08-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series Access Points Command References(R1507P09)-6W10108-Network Management and Monitoring Command Reference
05-Information Center Commands
05-Information Center Commands 149.71 KB
Information center configuration commands
display channel
Use display channel to display channel information.
display channel [ channel-number | channel-name ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
channel-number: Specifies a channel by its number in the range of 0 to 9.
channel-name: Specifies a channel by its name, a default name or a self-defined name. For how to configure a channel name, see info-center channel name.
Table 1 Information channels for different output destinations
Output destination
Information channel number
Default channel name
Console
0
console
Monitor terminal
1
monitor
Log host
2
loghost
Trap buffer
3
trapbuffer
Log buffer
4
logbuffer
SNMP module
5
snmpagent
Web interface
6
channel6
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If no channel is specified, the command displays information about all channels.
# Display information about channel 0.
<Sysname> display channel 0
channel number:0, channel name:console
MODU_ID  NAME     ENABLE LOG_LEVEL        ENABLE TRAP_LEVEL    ENABLE DEBUG_LEVEL
ffff0000 default  Y      informational    Y      debugging     Y      debugging
The output shows that the system is allowed to output log information with a severity from 0 to 4, trap information with a severity from 0 to 7, and debug information with a severity from 0 to 7 to the console. The information source modules are all modules (default).
channel number
Channel number in the range 0 to 9.
channel name
Channel name. For more information, see info-center channel name.
MODU_ID
ID of the source module.
NAME
Name of the source module.
"default" means all modules are allowed to output system information, but the actual modules depend on the device model.
ENABLE
Indicates whether log output is enabled, Y or N.
LOG_LEVEL
Log information severity. See Table 3 for details.
ENABLE
Indicates whether trap output is enabled, Y or N.
TRAP_LEVEL
Trap information severity. See Table 3 for details.
ENABLE
Indicates whether debug output is enabled, Y or N.
DEBUG_LEVEL
Debug information severity. See Table 3 for details.
display info-center
Use display info-center to display information center configuration information.
display info-center [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display information center configuration information.
<Sysname> display info-center
Information Center:enabled
Log host:
    1.1.1.1,
    port number : 514, host facility : local7,
    channel number : 2, channel name : loghost
Console:
    channel number : 0, channel name : console
Monitor:
    channel number : 1, channel name : monitor
SNMP Agent:
    channel number : 5, channel name : snmpagent
Log buffer:
    enabled,max buffer size 1024, current buffer size 512,
    current messages 512, dropped messages 0, overwritten messages 740
    channel number : 4, channel name : logbuffer
Trap buffer:
    enabled,max buffer size 1024, current buffer size 256,
    current messages 216, dropped messages 0, overwritten messages 0
    channel number : 3, channel name : trapbuffer
syslog:
    channel number:6, channel name:channel6
Information timestamp setting:
    log - date, trap - date, debug - date,
    loghost - date
display logbuffer
Use display logbuffer to display the state of the log buffer and the log information in the log buffer. Without size buffersize, the command displays all log information in the log buffer.
display logbuffer [ reverse ] [ level severity | size buffersize ] * [ | { begin | exclude | include } regular-expression ]
1: Monitor level
reverse: Displays log entries chronologically, with the most recent entry at the top. Without this keyword, the command displays log entries chronologically, with the oldest entry at the top.
level severity: Displays log information of at least the specified level in the range of 0 to 7.
Table 3 Severity description
Severity
Value
Corresponding keyword in commands
Emergency
0
The system is unusable.
emergencies
Alert
1
Action must be taken immediately.
alerts
Critical
2
Critical condition.
critical
Error
3
Error condition.
errors
Warning
4
Warning condition.
warnings
Notification
5
Normal but significant condition.
notifications
Informational
6
Informational message.
informational
Debug
7
Debugging message.
debugging
size buffersize: Specifies the number of latest log messages to be displayed, in the range of 1 to 1024.
# Display the state and log information of the log buffer.
<Sysname> display logbuffer
Logging buffer configuration and contents:enabled
Allowed max buffer size : 1024
Actual buffer size : 512
Channel number : 4 , Channel name : logbuffer
Dropped messages : 0
Overwritten messages : 718
Current messages : 512
%Jun 17 15:57:09:578 2006 Sysname IC/7/SYS_RESTART:
System restarted –
State of the log buffer, enabled or disabled.
Maximum number of messages that can be stored in the log buffer.
Actual buffer size
Actual buffer size.
Channel number
Channel number of the log buffer. The default channel number is 4.
Channel name
Channel name of the log buffer. The default channel name is logbuffer.
Dropped messages
Number of dropped messages.
Number of overwritten messages (when the buffer size is not big enough to hold all messages, the latest messages overwrite the old ones).
Current messages
Number of current messages.
display logbuffer summary
Use display logbuffer summary to display the summary of the log buffer.
display logbuffer summary [ level severity ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
level severity: Specifies a severity level in the range of 0 to 7.
# Display the summary of the log buffer.
<Sysname> display logbuffer summary
EMERG ALERT  CRIT ERROR  WARN NOTIF  INFO DEBUG
    0     0     0     0    22     0     1     0
Table 5 Command output
EMERG
Represents emergency. See Table 3 for details.
ALERT
Represents alert. See Table 3 for details.
CRIT
Represents critical. See Table 3 for details.
ERROR
Represents error. See Table 3 for details.
WARN
Represents warning. See Table 3 for details.
NOTIF
Represents notice. See Table 3 for details.
INFO
Represents informational. See Table 3 for details.
DEBUG
Represents debug. See Table 3 for details.
display trapbuffer
Use display trapbuffer to display the state and the trap information of the trap buffer. Without the size buffersize argument, the command displays all trap information.
display trapbuffer [ reverse ] [ size buffersize ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
reverse: Displays trap entries chronologically, with the most recent entry at the top. Without this keyword, the command displays trap entries chronologically, with the oldest entry at the top.
size buffersize: Specifies the number of latest trap messages to be displayed, in the range of 1 to 1024.
# Display the state and trap information of the trap buffer. (The actual command output depends on the operations executed on the device.)
<Sysname> display trapbuffer
Trapping buffer configuration and contents:enabled
Actual buffer size : 256
Channel number : 3 , channel name : trapbuffer
Overwritten messages : 0
Current messages : 9
#Aug  7 08:03:27:421 2009 Sysname IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983041 is Up, ifAdminStatus is 1, ifOperStatus is 1
#Aug  7 08:03:27:439 2009 Sysname IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983048 is Up, ifAdminStatus is 1, ifOperStatus is 1
 Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983056 is Up, ifAdminStatus is 1, ifOperStatus is 1
#Aug  7 08:03:27:465 2009 Sysname IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 3277798 is Up, ifAdminStatus is 1, ifOperStatus is 1
#Aug  7 08:05:32:425 2009 Sysname IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.3<linkDown>: Interface 983048 is Down, ifAdminStatus is 1, ifOperStatus is 2
#Aug  7 08:39:53:302 2009 Sysname SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.2011.10.2.2.1.1.3.0.1<h3cLogIn>: login from VTY
#Aug  7 08:43:25:583 2009 Sysname CFGMAN/4/TRAP:
          1.3.6.1.4.1.2011.10.2.4.2.1<h3cCfgManEventlog> configure changed:
          EventIndex=1,CommandSource=2,ConfigSource=4,ConfigDestination=2
Table 6 Command output
State of the trap buffer, enabled or disabled.
Maximum capacity of the trap buffer.
Actual buffer size
Actual capacity of the trap buffer.
Channel number
Channel number of the trap buffer, which defaults to 3.
channel name
Channel name of the trap buffer, which defaults to trapbuffer.
Dropped messages
Current messages
enable log updown
Use enable log updown to allow a port to generate link up/down logs when the port state changes.
Use undo enable log updown to disable a port from generating link up/down logs when the  port state changes.
enable log updown
All the ports are allowed to generate port link up/down logs when the port state changes.
Interface view
2: System level
# Disable port GigabitEthernet 1/0/1 from generating link up/down logs.
[Sysname-GigabitEthernet1/0/1] undo enable log updown
Use info-center channel name to name a channel.
Use undo info-center channel to command to restore the default name for a channel.
info-center channel channel-number name channel-name
undo info-center channel channel-number
See Table 1 for information about default channel names and channel numbers.
2: System level
channel-name: Specifies a name for the channel, a case-insensitive string of 1 to 30 characters. It must be a combination of letters and numbers and start with a letter.
# Name channel 0 as abc.
[Sysname] info-center channel 0 name abc
info-center console channel
Use info-center console channel to specify the console output channel. The system uses this channel to output information to the console.
Use undo info-center console channel to restore the default console output channel.
info-center console channel { channel-number | channel-name }
The console output channel is channel 0.
2: System level
The info-center console channel command takes effect only when the information center has been enabled with the info-center enable command.
# Specify the console output channel as channel 0.
[Sysname] info-center console channel 0
info-center enable
Use info-center enable to enable the information center.
Use undo info-center enable to disable the information center.
info-center enable
The information center is enabled.
2: System level
The device can output system information only after the information center is enabled.
# Enable the information center.
[Sysname] info-center enable
Info: Information center is enabled.
info-center format unicom
Use info-center format unicom to set the UNICOM format for system information sent to a log host.
Use undo info-center format to restore the default.
The format for the system information sent to a log host is H3C.
2: System level
System information sent to a log host has two formats: H3C and UNICOM. For more information, see Network Management and Monitoring Configuration Guide.
# Set the UNICOM format for system information sent to a log host.
[Sysname] info-center format unicom
info-center logbuffer
Use info-center logbuffer to configure information output to the log buffer.
Use undo info-center logbuffer to disable information output to the log buffer.
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ] *
undo info-center logbuffer [ channel | size ]
The system outputs information to the log buffer through channel 4 (logbuffer) and the default buffer size is 512.
2: System level
buffersize: Specifies the maximum number of log messages that can be stored in the log buffer. The value range is 0 to 1024.
The info-center logbuffer command takes effect only after the information center has been enabled with the info-center enable command.
# Output system information to the log buffer through channel 4, and set the log buffer size to 50.
[Sysname] info-center logbuffer size 50
info-center loghost
Use info-center loghost to specify a log host and configure output parameters.
Use undo info-center loghost to restore the default.
info-center loghost host-ipv4-address [ port port-number ] [ channel { channel-number | channel-name } | facility local-number ] *
undo info-center loghost host-ipv4-address
No log host is specified.
2: System level
host-ipv4-address: Specifies the IPv4 address of a log host.
port port-number: Specifies the port number of the log host, in the range of 1 to 65535. The default value is 514. It must be the same as the value configured on the log host. Otherwise, the log host cannot receive system information.
channel: Specifies the channel through which system information is output to the log host.
facility local-number: Specifies a logging facility from local0 to local7 for the log host. The default value is local7. Logging facilities are used to mark different logging sources, and query and filer logs.
If you configure this command without specifying a channel, the system specifies channel 2 (loghost) by default.
The info-center loghost command takes effect only after the information center has been enabled with the info-center enable command.
Enter a correct log host IP address. The system prompts an invalid address if an incorrect IP address, such as an IPv6 loopback address or a broadcast address, is entered.
The device supports up to four log hosts.
# Output log information to the log host 1.1.1.1.
[Sysname] info-center loghost 1.1.1.1
info-center loghost source
Use info-center loghost source to specify the source IP address for log information sent to a log host.
Use undo info-center loghost source to restore the default.
The source IP address of log information sent to a log host is the primary IP address of the matching route's egress interface.
2: System level
interface-type interface-number: Specifies the egress interface for log information by the interface type and interface number.
The system uses the primary IP address of the specified egress interface as the source IP address of log information no matter which physical interface is used to output the log information. If you want to display the source IP address in the log information, you can configure it by using this command.
The info-center loghost source command takes effect only when the information center has been enabled with the info-center enable command.
The IP address of the specified egress interface must have been configured. Otherwise, although the info-center loghost source command can be configured successfully, the log host cannot receive any log information.
When no source IP address is specified for log information, log in to the FTP server by using the username ftp. The following log information is displayed on the log host:
<189>May 31 05:37:52 2003 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully.
# Specify the IP address of the VLAN interface as the source IP address of log information.
[Sysname] vlan 100
[Sysname-vlan100] interface vlan-interface 100
[Sysname-Vlan-interface100] ip address 2.2.2.2 24
[Sysname-Vlan-interface100] quit
[Sysname] info-center loghost source Vlan-interface 100
After the above configuration, log in to the FTP server by using the username ftp. The following log information is displayed on the log host (the -DevIP=2.2.2.2 field identifies the source IP address):
<189>May 31 05:38:14 2003 Sysname %%10FTPD/5/FTPD_LOGIN(l): -DevIP=2.2.2.2; User ftp (192.168.1.23) has logged in successfully.
info-center monitor channel
Use info-center monitor channel to configure the monitor output channel. The system uses this channel to output information to the monitor.
Use undo info-center monitor channel to restore the default monitor output channel.
info-center monitor channel { channel-number | channel-name }
The system outputs information to the monitor through channel 1.
2: System level
The info-center monitor channel command takes effect only after the information center enabled with the info-center enable command.
# Output system information to the monitor through channel 0.
[Sysname] info-center monitor channel 0
info-center snmp channel
Use info-center snmp channel to configure the SNMP output channel. The system uses this channel to output information to the SNMP module.
Use undo info-center snmp channel to restore the default SNMP output channel.
info-center snmp channel { channel-number | channel-name }
The system outputs information to the SNMP module through channel 5 (snmpagent).
2: System level
channel-number: Specifies a channel by its number, in the range of 0 to 9.
channel-name: Specifies a channel by its name, a default name or a self-defined name. For how to configure a channel name, see the info-center channel name command.
# Output system information to the SNMP module through channel 6.
[Sysname] info-center snmp channel 6
display snmp-agent
info-center source
Use info-center source to configure an information output rule for a module.
Use undo info-center source to remove the specified output rule.
info-center source { module-name | default } channel { channel-number | channel-name } [ debug { level severity | state state } * | log { level severity | state state } * | trap { level severity | state state } * ] *
undo info-center source { module-name | default } channel { channel-number | channel-name }
The default output rules are listed in Table 7.
2: System level
module-name: Specifies a module. For instance, to output ARP information, specify this argument as ARP. You can use the info-center source ? command to view the modules supported by the device.
default: Specifies all the modules, which can be displayed by using the info-center source ? command.
debug: Specifies debug information.
log: Specifies log information.
trap: Specifies trap information.
level severity: Specifies a severity level. For more information, see Table 3.
state state: Specifies whether to output the specified system information, on (enabled) or off (disabled).
This command sets an output rule for a specified module or all modules. For example, you can output IP log information with a severity higher than warning to the log host, and output IP log information with a severity higher than informational to the log buffer.
If you do not set an output rule for a module, the module uses the default output rule or the output rule set by using the default keyword.
If you use the default keyword to set an output rule for all the modules without specifying the debug, log, and trap keywords, the default output rules for the modules are used. See Table 7 for more information about default output rules.
If you use the module-name argument to set the output rule for a module without specifying the debug, log, and trap keywords, the default settings for the module are as follows: the output of log and trap information is enabled, with severity being informational. The output of debug information is disabled, with severity being debug. For example, if you execute the command info-center source snmp channel 5, the command is actually equal to the command info-center source snmp channel 5 debug level debugging state off log level informational state on trap level informational state on.
If you use the command multiple times, only the most recent output rule takes effect for the specified module.
After you set an output rule for a module, you must use the module-name argument to modify or remove the rule. A new output rule configured by using the default keyword does not take effect for the module.
The trap buffer only receives trap information and discards log and debug information.
The log buffer only receives log and debug information and discards trap information.
The SNMP module only receives trap information and discards log and debug information.
Table 7 Default output rules
Output destination
Source modules
Log
Trap
Debug
Enabled/disabled
Severity
Enabled/disabled
Severity
Enabled/disabled
Severity
Console
All supported modules
Enabled
Informational
Enabled
Debug
Enabled
Debug
Monitor terminal
Enabled
Informational
Enabled
Debug
Enabled
Debug
Log host
Enabled
Informational
Enabled
Debug
Disabled
Debug
Trap buffer
Disabled
Informational
Enabled
Informational
Disabled
Debug
Log buffer
Enabled
Informational
Disabled
Debug
Disabled
Debug
SNMP module
Disabled
Debug
Enabled
Informational
Disabled
Debug
# Output VLAN module's trap information with a severity level of at least emergency to the channel console. All other system information cannot be output to this channel.
[Sysname] info-center source default channel console debug state off log state off trap state off
[Sysname] info-center source vlan channel console trap level emergencies state on
info-center synchronous
Use info-center synchronous to enable synchronous information output.
Use undo info-center synchronous to disable synchronous information output.
Synchronous information output is disabled.
2: System level
If system information is output before you enter information at a command line prompt, the system does not display the command line prompt after the system information output.
If system information is output when you are entering some interactive information (non Y/N confirmation information), the system displays your input in a new line after the system information output.
# Enable synchronous information output, and then execute the display current-configuration command to view the current configuration of the device.
[Sysname] info-center synchronous
% Info-center synchronous output is on
[Sysname] display current-
At this time, the system receives log information. It displays the log information first, and then displays your previous input, which is display current- in this example.
%May 21 14:33:19:425 2007 Sysname SHELL/4/LOGIN: VTY login from 192.168.1.44
Enter configuration to complete the display current-configuration command, and press the Enter key to execute the command.
# Enable synchronous information output, and then save the current configuration (enter interactive information).
[Sysname] save
The current configuration will be written to the device. Are you sure? [Y/N]:
At this time, the system receives the log information. It displays the log information first and then displays [Y/N].
[Y/N]:
Enter Y or N to complete your input.
info-center syslog channel
Use info-center syslog channel to configure the Web output channel. The system uses this channel to output information to the Web interface.
Use undo info-center syslog channel to restore the default.
info-center syslog channel { channel-number | channel-name }
The default Web output channel is channel 6.
2: System level
# Output system information to the Web interface through channel 7.
[Sysname] info-center syslog channel 7
info-center timestamp
Use info-center timestamp to configure the timestamp format for system information sent to all destinations except the log host.
Use undo info-center timestamp to restore the default.
info-center timestamp { debugging | log | trap } { boot | date | none }
undo info-center timestamp { debugging | log | trap }
The timestamp format for system information is date.
2: System level
debugging: Sets the timestamp format for debug information.
log: Sets the timestamp format for log information.
trap: Sets the timestamp format for trap information.
boot: Sets the timestamp format as xxxxxx.yyyyyy, where xxxxxx is the most significant 32 bits (in milliseconds) and yyyyyy is the least significant 32 bits. For example, 0.21990989 equals Jun 25 14:09:26:881 2007. The boot time shows the time since system startup.
date: Sets the timestamp format as "Mmm dd hh:mm:ss:sss yyyy", such as Dec  8 10:12:21:708 2007. The date time shows the current system time.
·          Mmm: Abbreviations of the months in English, which could be Jan, Feb, Mar, Apr, May, Jun, Jul, Aug, Sep, Oct, Nov, or Dec.
·          dd: Date, starting with a space if it is less than 10, for example " 7".
·          hh:mm:ss:sss: Local time, with hh ranging from 00 to 23, mm and ss ranging from 00 to 59, and sss ranging from 0 to 999.
·          yyyy: Year.
none: Indicates no time information is provided.
# Configure the timestamp format for log information as boot.
[Sysname] info-center timestamp log boot
At this time, if you log in to the FTP server by using the username ftp, the log information generated is as follows:
%0.109391473 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
# Configure the timestamp format for log information as date.
[Sysname] info-center timestamp log date
%May 30 05:36:29:579 2003 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
# Configure the timestamp format for log information as none.
[Sysname] info-center timestamp log none
% Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
info-center timestamp loghost
Use info-center timestamp loghost to configure the timestamp format for system information sent to the log host.
Use undo info-center timestamp loghost to restore the default.
info-center timestamp loghost { date | iso | no-year-date | none }
The timestamp format for system information sent to the log host is date.
2: System level
date: Sets the timestamp format as "Mmm dd hh:mm:ss:ms yyyy", such as Dec  8 10:12:21:708 2007. The date time shows the current system time. The actual format depends on the log host.
iso: Sets the ISO 8601 timestamp format. For example, 2009-09-21T15:32:55.
no-year-date: Sets the timestamp format as the current system date and time without year.
none: Indicates that no timestamp information is provided.
# Configure the timestamp format for system information sent to the log host as no-year-date.
[Sysname] info-center timestamp loghost no-year-date
info-center trapbuffer
Use info-center trapbuffer to configure information output to the trap buffer.
Use undo info-center trapbuffer to disable information output to the trap buffer.
info-center trapbuffer [ channel { channel-number | channel-name } | size buffersize ] *
undo info-center trapbuffer [ channel | size ]
The system outputs information to the trap buffer through channel 3 (trapbuffer), and the maximum buffer size is 256.
2: System level
size buffersize: Specifies the maximum number of trap messages allowed in the trap buffer, in the range of 0 to 1024. The default value is 256.
The info-center trapbuffer command takes effect only after the information center has been enabled with the info-center enable command.
# Output system information to the trap buffer through the default channel, and set the trap buffer size to 30.
[Sysname] info-center trapbuffer size 30
reset logbuffer
Use reset logbuffer to clear the log buffer.
reset logbuffer
3: Manage level
# Clear the log buffer.
<Sysname> reset logbuffer
reset trapbuffer
Use reset trapbuffer to clear the trap buffer.
reset trapbuffer
3: Manage level
# Clear the trap buffer.
<Sysname> reset trapbuffer
terminal debugging
Use terminal debugging to enable the display of debug information on the current terminal.
Use undo terminal debugging to disable the display of debug information on the current terminal.
terminal debugging
The display of debug information is disabled both on the console and the current terminal.
1: Monitor level
To view debug information, execute the terminal monitor and terminal debugging commands, enable the information center (enabled by default), and use a debugging command to enable the related debugging.
The configuration of this command is only valid for the current connection between the terminal and the device. If a new connection is established, the default is restored.
# Enable the display of debug information on the current terminal.
<Sysname> terminal debugging
Info: Current terminal debugging is on.
terminal logging
Use terminal logging to enable the display of log information on the current terminal.
Use undo terminal logging to disable the display of log information on the current terminal.
terminal logging
The display of log information is enabled both on the console and the current terminal.
1: Monitor level
To view log information, execute the terminal monitor and terminal logging commands, and then enable the information center (enabled by default).
# Disable the display of log information on the current terminal.
<Sysname> undo terminal logging
Info: Current terminal logging is off.
terminal monitor
Use terminal monitor to enable the monitoring of system information on the current terminal.
Use undo terminal monitor to disable the monitoring of system information on the current terminal.
terminal monitor
Monitoring of system information is enabled on the console and disabled on the monitor terminal.
1: Monitor level
Configure the terminal monitor command before you can display the log, trap, and debug information.
The undo terminal monitor command automatically disables the monitoring of log, trap, and debug information.
# Enable the monitoring of system information on the current terminal.
<Sysname> terminal monitor
Info: Current terminal monitor is on.
terminal trapping
Use terminal trapping to enable the display of trap information on the current terminal.
Use undo terminal trapping to disable the display of trap information on the current terminal.
terminal trapping
The display of trap information is enabled both on the console and the current terminal.
1: Monitor level
To view the trap information, execute the terminal monitor and terminal trapping commands, and then enable the information center (enabled by default).
# Enable the display of trap information on the current terminal.
<Sysname> terminal trapping
Info: Current terminal trapping is on.
