00-Preface
Download Book (81.04 KB)This installation guide describes the installation procedure for the H3C WA530X Access Point .
· Audience.
· Conventions.
· Network planners.
· Network administrators working with the WA530X.
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
Convention |
Boldface |
Convention |
NOTE: |
Convention |
Represents an access point. |
