- 10 Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Port security commands
- 06-Password control commands
- 07-Keychain commands
- 08-Public key management commands
- 09-PKI commands
- 10-IPsec commands
- 11-SSH commands
- 12-SSL commands
- 13-Attack detection and prevention commands
- 14-TCP attack prevention commands
- 15-IP source guard commands
- 16-ARP attack protection commands
- 17-ND attack defense commands
- 18-uRPF commands
- 19-MFF commands
- 20-FIPS commands
- 21-MACsec commands
- 22-802.1X client commands
- 23-Web authentication commands
- 24-Object group commands
| 05-Port security commands | 141.01 KB |
display port-security mac-address block
display port-security mac-address security
port-security access-user log enable
port-security authentication open
port-security authentication open global
port-security authorization ignore
port-security authorization-fail offline
port-security escape critical-vsi
port-security global escape critical-vsi
port-security mac-address aging-type inactivity
port-security mac-address dynamic
port-security timer autolearn aging
port-security timer disableport
snmp-agent trap enable port-security
Use display port-security to display port security configuration, operation information, and statistics for ports.
display port-security [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays port security information for all ports.
# Display port security information for all ports.
<Sysname> display port-security
Global port security parameters:
Port security : Enabled
AutoLearn aging time : 0 min
Disableport timeout : 20 s
MAC move : Denied
Authorization fail : Online
NAS-ID profile : Not configured
Dot1x-failure trap : Disabled
Dot1x-logon trap : Disabled
Dot1x-logoff trap : Enabled
Intrusion trap : Disabled
Address-learned trap : Enabled
Mac-auth-failure trap : Disabled
Mac-auth-logon trap : Enabled
Mac-auth-logoff trap : Disabled
Open authentication : Disabled
OUI value list :
Index : 1 Value : 123401
Ten-GigabitEthernet1/0/1 is link-up
Port mode : userLogin
NeedToKnow mode : Disabled
Intrusion protection mode : NoAction
Security MAC address attribute
Learning mode : Sticky
Aging type : Periodical
Max secure MAC addresses : 32
Current secure MAC addresses : 0
Authorization : Permitted
Free VLANs : Not configured
Port security |
Whether the port security feature is enabled. |
AutoLearn aging time |
Sticky MAC address aging timer, in minutes or seconds. |
Disableport timeout |
Silence period (in seconds) of the port that receives illegal packets. |
MAC move |
Status of MAC move: · If the feature is enabled, this field displays Permitted. · If the feature is disabled, this field displays Denied. |
Authorization fail |
Action to be taken for users that have failed authorization: · Online—Allows the users to go online. · Offline—Logs off the users. |
NAS-ID profile |
NAS-ID profile applied globally. |
Dot1x-failure trap |
Whether SNMP notifications for 802.1X authentication failures are enabled. |
Dot1x-logon trap |
Whether SNMP notifications for 802.1X authentication successes are enabled. |
Dot1x-logoff trap |
Whether SNMP notifications for 802.1X authenticated user logoffs are enabled. |
Intrusion trap |
Whether SNMP notifications for intrusion protection are enabled. If they are enabled, the device sends SNMP notifications after illegal packets are detected. |
Address-learned trap |
Whether SNMP notifications for MAC address learning are enabled. If they are enabled, the device sends SNMP notifications after it learns a new MAC address. |
Mac-auth-failure trap |
Whether SNMP notifications for MAC authentication failures are enabled. |
Mac-auth-logon trap |
Whether SNMP notifications for MAC authentication successes are enabled. |
Mac-auth-logoff trap |
Whether SNMP notifications for MAC authentication user logoffs are enabled. |
Open authentication |
Whether global open authentication mode is enabled. |
OUI value list |
List of OUI values allowed for authentication. |
Port mode |
Port security mode: · noRestrictions. · autoLearn. · macAddressWithRadius. · macAddressElseUserLoginSecure. · macAddressElseUserLoginSecureExt. · secure. · userLogin. · userLoginSecure. · userLoginSecureExt. · macAddressOrUserLoginSecure. · macAddressOrUserLoginSecureExt. · userLoginWithOUI. For more information about port security modes, see Security Configuration Guide. |
NeedToKnow mode |
Need to know (NTK) mode: · NeedToKnowOnly—Allows only unicast frames with authenticated destination MAC addresses. · NeedToKnowWithBroadcast—Allows only broadcast frames and unicast frames with authenticated destination MAC addresses. · NeedToKnowWithMulticast—Allows broadcast frames, multicast frames, and unicast frames with authenticated destination MAC addresses. · NeedToKnowAuto—Allows broadcast frames, multicast frames, and unicast frames with authenticated destination MAC addresses only when the port has online users. · Disabled—NTK is disabled. |
Intrusion protection mode |
Intrusion protection action: · BlockMacAddress—Adds the source MAC address of the illegal packet to the blocked MAC address list. · DisablePort—Shuts down the port that receives illegal packets permanently. · DisablePortTemporarily—Shuts down the port that receives illegal packets for some time. · NoAction—Does not perform intrusion protection. |
Learning mode |
Secure MAC address learning mode: · Dynamic. · Sticky. |
Aging type |
Secure MAC address aging type: · Periodical—Timer aging only. · Inactivity—Inactivity aging feature together with the aging timer. |
Max secure MAC addresses |
Maximum number of secure MAC addresses (or online users) that port security allows on the port. |
Current secure MAC addresses |
Number of secure MAC addresses stored. |
Authorization |
Whether the authorization information from the authentication server (RADIUS server or local device) is ignored: · Permitted—Authorization information from the authentication server takes effect. · Ignored—Authorization information from the authentication server does not take effect. |
NAS-ID profile |
NAS-ID profile applied to the port. |
Free VLANs |
VLANs in which packets will not trigger authentication. If you do not configure free VLANs, this field displays Not configured. |
Whether open authentication mode is enabled on the port. |
Use display port-security mac-address block to display information about blocked MAC addresses.
display port-security mac-address block [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
vlan vlan-id: Specifies a VLAN by its ID. The value range is 1 to 4094.
count: Displays only the count of the blocked MAC addresses.
If you do not specify any parameters, this command displays information about all blocked MAC addresses.
# (In standalone mode.) Display information about all blocked MAC addresses.
<Sysname> display port-security mac-address block
MAC ADDR Port VLAN ID
000f-3d80-0d2d XGE1/0/1 30
--- On slot 1, 1 MAC address(es) found ---
--- 1 mac address(es) found ---
# (In standalone mode.) Display the count of all blocked MAC addresses.
<Sysname> display port-security mac-address block count
MAC ADDR |
Blocked MAC address. |
Port |
Port having received frames with the blocked MAC address being the source address. |
VLAN ID |
ID of the VLAN to which the port belongs. |
number mac address(es) found |
Number of blocked MAC addresses. |
port-security intrusion-mode
Use display port-security mac-address security to display information about secure MAC addresses.
display port-security mac-address security [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
count: Displays only the count of the secure MAC addresses.
Secure MAC addresses are those that are automatically learned by the port in autoLearn mode or configured by the port-security mac-address security command.
If you do not specify any parameters, this command displays information about all secure MAC addresses.
# Display information about all secure MAC addresses.
<Sysname> display port-security mac-address security
MAC ADDR VLAN ID STATE PORT INDEX AGING TIME
0002-0002-0002 1 Secure XGE1/0/1 Not aged
--- Number of secure MAC addresses: 1 ---
# Display only the count of the secure MAC addresses.
<Sysname> display port-security mac-address security count
MAC ADDR |
Secure MAC address. |
VLAN ID |
STATE |
Type of the MAC address. This field displays Secure for a secure MAC address. |
PORT INDEX |
Port to which the secure MAC address belongs. |
AGING TIME |
Period of time before the secure MAC address ages out. · If the secure MAC address is a static MAC address, this field displays Not aged. · If the secure MAC address is a sticky MAC address, this field displays the remaining lifetime. If the remaining lifetime is less than 60 seconds, the lifetime is counted in seconds. If the lifetime is not less than 60 seconds, the lifetime is counted in minutes. By default, sticky MAC addresses do not age out, and this field displays Not aged. |
Number of secure MAC addresses |
Use port-security access-user log enable to enable logging for port security users.
Use undo port-security access-user log enable to disable logging for port security users.
port-security access-user log enable [ failed-authorization | mac-learning | violation ] *
undo port-security access-user log enable [ failed-authorization | mac-learning | violation ] *
All types of logging are disabled for port security users.
failed-authorization: Specifies logs generated for authorization failures of 802.1X or MAC authentication users.
mac-learning: Specifies logs generated for new MAC address learning.
violation: Specifies logs generated when intrusion protection is triggered.
As a best practice, disable this feature to prevent excessive output of logs for port security users.
If you do not specify any parameters, this command enables all types of logging for port security users.
# Enable logging for intrusion protection.
[Sysname] port-security access-user log enable violation
info-center source portsec logfile deny (Network Management and Monitoring Command Reference)
Use port-security authentication open to enable open authentication mode on a port.
Use undo port-security authentication open to disable open authentication mode on a port.
Open authentication mode is disabled on a port.
This command enables access users (802.1X or MAC authentication users) of a port to come online and access the network even if they use nonexistent usernames or incorrect passwords.
Access users that come online in open authentication mode are called open users. Authorization and accounting are not available for open users. To display open user information, use the following commands:
· display dot1x connection open.
· display mac-authentication connection open.
Open authentication mode does not affect the access of users that use correct user information on the port.
The open authentication mode setting has lower priority than the 802.1X Auth-Fail VLAN and the MAC authentication guest VLAN. Open authentication mode does not take effect on a port if the port is also configured with the 802.1X Auth-Fail VLAN or the MAC authentication guest VLAN.
For information about 802.1X authentication or MAC authentication, see Security Configuration Guide.
# Enable open authentication mode on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] port-security authentication open
Use port-security authentication open global to enable global open authentication mode.
Use undo port-security authentication open global to disable global open authentication mode.
Global open authentication mode is disabled.
This command enables access users (802.1X or MAC authentication users) to come online and access the network even if they use nonexistent usernames or incorrect passwords.
Open authentication mode does not affect the access of users that use correct user information.
# Enable global open authentication mode.
[Sysname] port-security authentication open global
Use port-security authorization ignore to configure a port to ignore the authorization information received from the authentication server (a RADIUS server or the local device).
Use undo port-security authorization ignore to restore the default.
A port uses the authorization information from the server.
After a user passes RADIUS or local authentication, the server performs authorization based on the authorization attributes configured for the user account. For example, the server can assign a VLAN. If you do not want the port to use such authorization attributes for users, use this command to ignore the authorization information from the server.
# Configure Ten-GigabitEthernet 1/0/1 to ignore the authorization information from the authentication server.
[Sysname-Ten-GigabitEthernet1/0/1] port-security authorization ignore
Use port-security authorization-fail offline to enable the authorization-fail-offline feature.
Use undo port-security authorization-fail offline to disable the authorization-fail-offline feature.
port-security authorization-fail offline [ quiet-period ]
The authorization-fail-offline feature is disabled. The device does not log off users that have failed authorization.
quiet-period: Enables the quiet timer for 802.1X or MAC authentication users that are logged off by the authorization-fail-offline feature. The device adds these users to the 802.1X or MAC authentication quiet queue. Within the quiet timer, the device does not process packets from these users or authenticate them. If you do not specify this keyword, the quiet timer feature is disabled for users that are logged off by the authorization-fail-offline feature. The device immediately authenticates these users upon receiving packets from them.
The authorization-fail-offline feature logs off port security users that have failed ACL authorization.
A user fails ACL authorization in the following situations:
· The device fails to authorize the specified ACL to the user.
· The server assigns a nonexistent ACL to the user.
If this feature is disabled, the device does not log off users that have failed ACL authorization. However, the device outputs messages to report the failure.
For the quiet-period keyword to take effect, complete the following tasks:
· For 802.1X users, use the dot1x quiet-period command to enable the quiet timer and use the dot1x timer quiet-period command to set the timer.
· For MAC authentication users, use the mac-authentication timer quiet command to set the quiet timer for MAC authentication.
# Enable the authorization-fail-offline feature.
[Sysname] port-security authorization-fail offline
dot1x quiet-period
port-security enable
Use port-security enable to enable port security.
Use undo port-security enable to disable port security.
Port security is disabled.
You must disable global 802.1X and MAC authentication before you enable port security on a port.
Enabling or disabling port security resets the following security settings to the default:
· 802.1X access control mode is MAC-based.
· Port authorization state is auto.
When online users are present on a port, disabling port security logs off the online users.
# Enable port security.
[Sysname] port-security enable
dot1x
dot1x port-control
dot1x port-method
mac-authentication
Use port-security escape critical-vsi to enable the escape critical VSI feature for 802.1X and MAC authentication users on a port.
Use undo port-security escape critical-vsi to disable the escape critical VSI feature for 802.1X and MAC authentication users on a port.
The escape critical VSI feature is disabled on a port.
The escape critical VSI feature operates on VXLAN networks. It enables 802.1X and MAC authentication users to escape the authentication failure that occurs because the RADIUS server is malfunctioning or unreachable.
You can enable this feature temporarily to prevent 802.1X and MAC authentication service interruption while you are troubleshooting a malfunctioning or unreachable RADIUS server.
Before enabling the escape critical VSI feature on a port, configure an 802.1X critical VSI and a MAC authentication critical VSI on the port.
For the escape critical VSI feature to work correctly on a port, make sure the port does not have the following settings:
· Guest, Auth-Fail, or critical VLAN for 802.1X authentication.
· Guest or critical VLAN for MAC authentication.
The escape critical VSI feature does not affect 802.1X or MAC authentication users that have been online before this feature is enabled.
When this feature is enabled, online MAC authentication users that are assigned authorization URLs on the port might be logged off depending on the critical VSI configuration.
The escape critical VSI feature does not take effect on a new 802.1X or MAC authentication user if any of the following conditions exists:
· The 802.1X client and the device use different EAP message handling methods.
· 802.1X MAC address binding is enabled on the user's access port, but the MAC address of the 802.1X user is not bound to that port.
· The user's MAC address is an all-zero, all-F, or multicast MAC address.
When you disable the escape critical VSI feature on a port, the device handles users in the critical VSIs on the port as follows:
· If the global escape critical VSI feature is enabled, the users are not removed from the critical VSIs on the port.
· If the global escape critical VSI feature is disabled, the users are removed from the critical VSIs on the port. The users must perform authentication to come online again on the port.
# Enable the escape critical VSI on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] port-security escape critical-vsi
Please make sure the port is configured with the 802.1X and MAC authentication critical VSIs. Continue? [Y/N]:y
dot1x critical vsi
mac-authentication critical vsi
vsi (VXLAN Command Reference)
port-security free-vlan
Use port-security free-vlan to configure free VLANs for port security.
Use undo port-security free-vlan to restore the default.
port-security free-vlan vlan-id-list
undo port-security free-vlan vlan-id-list
No free VLANs are configured for port security on a port. Authentication will be triggered by packets from users in any VLAN on the port that is configured with 802.1X, MAC authentication, or a port security authentication mode.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by VLAN ID or specifies a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range for VLAN IDs is 1 to 4094. The end VLAN ID must be equal to or greater than the start VLAN ID.
This command allows packets from the specified VLANs to not trigger 802.1X or MAC authentication on a port configured with any of the following features:
· 802.1X authentication.
· MAC authentication.
· Any of the following port security modes:
¡ userLogin.
¡ userLoginSecure.
¡ userLoginWithOUI.
¡ userLoginSecureExt.
¡ macAddressWithRadius.
¡ macAddressOrUserLoginSecure.
¡ macAddressElseUserLoginSecure.
¡ macAddressOrUserLoginSecureExt.
¡ macAddressElseUserLoginSecureExt.
Execute this command multiple times to specify multiple free VLANs for port security.
# Configure free VLANs for port security on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] port-security free-vlan 2 3
Use port-security global escape critical-vsi to enable the escape critical VSI feature globally for 802.1X and MAC authentication users.
Use undo port-security global escape critical-vsi to disable the escape critical VSI feature globally for 802.1X and MAC authentication users.
The global escape critical VSI feature is disabled.
Before enabling the global escape critical VSI feature, configure an 802.1X critical VSI and a MAC authentication critical VSI on the access port of each 802.1X or MAC authentication user.
For the global escape critical VSI feature to work correctly on a port, make sure the port does not have the following settings:
· Web authentication.
The global escape critical VSI feature does not affect 802.1X or MAC authentication users that have been online before this feature is enabled.
The global escape critical VSI feature does not take effect on a new 802.1X or MAC authentication user if any of the following conditions exists:
When you disable the global escape critical VSI feature, the device handles users in the critical VSIs on each port as follows:
· If the escape critical VSI feature is enabled on the port, the users on the port are not removed from the critical VSIs.
· If the escape critical VSI feature is disabled on the port, the users on the port are removed from the critical VSIs. The users must perform authentication to come online again on the port.
# Enable the global escape critical VSI feature.
[Sysname] port-security global escape critical-vsi
Please make sure critical VSI settings exist. Continue? [Y/N]:y
dot1x critical vsi
Use port-security intrusion-mode to configure the intrusion protection feature so the port takes the predefined actions when intrusion protection detects illegal frames on the port.
Use undo port-security intrusion-mode to restore the default.
port-security intrusion-mode { blockmac | disableport | disableport-temporarily }
Intrusion protection is disabled.
blockmac: Adds the source MAC addresses of illegal frames to the blocked MAC address list and discards frames with blocked source MAC addresses. This action implements illegal traffic filtering on the port. A blocked MAC address is restored to normal after being blocked for 3 minutes, which is not user configurable. To display the blocked MAC address list, use the display port-security mac-address block command.
disableport: Disables the port permanently upon detecting an illegal frame received on the port.
disableport-temporarily: Disables the port for a period of time whenever it receives an illegal frame. You can use the port-security timer disableport command to set the period.
To restore the connection of the port disabled by the intrusion protection feature, use the undo shutdown command.
# Configure Ten-GigabitEthernet 1/0/1 to block the source MAC addresses of illegal frames after intrusion protection detects the illegal frames.
[Sysname-Ten-GigabitEthernet1/0/1] port-security intrusion-mode blockmac
Use port-security mac-address aging-type inactivity to enable inactivity aging for secure MAC addresses.
Use undo port-security mac-address aging-type inactivity to disable inactivity aging for secure MAC addresses.
The inactivity aging feature is disabled for secure MAC addresses.
This command enables the device to periodically detect traffic data from secure MAC addresses.
If only the aging timer is configured, the aging timer counts up regardless of whether traffic data has been sent from the secure MAC addresses. When you use the aging timer together with the inactivity aging feature, the aging timer restarts once traffic data is detected from the secure MAC addresses. The secure MAC addresses age out only when no traffic data is detected within the aging timer.
The inactivity aging feature prevents the unauthorized use of a secure MAC address when the authorized user is offline. The feature also removes outdated secure MAC addresses so that new secure MAC addresses can be learned or configured.
If the aging timer is set to a value not less than 60 seconds, the traffic data detection interval is fixed at 30 seconds.
If the aging timer is set to a value less than 60 seconds, the traffic data detection interval is the effective aging period.
To set the aging timer for secure MAC addresses, use the port-security timer autolearn aging command.
This command takes effect only on sticky MAC addresses and dynamic secure MAC addresses.
# Enable inactivity aging for secure MAC addresses on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] port-security mac-address aging-type inactivity
Use port-security mac-address dynamic to enable the dynamic secure MAC feature.
Use undo port-security mac-address dynamic to disable the dynamic secure MAC feature.
The dynamic secure MAC feature is disabled. Sticky MAC addresses can be saved to the configuration file. Once saved, they survive a device reboot.
The dynamic secure MAC feature converts sticky MAC addresses to dynamic and disables saving them to the configuration file.
After you execute this command, you cannot manually configure sticky MAC addresses, and secure MAC addresses learned by a port in autoLearn mode are dynamic. All dynamic MAC addresses are lost at reboot. Use this command when you want to clear all sticky MAC addresses after a device reboot.
You can display dynamic secure MAC addresses by using the display port-security mac-address security command.
The undo port-security mac-address dynamic command converts all dynamic secure MAC addresses on the port to sticky MAC addresses. You can manually configure sticky MAC addresses.
# Enable the dynamic secure MAC feature on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] port-security mac-address dynamic
Use port-security mac-address security to add a secure MAC address.
Use undo port-security mac-address security to remove a secure MAC address.
In Layer 2 Ethernet interface view:
port-security mac-address security [ sticky ] mac-address vlan vlan-id
undo port-security mac-address security [ sticky ] mac-address vlan vlan-id
In system view:
port-security mac-address security [ sticky ] mac-address interface interface-type interface-number vlan vlan-id
undo port-security mac-address security [ [ mac-address [ interface interface-type interface-number ] ] vlan vlan-id ]
No manually configured secure MAC address entries exist.
sticky: Specifies the MAC address type as sticky. If you do not specify this keyword, the command configures a static secure MAC address.
mac-address: Specifies a MAC address, in H-H-H format.
vlan vlan-id: Specifies the VLAN to which the secure MAC address belongs. The value range for the vlan-id argument is 1 to 4094.
Secure MAC addresses are MAC addresses configured or learned in autoLearn mode, and if saved, can survive a device reboot. You can bind a secure MAC address only to one port in a VLAN.
You can add important or frequently used MAC addresses as sticky or static secure MAC addresses to avoid the secure MAC address limit causing authentication failure. To successfully add secure MAC addresses on a port, first complete the following tasks:
· Enable port security on the port.
· Set the port security mode to autoLearn.
· Configure the port to permit packets of the specified VLAN to pass or add the port to the VLAN. Make sure the VLAN already exists.
Sticky MAC addresses can be manually configured or automatically learned in autoLearn mode. Sticky MAC addresses do not age out by default. You can use the port-security timer autolearn aging command to set an aging timer for the sticky MAC addresses. When the timer expires, the sticky MAC addresses are removed.
Static secure MAC addresses never age out unless you perform the following operations:
· Remove these MAC addresses by using the undo port-security mac-address security command.
· Change the port security mode.
· Disable the port security feature.
You cannot change the type of a secure address entry that has been added or add two entries that are identical except for their entry type. For example, you cannot add the port-security mac-address security sticky 1-1-1 vlan 10 entry when a port-security mac-address security 1-1-1 vlan 10 entry exists. To add the new entry, you must delete the old entry.
# Enable port security, set Ten-GigabitEthernet 1/0/1 to operate in autoLearn mode, and configure the port to support a maximum number of 100 secure MAC addresses.
[Sysname-Ten-GigabitEthernet1/0/1] port-security max-mac-count 100
[Sysname-Ten-GigabitEthernet1/0/1] port-security port-mode autolearn
# Specify MAC address 0001-0002-0003 in VLAN 4 as a sticky MAC address.
[Sysname-Ten-GigabitEthernet1/0/1] port-security mac-address security sticky 0001-0002-0003 vlan 4
# In system view, specify MAC address 0001-0001-0002 in VLAN 10 as a secure MAC address for Ten-GigabitEthernet 1/0/1.
[Sysname] port-security mac-address security 0001-0001-0002 interface ten-gigabitethernet 1/0/1 vlan 10
port-security mac-limit
Use port-security mac-limit to set the maximum number of MAC addresses that port security allows for specific VLANs on a port.
Use undo port-security mac-limit to restore the default.
port-security mac-limit max-number per-vlan vlan-id-list
undo port-security mac-limit per-vlan vlan-id-list
The maximum number is 2147483647.
max-number: Specifies the maximum number of MAC addresses. The value range is 1 to 2147483647.
per-vlan vlan-id-list: Applies the maximum number to a VLAN list on per-VLAN basis. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by VLAN ID or specifies a range of VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
This command limits the number of MAC addresses that port security allows to access a port through specific VLANs. Use this command to prevent resource contentions among MAC addresses and ensure reliable performance for each access user on the port. When the number of MAC addresses in a VLAN on the port reaches the upper limit, the device denies any subsequent MAC addresses in the VLAN on the port.
Port security allows the access of the following types of MAC addresses on a port:
· MAC addresses that pass 802.1X or MAC authentication.
· MAC addresses in the MAC authentication guest VLAN or MAC authentication critical VLAN and MAC addresses in the MAC authentication guest VSI or MAC authentication critical VSI.
· MAC addresses in the 802.1X guest VLAN, 802.1X Auth-Fail VLAN, or 802.1X critical VLAN and MAC addresses in the 802.1X guest VSI, 802.1X Auth-Fail VSI, or 802.1X critical VSI.
On a port, the maximum number of MAC addresses in a VLAN cannot be smaller than the number of existing MAC addresses in the VLAN. If the specified maximum number is smaller, the setting does not take effect.
# On Ten-GigabitEthernet 1/0/1, configure VLAN 1, VLAN 5, and VLANs 10 through 20 each to allow a maximum of 32 MAC authentication and 802.1X users.
[Sysname-Ten-GigabitEthernet1/0/1] port-security mac-limit 32 per-vlan 1 5 10 to 20
display dot1x
port-security mac-move permit
Use port-security mac-move permit to enable MAC move on the device.
Use undo port-security mac-move permit to disable MAC move on the device.
MAC move is disabled on the device.
This command takes effect on both 802.1X and MAC authentication users.
MAC move allows 802.1X or MAC authenticated users to move between ports on a device. For example, if an 802.1X-authenticated user moves to another 802.1X-enabled port on the device, the authentication session is deleted from the first port. The user is reauthenticated on the new port.
If MAC move is disabled, 802.1X or MAC users authenticated on one port cannot pass authentication after they move to another port.
802.1X or MAC authenticated users cannot move between ports on a device if the number of online users on the authentication server (local or remote) has reached the upper limit.
# Enable MAC move.
[Sysname] port-security mac-move permit
Use port-security max-mac-count to set the maximum number of secure MAC addresses that port security allows on a port.
Use undo port-security max-mac-count to restore the default.
port-security max-mac-count max-count [ vlan [ vlan-id-list ] ]
undo port-security max-mac-count [ vlan [ vlan-id-list ] ]
Port security does not limit the number of secure MAC addresses on a port.
max-count: Specifies the maximum number of secure MAC addresses that port security allows on the port. The value range is 1 to 2147483647.
vlan [ vlan-id-list ]: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN ID or a range of VLAN IDs in the form of start-vlan-id to end-vlan-id. The end VLAN ID cannot be smaller than the start VLAN ID. The value range for VLAN IDs is 1 to 4094. If you do not specify the vlan keyword, this command sets the maximum number of secure MAC addresses that port security allows on a port. If you do not specify the vlan-id-list argument, this command sets the maximum number of secure MAC addresses for each VLAN on the port. This option takes effect only on a port that operates in autoLearn mode.
For autoLearn mode, this command sets the maximum number of secure MAC addresses (both configured and automatically learned) on the port.
In any other mode that enables 802.1X, MAC authentication, or both, this command sets the maximum number of authenticated MAC addresses on the port. The actual maximum number of concurrent users that the port accepts equals the smaller of the following values:
· The value set by using this command.
· The maximum number of concurrent users allowed by the authentication mode in use.
For example, in userLoginSecureExt mode, if 802.1X allows more concurrent users than port security's limit on the number of MAC addresses, port security's limit takes effect.
When you configure this command, follow these guidelines and restrictions:
· Make sure the maximum number of secure MAC addresses for a VLAN is not less than the number of MAC addresses currently saved for the VLAN.
· If you execute this command multiple times to set the maximum number of secure MAC addresses for the same VLAN, the most recent configuration takes effect.
· You cannot change port security's limit on the number of MAC addresses when the port is operating in autoLearn mode.
# Set the maximum number of secure MAC address port security allows on Ten-GigabitEthernet 1/0/1 to 100.
port-security nas-id-profile
Use port-security nas-id-profile to apply a NAS-ID profile to global or port-based port security.
Use undo port-security nas-id-profile to restore the default.
port-security nas-id-profile profile-name
No NAS-ID profile is applied to port security globally or on any port.
profile-name: Specifies a NAS-ID profile by its name. The argument is a case-insensitive string of 1 to 31 characters.
A NAS-ID profile defines NAS-ID and VLAN bindings. You can create a NAS-ID profile by using the aaa nas-id profile command.
The device selects a NAS-ID profile for a port in the following order:
1. The port-specific NAS-ID profile.
2. The NAS-ID profile applied globally.
If no NAS-ID profile is applied or no matching binding is found in the selected profile, the device uses the device name as the NAS-ID.
# Apply NAS-ID profile aaa to Ten-GigabitEthernet 1/0/1 for port security.
[Sysname-Ten-GigabitEthernet1/0/1] port-security nas-id-profile aaa
# Globally apply NAS-ID profile aaa to port security.
[Sysname] port-security nas-id-profile aaa
aaa nas-id profile
port-security ntk-mode
Use port-security ntk-mode to configure the NTK feature.
Use undo port-security ntk-mode to restore the default.
port-security ntk-mode { ntk-withbroadcasts | ntk-withmulticasts | ntkauto | ntkonly }
The NTK feature is not configured on a port and all frames are allowed to be sent.
ntk-withbroadcasts: Forwards only broadcast frames and unicast frames with authenticated destination MAC addresses.
ntk-withmulticasts: Forwards only broadcast frames, multicast frames, and unicast frames with authenticated destination MAC addresses.
ntkauto: Forwards broadcast frames, multicast frames, and unicast frames with authenticated destination MAC addresses only when the port has online users.
ntkonly: Forwards only unicast frames with authenticated destination MAC addresses.
The NTK feature checks the destination MAC addresses in outbound frames. This feature allows frames to be sent only to devices passing authentication, preventing illegal devices from intercepting network traffic.
# Set the NTK mode of Ten-GigabitEthernet 1/0/1 to ntkonly, allowing the port to forward received packets only to devices passing authentication.
[Sysname-Ten-GigabitEthernet1/0/1] port-security ntk-mode ntkonly
port-security oui
Use port-security oui to configure an OUI value for user authentication.
Use undo port-security oui to delete the OUI value with the specified OUI index.
port-security oui index index-value mac-address oui-value
undo port-security oui index index-value
No OUI values are configured.
index-value: Specifies the OUI index, in the range of 1 to 16.
oui-value: Specifies an OUI string, a 48-bit MAC address in the H-H-H format. The system uses only the 24 high-order bits as the OUI value.
You can configure multiple OUI values.
An OUI, the first 24 binary bits of a MAC address, is assigned by IEEE to uniquely identify a device vendor. Use this command to allow devices of specific vendors to access the network without being authenticated. For example, you can specify the OUIs of IP phones and printers.
The OUI values configured by this command apply only to the ports operating in userLoginWithOUI mode. In userLoginWithOUI mode, a port allows only one 802.1X user and one user whose MAC address matches one of the configured OUI values.
# Configure an OUI value of 000d2a, and set the index to 4.
[Sysname] port-security oui index 4 mac-address 000d-2a10-0033
Use port-security port-mode to set the port security mode of a port.
Use undo port-security port-mode to restore the default.
port-security port-mode { autolearn | mac-authentication | mac-else-userlogin-secure | mac-else-userlogin-secure-ext | secure | userlogin | userlogin-secure | userlogin-secure-ext | userlogin-secure-or-mac | userlogin-secure-or-mac-ext | userlogin-withoui }
A port operates in noRestrictions mode, where port security does not take effect.
Keyword |
Security mode |
autolearn |
autoLearn |
A port in this mode can learn MAC addresses. The automatically learned MAC addresses are not added to the MAC address table as dynamic MAC address. Instead, the MAC addresses are added to the secure MAC address table as secure MAC addresses. You can also configure secure MAC addresses by using the port-security mac-address security command. A port in autoLearn mode allows frames sourced from the following MAC addresses to pass: · Secure MAC addresses. · MAC addresses configured by using the mac-address dynamic and mac-address static commands. When the number of secure MAC addresses reaches the upper limit set by the port-security max-mac-count command, the port changes to secure mode. |
macAddressWithRadius |
In this mode, a port performs MAC authentication for users and services multiple users. |
macAddressElseUserLoginSecure |
This mode is the combination of the macAddressWithRadius and userLoginSecure modes, with MAC authentication having a higher priority. In this mode, the port allows one 802.1X authentication user and multiple MAC authentication users to log in. · Upon receiving a non-802.1X frame, a port in this mode performs only MAC authentication. · Upon receiving an 802.1X frame, the port performs MAC authentication and then, if MAC authentication fails, 802.1X authentication. |
macAddressElseUserLoginSecureExt |
Same as the macAddressElseUserLoginSecure mode except that a port in this mode supports multiple 802.1X and MAC authentication users. |
secure |
secure |
In this mode, MAC address learning is disabled on the port and you can configure MAC addresses by using the mac-address static and mac-address dynamic commands. The port permits only frames sourced from the following MAC addresses to pass: · Secure MAC addresses. · MAC addresses configured by using the mac-address static and mac-address dynamic commands. |
userlogin |
userLogin |
In this mode, a port performs 802.1X authentication and implements port-based access control. If one 802.1X user passes authentication, all the other 802.1X users of the port can access the network without authentication. |
userlogin-secure |
userLoginSecure |
In this mode, a port performs 802.1X authentication and implements MAC-based access control. The port services only one user passing 802.1X authentication. |
userLoginSecureExt |
Same as the userLoginSecure mode, except that this mode supports multiple online 802.1X users. |
macAddressOrUserLoginSecure |
This mode is the combination of the userLoginSecure and macAddressWithRadius modes. In this mode, the port allows one 802.1X authentication user and multiple MAC authentication users to log in. In this mode, the port performs 802.1X authentication first. By default, if 802.1X authentication fails, MAC authentication is performed. However, the port in this mode processes authentication differently when the following conditions exist: · The port is enabled with parallel processing of MAC authentication and 802.1X authentication. · The port is enabled with the 802.1X unicast trigger. · The port receives a packet from an unknown MAC address. Under such conditions, the port sends a unicast EAP-Request/Identity packet to the MAC address to initiate 802.1X authentication. After that, the port immediately processes MAC authentication without waiting for the 802.1X authentication result. |
macAddressOrUserLoginSecureExt |
Same as the macAddressOrUserLoginSecure mode, except that a port in this mode supports multiple 802.1X and MAC authentication users. |
userlogin-withoui |
userLoginWithOUI |
Similar to the userLoginSecure mode. In addition, a port in this mode also permits frames from a user whose MAC address contains a specific OUI. In this mode, the port performs OUI check at first. If the OUI check fails, the port performs 802.1X authentication. The port permits frames that pass OUI check or 802.1X authentication. |
NOTE: · The autolearn, secure, and userlogin-withoui keywords are not supported on Layer 2 aggregate interfaces. |
To change the security mode for a port security enabled port, you must set the port in noRestrictions mode first. Do not change port security mode when the port has online users.
IMPORTANT: If you are configuring the autoLearn mode, first set port security's limit on the number of secure MAC addresses by using the port-security max-mac-count command. You cannot change the setting when the port is operating in autoLearn mode. |
When port security is enabled, you cannot enable 802.1X or MAC authentication, or change the access control mode or port authorization state. The port security automatically modifies these settings in different security modes.
As a best practice, do not enable the mac-else-userlogin-secure or mac-else-userlogin-secure-ext mode on the port where MAC authentication delay is enabled. The two modes are mutually exclusive with the MAC authentication delay feature. For more information about MAC authentication delay, see "MAC authentication commands."
# Enable port security, and set Ten-GigabitEthernet 1/0/1 to operate in secure mode.
[Sysname-Ten-GigabitEthernet1/0/1] port-security port-mode secure
# Change the port security mode of Ten-GigabitEthernet 1/0/1 to userLogin.
[Sysname-Ten-GigabitEthernet1/0/1] undo port-security port-mode
[Sysname-Ten-GigabitEthernet1/0/1] port-security port-mode userlogin
Use port-security timer autolearn aging to set the secure MAC aging timer.
Use undo port-security timer autolearn aging to restore the default.
port-security timer autolearn aging [ second ] time-value
Secure MAC addresses do not age out.
second: Specifies the aging timer in seconds for secure MAC addresses. If you do not specify this keyword, the command sets the aging timer in minutes for secure MAC addresses.
time-value: Specifies the aging timer. The value range is 0 to 129600 if the unit is minute. To disable the aging timer, set the timer to 0. The value range is 10 to 7776000 if the unit is second.
The timer applies to all sticky secure MAC addresses and those automatically learned by a port.
The effective aging timer varies by the aging timer setting:
· If the aging timer is set in seconds, the effective aging timer can be either of the following values:
¡ The nearest multiple of 30 seconds to the configured aging timer if the configured timer is not less than 60 seconds. The effective aging timer is not less than the configured aging timer.
¡ The configured aging timer if the configured timer is less than 60 seconds.
· If the aging timer is set in minutes, the effective aging timer is the configured aging timer.
A short aging time improves port access security and port resource utility but affects online user stability. Set an appropriate secure MAC address aging timer according to your device performance and the network environment.
When a short aging time (less than 60 seconds) works with inactivity aging, do not assign a large value to the maximum number of secure MAC addresses on a port. A large value in this case might affect device performance.
# Set the secure MAC aging timer to 30 minutes.
[Sysname] port-security timer autolearn aging 30
# Set the secure MAC aging timer to 50 seconds.
[Sysname] port-security timer autolearn aging second 50
Use port-security timer disableport to set the silence period during which the port remains disabled.
Use undo port-security timer disableport to restore the default.
port-security timer disableport time-value
The port silence period is 20 seconds.
time-value: Specifies the silence period in seconds during which the port remains disabled. The value is in the range of 20 to 300.
If you configure the intrusion protection action as disabling the port temporarily, use this command to set the silence period.
# Configure the intrusion protection action on Ten-GigabitEthernet 1/0/1 as disabling the port temporarily, and set the port silence period to 30 seconds.
[Sysname] port-security timer disableport 30
[Sysname-Ten-GigabitEthernet1/0/1] port-security intrusion-mode disableport-temporarily
Use snmp-agent trap enable port-security to enable SNMP notifications for port security.
Use undo snmp-agent trap enable port-security to disable SNMP notifications for port security.
snmp-agent trap enable port-security [ address-learned | dot1x-failure | dot1x-logoff | dot1x-logon | intrusion | mac-auth-failure | mac-auth-logoff | mac-auth-logon ] *
undo snmp-agent trap enable port-security [ address-learned | dot1x-failure | dot1x-logoff | dot1x-logon | intrusion | mac-auth-failure | mac-auth-logoff | mac-auth-logon ] *
All port security SNMP notifications are disabled.
address-learned: Specifies notifications about MAC address learning.
dot1x-failure: Specifies notifications about 802.1X authentication failures.
dot1x-logoff: Specifies notifications about 802.1X user logoffs.
dot1x-logon: Specifies notifications about 802.1X authentication successes.
intrusion: Specifies notifications about illegal frame detection.
mac-auth-failure: Specifies notifications about MAC authentication failures.
mac-auth-logoff: Specifies notifications about MAC authentication user logoffs.
mac-auth-logon: Specifies notifications about MAC authentication successes.
To report critical port security events to an NMS, enable SNMP notifications for port security. For port security event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
If you do not specify a notification, this command enables all SNMP notifications for port security.
For this command to take effect, make sure the intrusion protection feature is configured.
# Enable SNMP notifications about MAC address learning.
[Sysname] snmp-agent trap enable port-security address-learned
