05-Layer 3—IP Routing Command Reference
HomeSupportSwitchesS6300 SeriesReference GuidesCommand ReferencesH3C S6300 Switch Series Command References-Release 243x-6W10005-Layer 3—IP Routing Command Reference
01-Basic IP routing commands
01-Basic IP routing commands 167.61 KB
address-family ipv4
Use address-family ipv4 to create a RIB IPv4 address family and enter RIB IPv4 address family view.
Use undo address-family ipv4 to remove a RIB IPv4 address family and all configurations in the view.
address-family ipv4
No RIB IPv4 address family is created.
RIB view
# Create a RIB IPv4 address family and enter RIB IPv4 address family view.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6
Use address-family ipv6 to create a RIB IPv6 address family and enter RIB IPv6 address family view.
Use undo address-family ipv6 to remove a RIB IPv6 address family and all configurations in the view.
address-family ipv6
No RIB IPv6 address family is created.
RIB view
# Create a RIB IPv6 address family and enter RIB IPv6 address family view.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
display ip routing-table
Use display ip routing-table to display routing table information.
display ip routing-table [ vpn-instance vpn-instance-name ] [ verbose ] [ standby slot slot-number ]
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays routing table information for the public network.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays only brief information about active routes.
standby slot slot-number: Displays backup routing table information on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays routing table information.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
         Destinations : 13        Routes : 13
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
1.1.1.0/24          Static 60   0            192.168.47.4    Vlan1
127.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
192.168.1.0/24      Direct 0    0            192.168.1.40    Vlan11
192.168.1.0/32      Direct 0    0            192.168.1.40    Vlan11
192.168.1.40/32     Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.40    Vlan11
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
Destinations
Number of destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address/mask length.
Proto
Protocol that installed the route.
Pre
Preference of the route.
Cost
Cost of the route.
NextHop
Next hop address of the route.
Output interface for packets to be forwarded along the route.
Summary Count
Number of routes.
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Destination: 0.0.0.0/32
   Protocol: Direct          Process ID: 0
  SubProtID: 0x0                    Age: 08h34m37s
       Cost: 0               Preference: 0
        Tag: 0                    State: Active NoAdv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x10000000          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 0.0.0.0
      Flags: 0x1000c        OrigNextHop: 127.0.0.1
      Label: NULL           RealNextHop: 127.0.0.1
    BkLabel: NULL             BkNextHop: N/A
  Tunnel ID: Invalid          Interface: InLoopBack0
BkTunnel ID: Invalid        BkInterface: N/A
Destination: 1.1.1.0/24
   Protocol: Static          Process ID: 0
  SubProtID: 0x0                    Age: 04h20m37s
       Cost: 0               Preference: 60
        Tag: 0                    State: Active Adv
      NibID: 0x10000003          LastAs: 0
      Flags: 0x1008c        OrigNextHop: 192.168.47.4
      Label: NULL           RealNextHop: 192.168.47.4
  Tunnel ID: Invalid          Interface: Vlan-interface1
Destinations
Routes
Number of routes.
Destination
Protocol
SubProtID
ID of the subprotocol for routing.
Age
Time for which the route has been in the routing table.
Cost
Cost of the route.
Preference
Tag
Route tag.
Route status:
·     Active—Active unicast route.
·     Adv—Route that can be advertised.
·     Inactive—Inactive route.
·     NoAdv—Route that the router must not advertise.
·     Virtual—Routes for virtual IP addresses generated by virtual gateway protocols.
·     Nat—Routes generated by NAT.
OrigTblID
Original routing table ID.
OrigVrf
Original VPN instance to which the route belongs.
TableID
ID of the routing table.
OrigAs
Original AS number.
NibID
ID of the next hop.
LastAs
Last AS number.
AttrID
Attribute ID.
Neighbor
Address of the neighbor determined by the routing protocol.
Flags
Flags of the route.
OrigNextHop
RealNextHop
Real next hop of the route.
BkLabel
Backup label.
BkNexthop
Backup next hop.
Tunnel ID
Tunnel ID.
BkTunnel ID
Backup tunnel ID.
BkInterface
Backup output interface.
FtnIndex
Index of the FTN entry.
Summary Count
Number of routes.
display ip routing-table acl
Use display ip routing-table acl to display information about routes permitted by a specific basic ACL.
display ip routing-table [ vpn-instance vpn-instance-name ] acl acl-number [ verbose ] [ standby slot slot-number ]
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays routing information for the public network.
acl-number: Specifies a basic ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic ACL.
standby slot slot-number: Displays backup information about routes permitted by the basic ACL on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays information about routes permitted by the basic ACL.
If the specified ACL does not exist or has no rules configured, the command displays information about all routes.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-basic-2000] display ip routing-table acl 2000
Routes Matched by Access control list : 2000
Summary Count : 4
192.168.1.0/24      Direct 0    0            192.168.1.111   Vlan1
192.168.1.0/32      Direct 0    0            192.168.1.111   Vlan1
192.168.1.111/32    Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.111   Vlan1
For command output, see Table 1.
# Display detailed information about all routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary Count : 4
Destination: 192.168.1.0/24
  SubProtID: 0x1                    Age: 04h20m37s
      Flags: 0x10080        OrigNextHop: 192.168.1.111
      Label: NULL           RealNextHop: 192.168.1.111
Destination: 192.168.1.0/32
      Flags: 0x1008c        OrigNextHop: 192.168.1.111
Destination: 192.168.1.111/32
      Flags: 0x10004        OrigNextHop: 127.0.0.1
Destination: 192.168.1.255/32
For command output, see Table 2.
display ip routing-table ip-address
Use display ip routing-table ip-address to display information about routes to a specific destination address.
Use display ip routing-table ip-address1 to ip-address2 to display information about routes to a range of destination addresses.
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask | mask-length ] [ longer-match ] [ verbose ] [ standby slot slot-number ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ] [ standby slot slot-number ]
ip-address: Specifies a destination IP address in dotted decimal notation.
mask: Specifies the IP address mask in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
longer-match: Displays the route entry with the longest mask.
ip-address1 to ip-address2: Specifies a destination IP address range.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays brief information about active routes.
standby slot slot-number: Displays backup information about routes to the specified destination addresses on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays information about routes to the specified destination addresses.
Executing the command with different parameters yields different outputs.
·     display ip routing-table ip-address
¡     The system ANDs the entered destination IP address with the subnet mask in each active route entry.
¡     The system ANDs the destination IP address in each active route entry with its own subnet mask.
If the two operations yield the same result for an entry, the entry is displayed.
·     display ip routing-table ip-address mask
¡     The system ANDs the entered destination IP address with the entered subnet mask.
¡     The system ANDs the destination IP address in each active route entry with the entered subnet mask.
If the two operations yield the same result for an entry and the entry has a subnet mask less than or equal to the entered subnet mask, the entry is displayed.
·     display ip routing-table ip-address longer-match
If the two operations yield the same result for multiple entries, the one with longest mask length is displayed.
·     display ip routing-table ip-address mask longer-match
If the two operations yield the same result for multiple entries and the entries have a mask less than or equal to the entered subnet mask, the one with the longest mask length is displayed.
·     display ip routing-table ip-address1 to ip-address2
The system displays active route entries with destinations in the range of ip-address1/32 to ip-address2/32.
# Display brief information about the routes to the destination IP address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1
Summary Count : 3
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.0.0.0/16         Static 60   0            0.0.0.0         NULL0
11.0.0.0/24         Static 60   0            0.0.0.0         NULL0
# Display brief information about the routes to the destination IP address 11.0.0.1 and mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20
Summary Count : 2
# Display brief information about the most specific route to the destination address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary Count : 1
# Display brief information about the most specific route to the destination IP address 11.0.0.1 and mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary Count : 1
# Display brief information about the routes to destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary Count : 6
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1         Vlan2
3.3.3.0/24          Direct 0    0            3.3.3.1         Vlan2
3.3.3.1/32          Direct 0    0            127.0.0.1       InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1         Vlan1
4.4.4.1/32          Direct 0    0            127.0.0.1       InLoop0
display ip routing-table prefix-list
Use display ip routing-table prefix-list to display routes permitted by an IP prefix list.
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ] [ standby slot slot-number ]
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all routes permitted by the IP prefix list. If you do not specify this keyword, the command displays brief information about active routes permitted by the IP prefix list.
standby slot slot-number: Displays backup routes permitted by the IP prefix list on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays routes permitted by the IP prefix list.
If the specified IP prefix list does not exist, the command displays information about all routes.
# Create an IP prefix list named test to permit the route 1.1.1.0/24.
[Sysname] ip prefix-list test permit 1.1.1.0 24
# Display brief information about the active route permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test
Routes Matched by Prefix list : test
Summary Count : 1
1.1.1.0/24          Direct 0    0            1.1.1.2         Vlan2
# Display detailed information about all routes permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test verbose
Summary Count : 1
      Flags: 0x1008c        OrigNextHop: 1.1.1.2
      Label: NULL           RealNextHop: 1.1.1.2
  Tunnel ID: Invalid          Interface: Vlan-interface2
display ip routing-table protocol
Use display ip routing-table protocol to display information about routes installed by a protocol.
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] [ standby slot slot-number ]
protocol: Specifies a routing protocol. It can be bgp, direct, isis, ospf, rip, or static.
inactive: Displays information about inactive routes. If you do not specify this keyword, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. If you do not specify this keyword, the command displays brief routing information.
standby slot slot-number: Displays backup information about routes installed by the protocol on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays information about routes installed by the protocol.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Summary Count : 13
Direct Routing Table Status : <Active>
Summary Count : 13
2.2.2.0/32          Direct 0    0            2.2.2.1         Vlan2
2.2.2.2/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.255/32        Direct 0    0            2.2.2.1         Vlan2
192.168.80.0/24     Direct 0    0            192.168.80.10   Vlan1
192.168.80.0/32     Direct 0    0            192.168.80.10   Vlan1
192.168.80.10/32    Direct 0    0            127.0.0.1       InLoop0
192.168.80.255/32   Direct 0    0            192.168.80.10   Vlan1
Direct Routing Table Status : <Inactive>
Summary Count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Summary Count : 2
Static Routing Table Status : <Active>
Summary Count : 0
Static Routing Table Status : <Inactive>
Summary Count : 2
1.2.3.0/24          Static 60   0            1.2.4.5        Vlan10
3.0.0.0/8           Static 60   0            2.2.2.2        Vlan1
display ip routing-table statistics
Use display ip routing-table statistics to display IPv4 route statistics.
display ip routing-table [ vpn-instance vpn-instance-name ] statistics [ standby slot slot-number ]
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv4 route statistics for the public network.
standby slot slot-number: Displays backup IPv4 route statistics on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays IPv4 route statistics.
# Display IPv4 route statistics for the public network.
<Sysname> display ip routing-table statistics
Proto      route       active      added       deleted
DIRECT     12          12          30          18
STATIC     3           3           5           2
RIP        0           0           0           0
OSPF       0           0           0           0
ISIS       0           0           0           0
BGP        0           0           0           0
Total      15          15          35          20
Proto
route
Number of routes installed by the protocol.
active
Number of active routes.
added
Number of routes added to the routing table after the router started up or the routing table was cleared most recently.
deleted
Number of routes marked as deleted, which will be cleared after a period.
Total
Total number of routes.
display ip routing-table summary
Use display ip routing-table summary to display brief routing table information.
display ip routing-table [ vpn-instance vpn-instance-name ] summary [ standby slot slot-number ]
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays brief routing table information for the public network.
standby slot slot-number: Displays backup of brief routing table information on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays brief routing table information.
# Display brief routing table information.
<Sysname>display ip routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
# Display brief routing table information for VPN instance vpn1.
<Sysname>display ip routing-table vpn-instance vpn1 summary
Max ECMP: 32
Remain Active Route: 262134
Threshold value of active routes alert: 65100
Max ECMP
Maximum number of ECMP routes supported by the system.
Max Active Route
Maximum number of supported routes.
Remain Active Route
Number of the remaining inactive routes.
Threshold value percentage of max active routes
Alarm threshold specified by using the routing-table limit number warn-threshold command in a VPN instance, in the range of 1 to 100 in percentage. When the percentage of active routes exceeds the alarm threshold, the system logs the event and sends traps. If the number of active routes reaches the maximum number, no more routes can be added. The percentage of active routes equals the number of active routes divided by the maximum number of active routes supported in a VPN instance.
If the routing-table limit command is not configured for the VPN instance, this field displays the maximum number of active routes supported by the device.
Alarm threshold specified by using the routing-table limit number simply-alert command in a VPN instance. When the number of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes.
display ipv6 rib attribute
Use display ipv6 rib attribute to display route attribute information in the IPv6 RIB.
display ipv6 rib attribute [ attribute-id ] [ standby slot slot-number ]
attribute-id: Specifies a route attribute by its ID in the range of 0 to FFFFFFFF.
standby slot slot-number: Displays backup route attribute information in the IPv6 RIB on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays route attribute information in the IPv6 RIB.
# Display route attribute information in the IPv6 RIB.
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
                  Flag: 0x0
              Protocol: BGP4+
        Address family: IPv6
       Reference count: 0
      Local preference: 0
Ext-communities number: 0
 Ext-communities value: N/A
    Communities number: 0
     Communities value: N/A
        AS-path number: 0
         AS-path value: N/A
For command output, see Table 11.
Use display ipv6 rib graceful-restart to display IPv6 RIB GR state information.
# Display IPv6 RIB GR state information.
<Sysname> display ipv6 rib graceful-restart
RIB GR state     : Phase2-calculation end
RCOM GR State    : Flush end
Protocol GR state:
 No.  Protocol   Lifetime FD   State    Start/End
 1    DIRECT6    480      29   End      No/No
 2    STATIC6    480      32   End      No/No
 3    ISISV6     480      30   End      No/No
 4    BGP4+      480      31   End      No/No
For command output, see Table 12.
display ipv6 rib nib
Use display ipv6 rib nib to display next hop information in the IPv6 RIB.
display ipv6 rib nib [ self-originated ] [ nib-id ] [ verbose ] [ standby slot slot-number ]
display ipv6 rib nib protocol protocol-name [ verbose ] [ standby slot slot-number ]
self-originated: Displays information about next hops of self-originated routes in the IPv6 RIB.
nib-id: Specifies a NIB by its ID in the range of 1 to FFFFFFFF.
verbose: Displays detailed next hop information in the IPv6 RIB. If you do not specify this keyword, the command displays brief next hop information in the IPv6 RIB.
protocol protocol-name: Specifies a protocol by its name, which can be bgp+, direct6, isisv6, ospfv3, ripng, or static6.
standby slot slot-number: Displays backup next hop information in the IPv6 RIB on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays next hop information in the IPv6 RIB.
# Display brief next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
      NibID: 0x20000000        Sequence: 0
       Type: 0x1                Flushed: Yes
   UserKey0: 0x0                VrfNthp: 1
   UserKey1: 0x0                Nexthop: ::
    IFIndex: 0x111            LocalAddr: ::
      NibID: 0x20000001        Sequence: 1
   UserKey1: 0x0                Nexthop: ::1
    IFIndex: 0x112            LocalAddr: ::1
# Display detailed next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib verbose
     RefCnt: 4              FlushRefCnt: 1
       Flag: 0x84               Version: 1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::
  RelyDepth: 0              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: vpn1
   TunnelID: N/A
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::1
  RelyDepth: 0              RealNexthop: ::1
  Interface: InLoop0          LocalAddr: ::1
   TunnelID: N/A
For command output, see Table 13 and Table 14.
display ipv6 route-direct nib
Use display ipv6 route-direct nib to display next hop information for IPv6 direct routes.
verbose: Displays detailed next hop information for IPv6 direct routes. If you do not specify this keyword, the command displays brief next hop information for IPv6 direct routes.
# Display brief next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
Table 5 Command output
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the FIB.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Index of the VPN instance to which the next hop belongs.
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
Local interface address.
# Display detailed next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib verbose
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x2                Version: 1
 1 nexthop(s):
   TunnelID: N/A
 1 nexthop(s):
   TunnelID: N/A
Table 6 Command output
x nexthop(s)
Number of next hops.
Tnl-Policy
Tunnel policy.
PrefixIndex
Prefix index of the next hop for an ECMP route.
Vrf
VPN name.
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
localAddr
RelyDepth
Recursion depth.
TunnelCnt
Number of tunnels after route recursion.
TunnelID
ID of the tunnel after route recursion.
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
display ipv6 routing-table
Use display ipv6 routing-table to display IPv6 routing table information.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] [ verbose ] [ standby slot slot-number ]
standby slot slot-number: Displays backup IPv6 routing table information on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays IPv6 routing table information.
# Display brief information about active routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table
Destinations : 3 Routes : 3
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
Interface  : NULL0                                       Cost      : 0
Destination: FF00::/8                                    Protocol  : Direct
Table 7 Command output
Destinations
Routes
Number of routes.
Destination
IPv6 address and prefix of the destination network or host.
NextHop
Preference
Protocol
Protocol that installed the route. Route types include:
·     O_INTRA—OSPF intra area route.
·     O_INTER—OSPF inter area route.
·     O_ASE1—OSPF external type 1 route.
·     O_ASE2—OSPF external type 2 route.
·     O_NSSA1—OSPF NSSA external type 1 route.
·     O_NSSA2—OSPF NSSA external type 2 route.
·     O_SUM—OSPF summary route.
·     IS_L1—IS-IS level-1 route.
·     IS_L2—IS-IS level-2 route.
·     IS_SUM—IS-IS summary route.
Cost
Cost of the route.
Summary Count
Number of routes.
<Sysname> display ipv6 routing-table verbose
  SubProtID: 0x0                    Age: 00h53m50s
    TableID: 0xa                 OrigAs: 0
      NibID: 0x20000000          LastAs: 0
     AttrID: 0xffffffff        Neighbor: ::
      Flags: 0x10004        OrigNextHop: ::1
      Label: NULL           RealNextHop: ::1
      NibID: 0x20000002          LastAs: 0
      Flags: 0x10084        OrigNextHop: ::
  Tunnel ID: Invalid          Interface: NULL0
      NibID: 0x20000001          LastAs: 0
      Flags: 0x10014        OrigNextHop: ::
Table 8 Command output
Destination
Protocol
SubProtID
Age
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Tag
Tag of the route.
Route status:
·     Virtual—Routes for virtual IPv6 addresses generated by virtual gateway protocols.
·     TunE—Tunnel. (This value is not supported in the current software version.)
OrigTblID
OrigVrf
TableID
OrigAs
Original AS number.
NibID
ID of the next hop.
LastAs
Last AS number.
AttrID
Attribute ID.
Neighbor
Flags
Flags of the route.
OrigNextHop
RealNextHop
BkLabel
Backup label.
BkNexthop
Backup next hop.
Tunnel ID
Tunnel ID.
BkTunnel ID
Backup tunnel ID.
BkInterface
Summary Count
Number of routes.
display ipv6 routing-table acl
Use display ipv6 routing-table acl to display routing information permitted by a specific IPv6 basic ACL.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl acl-number [ verbose ] [ standby slot slot-number ]
acl6-number: Specifies a basic IPv6 ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic IPv6 ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic IPv6 ACL.
standby slot slot-number: Displays backup information permitted by the IPv6 basic ACL on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays information permitted by the IPv6 basic ACL.
If the specified IPv6 ACL does not exist or has no rules configured, the command displays information about all IPv6 routes.
# Display brief information about active routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Summary Count : 3
Destination : ::1/128                                    Protocol  : Direct
Destination : 1:1::/64                                   Protocol  : Static
NextHop     : ::                                         Preference: 60
For command output, see Table 7.
# Display detailed information about all routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary Count : 3
  SubProtID: 0x0                    Age: 08h57m19s
Destination: 1:1::/64
  SubProtID: 0x2                    Age: 08h57m19s
For command output, see Table 8.
display ipv6 routing-table ipv6-address
Use display ipv6 routing-table ipv6-address to display information about routes to an IPv6 destination address.
Use display ipv6 routing-table ipv6-address1 to ipv6-address2 to display information about routes to a range of IPv6 destination addresses.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ] [ standby slot slot-number ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ] [ standby slot slot-number ]
ipv6-address: Specifies a destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
longer-match: Displays the route entry with the longest prefix.
ipv6-address1 to ipv6-address2: Specifies a destination IPv6 address range.
standby slot slot-number: Displays backup information about IPv6 routes on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays information about IPv6 routes.
Executing the command with different parameters yields different output.
·     display ipv6 routing-table ipv6-address
¡     The system ANDs the entered destination IPv6 address with the prefix length in each active route entry.
¡     The system ANDs the destination IPv6 address in each active route entry with the prefix length in the entry.
If the two operations yield the same result for an entry, this entry is displayed.
·     display ipv6 routing-table ipv6-address prefix-length
¡     The system ANDs the entered destination IPv6 address with the entered prefix length.
¡     The system ANDs the destination IPv6 address in each active route entry with the entered prefix length.
If the two operations yield the same result for an entry and the entry has a prefix length less than or equal to the entered prefix length, the entry is displayed.
·     display ipv6 routing-table ipv6-address longer-match
If the two operations yield the same result for multiple entries, the one that has the longest prefix length is displayed.
·     display ipv6 routing-table ipv6-address prefix-length longer-match
If the two operations yield the same result for multiple entries with a prefix length less than or equal to the entered prefix length, the one with the longest prefix length is displayed.
·     display ipv6 routing-table ipv6-address1 to ipv6-address2
The system displays route entries with destinations in the range of ipv6-address1/128 to ipv6-address2/128.
# Display brief information about the routes to the destination IPv6 address 10::1 127.
<Sysname> display ipv6 routing-table 10::1 127
Summary Count: 3
Destination: 10::/64                                     Protocol  : Static
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# Display brief information about the most specific route to the destination IPv6 address 10::1 and prefix length 127.
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary Count : 1
# Display brief information about the routes to destination addresses in the range of 100:: to 300::.
<Sysname> display ipv6 routing-table 100:: to 300::
Summary Count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
display ipv6 routing-table prefix-list
Use display ipv6 routing-table prefix-list to display information about IPv6 routes permitted by an IPv6 prefix list.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ] [ standby slot slot-number ]
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all IPv6 routes permitted by the IPv6 prefix list. If you do not specify this keyword, the command displays brief information about active IPv6 routes permitted by the IPv6 prefix list.
standby slot slot-number: Displays backup information about IPv6 routes permitted by the IPv6 prefix list on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays information about IPv6 routes permitted by the IPv6 prefix list.
If the specified IPv6 prefix list does not exist, the command displays information about all routes.
# Create an IPv6 prefix list named test to permit the prefix ::1/128.
[Sysname] ipv6 prefix-list test permit ::1 128
# Display brief information about the active IPv6 route permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test
Summary Count : 1
# Display detailed information about all routes permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary Count : 1
display ipv6 routing-table protocol
Use display ipv6 routing-table protocol to display information about IPv6 routes installed by a protocol.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] [ standby slot slot-number ]
protocol: Specifies a routing protocol. It can be bgp4+, direct, isisv6, ospfv3, ripng, or static.
standby slot slot-number: Displays backup information about IPv6 routes installed by the protocol on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays information about IPv6 routes installed by the protocol.
<Sysname> display ipv6 routing-table protocol direct
Summary Count : 3
Summary Count : 3
Summary Count : 0
<Sysname> display ipv6 routing-table protocol static
Summary Count : 3
Static Routing table Status : <Active>
Summary Count : 3
Destination: 2::2/128                                    Protocol  : Static
NextHop    : fe80::2                                     Preference: 60
Interface  : Vlan2                                       Cost      : 0
NextHop    : fe80::3                                     Preference: 60
Destination: 3::3/128                                    Protocol  : Static
NextHop    : 2::2                                        Preference: 60
Static Routing table Status : <Inactive>
Summary Count : 0
display ipv6 routing-table statistics
Use display ipv6 routing-table statistics to display IPv6 route statistics.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] statistics [ standby slot slot-number ]
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays route statistics for the public network.
standby slot slot-number: Displays backup IPv6 route statistics on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays IPv6 route statistics.
# Display IPv6 route statistics for the public network.
<Sysname> display ipv6 routing-table statistics
DIRECT     5           5           5           0
STATIC     3           3           3           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
BGP4+      0           0           0           0
Total      8           8           8           0
Table 9 Command output
Proto
route
active
added
deleted
Total
display ipv6 routing-table summary
Use display ipv6 routing-table summary to display brief IPv6 routing table information.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary [ standby slot slot-number ]
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays brief IPv6 routing table information for the public network.
standby slot slot-number: Displays backup of brief IPv6 routing table information on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays brief IPv6 routing table information.
# Display brief IPv6 routing table information.
<Sysname>display ipv6 routing-table summary
Max ECMP: 32
# Display brief IPv6 routing table information for VPN instance vpn1.
<Sysname>display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 32
Table 10 Command output
Max ECMP
Max Active Route
Remain Active Route
display rib attribute
Use display rib attribute to display route attribute information in the RIB.
display rib attribute [ attribute-id ] [ standby slot slot-number ]
standby slot slot-number: Displays backup route attribute information in the RIB on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays route attribute information in the RIB.
# Display route attribute information in the RIB.
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
                  Flag: 0x0
              Protocol: BGP
        Address family: IPv4
       Reference count: 0
      Local preference: 0
Ext-communities number: 26
 Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
                        > <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
                        : 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
                         <RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
                        13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
        AS-path number: 0
         AS-path value: N/A
Detailed information of attribute 0x1:
                  Flag: 0x0
              Protocol: BGP
       Reference count: 0
      Local preference: 0
Ext-communities number: 1
 Ext-communities value: <RT: 1:2>
        AS-path number: 0
         AS-path value: N/A
Table 11 Command output
Protocol
Protocol that generates the attribute.
Number of the extended community attribute values.
Values of the extended community attribute. This field displays N/A when no value exists, and it can display a maximum of 20 values.
Communities number
Number of the COMMUNITY attribute values.
Communities value
Values of the COMMUNITY attribute. This field displays N/A when no value exists, and it can display a maximum of 20 values.
AS-path number
Number of ASs in the AS_PATH attribute.
AS-path value
Values of the AS_PATH attribute, including AS_SET, AS_SEQUENCE, confederation AS_SET, and confederation AS_SEQUENCE. This field displays N/A when no value exists, and it can display a maximum of 20 values.
display rib graceful-restart
Use display rib graceful-restart to display RIB GR state information.
# Display RIB GR state information.
<Sysname> display rib graceful-restart
Protocol GR state:
 1    DIRECT     100      30   End      No/No
 2    STATIC     480      34   End      No/No
 3    OSPF       480      36   End      No/No
 4    ISIS       480      32   End      No/No
 5    BGP        480      31   End      No/No
 6    LDP        480      35   End      No/No
 7    SLSP       480      29   End      No/No
Table 12 Command output
RIB GR state
RIB GR status:
·     Start—GR starts.
·     IGP end—All IGP protocols complete GR.
·     VPN-triggering end—Optimal route selection triggered by VPN routes completes.
·     VPN-calculation end—Optimal VPN route selection completes.
·     Routing protocol end—All routing protocols complete GR.
·     NSR-calculation unfinished—NSR has not finished optimal route selection.
·     Triggering start—All triggered optimal route selection starts.
·     Triggering end—All triggered optimal route selection completes.
·     Phase1-calculation end—Optimal route selection phase 1 completes.
·     All end—All protocols complete GR.
·     Phase2-calculation end—Optimal route selection phase 1 completes.
RCOM GR state
RCOM GR status:
·     Start—GR starts.
·     VPN-notification end—VPN routes have been delivered to the route management module.
·     Notification end—All routes have been delivered to the route management module.
·     Phase2-calculation end—Optimal route selection phase 2 completes.
·     Flush start—Starts to flush routes to the FIB.
·     Flush end—Completes flushing routes to the FIB.
No.
Protocol number.
Lifetime
Lifetime (in seconds) of routes/labels in the RIB during GR.
FD
Handle between the protocol and the RIB.
Protocol GR state:
·     Init—Initialization state.
·     Listen—Listening state.
·     Idle.
·     Active.
·     Start—GR starts.
·     End—GR completes.
Start/End
Message sending state:
·     No—The message has not been sent.
·     Yes—The message has been sent.
display rib nib
Use display rib nib to display next hop information in the RIB.
display rib nib [ self-originated ] [ nib-id ] [ verbose ] [ standby slot slot-number ]
display rib nib protocol protocol-name [ verbose ] [ standby slot slot-number ]
self-originated: Displays information about next hops of self-originated routes in the RIB.
verbose: Displays detailed next hop information in the RIB. If you do not specify this keyword, the command displays brief next hop information in the RIB.
protocol protocol-name: Specifies a protocol by its name, which can be bgp, direct, isis, ospf, rip, or static.
standby slot slot-number: Displays backup next hop information in the RIB on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command displays next hop information in the RIB.
# Display brief next hop information in the RIB.
<Sysname> display rib nib
Total number of nexthop(s): 176
      NibID: 0x10000000        Sequence: 0
   UserKey1: 0x0                Nexthop: 0.0.0.0
    IFIndex: 0x111            LocalAddr: 0.0.0.0
      NibID: 0x10000001        Sequence: 1
   UserKey1: 0x0                Nexthop: 127.0.0.1
    IFIndex: 0x112            LocalAddr: 127.0.0.1
      NibID: 0x10000002        Sequence: 2
       Type: 0x5                Flushed: Yes
      NibID: 0x26000000        Sequence: 42
       Type: 0x2000             Flushed: Yes
   SubNibID: 0x21000023          SubSeq: 35
    NthpCnt: 1                    Samed: 0
   NthpType: IP
   SubNibID: 0x21000003          SubSeq: 36
    NthpCnt: 1                    Samed: 0
   NthpType: IP
   SubNibID: 0x21000004          SubSeq: 37
    NthpCnt: 1                    Samed: 0
   NthpType: IP
   SubNibID: 0x21000005          SubSeq: 38
    NthpCnt: 1                    Samed: 0
   NthpType: IP
Table 13 Command output
NibID
ID of the next hop.
Sequence
Sequence number of the next hop.
Type of the next hop.
Flushed
Indicates whether the route with the next hop has been flushed to the FIB.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
VPN to which the next hop belongs.
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
SubNibID
ID of the sub-next hop.
SubSeq
Sequence number of the sub-next hop.
NthpCnt
Number of sub-next hops.
Samed
Number of the same sub-next hops.
NthpType
Sub-next hop type: IP forwarding.
# Display detailed next hop information in the RIB.
<Sysname> display rib nib verbose
     RefCnt: 6              FlushRefCnt: 2
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 0.0.0.0
  RelyDepth: 0              RealNexthop: 0.0.0.0
  Interface: NULL0            LocalAddr: 0.0.0.0
   TunnelID: N/A
     RefCnt: 13             FlushRefCnt: 5
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 127.0.0.1
  RelyDepth: 0              RealNexthop: 127.0.0.1
  Interface: InLoop0          LocalAddr: 127.0.0.1
   TunnelID: N/A
      NibID: 0x15000003        Sequence: 3
       Type: 0x43               Flushed: Yes
   UserKey0: 0x100010000        VrfNthp: 0
   UserKey1: 0x0                Nexthop: 22.22.22.22
    IFIndex: 0x0              LocalAddr: 0.0.0.0
     RefCnt: 9              FlushRefCnt: 3
     Policy: tnl-policy1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 22.22.22.22
  RelyDepth: 1              RealNexthop: 13.1.1.2
  Interface: GE0/1/3          LocalAddr: 13.1.1.1
  TunnelCnt: 1                      Vrf: default-vrf
   TunnelID: 1025
      NibID: 0x16000000        Sequence: 0
   SubNibID: 0x11000009          SubSeq: 13
    NthpCnt: 1                    Samed: 0
   NthpType: IP
   SubNibID: 0x1100000d          SubSeq: 14
    NthpCnt: 1                    Samed: 0
   NthpType: IP
 2 nexthop(s):
PrefixIndex: 0              OrigNexthop: 10.1.1.2
  RelyDepth: 0              RealNexthop: 10.1.1.2
  Interface: Vlan10           LocalAddr: 10.1.1.1
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A
PrefixIndex: 1              OrigNexthop: 11.1.1.2
  RelyDepth: 0              RealNexthop: 11.1.1.2
  Interface: Vlan11           LocalAddr: 11.1.1.1
   TunnelID: N/A
Table 14 Command output
x nexthop (s)
PrefixIndex
Vrf
VPN name.
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
LocalAddr
RelyDepth
Recursion depth.
TunnelCnt
TunnelID
RefCnt
FlushRefCnt
Flag
Version
display route-direct nib
Use display route-direct nib to display next hop information for direct routes.
verbose: Displays detailed next hop information for direct routes. If you do not specify this keyword, the command displays brief next hop information for direct routes.
# Display brief next hop information for direct routes.
<Sysname> display route-direct nib
Total number of nexthop(s): 116
Table 15 Command output
NibID
ID of the NIB.
Sequence
Type of the NIB.
Flushed
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Nexthop
Next hop address.
IFIndex
Interface index.
# Display detailed next hop information for direct routes.
<Sysname> display route-direct nib verbose
     RefCnt: 2              FlushRefCnt: 0
 1 nexthop(s):
   TunnelID: N/A
     RefCnt: 5              FlushRefCnt: 0
 1 nexthop(s):
   TunnelID: N/A
Table 16 Command output
x nexthop(s)
PrefixIndex
Vrf
VPN name.
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
localAddr
RelyDepth
Recursion depth.
TunnelCnt
TunnelID
RefCnt
FlushRefCnt
Flag
Version
fib lifetime
Use fib lifetime to set the maximum lifetime for IPv4 or IPv6 routes in the FIB.
Use undo fib lifetime to restore the default.
fib lifetime seconds
undo fib lifetime
The maximum lifetime for IPv4 or IPv6 routes in the FIB is 600 seconds.
RIB IPv4 address family view, RIB IPv6 address family view
seconds: Sets the maximum lifetime for routes in the FIB, in the range of 0 to 900 seconds. When this argument is set to 0, FIB entries immediately age out after a protocol or RIB process switchover.
When a protocol or RIB process switchover occurs and GR or NSR is not configured, FIB entries age out after the time specified in this command.
# Set the maximum lifetime for IPv4 routes in the FIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
flush route-attribute
Use flush route-attribute to configure the RIB to flush route attribute information to the FIB.
Use undo flush route-attribute to remove the configuration.
flush route-attribute protocol
undo flush route-attribute protocol
The RIB does not flush route attribute information to the FIB.
protocol: Specifies a protocol. Only BGP is supported.
# Configure the RIB to flush BGP route attribute information to FIB.
[Sysname] rib
[Sysname-rib-ipv4] flush route-attribute bgp
protocol lifetime
Use protocol lifetime to set the maximum lifetime for IPv4 or IPv6 routes and labels in the RIB.
Use undo protocol lifetime to restore the default.
protocol protocol lifetime seconds
undo protocol protocol lifetime
The maximum lifetime for IPv4 or IPv6 routes and labels in the RIB is 480 seconds.
seconds: Sets the maximum lifetime for routes and labels in the RIB, in the range of 0 to 900 seconds. When this argument is set to 0, RIB entries immediately age out when a protocol switchover occurs.
When GR is enabled, make sure the protocol can complete GR and install all route entries to the RIB within the lifetime configured in this command.
# Set the maximum lifetime for OSPF routes and labels in the RIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] protocol ospf lifetime 60
reset ip routing-table statistics protocol
Use reset ip routing-table statistics protocol to clear IPv4 route statistics.
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all } [ standby slot slot-number ]
vpn-instance vpn-instance-name: Clears the IPv4 route statistics for a VPN instance specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command clears IPv4 route statistics for the public network.
protocol: Clears route statistics for a routing protocol. It can be bgp, direct, isis, ospf, rip, or static.
all: Clears route statistics for all IPv4 routing protocols.
standby slot slot-number: Clears backup IPv4 route statistics on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command clears IPv4 route statistics.
# Clear all IPv4 route statistics for the public network.
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics protocol
Use reset ipv6 routing-table statistics protocol to clear IPv6 route statistics.
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all } [ standby slot slot-number ]
vpn-instance vpn-instance-name: Clears route statistics for a VPN instance specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command clears the IPv6 route statistics for the public network.
protocol: Clears route statistics for an IPv6 routing protocol. It can be bgp4+, direct, isisv6, ospfv3, ripng, or static.
all: Clears route statistics for all IPv6 routing protocols.
standby slot slot-number: Clears backup IPv6 route statistics on the specified device. The slot-number argument specifies the IRF member device by its member ID. If you do not specify this option, the command clears IPv6 route statistics.
# Clear all IPv6 route statistics for the public network.
<Sysname> reset ipv6 routing-table statistics protocol all
rib
Use rib to enter RIB view.
Use undo rib to remove all configurations in RIB view.
rib
undo rib
# Enter RIB view.
[Sysname] rib
[Sysname-rib]
