11 High Availability Command Reference
HomeSupportSwitchesS7500E-X SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release757X-6W10011 High Availability Command Reference
07-Monitor Link commands
07-Monitor Link commands 51.48 KB
display monitor-link group
Use display monitor-link group to display information about monitor link groups.
display monitor-link group { group-id | all }
group-id: Specifies a monitor link group by its ID. The value range for this argument is 1 to 16.
all: Specifies all monitor link groups.
This command does not display information about ports that belong to a link aggregation group.
# Display information about all monitor link groups.
<Sysname> display monitor-link group all
Monitor link protocol status: Disabled
Monitor link group 1 information:
  Group status     : N/A
  Downlink up-delay: 0(s)
  Last-up-time     : -
  Last-down-time   : -
  Up-port-threshold: 1
  Member                    Role       Status
  XGE1/0/1                  UPLINK     UP
  XGE1/0/2                  DOWNLINK   UP
Whether Monitor Link is enabled:
·     Enabled.
·     Disabled.
Group status
Monitor link group status:
·     DOWN.
·     UP.
·     N/A—Monitor Link is disabled globally. The monitor link group does not operate.
Downlink up-delay
Switchover delay of the downlink interfaces in the monitor link group, in seconds.
Last-up-time
Last time when the monitor link group came up.
Last-down-time
Last time when the monitor link group went down.
Up-port-threshold
Uplink interface threshold for triggering monitor link group state switchover.
Member
Member interfaces of the monitor link group.
Role
Interface role, which can be uplink interface or downlink interface.
Status
Member interface state, which can be up or down.
downlink up-delay
Use downlink up-delay to set the switchover delay for the downlink interfaces in a monitor link group.
Use undo downlink up-delay to restore the default.
downlink up-delay delay
The switchover delay is 0 seconds. The downlink interfaces come up as soon as an uplink interface in the monitor link group comes up.
Monitor link group view
delay: Sets the switchover delay in the range of 1 to 300 seconds.
To avoid frequent state changes of downlink interfaces in the event that the uplink interfaces in the monitor link group flap, you can configure a switchover delay. The switchover delay is the time that the downlink interfaces wait before they come up following an uplink interface.
# Set the switchover delay to 50 seconds for the downlink interfaces in monitor link group 1.
[Sysname] monitor-link group 1
[Sysname-mtlk-group1] downlink up-delay 50
monitor-link disable
Use monitor-link disable to disable Monitor Link globally.
Use undo monitor-link disable to enable Monitor Link globally.
Monitor Link is enabled globally.
All monitor link groups can operate only after you enable Monitor Link globally. When you disable Monitor Link globally, all monitor link groups cannot operate and the downlink interfaces brought down by the monitor link groups resume their original states.
# Disable Monitor Link globally.
[Sysname] monitor-link disable
monitor-link group
Use monitor-link group to create a monitor link group and enter its view, or enter the view of an existing monitor link group.
Use undo monitor-link group to remove a monitor link group.
monitor-link group group-id
undo monitor-link group group-id
No monitor link groups exist.
group-id: Specifies a monitor link group ID. The value range for this argument is 1 to 16.
# Create monitor link group 1 and enter its view.
port
Use port to assign an interface to a monitor link group.
Use undo port to remove an interface from a monitor link group.
port interface-type { interface-number | interface-number.subnumber } { downlink | uplink }
undo port interface-type interface-number
No member interfaces exist in a monitor link group.
interface-type: Specifies an interface by its type.
interface-number: Specifies an interface by its number.
interface-number.subnumber: Specifies a subinterface by its number. The argument subnumber is in the range of 1 to 4094.
downlink: Specifies a downlink interface.
uplink: Specifies an uplink interface.
You can assign an interface to only one monitor link group.
You can also assign an interface to a monitor link group by using the port monitor-link group command in interface view.
If you have configured an interface as the downlink interface of a monitor link group, do not configure its subinterfaces as the uplink interfaces of any monitor link group.
Because the state of subinterfaces is associated with the state of the interface, do not add them to the same monitor link group.
If you have configured a Selected port of an aggregation group as the downlink interface of a monitor link group, do not configure an Unselected port of the aggregation group as the uplink interface of the monitor link group.
Do not assign an aggregate interface and member ports of the aggregate group to the same monitor link group.
# Configure Ten-GigabitEthernet 1/0/1 as an uplink interface and Ten-GigabitEthernet 1/0/2 as a downlink interface for monitor link group 1.
[Sysname-mtlk-group1] port ten-gigabitethernet 1/0/1 uplink
[Sysname-mtlk-group1] port ten-gigabitethernet 1/0/2 downlink
Use port monitor-link group to assign an interface to a monitor link group.
Use undo port monitor-link group to remove an interface from a monitor link group.
port monitor-link group group-id { downlink | uplink }
undo port monitor-link group group-id
An interface is not a monitor link group member.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
S-channel interface/S-channel aggregate interface view
Loopback interface view
You can also assign an interface to a monitor link group by using the port command in monitor link group view.
Because the state of subinterfaces is associated with the state of the interface, do not add the interface and its subinterfaces to the same monitor link group.
[Sysname-mtlk-group1] quit
[Sysname-Ten-GigabitEthernet1/0/1] port monitor-link group 1 uplink
[Sysname-Ten-GigabitEthernet1/0/2] port monitor-link group 1 downlink
port
uplink up-port-threshold
Use uplink up-port-threshold to configure the uplink interface threshold for triggering monitor link group state switchover.
Use undo uplink up-port-threshold to restore the default.
uplink up-port-threshold number-of-port
The uplink interface threshold for triggering monitor link group state switchover is 1.
number-of-port: Specifies the uplink interface threshold for triggering monitor link group state switchover, in the range of 1 to 1024.
When the number of uplink interfaces in up state in a monitor link group is less than the specified threshold, the monitor link group goes down and shuts down its downlink interfaces. When the number of uplink interfaces in up state reaches the threshold, the monitor link group comes up and brings up all its downlink interfaces.
As a best practice, use the display monitor-link group command to display the total number of uplink interfaces before executing the uplink up-port-threshold command. If you set the threshold to be greater than the total number of uplink interfaces, the monitor link group cannot come up and data will be lost.
# Set the uplink interface threshold for triggering monitor link group state switchover to 5.
[Sysname-mtlk-group1] uplink up-port-threshold 5
