Router IP: 1.2.3.4
Router IPv6: --
Link-group: lg
Weight: 100
Priority: 4
Cost: 0
Slow-shutdown: Disabled
Connection limit: 0
Rate limit:
Connections: 10000
Bandwidth: 10000 Kbytes/s
Inbound bandwidth: 5000 Kbytes/s
Outbound bandwidth: 5000 Kbytes/s
Bandwidth busy:
Max bandwidth: 10000 Kbytes/s
Max inbound bandwidth: 5000 Kbytes/s
Max outbound bandwidth: 5000 Kbytes/s
Busy rate: 80
Inbound busy rate: 70
Outbound busy rate: 60
Busy recovery rate: 60
Inbound busy recovery rate: 60
Outbound busy recovery rate: 60
Probe information:
Probe method State
t4 Inactive
Link: lk2
Description: link2
State: Inactive
VPN instance: vpn2 (Config)
Inherit VPN: Disabled
IPv4 address state: Active
IPv6 address state: Inactive
Router interface: Dialer0
Link group: lg
Weight: 150
Priority: 3
Cost: 100
Slow shutdown: Enabled
Connection limit: 10000
Rate limit:
Connections: 10000
Bandwidth busy:
Busy rate: 80
Probe information:
Probe method State
t4 Inactive
# Display information about all members of link group lg.
<Sysname> display loadbalance link link-group lg
Link group: lg
Link: lk1
Description: link 1
State: Inactive
Weight: 2
Priority: 2
Slow shutdown: Disabled
Connection limit: --
Connection rate limit: --
Probe information:
Probe method State
icmp Failed
Link: lk2
Description: link 2
State: Inactive
Weight: 100
Priority: 4
Probe information:
Probe method State
tcp Failed
Table 11 Command output
Link |
LB link name. |
Router IP/Interface |
Gateway IP address or outgoing interface of the LB link. |
LB link state/Link group member state: · Active—The LB link is available. · Busy—The LB link is busy. · Inactive—The LB link is unavailable, because the configuration is not complete, the LB link is not referenced, or the virtual server is not enabled. · Probe-failed—Health monitoring has failed. · Ramp—Ramp-up phase of slow online. · Shutdown—The LB link is shut down. · Standby—Standby phase of slow online. · Unknown—Health monitoring is not configured. |
VPN instance |
VPN instance of the LB link. · Config—Manually configured. · Inherit—Inherited. |
Link group |
Link group to which the LB link belongs. |
Description for the LB link. |
Inherit VPN |
State of VPN instance inheritance: Enabled or Disabled. |
IPv4 address state |
IPv4 address state of the LB link: · Active—An available IPv4 address is obtained through the outgoing interface of the LB link. · Inactive—No available IPv4 address is obtained through the outgoing interface of the LB link. This field is displayed only if an outgoing interface is specified for an LB link. |
IPv6 address state |
IPv6 address state of the link: · Active—An available IPv6 address is obtained through the outgoing interface of the LB link. · Inactive—No available IPv6 address is obtained through the outgoing interface of the LB link. This field is displayed only if an outgoing interface is specified for an LB link. |
Weight |
Weight of the LB link. |
Priority |
Priority of the LB link. |
Cost |
Cost for proximity calculation. |
Slow shutdown |
Slow offline state of the LB link: · Disabled. · Enabled. |
Connection limit |
Maximum number of connections for the LB link. |
Connection rate limit |
Maximum number of connections per second for the LB link. |
Rate limit |
Rate limit of the LB link. |
Connections |
Bandwidth |
Maximum bandwidth for the LB link in KBps. |
Inbound bandwidth |
Maximum inbound bandwidth for the LB link in KBps. |
Outbound bandwidth |
Maximum outbound bandwidth for the LB link in KBps. |
Bandwidth busy |
Bandwidth ratio. |
Max bandwidth |
Maximum expected bandwidth for the LB link in KBps. |
Max inbound bandwidth |
Maximum inbound expected bandwidth for the LB link in KBps. |
Max outbound bandwidth |
Maximum outbound expected bandwidth for the LB link in KBps. |
Busy rate |
Bandwidth ratio for the LB link. |
Inbound busy rate |
Inbound bandwidth ratio for the LB link. |
Outbound busy rate |
Outbound bandwidth ratio for the LB link. |
Busy recovery rate |
Bandwidth recovery ratio for the LB link. |
Inbound busy recovery rate |
Inbound bandwidth recovery ratio for the LB link. |
Outbound busy recovery rate |
Outbound bandwidth recovery ratio for the LB link. |
Probe information |
Detailed health monitoring information for the LB link. |
Health monitoring success criteria for the LB link: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least—Health monitoring succeeds when a specified minimum number of health monitoring methods succeed. |
Probe method |
State |
State of the health monitoring method: · Failed—Health monitoring has failed. · In progress—Health monitoring is in progress. · Invalid—Health monitoring is unavailable (because the configuration of the NQA template is not complete), or the real server is unavailable. · Succeeded—Health monitoring has succeeded. |
display loadbalance link out-interface statistics
Use display loadbalance link out-interface statistics to display link outbound interface statistics.
display loadbalance link out-interface statistics [ name link-name ]
name link-name: Specifies a link by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays outbound interface statistics for all links.
If the link outbound interface is a logical interface, the rate statistics are calculated based on the interface traffic.
# Display outbound interface statistics for the link lk1.
<Sysname> display loadbalance link out-interface statistics name lk1
Loadbalance link: lk1
Input rate: 1524 bytes/s
Output rate: 90 bytes/s
Loadbalance link |
LB link name. |
Input rate |
Input rate of the outbound interface in Bps. |
Output rate |
Output rate of the outbound interface in Bps. |
display loadbalance link statistics
Use display loadbalance link statistics to display link statistics or link group member statistics.
In standalone mode:
display loadbalance link statistics [ name link-name ]
display loadbalance link statistics link-group link-group-name [ name link-name ]
In IRF mode:
display loadbalance link statistics [ name link-name ] [ slot slot-number ]
display loadbalance link statistics link-group link-group-name [ name link-name ] [ slot slot-number ]
link-group link-group-name: Displays statistics for members of a link group. The link-group-name argument specifies a link group by its name, a case-insensitive string of 1 to 63 characters.
name link-name: Displays statistics for a link group member. The link-name argument specifies a link group member by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all members of a link group.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays link statistics for all member devices. (In IRF mode.)
# Display statistics for the link lk1.
<Sysname> display loadbalance link statistics name lk1
Total connections: 1798
Active connections: 788
Max connections: 803
Connections per second: 157
Max connections per second: 163
Downstream traffic: 333332 bytes
Upstream traffic: 472054 bytes
Throughput: 4396 bytes/s
Inbound throughput: 1214 bytes/s
Outbound throughput: 3128 bytes/s
Max throughput: 4564 bytes/s
Max inbound throughput: 1214 bytes/s
Max outbound throughput: 3320 bytes/s
Received packets: 1798
Sent packets: 0
Dropped packets: 0
# Display statistics for all members of link group lg.
<Sysname> display loadbalance link statistics link-group lg
Loadbalance link group: lg
Total connections: 0
Active connections: 0
Max connections: 0
Connections per second: 0
Max connections per second: 0
Downstream traffic: 0 bytes
Upstream traffic: 0 bytes
Throughput: 0 bytes/s
Inbound throughput: 0 bytes/s
Outbound throughput: 0 bytes/s
Max throughput: 0 bytes/s
Max inbound throughput: 0 bytes/s
Max outbound throughput: 0 bytes/s
Received packets: 0
Sent packets: 0
Dropped packets: 0
Loadbalance link: lk2
Max connections: 0
Received packets: 0
Sent packets: 0
Dropped packets: 0
Table 12 Command output
Loadbalance link |
Link name. |
Total connections |
Total number of connections. |
Active connections |
Number of active connections. |
Max connections |
Maximum number of connections. |
Connections per second |
Number of connections per second. |
Max connections per second |
Maximum number of connections per second. |
Downstream traffic |
Downstream traffic (in bytes) received by the LB device. |
Upstream traffic |
Upstream traffic (in bytes) sent by the LB device. |
Throughput |
Total packet throughput in Bps. |
Inbound throughput |
Inbound packet throughput in Bps. |
Outbound throughput |
Outbound packet throughput in Bps. |
Max throughput |
Maximum packet throughput in Bps. |
Max inbound throughput |
Maximum inbound packet throughput in Bps. |
Max outbound throughput |
Maximum outbound packet throughput in Bps. |
Received packets |
Number of received packets. |
Sent packets |
Number of sent packets. |
Dropped packets |
Number of dropped packets. |
display loadbalance link-group
Use display loadbalance link-group to display link group information.
display loadbalance link-group [ brief | name link-group-name ]
brief: Displays brief information about all link groups. If you do not specify this keyword, the command displays detailed link group information.
name link-group-name: Specifies a link group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all link groups.
If you do not specify any parameters, the command displays detailed information about all link groups.
A link is displayed as unavailable if the link group configuration is not complete, the link group is not referenced, or the virtual server is not enabled. This does not mean that the link is not available.
# Display brief information about all link groups.
<Sysname> display loadbalance link-group brief
Predictor: RR - Round robin, RD - Random, LC - Least connection,
BW – Bandwidth, MBW – Max bandwidth,
IBW – Inbound bandwidth, OBW – Outbound bandwidth,
MIBW – Max inbound bandwidth, MOBW – Max outbound bandwidth,
NAT/SNAT: Y - Enabled, N - Disabled
Link group Predictor NAT SNAT Total Active
lg RR Y N 3 3
# Display detailed information about all link groups.
Link group: lg1
Description:
Predictor: Hash address
Proximity: Disabled
NAT: Enabled
SNAT pool:
Failed action: Keep
Active threshold: Enabled
Lower: 80
Upper: 90
Slow-online: Enabled
Standby time: 5s
Ramp-up time: 10s
Selected link: Enabled
Min link: 100
Max link: 600
Probe information:
Probe method:
aaa
ddd
Total link: 1
Active link: 1
Link list:
Name State VPN instance Router IP Weight Priority
Link1 Inactive vpn1 1.2.3.4 4 100
Table 13 Command output
Link group |
Link group name. |
Description for the link group. |
Predictor |
Scheduling algorithm of the link group: · RR—Weighted round robin algorithm. · RD—Random algorithm. · LC—Weighted least connection algorithm. · BW—Bandwidth algorithm. · IBW—Inbound bandwidth algorithm. · OBW—Outbound bandwidth algorithm. · MBW—Maximum bandwidth algorithm. · MIBW—Maximum inbound bandwidth algorithm. · MOBW—Maximum outbound bandwidth algorithm. · HASH(SIP)—Hash algorithm based on source IP address. · HASH(DIP)—Hash algorithm based on destination IP address. · HASH(SIP-PORT)—Hash algorithm based on source IP address and port number. |
Proximity |
Proximity state of the link group: · Disabled. · Enabled. |
NAT |
NAT state of the link group: · Disabled. · Enabled. |
SNAT pool |
Name of the SNAT address pool referenced by the link group. |
Failed action |
Fault processing method of the link group: · Keep—Keeps existing connections. · Reschedule—Redirects connections. · Reset—Terminates existing connections. |
Active threshold |
State of the criteria to determine that the link group is available: disabled or enabled. If the state is enabled, the following fields are displayed: · Lower—Lower percentage value. · Upper—Upper percentage value. |
Slow-online |
State of the slow online feature: disabled or enabled. If the state is enabled, the following fields are displayed: · Standby time. · Ramp-up time. |
Selected link |
State of link limit to participate in scheduling: disabled or enabled. If the state is enabled, the following fields are displayed: · Min server—Minimum number of links that participate in scheduling. · Max server—Maximum number of links that participate in scheduling. |
Health monitoring success criteria for the link group: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least X—Health monitoring succeeds when a minimum of X health monitoring methods succeed. |
Probe method |
Total link |
Total number of links. |
Active link |
Number of active links. |
Name |
Link name. |
State |
Link state: · Active—The link is available. · Busy—The link is busy. When the link is in Active or Ramp state and enabled with bandwidth statistics collection and link protection, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The link is unavailable, because the configuration is not complete, the link is not referenced, or the virtual server is not enabled. · Probe-failed—Health monitoring has failed. · Ramp—Ramp-up phase of slow online. · Shutdown—The link is shut down. · Standby—Standby phase of slow online. |
VPN instance |
VPN instance of the link. |
Router IP |
IPv4 and IPv6 addresses of the link. |
Weight |
Weight of the link. |
Priority |
Priority of the link. |
display loadbalance policy
Use display loadbalance policy to display LB policy information.
display loadbalance policy [ name policy-name ]
name policy-name: Specifies an LB policy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all LB policies.
# Display information about all LB policies.
<Sysname> display loadbalance policy
LB policy: lbp1
Description:
Type: Generic
Class: lbc1
Action: lba1
Default class action: lba0
LB policy: lbp2
Description:
Type: HTTP
LB policy: lbp3
Description:
Type: Link-generic
Class: lbc3
Action: lba3
Default class action: lba3
LB policy: lbp4
Description:
Type: DNS
Class: lbc4
Action: lba4
Default class action: lba4
Table 14 Command output
LB policy |
LB policy name. |
Description for the LB policy. |
Type |
LB policy type: · DNS. · Generic. · HTTP. · Link-generic. · RADIUS. |
Class |
LB class for the LB policy. |
Action |
LB action for the LB class. |
Default class action |
Default LB action. |
display loadbalance probe-template
Use display loadbalance probe-template to display LB probe template information.
display loadbalance probe-template [ name template-name ]
name template-name: Specifies an LB probe template by its name, a case-insensitive string of 1 to 32 characters. If you do not specify this option, the command displays information about all LB probe templates.
# Display information about all LB probe templates.
<Sysname> display loadbalance probe-template
Load balancing probe template: rst1
Description:
Type: tcp-rst
Monitoring interval: 20
RST threshold: 10
Protection action: auto-shutdown
Load balancing probe template: zero2
Description:
Type: tcp-zero-window
Monitoring interval: 30
Zero-window threshold: 20
Protection action: busy
Probe interval: 30
Probe times: 3
Load balancing probe template: icmp1
Description:
Type: icmp
Timeout: 3
Frequency: 300
Table 15 Command output
Load balancing probe template |
LB probe template name. |
Description for the LB probe template. |
Type |
LB probe template type: · icmp. · tcp-rst. · tcp-zero-window. |
Monitoring interval |
Monitoring time. During the monitoring time, the system counts the number of RST packets or zero-window packets sent by each server farm member in a server farm. This field is displayed only for a TCP-RST or TCP zero-window LB probe template. |
RST threshold |
Maximum number of RST packets a real server can send. This field is displayed only for a TCP-RST LB probe template. |
Zero-window threshold |
Maximum percentage of zero-window packets a real server can send. This field is displayed only for a TCP zero-window LB probe template. |
Protection action |
Action to take when the RST or zero-window packet threshold is reached: Auto-shutdown or Busy. This field is displayed only for a TCP-RST or TCP zero-window LB probe template. |
Probe interval |
Interval to probe the real server in busy state. This field is displayed only for a TCP-RST or TCP zero-window LB probe template. |
Probe times |
Maximum number of times for probing the real server in busy state. If the number of probe times is reached, the real server is automatically shut down. This field is displayed only for a TCP-RST or TCP zero-window LB probe template. |
Timeout |
Timeout time for probe responses. This field is displayed only for an ICMP LB probe template. |
Frequency |
Probe interval for an LB probe template This field is displayed only for an ICMP LB probe template. |
reset real-server statistics
display loadbalance proximity
Use display loadbalance proximity to display proximity entry information.
In standalone mode:
display loadbalance proximity [ vpn-instance vpn-instance-name ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ]
In IRF mode:
display loadbalance proximity [ vpn-instance vpn-instance-name ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ] [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays proximity entry information for the public network.
ip [ ipv4-address ]: Displays IPv4 proximity entry information. If you specify the ipv4-address argument, this command displays detailed information about the proximity entry corresponding to the IPv4 address. If you do not specify the ipv4-address argument, this command displays brief information about all IPv4 proximity entries.
ipv6 [ ipv6-address ]: Displays IPv6 proximity entry information. If you specify the ipv6-address argument, this command displays detailed information about the proximity entry corresponding to the IPv6 address. If you do not specify the ipv6-address argument, this command displays brief information about all IPv6 proximity entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays proximity information for all member devices. (In IRF mode.)
If you do not specify the vpn-instance, ip, or ipv6 keyword, this command displays brief information about all IPv4 and IPv6 proximity entries.
# Display brief information about all IPv4 and IPv6 proximity entries for the public network.
<Sysname> display loadbalance proximity
(*) – Real server object
Slot :1
IPv4 address/Mask length Timeout Best link
1.2.3.0/24 59 lk1
1.2.15.0/24 58 lk2
IPv6 address/Prefix length Timeout Best link
11:22::/96 40 lk1
# Display detailed information about the proximity entry corresponding to the IP address 1.2.3.1 for the public network.
<Sysname> display loadbalance proximity ip 1.2.3.1
IPv4 address/Mask length: 1.2.3.0/24
Timeout: 40
Link list:
lk1
lk2
<Sysname> display loadbalance proximity vpn-instance vpn1 ipv6 11:22::
IPv6 address/Prefix length: 11:22::/96
Timeout: 34
Link list:
lk1
lk2
Table 16 Command output
Slot |
Card for which proximity entry information is displayed. |
Remaining time of the proximity entries, in seconds. |
Links for the proximity entry. They are listed in descending priority order. |
display loadbalance snat-pool
Use display loadbalance snat-pool to display SNAT address pool information.
display loadbalance snat-pool [ name pool-name ]
name pool-name: Specifies an SNAT address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all SNAT address pools.
# Display information about all SNAT address pools.
<Sysname> display loadbalance snat-pool
SNAT pool: lbsp1
Description:
IPv4 range:
Start address End address
202.110.10.10 202.110.10.15
IPv6 range:
2002::2 2002::100
ARP/ND interfaces:
GigabitEthernet1/0
GigabitEthernet1/0/3
SNAT pool: lbsp2
Description:
IPv4 range:
203.110.10.10 203.110.10.15
IPv6 range:
2003::2 2003::100
ARP/ND interfaces:
GigabitEthernet2/0
Table 17 Command output
SNAT pool |
SNAT address pool name. |
Description for the SNAT address pool. |
IPv4 range |
IPv4 address range. |
IPv6 range |
IPv6 address range. |
ARP/ND interfaces |
Interfaces from which gratuitous ARP packets and ND packets are sent out. |
display parameter-profile
Use display parameter-profile to display parameter profile information.
display parameter-profile [ name parameter-name ]
name parameter-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all parameter profiles.
# Display information about all parameter profiles.
<Sysname> display parameter-profile
Parameter profile: pp1
Description:
Type: IP
IP ToS: 20
Parameter profile: pp2
Description:
Type: TCP
Exceed MSS: Allow
TCP window size: 65535
TCP connection idle-timeout: 10
Time-wait timeout: 5
Keepalive idle-timeout: 300
Keepalive retransmission interval: 3
Keepalive retransmission count: 5
SYN retransmission-timeout: 5
Fin-wait1 timeout: 6
Fin-wait2 timeout: 10
Parameter profile: pp3
Description:
Type: HTTP
Rebalance per request: Enabled
Server connection reuse: Enabled
Case insensitive: Enabled
Header modify per request: Enabled
Content maximum parse length: 8192
Header maximum parse length: 8192
Secondary cookie delimiters: !@#$
Secondary cookie start: ?
Header exceed length: Drop
Parameter profile: compress
Description:
Type: HTTP compression
Compression level: 1
Prefer method: Gzip
Content length threshold: 1024
Memory size: 8KB
Window size: 16KB
Header Insert: Enabled
Header Delete: Enabled
Request version all: Disabled
Rule 1: Permit url abc
Parameter profile: urlstat
Description:
Type: HTTP-statistics
Node: bank1
Description:
rule 1 url url1
rule 2 url url2
Node: bank2
Description:
rule 1 url url3
rule 2 url url4
Object group name:
ObjGrp1
ObjGrp2
Parameter profile: pp4
Description:
Type: OneConnect
Max reuse times: 1000
Idle time: 10000
IPv4 source mask length: 24
IPv6 source prefix length: 120
Parameter profile: pp5
Description:
Type: TCP-application
Match-buffer-time: 5
Match-buffer-size: 4096
Match-buffer-end: YY
Table 18 Command output
Parameter profile |
Parameter profile name. |
Description for the parameter profile. |
Type |
Parameter profile type: · IP. · HTTP. · HTTP-compression. · HTTP statistics. · OneConnect. · TCP. · TCP-application. |
IP ToS |
ToS field of the IP packets sent to the server. |
Exceed MSS |
Action to take on the segments that exceed the MSS in the HTTP requests sent by the client: · Allow—Allows the segments to exceed the MSS. · Drop—Discards the segments that exceed the MSS. |
Rebalance per request |
Whether or not to enable load balancing for each HTTP request. |
Server connection reuse |
Whether or not to reuse the connection between the LB device and the server. |
Header modify per request |
Whether or not to perform the insert, delete, or modify operation for the header of each HTTP request or response packet. |
Case insensitive |
Whether or not to enable case sensitivity for matching character strings. |
Content maximum parse length |
Maximum length of the HTTP entities that can be parsed. |
Header maximum parse length |
Maximum length of the HTTP headers that can be parsed. |
Secondary cookie delimiters |
Delimiters that can separate secondary cookies in URLs. |
Secondary cookie start |
Start delimiter for secondary cookies in URLs. |
Header exceed length |
Action to take on the HTTP requests or responses when their packet headers exceed the maximum length: · Continue—Continues to perform load balancing. · Drop—Stops performing load balancing, discards the packet, and terminates the connection. |
TCP window size |
Maximum local window size for TCP connections. |
TCP connection idle-timeout |
Idle timeout time for TCP connections, in seconds. |
Time-wait timeout |
TIME_WAIT state timeout time for TCP connections, in seconds. |
Keepalive idle-timeout |
Idle timeout time for sending TCP keepalive packets. |
Keepalive retransmission interval |
Retransmission interval for TCP keepalive packets. |
Keepalive retransmission count |
Retransmission times for TCP keepalive packets. |
SYN retransmission-timeout |
Retransmission timeout time for TCP SYN packets |
Fin-wait1 timeout |
FIN-WAIT-1 state timeout time for TCP connections. |
Fin-wait2 timeout |
FIN-WAIT-2 state timeout time for TCP connections. |
Node |
Statistics node name and all URL match rules configured for the statistics node. |
Object group name |
IP address object groups used by the HTTP statistics parameter profile. |
Max reuse times |
Maximum number of times a TCP connection can be reused. |
Idle time |
IPv4 source mask length |
Mask length for connection reuse. |
IPv6 source prefix length |
Prefix length for connection reuse. |
Match-buffer-time |
Buffering period for TCP payload matching, in seconds. |
Match-buffer-size |
Maximum buffering size for TCP payload matching. |
Match-buffer-end |
Buffering end string for TCP payload matching. |
display real-server
Use display real-server to display real server information or server farm member information.
display real-server [ brief | name real-server-name ]
display real-server server-farm server-farm-name [ name real-server-name port port-number ]
brief: Displays brief real server information. If you do not specify this keyword, the command displays detailed real server information.
name real-server-name: Displays information about the specified real server. The real-server-name argument specifies a real server name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all real servers.
server-farm server-farm-name: Displays information about members of a server farm. The server-farm-name argument specifies a server farm by its name, a case-insensitive string of 1 to 63 characters.
name real-server-name port port-number: Displays information about a server farm member. The real-server-name argument specifies a server farm member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the server farm member, in the range of 0 to 65535. If you do not specify this option, the command displays information about all members of a server farm.
# Display brief information about all real servers.
<Sysname> display real-server brief
Real server Address Port State VPN instance Server farm
rs1 192.168.1.1 0 Active vpn1 sf
rs2 192.168.1.2 0 Busy sf
rs3 192.168.1.3 0 Active sf
# Display detailed information about the real server rs.
<Sysname> display real-server name rs
Real server: rs
Description: Real server RS
State: Active
VPN instance:
Inherit VPN: Enable
IPv4 address: 1.1.1.1
IPv6 address: 1001::1
Server farm: sf
Weight: 150
Priority: 3
Cost: 100
Rate limit:
Connections: 10000
Bandwidth busy:
Busy rate: 80
Probe information:
Dynamic weight: 1
SNMPDCA busy state: Normal
Probe method State
t4 Succeeded
# Display information about all members of server farm sf.
<Sysname> display real-server server-farm sf
Server farm: sf
Real server: rs1
Description: real server 1
State: Inactive
Port: 2
Weight: 2
Priority: 2
Probe information:
Probe method State
icmp Failed
Real server: rs2
Description: real server 2
State: Inactive
Port: 80
Weight: 100
Priority: 4
Probe information:
Probe method State
tcp Failed
Table 19 Command output
Real server |
Address |
IPv4 address of the real server. |
Port |
Port number of the real server. 0 means the port number in the packet is used. |
Real server state/Server farm member state: · Active—The real server is available. · Busy—The real server is busy. When the real server is in Active or Ramp state and enabled with bandwidth statistics collection and link protection, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The real server is unavailable, because the configuration is not complete, the server is not referenced, or the virtual server is not enabled. · Probe-failed—Health monitoring has failed. · Ramp—Ramp-up phase of slow online. · Shutdown—The real server is shut down. · Standby—Standby phase of slow online. · Unknown—Health monitoring is not configured. · Auto shutdown—The real server is automatically shut down when the RST or zero-window packet threshold is reached or the number of probe times is reached. |
VPN instance |
VPN instance to which the real server belongs. |
Inherit VPN |
Server farm |
Server farm of the real server. |
Description for the real server. |
IPv4 address |
IPv6 address |
IPv6 address of the real server. |
Weight |
Weight of the real server. |
Priority |
Priority of the real server. |
Slow shutdown |
Slow offline state of the real server: · Disabled. · Enabled. |
Connection limit |
Maximum number of connections for the real server. |
Maximum number of connections per second for the real server. |
Rate limit |
Rate limit of the real server. |
Connections |
Bandwidth |
Maximum bandwidth for the real server in KBps. |
Inbound bandwidth |
Maximum uplink bandwidth for the real server in KBps. |
Maximum downlink bandwidth for the real server in KBps. |
Max bandwidth |
Maximum expected bandwidth for the real server in KBps. |
Maximum uplink expected bandwidth for the real server in KBps. |
Maximum downlink expected bandwidth for the real server in KBps. |
Bandwidth ratio for the real server. |
Inbound bandwidth ratio for the real server. |
Outbound bandwidth ratio for the real server. |
Bandwidth recovery ratio for the real server. |
Inbound bandwidth recovery ratio for the real server. |
Outbound bandwidth recovery ratio for the real server. |
Dynamic weight |
Dynamic weight calculated by using the dynamic round robin algorithm. This field displays a weight value only if the dynamic round robin algorithm is used. If any other algorithm is used, this field displays two hyphens (--). |
SNMPDCA busy state |
Busy state obtained by using the dynamic round robin algorithm: Normal or Busy. If the dynamic round robin algorithm is not used, this field displays two hyphens (--). |
Health monitoring success criteria for the real server: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least X—Health monitoring succeeds when a minimum of X health monitoring methods succeed. |
Probe method |
State |
display real-server statistics
Use display real-server statistics to display real server statistics or server farm member statistics.
In standalone mode:
display real-server statistics [ name real-server-name ]
display real-server statistics server-farm server-farm-name [ name real-server-name port port-number ]
In IRF mode:
display real-server statistics [ name real-server-name ] [ slot slot-number ]
display real-server statistics server-farm server-farm-name [ name real-server-name port port-number ] [ slot slot-number ]
name real-server-name: Specifies a real server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all real servers.
server-farm server-farm-name: Displays statistics for members of a server farm. The server-farm-name argument specifies a server farm by its name, a case-insensitive string of 1 to 63 characters.
name real-server-name port port-number: Displays statistics for a server farm member. The real-server-name argument specifies a server farm member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the server farm member, in the range of 0 to 65535. If you do not specify this option, the command displays statistics for all members of a server farm.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays real server statistics for all member devices. (In IRF mode.)
# Display statistics for the real server rs.
<Sysname> display real-server statistics name rs
Real server: rs
Server input: 333332 bytes
Server output: 472054 bytes
Sent packets: 0
Dropped packets: 0
Received requests: 0
Dropped requests: 0
Sent responses: 0
Connection failures: 1
Busy state: Busy
# Display statistics for all members of server farm sf.
<Sysname> display real-server statistics server-farm sf
Server farm: sf
Real server: rs1
Max connections: 0
Server input: 0 bytes
Server output: 0 bytes
Received packets: 0
Sent packets: 0
Dropped packets: 0
Dropped requests: 0
Sent responses: 0
Connection failures: 0
RST packets: 50
Max RST packets: 5000
RST probe protection times: 3
Max RST probe protection times: 9
Zero-window packet rate: 10
Max zero-window packet rate: 50
Zero-window probe protection times: 2
Max zero-window probe protection times: 8
Real server: rs2
Max connections: 0
Received packets: 0
Sent packets: 0
Dropped packets: 0
Dropped requests: 0
Sent responses: 0
RST packets: 50
Table 20 Command output
Real server |
Real server name. |
Total connections |
Max connections |
Server input |
Traffic (in bytes) received by the server. |
Server output |
Traffic (in bytes) sent by the server. |
Throughput |
Max throughput |
Received packets |
Sent packets |
Dropped packets |
Received requests |
Number of received HTTP request packets. This field is displayed only for Layer 7 real servers. |
Dropped requests |
Number of dropped HTTP request packets. This field is displayed only for Layer 7 real servers. |
Sent responses |
Number of sent HTTP response packets. This field is displayed only for Layer 7 real servers. |
Dropped responses |
Number of dropped HTTP response packets. This field is displayed only for Layer 7 real servers. |
Connection failures |
Number of connection establishment failures. |
Busy state |
Real server state: · --—Unavailable. · Normal. · Busy. |
RST packets |
Number of RST packets sent by the real server. |
Max RST packets |
Maximum number of RST packets sent by the real server. |
RST probe protection times |
Number of probe times for the RST LB probe template. |
Max RST probe protection times |
Maximum number of probe times for the RST LB probe template. |
Zero-window packet rate |
Percentage of zero-window packets sent by the real server. |
Max zero-window packet rate |
Maximum percentage of zero-window packets sent by the real server. |
Zero-window probe protection times |
Number of probe times for the zero-window LB probe template. |
Max zero-window probe protection times |
Maximum number of probe times for the zero-window LB probe template. |
display server-farm
Use display server-farm to display server farm information.
display server-farm [ brief | name server-farm-name ]
brief: Displays brief server farm information. If you do not specify this keyword, the command displays detailed server farm information.
name server-farm-name: Displays information about the specified server farm. The server-farm-name argument specifies a server farm name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all server farms.
# Display brief information about all server farms.
<Sysname> display server-farm brief
LT - Least time, DRR - Dynamic round robin
CARP(SIP) - CARP address source IP
CARP(DIP) - CARP address destination IP
CARP(SIP-PORT) - CARP address source IP-port
CARP(HTTP) - CARP HTTP payload
HASH(HTTP) - Hash HTTP payload
Server farm Predictor NAT SNAT Total Active
sf RR Y N 3 3
# Display detailed information about all server farms.
Server farm: sf1
Description:
Proximity: Disabled
NAT: Enabled
SNAT pool:
Failed action: Keep
Lower: 80
Upper: 90
Standby time: 5s
Ramp-up time: 10s
Min server: 100
Max server: 600
Busy action: Enqueue
Queue length: 11
Queue timeout: 12
Probe information:
Probe method:
aaa
bbb
ccc
TCP RST probe template: aaa
TCP zero-window probe template: bbb
Auto-shutdown recovery time: 30
Total real server: 1
Active real server: 1
Real server list:
Name State VPN instance Address Port Weight Priority LT-weight
rs1 Inactive 1.2.3.4 0 4 100 50
rs2 Auto shutdown 1.2.3.4 0 4 100 50
Table 21 Command output
Server farm |
Server farm name. |
Predictor |
Scheduling algorithm of the server farm: · RR—Weighted round robin algorithm. · RD—Random algorithm. · LC—Weighted least connection algorithm. · BW—Bandwidth algorithm. · IBW—Inbound bandwidth algorithm. · OBW—Outbound bandwidth algorithm. · MBW—Maximum bandwidth algorithm. · MIBW—Maximum inbound bandwidth algorithm. · MOBW—Maximum outbound bandwidth algorithm. · HASH(SIP)—Hash algorithm based on source IP address. · HASH(DIP)—Hash algorithm based on destination IP address. · HASH(SIP-PORT)—Hash algorithm based on source IP address and port number. · LT—Least time algorithm. · DRR—Dynamic round robin algorithm. · CARP(SIP)—CARP hash algorithm based on source IP address. · CARP(DIP)—CARP hash algorithm based on destination IP address. · CARP(SIP-PORT)—CARP hash algorithm based on source IP address and port number. · CARP(HTTP)—CARP hash algorithm based on HTTP content. · HASH(HTTP)—Hash algorithm based on HTTP content. |
NAT |
NAT state of the server farm: · N—Disabled. · Y—Enabled. |
SNAT |
SNAT state of the server farm: · N—Disabled. · Y—Enabled. |
Total |
Total number of real servers. |
Active |
Number of active real servers. |
Description for the server farm. |
Proximity state of the server farm: · Disabled. · Enabled. |
NAT |
NAT state of the server farm: · Disabled—NAT is not configured. · Enabled. |
SNAT pool |
Name of the SNAT address pool referenced by the server farm. |
Failed action |
Fault processing method of the server farm: · Keep—Keeps existing connections. · Reschedule—Redirects connections. · Reset—Terminates existing connections. |
Active threshold |
State of the criteria to determine that the server farm is available: disabled or enabled. If the state is enabled, the following fields are displayed: · Lower—Lower percentage value. · Upper—Upper percentage value. |
Slow-online |
Selected server |
State of real server limit to participate in scheduling: disabled or enabled. If the state is enabled, the following fields are displayed: · Min server—Minimum number of real servers that participate in scheduling. · Max server—Maximum number of real servers that participate in scheduling. |
Health monitoring success criteria for the real server: · All—Health monitoring succeeds only when all the specified health monitoring methods succeed. · At least—Health monitoring succeeds when a specified minimum number of health monitoring methods succeed. |
Busy action |
Action to take when the server farm is busy: · Drop. · Enqueue. · Force. |
Queue length |
This field is displayed only if the busy action is Enqueue. |
Queue timeout |
Probe method |
Total real server |
Active real server |
Name |
Real server name. |
State |
Real server state: · Active—The real server is available. · Busy—The real server is busy. When the real server is in Active or Ramp state and enabled with bandwidth statistics collection and link protection, this field displays Busy if the maximum expected bandwidth is reached. · Inactive—The real server is unavailable, because the configuration is not complete, the server is not referenced, or the virtual server is not enabled. · Probe-failed—Health monitoring has failed. · Ramp—Ramp-up phase of slow online. · Shutdown—The real server is shut down. · Standby—Standby phase of slow online. · Unknown—Health monitoring is not configured. · Auto shutdown—The real server is automatically shut down when the RST or zero-window packet threshold is reached or the number of probe times is reached. |
Address |
IPv4 and IPv6 addresses of the real server. |
Port |
Port number of the real server. |
Weight |
Priority |
LT-weight |
Weight calculated by using the least time algorithm. This field displays a weight value only if the least time algorithm is used. If any other algorithm is used, this field displays two hyphens (--). |
TCP RST probe template |
TCP-RST LB probe template referenced by the server farm. This field is displayed only if a TCP-RST LB probe template is referenced. |
TCP zero-window probe template |
TCP zero-window LB probe template referenced by the server farm. This field is displayed only if a TCP zero-window LB probe template is referenced. |
Auto-shutdown recovery time |
Automatic recovery time for intelligent monitoring, in minutes. |
display sticky
Use display sticky to display sticky entry information.
In standalone mode:
display sticky { dns-proxy [ dns-proxy-name ] | virtual-server [ virtual-server-name ] } [ class class-name | default-class | default-dns-server-pool | default-link-group | default-server-farm ]
In IRF mode:
display sticky { dns-proxy [ dns-proxy-name ] | virtual-server [ virtual-server-name ] } [ class class-name | default-class | default-dns-server-pool | default-link-group | default-server-farm ] [ slot slot-number ]
dns-proxy dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays sticky entry information for all transparent DNS proxies.
virtual-server virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays sticky entry information for all virtual servers.
class class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters.
default-class: Specifies the default LB action.
default-dns-server-pool: Specifies the default DNS server pool.
default-link-group: Specifies the default link group.
default-server-farm: Specifies the default server farm.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays sticky entry information for all member devices. (In IRF mode.)
# Display sticky entry information for all virtual services.
<Sysname> display sticky virtual-server
Virtual server name: vs1
Sticky zone type: Class
Class name: lbc1
Sticky group name: sg1
Sticky method: Source IP and port
Timeout: 60
Sticky entry Real server Expired time Count
192.168.6.206/1566 192.168.6.206/0 53 0
192.168.6.206/1567 192.168.6.206/0 56 0
Virtual server name: vs2
Sticky zone type: Default class
Class name:
Sticky group name: sg2
Sticky method: Payload
Timeout: 60
\12\22\07\07\08\00 81.8.8.3/0 604751 0
7222bd4ace193907d5d6a2bbc37953f3
Virtual server name: vs3
Sticky zone type: Default server farm
Class name:
Sticky group name: sg3
Sticky method: HTTP version
Timeout: 60
1.0 192.168.6.206/0 109 0
1.1 192.168.6.206/0 97 0
0.9 192.168.6.206/0 116 0
Virtual server name: vs4
Sticky zone type: Default link group
Class name:
Sticky method: Both IP and port
Timeout: 60
Sticky entry Link Expired time Count
192.168.6.206/2606 Dialer0 57 0
192.168.6.40/80
192.168.6.206/2605 192.168.6.206/0 55 0
192.168.6.40/80
# Display sticky entry information for all transparent DNS proxies.
<Sysname> display sticky dns-proxy
DNS proxy name: dns-proxy1
Sticky zone type: Default DNS server pool
Sticky group name: st
Timeout: 60
Sticky entry DNS server Expired time Count
192.168.6.206/2606 192.168.6.206/0 57 0
DNS proxy name: dns-proxy2
Class name: class
Timeout: 60
DNS proxy name: dns-proxy3
Timeout: 60
Table 22 Command output
Sticky zone type |
Sticky entry source: · Class—Generated by the class and action in the policy referenced by the virtual service. · Default class—Generated by the default action in the policy referenced by the virtual service. · Default DNS server pool—Generated by the default DNS server pool of the transparent DNS proxy. · Default link group—Generated by the default primary or backup link group of the virtual service. · Default server farm—Generated by the default primary or backup server farm of the virtual service. |
Class name |
LB class name. The LB class name is displayed only when the sticky entries are generated by the class and action. |
Sticky group name |
Name of the sticky group that generates the sticky entries. |
Sticky method |
Sticky method corresponding to the sticky entries: · Source IP—Source IPv4 address sticky method. · Source IPv6—Source IPv6 address sticky method. · Source IP and port—Source IPv4 address + source port sticky method. · Source IPv6 and port—Source IPv6 address + source port sticky method. · Destination IP—Destination IPv4 address sticky method. · Destination IPv6—Destination IPv6 address sticky method. · Destination IP and port—Destination IPv4 address + destination port sticky method. · Destination IPv6 and port—Destination IPv6 address + destination port sticky method. · Both IP—Source IPv4 address + destination IPv4 address sticky method. · Both IPv6—Source IPv6 address + destination IPv6 address sticky method. · Both IP and port—Source IPv4 address + source port + destination IPv4 address + destination port sticky method. · Both IPv6 and port—Source IPv6 address + source port + destination IPv6 address + destination port sticky method. · HTTP URL—HTTP URL based sticky method. · HTTP header name—HTTP header name based sticky method. · HTTP version—HTTP version based sticky method. · HTTP host—HTTP host based sticky method. · HTTP method—HTTP Request-Method based sticky method. · HTTP content—HTTP entity sticky method. · HTTP cookie—HTTP Cookie sticky method. · Payload—HTTP or UDP payload sticky method. · Framed-IP-Address—Sticky method based on the Framed-IP-Address attribute of RADIUS packets. · User-Name—Sticky method based on the User-Name attribute of RADIUS packets. · Code=attribute-code—Sticky method based on the attribute (specified by attribute-code) of RADIUS packets. · SIP Call-ID—Sticky method based on the Call-ID header field of SIP packets. · SSL session ID—SSL sticky method based on SSL session ID. |
Timeout |
Timeout time of the sticky entries, in seconds. |
Sticky entry |
Key value corresponding to the sticky entry. |
DNS server |
IP address and port number of the DNS server. |
Real server |
IP address and port number of the real server. For the Layer 7 sticky method, if both IPv4 and IPv6 addresses are configured for the real server, both addresses are displayed. |
Link |
Outbound next hop IP address and port number of the link or outgoing interface of the link. |
Expired time |
Remaining lifetime of the sticky entry. If the reference count is not 0, the configured value is displayed. |
Count |
Reference count of the sticky entry. |
display sticky-group
Use display sticky-group to display sticky group information.
display sticky-group [ name group-name ]
name group-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all sticky groups.
# Display information about all sticky groups.
<Sysname> display sticky-group
Sticky group: sg1
Description:
Timeout: 60
Override limit: Disabled
Stickiness-over-busyness: Enabled
Sticky group type: Address-port
Method: Both IP and port
Mask: 32
Sticky group: sg2
Description:
Timeout: 60
Sticky group type: HTTP header
Method: HTTP header name
Offset: 4
Start: gzip
Length: 10
Sticky group: sg3
Description:
Timeout: 60
Sticky group type: RADIUS
Method: User-Name
Table 23 Command output
Sticky group |
Sticky group name. |
Description for the sticky group. |
Timeout |
Timeout time for sticky entries in seconds. |
Override limit |
Whether the feature of ignoring the limits for sessions that match sticky entries is enabled: Enabled or Disabled. |
Stickiness-over-busyness |
Whether the stickiness-over-busyness feature is enabled: Enabled or Disabled. |
Sticky group type |
Sticky group type: · Address-port—Address and port. · HTTP content—HTTP entity. · HTTP cookie. · HTTP header. · Payload—HTTP or UDP payload. · RADIUS. · SIP. · SSL. |
Table 24 Detailed information for sticky groups
Sticky group type |
Address-port |
Method |
Sticky method: · Source IP—Source IPv4 address sticky method. · Source IPv6—Source IPv6 address sticky method. · Source IP and port—Source IPv4 address + source port sticky method. · Source IPv6 and port—Source IPv6 address + source port sticky method. · Destination IP—Destination IPv4 address sticky method. · Destination IPv6—Destination IPv6 address sticky method. · Destination IP and port—Destination IPv4 address + destination port sticky method. · Destination IPv6 and port—Destination IPv6 address + destination port sticky method. · Both IP—Source IPv4 address + destination IPv4 address sticky method. · Both IPv6—Source IPv6 address + destination IPv6 address sticky method. · Both IP and port—Source IPv4 address + source port + destination IPv4 address + destination port sticky method. · Both IPv6 and port—Source IPv6 address + source port + destination IPv6 address + destination port sticky method. |
Mask |
Mask length for the sticky method. This field is displayed only for IPv4 sticky methods. |
Prefix |
Prefix length for the sticky method. This field is displayed only for IPv6 sticky methods. |
HTTP content |
Offset |
Offset value of the entity based on the start of the HTTP packet. |
Start |
Regular expression that marks the start of the entity. |
End |
Regular expression that marks the end of the entity. Either this field or the Length field is displayed, but not both of them. |
Length |
Length of the entity. Either this field or the End field is displayed, but not both of them. |
HTTP cookie |
Method |
Sticky method: · HTTP cookie insert—Cookie insert sticky method. · HTTP cookie rewrite—Cookie rewrite sticky method. · HTTP cookie get—Cookie get sticky method. This field is displayed only for the HTTP cookie sticky method. |
Name |
HTTP cookie name. This field is displayed only for the HTTP cookie sticky method. |
Offset |
Offset value of the cookie based on the start of the HTTP packet. This field is displayed only for the cookie insert sticky method. |
Start |
Regular expression that marks the start of the cookie. This field is displayed only for the cookie insert sticky method. |
End |
Regular expression that marks the end of the cookie. Either this field or the Length field is displayed, but not both of them. This field is displayed only for the cookie insert sticky method. |
Length |
Length of the cookie. Either this field or the End field is displayed, but not both of them. This field is displayed only for the cookie insert sticky method. |
Cookie secondary name |
Name of the secondary cookie to be searched in the URI. This field is displayed only for the cookie insert sticky method. |
Check all packets |
Whether or not to enable checking for all packets. |
HTTP header |
Method |
Sticky method: · HTTP host—HTTP host based sticky method. · HTTP header name—HTTP header name based sticky method. · HTTP method—HTTP Request-Method based sticky method. · HTTP URL—HTTP URL based sticky method. · HTTP version—HTTP version based sticky method. This field is displayed only for the HTTP header sticky method. |
Name |
HTTP header name. This field is displayed only for the HTTP header name based sticky method. |
Offset |
Offset value of the HTTP header based on the start of the HTTP packet. This field is displayed only for the HTTP host or URL based sticky method. |
Start |
Regular expression that marks the start of the HTTP header. This field is displayed only for the HTTP host or URL based sticky method. |
End |
Regular expression that marks the end of the HTTP header. Either this field or the Length field is displayed, but not both of them. This field is displayed only for the HTTP host or URL based sticky method. |
Length |
Length of the HTTP header. Either this field or the End field is displayed, but not both of them. This field is displayed only for the HTTP host or URL based sticky method. |
Payload |
Offset |
Offset value of the HTTP or UDP payload based on the start of the HTTP packet. |
Start |
Regular expression that marks the start of the HTTP or UDP payload. |
End |
Regular expression that marks the end of the HTTP or UDP payload. Either this field or the Length field is displayed, but not both of them. . |
Length |
Length of the HTTP or UDP payload. Either this field or the End field is displayed, but not both of them. |
RADIUS |
Method |
Sticky method: · Framed-IP-Address—Sticky method based on the Framed-IP-Address attribute of RADIUS packets. · User-Name—Sticky method based on the User-Name attribute of RADIUS packets. · Code=attribute-code—Sticky method based on the attribute (specified by attribute-code) of RADIUS packets. This field is not displayed if no RADIUS attribute based sticky method is specified. |
SIP |
Method |
Sticky method, which can only be SIP Call-ID (SIP sticky method based on the Call-ID header field of SIP packets). |
SSL |
Method |
Sticky method, which can only be SSL session ID (SSL sticky method based on SSL session ID). This field is displayed only for the SSL sticky method based on SSL session ID. |
display virtual-server
Use display virtual-server to display virtual server information.
display virtual-server [ brief | name virtual-server-name ]
brief: Displays brief virtual server information. If you do not specify this keyword, the command displays detailed virtual server information.
name virtual-server-name: Displays information about the specified virtual server. The virtual-server-name argument specifies a virtual server name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all virtual servers.
# Display brief information about all virtual servers.
<Sysname> display virtual-server brief
Virtual server State Type VPN instance Virtual address Port
vs1 Inactive IP vpn1 192.168.21.148/32 80
1111:2222:3333:4444
:5555:6666:7777:888
8/128
vs2 Active HTTP 61.159.4.100/32 8080
vs3 Active LINK-IP 51.139.4.100/32 0
# Display detailed information about all virtual servers.
Virtual server: vs
Description: Virtual server VS
Type: HTTP
State: Active
VPN instance: vpn1
Virtual IPv4 address: 1.1.1.1/32
Virtual IPv6 address: 1001::1/128
Port: 0 (any port)
Primary server farm: sf (in use)
Backup server farm: sfb
Sticky: sg3
LB policy: lbp2
LB limit-policy:
TCP parameter profile (client-side): ptc
TCP parameter profile (server-side): pts
HTTP parameter profile: pp1
HTTP-statistics parameter profile: 1
OneConnect parameter profile: one
UDP per-packet: Enabled
Rate limit:
Connections: 10000
SSL server policy: ssl-server
SSL client policy: ssl-client
Redirect relocation:
Redirect return-code: 302
Sticky synchronization: Disabled
Bandwidth busy protection: Disabled
Interface bandwidth statistics: Disabled
Route advertisement: Enabled
ARP/ND interfaces:
GigabitEthernet1/0
GigabitEthernet2/0
Virtual server: vstcp
Type: TCP
State: Active
VPN instance: vpn1
Port: 8080
Sticky: sg3
LB policy: lbp2
LB limit-policy:
TCP-Application parameter profile: ptapp
Rate limit:
Connections: 10000
Application-Mode: Enabled
ARP/ND interfaces:
GigabitEthernet1/0
GigabitEthernet2/0
# Display detailed information about the virtual server lk.
<Sysname> display virtual-server name lk
Virtual server: lk
Description:
Type: Link-IP
State: Active
VPN instance: vpn1
Port: 0
Primary link group: lg1 (in use)
Backup link group: lg2
Sticky: sg3
LB policy: lbp2
LB limit-policy:
Rate limit:
Connections: 10000
Connection synchronization: Disabled
Route advertisement: Disabled
ARP/ND interfaces:
GigabitEthernet1/0
Table 25 Command output
Virtual server |
Virtual server name. |
State |
Virtual server state: · Active—The virtual server is available. · Inactive—The virtual server is unavailable. · Inactive (disabled)—The virtual server is unavailable because the virtual server is disabled. |
Type |
Virtual server type: Fast HTTP, HTTP, IP, RADIUS, TCP, UDP, or link-IP. |
Name of the VPN instance to which the virtual server belongs. |
Virtual address |
IPv4 address and mask of the virtual server. |
Port |
Port number of the virtual server. 0 means any port. |
Description of the virtual server. |
Virtual IPv4 address |
Virtual IPv6 address |
IPv6 address and prefix of the virtual server. |
Primary server farm |
Default primary server farm name. (in use) indicates the server farm is in use. |
Backup server farm |
Default backup server farm name. (in use) indicates the server farm is in use. |
Primary link group |
Default primary link group name. (in use) indicates the link group is in use. |
Backup link group |
Default backup link group name. (in use) indicates the link group is in use. |
Sticky |
Default sticky group name. |
LB policy |
LB policy referenced by the virtual server. |
HTTP parameter profile |
HTTP parameter profile referenced by the virtual server. This field is displayed only if an HTTP parameter profile is configured. |
IP parameter profile |
IP parameter profile referenced by the virtual server. This field is displayed only if an IP parameter profile is configured. |
TCP parameter profile |
TCP parameter profile referenced by the virtual server. This field is displayed only if a TCP parameter profile is configured. |
TCP parameter profile (client-side) |
Client-side TCP parameter profile referenced by the virtual server. This field is displayed only if a client-side TCP parameter profile is configured. |
TCP parameter profile (server-side) |
Server-side TCP parameter profile referenced by the virtual server. This field is displayed only if a server-side TCP parameter profile is configured. |
OneConnect parameter profile |
OneConnect parameter profile referenced by the virtual server. This field is displayed only if a OneConnect parameter profile is configured. |
HTTP-statistics parameter profile |
HTTP statistics parameter profile referenced by the virtual server. This field is displayed only if an HTTP statistics parameter profile is configured. |
TCP-Application parameter profile |
TCP-application parameter profile referenced by the virtual server. This field is displayed only if a TCP-application parameter profile is configured. |
UDP per-packet |
State of the per-packet load balancing for UDP traffic: · Disabled. · Enabled. This field is displayed only for UDP virtual servers. |
Connection limit |
Maximum number of connections of the virtual server. |
Rate limit |
Rate limit of the virtual server. |
Connections |
Maximum number of connections per second of the virtual server. |
Bandwidth |
Maximum bandwidth for the virtual server in KBps. |
Inbound bandwidth |
Maximum inbound bandwidth for the virtual server in KBps. |
Maximum outbound bandwidth for the virtual server in KBps. |
SSL server policy |
SSL server policy name. This field is displayed only for HTTP-type virtual servers. |
SSL client policy |
SSL client policy name. This field is displayed only for HTTP-type virtual servers. |
Redirect relocation |
Redirection URL. This field is displayed only for HTTP-type virtual servers. |
Redirect return-code |
Status code in the redirection packets. This field is displayed only for HTTP-type virtual servers. |
Session extension information synchronization state: Enabled or Disabled. This field is not displayed for HTTP-type virtual servers. |
Sticky entry synchronization state: Enabled or Disabled. |
Link protection state: Enabled or Disabled. |
Interface bandwidth statistics |
Bandwidth statistics collection by interfaces: Disabled or Enabled. |
Route advertisement |
IP address advertisement for the virtual server: Disabled or Enabled. |
Application-Mode |
Layer 7 operating mode for the virtual server: Disabled or Enabled. This field is displayed only for a TCP virtual server. |
ARP/ND interfaces |
display virtual-server statistics
Use display virtual-server statistics to display virtual server statistics.
In standalone mode:
display virtual-server statistics [ name virtual-server-name ]
In IRF mode:
display virtual-server statistics [ name virtual-server-name ] [ slot slot-number ]
name virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics of all virtual servers.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays virtual server statistics for all member devices. (In IRF mode.)
# Display statistics for the virtual server vs.
<Sysname> display virtual-server statistics name vs
Virtual server: vs
Total connections: 979
Active connections: 618
Max connections: 661
Connections per second: 146
Max connections per second: 156
Client input: 333332 bytes
Client output: 472054 bytes
Throughput: 4088 bytes/s
Outbound throughput: 2874 bytes/s
Max throughput: 4368 bytes/s
Max outbound throughput: 3154 bytes/s
Received packets: 979
Sent packets: 0
Dropped packets: 0
Table 26 Command output
Virtual server |
Total connections |
Max connections |
Client input |
Traffic (in bytes) received from the client. |
Client output |
Traffic (in bytes) sent to the client. |
Throughput |
Max throughput |
Max throughput |
Max throughput |
Received packets |
Sent packets |
Number of packets sent by the virtual server to the client. |
Dropped packets |
Received requests |
Number of received HTTP request packets. This field is displayed only for HTTP-type virtual servers. |
Dropped requests |
Number of dropped HTTP request packets. This field is displayed only for HTTP-type virtual servers. |
Sent responses |
Number of sent HTTP response packets. This field is displayed only for HTTP-type virtual servers. |
Dropped responses |
Number of dropped HTTP response packets. This field is displayed only for HTTP-type virtual servers. |
reset virtual-server statistics
dns-server (DNS server pool view)
Use dns-server to create a DNS server pool member and enter its view, or enter the view of an existing DNS server pool member.
Use undo dns-server to delete a DNS server pool member.
dns-server dns-server-name port port-number
undo dns-server dns-server-name port port-number
No DNS server pool members exist.
dns-server-name: Specifies a DNS server pool member name, a case-insensitive string of 1 to 63 characters.
port-number: Specifies the port number of the DNS server pool member, in the range of 0 to 65535.
You can use one of the following methods to add a member to a DNS server pool:
· Use the dns-server command in DNS server pool view. H3C recommends using this method.
· Use the dns-server-pool command in DNS server view.
You cannot use both methods to add a member with the same DNS server name and port number to a DNS server pool.
# Add DNS server pool member ds1 and enter DNS server pool member view.
[Sysname] loadbalance dns-server-pool dsp1
[Sysname-lb-dspool-dsp1] dns-server ds1 port 10
[Sysname-lb-dspool-dsp1-#member#-ds1-port-10]
dns-server-pool (DNS server view)
dns-server-pool (LB action view)
Use dns-server-pool to specify a DNS server pool for guiding packet forwarding.
Use undo dns-server-pool to restore the default.
dns-server-pool pool-name [ sticky sticky-name ]
No DNS server pool is specified for guiding packet forwarding.
DNS LB action view
pool-name: Specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
sticky sticky-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a sticky group, the DNS server pool does not correspond to any sticky group.
This command is mutually exclusive with the forward all or skip current-dns-proxy command. If you configure one command, the other command (if configured) is automatically cancelled.
# Specify the DNS server pool dsp and the sticky group sg1 for DNS LB action lba1.
[Sysname] loadbalance action lba1 type dns
[Sysname-lba-dns-lba1] dns-server-pool dsp sticky st1
forward all
Use dns-server-pool to specify a DNS server pool for a DNS server.
A DNS server does not belong to any DNS server pool.
DNS server view
You can specify a DNS server pool that has not been created.
# Specify DNS server pool dns-pool1 for DNS server ds1.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] dns-server-pool dns-pool1
display loadbalance dns-server
exceed-mss
Use exceed-mss to specify the action to take on the segments that exceed the MSS in the HTTP requests sent by the client.
Use undo exceed-mss to restore the default.
exceed-mss { allow | drop }
undo exceed-mss
The device allows the segments to exceed the MSS in the HTTP requests sent by the client.
TCP parameter profile view
allow: Allows the segments to exceed the MSS.
drop: Discards the segments that exceed the MSS.
# For the TCP parameter profile pp3, specify the drop action for the segments that exceed the MSS in the HTTP requests sent by the client.
[Sysname] parameter-profile pp3 type tcp
[Sysname-para-tcp-pp3] exceed-mss drop
fail-action (link group view)
Use fail-action to specify the fault processing method for a link group.
Use undo fail-action to restore the default.
fail-action { keep | reschedule | reset }
undo fail-action
The fault processing method is to keep existing connections.
Link group view
keep: Keeps the connection with the failed link. Keeping or terminating the connection depends on the timeout mechanism of the protocol.
reschedule: Redirects the connection to another available link in the link group.
reset: Terminates the connection with the failed link by sending RST packets (for TCP packets) or ICMP unreachable packets (for other types of packets).
The fault processing method applies when the link that processes packets fails.
# Specify the fault processing method for the link group lg as reschedule.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] fail-action reschedule
fail-action (server farm view)
Use fail-action to specify the fault processing method for a server farm.
undo fail-action
Server farm view
keep: Keeps the connection with the failed real server. Keeping or terminating the connection depends on the timeout mechanism of the protocol.
reschedule: Redirects the connection to another available real server in the server farm.
reset: Terminates the connection with the failed real server by sending RST packets (for TCP packets) or ICMP unreachable packets (for other types of packets).
The fault processing method applies when the real server that processes packets fails.
# Specify the fault processing method for the server farm sf as reschedule.
[Sysname] server-farm sf
[Sysname-sfarm-sf] fail-action reschedule
fallback-action close
Use fallback-action close to configure the method of closing TCP connections upon failure to find a real server.
Use undo fallback-action to restore the default.
fallback-action close { fin | rst }
Packets are dropped when no real servers are available for the current LB action.
Generic/HTTP LB action view
fin: Closes TCP connections by sending FIN packets.
rst: Closes TCP connections by sending RST packets.
This command enables the device to close TCP connections matching the LB policy by sending FIN or RST packets if the device fails to find a real server according to the LB action.
# In HTTP LB action a1, configure the method of closing TCP connections by sending RST packets.
[Sysname] loadbalance action a1 type http
[Sysname-lba-http-a1] fallback-action close rst
fallback-action continue
Use fallback-action continue to match the next rule upon failure to find an available server.
Use undo fallback-action continue to restore the default.
Packets are dropped when no servers are available for the current LB action.
LB action view
This command enables packets to match the next rule in an LB policy when no servers are available for the current LB action.
# Match the next rule upon failure to find a real server for the HTTP LB action a1.
[Sysname-lba-http-a1] fallback-action continue
# Match the next rule upon failure to find a DNS server for the DNS LB action a2.
[Sysname] loadbalance action a2 type dns
[Sysname-lba-dns-a2] fallback-action continue
fallback-action response raw-file
Use fallback-action response raw-file to specify a response file used upon load balancing failure.
Use undo fallback-action response raw-file to restore the default.
fallback-action response raw-file raw-filename
No response file is specified for use upon load balancing failure.
HTTP LB action view
raw-filename: Specifies a response file by its name, a case-insensitive string of 1 to 255 characters.
This command enables the device to respond to client requests when the device fails to find an available real server or fails to find the response file specified in the response command. The response file specified in the fallback-action response raw-file command must contain a complete HTTP packet and cannot contain only the HTTP content.
The fallback-action response raw-file command and the fallback-action continue command are mutually exclusive.
# Specify the 301.raw file as the response file used upon load balancing failure.
[Sysname] loadbalance action a_http type http
[Sysname-lba-http-a_http] fallback-action response raw-file 301.raw
display loadbalance action
fin-wait1 timeout
Use fin-wait1 timeout to set the FIN-WAIT-1 state timeout time for TCP connections.
Use undo fin-wait1 timeout to restore the default.
fin-wait1 timeout timeout-value
The FIN-WAIT-1 state timeout time is 5 seconds for TCP connections.
timeout-value: Specifies the FIN-WAIT-1 state timeout time in the range of 1 to 65535 seconds.
# Set the FIN-WAIT-1 state timeout time for TCP connections to 10 seconds in the TCP parameter profile profile.
[Sysname] parameter-profile profile type tcp
[Sysname-para-tcp-profile] fin-wait1 timeout 10
fin-wait2 timeout
Use fin-wait2 timeout to set the FIN-WAIT-2 state timeout time for TCP connections.
Use undo fin-wait2 timeout to restore the default.
The FIN-WAIT-2 state timeout time is 5 seconds for TCP connections.
timeout-value: Specifies the FIN-WAIT-2 state timeout time in the range of 1 to 65535 seconds.
# Set the FIN-WAIT-2 state timeout time for TCP connections to 10 seconds in the TCP parameter profile profile.
[Sysname-para-tcp-profile] fin-wait2 timeout 10
forward all
Use forward all to configure the packet forwarding mode.
Use undo forward to restore the default.
forward all
undo forward
The packet forwarding mode is to discard packets.
DNS/Generic/Link-generic LB action view
In DNS LB action view, this command is mutually exclusive with the dns-server-pool or skip current-dns-proxy command. In generic LB action view, the forward all and server-farm commands are mutually exclusive. In link-generic LB action view, the forward all and link-group commands are mutually exclusive. If you configure one command, the other command (if configured) is automatically cancelled.
# Configure the packet forwarding mode for the generic LB action lba1.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] forward all
dns-server-pool
link-group (LB action view)
server-farm (LB action view)
frequency
Use frequency to set the probe interval for an LB probe template.
Use undo frequency to restore the default.
frequency interval
undo frequency
The probe interval is 300 seconds.
Load balancing probe template view
interval: Specifies the probe interval in the range of 1 to 604800 seconds.
This command specifies the interval for sending probe packets.
# Set the probe interval to 3600 seconds for ICMP probe template icmptplt.
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lb-pt-icmp-icmptplt] frequency 3600
header
Use header to configure the HTTP header sticky method.
Use undo header to restore the default.
header { { { host | name header-name | url } [ offset offset ] [ start start-string ] [ end end-string | length length ] } | request-method | version }
undo header
No HTTP header sticky methods exist.
HTTP header sticky group view
host: Specifies the HTTP host based sticky method.
name header-name: Specifies the HTTP header name based sticky method. The header-name argument is a string of 1 to 63 characters.
url: Specifies the HTTP URL based sticky method.
offset offset: Specifies the offset value of the HTTP header based on the start of the HTTP packet, in the range of 0 to 1000. The default is 0.
start start-string: Specifies the regular expression that marks the start of the HTTP header, a string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP header, a string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP header, in the range of 0 to 1000. The default is 0, which indicates all lengths.
request-method: Specifies the HTTP Request-Method based sticky method.
version: Specifies the HTTP version based sticky method.
Use this command to obtain the HTTP header information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
# Configure the HTTP header sticky method for the HTTP header sticky group sg4: Specify the HTTP host based sticky method.
[Sysname] sticky-group sg4 type http-header
[Sysname-sticky-http-header-sg4] header host
header call-id
Use header call-id to configure the SIP call ID sticky method.
Use undo header call-id to restore the default.
header call-id
undo header call-id
No sticky methods exist.
SIP sticky group view
The SIP call ID sticky method allows the device to generate sticky entries based on the Call-ID header field in SIP messages. Packets with the same call ID are assigned to the same real server.
# Configure the SIP call ID sticky method for the SIP sticky group sg6.
[Sysname] sticky-group sg6 type sip
[Sysname-sticky-sip-sg6] header call-id
header delete
Use header delete to delete the HTTP header.
Use undo header delete to keep the HTTP header.
header delete { both | request | response } name header-name
undo header delete { both | request | response } name header-name
The HTTP header is kept.
HTTP LB action view
both: Specifies both the HTTP request and response packets.
request: Specifies the HTTP request packets.
response: Specifies the HTTP response packets.
name header-name: Specifies the name of the HTTP packet header, including standard and user-defined headers that must match the header in the packet. The header-name argument is a case-insensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
This command deletes the specified header from HTTP packets.
# Delete the header named host from HTTP request packets for the HTTP LB action lba2.
[Sysname] loadbalance action lba2 type http
[Sysname-lba-http-lba2] header delete request name host
header delete request accept-encoding
Use header delete request accept-encoding to delete the Accept-Encoding header from HTTP requests.
Use undo header delete request accept-encoding to keep the Accept-Encoding header in HTTP requests.
The LB device deletes the Accept-Encoding header from HTTP requests.
HTTP-compression parameter profile view
This command enables the LB device to delete the Accept-Encoding header from the HTTP request before sending it to the server. If the response packet sent by the server matches the specified match rule, the LB device compresses the packet before sending it to the requesting client. If the HTTP request sent by the client does not contain the Accept-Encoding header, the LB device does not compress the response packet regardless of whether this command is executed.
By default, the LB device does not modify request packets. If the response packet sent by the server is compressed, the LB device sends the packet to the requesting client without compressing it. If the response packet sent by the server is not compressed and matches the specified match rule, the LB device compresses the packet before sending it to the requesting client.
# Create the HTTP-compression parameter profile http1, and delete the Accept-Encoding header from HTTP requests.
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] header delete request accept-encoding
header exceed-length
Use header exceed-length to specify the action to take on the HTTP requests or responses when their packet headers exceed the maximum length.
Use undo header exceed-length to restore the default.
header exceed-length { continue | drop }
The system continues to perform load balancing for HTTP requests or responses when their packet headers exceed the maximum length.
HTTP parameter profile view
continue: Continues to perform load balancing.
drop: Stops performing load balancing, discards the packet, and terminates the connection.
This command is not supported by virtual servers of the fast HTTP type.
When the HTTP packet header length exceeds the processing capability of load balancing, the drop method applies.
# For the HTTP parameter profile pp1, specify the drop action for the HTTP requests or responses with their packet headers exceeding the maximum length.
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] header exceed-length drop
header insert
Use header insert to insert the HTTP header.
Use undo header insert to remove the configuration.
header insert { both | request | response } name header-name value value [ encode { base64 | url } ]
undo header insert { both | request | response } name header-name
The HTTP header is not inserted.
HTTP LB action view
name header-name: Specifies the name of the HTTP packet header, including standard and user-defined headers. The header-name argument is a case-insensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
value value: Specifies the header content to be inserted to the HTTP packet, a string of 1 to 255 characters. You can also specify the following replacement strings:
· %is—Source IP address in HTTP requests.
· %ps—Source port number in HTTP requests.
· %id—Destination IP address in HTTP requests.
· %pd—Destination port number in HTTP requests.
· %sps—Source IP address in HTTP responses.
· %spd—Source port number in HTTP responses.
· %sis—Destination IP address in HTTP responses.
· %sid—Destination port number in HTTP responses.
· %{x509v}—Certificate version.
· %{x509snum}—Certificate serial number.
· %{x509sigalgo}—Certificate signature algorithm.
· %{x509issuer}—Certificate issuer.
· %{x509before}—Certificate effective time.
· %{x509after}—Certificate expiration time.
· %{x509sub}—Certificate subject.
· %{x509spktype}—Public key type for the certificate subject.
· %{x509spk}—Public key for the certificate subject.
· %{x509spkRSA}—Length of the RSA public key for the certificate subject (this field is available only for an RSA public key).
· %{x509hash}—MD5 hash value of the client certificate.
· %{dncn}—Issuee.
· %{dne}—Email.
· %{dno}—Company/Organization.
· %{dnou}—Department.
· %{dnc}—Country.
· %{dns}—State/Province.
· %{dnl}—City.
encode { base64 | url }: Specifies an encoding method for replacement strings. If you do not specify an encoding method, replacement strings are not encoded.
This command inserts the specified header to HTTP packets.
URL encoding encodes only special characters in replacement strings, for example, colons in IPv6 addresses. Base64 encoding encodes entire replacement strings.
# Insert the header named source with source IP address and source port number as the content to HTTP request packets for the HTTP LB action lba2.
[Sysname-lba-http-lba2] header insert request name source value %is:%ps
header insert response vary
Use header insert response vary to insert the Vary header into HTTP responses.
Use undo header insert response vary to remove the configuration.
The Vary header is inserted into HTTP responses.
This command inserts the Vary header to HTTP responses and sets the header content to Accept-Encoding before sending them to the client. The command takes effect regardless of whether the response packets contain the Vary header or whether the packets are compressed.
# Create the HTTP-compression parameter profile http1, and insert the Vary header into HTTP responses.
[Sysname-para-http-compression-http1] header insert response vary
header maxparse-length
Use header maxparse-length to set the maximum length of HTTP headers that can be parsed.
Use undo header maxparse-length to restore the default.
header maxparse-length length
The maximum length of HTTP headers that can be parsed is 4096.
length: Specifies the maximum length of HTTP headers that can be parsed, in the range of 1 to 65535.
This command is not supported by the virtual servers of the fast HTTP type.
# Set the maximum length of HTTP headers that can be parsed to 8192 for the HTTP parameter profile pp1.
[Sysname-para-http-pp1] header maxparse-length 8192
header modify per-request
Use header modify per-request to perform the insert, delete, or modify operation for the header of each HTTP request or response packet.
Use undo header modify per-request to restore the default.
The insert, delete, or modify operation is performed for the header of the first HTTP request or response packet of a connection.
# For the HTTP parameter profile pp1, perform the insert, delete, or modify operation for the header of each HTTP request or response packet.
[Sysname-para-http-pp1] header modify per-request
header rewrite
Use header rewrite to rewrite the HTTP header.
Use undo header rewrite to remove the configuration.
header rewrite { both | request | response } name header-name value value replace replace [ encode { base64 | url } ]
undo header rewrite { both | request | response } name header-name
The HTTP header is not rewritten.
HTTP LB action view
value value: Specifies the HTTP packet header content to be rewritten, a string of 1 to 127 characters. The string cannot contain question marks (?).
replace replace: Specifies the content after rewrite, a string of 1 to 127 characters. You can also specify the following replacement strings:
· %{dncn}—Issuee.
· %{dne}—Email.
· %{dnc}—Country.
· %{dnl}—City.
This command rewrites the value setting of the specified header in HTTP packets to the replace setting.
# For the HTTP LB action lba2, rewrite the content www.hello.com of the header named host in HTTP request packets to www.he.com.cn.
[Sysname-lba-http-lba2] header rewrite request name host value www/.(he)(llo)/.com replace www.%1.com.cn encode url
header rewrite request url
Use header rewrite request url to rewrite the URL in HTTP requests.
Use undo header rewrite request url to restore the default.
header rewrite request url value value replace replace [ encode { base64 | url } ]
The URL in HTTP requests is not rewritten.
HTTP LB action view
value value: Specifies the URL to be rewritten, a string of 1 to 127 characters. The string cannot contain question marks (?).
replace replace: Specifies the URL after rewrite, a string of 1 to 127 characters. You can also specify the following replacement strings:
· %{dncn}—Issuee.
· %{dne}—Email.
· %{dnc}—Country.
· %{dnl}—City.
This command rewrites the value setting in the HTTP request URL to the replace setting.
# For the HTTP LB action lba2, rewrite the URL www.hello.com in HTTP requests to www.he.com.cn.
[Sysname-lba-http-lba2] header rewrite request url value www/.(he)(llo)/.com replace www.%1.com.cn encode url
idle-time
Use idle-time to set the idle timeout time for TCP connections between the LB device and servers.
Use undo idle-time to restore the default.
idle-time idle-time
undo idle-time
The idle timeout time for TCP connections between the LB device and servers is 86400 seconds.
OneConnect parameter profile view
idle-time: Specifies the idle timeout time in the range of 1 to 4294967295 seconds.
The idle timeout time is the amount of time that a TCP connection can stay idle before it is disconnected. After the TCP connection is disconnected, new connection requests trigger establishment of a new TCP connection.
# In OneConnect parameter profile ocp, set the idle timeout time to 10000 seconds for TCP connections between the LB device and servers.
[Sysname] parameter-profile ocp type oneconnect
[Sysname-para-oneconnect-ocp] idle-time 10000
inherit vpn-instance disable (link view)
Use inherit vpn-instance disable to disable VPN instance inheritance for a link.
Use undo inherit vpn-instance disable to enable VPN instance inheritance for a link.
VPN instance inheritance is enabled for a link.
Link view
When VPN instance inheritance is enabled, a link without a VPN instance specified inherits the VPN instance of the virtual server. When VPN instance inheritance is disabled, a link without a VPN instance specified belongs to the public network.
To specify a VPN instance for a link, use the vpn-instance vpn-instance-name command in link view.
You can display the VPN instance for a link by using the display loadbalance link command.
# Disable VPN instance inheritance for link lk1.
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] inherit vpn-instance disable
vpn-instance (link view)
inherit vpn-instance disable (real server view)
Use inherit vpn-instance disable to disable VPN instance inheritance for a real server.
Use undo inherit vpn-instance disable to enable VPN instance inheritance for a real server.
VPN instance inheritance is enabled for a real server.
Real server view
When VPN instance inheritance is enabled, a real server without a VPN instance specified inherits the VPN instance of its virtual server. When VPN instance inheritance is disabled, a real server without a VPN instance specified belongs to the public network.
To specify a VPN instance for a real server, use the vpn-instance command in real server view.
# Disable VPN instance inheritance for real server rs.
[Sysname] real-server rs
[Sysname-rserver-rs] inherit vpn-instance disable
vpn-instance (real server view)
vpn-instance (virtual server view)
ip
Use ip to configure the IPv4 sticky method.
Use undo ip to restore the default.
ip [ port ] { both | destination | source } [ mask mask-length ]
undo ip
No IPv4 sticky method is configured.
Sticky group view
port: Specifies the sticky method as IPv4 address + port number. If you do not specify this keyword, the sticky method is IPv4 address.
both: Specifies the sticky method as source IPv4 address + destination IPv4 address (if you do not specify the port keyword), or source IPv4 address + source port number + destination IPv4 address + destination port number (if you specify the port keyword).
destination: Specifies the sticky method as destination IPv4 address if you do not specify the port keyword, or destination IPv4 address + destination port number if you specify the port keyword.
source: Specifies the sticky method as source IPv4 address if you do not specify the port keyword, or source IPv4 address + source port number if you specify the port keyword.
mask mask-length: Specifies the mask length for the sticky method.
# Configure the sticky method for the address and port-based sticky group sg1 as source IPv4 address.
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] ip source
# Configure the sticky method for the address and port-based sticky group sg1 as source IPv4 address + source port number.
[Sysname-sticky-address-port-sg1] ip port source
sticky-group
ip address (DNS server view)
Use ip address to specify an IPv4 address for a DNS server.
Use undo ip address to restore the default.
ip address ipv4-address
undo ip address
No IPv4 address is specified for a DNS server.
DNS server view
ipv4-address: Specifies an IPv4 address, which cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X.
# Specify the IPv4 address for DNS server ds1 as 1.2.3.4.
[Sysname-lb-ds-ds1] ip address 1.2.3.4
ip address (ISP view)
Use ip address to configure an IPv4 address for an ISP.
ip address ipv4-address { mask-length | mask }
undo ip address ipv4-address { mask-length | mask }
No IPv4 address is configured for an ISP.
ISP view
ipv4-address: Specifies an IPv4 address.
mask-length: Specifies the mask length for the IPv4 address, in the range of 0 to 32.
mask: Specifies the mask for the IPv4 address.
# Configure the IPv4 address for the ISP isp1 as 1.1.1.1.
[Sysname] loadbalance isp name isp1
[Sysname-lbisp-isp1] ip address 1.1.1.1 24
ip address (real server view)
Use ip address to configure an IPv4 address for a real server.
undo ip address
No IPv4 address is configured for a real server.
Real server view
# Configure the IPv4 address for the real server rs as 1.1.1.1.
[Sysname-rserver-rs] ip address 1.1.1.1
ip address (transparent DNS proxy view)
Use ip address to specify an IPv4 address for a transparent DNS proxy.
ip address ipv4-address [ mask-length | mask ]
undo ip address
No IPv4 address is specified for a transparent DNS proxy.
Transparent DNS proxy view
mask-length: Specifies a mask length in the range of 0 to 32.
mask: Specifies a subnet mask.
A transparent DNS proxy processes a DNS request only when the destination IP address and port number of the DNS request match those of the transparent DNS proxy.
If server load balancing is configured, configure different IP addresses and port numbers for the transparent DNS proxy and the virtual server of the UDP type.
# Specify the IPv4 address for transparent DNS proxy dns-proxy1 as 1.2.3.4/24.
[Sysname] loadbalance dns-proxy dns_proxy1
[Sysname-lb-dp-udp-dns-proxy1] ip address 1.2.3.4 24
ip mask
Use ip mask to set the mask length for IPv4 proximity entries.
Use undo ip mask to restore the default.
ip mask { mask-length | mask }
The mask length for IPv4 proximity entries is 24.
Proximity view
mask-length: Specifies the mask length for IPv4 proximity entries, in the range of 0 to 32. A value of 0 indicates the natural mask.
mask: Specifies the mask for IPv4 proximity entries.
# Set the mask length for IPv4 proximity entries to 30.
[Sysname] loadbalance proximity
[Sysname-lb-proximity] ip mask 30
ip range (SNAT address pool view)
Use ip range to specify an IPv4 address range for an SNAT address pool.
Use undo ip range to restore the default.
ip range start start-ipv4-address end end-ipv4-address
undo ip range
No IPv4 address range is specified for an SNAT address pool.
start start-ipv4-address: Specifies the start IPv4 address.
end end-ipv4-address: Specifies the end IPv4 address, which must be greater than or equal to the start IPv4 address.
An SNAT address pool can have a maximum of 256 IPv4 addresses. No overlapping IPv4 addresses are allowed in different SNAT address pools.
# Specify IPv4 address range 1.1.1.1 to 1.1.1.100 for the SNAT address pool lbsp.
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] ip range start 1.1.1.1 end 1.1.1.100
ip source mask
Use ip source mask to specify the IPv4 mask for connection reuse.
Use undo ip source mask to restore the default.
ip source mask { mask-length | mask }
undo ip source mask
The IPv4 mask for connection reuse is the natural mask.
mask-length: Specifies the mask length in the range of 0 to 32. A value of 0 indicates the natural mask.
mask: Specifies the subnet mask in dotted decimal notation.
This command limits the network segment of clients that can reuse connections between the LB device and servers. If the client that initiates a connection request is in the same network segment as the idle TCP connection, the idle TCP connection is reused. If the client does not match this requirement, a new TCP connection is established.
# In OneConnect parameter profile ocp, set the mask length for connection reuse to 24.
[Sysname-para-oneconnect-ocp] ip source mask 24
ipv6
Use ipv6 to configure the IPv6 sticky method.
Use undo ipv6 to restore the default.
ipv6 [ port ] { both | destination | source } [ prefix prefix-length ]
undo ipv6
No IPv6 sticky method is configured.
Sticky group view
port: Specifies the sticky method as IPv6 address + port number. If you do not specify this keyword, the sticky method is IPv6 address.
both: Specifies the sticky method as source IPv6 address + destination IPv6 address if you do not specify the port keyword, or source IPv6 address + source port number + destination IPv6 address + destination port number if you specify the port keyword.
destination: Specifies the sticky method as destination IPv6 address if you do not specify the port keyword, or destination IPv6 address + destination port number if you specify the port keyword.
source: Specifies the sticky method as source IPv6 address if you do not specify the port keyword, or source IPv6 address + source port number if you specify the port keyword.
prefix prefix-length: Specifies the prefix length for the sticky method.
# Configure the sticky method for the address- and port-based sticky group sg1 as source IPv6 address.
[Sysname-sticky-address-port-sg1] ipv6 source
# Configure the sticky method for the address- and port-based sticky group sg1 as source IPv6 address + source port number.
[Sysname-sticky-address-port-sg1] ipv6 port source
sticky-group
ipv6 address (transparent DNS proxy view)
Use ipv6 address to configure an IPv6 address for a transparent DNS proxy.
Use undo ipv6 address to restore the default.
ipv6 address ipv6-address [ prefix-length ]
undo ipv6 address
No IPv6 address is configured for a transparent DNS proxy.
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address (If the prefix length is 0, you can specify the all-zero address.).
prefix-length: Specifies a prefix length for the IPv6 address, in the range of 0 to 128.
# Configure the IPv6 address for transparent DNS proxy dns-proxy1 as 1::2:3/112.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] ipv6 address 1::2:3 112
ipv6 address (DNS server view)
Use ipv6 address to configure an IPv6 address for a DNS server.
undo ipv6 address
No IPv6 address is configured for a DNS server.
DNS server view
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address.
# Configure the IPv6 address for DNS server ds1 as 1001::1.
[Sysname-lb-ds-ds1] ipv6 address 1001::1
ipv6 address (ISP view)
Use ipv6 address to configure an IPv6 address for an ISP.
ipv6 address ipv6-address prefix-length
undo ipv6 address ipv6-address prefix-length
No IPv6 address is configured for an ISP.
ISP view
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies the prefix length for the IPv6 address, in the range of 1 to 128.
# Configure the IPv6 address for the ISP isp1 as 200::1.
[Sysname-lbisp-isp1] ipv6 address 200::1 100
ipv6 address (real server view)
Use ipv6 address to configure an IPv6 address for a real server.
undo ipv6 address
No IPv6 address is configured for a real server.
Real server view
# Configure the IPv6 address for the real server rs as 1001::1.
[Sysname-rserver-rs] ipv6 address 1001::1
ipv6 prefix
Use ipv6 prefix to configure the prefix length for IPv6 proximity entries.
Use undo ipv6 prefix to restore the default.
ipv6 prefix prefix-length
The prefix length for IPv6 proximity entries is 96.
Proximity view
prefix-length: Specifies the prefix length for IPv6 proximity entries, in the range of 1 to 128.
# Specify the prefix length for IPv6 proximity entries as 64.
[Sysname-lb-proximity] ipv6 prefix 64
ipv6 range
Use ip range to specify an IPv6 address range for an SNAT address pool.
ipv6 range start start-ipv6-address end end-ipv6-address
undo ipv6 range
No IPv6 address range is specified for an SNAT address pool.
start start-ipv6-address: Specifies the start IPv6 address.
end end-ipv6-address: Specifies the end IPv6 address, which must be greater than or equal to the start IPv6 address.
An SNAT address pool can have a maximum of 65536 IPv6 addresses. No overlapping IPv6 addresses are allowed in different SNAT address pools.
# Specify IPv6 address range 1001::1 to 1001::100 for the SNAT address pool lbsp.
[Sysname-lbsnat-pool-lbsp] ipv6 range start 1001::1 end 1001::100
ipv6 source prefix
Use ipv6 source prefix to specify the IPv6 prefix length for connection reuse.
Use undo ipv6 source prefix to restore the default.
ipv6 source prefix prefix-length
Client IPv6 addresses with a prefix length of 0 can reuse connections.
prefix-length: Specifies the prefix length in the range of 0 to 128.
# In OneConnect parameter profile ocp, set the prefix length for connection reuse to 24.
[Sysname-para-oneconnect-ocp] ipv6 source prefix 24
isp
Use isp to add an ISP to a region.
Use undo isp to delete an ISP from a region.
isp isp-name
undo isp isp-name
A region does not contain any ISPs.
Region view
isp-name: Specifies an ISP by its name, a case-insensitive string of 1 to 63 characters.
# Add the ISP isp-ct to the region region-ct.
[Sysname] loadbalance region region-ct
[Sysname-lb-region-region-ct] isp isp-ct
loadbalance region
keepalive idle-timeout
Use keepalive idle-timeout to set the idle timeout time for sending keepalive packets.
Use undo keepalive idle-timeout to restore the default.
keepalive idle-timeout timeout-value
The idle timeout time for sending keepalive packets is 10 seconds.
timeout-value: Specifies the idle timeout time for sending keepalive packets, in the range of 1 to 65535 seconds.
# Set the timeout time for sending keepalive packets to 5 seconds in the TCP parameter profile profile.
[Sysname-para-tcp-profile] keepalive idle-timeout 5
display parameter-profile
keepalive retransmission interval
Use keepalive retransmission interval to set the retransmission interval and retransmission times for keepalive packets.
Use undo keepalive retransmission interval to restore the default.
keepalive retransmission interval interval count count
The retransmission interval is 3 seconds, and the retransmission times is 3.
interval: Specifies the retransmission interval for keepalive packets, in the range of 1 to 65535 seconds.
count: Specifies the retransmission times for keepalive packets, in the range of 1 to 65535.
# Set the retransmission interval and retransmission times for keepalive packets to 5 seconds and 10, respectively, in the TCP parameter profile profile.
[Sysname-para-tcp-profile] keepalive retransmission interval 5 count 10
lb-limit-policy
Use lb-limit-policy to apply an LB connection limit policy to a virtual server.
Use undo lb-limit-policy to restore the default.
lb-limit-policy policy-name
No LB connection limit policies are applied to a virtual server.
Virtual server view
policy-name: Specifies an LB connection limit policy by its name, a case-insensitive string of 1 to 63 characters.
Use this command to implement rate limit for user traffic.
This command takes effect only on new sessions and does not take effect on existing sessions.
# Apply the LB connection limit policy llp to the HTTP-type virtual server vs.
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs]lb-limit-policy llp
loadbalance limit-policy
lb-policy (transparent DNS proxy view)
Use lb-policy to specify an LB policy to be referenced by a transparent DNS proxy.
Use undo lb-policy to restore the default.
lb-policy policy-name
undo lb-policy
No LB policy is referenced by a transparent DNS proxy.
policy-name: Specifies an LB policy by its name, a case-insensitive string of 1 to 63 characters.
By referencing an LB policy, a transparent DNS proxy implements load balancing for matching packets based on the packet contents.
A transparent DNS proxy can reference only a DNS policy template.
# Specify the LB policy dns-policy1 to be referenced by transparent DNS proxy dns-proxy1.
[Sysname-lb-dp-udp-dns-proxy1] lb-policy dns-policy1
lb-policy (virtual server view)
Use lb-policy to specify an LB policy to be referenced by the specified virtual server.
undo lb-policy
No LB policy is referenced by a virtual server.
Virtual server view
By referencing an LB policy, the virtual server implements load balancing for matching packets based on the packet contents.
A virtual server can reference the policy template of the specified type. For example, a virtual server of the fast HTTP or HTTP type can reference a policy template of the generic type or HTTP type. A virtual server of the IP, SIP, TCP, or UDP type can reference a policy template of the generic type only.
# Specify the LB policy lbp1 to be referenced by the IP-type virtual server vs3.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] lb-policy lbp1
limit
Use limit to configure an LB connection limit rule.
Use undo limit to delete an LB connection limit rule.
limit limit-id acl [ ipv6 ] { acl-number | name acl-name } [ per-destination | per-service | per-source ] * amount max-amount min-amount
undo limit limit-id
No rules are configured for an LB connection limit policy.
LB connection limit policy view
limit-id: Specifies an LB connection limit rule ID. The value range for this argument is 1 to 65535.
acl: Specifies an ACL to limit user connections of a specified user range.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the command uses an IPv4 ACL.
acl-number: Specifies the ACL number in the range of 2000 to 3999.
name acl-name: Specifies an ACL by its name.
per-destination: Limits user connections by destination IP address.
per-service: Limits user connections by service. Services are classified by transport layer protocol and service port number.
per-source: Limits user connections by source IP address.
max-amount: Specifies the upper limit of connections, in the range of 1 to 4294967295. When the number of connections in a specified range or for a certain type reaches the upper limit, the device does not accept new connection requests.
min-amount: Specifies the lower limit of connections, in the range of 1 to 4294967295. The min-amount must be equal to or smaller than the max-amount. The device accepts new connection requests only when the number of connections drops below the lower limit.
An LB connection limit policy can have multiple rules. You can specify an ACL, a type, and the upper and lower limits for each rule. You can specify one or more of the per-destination, per-service, and per-source keywords for the command. For example, you can specify both the per-destination and per-source keywords to limit user connections by destination address and source address of packets.
You must specify a different ACL for each rule in an LB connection limit policy.
If the per-destination, per-service, and per-source keywords are not specified, the command limits all user connections matching the specified ACL.
The rules in an LB connection limit policy are matched in ascending order of the rule IDs until a match is found.
When the specified ACL changes, the device uses a new LB connection limit policy to process existing connections again.
# Configure rule 1 for the LB connection limit policy 1. Use ACL 3000 to permit user connections sourced from the network 192.168.0.0/24, and set the upper and lower limits to 2000 and 1800 for the user connections by source and destination addresses.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source 192.168.0.0 0.0.0.255
[Sysname] loadbalance limit-policy 1
[Sysname-lb-limit-policy-1] limit 1 acl 3000 per-destination per-source amount 2000 1800
link (DNS server view)
Use link to associate a link with a DNS server.
Use undo link to restore the default.
link link-name
undo link
No link is associated with a DNS server.
DNS server view
link-name: Specifies a link by its name, a case-insensitive string of 1 to 63 characters.
A DNS server can be associated with only one link. A link can be associated with multiple DNS servers.
# Associate link link1 with DNS server ds1.
[Sysname-lb-ds-ds1] link link1
link (link group view)
Use link to create a link group member and enter its view, or enter the view of an existing link group member.
Use undo link to delete a link group member.
link link-name
undo link link-name
No link group members exist.
Link group view
link-name: Specifies a link group member name, a case-insensitive string of 1 to 63 characters.
You can use one of the following methods to add a member to a link group:
· Use the link command in link group view. H3C recommends using this method.
· Use the link-group command in link view.
You cannot use both methods to add a member with the same link name to a link group.
# Add link group member lk1 and enter link group member view.
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1]
link-group (link view)
Use link-group to specify the primary link group.
Use undo link-group to restore the default.
link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
undo link-group
No primary link group is specified.
LB action view
link-group-name: Specifies a primary link group name, a case-insensitive string of 1 to 63 characters.
backup backup-link-group-name: Specifies a backup link group name, a case-insensitive string of 1 to 63 characters.
sticky sticky-name: Specifies the name of the sticky group corresponding to the link group. It is a case-insensitive string of 1 to 63 characters.
The link-group and forward all commands are mutually exclusive. If you configure one command, the other command (if configured) is automatically cancelled.
When the primary link group is available (contains links), packets are forwarded through the primary link group. When the primary link group is not available, packets are forwarded through the backup link group.
# Specify the primary link group lg, the backup link group lgb, and the sticky group sg1 for the link-generic LB action lba1.
[Sysname] loadbalance action lba1 type link-generic
[Sysname-lba-link-generic-lba1] server-farm sf backup sfb sticky sg1
forward all
Use link-group to specify a link group for a link.
undo link-group
A link does not belong to any link group.
Link view
link-group-name: Specifies a link group name, a case-insensitive string of 1 to 63 characters.
The device selects the best link from the matching link group to perform link load balancing.
# Specify the link group lkg1 for the link lk1.
[Sysname-lb-link-lk1] link-group lkg1
loadbalance action
Use loadbalance action to create an LB action and enter its view, or enter the view of an existing LB action.
Use undo loadbalance action to delete the specified LB action.
loadbalance action action-name [ type { dns | generic | http | link-generic | radius } ]
undo loadbalance action action-name
No LB actions exist.
action-name: Specifies the LB action name, a case-insensitive string of 1 to 63 characters.
type { dns | generic | http | link-generic | radius }: Specifies an LB action type.
· dns: DNS load balancing action.
· generic: Generic server load balancing action.
· http: HTTP load balancing action.
· link-generic: Link load balancing action.
· radius: RADIUS load balancing action.
When you create an LB action, you must specify the LB action type. You can enter an existing LB action view without entering the type of the LB action.
# Create the LB action lba1 with the generic type, and enter LB action view.
loadbalance alg
Use loadbalance alg to enable ALG for the specified protocols.
Use undo loadbalance alg to disable ALG for the specified protocols.
loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
ALG is enabled for the DNS, FTP, PPTP, and RTSP protocols and ICMP error packets.
dns: Specifies the DNS protocol.
ftp: Specifies the FTP protocol.
h323: Specifies the H.323 protocol.
icmp-error: Specifies the ICMP error packets.
ils: Specifies the Internet Locator Service (ILS) protocol.
mgcp: Specifies the Media Gateway Control Protocol (MGCP).
nbt: Specifies the NetBIOS over TCP/IP (NBT) protocol.
pptp: Specifies the Point-to-Point Tunneling Protocol (PPTP).
rsh: Specifies the Remote Shell (RSH) protocol.
rtsp: Specifies the Real Time Streaming Protocol (RTSP).
sccp: Specifies the Skinny Client Control Protocol (SCCP).
sip: Specifies the Session Initiation Protocol (SIP).
sqlnet: Specifies the SQLNET protocol.
tftp: Specifies the TFTP protocol.
xdmcp: Specifies the X Display Manager Control Protocol (XDMCP).
The ALG feature distributes parent and child sessions to the same link.
# Enable ALG for TFTP.
[Sysname] loadbalance alg tftp
loadbalance alg all-enable
Use loadbalance alg all-enable to enable ALG for all protocols.
Use loadbalance alg all-disable to disable ALG for all protocols.
# Enable ALG for all protocols.
[Sysname] loadbalance alg all-enable
loadbalance class
Use loadbalance class to create an LB class and enter its view, or enter the view of an existing LB class.
Use undo loadbalance class to delete the specified LB class.
loadbalance class class-name [ type { dns | generic | http | link-generic | radius } [ match-all | match-any ] ]
undo loadbalance class class-name
No LB classes exist.
class-name: Specifies the LB class name, a case-insensitive string of 1 to 63 characters.
type { dns | generic | http | link-generic | radius }: Specifies an LB class type.
· dns: DNS load balancing class.
· generic: Generic server load balancing class.
· http: HTTP load balancing class.
· link-generic: Link load balancing class.
· radius: RADIUS load balancing class.
[ match-all | match-any ]: Requires matching all rules or any rule of the LB class. match-all is the default match mode.
When you create an LB class, you must specify an LB class type. You can enter an existing LB class view without entering the type of the LB class.
# Create the LB class lbc1 with the generic type, and enter LB class view.
[Sysname] loadbalance class lbc1 type generic
[Sysname-lbc-generic-lbc1]
loadbalance dns-cache aging-time
Use loadbalance dns-cache aging-time to set the aging time for DNS cache entries.
Use undo loadbalance dns-cache aging-time to restore the default.
loadbalance dns-cache aging-time aging-time
The aging time for DNS cache entries is 60 minutes.
aging-time: Specifies the aging time for DNS cache entries, in the range of 1 to 1440 minutes.
# Set the aging time for DNS cache entries to 100 minutes.
[Sysname] loadbalance dns-cache aging-time 100
Use loadbalance dns-proxy to create a transparent DNS proxy and enter its view, or enter the view of an existing transparent DNS proxy.
Use undo loadbalance dns-proxy to delete a transparent DNS proxy.
loadbalance dns-proxy dns-proxy-name type udp
undo loadbalance dns-proxy dns-proxy-name
No transparent DNS proxies exist.
dns-proxy-name: Specifies the transparent DNS proxy name, a case-insensitive string of 1 to 63 characters.
type udp: Specifies the transparent DNS proxy type as UDP.
# Create the UDP transparent DNS proxy dns-proxy1, and enter UDP transparent DNS proxy view.
[Sysname] loadbalance dns-proxy dns-proxy1 type udp
display loadbalance dns-proxy
Use loadbalance dns-server to create a DNS server and enter its view, or enter the view of an existing DNS server.
Use undo loadbalance dns-server to delete a DNS server.
loadbalance dns-server dns-server-name
undo loadbalance dns-server dns-server-name
No DNS servers exist.
dns-server-name: Specifies the DNS server name, a case-insensitive string of 1 to 63 characters.
# Create the DNS server ds1, and enter DNS server view.
[Sysname-lb-ds-ds1]
Use loadbalance dns-server-pool to create a DNS server pool and enter its view, or enter the view of an existing DNS server pool.
Use undo loadbalance dns-server-pool to delete a DNS server pool.
loadbalance dns-server-pool pool-name
undo loadbalance dns-server-pool pool-name
No DNS server pools exist.
pool-name: Specifies the DNS server pool name, a case-insensitive string of 1 to 63 characters.
# Create the DNS server pool dns-pool1, and enter DNS server pool view.
[Sysname] loadbalance dns-server-pool dns-pool1
[Sysname-lb-dspool-dns-pool1]
loadbalance isp auto-update enable
Use loadbalance isp auto-update enable to enable ISP auto update.
Use undo loadbalance isp auto-update enable to disable ISP auto update.
ISP auto update is disabled.
With ISP auto update enabled, the device regularly queries IP address information from the whois server according to the whois maintainer object of the ISP.
# Enable ISP auto update.
[Sysname] loadbalance isp auto-update enable
loadbalance isp auto-update frequency
loadbalance isp auto-update whois-server
Use loadbalance isp auto-update frequency to configure the ISP auto update frequency.
Use undo loadbalance isp auto-update frequency to restore the default.
loadbalance isp auto-update frequency { per-day | per-week | per-month }
The ISP auto update is performed once per week.
per-day: Updates ISP address information once per day.
per-week: Updates ISP address information once per week.
per-month: Updates ISP address information once per month.
The specific update time is about 04:00:00 a.m. For the first auto update, the specific update time is 04:00:00 a.m on the next day.
# Configure the ISP auto update frequency as per day.
[Sysname] loadbalance isp auto-update frequency per-day
Use loadbalance isp auto-update whois-server to specify the whois server to be queried for ISP auto update.
Use undo loadbalance isp auto-update whois-server to restore the default.
loadbalance isp auto-update whois-server { domain domain-name | ip ip-address }
No whois server is specified for ISP auto update.
domain domain-name: Specify a whois server by its domain name, a case-insensitive, dot-separated string of 1 to 253 characters (for example, aabbcc.com). Each dot-separated part in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), and periods (.).
ip ip-address: Specify a whois server by its IPv4 address.
# Specify the whois server with IP address 20.1.1.1 for ISP auto update.
[Sysname] loadbalance isp auto-update whois-server ip 20.1.1.1
loadbalance isp file
Use loadbalance isp file to import an ISP file.
Use undo loadbalance isp file to delete an ISP file.
loadbalance isp file isp-file-name
isp-file-name: Specifies the ISP file name, a case-insensitive string of 1 to 255 characters.
The system keeps the imported information intact when detecting the following problems:
· The file does not exist.
· The file name is invalid.
· File decryption occurs.
If the system quits the import operation because of IP address parsing failure, the system performs the following operations:
· Clears the most recently imported information.
· Saves the information imported this time.
You cannot delete the imported ISP and its IPv4 or IPv6 address. If the manually configured and imported ISP information overlaps, you can delete the manually configured ISP information.
To perform an active/standby MPU switchover, make sure the standby MPU has the same ISP file as the active MPU.
# Import the ISP file isp2.
[Sysname] loadbalance isp file isp2
Use loadbalance isp name to create an ISP and enter its view, or enter the view of an existing ISP.
Use undo loadbalance isp name to delete the specified ISP.
loadbalance isp name isp-name
undo loadbalance isp name isp-name
No ISPs exist.
isp-name: Specifies the ISP name, a case-insensitive string of 1 to 63 characters.
# Create ISP isp1, and enter ISP view.
Use loadbalance limit-policy to create an LB connection limit policy and enter its view, or enter the view of an existing LB connection limit policy.
Use undo loadbalance limit-policy to delete an LB connection limit policy.
loadbalance limit-policy policy-name
undo loadbalance limit-policy policy-name
No LB connection limit policies exist.
policy-name: Specifies the LB connection limit policy name, a case-insensitive string of 1 to 63 characters.
Using an LB connection limit policy can limit the number of connections on the device. It helps prevent a large number of connections from consuming too many device system resources and server resources. In this way, internal network resources (hosts or servers) are protected, and device system resources can be used more appropriately.
# Create the LB connection limit policy llp, and enter LB connection limit policy view.
[Sysname] loadbalance limit-policy llp
[Sysname-lb-limit-policy-llp]
loadbalance link
Use loadbalance link to create an LB link and enter its view, or enter the view of an existing LB link.
Use undo loadbalance link to delete an LB link.
loadbalance link link-name
undo loadbalance link link-name
No LB links exist.
link-name: Specifies the LB link name, a case-insensitive string of 1 to 63 characters.
Each physical link connected to the external network corresponds to an LB link.
# Create the LB link lk1, and enter LB link view.
Use loadbalance link-group to create a link group and enter its view, or enter the view of an existing link group.
Use undo loadbalance link-group to delete a link group.
loadbalance link-group link-group-name
undo loadbalance link-group link-group-name
No link groups exist.
link-group-name: Specifies the link group name, a case-insensitive string of 1 to 63 characters.
You can add links that contain similar functions to a link group to facilitate management.
# Create the link group lg, and enter link group view.
loadbalance log enable bandwidth-busy
Use loadbalance log enable bandwidth-busy to enable load balancing link busy state logging.
Use undo loadbalance log enable bandwidth-busy to disable load balancing link busy state logging.
Load balancing link busy state logging is disabled.
Load balancing link busy state logging records busy states for all links.
# Enable load balancing link busy state logging.
[Sysname] loadbalance log enable bandwidth-busy
loadbalance log enable base
Use loadbalance log enable base to enable load balancing basic logging.
Use undo loadbalance log enable base to disable load balancing basic logging.
Load balancing basic logging is enabled.
Load balancing basic logging generates logs for the following events:
· The state of a real server, real server group, link, or link group changes.
· The health monitoring result of a real server or link changes.
· The number of connections on a real server, virtual server, or link reaches or drops below the upper limit.
· The connection establishment rate on a real server, virtual server, or link reaches or drops below the upper limit.
· A primary/backup server farm switchover occurs between server farms specified for a virtual server.
· A primary/backup link group switchover occurs between link groups specified for a virtual server.
· A primary/backup server farm switchover occurs between server farms specified for an LB action.
· A primary/backup link group switchover occurs between link groups specified for an LB action.
# Enable load balancing basic logging.
[Sysname] loadbalance log enable base
loadbalance log enable nat
Use loadbalance log enable nat to enable load balancing NAT logging.
Use undo loadbalance log enable nat to disable load balancing NAT logging.
Load balancing NAT logging is disabled.
Load balancing NAT logging records NAT session information, including IP address and port translation information and access information.
# Enable load balancing NAT logging.
[Sysname] loadbalance log enable nat
loadbalance policy
Use loadbalance policy to create an LB policy and enter its view, or enter the view of an existing LB policy.
Use undo loadbalance policy to delete the specified LB policy.
loadbalance policy policy-name [ type { dns | generic | http | link-generic | radius } ]
undo loadbalance policy policy-name
No LB policies exist.
policy-name: Specifies the LB policy name, a case-insensitive string of 1 to 63 characters.
type { dns | generic | http | link-generic | radius }: Specifies an LB policy type.
· dns: DNS load balancing policy.
· generic: Generic server load balancing policy.
· http: HTTP load balancing policy.
· link-generic: Link load balancing policy.
· radius: RADIUS load balancing policy.
When you create an LB policy, you must specify the LB policy type. You can enter existing LB policy view without entering the type of the LB policy.
# Create the LB policy lbp1 with the generic type, and enter LB policy view.
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1]
Use loadbalance probe-template to create an LB probe template and enter its view, or enter the view of an existing LB probe template.
Use undo loadbalance probe-template to delete an LB probe template.
loadbalance probe-template { icmp | tcp-rst | tcp-zero-window } template-name
undo loadbalance probe-template { icmp | tcp-rst | tcp-zero-window } template-name
No LB probe templates exist.
icmp: Specifies the ICMP-type template.
tcp-rst: Specifies the TCP-RST template.
tcp-zero-window: Specifies the TCP zero-window template.
template-name: Specifies a template name, a case-insensitive string of 1 to 32 characters.
The proximity feature can use an ICMP LB probe template to start ICMP tests and identify the reachability of hosts according to received ICMP responses.
A server farm can use a TCP-RST or TCP zero-window LB probe template to count the number of RST packets or zero-window packets sent by each server farm member.
# Create an LB probe template named icmptplt, and enter LB probe template view.
[Sysname-lbpt-icmp-icmptplt]
Use loadbalance proximity to create proximity and enter its view, or enter the view of the existing proximity.
Use undo loadbalance proximity to delete proximity view and clear all configuration in proximity view.
loadbalance proximity [ vpn-instance vpn-instance-name ]
undo loadbalance proximity [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command is executed for the public network.
# Create and enter proximity view for the VPN instance vpn1.
[Sysname] loadbalance proximity vpn vpn1
[Sysname-lb-proximity-vpn1]
loadbalance region
Use loadbalance region to create a region and enter its view, or enter the view of an existing region.
Use undo loadbalance region to delete a region.
loadbalance region region-name
undo loadbalance region region-name
No regions exist.
region-name: Specifies the region name, a case-insensitive string of 1 to 63 characters.
A region contains network segments corresponding to different ISPs.
# Create the region isp-ct, and enter region view.
[Sysname] loadbalance region isp-ct
[Sysname-lb-region-isp-ct]
loadbalance schedule-test ip
Use loadbalance schedule-test ip to perform an IPv4 load balancing test.
In standalone mode:
loadbalance schedule-test ip [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmp | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port
In IRF mode:
loadbalance schedule-test ip [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmp | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ slot slot-number ]
application: Specifies an application to be tested.
http: Specifies the HTTP application.
message-file file-name: Specifies the file that contains HTTP packet contents. The file name is a case-insensitive string of 1 to 255 characters. The file size cannot exceed 5000 bytes.
method: Specifies an HTTP request method.
get: Specifies the GET method.
post: Specifies the POST method.
url url: Specifies a URL for the HTTP packet, a case-insensitive string of 1 to 255 characters. A URL can contain letters, digits, hyphens (-), underscores (_), and periods (.). The URL cannot contain consecutive periods.
[ header header ]&<1-10>: Specifies a space-separated list of up to 10 HTTP packet headers. A header is a string of 1 to 127 characters excluding question marks (?).
content content-value: Specifies the content of the HTTP packet body, a string of 1 to 255 characters excluding question marks (?).
protocol { protocol-number | icmp | tcp | udp }: Specifies a protocol by its number in the range of 0 to 255 or by its name. For ICMP (1), TCP (6), and UDP (17), you can enter the protocol number or protocol name.
destination destination-address: Specifies the destination IPv4 address.
destination-port destination-port: Specifies the destination port number in the range of 0 to 65535. This option is not supported by some protocols.
source source-address: Specifies the source IPv4 address.
source-port source-port: Specifies the source port number in the range of 0 to 65535. This option is not supported by some protocols.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command tests all member devices. (In IRF mode.)
# Perform an IPv4 load balancing test for the TCP protocol.
Matched virtual server: vs2
Matched default server farm: sf
Forward type: Forwarding to real server
Selected real server: rs2
Scheduling algorithm: Predictor
<Sysname> loadbalance schedule-test ip protocol tcp destination 7.7.7.7 destination-port 4 source 2.2.2.2 source-port 5
Matched default link group: lg
Forward type: Forwarding to link
Selected link: link2
Table 27 Command output
Forwarding mode: · The destination address is not supported. Load balancing is not performed. · Matching HTTP virtual server is not supported—An HTTP virtual server is matched. Load balancing is not supported. · Forward all—Forwards packets. · Forwarding to real server—Forwards packets to the real server. · Forwarding to link—Forwards packets to the link. · Drop—Drops packets. · Redirect—Redirects packets. · Waiting—Enqueues packets. |
Packet drop reason: · Number of connections or bandwidth for the virtual server exceeded the limit. · No class matched and no valid default server farm/link group configured. · No valid real server/link in the server farm/link group. · Action is drop. · A sticky entry was matched but the number of connections or bandwidth for the real server/link exceeded the limit. · A class was matched but no valid server farm/link group exists in the action of the class. · The HTTP message is not valid. · The HTTP request line is not valid. · The HTTP header is not valid. · The chunk HTTP content is not valid. · The server farm is busy. · Queue overflow (which means the wait queue is full). |
Scheduling algorithm used to select the real server or link: · Predicator—The real server or link is selected by using the scheduling algorithm. · Sticky method—The real server or link is selected by using the sticky method. · Proximity—The link is selected by using the proximity feature. |
loadbalance schedule-test ipv6
Use loadbalance schedule-test ipv6 to perform an IPv6 load balancing test.
In standalone mode:
loadbalance schedule-test ipv6 [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmpv6 | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port
In IRF mode:
loadbalance schedule-test ipv6 [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmpv6 | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ slot slot-number ]
protocol { protocol-number | icmpv6 | tcp | udp }: Specifies a protocol by its number in the range of 0 to 255 or by its name. For ICMPv6 (58), TCP (6), and UDP (17), you can enter the protocol number or protocol name.
destination destination-address: Specifies the destination IPv6 address.
source source-address: Specifies the source IPv6 address.
# Schedule an IPv6 load balancing test for the ICMPv6 protocol.
<Sysname> loadbalance schedule-test ipv6 protocol icmpv6 destination 10::1 source 12::2
Table 28 Command output
Forward type |
Forwarding mode: · The destination address is not supported. Load balancing is not performed. · Matching HTTP virtual server is not supported—An HTTP virtual server is matched. Load balancing is not supported. · Forward all—Forwards packets. · Forwarding to real server/link—Forwards packets to the real server or link. · Drop—Drops packets. · Redirect—Redirects packets. · Waiting—Enqueues packets. |
Drop reason |
Scheduling algorithm |
Use loadbalance snat-pool to create an SNAT address pool and enter its view, or enter the view of an existing SNAT address pool.
Use undo loadbalance snat-pool to delete the specified SNAT address pool.
loadbalance snat-pool pool-name
undo loadbalance snat-pool pool-name
No SNAT address pools exist.
pool-name: Specifies the SNAT address pool name, a case-insensitive string of 1 to 63 characters.
# Create the SNAT address pool lbsp, and enter SNAT address pool view.
loadbalance test pcre
Use loadbalance test pcre to perform a PCRE regular expression match test and display the match result.
loadbalance test pcre value value { string string | file file-name } [ offset offset ] [ case-insensitive ]
value value: Specifies a PCRE regular expression, a string of 1 to 255 characters excluding question marks (?).
string string: Specifies the string to be tested. The string can contain 1 to 255 characters.
file file-name: Specifies the file to be tested by its name, a case-insensitive string of 1 to 255 characters. The file size cannot exceed 5000 bytes.
offset offset: Specifies the offset from the content to be tested, in the range of 0 to 255. The default is 0.
case-insensitive: Enables case-insensitivity matching. If you do not specify this keyword, case-sensitivity matching applies.
If the specified string or file matches the PCRE regular expression multiple times, the device displays only the result of the first match.
For a string test, the device displays the match result in text strings. For a file test, the device displays the match result in both hexadecimal characters and text strings. Characters that cannot be displayed are represented as periods (.).
# Perform a PCRE regular expression match test for string ABCDAAaefg.
<Sysname> loadbalance test pcre value aaa string ABCDAAaefg case-insensitive
Matched string content: AAa
# Perform a PCRE regular expression match test for file 123.txt.
<Sysname> loadbalance test pcre value dzckgjlfdsfdsfsdnfsdkjgnf file 123.txt
Matched file content:
64 7a 63 6b 67 6a 6c 66 64 73 66 64 73 66 73 64 dzckgjlf dsfdsfsd
6e 66 73 64 6b 6a 67 6e 66 64 nfsdkjgn f
loadbalance test rewrite
Use loadbalance test rewrite to perform a regular-expression-based rewrite test and display the rewrite result.
loadbalance test rewrite value value replace replace-string { string string | file file-name } [ offset offset ] [ case-insensitive ]
value value: Specifies a regular expression to match the content to be rewritten, a string of 1 to 255 characters excluding question marks (?). You can also specify the following character strings:
· %is—Source IP address.
· %ps—Source port number.
· %id—Destination IP address.
· %pd—Destination port number.
replace replace-string: Specifies the content after rewrite, a string of 1 to 255 characters.
offset offset: Specifies the offset from the content to be tested, in the range of 0 to 255 bytes. The default is 0.
If the string or file to be tested matches the regular expression, the device replaces the matching content with the content after rewrite.
If the string or file matches the regular expression multiple times, the device displays only the rewrite result of the first match.
For a string test, the device displays the rewrite result in text strings. For a file test, the device displays the rewrite result in both hexadecimal characters and text strings. Characters that cannot be displayed are represented as periods (.).
# Perform a rewrite test for string ABCDAAaefg.
<Sysname> loadbalance test rewrite value %id replace ip:%id,port:%pd string ABCDAAaefg case-insensitive
Rewritten string content: ABCD172.0.0.1fg
# Perform a rewrite test for file 123.txt.
<Sysname> loadbalance test rewrite value dzckgjlfdsfdsfsdnfsdkjgnf replace ip:%id,port:%pd file 123.txt
Rewritten file content:
66 67 73 2d 61 47 76 61 73 64 64 73 61 67 76 62 fgs-aGva sddsagvb
64 6a 63 78 6b 6c 63 78 76 0d 0a 0d 0a 0d 0a 0d djcxklcx v.......
0a 69 70 3a 31 37 32 2e 30 2e 30 2e 31 2c 70 6f .ip:172. 0.0.1,po
72 74 3a 38 30 09 6a 6b 64 67 6e 66 64 6a 6b 67 rt:80.jk dgnfdjkg
6e 66 64 6b 6a 67 6e 66 64 6b 6e 67 76 73 64 66 nfdkjgnf dkngvsdf
6c 0d 0a 0d 0a 0d 0a 0d 0a 66 67 73 2b 61 67 76 l....... .fgs+agv
61 73 64 64 73 61 67 76 62 64 6a 63 78 6b 6c 63 asddsagv bdjcxklc
78 76 0d 0a 66 67 73 64 61 67 76 61 73 64 64 73 xv..fgsd agvasdds
61 67 76 62 64 6a 63 78 6b 6c 63 78 76 agvbdjcx klcxv
match
Use match to specify the proximity probe method for packets.
Use undo match to restore the default.
match [ match-id ] tcp { lb-probe lb-template | probe nqa-template }
undo match match-id
No proximity probe method is specified.
Proximity view
match-id: Specifies a proximity probe method by its ID in the range of 1 to 65535. If the rule does not exist, the command creates the proximity probe method. If the rule already exists, the command modifies the proximity probe method. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest available ID.
tcp: Specifies TCP packets.
lb-probe lb-template: Specifies an LB probe template by its name, a case-insensitive string of 1 to 32 characters.
probe nqa-template: Specifies an NQA template by its name, a case-insensitive string of 1 to 32 characters.
If the match command is configured, the specified proximity probe method applies. If no packets match the type in the match command or the match command is not configured, the default proximity probe method specified by using the match default command applies.
You can specify only one proximity probe method for each type of packets.
If both the match command and the match default command are configured, specify the same template type in the two commands as a best practice for both templates to take effect. If you specify different template types, the NQA template does not take effect.
# Create the ICMP-type NQA template t4, and specify the NQA template as the proximity probe method for TCP packets.
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-lb-proximity] match tcp probe t4
match default
match acl
Use match class to create an ACL match rule or modify an existing ACL match rule.
Use undo match to delete a match rule.
match [ match-id ] acl [ ipv6 ] { acl-number | name acl-name }
undo match match-id
No match rules exist.
LB class view
match-id: Specifies a match rule by its ID in the range of 1 to 65535. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest number.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the command creates an IPv4 ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter.
If the specified ACL does not exist, this rule is not matched.
You can create a maximum of 65535 match rules for an LB class.
# Create an ACL match rule for the generic LB class lbc1.
[Sysname-lbc-generic-lbc1] match acl 2000
match app-group
Use match app-group to create an application group match rule or modify an existing application group match rule.
Use undo match app-group to delete a match rule.
match [ match-id ] app-group group-name
undo match match-id
Link-generic LB class view
match-id: Specifies a match rule ID in the range of 1 to 65535. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest number.
app-group group-name: Specifies an application group by its name, a case-insensitive string of 1 to 63 characters.
If the specified application group does not exist, the rule does not take effect.
# Create an application group match rule for the link-generic LB class lbc1.
[Sysname] loadbalance class lbc1 type link-generic
[Sysname-lbc-link-generic-lbc1] match app-group http
app-group (Security Command Reference)
match class
Use match class to create a match rule that references an LB class or modify an existing match rule that references an LB class.
match [ match-id ] class class-name
undo match match-id
An LB class does not have a match rule.
LB class view
class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters, to be referenced by the match rule. The current LB class cannot be referenced.
A match rule cannot reference an LB class that has already been referenced.
# Create a match rule that references the LB class lbc2 for the generic LB class lbc1.
[Sysname-lbc-generic-lbc1] match class lbc2
match content
Use match content to create an HTTP entity match rule or modify an existing HTTP entity match rule.
match [ match-id ] content content [ offset offset ]
undo match match-id
HTTP LB class view
content content: Specifies the HTTP entity regular expression, a string of 1 to 255 characters. The string cannot contain question marks (?).
offset offset: Specifies the offset value of the HTTP entity based on the start of the HTTP packet, in the range of 0 to 1000. The default is 0.
If the entity of an HTTP packet after the offset value matches the specified regular expression, the packet matches the rule.
# Create an HTTP entity match rule for the HTTP LB class lbc2: Specify the offset value as 10 and regular expression as abc.
[Sysname] loadbalance class lbc2 type http
[Sysname-lbc-http-lbc2] match content abc.* offset 10
match cookie
Use match cookie to create an HTTP cookie match rule or modify an existing HTTP cookie match rule.
match [ match-id ] cookie cookie-name value value
undo match match-id
HTTP LB class view
cookie cookie-name: Specifies the name of the HTTP cookie, a case-sensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
value value: Specifies the cookie value regular expression, a string of 1 to 255 characters. The string cannot contain question marks (?).
If an HTTP packet contains the specified cookie with the value matching the specified regular expression, the packet matches the rule.
# Create an HTTP cookie match rule for the HTTP LB class lbc2: Specify the cookie name as JSession-id and cookie value regular expression as abc.
[Sysname-lbc-http-lbc2] match cookie JSession-id value abc.*
match default
Use match default to specify the default proximity probe method.
Use undo match default to restore the default.
match default { lb-probe lb-template | probe nqa-template }
The default proximity probe method is not specified.
Proximity view
If the match command is configured, the specified proximity probe method applies. If no packets match the type in the match command or the match command is not configured, the default proximity probe method applies.
If both the match command and the match default command are configured, you must specify the same template type (load balancing or NQA) in the two commands as a best practice for both templates to take effect. If you specify different template types, the NQA template does not take effect.
# Create the ICMP-type NQA template t4, and specify the NQA template as the default proximity probe method.
[Sysname-lb-proximity] match default probe t4
match
nqa template (Network Management and Monitoring Command Reference)
match destination
Use match destination to create a destination IP address match rule or modify an existing destination IP address match rule.
match [ match-id ] destination { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
DNS/Link-generic LB class view
ip address ipv4-address: Specifies an IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. The default is 32.
mask: Specifies a subnet mask. The default is 255.255.255.255.
ipv6 address ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. The default is 128.
# Create a match rule to match destination IPv4 address 1.1.1.1/32 for the DNS LB class lbc1.
[Sysname] loadbalance class lbc1 type dns
[Sysname-lbc-dns-lbc1] match destination ip address 1.1.1.1
# Create a match rule to match destination IPv4 address 1.1.1.1/32 for the link-generic LB class lbc2.
[Sysname] loadbalance class lbc2 type link-generic
[Sysname-lbc-link-generic-lbc2] match destination ip address 1.1.1.1
match destination domain-name
Use match destination domain-name to create a domain name match rule or modify an existing domain name match rule.
match [ match-id ] destination domain-name domain-name
undo match match-id
domain-name: Specifies a domain name, a case-insensitive string of 1 to 253 characters. Each dot-separated part in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), dots (.), and wildcards (asterisks and question marks).
When you use wildcards (asterisks and question marks) in a domain name, follow these guidelines:
· The wildcards can substitute any characters except for dots (.).
· An asterisk (*) can substitute a character string.
· A question mark (?) can substitute a single character.
# Create a domain name match rule for the link-generic LB class lbc1 to match domain name www.abc.com.
[Sysname-lbc-link-generic-lbc1] match destination domain-name www.aaa.com
match domain-name
Use match domain-name to create a domain name match rule or modify an existing domain name match rule.
match [ match-id ] domain-name domain-name
undo match match-id
DNS LB class view
# Create a domain name match rule for DNS LB class lbc1 to match domain name www.abc.com.
[Sysname-lbc-dns-lbc1] match domain-name www.abc.com
match header
Use match header to create an HTTP header match rule or modify an existing HTTP header match rule.
match [ match-id ] header header-name value value
undo match match-id
HTTP LB class view
header header-name: Specifies the name of the HTTP packet header, a case-insensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
value value: Specifies the header value regular expression, a string of 1 to 255 characters. The string cannot contain question marks (?).
If an HTTP packet contains the specified header with the value matching the specified regular expression, the packet matches the rule.
# Create an HTTP header match rule for the HTTP LB class lbc2: Specify the HTTP packet header name as user-agent and header value regular expression as abcd.
[Sysname-lbc-http-lbc2] match header user-agent value abcd
match interface
Use match interface to create an interface match rule or modify an existing interface match rule.
match [ match-id ] interface interface-type interface-number
undo match match-id
Generic/HTTP/Link-generic LB class view
interface interface-type interface-number: Specifies an interface by its type and number. The interface type can be Layer 3 Ethernet interface and Layer 3 aggregate interface.
If the specified interface does not exist, the rule does not take effect.
# Create an interface match rule for the link-generic LB class lbc1 to match interface GigabitEthernet 1/0/0.
[Sysname-lbc-link-generic-lbc1] match interface gigabitethernet 1/0/0
match isp
Use match isp to create an ISP match rule or modify an existing ISP match rule.
match [ match-id ] isp isp-name
undo match match-id
LB class view
isp-name: Specifies an ISP name, a case-insensitive string of 1 to 63 characters.
If the specified ISP does not exist or is not configured with an IP network segment, this rule is not matched.
# Create an ISP match rule for the generic LB class lbc1. Specify the ISP name as isp1.
[Sysname-lbc-generic-lbc1] match isp isp1
match method
Use match method to create an HTTP method match rule or modify an existing HTTP method match rule.
match [ match-id ] method { ext ext-type | rfc rfc-type }
undo match match-id
HTTP LB class view
ext ext-type: Specifies the extended type, a case-sensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
rfc rfc-type: Specifies the RFC type to process the resources identified by the URI in HTTP request packets:
· CONNECT—Maintain the resources.
· DELETE—Delete the resources.
· GET—Request for the resources.
· HEAD—Request for the header of the response message of the resources.
· OPTIONS—Request to query the resources-related options and requirements supported by the server.
· POST—Add new data to the resources.
· PUT—Request the server to store the resource identified by the URI.
· TRACE—Request the server to return the request message it receives for test or diagnosis.
# Create a packet matching method match rule with extended type user for the HTTP LB class lbc2.
[Sysname-lbc-http-lbc2] match method ext user
# Create a packet matching method match rule with RFC type CONNECT for the HTTP LB class lbc2.
[Sysname-lbc-http-lbc2] match method rfc CONNECT
match payload
Use match payload to create a TCP payload match rule or modify an existing TCP payload match rule.
match [ match-id ] payload payload [ case-insensitive ] [ not ]
undo match match-id
Generic LB class view
payload: Specifies the TCP payload regular expression, a string of 1 to 255 characters.
case-insensitive: Disables case sensitivity for matching character strings. If you do not specify this keyword, case sensitivity is enabled.
not: Negates the match rule. If you do not specify this keyword, the LB action is taken when the TCP payload regular expression is matched.
The device takes the corresponding LB action on TCP packets matching a TCP payload match rule. If you specify the not keyword for a TCP payload match rule, the device takes the corresponding LB action on TCP packets not matching the TCP payload match rule.
# Create a match rule to match the payload hello for generic LB class c1.
[Sysname] loadbalance class c1 type generic
[Sysname-lbc-generic-c1] match payload hello
match radius-attribute
Use match radius-attribute to create a RADIUS attribute match rule or modify an existing RADIUS attribute match rule.
match [ match-id ] radius-attribute { code attribute-code | user-name } value attribute-value
undo match match-id
RADIUS LB class view
code attribute-code: Specifies the code of the RADIUS attribute type, in the range of 1 to 255.
user-name: Specifies the RADIUS attribute type as user-name (code 1).
value attribute-value: Specifies the RADIUS attribute regular expression, a string of 1 to 255 characters.
# Create a match rule to match usernames that contain aaa for RADIUS LB class lbc1.
[Sysname] loadbalance class lbc1 type radius
[Sysname-lbc-radius-lbc1] match radius-attribute user-name value aaa*
match source
Use match source to create a source IP address match rule or modify an existing source IP address match rule.
match [ match-id ] source { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
LB class view
source: Specifies the match rule type as source IP address.
# Create a match rule that matches source IP address 1.1.1.1/32 for the generic LB class lbc1.
[Sysname-lbc-generic-lbc1] match source ip address 1.1.1.1
match url
Use match url to create an HTTP URL match rule or modify an existing HTTP URL match rule.
match [ match-id ] url url
undo match match-id
HTTP LB class view
url url: Specifies a URL regular expression, a string of 1 to 255 characters. The string cannot contain question marks (?).
# Create an HTTP URL match rule with regular expression .*.html for the HTTP LB class lbc2.
[Sysname-lbc-http-lbc2] match url .*.html
match user
Use match user to create a user match rule or modify an existing user match rule.
match [ match-id ] [ identity-domain domain-name ] user user-name
undo match match-id
identity-domain domain-name: Matches the user in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters excluding question marks (?). If you do not specify this option, the system matches the user among users that do not belong to any identity domain.
user-name: Specifies a username, a case-sensitive string of 1 to 55 characters.
If the specified user does not exist, the rule does not take effect.
# Create a user match rule for the link-generic LB class lbc1 to match user u1 in identity domain domain1.
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user u1
display loadbalance class
match user-group
Use match user-group to create a user group match rule or modify an existing user group match rule.
match [ match-id ] [ identity-domain domain-name ] user-group user-group-name
undo match match-id
identity-domain domain-name: Matches the user group in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters excluding question marks (?). If you do not specify this option, the system matches the user group among user groups that do not belong to any identity domain.
user-group-name: Specifies a user group by its name, a case-insensitive string of 1 to 200 characters.
If the specified user group does not exist, the rule does not take effect.
# Create a user group match rule for the link-generic LB class lbc1 to match user group lb-group in identity domain domain1.
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user-group lb-group
match-buffer-end
Use match-buffer-end to configure the buffering end string for TCP payload matching.
Use undo match-buffer-end to restore the default.
match-buffer-end string
No buffering end string is configured.
TCP-application parameter profile view
string: Specifies a string that indicates the end of buffering, a string of 1 to 31 characters.
For the TCP payload match rule, the device buffers traffic from clients for TCP payload matching during the buffering period. The device stops buffering traffic when any of the following events occurs:
· The device receives the buffering end string from clients.
· The size of buffered data exceeds the specified buffering size.
· The buffered data matches the TCP payload match rule.
This command specifies the string that indicates the end of buffering for traffic received from clients.
# In TCP-application parameter profile p1, configure the buffering end string as over.
[Sysname] parameter-profile p1 type tcp-application
[Sysname-para-tcp-application-p1] match-buffer-end over
match-buffer-size
match-buffer-time
match payload
match-buffer-size
Use match-buffer-size to set the maximum buffering size for TCP payload matching.
Use undo match-buffer-size to restore the default.
match-buffer-size size
The maximum buffering size is 4096 bytes.
size: Specifies the maximum buffering size in the range of 1 to 4096 bytes.
This command specifies the maximum size of TCP data from clients that the device can buffer.
# In TCP-application parameter profile p1, set the maximum buffering size to 2048 bytes for TCP payload matching.
[Sysname-para-tcp-application-p1] match-buffer-size 2048
match-buffer-end
match-buffer-time
match payload
match-buffer-time
Use match-buffer-time to set the buffering period for TCP payload matching.
Use undo match-buffer-time to restore the default.
match-buffer-time time
The buffering period for TCP payload matching is 3 seconds.
time: Specifies the buffering period in the range of 1 to 5 seconds.
This command specifies the amount of time for the device to buffer TCP data sent by clients.
# In TCP-application parameter profile p1, set the buffering period for TCP payload matching to 3 seconds.
[Sysname-para-tcp-application-p1] match-buffer-time 3
match-buffer-end
match-buffer-size
match payload
max-bandwidth (link view)
Use max-bandwidth to set the maximum expected bandwidth of an LB link.
Use undo max-bandwidth to restore the default.
max-bandwidth [ inbound | outbound ] bandwidth-value
undo max-bandwidth [ inbound | outbound ]
The maximum expected bandwidth of an LB link is not limited.
Link view
inbound: Specifies the maximum inbound expected bandwidth.
outbound: Specifies the maximum outbound expected bandwidth.
bandwidth-value: Specifies the maximum expected bandwidth in the range of 0 to 4294967295 in KBps. The value 0 means the bandwidth is not limited.
If you do not specify the inbound or outbound keyword, the maximum expected bandwidth equals the inbound expected bandwidth plus the outbound expected bandwidth.
In addition to being used for link protection, the maximum expected bandwidth is used for remaining bandwidth calculation in the bandwidth algorithm, maximum bandwidth algorithm, and dynamic proximity algorithm.
# Set the maximum expected bandwidth of the LB link lk1 to 1 KBps.
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] max-bandwidth 1
# Set the maximum inbound expected bandwidth of the LB link lk1 to 1 KBps.
[Sysname-lb-link-lk1] max-bandwidth inbound 1
# Set the maximum outbound expected bandwidth of the LB link lk1 to 1 KBps.
[Sysname-lb-link-lk1] max-bandwidth outbound 1
max-bandwidth (real server view)
Use max-bandwidth to set the maximum expected bandwidth of a real server.
The maximum expected bandwidth of a real server is not limited.
Real server view
inbound: Specifies the maximum uplink expected bandwidth.
outbound: Specifies the maximum downlink expected bandwidth.
When the traffic exceeds the maximum expected bandwidth multiplied by the bandwidth ratio of a real server, new traffic (traffic that does not match any sticky entries) is not distributed to the link.
If you do not specify the inbound or outbound keyword, the maximum expected bandwidth equals the uplink expected bandwidth plus the downlink expected bandwidth.
If this command is not configured or the bandwidth-value is set to 0 (not limited), the maximum expected bandwidth depends on the setting of the rate-limit bandwidth (real server view) command.
This command takes effect only on new sessions and does not take effect on existing sessions.
In addition to being used for link protection, the maximum expected bandwidth is used for remaining bandwidth calculation in the bandwidth algorithm and maximum bandwidth algorithm.
# Set the maximum expected bandwidth of the real server rs to 1 KBps.
[Sysname] real-server rs
[Sysname-rserver-rs] max-bandwidth 1
# Set the maximum uplink expected bandwidth of the real server rs to 1 KBps.
[Sysname-rserver-rs] max-bandwidth inbound 1
# Set the maximum downlink expected bandwidth of the real server rs to 1 KBps.
[Sysname-rserver-rs] max-bandwidth outbound 1
max-number
Use max-number to set the maximum number of proximity entries.
Use undo max-number to restore the default.
max-number number
The maximum number of proximity entries is not set.
Proximity view
number: Specifies the maximum number of proximity entries, in the range of 0 to 10000000. The default value is 0, which indicates that the maximum number of proximity entries is not limited.
# Set the maximum number of proximity entries to 100.
[Sysname-lb-proximity] max-number 100
max-reuse
Use max-reuse to set the maximum number of times that a TCP connection can be reused.
Use undo max-reuse to restore the default.
max-reuse reuse-number
undo max-reuse
A TCP connection can be reused for a maximum of 1000 times.
OneConnect parameter profile view
reuse-number: Specifies the maximum number of reuse times, in the range of 1 to 4294967295.
After connection reuse is enabled, a TCP connection is not disconnected until the maximum number of reuse times is reached. After the TCP connection is disconnected, new connection requests trigger establishment of a new TCP connection.
# In OneConnect parameter profile ocp, set the maximum number of reuse times to 10000.
[Sysname] parameter-profile ocp type oneconnect
[Sysname-para-oneconnect-ocp] max-reuse 10000
memory-size
Use memory-size to set the memory size used for compression.
Use undo memory-size to restore the default.
memory-size size
undo memory-size
The memory size used for compression is 8 KB.
HTTP-compression parameter profile view
size: Specifies the memory size in KB used for compression. The value can only be 1, 2, 4, 8, 16, 32, or 64.
# Create the HTTP-compression parameter profile pa1, and set the memory size used for compression to 32 KB.
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] memory-size 32
monitor-interval
Use monitor-interval to set the monitoring time for an LB probe template.
Use undo monitor-interval to restore the default.
monitor-interval interval-time
The monitoring time for an LB probe template is 10 seconds.
TCP-RST LB probe template view
TCP zero-window LB probe template view
interval-time: Specifies the monitoring time in the range of 5 to 255 seconds.
During the monitoring time, the system counts the number of RST packets or zero-window packets sent by each server farm member in a server farm.
# In TCP RST LB probe template rsttplt, set the monitoring time to 60 seconds.
[Sysname] loadbalance probe-template tcp-rst rsttplt
[Sysname-lbpt-tcp-rst-rsttplt] monitor-interval 60
node
Use node to create a statistics node and enter its view, or enter the view of an existing statistics node.
Use undo node to delete the specified statistics node.
node node-name
undo node node-name
No statistics nodes exist.
HTTP statistics parameter profile view
node-name: Specifies the statistics node name, a case-insensitive string of 1 to 63 characters.
You can configure a maximum of 256 statistics nodes in one HTTP statistics parameter profile.
# In HTTP statistics parameter profile http1, create statistics node node1 and enter statistics node view.
[Sysname] parameter-profile http1 type http-statistics
[Sysname-para-http-statistics-http1] node node1
[Sysname-para-http-statistics-http1-node-node1]
override-limit enable
Use override-limit enable to ignore the limits for sessions that match sticky entries.
Use undo override-limit enable to remove the configuration.
The session limits apply to sessions that match sticky entries.
Sticky group view
Use this command to ignore the following limits for sessions that match sticky entries:
· Bandwidth and connection parameters on real servers or links.
· Bandwidth ratios and maximum expected bandwidths for real servers or links.
· LB connection limit policies on virtual servers.
# Ignore the limits for sessions that match sticky entries generated in the sticky group st.
[Sysname] sticky-group st type http-cookie
[Sysname-sticky-http-cookie-st] override-limit enable
parameter
Use parameter to specify a parameter profile to be referenced by a virtual server.
Use undo parameter to restore the default.
parameter { http | http-compression | http-statistics | ip | oneconnect | tcp | tcp-application } profile-name [ client-side | server-side ]
undo parameter { http | http-compression | http-statistics | ip | oneconnect | tcp | tcp-application } [ client-side | server-side ]
No parameter profile is referenced by a virtual server.
Virtual server view
{ http | http-compression | http-statistics | ip | oneconnect | tcp | tcp-application }: Specifies a parameter profile type, HTTP, HTTP-compression, HTTP statistics, IP, OneConnect, TCP, or TCP-application. The http and tcp keywords are supported by the virtual servers of the fast HTTP or HTTP type. The http-compression, http-statistics, and oneconnect keywords are supported only by the virtual servers of the HTTP type. The tcp-application keyword is suppored only by TCP virtual servers operating at Layer 7.
profile-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 63 characters.
client-side: Specifies a client-side parameter profile.
server-side: Specifies a server-side parameter profile.
The virtual server references the parameter profile to implement analysis, processing, and optimization for service traffic.
The virtual servers of the RADIUS type can only reference the IP parameter profile.
A client-side parameter profile optimizes and processes TCP connections between the client and the device. A server-side parameter profile optimizes and processes TCP connections between the device and the server. Only TCP parameter profiles support the client-side and server-side keywords.
# Specify the IP parameter profile pp2 to be referenced by the IP-type virtual server vs3.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] parameter ip pp2
parameter-profile
Use parameter-profile to create a parameter profile and enter its view, or enter the view of an existing parameter profile.
Use undo parameter-profile to delete the specified parameter profile.
parameter-profile profile-name [ type { http | http-compression | http-statistics | ip | oneconnect | tcp | tcp-application } ]
undo parameter-profile profile-name
No parameter profiles exist.
profile-name: Specifies a parameter profile name, a case-insensitive string of 1 to 63 characters.
type { http | http-compression | http-statistics | ip | oneconnect | tcp | tcp-application }: Specifies a parameter profile type, HTTP, HTTP-compression, HTTP statistics, IP, OneConnect, TCP, or TCP-application. When you create a parameter profile, you must specify the parameter profile type. You can enter an existing parameter profile view without entering the parameter profile type.
You can configure advanced parameters through the parameter profile. The virtual server references the parameter profile to implement analysis, processing, and optimization for service traffic.
# Create the IP parameter profile pp2, and enter parameter profile view.
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2]
payload
Use payload to configure the HTTP or UDP payload sticky method.
Use undo payload to delete the HTTP or UDP payload sticky method.
payload [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo payload
No sticky methods exist.
HTTP/UDP payload sticky group view
offset offset: Specifies the offset value of the HTTP or UDP payload based on the start of the HTTP or UDP packet, in the range of 0 to 1000. The default is 0.
start start-string: Specifies the regular expression that marks the start of the HTTP or UDP payload, a string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP or UDP payload, a string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP or UDP payload, in the range of 0 to 1000. The default is 0, which indicates all lengths.
Use this command to obtain the HTTP or UDP payload information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
This command is not supported by the virtual servers of the fast HTTP type.
# Configure the HTTP payload sticky method for the HTTP payload sticky group sg5: Starting from the 10th byte of start of the HTTP packet, use the 20-byte HTTP payload to generate sticky entries.
[Sysname] sticky-group sg5 type payload
[Sysname-sticky-payload-sg5] payload offset 10 length 20
# Configure the UDP payload sticky method for the UDP payload sticky group sg6: Starting from the 28th byte of start of the UDP packet, use the 6-byte UDP payload to generate sticky entries.
[Sysname] sticky-group sg6 type payload
[Sysname-sticky-payload-sg6] payload offset 28 length 6
port (DNS server view)
Use port to configure the port number of a DNS server.
Use undo port to restore the default.
port port-number
undo port
The port number of a DNS server is 0.
DNS server view
port-number: Specifies a port number in the range of 0 to 65535. The value 0 means that the original port number is used.
# Specify the port number of DNS server ds1 as 5353.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] port 5353
port (real server view)
Use port to configure the port number of a real server.
port port-number
undo port
The port number of a real server is 0. (The original port number is used.)
Real server view
port-number: Specifies a port number in the range of 0 to 65535. 0 means the original port number is used.
This configuration takes effect only when you enable the NAT feature for the server farm.
# Specify the port number of the real server rs as 8080.
[Sysname-rserver-rs] port 8080
transparent enable (server farm view)
port (transparent DNS proxy view)
Use port to configure the port number of a transparent DNS proxy.
port port-number
undo port
The port number of a transparent DNS proxy is 53.
Transparent DNS proxy view
port-number: Specifies a port number in the range of 1 to 65535.
A transparent DNS proxy processes a DNS request only when the destination IP address and port number of the DNS request matches those of the transparent DNS proxy.
# Specify the port number of transparent DNS proxy dns-proxy1 as 5353.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-dns-proxy1] port 5353
display loadbalance dns-proxy
port (virtual server view)
Use port to configure the port number of a virtual server.
port { port-number [ to port-number ] } &<1-n>
undo port
The port number is 0 (indicates any port) for the virtual server of the IP, RADIUS, TCP, or UDP type. The port number is 80 for the virtual server of the fast HTTP or HTTP type. The port number is 5060 for the virtual server of the SIP type.
Virtual server view
port-number [ to port-number ] &<1-n>: Specifies a space-separated list of up to n port number items. Each port number item specifies a port number or a range of port numbers in the form of start-port-number to end-port-number. For IP, RADIUS, TCP, and UDP virtual servers, the value range for the port-number argument is 0 to 65535 (0 means any port) and the value range for n is 1 to 8. For HTTP, fast HTTP, and SIP virtual servers, the value range for the port-number argument is 1 to 65535 and the value of n can only be 1.
If the virtual server has referenced an SSL policy, you must configure a non-default port number (typically 443) for the virtual server.
# Specify the port number of the IP-type virtual server vs3 as 8080.
[Sysname-vs-ip-vs3] port 8080
ssl-server-policy
predictor (DNS server pool view)
Use predictor to specify a scheduling algorithm for a DNS server pool.
Use undo predictor to restore the default.
predictor hash address { destination | source | source-ip-port } [ mask mask-length ] [ prefix prefix-length ]
predictor { random | round-robin | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
The scheduling algorithm for a DNS server pool is weighted round robin.
hash address: Specifies the hash algorithm based on the IP address.
destination: Specifies the hash algorithm based on the destination IP address.
source: Specifies the hash algorithm based on the source IP address.
source-ip-port: Specifies the hash algorithm based on the source IP address and port number.
mask mask-length: Specifies the mask length of the IPv4 address used in the hash algorithm. The value range for the mask-length argument is 0 to 32. The default is 32.
prefix prefix-length: Specifies the prefix length of the IPv6 address used in the hash algorithm. The value range for the prefix-length argument is 0 to 128. The default is 128.
random: Specifies the random algorithm, which randomly assigns DNS requests to DNS servers.
round-robin: Specifies the weighted round robin algorithm, which assigns DNS requests to DNS servers based on the weights of the DNS servers. A higher weight indicates more DNS requests will be assigned. The weight value used in this algorithm is configured in DNS server pool member view.
bandwidth: Specifies the bandwidth algorithm, which assigns DNS requests to DNS servers based on the weight and remaining bandwidth of the DNS servers. The weight value used in this algorithm is configured in DNS server view.
max-bandwidth: Specifies the maximum bandwidth algorithm, which always assigns DNS requests to the DNS server corresponding to the idle link with the largest remaining bandwidth.
inbound: Selects a DNS server based on the inbound bandwidth.
outbound: Selects a DNS server based on the outbound bandwidth.
If you do not specify the inbound or outbound keyword, the total bandwidth is used to select a DNS server.
In the bandwidth algorithm and maximum bandwidth algorithm, the remaining bandwidth is the maximum expected bandwidth minus the current bandwidth. If the maximum expected bandwidth is not configured, the remaining bandwidth is the maximum bandwidth of the link minus the current bandwidth.
# Specify the scheduling algorithm as random for DNS server pool dns-pool.
[Sysname] loadbalance dns-server-pool dns-pool
[Sysname-lb-dspool-dns-pool] predictor random
rate-limit bandwidth (link view)
predictor (link group view)
Use predictor to specify a scheduling algorithm for a link group.
Link-based:
predictor { least-connection | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
Link group member-based:
predictor { least-connection member | random | round-robin }
undo predictor
The scheduling algorithm for a link group is weighted round robin.
Link group view
hash address: Performs the hash algorithm based on IP address.
destination: Performs the hash algorithm based on destination IP address.
source: Performs the hash algorithm based on source IP address.
source-ip-port: Performs the hash algorithm based on source IP address and port number.
mask mask-length: Specifies the IPv4 address mask length, in the range of 0 to 32. The default is 32.
prefix prefix-length: Specifies the IPv6 address prefix length, in the range of 0 to 128. The default is 128.
least-connection: Specifies the link-based weighted least connection algorithm. This algorithm always assigns new connections to the link with the fewest number of weighted active connections (the total number of active connections in all link groups divided by weight). The weight value used in this algorithm is configured in link view.
least-connection member: Specifies the link group member-based weighted least connection algorithm. This algorithm always assigns new connections to the link with the fewest number of weighted active connections (the number of active connections in the specified link group divided by weight). The weight value used in this algorithm is configured in link group member view.
random: Specifies the random algorithm, which randomly assigns new connections to links.
round-robin: Specifies the weighted round robin algorithm, which assigns new connections to links based on the weights of links. A higher weight indicates more new connections will be assigned. The weight value used in this algorithm is configured in link group member view.
bandwidth: Specifies the bandwidth algorithm, which assigns packets to links based on the weight of the links and the bandwidth ratio. The weight value used in this algorithm is configured in link view.
max-bandwidth: Specifies the maximum bandwidth algorithm, which always assigns packets to the idle link with the largest remaining bandwidth.
inbound: Selects a link based on the inbound bandwidth.
outbound: Selects a link based on the outbound bandwidth.
If you do not specify the inbound or outbound keyword, the total bandwidth is used to select a link.
# Specify the scheduling algorithm random for the link group lg.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] predictor random
predictor (server farm view)
Use predictor to specify a scheduling algorithm for a server farm.
Real server-based:
predictor { dync-roundrobin | least-connection | least-time | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
Server farm member-based:
predictor hash [ carp ] address { destination | source | source-ip-port } [ mask mask-length ] [ prefix prefix-length ]
predictor hash [ carp ] http [ offset offset ] [ start start-string ] [ [ end end-string ] | [ length length ] ]
predictor { least-connection member | random | round-robin | }
undo predictor
The scheduling algorithm for a server farm is weighted round robin.
Server farm view
carp: Specifies the Cache Array Routing Protocol (CARP) hash algorithm. When the number of available real servers changes, this protocol makes all available real servers have the smallest load changes.
http: Performs the hash algorithm based on the HTTP content.
offset offset: Specifies the offset value based on the start of the HTTP content, in the range of 0 to 1000. The default is 0.
start start-string: Specifies the regular expression that marks the start of the HTTP content, a string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP content, a string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP content, in the range of 0 to 1000. The default is 0, which indicates all lengths.
dync-roundrobin: Specifies the dynamic round robin algorithm, which assigns new connections to real servers based on load weight values calculated by using the memory usage, CPU usage, and disk usage of the real servers. The smaller the load, the greater the weight value. A real server with a greater weight value is assigned more connections.
least-connection: Specifies the real server-based weighted least connection algorithm, which always assigns new connections to the real server with the fewest number of weighted active connections (the total number of active connections in all server farms divided by weight). The weight value used in this algorithm is configured in real server view.
least-connection member: Specifies the server farm member-based weighted least connection algorithm, which always assigns new connections to the real server with the fewest number of weighted active connections (the number of active connections in the specified server farm divided by weight). The weight value used in this algorithm is configured in server farm member view.
least-time: Specifies the least time algorithm, which assigns new connections to real servers based on load weight values calculated by using the response time of the real servers. The shorter the response time, the greater the weight value. A real server with a greater weight value is assigned more connections.
random: Specifies the random algorithm, which randomly assigns new connections to real servers.
round-robin: Specifies the weighted round robin algorithm, which assigns new connections to real servers based on the weights of real servers. A higher weight indicates more new connections will be assigned. The weight value used in this algorithm is configured in server farm member view.
bandwidth: Specifies the bandwidth algorithm, which assigns packets to real servers based on the weight of the real servers and the bandwidth ratio. The weight value used in this algorithm is configured in real server view.
max-bandwidth: Specifies the maximum bandwidth algorithm, which always assigns packets to the idle real server with the largest remaining bandwidth.
inbound: Selects a real server based on the inbound bandwidth.
outbound: Selects a real server based on the outbound bandwidth.
The dynamic round robin algorithm can take effect only if you specify an SNMP-DCA NQA template. If no SNMP-DCA NQA template is specified, the non-weighted round robin algorithm is used. For more information about NQA templates, see NQA configuration in Network Management and Monitoring Configuration Guide.
If you do not specify the inbound or outbound keyword, the total bandwidth is used to select a real server.
In the bandwidth algorithm and maximum bandwidth algorithm, the remaining bandwidth is the maximum expected bandwidth minus the current bandwidth. If the maximum expected bandwidth is not configured, the remaining bandwidth is the maximum bandwidth of the real server minus the current bandwidth.
# Specify the scheduling algorithm for the server farm sf as random.
[Sysname] server-farm sf
[Sysname-sfarm-sf] predictor random
prefer-method
Use prefer-method to specify the preferred compression algorithm.
Use undo prefer-method to restore the default.
prefer-method { deflate | gzip }
undo prefer-method
The preferred compression algorithm is gzip.
deflate: Specifies the Deflate compression algorithm.
gzip: Specifies the default GNU zip compression algorithm.
If the client request supports the configured compression algorithm, the configured compression algorithm applies. If the client request does not support the configured compression algorithm, the compression algorithm contained in the request applies.
# Create the HTTP-compression parameter profile http1, and specify the preferred compression algorithm as deflate.
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] prefer-method deflate
priority (DNS server pool member view)
Use priority to set the priority of a DNS server pool member.
Use undo priority to restore the default.
priority priority
undo priority
The priority of a DNS server pool member is 4.
priority: Specifies the priority value in the range of 1 to 8. A greater value means a higher priority.
Typically, only the members with the highest priority in a DNS server pool participate in scheduling. If the number of such members is smaller than the required minimum number, more members are selected by priority in descending order. If the allowed maximum number is exceeded after members with a certain priority are added, only some of the members with that priority are added.
Use this command together with the selected-server command in DNS server pool view.
# Set the priority of DNS server pool member ds1 to 3.
[Sysname] loadbalance dns-server-pool dsp1
[Sysname-lb-dspool-dsp1] dns-server ds1 port 10
[Sysname-dspool-dsp1-#member#-ds1-port-10] priority 3
selected-server (DNS server pool view)
priority (DNS server view)
Use priority to set the priority of a DNS server.
priority priority
undo priority
The priority of a DNS server is 4.
DNS server view
Typically, only the DNS servers with the highest priority participate in scheduling. If the number of such DNS servers is smaller than the required minimum number, more DNS servers are selected by priority in descending order. If the allowed maximum number is exceeded after DNS servers with a certain priority are added, only some of the DNS servers with that priority are added.
# Set the priority of DNS server ds1 to 3.
[Sysname-lb-ds-ds1] priority 3
priority (link group member view)
Use priority to set the priority of a link group member.
priority priority
undo priority
The priority of a link group member is 4.
Link group member view
Typically, only the members with the highest priority in a link group participate in scheduling. If the number of such members is smaller than the required minimum number, more members are selected by priority in descending order. If the allowed maximum number is exceeded after members with a certain priority are added, only some of the members with that priority are added.
Use this command together with the selected-server command.
# Set the priority of link group member lk1 to 3.
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1] priority 3
selected- link
priority (link view)
Use priority to set the priority of a link.
priority priority
undo priority
The priority of a link is 4.
Link view
Typically only the links with the highest priority participate in scheduling. If the number of such links is smaller than the required minimum number, more links are selected by priority in descending order.
# Set the priority of the link lk1 to 3.
[Sysname-lb-link-lk1] priority 3
selected-link
priority (real server view)
Use priority to set the priority of a real server.
priority priority
undo priority
The priority of a real server is 4.
Real server view
priority: Specifies the priority value of the real server, in the range of 1 to 8. A greater value means a higher priority to be referenced.
Typically only the real servers with the highest priority participate in scheduling. If the number of such real servers is smaller than the required minimum number, more real servers are selected by priority in descending order.
# Set the priority of the real server rs to 3.
[Sysname-rserver-rs] priority 3
selected-server
priority (server farm member view)
Use priority to set the priority of a server farm member.
priority priority
undo priority
The priority of a server farm member is 4.
Server farm member view
Typically, only the members with the highest priority in a server farm participate in scheduling. If the number of such members is smaller than the required minimum number, more members are selected by priority in descending order. If the allowed maximum number is exceeded after members with a certain priority are added, only some of the members with that priority are added.
Use this command together with the selected-server command in server farm view.
# Set the priority of server farm member rs1 to 3.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname-sfarm-sf-#member#-rs1-port-80] priority 3
selected-server (server farm view)
probe (DNS server pool member view)
Use probe to specify a health monitoring method for a DNS server pool member.
Use undo probe to restore the default.
probe template-name
undo probe template-name
No health monitoring method is specified for a DNS server pool member.
template-name: Specifies an NQA template by its name, a case-insensitive string of 1 to 32 characters.
Use the nqa template command to create an NQA template to be referenced by the health monitoring method. The DNS server pool uses the parameters defined in the NQA template to detect the availability of the pool members.
The health monitoring method configuration in DNS server pool member view takes precedence over the configuration in DNS server pool view.
The health monitoring result for a DNS server affects the availability of a DNS server pool member. The health monitoring result for a DNS server pool member does not affect the availability of a DNS server.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the DNS server pool member ds1 as t4.
[Sysname-lb-dspool-dsp1-#member#-ds1-port-10] probe t4
success-criteria (DNS server pool member view)
probe (DNS server pool view)
Use probe to specify a health monitoring method for a DNS server pool.
probe template-name
No health monitoring method is specified for a DNS server pool.
Use the nqa template command to create an NQA template to be referenced by the health monitoring method. The DNS server pool uses the parameters defined in the NQA template to detect the availability of DNS servers.
The health monitoring method configuration in DNS server view takes precedence over the configuration in DNS server pool view.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the DNS server pool dns-pool as t4.
[Sysname-lb-dspool-dns-pool] probe t4
success-criteria (DNS server pool view)
probe (DNS server view)
Use probe to specify a health monitoring method for a DNS server.
probe template-name
No health monitoring method is specified for a DNS server.
DNS server view
# Create the ICMP-type NQA template t4, and specify the health monitoring method for DNS server ds1 as t4.
[Sysname-lb-ds-ds1] probe t4
success-criteria (DNS server view)
probe (link group member view)
Use probe to specify a health monitoring method for a link group member.
probe template-name
No health monitoring method is specified for a link group member.
Use the nqa template command to create an NQA template to be referenced by the health monitoring method. The link group uses the parameters defined in the NQA template to detect the availability of the link group members.
The health monitoring method configuration in link group member view takes precedence over the configuration in link group view.
The health monitoring result for a link affects the availability of a link group member. The health monitoring result for a link group member does not affect the availability of a link.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the link group member lk1 as t4.
[Sysname-lb-lgroup-lg-#member#-lk1] probe t4
success-criteria (link group member view)
probe (link group view)
Use probe to specify a health monitoring method for a link group.
probe template-name
No health monitoring method is specified for a link group.
Link group view
The link group uses the parameters defined in the NQA template to detect the availability of links.
The health monitoring method configuration in link view takes precedence over the configuration in link group view.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the link group lg as t4.
[Sysname-lb-lgroup-lg] probe t4
success-criteria (link group view)
probe (link view)
Use probe to specify a health monitoring method for an LB link.
probe template-name
No health monitoring method is specified for an LB link.
Link view
You can configure multiple health monitoring methods for an LB link. By default, health monitoring succeeds only when all the specified health monitoring methods succeed. You can use the success-criteria command to specify the health monitoring success criteria for the LB link.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the LB link lk1 as t4.
[Sysname-lb-link-lk1] probe t4
success-criteria (link view)
probe (real server view)
Use probe to specify a health monitoring method for a real server.
probe template-name [ nqa-template-port ]
No health monitoring method is specified for a real server.
Real server view
nqa-template-port: Uses the destination port number specified in the NQA template for detection. If you do not specify this keyword, the real server's port number is used for detection.
The health monitoring method configuration in real server view takes precedence over the configuration in server farm view.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the real server rs as t4.
[Sysname-rserver-rs] probe t4
success-criteria (real server view)
probe (server farm member view)
Use probe to specify a health monitoring method for a server farm member.
No health monitoring method is specified for a server farm member.
nqa-template-port: Uses the destination port number specified in the NQA template for detection. If you do not specify this keyword, the server farm member's port number is used for detection.
Use the nqa template command to create an NQA template to be referenced by the health monitoring method. The server farm uses the parameters defined in the NQA template to detect the availability of the server farm members.
The health monitoring method configuration in server farm member view takes precedence over the configuration in server farm view.
The health monitoring result for a real server affects the availability of a server farm member. The health monitoring result for a server farm member does not affect the availability of a real server.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the server farm member rs1 as t4.
[Sysname-sfarm-sf-#member#-rs1-port-80] probe t4
success-criteria (server farm member view)
probe (server farm view)
Use probe to specify a health monitoring method for a server farm.
Use undo probe to delete a health monitoring method from a server farm.
No health monitoring method is specified for a server farm.
Server farm view
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the server farm sf as t4.
<Sysname>system-view
[Sysname-sfarm-sf] probe t4
success-criteria (server farm view)
probe-template
Use probe-template to specify an LB probe template for a server farm.
Use undo probe-template to restore the default.
probe-template { tcp-rst | tcp-zero-window } template-name
undo probe-template { tcp-rst | tcp-zero-window }
No LB probe template is specified for a server farm.
Server farm view
tcp-rst: Specifies a TCP-RST LB probe template.
tcp-zero-window: Specifies a TCP zero-window LB probe template.
template-name: Specifies the template name, a case-insensitive string of 1 to 32 characters.
This command can monitor all real severs in a server farm.
A server farm can reference only one TCP-RST LB probe template and one TCP zero-window LB probe template at the same time.
# Specify TCP-RST LB probe template r1 for server farm sf.
[Sysname-sfarm-sf] probe-template tcp-rst r1
protect-action
Use protect-action to configure the protection action for an LB probe template.
Use undo protect-action to restore the default.
protect-action { auto-shutdown | busy [ probe-interval interval ] [ probe-times times ] }
undo protect-action
The protection action is to place a real server in busy state.
auto-shutdown: Automatically shuts down a real server.
busy: Places a real server in busy state.
probe-interval interval: Specifies the interval for probing the real server in busy state, in the range of 5 to 3600 seconds. The default is 30 seconds.
probe-times times: Specifies the maximum number of times for probing the real server in busy state, in the range of 0 to 255. The default is 0, which means that the number of probe times is not limited.
For the busy action, after placing a real server in busy state, the device starts probing the real server at the specified probe intervals. If the number of RST or zero-window packets sent does not reach the threshold in a probe interval, the real server is placed back in normal state. If threshold violation persists when the maximum probe times is reached, the system automatically shuts down the real server.
A real server that is shut down or placed in busy state due to packet threshold violation will be restored to normal state immediately when the referenced LB probe template is deleted.
# In TCP-RST LB probe template rsttplt, configure the protection action as busy, set the probe interval to 30 seconds, and set the probe times to 3.
[Sysname-lbpt-tcp-rst-rsttplt] protect-action busy probe-interval 30 probe-times 3
proximity enable (link group view)
Use proximity enable to enable the proximity feature for a link group.
Use undo proximity enable to disable the proximity feature for a link group.
proximity enable
The proximity feature is disabled for a link group.
Link group view
The proximity feature takes precedence over the scheduling algorithm in selecting a link. If no link is selected according to the proximity feature, the scheduling algorithm is used.
# Enable the proximity feature for the link group lg.
[Sysname-lb-lgroup-lg] proximity enable
proximity enable (server farm view)
Use proximity enable to enable the proximity feature for a server farm.
Use undo proximity enable to disable the proximity feature for a server farm.
The proximity feature is disabled for a server farm.
Server farm view
The proximity feature takes precedence over the scheduling algorithm in selecting a real server. If no real server is selected according to the proximity feature, the scheduling algorithm is used.
# Enable the proximity feature for the server farm sf.
[Sysname-sfarm-sf] proximity enable
radius-attribute
Use radius-attribute to configure the RADIUS attribute sticky method.
Use undo radius-attribute to delete the RADIUS attribute sticky method.
radius-attribute { code attribute-code | framed-ip-address | user-name }
No RADIUS sticky methods exist.
RADIUS sticky group view
framed-ip-address: Specifies the RADIUS attribute type as framed-ip-address (code 8).
The RADIUS attribute sticky method takes effect only on RADIUS packets.
# Configure the RADIUS attribute sticky method for sticky group s1 by specifying the RADIUS attribute type as user-name.
[Sysname] sticky-group s1 type radius
[Sysname-sticky-radius-s1] radius-attribute user-name
Use rate-limit bandwidth to set the maximum bandwidth of a link.
Use undo rate-limit bandwidth to restore the default.
rate-limit bandwidth [ inbound | outbound ] bandwidth-value
undo rate-limit bandwidth [ inbound | outbound ]
The maximum bandwidth of a link is not limited.
Link view
inbound: Specifies the maximum inbound bandwidth.
outbound: Specifies the maximum outbound bandwidth.
bandwidth-value: Specifies the maximum bandwidth in the range of 0 to 4294967295 in KBps. The value 0 means the bandwidth is not limited.
If you do not specify the inbound or outbound keyword, the maximum bandwidth equals the inbound bandwidth plus the outbound bandwidth.
# Set the maximum bandwidth of the link lk1 to 1 KBps.
[Sysname-lb-link-lk1] rate-limit bandwidth 1
# Set the maximum inbound bandwidth of the link lk1 to 1 KBps.
[Sysname-lb-link-lk1] rate-limit bandwidth inbound 1
# Set the maximum outbound bandwidth of the link lk1 to 1 KBps.
[Sysname-lb-link-lk1] rate-limit bandwidth outbound 1
Use rate-limit bandwidth to set the maximum bandwidth of a real server.
The maximum bandwidth of a real server is not limited.
Real server view
# Set the maximum bandwidth of the real server rs to 1 KBps.
[Sysname-rserver-rs] rate-limit bandwidth 1
# Set the maximum inbound bandwidth of the real server rs to 1 KBps.
[Sysname-rserver-rs] rate-limit bandwidth inbound 1
# Set the maximum outbound bandwidth of the real server rs to 1 KBps.
[Sysname-rserver-rs] rate-limit bandwidth outbound 1
rate-limit bandwidth (virtual server view)
Use rate-limit bandwidth to set the maximum bandwidth of a virtual server.
The maximum bandwidth of a virtual server is not limited.
Virtual server view
# Set the maximum bandwidth of the IP-type virtual server vs3 to 1 KBps.
[Sysname-vs-ip-vs3] rate-limit bandwidth 1
# Set the maximum inbound bandwidth of the IP-type virtual server vs3 to 1 KBps.
[Sysname-vs-ip-vs3] rate-limit bandwidth inbound 1
# Set the maximum outbound bandwidth of the IP-type virtual server vs3 to 1 KBps.
[Sysname-vs-ip-vs3] rate-limit bandwidth outbound 1
rate-limit connection (link group member view)
Use rate-limit connection to set the maximum number of connections per second of a link group member.
Use undo rate-limit connection to restore the default.
rate-limit connection connection-number
The maximum number of connections per second of a link group member is 0.
connection-number: Specifies the maximum number of connections per second in the range of 0 to 4294967295. 0 means the number is not limited.
# Set the maximum number of connections per second of the link group member lk1 to 1000.
[Sysname-lb-lgroup-lg-#member#-lk1] rate-limit connection 1000
rate-limit connection (link view)
Use rate-limit connection to set the maximum number of connections per second of a link.
The maximum number of connections per second of a link is 0.
Link view
# Set the maximum number of connections per second of the link lk1 to 10000.
[Sysname-lb-link-lk1] rate-limit connection 10000
rate-limit connection (real server view)
Use rate-limit connection to set the maximum number of connections per second of a real server.
The maximum number of connections per second of a real server is 0.
Real server view
# Set the maximum number of connections per second of the real server rs to 10000.
[Sysname-rserver-rs] rate-limit connection 10000
rate-limit connection (server farm member view)
Use rate-limit connection to set the maximum number of connections per second of a server farm member.
The maximum number of connections per second of a server farm member is 0.
# Set the maximum number of connections per second of the server farm member rs1 to 1000.
[Sysname-sfarm-sf-#member#-rs1-port-80] rate-limit connection 1000
rate-limit connection (virtual server view)
Use rate-limit connection to set the maximum number of connections per second of a virtual server.
The maximum number of connections per second of a virtual server is 0.
Virtual server view
# Set the maximum number of connections per second of the IP-type virtual server vs3 to 10000.
[Sysname-vs-ip-vs3] rate-limit connection 10000
rate-limit http-request
Use rate-limit http-request to set the maximum number of HTTP requests per second for a real server.
Use undo rate-limit http-request to restore the default.
rate-limit http-request request-number
The maximum number of HTTP requests per second is 0 for a real server.
Real server view
request-number: Specifies the maximum number of HTTP requests per second, in the range of 0 to 4294967295. 0 means the number is not limited.
# Set the maximum number of HTTP requests per second to 10000 for real server rs.
[Sysname-rserver-rs] rate-limit http-request 10000
real-server (server farm view)
Use real-server to create a server farm member and enter its view, or enter the view of an existing server farm member.
Use undo real-server to delete a server farm member.
real-server real-server-name port port-number
undo real-server real-server-name port port-number
No server farm members exist.
Server farm view
real-server-name: Specifies a server farm member by its name, a case-insensitive string of 1 to 63 characters.
port-number: Specifies the port number of the server farm member, in the range of 0 to 65535.
You can use one of the following methods to add a member to a server farm:
· Use the real-server command in server farm view. H3C recommends using this method.
· Use the server-farm command in real server view.
You cannot use both methods to add a member with the same real server name and port number to a server farm.
# Add server farm member rs1 and enter server farm member view.
server-farm (real server view)
real-server (system view)
Use real-server to create a real server and enter its view, or enter the view of an existing real server.
Use undo real-server to delete the specified real server.
No real servers exist.
real-server-name: Specifies the real server name, a case-insensitive string of 1 to 63 characters.
# Create real server rs and enter real server view.
rebalance per-request
Use rebalance per-request to enable load balancing for each HTTP request.
Use undo rebalance per-request to restore the default.
Load balancing applies to the first HTTP request of a connection. Other HTTP requests are processed in the same way.
HTTP parameter profile view
# Enable load balancing for each HTTP request in the HTTP parameter profile pp1.
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] rebalance per-request
recover-from-auto-shutdown (real server view)
Use recover-from-auto-shutdown to manually recover a real server in Auto shutdown state.
Real server view
Use this command to manually recover a real server shut down by intelligent monitoring.
If health monitoring is not configured, a recovered real server is set to Unknown state.
If health monitoring is configured and succeeds, a recovered real server is set to Active state. If health monitoring fails, a recovered real server is set to Probe-failed state.
# Manually recover a real server in Auto shutdown state.
[Sysname-rserver-rs] recover-from-auto-shutdown
recover-from-auto-shutdown (server farm member view)
Use recover-from-auto-shutdown to manually recover a server farm member in Auto shutdown state.
Use this command to manually recover a server farm member shut down by intelligent monitoring.
If health monitoring is not configured, a recovered server farm member is set to Unknown state.
If health monitoring is configured and succeeds, a recovered server farm member is set to Active state. If health monitoring fails, a recovered server farm member is set to Probe-failed state.
# Manually recover a server farm member in Auto shutdown state.
[Sysname-sfarm-sf-#member#-rs1-port-80] recover-from-auto-shutdown
redirect relocation (LB action view)
Use redirect relocation to enable the redirection feature and specify a redirection URL for an LB action.
Use undo redirect relocation to disable the redirection feature for an LB action.
redirect relocation relocation
The redirection feature is disabled for an LB action.
HTTP LB action view
relocation: Specifies a redirection URL, a case-sensitive string of 1 to 255 characters. You can also specify the question mark (?) or the following character strings as the redirection URL (each character string can be used only once):
· %h: Specifies the host name in the client request packet.
· %p: Specifies the URL in the client request packet.
This command and the server-farm command are mutually exclusive. If you configure one command, the other command (if configured) is automatically cancelled.
This command redirects all HTTP request packets matching an LB action to the specified URL.
# Enable the redirection feature for the HTTP LB action lba1, and specify the redirection URL as https://%h%p.
[Sysname] loadbalance action lba1 type http
[Sysname-lba-http-lba1] redirect relocation https://%h%p
redirect relocation (virtual server view)
Use redirect relocation to enable the redirection feature and specify a redirection URL for a virtual server.
Use undo redirect relocation to disable the redirection feature for a virtual server.
The redirection feature is disabled for a virtual server.
HTTP virtual server view
relocation: Specifies a redirection URL, a case-sensitive string of 1 to 255 characters. The redirection feature redirects all request packets matching the virtual server to the URL. You can also specify the question mark (?) or the following character strings as the redirection URL (each character string can be used only once):
# Enable the redirection feature for the HTTP-type virtual server vs2, and specify the redirection URL as https://%h%p.
[Sysname] virtual-server vs2 type http
[Sysname-vs-http-vs2] redirect relocation https://%h%p
redirect return-code (LB action view)
Use redirect return-code to specify the status code in the redirection packets that the LB device returns to clients.
Use undo redirect return-code to restore the default.
redirect return-code { 301 | 302 }
The status code in the redirection packets that the LB device returns to clients is 302.
HTTP LB action view
301: Deletes request resources permanently.
302: Deletes request resources temporarily.
This configuration takes effect only when the redirection feature is enabled for the HTTP LB action.
# Specify the status code in the redirection packets that the LB device returns to clients as 301 for the HTTP LB action lba1.
[Sysname-lba-http-lba1] redirect return-code 301
redirect relocation
redirect return-code (virtual server view)
This configuration takes effect only when the redirection feature is enabled for the virtual server.
# Specify the status code in the redirection packets that the LB device returns to clients as 301 for the HTTP-type virtual server vs2.
[Sysname-vs-http-vs2] redirect return-code 301
redirect relocation
reload http-response
Use reload http-response to reload a response file.
reload http-response { file filename }
file filename: Specifies a file by its name, a case-insensitive string of 1 to 255 characters.
If a response file changes, you must reload the file to make it take effect.
# Reload response file subsys_intf.js.
[Sysname] reload http-response /index/subsys_intf.js
fallback-action response raw-file
response
request-version all
Use request-version all to enable compression for responses to HTTP 1.0 requests.
Use undo request-version all to restore the default.
request-version all
Compression is disabled for responses to HTTP 1.0 requests.
# Create the HTTP-compression parameter profile http1, and enable compression for responses to HTTP 1.0 requests.
[Sysname-para-http-compression-http1] request-version all
reset loadbalance connections
Use reset loadbalance connections to clear application layer connections.
This command clears all application layer connections, including reused idle connections.
# Clear application layer connections.
<Sysname> reset loadbalance connection
reset loadbalance dns-cache
Use reset loadbalance dns-cache to clear DNS cache information.
reset loadbalance dns-cache [ domain-name domain-name ]
domain-name domain-name: Specifies a domain name, a case-insensitive string of 1 to 253 characters. If you do not specify this option, the command clears DNS cache information for all domain names.
# Clear DNS cache information for all domain names.
<Sysname> reset loadbalance dns-cache
reset loadbalance dns-proxy statistics
Use reset loadbalance dns-proxy statistics to clear transparent DNS proxy statistics.
reset loadbalance dns-proxy statistics [ dns-proxy-name ]
dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all DNS transparent proxies.
# Clear statistics for transparent DNS proxy dns-proxy1.
<Sysname> reset loadbalance dns-proxy statistics dns-proxy1
display loadbalance dns-proxy statistics
reset loadbalance dns-server statistics
Use reset loadbalance dns-server statistics to clear DNS server statistics or DNS server pool member statistics.
reset loadbalance dns-server statistics [ dns-server-name ]
reset loadbalance dns-server statistics dns-server-pool dns-server-pool-name [ name dns-server-name port port-number ]
dns-server-name: Specifies a DNS server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all DNS servers.
dns-server-pool dns-server-pool-name: Clears statistics for members of a DNS server pool. The dns-server-pool-name argument specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
dns-server dns-server-name port port-number: Clears statistics for a DNS server pool member. The dns-server-name argument specifies a DNS server pool member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the DNS server pool member, in the range of 0 to 65535. If you do not specify this option, the command clears statistics for all members of a DNS server pool.
# Clear statistics for DNS server ds1.
<Sysname> reset loadbalance dns-server statistics ds1
# Clear statistics for all members in DNS server pool dsp.
<Sysname> reset loadbalance dns-server statistics dns-server-pool dsp
display loadbalance dns-server statistics
reset loadbalance hot-backup statistics
Use reset loadbalance hot-backup statistics to clear LB hot backup statistics.
# Clear LB hot backup statistics.
<Sysname> reset loadbalance hot-backup statistics
reset loadbalance link statistics
Use reset loadbalance link statistics to clear link statistics or link group member statistics.
reset loadbalance link statistics [ link-name ]
reset loadbalance link statistics link-group link-group-name [ name link-name ]
link-name: Specifies a link by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics about all links.
link-group link-group-name: Clears statistics for members of a link group. The link-group-name argument specifies a link group by its name, a case-insensitive string of 1 to 63 characters.
name link-name: Clears statistics for of a link group member. The link-name argument specifies a link group member by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command clears statistics for all members of a link group.
# Clear statistics about all links.
<Sysname> reset loadbalance link statistics
# Clear statistics about all members in link group lg.
<Sysname> reset loadbalance link statistics link-group lg
reset loadbalance local-dns-server parse-fail-record
Use reset loadbalance local-dns-server parse-fail-record to clear DNS request parse failures.
# Clear DNS request parse failures.
<Sysname> reset loadbalance local-dns-server parse-fail-record
reset loadbalance proximity
Use reset loadbalance proximity to clear proximity entry information.
reset loadbalance proximity [ vpn-instance vpn-instance-name ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command clears proximity entry information for the public network.
ip [ ipv4-address ]: Clears IPv4 proximity entry information. If you specify the ipv4-address argument, this command clears information about the proximity entry corresponding to the IPv4 address. If you do not specify the ipv4-address argument, this command clears information about all IPv4 proximity entries.
ipv6 [ ipv6-address ]: Clears IPv6 proximity entry information. If you specify the ipv6-address argument, this command clears information about the proximity entry corresponding to the IPv6 address. If you do not specify the ipv6-address argument, this command clears information about all IPv6 proximity entries.
If you do not specify the vpn-instance, ip, or ipv6 keyword, this command clears information about all IPv4 and IPv6 proximity entries for the public network.
# Clear information about the proximity entry corresponding to the IPv4 address 1.1.1.1 for the VPN instance vrf1.
<Sysname> reset loadbalance proximity vpn vrf1 ip 1.1.1.1
# Clear information about all IPv6 proximity entries for the public network.
<Sysname> reset loadbalance proximity ipv6
reset real-server statistics
Use reset real-server statistics to clear real server statistics or server farm member statistics.
reset real-server statistics [ real-server-name ]
reset real-server statistics server-farm server-farm-name [ name real-server-name port port-number ]
real-server-name: Clears statistics of the specified real server. The real-server-name argument specifies a real server name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics of all real servers.
server-farm server-farm-name: Clears statistics for members of a server farm. The server-farm-name argument specifies a server farm by its name, a case-insensitive string of 1 to 63 characters.
name real-server-name port port-number: Clears statistics for a server farm member. The real-server-name argument specifies a server farm member by its name, a case-insensitive string of 1 to 63 characters. The port-number argument specifies the port number of the server farm member, in the range of 0 to 65535. If you do not specify this option, the command clears statistics for all members of a server farm.
# Clear statistics of all real servers.
<Sysname> reset real-server statistics
# Clear statistics of all members in server farm sf.
<Sysname> reset real-server statistics server-farm sf
display real-server statistics
reset virtual-server statistics
Use reset virtual-server statistics to clear virtual server statistics.
reset virtual-server statistics [ virtual-server-name ]
virtual-server-name: Clears statistics of the specified virtual server. The virtual-server-name argument specifies a virtual server name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics of all virtual servers.
# Clear statistics of all virtual servers.
<Sysname> reset virtual-server statistics
display virtual-server statistics
response
Use response to specify a response file for matching HTTP requests.
Use undo response to restore the default.
response { url url file filename | workpath workpath zip-file zip-filename }
undo response { url url | workpath workpath }
No response file is specified for HTTP requests.
HTTP LB action view
url url: Specifies the URL path used to match HTTP requests, a case-sensitive string of 1 to 255 characters. The specified URL path must start with a forward slash (/).
file filename: Specifies an uncompressed file by its name, a case-insensitive string of 1 to 255 characters.
workpath workpath: Specifies a working path to match the URL in HTTP requests, a case-sensitive string of 1 to 255 characters. The working path can be a single forward slash (/), or a string that starts with a forward slash and does not end with a forward slash.
zip-file zip-filename: Specifies a zip file by its name, a case-insensitive string of 1 to 255 characters. The relative path in the zip file is used to match the URL in HTTP requests.
If the URL path in a client request matches the specified URL path, the device responds to the request by using an uncompressed file.
If the URL path in a client request matches the specified working path plus a relative path in the zip file, the device responds to the request by using the file in the zip file. For example, if you configure the response workpath /index zip-file flash:/za/zb/test.zip command and a relative path /css/col.css exists in test.zip, the matching URL is /index/css/col.css and the response file is col.css.
URL-encoded URLs cannot be matched.
If you configure both an uncompressed file and a compressed file for the same URL path, the uncompressed file is used to respond to matching HTTP requests.
For the same HTTP LB action, only one uncompressed file can be used for a URL, and one uncompressed file can be used for multiple URLs.
If you specify multiple compressed files for one or more URL paths in the same HTTP LB action, the most recent configuration takes effect.
If you specify multiple uncompressed files for one URL path in the same HTTP LB action, the most recent configuration takes effect. One uncompressed file can be used for different URL paths.
Any two of the following commands are mutually exclusive:
· response
· server-farm (LB action view)
· redirect relocation (LB action view)
# Specify response file subsys.js for the HTTP requests with URL path /index/subsys/subsys_intf.js.
[Sysname] loadbalance action a_http type http
[Sysname-lba-http-a_http] response url /index/subsys/subsys_intf.js file subsys.js
display loadbalance action
route-advertisement enable
Use route-advertisement enable to enable IP address advertisement for a virtual server.
Use undo route-advertisement enable to disable IP address advertisement for a virtual server.
IP address advertisement is disabled for a virtual server.
Virtual server view
After this feature is configured, the device advertises the IP address of the virtual server to OSPF for route calculation. When the service of a data center switches to another data center, the traffic to the virtual server can also be switched to that data center. For information about OSPF, see Layer 3—IP Routing Configuration Guide.
# Enable IP address advertisement for the virtual server vs.
[Sysname] virtual-server vs type ip
[Sysname-vs-ip-vs] route-advertisement enable
router interface
Use router interface to specify an outgoing interface for an LB link.
Use undo router interface to delete the outgoing interface for an LB link.
router interface interface-type interface-number
No outgoing interface is specified for an LB link.
LB link view
interface-type interface-number: Specifies an outgoing interface.
In scenarios where IP addresses are obtained through PPPoE, use this command to dynamically obtain the outbound next hop IP address through the specified outgoing interface.
The specified outgoing interface must be an interface that can dynamically obtain IP addresses.
You can configure both this command and the router ip or router ipv6 command. The command configured later overwrites the command configured first.
If you configure this command after configuring the vpn-instance (link view) command, this command overwrites the vpn-instance (link view) command. After you configure this command, you cannot configure the vpn-instance (link view) command.
# Specify Dialer0 as the outgoing interface for the LB link cnc.
[Sysname] loadbalance link cnc
[Sysname-lb-link-cnc] router interface Dialer0
router ip
Use router ip to specify the outbound next hop for an LB link.
Use undo router ip to restore the default.
router ip ipv4-address
undo router ip
The outbound next hop is not specified for an LB link.
LB link view
ipv4-address: Specifies an IPv4 address, which cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X.
You can specify only one outbound next hop for an LB link.
# Specify the outbound next hop as 1.2.3.4 for the LB link lk1.
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] router ip 1.2.3.4
router ipv6
Use router ipv6 to specify the outbound next hop for an LB link.
Use undo router ipv6 to restore the default.
router ipv6 ipv6-address
undo router ipv6
LB link view
ipv6-address: Specifies an IPv6 address, which cannot be an all-zero address, a multicast address, a loopback address, or a link-local address.
# Specify the outbound next hop as 8008::8 for the LB link lk1.
[Sysname-lb-link-lk1] router ipv6 8008::8
rst threshold
Use rst threshold to set the RST packet count threshold for a TCP-RST LB probe template.
Use undo rst threshold to restore the default.
rst threshold number
undo rst threshold
The RST packet count threshold is 1000000.
TCP-RST LB probe template view
number: Specifies the RST packet count threshold value, in the range of 1 to 4294967295.
When the number of RST packets sent by a real server reaches the threshold, the protection action specified in the protect-action command is taken.
# In TCP-RST LB probe template rsttplt, set the RST packet count threshold to 20.
[Sysname] loadbalance probe-template tcp-rst rsttplt
[Sysname-lbpt-tcp-rst-rsttplt] rst threshold 20
protect-action
rtt weight
Use rtt weight to set the network delay weight for proximity calculation.
Use undo rtt weight to restore the default.
rtt weight rtt-weight
The network delay weight for proximity calculation is 100.
Proximity view
rtt-weight: Specifies the network delay weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher weight.
# Set the network delay weight for proximity calculation to 200.
[Sysname] loadbalance proximity
[Sysname-lb-proximity] rtt weight 200
rule
Use rule to configure a filtering rule for compression.
Use undo rule to restore the default.
rule [ rule-id ] { deny | permit } { content-type | url } expression
undo rule rule-id
No filtering rules are configured.
HTTP-compression parameter profile view
rule-id: Specifies a rule by its ID in the range of 1 to 65535. If the rule does not exist, the command creates the rule. If the rule already exists, the command modifies the rule. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest number.
deny: Does not compress matching packets.
permit: Compresses matching packets.
content-type: Matches content types in the content-type header of packets.
url: Matches URLs in packets.
expression: Specifies a regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
# Create the HTTP-compression parameter profile http1, and configure the device to not compress the response packets containing the string image in URLs.
[Sysname-para-http-compression-http1] rule deny url image
secondary-cookie delimiters
Use secondary-cookie delimiters to configure the delimiter that separates secondary cookies in URLs.
Use undo secondary-cookie delimiters to restore the default.
secondary-cookie delimiters text
The delimiter that separates secondary cookies in URLs can be slash (/), ampersand (&), number sign (#), or plus (+).
text: Specifies the delimiter, a string of 1 to 4 characters including exclamation mark (!), quotation mark (',"), number sign (#), semicolon (;), brackets (( ),[ ], < >), question mark (?), backslash (\), caret (^), grave accent (`), vertical bar (|), colon (:), at sign (@), ampersand (&), dollar sign ($), plus (+), asterisk (*), comma (,), and slash (/). Each character in the string is considered as a delimiter.
# For the HTTP parameter profile pp1, configure the delimiter that separates secondary cookies in URLs as slash (/), at sign (@), number sign (#), or dollar sign ($).
[Sysname-para-http-pp1] secondary-cookie delimiters !@#$
secondary-cookie start
Use secondary-cookie start to configure the start delimiter for secondary cookies in URLs.
Use undo secondary-cookie start to restore the default.
secondary-cookie start text
The start delimiter for secondary cookies in URLs is question mark (?).
text: Specifies the delimiter, a string of 1 to 2 characters including exclamation mark (!), quotation mark ("), number sign (#), semicolon (;), brackets ([ ], < >), question mark (?), backslash (\), caret (^), grave accent (`), and vertical bar (|).
# For the HTTP parameter profile pp1, configure the start delimiter for secondary cookies in URLs as question mark (?) or exclamation mark (!).
[Sysname-para-http-pp1] secondary-cookie start ?!
selected-link
Use selected-link to specify the number of links to participate in scheduling.
Use undo selected-link to restore the default.
selected-link min min-number max max-number
undo selected-link
The links with the highest priority participate in scheduling.
Link group view
min min-number: Specifies the minimum number of links to participate in scheduling, in the range of 1 to 1000.
max max-number: Specifies the maximum number of links to participate in scheduling, in the range of 1 to 1000. The value of the max-number argument must be greater than or equal to the value of the min-number argument.
If the number of links available to participate in scheduling exceeds the max-number setting, the max-number setting applies.
If the number of links available to participate in scheduling is smaller than the min-number setting, more links are selected by priority in descending order.
# Configure the minimum number and maximum number of links in the link group lg to participate in scheduling as 20 and 30, respectively.
[Sysname-lb-lgroup-lg] selected-link min 20 max 30
Use selected-server to specify the number of DNS servers to participate in scheduling.
Use undo selected-server to restore the default.
selected-server min min-number max max-number
The DNS servers with the highest priority participate in scheduling.
min min-number: Specifies the minimum number of DNS servers to participate in scheduling, in the range of 1 to 1000.
max max-number: Specifies the maximum number of DNS servers to participate in scheduling, in the range of 1 to 1000. The value of the max-number argument must be greater than or equal to the value of the min-number argument.
If the number of DNS servers available to participate in scheduling exceeds the max-number setting, the max-number setting applies.
If the number of DNS servers available to participate in scheduling is less than the min-number setting, more DNS servers are selected by priority in descending order.
# Configure the minimum number and maximum number of DNS servers in DNS server pool dns-pool to participate in scheduling as 20 and 30, respectively.
[Sysname-lb-dspool-dns-pool] selected-server min 20 max 30
Use selected-server to specify the number of real servers to participate in scheduling.
The real servers with the highest priority participate in scheduling.
Server farm view
min min-number: Specifies the minimum number of real servers to participate in scheduling, in the range of 1 to 1000.
max max-number: Specifies the maximum number of real servers to participate in scheduling, in the range of 1 to 1000. The value of the max-number argument must be greater than or equal to the value of the min-number argument.
If the number of real servers available to participate in scheduling exceeds the max-number setting, the max-number setting applies.
If the number of real servers available to participate in scheduling is less than the min-number setting, more real servers are selected by priority in descending order.
# Configure the minimum number and maximum number of real servers in the server farm sf to participate in scheduling as 20 and 30, respectively.
[Sysname-sfarm-sf] selected-server min 20 max 30
server-connection reuse
Use server-connection reuse to enable connection reuse between the LB device and the server.
Use undo server-connection reuse to disable connection reuse between the LB device and the server.
Connection reuse between the LB device and the server is disabled.
This command allows the LB device to establish connections to the server that can be reused by clients. Because multiple clients can use the same connection, the number of connections between the clients and the server is reduced.
This command is not supported by the virtual servers of the fast HTTP type.
# Enable connection reuse between the LB device and the server for the HTTP parameter profile pp1.
[Sysname-para-http-pp1] server-connection reuse
Use server-farm to specify the primary server farm.
Use undo server-farm to restore the default.
server-farm server-farm-name [ backup backup-server-farm-name ] [ sticky sticky-name ]
undo server-farm
No primary server farm is specified.
LB action view
server-farm-name: Specifies a primary server farm name, a case-insensitive string of 1 to 63 characters.
backup backup-server-farm-name: Specifies a backup server farm name, a case-insensitive string of 1 to 63 characters.
sticky sticky-name: Specifies the name of the sticky group corresponding to the server farm. It is a case-insensitive string of 1 to 63 characters.
This command is mutually exclusive with the forward all or redirect relocation command. If you configure one command, the other command (if configured) is automatically cancelled.
When the primary server farm is available (contains real servers), packets are forwarded through the primary server farm. When the primary server farm is not available, packets are forwarded through the backup server farm.
# Specify the primary server farm sf, the backup server farm sfb, and the sticky group sg1 for the generic LB action lba1.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] server-farm sf backup sfb sticky sg1
forward all
Use server-farm to specify the server farm for a real server.
undo server-farm [ server-farm-name ]
A real server does not belong to any server farm.
Real server view
server-farm-name: Specifies a server farm name, a case-insensitive string of 1 to 63 characters.
You can specify a server farm that has not been created.
# Specify the server farm sf for the real server rs.
[Sysname] real-server rs
[Sysname-rserver-rs] server-farm sf
server-farm (system view)
Use server-farm to create a server farm and enter its view, or enter the view of an existing server farm.
Use undo server-farm to delete the specified server farm.
undo server-farm server-farm-name
No server farms exist.
You can add servers with common attributes to a server farm to facilitate management.
# Create the server farm sf and enter server farm view.
[Sysname-sfarm-sf]
service enable (transparent DNS proxy view)
Use service enable to enable the transparent DNS proxy feature.
Use undo service enable to disable the transparent DNS proxy feature.
service enable
undo service enable
The transparent DNS proxy feature is disabled.
Transparent DNS proxy view
# Enable the transparent DNS proxy feature for transparent DNS proxy dns-proxy1.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] service enable
service enable (virtual server view)
Use service enable to enable a virtual server.
Use undo service enable to disable a virtual server.
service enable
undo service enable
A virtual server is disabled.
Virtual server view
# Enable the IP-type virtual server vs3.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] service enable
set ip tos (LB action view)
Use set ip tos to set the ToS field value of IP packets sent to the server.
Use undo set ip tos to restore the default.
set ip tos tos-number
undo set ip tos
The ToS field of IP packets sent to the server is not changed.
LB action view
tos-number: Specifies the ToS field value in the range of 0 to 255.
# Set the ToS field value to 20 for IP packets sent to the server for the generic LB action lba1.
[Sysname-lba-generic-lba1] set ip tos 20
set ip tos (parameter profile view)
Use set ip tos to set the ToS field value of IP packets sent to the client.
undo set ip tos
The ToS field of IP packets sent to the client is not changed.
Parameter profile view
This command is available in IP parameter profile view only.
# Set the ToS field value to 20 for IP packets sent to the client for the IP parameter profile pp2.
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2] set ip tos 20
shutdown (link group member view)
Use shutdown to shut down a link group member.
Use undo shutdown to activate a link group member.
shutdown
A link group member is activated.
# Shut down the link group member lk1.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg-#member#-lk1] shutdown
shutdown (link view)
Use shutdown to shut down a link.
Use undo shutdown to activate a link.
shutdown
A link is activated.
Link view
# Shut down the link lk1.
[Sysname-lb-link-lk1] shutdown
Use shutdown to shut down a real server.
Use undo shutdown to activate a real server.
shutdown
A real server is activated.
Real server view
# Shut down the real server rs.
[Sysname-rserver-rs] shutdown
Use shutdown to shut down a server farm member.
Use undo shutdown to activate a server farm member.
shutdown
A server farm member is activated.
# Shut down the server farm member rs1.
[Sysname-sfarm-sf-#member#-rs1-port-80] shutdown
skip current-dns-proxy
Use skip current-dns-proxy to skip the current transparent DNS proxy.
Use undo skip current-dns-proxy to restore the default.
The forwarding mode is to discard packets.
DNS LB action view
This command enables DNS requests to skip the current transparent DNS proxy and match the next transparent DNS proxy or virtual server.
A DNS request can skip a maximum of five transparent DNS proxies and virtual servers.
This command is mutually exclusive with the dns-server-pool or forward all command. If you configure one command, the other command (if configured) is automatically cancelled.
# Skip the current transparent DNS proxy in DNS LB action lba1.
[Sysname] loadbalance action lba1 type dns
[Sysname-lba-dns-lba1] skip current-dns-proxy
slow-online (link group view)
Use slow-online to enable the slow online feature for a link group.
Use undo slow-online to disable the slow online feature for a link group.
slow-online [ standby-time standby-time ramp-up-time ramp-up-time ]
undo slow-online
The slow online feature is disabled for a link group.
Link group view
standby-time standby-time: Specifies the standby timer in the range of 0 to 600 seconds. The default is 5 seconds.
ramp-up-time ramp-up-time: Specifies the ramp-up timer in the range of 3 to 600 seconds. The default is 5 seconds.
The links newly added to a link group might be unable to immediately process large numbers of services assigned by the LB device. To resolve this issue, enable the slow online feature for the link group. The feature uses the standby timer and ramp-up timer. When a link is added, the LB device does not assign any service to the link until the standby timer expires.
When the standby timer expires, the ramp-up timer starts. During the ramp-up time, the LB device increases the service amount according to the processing capability of the link, until the ramp-up timer expires.
# Enable the slow online feature for the link group lg.
[Sysname-lb-lgroup-lg] slow-online
slow-online (server farm view)
Use slow-online to enable the slow online feature for a server farm.
Use undo slow-online to disable the slow online feature for a server farm.
undo slow-online
The slow online feature is disabled for a server farm.
Server farm view
The real servers newly added to a server farm might not be able to immediately process large numbers of services assigned by the LB device. To resolve this issue, enable the slow online feature for the server farm. The feature uses the standby timer and ramp-up timer. When a real server is added, the LB device does not assign any service to the real server until the standby timer expires.
When the standby timer expires, the ramp-up timer starts. During the ramp-up time, the LB device increases the service amount according to the processing capability of the real server, until the ramp-up timer expires.
# Enable the slow online feature for the server farm sf.
[Sysname] server-farm sf
[Sysname-sfarm-sf] slow-online
slow-shutdown enable (link group member view)
Use slow-shutdown enable to enable the slow offline feature for a link group member.
Use undo slow-shutdown enable to disable the slow offline feature for a link group member.
The slow offline feature is disabled for a link group member.
The shutdown command immediately terminates existing connections of a link group member. The slow offline feature ages out the connections, and does not establish new connections.
To enable the slow offline feature for a link group member, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow offline feature does not take effect and the link group member is shut down.
# Enable the slow offline feature for the link group member lk1.
[Sysname-lb-lgroup-lg-link-lk1] slow-shutdown enable
slow-shutdown enable (link view)
Use slow-shutdown enable to enable the slow offline feature for a link.
Use undo slow-shutdown enable to disable the slow offline feature for a link.
The slow offline feature is disabled for a link.
Link view
The shutdown command immediately terminates existing connections of a link. The slow offline feature ages out the connections, and does not establish new connections.
To enable the slow offline feature for a link, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow offline feature does not take effect and the link is shut down.
# Enable the slow offline feature for the link lk1.
[Sysname-lb-link-lk1] slow-shutdown enable
slow-shutdown enable (real server view)
Use slow-shutdown enable to enable the slow offline feature for a real server.
Use undo slow-shutdown enable to disable the slow offline feature for a real server.
The slow offline feature is disabled for a real server.
Real server view
The shutdown command immediately terminates existing connections of a real server. The slow offline feature ages out the connections, and does not establish new connections.
To enable the slow offline feature for a real server, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow offline feature does not take effect and the real server is shut down.
# Enable the slow offline feature for the real server rs.
[Sysname-rserver-rs] slow-shutdown enable
slow-shutdown enable (server farm member view)
Use slow-shutdown enable to enable the slow offline feature for a server farm member.
Use undo slow-shutdown enable to disable the slow offline feature for a server farm member.
The slow offline feature is disabled for a server farm member.
Server farm member view
The shutdown command immediately terminates existing connections of a server farm member. The slow offline feature ages out the connections, and does not establish new connections.
To enable the slow offline feature for a server farm member, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow offline feature does not take effect and the server farm member is shut down.
# Enable the slow offline feature for the server farm member rs1.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname-sfarm-sf-#member#-rs1-port-80] slow-shutdown enable
snat-pool (link group view)
Use snat-pool to specify the SNAT address pool to be referenced by a link group.
Use undo snat-pool to restore the default.
snat-pool pool-name
undo snat-pool
No SNAT address pool is referenced by a link group.
Link group view
pool-name: Specifies the SNAT address pool name, a case-insensitive string of 1 to 63 characters.
After a link group references an SNAT address pool, the LB device replaces the source address of packets it receives with an SNAT address before forwarding the packets.
# Specify the SNAT address pool lbsp to be referenced by the link group lg.
[Sysname-lb-lgroup-lg] snat-pool lbsp
snat-pool (server farm view)
Use snat-pool to specify the SNAT address pool to be referenced by a server farm.
snat-pool pool-name
undo snat-pool
No SNAT address pool is referenced by a server farm.
Server farm view
After a server farm references an SNAT address pool, the LB device replaces the source address of packets it receives with an SNAT address before forwarding the packets.
# Specify the SNAT address pool lbsp to be referenced by the server farm sf.
[Sysname-sfarm-sf] snat-pool lbsp
snmp-agent trap enable loadbalance
Use snmp-agent trap enable loadbalance to enable SNMP notifications for load balancing.
Use undo snmp-agent trap enable loadbalance to disable SNMP notifications for load balancing.
All SNMP notifications are enabled for load balancing.
To report critical load balancing events to an NMS, enable SNMP notifications for load balancing. For load balancing event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for load balancing.
[Sysname] undo snmp-agent trap enable loadbalance
source-ip object-group
Use source-ip object-group to enable collection of HTTP traffic statistics by source IP address object group.
Use undo source-ip object-group to remove a source IP address object group for HTTP traffic statistics collection.
source-ip object-group object-group-name
undo source-ip object-group object-group-name
HTTP traffic statistics are collected on a per-IP address basis.
HTTP statistics parameter profile view
object-group-name: Specifies a source IP address object group by its name, a case-insensitive string of 1 to 31 characters.
If HTTP packets match the specified URL and source IP address object group, they are counted based on the source IP address object group. If HTTP packets match the specified URL but do not match the specified source IP address object group, they are counted based on the source IP address.
You can specify a maximum of 1024 source IP address object groups in one HTTP statistics parameter profile.
This command takes effect only on IP address objects configured by using the host, subnet, and range keywords in the network command. For information about configuring IP address objects, see object group configuration in Security Configuration Guide.
# In HTTP statistics parameter profile http1, enable collection of HTTP traffic statistics by source IP address object group cnc.
[Sysname] parameter-profile http1 type http-statistics
[Sysname-para-http-statistics-http1] source-ip object-group cnc
network (Security Command Reference)
object-group (Security Command Reference)
ssl session-id
Use ssl session-id to configure an SSL sticky method based on SSL session ID.
Use undo ssl session-id to restore the default.
ssl session-id
undo ssl session-id
No sticky methods exist.
SSL sticky group view
The SSL sticky method based on SSL session ID applies only to HTTPS request packets. This sticky method requires specifying an SSL server policy for the virtual server.
# Configure the SSL sticky method based on SSL session ID for the SSL sticky group sg6.
[Sysname] sticky-group sg6 type ssl
[Sysname-sticky-ssl-sg6] ssl session-id
ssl url rewrite
Use ssl url rewrite to rewrite the URL in the Location header of HTTP response packets sent by the server.
Use undo ssl url rewrite to remove the configuration.
ssl url rewrite location location [ clearport clear-port ] [ sslport ssl-port ]
undo ssl url rewrite location location [ clearport clear-port ]
The URL in the Location header of HTTP response packets sent by the server is not rewritten.
HTTP LB action view
location location: Specifies the Location header URL regular expression, a string of 1 to 255 characters.
clearport clear-port: Specifies the HTTP port number to be rewritten, in the range of 1 to 65535. The default is 80.
sslport ssl-port: Specifies the SSL port number after rewrite, in the range of 1 to 65535. The default is 443.
If the Location header of an HTTP response packet contains the location and clear-port values, the system rewrites HTTP in the URL to HTTPS and rewrites the clear-port value to the ssl-port value.
# For the HTTP LB action lba2, rewrite the URL http://www.ss.com:8080 in the Location header of HTTP response packets sent by the server to https://www.ss.com:443.
[Sysname] loadbalance action lba2 type http
[Sysname-lba-http-lba2] ssl url rewrite location www.ss.com clearport 8080 sslport 443
ssl-client-policy (LB action view)
Use ssl-client-policy to specify an SSL client policy to encrypt traffic between the LB device (SSL client) and the SSL server.
Use undo ssl-client-policy to restore the default.
ssl-client-policy policy-name
undo ssl-client-policy policy-name
No SSL client policy is referenced.
HTTP LB action view
policy-name: Specifies an SSL policy by its name, a case-insensitive string of 1 to 31 characters.
The virtual servers of the fast HTTP type do not support this command.
You must disable and then enable a virtual server for a modified SSL policy to take effect.
# Specify the SSL client policy scp for the HTTP LB action lba2.
[Sysname-lba-http-lba2] ssl-client-policy scp
ssl-client-policy (virtual server view)
Use ssl-client-policy to specify an SSL client policy for a virtual server to encrypt traffic between the LB device (SSL client) and the SSL server.
A virtual server does not reference any SSL client policy.
# Specify the SSL client policy scp for the HTTP virtual server vs2.
[Sysname-vs-http-vs2] ssl-client-policy scp
ssl-server-policy
Use ssl-server-policy to specify an SSL server policy for a virtual server to encrypt traffic between the LB device (SSL server) and the SSL client.
Use undo ssl-server-policy to restore the default.
ssl-server-policy policy-name
undo ssl-server-policy policy-name
A virtual server does not reference any SSL server policy.
HTTP/TCP virtual server view
# Specify the SSL server policy ssp for the HTTP virtual server vs2.
[Sysname-vs-http-vs2] ssl-server-policy ssp
statistics-match url
Use statistics-match url to configure a URL match rule.
Use undo statistics-match url to delete a URL match rule.
statistics-match [ rule-id ] url url
undo statistics-match rule-id
No URL match rules exist.
Statistics node view
rule-id: Specifies the match rule ID in the range of 1 to 256. If you do not specify a match rule ID, the system assigns the smallest available rule ID to the match rule.
url: Specifies a URL regular expression, a string of 1 to 255 characters. The string cannot contain question marks (?).
You can configure a maximum of 256 URL match rules for one statistics node.
# In statistics node bank, configure a string of .html to match URLs in HTTP packets.
[Sysname-para-http-statistics-http1] node bank
[Sysname-para-http-statistics-http1-node-bank] statistics-match url *.html
sticky-group
Use sticky-group to create a sticky group and enter its view, or enter the view of an existing sticky group.
Use undo sticky-group to delete the specified sticky group.
sticky-group group-name [ type { address-port | http-content | http-cookie | http-header | payload | radius| sip | ssl } ]
undo sticky-group group-name
No sticky groups exist.
group-name: Specifies a sticky group name, a case-insensitive string of 1 to 63 characters.
type { address-port | http-content | http-cookie | http-header | payload | radius | sip | ssl }: Specifies the sticky group type, address and port, HTTP entity, HTTP cookie, HTTP header, HTTP or UDP payload, RADIUS, SIP, or SSL. When you create a sticky group, you must specify the sticky group type. You can enter an existing sticky group view without entering the type of the sticky group.
A sticky group uses a specific sticky method to distribute similar sessions to the same real server or link. The sticky method applies to the first packet of a session. Subsequent packets of the session are distributed to the same real server or link.
# Create the address- and port-type sticky group sg1 and enter sticky group view.
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1]
sticky-over-busy enable
Use sticky-over-busy enable to enable stickiness-over-busyness.
Use undo sticky-over-busy enable to disable stickiness-over-busyness.
Stickiness-over-busyness is disabled.
Sticky group view
This command enables the device to assign client requests to real servers based on sticky entries, regardless of whether the real servers are busy.
When stickiness-over-busyness is disabled, the device assigns client requests to only the real servers in normal state.
# In address- and port-type sticky group sg1, enable stickiness-over-busyness.
[Sysname-sticky-address-port-sg1] sticky-over-busy enable
sticky-sync enable (transparent DNS proxy view)
Use sticky-sync enable to enable sticky entry synchronization for a transparent DNS proxy.
Use undo sticky-sync enable to disable sticky entry synchronization for a transparent DNS proxy.
sticky-sync enable
Sticky entry synchronization is disabled for a transparent DNS proxy.
This command can back up sticky entry information to ensure service continuity during a master and backup switchover in hot backup mode.
# Enable sticky entry synchronization for transparent DNS proxy dns_proxy1.
<Sysname>system-view
[Sysname] loadbalance dns-proxy dns_proxy1 type udp
[Sysname-lb-dp-udp-dns_proxy1] sticky-sync enable
sticky-sync enable (virtual server view)
Use sticky-sync enable to enable sticky entry synchronization for a virtual server.
Use undo sticky-sync enable to disable sticky entry synchronization for a virtual server.
Sticky entry synchronization is disabled for a virtual server.
Virtual server view
For successful sticky entry synchronization, if you want to specify a sticky group, enable sticky entry synchronization before specifying a sticky group on both LB devices. You can specify a sticky group by using the sticky sticky-name option when you specify a primary server farm (see the default server-farm command).
# Enable sticky entry synchronization for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] sticky-sync enable
success-criteria (DNS server pool member view)
Use success-criteria to specify the health monitoring success criteria for a DNS server pool member.
Use undo success-criteria to restore the default.
success-criteria { all | at-least min-number }
Health monitoring succeeds only when all the specified health monitoring methods succeed.
all: Specifies the health monitoring success criteria as all successful health monitoring methods.
at-least min-number: Specifies the health monitoring success criteria as the specified minimum number of successful health monitoring methods, in the range of 1 to 4294967295.
If the min-number setting exceeds the number of existing health monitoring methods on the device, the number of existing health monitoring methods applies.
The health monitoring success criteria configuration in DNS server pool member view takes precedence over the configuration in DNS server pool view.
The health monitoring result for a DNS server affects the availability of a DNS server pool member. The health monitoring result for a DNS server pool member does not affect the availability of a DNS server.
# Configure the health monitoring success criteria for the DNS server pool member ds1 as a minimum number of 2 successful health monitoring methods.
[Sysname] loadbalance dns-server-pool dsp1
[Sysname-lb-dsp-dsp1] dns-server ds1 port 10
[Sysname-lb-dsp-dsp1-#member#-ds1-port-10] success-criteria at-least 2
success-criteria (DNS server pool view)
Use success-criteria to specify the health monitoring success criteria for a DNS server pool.
The health monitoring success criteria configuration in DNS server view takes precedence over the configuration in DNS server pool view.
# Configure the health monitoring success criteria for the DNS server pool dns-pool as a minimum number of 2 successful health monitoring methods.
[Sysname] loadbalance dns-server-pool dns-pool
[Sysname-lb-dspool-dns-pool] success-criteria at-least 2
success-criteria (DNS server view)
Use success-criteria to specify the health monitoring success criteria for a DNS server.
DNS server view
# Configure the health monitoring success criteria for DNS server ds1 as a minimum number of 2 successful health monitoring methods.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] success-criteria at-least 2
success-criteria (link group member view)
Use success-criteria to specify the health monitoring success criteria for a link group member.
Link group member view
The health monitoring success criteria configuration in link group member view takes precedence over the configuration in link group view.
The health monitoring result for a link affects the availability of a link group member. The health monitoring result for a link group member does not affect the availability of a link.
# Configure the health monitoring success criteria for the link group member lk1 as a minimum number of 2 successful health monitoring methods.
[Sysname-lb-lgroup-lg] link lk1
[Sysname-lb-lgroup-lg-#member#-lk1] success-criteria at-least 2
success-criteria (link group view)
Use success-criteria to specify the health monitoring success criteria for a link group.
Link group view
The health monitoring success criteria configuration in link view takes precedence over the configuration in link group view.
# Configure the health monitoring success criteria for the link group lg as a minimum number of 2 successful health monitoring methods.
[Sysname-lb-lgroup-lg] success-criteria at-least 2
success-criteria (link view)
Use success-criteria to specify the health monitoring success criteria for an LB link.
LB link view
# Configure the health monitoring success criteria for the LB link lk1 as a minimum number of 2 successful health monitoring methods.
[Sysname-lb-link-lk1] success-criteria at-least 2
success-criteria (real server view)
Use success-criteria to specify the health monitoring success criteria for a real server.
Real server view
The health monitoring success criteria configuration in real server view takes precedence over the configuration in server farm view.
# Configure the health monitoring success criteria for the real server rs as a minimum number of 2 successful health monitoring methods.
[Sysname-rserver-rs] success-criteria at-least 2
success-criteria (server farm member view)
Use success-criteria to specify the health monitoring success criteria for a server farm member.
The health monitoring success criteria configuration in server farm member view takes precedence over the configuration in server farm view.
The health monitoring result for a real server affects the availability of a server farm member. The health monitoring result for a server farm member does not affect the availability of a real server.
# Configure the health monitoring success criteria for the server farm member rs1 as a minimum number of 2 successful health monitoring methods.
[Sysname-sfarm-sf-#member#-rs1-port-80] success-criteria at-least 2
success-criteria (server farm view)
Use success-criteria to specify the health monitoring success criteria for a server farm.
Server farm view
# Configure the health monitoring success criteria for the server farm sf as a minimum number of 2 successful health monitoring methods.
[Sysname-sfarm-sf] success-criteria at-least 2
syn retransmission-timeout
Use syn retransmission-timeout to set the retransmission timeout time for SYN packets.
Use undo syn retransmission-timeout to restore the default.
syn retransmission-timeout timeout-value
The retransmission timeout time for SYN packets is 10 seconds.
TCP parameter profile view
timeout-value: Specifies the retransmission timeout time for SYN packets, in the range of 1 to 75 seconds.
This command sets the amount of time the device waits for a SYN ACK before closing a TCP connection.
# Set the retransmission timeout time for SYN packets to 5 seconds for TCP connections.
[Sysname] parameter-profile profile type tcp
[Sysname-para-tcp-profile] syn retransmission-timeout 5
display parameter-profile
tcp connection idle-timeout
Use tcp connection idle-timeout to set the idle timeout for TCP connections.
Use undo tcp connection idle-timeout to restore the default.
tcp connection idle-timeout value
The idle timeout is 0 seconds for TCP connections, which means TCP connections never time out.
value: Specifies the idle timeout in the range of 10 to 86400 seconds.
This command sets the idle timeout for TCP connections between the LB device and the clients and for TCP connections between the LB device and the servers. If no traffic is available on a TCP connection before the idle timeout expires, the LB device terminates the TCP connection.
# Set the idle timeout to 60 seconds for TCP connections.
[Sysname] parameter-profile pp1 type tcp
[Sysname-para-tcp-pp1] tcp connection idle-timeout 60
tcp mss
Use tcp mss to set the MSS for the LB device.
Use undo tcp mss to restore the default.
tcp mss value
undo tcp mss
The MSS is not set for the LB device.
value: Specifies the MSS value in the range of 128 to 1460 bytes.
This command takes effect only when the fast HTTP or HTTP virtual server has referenced a TCP parameter profile.
When the client establishes a TCP connection to the LB device, the client sends its own MSS value to the LB device. The LB device records the MSS value and sends the configured MSS value to the client. The client and the LB device use the smaller MSS value for communication.
When the LB device establishes a TCP connection to the server, the LB device sends the configured MSS value to the server. The server records the MSS value and sends its own MSS value to the LB device. The LB device and the server use the smaller MSS value for communication.
# Set the MSS to 1300 bytes for the LB device.
[Sysname] parameter-profile tcp type tcp
[Sysname-para-tcp-tcp] tcp mss 1300
tcp window-size
Use tcp window-size to configure the maximum local window size for TCP connections.
Use undo tcp window-size to restore the default.
tcp window-size size
The maximum local window size for TCP connections is 65535.
size: Specifies the maximum local window size for TCP connections, in the range of 8192 to 65535.
# Set the maximum local window size for TCP connections to 8192 for the TCP parameter profile pp3.
[Sysname] parameter-profile pp3 type tcp
[Sysname-para-tcp-pp3] tcp window-size 8192
tcp-close
Use tcp-close to configure the method to close TCP connections.
Use undo tcp-close to restore the default.
tcp-close { fin | rst }
undo tcp-close
FIN packets are sent to close TCP connections.
Generic/HTTP LB action view
fin: Closes TCP connections by sending FIN packets.
rst: Closes TCP connections by sending RST packets.
# In generic LB action lba1, configure the rst method to close TCP connections.
[Sysname-lba-generic-lba1] tcp-close rst
timeout (proximity view)
Use timeout to set the timeout timer for proximity entries.
Use undo timeout to restore the default.
undo timeout
The timeout timer for proximity entries is 60 seconds.
Proximity view
timeout-value: Specifies the timeout timer in the range of 60 to 3600 seconds.
# Set the timeout timer for proximity entries to 80 seconds.
[Sysname-lb-proximity] timeout 80
timeout (sticky group view)
Use timeout to set the timeout timer for sticky entries.
undo timeout
The timeout timer for sticky entries is 86400 seconds for sticky groups of the HTTP cookie type and 60 seconds for sticky groups of other types.
Sticky group view
timeout-value: Specifies the timeout timer in the range of 0 to 31536000 seconds for sticky groups of the HTTP cookie type and in the range of 10 to 604800 seconds for sticky groups of other types.
For sticky groups of the HTTP cookie type, the following principles apply:
· If the sticky method is cookie insert or cookie rewrite, a timeout timer of 0 indicates session persistency.
· If the sticky method is cookie get, a timeout timer of 0 indicates the timeout time for the sticky entries is 0 seconds.
# Set the timeout timer for sticky entries to 100 seconds in the address- and port-type sticky group sg1.
[Sysname-sticky-address-port-sg1] timeout 100
timeout (template view)
Use timeout to set the timeout time for probe responses.
undo timeout
The timeout time for probe responses is 3 seconds.
Load balancing template view
timeout-value: Specifies the timeout time for probe responses, in the range of 1 to 60 seconds.
As a best practice, set the timeout time for probe responses to be smaller than the probe interval.
# Set the timeout time for probe responses to 5 seconds in the ICMP template icmptplt.
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lbpt-icmp-icmptplt] timeout 5
time-wait timeout
Use time-wait timeout to set the TIME_WAIT state timeout time for TCP connections.
Use undo time-wait timeout to restore the default.
time-wait timeout value
The TIME_WAIT state timeout time is 2 seconds for TCP connections.
value: Specifies the TIME_WAIT state timeout time in the range of 1 to 65535 seconds.
A TCP connection cannot be released until the TIME_WAIT timer expires. To release TCP connections faster and improve load balancing efficiency, use this command to set a shorter TIME_WAIT state timeout time.
# Set the TIME_WAIT state timeout time for TCP connections to 30 seconds in the TCP parameter profile pa1.
[Sysname] parameter-profile pa1 type tcp
[Sysname-para-tcp-pa1] time-wait timeout 30
topology region
Use topology region to configure a topology.
Use undo topology region to restore the default.
topology region region-name { ip ipv4-address { mask-length | mask } | ipv6 ipv6-address prefix-length } [ weight weight-value ]
undo topology region region-name [ ip ipv4-address [ mask-length | mask ] | ipv6 ipv6-address [ prefix-length ] ]
No topologies exist.
region-name: Specifies a region by its name, a case-insensitive string of 1 to 63 characters.
ip ipv4-address: Specifies the IPv4 address of a virtual server.
mask-length: Specifies the mask length for the IPv4 address, in the range of 0 to 32. The default is 32.
mask: Specifies the mask for the IPv4 address. The default is 255.255.255.255.
ipv6 ipv6-address prefix-length: Specifies the IPv6 address of a virtual server.
prefix-length: Specifies the prefix length for the IPv6 address, in the range of 0 to 128. The default is 128.
weight-value: Specifies the weight of the topology, in the range of 1 to 255. The default weight is 100.
A topology associates the region where the local DNS server resides with the IP address of a virtual server.
When the static proximity algorithm (topology) is specified for the virtual server pool by using the predictor command, you must configure a topology.
When a DNS request matches multiple topology records, the topology record with the highest weight is selected.
You can execute this command multiple times to configure multiple IP address ranges for a region.
If you only specify a region when deleting a topology, all topologies for the region are deleted.
# Configure a topology by associating the region region-ct with the IPv4 address 1.2.3.4.
[Sysname] topology region region-ct ip 1.2.3.4 24 weight 200
loadbalance region
predictor (virtual server pool view)
transparent enable (link group view)
Use transparent enable to disable NAT for a link group.
Use undo transparent enable to enable NAT for a link group.
transparent enable
NAT is enabled for a link group.
Link group view
# Disable NAT for the link group lg.
[Sysname-lb-lgroup-sinalab] transparent enable
transparent enable (server farm view)
Use transparent enable to disable NAT for a server farm.
Use undo transparent enable to enable NAT for a server farm.
transparent enable
NAT is enabled for a server farm.
Server farm view
If the server farm is referenced by a virtual server of the HTTP type, the NAT feature takes effect even if it is disabled.
# Disable NAT for the server farm sf.
[Sysname-sfarm-sf] transparent enable
ttl weight
Use ttl weight to set the TTL weight for proximity calculation.
Use undo ttl weight to restore the default.
ttl weight ttl-weight
undo ttl weight
The TTL weight for proximity calculation is 100.
Proximity view
ttl-weight: Specifies the TTL weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher weight.
# Set the TTL weight for proximity calculation to 200.
[Sysname-lb-proximity] ttl weight 200
udp per-packet
Use udp per-packet to enable per-packet load balancing for UDP traffic for a virtual server.
Use undo udp per-packet to disable per-packet load balancing for UDP traffic for a virtual server.
udp per-packet
undo udp per-packet
Per-packet load balancing for UDP traffic is disabled for a virtual server.
UDP virtual server view
UDP-based SIP virtual server view
When per-packet load balancing for UDP traffic is disabled, the LB device distributes traffic matching the virtual server according to application type. Traffic of the same application type is distributed to one real server.
When per-packet load balancing for UDP traffic is enabled, the following results apply:
· The LB device distributes traffic matching the virtual server on a per-packet basis.
· The LB device does not collect statistics of connections on the virtual server or real server.
· If NAT is not enabled for the referenced server farm, the LB device does not collect statistics of packets sent by the virtual server or real server.
· The following configurations are still effective:
¡ Scheduling algorithm configured on the server farm referenced by the virtual server.
¡ Sticky method of the sticky group when the virtual server references the server farm.
Because packets of the same session have the same quintuple, the hash scheduling algorithm or the source IP address sticky method yields the same result for the packets. For example, if a server farm uses the hash scheduling algorithm or the source IP address sticky method, the LB device distributes UDP packets of the same session to one real server. In this case, the LB device cannot distribute UDP packets on a per-packet basis.
# Enable per-packet load balancing for UDP traffic for the UDP virtual server vs5.
[Sysname] virtual-server vs5 type udp
[Sysname-vs-udp-vs5] udp per-packet
virtual ip address
Use virtual ip address to configure an IPv4 address (VSIP) for a virtual server.
Use undo virtual ip address to restore the default.
virtual ip address ipv4-address [ mask-length | mask ]
No IPv4 address is configured for a virtual server.
Virtual server view
ipv4-address: Specifies an IPv4 address. It cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X (with a mask length of 32).
mask-length: Specifies a mask length in the range of 0 to 32. The default is 32. This argument is not supported by virtual servers of the fast HTTP type and HTTP type.
mask: Specifies a subnet mask. The default is 255.255.255.255. This argument is not supported by virtual servers of the fast HTTP type and HTTP type.
# Configure the IPv4 address for the IP-type virtual server vs3 as 1.1.1.1/24.
[Sysname-vs-ip-vs3] virtual ip address 1.1.1.1 24
virtual ipv6 address
Use virtual ipv6 address to configure an IPv6 address (VSIP) for a virtual server.
Use undo virtual ipv6 address to restore the default.
virtual ipv6 address ipv6-address [ prefix-length ]
No IPv6 address is configured for a virtual server.
Virtual server view
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address (when the prefix length is not 0).
prefix-length: Specifies a prefix length in the range of 0 to 128. The default is 128. This argument is not supported by virtual servers of the fast HTTP type and HTTP type.
# Configure the IPv6 address for the IP-type virtual server vs3 as 1001::1/64.
[Sysname-vs-ip-vs3] virtual ipv6 address 1001::1 64
virtual-server (system view)
Use virtual-server to create a virtual server and enter its view, or enter the view of an existing virtual server.
Use undo virtual-server to delete the specified virtual server.
virtual-server virtual-server-name [ type { fast-http |http | ip | link-ip | sip-tcp | sip-udp | radius | tcp | udp } ]
undo virtual-server virtual-server-name
No virtual servers exist.
virtual-server-name: Specifies the virtual server name, a case-insensitive string of 1 to 63 characters.
type { fast-http |http | ip | link-ip | sip-tcp | sip-udp | radius | tcp | udp }: Specifies the virtual server type as fast HTTP, HTTP, IP, link-IP, RADIUS, TCP-based SIP, UDP-based SIP, TCP, or UDP. When you create a virtual server, you must specify a virtual server type. You can enter an existing virtual server view without entering the type of the virtual server.
# Create the virtual server vs3 with the IP type, and enter virtual server view.
[Sysname-vs-ip-vs3]
virtual-server (virtual server pool view)
Use virtual-server to add a virtual server to a virtual server pool.
Use undo virtual-server to delete a virtual server from a virtual server pool.
virtual-server virtual-server-name link link-name [ weight weight-value ]
No virtual servers are added to a virtual server pool.
Virtual server pool view
virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 63 characters.
link link-name: Specifies an LB link by its name, a case-insensitive string of 1 to 63 characters.
weight weight-value: Specifies the weight for the virtual server, in the range of 1 to 255. The default weight is 100. For the weighted round robin algorithm, a greater value means a higher priority to be referenced. If you do not specify this option, the default weight 100 applies.
You can add multiple virtual servers to a virtual server pool.
To ensure correct operation of inbound link load balancing when server load balancing is also enabled, do not specify the virtual server's IP address as the DNS listener's IP address.
The virtual server's IP address for inbound link load balancing must be a unicast address with a 32-bit mask length. The IP address cannot be an all-zero address.
# Add the virtual server vs1 associated with the LB link link1 to the virtual server pool local-pool.
[Sysname] loadbalance virtual-server-pool local-pool
[Sysname-lb-vspool-local-pool] virtual-server vs1 link link1
loadbalance link
Use vpn-instance to specify a VPN instance for a link.
Use undo vpn-instance to restore the default.
undo vpn-instance
A link belongs to the public network.
Link view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
Before executing this command, you must create the VPN instance by using the ip vpn-instance vpn-instance-name command. If the specified VPN instance has not been created, the link state will be unavailable.
# Specify VPN instance vpn1 for link lk1.
[Sysname-lb-link-lk1] vpn-instance vpn1
ip vpn-instance (MPLS Command Reference)
vpn-instance (real server view)
Use vpn-instance to specify a VPN instance for a real server.
undo vpn-instance
A real server belongs to the public network if VPN instance inheritance is disabled.
A real server belongs to the VPN instance specified for its virtual server if VPN instance inheritance is enabled.
Real server view
# Specify VPN instance vpn1 for real server rs.
[Sysname-rserver-rs] vpn-instance vpn1
inherit vpn-instance disable
vpn-instance (transparent DNS proxy view)
Use vpn-instance to specify a VPN instance for a transparent DNS proxy.
undo vpn-instance
A transparent DNS proxy belongs to the public network.
# Specify VPN instance vpn1 for transparent DNS proxy dns-proxy1.
[Sysname-lb-dp-udp-dns-proxy1] vpn-instance vpn1
vpn-instance (virtual server view)
Use vpn-instance to specify a VPN instance for a virtual server.
A virtual server belongs to the public network.
Virtual server view
# Specify VPN instance vpn1 for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] vpn-instance vpn1
weight (DNS server pool member view)
Use weight to set the weight of a DNS server pool member.
Use undo weight to restore the default.
weight weight-value
undo weight
The weight of a DNS server pool member is 100.
weight-value: Specifies the weight in the range of 1 to 255. A greater value means a higher priority in scheduling.
The weight configured in this command is used in the weighted round-robin algorithm.
# Set the weight of the DNS server pool member ds1 to 150.
[Sysname-lb-dspool-dsp1] dns-server ds1 port 10
[Sysname-lb-dspool-dsp1-#member#-ds1-port-10] weight 150
weight (DNS server view)
Use weight to set the weight of a DNS server to be used by the weighted round robin algorithm and bandwidth algorithm.
weight weight-value
undo weight
The weight of a DNS server is 100.
DNS server view
# Set the weight of the DNS server ds1 to 150.
[Sysname-lb-ds-ds1] weight 150
weight (link group member view)
Use weight to set the weight of a link group member.
weight weight-value
undo weight
The weight of a link group member is 100.
The weight configured in this command is used in the weighted least-connection algorithm and weighted round-robin algorithm.
# Set the weight of the link group member lk1 to 150.
[Sysname-lb-lgroup-lg-#member#-lk1] weight 150
weight (link view)
Use weight to set the weight of a link to be used by the weighted round robin and weighted least connection algorithms.
weight weight-value
undo weight
The weight of a link is 100.
Link view
weight-value: Specifies the weight in the range of 1 to 255. For the weighted round robin or weighted least connection algorithm, a greater value means a higher priority to be referenced.
# Set the weight of the link lk1 to 150.
[Sysname-lb-link-lk1] weight 150
weight (real server view)
Use weight to set the weight of a real server to be used by the weighted round robin and weighted least connection algorithms.
weight weight-value
undo weight
The weight of a real server is 100.
Real server view
# Set the weight of the real server rs to 150.
[Sysname-rserver-rs] weight 150
weight (server farm member view)
Use weight to set the weight of a server farm member.
weight weight-value
undo weight
The weight of a server farm member is 100.
# Set the weight of the server farm member rs1 to 150.
[Sysname-sfarm-sf-#member#-rs1-port-80] weight 150
whois-mntner
Use whois-mntner to specify a whois maintainer object for an ISP.
Use undo whois-mntner to delete a whois maintainer object for an ISP.
whois-mntner mntner-name
undo whois-mntner mntner-name
No whois maintainer object is specified for an ISP.
ISP view
mntner-name: Specify a whois maintainer object by its name, a case-sensitive string of 1 to 63 characters.
This command specifies the geographical area where ISP address information is to be updated by the whois server.
You can specify a maximum of 10 whois maintainer objects for an ISP.
A whois maintainer object is globally unique.
# Specify whois maintainer object MAINT-CHINANET for ISP isp1.
[Sysname] loadbalance isp name isp1
[Sysname-lbisp-isp1] whois-mntner MAINT-CHINANET
window-size
Use window-size to set the window size used for compression.
Use undo window-size to restore the default.
window-size size
undo window-size
The window size used for compression is 16 KB.
size: Specifies the window size in KB used for compression. The value can only be 1, 2, 4, 8, 16, or 32.
# Create the HTTP-compression parameter profile pa1, and set the window size used for compression to 32 KB.
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compression-pa1] window-size 32
zero-window threshold
Use zero-window threshold to set the percentage threshold of zero-window packets for a TCP zero-window LB probe template.
Use undo zero-window threshold to restore the default.
zero-window threshold percentage
undo packet-zero-window
The percentage threshold of zero-window packets is 40%.
TCP zero-window LB probe template view
percentage: Specifies the percentage threshold of zero-window packets, in the range of 1 to 100.
When the percentage of zero-window packets sent by a real server reaches the threshold, the protection action specified in the protect-action command is taken.
# In TCP zero-window LB probe template zerotplt, set the percentage threshold of zero-window packets to 20%.
[Sysname] loadbalance probe-template tcp-zero-window zerotplt
[Sysname-lbpt-tcp-zwnd-zerotplt] zero-window threshold 20
protect-action
