- 10-Security Configuration Guide
- 01-AAA configuration
- 02-802.1X configuration
- 04-Portal configuration
- 05-Port security configuration
- 06-Password control configuration
- 07-Keychain configuration
- 08-Public key management
- 09-PKI configuration
- 10-IPsec configuration
- 11-SSH configuration
- 12-SSL configuration
- 13-Attack detection and prevention configuration
- 14-TCP attack prevention configuration
- 15-IP source guard configuration
- 16-ARP attack protection configuration
- 17-ND attack defense configuration
- 18-uRPF configuration
- 19-MFF configuration
- 20-FIPS configuration
- 21-MACsec configuration
- 22-802.1X client configuration
- 23-Web authentication configuration
- 24-Object group configuration
- 25-Triple authentication configuration
| 04-Portal configuration | 814.28 KB |
Configuring portal authentication
Portal system using the local portal Web server
Interaction between portal system components
MAC-based quick portal authentication
Portal configuration task list
Configuring a portal authentication server
Configuring a portal Web server
Enabling portal authentication
Specifying a portal Web server
Controlling portal user access
Configuring a portal-free rule
Configuring an authentication source subnet
Configuring an authentication destination subnet
Checking the issuing of category-2 portal filtering rules
Setting the maximum number of portal users
Specifying a portal authentication domain
Specifying a preauthentication domain
Specifying a preauthentication IP address pool for portal users
Configuring support of Web proxy for portal authentication
Enabling strict-checking on portal authorization information
Allowing only users with DHCP-assigned IP addresses to pass portal authentication
Configuring portal detection features
Configuring online detection of portal users
Configuring portal authentication server detection
Configuring portal Web server detection
Configuring portal user synchronization
Configuring the portal fail-permit feature
Configuring BAS-IP for unsolicited portal packets sent to the portal authentication server
Configuring the NAS-Port-Type attribute
Specifying a format for the NAS-Port-Id attribute
Logging out online portal users
Applying a NAS-ID profile to an interface
Configuring the local portal Web server feature
Customizing authentication pages
Configuring a local portal Web server
Configuring the Rule ARP or ND entry feature for portal clients
Configuring MAC-based quick portal authentication
Configuring a MAC binding server
Specifying a MAC binding server on an interface
Enabling logging for user logins and logouts
Displaying and maintaining portal
Configuring direct portal authentication
Configuring re-DHCP portal authentication
Configuring cross-subnet portal authentication
Configuring extended direct portal authentication
Configuring extended re-DHCP portal authentication
Configuring extended cross-subnet portal authentication
Configuring portal server detection and portal user synchronization
Configuring cross-subnet portal authentication for MPLS L3VPNs
Configuring direct portal authentication with a preauthentication domain
Configuring re-DHCP portal authentication with a preauthentication domain
Configuring direct portal authentication using local portal Web server
No portal authentication page is pushed for users
Cannot log out portal users on the access device
Cannot log out portal users on the RADIUS server
Users logged out by the access device still exist on the portal authentication server
Re-DHCP portal authenticated users cannot log in successfully
Overview
Portal authentication controls user access to networks. Portal authenticates a user by the username and password the user enters on a portal authentication page. Therefore, portal authentication is also known as Web authentication. When portal authentication is deployed on a network, an access device redirects unauthenticated users to the website provided by a portal Web server. The users can access the resources on the website without authentication. If the users want to access other network resources, they must pass authentication on the website.
Portal authentication is classified into the following types:
· Active authentication—Users visit the authentication website provided by the portal Web server and enter their username and password for authentication.
· Forced authentication—Users are redirected to the portal authentication website for authentication when they visit other websites.
Portal authentication flexibly imposes access control on the access layer and vital data entries. It has the following advantages:
· Allows users to perform authentication through a Web browser without installing client software.
· Provides ISPs with diversified management choices and extended functions. For example, the ISPs can place advertisements, provide community services, and publish information on the authentication page.
· Supports multiple authentication modes. For example, re-DHCP authentication implements a flexible address assignment scheme and saves public IP addresses. Cross-subnet authentication can authenticate users who reside in a different subnet than the access device.
The device supports Portal 1.0, Portal 2.0, and Portal 3.0.
Extended portal functions
By forcing patching and anti-virus policies, extended portal functions help hosts to defend against viruses. Portal supports the following extended functions:
· Security check—Detects after authentication whether or not a user host installs anti-virus software, virus definition file, unauthorized software, and operating system patches.
· Resource access restriction—Allows an authenticated user to access certain network resources such as the virus server and the patch server. Users can access more network resources after passing security check.
Security check must cooperate with the H3C IMC security policy server and the iNode client.
Portal system components
A typical portal system consists of these basic components: authentication client, access device, portal authentication server, portal Web server, AAA server, and security policy server.
Figure 1 Portal system components
Authentication client
An authentication client is a Web browser that runs HTTP/HTTPS or a user host that runs a portal client application. Security check for the user host is implemented through the interaction between the portal client and the security policy server.
Access device
An access device refers to a broadband access device such as a switch or a router. An access device has the following functions:
· Redirects all HTTP requests of unauthenticated users to the portal Web server.
· Interacts with the portal authentication server and the AAA server to complete authentication, authorization, and accounting.
· Allows users that pass portal authentication to access authorized network resources.
Portal authentication server
The portal authentication server receives authentication requests from authentication clients and interacts with the access device to authenticate users.
Portal Web server
The portal Web server pushes the Web authentication page to authentication clients and forwards user authentication information (username and password) to the portal authentication server. The access device also redirects HTTP requests from unauthenticated users to the portal Web server.
The portal Web server can be integrated with the portal authentication server or an independent server.
AAA server
The AAA server interacts with the access device to implement authentication, authorization, accounting for portal users. In a portal system, a RADIUS server can perform authentication, authorization, accounting for portal users, and an LDAP server can perform authentication for portal users.
Security policy server
The security policy server interacts with the portal client and the access device for security check and authorization for users.
The access device supports the local portal Web server feature. Using this feature, the access device also acts as the portal Web server and the portal authentication server to perform local portal authentication on portal users. In this case, the portal system consists of only three components: authentication client, access device, and authentication/accounting server, as shown in Figure 2.
Figure 2 Portal system using the local portal Web server
The authentication client cannot be an H3C iNode client. Local portal authentication only supports authenticating Web clients.
No security policy server is needed because local portal authentication does not support extended portal functions.
The local portal Web server feature implements only some simple portal server functions. It only allows users to log in and log out through the Web interface. It cannot take the place of independent portal Web and authentication servers.
Client and local portal Web server interaction protocols
HTTP and HTTPS can be used for interaction between an authentication client and a local portal Web server. If HTTP is used, there are potential security problems because HTTP packets are transferred in plain text. If HTTPS is used, secure data transmission is ensured because HTTP packets are secured by SSL.
Portal page customization
To perform local portal authentication, you must customize a set of authentication pages that the device will push to users. You can customize multiple sets of authentication pages, compress each set of the pages to a .zip file, and upload the compressed files to the storage medium of the device. On the device, you must specify one of the files as the default authentication page file by using the default-logon-page command.
For more information about authentication page customization, see "Customizing authentication pages." For more information about the default-logon-page command, see Security Command Reference.
The components of a portal system interact as follows:
1. An unauthenticated user initiates authentication by accessing an Internet website through a Web browser. When receiving the HTTP or HTTPS request, the access device redirects it to the Web authentication page provided by the portal Web server. The user can also visit the authentication website to log in. The user must log in through the H3C iNode client for extended portal functions.
2. The user enters the authentication information on the authentication page/dialog box and submits the information. The portal Web server forwards the information to the portal authentication server. Then the portal authentication server processes the information and forwards it to the access device.
3. The access device interacts with the AAA server to implement authentication, authorization, accounting for the user.
4. If security policies are not imposed on the user, the access device allows the authenticated user to access networks. If security policies are imposed on the user, the portal client, the access device, and the security policy server interact to check the user host. If the user passes the security check, the security policy server authorizes the user to access resources based on the check result. Portal authentication through Web does not support security check for users. To implement security check, the client must be the H3C iNode client.
Portal authentication modes
Portal authentication has three modes: direct authentication, re-DHCP authentication, and cross-subnet authentication. In direct authentication and re-DHCP authentication, no Layer 3 forwarding devices exist between the authentication client and the access device. In cross-subnet authentication, Layer 3 forwarding devices can exist between the authentication client and the access device.
Direct authentication
A user manually configures a public IP address or obtains a public IP address through DHCP. Before authentication, the user can access only the portal Web server and predefined authentication-free websites. After passing authentication, the user can access other network resources. The process of direct authentication is simpler than that of re-DHCP authentication.
Re-DHCP authentication
Before a user passes authentication, DHCP allocates an IP address (a private IP address) to the user. The user can access only the portal Web server and predefined authentication-free websites. After the user passes authentication, DHCP reallocates an IP address (a public IP address) to the user. The user then can access other network resources. No public IP address is allocated to users who fail authentication. Re-DHCP authentication saves public IP addresses. For example, an ISP can allocate public IP addresses to broadband users only when they access networks beyond the residential community network.
Only the H3C iNode client supports re-DHCP authentication. IPv6 portal authentication does not support the re-DHCP authentication mode.
Cross-subnet authentication is similar to direct authentication, except it allows Layer 3 forwarding devices to exist between the authentication client and the access device.
In direct authentication, re-DHCP authentication, and cross-subnet authentication, a user's IP address uniquely identifies the user. After a user passes authentication, the access device generates an ACL for the user based on the user's IP address to control forwarding of the packets from the user. Because no Layer 3 forwarding device exists between authentication clients and the access device in direct authentication and re-DHCP authentication, the access device can learn the user MAC addresses. The access device can enhance its capability of controlling packet forwarding by using the learned MAC addresses.
Portal support for EAP
Compared with username and password based authentication, digital certificate-based authentication ensures higher security.
The Extensible Authentication Protocol (EAP) supports several digital certificate-based authentication methods, for example, EAP-TLS. Working together with EAP, portal authentication can implement digital certificate-based user authentication.
Figure 3 Portal support for EAP working flow diagram
As shown in Figure 3, the authentication client and the portal authentication server exchange EAP authentication packets. The portal authentication server and the access device exchange portal authentication packets that carry the EAP-Message attributes. The access device and the RADIUS server exchange RADIUS packets that carry the EAP-Message attributes. The RADIUS server that supports the EAP server function processes the EAP packets encapsulated in the EAP-Message attributes, and provides the EAP authentication result.
The access device does not process but only transports EAP-Message attributes between the portal authentication server and the RADIUS server. Therefore, the access device requires no additional configuration to support EAP authentication.
NOTE: · To use portal authentication that supports EAP, the portal authentication server and client must be the H3C IMC portal server and the H3C iNode portal client. · Local portal authentication does not support EAP authentication. |
Portal authentication process
Direct authentication and cross-subnet authentication share the same authentication process. Re-DHCP authentication has a different process as it has two address allocation procedures.
Direct authentication/cross-subnet authentication process (with CHAP/PAP authentication)
Figure 4 Direct authentication/cross-subnet authentication process
The direct/cross-subnet authentication process is as follows:
1. A portal user access the Internet through HTTP, and the HTTP packet arrives at the access device.
¡ If the packet matches a portal free rule, the access device allows the packet to pass.
¡ If the packet does not match any portal-free rule, the access device redirects the packet to the portal Web server. The portal Web server pushes the Web authentication page to the user for him to enter his username and password.
2. The portal Web server submits the user authentication information to the portal authentication server.
3. The portal authentication server and the access device exchange CHAP messages. This step is skipped for PAP authentication. The portal authentication server decides the method (CHAP or PAP) to use.
4. The portal authentication server adds the username and password into an authentication request packet and sends it to the access device. Meanwhile, the portal authentication server starts a timer to wait for an authentication reply packet.
5. The access device and the RADIUS server exchange RADIUS packets.
6. The access device sends an authentication reply packet to the portal authentication server to notify authentication success or failure.
7. The portal authentication server sends an authentication success or failure packet to the client.
8. If the authentication is successful, the portal authentication server sends an authentication reply acknowledgment packet to the access device.
If the client is an iNode client, the authentication process includes step 9 and step 10 for extended portal functions. Otherwise the authentication process is complete.
9. The client and the security policy server exchange security check information. The security policy server detects whether or not the user host installs anti-virus software, virus definition files, unauthorized software, and operating system patches.
10. The security policy server authorizes the user to access certain network resources based on the check result. The access device saves the authorization information and uses it to control access of the user.
Re-DHCP authentication process (with CHAP/PAP authentication)
Figure 5 Re-DHCP authentication process
The re-DHCP authentication process is as follows:
Step 1 through step 7 are the same as those in the direct authentication/cross-subnet authentication process.
8. After receiving the authentication success packet, the client obtains a public IP address through DHCP. The client then notifies the portal authentication server that it has a public IP address.
9. The portal authentication server notifies the access device that the client has obtained a public IP address.
10. The access device detects the IP change of the client through DHCP and then notifies the portal authentication server that it has detected an IP change of the client IP.
11. After receiving the IP change notification packets sent by the client and the access device, the portal authentication server notifies the client of login success.
12. The portal authentication server sends an IP change acknowledgment packet to the access device.
Step 13 and step 14 are for extended portal functions.
13. The client and the security policy server exchanges security check information. The security policy server detects whether or not the user host installs anti-virus software, virus definition files, unauthorized software, and operating system patches.
14. The security policy server authorizes the user to access certain network resources based on the check result. The access device saves the authorization information and uses it to control access of the user.
Portal filtering rules
The access device uses portal filtering rules to control user traffic forwarding on a portal-enabled interface.
Based on the configuration and authentication status of portal users, the device generates the following categories of portal filtering rules:
· Category 1—The rule permits user packets that are destined for the portal Web server and packets that match the portal-free rules to pass through.
· Category 2—For an authenticated user with no ACL authorized, the rule allows the user to access any destination network resources. For an authenticated user with an ACL authorized, the rule allows users to access resources permitted by the ACL. The device adds the rule when a user comes online and deletes the rule when the user goes offline.
The device supports the following types of authorization ACLs:
¡ Basic ACLs (ACL 2000 to ACL 2999).
¡ Advanced ACLs (ACL 3000 to ACL 3999).
¡ Layer 2 ACLs (ACL 4000 to ACL 4999).
For an authorization ACL to take effect, make sure the ACL exists and has ACL rules excluding rules configured with the counting, established, fragment, source-mac, or logging keyword. For more information about ACL rules, see ACL commands in ACL and QoS Command Reference.
· Category 3—The rule redirects all HTTP requests from unauthenticated users to the portal Web server.
· Category 4—For direct authentication and cross-subnet authentication, the rule forbids any user packets to pass through. For re-DHCP authentication, the device forbids user packets with private source addresses to pass.
After receiving a user packet, the device compares the packet against the filtering rules from category-1 to category-4. Once the packet matches a rule, the matching process completes.
MAC-based quick portal authentication is applicable to scenarios where users access the network frequently. It allows users to pass authentication without entering a username and password. MAC-based quick portal authentication is also called MAC-trigger authentication or transparent portal authentication.
A MAC binding server is required for MAC-trigger authentication. The MAC binding server records the MAC-to-account bindings of portal users for authentication. The account contains the portal authentication information of the user, including username and password.
The authentication is implemented as follows:
1. When a user accesses the network for the first time, the access device generates a MAC-trigger entry that records the user' MAC address and access interface.
2. The access device sends a MAC binding query to the MAC binding server.
3. The MAC binding server checks whether the MAC address of the user is bound with a portal user account.
¡ If yes, the MAC binding server sends the user authentication information to the access device to initiate portal authentication. The user can pass portal authentication without entering the username and password.
¡ If not, the MAC binding server notifies the access device to perform normal portal authentication for the user. After authentication, the access device sends the user's MAC address and authentication information to the MAC binding server for MAC-account binding.
4. When the user passes portal authentication, the access device removes the MAC-trigger entry for the user.
NOTE: For information about MAC binding server configuration, see the user manual of the server. |
IPv6 portal is supported only on the following interface modules:
· FD interface modules.
· FE interface modules.
· SF interface modules.
· SG interface modules.
The device processes user traffic that matches a rule in the authorization ACL based on the permit or deny statement of the rule. To ensure that the device can process all user traffic based on the authorization ACL, perform the following tasks:
· In the authorization ACL for preauthentication users, configure the last rule as rule deny ip.
· In the authorization ACL for authenticated portal users, configure the last rule as rule permit ip.
Make sure the authorization ACLs assigned to portal users do not have rules specified with a source IPv4, IPv6, or MAC address. Otherwise, the users cannot come online after passing authentication. For more information about authorization ACLs, see authorization attribute configuration in "Configuring AAA."
Configuration prerequisites
The portal feature provides a solution for user identity authentication and security check. To complete user identity authentication, portal must cooperate with RADIUS.
The prerequisites for portal authentication configuration are as follows:
· The portal authentication server, portal Web server, and RADIUS server have been installed and configured correctly.
· To use the re-DHCP portal authentication mode, make sure the DHCP relay agent is enabled on the access device, and the DHCP server is installed and configured correctly.
· The portal client, access device, and servers can reach each other.
· To use the remote RADIUS server, configure usernames and passwords on the RADIUS server, and configure the RADIUS client on the access device. For information about RADIUS client configuration, see "Configuring AAA."
· To implement extended portal functions, install and configure CAMS EAD or IMC EAD. Make sure the ACLs configured on the access device correspond to the isolation ACL and the security ACL on the security policy server.
To avoid user login failure, do not specify a source IP address or source MAC address when you configure a rule in the ACLs used by the security policy server.
For information about security policy server configuration on the access device, see "Configuring AAA." For installation and configuration about the security policy server, see CAMS EAD Security Policy Component User Manual or IMC EAD Security Policy Help.
Configure this feature when user authentication uses an external portal authentication server.
Perform this task to configure the following portal authentication server parameters:
· IP address of the portal authentication server.
· VPN instance of the portal authentication server.
· Shared encryption key used between the device and the portal authentication server.
· Destination UDP port number used by the device to send unsolicited portal packets to the portal authentication server.
· Portal authentication server type, which must be the same as the server type the device actually uses.
The device supports multiple portal authentication servers.
Do not delete a portal authentication server in use. Otherwise, users authenticated by that server cannot log out normally.
To configure a portal authentication server:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Create a portal authentication server, and enter its view. |
portal server server-name |
By default, no portal authentication servers exist. |
3. Specify the IP address of the portal authentication server. |
To specify an IPv4 portal server: ·
To specify an IPv6 portal server: |
Specify an IPv4 portal authentication server, an IPv6 authentication portal server, or both. By default, no portal authentication server is specified. |
4. (Optional.) Set the destination UDP port number used by the device to send unsolicited portal packets to the portal authentication server. |
port port-number |
By default, the UDP port number is 50100. This port number must be the same as the listening port number specified on the portal authentication server. |
5. (Optional.) Specify the portal authentication server type. |
server-type imc |
By default, the portal authentication server type is IMC. |
The device supports multiple portal Web servers.
Perform this task to configure the following parameters for a portal Web server:
· VPN instance of the portal Web server.
· URL of the portal Web server.
· Parameters carried in the URL when the device redirects the URL to users.
· Portal Web server type, which must be the same as the server type the device actually uses.
· The captive-bypass feature.
Typically, when iOS mobile devices or some Android mobile devices are connected a portal-enabled network, the device pushes the authentication page to the mobile devices.
The captive-bypass feature enables the device to push the portal authentication page to the iOS and Android devices only when the users access the Internet by using a browser.
· URL redirection match rule.
A URL redirection match rule matches HTTP requests by user-requested URL or User-Agent information, and redirects the matching HTTP requests to the specified redirection URL.
For a user to successfully access a redirection URL, configure a portal-free rule to allow HTTP requests destined for the redirection URL to pass. For information about configuring portal-free rules, see the portal free-rule command.
The url command redirects all HTTP or HTTPS requests from unauthenticated users to the portal Web server for authentication. The if-match command allows for flexible URL redirection by redirecting specific HTTP or HTTPS requests to specific redirection URLs. If both commands are configured for a portal Web server, the if-match command takes priority to perform URL redirection.
To configure a portal Web server:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a portal Web server and enter its view. |
portal web-server server-name |
By default, no portal Web servers exist. |
3. Specify the VPN instance to which the portal Web server belongs. |
vpn-instance vpn-instance-name |
By default, the portal Web server belongs to the public network. |
4. Specify the URL of the portal Web server. |
url url-string |
By default, no URL is specified. To redirect users' HTTPS requests to the portal Web server URL, you must specify the HTTPS redirect listening port number. For more information about specifying the HTTPS redirect listening port number, see HTTP redirect in Layer 3—IP Services Configuration Guide. |
5. Return to system view. |
quit |
N/A |
6. Specify the HTTPS redirect listening port number. |
http-redirect https-port port-number |
By default, no HTTPS redirect listening port number is specified. Perform this step only when you need to redirect users' HTTPS requests to the portal Web server. For more information about this command, see HTTP redirect in Layer 3—IP Services Command Reference. |
7. Enter portal Web server view. |
N/A |
8. Configure the parameters to be carried in the URL when the device redirects it to users. |
url-parameter param-name { nas-id | nas-port-id | original-url | source-address | source-mac [ encryption { aes | des } key { cipher | simple } string ] | value expression } |
By default, no redirection URL parameters are configured. |
9. (Optional.) Specify the portal Web server type. |
server-type imc |
By default, the portal Web server type is IMC. |
10. (Optional.) Enable the captive-bypass feature. |
captive-bypass enable |
By default, the captive-bypass feature is disabled. The device automatically pushes the portal authentication page to iOS mobile devices and some Android mobile devices when they are connected to a portal-enabled network. |
11. (Optional.) Configure a match rule for URL redirection. |
if-match { original-url url-string redirect-url url-string [ url-param-encryption { aes | des } key { cipher | simple } string ] | user-agent string redirect-url url-string } |
By default, no URL redirection match rules exist. |
You must first enable portal authentication on an access interface before it can perform portal authentication for connected clients.
With portal authentication enabled, the device searches for a portal authentication server for a received portal packet according to the source IP address and VPN information of the packet.
· If the packet matches a locally configured portal authentication server, the device regards the packet valid and sends an authentication response packet to the portal authentication server. After a user logs in to the device, the user interacts with the portal authentication server as needed.
· If the packet does not match a portal authentication server, the device drops the packet.
When you enable portal authentication on an interface, follow these restrictions and guidelines:
· Portal authentication does not take effect if configured on a super VLAN interface or a primary VLAN interface.
· If cross-subnet portal authentication is configured on a DHCPv6 relay agent, you must configure the IPv6 address of the DHCPv6 server as the destination address of a portal-free rule.
· Make sure the interface has a valid IP address before you enable re-DHCP portal authentication on the interface.
· Do not add the Ethernet interface enabled with portal authentication to an aggregation group. Otherwise, portal authentication does not take effect.
· Cross-subnet authentication mode (layer3) does not require Layer 3 forwarding devices between the access device and the portal authentication clients. However, if a Layer 3 forwarding device exists between the authentication client and the access device, you must use the cross-subnet portal authentication mode.
· With re-DHCP portal authentication, configure authorized ARP on the interface as a best practice to make sure only valid users can access the network. With authorized ARP configured on the interface, the interface learns ARP entries only from the users who have obtained a public address from DHCP.
· For successful re-DHCP portal authentication, make sure the BAS-IP/BAS-IPv6 attribute value is the same as the device IP or IPv6 address specified on the portal authentication server. To configure the BAS-IP/BAS-IPv6 attribute, use the portal { bas-ip | bas-ipv6 } command.
· An IPv6 portal server does not support re-DHCP portal authentication.
· You can enable both IPv4 portal authentication and IPv6 portal authentication on an interface.
Configuration procedure
To enable portal authentication:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
The interface must be a Layer 3 interface. |
3. Enable portal authentication. |
To enable IPv4 portal authentication: ·
To enable IPv6 portal authentication: |
Enable IPv4 portal authentication, IPv6 portal authentication, or both on the interface. By default, portal authentication is disabled. |
With a portal Web server specified on an interface, the device redirects the HTTP requests of portal users on the interface to the portal Web server.
You can specify both an IPv4 portal Web server and an IPv6 portal Web server on an interface.
To specify a portal Web server:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify a portal Web server. |
To specify an IPv4 portal Web server: ·
To specify an IPv6 portal Web server: |
Specify an IPv4 portal Web server, an IPv6 portal Web server, or both. By default, no portal Web servers are specified. |
A portal-free rule allows specified users to access specified external websites without portal authentication.
The matching items for a portal-free rule include the host name, source/destination IP address, TCP/UDP port number, source MAC address, access interface, and VLAN. Packets matching a portal-free rule will not trigger portal authentication, so users sending the packets can directly access the specified external websites.
You cannot configure two or more portal-free rules with the same filtering criteria. Otherwise, the system prompts that the rule already exists.
Regardless of whether portal authentication is enabled or not, you can only add or remove a portal-free rule. You cannot modify it.
To configure an IP-based portal-free rule:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure an IPv4-based portal-free rule. |
portal free-rule rule-number { destination ip { ip-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] | source ip { ip-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ] |
By default, no IPv4-based portal-free rule exists. |
3. Configure an IPv6-based portal-free rule. |
portal free-rule rule-number { destination ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] | source ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ] |
By default, no IPv6-based portal-free rule exists. |
To configure a source-based portal-free rule:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a source-based portal-free rule. |
portal free-rule rule-number source { interface interface-type interface-number | mac mac-address | vlan vlan-id } * |
By default, no source-based portal-free rule exists. The vlan vlan-id option takes effect only on portal users that access the network through VLAN interfaces. If you specify both a VLAN and an interface, the interface must belong to the VLAN. Otherwise, the portal-free rule does not take effect. |
To configure a destination-based portal-free rule:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a destination-based portal-free rule. |
portal free-rule rule-number destination host-name |
By default, no destination-based portal-free rule exists. |
By configuring authentication source subnets, you specify that only HTTP packets from users on the authentication source subnets can trigger portal authentication. If an unauthenticated user is not on any authentication source subnet, the access device discards all the user's HTTP packets that do not match any portal-free rule.
When you configure a portal authentication source subnet, follow these restrictions and guidelines:
· Authentication source subnets apply only to cross-subnet portal authentication.
· In direct or re-DHCP portal authentication mode, a portal user and its access interface (portal-enabled) are on the same subnet. It is not necessary to specify the subnet as the authentication source subnet. If the specified authentication source subnet is different from the access subnet of the users, the users will fail the portal authentication.
¡ In direct mode, the access device regards the authentication source subnet as any source IP address.
¡ In re-DHCP mode, the access device regards the authentication source subnet on an interface as the subnet to which the private IP address of the interface belongs.
· If both authentication source subnets and destination subnets are configured on an interface, only the authentication destination subnets take effect.
· You can configure multiple authentication source subnets. If the source subnets overlap, the subnet with the largest address scope (with the smallest mask or prefix) takes effect.
To configure an IPv4 portal authentication source subnet:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure an IPv4 portal authentication source subnet. |
portal layer3 source ipv4-network-address { mask-length | mask } |
By default, no IPv4 portal authentication source subnet is configured, and users from any subnets must pass portal authentication. |
To configure an IPv6 portal authentication source subnet:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure an IPv6 portal authentication source subnet. |
portal ipv6 layer3 source ipv6-network-address prefix-length |
By default, no IPv6 portal authentication source subnet is configured, and IPv6 users from any subnets must pass portal authentication. |
By configuring authentication destination subnets, you specify that users trigger portal authentication only when they accessing the specified subnets (excluding the destination IP addresses and subnets specified in portal-free rules). Users can access other subnets without portal authentication.
You can configure multiple authentication destination subnets. If the destination subnets overlap, the subnet with the largest address scope (with the smallest mask or prefix) takes effect.
To configure an IPv4 portal authentication destination subnet:
To configure an IPv6 portal authentication destination subnet:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure an IPv6 portal authentication destination subnet. |
portal ipv6 free-all except destination ipv6-network-address prefix-length |
By default, no IPv6 portal authentication destination subnet is configured, and users accessing any subnets must pass portal authentication. |
Category-2 portal filtering rules permit authenticated users to access authorized network resources. By default, the device allows an authenticated user to come online as long as a card has issued a category-2 portal filtering rule for the user. Users coming online from global interfaces might fail to access network resources because some member ports might not have category-2 rules for the users. To resolve this issue, enable the device to check the issuing of category-2 portal filtering rules. Then, the device allows users to come online only when all cards have issued category-2 portal filtering rules for the users.
As a best practice, perform this task when portal authentication is enabled on a global interface.
To enable the device to check the issuing of category-2 portal filtering rules:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the device to check the issuing of category-2 portal filtering rules. |
portal user-rule assign-check enable |
By default, the device does not check the issuing of category-2 portal filtering rules. |
Perform this task to control the total number of portal users in the system, and the maximum number of IPv4 or IPv6 portal users on an interface.
If you set the maximum total number smaller than the number of current online portal users on the device, this configuration still takes effect. The online users are not affected but the system forbids new portal users to log in.
If you set the maximum number smaller than the current number of portal users on an interface, this configuration still takes effect. The online users are not affected but the system forbids new portal users to log in from the interface.
Make sure the maximum combined number of IPv4 and IPv6 portal users specified on all interfaces does not exceed the system-allowed maximum number. Otherwise, the exceeding number of portal users will not be able to log in to the device.
To set the maximum number of total portal users allowed in the system:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the maximum number of total portal users. |
portal max-user max-number |
By default, no limit is set on the number of portal users in the system. |
To set the maximum number of portal users on an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the maximum number of portal users. |
portal { ipv4-max-user | ipv6-max-user } max-number |
By default, no limit is set on the number of portal users. |
An authentication domain defines a set of authentication, authorization, and accounting policies. Each portal user belongs to an authentication domain and is authenticated, authorized, and accounted in the domain.
With an authentication domain specified on an interface, the device uses the authentication domain for AAA of portal users. This allows for flexible portal access control.
The device selects the authentication domain for a portal user in this order:
1. ISP domain specified for the interface.
2. ISP domain carried in the username.
3. System default ISP domain. For information about the default ISP domain, see "Configuring AAA."
You can specify an IPv4 portal authentication domain, an IPv6 portal authentication domain, or both on an interface.
To specify an IPv4 portal authentication domain:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify an IPv4 portal authentication domain. |
portal domain domain-name |
By default, no ISP domain is specified for IPv4 portal users on the interface. |
To specify an IPv6 portal authentication domain:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify an IPv6 portal authentication domain. |
portal ipv6 domain domain-name |
By default, no ISP domain is specified for IPv6 portal users on the interface. |
The preauthentication domain takes effect only on portal users with IP addresses obtained through DHCP or DHCPv6.
After you configure a preauthentication domain on a portal-enabled interface, the device authorizes users on the interface as follows:
1. After an unauthenticated user obtains an IP address, the user is assigned authorization attributes configured for the preauthentication domain.
The authorization attributes in a preauthentication domain include ACL.
An unauthenticated user who is authorized with the authorization attributes in a preauthentication domain is called a preauthentication user.
2. After the user passes portal authentication, the user is assigned new authorization attributes from the AAA server.
3. After the user goes offline, the user is reassigned the authorization attributes in the preauthentication domain.
When you specify a preauthentication domain, follow these restrictions and guidelines:
· The preauthentication domain does not take effect on interfaces enabled with cross-subnet portal authentication.
· Make sure you specify an existing ISP domain as a preauthentication domain. If the specified ISP domain does not exist, the device might operate incorrectly.
· You must delete a preauthentication domain (by using the undo portal [ ipv6 ] pre-auth domain command) and reconfigure it in the following situations:
¡ You create the ISP domain after specifying it as the preauthentication domain.
¡ You delete the specified ISP domain and then re-create it.
For the authorization ACL in the preauthentication domain, the following rules apply:
· If the ACL does not exist or the destination address permitted by a rule in the ACL is set to any, the device does not control user access. Users can access any network resources without passing portal authentication.
· If the ACL does not have any rules, the device allows users to access network resources only after the users pass authentication.
· Do not specify a source address. If you specify a source address, users cannot trigger portal authentication.
· If the authorization ACL is an IPv4 ACL, specify only the destination IPv4 address, protocol, DSCP priority, TCP or UDP source port, and TCP or UDP destination port.
· If the authorization ACL is an IPv6 ACL, specify only the destination IPv6 address, protocol, DSCP priority, TCP or UDP source port, and TCP or UDP destination port.
· If the authorization ACL is a Layer 2 ACL, specify only the destination MAC address and link layer protocol.
To specify a preauthentication domain:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify a preauthentication domain. |
portal [ ipv6 ] pre-auth domain domain-name |
By default, no preauthentication domain is specified on an interface. |
You must specify a preauthentication IP address pool on a portal-enabled interface in the following situation:
· Portal users access the network through a subinterface of the portal-enabled interface.
· The subinterface does not have an IP address.
· Portal users need to obtain IP addresses through DHCP.
After a user connects to a portal-enabled interface, the user uses an IP address for portal authentication according to the following rules:
· If the interface is configured with a preauthentication IP address pool, the user uses the following IP address:
¡ If the client is configured to obtain an IP address automatically through DHCP, the user obtains an address from the specified IP address pool.
¡ If the client is configured with a static IP address, the user uses the static IP address. However, if the interface does not have an IP address, users using static IP addresses cannot pass authentication.
· If the interface has an IP address but no preauthentication IP pool specified, the user uses the static IP address or the IP address obtained from a DHCP server.
· If the interface has no IP address or preauthentication IP pool specified, the user cannot perform portal authentication.
After the user passes portal authentication, the AAA server authorizes an IP address pool for re-assigning an IP address to the user. If no authorized IP address pool is deployed, the user continues using the previous IP address.
If the portal user does not perform authentication or fails to pass authentication, the assigned IP address is still retained.
When you specify a preauthentication IP address pool, follow these guidelines and restrictions:
· This configuration takes effect only when the direct IPv4 portal authentication is enabled on the interface.
· Make sure the specified IP address pool exists and is complete. Otherwise, the user cannot obtain the IP address and cannot perform portal authentication.
To specify an IP address pool before portal authentication:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify a preauthentication IP address pool for portal users. |
portal [ ipv6 ] pre-auth ip-pool pool-name |
By default, no preauthentication IP address pool is specified on an interface. |
To allow HTTP requests proxied by a Web proxy server to trigger portal authentication, specify the port number of the Web proxy server on the device. If a Web proxy server port is not specified on the device, HTTP requests proxied by the Web proxy server are dropped, and portal authentication cannot be triggered.
If a user's browser uses the Web Proxy Auto-Discovery (WPAD) protocol to discover Web proxy servers, you must perform the following tasks on the device:
· Specify port numbers of the Web proxy servers.
· Configure portal-free rules to allow user packets destined for the WPAD server to pass without authentication.
If portal users enable Web proxy in their browsers, the users must add the IP address of the portal authentication server as a proxy exception in their browsers. Thus, HTTP packets that the users send to the portal authentication server will not be sent to Web proxy servers.
You cannot specify Web proxy server port 443 on the device.
To specify the port number of a Web proxy server:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify the port number of a Web proxy server. |
portal web-proxy port port-number |
By default, no port numbers of Web proxy servers are specified. You can configure this command multiple times to specify multiple port numbers of Web proxy servers. |
The strict checking mode allows a portal user to stay online only when the authorized information for the user is successfully deployed on the interface.
You can enable strict checking on authorized ACLs. If you enable ACL checking, the user will be logged out if either checking fails.
An ACL checking fails when the authorized ACL does not exist on the device or the ACL fails to be deployed.
To enable strict-checking on portal authorization information:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable strict checking mode on portal authorization information. |
portal authorization { acl | user-profile } strict-checking |
By default, the strict checking mode is disabled. In this case, the portal users stay online even when the authorized ACLs do not exist or fail to be deployed. The user-profile keyword is not supported in the current software version. |
This feature allows only users with DHCP-assigned IP addresses to pass portal authentication. Users with static IP addresses cannot pass portal authentication to come online. Use this feature to ensure that only users with valid IP addresses can access the network.
To allow only users with DHCP-assigned IP addresses to pass portal authentication:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Allow only users with DHCP-assigned IP addresses to pass portal authentication. |
portal [ ipv6 ] user-dhcp-only |
By default, both users with IP addresses obtained through DHCP and users with static IP addresses can pass authentication to come online. |
Configure online detection to quickly detect abnormal logouts of portal users.
· Configure ARP or ICMP detection for IPv4 portal users.
· Configure ND or ICMPv6 detection for IPv6 portal users.
If the device receives no packets from a portal user within the idle time, the device detects the user's online status as follows:
· ICMP or ICMPv6 detection—Sends ICMP or ICMPv6 requests to the user at configurable intervals to detect the user status.
¡ If the device receives a reply within the maximum number of detection attempts, it considers that the user is online and stops sending detection packets. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡ If the device receives no reply after the maximum number of detection attempts, the device logs out the user.
· ARP or ND detection—Sends ARP or ND requests to the user and detects the ARP or ND entry status of the user at configurable intervals.
¡ If the ARP or ND entry of the user is refreshed within the maximum number of detection attempts, the device considers that the user is online and stops detecting the user's ARP or ND entry. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡ If the ARP or ND entry of the user is not refreshed after the maximum number of detection attempts, the device logs out the user.
ARP and ND detections apply only to direct and re-DHCP portal authentication. ICMP detection applies to all portal authentication modes.
To configure online detection of IPv4 portal users:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure online detection of IPv4 portal users. |
portal user-detect type { arp | icmp } [ retry retries ] [ interval interval ] [ idle time ] |
By default, this feature is disabled on the interface. |
To configure online detection of IPv6 portal users:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure online detection of IPv6 portal users. |
portal ipv6 user-detect type { icmpv6 | nd } [ retry retries ] [ interval interval ] [ idle time ] |
During portal authentication, if the communication between the access device and portal authentication server is broken, both of the following occur:
· New portal users are not able to log in.
· The online portal users are not able to log out normally.
To address this problem, the access device needs to be able to detect the reachability changes of the portal server quickly and take corresponding actions to deal with the changes.
With the portal authentication server detection feature, the device periodically detects portal packets sent by a portal authentication server to determine the reachability of the server. If the device receives a portal packet within a detection timeout (timeout timeout) and the portal packet is valid, the device considers the portal authentication server to be reachable. Otherwise, the device considers the portal authentication server to be unreachable.
Portal packets include user login packets, user logout packets, and heartbeat packets. Heartbeat packets are periodically sent by a server. By detecting heartbeat packets, the device can detect the server's actual status more quickly than by detecting other portal packets.
Only the IMC portal authentication server supports sending heartbeat packets. To test server reachability by detecting heartbeat packets, you must enable the server heartbeat feature on the IMC portal authentication server.
You can configure the device to take one or more of the following actions when the server reachability status changes:
· Sending a trap message to the NMS. The trap message contains the name and current state of the portal authentication server.
· Sending a log message, which contains the name, the current state, and the original state of the portal authentication server.
· Enabling portal fail-permit. When the portal authentication server is unreachable, the portal fail-permit feature on an interface allows users on the interface to have network access. When the server recovers, it resumes portal authentication on the interface. For more information, see "Configuring the portal fail-permit feature."
To configure portal authentication server detection:
Step |
Command |
Remarks |
system-view |
N/A- |
2. Enter portal authentication server view. |
N/A |
3. Configure portal authentication server detection. |
server-detect [ timeout timeout ] { log | trap } * |
By default, portal authentication server detection is disabled. This feature takes effect regardless of whether portal authentication is enabled on an interface or not. |
A portal authentication process cannot complete if the communication between the access device and the portal Web server is broken. To address this problem, you can enable portal Web server detection on the access device.
With the portal Web server detection feature, the access device simulates a Web access process to initiate a TCP connection to the portal Web server. If the TCP connection can be established successfully, the access device considers the detection successful, and the portal Web server is reachable. Otherwise, it considers the detection to have failed. Portal authentication status on interfaces of the access device does not affect the portal Web server detection feature.
You can configure the following detection parameters:
· Detection interval—Interval at which the device detects the server reachability.
· Maximum number of consecutive failures—If the number of consecutive detection failures reaches this value, the access device considers that the portal Web server is unreachable.
· Sending a trap message to the NMS. The trap message contains the name and current state of the portal Web server.
· Sending a log message, which contains the name, the current state, and the original state of the portal Web server.
· Enabling portal fail-permit. When the portal Web server is unreachable, the portal fail-permit feature on an interface allows users on the interface to have network access. When the server recovers, it resumes portal authentication on the interface. For more information, see "Configuring the portal fail-permit feature."
To configure portal Web server detection:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter portal Web server view. |
N/A |
3. Configure portal Web server detection. |
server-detect [ interval interval ] [ retry retries ] { log | trap } * |
By default, portal Web server detection is disabled. This feature takes effect regardless of whether portal authentication is enabled on an interface or not. |
Once the access device loses communication with a portal authentication server, the portal user information on the access device and that on the portal authentication server might be inconsistent after the communication resumes. To address this problem, the device provides the portal user synchronization feature. This feature is implemented by sending and detecting portal synchronization packets, as follows:
1. The portal authentication server sends the online user information to the access device in a synchronization packet at the user heartbeat interval.
The user heartbeat interval is set on the portal authentication server.
2. Upon receiving the synchronization packet, the access device compares the users carried in the packet with its own user list and performs the following operations:
¡ If a user contained in the packet does not exist on the access device, the access device informs the portal authentication server to delete the user. The access device starts the synchronization detection timer (timeout timeout) immediately when a user logs in.
¡ If the user does not appear in any synchronization packet within a synchronization detection interval, the access device considers the user does not exist on the portal authentication server and logs the user out.
Portal user synchronization requires a portal authentication server to support the portal user heartbeat function. Only the IMC portal authentication server supports the portal user heartbeat function. To implement the portal user synchronization feature, you also need to configure the user heartbeat function on the portal authentication server. Make sure the user heartbeat interval configured on the portal authentication server is not greater than the synchronization detection timeout configured on the access device.
Deleting a portal authentication server on the access device also deletes the user synchronization configuration for the portal authentication server.
To configure portal user information synchronization:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure portal user synchronization. |
user-sync timeout timeout |
By default, portal user synchronization is disabled. |
Perform this task to configure the portal fail-permit feature on an interface. When the access device detects that the portal authentication server or portal Web server is unreachable, it allows users on the interface to have network access without portal authentication.
If you enable fail-permit for both a portal authentication server and a portal Web server on an interface, the interface does the following:
· Disables portal authentication when either server is unreachable.
· Resumes portal authentication when both servers are reachable.
After portal authentication resumes, unauthenticated users must pass portal authentication to access the network. Users who have passed portal authentication before the fail-permit event can continue accessing the network.
To configure portal fail-permit on an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable portal fail-permit for a portal authentication server. |
portal [ ipv6 ] fail-permit server server-name |
By default, portal fail-permit is disabled for a portal authentication server. |
4. Enable portal fail-permit for a portal Web server. |
portal [ ipv6 ] apply web-server server-name [ fail-permit ] |
By default, portal fail-permit is disabled for a portal Web server. |
If the device runs Portal 2.0, the unsolicited packets sent to the portal authentication server must carry the BAS-IP attribute. If the device runs Portal 3.0, the unsolicited packets sent to the portal authentication server must carry the BAS-IP or BAS-IPv6 attribute.
If IPv4 portal authentication is enabled on an interface, you can configure the BAS-IP attribute on the interface. If IPv6 portal authentication is enabled on an interface, you can configure the BAS-IPv6 attribute on the interface.
The device uses the configured BAS-IP or BAS-IPv6 address as the source IP address of the portal notifications sent to the portal authentication server. If you do not configure the BAS-IP or BAS-IPv6 attribute, the source IP address is the IP address of the packet's output interface.
During a re-DHCP portal authentication or mandatory user logout process, the device sends portal notification packets to the portal authentication server. For the authentication or logout process to complete, make sure the BAS-IP/BAS-IPv6 attribute is the same as the device IP or IPv6 address specified on the portal authentication server.
To configure the BAS-IP attribute for unsolicited portal packets sent to the portal authentication server:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure BAS-IP for IPv4 portal packets sent to the portal authentication server. |
portal bas-ip ipv4-address |
By default: · The BAS-IP attribute of an IPv4 portal response packet sent to the portal authentication server is the source IPv4 address of the packet. · The BAS-IP attribute of an IPv4 portal notification packet sent to the portal authentication server is the IPv4 address of the packet's output interface. |
4. Configure BAS-IPv6 for IPv6 portal packets sent to the portal authentication server. |
portal bas-ipv6 ipv6-address |
By default: · The BAS-IPv6 attribute of an IPv6 portal response packet sent to the portal authentication server is the source IPv6 address of the packet. · The BAS-IPv6 attribute of an IPv6 portal notification packet sent to the portal authentication server is the IPv6 address of the packet's output interface. |
Configuring the NAS-Port-Type attribute
The NAS-Port-Type attribute in a RADIUS request represents the type of a user's access interface.
The access device might not be able to correctly obtain the type of users' access interfaces when multiple network devices exist between the access device and the portal client. For the access device to send the correct access interface type to the RADIUS server, perform this task to configure the NAS-Port-Type attribute.
This configuration takes effect only on portal users that newly come online.
To configure the RADIUS NAS-Port-Type attribute:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the NAS-Port-Type attribute carried in outgoing RADIUS requests on the interface. |
portal nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax | hdlc | idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl } |
By default, the NAS-Port-Type carried in outgoing RADIUS requests is Ethernet (attribute value 15). |
Enabling portal roaming
Portal roaming takes effect only on portal users logging in from VLAN interfaces. It does not take effect on portal users logging in from common Layer 3 interface.
If portal roaming is enabled on a VLAN interface, an online portal user can access resources from any Layer 2 port in the VLAN without re-authentication.
If portal roaming is disabled, to access external network resources from a Layer 2 port different from the current access port in the VLAN, the user must do the following:
· First log out from the current port.
· Then re-authenticate on the new Layer 2 port.
To enable portal roaming:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable portal roaming. |
portal roaming enable |
By default, portal roaming is disabled. You cannot enable portal roaming when online portal users or preauthentication portal users exist on the device. |
Specifying a format for the NAS-Port-Id attribute
RADIUS servers from different vendors might require different formats of the NAS-Port-Id attribute in the RADIUS packets. You can specify the NAS-Port-Id attribute format as required.
The device supports the NAS-Port-Id attribute in format 1, format 2, format 3, and format 4. For more information about the formats, see Security Command Reference.
To specify a format for the NAS-Port-Id attribute:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify the format for the NAS-Port-Id attribute. |
portal nas-port-id format { 1 | 2 | 3 | 4 } |
By default, the format for the NAS-Port-Id attribute is format 2. |
Logging out online portal users
This feature deletes users that have passed portal authentication and terminates ongoing portal authentications.
When the number of online users on the device exceeds 2000, executing the portal delete-user command takes a few minutes. To ensure successful logout of online users, do not perform the following operations during the command execution:
· Master/backup device switchover.
· Active/standby MPU switchover.
· Disabling portal authentication on any interfaces.
To log out online users:
Step |
Command |
system-view |
2. Log out IPv4 online portal users. |
portal delete-user { ipv4-address | all | interface interface-type interface-number } |
3. Log out IPv6 online portal users. |
portal delete-user { all | interface interface-type interface-number | ipv6 ipv6-address } |
Configuring Web redirect
Web redirect is a simplified portal feature. With Web redirect, a user does not perform portal authentication but is directly redirected to the specified URL on the first Web access attempt in a browser. After the specified redirect interval, the user is redirected from the visiting website to the specified URL again.
Web redirect can provide ISPs with extended services. For example, the ISPs can place advertisements and publish information on the redirected webpage.
On Etherchannel interfaces, both Web redirect and portal authentication can be enabled at the same time. When portal authentication and Web redirect are both enabled on an interface, the device redirects users on the interface as follows:
· The device redirects the first HTTP request of a user to the specified URL. Then, the device redirects the next HTTP request of the user to the portal authentication page. After the user logs out, the user is redirected to the specified URL again at the first Web access.
· After the specified redirect interval, a user is redirected to the specified URL regardless of whether the user is online or not. This process does not cause online users to be offline.
When you configure Web redirect, follow these restrictions and guidelines:
· Web redirect does not work when both Web redirect and portal authentication are enabled.
· The Web redirect feature takes effect only on HTTP packets that use the default port number 80.
To configure Web redirect:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure Web redirect. |
web-redirect [ ipv6 ] url url-string [ interval interval ] |
By default, Web redirect is disabled. |
Applying a NAS-ID profile to an interface
By default, the device sends its device name in the NAS-Identifier attribute of all RADIUS requests.
A NAS-ID profile enables you to send different NAS-Identifier attribute strings in RADIUS requests from different VLANs. The strings can be organization names, service names, or any user categorization criteria, depending on the administrative requirements.
For example, map the NAS-ID companyA to all VLANs of company A. The device will send companyA in the NAS-Identifier attribute for the RADIUS server to identify requests from any Company A users.
You can apply a NAS-ID profile to a portal-enabled interface. If no NAS-ID profile is specified on the interface or no matching NAS-ID is found in the specified profile, the device uses the device name as the interface NAS-ID.
To apply a NAS-ID profile to an interface:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a NAS-ID profile and enter NAS-ID profile view. |
aaa nas-id profile profile-name |
For more information about this command, see Security Command Reference. |
3. Configure a NAS ID and VLAN binding in the profile. |
nas-id nas-identifier bind vlan vlan-id |
4. Return to system view. |
quit |
N/A |
5. Enter interface view. |
N/A |
6. Specify the NAS-ID profile on the interface. |
portal nas-id-profile profile-name |
By default, no NAS-ID profile is specified on the interface. |
Configuring the local portal Web server feature
To perform local portal authentication for users, perform the following tasks:
· Configure a local portal Web server.
· Configure a name for the portal Web server and specify a local IP address of the device as the server's URL.
· Enable portal authentication on the user access interface.
· Specify the portal Web server on the portal-enabled interface.
During local portal authentication, the local Web portal server pushes authentication pages to users. You must customize the authentication pages and upload them to the device. On the device, specify an authentication page file as the default authentication page file for local portal authentication.
Customizing authentication pages
Authentication pages are HTML files. Local portal authentication requires the following authentication pages:
· Logon page
· Logon success page
· Logon failure page
· Online page
· System busy page
· Logoff success page
You must customize the authentication pages, including the page elements that the authentication pages will use, for example, back.jpg for authentication page Logon.htm.
Follow the authentication page customization rules when you edit the authentication page files.
File name rules
The names of the main authentication page files are fixed (see Table 1). You can define the names of the files other than the main authentication page files. File names and directory names are case insensitive.
Table 1 Main authentication page file names
Main authentication page |
File name |
Logon page |
logon.htm |
Logon success page |
logonSuccess.htm |
Logon failure page |
logonFail.htm |
Online page Pushed after the user gets online for online notification |
online.htm |
System busy page Pushed when the system is busy or the user is in the logon process |
busy.htm |
Logoff success page |
logoffSuccess.htm |
Page request rules
The local portal Web server supports only Get and Post requests.
· Get requests—Used to get the static files in the authentication pages and allow no recursion. For example, if file Logon.htm includes contents that perform Get action on file ca.htm, file ca.htm cannot include any reference to file Logon.htm.
· Post requests—Used when users submit username and password pairs, log in, and log out.
Post request attribute rules
1. Observe the following requirements when editing a form of an authentication page:
¡ An authentication page can have multiple forms, but there must be one and only one form whose action is logon.cgi. Otherwise, user information cannot be sent to the local portal Web server.
¡ The username attribute is fixed as PtUser. The password attribute is fixed as PtPwd.
¡ The value of the PtButton attribute is either Logon or Logoff, which indicates the action that the user requests.
¡ A logon Post request must contain PtUser, PtPwd, and PtButton attributes.
¡ A logoff Post request must contain the PtButton attribute.
2. Authentication pages logon.htm and logonFail.htm must contain the logon Post request.
The following example shows part of the script in page logon.htm.
<form action=logon.cgi method = post >
<p>User name:<input type="text" name = "PtUser" style="width:160px;height:22px" maxlength=64>
<p>Password :<input type="password" name = "PtPwd" style="width:160px;height:22px" maxlength=32>
<p><input type=SUBMIT value="Logon" name = "PtButton" style="width:60px;" onclick="form.action=form.action+location.search;">
</form>
3. Authentication pages logonSuccess.htm and online.htm must contain the logoff Post request.
The following example shows part of the script in page online.htm.
<p><input type=SUBMIT value="Logoff" name="PtButton" style="width:60px;">
</form>
Page file compression and saving rules
You must compress the authentication pages and their page elements into a standard zip file.
· The name of a zip file can contain only letters, numbers, and underscores.
· The authentication pages must be placed in the root directory of the zip file.
· Zip files can be transferred to the device through FTP or TFTP and must be saved in the root directory of the device.
Examples of zip files on the device:
<Sysname> dir
Directory of flash:
1 -rw- 1405 Feb 28 2008 15:53:20
0 -rw- 1405 Feb 28 2008 15:53:31
2 -rw- 1405 Feb 28 2008 15:53:39
3 -rw- 1405 Feb 28 2008 15:53:44
2540 KB total (1319 KB free)
Redirecting authenticated users to a specific webpage
To make the device automatically redirect authenticated users to a specific webpage, do the following in logon.htm and logonSuccess.htm:
1. In logon.htm, set the target attribute of Form to _blank.
See the contents in gray:
<form method=post action=logon.cgi target="_blank">
2. Add the function for page loading pt_init() to logonSuccess.htm.
<html>
<head>
<title>LogonSuccess</title>
<script type="text/javascript" language="javascript" src="pt_private.js"></script>
</head>
<body onload="pt_init();" onbeforeunload="return pt_unload();">
</body>
</html>
Configuring a local portal Web server
Perform the following tasks for the local portal Web server to support HTTPS:
· Configure a PKI policy, obtain the CA certificate, and request a local certificate. For more information, see "Configuring PKI."
· Configure an SSL server policy, and specify the PKI domain configured in the PKI policy. For more information, see "Configuring SSL."
To configure a local portal Web server:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a local portal Web server and enter its view. |
portal local-web-server { http | https ssl-server-policy policy-name [ tcp-port port-number ] } |
By default, no local portal Web servers exist. |
3. Specify the default authentication page file for the local portal Web server. |
default-logon-page filename |
By default, no default authentication page file is specified for the local portal Web server. |
4. (Optional.) Configure the listening TCP port for the local portal Web server. |
tcp-port port-number |
By default, the HTTP service listening port number is 80 and the HTTPS service listening port number is the TCP port number set by the portal local-web-server command. |
Configuring the Rule ARP or ND entry feature for portal clients
When the Rule ARP or ND entry feature is enabled for portal clients, ARP or ND entries for portal clients are Rule entries after the clients come online. The Rule ARP or ND entries will not age out and will be deleted immediately after the portal clients go offline. If a portal client goes offline and then tries to get online before the ARP or ND entry is relearned for the client, the client will fail the authentication. To avoid such authentication failure, disable the Rule ARP or ND entry feature.
When the Rule ARP or ND entry feature is disabled, ARP or ND entries for portal clients are dynamic entries after the clients come online. The dynamic ARP or ND entries are deleted when they age out.
Enabling or disabling of this feature does not affect existing Rule/dynamic ARP or ND entries.
To configure the Rule ARP or ND entry feature for portal clients:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the Rule ARP or ND entry feature for portal clients. |
portal refresh { arp | nd } enable |
By default, the Rule ARP or ND entry feature is enabled for portal clients. |
3. Disable the Rule ARP or ND entry feature for portal clients. |
undo portal refresh { arp | nd } enable |
Configuring HTTPS redirect
The device can redirect HTTPS requests to the portal Web server for portal authentication. During SSL connection establishment, the user browser might display a message that it cannot verify server identity by certificate. For users to perform portal authentication without checking such a message, configure an SSL server policy to request a client-trusted certificate on the device. The name of the policy must be https_redirect. For information about SSL server policy configuration, see "Configuring SSL." For information about certificate request, see "Configuring PKI."
To configure HTTPS redirect:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create an SSL server policy and enter its view. |
ssl server-policy policy-name |
By default, no SSL server policies exist on the device. The name of the SSL server policy for HTTPS redirect must be https_redirect. For more information about this command, see Security Command Reference. |
Configuring MAC-based quick portal authentication
To configure MAC-based quick portal authentication, complete the following configuration on the device:
· Configure MAC binding servers.
· Specify a MAC binding server on an interface.
When you configure MAC-based quick portal authentication, follow these restrictions and guidelines:
· Only IPv4 direct authentication supports MAC-based quick portal authentication.
· For MAC-based quick portal authentication to take effect on an interface configured with a portal preauthentication policy, set the free-traffic threshold to 0 bytes.
Configuring a MAC binding server
You can configure multiple MAC binding servers on the device.
To configure a MAC binding server:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a MAC binding server and enter its view. |
portal mac-trigger-server server-name |
By default, no MAC binder servers exist. |
3. Specify the IP address of the MAC binding server. |
ip ipv4-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ] |
By default, the IP address of a MAC binding server is not specified. |
4. (Optional.) Set the free-traffic threshold. |
free-traffic threshold value |
By default, the free-traffic threshold is 0 bytes. |
5. (Optional.) Specify the NAS-Port-Type value carried in RADIUS requests sent to the RADIUS server. |
nas-port-type value |
By default, the NAS-Port-Type value carried in RADIUS requests is 0. |
6. (Optional.) Set the UDP port number on which the MAC binding server listens for MAC binding query packets. |
port port-number |
By default, the MAC binding server listens for MAC binding query packets on UDP port 50100. |
7. (Optional.) Specify the maximum number of attempts and the interval for sending MAC binding queries to the MAC binding server. |
binding-retry { retries | interval interval } * |
By default, the maximum number of query attempts is 3 and the query interval is 1 second. |
8. (Optional.) Specify the type of the MAC binding server |
server-type imc |
By default, the type of a MAC binding server is IMC. |
9. (Optional.) Specify the version of the portal protocol. |
version version-number |
By default, the version of the portal protocol is 1. |
10. (Optional.) Specify the timeout the device waits for portal authentication to complete after receiving the MAC binding query response. |
authentication-timeout minutes |
By default, the portal authentication timeout time is 3 minutes. |
11. (Optional.) Set the aging time for MAC-trigger entries. |
aging-time seconds |
By default, the aging time for MAC-trigger entries is 300 seconds. |
Specifying a MAC binding server on an interface
After a MAC binding server is specified on an interface, the device can implement MAC-based quick portal authentication for portal users on the interface.
To specify a MAC binding server on an interface:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify a MAC binding server on the interface. |
portal apply mac-trigger-server server-name |
By default, no MAC binding server is specified on an interface. |
Enabling logging for user logins and logouts
This feature logs information about user login and logout events, including the username, IP address, user's MAC address, interface name, VLAN, and reason for login failure. For portal log messages to be sent correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
To enable logging for user logins and logouts:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable logging for user logins and logouts. |
portal log enable |
By default, logging for user logins and logouts is disabled. |
Displaying and maintaining portal
Task |
Command |
Display information about MAC binding servers. |
display portal mac-trigger-server { all | name server-name } |
(In standalone mode.) Display portal rules. |
display portal rule { all | dynamic | static } interface interface-type interface-number [ slot slot-number ] |
(In IRF mode.) Display portal filtering rules. |
display portal rule { all | dynamic | static } interface interface-type interface-number [ chassis chassis-number slot slot-number ] |
Display portal configuration and portal running state information. |
display portal interface interface-type interface-number |
Display portal authentication server information. |
display portal server [ server-name ] |
Display portal Web server information. |
display portal web-server [ server-name ] |
Display packet statistics for portal authentication servers. |
display portal packet statistics [ server server-name ] |
Display portal user information. |
display portal user { all | interface interface-type interface-number | ip ip-address | ipv6 ipv6-address | pre-auth [ interface interface-type interface-number | ip ip-address | ipv6 ipv6-address ] } [ verbose ] |
Clear packet statistics for portal authentication servers. |
reset portal packet statistics [ server server-name ] |
(In standalone mode.) Display Web redirect rule information. |
display web-redirect rule interface interface-type interface-number [ slot slot-number ] |
(In IRF mode.) Display Web redirect rule information. |
display web-redirect rule interface interface-type interface-number [ chassis chassis-number slot slot-number ] |
Portal configuration examples
Configuring direct portal authentication
Network requirements
As shown in Figure 6, the host is directly connected to the switch (the access device). The host is assigned a public IP address either manually or through DHCP. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication/accounting server.
Configure direct portal authentication, so the host can access only the portal server before passing the authentication and access other network resources after passing the authentication.
Configuration prerequisites
· Configure IP addresses for the host, switch, and servers as shown in Figure 6 and make sure they can reach each other.
· Configure the RADIUS server correctly to provide authentication and accounting functions.
Configuring the portal authentication server on IMC PLAT 3.20
In this example, the portal server runs on IMC PLAT 3.20-R2602P13 and IMC UAM 3.60-E6301.
1. Configure the portal authentication server:
a. Log in to IMC and click the Service tab.
b. Select Access Service > Portal Service Management > Server from the navigation tree to open the portal server configuration page, as shown in Figure 7.
c. Configure the portal server parameters as needed.
This example uses the default values.
d. Click OK.
Figure 7 Portal authentication server configuration
2. Configure the IP address group:
a. Select Access Service > Portal Service Management > IP Group from the navigation tree to open the portal IP address group configuration page.
b. Click Add to open the page as shown in Figure 8.
c. Enter the IP group name.
d. Enter the start IP address and end IP address of the IP group.
Make sure the host IP address (2.2.2.2) is in the IP group.
e. Select a service group.
This example uses the default group Ungrouped.
f. Select the action Normal.
g. Click OK.
Figure 8 Adding an IP address group
3. Add a portal device:
a. Select Access Service > Portal Service Management > Device from the navigation tree to open the portal device configuration page.
b. Click Add to open the page as shown in Figure 9.
c. Enter the device name NAS.
d. Enter the IP address of the switch's interface connected to the host.
e. Enter the key, which must be the same as that configured on the switch.
f. Set whether to enable IP address reallocation.
This example uses direct portal authentication. Therefore, select No from the Reallocate IP list.
g. Set whether to support the portal server heartbeat and user heartbeat functions.
In this example, select No for both Support Server Heartbeat and Support User Heartbeat.
h. Click OK.
Figure 9 Adding a portal device
4. Associate the portal device with the IP address group:
a. As shown in Figure 10, click the icon in the Port Group Information Management column of device NAS to open the port group configuration page.
b. Click Add to open the page as shown in Figure 11.
Figure 11 Port group configuration
c. Enter the port group name.
d. Select the configured IP address group.
The IP address used by the user to access the network must be within this IP address group.
e. Click OK.
5. Select Access Service > Service Parameters > Validate System Configuration from the navigation tree to validate the configurations.
Configuring the portal authentication server on IMC PLAT 5.0
In this example, the portal server runs on IMC PLAT 5.0(E0101) and IMC UAM 5.0(E0101).
b. Select User Access Manager > Portal Service Management > Server from the navigation tree to open the portal server configuration page, as shown in Figure 12.
This example uses the default settings.
d. Click OK.
Figure 12 Portal server configuration
a. Select User Access Manager > Portal Service Management > IP Group from the navigation tree to open the portal IP address group configuration page.
b. Click Add to open the page as shown in Figure 13.
Make sure the host IP address is in the IP group.
g. Click OK.
Figure 13 Adding an IP address group
a. Select User Access Manager > Portal Service Management > Device from the navigation tree to open the portal device configuration page.
b. Click Add to open the page as shown in Figure 14.
This example uses direct portal authentication, and therefore select No from the Reallocate IP list.
g. Select whether to support server heartbeat and user heartbeat functions.
h. Click OK.
Figure 14 Adding a portal device
a. As shown in Figure 15, click the icon in the Port Group Information Management column of device NAS to open the port group configuration page.
b. Click Add to open the page as shown in Figure 16.
e. Use the default settings for other parameters.
f. Click OK.
5. Select User Access Manager > Service Parameters > Validate System Configuration from the navigation tree to validate the configurations.
Configuring the switch
1. Configure a RADIUS scheme:
# Create a RADIUS scheme named rs1 and enter its view.
<Switch> system-view
[Switch] radius scheme rs1
# Specify the primary authentication server and primary accounting server, and configure the keys for communication with the servers.
[Switch-radius-rs1] primary authentication 192.168.0.112
[Switch-radius-rs1] primary accounting 192.168.0.112
[Switch-radius-rs1] key authentication simple radius
[Switch-radius-rs1] key accounting simple radius
# Exclude the ISP domain name from the username sent to the RADIUS server.
[Switch-radius-rs1] user-name-format without-domain
[Switch-radius-rs1] quit
# Enable RADIUS session control.
[Switch] radius session-control enable
2. Configure an authentication domain:
# Create an ISP domain named dm1 and enter its view.
[Switch] domain dm1
# Configure AAA methods for the ISP domain.
[Switch-isp-dm1] authentication portal radius-scheme rs1
[Switch-isp-dm1] authorization portal radius-scheme rs1
[Switch-isp-dm1] accounting portal radius-scheme rs1
[Switch-isp-dm1] quit
# Configure domain dm1 as the default ISP domain. If a user enters the username without the ISP domain name at login, the authentication and accounting methods of the default domain are used for the user.
[Switch] domain default enable dm1
3. Configure portal authentication:
# Configure a portal authentication server.
[Switch] portal server newpt
[Switch-portal-server-newpt] ip 192.168.0.111 key simple portal
[Switch-portal-server-newpt] port 50100
[Switch-portal-server-newpt] quit
# Configure a portal Web server.
[Switch] portal web-server newpt
[Switch-portal-websvr-newpt] url http://192.168.0.111:8080/portal
[Switch-portal-websvr-newpt] quit
# Enable direct portal authentication on VLAN-interface 100.
[Switch–Vlan-interface100] portal enable method direct
# Reference the portal Web server newpt on VLAN-interface 100.
[Switch–Vlan-interface100] portal apply web-server newpt
# Configure the BAS-IP as 2.2.2.1 for portal packets sent from VLAN-interface 100 to the portal authentication server.
[Switch–Vlan-interface100] portal bas-ip 2.2.2.1
[Switch–Vlan-interface100] quit
# Verify that the portal configuration has taken effect.
[Switch] display portal interface vlan-interface 100
Portal information of Vlan-interface100
NAS-ID profile: Not configured
VSRP instance : Not configured
VSRP state : N/A
Authorization : Strict checking
ACL : Disabled
User profile : Disabled
IPv4:
Portal status: Enabled
Portal authentication method: Direct
Portal web server: newpt
Authentication domain: Not configured
Pre-auth domain: Not configured
User-dhcp-only: Disabled
Pre-auth IP pool: Not configured
Max Portal users: Not configured
Bas-ip: 2.2.2.1
User Detection: Not configured
Action for server detection:
Server type Server name Action
Layer3 source network:
IP address Mask
Destination authenticate subnet:
IP address Mask
IPv6:
Portal status: Disabled
Portal authentication method: Disabled
Portal web server: Not configured
Bas-ipv6: Not configured
User detection: Not configured
IP address Prefix length
A user can perform portal authentication by using the H3C iNode client or through a Web browser. Before passing the authentication, the user can access only the authentication page http://192.168.0.111:8080/portal. All Web requests from the user will be redirected to the authentication page. After passing the authentication, the user can access other network resources.
# After the user passes authentication, use the following command to display information about the portal user.
[Switch] display portal user interface vlan-interface 100
Total portal users: 1
Username: abc
Portal server: newpt
State: Online
VPN instance: N/A
MAC IP VLAN Interface
0015-e9a6-7cfe 2.2.2.2 100 Vlan-interface100
Authorization information:
DHCP IP pool: N/A
ACL: N/A
CAR: N/A
Configuring re-DHCP portal authentication
As shown in Figure 17, the host is directly connected to the switch (the access device). The host obtains an IP address through the DHCP server. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication/accounting server.
Configure re-DHCP portal authentication. Before passing the authentication, the host is assigned a private IP address. After passing the authentication, the host gets a public IP address and can access network resources.
Configuration prerequisites and guidelines
· Configure IP addresses for the switch and servers as shown in Figure 17 and make sure the host, switch, and servers can reach each other.
· For re-DHCP portal authentication, configure a public address pool (20.20.20.0/24) and a private address pool (10.0.0.0/24) on the DHCP server. (Details not shown.)
· For re-DHCP portal authentication:
¡ The switch must be configured as a DHCP relay agent.
¡ The portal-enabled interface must be configured with a primary IP address (a public IP address) and a secondary IP address (a private IP address).
For information about DHCP relay agent configuration, see Layer 3—IP Services Configuration Guide.
· Make sure the IP address of the portal device added on the portal server is the public IP address (20.20.20.1) of the switch's interface connecting the host. The private IP address range for the IP address group associated with the portal device is the private subnet 10.0.0.0/24 where the host resides. The public IP address range for the IP address group is the public subnet 20.20.20.0/24.
Configuration procedure
[Switch-radius-rs1] primary authentication 192.168.0.113
[Switch-radius-rs1] primary accounting 192.168.0.113
[Switch] domain dm1
3. Configure DHCP relay and authorized ARP:
# Configure DHCP relay.
[Switch] dhcp enable
[Switch] dhcp relay client-information record
[Switch–Vlan-interface100] ip address 20.20.20.1 255.255.255.0
[Switch–Vlan-interface100] ip address 10.0.0.1 255.255.255.0 sub
[Switch-Vlan-interface100] dhcp select relay
[Switch-Vlan-interface100] dhcp relay server-address 192.168.0.112
# Enable authorized ARP.
[Switch-Vlan-interface100] arp authorized enable
4. Configure portal authentication:
# Enable re-DHCP portal authentication on VLAN-interface 100.
[Switch–Vlan-interface100] portal enable method redhcp
# Configure the BAS-IP as 20.20.20.1 for portal packets sent from VLAN-interface 100 to the portal authentication server.
[Switch–Vlan-interface100] portal bas-ip 20.20.20.1
VSRP state : N/A
ACL : Disabled
IPv4:
Portal authentication method: Redhcp
Bas-ip: 20.20.20.1
IP address Mask
IP address Mask
IPv6:
Before passing the authentication, a user that uses the H3C iNode client can access only the authentication page http://192.168.0.111:8080/portal. All Web requests from the user will be redirected to the authentication page. After passing the authentication, the user can access other network resources.
Username: abc
State: Online
VPN instance: N/A
0015-e9a6-7cfe 20.20.20.2 100 Vlan-interface100
DHCP IP pool: N/A
ACL: N/A
CAR: N/A
Configuring cross-subnet portal authentication
As shown in Figure 18, Switch A supports portal authentication. The host accesses Switch A through Switch B. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication/accounting server.
Configure Switch A for cross-subnet portal authentication. Before passing the authentication, the host can access only the portal Web server. After passing the authentication, the user can access other network resources.
· Configure IP addresses for the switch and servers as shown in Figure 18 and make sure the host, switch, and servers can reach each other.
· Make sure the IP address of the portal device added on the portal authentication server is the IP address (20.20.20.1) of the switch's interface connecting the host. The IP address group associated with the portal device is the subnet of the host (8.8.8.0/24).
[SwitchA] radius scheme rs1
[SwitchA-radius-rs1] primary authentication 192.168.0.112
[SwitchA-radius-rs1] primary accounting 192.168.0.112
[SwitchA-radius-rs1] key authentication simple radius
[SwitchA-radius-rs1] key accounting simple radius
[SwitchA-radius-rs1] user-name-format without-domain
[SwitchA-radius-rs1] quit
[SwitchA] radius session-control enable
[SwitchA] domain dm1
[SwitchA-isp-dm1] authentication portal radius-scheme rs1
[SwitchA-isp-dm1] authorization portal radius-scheme rs1
[SwitchA-isp-dm1] accounting portal radius-scheme rs1
[SwitchA-isp-dm1] quit
[SwitchA] domain default enable dm1
[SwitchA] portal server newpt
[SwitchA-portal-server-newpt] ip 192.168.0.111 key simple portal
[SwitchA-portal-server-newpt] port 50100
[SwitchA-portal-server-newpt] quit
[SwitchA] portal web-server newpt
[SwitchA-portal-websvr-newpt] url http://192.168.0.111:8080/portal
[SwitchA-portal-websvr-newpt] quit
# Enable cross-subnet portal authentication on VLAN-interface 4.
[SwitchA] interface vlan-interface 4
[SwitchA–Vlan-interface4] portal enable method layer3
# Reference the portal Web server newpt on VLAN-interface 4.
[SwitchA–Vlan-interface4] portal apply web-server newpt
# Configure the BAS-IP as 20.20.20.1 for portal packets sent from VLAN-interface 4 to the portal authentication server.
[SwitchA–Vlan-interface4] portal bas-ip 20.20.20.1
[SwitchA–Vlan-interface4] quit
[SwitchA] display portal interface vlan-interface 4
Portal information of Vlan-interface4
VSRP state : N/A
ACL : Disabled
IPv4:
Portal authentication method: Layer3
Bas-ip: 20.20.20.1
IP address Mask
IP address Mask
IPv6:
[SwitchA] display portal user interface vlan-interface 4
Username: abc
State: Online
VPN instance: N/A
0000-0000-0000 8.8.8.2 4 Vlan-interface4
DHCP IP pool: N/A
ACL: N/A
CAR: N/A
Configuring extended direct portal authentication
As shown in Figure 19, the host is directly connected to the switch (the access device). The host is assigned a public IP address either manually or through DHCP. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication/accounting server.
Configure extended direct portal authentication. If the host fails security check after passing identity authentication, it can access only subnet 192.168.0.0/24. After passing security check, the host can access other network resources.
· Configure IP addresses for the host, switch, and servers as shown in Figure 19 and make sure they can reach each other.
# Specify a session-control client with IP address 192.168.0.112 and shared key 12345 in plaintext form.
[Switch] radius session-control client ip 192.168.0.112 key simple 12345
[Switch] domain dm1
3. Configure ACL 3000 as the isolation ACL and ACL 3001 as the security ACL.
[Switch] acl advanced 3000
[Switch-acl-ipv4-adv-3000] rule permit ip destination 192.168.0.0 0.0.0.255
[Switch-acl-ipv4-adv-3000] rule deny ip
[Switch-acl-ipv4-adv-3000] quit
[Switch] acl advanced 3001
[Switch-acl-ipv4-adv-3001] rule permit ip
[Switch-acl-ipv4-adv-3001] quit
NOTE: · To avoid user login failure , do not specify a source IP address when you configure a rule in ACL 3000 and ACL 3001. · Make sure you specify ACL 3000 as the isolation ACL and ACL 3001 as the security ACL on the security policy server. |
VSRP state : N/A
ACL : Disabled
IPv4:
Bas-ip: 2.2.2.1
IP address Mask
IP address Mask
IPv6:
Before passing portal authentication, a user that uses the H3C iNode client can access only the authentication page http://192.168.0.111:8080/portal. All Web requests from the user will be redirected to the authentication page.
· The user can access the resources permitted by ACL 3000 after passing only identity authentication.
· The user can access network resources permitted by ACL 3001 after passing both identity authentication and security check.
# After the user passes identity authentication and security check, use the following command to display information about the portal user.
Username: abc
State: Online
VPN instance: N/A
DHCP IP pool: N/A
ACL: 3001
CAR: N/A
Configuring extended re-DHCP portal authentication
As shown in Figure 20, the host is directly connected to the switch (the access device). The host obtains an IP address through the DHCP server. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication/accounting server.
Configure extended re-DHCP portal authentication. Before passing portal authentication, the host is assigned a private IP address. After passing portal identity authentication, the host obtains a public IP address and accepts security check. If the host fails the security check, it can access only subnet 192.168.0.0/24. After passing the security check, the host can access other network resources.
· Configure IP addresses for the switch and servers as shown in Figure 20 and make sure the host, switch, and servers can reach each other.
# Specify a session-control client with IP address 192.168.0.113 and shared key 12345 in plaintext form.
[Switch] radius session-control client ip 192.168.0.113 key simple 12345
[Switch] domain dm1
4. Configure DHCP relay and authorized ARP:
5. Configure portal authentication:
VSRP state : N/A
ACL : Disabled
IPv4:
Bas-ip: 20.20.20.1
IP address Mask
IP address Mask
IPv6:
Username: abc
State: Online
VPN instance: N/A
DHCP IP pool: N/A
ACL: 3001
CAR: N/A
Configuring extended cross-subnet portal authentication
As shown in Figure 21, Switch A supports portal authentication. The host accesses Switch A through Switch B. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication/accounting server.
Configure Switch A for extended cross-subnet portal authentication. Before passing portal authentication, the host can access only the portal server. After passing portal identity authentication, the host accepts security check. If the host fails the security check it can access only the subnet 192.168.0.0/24. After passing the security check, the host can access other network resources.
· Configure IP addresses for the switch and servers as shown in Figure 21 and make sure the host, switch, and servers can reach each other.
· Make sure the IP address of the portal device added on the portal server is the IP address (20.20.20.1) of the switch's interface connecting the host. The IP address group associated with the portal device is the subnet of the host (8.8.8.0/24).
[SwitchA] radius session-control client ip 192.168.0.112 key simple 12345
[SwitchA] acl advanced 3000
[SwitchA-acl-ipv4-adv-3000] rule permit ip destination 192.168.0.0 0.0.0.255
[SwitchA-acl-ipv4-adv-3000] rule deny ip
[SwitchA-acl-ipv4-adv-3000] quit
[SwitchA] acl advanced 3001
[SwitchA-acl-ipv4-adv-3001] rule permit ip
[SwitchA-acl-ipv4-adv-3001] quit
On Switch B, configure a default route to subnet 192.168.0.0/24, specifying the next hop address as 20.20.20.1. (Details not shown.)
VSRP state : N/A
ACL : Disabled
IPv4:
Bas-ip: 20.20.20.1
IP address Mask
IP address Mask
IPv6:
Bas-ip: Not configured
Username: abc
State: Online
VPN instance: N/A
DHCP IP pool: N/A
ACL: 3001
CAR: N/A
Configuring portal server detection and portal user synchronization
As shown in Figure 22, the host is directly connected to the switch (the access device). The host is assigned a public IP address either manually or through DHCP. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication/accounting server.
· Configure direct portal authentication on the switch, so the host can access only the portal server before passing the authentication and access other network resources after passing the authentication.
· Configure the switch to detect the reachability state of the portal authentication server, send log messages upon state changes, and disable portal authentication when the authentication server is unreachable.
· Configure the switch to synchronize portal user information with the portal server periodically.
· Configure IP addresses for the switch and servers as shown in Figure 22 and make sure the host, switch, and servers can reach each other.
· Configure the portal authentication server. Be sure to enable the server heartbeat function and the user heartbeat function.
· Configure the switch (access device) as follows:
¡ Configure direct portal authentication on VLAN-interface 100, the interface to which the host is connected.
¡ Configure portal authentication server detection, so that the switch can detect the reachability of the portal authentication server by cooperating with the portal server heartbeat function.
¡ Configure portal user synchronization, so that the switch can synchronize portal user information with the portal authentication server by cooperating with the portal user heartbeat function.
b. Select Access Service > Portal Service Management > Server from the navigation tree to open the portal server configuration page, as shown in Figure 23.
c. Configure the portal server heartbeat interval and user heartbeat interval.
d. Use the default settings for other parameters.
e. Click OK.
Figure 23 Portal authentication server configuration
b. Click Add to open the page as shown in Figure 24.
g. Click OK.
Figure 24 Adding an IP address group
b. Click Add to open the page as shown in Figure 25.
In this example, select Yes for both Support Server Heartbeat and Support User Heartbeat.
h. Click OK.
Figure 25 Adding a portal device
a. As shown in Figure 26, click the icon in the Port Group Information Management column of device NAS to open the port group configuration page.
b. Click Add to open the page as shown in Figure 27.
Figure 27 Port group configuration
e. User default values for other parameters.
f. Click OK.
b. Select User Access Manager > Portal Service Management > Server from the navigation tree to open the portal server configuration page, as shown in Figure 28.
e. Click OK.
Figure 28 Portal authentication server configuration
b. Click Add to open the page as shown in Figure 29.
g. Click OK.
Figure 29 Adding an IP address group
b. Click Add to open the page as shown in Figure 30.
h. Click OK.
Figure 30 Adding a portal device
a. As shown in Figure 31, click the icon in the Port Group Information Management column of device NAS to open the port group configuration page.
b. Click Add to open the page as shown in Figure 32.
f. Click OK.
[Switch] domain dm1
# Configure reachability detection of the portal authentication server: set the server detection interval to 40 seconds, and send log messages upon reachability status changes.
[Switch-portal-server-newpt] server-detect timeout 40 log
NOTE: The value of timeout must be greater than or equal to the portal server heartbeat interval. |
# Configure portal user synchronization with the portal authentication server, and set the synchronization detection interval to 600 seconds.
[Switch-portal-server-newpt] user-sync timeout 600
NOTE: The value of timeout must be greater than or equal to the portal user heartbeat interval. |
# Enable portal fail-permit for the portal authentication server newpt.
[Switch–Vlan-interface100] portal fail-permit server newpt
# Use the following command to display information about the portal authentication server.
[Switch] display portal server newpt
IP : 192.168.0.111
VPN instance : Not configured
Port : 50100
Server Detection : Timeout 40s Action: log
User synchronization : Timeout 600s
Status : Up
The Up status of the portal authentication server indicates that the portal authentication server is reachable. If the access device detects that the portal authentication server is unreachable, the Status field in the command output displays Down. The access device generates a server unreachable log "Portal server newpt turns down from up." and disables portal authentication on the access interface, so the host can access the external network without authentication.
Configuring cross-subnet portal authentication for MPLS L3VPNs
As shown in Figure 33, the PE device Switch A provides portal authentication for the host in VPN 1. A portal server in VPN 3 acts as the portal authentication server, portal Web server, and RADIUS server.
Configure cross-subnet portal authentication on Switch A, so the host can access network resources after passing identity authentication.
· Before enabling portal authentication, configure MPLS L3VPN and specify VPN targets for VPN 1 and VPN 3 so that VPN 1 and VPN 3 can communicate with each other. This example describes only the access authentication configuration on the user-side PE. For information about MPLS L3VPN configurations, see MPLS Configuration Guide.
# For the RADIUS scheme, specify the VPN instance that is bound to the interface connected to the portal/RADIUS server. This example uses VPN instance vpn3. (For information about the VPN instance, see the MPLS L3VPN configuration on Switch A.)
[SwitchA-radius-rs1] vpn-instance vpn3
[SwitchA-radius-rs1] primary authentication 192.168.0.111
[SwitchA-radius-rs1] primary accounting 192.168.0.111
# Specify the source IP address for RADIUS packets to be sent as 3.3.0.3. This address must be the same as that of the portal device specified on the portal authentication server to avoid authentication failures.
[SwitchA-radius-rs1] nas-ip 3.3.0.3
[SwitchA-portal-server-newpt] ip 192.168.0.111 vpn-instance vpn3 key simple portal
[SwitchA-portal-websvr-newpt] vpn-instance vpn3
# Enable cross-subnet portal authentication on VLAN-interface 3.
[SwitchA–Vlan-interface3] portal enable method layer3
# Reference the portal Web server newpt on VLAN-interface 3.
[SwitchA–Vlan-interface3] portal apply web-server newpt
# Configure the BAS-IP as 3.3.0.3 for portal packets sent from VLAN-interface 3 to the portal authentication server.
[SwitchA–Vlan-interface3] portal bas-ip 3.3.0.3
[SwitchA–Vlan-interface3] quit
# Verify the portal configuration by executing the display portal interface command. (Details not shown.)
# After the user passes authentication, execute the display portal user command to display the portal user information.
[SwitchA] display portal user all
Username: abc
State: Online
VPN instance: vpn3
0000-0000-0000 3.3.0.1 3 Vlan-interface3
DHCP IP pool: N/A
ACL: N/A
CAR: N/A
Configuring direct portal authentication with a preauthentication domain
As shown in Figure 34, the host is directly connected to the switch (the access device). The host is assigned a public IP address through DHCP. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication/accounting server.
Configure direct portal authentication, so the host can access only subnet 192.168.0.0/24 before passing the authentication and access other network resources after passing the authentication.
· Configure IP addresses for the host, switch, and servers as shown in Figure 34 and make sure they can reach each other.
1. Configure a preauthentication IP address pool:
# Configure DHCP address pool pre to assign IP addresses and other configuration parameters to clients on subnet 2.2.2.0/24.
[Switch] dhcp server ip-pool pre
[Switch-dhcp-pool-pre] gateway-list 2.2.2.1
[Switch-dhcp-pool-pre] network 2.2.2.0 24
[Switch-dhcp-pool-pre] quit
# Enable the DHCP server on VLAN-interface 100.
[Switch–Vlan-interface100] dhcp select server
2. Configure a preauthentication domain:
# Create an ISP domain named abc and enter its view.
[Switch] domain abc
# Specify authorization ACL 3010 in the domain.
[Switch-isp-abc] authorization-attribute acl 3010
[Switch-isp-abc] quit
# Configure a rule to permit access to the subnet 192.168.0.0/24.
[Switch] acl advanced 3010
[Switch-acl-ipv4-adv-3010] rule 1 permit ip destination 192.168.0.0 0.0.0.255
[Switch-acl-ipv4-adv-3010] quit
# Configure preauthentication domain abc on VLAN-interface 100.
[Switch–Vlan-interface100] portal pre-auth domain abc
# Display information about preauthentication portal users.
[Switch] display portal user pre-authenticate interface vlan-interface 100
0015-e9a6-7cfe 10.10.10.4 100 Vlan-interface100
State: Online
VPN instance: --
DHCP IP pool: N/A
ACL number: 3010
Inbound CAR: N/A
Outbound CAR: N/A
Configuring re-DHCP portal authentication with a preauthentication domain
As shown in Figure 35, the host is directly connected to the switch (the access device). The host obtains an IP address through the DHCP server. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication/accounting server.
Configure re-DHCP portal authentication. Before passing the authentication, the host is assigned a private IP address and can access only the subnet 192.168.0.0/24. After passing the authentication, the host gets a public IP address and can access other network resources.
· Configure IP addresses for the switch and servers as shown in Figure 35 and make sure the host, switch, and servers can reach each other.
· If you have configured a preauthentication IP address pool on portal-enabled interfaces, configure a DHCP relay address pool with the same name on the device. For the DHCP relay address pool, specify the subnet address where the unauthenticated users reside (with the export-router keyword specified) and the DHCP server address.
1. Configure a preauthentication domain:
[Switch] domain abc
2. Configure DHCP relay and authorized ARP.
[Switch-Vlan-interface100] portal enable method redhcp
State: Online
VPN instance: --
DHCP IP pool: N/A
ACL number: 3010
Inbound CAR: N/A
Outbound CAR: N/A
Configuring direct portal authentication using local portal Web server
As shown in Figure 36, the host is directly connected to the switch (the access device). The host is assigned a public IP address either manually or through DHCP. The switch acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication/accounting server.
Configure direct portal authentication on the switch. Before a user passes portal authentication, the user can access only the local portal Web server. After passing portal authentication, the user can access other network resources.
· Configure IP addresses for the host, switch, and server as shown in Figure 36 and make sure they can reach each other.
· Customize the authentication pages, compress them to a file, and upload the file to the root directory of the storage medium of the switch.
[Switch] domain dm1
# Create a local portal Web server. Use HTTP to exchange authentication information with clients.
[Switch] portal local-web-server http
# Specify file abc.zip as the default authentication page file for local portal authentication. (Make sure the file exist under the root directory of the switch.)
[Switch–portal-local-websvr-http] default-logon-page abc.zip
# Set the HTTP service listening port number to 2331 for the local portal Web server.
[Switch–portal-local-webserver-http] tcp-port 2331
[Switch–portal-local-websvr-http] quit
# Configure the portal Web server name as newpt and URL as the IP address of the portal authentication-enabled interface or a loopback interface (except 127.0.0.1).
[Switch-portal-websvr-newpt] url http://2.2.2.1:2331/portal
# Specify the portal Web server newpt on VLAN-interface 100.
Portal information of Vlan-interface 100
VSRP instance: --
VSRP state: N/A
Authorization Strict checking
ACL Disabled
User profile Disabled
IPv4:
IP address Mask
IP address Mask
IPv6:
A user can perform portal authentication through a Web page. Before passing the authentication, the user can access only the authentication page http://2.2.2.1:2331/portal and all Web requests will be redirected to the authentication page. After passing the authentication, the user can access other network resources.
Username: abc
State: Online
VPN instance: --
IP pool: N/A
ACL: N/A
CAR: N/A
Troubleshooting portal
No portal authentication page is pushed for users
Symptom
When a user is redirected to the IMC portal authentication server, no portal authentication page or error message is prompted for the user. The login page is blank.
Analysis
The key configured on the portal access device and that configured on the portal authentication server are inconsistent. As a result, packet verification fails, and the portal authentication server refuses to push the authentication page.
Solution
Use the display portal server command on the access device to check whether a key is configured for the portal authentication server.
· If no key is configured, configure the right key.
· If a key is configured, use the ip or ipv6 command in the portal authentication server view to correct the key, or correct the key configured for the access device on the portal authentication server.
Cannot log out portal users on the access device
Symptom
You cannot use the portal delete-user command on the access device to log out a portal user, but the portal user can log out by clicking the Disconnect button on the portal authentication client.
Analysis
When you execute the portal delete-user command on the access device to log out a user, the access device sends an unsolicited logout notification message to the portal authentication server. The destination port number in the logout notification is the listening port number of the portal authentication server configured on the access device. If this listening port number is not the actual listening port number configured on the server, the server cannot receive the notification. As a result, the server does not log out the user.
When a user uses the Disconnect button on the authentication client to log out, the portal authentication server sends an unsolicited logout request message to the access device. The access device uses the source port in the logout request as the destination port in the logout ACK message. As a result, the portal authentication server can definitely receive the logout ACK message and log out the user.
Solution
1. Use the display portal server command to display the listening port of the portal authentication server configured on the access device.
2. Use the portal server command in system view to change the listening port number to the actual listening port of the portal authentication server.
Cannot log out portal users on the RADIUS server
Symptom
The access device uses the H3C IMC server as the RADIUS server to perform identity authentication for portal users. You cannot log out the portal users on the RADIUS server.
Analysis
The H3C IMC server uses session control packets to send disconnection requests to the access device. On the access device, the listening UDP port for session control packets is disabled by default. Therefore, the access device cannot receive the portal user logout requests from the RADIUS server.
Solution
On the access device, execute the radius session-control enable command in system view to enable the RADIUS session control function.
Users logged out by the access device still exist on the portal authentication server
Symptom
After you log out a portal user on the access device, the user still exists on the portal authentication server.
Analysis
When you execute the portal delete-user command on the access device to log out a user, the access device sends an unsolicited logout notification to the portal authentication server. If the BAS-IP or BAS-IPv6 address carried in the logout notification is different from the portal device IP address specified on the portal authentication server, the portal authentication server discards the logout notification. When sending of the logout notifications times out, the access device logs out the user. However, the portal authentication server does not receive the logout notification successfully, and therefore it regards the user is still online.
Solution
Configure the BAS-IP or BAS-IPv6 attribute on the interface enabled with portal authentication. Make sure the attribute value is the same as the portal device IP address specified on the portal authentication server.
Re-DHCP portal authenticated users cannot log in successfully
Symptom
The device performs re-DHCP portal authentication for users. A user enters the correct username and password, and the client successfully obtains the private and public IP addresses. However, the authentication result for the user is failure.
Analysis
When the access device detects that the client IP address is changed, it sends an unsolicited portal packet to notify of the IP change to the portal authentication server. The portal authentication server notifies of the authentication success only after it receives the IP change notification from both the access device and the client.
If the BAS-IP or BAS-IPv6 address carried in the portal notification packet is different from the portal device IP address specified on the portal authentication server, the portal authentication server discards the portal notification packet. As a result, the portal authentication server considers that the user has failed the authentication.
Solution
