HomeSupportSwitchesH3C S6300 Switch SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10009-Security Configuration Guide
00-Preface
00-Preface 83.82 KB
Preface
This configuration guide describes the security fundamentals and configuration procedures, including:
·           Identity authentication features (such as AAA and PKI).
·           Access security features (such as 802.1X, MAC authentication, portal, and port security).
·           Data security features (such as public key management, IPsec, SSL, SSH, Crypto engine, and FIPS).
·           Attack protection features (such as IP source guard, ARP attack protection, MFF, uRPF, and attack detection and prevention).
·           Audience
·           Conventions
·           Obtaining documentation
·           Technical support
·           Documentation feedback
Audience
·           Network planners.
·           Field technical support and servicing engineers.
·           Network administrators working with the S6300 switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
To access the most up-to-date H3C product documentation, go to the H3C website at
http://www.h3c.com.hk
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
[email protected]
We appreciate your comments.
