06 Layer 3 - IP Routing Command Reference
HomeSupportSwitchesH3C S7500X Switch SeriesReference GuidesCommand ReferencesH3C S7500X Switch Series Command References-R757X-6W10006 Layer 3 - IP Routing Command Reference
11-IPv6 policy-based routing commands
11-IPv6 policy-based routing commands 77.80 KB
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] } &<1-2>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-2> ]
No next hop is set.
IPv6 policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ipv6-address: Specifies the IPv6 address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-2>: Indicates that the argument before it can be entered up to two times.
You can specify multiple next hops for backup in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1::1.
[Sysname] ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply next-hop 1::1
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }
undo apply output-interface [ { interface-type interface-number } ]
No output interface is set.
# Specify VLAN-interface 2 as the output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply output-interface vlan-interface 2
apply loadshare
apply precedence
Use apply precedence to set a precedence for IPv6 packets.
Use undo apply precedence to restore the default.
No precedence is set for IPv6 packets.
type: Specifies the precedence type for IPv6 packets.
value: Specifies the precedence for IPv6 packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IPv6 packets.
Table 1 IP precedences and the corresponding types
Precedence value
Precedence type
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
# Set the precedence to 5 (critical) for IPv6 packets.
[Sysname]ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply precedence critical
description
Use description to configure a description for an IPv6 policy node.
No description is configured for an IPv6 policy node.
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for IPv6 policy node 1.
[Sysname] ipv6 policy-based-route 1 permit node 1
[Sysname-pbr6-1-1] description Officeuse
display ipv6 policy-based-route
Use display ipv6 policy-based-route to display IPv6 PBR policy information.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all IPv6 PBR policies.
# Display all IPv6 policy information.
<Sysname> display ipv6 policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
    apply next-hop 1000::1
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares IPv6 packets with IPv6 ACL.
apply next-hop
Specifies a next hop for permitted IPv6 packets.
ipv6 policy-based-route (system view)
display ipv6 policy-based-route apply
Use display ipv6 policy-based-route apply to display the IPv6 PBR configuration and statistics for a VLAN interface.
In standalone mode:
display ipv6 policy-based-route apply vlan-interface interface-number [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route apply vlan-interface interface-number [ chassis chassis-number slot slot-number ]
vlan-interface interface-number: Specifies a VLAN interface by its number.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for the specified VLAN interface on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for the specified VLAN interface on the global active MPU. (In IRF mode.)
This command displays configuration and statistics for IPv6 PBR that is configured with the ipv6 policy-based-route apply command. To display configuration and statistics for IPv6 PBR that is configured in VLAN interface view, use the display ipv6 policy-based-route interface command.
# Display the IPv6 PBR configuration and statistics for VLAN-interface 100.
<Sysname> display ipv6 policy-based-route apply vlan-interface 100
Policy-based routing information for Vlan-interface 100:
Policy name: aaa
  node 2 permit:
    if-match acl 3000
    apply next-hop 2::2
  Matched: 0
Total matched: 0
Policy-based routing information for Vlan-interface xxx
IPv6 PBR configuration and statistics for the VLAN interface.
node 2 permit
Match mode of the node: permit.
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
Matched: 0
Number of successful matches on the node.
Total matched
Total number of successful matches on all nodes.
Use display ipv6 policy-based-route interface to display IPv6 interface PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 interface PBR configuration and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 interface PBR configuration and statistics for the global active MPU. (In IRF mode.)
# Display IPv6 PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ipv6 policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-inerface2(failed):
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
    apply output-interface Vlan-inerface3 track 1 (down)
    apply output-interface Vlan-inerface4 track 2 (inactive)
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0
Total matched: 0
<Sysname> display ipv6 policy-based-route interface Vlan-inerface2
Policy based routing information for interface Vlan-inerface2:
Policy name: aaa
  node 0 deny(not support):
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit(no resource):
    if-match acl 2000
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0 (no statistics resource)
Total matched: 0
Policy based routing information for interface XXXX (failed)
IPv6 PBR configuration and statistics on the interface.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the policy from the interface and then apply it on the interface again.
The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
·     For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces.
·     For a physical interface, specify its slot number.
Match mode of the node, permit or deny.
If a node fails to be issued to the driver, the command displays the cause in brackets, which include:
·     not support—The device does not support the match criteria configured on the node.
·     no resource—No sufficient resources (for example, ACLs) are available for the node.
The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
if-match acl
Compares IPv6 packets with the IPv6 ACL.
apply next-hop
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets.
The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
Total matched
reset ipv6 policy-based-route statistics
display ipv6 policy-based-route local
Use display ipv6 policy-based-route local to display IPv6 local PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route local [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route local [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 local PBR configuration and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 local PBR configuration and statistics for the global active MPU. (In IRF mode.)
# Display IPv6 local PBR configuration and statistics.
<Sysname> display ipv6 policy-based-route local
Policy based routing information for local:
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
    apply next-hop 1::1
  Matched: 0
  node 5 permit:
    if-match acl 3101
    apply next-hop 2::2
  Matched: 0
Total matched: 0
Table 5 Command output
node 0 deny/node 2 permit
if-match acl
apply next-hop
Matched: 0
Total matched
display ipv6 policy-based-route setup
Use display ipv6 policy-based-route setup to display IPv6 PBR configuration.
# Display IPv6 PBR configuration.
<Sysname> display ipv6 policy-based-route setup
Policy name              Type               Interface
pr01                     Forward            Vlan-interface 2
pr02                     Local              N/A
Table 6 Command output
Policy name
Policy name.
Type of the PBR:
·     Forward—Interface PBR.
·     Local—Local PBR.
Interface where the policy is applied.
ipv6 policy-based-route (interface view)
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999. The value range of a basic ACL is 2000 to 2999 and that of an advanced ACL is 3000 to 3999.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all. For the command to take effect, make sure the specified IPv6 ACL is a basic or advanced ACL.
# Configure Node 10 of policy aa to permit the packets matching ACL 2000.
[Sysname] ipv6 policy-based-route aa permit node 10
[Sysname-pbr6-aa-10] if-match acl 2000
# Configure Node 10 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr6-aa-10] if-match acl name aaa
ipv6 local policy-based-route
Use ipv6 local policy-based-route to configure IPv6 local PBR based on a specified policy.
Use undo ipv6 local policy-based-route to restore the default.
No policy is referenced for IPv6 local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified IPv6 policy must already exist.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR is used to route locally generated packets except the packets destined for the sender. This feature might affect local services. Do not configure IPv6 local PBR unless doing so is required.
# Configure IPv6 local PBR based on policy aaa.
[Sysname] ipv6 local policy-based-route aaa
Use ipv6 policy-based-route to configure IPv6 interface PBR by applying an IPv6 policy to an interface.
Use undo ipv6 policy-based-route to restore the default.
ipv6 policy-based-route policy-name
No IPv6 is applied to an interface.
Interface view
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
IPv6 interface PBR is not supported on Layer 3 aggregate interfaces, Layer 3 aggregate subinterfaces, or member ports of the Layer 3 aggregate subinterfaces.
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ipv6 policy-based-route aaa
Use ipv6 policy-based-route to create an IPv6 policy node and enter its view, or enter the view of an existing IPv6 policy node.
Use undo ipv6 policy-based-route to delete an IPv6 policy or IPv6 policy node.
undo ipv6 policy-based-route policy-name [ deny | node node-number | permit ]
No IPv6 policy nodes exist.
policy-name: Specifies a policy name, a case-sensitive string of 1 to 19 characters.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies the number of the IPv6 policy node. A smaller number has a higher priority. The value range for the node-number argument is 0 to 255.
To delete an IPv6 policy that has already applied to an interface, you must delete the policy from the interface first.
If a policy node is specified, the undo ipv6 policy-based-route command deletes the specified policy node. If a match mode is specified, the command deletes all nodes configured with the match mode. If no node is specified, the command deletes the whole policy.
# Create permit-mode Node 10 for IPv6 policy aaa and enter its view.
[Sysname] ipv6 policy-based-route aaa permit node 10
[Sysname-pbr6-aaa-10]
Use reset ipv6 policy-based-route statistics to clear IPv6 PBR statistics.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears IPv6 PBR statistics for all policies.
# Clear all IPv6 PBR statistics.
<Sysname> reset ipv6 policy-based-route statistics
