01-Fundamentals Command Reference
HomeSupportWirelessWX5500E Series Access ControllersReference GuidesCommand ReferencesH3C WX5540E Access Controller Switching Engine Command References(R2607P26)-6W10101-Fundamentals Command Reference
02-Login management commands
02-Login management commands 219.29 KB
acl (user interface view)
Use acl to reference ACLs to control access to the VTY user interface.
Use undo acl to cancel the ACL application.
To use a basic or advanced ACL:
acl acl-number { inbound | outbound }
undo acl acl-number { inbound | outbound }
To use an Ethernet frame header ACL:
acl acl-number inbound
undo acl acl-number inbound
Access to the VTY user interface is not restricted.
VTY user interface view
Default command level
2: System level
acl-number: Specifies the number of the ACL:
·           Basic ACL—2000 to 2999
·           Advanced ACL—3000 to 3999
·           Ethernet frame header ACL—4000 to 4999
inbound: Restricts Telnet or SSH connections established in the inbound direction through the VTY user interface. If the received packets for establishing a Telnet or SSH connection are permitted by an ACL rule, the connection is allowed to be established. When the device functions as a Telnet server or SSH server, use this keyword to control access of Telnet clients or SSH clients.
outbound: Restricts Telnet connections established in the outbound direction through the VTY user interface. If the packets sent for establishing a Telnet connection are permitted by an ACL rule, the connection is allowed to be established. When the device functions as a Telnet client, use this keyword to define Telnet servers accessible to the client.
If no ACL is referenced in VTY user interface view, the VTY user interface has no access control over establishing a Telnet or SSH connection.
If an ACL is referenced in VTY user interface view, the connection is permitted  to be established only when packets for establishing a Telnet or SSH connection match a permit statement in the ACL.
The system regards the basic/advanced ACL with the inbound keyword and the basic/advanced ACL with the outbound keyword as different types of ACLs, which can coexist in one VTY user interface. The match order is basic/advanced ACL, Ethernet frame header ACL. At most one ACL of each type can be referenced in the same VTY user interface, and the last configured one takes effect.
For more information about ACL, see ACL and QoS Command Reference.
# Allow only the user with the IP address of 192.168.1.26 to access the device through Telnet or SSH.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 192.168.1.26 0
[Sysname-acl-basic-2001] quit
[Sysname] user-interface vty 0
[Sysname-ui-vty0] acl 2001 inbound
After the configuration, user A (with the IP address 192.168.1.26) can Telnet to the device, but user B (with the IP address 192.168.1.60) cannot. Upon a connection failure, a message appears: "%connection closed by remote host!"
# Allow the device to only Telnet to the Telnet server with IP address 192.168.1.41.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit tcp destination 192.168.1.41 0
[Sysname-acl-adv-3001] quit
[Sysname] user-interface vty 0 15
[Sysname-ui-vty0-15] acl 3001 outbound
[Sysname-ui-vty0-15] return
<Sysname>
After your configuration, if you Telnet to 192.168.1.46, your operation fails.
<Sysname> telnet 192.168.1.46
%Can't access the host from this terminal!
But you can Telnet to 192.168.1.41.
<Sysname> telnet 192.168.1.41
Trying 192.168.1.41 ...
Press CTRL+K to abort
Connected to 192.168.1.41 ...
activation-key
Use activation-key to define a shortcut key for starting a terminal session.
Use undo activation-key to restore the default.
activation-key character
undo activation-key
Pressing the Enter key starts a terminal session.
AUX user interface view
3: Manage level
character: Specifies the shortcut key for starting a terminal session. The shortcut key can be a single character or an ASCII code in the range of 0 to 127. If you specify a number that is greater than 127 or a non-numeric string of one to three characters, only the first character is used as the shortcut key. For example, if you enter activation-key 987, the shortcut key is 9. If you enter activation-key abc, the shortcut key is a.
To display the defined shortcut key, use the display current-configuration command. This command displays the ASCII code of the shortcut key.
# Configure character s as the shortcut key for starting a terminal session on the AUX user interface.
[Sysname] user-interface aux 0
[Sysname-ui-aux0] activation-key s
To verify the configuration:
1.      Exit to the user view.
[Sysname-ui-aux0] return
<Sysname> quit
2.      Log in to the AUX user interface again.
The following message appears.
* Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
User interface aux0 is available.
Please press ENTER.
3.      Press Enter.
At this moment, pressing Enter does not start a session.
4.      Enter s.
A terminal session is started.
<Sysname>
%Mar  2 18:40:27:981 2013 Sysname SHELL/5/LOGIN: Console login from aux0
auto-execute command
CAUTION
CAUTION:
After configuring this command for a user interface,  you might be unable to access the CLI through the user interface. Make sure you can access the CLI through a different user interface before you configure this command and save the configuration.
Use auto-execute command to specify a command to be automatically executed when a user logs in to the current user interface.
Use undo auto-execute command to remove the configuration.
auto-execute command command
Command auto-execution is disabled.
User interface view
3: Manage level
command: Specifies the command to be automatically executed.
This command is not supported on AUX interfaces.
The system automatically executes the specified command when a user logs in to the user interface, and tears down the user connection after the command is executed. If the command triggers another task, the system does not tear down the user connection until the task is completed.
The command auto-execute function is typically used for redirecting a Telnet user to a specific host. After executing the specified command and performing the incurred task, the system automatically disconnect the Telnet session.
# Configure the device to automatically Telnet to 192.168.1.41 after a user logs in to interface VTY 0.
[Sysname -ui-vty0] auto-execute command telnet 192.168.1.41
% This action will lead to configuration failure through ui-vty0. Are you sure?
[Y/N]:y
[Sysname-ui-vty0]
# Telnet to 192.168.1.40 to verify the configuration.
The device automatically Telnets to 192.168.1.41. The following output is displayed:
C:\> telnet 192.168.1.40
<Sysname>
<Sysname>
This operation is the same as directly logging in to the device at 192.168.1.41. If the Telnet connection to 192.168.1.41 is broken down, the Telnet connection to 192.168.1.40 breaks down at the same time.
authentication-mode
Use authentication-mode to set the authentication mode for the user interface.
Use undo authentication-mode to restore the default.
authentication-mode { none | password | scheme }
The authentication mode is password for VTY user interfaces, and none for AUX user interfaces.
User interface view
3: Manage level
none: Performs no authentication.
password: Performs local password authentication.
scheme: Performs AAA authentication. For more information about AAA, see Security Configuration Guide.
For scheme authentication mode, if local authentication is used and password control is enabled, a user must change the password after the first login (unless the user uses SSH for the first login). If NTP synchronization is also configured, H3C recommends that you wait for 10 minutes before changing the password to make sure the NTP synchronization is finished before the password is created.
# Specify that no authentication is needed for VTY 0. (This mode is insecure.)
[Sysname-ui-vty0] authentication-mode none
# Use password authentication when users log in to the device through VTY 0, and set the authentication password to 321.
[Sysname-ui-vty0] authentication-mode password
[Sysname-ui-vty0] set authentication password simple 321
# Authenticate users by username and password for VTY 0. Set the username to 123 and the password to 321.
[Sysname-ui-vty0] authentication-mode scheme
[Sysname-ui-vty0] quit
[Sysname] local-user 123
[Sysname-luser-123] password simple 321
[Sysname-luser-123] service-type telnet
[Sysname-luser-123] authorization-attribute level 3
command accounting
Use command accounting to enable command accounting.
Use undo command accounting to restore the default.
command accounting
Command accounting is disabled, and the accounting server does not record executed commands.
User interface view
3: Manage level
When command accounting is enabled and command authorization is not, every executed command is recorded on the HWTACACS server.
When both command accounting and command authorization are enabled, only the authorized and executed commands are recorded on the HWTACACS server.
# Enable command accounting on VTY 0.
[Sysname-ui-vty0] command accounting
Use command authorization to enable command authorization.
Use undo command authorization to restore the default.
Command authorization is disabled. Logged-in users can execute commands without authorization.
User interface view
3: Manage level
With command authorization enabled, users can execute only commands authorized by the server.
# Enable command accounting for VTY 0 so users logging in from VTY 0 can execute only the commands authorized by the HWTACACS server.
[Sysname-ui-vty0] command authorization
databits
Use databits to set the number of data bits for each character.
Use undo databits to restore the default.
databits { 7 | 8 }
undo databits
Eight data bits are used for each character.
User interface view
2: System level
7: Uses seven data bits for each character.
8: Uses eight data bits for each character.
The command is applicable only to the AUX user interface.
The data bits setting must be the same for the user interfaces of the connecting ports on the device and the terminal device for communication.
# Use seven data bits for each character.
[Sysname-ui-aux0] databits 7
display ip http
Use display ip http to display HTTP information.
display ip http [ | { begin | exclude | include } regular-expression ]
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display information about HTTP.
<Sysname> display ip http
HTTP port: 80
Basic ACL: 2222
Current connection: 0
Operation status: Running
HTTP port
Port number used by the HTTP service.
Basic ACL
Basic ACL number associated with the HTTP service.
Current connection
Number of current connections.
Operation status
Operation status:
·       Running—The HTTP service is enabled.
·       Stopped—The HTTP service is disabled.
display ip https
Use display ip https to display information about HTTPS.
display ip https [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display information about HTTPS.
<Sysname> display ip https
HTTPS port: 443
SSL server policy: test
Certificate access-control-policy:
Basic ACL: 2222
HTTPS port
Port number used by the HTTPS service.
SSL server policy
SSL server policy associated with the HTTPS service.
Certificate attribute access control policy associated with the HTTPS service.
Basic ACL
Basic ACL number associated with the HTTPS service.
Current connection
Operation status
Operation status:
·       Running—The HTTPS service is enabled.
·       Stopped—The HTTPS service is disabled.
display telnet client configuration
Use display telnet client configuration to display the configuration of the device when it serves as a Telnet client.
display telnet client configuration [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the configuration of the device when it serves as a Telnet client.
<Sysname> display telnet client configuration
 The source IP address is 1.1.1.1.
The output shows that when the device serves as a client, the source IPv4 address for sending Telnet packets is 1.1.1.1.
display user-interface
Use display user-interface to display information about the specified or all user interfaces.
display user-interface [ num1 | { aux | vty } num2 ] [ summary ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
num1: Specifies the absolute number of a user interface, in the range of 0 to 44.
aux: Specifies the AUX user interface.
vty: Specifies the VTY user interface.
num2: Specifies the relative number of a user interface, in the range of 0 to 9 for an AUX user interface and 0 to 15 for a VTY user interface.
summary: Displays summary about user interfaces.
If the summary keyword is not included, the command displays the type of the user interface, the absolute or relative number, the transmission rate, the user privilege level, the authentication mode, and the access port.
If the summary keyword is included, the command displays all user interface numbers and types.
# Display information about user interface 0.
<Sysname> display user-interface 0
<Sysname>display user-interface 3
  Idx  Type     Tx/Rx      Modem Privi Auth  Int
F 3    AUX 0    9600       -     3     N     -
  +    : Current user-interface is active.
  F    : Current user-interface is active and work in async mode.
  Idx  : Absolute index of user-interface.
  Type : Type and relative index of user-interface.
  Privi: The privilege of user-interface.
  Auth : The authentication mode of user-interface.
  Int  : The physical location of UIs.
  A    : Authentication use AAA.
  L    : Authentication use local database.
  N    : Current UI need not authentication.
  P    : Authentication use current UI's password.
The current user interface is active.
F
The current user interface is active and operates in asynchronous mode.
Idx
Absolute number of the user interface.
Type and relative number of the user interface.
Tx/Rx
Transmission/Receive rate of the user interface.
Modem
Whether the modem is allowed to dial in (in), dial out (out), or both (inout).
If this function is disabled, a hyphen (-) is displayed.
Privi
Command level of a user under that user interface.
Auth
Authentication mode for the users:
·       A—Scheme authentication mode.
·       L—Local authentication mode (not supported).
·       N—None authentication mode.
·       P—Password authentication mode.
Int
Physical port that corresponds to the user interface. For AUX and VTY user interfaces, a hyphen (-) is displayed.
# Display summary about all user interfaces.
<Sysname> display user-interface summary
<H3C>dis user-interface summary
  User interface type : [TTY]
            0:XXX
  User interface type : [AUX]
            3:XXXX XXXX XX
  User interface type : [VTY]
           29:UUUU XXXX XXXX XXXX
    4 character mode users.    (U)
   25 UI never used.        (X)
4 total UI in use
User interface type
Type of the user interface, AUX or VTY.
Type of the user interface, AUX, VTY, or TTY. The device does not support TTY user interfaces.
0:X
0 represents the absolute number of the user interface. If the user interface is not used, an X is displayed. If the user interface is in use, a U is displayed.
Number of users, or the total number of character U.
UI never used.             (X)
Number of user interfaces not used, or the total number of character X.
total UI in use
Total number of user interfaces in use.
display users
Use display users to display information about the user interfaces being used.
display users [ all ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays information about all user interfaces the device supports.
Use the display users all command to display information about all user interfaces supported by the device.
# Display information about the user interfaces being used.
<Sysname> display users
The user application information of the user interface(s):
  Idx UI      Delay    Type Userlevel
  29  VTY 0   05:51:43 TEL  3
+ 30  VTY 1   00:00:00 TEL  3
Following are more details.
VTY 0   :
VTY 1   :
+    : Current operation user.
 F    : Current operation user work in async mode.
The output shows that two users have logged in to the device. The one with IP address 192.168.1.54 uses VTY 0, and the other with IP address 192.168.1.58 uses VTY 1.
Table 5 Command output
Idx
UI
Relative number of the user interface. For example, with VTY, the first column represents user interface type, and the second column represents the relative number of the user interface.
Delay
Time elapsed after the user's last input, in the format hh:mm:ss.
User type, such as Telnet or SSH.
Userlevel
User level, 0 for visit, 1 for monitor, 2 for system, or 3 for manage.
Current user.
Location
IP address of the user.
F
The current user is operating in asynchronous mode.
display web users
Use display web users to display information about the Web users.
display web users [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display information about the Web users.
<Sysname> display web users
UserID    Name       Language  Level      State    LinkCount LoginTime LastTime
ab890000  admin      Chinese   Management Enable      0      14:13:46  14:14:18
Table 6 Command output
UserID
Web user ID.
Name
Web username.
Language
Language used in Web login.
Level
Web user level.
Web user status.
LinkCount
Number of tasks running for the Web user.
LoginTime
Login time.
LastTime
Last time when the Web user accessed the device.
escape-key
Use escape-key to define a shortcut key for terminating a task.
Use undo escape-key to disable the shortcut key for terminating tasks.
escape-key { default | character }
undo escape-key
Pressing Ctrl+C terminates a task.
User interface view
3: Manage level
character: Specifies the shortcut key for terminating a task. The shortcut key can be a single character or an ASCII code in the range of 0 to 127. If you specify a number that is greater than 127 or a non-numeric string of one to three characters, only the first character is used as the shortcut key. For example, if you enter activation-key 987, the shortcut key is 9. If you enter activation-key abc, the shortcut key is a.
default: Restores the default escape key sequence Ctrl+C.
If you set the character argument in a user interface of a device, when you use the user interface to log in to the device and then Telnet to another device, the character argument can only be used as a control character to terminate a task, rather than a common character. For example, if you specify character e in VTY 0 user interface of Device A, when you log in to Device A through VTY 0 from a PC (HyperTerminal), you can enter e as a common character on the PC, and you can also use e to terminate the task running on Device A. If you Telnet to Device B from Device A, you can only use e to terminate the task running on Device B, rather than use e as a common character. It is a good practice to specify a key sequence.
# Define key a as the shortcut key for terminating a task.
[Sysname-ui-aux0] escape-key a
1.      Ping the IP address of 192.168.1.49 and use the -c keyword to specify the number of ICMP echo packets to be sent as 20.
<Sysname> ping -c 20 192.168.1.49
  PING 192.168.1.49: 56  data bytes, press a to break
    Reply from 192.168.1.49: bytes=56 Sequence=1 ttl=255 time=3 ms
    Reply from 192.168.1.49: bytes=56 Sequence=2 ttl=255 time=3 ms
2.      # Enter a.
The task terminates immediately and the system returns to system view.
  --- 192.168.1.49 ping statistics ---
    2 packet(s) transmitted
    2 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 3/3/3 ms
<Sysname>
flow-control
Use flow-control to configure the flow control mode.
Use undo flow-control to restore the default.
undo flow-control
The flow control mode is none, and no flow control is performed.
2: System level
hardware: Performs hardware flow control.
none: Disables flow control.
software: Performs software flow control.
The device supports only the none mode.
A flow control mode takes effect on both the inbound and outbound directions. In inbound flow control, the local device listens to the remote device for flow control information. In the outbound flow control, the local device sends flow control information to the remote device.
To communicate, the two ends must be configured with the same flow control mode.
# Configure the flow control mode as none for user interface AUX 0.
[Sysname-ui-aux0] flow-control none
free user-interface
Use free user-interface to release the connections established on a user interface.
free user-interface { num1 | { aux | vty } num2 }
3: Manage level
This command cannot release the connection you are using.
# Display the connection established on user interface VTY 1:
1.      Display which users are operating the device.
  29  VTY 0   05:56:53 TEL  3
  31  VTY 2   00:43:04 TEL  3
  32  VTY 3   05:49:26 TEL  3
VTY 0   :
VTY 1   :
VTY 2   :
VTY 3   :
2.      If the operations of the user using VTY 1 affect the operations of the administrator, log out the user.
<Sysname> free user-interface vty 1
Are you sure to free user-interface vty1? [Y/N]:y
free web-users
Use free web-users to log out Web users.
free web-users { all | user-id user-id | user-name user-name }
2: System level
all: Specifies all Web users.
user-id: Specifies a Web user ID, a hexadecimal number of eight digits.
user-name: Specifies a Web username, a string of 1 to 80 characters.
# Log out all Web users.
<Sysname> free web-users all
display web users
history-command max-size
Use history-command max-size to set the size of the command history buffer for the user interface.
Use undo history-command max-size to restore the default.
history-command max-size size-value
The buffer of a user interface saves 10 history commands at most.
User interface view
2: System level
size-value: Specifies the maximum number of history commands the buffer can store. The value ranges from 0 to 256.
The command history buffer saves executed history commands per user interface and buffers for different user interfaces do not affect each other. To display the commands stored in the history buffer for the current user interface, use the display history-command command. To view the recently executed commands, press the up and down arrow keys.
When a user terminates the session, the system automatically removes the commands saved in the history buffer.
# Set the buffer to store a maximum of 20 history commands.
[Sysname-ui-aux0] history-command max-size 20
idle-timeout
Use idle-timeout to set the idle-timeout timer.
Use undo idle-timeout to restore the default.
undo idle-timeout
The idle-timeout is 10 minutes.
User interface view
2: System level
minutes: Specifies the number of minutes for the idle-timeout time, in the range of 0 to 35791. The default is 10 minutes.
seconds: Specifies the number of seconds for the idle-timeout time, in the range of 0 to 59. The default is 0 seconds.
The system automatically terminates the user's connections if there is no information interaction between the device and the users within the idle timeout time.
Setting idle-timeout to zero disables the timer. In this case, connections are maintained unless you terminate them.
# Set the idle-timeout timer to 1 minute and 30 seconds.
[Sysname-ui-aux0] idle-timeout 1 30
ip http acl
Use ip http acl to associate the HTTP service with an ACL.
Use undo ip http acl to remove the association.
ip http acl acl-number
undo ip http acl acl-number
The HTTP service is not associated with any ACL.
2: System level
acl-number: Specifies an ACL number in the range of 2000 to 2999.
After the HTTP service is associated with an ACL, only clients permitted by the ACL can access the device through HTTP.
The HTTP service can be associated with only one basic ACL. If you execute the ip http acl command multiple times, the most recent configuration takes effect.
# Associate the HTTP service with ACL 2001 to only allow the clients within the 10.10.0.0/16 network to access the device through HTTP.
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname] ip http acl 2001
·           display ip http
·           acl number (ACL and QoS Command Reference)
ip http enable
Use ip http enable to enable the HTTP service.
Use undo ip http enable to disable the HTTP service.
ip http enable
undo ip http enable
2: System level
The default setting of this command varies with devices.
The device can act as the HTTP server that can be accessed only after the HTTP service is enabled.
# Enable the HTTP service.
[Sysname] ip http enable
# Disable the HTTP service.
[Sysname] undo ip http enable
display ip http
ip http dscp
Use ip http dscp to set the DSCP value for IPv4 to use for outgoing HTTP packets.
Use undo ip http dscp to restore the default.
ip http dscp dscp-value
undo ip http dscp
IPv4 uses the DSCP value 16 for outgoing HTTP packets.
2: System level
dscp-value: Specifies a DSCP value in the range of 0 to 63.
# Set the DSCP value for IPv4 to use for outgoing HTTP packets to 30.
[Sysname] ip http dscp 30
ip http port
Use ip http port to configure the port number of the HTTP service.
Use undo ip http port to restore the default.
ip http port port-number
undo ip http port
The port number of the HTTP service is 80.
3: Manage level
port-number: Specifies the port number of the HTTP service, in the range of 1 to 65535.
Verify that the port number is not used by another service, because this command does not examine for conflicts with configured port numbers.
# Configure the port number of the HTTP service as 8080.
[Sysname] ip http port 8080
display ip http
ip https acl
Use ip https acl to associate the HTTPS service with an ACL.
Use undo ip https acl to remove the association.
ip https acl acl-number
undo ip https acl acl-number
The HTTPS service is not associated with any ACL.
3: Manage level
After the HTTPS service is associated with an ACL, only the clients permitted by the ACL can access the device.
The HTTPS service can be associated with only one basic ACL. If you execute the ip https acl command multiple times, the most recent configuration takes effect.
# Associate the HTTPS service with ACL 2001 to only allow the clients within the 10.10.0.0/16 network segment to access the HTTPS server through HTTP.
[Sysname] ip https acl 2001
·           display ip https
ip https certificate access-control-policy
Use ip https certificate access-control-policy to associate the HTTPS service with a certificate attribute access control policy.
Use undo ip https certificate access-control-policy to remove the association.
The HTTPS service is not associated with any certificate attribute access control policy.
3: Manage level
policy-name: Specifies the name of the certificate attribute access control policy, a string of 1 to 16 characters.
Association of the HTTPS service with a certificate attribute access control policy can control the access rights of clients.
# Associate the HTTPS server to certificate attribute access control policy myacl.
[Sysname] ip https certificate access-control-policy myacl
·           display ip https
·           pki certificate access-control-policy (Security Command Reference)
ip https enable
Use ip https enable to enable the HTTPS service.
Use undo ip https enable to disable the HTTPS service.
ip https enable
3: Manage level
Enabling the HTTPS service triggers an SSL handshake negotiation process:
·           If the local certificate of the device exists, the SSL negotiation succeeds, and the HTTPS service can be started.
·           If no local certificate exists, the SSL negotiation triggers a certificate application process that often fails because it times out. If that happens, execute the ip https enable command multiple times to start the HTTPS service.
# Enable the HTTPS service.
[Sysname] ip https enable
ip https port
Use ip https port to configure the port number of the HTTPS service.
Use undo ip https port to restore the default.
ip https port port-number
undo ip https port
The port number of the HTTPS service is 443.
3: Manage level
port-number: Specifies the port number of the HTTPS service, in the range of 1 to 65535.
# Configure the port number of the HTTPS service as 6000.
[Sysname] ip https port 6000
display ip https
ip https ssl-server-policy
Use ip https ssl-server-policy to associate the HTTPS service with an SSL server-end policy.
Use undo ip https ssl-server-policy to remove the association.
The HTTPS service is not associated with any SSL server-end policy, and the device uses a self-signed certificate for authentication (a self-signed certificate is generated and signed by the device itself, rather than the CA).
3: Manage level
policy-name: Specifies the name of an SSL server policy, a string of 1 to 16 characters.
The HTTPS service can be enabled only after this command is configured successfully.
With the HTTPS service enabled, you cannot modify the associated SSL server-end policy or remove the association between the HTTPS service and the SSL server-end policy after the HTTPS service is enabled.
# Associate the HTTPS service with SSL server-end policy myssl.
[Sysname] ip https ssl-server-policy myssl
·           display ip https
·           ssl server-policy (Security Command Reference)
lock
Use lock to lock the current user interface.
lock
This function is disabled.
3: Manage level
When you must leave the device for a while, use this command to lock the current user interface to prevent unauthorized access.
After you enter this command, you are asked to enter a password (up to 16 characters) and confirm it by entering the password again. To unlock the user interface, press Enter and enter the correct password.
# Lock the current user interface.
<Sysname> lock
Please input password<1 to 16> to lock current user terminal interface:
Password:
Again:
                   locked !
Password:
<Sysname>
parity
Use parity to set a parity check method.
Use undo parity to restore the default.
parity { even | none | odd }
undo parity
No parity check is performed.
2: System level
even: Performs an even parity check.
none: Performs no parity check.
odd: Performs an odd parity check.
The parity check setting must be the same for the user interfaces of the connecting ports on the device and the target terminal device for communication.
# Configure AUX user interface 0 to perform an odd parity check.
[Sysname-ui-aux0] parity odd
protocol inbound
Use protocol inbound to enable the current user interface to support Telnet, SSH, or both of them. The configuration takes effect the next time you log in.
Use undo protocol inbound to restore the default.
Both SSH and Telnet are supported.
VTY interface view
3: Manage level
all: Supports both Telnet and SSH.
ssh: Supports only SSH.
telnet: Supports only Telnet.
Before configuring a user interface to support SSH, set the authentication mode to scheme for the user interface; otherwise, the protocol inbound ssh command fails. For more information, see authentication-mode.
# Enable the VTYs 0 through 4 to support only SSH.
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] authentication-mode scheme
[Sysname-ui-vty0-4] protocol inbound ssh
screen-length
Use screen-length to set the maximum number of lines to be displayed on a screen.
Use undo screen-length to restore the default.
screen-length screen-length
undo screen-length
A screen displays 24 lines at most.
User interface view
2: System level
screen-length: Specifies the maximum number of lines to be displayed on a screen, in the range of 0 to 512. The value of 0 disables pausing between screens of output.
When screen output pauses, press the Space key to display the next screen. Not all terminals support this setting. For example, assume you set screen-length to 40, but the terminal can display 24 lines in one screen at most. When you press Space, the device sends 40 lines to the terminal, but the screen displays only lines 18 through 40. To view the first 17 lines, press the page up or page down key.
To disable pausing between screens of output for the current session, use the screen-length disable command.
# Set the screen length of AUX user interface 0 to 30 lines.
[Sysname-ui-aux0] screen-length 30
send
Use send to send messages to user interfaces.
send { all | num1 | { aux | vty } num2 }
1: Monitor level
all: Specifies all user interfaces.
aux: Specifies an AUX user interface.
vty: Specifies a VTY user interface.
After you issue the command, enter the message to be sent at the prompt. To end message input, press Ctrl+Z. To cancel message input and return to user view, press Ctrl+C.
# Send message hello abc to AUX user interface 0.
<Sysname> send aux 0
Enter message, end with CTRL+Z or Enter; abort with CTRL+C:
hello abc^Z
Send message? [Y/N]:y
<Sysname>
***Message from aux0 to aux0
hello abc
<Sysname>
# Before you restart the device, follow these steps to inform users accessing the device through other user interfaces:
1.      Display information about all users.
  29  VTY 0   06:07:50 TEL  3
  31  VTY 2   00:54:02 TEL  3
  32  VTY 3   06:00:24 TEL  3
VTY 0   :
VTY 1   :
VTY 2   :
VTY 3   :
// The output shows that you are using VTY 0 and another user is using VTY 1.
2.      Send a notification to the user of VTY 1.
<Sysname> send vty 1
Your attention please. I will reboot the system in 3 minutes!^Z
// The message is sent to VTY 1 and displayed on VTY 1. (Suppose the user of VTY 1 is entering the interface gigabitethernet command.)
[Sysname] interface gigabitethernet
***Message from vty0 to vty1
Use set authentication password to set a password.
Use undo set authentication password to remove the password.
set authentication password [ hash ] { cipher | simple } password
No password is set.
User interface view
3: Manage level
hash: Uses a hash algorithm to encrypt the password.
cipher: Sets a ciphertext password.
simple: Sets a plaintext password.
password: Specifies the password string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 16 characters. If you specify the hash keyword, the ciphertext password can be a string of 1 to 110 characters. If you do not specify the hash keyword, the ciphertext password can be a string of 1 to 53 characters..
For secrecy, the password is saved in cipher text, even if configured in plain text.
# Set the password for user interface AUX 0 to hello.
[Sysname-ui-aux0] authentication-mode password
[Sysname-ui-aux0] set authentication password simple hello
authentication-mode
shell
Use shell to enable the terminal service for user interfaces.
Use undo shell to disable the terminal service for user interfaces.
shell
undo shell
Terminal service is enabled on all user interfaces.
User interface view
3: Manage level
The AUX user interface does not support the undo shell command.
You cannot disable the terminal service on the user interface you are using.
# Disable the terminal service for VTYs 0 through 15, so no user can log in to the device through VTYs 0 through 15.
[Sysname-ui-vty0-15] undo shell
% Disable ui-vty0-15 , are you sure? [Y/N]:y
The following message appears when a user tries to Telnet to the device:
The connection was closed by the remote host!
speed (user interface view)
Use speed to set the transmission rate on the user interface.
Use undo speed to restore the default transmission rate.
speed speed-value
undo speed
The transmission rate is 9600 bps.
2: System level
speed-value: Specifies a transmission rate in bps. The transmission rates available with asynchronous serial interfaces include: 300 bps, 600 bps, 1200 bps, 2400 bps, 4800 bps, 9600 bps, 19200 bps, 38400 bps, 57600 bps, and 115200 bps. The transmission rate varies with devices and configuration environment.
The transmission rate setting must be identical for the user interfaces of the connecting ports on the device and the target terminal device for communication.
# Set the transmission rate on the user interface AUX 0 to 19200 bps.
[Sysname-ui-aux0] speed 19200
stopbits
Use stopbits to set the number of stop bits transmitted per byte.
Use undo stopbits to restore the default.
stopbits { 1 | 1.5 | 2 }
undo stopbits
The stop bit is one.
2: System level
1: Uses one stop bit.
1.5: Uses one and a half stop bits.
2: Uses two stop bits.
The stop bits setting must be the identical for the user interfaces of the connecting ports on the device and the target device for communication.
# Set the stop bits on the user interface AUX 0 to 1.5.
[Sysname-ui-aux0] stopbits 1.5
stopbit-error intolerance
telnet
Use telnet to Telnet to a remote host.
telnet remote-host [ service-port ] [ source { interface interface-type interface-number | ip ip-address } ]
0: Visit level
remote-host: Specifies the IPv4 address or host name of the remote host, a case-insensitive string of 1 to 20 characters.
service-port: Specifies the TCP port number of the Telnet service on the remote host. It ranges from 0 to 65535, with a default of 23.
source: Specifies a source interface or source IPv4 address for outgoing Telnet packets.
interface interface-type interface-number: Specifies a source interface for outgoing Telnet packets. The primary IP address of this interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies a source IPv4 address for outgoing Telnet packets.
To terminate your Telnet connection, press Ctrl+K or enter quit.
The source IPv4 address or source interface specified with this command only applies to the current Telnet connection.
# Telnet to the remote host 1.1.1.2, specifying the source IP address for outgoing Telnet packets as 1.1.1.1.
<Sysname> telnet 1.1.1.2 source ip 1.1.1.1
telnet client dscp
Use telnet client dscp to set the DSCP value for IPv4 to use for outgoing Telnet packets on a Telnet client.
Use undo telnet client dscp to restore the default.
telnet client dscp dscp-value
IPv4 uses the DSCP value 16 for outgoing Telnet packets on a Telnet client.
2: System level
# Set the DSCP value for IPv4 to use for outgoing Telnet packets to 30 on a Telnet client.
[Sysname] telnet client dscp 30
telnet client source
Use telnet client source to specify a source IPv4 address or source interface for outgoing Telnet packets when the device serves as a Telnet client.
Use undo telnet client source to restore the default.
No source IPv4 address or source interface is specified for outgoing Telnet packets. The IP address of the outbound interface is used as the source IPv4 address.
2: System level
The setting by this command applies to all Telnet connections.
If you use both this command and the telnet command to specify the source IPv4 address or source interface, the setting specified with the telnet command takes effect.
# Specify the source IPv4 address for outgoing Telnet packets when the device serves as a Telnet client as 1.1.1.1.
[Sysname] telnet client source ip 1.1.1.1
telnet server dscp
Use telnet server dscp to set the DSCP value for IPv4 to use for outgoing Telnet packets on a Telnet server.
Use undo telnet server dscp to restore the default.
telnet server dscp dscp-value
IPv4 uses the DSCP value 48 for outgoing Telnet packets on a Telnet server.
2: System level
# Set the DSCP value for IPv4 to use for outgoing Telnet packets to 30 on a Telnet server.
[Sysname] telnet server dscp 30
telnet server enable
Use telnet server enable to enable the Telnet server.
Use undo telnet server enable to disable the Telnet server.
The Telnet server is enabled.
3: Manage level
# Enable the Telnet server.
terminal type
Use terminal type to configure the type of terminal display of the current user interface.
Use undo terminal type to restore the default.
undo terminal type
The terminal display type is ANSI.
User interface view
2: System level
ansi: Specifies the terminal display type as ANSI.
vt100: Specifies the terminal display type as VT100.
The device supports two terminal display types: ANSI and VT100. H3C recommends setting the display type to VT100 for both the device and the client. If the device and the client use different display types or both are using the ANSI display type, when the total number of characters for a command line exceeds 80, the screen display on the terminal might be abnormal. For example, the cursor might be displayed at a wrong place.
# Set the terminal display type to VT100.
[Sysname-ui-vty0] terminal type vt100
Use user privilege level to configure the user privilege level. Users logging into the user interface are assigned a user privilege level.
Use undo user privilege level to restore the default.
user privilege level level
The command level is 3 for the AUX user interface and 0 for other user interfaces.
User interface view
3: Manage level
level: Specifies a user privilege level in the range of 0 to 3.
User privilege levels include visit, monitor, system, and manage, represented by the number 0, 1, 2 and 3 respectively. You can change the user privilege level when necessary.
# Set the command level for users logging in through VTY 0 to 0.
[Sysname-ui-vty0] user privilege level 0
After you Telnet to the device through VTY 0, the terminal only displays commands of level 0 in the help information:
<Sysname> ?
User view commands:
  archive           Specify archive settings
  backup            Backup next startup-configuration file to TFTP server
  boot-loader       Set boot loader
  bootrom           Update/read/backup/restore bootrom
  brand             Set Original Equipment Manufacturer (BRAND) information
  cd                Change current directory
  cfd               Connectivity fault detection (IEEE 802.1ag)
  clock             Specify the system clock
  cluster           Run cluster command
  copy              Copy from one file to another
  debugging         Enable system debugging functions
  delete            Delete a file
  dir               List files on a file system
  display           Display current system information
  fixdisk           Recover lost chains in storage device
  format            Format the device
  free              Clear user terminal interface
  ftp               Open FTP connection
  graceful-restart  Graceful restart
  lock              Lock current user terminal interface
  logfile           Specify log file configuration
  mcms              Specify multi-core multi-system configuration information
  ---- More ----
user-interface
Use user-interface to enter user interface view.
user-interface { first-num1 [ last-num1 ] | { aux | vty } first-num2 [ last-num2 ] }
2: System level
first-num1: Specifies the absolute number of the first user interface, in the range of 0 to 44.
last-num1: Specifies the absolute number of the last user interface, in the range of 1 to 33. This value cannot be smaller than the first-num1.
first-num2: Specifies the relative number of the first user interface, in the range of 0 to 9 for an AUX user interface and 0 to 15 for a VTY user interface.
last-num2: Specifies the relative number of the last user interface, in the range of 1 to 15 for a VTY user interface. For an AUX user interface, do not specify this argument or set it to 1. This value cannot be smaller than first-num 2.
If you specify a single user interface, the configuration you perform only applies to the user interface.
If you specify multiple user interfaces, the configuration you perform applies to all those user interfaces.
# Enter the AUX user interface view.
[Sysname-ui-aux0]
# Enter the user interface views of VTYs 0 to 4.
[Sysname-ui-vty0-4]
web captcha
Use web captcha to specify a fixed verification code for Web login.
Use undo web captcha to restore the default.
web captcha verification-code
undo web captcha
A Web user must enter the verification code indicated on the login page to log in.
3: Manage level
verification-code: Specifies the fixed verification code for Web login, a case-sensitive four-character string.
If you configure the web captcha command multiple times, the most recent configuration takes effect.
After you configure a fixed verification code for Web login, a Web user can use the code for login, without caring about the verification code displayed on the login page. This feature is intended for test environments where a script is usually used for Web function tests. Eliminating the requirement for entering the verification code every time, this feature helps improve the test efficiency.
For Web access security, do not use this feature in production environments.
This command is not saved to the configuration file and cannot survive a reboot.
# Specify a fixed verification code for Web login.
<Sysname> web captcha test
web https-authorization mode
Use web https-authorization mode to specify the authentication mode for users trying to log in to the device through HTTPS.
Use undo web https-authorization mode to restore the default.
A user must enter correct username and password to log in through HTTPS.
2: System level
auto: Uses the PKI certificates of HTTPS users to automatically authenticate them.
manual: Provides a login page for HTTPS users to enter the correct username and password.
When the auto mode is enabled:
·           If the PKI certificate of the user is correct and not expired, the CN field in the certificate is used as the username to perform AAA authentication. If the authentication succeeds, the user automatically enters the Web interface of the device.
·           If the PKI certificate of the user is correct and not expired, but the AAA authentication fails, the device shows the Web login page. The user can log in to the device after entering correct username and password.
·           When the PKI certificate of the user is incorrect or expired, the HTTPS connection is terminated.
# Specify the auto authentication mode for users trying to log in to the device through HTTPS.
[Sysname] web https-authorization mode auto
web idle-timeout
Use web idle-timeout to set the Web user connection timeout time.
Use undo web idle-timeout to restore the default.
web idle-timeout minutes
The Web user connection timeout time is 10 minutes.
2: System level
minutes: Specifies the timeout time in minutes, in the range of 1 to 999.
# Set the Web user connection timeout time to 20 minutes.
<System> system-view
[System] web idle-timeout 20
web logbuffer size
Use web logbuffer size to set the size of the buffer for Web login logging.
Use undo web logbuffer size to restore the default.
web logbuffer size pieces
The buffer can store up to 512 logs.
2: System level
pieces: Specifies the size of the buffer for Web login logging, in the number of log messages. The value range is 0 to 1024. The default is 512.
# Set the size of the buffer for Web login logging to 800.
[System] web logbuffer size 800
