06-Terminal Access Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR810 2600 3600 Routers Command References(V7)-R0707-6W30106-Terminal Access Command Reference
02-RTC terminal access commands
02-RTC terminal access commands 132.83 KB
The following compatibility matrix shows the support of hardware platforms for RTC terminal access:
Hardware
RTC terminal access compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA
No
MSR810-LMS, MSR810-LUS
No
MSR2600-6-X1, MSR2600-10-X1
No
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
Yes
MSR3610-I-DP, MSR3610-IE-DP
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
auto-close
Use auto-close to set the automatic link teardown time.
Use undo auto-close to restore the default.
auto-close time
undo auto-close
The automatic link teardown time is 0, which indicates that automatic link teardown is disabled.
Terminal template view
time: Specifies the automatic link teardown time in the range of 5 to 240 seconds.
Automatic link teardown for a terminal is enabled after you specify an automatic link teardown time in the terminal template view. Then, when the terminal and the initiator are disconnected from each other for the specified teardown time, the initiator automatically tears down the TCP connection to the receiver. The TCP connection always remains active if automatic link teardown is disabled.
# Set the automatic link teardown time to 10 seconds.
[Sysname] rta template abc
[Sysname-rta-template-abc] auto-close 10
auto-link
auto-link
Use auto-link to enable automatic link establishment and set the automatic link establishment time.
Use undo auto-link to restore the default.
auto-link time
undo auto-link
The automatic link establishment time is 0. The value of 0 indicates that automatic link establishment is disabled and a link needs to be established manually.
time: Specifies the automatic link establishment time in the range of 5 to 240 seconds.
Automatic link establishment for a terminal is enabled after you specify an automatic link establishment time in the terminal template view. Then, when the terminal is in Up state for the specified link establishment time, the initiator automatically establishes a TCP connection to the receiver. If automatic link establishment is disabled, a link needs to be established manually. The initiator establishes a TCP connection to the receiver only after you enter a character on the terminal. The characters cannot be hotkeys or the special characters that terminals can process directly, such as Shift+F2.
# Set the automatic link establishment time to 10 seconds.
[Sysname-rta-template-abc] auto-link 10
auto-close
bind vpn-instance
Use bind vpn-instance to bind a VPN instance to a terminal template.
Use undo bind vpn-instance to restore the default.
bind vpn-instance vpn-instance-name
No VPN instance is bound to a terminal template.
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
When the RTC client is also acting as an MPLS PE router, you can configure this command on the RTC client to identify terminals in VPN instances. To bind a terminal to a VPN instance:
·     Create a terminal template.
·     Bind the terminal template to the VPN instance.
·     Apply the terminal template to the asynchronous serial interface connected to the terminal.
If you do not configure this command on the RTC server, the RTC server receives connection requests from any VPN instances.
You can bind only one VPN instance to each terminal template. If you execute this command for a terminal template multiple times, the most recent configuration takes effect.
# Bind VPN instance vpn1 to terminal template abc.
[Sysname-rta-template-abc] bind vpn-instance vpn1
display rta
Use display rta to display terminal access information.
display rta { all | statistics | terminal-number { vty-number | brief | detail | statistics } }
all: Displays information about all terminals.
statistics: Displays statistics for terminals.
terminal-number: Specifies a terminal by its number, in the range of 1 to 255.
vty-number: Specifies a VTY by its number, in the range of 0 to 7.
brief: Displays brief information about the specified terminal.
detail: Displays detailed information about the specified terminal.
# Display information about VTY 1 of terminal 1.
<Sysname> display rta 1 1
VTY 1
    APP index: 0
    APP type: RTC Client
    APP state: Unlinked
    Remote IP: 192.168.0.110
    Source IP: Not configured
    Actual source IP: --
    Remote port: 9010
    Local port: Not configured
    Connection duration: 00:00:00
APP Index
Application index.
APP Type
Application type: RTC client or RTC server.
APP State
Application state:
·     Unlinked—Application is not connected.
·     Linking—Application is being connected. This state is available only for a TCP RTC client.
·     Linked—Application is connected.
If a template has no applications, this field displays two hyphens (--).
Remote IP
IP address of the peer access device.
Source IP
Source IP address that is configured for the VTY in terminal template view.
Actual Source IP
Actual source IP address that is used for establishing a connection.
If the connection is not established, this field displays two hyphens (--).
Remote Port
Listening port number of the peer access device.
Local Port
Listening port number of the local access device.
Connection duration
Time since the application was connected, in the format hh:mm:ss.
# Display brief information about terminal 1.
<Sysname> display rta 1 brief
TTY 1
    Interface used         :  Async2/2/0
    Current state          :  Up
    Current APP            :  0
    APP type               :  RTC client
    APP name               :  Not configured
    APP state              :  Unlinked
    Socket recvBuf Size    :  2048 bytes
    Socket sendBuf Size    :  2048 bytes
    TTY auto-link          :  10 seconds
    TTY close-link         :  10 seconds
    TTY receive bytes      :  1371 bytes
    TTY send bytes         :  63696 bytes
    Last receive time      :  19:39:33
    Last send time         :  03:39:34
    Current APP receive    :  55280 bytes
    Current APP send       :  1524 bytes
    Time from APP is linked: 00:00:00
    VTY       APP       Type       State
    0         0         RTC client Unlinked
TTY 1
TTY terminal whose terminal number is 1.
Interface used
Physical interface corresponding to the terminal number.
Current state
Current terminal state:
·     Down—The physical connection is down.
·     Up—The physical connection is up.
Current APP
Current application.
APP type
Application type.
APP name
Application name.
APP state
Application state.
Socket recvbuf size
TCP receive buffer size.
Socket sendbuf size
TCP send buffer size.
TTY auto-link
Automatic link establishment time.
TTY close-link
Automatic link teardown time.
TTY receive bytes
Data in bytes that is received.
TTY send bytes
Data in bytes that is sent.
Last receive time
Time when last data was received.
Last send time
Time when last data was sent.
Current APP receive
Data in bytes received by the current application.
Current APP send
Data in bytes sent by the current application.
Time since the application was connected.
VTY APP Type State
VTY list configured on the terminal:
·     VTY—VTY number.
·     APP—Application.
·     Type—Application type.
·     State—Application state.
# Display statistics about terminal 1.
<Sysname> display rta 1 statistics
TTY 1
  Received from terminal: 1231
  Send to terminal:       348
  Received from remote:   8342
  Send to remote:         7342
  VTY 0
    Receive from terminal: 1231            Last receive time: 03:08:29
    Send to terminal:      348             Last send time:    01:10:30
    Receive from remote:   8342            Last receive time: 17:21:25
    Send to remote:        7342            Last send time:    09:44:43
Data in bytes received from the terminal.
Send to terminal
Data in bytes sent to the terminal.
Receive from remote
Data in bytes received from the remote terminal.
Send to remote
Data in bytes sent to the remote terminal.
Last receive time
Time when last data was received, in the format hh:mm:ss.
If no data was received, this field displays two hyphens (--).
Last send time
Time when last data was sent, in the format hh:mm:ss.
If no data was sent, this field displays two hyphens (--).
# Display all terminal access information.
<Sysname> display rta all
TTYID    TTY State     Current APP    APP Type    APP State
1        Up            0              RTC client  Unlinked
TTYID
Terminal number.
TTY State
Terminal state.
Current APP
APP Type
Application type.
APP State
Application state.
# Display terminal access statistics.
<Sysname> display rta statistics
    RTA template number: 2
    RTA TTY number: 1
    RTA APP number: 1
    RTA listen port number: 0
Table 5 Command output
RTA template number
Number of terminal templates configured on the router.
RTA TTY number
Number of terminals configured on the router.
RTA APP number
Number of applications generated after terminal configuration.
Number of listening ports on the router.
display rta relay statistics
display rta relay status
Use display rta relay statistics to display the forwarding statistics of a relay server.
A relay server calculates the bytes and packets that are received from and sent to RTC clients.
# Display the forwarding statistics of a relay server.
<Sysname> display rta relay statistics
Server   Port    Client-IP    Recv-Packets Recv-Bytes Sent-Packets Sent-Bytes
0        1026    1.1.1.2      15           190        30           370
0        1026    1.1.1.3      15           110        35           421
1        1027    1.1.1.4      0            0          0            0
Table 6 Command output
Server
Forwarding group ID.
Port
TCP listening port of the forwarding group.
Client-IP
IP address of a client.
recv-packets
Number of packets received from a client.
recv-bytes
Bytes received from a client.
sent-packets
Number of packets sent to a client.
sent-bytes
Bytes sent to a client.
display rta
Use display rta relay status to display states of all RTC client connections accepted by a relay server.
A relay server can accept a maximum of 10 client connections in each forwarding group. A forwarding group is identified by a port number.
# Display states of all RTC client connections accepted by a relay server.
<Sysname> display rta relay status
Server-ID   Port   Client-ID    Client-IP        State
0           1026   0            1.1.1.2          Linked
0           1026   1            1.1.1.3          Linked
1           1027   0            1.1.1.4          Linking
1           1027   2            1.1.1.6          Linked
Table 7 Command output
Server-ID
Port
TCP listening port for a forwarding group.
Client-ID
Client identifier in a forwarding group.
Client-IP
Client IP address.
Client negotiation status:
·     Linking—The client has not sent the negotiation field.
·     Linked—The client has completed the negotiation process.
display rta
driverbuf save
Use driverbuf save to configure a router not to clear the terminal receive buffer after a TCP connection is established.
Use undo driverbuf save to restore the default.
driverbuf save
undo driverbuf save
The router clears the terminal receive buffer after a TCP connection is established.
The terminal receive buffer is used by a router to store data exchanged with terminals.
# Configure the router not to clear the terminal receive buffer after a TCP connection is established.
[Sysname-rta-template-abc] driverbuf save
driverbuf size
driverbuf size
Use driverbuf size to configure the size of the terminal receive buffer.
Use undo driverbuf size to restore the default.
driverbuf size size
undo driverbuf size
The size of the terminal receive buffer is 8 KB.
size: Specifies the receive buffer size in the range of 8 to 32 KB.
If the terminal template has been applied to an interface, this command takes effect only after the terminal template is re-applied to the interface.
# Set the receive buffer size to 8 KB.
[Sysname-rta-template-abc] driverbuf size 8
drivebuf save
idle-timeout
Use idle-timeout to set the TCP connection idle timeout time for RTC terminal access.
Use undo idle-timeout to restore the default.
idle-timeout seconds
undo idle-timeout
The TCP connection never times out.
seconds: Specifies the connection idle timeout time in the range of 10 to 3600 seconds.
A TCP connection is automatically torn down when the following conditions are met:
·     A TCP connection idle timeout time is set.
·     No data is transmitted over the TCP connection during the specified idle timeout time.
# Set the terminal access idle timeout time to 1000 seconds.
[Sysname-rta-template-abc] idle-timeout 1000
link-protocol stlp
Use link-protocol stlp to enable STLP encapsulation on an interface.
Use Undo link-protocol stlp to restore the default.
link-protocol stlp
undo link-protocol stlp
PPP encapsulation is enabled on all interfaces except Ethernet and VLAN interfaces.
Interface view
Secure Transport Layer Protocol (STLP) is a data link layer protocol. STLP is used for synchronous transparent transmission over remote terminal connections.
# Enable STLP encapsulation on synchronous serial interface Serial 2/1/0.
[Sysname] interface serial 2/1/0
[Sysname-Serial2/1/0] link-protocol stlp
reset rta connection
Use reset rta connection to forcibly tear down the TCP connection corresponding to a VTY of a terminal.
reset rta connection terminal-number vty-number
terminal-number: Specifies a terminal number in the range of 1 to 255.
vty-number: Specifies a VTY number in the range of 0 to 7.
# Tear down the TCP connection corresponding to VTY 1 of terminal 1.
<Sysname> reset rta connection 1 1
reset rta relay statistics
reset rta statistics
Use reset rta relay statistics to clear packet statistics for all clients connected to a relay server.
# Clear packet statistics for all clients on the relay server.
<Sysname> reset rta relay statistics
Use reset rta statistics to clear statistics for a terminal.
reset rta statistics terminal-number
# Clear all statistics for terminal 1.
<Sysname> reset rta statistics 1
resetkey
Use resetkey to configure the terminal reset hotkey.
Use undo resetkey to restore the default.
resetkey ascii-code&<1-3>
undo resetkey
No terminal reset hotkey is configured.
ascii-code&<1-3>: Specifies the ASCII value of the terminal reset hotkey, in the range of 1 to 255. The &<1-3> means that you can enter a maximum of three ASCII values.
When a terminal fault occurs, you can press the terminal reset hotkey on the terminal. The RTC client tears down and then re-establishes the TCP connection with the RTC server.
The ASCII value of the hotkey configured for terminal reset must be different from that of any other hotkeys configured on the device. Otherwise, hotkey conflicts occur. Using the hotkey might not get a fast response when the terminal display is busy.
# Set the terminal reset hotkey to Ctrl+A by setting its ASCII value to 1.
[Sysname-rta-template-abc] resetkey 1
rta relay buffer-size
Use rta relay buffer-size to set the RTC relay forward buffer size for each RTC client.
Use undo rta relay buffer-size to restore the default.
rta relay buffer-size buffer-size
The forward buffer size for each RTC client connected to a relay server is 8 KB.
buffer-size: Specifies the forward buffer size for each RTC client, in the range of 1 to 64 KB.
If the number of packets to be sent out reaches the specified buffer size, new data will overwrite existing data, resulting in packet loss. By comparision, the TCP send buffer size (set by the rta relay tcp sendbuf-size command) will affect the transmission efficiency but will not cause packet loss.
# Set the RTC relay forward buffer size to 2 KB.
[Sysname] rta relay buffer-size 2
rta relay disconnect
Use rta relay disconnect to forcibly disconnect client connections from a relay server.
rta relay disconnect { server-id client-id | all }
server-id: Specifies a forwarding group ID in the range of 0 to 63.
client-id: Specifies a client ID in the forwarding group, in the range of 0 to 9.
all: specifies all client connections.
# Disconnect all client connections from a relay server.
[Sysname] rta relay disconnect all
rta relay enable
Use rta relay enable to enable relay forwarding for a relay server.
Use undo rta relay enable to restore the default.
rta relay enable
Relay forwarding is disabled for a relay server.
Relay forwarding is applicable only to TCP transparent transmission between multiple RTC clients and one relay server (many-to-one mode).
# Enable RTC relay forwarding.
[Sysname] rta relay enable
rta relay listen-port
Use rta relay listen-port to set a TCP listening port for a relay server.
Use undo rta relay listen-port to restore the default.
rta relay listen-port port-number
undo rta relay listen-port port-number
No TCP listening ports are configured.
port-number: Specifies a TCP listening port in the range of 1024 to 50000.
A relay server can accept a maximum of 10 connections in each forwarding group.
The system supports a maximum of 64 TCP listening ports. A forwarding group contains the connections established through the same port and allows data from a terminal to be broadcast within the group.
Deleting a listening port will disconnect all the clients connected to the port.
# Set TCP listening ports to 1026 and 1027.
[Sysname] rta relay listen-port 1026
[Sysname] rta relay listen-port 1027
rta relay enable
rta relay tcp
Use rta relay tcp to set the send buffer size and receive buffer size for TCP connections between the relay server and an RTC client.
Use undo rta relay tcp to restore the default send buffer size and receive buffer size.
rta relay tcp { recvbuf-size recvbuff-size | sendbuf-size sendbuff-size }
undo rta relay tcp { recvbuf-size | sendbuf-size }
The send buffer size and receive buffer size for TCP connections are both 2048 bytes.
recvbuff-size: Specifies the TCP receive buffer size in the range of 512 to 16384 bytes.
sendbuff-size: Specifies the TCP send buffer size in the range of 512 to 16384 bytes.
As a best practice, use the default settings. An improper send buffer size or receive buffer size can affect data forwarding efficiency or cause system overload.
# Set the TCP send buffer size and TCP receive buffer size on the relay server to 8194 bytes and 2046 bytes, respectively.
[Sysname] rta relay tcp sendbuf-size 8194
[Sysname] rta relay tcp recvbuf-size 2046
rta relay tcp keepalive
rta relay tcp nodelay
Use rta relay tcp keepalive to configure the TCP keepalive attributes on a relay server.
Use undo rta relay tcp keepalive to restore the default.
rta relay tcp keepalive time count
The TCP keepalive interval is 50 seconds. The keepalive number is 3.
time: Specifies the keepalive interval in the range of 10 to 7200 seconds.
count: Specifies the keepalive number in the range of 1 to 100.
This command enables the relay server to use the TCP keepalive feature to detect the reachability of an RTC client. If the relay server receives no keepalive from an RTC client within the timeout time, it disconnects the RTC client. The timeout time is the result of multiplying the keepalive interval by the keepalive number.
# Set the keepalive interval to 100 seconds and the keepalive number to 3 for TCP connections on the relay server.
[Sysname] rta relay tcp keepalive 100 3
rta relay tcp
Use rta relay tcp nodelay to enable TCP_NODELAY on a relay server.
Use undo rta relay tcp nodelay to disable TCP_NODELAY on a relay server.
TCP_NPDELAY is disabled on a relay server.
TCP_NODELAY disables the Nagle algorithm for TCP. TCP_NODELAY removes the time delay caused by Nagle during TCP traffic transmission to improve the forwarding performance of a relay server.
# Enable TCP_NODELAY on the relay server.
[Sysname] rta relay tcp nodelay
rta relay tcp
rta rtc-server listen-port
Use rta rtc-server listen-port to configure the listening port on an RTC server.
Use undo rta rtc-server listen-port to restore the default.
rta rtc-server listen-port port-number
undo rta rtc-server listen-port port-number
No listening port is configured on an RTC server.
port-number: Specifies the listening TCP port number in the range of 1024 to 50000.
Only one listening port can be configured on an RTC server.
# Set the RTC server listening port number to 9010.
[Sysname] rta rtc-server listen-port 9010
rta server enable
rta server enable
Use rta server enable to enable terminal access on a router.
Use undo rta server enable to disable terminal access on a router.
rta server enable
Terminal access is disabled on a router.
Disabling terminal access does not remove the existing settings for terminal templates, terminals, and VTYs on the router.
# Enable terminal access.
[Sysname] rta server enable
rta source-ip
Use rta source-ip to configure a global source IP address for TCP connections.
Use undo rta source-ip to restore the default.
rta source-ip ip-address
undo rta source-ip
No global source IP address is configured for TCP connections.
ip-address: Specifies a source IP address for TCP connections.
This command specifies a TCP source address. If no TCP source address is specified, the router uses the outbound interface's IP address as the TCP source address. Typically, the IP address of the loopback interface or dialer interface of a router is used as the TCP connection source IP address for dial-up backup and address hiding.
A source IP address configured in a terminal template has priority over the global TCP source IP address for the terminal using that template.
After a global TCP connection source IP address is configured, a TCP connection must be re-established for the address to take effect.
# Set the source IP address to 1.1.1.1 for the global TCP connection.
[Sysname] rta source-ip 1.1.1.1
rta template
Use rta template to create a terminal template and enter its view, or enter the view of an existing terminal template.
Use undo rta template to delete a terminal template.
rta template template-name
undo rta template template-name
No terminal templates exist.
template-name: Specifies a terminal template name, a string of 1 to 15 characters.
# Create terminal template abc and enter its view.
rta terminal
Use rta terminal to apply a terminal template to an interface.
Use undo rta terminal to restore the default.
rta terminal template-name terminal-number
undo rta terminal
No terminal template is applied to an interface.
Asynchronous serial interface view
Synchronous/asynchronous serial interface view
template-name: Specifies a template by its name, a string of 1 to 15 characters.
To implement terminal access, apply a configured terminal template to an interface to create a terminal. An interface can be connected to only one physical terminal. The router identifies physical terminals by terminal number.
# Apply terminal template abc with the terminal number of 1 to Async 2/2/1.
[Sysname] interface async 2/2/1
[Sysname-rta-async2/2/1] rta terminal abc 1
rta terminal backup
Use rta terminal backup to apply a terminal template to a backup interface.
Use undo rta terminal backup to restore the default.
syntax
rta terminal template-name terminal-number backup
default
No terminal template is applied to a backup interface.
Interface view
template-name: Specify a terminal template by its name, a string of 1 to 15 characters.
The primary interface takes over the traffic forwarding again when it recovers from a failure condition.
# Apply terminal template abc with the terminal number of 1 to backup interface async 2/2/1.
[Sysname-rta-async2/2/1] rta terminal abc 1 backup
rtc-multipeer remote
Use rtc-multipeer remote to configure a client on a VTY serving as a one-to-many UDP RTC server.
Use undo rtc-multipeer remote to delete a client from a VTY serving as a one-to-many UDP RTC server.
rtc-multipeer vty-number remote ip-address port-number
undo rtc-multipeer vty-number remote ip-address port-number
No clients exist on a VTY serving as a one-to-many UDP RTC server.
ip-address: Specifies the IP address of a client.
port-number: Specifies the UDP port of the client, in the range of 1024 to 50000.
Create a UDP_1N_Server VTY before you configure a client list for it. You can configure a maximum of 10 clients for a VTY. For more information about configuring UDP_1N_Server VTYs, see the vty rtc-multipeer command.
Deleting a UDP_1N_Server VTY deletes the client list of the VTY.
# Configure a client list for one-to-many UDP RTC server VTY 1. The client list includes a client with an IP address of 1.1.1.2 and a UDP port number of 1024, and a client with an IP address of 1.1.1.3 and a UDP port number of 1025.
[Sysname] rta template temp3
[Sysname-rta-template-temp3] vty 1 rtc-multipeer 1.1.1.1 1024
[Sysname-rta-template-temp3] rtc-multipeer 1 remote 1.1.1.2 1024
[Sysname-rta-template-temp3] rtc-multipeer 1 remote 1.1.1.3 1025
vty rtc-multipeer
sendbuf bufsize
Use sendbuf bufsize to configure the maximum size of data to be sent to a terminal at one time.
Use undo sendbuf bufsize to restore the default.
sendbuf bufsize size
The maximum size of data to be sent to a terminal at one time is 500 bytes.
size: Specifies the maximum size of data sent to a terminal at one time, in the range of 2 to 500 bytes.
The router sends data in packets to a terminal. The size of the packet might be different each time it is sent.
# Configure the maximum size to 200 bytes for data to be sent at one time.
[Sysname-rta-template-abc] sendbuf bufsize 200
sendbuf threshold
sendbuf threshold
Use sendbuf threshold to set the threshold of the terminal send buffer.
Use undo sendbuf threshold to restore the default.
sendbuf threshold value
No threshold is set for the terminal send buffer.
value: Specifies the threshold of the terminal send buffer, in the range of 50 to 2048 bytes.
The router uses the terminal send buffer to store the data to be sent to the terminal. The threshold specifies the maximum data in bytes that the send buffer can store.
# Set the terminal send buffer threshold to 1000 bytes.
[Sysname-rta-template-abc] sendbuf threshold 1000
sendbuf bufsize
tcp
Use tcp to configure a TCP parameter.
Use undo tcp to remove the configuration of a TCP parameter.
tcp { keepalive time count | nodelay | recvbuf-size recvsize | sendbuf-size sendsize }
undo tcp { keepalive | nodelay | recvbuf-size | sendbuf-size }
The keepalive interval is 50 seconds, and the keepalive number is 3.
Delay is enabled.
The receive buffer size is 2048 bytes.
The send buffer size is 2048 bytes.
keepalive time count: Specifies the keepalive interval and the keepalive number. The keepalive interval is in the range of 10 to 7200 seconds. The keepalive number is in the range of 1 to 100.
nodelay: Disables the TCP Nagle algorithm, and enables TCP no delay.
recvbuf-size recvsize: Specifies the TCP receive buffer size in the range of 512 to 16384 bytes.
sendbuf-size sendsize: Specifies the TCP send buffer size in the range of 512 to 16384 bytes.
This command takes effect only after a TCP connection is re-established.
# Set the TCP receive buffer size to 512 bytes.
[Sysname-rta-template-abc] tcp recvbuf-size 512
# Set the TCP send buffer size to 512 bytes.
[Sysname-rta-template-abc] tcp sendbuf-size 512
# Disable TCP delay.
[Sysname-rta-template-abc] tcp nodelay
# Set the TCP keepalive interval to 1800 seconds and the keepalive number to 2.
[Sysname-rta-template-abc] tcp keepalive 1800 2
update changed-config
Use update changed-config to update the most recent template configurations immediately.
The configuration changes to a terminal template do not take effect immediately.
If you modify a terminal template that has been applied to an interface, use this command to apply the most recent configurations.
Executing this command disconnects current connections and re-establishes connections. Make sure critical services will not be affected.
Some configurations (such as source IP address configuration) take effect only after they are updated and the connection is re-established.
# Set the automatic link teardown time under the template and update the configuration.
[Sysname-rta-template-abc] update changed-config
vty description
Use vty description to configure a description for a VTY.
Use undo vty description to restore the default.
vty vty-number description string
undo vty vty-number description
No description is configured for a VTY.
string: Specifies a description, a case-sensitive string of 1 to 31 characters.
When a VTY is used for a service, you can use the service name as the description of the VTY.
# Configure the description as chuxu for VTY 1.
[Sysname-rta-template-abc] vty 1 description chuxu
vty hotkey
Use vty hotkey to set the hotkey for VTY fast switching.
Use undo vty hotkey to restore the default.
vty vty-number hotkey ascii-code&<1-3>
undo vty vty-number hotkey
No hotkey is set for VTY fast switching.
ascii-code&<1-3>: Specifies the ASCII value of the hotkey, in the range of 1 to 255. The &<1-3> means that you can enter a maximum of three ASCII values.
Fast VTY switching allows you to switch between applications. In RTC terminal access, each terminal can be logically divided into eight VTYs and each VTY corresponds to one application. When multiple VTYs are configured for a terminal with the corresponding switching hotkeys, you can press the switching hotkeys to quickly switch between the VTYs. The connection of the original VTY application is not torn down. This way, dynamic switching between the VTYs (that is, different applications) on a terminal is implemented.
The ASCII value of the hotkey must be different from any other hotkey configured on the device. Otherwise, hotkey conflicts occur. For example, the hotkey value cannot be 17 or 19 because these values are used for flow control. Using a hotkey might not get a fast response when the terminal display is busy.
# Set the hotkey to Ctrl+A for VTY 1 by setting its ASCII value to 1.
[Sysname-rta-template-abc] vty 1 hotkey 1
vty password
Use vty password to configure the password for VTY authentication.
Use undo vty password to restore the default.
vty vty-number password { simple | cipher } string
undo vty vty-number password
No password is configured for VTY authentication.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
To support terminal access authentication, passwords must be configured on the RTC server and the RTC clients. Authentication succeeds only if the passwords are the same. If no authentication is needed, do not set a password on the RTC server or RTC clients.
# Set the authentication password to plaintext password abc for VTY 1.
[Sysname-rta-template-abc] vty 1 password simple abc
vty rtc-client remote
vty rtc-server remote
Use vty rtc-client remote to create a VTY to act as a TCP RTC client.
Use undo vty to delete a VTY.
vty vty-number rtc-client remote ip-address port-number [ source source-ip ]
undo vty vty-number
No TCP RTC client VTYs exist.
ip-address: Specifies the IP address of the RTC server.
port-number: Specifies the listening port number of the RTC server, in the range of 1024 to 50000.
source source-ip: Specifies the TCP source IP address.
After this configuration, no VTY of another type can be configured in the template.
# Create VTY 1 to act as a TCP RTC client. Set the IP address of the RTC server to 1.1.1.1, listening port of the RTC server to 9010, and the source IP address to be used for establishing TCP connections to 2.2.2.2.
[Sysname-rta-template-abc] vty 1 rtc-client remote 1.1.1.1 9010 source 2.2.2.2
vty rtc-client remote remote-port
Use vty rtc-client remote remote-port to create a VTY to act as a UDP RTC client.
vty vty-number rtc-client remote ip-address remote-port remote-port-number udp [ local-port local-port-number ] [ source source-ip-address ]
undo vty vty-number
No UDP RTC client VTYs exist.
ip-address: Specifies the RTC server IP address.
remote-port-number: Specifies the UDP port number of the RTC server, in the range of 1024 to 50000.
source-ip-address: Specifies the local IP address.
local-port-number: Specifies the local UDP listening port, in the range of 1024 to 50000.
# Create VTY 1 to act as a UDP RTC client. Set the RTC server IP address to 1.1.1.1, RTC server UDP port to 1024, local address to 1.1.1.2, and the local UDP listening port to 1025.
[Sysname] rta template temp2
[Sysname-rta-template-temp2] vty 1 rtc-client remote 1.1.1.1 remote-port 1024 udp local-port 1025 source 1.1.1.2
rta rtc-server remote-udp
vty rtc-multipeer
Use vty rtc-multipeer to create a VTY to act as a one-to-many UDP RTC server.
vty vty-number rtc-multipeer [ ip-address ] port-number
undo vty vty-number
No one-to-many UDP RTC server VTYs exist.
port-number: Specifies the local UDP port in the range of 1024 to 50000.
Deleting a VTY that acts as a one-to-many UDP RTC server deletes the client list of the VTY.
# Create VTY 1 to act as a one-to-many UDP RTC server. Set the local UDP listening port to 1024 and the local IP address to 1.1.1.1.
Use vty rtc-server remote to create a VTY to act as a TCP RTC server.
vty vty-number rtc-server remote ip-address terminal-number
undo vty vty-number
No TCP RTC server VTYs exist.
ip-address: Specifies the RTC client IP address.
terminal-number: Specifies the terminal number corresponding to the RTC client, in the range of 1 to 255.
# Create a VTY to act as a TCP RTC server. Set the IP address of the RTC client to 2.2.2.2 and the terminal number to 1.
[Sysname-rta-template-abc] vty 1 rtc-server remote 2.2.2.2 1
vty rtc-server remote udp
Use vty rtc-server remote udp to create a VTY to act as a UDP RTC server.
vty vty-number rtc-server remote [ ip-address remote-port remote-port-number ] udp local-port local-port-number [ source source-ip-address ]
undo vty vty-number
No UDP RTC server VTYs exist.
ip-address: Specifies the IP address of the RTC client.
remote-port-number: Specifies the UDP port of the RTC client, in the range of 1024 to 50000.
# Create VTY 1 to act as a UDP RTC server. Set the local IP address to 1.1.1.1, local UDP listening port to 1024, RTC client IP address to 1.1.1.2, and the RTC client UDP port to 1025.
[Sysname] rta template temp1
[Sysname-rta-template-temp1] vty 1 rtc-server remote 1.1.1.2 remote-port 1025 udp local-port 1024 source 1.1.1.1
