08-ACL and QoS Configuration Examples
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7577P04-6W10008-ACL and QoS Configuration Examples
06-H3C_Congestion_Avoidance_and_Queue_Scheduling_Configuration_Examples
H3C Congestion Avoidance and Queue Scheduling Configuration Examples
Software version: Release 7577P04
Document version: 6W100-20190330
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides examples for configuring congestion avoidance and queue scheduling profiles.
This document assumes that you have basic knowledge of congestion avoidance and queue scheduling profiles.
Example: Configuring congestion avoidance and queue scheduling
As shown in Figure 1, three types of traffic come from the Internet to the device through the gateway.
·          Voice trafficTransmitted in VLAN 6 and carries 802.1p priority 6.
·          Video trafficTransmitted in VLAN 4 and carries 802.1p priority 4.
·          Data trafficTransmitted in VLAN 2 and carries 802.1p priority 2.
Configure congestion avoidance and queue scheduling on the device to meet the following requirements:
·          The voice traffic, video traffic, and data traffic are scheduled in the ratio of 1:2:2 when congestion occurs.
·          WRED drop is used when serious congestion occurs.
Figure 1 Network diagram
Analysis
To configure congestion avoidance and queue scheduling, you must perform the following tasks:
·          To assign different types of traffic to different queues, configure the incoming interface to trust the 802.1p priority in packets.
·          To schedule the three types of traffic in the ratio of 1:2:2, assign their queues to one WRR group and configure weights for these queues.
·          To minimize performance degradation for different types of traffic, use the drop parameters in Table 1.
Table 1 Drop parameters
Traffic type
Packet color
Lower limit
Upper limit
Drop probability
Voice
Yellow
1000
1500
3%
Red
500
1000
30%
Video
Yellow
1000
1500
2%
Red
500
1000
20%
Data
Yellow
1000
1500
1%
Red
500
1000
10%
Procedures
1.        Allow VLANs for different types of traffic to pass through:
# Create three VLANs .
[Device] vlan 2
[Device-vlan2] quit
[Device] vlan 4
[Device-vlan4] quit
[Device] vlan 6
[Device-vlan6] quit
# Assign interfaces to VLANs.
[Device] interface ten-gigabitethernet 1/0/3
[Device-Ten-GigabitEthernet1/0/3] port link-type trunk
[Device-Ten-GigabitEthernet1/0/3] port trunk permit vlan 2 4 6
[Device-Ten-GigabitEthernet1/0/3] quit
[Device-Ten-GigabitEthernet1/0/1] port link-type trunk
[Device-Ten-GigabitEthernet1/0/1] port trunk permit vlan 2 4 6
[Device] interface ten-gigabitethernet 1/0/2
[Device-Ten-GigabitEthernet1/0/2] port link-type trunk
[Device-Ten-GigabitEthernet1/0/2] port trunk permit vlan 2 4 6
[Device-Ten-GigabitEthernet1/0/2] quit
2.        Configure interface Ten-GigabitEthernet 1/0/3 to trust the 802.1p priority in packets.
[Device-Ten-GigabitEthernet1/0/3] qos trust dot1p
3.        Configure WRR on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2:
# Enable weighted-based WRR on Ten-GigabitEthernet 1/0/1.
[Device-Ten-GigabitEthernet1/0/1] qos wrr weight
# Display the 802.1p-to-local precedence map to determine the local precedence for each type of traffic.
[Device-Ten-GigabitEthernet1/0/1] display qos map-table dot1p-lp
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
# Configure the weights of queue 1 (for data traffic), queue 4 (for video traffic), and queue 6 (for voice traffic) as 2, 2, and 1, respectively.
[Device-Ten-GigabitEthernet1/0/1] qos wrr 1 group 1 weight 2
[Device-Ten-GigabitEthernet1/0/1] qos wrr 4 group 1 weight 2
[Device-Ten-GigabitEthernet1/0/1] qos wrr 6 group 1 weight 1
# Enable weighted-based WRR on GigabitEthernet 1/0/2.
[Device-Ten-GigabitEthernet1/0/2] qos wrr weight
[Device-Ten-GigabitEthernet1/0/2] qos wrr 1 group 1 weight 2
[Device-Ten-GigabitEthernet1/0/2] qos wrr 4 group 1 weight 2
[Device-Ten-GigabitEthernet1/0/2] qos wrr 6 group 1 weight 1
4.        Configure congestion avoidance:
# Configure a WRED table.
[Device] qos wred queue table droppolicy
[Device-wred-table-droppolicy] queue 6 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 3
[Device-wred-table-droppolicy] queue 6 drop-level 2 low-limit 500 high-limit 1000 discard-probability 30
[Device-wred-table-droppolicy] queue 4 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 2
[Device-wred-table-droppolicy] queue 4 drop-level 2 low-limit 500 high-limit 1000 discard-probability 20
[Device-wred-table-droppolicy] queue 1 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 1
[Device-wred-table-droppolicy] queue 1 drop-level 2 low-limit 500 high-limit 1000 discard-probability 10
[Device-wred-table-droppolicy] quit
# Apply the WRED table to interfaces Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[Device-Ten-GigabitEthernet1/0/1] qos wred apply droppolicy
[Device-Ten-GigabitEthernet1/0/2] qos wred apply droppolicy
# Verify the WRR configuration on interfaces Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[Device] display qos queue wrr interface
Interface: display qos queue wrr interface
 Output queue: Weighted Round Robin queuing
 Queue ID     Queue name     Group     Weight
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         2
 5            ef             1         6
 6            cs6            1         1
 7            cs7            1         8
Interface: Ten-GigabitEthernet1/0/2
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         2
 5            ef             1         6
 6            cs6            1         1
 7            cs7            1         8
# Display the WRED information for interfaces Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[Device] display qos wred interface
 Current WRED configuration:
 Applied WRED table name: droppolicy
# Display the WRED table configuration.
[Device] display qos wred table
Table name: droppolicy
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
0     100   1000  10     100   1000  10     100   1000  10     9         N
1     100   1000  10     1000  1500  1      500   1000  10     9         N
2     100   1000  10     100   1000  10     100   1000  10     9         N
3     100   1000  10     100   1000  10     100   1000  10     9         N
4     100   1000  10     1000  1500  2      500   1000  20     9         N
5     100   1000  10     100   1000  10     100   1000  10     9         N
6     100   1000  10     1000  1500  3      500   1000  30     9         N
7     100   1000  10     100   1000  10     100   1000  10     9         N
Configuration files
vlan 1
vlan 2
vlan 4
vlan 6
 port link-mode bridge
 port trunk permit vlan 1 to 2 4 6
 qos wrr weight
 qos wrr af1 group 1 weight 2
 qos wrr af4 group 1 weight 2
 qos wrr cs6 group 1 weight 1
 qos wrr weight
return
Related documentation
·          H3C S7500E  Switch Series ACL and QoS Configuration Guide-R757X
·          H3C S7500E  Switch Series ACL and QoS Command Reference-R757X
