- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Emergency shell commands
- 09-Automatic configuration commands
- 10-Device management commands
- 11-Tcl commands
- 12-Python commands
- 13-License management commands
| 09-Automatic configuration commands | 28.56 KB |
autodeploy sms enable
Use autodeploy sms enable to enable SMS-based automatic configuration.
Use undo autodeploy sms enable to disable SMS-based automatic configuration.
SMS-based automatic configuration is enabled.
# Disable SMS-based automatic configuration.
[Sysname] undo autodeploy sms enable
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
