03-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesH3C S12500X-AF Switch SeriesReference GuidesCommand ReferencesH3C S12500X-AF Switch Series Command References(R320x)-6W10003-Layer 2—LAN Switching Command Reference
03-Ethernet interface commands
03-Ethernet interface commands 307.96 KB
Ethernet interface commands· 1
Common Ethernet interface commands· 1
bandwidth· 1
broadcast-suppression· 1
dampening· 3
default 4
description· 5
display counters· 5
display counters rate· 6
display ethernet statistics· 8
display interface· 10
display interface split-capable· 21
display interface link-info· 21
display interface main· 23
display link-flap protection· 26
display packet-drop· 27
display priority-flow-control 28
duplex· 30
flow-control 30
flow-control receive enable· 31
flow-interval 32
interface· 32
jumboframe enable· 33
link-delay· 33
link-flap protect enable· 35
loopback· 35
multicast-suppression· 36
port fec mode· 37
port ifmonitor crc-error 38
port ifmonitor input-error 39
port ifmonitor output-error 40
port link-flap protect enable· 41
port link-mode· 42
port training· 43
port up-mode· 44
priority-flow-control (Ethernet interface view) 44
priority-flow-control (system view) 45
priority-flow-control deadlock auto-recover action· 46
priority-flow-control deadlock auto-recover cos· 47
priority-flow-control deadlock cos· 48
priority-flow-control deadlock enable· 49
priority-flow-control deadlock precision· 50
priority-flow-control deadlock recover 51
priority-flow-control deadlock recover-mode· 52
priority-flow-control deadlock threshold· 53
priority-flow-control dot1p headroom·· 54
priority-flow-control dot1p ingress-buffer dynamic· 55
priority-flow-control dot1p ingress-buffer static· 56
priority-flow-control dot1p ingress-threshold-offset 57
priority-flow-control dot1p reserved-buffer 58
priority-flow-control early-warning inpps· 58
priority-flow-control early-warning outpps· 59
priority-flow-control inner-port enable· 60
priority-flow-control inner-port no-drop· 61
priority-flow-control no-drop dot1p (Ethernet interface view) 62
priority-flow-control no-drop dot1p (system view) 63
priority-flow-control poolID headroom·· 64
reset counters interface· 65
reset ethernet statistics· 65
reset packet-drop interface· 66
shutdown· 67
snmp-agent trap enable ifmonitor 67
speed· 68
unicast-suppression· 69
using hundredgige· 70
using tengige· 71
using twenty-fivegige· 72
Layer 2 Ethernet interface commands· 72
display storm-constrain· 72
storm-constrain· 74
storm-constrain control 75
storm-constrain enable log· 76
storm-constrain enable trap· 77
storm-constrain interval 77
Layer 3 Ethernet interface or subinterface commands· 78
mac-address· 78
mtu· 79
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Ethernet subinterface view
# Set the expected bandwidth of HundredGigE 1/0/1 to 1000 kbps.
[Sysname-HundredGigE1/0/1] bandwidth 1000
# Set the expected bandwidth of HundredGigE 1/0/1.1 to 1000 kbps.
[Sysname] interface hundredgige 1/0/1.1
[Sysname-HundredGigE1/0/1.1] bandwidth 1000
speed
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to disable broadcast suppression.
Ethernet interfaces do not suppress broadcast traffic.
ratio: Sets the broadcast suppression threshold as a percentage of the interface bandwidth. The value range for this argument is 0 to 100. A smaller value means that less broadcast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The broadcast storm suppression features limits the size of broadcast traffic to a threshold on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the broadcast-suppression command can suppress broadcast storms on a port. The broadcast-suppression command uses the chip to physically suppress broadcast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress broadcast traffic.
For the traffic suppression result to be determined, do not configure both the storm-constrain broadcast command and the broadcast-suppression command on an interface.
When you configure the suppression threshold in kbps, the actual suppression threshold might be different from the configured one as follows:
·     If the configured value is smaller than 64, the value of 64 takes effect.
·     If the configured value is greater than 64 but not an integer multiple of 64, the integer multiple of 64 that is greater than and closest to the configured value takes effect.
To determine the suppression threshold that takes effect, see the prompts on the switch.
Set the same type of thresholds for each interface.
# Set the broadcast suppression threshold to 10000 kbps on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] broadcast-suppression kbps 10000
The actual value is 10048 on port HundredGigE1/0/1 currently.
The output shows that the value that takes effect is 10048 kbps (157 times of 64), because the chip only supports step 64.
unicast-suppression
dampening
Use dampening to enable the device to dampen an interface when the interface is flapping.
Use undo dampening to restore the default.
undo dampening
Interface dampening is disabled on Ethernet interfaces.
half-life: Specifies the amount of time after which a penalty is decreased, in the range of 1 to 120 seconds. The default value is 54 seconds.
reuse: Specifies the reuse threshold in the range of 200 to 20000. The default value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies the suppression threshold in the range of 200 to 20000. The default value is 2000.
max-suppress-time: Specifies the maximum amount of time the interface can be dampened, in the range of 1 to 255 seconds. The default value is 162 seconds (three times the half-life timer).
When configuring the dampening command, follow these rules to set the values mentioned above:
·     The ceiling is equal to 2 (Max-suppress-time/Decay) × reuse-limits. It is not user configurable.
·     The configured suppress limit is lower than or equal to the ceiling.
·     The ceiling is lower than or equal to the maximum suppress limit supported.
This command, the link-delay command, and the port link-flap protect enable command are mutually exclusive on an interface.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
Do not enable the dampening function on an interface with RRPP, MSTP, or Smart Link enabled.
After an interface in down state is dampened, the interface state displayed through the display interface command is always down.
# Enable interface dampening on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] dampening
# Enable interface dampening on HundredGigE 1/0/1, and set the following parameters:
·     Half life time to 2 seconds.
·     Reuse value to 800.
·     Suppression threshold to 3000.
·     Maximum suppression interval to 5 seconds.
[Sysname-HundredGigE1/0/1] dampening 2 800 3000 5
display interface
link-delay
default
Use default to restore the default settings for an interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] default
# Restore the default settings for HundredGigE 1/0/1.1.
[Sysname-HundredGigE1/0/1.1] default
description
The description of an interface is the interface name plus Interface (for example, HundredGigE1/0/1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of HundredGigE 1/0/1 to lan-interface.
[Sysname-HundredGigE1/0/1] description lan-interface
# Set the description of HundredGigE 1/0/1.1 to subinterface1/0/1.1.
[Sysname-HundredGigE1/0/1.1] description subinterface1/0/1.1
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
To clear the Ethernet interface traffic statistics, use the reset counters interface command.
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and number, this command displays traffic statistics for the specified interface.
# Display inbound traffic statistics for all interfaces.
<Sysname> display counters inbound interface
Interface            Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
HGE1/0/1                       --                  --                  --           0
HGE1/0/2                       --                  --                  --    Overflow
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
Abbreviated interface name.
Total (pkts)
Total number of packets received or sent through the interface.
Broadcast (pkts)
Total number of broadcast packets received or sent through the interface.
Multicast (pkts)
Total number of multicast packets received or sent through the interface.
Err (pkts)
Total number of error packets received or sent through the interface.
The command displays Overflow when any of the following conditions exist:
·     The data length of an Err field value is greater than 7 decimal digits.
·     The data length of a non-Err field value is greater than 14 decimal digits.
--: Not supported
The statistical item is not supported.
Use display counters rate to display traffic rate statistics for interfaces in up state for the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic rate statistics for all up interfaces of the specified type.
If you specify an interface type and an interface, this command displays traffic rate statistics for the specified interface.
If an interface that you specify is always down for the most recent statistics polling interval, the system prompts that the interface does not support the command.
To set the statistics polling interval, use the flow-interval command.
# Display the inbound traffic rate statistics for all interfaces.
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface            Usage (%)   Total (pps)   Broadcast (pps)   Multicast (pps)
HGE1/0/1                    0             0                --                --
 Overflow: More than 14 digits.
       --: Not supported.
Usage (%)
Bandwidth usage (in percentage) of the interface for the last statistics polling interval.
Total (pps)
Average receiving or sending rate (in pps) for unicast packets for the last statistics polling interval.
Broadcast (pps)
Average receiving or sending rate (in pps) for broadcast packets for the last statistics polling interval.
Multicast (pps)
Average receiving or sending rate (in pps) for multicast packets for the last statistics polling interval. .
Overflow: more than 14 decimal digits
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits.
--: not supported
flow-interval
Use display ethernet statistics to display the Ethernet module statistics.
In standalone mode:
display ethernet statistics slot slot-number
In IRF mode:
display ethernet statistics chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
# (In standalone mode.) Display the Ethernet module statistics for the specified slot.
<Sysname> display ethernet statistics slot 1
ETH receive packet statistics:
    Totalnum        : 10447          ETHIINum     : 4459
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 4459           ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 5988           ErrSrcMAC    : 5988
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 211            VLANOutNum   : 0
    FastOutNum      : 155            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQoSTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
Table 3 Output description
Statistics about the Ethernet packets received by the Ethernet module:
·     Totalnum—Total number of received packets.
·     ETHIINum—Number of packets encapsulated by using Ethernet II.
·     SNAPNum—Number of packets encapsulated by using SNAP.
·     RAWNum—Number of packets encapsulated by using RAW.
·     ISISNum—Number of packets encapsulated by using ISIS.
·     LLCNum—Number of packets encapsulated by using LLC.
·     UnknownNum—Number of packets encapsulated by using unknown methods.
·     ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU.
·     ARP—Number of ARP packets.
·     MPLS—Number of MPLS packets.
·     ISIS—Number of IS-IS packets.
·     ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS.
·     IP—Number of IP packets.
·     IPv6—Number of IPv6 packets.
Statistics about the error Ethernet packets in the inbound direction on the Ethernet module. Errors might be included in packets or occur during the receiving process. The items include:
·     NullPoint—Number of packets that include null pointers.
·     ErrIfindex—Number of packets that include incorrect interface indexes.
·     ErrIfcb—Number of packets that include incorrect interface control blocks.
·     IfShut—Number of packets that are being received when the interface is shut down.
·     ErrAnalyse—Number of packets that include packet parsing errors.
·     ErrSrcMAC—Number of packets that include incorrect source MAC addresses.
·     ErrHdrLen—Number of packets that include header length errors.
Statistics about the Ethernet packets sent by the Ethernet module:
·     L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces.
·     VLANOutNum—Number of packets sent out of VLAN interfaces.
·     FastOutNum—Number of packets fast forwarded.
·     L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces.
·     MbufRelayNum—Number of packets transparently sent.
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module:
·     NullMbuf—Number of packets with null pointers.
·     ErrAdjFwd—Number of packets with adjacency table errors.
·     ErrPrepend—Number of packets with extension errors.
·     ErrHdrLen—Number of packets with header length errors.
·     ErrPad—Number of packets with padding errors.
·     ErrQoSTrs—Number of packets that failed to be sent by QoS.
·     ErrVLANTrs—Number of packets that failed to be sent in VLANs.
·     ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures.
·     ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures.
·     IfShut—Number of packets that are being sent when the interface is shut down.
·     IfErr—Number of packets with incorrect outgoing interfaces.
display interface
Use display interface to display interface information.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
# Display information about Layer 3 interface HundredGigE 1/0/1.
<Sysname> display interface hundredgige 1/0/1
HundredGigE1/0/1
Line protocol state: DOWN
Description: HundredGigE1/0/1 Interface
Bandwidth: 1000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Unknown-multicast max-ratio: 100%
Unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
Loopback is not set
Media type is not sure, port hardware type is No connector
Ethernet port mode: LAN
Port priority: 2
Flow-control is not enabled
The maximum frame length is 9416
Last link flapping: 6 hours 39 minutes 28 seconds
Current system time:2018-08-10 14:56:12
Last time when physical state changed to up:-
Last time when physical state changed to down:2018-08-10 14:55:25
 Peak input rate: 0 bytes/sec, at 2013-07-07 16:07:11
 Peak output rate: 0 bytes/sec, at 2013-07-07 16:07:11
 Last 300 seconds input:  0 packets/sec 0 bytes/sec  0%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec  0%
 Input  (total): 0 packets, 0 bytes
          0 unicasts, 0 broadcasts, 0 multicasts, - pauses
 Input  (normal): 0 packets, 0 bytes
 Input: 0 input errors, 0 runts, 0 giants, 0 throttles
          - ignored, - parity errors
 Output  (total): 0 packets, 0 bytes
 Output  (normal): 0 packets, 0 bytes
          - lost carrier, - no carrier
IPv4 traffic statistics:
 Last 0 seconds input rate: 0 packets/sec, 0 bytes/sec
 Last 0 seconds output rate: 0 packets/sec, 0 bytes/sec
 Input: 0 packets, 0 bytes
 Output: 0 packets, 0 bytes
IPv6 traffic statistics:
# Display detailed information about Layer 2 interface HundredGigE 1/0/1.
HundredGigE1/0/1
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Bandwidth: 100000 kbps
Loopback is not set
Maximum frame length: 9416
Allow jumbo frame to pass
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters:  14:34:09 Tue 11/01/2011
Current system time:2018-08-10 14:58:27
Last time when physical state changed to down:2018-08-10 14:57:58
 Peak input rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Peak output rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Last 300 seconds input:  0 packets/sec 0 bytes/sec -%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec -%
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     DOWN ( Link-Aggregation interface down )—The aggregate interface to which the interface belongs has been shut down by using the shutdown command.
·     DOWN (Monitor-Link uplink down )—The interface has been shut down by Monitor Link.
·     Link-Flap DOWN—The interface has been shut down by the link flapping protection feature.
·     mac-address moving down—The interface has been shut down by the MAC address move suppression feature.
·     OFP DOWN—The interface has been shut down by OpenFlow.
·     Storm-Constrain—The interface has been shut down because the storm control feature detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold.
·     STP DOWN—The interface has been shut down by the BPDU guard feature.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
·     DOWN (protocols)—The data link layer has been shut down by protocols included in the parentheses. Available protocols include:
¡     DLDP—Shuts down the data link layer when it detects that the link is unidirectional.
¡     OAM—Shuts down the data link layer when it detects a remote link failure.
¡     LAGG—Shuts down the data link layer when it detects that the aggregate interface does not have Selected ports.
¡     BFD—Shuts down the data link layer when it detects a link failure.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
Internet address
IP address of the interface. The primary attribute indicates that the address is the primary IP address.
IPv4 packet framing format.
hardware address
MAC address of the interface.
FEC mode
FEC mode of the interface, which depends on the configuration.
When the FEC mode of an interface is set to autonegotiation, the actual FEC mode depends on the model of the transceiver module installed in the fiber port.
IPv6 packet framing format.
Port priority
Port priority of the interface.
Loopback is set internal
An internal loopback test is running on the interface. This field depends on your configuration.
Loopback is set external
An external loopback test is running on the interface. This field depends on your configuration.
Loopback is not set
No loopback test is running on the interface. This field depends on your configuration.
10Gbps-speed mode
The interface is operating at 10 Gbps. This field depends on your configuration and the link parameter negotiation result.
25Gbps-speed mode
The interface is operating at 25 Gbps. This field depends on your configuration and the link parameter negotiation result.
40Gbps-speed mode
The interface is operating at 40 Gbps. This field depends on your configuration and the link parameter negotiation result.
100Gbps-speed mode
The interface is operating at 100 Gbps. This field depends on your configuration and the link parameter negotiation result.
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
full-duplex mode
The interface is operating in full duplex mode. This field depends on your configuration and the link parameter negotiation result.
unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
The interface is configured with the speed auto command.
Link speed type is force link
The interface is manually configured with a speed (for example, 1000 Mbps) by using the speed command.
The interface is configured with the duplex auto command.
link duplex type is force link
The interface is manually configured with a duplex mode (for example, half or full) by using the duplex command.
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result.
Maximum length of Ethernet frames allowed to pass through the interface.
The interface allows jumbo frames to pass through.
Broadcast max-
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast max-
Unknown unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the interface.
MDI type
MDIX mode of the interface:
·     automdix.
·     mdi.
·     mdix.
Port link-type
Link type of the interface:
·     access.
·     trunk.
·     hybrid.
Tagged VLANs
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLANs
VLANs for which the interface sends packets after removing VLAN tags.
VLAN Passing
VLANs whose packets can be forwarded by the port. The VLANs must have been created.
VLAN permitted
VLANs whose packets are permitted by the port.
Trunk port encapsulation
Encapsulation protocol type for the trunk port.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Current system time
Current system time in the YYYY/MM/DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone.
Last time when the physical state of the interface changed to up.
A hyphen (-) indicates that the physical state of the interface has never changed.
Last time when the physical state of the interface changed to down.
Average inbound or outbound traffic rate (in pps and Bps) in the last 300 seconds, and the ratio of the actual rate to the interface bandwidth.
A hyphen (-) indicates that the statistical item is not supported.
Input(total):  0 packets, 0 bytes
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
Input(normal):  0 packets, 0 bytes
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
input errors
Statistics of incoming error packets.
runts
Number of inbound frames meeting the following conditions:
·     Shorter than 64 bytes.
·     In correct format.
·     Containing valid CRCs.
giants
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface.
For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows:
·     1518 bytes (without VLAN tags).
·     1522 bytes (with VLAN tags).
For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡     For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
¡     For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained a minimum of one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output(total): 0 packets, 0 bytes
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
Output(normal): 0 packets, 0 bytes
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
Peak input rate
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred.
Peak output rate
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred.
IPv4 packet statistics.
IPv6 packet statistics.
Last 300 seconds input rate: 300 packets/sec, 230000 bytes/sec
Average inbound traffic rate (in pps and Bps) in the last 300 seconds.
Last 300 seconds output rate: 200 packets/sec, 220000 bytes/sec
Average outbound traffic rate (in pps and Bps) in the last 300 seconds.
Input: 12 packets, 1968 bytes
Inbound traffic statistics (in packets and bytes) for the interface.
Outbound traffic statistics (in packets and bytes) for the interface.
# Display brief information about all interfaces.
Protocol: (s) – spoofing
Interface            Link Protocol Primary IP      Description
HGE1/0/1             DOWN DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
HGE1/0/2             DOWN auto    A      A    1
HGE1/0/3             UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about HundredGigE 1/0/3, including the complete description of the interface.
<Sysname> display interface hundredgige 1/0/3 brief description
Speed: (a) - auto
HGE1/0/3             UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
HGE1/0/1             DOWN Not connected
Vlan2                DOWN Not connected
HGE1/0/2             DOWN Not connected
Table 5 Command output
Brief information about Layer 3 interfaces.
Interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Brief information of interfaces in bridge mode:
Brief information about Layer 2 interfaces.
Type: A - access; T - trunk; H – hybrid
Link type options for interfaces.
Speed
Speed of the interface, in bps.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is down.
·     DOWN (Loopback detection down)—The loopback detection module has detected loops.
·     DOWN ( Monitor-Link uplink down )—The monitor link module has detected that the uplink is down.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
·     Storm-Constrain—The storm control feature has detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold.
Use display interface split-capable to display interfaces capable of being split.
display interface split-capable [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays interfaces capable of being split for all cards.
# Display interfaces capable of being split.
<Sysname> display interface split-capable
slot 7:
100-GE interfaces capable of being split into multiple 10-GE or 25-GE interfaces:
 HundredGigE5/0/1       HundredGigE5/0/2       HundredGigE5/0/3
 HundredGigE5/0/4       HundredGigE5/0/5       HundredGigE5/0/7
 HundredGigE5/0/8       HundredGigE5/0/9       HundredGigE5/0/10
 HundredGigE5/0/11      HundredGigE5/0/12      HundredGigE5/0/13
 HundredGigE5/0/14      HundredGigE5/0/15      HundredGigE5/0/16
 HundredGigE5/0/17      HundredGigE5/0/18      HundredGigE5/0/19
 HundredGigE5/0/20      HundredGigE5/0/21      HundredGigE5/0/22
 HundredGigE5/0/23      HundredGigE5/0/24      HundredGigE5/0/25
 HundredGigE5/0/26      HundredGigE5/0/27      HundredGigE5/0/28
 HundredGigE5/0/29      HundredGigE5/0/30      HundredGigE5/0/31
 HundredGigE5/0/32      HundredGigE5/0/33      HundredGigE5/0/34
 HundredGigE5/0/35      HundredGigE5/0/36
40-GE interfaces capable of being split into four 10-GE interfaces:
Use display interface link-info to display the status and packet statistics of interfaces.
display interface link-info [ main ]
main: Specifies all interfaces except subinterfaces. If you do not specify this keyword, this command displays status and packet statistics of all interfaces.
# Display status and statistics of all interfaces.
<Sysname> display interface link-info
Protocol: (s) - spoofing
Interface        Link Protocol  InUsage OutUsage         InErrs        OutErrs
HGE1/0/1         UP   UP            10%       0%              0              0
NULL0            UP   UP(s)          0%       0%              0              0
 Overflow: More than 7 digits.
       --: Not supported.
Table 6 Command output
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces.
Link
Protocol
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces.
InUsage
Inbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average inbound speed of the interface within the most recent statistics polling interval/interface bandwidth. To set the statistics polling interval, use the flow-interval command.
OutUsage
Outbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average outbound speed of the interface within the most recent statistics polling interval/interface bandwidth. To set the statistics polling interval, use the flow-interval command.
InErrs
Number of error packets received.
OutErrs
Number of error packets sent.
The data length of a statistical item value is greater than 7 decimal digits.
--: Not supported.
A hyphen (-) indicates that the corresponding statistical item is not supported.
flow-interval
Use display interface main to display operating status and information of all interfaces except subinterfaces.
display interface [ interface-type ] [ brief [ description | down ] ] main
interface-type: Specifies an interface type. If you do not specify this argument, the command displays information about interfaces of all types.
# Display operating status and information of all interfaces except subinterfaces.
<Sysname> display interface main
HundredGigE1/0/1
IP packet frame type: Ethernet II, hardware address: 4005-6538-0100
Loopback is not set
Maximum frame length: 9216
Multicast max-ratio: 100%
PVID: 1
MDI type: Automdix
 Tagged VLANs:   None
 Untagged VLANs: 1
Port priority: 2
Last link flapping: Never
Current system time:2018-04-11 10:20:24
Last time when physical state changed to down:2018-04-11 09:11:09
 Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00
 Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00
HundredGigE1/0/2
Description: HundredGigE1/0/2 Interface
IP packet frame type: Ethernet II, hardware address: 4005-6538-0107
IPv6 packet frame type: Ethernet II, hardware address: 4005-6538-0107
Last time when physical state changed to down:2018-04-11 09:33:52
# Display brief information of all interfaces except subinterfaces.
<Sysname> display interface brief main
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
Speed: (a) - auto
# Display brief information about all interfaces, including the complete interface descriptions.
<Sysname> display interface  brief description main
Speed: (a) - auto
<Sysname> display interface brief down main
For description on the display interface main command output, see Table 4 and Table 5.
Use display link-flap protection to display information about link flapping protection on an interface.
display link-flap protection [ interface interface-type [ interface-number ] ]
interface-type: Specifies an interface type. If you do not specify an interface type, the command displays information about link flapping protection on all interfaces.
interface-number: Specifies an interface number. If you do not specify an interface number, the command displays information about link flapping protection on all interfaces of the specified type.
# Display information about link flapping protection on all interfaces.
<Sysname> display link-flap protection
Link-flap protection: Enabled
Interface            Link-flap  Status  Interval  Threshold
HGE1/0/1             Enabled    Down    10        5
HGE1/0/2             Disabled   N/A     --        --
Table 7 Command output
Status of global link flapping protection:
·     Enabled—Link flapping protection is enabled globally.
·     Disabled—Link flapping protection is disabled globally.
Link-flap
Status of link flapping protection on an interface:
·     Enabled—Link flapping protection is enabled on an interface.
·     Disabled—Link flapping protection is disabled on an interface.
Status
Status of an interface:
·     Down—The interface has been shut down by the link flapping protection feature.
·     N/A—The interface status is not affected by the link flapping protection feature.
Interval
Link flapping detection interval for an interface.
Threshold
Link flapping detection threshold for an interface.
display packet-drop
Use display packet-drop to display information about packets dropped on an interface.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
summary: Displays the summary of dropped packets on only interfaces that support this command.
If you do not specify an interface type, this command displays information about dropped packets on only interfaces that support this command on the device.
If you specify an interface type but do not specify an interface number, this command displays information about dropped packets on only interfaces of the specified type that support this command.
# Display information about dropped packets on HundredGigE 1/0/1.
<Sysname> display packet-drop interface hundredgige 1/0/1
HundredGigE1/0/1:
  Packets dropped due to Fast Filter Processor (FFP): 261
  Packets dropped due to Egress Filter Processor (EFP): 0
  Packets dropped due to STP non-forwarding state: 0
  Packets dropped due to insufficient data buffer. Input dropped: 0 Output dropped:0
  Packets of ECN marked: 0
  Packets of WRED dropped: 0
# Display the summary of dropped packets on only interfaces that support this command.
<Sysname> display packet-drop summary
All interfaces:
Table 8 Command output
Packets that are dropped due to FFP in the inbound direction.
Packets that are dropped due to EFP in the outbound direction.
Packets that are dropped because STP is in the non-forwarding state.
Inbound and outbound packets that are dropped due to insufficient data buffer.
Packets with the ECN field set to 11 because WRED queue thresholds are reached. For more information about WRED and ECN, see ACL and QoS Configuration Guide.
Packets that are dropped because the WRED queue thresholds are reached.
Use display priority-flow-control to display the PFC information for an interface.
display priority-flow-control interface [ interface-type [ interface-number ] ]
interface-type: Specifies an interface type. If you do not specify an interface type, the command displays the PFC information for all Ethernet interfaces.
interface-number: Specifies an interface number. If you do not specify an interface number, the command displays the PFC information for all Ethernet interfaces of the specified type.
# Display the PFC information for all Ethernet interfaces.
<Sysname> display priority-flow-control interface
Conf -- Configured mode   Ne -- Negotiated mode   P -- Priority
Interface     Conf Ne  Dot1pList   P Recv       Sent       Inpps      Outpps
HGE1/0/1      Auto On  0,2-3,5-6   0 178        43         12         15
Table 9  Command output
Locally configured PFC status.
Negotiated PFC status.
P -- Priority
802.1p priority value for which PFC is enabled.
Abbreviated name of the interface.
Conf
Locally configured PFC status:
·     Auto—The interface is configured to autonegotiate the PFC status with the remote end.
·     Off—PFC is disabled for the interface.
·     On—PFC is enabled for the interface.
Ne
Negotiated PFC status:
·     Off—PFC is disabled.
·     On—PFC is enabled.
Dot1pList
802.1p priorities that are enabled with PFC. 802.1p priority values 0 through 7 are available.
P
An 802.1p priority is displayed only when the 802.1p priority is enabled with PFC and the interface has received or sent packets with the 802.1p priority.
Recv
Number of received PFC pause frames.
Sent
Number of sent PFC pause frames.
Inpps
Incoming PFC frame rate in pps for the 802.1p priority.
Outpps
Outgoing PFC frame rate in pps for the 802.1p priority.
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default.
duplex { auto | full }
undo duplex
Ethernet interfaces operate in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode. In this mode, the interface can receive and transmit packets simultaneously.
# Configure HundredGigE 1/0/1 to operate in full duplex mode.
[Sysname-HundredGigE1/0/1] duplex full
flow-control
Use flow-control to enable TxRx-mode generic flow control on an Ethernet interface.
Use undo flow-control to disable TxRx-mode generic flow control on the Ethernet interface.
flow-control
undo flow-control
TxRx-mode generic flow control is disabled on an Ethernet interface.
With TxRx-mode generic flow control configured, an interface can both send and receive flow control frames:
·     When congested, the interface sends a flow control frame to its peer.
·     Upon receiving a flow control frame from the peer, the interface suspends sending packets.
To implement flow control on a link, enable generic flow control at both ends of the link.
# Enable TxRx-mode generic flow control on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] flow-control
Use flow-control receive enable to enable Rx-mode generic flow control on an Ethernet port.
Use undo flow-control to disable Rx-mode generic flow control on an Ethernet port.
undo flow-control
Rx-mode generic flow control is disabled on Ethernet interfaces.
With Rx-mode flow control enabled, an interface can receive but cannot send flow control frames.
·     When the interface receives a flow control frame from its peer, it suspends sending packets to the peer.
·     When traffic congestion occurs on the interface, it cannot send flow control frames to the peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end, and the flow-control command at the other. To enable both ends of the link to handle traffic congestion, configure the flow-control command at both ends.
This command, the priority-flow-control command, and the priority-flow-control no-drop dot1p command are mutually exclusive.
# Enable Rx-mode generic flow control on HundredGigE 1/0/1.
[Sysname-hundredgige 1/0/1] flow-control receive enable
flow-control
flow-interval
Use flow-interval to set the statistics polling interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval in seconds. The interval is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] flow-interval 100
interface
Use interface to enter interface view, create a subinterface and enter its view, or enter the view of an existing subinterface.
# Enter the view of HundredGigE 1/0/1.
# Create Ethernet subinterface HundredGigE 1/0/1.1 and enter its view.
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
The device allows jumbo frames within 9416 bytes to pass through.
size: Sets the maximum length (in bytes) of Ethernet frames that are allowed to pass through. The value range for this argument is 1536 to 9416.
# Allow jumbo frames to pass through HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] jumboframe enable
link-delay
Use link-delay to set the physical state change suppression interval on an Ethernet interface.
Use undo link-delay to restore the default.
undo link-delay { down | up }
Each time the physical link of a port goes up or comes down, the interface immediately reports the change to the CPU.
down: Suppresses link-down events.
up: Suppresses link-up events.
msec: Enables the physical state change suppression interval to be accurate to milliseconds. If you do not specify this keyword, the suppression interval is accurate to seconds.
delay-time: Sets the physical state change suppression interval on the Ethernet interface. A value of 0 means that physical state changes are immediately reported to the CPU and are not suppressed.
·     If you do not specify the msec keyword, the value range is 0 to 30 seconds.
·     If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
When you configure this feature, follow these guidelines:
·     To suppress link-down events, configure the link-delay down command.
·     To suppress link-up events, configure the link-delay up command.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times on an interface, the following rules apply:
·     You can configure the suppression intervals for link-up and link-down events separately.
·     If you configure the suppression interval multiple times for link-up or link-down events, the most recent configuration takes effect.
Do not configure this command on an interface that has RRPP, spanning tree protocols, or Smart Link enabled.
This command, the dampening command, and the port link-flap protect enable command are mutually exclusive on an Ethernet interface.
# Set the link-down event suppression interval to 8 seconds on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] link-delay down 8
# Set the link-up event suppression interval to 800 milliseconds on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] link-delay up msec 800
dampening
Use link-flap protect enable to enable link flapping protection globally.
Use undo link-flap protect enable to disable link flapping protection globally.
Link flapping on any interface changes network topology and increases the system overhead. For example, in an active/standby link scenario, when the interface status on the active link changes between UP and DOWN, traffic switches between active and standby links. To solve this problem, execute this command.
With link flapping protection enabled on an interface, when the interface goes down, the system enables link flapping detection on the interface. During the link flapping detection interval, if the number of detected flaps reaches or exceeds the link flapping detection threshold, the system shuts down the interface.
Link flapping protection takes effect only when it is enabled in both system view and interface view.
# Enable link flapping protection globally.
[Sysname] link-flap protect enable
loopback
Use loopback to enable loopback testing on an Ethernet interface.
loopback internal
Loopback testing is disabled on an Ethernet interface.
internal: Enables internal loopback testing on the Ethernet interface.
After you enable loopback testing on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable loopback testing, the Ethernet interface restores to its duplex setting.
An Ethernet interface in a loopback test cannot correctly forward data packets.
You cannot perform a loopback test on the following Ethernet interfaces:
·     Ethernet interfaces manually brought down (displayed as in ADM or Administratively DOWN state).
·     Ethernet interfaces configured with the port up-mode command.
The speed, duplex, and shutdown commands cannot be configured on an Ethernet interface in a loopback test.
# Enable internal loopback testing on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] loopback internal
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to disable multicast storm suppression.
Ethernet interfaces do not suppress multicast traffic.
ratio: Sets the multicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less multicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The multicast storm suppression feature limits the size of multicast traffic to a threshold on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the multicast-suppression command can suppress multicast storms on a port. The multicast-suppression command uses the chip to physically suppress multicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress multicast traffic.
For the traffic suppression result to be determined, do not configure both the storm-constrain multicast command and the multicast-suppression command on an interface.
# Set the multicast storm suppression threshold to 10000 kbps on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] multicast-suppression kbps 10000
unicast-suppression
port fec mode
Use port fec mode to set the forward error correction (FEC) mode of an interface.
Use undo port fec mode to restore the default.
port fec mode { auto | base-r | none | rs-fec }
undo port fec mode
The FEC mode of an interface is autonegotiation.
25-GE interface view
auto: Specifies the FEC autonegotiation mode.
base-r: Specifies the BASE-R FEC mode.
none: Performs no FEC.
rs-fec: Specifies the RS-FEC mode.
The FEC feature corrects packet errors to improve transmission quality. It attaches correction information to a packet at the sending end, and corrects error codes generated during transmission at the receiving end based on the correction information. You can set the FEC mode as needed.
Make sure you set the same FEC mode for both interfaces of a link.
# Set the FEC mode of Twenty-FiveGigE 1/0/1 to autonegotiation.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] port fec mode auto
Use port ifmonitor crc-error to configure CRC error packet alarm parameters for an interface.
Use undo port ifmonitor crc-error to restore the default.
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds.
ratio: Specifies the alarm thresholds in percentage. If you do not specify this keyword, you configure the alarm thresholds in absolute value.
high-threshold high-value: Specifies the upper threshold for CRC error packet alarms. If you specify the ratio keyword, the value range is 1 to 100. If you do not specify the ratio keyword, the value range is 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for CRC error packet alarms. If you specify the ratio keyword, the value range is 1 to 100. If you do not specify the ratio keyword, the value range is 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for CRC error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming CRC error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming CRC error packets exceeds the upper threshold on the interface.
With the CRC error packet alarm function enabled, when the number of incoming CRC error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming CRC error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
When you execute this command multiple times, the most recent configuration takes effect.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for CRC error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
snmp-agent trap enable ifmonitor
port ifmonitor input-error
Use port ifmonitor input-error to configure input error packet alarm parameters for an interface.
Use undo port ifmonitor input-error to restore the default.
high-threshold high-value: Specifies the upper threshold for input error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for input error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for input error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of input error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of input error packets exceeds the upper threshold on the interface.
With the input error packet alarm function enabled, when the number of input error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of input error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for input error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor output-error
Use port ifmonitor output-error to configure output error packet alarm parameters for an interface.
Use undo port ifmonitor output-error to restore the default.
high-threshold high-value: Specifies the upper threshold for output error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for output error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for output error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of output error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of output error packets exceeds the upper threshold on the interface.
With the output error packet alarm function enabled, when the number of output error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of output error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for output error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
Use port link-flap protect enable to enable link flapping protection on an interface.
Use undo port link-flap protect enable to disable link flapping protection on an interface.
port link-flap protect enable [ interval interval | threshold threshold ] *
undo port link-flap protect enable [ interval | threshold ]
interval: Specifies the link flapping detection interval in seconds. The value range for this argument is 10 to 60. The default value for this argument is 10.
threshold: Specifies the link flapping detection threshold in the range of 5 to 10. The default value for this argument is 5.
If you do not specify the interval interval or threshold threshold option when you execute the port link-flap protect enable command, the command uses the default settings.
If you specify the interval or threshold keyword when you execute the undo port link-flap protect enable command, the command restores the default setting for the keyword.
To bring up an interface that has been shut down by link flapping protection, execute the undo shutdown command.
This command, the dampening command, and the link-delay command are mutually exclusive on an Ethernet interface.
# Enable link flapping protection on an interface. Set the link flapping detection interval to 10 seconds, and set the link flapping detection threshold to 5.
[Sysname-HundredGigE 1/0/1] port link-flap protect enable interval 10 threshold 5
dampening
link-delay
port link-mode
Use port link-mode to change the link mode of an Ethernet interface.
Use undo port link-mode to restore the default.
undo port link-mode
Interfaces operate in bridge mode.
bridge: Specifies the Layer 2 mode.
route: Specifies the Layer 3 mode.
Interfaces on the device can operate either as Layer 2 or Layer 3 Ethernet interfaces.
You can use commands to set the link mode to bridge or route.
Changing the link mode of an Ethernet interface also restores all commands (except speed, shutdown) on the Ethernet interface to their defaults in the new link mode.
# Configure HundredGigE 1/0/1 to operate in Layer 2 mode.
[Sysname-HundredGigE1/0/1] port link-mode bridge
port training
Use port training to configure link compensation on an interface.
Use undo port training to restore the default.
port training { disable | enable }
undo port training
Link compensation is disabled on an interface.
disable: Disables link compensation.
enable: Enables link compensation.
Link compensation enables the sending and receiving ends to exchange pre-emphasis and equalization parameters through frames. This feature improves the performance of pre-emphasis and equalization.
Only 25-GE Ethernet interfaces connected through copper cables support this command. For 25-GE interfaces connected through copper cables to operate properly, you must enable link compensation.
You must enable or disable link compensation on both interfaces of a link.
Typically, the link compensation status is controlled by the software, and do not adjust the link compensation status as a best practice. Use this command to adjust the link compensation status only when the interface cannot come up.
# Enable link compensation on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] port training enable
port up-mode
Use port up-mode to forcibly bring up a fiber Ethernet port.
Use undo port up-mode to restore the default.
port up-mode
undo port up-mode
A fiber Ethernet port is not forcibly brought up. The physical state of a fiber port depends on the physical state of the fibers.
This command forcibly brings up a fiber Ethernet port and enables the port to forward packets unidirectionally over a single link. In this way, transmission links are well utilized.
The following operations on a fiber port will cause link updown events before the port finally stays up:
·     Configure both the port up-mode command and the speed or duplex command.
·     Install or remove fiber links or transceiver modules after you forcibly bring up the fiber port.
The shutdown and port up-mode commands are mutually exclusive.
A fiber Ethernet port does not support this command if the port is shut down by a protocol or by using the shutdown command.
A fiber Ethernet port does not support this command if the port joins an aggregation group.
# Forcibly bring up fiber port HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] port up-mode
priority-flow-control (Ethernet interface view)
Use priority-flow-control to enable PFC on an Ethernet interface.
Use undo priority-flow-control to disable PFC on an Ethernet interface.
priority-flow-control enable
PFC is disabled on an Ethernet interface.
enable: Forcibly enables PFC.
The local device notifies the remote end to stop sending packets carrying the specified 802.1p priority if all of the following conditions exist:
·     Both the local end and the remote end have PFC enabled.
·     Both the local end and the remote end have the priority-flow-control no-drop dot1p command configured.
·     The specified 802.1p priority is in the 802.1p priority list specified by the dot1p-list argument.
·     The local end receives packets carrying the specified 802.1p priority, and the received packets cause congestion.
When congestion is eliminated, the local end notifies the remote end to continue to send packets carrying the specified 802.1p priority. In this way, the local device can forward packets carrying 802.1p priorities in the specified 802.1p priority list without packet drops.
If you execute this command in system view and Ethernet interface view multiple times, the most recent configuration takes effect.
# Enable PFC on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] priority-flow-control enable
priority-flow-control (system view)
Use priority-flow-control to enable PFC on all Ethernet interfaces.
Use undo priority-flow-control to disable PFC on all Ethernet interfaces.
PFC is disabled on Ethernet interfaces.
# Enable PFC on all Ethernet interfaces.
[Sysname] priority-flow-control enable
priority-flow-control deadlock auto-recover action
Use priority-flow-control deadlock auto-recover action to configure the action to take on packets during the delay timer period for PFC deadlock detection automatic recovery.
Use undo priority-flow-control deadlock auto-recover action to restore the default.
priority-flow-control deadlock auto-recover action { discard | forwarding }
The device forwards received data packets during the delay timer period for PFC deadlock detection automatic recovery.
discard: Drops the received data packets.
forwarding: Forwards the received data packets.
This command is not supported on devices in PFC deadlock state.
# Configure the device to drop received data packets during the delay timer period for PFC deadlock detection automatic recovery.
[Sysname] priority-flow-control deadlock auto-recover action discard
priority-flow-control deadlock cos
priority-flow-control deadlock enable
priority-flow-control deadlock auto-recover cos
Use priority-flow-control deadlock auto-recover cos to configure the delay timer for PFC deadlock detection automatic recovery.
Use undo priority-flow-control deadlock auto-recover cos to delete the delay timer for PFC deadlock detection automatic recovery.
In standalone mode:
priority-flow-control deadlock auto-recover slot slot-number cos cos-value delay delay-time
undo priority-flow-control deadlock auto-recover slot slot-number cos [ cos-value ]
In IRF mode:
priority-flow-control deadlock auto-recover chassis chassis-number slot slot-number cos cos-value delay delay-time
undo priority-flow-control deadlock auto-recover chassis chassis-number slot slot-number cos [ cos-value ]
The delay timer for PFC deadlock detection automatic recovery is not configured.
cos cos-value: Specifies the CoS value of packets, in the range of 0 to 7. Different CoS values correspond to different 802.1p priority values. To see the CoS-to-802.1p mapping, execute the display qos map-table dot1p-lp command.
delay delay-time: Specifies the delay timer for PFC deadlock detection automatic recovery in the range of 1 to 15.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
PFC deadlock detection periodically detects whether deadlock occurs to packets carrying the specified CoS value. If the device enters the PFC deadlock state and PFC deadlock detection is recovered in automatic mode, the device automatically recovers PFC deadlock detection after the delay timer expires. The delay timer is determined by this command and the PFC deadlock detection timer precision.
This command takes effect only in automatic recovery mode. This command is not supported on devices in PFC deadlock state.
The specified CoS value must be within the 802.1p priority values configured by using the priority-flow-control no-drop dot1p command.
You can set the same delay timer for different CoS values.
If you execute this command multiple times for the same CoS value, the most recent configuration takes effect.
# Set the delay timer for PFC deadlock detection automatic recovery to 5 for packets carrying CoS value 7.
[Sysname] priority-flow-control deadlock auto-recover cos 7 delay 5
display qos map-table dot1p-lp (ACL and QoS Command Reference)
priority-flow-control deadlock precision
Use priority-flow-control deadlock cos to set the PFC deadlock detection interval for the specified CoS value.
Use undo priority-flow-control deadlock cos to delete the PFC deadlock detection interval for the specified CoS value or all CoS values.
In standalone mode:
priority-flow-control deadlock slot slot-number cos cos-value interval interval
undo priority-flow-control deadlock slot slot-number cos [ cos-value ]
In IRF mode:
priority-flow-control deadlock chassis chassis-number slot slot-number cos cos-value interval interval
undo priority-flow-control deadlock chassis chassis-number slot slot-number cos [ cos-value ]
The PFC deadlock detection interval for a CoS value is not set.
interval interval: Specifies the PFC deadlock detection interval in the range of 1 to 15.
The PFC deadlock detection feature periodically detects whether deadlock occurs to packets that carry the specified CoS value. To obtain the length of time for the detection interval, multiply the detection interval by the precision of the PFC deadlock detection timer.
The specified CoS value must be within the 802.1p priority list specified by using the priority-flow-control no-drop dot1p command. To view the 802.1p priority for each CoS value, execute the display qos map-table dot1p-lp command.
You can set the same detection interval for different CoS values.
If you execute this command for the same CoS value multiple times, the most recent configuration takes effect.
# (In standalone mode.) Set the PFC deadlock detection interval to 5 for packets carrying CoS value 7 on slot 1.
[Sysname] priority-flow-control deadlock slot 1 cos 7 interval 5
Use priority-flow-control deadlock enable to enable PFC deadlock detection on an interface.
Use undo priority-flow-control deadlock enable to disable PFC deadlock detection on an interface.
PFC deadlock detection is disabled on an interface.
The device enters the PFC deadlock state if the following conditions exist on an interface:
·     PFC for 802.1p priorities is enabled by using the priority-flow-control and priority-flow-control no-drop dot1p commands.
·     Packets carrying the specified 802.1p priority are transmitted in a loop.
·     No packets in the data buffer can be forwarded.
This command enables periodically detecting whether the device is in PFC deadlock state.
# Enable PFC deadlock detection on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] priority-flow-control deadlock enable
Use priority-flow-control deadlock precision to set the precision for the PFC deadlock detection timer.
Use undo priority-flow-control deadlock precision to restore the default.
In standalone mode:
priority-flow-control deadlock slot slot-number precision { high | low | normal }
undo priority-flow-control deadlock slot slot-number precision
In IRF mode:
priority-flow-control deadlock chassis chassis-number slot slot-number precision { high | low | normal }
undo priority-flow-control deadlock chassis chassis-number slot slot-number precision
The PFC deadlock detection timer uses normal precision.
high: Specifies the high precision for the PFC deadlock detection timer.
low: Specifies the low precision for the PFC deadlock detection timer. This keyword is not supported in the current software version.
normal: Specifies the normal precision for the PFC deadlock detection timer.
Use this command to adjust the precision for the PFC deadlock detection timer and change the PFC deadlock detection interval. For the PFC deadlock detection timer of the device, the high precision represents 10 ms and the normal precision represents 100 ms.
# (In standalone mode.) Set the high precision for the PFC deadlock detection timer on slot 1.
[Sysname] priority-flow-control deadlock slot 1 precision high
priority-flow-control deadlock recover
Use priority-flow-control deadlock recover to recover PFC deadlock detection on an interface.
Before executing this command, you must use the priority-flow-control deadlock recover-mode command to set the recovery mode for PFC deadlock detection.
The device can automatically release the deadlock state, but both the PFC deadlock detection and PFC features are disabled on the interface at the same time. To manually recover PFC deadlock detection on the interface, execute this command after setting the manual recovery mode for PFC deadlock detection on the interface. The PFC feature is also enabled again when you execute this command.
# Recover PFC deadlock detection on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] priority-flow-control deadlock recover
Use priority-flow-control deadlock recover-mode to set the recovery mode for PFC deadlock detection on an interface.
Use undo priority-flow-control deadlock recover-mode to restore the default.
priority-flow-control deadlock recover-mode { auto | manual }
PFC deadlock detection recovers in automatic mode on an interface.
auto: Specifies the automatic recovery mode.
manual: Specifies the manual recovery mode.
When the PFC deadlock state is detected and PFC deadlock detection is recovered in automatic mode, the device automatically releases the deadlock state and recovers PFC and PFC deadlock detection after the delay timer expires. Within the delay timer period, the device disables PFC and PFC deadlock detection on the interface, so that packets can be forwarded properly. PFC deadlock detection can be recovered in automatic or manual mode on the interface. Recovering this feature enables the PFC feature again at the same time. Use the automatic recovery mode when no serious failures occur.
When a packet loop cannot be resolved and the device enters the PFC deadlock state frequently, manually recover PFC deadlock detection on the interface as follows:
1.     Perform troubleshooting and set the manual recovery mode for PFC deadlock detection.
2.     Execute the priority-flow-control deadlock recover command to recover the PFC deadlock detection and PFC features.
# Set the manual recovery mode for PFC deadlock detection on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] priority-flow-control deadlock recover-mode manual
priority-flow-control deadlock threshold
Use priority-flow-control deadlock threshold to configure the upper threshold for PFC deadlock times within the specified period.
Use undo priority-flow-control deadlock threshold to restore the default.
In standalone mode:
priority-flow-control deadlock threshold slot slot-number cos cos-value period period count count
undo priority-flow-control deadlock threshold slot slot-number cos [ cos-value ]
In IRF mode:
priority-flow-control deadlock threshold chassis chassis-number slot slot-number cos cos-value period period count count
undo priority-flow-control deadlock threshold chassis chassis-number slot slot-number cos [ cos-value ]
The upper threshold for PFC deadlock times within the specified period is not configured.
period period: Specifies the period for detecting PFC deadlock times, in the range of 1 to 60 seconds.
count count: Specifies the upper threshold for PFC deadlock times within the specified period, in the range of 1 to 500.
With this command configured, when the PFC deadlock times within the specified period exceed the upper threshold on an interface, the device disables PFC for the corresponding 802.1p priority on the interface. To recover the PFC feature on the interface in this case, execute the undo priority-flow-control deadlock threshold command.
The detection period specified in this command must be longer than the PFC deadlock detection interval configured by using the priority-flow-control deadlock cos command, so that you can determine whether the device frequently enters the PFC deadlock state.
You can set the same detection period for different CoS values.
# Set the upper threshold for PFC deadlock times to 100 within the period of 5 seconds.
[Sysname] priority-flow-control deadlock threshold cos 7 period 5 count 100
priority-flow-control dot1p headroom
Use priority-flow-control dot1p headroom to set the headroom buffer threshold.
Use undo priority-flow-control dot1p headroom to restore the default.
priority-flow-control dot1p dot1p headroom headroom-number
undo priority-flow-control dot1p dot1p headroom
The headroom buffer threshold is 8192.
dot1p: Specifies an 802.1p priority in the range of 0 to 7.
headroom-number: Specifies the headroom buffer threshold in the range of 1 to 131072.
Before executing this command, you must use the priority-flow-control no-drop dot1p command to enable PFC for the specified 802.1p priority.
If you execute this command multiple times for the same 802.1p priority, the most recent configuration takes effect.
When two directly connected interfaces transmit data, the buffers of interfaces are used for buffering received data. A longer transmission distances needs a large buffer size. You can use this command to set the headroom buffer threshold to implement zero packet loss.
·     For a 100-GE interface:
¡     When the transmission distance is 300 meters, you only need to execute the priority-flow-control no-drop dot1p command on the interface. This command automatically sets the default headroom buffer threshold, which is adequate for implementing zero packet loss for the transmission distance.
¡     When the transmission distance is 10000 meters, you must use the priority-flow-control dot1p headroom command on the interface to set the headroom buffer threshold. As a best practice, set the headroom buffer threshold to 9984. You can adjust the threshold as needed to ensure zero packet loss for the transmission distance.
¡     When the transmission distance is longer than 10000 meters, the device series does not support transceiver modules with the transmission distance in the current software version.
·     For a non-100-GE interface:
¡     When the transmission distance is 300, 10000, or 20000 meters, you only need to execute the priority-flow-control no-drop dot1p command on the interface. This command automatically sets the default headroom buffer threshold, which is adequate for implementing zero packet loss for the transmission distance.
¡     When the transmission distance is 40000 meters, you must use the priority-flow-control dot1p headroom command on the interface to set the headroom buffer threshold. As a best practice, set the headroom buffer threshold to 9984. You can adjust the threshold as needed to ensure zero packet loss for the transmission distance.
# Set the headroom buffer threshold to 1000 for 802.1p priority 1 on HundredGigE 1/0/1.
<sysname> system-view
[Sysname-HundredGigE1/0/1] priority-flow-control dot1p 1 headroom 1000
priority-flow-control dot1p ingress-buffer dynamic
Use priority-flow-control dot1p ingress-buffer dynamic to set the dynamic back pressure frame triggering threshold.
Use undo priority-flow-control dot1p ingress-buffer to restore the default.
priority-flow-control dot1p dot1p ingress-buffer dynamic ratio
undo priority-flow-control dot1p dot1p ingress-buffer
No dynamic back pressure frame triggering thresholds are set.
ratio: Specifies the dynamic back pressure frame triggering threshold in percentage. The value range for this argument is 1 to 100.
# Set the dynamic back pressure frame triggering threshold to 30 for 802.1p priority 1 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] priority-flow-control dot1p 1 ingress-buffer dynamic 30
priority-flow-control dot1p ingress-buffer static
Use priority-flow-control dot1p ingress-buffer static to set the static back pressure frame triggering threshold.
priority-flow-control dot1p dot1p ingress-buffer static threshold
The static back pressure frame triggering threshold is 512.
dot1p-list: Specifies an 802.1p priority in the range of 0 to 7.
threshold: Specifies the static back pressure frame triggering threshold in the range of 1 to 131072.
If you execute this command for the same 802.1p priority multiple times, the most recent configuration takes effect.
# Set the static back pressure frame triggering threshold to 1000 for 802.1p priority 1 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] priority-flow-control dot1p 1 ingress-buffer static 1000
priority-flow-control dot1p ingress-threshold-offset
Use priority-flow-control dot1p ingress-threshold-offset to set the offset between the back pressure frame stopping threshold and triggering threshold.
Use undo priority-flow-control dot1p ingress-threshold-offset to restore the default.
priority-flow-control dot1p dot1p ingress-threshold-offset offset-number
undo priority-flow-control dot1p dot1p ingress-threshold-offset
The offset between the back pressure frame stopping threshold and triggering threshold is 48.
offset-number: Specifies the offset between the back pressure frame stopping threshold and triggering threshold in the range of 1 to 131072.
# Set the offset between the back pressure frame stopping threshold and triggering threshold to 1000 for 802.1p priority 1 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] priority-flow-control dot1p 1 ingress-threshold-offset 1000
priority-flow-control dot1p reserved-buffer
Use priority-flow-control dot1p reserved-buffer to set the PFC reserved threshold.
Use undo priority-flow-control dot1p reserved-buffer to restore the default.
priority-flow-control dot1p dot1p reserved-buffer reserved-number
undo priority-flow-control dot1p dot1p reserved-buffer
The PFC reserved threshold is 6.
reserved-number: Specifies the PFC reserved threshold in the range of 1 to 131072.
# Set the PFC reserved threshold to 1000 for 802.1p priority 1 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] priority-flow-control dot1p 1 reserved-buffer 1000
priority-flow-control early-warning inpps
Use priority-flow-control early-warning inpps to configure the early warning threshold for incoming PFC packets.
Use undo priority-flow-control early-warning inpps to delete the early warning threshold for incoming PFC packets.
priority-flow-control early-warning dot1p dot1p-list inpps pps-value
undo priority-flow-control early-warning [ dot1p dot1p-list ] inpps
No early warning threshold is configured for incoming PFC packets.
dot1p-list: Specifies an 802.1p priority (or dot1p priority) list to identify flows that are subject to PFC (for example: 1,3-5). A hyphen (-) connects two numeric values, which together indicate a continuous value range. Different values or value ranges are separated with commas (,). You can configure up to 16 characters for this argument.
inpps pps-value: Specifies the number of PFC frames that an interface can receive in pps. The value range for this argument is 1 to 159783010.
You can configure the early warning threshold for incoming or outgoing PFC packets of an interface as needed. The early warning threshold notifies a situation where the PFC packet transmission rate is still within a normal range but needs attention.
When the rate of PFC packets that an interface sends or receives reaches the early warning threshold, the system generates traps and logs to notify the user. According to the traps and logs, the user can discover some exceptions in the network, for example:
·     The NIC of the peer device fails and continuously sends PFC packets at a high speed. In this case, you can set the early warning threshold for incoming PFC packets.
·     The device fails and continuously sends PFC frames. In this case, you can set the early warning threshold for outgoing PFC packets.
To monitor bidirectional PFC packets, you can set the early warning thresholds for incoming packets and outgoing packets separately.
The number of PFC pause frames that an interface receives is counted and the early warning threshold configuration takes effect only when PFC is enabled.
# Set the early warning threshold to 80 pps for incoming PFC packets with 802.1p priority value 7 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] priority-flow-control early-warning dot1p 7 inpps 80
priority-flow-control early-warning outpps
Use priority-flow-control early-warning outpps to configure the early warning threshold for outgoing PFC packets.
Use undo priority-flow-control early-warning outpps to delete the early warning threshold for outgoing PFC packets.
priority-flow-control early-warning dot1p dot1p-list outpps pps-value
undo priority-flow-control early-warning [ dot1p dot1p-list ] outpps
No early warning threshold is configured for outgoing PFC packets.
outpps pps-value: Specifies the number of PFC frames that an interface can send in pps. The value range for this argument is 1 to 159783010.
The number of PFC pause frames that an interface sends is counted and the early warning threshold configuration takes effect only when PFC is enabled.
# Set the early warning threshold to 50 pps for outgoing PFC packets with 802.1p priority value 1 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] priority-flow-control early-warning dot1p 1 outpps 50
priority-flow-control inner-port enable
Use priority-flow-control inner-port enable to enable PFC on inner interfaces.
Use undo priority-flow-control inner-port enable to disable PFC on inner interfaces.
PFC is disabled on inner interfaces.
An inner interface is the inner Ethernet interface through which a card communicates with the device, and is invisible for users.
With PFC enabled on an inner interface, when the traffic from an LPU to a switching fabric module is congested, the inner interface on the switching fabric module sends PFC pause frames to the inner interface on the LPU to notify the LPU to stop sending packets to the switching fabric module. When congestion is eliminated, the inner interface on the switching fabric module notifies the LPU to continue to send packets to the switching fabric module. This rule also applies to the traffic from a switching fabric module to an LPU.
# Enable PFC on inner interfaces.
[Sysname] priority-flow-control inner-port enable
priority-flow-control inner-port no-drop
Use priority-flow-control inner-port no-drop to enable PFC for 802.1p priorities on inner interfaces.
Use undo priority-flow-control inner-port no-drop to disable PFC for 802.1p priorities on inner interfaces.
priority-flow-control inner-port no-drop dot1p dot1p-list
undo priority-flow-control inner-port no-drop dot1p dot1p-list
PFC is disabled for all 802.1p priorities on inner interfaces.
With PFC enabled and this command configured on inner interfaces, when an inner interface is congested, the inner interface will send PFC pause frames to notify the peer inner interface to stop sending packets carrying the specified 802.1p priorities to prevent these packets from being dropped due to congestion. For more information about 802.1p priorities, see ACL and QoS Configuration Guide.
# Enable PFC for 802.1p priority 1 on inner interfaces.
[Sysname] priority-flow-control inner-port no-drop dot1p 1
priority-flow-control no-drop dot1p (Ethernet interface view)
Use priority-flow-control no-drop dot1p to enable PFC for 802.1p priorities on an Ethernet interface.
Use undo priority-flow-control no-drop dot1p to disable PFC for 802.1p priorities on an Ethernet interface.
priority-flow-control no-drop dot1p dot1p-list
PFC is disabled for all 802.1p priorities on an Ethernet interface.
When congestion is eliminated, the local end notifies the remote end to continue to send packets carrying the specified 802.1p priority. In this way, the local device can forward packets carrying 802.1p priorities in the specified 802.1p priority list without packet drops. For more information about the 802.1p priority, see ACL and QoS Configuration Guide.
This command, the flow-control command, and the flow-control receive enable command are mutually exclusive.
# Enable PFC in auto mode on HundredGigE 1/0/1, and enable PFC for 802.1p priority 5.
[Sysname-HundredGigE1/0/1] priority-flow-control auto
[Sysname-HundredGigE1/0/1] priority-flow-control no-drop dot1p 5
flow-control
priority-flow-control no-drop dot1p (system view)
Use priority-flow-control no-drop dot1p to enable PFC for 802.1p priorities on all Ethernet interfaces.
Use undo priority-flow-control no-drop dot1p to disable PFC for 802.1p priorities on all Ethernet interfaces.
PFC is disabled for all 802.1p priorities on all Ethernet interfaces.
# Enable PFC for 802.1p priority 5 globally.
[Sysname] priority-flow-control no-drop dot1p 5
priority-flow-control poolID headroom
Use priority-flow-control poolID headroom to set the maximum number of cell resources that can be used in a headroom storage space.
Use undo priority-flow-control poolID headroom to restore the default.
priority-flow-control poolID pool-number headroom headroom-number
undo priority-flow-control poolID pool-number headroom
The maximum number of cell resources that can be used in a headroom storage space is 12288.
pool-number: Specifies a headroom storage space by its number in the range of 0 to 3.
headroom-number: Specifies the maximum number of cell resources, in the range of 1 to 131072.
# Set the headroom buffer threshold to 1000 for headroom storage space 1.
[Sysname] priority-flow-control poolID 1 headroom 1000
reset counters interface
Use reset counters interface to clear the interface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify an interface type, this command clears statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command clears statistics for all interfaces of the specified type.
# Clear the statistics for HundredGigE 1/0/1.
<Sysname> reset counters interface hundredgige 1/0/1
display counters interface
display counters rate interface
display interface
reset ethernet statistics
Use reset ethernet statistics to clear the Ethernet module statistics.
In standalone mode:
reset ethernet statistics [ slot slot-number ]
In IRF mode:
reset ethernet statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears statistics for all cards of all IRF member devices. (In IRF mode.)
# (In standalone mode.) Clear the Ethernet module statistics for the specified slot.
<Sysname> reset ethernet statistics slot 1
display ethernet statistics
reset packet-drop interface
Use reset packet-drop interface to clear the dropped packet statistics for an interface.
reset packet-drop interface [ interface-type [ interface-number ] ]
interface-type: Specify an interface type.
interface-number: Specify an interface number.
If you do not specify an interface type, this command clears dropped packet statistics for all interfaces on the device.
If you specify an interface type but do not specify an interface number, the command clears dropped packet statistics for all interfaces of the specified type.
# Clear dropped packet statistics for HundredGigE 1/0/1.
<Sysname> reset packet-drop interface hundredgige 1/0/1
# Clear dropped packet statistics for all interfaces.
display packet-drop
shutdown
Use shutdown to shut down an Ethernet interface or subinterface.
Use undo shutdown to bring up an Ethernet interface or subinterface.
shutdown
Ethernet interfaces are in down state and Ethernet subinterfaces are in up state.
Ethernet subinterface view
Some interface configurations might require an interface restart before taking effect.
The shutdown command cannot be configured on an interface in a loopback test.
# Shut down and then bring up HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] shutdown
[Sysname-HundredGigE1/0/1] undo shutdown
# Shut down and then bring up HundredGigE 1/0/1.1.
[Sysname] interface hundredgige 1/0/1.1
[Sysname-HundredGigE1/0/1.1] shutdown
[Sysname-HundredGigE1/0/1.1] undo shutdown
Use snmp-agent trap enable ifmonitor to enable interface alarm functions.
Use undo snmp-agent trap enable ifmonitor to disable interface alarm functions.
snmp-agent trap enable ifmonitor { crc-error | input-error | output-error } *
undo snmp-agent trap enable ifmonitor { crc-error | input-error | output-error } *
Interface alarm functions are enabled.
crc-error: Enables the CRC error packet alarm function for interfaces.
input-error: Enables the input error packet alarm function for interfaces.
output-error: Enables the output error packet alarm function for interfaces.
# Enable the CRC error packet alarm function for interfaces.
[Sysname] snmp-agent trap enable ifmonitor crc-error
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10 | 100 | 1000 | 10000 | 25000 | 40000 | 100000 | auto }
undo speed
An Ethernet interface negotiates a speed with its peer.
10: Sets the interface speed to 10 Mbps.
100: Sets the interface speed to 100 Mbps.
1000: Sets the interface speed to 1000 Mbps.
10000: Sets the interface speed to 10000 Mbps.
25000: Sets the interface speed to 25000 Mbps.
40000: Sets the interface speed to 40000 Mbps.
100000: Sets the interface speed to 100000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module.
Support of an interface for the keywords depends on the interface type. For more information, use the speed ? command in interface view.
# Configure HundredGigE 1/0/1 to autonegotiate the speed.
[Sysname-HundredGigE1/0/1] speed auto
unicast-suppression
Use unicast-suppression to enable unknown unicast storm suppression and set the unknown unicast storm suppression threshold.
Use undo unicast-suppression to disable unknown unicast storm suppression.
Ethernet interfaces do not suppress unknown unicast traffic.
ratio: Sets the unknown unicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less unknown unicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of unknown unicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of unknown unicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The unknown unicast storm suppression feature limits the size of unknown unicast traffic to a threshold on an interface. When the unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the unknown unicast traffic drops below this threshold.
Both the storm-constrain command and the unicast-suppression command can suppress unknown unicast storms on a port. The unicast-suppression command uses the chip to physically suppress unknown unicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress unknown unicast traffic.
For the unknown unicast traffic suppression result to be determined, do not configure both the storm-constrain unicast command and the unicast-suppression command on an interface.
When you configure the suppression threshold in kbps, the actual suppression threshold might be different from the configured one as follows:
·     If the configured value is smaller than 64, the value of 64 takes effect.
·     If the configured value is greater than 64 but not an integer multiple of 64, the integer multiple of 64 that is greater than and closest to the configured value takes effect.
For the suppression threshold that takes effect, see the prompt on the device.
Set the same type of thresholds for each interface.
# Set the unknown unicast storm suppression threshold to 10000 kbps on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] unicast-suppression kbps 10000
The actual value is 10048 on port HundredGigE1/0/1 currently.
The output shows that the value that takes effect is 10048 kbps (157 times of 64), because the chip only supports step 64.
broadcast-suppression
using hundredgige
Use using hundredgige to combine 10-GE or 25-GE breakout interfaces split from a 100-GE interface into a 100-GE interface.
using hundredgige
The 10-GE or 25-GE breakout interfaces are not combined and operate as single interfaces.
10-GE breakout interface view
25-GE breakout interface view
If you need higher bandwidth on a single interface, perform the following tasks as needed:
·     After a 100-GE interface has a split-capable 40-GE transceiver module or cable installed, you can combine the four 10-GE breakout interfaces into a 100-GE interface. To do so, execute this command on any of these 10-GE breakout interfaces.
·     You can combine four 25-GE breakout interfaces split from a 100-GE interface into a 100-GE interface. To do so, execute this command on any of these 25-GE breakout interfaces.
Device reboot is not required for this command to take effect. You can view the split or combined interface by using the display interface brief command.
When interfaces are being split or combined, you cannot reboot the MPU or perform active/standby MPU switchover.
# Combine Ten-GigabitEthernet 1/0/1:1 through Ten-GigabitEthernet 1/0/1:4 into an interface.
[Sysname] interface ten-gigabitethernet 1/0/1:1
[Sysname-Ten-GigabitEthernet1/0/1:1]using hundredgige
The interfaces Ten-GigabitEthernet1/0/1:1 through Ten-GigabitEthernet1/0/1:10 will be deleted. Continue? [Y/N]:y
# Combine Twenty-FiveGigE 1/0/1:1 through Twenty-FiveGigE 1/0/1:4 into a 100-GE interface.
[Sysname] interface twenty-fivegige 1/0/1:1
[Sysname-Twenty-FiveGigE1/0/1:1] using hundredgige
The interfaces Twenty-FiveGigE 1/0/1:1 through Twenty-FiveGigE 1/0/1:4 will be deleted. Continue? [Y/N]:y
using tengige
using twenty-fivegige
using tengige
Use using tengige to split a high bandwidth interface into multiple 10-GE breakout interfaces.
using tengige
A high bandwidth interface is not split and operates as a single interface.
100-GE interface view
To improve port density, reduce costs, and improve network flexibility, you can split a high bandwidth interface into multiple 10-GE breakout interfaces. For example:
·     The 100-GE interface HundredGigE 1/0/1 with a split-capable 40-GE transceiver module or cable installed can be split into four 10-GE breakout interfaces Ten-GigabitEthernet 1/0/1:1 through Ten-GigabitEthernet 1/0/1:4.
# Split HundredGigE 1/0/1 into 10-GE breakout interfaces.
[Sysname-HundredGigE1/0/1] using tengige
The interface HundredGigE1/0/1 will be deleted. Continue? [Y/N]:y
Use using twenty-fivegige to split a 100-GE interface into four 25-GE breakout interfaces.
A 100-GE interface is not split and operates as a single interface.
To improve port density, reduce costs, and improve network flexibility, you can split a 100-GE interface into four 25-GE breakout interfaces. For example, you can split the 100-GE interface HundredGigE 1/0/1 into four 25-GE breakout interfaces Twenty-FiveGigE 1/0/1:1 through Twenty-FiveGigE 1/0/1:4.
# Split HundredGigE 1/0/1 into four 25-GE breakout interfaces.
[Sysname-HundredGigE1/0/1] using twenty-fivegige
using hundredgige
Layer 2 Ethernet interface commands
display storm-constrain
Use display storm-constrain to display storm control settings and statistics.
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
broadcast: Displays broadcast storm control settings and statistics.
multicast: Displays multicast storm control settings and statistics.
unicast: Displays unknown unicast storm control settings and statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays storm control settings and statistics for all storm control-enabled interfaces.
If you do not specify any keywords, this command displays all storm control settings on all storm control-enabled interfaces.
# Display the storm control settings on all storm control-enabled ports.
<Sysname> display storm-constrain
 Abbreviation: BC - broadcast; MC - multicast; UC - unknown unicast;
               FW - forwarding
 Flow Statistic Interval: 5 (in seconds)
Port          Type Lower     Upper     Unit  Mode     Status   Trap Log StateChg
HGE1/0/1      MC   100       200       kbps  shutdown shutdown off  on  10
Table 10 Command output
Traffic polling interval (in seconds) of the storm control module.
Port
Abbreviated interface name.
Type of traffic subjected to storm control:
·     BC—Broadcast packets.
·     MC—Multicast packets.
·     UC—Unknown unicast packets.
·     KNUC—Known unicast packets. This field is not supported in the current software version.
Lower
Lower storm control threshold, in pps, kbps, or percentage.
Upper
Upper storm control threshold, in pps, kbps, or percentage.
Unit
Storm control threshold unit:
·     pps.
·     kbps.
·     percentage.
Mode
Action (block or shutdown) taken on the interface when the upper threshold is reached. N/A indicates that no action is configured.
Status
Packet forwarding status:
·     FW—The port is forwarding traffic correctly.
·     shutdown—The port has been shut down.
·     block—The port drops the type of traffic.
Trap
Status of the storm control threshold event trap switch:
·     on—The port sends threshold event traps.
·     off—The port does not send threshold event traps.
Log
Status of the storm control threshold event log switch:
·     on—The port sends threshold event log messages.
·     off—The port does not send threshold event log messages.
StateChg
Number of forwarding state changes of the interface.
When the StateChg field reaches 65535, it resets automatically.
storm-constrain
Use storm-constrain to enable storm control and set thresholds for broadcast, multicast, or unknown unicast packets on an Ethernet interface.
Use undo storm-constrain to disable storm control for broadcast, multicast, unknown unicast, or all types of traffic.
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
undo storm-constrain { all | broadcast | multicast | unicast }
Traffic storm control is disabled.
all: Disables storm control for all types of traffic: broadcast, multicast, and unknown unicast.
broadcast: Enables or disables broadcast storm control.
multicast: Enables or disables multicast storm control.
unicast: Enables or disables unknown unicast storm control.
pps: Sets storm control thresholds in pps.
kbps: Sets storm control thresholds in kbps.
ratio: Sets storm control thresholds as a percentage of the transmission capacity of the interface.
upperlimit: Sets the upper threshold, in pps, kbps, or percentage.
·     If you specify the pps keyword, the value range for the upperlimit argument is 0 to 1.4881 × the interface bandwidth.
·     If you specify the kbps keyword, the value range for the upperlimit argument is 0 to the interface bandwidth.
·     If you specify the ratio keyword, the value range for the upperlimit argument is 0 to 100.
lowerlimit: Sets the lower threshold, in pps, kbps, or percentage.
·     If you specify the pps keyword, the value range for the lowerlimit argument is 0 to 1.4881 × the interface bandwidth.
·     If you specify the kbps keyword, the value range for the lowerlimit argument is 0 to the interface bandwidth.
·     If you specify the ratio keyword, the value range for the lowerlimit argument is 0 to 100.
After you configure storm control for a type of traffic, the device collects the statistics for the type of traffic at the interval configured by using the storm-constrain interval command. When the type of traffic exceeds its upper threshold, the interface takes an action configured by using the storm-constrain control command.
The storm-constrain, broadcast-suppression, multicast-suppression, and unicast-suppression commands can suppress storms on an interface. The broadcast-suppression, multicast-suppression, and unicast-suppression commands use the chip to physically suppress traffic. They have less influence on the device performance than the storm-constrain command, which uses software to suppress traffic.
For the traffic suppression result to be determined, do not configure both storm control and storm suppression for the same type of traffic.
When configuring this command, make sure upperlimit is greater than lowerlimit.
# Enable unknown unicast storm control on HundredGigE 1/0/1 and set the upper and lower thresholds to 200 pps and 150 pps, respectively.
[Sysname-HundredGigE1/0/1] storm-constrain unicast pps 200 150
# Enable broadcast storm control on HundredGigE 1/0/2, and set the upper and lower thresholds to 2000 kbps and 1500 kbps, respectively.
[Sysname] interface hundredgige 1/0/2
[Sysname-HundredGigE1/0/2] storm-constrain broadcast kbps 2000 1500
# Enable multicast storm control on HundredGigE 1/0/3, and set the upper and lower thresholds to 80% and 15%, respectively.
[Sysname] interface hundredgige 1/0/3
[Sysname-HundredGigE1/0/3] storm-constrain multicast ratio 80 15
Use storm-constrain control to set the action to take on an Ethernet interface when a type of traffic (unknown unicast, multicast, or broadcast) exceeds the upper storm control threshold.
Use undo storm-constrain control to restore the default.
No action is taken on an Ethernet interface when a type of traffic exceeds the upper storm control threshold.
block: Blocks this type of traffic and forwards other types of traffic. Even though the interface does not forward the blocked traffic, it still counts the traffic. When the blocked traffic drops below the lower threshold, the port begins to forward the traffic.
shutdown: Goes down automatically. The interface goes down automatically and stops forwarding any traffic. When the blocked traffic drops below the lower threshold, the interface does not forward the traffic. To bring up the interface, use the undo shutdown command or disable storm control on the interface.
# Configure HundredGigE 1/0/1 to block a specific type of traffic when the type of traffic exceeds the upper storm control threshold.
[Sysname-HundredGigE1/0/1] storm-constrain control block
storm-constrain
storm-constrain enable log
Use storm-constrain enable log to enable an Ethernet interface to output log messages when it detects storm control threshold events.
Use undo storm-constrain enable log to disable an Ethernet interface from outputting log messages for storm control threshold events.
An Ethernet interface outputs log messages when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
# Enable HundredGigE 1/0/1 to output log messages when it detects storm control threshold events.
[Sysname-HundredGigE1/0/1] storm-constrain enable log
storm-constrain enable trap
Use storm-constrain enable trap to enable an Ethernet interface to send storm control threshold event traps.
Use undo storm-constrain enable trap to disable an Ethernet interface from sending storm control threshold event traps.
An interface sends out storm control threshold event traps when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
# Enable HundredGigE 1/0/1 to send traps when it detects storm control threshold events.
[Sysname-HundredGigE1/0/1] storm-constrain enable trap
Use storm-constrain interval to set the traffic polling interval of the storm control module.
Use undo storm-constrain interval to restore the default.
storm-constrain interval interval
The storm control module polls traffic statistics every 10 seconds.
interval: Sets the traffic polling interval of the storm control module. The value range is 1 to 300 seconds. To ensure network stability, as a best practice, do not use a traffic polling interval shorter than 10 seconds.
The traffic polling interval set by using the storm-constrain interval command is specific to storm control. To set the statistics polling interval of an interface, use the flow-interval command.
# Set the traffic statistics polling interval of the storm control module to 60 seconds.
[Sysname] storm-constrain interval 60
storm-constrain
Layer 3 Ethernet interface or subinterface commands
mac-address
Use mac-address to set the MAC address of an Ethernet interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
No MAC address is set for a Layer 3 Ethernet interface.
mac-address: Specifies a MAC address in the format of H-H-H.
When you set a MAC address for a Layer 3 Ethernet subinterface, select a MAC address different from that of the main interface.
Do not set a VRRP-reserved MAC address for a Layer 3 Ethernet subinterface.
# Set the MAC address of HundredGigE 1/0/1 to 0001-0001-0001.
[Sysname-HundredGigE1/0/1] mac-address 1-1-1
mtu
Use mtu to set the MTU for an Ethernet interface or subinterface.
mtu size
undo mtu
The MTU of an Ethernet interface or subinterface is 1500 bytes.
size: Sets the MTU in bytes. The value range for this argument is 46 to 9008.
The MTU configured on an interface takes effect only on packets sent to the CPU for software forwarding. Configure the MTU as appropriate for interfaces in the network to avoid fragmentation.
If an interface supports both the mtu and ip mtu commands, the device fragments an IPv4 packet based on the MTU set by using the ip mtu command. For more information about the ip mtu command, see Layer 3—IP Services Command Reference.
# Set the MTU to 1430 bytes for HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] mtu 1430
# Set the MTU to 1430 bytes for HundredGigE 1/0/1.1.
[Sysname-HundredGigE1/0/1.1] mtu 1430
