03-Layer 2 - LAN Switching Configuration Examples
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7577P04-6W10003-Layer 2 - LAN Switching Configuration Examples
01-H3C_MAC_Address_Table_Configuration_Examples
H3C MAC Address Table
Software version: Release 7577P04
Document version: 6W100-20190330
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides MAC address table configuration examples.
This document assumes that you have basic knowledge of the MAC address table.
Example: Configuring static MAC address entries
As shown in Figure 1, for secure communication between users in VLAN 100 and the server, perform the following tasks:
·          Assign Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 to VLAN 100.
·          Add a static MAC address entry on Device to bind the server MAC address to Ten-GigabitEthernet 1/0/2.
Figure 1 Network diagram
Procedures
# Create VLAN 100, and assign Ten-GigabitEthernet 1/0/2 to VLAN 100.
[Device] vlan 100
[Device-vlan100] quit
[Device] interface ten-gigabitethernet 1/0/2
[Device-Ten-GigabitEthernet1/0/2] port link-mode bridge
[Device-Ten-GigabitEthernet1/0/2] port access vlan 100
[Device-Ten-GigabitEthernet1/0/2] undo shutdown
[Device-Ten-GigabitEthernet1/0/2] quit
# Configure Ten-GigabitEthernet 1/0/3 (port connected to the LAN switch) as a trunk port, and assign the port to VLAN 100.
[Device] interface ten-gigabitethernet 1/0/3
[Device-Ten-GigabitEthernet1/0/3] port link-mode bridge
[Device-Ten-GigabitEthernet1/0/3] port link-type trunk
[Device-Ten-GigabitEthernet1/0/3] port trunk permit vlan 100
[Device-Ten-GigabitEthernet1/0/3] undo shutdown
[Device-Ten-GigabitEthernet1/0/3] quit
# Add a static entry for MAC address 0000-fc00-a249 on Ten-GigabitEthernet 1/0/2 that belongs to VLAN 100.
[Device] mac-address static 0000-fc00-a249 interface ten-gigabitethernet 1/0/2 vlan 100
# Verify that any 10.0.0.0/24 host in VLAN 100 can communicate with the server. (Details not shown.)
# Verify that the static MAC address entry has been added.
[Device] display mac-address
MAC Address      VLAN ID    State            Port/NickName            Aging
0000-fc00-a249   100        Static           XGE1/0/2                 N
7425-8a02-4d00   100        Learned          XGE1/0/3                 Y
Configuration files
 sysname Device
vlan 1
vlan 100
 mac-address static 0000-fc00-a249 vlan 100
 port trunk permit vlan 1 100
Example: Configuring MAC address move suppression
As shown in Figure 2, Devices A, B, and C form a loop because of cable misconnection, and spanning tree protocols are not enabled on the devices. As a result, MAC addresses are frequently moves among Devices A, B, and C. To deal with loop-triggered MAC flapping, perform the following tasks:
·          Display MAC address move records to locate the Layer 2 loop.
·          Configure MAC address move suppression on Device A to eliminate the Layer 2 loop.
Figure 2 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·          For Devices A, B, and C to communicate with each other, assign all inter-connected ports to VLAN 100.
·          Configure MAC address move suppression on one or more ports of Device A.
·          To monitor the port status change of Device A, enable the log monitoring of the current terminal feature.
·          For loop detection, create VLAN-interface 100 and assign an IP address to the interface on each device.
·          To display MAC address move records, ping Device B from Device A.
Procedures
Configuring Device A
# Enable the monitoring of logs on the current terminal.
<DeviceA> terminal monitor
<DeviceA> terminal debugging
# Create VLAN 100.
[DeviceA] vlan 100
[DeviceA-vlan100] quit
# Configure Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 as trunk ports, and assign the ports to VLAN 100.
[DeviceA] interface range ten-gigabitethernet 1/0/1 ten-gigabitethernet 1/0/2
[DeviceA-if-range] port link-mode bridge
[DeviceA-if-range] port link-type trunk
[DeviceA-if-range] port trunk permit vlan 100
[DeviceA-if-range] undo shutdown
[DeviceA-if-range] quit
# Set the suppression interval to 300 seconds. A suppressed port will automatically come up after 300 seconds.
[DeviceA] mac-address notification mac-move suppression interval 300
# Set the suppression threshold to 0. A port will be shut down when the system detects a MAC address move on the port within a MAC move detection interval (1 minute by default).
[DeviceA] mac-address notification mac-move suppression threshold 0
# Enable MAC address move suppression on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] mac-address notification mac-move suppression
# Create VLAN-interface 100, and assign an IP address to the interface.
[DeviceA] interface vlan-interface 100
[DeviceA-Vlan-interface100] ip address 10.0.0.1 24
[DeviceA-Vlan-interface100] quit
Configuring Device B and Device C
1.        Configure Device B:
# Create VLAN 100.
[DeviceB] vlan 100
[DeviceB-vlan100] quit
[DeviceB] interface range ten-gigabitethernet 1/0/1 ten-gigabitethernet 1/0/2
[DeviceB-if-range] port link-mode bridge
[DeviceB-if-range] port link-type trunk
[DeviceB-if-range] port trunk permit vlan 100
[DeviceB-if-range] undo shutdown
[DeviceB-if-range] quit
[DeviceB] interface vlan-interface 100
[DeviceB-Vlan-interface100] ip address 10.0.0.2 24
[DeviceB-Vlan-interface100] quit
2.        # Configure Device C in the same way Device B was configured. (Details not shown.)
# Ping Device B from Device A. (Details not shown.)
# Verify that Ten-GigabitEthernet 1/0/1 on Device A is shut down.
[DeviceA] %Dec 11 09:51:06:309 2016 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the Ten-GigabitEthernet1/0/1 changed to down.
%Dec 11 09:51:06:323 2016 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on
the interface Ten-GigabitEthernet1/0/1 changed to down.
# Verify that Ten-GigabitEthernet 1/0/1 is shut down because a MAC address move is detected.
[DeviceA] display interface ten-gigabitethernet 1/0/1
Current state: mac-address moving down
Line protocol state: DOWN
# Verify that Ten-GigabitEthernet 1/0/1 comes up automatically after 300 seconds.
[DeviceA] %Dec 11 09:56:07:002 2016 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the Ten-GigabitEthernet1/0/1 changed to up.
%Dec 11 09:56:07:004 2016 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on
the interface Ten-GigabitEthernet1/0/1 changed to up.
# Verify that the MAC address of Device B's VLAN-interface 100 moves between Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2. You can manually shut down either port to eliminate the loop.
[DeviceA] display mac-address mac-move
MAC address    VLAN Current port  Source port   Last time              Times
0000-fc00-6506  100      XGE1/0/2    XGE1/0/1   2014-12-11 09:29:48        3
0000-fc00-6506  100      XGE1/0/1    XGE1/0/2   2014-12-11 09:51:03        4
---  2 MAC address moving records found  ---
Configuration files
·          Device A:
 sysname DeviceA
vlan 1
vlan 100
interface Vlan-interface100
 ip address 10.0.0.1 255.255.255.0
·          Device B:
 sysname DeviceB
vlan 1
vlan 100
 ip address 10.0.0.2 255.255.255.0
·          Device C:
 sysname DeviceC
vlan 1
vlan 100
 ip address 10.0.0.3 255.255.255.0
Related documentation
·          H3C S7500ESwitch Series Layer 2—LAN Switching Configuration Guide-R757X
·          H3C S7500E Switch Series Layer 2—LAN Switching Command Reference-R757X
