05-Layer 3 - IP Routing Configuration Examples
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7577P04-6W10005-Layer 3 - IP Routing Configuration Examples
04-H3C_IS-IS_Configuration_Examples
04-H3C_IS-IS_Configuration_Examples 93.37 KB
H3C IS-IS Configuration Examples
Software version: Release 7577P04
Document version: 6W100-20190330
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides IS-IS configuration examples.
This document assumes that you have basic knowledge of IS-IS.
Example: Configuring IS-IS
As shown in Figure 1, the company's headquarters and the branch run IS-IS. The partner runs OSPF.
Configure the switches to meet the following requirements:
·          Reduce traffic for Switch A and Switch B because they have relative low performance.
·          The Marketing department can reach the Finance department, the branch, and the partner.
·          The Finance department and the branch cannot reach each other, and the branch does not have a route to the Finance department.
·          When the IS-IS process on Switch C restarts, the communication is not interrupted.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·          To reduce traffic for Switch A and Switch B, configure them as Level-1 routers to allow communication only between the Marketing department and the Finance department.
·          Configure route redistribution between IS-IS and OSPF on Switch D to allow communication between the Marketing department and the partner.
·          Configure Switch C to use a prefix list to advertise only network 10.100.1.0/24 to Level-2 to ensure that the branch does not have a route to the Finance department.
·          Enable IS-IS Graceful Restart (GR) on Switch C to ensure that the communication is not interrupted when the IS-IS process on Switch C restarts.
To avoid blackhole routes, do not change the network topology during the IS-IS GR process.
Procedures
Configuring Switch A
# Configure an IP address for VLAN-interface 11.
[SwitchA-Vlan-interface11] ip address 192.168.1.1 24
# Configure IP addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Configure IS-IS.
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.1921.6800.1001.00
[SwitchA-isis-1] quit
[SwitchA–Vlan-interface11] isis enable 1
[SwitchA–Vlan-interface11] quit
[SwitchA–Vlan-interface100] isis enable 1
[SwitchA–Vlan-interface100] quit
Configuring Switch B
# Configure an IP address for VLAN-interface 12.
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] ip address 192.168.2.1 24
[SwitchB-Vlan-interface12] quit
# Configure IS-IS.
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.1921.6800.2001.00
[SwitchB-isis-1] quit
[SwitchB–Vlan-interface12] isis enable 1
[SwitchB–Vlan-interface12] quit
[SwitchB–Vlan-interface 200] isis enable 1
[SwitchB–Vlan-interface 200] quit
Configuring Switch C
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] ip address 192.168.1.2 24
[SwitchC-Vlan-interface11] quit
# Configure IS-IS.
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 10.1921.6801.0001.00
[SwitchC-isis-1] quit
[SwitchC] interface vlan-interface 10
[SwitchC–Vlan-interface10] isis enable 1
[SwitchC–Vlan-interface10] quit
[SwitchC–Vlan-interface11] isis enable 1
[SwitchC–Vlan-interface11] quit
[SwitchC] interface vlan-interface 12
[SwitchC–Vlan-interface12] isis enable 1
[SwitchC–Vlan-interface12] quit
# Configure route leaking from Level-1 to Level-2, and use prefix list 1 to advertise only network 10.100.1.0/24 to Level-2.
[SwitchC] ip prefix-list 1 permit 10.100.1.0 24
[SwitchC] isis 1
[SwitchC-isis-1] address-family ipv4
[SwitchC-isis-1-ipv4] import-route isis level-1 into level-2 filter-policy prefix-list 1
[SwitchC-isis-1-ipv4] quit
# Enable IS-IS GR.
[SwitchC-isis-1] graceful-restart
Configuring Switch D
# Configure an IP address for VLAN-interface 10.
<SwitchD> system-view
[SwitchD] interface vlan-interface 10
[SwitchD- Vlan-interface10] ip address 192.168.10.2 24
[SwitchD- Vlan-interface10] quit
# Configure IS-IS.
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.1921.6802.0001.00
[SwitchD-isis-1] quit
[SwitchD–Vlan-interface10] isis enable 1
[SwitchD–Vlan-interface10] quit
[SwitchD] interface vlan-interface 20
[SwitchD–Vlan-interface20] isis enable 1
[SwitchD–Vlan-interface20] quit
# Configure OSPF.
[SwitchD] ospf
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[SwitchD-ospf-1] quit
# Redistribute OSPF and direct routes into IS-IS
[SwitchD] isis 1
[SwitchD-isis-1] address-family ipv4
[SwitchD-isis-1-ipv4] import-route ospf
[SwitchD-isis-1-ipv4] import-route direct
[SwitchD-isis-1-ipv4] quit
# Redistribute IS-IS and direct routes into OSPF.
[SwitchD] ospf 1
[SwitchD-ospf-1] import-route isis 1
[SwitchD-ospf-1] import-route direct
Configuring Switch E
# Configure an IP address for VLAN-interface 20.
<SwitchE> system-view
[SwitchE] interface vlan-interface20
[SwitchE-Vlan-interface12] ip address 192.168.20.2 24
[SwitchE-Vlan-interface12] quit
# Configure OSPF.
[SwitchE] ospf
[SwitchE-ospf-1] area 0
[SwitchE-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] network 10.200.1.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] quit
[SwitchE-ospf-1] quit
# Verify that the branch can reach the Marketing department, but cannot reach the Finance department.
[SwitchD] display isis route
                         Level-2 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 192.168.10.0/24      10         NULL    Vlan10          Direct          D/L/-
 192.168.1.0/24       20         NULL    Vlan10          192.168.10.1    R/-/-
 10.100.1.0/24        30         NULL    Vlan10          192.168.10.1    R/-/-
 192.168.2.0/24       20         NULL    Vlan10          192.168.10.1    R/-/-
# Verify that the company can communicate with the partner.
·          Display the IS-IS routing table on Switch C.
[SwitchC] display isis route
                         Level-1 IPv4 Forwarding Table
 192.168.1.0/24       10         NULL    Vlan11          Direct          D/L/-
 10.100.1.0/24        20         NULL    Vlan11          192.168.1.1     R/L/-
 10.100.2.0/24        20         NULL    Vlan12          192.168.2.1     R/-/-
 192.168.2.0/24       10         NULL    Vlan12          Direct          D/L/-
 10.200.1.0/24        10         0       Vlan10          192.168.10.2    R/-/-
 192.168.20.0/24      10         0       Vlan10          192.168.10.2    R/-/-
·          Ping 10.200.1.1 from the interface VLAN-interface 100 on Switch A.
[SwitchA] ping –a 10.1.1.1 10.200.1.1
Ping 10.200.1.1 (10.200.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.200.1.1: icmp_seq=0 ttl=252 time=1.862 ms
56 bytes from 10.200.1.1: icmp_seq=1 ttl=252 time=2.969 ms
56 bytes from 10.200.1.1: icmp_seq=2 ttl=252 time=1.402 ms
56 bytes from 10.200.1.1: icmp_seq=3 ttl=252 time=1.324 ms
56 bytes from 10.200.1.1: icmp_seq=4 ttl=252 time=1.510 ms
--- Ping statistics for 10.200.1.1 ---
round-trip min/avg/max/std-dev = 1.324/1.813/2.969/0.606 ms
# Verify that the communication is not interrupted when the IS-IS process restarts.
·          Ping Switch B from Switch A.
[SwitchA] ping -c 10000 10.100.2.1
Ping 10.100.2.1 (10.100.2.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.100.2.1: icmp_seq=0 ttl=254 time=1.185 ms
56 bytes from 10.100.2.1: icmp_seq=1 ttl=254 time=1.087 ms
·          Restart the IS-IS process on Switch C.
[SwitchC] reset isis all graceful-restart
Reset IS-IS process? [Y/N] :y
# Ping Switch B from Switch A.
56 bytes from 10.100.2.1: icmp_seq=2 ttl=254 time=1.672 ms
56 bytes from 10.100.2.1: icmp_seq=3 ttl=254 time=1.751 ms
56 bytes from 10.100.2.1: icmp_seq=4 ttl=254 time=1.816 ms
56 bytes from 10.100.2.1: icmp_seq=5 ttl=254 time=1.814 ms
# Check the IS-IS GR state on Switch C.
[SwitchC] display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
                          Level-1 restart information
Total number of interfaces: 3
Number of waiting LSPs: 0
                          Level-2 restart information
Configuration files
·          Switch A:
isis 1
 is-level level-1
vlan 11
vlan 100
interface Vlan-interface11
 isis enable 1
interface Vlan-interface100
 ip address 10.100.1.1 255.255.255.0
 isis enable 1
·          Switch B:
isis 1
 is-level level-1
vlan 12
vlan 200
interface Vlan-interface12
 ip address 192.168.2.1 255.255.255.0
 isis enable 1
interface Vlan-interface200
 ip address 10.100.2.1 255.255.255.0
 isis enable 1
·          Switch C:
isis 1
 graceful-restart
address-family ipv4 unicast
isis 1
 graceful-restart
vlan 11 to 13
 ip address 192.168.1.2 255.255.255.0
 isis enable 1
 ip address 192.168.2.2 255.255.255.0
 isis enable 1
interface Vlan-interface13
 ip address 192.168.10.1 255.255.255.0
 isis enable 1
 ip prefix-list 1 index 10 permit 10.100.1.0 24
·          Switch D:
isis 1
 is-level level-2
 import-route direct
 import-route ospf 1
  import-route direct
  import-route ospf 1
ospf 1
 import-route direct
 import-route isis 1
 area 0.0.0.0
vlan 10
vlan 20
 ip address 192.168.10.2 255.255.255.0
 isis enable 1
 ip address 192.168.20.1 255.255.255.0
·          Switch E:
ospf 1
 area 0.0.0.0
vlan 20
vlan 300
 ip address 192.168.20.2 255.255.255.0
interface Vlan-interface300
 ip address 10.200.1.1 255.255.255.0
Related documentation
·          H3C S7500E Switch Series Layer 3—IP Routing Command Reference-R757X
·          H3C S7500E Switch Series Layer 3—IP Routing Configuration Guide-R757X
