04-Layer 2—LAN Switching Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR810 2600 3600 Routers Configuration Guides(V7)-R0707-6W30104-Layer 2—LAN Switching Configuration Guide
09-Layer 2 forwarding configuration
09-Layer 2 forwarding configuration 48.46 KB
Configuring normal Layer 2 forwarding
About normal Layer 2 forwarding
When an incoming frame's destination MAC address does not match any Layer 3 interface's MAC address, normal Layer 2 forwarding forwards the frame through a Layer 2 interface.
The device uses the destination MAC address of the frame to look for a match in the MAC address table.
·     The device forwards the frame out of the outgoing interface in the matching entry if a match is found.
·     The device floods the frame to all interfaces in the VLAN of the frame if no match is found.
Normal Layer 2 forwarding is enabled by default.
Restrictions: Hardware compatibility with Layer 2 forwarding
This feature is supported only on the following ports:
Hardware
Layer 2 forwarding and port compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA
Fixed Layer 2 Ethernet ports.
MSR2600-6-X1, MSR2600-10-X1
MSR3600-28, MSR3600-51, MSR3600-28-SI, MSR3600-51-SI
MSR3610-I-DP, MSR3610-IE-DP
Routers installed with an Ethernet switching module
Layer 2 Ethernet ports on Ethernet switching modules.
For more information about the support of the routers for Ethernet switching modules, see H3C MSR Router Series Comware 7 Interface Module Guide.
On Layer 2 Ethernet switching modules of MSR devices that are operating in IRF mode, Layer 2 forwarding across member devices is not supported. On SIC Layer 2 Ethernet switching modules, Layer 2 forwarding across member devices and slots is not supported.
Layer 2 forwarding across slots that reside on the same device is supported if multiple HMIM-24GSW, HMIM-24GSWP, HMIM-8GSW, or HMIM-8GSWF Layer 2 Ethernet switching modules are installed on the following devices:
·     MSR3640.
·     MSR3660.
Layer 2 forwarding across slots that reside on the same device is not supported on MSR3620-DP devices that are installed with multiple HMIM-8GSW or HMIM-8GSWF Layer 2 Ethernet switching modules.
Display and maintenance commands for Layer 2 forwarding
Display Layer 2 forwarding statistics.
display mac-forwarding statistics [ interface interface-type interface-number ]
Clear Layer 2 forwarding statistics.
reset mac-forwarding statistics
Configuring fast Layer 2 forwarding
About fast Layer 2 forwarding
Fast Layer 2 forwarding improves packet forwarding efficiency by using a high-speed cache and flow-based technology. It identifies a flow by using the following items:
·     Source IP address.
·     Source port number.
·     Destination IP address.
·     Destination port number.
·     Protocol number.
·     Input interface.
·     Output interface.
·     VLAN ID.
Fast Layer 2 forwarding creates an entry in a high-speed cache by obtaining the forwarding information of a flow's first packet. Subsequent packets of the flow are forwarded based on the entry.
Fast Layer 2 forwarding is enabled by default.
Restrictions: Hardware compatibility with fast Layer 2 forwarding
Hardware
Fast Layer 2 forwarding and port compatibility
·     MSR3640.
·     MSR3660.
Display and maintenance commands for fast Layer 2 forwarding
Display IPv4 fast forwarding entries.
In standalone mode:
display mac-forwarding cache ip [ ip-address ]
In IRF mode:
display mac-forwarding cache ip [ ip-address ] [ slot slot-number ]
Display IPv4 fast forwarding entries for fragments.
In standalone mode:
display mac-forwarding cache ip fragment [ ip-address ]
In IRF mode:
display mac-forwarding cache ip fragment [ ip-address ] [ slot slot-number ]
Display IPv6 fast forwarding entries.
In standalone mode:
display mac-forwarding cache ipv6 [ ipv6-address ]
In IRF mode:
display mac-forwarding cache ipv6 [ ipv6-address ] [ slot slot-number ]
