08-MPLS Configuration Guide
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Switch Series Configuration Guides-Release757X-6W10008-MPLS Configuration Guide
04-MPLS TE configuration
04-MPLS TE configuration 546.29 KB
Configuring MPLS TE· 1
Overview·· 1
TE and MPLS TE· 1
MPLS TE basic concepts· 1
Static CRLSP establishment 1
Dynamic CRLSP establishment 1
CRLSP establishment using PCE path calculation· 3
Traffic forwarding· 4
Make-before-break· 5
Route pinning· 6
Tunnel reoptimization· 6
CRLSP backup· 6
FRR·· 6
Bidirectional MPLS TE tunnel 7
Protocols and standards· 8
Restrictions and guidelines for MPLS TE· 8
MPLS TE configuration task list 8
Enabling MPLS TE· 10
Configuring a tunnel interface· 10
Configuring an MPLS TE tunnel to use a static CRLSP· 11
Configuring an MPLS TE tunnel to use a dynamic CRLSP· 11
Configuration task list 11
Configuring MPLS TE attributes for a link· 12
Advertising link TE attributes by using IGP TE extension· 12
Configuring MPLS TE tunnel constraints· 13
Establishing an MPLS TE tunnel by using RSVP-TE· 15
Controlling CRLSP path selection· 15
Controlling MPLS TE tunnel setup· 17
Configuring an MPLS TE tunnel to use a CRLSP calculated by PCEs· 19
Configuring a PCE· 19
Discovering PCEs· 19
Establishing a CRLSP by using the path calculated by PCEs· 20
Establishing a backup CRLSP by using the path calculated by PCEs· 20
Configuring PCEP session parameters· 20
Configuring traffic forwarding· 21
Configuring static routing to direct traffic to an MPLS TE tunnel 21
Configuring automatic route advertisement to direct traffic to an MPLS TE tunnel 21
Configuring a bidirectional MPLS TE tunnel 22
Configuring CRLSP backup· 23
Configuring MPLS TE FRR·· 24
Enabling FRR·· 24
Configuring a bypass tunnel on the PLR·· 24
Configuring node fault detection· 28
Setting the optimal bypass tunnel selection interval 28
Enabling SNMP notifications for MPLS TE· 29
Displaying and maintaining MPLS TE· 29
MPLS TE configuration examples· 30
Establishing an MPLS TE tunnel over a static CRLSP· 30
Establishing an MPLS TE tunnel with RSVP-TE· 34
Establishing an inter-AS MPLS TE tunnel with RSVP-TE· 40
Establishing an inter-area MPLS TE tunnel over a CRLSP calculated by PCEs· 47
Bidirectional MPLS TE tunnel configuration example· 52
CRLSP backup configuration example· 58
Manual bypass tunnel for FRR configuration example· 62
Auto FRR configuration example· 68
Troubleshooting MPLS TE· 74
No TE LSA generated· 74
Configuring MPLS TE
Overview
TE and MPLS TE
Network congestion can degrade the network backbone performance. It might occur when network resources are inadequate or when load distribution is unbalanced. Traffic engineering (TE) is intended to avoid the latter situation where partial congestion might occur because of improper resource allocation.
TE can make the best use of network resources and avoid uneven load distribution by using the following functionalities:
·     Real-time monitoring of traffic and traffic load on network elements.
·     Dynamic tuning of traffic management attributes, routing parameters, and resources constraints.
MPLS TE combines the MPLS technology and traffic engineering. It reserves resources by establishing LSP tunnels along the specified paths, allowing traffic to bypass congested nodes to achieve appropriate load distribution.
With MPLS TE, a service provider can deploy traffic engineering on the existing MPLS backbone to provide various services and optimize network resources management.
·     CRLSP—Constraint-based Routed Label Switched Path. To establish a CRLSP, you must configure routing, and specify constraints, such as the bandwidth and explicit paths.
·     MPLS TE tunnel—A virtual point-to-point connection from the ingress node to the egress node. Typically, an MPLS TE tunnel consists of one CRLSP. To deploy CRLSP backup or transmit traffic over multiple paths, you need to establish multiple CRLSPs for one class of traffic. In this case, an MPLS TE tunnel consists of a set of CRLSPs. An MPLS TE tunnel is identified by an MPLS TE tunnel interface on the ingress node. When the outgoing interface of a traffic flow is an MPLS TE tunnel interface, the traffic flow is forwarded through the CRLSP of the MPLS TE tunnel.
A static CRLSP is established by manually specifying the incoming label, outgoing label, and other constraints on each hop along the path that the traffic travels. Static CRLSPs feature simple configuration, but they cannot automatically adapt to network changes.
For more information about static CRLSPs, see "Configuring a static CRLSP."
Dynamic CRLSPs are dynamically established as follows:
1.     An IGP advertises TE attributes for links.
2.     MPLS TE uses the CSPF algorithm to calculate the shortest path to the tunnel destination.
The path must meet constraints such as bandwidth and explicit routing.
3.     A label distribution protocol (such as RSVP-TE) advertises labels to establish CRLSPs and reserves bandwidth resources on each node along the calculated path.
Dynamic CRLSPs adapt to network changes and support CRLSP backup and fast reroute, but they require complicated configurations.
Advertising TE attributes
MPLS TE uses extended link state IGPs, such as OSPF and IS-IS, to advertise TE attributes for links.
TE attributes include the maximum bandwidth, maximum reservable bandwidth, non-reserved bandwidth for each priority, and the link attribute. The IGP floods TE attributes on the network. Each node collects the TE attributes of all links on all routers within the local area or at the same level to build up a TE database (TEDB).
Calculating paths
Based on the TEDB, MPLS TE uses the Constraint-based Shortest Path First (CSPF) algorithm, an improved SPF algorithm, to calculate the shortest, TE constraints-compliant path to the tunnel destination.
CSPF first prunes TE constraints-incompliant links from the TEDB, and then it performs SPF calculation to identify the shortest path (a set of LSR addresses) to an egress. CSPF calculation is usually performed on the ingress node of an MPLS TE tunnel.
TE constraints include the bandwidth, affinity, setup and holding priorities, and explicit path. They are configured on the ingress node of an MPLS TE tunnel.
·     Bandwidth
Bandwidth constraints specify the class of service and the required bandwidth for the traffic to be forwarded along the MPLS TE tunnel. A link complies with the bandwidth constraints when the reservable bandwidth for the class type is greater than or equal to the bandwidth required by the class type.
·     Affinity
Affinity determines which links a tunnel can use. The affinity attribute and its mask, and the link attribute are all 32-bit long. A link is available for a tunnel if the link attribute meets the following requirements:
¡     The link attribute bits corresponding to the affinity attribute's 1 bits whose mask bits are 1 must have a minimum of one bit set to 1.
¡     The link attribute bits corresponding to the affinity attribute's 0 bits whose mask bits are 1 must have no bit set to 1.
The link attribute bits corresponding to the 0 bits in the affinity mask are not checked.
For example, if the affinity attribute is 0xFFFFFFF0 and its mask is 0x0000FFFF, a link is available for the tunnel when its link attribute bits meet the following requirements:
¡     The highest 16 bits each can be 0 or 1 (no requirements).
¡     The 17th through 28th bits must have a minimum of one bit whose value is 1.
¡     The lowest four bits must be 0.
·     Setup priority and holding priority
If MPLS TE cannot find a qualified path to set up an MPLS TE tunnel, it removes an existing MPLS TE tunnel and preempts its bandwidth.
MPLS TE uses the setup priority and holding priority to make preemption decisions. For a new MPLS TE tunnel to preempt an existing MPLS TE tunnel, the setup priority of the new tunnel must be higher than the holding priority of the existing tunnel. Both setup and holding priorities are in the range of 0 to 7. A smaller value represents a higher priority.
To avoid flapping caused by improper preemptions, the setup priority value of a tunnel must be equal to or greater than the holding priority value.
·     Explicit path
Explicit path specifies the nodes to pass and the nodes to not pass for a tunnel.
Explicit paths include the following types:
¡     Strict explicit path—Among the nodes that the path must traverse, a node and its previous hop must be directly connected. Strict explicit path precisely specifies the path that an MPLS TE tunnel must traverse.
¡     Loose explicit path—Among the nodes that the path must traverse, a node and its previous hop can be indirectly connected. Loose explicit path vaguely specifies the path that an MPLS TE tunnel must traverse.
Strict explicit path and loose explicit path can be used together to specify that some nodes are directly connected and some nodes have other nodes in between.
Setting up a CRLSP through RSVP-TE
After calculating a path by using CSPF, MPLS TE uses a label distribution protocol to set up the CRLSP and reserves resources on each node of the path.
The device supports the label distribution protocol of RSVP-TE for MPLS TE. Resource Reservation Protocol (RSVP) reserves resources on each node along a path. Extended RSVP can support MPLS label distribution and allow resource reservation information to be transmitted with label bindings. This extended RSVP is called RSVP-TE.
For more information about RSVP, see "Configuring RSVP."
On an MPLS TE network, a Path Computation Client (PCC), usually an LSR, uses the path calculated by Path Computation Elements (PCEs) to establish a CRLSP through RSVP-TE.
Basic concepts
·     PCE—An entity that can calculate a path based on the TEDB, bandwidth, and other MPLS TE tunnel constraints. A PCE can provide intra-area or inter-area path calculation. A PCE can be manually specified on a PCC or automatically discovered through the PCE information advertised by OSPF TE.
·     PCC—A PCC sends a request to PCEs for path calculation and uses the path information returned by PCEs to establish a CRLSP.
·     PCEP—Path Computation Element Communication Protocol. PCEP runs between a PCC and a PCE, or between PCEs. It is used to establish PCEP sessions to exchange PCEP messages over TCP connections.
PCE path calculation has the following types:
·     EPC—External Path Computation. EPC path calculation is performed by one PCE. It is applicable to intra-area path calculation.
·     BRPC—Backward-Recursive PCE-Based Computation. BRPC path calculation is performed by multiple PCEs. It is applicable to inter-area path calculation.
As shown in Figure 1, PCE 1 is the ABR that can calculate paths in Area 0 and Area 1. PCE 2 is the ABR that can calculate paths in Area 1 and Area 2. The CRLSP that PCC uses to reach a destination in Area 2 is established as follows:
1.     PCC sends a path calculation request to PCE 1 to request the path to the CRLSP destination.
2.     PCE 1 forwards the request to PCE 2.
PCE 1 cannot calculate paths in Area 2, so it forwards the request to PCE 2, the PCE responsible for Area 2 that contains the CRLSP destination.
3.     After receiving the request from PCE 1, PCE 2 calculates potential paths to the CRLSP destination and sends the path information back to PCE 1 in a reply.
4.     PCE 1 uses the local and received path information to select an end-to-end path for the PCC to reach the CRLSP destination, and sends the path to PCC as a reply.
5.     PCC uses the path calculated by PCEs to establish the CRLSP through RSVP-TE.
Figure 1 BRPC path calculation
Traffic forwarding
After an MPLS TE tunnel is established, traffic is not forwarded on the tunnel automatically. You must direct the traffic to the tunnel by using one of the following methods:
Static routing
You can direct traffic to an MPLS TE tunnel by creating a static route that reaches the destination through the tunnel interface. This is the easiest way to implement MPLS TE tunnel forwarding. When traffic to multiple networks is to be forwarded through the MPLS TE tunnel, you must configure multiple static routes, which are complicated to configure and difficult to maintain.
For more information about static routing, see Layer 3—IP Routing Configuration Guide.
Automatic route advertisement
You can also configure automatic route advertisement to forward traffic through an MPLS TE tunnel. Automatic route advertisement distributes the MPLS TE tunnel to the IGP (OSPF or IS-IS), so the MPLS TE tunnel can participate in IGP routing calculation. Automatic route advertisement is easy to configure and maintain.
Automatic route advertisement can be implemented by using the following methods:
·     IGP shortcut—Also known as AutoRoute Announce. It considers the MPLS TE tunnel as a link that directly connects the tunnel ingress node and the egress node. Only the ingress node uses the MPLS TE tunnel during IGP route calculation.
·     Forwarding adjacency—Considers the MPLS TE tunnel as a link that directly connects the tunnel ingress node and the egress node, and advertises the link to the network through an IGP. Every node in the network uses the MPLS TE tunnel during IGP route calculation.
As shown in Figure 2, an MPLS TE tunnel exists from Router D to Router C. IGP shortcut enables only the ingress node Router D to use the MPLS TE tunnel in the IGP route calculation. Router A cannot use this tunnel to reach Router C. With forwarding adjacency enabled, Router A can learn this MPLS TE tunnel and transfer traffic to Router C by forwarding the traffic to Router D.
Figure 2 IGP shortcut and forwarding adjacency diagram
Make-before-break
Make-before-break is a mechanism to change an MPLS TE tunnel with minimum data loss and without using extra bandwidth.
In the case of tunnel reoptimization, traffic forwarding is interrupted if the existing CRLSP is removed before a new CRLSP is established. The make-before-break mechanism ensures that the existing CRLSP is removed after the new CRLSP is established and the traffic is switched to the new CRLSP. However, this wastes bandwidth resources if some links on the old and new CRLSPs are the same. This is because you need to reserve bandwidth on these links for the old and new CRLSPs separately. The make-before-break mechanism uses the SE resource reservation style to address this problem.
The resource reservation style refers to the style in which RSVP-TE reserves bandwidth resources during CRLSP establishment. The resource reservation style used by an MPLS TE tunnel is determined by the ingress node, and is advertised to other nodes through RSVP.
The device supports the following resource reservation styles:
·     FF—Fixed-filter, where resources are reserved for individual senders and cannot be shared among senders on the same session.
·     SE—Shared-explicit, where resources are reserved for senders on the same session and shared among them. SE is mainly used for make-before-break.
As shown in Figure 3, a CRLSP with 30 M reserved bandwidth has been set up from Router A to Router D through the path Router A—Router B—Router C—Router D.
To increase the reserved bandwidth to 40 M, a new CRLSP must be set up through the path Router A—Router E—Router C—Router D. To achieve this purpose, RSVP-TE needs to reserve 30 M bandwidth for the old CRLSP and 40 M bandwidth for the new CRLSP on the link Router C—Router D. However, there is not enough bandwidth.
After the make-before-break mechanism is used, the new CRLSP can share the bandwidth reserved for the old CRLSP. After the new CRLSP is set up, traffic is switched to the new CRLSP without service interruption, and then the old CRLSP is removed.
Figure 3 Diagram for make-before-break
Route pinning
Route pinning enables CRLSPs to always use the original optimal path even if a new optimal route has been learned.
On a network where route changes frequently occur, you can use route pinning to avoid re-establishing CRLSPs upon route changes.
Tunnel reoptimization allows you to manually or dynamically trigger the ingress node to recalculate a path. If the ingress node recalculates a better path, it creates a new CRLSP, switches traffic from the old CRLSP to the new, and then deletes the old CRLSP.
MPLS TE uses the tunnel reoptimization feature to implement dynamic CRLSP optimization. For example, if a link on the optimal path does not have enough reservable bandwidth, MPLS TE sets up the tunnel on another path. When the link has enough bandwidth, the tunnel optimization feature can switch the MPLS TE tunnel to the optimal path.
CRLSP backup
CRLSP backup uses a CRLSP to back up a primary CRLSP. When the ingress detects that the primary CRLSP fails, it switches traffic to the backup CRLSP. When the primary CRLSP recovers, the ingress switches traffic back.
CRLSP backup has the following modes:
·     Hot standby—A backup CRLSP is created immediately after a primary CRLSP is created.
·     Ordinary—A backup CRLSP is created after the primary CRLSP fails.
FRR
Fast reroute (FRR) protects CRLSPs from link and node failures. FRR can implement 50-millisecond CRLSP failover.
After FRR is enabled for an MPLS TE tunnel, once a link or node fails on the primary CRLSP, FRR reroutes the traffic to a bypass tunnel. The ingress node attempts to set up a new CRLSP. After the new CRLSP is set up, traffic is forwarded on the new CRLSP.
CRLSP backup provides end-to-end path protection for a CRLSP without time limitation. FRR provides quick but temporary protection for a link or node on a CRLSP.
Basic concepts
·     Primary CRLSP—Protected CRLSP.
·     Bypass tunnel—An MPLS TE tunnel used to protect a link or node of the primary CRLSP.
·     Point of local repair—A PLR is the ingress node of the bypass tunnel. It must be located on the primary CRLSP but must not be the egress node of the primary CRLSP.
·     Merge point—An MP is the egress node of the bypass tunnel. It must be located on the primary CRLSP but must not be the ingress node of the primary CRLSP.
Protection modes
FRR provides the following protection modes:
·     Link protection—The PLR and the MP are connected through a direct link and the primary CRLSP traverses this link. When the link fails, traffic is switched to the bypass tunnel. As shown in Figure 4, the primary CRLSP is Router A—Router B—Router C—Router D, and the bypass tunnel is Router B—Router F—Router C. This mode is also called next-hop (NHOP) protection.
Figure 4 FRR link protection
·     Node protection—The PLR and the MP are connected through a device and the primary CRLSP traverses this device. When the device fails, traffic is switched to the bypass tunnel. As shown in Figure 5, the primary CRLSP is Router A—Router B—Router C—Router D—Router E, and the bypass tunnel is Router B—Router F—Router D. Router C is the protected device. This mode is also called next-next-hop (NNHOP) protection.
Figure 5 FRR node protection
MPLS Transport Profile (MPLS-TP) uses bidirectional MPLS TE tunnels to implement 1:1 and 1+1 protection switching, and to support in-band detection tools and signaling protocols such as OAM and PSC.
A bidirectional MPLS TE tunnel includes a pair of CRLSPs in opposite directions. It can be established in the following modes:
·     Co-routed mode—Uses the extended RSVP-TE protocol to establish a bidirectional MPLS TE tunnel. RSVP-TE uses a Path message to advertise the labels assigned by the upstream LSR to the downstream LSR. RSVP-TE uses a Resv message to advertise the labels assigned by the downstream LSR to the upstream LSR. During the delivery of the path message, a CRLSP in one direction is established. During the delivery of the Resv message, a CRLSP in the other direction is established. The CRLSPs of a bidirectional MPLS TE tunnel established in co-routed mode use the same path.
·     Associated mode—In this mode, you establish a bidirectional MPLS TE tunnel by binding two unidirectional CRLSPs in opposite directions. The two CRLSPs can be established in different modes and use different paths. For example, one CRLSP is established statically and the other CRLSP is established dynamically by RSVP-TE.
For more information about establishing MPLS TE tunnel through RSVP-TE, the Path message, and the Resv message, see "Configuring RSVP."
·     RFC 2702, Requirements for Traffic Engineering Over MPLS
·     RFC 3564, Requirements for Support of Differentiated Service-aware MPLS Traffic Engineering
·     RFC 3812, Multiprotocol Label Switching (MPLS) Traffic Engineering (TE) Management Information Base (MIB)
·     RFC 4124, Protocol Extensions for Support of Diffserv-aware MPLS Traffic Engineering
·     RFC 4125, Maximum Allocation Bandwidth Constraints Model for Diffserv-aware MPLS Traffic Engineering
·     RFC 4127, Russian Dolls Bandwidth Constraints Model for Diffserv-aware MPLS Traffic Engineering
·     ITU-T Recommendation Y.1720, Protection switching for MPLS networks
·     RFC 4655, A Path Computation Element (PCE)-Based Architecture
·     RFC 5088, OSPF Protocol Extensions for Path Computation Element Discovery
·     RFC 5440, Path Computation Element (PCE) Communication Protocol (PCEP)
·     RFC 5441, A Backward-Recursive PCE-Based Computation (BRPC) Procedure to Compute Shortest Constrained Inter-Domain Traffic Engineering LSP
·     RFC 5455, Diffserv-Aware Class-Type Object for the Path Computation Element Communication Protocol
·     RFC 5521, Extensions to the Path Computation Element Communication Protocol (PCEP) for Route Exclusions
·     RFC 5886, A Set of Monitoring Tools for Path Computation Element (PCE)-Based Architecture
·     draft-ietf-pce-stateful-pce-07
The device does not support configuring bandwidth reservation in the current software version.
To configure an MPLS TE tunnel to use a static CRLSP, perform the following tasks:
1.     Enable MPLS TE on each node and interface that the MPLS TE tunnel traverses.
2.     Create a tunnel interface on the ingress node of the MPLS TE tunnel, and specify the tunnel destination address—the address of the egress node.
3.     Create a static CRLSP on each node that the MPLS TE tunnel traverses.
For information about creating a static CRLSP, see "Configuring a static CRLSP."
4.     On the ingress node of the MPLS TE tunnel, configure the tunnel interface to use the created static CRLSP.
5.     On the ingress node of the MPLS TE tunnel, configure static routing or automatic route advertisement to direct traffic to the MPLS TE tunnel.
To configure an MPLS TE tunnel to use a CRLSP dynamically established by RSVP-TE, perform the following tasks:
1.     Enable MPLS TE and RSVP on each node and interface that the MPLS TE tunnel traverses.
For information about enabling RSVP, see "Configuring RSVP."
2.     Create a tunnel interface on the ingress node of the MPLS TE tunnel. On the tunnel interface, specify the tunnel destination address (the egress node IP address), and configure MPLS TE tunnel constraints (such as the tunnel bandwidth constraints and affinity).
3.     Configure the link TE attributes (such as the maximum link bandwidth and link attribute) on each interface that the MPLS TE tunnel traverses.
4.     Configure an IGP on each node that the MPLS TE tunnel traverses, and configure the IGP to support MPLS TE. Then, the nodes can advertise the link TE attributes through the IGP.
5.     On the ingress node of the MPLS TE tunnel, configure RSVP-TE to establish a CRLSP based on the tunnel constraints and link TE attributes.
6.     On the ingress node of the MPLS TE tunnel, configure static routing or automatic route advertisement to direct traffic to the MPLS TE tunnel.
To configure an MPLS TE tunnel to use a PCE-calculated path to establish a CRLSP, perform the following tasks:
2.     Specify an LSR as a PCE and configure an IP address for the PCE.
3.     Create a tunnel interface on the ingress node of the MPLS TE tunnel. On the tunnel interface, specify the tunnel destination address (the egress node IP address), and configure MPLS TE tunnel constraints (such as the tunnel bandwidth constraints and affinity).
4.     Configure link TE attributes (such as the maximum link bandwidth and link attribute) on each interface that the MPLS TE tunnel traverses.
5.     Configure an IGP on each node that the MPLS TE tunnel traverses, and configure the IGP to support MPLS TE. Then, the nodes can advertise the link TE attributes through the IGP.
6.     Configure the ingress node of the MPLS TE tunnel to use the path calculated by the PCE. Manually specify the PCE or configure OSPF TE to dynamically discover the PCE on the ingress node (PCC).
7.     On the ingress node of the MPLS TE tunnel, configure RSVP-TE to establish a CRLSP based on the path calculated by the PCE.
8.     On the ingress node of the MPLS TE tunnel, configure static routing or automatic route advertisement to direct traffic to the MPLS TE tunnel.
You can also configure other MPLS TE features such as the DS-TE and FRR as needed.
To configure MPLS TE, perform the following tasks:
Tasks at a glance
(Required.) Enabling MPLS TE
(Required.) Configuring a tunnel interface
(Required.) Perform one of the following tasks to configure an MPLS TE tunnel:
·     Configuring an MPLS TE tunnel to use a static CRLSP
·     Configuring an MPLS TE tunnel to use a dynamic CRLSP
·     Configuring an MPLS TE tunnel to use a CRLSP calculated by PCEs
(Required.) Configuring traffic forwarding:
·     Configuring static routing to direct traffic to an MPLS TE tunnel
·     Configuring automatic route advertisement to direct traffic to an MPLS TE tunnel
(Optional.) Configuring a bidirectional MPLS TE tunnel
(Optional.) Configuring CRLSP backup
Only MPLS TE tunnels established by RSVP-TE support this configuration.
(Optional.) Configuring MPLS TE FRR
(Optional.) Enabling SNMP notifications for MPLS TE
Enabling MPLS TE
Before you enable MPLS TE, perform the following tasks:
·     Configure static routing or IGP to ensure that all LSRs can reach each other.
·     Enable MPLS. For information about enabling MPLS, see "Configuring basic MPLS."
To enable MPLS TE:
Step
Remarks
N/A
2.     Enter MPLS TE view.
mpls te
By default, MPLS TE is disabled.
3.     Return to system view.
N/A
4.     Enter interface view.
N/A
5.     Enable MPLS TE for the interface.
mpls te enable
By default, MPLS TE is disabled on an interface.
To configure an MPLS TE tunnel, you must create an MPLS TE tunnel interface and enter tunnel interface view. All MPLS TE tunnel attributes are configured in tunnel interface view. For more information about tunnel interfaces, see Layer 3—IP Services Configuration Guide.
Perform this task on the ingress node of the MPLS TE tunnel.
To configure a tunnel interface:
Step
Remarks
N/A
2.     Create an MPLS TE tunnel interface and enter tunnel interface view.
interface tunnel tunnel-number mode mpls-te
By default, no tunnel interfaces exist.
3.     Configure an IP address for the tunnel interface.
ip address ip-address { mask-length | mask }
By default, a tunnel interface does not have an IP address.
4.     Specify the tunnel destination address.
destination ip-address
By default, no tunnel destination address is specified.
·     Establish the static CRLSP.
·     Specify the MPLS TE tunnel establishment mode as static.
·     Configure the MPLS TE tunnel to use the static CRLSP.
Other configurations, such as tunnel constraints and IGP extension, are not needed.
To configure an MPLS TE tunnel to use a static CRLSP:
Step
Remarks
N/A
2.     Create a static CRLSP.
See "Configuring a static CRLSP."
N/A
3.     Enter MPLS TE tunnel interface view.
interface tunnel tunnel-number [ mode mpls-te ]
Execute this command on the ingress node.
4.     Specify the MPLS TE tunnel establishment mode as static.
mpls te signaling static
By default, MPLS TE uses RSVP-TE to establish a tunnel.
5.     Apply the static CRLSP to the tunnel interface.
mpls te static-cr-lsp lsp-name
By default, a tunnel does not use any static CRLSP.
·     Configure MPLS TE attributes for the links.
·     Configure IGP TE extension to advertise link TE attributes, so as to generate a TEDB on each node.
·     Configure tunnel constraints.
·     Establish the CRLSP by using the signaling protocol RSVP-TE.
You must configure the IGP TE extension to form a TEDB. Otherwise, the path is created based on IGP routing rather than computed by CSPF.
To establish an MPLS TE tunnel by using a dynamic CRLSP:
Tasks at a glance
(Required.) Configuring MPLS TE attributes for a link
(Required.) Advertising link TE attributes by using IGP TE extension
(Required.) Configuring MPLS TE tunnel constraints
(Required.) Establishing an MPLS TE tunnel by using RSVP-TE
(Optional.) Controlling CRLSP path selection
(Optional.) Controlling MPLS TE tunnel setup
MPLS TE attributes for a link include the maximum link bandwidth and the link attribute.
Perform this task on each interface that the MPLS TE tunnel traverses.
To configure the link TE attributes:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Set the maximum link bandwidth for MPLS TE traffic.
mpls te max-link-bandwidth { bandwidth-value| percent percent-bandwidth }
By default, the maximum link bandwidth for MPLS TE traffic is 0.
4.     Set the link attribute.
mpls te link-attribute attribute-value
By default, the link attribute value is 0x00000000.
Both OSPF and IS-IS are extended to advertise link TE attributes. The extensions are called OSPF TE and IS-IS TE. If both OSPF TE and IS-IS TE are available, OSPF TE takes precedence.
Configuring OSPF TE
OSPF TE uses Type-10 opaque LSAs to carry the TE attributes for a link. Before you configure OSPF TE, you must enable opaque LSA advertisement and reception by using the opaque-capability enable command. For more information about opaque LSA advertisement and reception, see Layer 3—IP Routing Configuration Guide.
MPLS TE cannot reserve resources and distribute labels for an OSPF virtual link, and cannot establish a CRLSP through an OSPF virtual link. Therefore, make sure no virtual link exists in an OSPF area before you configure MPLS TE.
To configure OSPF TE:
Step
Remarks
N/A
2.     Enter OSPF view.
ospf [ process-id ]
N/A
3.     Enable opaque LSA advertisement and reception.
By default, opaque LSA advertisement and reception are enabled.
For more information about this command, see Layer 3—IP Routing Command Reference.
4.     Enter area view.
area area-id
N/A
5.     Enable MPLS TE for the OSPF area.
mpls te enable
By default, MPLS TE is disabled for an OSPF area.
Configuring IS-IS TE
IS-IS TE uses a sub-TLV of the extended IS reachability TLV (type 22) to carry TE attributes. Because the extended IS reachability TLV carries wide metrics, specify a wide metric-compatible metric style for the IS-IS process before enabling IS-IS TE. Available metric styles for IS-IS TE include wide, compatible, or wide-compatible. For more information about IS-IS, see Layer 3—IP Routing Configuration Guide.
On IS-IS enabled interfaces, set the MTU to a minimum of 512 bytes to ensure that IS-IS LSPs of different lengths can be flooded to the network.
To configure IS-IS TE:
Step
Remarks
N/A
2.     Create an IS-IS process and enter IS-IS view.
isis [ process-id ]
By default, no IS-IS process exists.
3.     Specify a metric style.
By default, only narrow metric style packets can be received and sent.
4.     Enable MPLS TE for the IS-IS process.
mpls te enable [ Level-1 | Level-2 ]
By default, MPLS TE is disabled for an IS-IS process.
Configuring bandwidth constraints for an MPLS TE tunnel
Step
Remarks
N/A
2.     Enter MPLS TE tunnel interface view.
N/A
3.     Configure bandwidth required for the tunnel, and specify a CT for the tunnel's traffic.
mpls te bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth
By default, no bandwidth is assigned, and the class type is CT 0.
Configuring the affinity attribute for an MPLS TE tunnel
The associations between the link attribute and the affinity attribute might vary by vendor. To ensure the successful establishment of a tunnel between two devices from different vendors, correctly configure their respective link attribute and affinity attribute.
To configure the affinity attribute for an MPLS TE tunnel:
Step
Remarks
N/A
N/A
3.     Set an affinity for the MPLS TE tunnel.
mpls te affinity-attribute attribute-value [ mask mask-value ]
By default, the affinity is 0x00000000, and the mask is 0x00000000. The default affinity matches all link attributes.
Setting a setup priority and a holding priority for an MPLS TE tunnel
Step
Remarks
N/A
N/A
3.     Set a setup priority and a holding priority for the MPLS TE tunnel.
mpls te priority setup-priority [ hold-priority ]
By default, the setup priority and the holding priority are both 7 for an MPLS TE tunnel.
Configuring an explicit path for an MPLS TE tunnel
An explicit path is a set of nodes. The relationship between any two neighboring nodes on an explicit path can be either strict or loose.
·     Strict—The two nodes must be directly connected.
·     Loose—The two nodes can have devices in between.
When establishing an MPLS TE tunnel between areas or ASs, you must perform the following tasks:
·     Use a loose explicit path.
·     Specify the ABR or ASBR as the next hop of the path.
·     Make sure the tunnel's ingress node and the ABR or ASBR can reach each other.
To configure an explicit path for a MPLS TE tunnel:
Step
Remarks
N/A
2.     Create an explicit path and enter its view.
explicit-path path-name
By default, no explicit paths exist.
3.     Enable the explicit path.
undo disable
By default, an explicit path is enabled.
4.     Add or modify a node in the explicit path.
nexthop [ index index-number ] ip-address [ exclude | include [ loose | strict ] ]
By default, an explicit path does not include any node.
You can specify the include keyword to have the CRLSP traverse the specified node or the exclude keyword to have the CRLSP bypass the specified node.
5.     Return to system view.
N/A
6.     Enter MPLS TE tunnel interface view.
N/A
7.     Configure the MPLS TE tunnel interface to use the explicit path, and specify a preference value for the explicit path.
mpls te path preference value explicit-path path-name [ no-cspf ]
By default, MPLS TE uses the calculated path to establish a CRLSP.
Before you configure this task, you must use the rsvp command and the rsvp enable command to enable RSVP on all nodes and interfaces that the MPLS TE tunnel traverses.
To configure RSVP-TE to establish an MPLS TE tunnel:
Step
Remarks
N/A
N/A
3.     Configure MPLS TE to use RSVP-TE to establish the tunnel.
mpls te signaling rsvp-te
4.     Specify an explicit path for the MPLS TE tunnel, and specify the path preference value.
mpls te path preference value { dynamic | explicit-path path-name } [ no-cspf ]
Before performing the configuration tasks in this section, be aware of each configuration objective and its impact on your device.
MPLS TE uses CSPF to calculate a path according to the TEDB and constraints and sets up the CRLSP through RSVP-TE. MPLS TE provides measures that affect the CSPF calculation. You can use these measures to tune the path selection for CRLSP.
Configuring the metric type for path selection
Each MPLS TE link has two metrics: IGP metric and TE metric. By planning the two metrics, you can select different tunnels for different classes of traffic. For example, use the IGP metric to represent a link delay (a smaller IGP metric value indicates a lower link delay), and use the TE metric to represent a link bandwidth value (a smaller TE metric value indicates a bigger link bandwidth value).
You can establish two MPLS TE tunnels: Tunnel 1 for voice traffic and Tunnel 2 for video traffic. Configure Tunnel 1 to use IGP metrics for path selection, and configure Tunnel 2 to use TE metrics for path selection. As a result, the video service (with larger traffic) travels through the path that has larger bandwidth, and the voice traffic travels through the path that has lower delay.
To configure the metric type for tunnel path selection:
Step
Remarks
N/A
mpls te
N/A
3.     Specify the metric type to use when no metric type is explicitly configured for a tunnel.
path-metric-type { igp | te }
By default, a tunnel uses the TE metric for path selection.
Execute this command on the ingress node of an MPLS TE tunnel.
4.     Return to system view.
N/A
5.     Enter MPLS TE tunnel interface view.
N/A
6.     Specify the metric type for path selection.
mpls te path-metric-type { igp | te }
By default, no link metric type is specified and the one specified in MPLS TE view is used.
7.     Return to system view.
N/A
8.     Enter interface view.
N/A
9.     Assign a TE metric to the link.
mpls te metric value
By default, the link uses its IGP metric as the TE metric.
This command is available on every interface that the MPLS TE tunnel traverses.
Configuring route pinning
When route pinning is enabled, MPLS TE tunnel reoptimization is not available.
Perform this task on the ingress node of an MPLS TE tunnel.
To configure route pinning:
Step
Remarks
N/A
N/A
3.     Enable route pinning.
mpls te route-pinning
By default, route pinning is disabled.
Configuring tunnel reoptimization
Tunnel reoptimization allows you to manually or dynamically trigger the ingress node to recalculate a path. If the ingress node recalculates a better path, it creates a new CRLSP, switches the traffic from the old CRLSP to the new CRLSP, and then deletes the old CRLSP.
To configure tunnel reoptimization:
Step
Remarks
N/A
N/A
3.     Enable tunnel reoptimization.
mpls te reoptimization [ frequency seconds ]
By default, tunnel reoptimization is disabled.
4.     Return to user view.
return
N/A
5.     (Optional.) Immediately reoptimize all MPLS TE tunnels that are enabled with the tunnel reoptimization feature.
N/A
Setting TE flooding thresholds and interval
When the bandwidth of an MPLS TE link changes, IGP floods the new bandwidth information, so the ingress node can use CSPF to recalculate the path.
To prevent such recalculations from consuming too many resources, you can configure IGP to flood only significant bandwidth changes by setting the following flooding thresholds:
·     Up threshold—When the percentage of the reservable-bandwidth increase to the maximum reservable bandwidth reaches the threshold, IGP floods the TE information.
·     Down threshold—When the percentage of the reservable-bandwidth decrease to the maximum reservable bandwidth reaches the threshold, IGP floods the TE information.
You can also set the flooding interval at which bandwidth changes that cannot trigger immediate flooding are flooded.
This task can be performed on all nodes that the MPLS TE tunnel traverses.
To set TE flooding thresholds and the flooding interval:
Step
Remarks
N/A
N/A
3.     Set the up/down threshold.
mpls te bandwidth change thresholds { down | up } percent
By default, the up/down threshold is 10% of the link reservable bandwidth.
N/A
5.     Enter MPLS TE view.
mpls te
N/A
6.     Set the flooding interval.
link-management periodic-flooding timer interval
By default, the flooding interval is 180 seconds.
Perform the tasks in this section on the ingress node of the MPLS TE tunnel.
Enabling route and label recording
Perform this task to record the nodes that an MPLS TE tunnel traverses and the label assigned by each node. The recorded information helps you know about the path used by the MPLS TE tunnel and the label distribution information, and when the tunnel fails, it helps you locate the fault.
To enable route and label recording:
Step
Remarks
N/A
N/A
3.     Record routes or record both routes and labels.
·     To record routes:
mpls te record-route
·     To record both routes and labels:
mpls te record-route label
By default, both route recording and label recording are disabled.
Enabling loop detection
Enabling loop detection also enables the route recording feature, regardless of whether you have configured the mpls te record-route command. Loop detection enables each node of the tunnel to detect whether a loop has occurred according to the recorded route information.
To enable loop detection:
Step
Remarks
N/A
N/A
3.     Enable loop detection.
mpls te loop-detection
By default, loop detection is disabled.
Setting tunnel setup retry
If the ingress node fails to establish an MPLS TE tunnel, it waits for the retry interval, and then tries to set up the tunnel again. It repeats this process until the tunnel is established or until the number of attempts reaches the maximum. If the tunnel cannot be established when the number of attempts reaches the maximum, the ingress waits for a longer period and then repeats the previous process.
To set tunnel setup retry:
Step
Remarks
N/A
N/A
3.     Set the maximum number of tunnel setup attempts.
mpls te retry retries
By default, the maximum number of attempts is 3.
4.     Set the retry interval.
mpls te timer retry seconds
By default, the retry interval is 2 seconds.
Configuring RSVP resource reservation style
Step
Remarks
N/A
N/A
3.     Configure the resources reservation style for the tunnel.
mpls te resv-style { ff | se }
By default, the resource reservation style is SE.
In current MPLS TE applications, tunnels are established usually by using the make-before-break mechanism. As a best practice, use the SE style.
Configuring a PCE
Step
Remarks
N/A
mpls te
N/A
3.     Configure a PCE IP address.
pce address ip-address
By default, no PCE address is configured.
Discovering PCEs
After the PCE is manually specified or dynamically discovered, a PCC sends a PCEP connection request to the PCE, but it does not accept a request from the PCE.
Manually specifying a PCE
Step
Remarks
N/A
mpls te
N/A
3.     Specify the IP address of the PCE.
pce static ip-address
By default, no PCE peers exist.
Dynamically discovering PCEs
OSPF TE advertises PCE IP addresses for PCCs and other PCEs to dynamically discover the PCEs and establish PCEP sessions to them. For OSPF TE configuration, see "Configuring OSPF TE."
Step
Remarks
N/A
N/A
3.     Establish a CRLSP by using the path calculated by PCEs.
mpls te path preference value dynamic pce [ ip-address ]&<0-8>
By default, the automatically calculated path is used to establish a CRLSP.
After this command is executed, the local device acts as a PCC and establishes PCEP sessions to the specified PCEs. If you do not specify a PCE, the local device establishes PCEP sessions to all discovered PCEs.
Perform this task to enable the specified PCEs to calculate a backup CRLSP for the PCC. When the primary CRLSP fails, traffic is switched to the backup CRLSP to ensure continuous traffic forwarding.
To establish a backup CRLSP by using the path calculated by PCEs:
Step
Remarks
N/A
N/A
3.     Enable tunnel backup and specify the backup mode.
mpls te backup { hot-standby | ordinary }
By default, tunnel backup is disabled.
4.     Establish a backup CRLSP by using the path calculated by PCEs.
mpls te backup-path preference value dynamic pce [ ip-address ]&<0-8>
By default, the automatically calculated path is used to establish a backup CRLSP.
Step
Remarks
N/A
mpls te
N/A
3.     Set the path calculation request timeout time.
pce request-timeout value
By default, the request timeout time is 10 seconds.
4.     Set the PCEP session deadtimer.
pce deadtimer value
By default, the PCEP session deadtimer is 120 seconds.
5.     Set the keepalive interval for PCEP sessions.
pce keepalive interval
By default, the keepalive interval is 30 seconds.
6.     Set the minimum acceptable keepalive interval and the maximum number of allowed unknown messages received from the peer.
pce tolerance { min-keepalive value | max-unknown-messages value }
By default, the minimum acceptable keepalive interval is 10 seconds, and the maximum number of allowed unknown messages in a minute is 5.
Step
Remarks
N/A
2.     Configure a static route to direct traffic to an MPLS TE tunnel.
See Layer 3—IP Routing Command Reference.
By default, no static routes exist.
The interface specified in this command can be an MPLS TE tunnel interface.
You can use either IGP shortcut or forwarding adjacency to implement automatic route advertisement. When you use IGP shortcut, you can specify a metric for the TE tunnel. If you assign an absolute metric, the metric is directly used as the MPLS TE tunnel's metric. If you assign a relative metric, the MPLS TE tunnel's metric is the assigned metric plus the IGP link metric.
Before configuring automatic route advertisement, perform the following tasks:
·     Enable OSPF or IS-IS on the tunnel interface to advertise the interface address to OSPF or IS-IS.
·     Enable MPLS TE for an OSPF area or an IS-IS process by executing the mpls te enable command in OSPF area view or IS-IS view.
Follow these restrictions and guidelines when you configure automatic route advertisement:
·     The destination address of the MPLS TE tunnel can be the LSR ID of the egress node or the primary IP address of an interface on the egress node. As a best practice, configure the destination address of the MPLS TE tunnel as the LSR ID of the egress node.
·     If you configure the tunnel destination address as the primary IP address of an interface on the egress node, you must enable MPLS TE, and configure OSPF or IS-IS on that interface. This makes sure the primary IP address of the interface can be advertised to its peer.
·     The route to the tunnel interface address and the route to the tunnel destination must be in the same OSPF area or at the same IS-IS level.
Configuring IGP shortcut
Step
Remarks
N/A
N/A
3.     Enable IGP shortcut.
mpls te igp shortcut [ isis | ospf ]
By default, IGP shortcut is disabled.
If no IGP is specified, both OSPF and IS-IS will include the MPLS TE tunnel in route calculation.
4.     Assign a metric to the MPLS TE tunnel.
mpls te igp metric { absolute value | relative value }
By default, the metric of an MPLS TE tunnel equals its IGP metric.
Configuring forwarding adjacency
To use forwarding adjacency, you must establish two MPLS TE tunnels in opposite directions between two nodes, and configure forwarding adjacency on both the nodes.
To configure forwarding adjacency:
Step
Remarks
N/A
N/A
3.     Enable forwarding adjacency.
mpls te igp advertise [ hold-time value ]
By default, forwarding adjacency is disabled.
Before you create a bidirectional MPLS TE tunnel, perform the following tasks:
·     Disable the PHP feature on both ends of the tunnel.
·     To set up a bidirectional MPLS TE tunnel in co-routed mode, you must specify the signaling protocol as RSVP-TE.
To create a bidirectional MPLS TE tunnel, create an MPLS TE tunnel interface on both ends of the tunnel and enable the bidirectional tunnel feature on the tunnel interfaces:
·     For a co-routed bidirectional tunnel, configure one end of the tunnel as the active end and the other end as the passive end, and specify the reverse CRLSP at the passive end.
·     For an associated bidirectional tunnel, specify a reverse CRLSP at both ends of the tunnel.
To configure the active end of a co-routed bidirectional MPLS TE tunnel:
Step
Remarks
N/A
N/A
3.     Configure a co-routed bidirectional MPLS TE tunnel and specify the local end as the active end of the tunnel.
mpls te bidirectional co-routed active
By default, bidirectional tunnel is disabled on the tunnel interface, and tunnels established on the tunnel interface are unidirectional MPLS TE tunnels.
To configure the passive end of a co-routed bidirectional MPLS TE tunnel:
Step
Remarks
N/A
N/A
3.     Configure a co-routed bidirectional MPLS TE tunnel and specify the local end as the passive end of the tunnel.
mpls te bidirectional co-routed passive reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id
To configure an associated bidirectional MPLS TE tunnel:
Step
Remarks
N/A
N/A
3.     Configure an associated bidirectional MPLS TE tunnel.
mpls te bidirectional associated reverse-lsp { lsp-name lsp-name | lsr-id ingress-lsr-id tunnel-id tunnel-id } }
CRLSP backup provides end-to-end CRLSP protection. Only MPLS TE tunnels established through RSVP-TE support CRLSP backup.
To configure CRLSP backup:
Step
Remarks
N/A
N/A
4.     Specify a path for the primary CRLSP and set the preference of the path.
By default, MPLS TE uses the dynamically calculated path to set up the primary CRLSP.
5.     Specify a path for the backup CRLSP and set the preference of the path.
mpls te backup-path preference value { dynamic | explicit-path path-name } [ no-cspf ]
By default, MPLS TE uses the dynamically calculated path to set up the backup CRLSP.
MPLS TE FRR provides temporary link or node protection on a CRLSP. When you configure FRR, follow these restrictions and guidelines:
·     Do not configure both FRR and RSVP authentication on the same interface.
·     Only MPLS TE tunnels established through RSVP-TE support FRR.
Enabling FRR
Perform this task on the ingress node of a primary CRLSP.
To enable FRR:
Step
Remarks
N/A
2.     Enter tunnel interface view of the primary CRLSP.
N/A
3.     Enable FRR.
mpls te fast-reroute [ bandwidth ]
By default, FRR is disabled.
If you specify the bandwidth keyword, the primary CRLSP must have bandwidth protection.
Overview
To configure FRR, you must configure bypass tunnels for primary CRLSPs on the PLR by using the following methods:
·     Manually configuring a bypass tunnel on the PLR—Create an MPLS TE tunnel on the PLR, and configure the tunnel as a bypass tunnel for a primary CRLSP. You need to specify the bandwidth and CT that the bypass tunnel can protect, and bind the bypass tunnel to the output interface of the primary CRLSP.
You can configure a maximum of three bypass tunnels for a primary CRLSP.
·     Configuring the PLR to set up bypass tunnels automatically—Configure the automatic bypass tunnel setup feature (also referred to as the auto FRR feature) on the PLR. The PLR automatically sets up two bypass tunnels for each of its primary CRLSPs: one in link protection mode and the other in node protection mode. Automatically created bypass tunnels can be used to protect any type of CT, but they cannot provide bandwidth protection.
A primary tunnel can have both manually configured and automatically created bypass tunnels. The PLR will select one bypass tunnel to protect the primary CRLSP. The selected bypass tunnel is bound to the primary CRLSP.
Manually created bypass tunnels take precedence over automatically created bypass tunnels. An automatically created bypass tunnel in node protection mode takes precedence over an automatically created bypass tunnel in link protection mode. Among manually created bypass tunnels, the PLR selects the bypass tunnel for protecting the primary CRLSP by following these rules:
1.     Selects a bypass tunnel according to the principles, as shown in Table 1.
2.     Prefers the bypass tunnel in node protection mode over the one in link protection mode.
3.     Prefers the bypass tunnel with a smaller ID over the one with a bigger tunnel ID.
Table 1 FRR protection principles
Bandwidth required by primary CRLSP
Primary CRLSP requires bandwidth protection or not
Bypass tunnel providing bandwidth protection
Bypass tunnel providing no bandwidth protection
0
Yes
The primary CRLSP cannot be bound to the bypass tunnel.
The primary CRLSP can be bound to the bypass tunnel if CT 0 or no CT is specified for the bypass tunnel.
After binding, the RRO message does not carry the bandwidth protection flag. The bypass tunnel does not provide bandwidth protection for the primary CRLSP, and performs best-effort forwarding for traffic of the primary CRLSP.
No
None-zero
Yes
The primary CRLSP can be bound to the bypass tunnel when all the following conditions are met:
·     The bandwidth that the bypass tunnel can protect is no less than the bandwidth required by the primary CRLSP.
·     There is not a CT specified for the bypass tunnel, or the specified CT is the same as that specified for the primary CRLSP.
After binding, the RRO message carries the bandwidth protection flag, and the bypass tunnel provides bandwidth protection for the primary CRLSP.
The primary CRLSP prefers bypass tunnels that provide bandwidth protection over those providing no bandwidth protection.
The primary CRLSP can be bound to the bypass tunnel when one of the following conditions is met:
·     No CT is specified for the bypass tunnel.
·     The specified CT is the same as that specified for the primary CRLSP.
This bypass tunnel is selected only when no bypass tunnel that provides bandwidth protection can be bound to the primary CRLSP.
Non-zero
No
·     No CT that the bypass tunnel can protect is specified, or the specified CT is the same as that of the traffic on the primary CRLSP.
After binding, the RRO message carries the bandwidth protection flag.
This bypass tunnel is selected only when no bypass tunnel that does not provide bandwidth protection can be bound to the primary CRLSP.
·     The specified CT is the same as that of the traffic on the primary CRLSP.
The primary CRLSP prefers bypass tunnels that does not provide bandwidth protection over those providing bandwidth protection.
When you configure a bypass tunnel on the PLR, follow these restrictions and guidelines:
·     Use bypass tunnels to protect only critical interfaces or links when bandwidth is insufficient. Bypass tunnels are pre-established and require extra bandwidth.
·     Make sure the bandwidth assigned to the bypass tunnel is no less than the total bandwidth needed by all primary CRLSPs to be protected by the bypass tunnel. Otherwise, some primary CRLSPs might not be protected by the bypass tunnel.
·     A bypass tunnel typically does not forward data when the primary CRLSP operates correctly. For a bypass tunnel to also forward data during tunnel protection, you must assign adequate bandwidth to the bypass tunnel.
·     A bypass tunnel cannot be used for services such as VPN.
·     You cannot configure FRR for a bypass tunnel. A bypass tunnel cannot act as a primary CRLSP.
·     Make sure the protected node or interface is not on the bypass tunnel.
·     After you associate a primary CRLSP that does not require bandwidth protection with a bypass tunnel that provides bandwidth protection, the primary CRLSP occupies the bandwidth that the bypass tunnel protects. The bandwidth is protected on a first-come-first-served basis. The primary CRLSP that needs bandwidth protection cannot preempt the one that does not need bandwidth protection.
·     After an FRR, the primary CRLSP will be down if you modify the bandwidth that the bypass tunnel can protect and your modification results in one of the following:
¡     The CT type changes.
¡     The bypass tunnel cannot protect adequate bandwidth as configured.
¡     FRR protection type (whether or not to provide bandwidth protection for the primary CRLSP) changes.
The bypass tunnel setup method is the same as a normal MPLS TE tunnel. This section describes only FRR-related configurations.
To configure a bypass tunnel on the PLR:
Step
Remarks
N/A
2.     Enter tunnel interface view of the bypass tunnel.
N/A
3.     Specify the destination address of the bypass tunnel.
The bypass tunnel destination address is the LSR ID of the MP.
4.     Configure the bandwidth and the CT to be protected by the bypass tunnel.
mpls te backup bandwidth [ ct0 | ct1 | ct2 | ct3 ] { bandwidth | un-limited }
By default, the bandwidth and the CT to be protected by the bypass tunnel are not specified.
N/A
6.     Enter interface view of the output interface of a primary CRLSP.
N/A
7.     Specify a bypass tunnel for the protected interface.
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
By default, no bypass tunnel is specified for an interface.
Automatically setting up bypass tunnels
With auto FRR, if the PLR is the penultimate node of a primary CRLSP, the PLR does not create a node-protection bypass tunnel for the primary CRLSP.
An automatically created bypass tunnel can protect multiple primary CRLSPs. A bypass tunnel is unused when the bypass tunnel is not bound to any primary CRLSP. When a bypass tunnel is unused for the period of time configured by the timers removal unused command, MPLS TE removes the bypass tunnel.
To configure auto FRR on the PLR:
Step
Remarks
N/A
mpls te
N/A
3.     Enable the auto FRR feature globally.
auto-tunnel backup
By default, the auto FRR feature is disabled globally.
4.     Specify an interface number range for the automatically created bypass tunnels.
tunnel-number min min-number max max-number
By default, no interface number range is specified, and the PLR cannot set up a bypass tunnel automatically.
5.     (Optional.) Configure the PLR to create only link-protection bypass tunnels.
nhop-only
By default, the PLR automatically creates both a link-protection and a node-protection bypass tunnel for each of its primary CRLSPs.
Execution of this command deletes all existing node-protection bypass tunnels automatically created for MPLS TE auto FRR.
6.     (Optional.) Set a removal timer for unused bypass tunnels.
timers removal unused seconds
By default, a bypass tunnel is removed after it is unused for 3600 seconds.
7.     (Optional.) Return to system view.
N/A
8.     (Optional.) Enter interface view.
N/A
9.     (Optional.) Disable the auto FRR feature on the interface.
mpls te auto-tunnel backup disable
By default, the auto FRR feature is enabled on all RSVP-enabled interfaces after it is enabled globally.
Execution of this command deletes all existing bypass tunnels automatically created on the interface for MPLS TE auto FRR.
Perform this task to configure the RSVP hello mechanism or BFD on the PLR and the protected node to detect the node faults caused by signaling protocol faults. FRR does not need to use the RSVP hello mechanism or BFD to detect the node faults caused by the link faults between the PLR and the protected node.
You do not need to perform this task for FRR link protection.
To configure node fault detection:
Step
Remarks
N/A
On the PLR, enter the view of the interface connected to the protected node.
On the protected node, enter the view of the interface connected to the PLR.
3.     Configure node fault detection.
·     (Method 1) Enable RSVP hello extension on the interface:
rsvp hello enable
·     (Method 2) Enable BFD on the interface:
rsvp bfd enable
By default, RSVP hello extension is disabled, and BFD is not configured.
For more information about the rsvp hello enable command and the rsvp bfd enable command, see "Configuring RSVP."
If you have specified multiple bypass tunnels for a primary CRLSP, MPLS TE selects an optimal bypass tunnel to protect the primary CRLSP. Sometimes, a bypass tunnel might become better than the current optimal bypass tunnel. Therefore, MPLS TE needs to poll the bypass tunnels periodically to update the optimal bypass tunnel.
Perform this task on the PLR to set the interval for selecting an optimal bypass tunnel:
Step
Remarks
N/A
mpls te
N/A
3.     Set the interval for selecting an optimal bypass tunnel.
fast-reroute timer interval
By default, the interval is 300 seconds.
This feature enables generating SNMP notifications for MPLS TE upon MPLS TE state changes, as defined in RFC 3812. For MPLS TE event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
To enable SNMP notifications for MPLS TE:
Step
Remarks
N/A
2.     Enable SNMP notifications for MPLS TE.
snmp-agent trap enable te
By default, SNMP notifications for MPLS TE are enabled.
Display information about explicit paths.
display explicit-path [ path-name ]
Display link and node information in an IS-IS TEDB.
display isis mpls te advertisement [ [ level-1 | level-2 ] | [ originate-system system-id | local ] | verbose ] * [ process-id ]
Display network information in an IS-IS TEDB.
display isis mpls te network [ [ level-1 | level-2 ] | local | lsp-id lsp-id ]* [ process-id ]
Display IS-IS tunnel interface information.
display isis mpls te tunnel [ level-1 | level-2 ] [ process-id ]
Display bandwidth information on MPLS TE-enabled interfaces.
display mpls te link-management bandwidth-allocation [ interface interface-type interface-number ]
Display information about discovered PCEs.
display mpls te pce discovery [ ip-address ] [ verbose ]
Display PCC and PCE peer information.
display mpls te pce peer [ ip-address ] [ verbose ]
Display PCC and PCE statistics.
display mpls te pce statistics [ ip-address ]
Display MPLS TEDB information.
display mpls te tedb { { isis { level-1 | level-2 } | ospf area area-id } | link ip-address | network | node [ local | mpls-lsr-id ] | summary }
Display information about MPLS TE tunnel interfaces.
display mpls te tunnel-interface [ tunnel number ]
Display information about PCEs discovered by OSPF.
display ospf [ process-id ] [ area area-id ] mpls te pce [ originate-router advertising-router-id | self-originate ]
Display link and node information in an OSPF TEDB.
display ospf [ process-id ] [ area area-id ] mpls te advertisement [ originate-router advertising-router-id | self-originate ]
Display network information in an OSPF TEDB.
display ospf [ process-id ] [ area area-id ] mpls te network [ originate-router advertising-router-id | self-originate ]
Display OSPF tunnel interface information.
display ospf [ process-id ] [ area area-id ] mpls te tunnel
Clear PCC and PCE statistics.
reset mpls te pce statistics [ ip-address ]
Network requirements
Switch A, Switch B, and Switch C run IS-IS.
Establish an MPLS TE tunnel over a static CRLSP from Switch A to Switch C to transmit data between the two IP networks.
The MPLS TE tunnel requires a bandwidth of 2000 kbps. The maximum bandwidth of the link that the tunnel traverses is 10000 kbps.
Figure 6 Network diagram
Configuration procedure
1.     Configure IP addresses and masks for interfaces. (Details not shown.)
2.     Configure IS-IS to advertise interface addresses, including the loopback interface address:
# Configure Switch A.
[SwitchA] isis 1
[SwitchA-isis-1] network-entity 00.0005.0000.0000.0001.00
[SwitchA-isis-1] quit
[SwitchA-Vlan-interface1] isis enable 1
[SwitchA-LoopBack0] isis enable 1
[SwitchA-LoopBack0] quit
# Configure Switch B.
[SwitchB] isis 1
[SwitchB-isis-1] network-entity 00.0005.0000.0000.0002.00
[SwitchB-isis-1] quit
[SwitchB] interface vlan-interface 1
[SwitchB-Vlan-interface1] isis enable 1
[SwitchB-Vlan-interface1] quit
[SwitchB-Vlan-interface2] isis enable 1
[SwitchB-LoopBack0] isis enable 1
[SwitchB-LoopBack0] quit
# Configure Switch C.
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 00.0005.0000.0000.0003.00
[SwitchC-isis-1] quit
[SwitchC-Vlan-interface2] isis enable 1
[SwitchC-LoopBack0] isis enable 1
[SwitchC-LoopBack0] quit
# Execute the display ip routing-table command on each switch to verify that the switches have learned the routes to one another, including the routes to the loopback interfaces. (Details not shown.)
3.     Configure an LSR ID, and enable MPLS and MPLS TE:
[SwitchA] mpls lsr-id 1.1.1.1
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA-Vlan-interface1] mpls enable
[SwitchA-Vlan-interface1] mpls te enable
[SwitchB] mpls lsr-id 2.2.2.2
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB-Vlan-interface1] mpls enable
[SwitchB-Vlan-interface1] mpls te enable
[SwitchB-Vlan-interface2] mpls te enable
[SwitchC] mpls lsr-id 3.3.3.3
[SwitchC] mpls te
[SwitchC-te] quit
[SwitchC-Vlan-interface2] mpls enable
[SwitchC-Vlan-interface2] mpls te enable
4.     Configure MPLS TE attributes of links:
# Set the maximum link bandwidth on Switch A.
[SwitchA-Vlan-interface1] mpls te max-link-bandwidth 10000
# Set the maximum link bandwidth on Switch B.
[SwitchB-Vlan-interface1] mpls te max-link-bandwidth 10000
[SwitchB-Vlan-interface2] mpls te max-link-bandwidth 10000
# Set the maximum link bandwidth on Switch C.
[SwitchC-Vlan-interface2] mpls te max-link-bandwidth 10000
5.     Configure an MPLS TE tunnel on Switch A:
# Configure MPLS TE tunnel interface Tunnel 0.
[SwitchA] interface tunnel 0 mode mpls-te
[SwitchA-Tunnel0] ip address 6.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Switch C.
[SwitchA-Tunnel0] destination 3.3.3.3
# Configure MPLS TE to use a static CRLSP to establish the tunnel.
[SwitchA-Tunnel0] mpls te signaling static
[SwitchA-Tunnel0] quit
6.     Create a static CRLSP:
# Configure Switch A as the ingress node of the static CRLSP, and specify the next hop address as 2.1.1.2, outgoing label as 20, and bandwidth for the tunnel as 2000 kbps.
[SwitchA] static-cr-lsp ingress static-cr-lsp-1 nexthop 2.1.1.2 out-label 20 bandwidth 2000
# On Switch A, configure tunnel 0 to use static CRLSP static-cr-lsp-1.
[SwitchA] interface Tunnel0
[SwitchA-Tunnel0] mpls te static-cr-lsp static-cr-lsp-1
# Configure Switch B as the transit node of the static CRLSP, and specify the incoming label as 20, next hop address as 3.2.1.2, outgoing label as 30, and bandwidth for the tunnel as 2000 kbps.
[SwitchB] static-cr-lsp transit static-cr-lsp-1 in-label 20 nexthop 3.2.1.2 out-label 30 bandwidth 2000
# Configure Switch C as the egress node of the static CRLSP, and specify the incoming label as 30.
[SwitchC] static-cr-lsp egress static-cr-lsp-1 in-label 30
7.     Configure a static route on Switch A to direct traffic destined for subnet 100.1.2.0/24 to MPLS TE tunnel 0.
[SwitchA] ip route-static 100.1.2.0 24 tunnel 0 preference 1
# Verify that the tunnel interface is up on Switch A.
[SwitchA] display interface tunnel
Tunnel0
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum transmission unit: 1496
Internet address: 6.1.1.1/24 (primary)
Tunnel source unknown, destination 3.3.3.3
Tunnel TTL 255
# Display detailed information about the MPLS TE tunnel on Switch A.
[SwitchA] display mpls te tunnel-interface
Tunnel Name            : Tunnel 0
Tunnel State           : Up (Main CRLSP up)
Tunnel Attributes      :
  LSP ID               : 1               Tunnel ID            : 0
  Admin State          : Normal
  Ingress LSR ID       : 1.1.1.1         Egress LSR ID        : 3.3.3.3
  Signaling            : Static          Static CRLSP Name    : static-cr-lsp-1
  Static SRLSP Name    : -
  Resv Style           : -
  Tunnel mode          : -
  Reverse-LSP name     : -
  Reverse-LSP LSR ID   : -               Reverse-LSP Tunnel ID: -
  Class Type           : -               Tunnel Bandwidth     : -
  Reserved Bandwidth   : -
  Setup Priority       : 0               Holding Priority     : 0
  Affinity Attr/Mask   : -/-
  Explicit Path        : -
  Backup Explicit Path : -
  Metric Type          : TE
  Record Route         : -               Record Label         : -
  FRR Flag             : -               Bandwidth Protection : -
  Backup Bandwidth Flag: -               Backup Bandwidth Type: -
  Backup Bandwidth     : -
  Bypass Tunnel        : -               Auto Created         : -
  Route Pinning        : -
  Retry Limit          : 3               Retry Interval       : 2 sec
  Reoptimization       : -               Reoptimization Freq  : -
  Backup Type          : -               Backup LSP ID        : -
  Auto Bandwidth       : -               Auto Bandwidth Freq  : -
  Min Bandwidth        : -               Max Bandwidth        : -
  Collected Bandwidth  : -               Service-Class        : -
# Display static CRLSP information on each switch.
[SwitchA] display mpls lsp
FEC                         Proto    In/Out Label    Interface/Out NHLFE
1.1.1.1/0/1                 StaticCR -/20            Vlan1
2.1.1.2                     Local    -/-             Vlan1
Tunnel0                     Local    -/-             NHLFE1025
[SwitchB] display mpls lsp
-                           StaticCR 20/30           Vlan2
3.2.1.2                     Local    -/-             Vlan2
[SwitchC] display mpls lsp
-                           StaticCR 30/-            -
[SwitchA] display mpls static-cr-lsp
Name            LSR Type    In/Out Label   Out Interface        State
static-cr-lsp-1 Ingress     Null/20        Vlan1                Up
[SwitchB] display mpls static-cr-lsp
static-cr-lsp-1 Transit     20/30          Vlan2                Up
[SwitchC] display mpls static-cr-lsp
static-cr-lsp1  Egress      30/Null        -                    Up
# Execute the display ip routing-table command on Switch A. The output shows a static route entry with interface Tunnel 0 as the output interface. (Details not shown.)
Establishing an MPLS TE tunnel with RSVP-TE
Switch A, Switch B, Switch C, and Switch D run IS-IS and all of them are Level-2 switches.
Use RSVP-TE to establish an MPLS TE tunnel from Switch A to Switch D to transmit data between the two IP networks. The MPLS TE tunnel requires a bandwidth of 2000 kbps.
Figure 7 Network diagram
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.9/32
Switch D
Loop0
4.4.4.9/32
Vlan-int1
10.1.1.1/24
Vlan-int3
30.1.1.2/24
Vlan-int10
100.1.1.1/24
Vlan-int10
100.1.2.1/24
Switch B
Loop0
2.2.2.9/32
Switch C
Loop0
3.3.3.9/32
Vlan-int1
10.1.1.2/24
Vlan-int3
30.1.1.1/24
Vlan-int2
20.1.1.1/24
Vlan-int2
20.1.1.2/24
[SwitchA] isis 1
[SwitchA-Vlan-interface1] isis circuit-level level-2
[SwitchA-LoopBack0] isis circuit-level level-2
[SwitchB] isis 1
[SwitchB-Vlan-interface1] isis circuit-level level-2
[SwitchB-Vlan-interface2] isis circuit-level level-2
[SwitchB-LoopBack0] isis circuit-level level-2
[SwitchC] isis 1
[SwitchC-Vlan-interface3] isis enable 1
[SwitchC-Vlan-interface3] isis circuit-level level-2
[SwitchC-Vlan-interface2] isis circuit-level level-2
[SwitchC-LoopBack0] isis circuit-level level-2
# Configure Switch D.
<SwitchD> system-view
[SwitchD] isis 1
[SwitchD-isis-1] network-entity 00.0005.0000.0000.0004.00
[SwitchD-isis-1] quit
[SwitchD] interface vlan-interface 3
[SwitchD-Vlan-interface3] isis enable 1
[SwitchD-Vlan-interface3] isis circuit-level level-2
[SwitchD-Vlan-interface3] quit
[SwitchD] interface loopback 0
[SwitchD-LoopBack0] isis enable 1
[SwitchD-LoopBack0] isis circuit-level level-2
[SwitchD-LoopBack0] quit
3.     Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE:
[SwitchA] mpls lsr-id 1.1.1.9
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchA-Vlan-interface1] rsvp enable
[SwitchB] mpls lsr-id 2.2.2.9
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchB-Vlan-interface1] rsvp enable
[SwitchB-Vlan-interface2] rsvp enable
[SwitchC] mpls lsr-id 3.3.3.9
[SwitchC] mpls te
[SwitchC-te] quit
[SwitchC] rsvp
[SwitchC-rsvp] quit
[SwitchC-Vlan-interface3] mpls te enable
[SwitchC-Vlan-interface3] rsvp enable
[SwitchC-Vlan-interface2] rsvp enable
[SwitchD] mpls lsr-id 4.4.4.9
[SwitchD] mpls te
[SwitchD-te] quit
[SwitchD] rsvp
[SwitchD-rsvp] quit
[SwitchD-Vlan-interface3] mpls enable
[SwitchD-Vlan-interface3] mpls te enable
[SwitchD-Vlan-interface3] rsvp enable
4.     Configure IS-IS TE:
[SwitchA] isis 1
[SwitchA-isis-1] cost-style wide
[SwitchA-isis-1] mpls te enable level-2
[SwitchB] isis 1
[SwitchB-isis-1] cost-style wide
[SwitchB-isis-1] mpls te enable level-2
[SwitchC] isis 1
[SwitchC-isis-1] cost-style wide
[SwitchC-isis-1] mpls te enable level-2
[SwitchD] isis 1
[SwitchD-isis-1] cost-style wide
[SwitchD-isis-1] mpls te enable level-2
5.     Configure MPLS TE attributes of links:
[SwitchC-Vlan-interface3] mpls te max-link-bandwidth 10000
# Set the maximum link bandwidth on Switch D.
[SwitchD-Vlan-interface3] mpls te max-link-bandwidth 10000
6.     Configure an MPLS TE tunnel on Switch A:
# Configure MPLS TE tunnel interface Tunnel 1.
[SwitchA] interface tunnel 1 mode mpls-te
[SwitchA-Tunnel1] ip address 7.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Switch D.
[SwitchA-Tunnel1] destination 4.4.4.9
# Configure MPLS TE to use RSVP-TE to establish the tunnel.
[SwitchA-Tunnel1] mpls te signaling rsvp-te
# Assign 2000 kbps bandwidth to the tunnel.
[SwitchA-Tunnel1] mpls te bandwidth 2000
[SwitchA-Tunnel1] quit
7.     Configure a static route on Switch A to direct the traffic destined for subnet 100.1.2.0/24 to MPLS TE tunnel 1.
[SwitchA] ip route-static 100.1.2.0 24 tunnel 1 preference 1
Tunnel1
Current state: UP
Bandwidth: 64kbps
Internet address: 7.1.1.1/24 (primary)
Tunnel source unknown, destination 4.4.4.9
Tunnel TTL 255
Last 300 seconds output rate: 6 bytes/sec, 48 bits/sec, 0 packets/sec
Output: 177 packets, 11428 bytes, 0 drops
Tunnel Name            : Tunnel 1
Tunnel State           : Up (Main CRLSP up. Shared-resource CRLSP down)
Tunnel Attributes      :
  LSP ID               : 23331           Tunnel ID            : 1
  Ingress LSR ID       : 1.1.1.9         Egress LSR ID        : 4.4.4.9
  Signaling            : RSVP-TE         Static CRLSP Name    : -
  Resv Style           : SE
  Tunnel mode          : -
  Class Type           : CT0             Tunnel Bandwidth     : 2000 kbps
  Reserved Bandwidth   : 0 kbps
  Setup Priority       : 7               Holding Priority     : 7
  Affinity Attr/Mask   : 0/0
  Explicit Path        : -
  Metric Type          : TE
  Record Route         : Disabled        Record Label         : Disabled
  FRR Flag             : Disabled        Bandwidth Protection : Disabled
  Backup Bandwidth Flag: Disabled        Backup Bandwidth Type: -
  Bypass Tunnel        : No               Auto Created         : No
  Route Pinning        : Disabled
  Retry Limit          : 10              Retry Interval       : 2 sec
  Reoptimization       : Disabled        Reoptimization Freq  : -
  Backup Type          : None            Backup LSP ID        : -
  Auto Bandwidth       : Disabled        Auto Bandwidth Freq  : -
# Execute the display ip routing-table command on Switch A. The output shows a static route entry with interface Tunnel 1 as the output interface. (Details not shown.)
Establishing an inter-AS MPLS TE tunnel with RSVP-TE
Switch A and Switch B are in AS 100. Switch C and Switch D are in AS 200. AS 100 and AS 200 use OSPF as the IGP.
Establish an EBGP connection between ASBRs Switch B and Switch C. Redistribute BGP routes into OSPF and OSPF routes into BGP, so that a route is available between AS 100 and AS 200.
Use RSVP-TE to establish an MPLS TE tunnel from Switch A to Switch D to transmit data between the two IP networks. The tunnel requires a bandwidth of 2000 kbps. The maximum bandwidth of the link that the tunnel traverses is 10000 kbps.
Figure 8 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.9/32
Switch D
Loop0
4.4.4.9/32
Vlan-int1
10.1.1.1/24
Vlan-int3
30.1.1.2/24
Vlan-int10
100.1.1.1/24
Vlan-int10
100.1.2.1/24
Switch B
Loop0
2.2.2.9/32
Switch C
Loop0
3.3.3.9/32
Vlan-int1
10.1.1.2/24
Vlan-int3
30.1.1.1/24
Vlan-int2
20.1.1.1/24
Vlan-int2
20.1.1.2/24
2.     Configure OSPF to advertise routes within the ASs, and redistribute the direct and BGP routes into OSPF on Switch B and Switch C:
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[SwitchA-ospf-1] quit
[SwitchB] ospf
[SwitchB-ospf-1] import-route direct
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[SwitchB-ospf-1] quit
[SwitchC] ospf
[SwitchC-ospf-1] import-route bgp
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[SwitchC-ospf-1] quit
[SwitchD] ospf
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[SwitchD-ospf-1] quit
# Verify that the switches have learned the routes to one another, including the routes to the loopback interfaces. This example uses Switch A.
Destinations : 6        Routes : 6
Destination/Mask   Proto   Pre Cost        NextHop         Interface
1.1.1.9/32         Direct  0   0           127.0.0.1       InLoop0
2.2.2.9/32         O_INTRA 10  1           10.1.1.2        Vlan1
10.1.1.0/24        Direct  0   0           10.1.1.1        Vlan1
10.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.1/32       Direct  0   0           127.0.0.1       InLoop0
3.     Configure BGP on Switch B and Switch C to ensure that the ASs can communicate with each other:
[SwitchB] bgp 100
[SwitchB-bgp] peer 20.1.1.2 as-number 200
[SwitchB-bgp] address-family ipv4 unicast
[SwitchB-bgp-ipv4] peer 20.1.1.2 enable
[SwitchB-bgp-ipv4] import-route ospf
[SwitchB-bgp-ipv4] import-route direct
[SwitchB-bgp-ipv4] quit
[SwitchB-bgp] quit
[SwitchC] bgp 200
[SwitchC-bgp] peer 20.1.1.1 as-number 100
[SwitchC-bgp] address-family ipv4 unicast
[SwitchC-bgp-ipv4] peer 20.1.1.1 enable
[SwitchC-bgp-ipv4] import-route ospf
[SwitchC-bgp-ipv4] import-route direct
[SwitchC-bgp-ipv4] quit
[SwitchC-bgp] quit
# Verify that the switches have learned AS-external routes.
Destinations : 10       Routes : 10
3.3.3.9/32         O_ASE   150 1           10.1.1.2        Vlan1
4.4.4.9/32         O_ASE   150 1           10.1.1.2        Vlan1
20.1.1.0/24        O_ASE   150 1           10.1.1.2        Vlan1
30.1.1.0/24        O_ASE   150 1           10.1.1.2        Vlan1
4.     Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE:
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchC] mpls te
[SwitchC-te] quit
[SwitchC] rsvp
[SwitchC-rsvp] quit
[SwitchD] mpls te
[SwitchD-te] quit
[SwitchD] rsvp
[SwitchD-rsvp] quit
5.     Configure OSPF TE:
[SwitchA] ospf
[SwitchA-ospf-1] opaque-capability enable
[SwitchA-ospf-1-area-0.0.0.0] mpls te enable
[SwitchB] ospf
[SwitchB-ospf-1] opaque-capability enable
[SwitchB-ospf-1-area-0.0.0.0] mpls te enable
[SwitchC] ospf
[SwitchC-ospf-1] opaque-capability enable
[SwitchC-ospf-1-area-0.0.0.0] mpls te enable
[SwitchD] ospf
[SwitchD-ospf-1] opaque-capability enable
[SwitchD-ospf-1-area-0.0.0.0] mpls te enable
6.     Configure an explicit path on Switch A. Specify Switch B and Switch D as loose nodes, and Switch C as a strict node.
[SwitchA] explicit-path atod
[SwitchA-explicit-path-atod] nexthop 10.1.1.2 include loose
[SwitchA-explicit-path-atod] nexthop 20.1.1.2 include strict
[SwitchA-explicit-path-atod] nexthop 30.1.1.2 include loose
[SwitchA-explicit-path-atod] quit
7.     Configure MPLS TE attributes of links:
8.     Configure an MPLS TE tunnel on Switch A:
# Specify explicit path atod for the tunnel.
[SwitchA-Tunnel1] mpls te path preference 5 explicit-path atod
9.     Configure a static route on Switch A to direct the traffic destined for subnet 100.1.2.0/24 to MPLS TE tunnel 1.
[SwitchA] display interface tunnel 1
Tunnel1
Current state: UP
Bandwidth: 64kbps
Tunnel TTL 255
Input: 0 packets input, 0 bytes, 0 drops
Output: 3077 packets output, 197028 bytes, 0 drops
Tunnel Attributes      :
  LSP ID               : 23549           Tunnel ID            : 1
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : atod
  Metric Type          : TE
# Verify that Switch A has a static route entry with interface Tunnel1 as the output interface.
Destinations : 14       Routes : 14
7.1.1.0/24         Direct  0   0           7.1.1.1         Tun1
7.1.1.1/32         Direct  0   0           127.0.0.1       InLoop0
100.1.2.0/24       Static  1   0           0.0.0.0         Tun1
Establishing an inter-area MPLS TE tunnel over a CRLSP calculated by PCEs
Switch A, Switch B, Switch C, and Switch D support MPLS TE and run OSPF.
Configure Switch A and Switch B as PCEs, and configure Switch C as a PCC to automatically discover the PCEs.
Establish an MPLS TE tunnel over a CRLSP from Switch C to Switch D that uses the inter-area path calculated by PCEs.
Figure 9 Network diagram
2.     Configure OSPF to advertise interface addresses and configure OSPF TE:
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[SwitchA-ospf-1] area 1
[SwitchA-ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.1] mpls te enable
[SwitchA-ospf-1-area-0.0.0.1] quit
[SwitchB] ospf
[SwitchB-ospf-1] area 2
[SwitchB-ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.2] mpls te enable
[SwitchB-ospf-1-area-0.0.0.2] quit
[SwitchC] ospf
[SwitchC-ospf-1] area 1
[SwitchC-ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.1] network 3.3.3.3 0.0.0.0
[SwitchC-ospf-1-area-0.0.0.1] mpls te enable
[SwitchC-ospf-1-area-0.0.0.1] quit
[SwitchD] ospf
[SwitchD-ospf-1] area 2
[SwitchD-ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.2] network 4.4.4.4 0.0.0.0
[SwitchD-ospf-1-area-0.0.0.2] mpls te enable
[SwitchD-ospf-1-area-0.0.0.2] quit
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchA-Vlan-interface10] mpls enable
[SwitchA-Vlan-interface10] mpls te enable
[SwitchA-Vlan-interface10] rsvp enable
[SwitchA-Vlan-interface11] mpls enable
[SwitchA-Vlan-interface11] mpls te enable
[SwitchA-Vlan-interface11] rsvp enable
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchB-Vlan-interface10] mpls enable
[SwitchB-Vlan-interface10] mpls te enable
[SwitchB-Vlan-interface10] rsvp enable
[SwitchB] interface vlan-interface 11
[SwitchB-Vlan-interface11] mpls enable
[SwitchB-Vlan-interface11] mpls te enable
[SwitchB-Vlan-interface11] rsvp enable
[SwitchB-Vlan-interface11] quit
[SwitchC] mpls te
[SwitchC-te] quit
[SwitchC] rsvp
[SwitchC-rsvp] quit
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] mpls enable
[SwitchC-Vlan-interface11] mpls te enable
[SwitchC-Vlan-interface11] rsvp enable
[SwitchC-Vlan-interface11] quit
[SwitchD] mpls lsr-id 4.4.4.4
[SwitchD] mpls te
[SwitchD-te] quit
[SwitchD] rsvp
[SwitchD-rsvp] quit
[SwitchD] interface vlan-interface 11
[SwitchD-Vlan-interface11] mpls enable
[SwitchD-Vlan-interface11] mpls te enable
[SwitchD-Vlan-interface11] rsvp enable
[SwitchD-Vlan-interface11] quit
4.     Configure Switch A and Switch B as PCEs:
[SwitchA] mpls te
[SwitchA-te] pce address 1.1.1.1
[SwitchB] mpls te
[SwitchB-te] pce address 2.2.2.2
5.     Configure Switch C as a PCC to use the path calculated by PCEs:
[SwitchC] interface tunnel 1 mode mpls-te
[SwitchC-Tunnel1] ip address 7.1.1.1 255.255.255.0
[SwitchC-Tunnel1] destination 4.4.4.4
[SwitchC-Tunnel1] mpls te signaling rsvp-te
[SwitchC-Tunnel1] mpls te bandwidth 2000
# Configure the tunnel to use the path calculated by PCEs.
[SwitchC-Tunnel1] mpls te path preference 2 dynamic pce 1.1.1.1 2.2.2.2
[SwitchC-Tunnel1] quit
# Display discovered PCE information on each switch. This example uses Switch A.
[SwitchA] display mpls te pce discovery verbose
PCE address: 2.2.2.2
  Discovery methods: OSPF
  Path scopes:
    Path scope                                                Preference
    Compute intra-area paths                                  7
    Act as PCE for inter-area TE LSP computation              6
    Act as a default PCE for inter-area TE LSP computation    6
  Capabilities:
    Bidirectional path computation
    Support for request prioritization
    Support for multiple requests per message
  Domains:
    OSPF 1 area 0.0.0.0
    OSPF 1 area 0.0.0.2
# Verify that PCEP sessions have been established on each switch. This example uses Switch A.
[SwitchA] display mpls te pce peer verbose
Peer address: 2.2.2.2
  TCP connection          : 1.1.1.1:29507 -> 2.2.2.2:4189
  Peer type               : PCE
  Session type            : Stateless
  Session state           : UP
  Mastership              : Normal
  Role                    : Active
  Session up time         : 0000 days 00 hours 00 minutes
  Session ID              : Local 0, Peer 0
  Keepalive interval      : Local 30 sec, Peer 30 sec
  Recommended DeadTimer   : Local 120 sec, Peer 120 sec
  Tolerance:
    Min keepalive interval: 10 sec
    Max unknown messages  : 5
  Request timeout         : 10 sec
  Delegation timeout      : 30 sec
Peer address: 3.3.3.3
  TCP connection          : 3.3.3.3:29507 -> 1.1.1.1:4189
  Peer type               : PCC
  Session state           : UP
  Mastership              : Normal
  Role                    : Active
  Session ID              : Local 2, Peer 0
  Tolerance:
Bidirectional MPLS TE tunnel configuration example
Switch A, Switch B, Switch C, and Switch D all run IS-IS and they are all level-2 switches.
Use RSVP-TE to establish a bidirectional MPLS TE tunnel between Switch A and Switch D.
Figure 10 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.9/32
Switch D
Loop0
4.4.4.9/32
Vlan-int1
10.1.1.1/24
Vlan-int3
30.1.1.2/24
Vlan-int10
100.1.1.1/24
Vlan-int10
100.1.2.1/24
Switch B
Loop0
2.2.2.9/32
Switch C
Loop0
3.3.3.9/32
Vlan-int1
10.1.1.2/24
Vlan-int3
30.1.1.1/24
Vlan-int2
20.1.1.1/24
Vlan-int2
20.1.1.2/24
2.     Configure IS-IS to advertise interface addresses, including the loopback interface address.
For more information, see "Establishing an MPLS TE tunnel with RSVP-TE."
3.     Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE on each switch. Configure Switch A and Switch D to assign a non-null label to the penultimate hop:
[SwitchA] mpls label advertise non-null
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchC] mpls te
[SwitchC-te] quit
[SwitchC] rsvp
[SwitchC-rsvp] quit
[SwitchD] mpls label advertise non-null
[SwitchD] mpls te
[SwitchD-te] quit
[SwitchD] rsvp
[SwitchD-rsvp] quit
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchC] isis 1
[SwitchD] isis 1
5.     Configure a co-routed bidirectional MPLS TE tunnel:
# Configure Switch A as the active end of the co-routed bidirectional tunnel.
[SwitchA-Tunnel1] mpls te resv-style ff
[SwitchA-Tunnel1] mpls te bidirectional co-routed active
# Configure Switch D as the passive end of the co-routed bidirectional tunnel.
[SwitchD] interface tunnel 4 mode mpls-te
[SwitchD-Tunnel4] ip address 8.1.1.1 255.255.255.0
[SwitchD-Tunnel4] destination 1.1.1.9
[SwitchD-Tunnel4] mpls te signaling rsvp-te
[SwitchD-Tunnel4] mpls te resv-style ff
[SwitchD-Tunnel4] mpls te bidirectional co-routed passive reverse-lsp lsr-id 1.1.1.9 tunnel-id 1
[SwitchD-Tunnel4] quit
6.     Create static routes to direct traffic to MPLS TE tunnels.
# On switch A, create a static route to direct traffic destined for 100.1.2.0/24 to MPLS TE tunnel 1.
# On switch D, create a static route to direct traffic destined for 100.1.1.0/24 to MPLS TE tunnel 4.
[SwitchD] ip route-static 100.1.1.0 24 tunnel 4 preference 1
Tunnel1
Current state: UP
Bandwidth: 64kbps
Tunnel State           : Up (Main CRLSP up. Reverse CRLSP up)
Tunnel Attributes      :
  LSP ID               : 30478           Tunnel ID            : 1
  Resv Style           : FF
  Tunnel mode          : Co-routed, active
  Class Type           : CT0             Tunnel Bandwidth     : 0 kbps
  Explicit Path        : -
  Metric Type          : TE
# Display detailed information about the bidirectional MPLS TE tunnel on Switch A.
[SwitchA] display mpls lsp verbose
Destination  : 4.4.4.9
FEC          : 1.1.1.9/1/30478
Protocol     : RSVP
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1027
State        : Active
Out-Label    : 1149
Nexthop      : 10.1.1.2
Out-Interface: Vlan1
Protocol     : RSVP
LSR Type     : Egress
Service      : -
In-Label     : 1151
State        : Active
Nexthop      : 127.0.0.1
Out-Interface: -
Destination  : 10.1.1.2
FEC          : 10.1.1.2
Protocol     : Local
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1026
State        : Active
Nexthop      : 10.1.1.2
FEC          : Tunnel1
Protocol     : Local
LSR Type     : Ingress
Service      : -
NHLFE ID     : 268435457
State        : Active
Out-Interface: NHLFE74
# Verify that the tunnel interface is up on Switch D.
[SwitchD] display interface tunnel
Tunnel4
Current state: UP
Description: Tunnel4 Interface
Bandwidth: 64kbps
Internet address: 8.1.1.1/24 (primary)
Tunnel source unknown, destination 1.1.1.9
Tunnel TTL 255
Output: 0 packets output, 0 bytes, 0 drops
# Display detailed information about the MPLS TE tunnel on Switch D.
[SwitchD] display mpls te tunnel-interface
Tunnel Name            : Tunnel 4
Tunnel Attributes      :
  LSP ID               : -               Tunnel ID            : 8
  Ingress LSR ID       : -               Egress LSR ID        : -
  Resv Style           : FF
  Tunnel mode          : Co-routed, passive
  Reverse-LSP LSR ID   : 1.1.1.9         Reverse-LSP Tunnel ID: 1
  Setup Priority       : -               Holding Priority     : -
  Explicit Path        : -
  Metric Type          : -
  Bypass Tunnel        : -              Auto Created         : No
  Route Pinning        : -
  Retry Limit          : -               Retry Interval       : -
# Display detailed information about the bidirectional MPLS TE tunnel on Switch D.
[SwitchD] display mpls lsp verbose
Protocol     : RSVP
LSR Type     : Egress
Service      : -
In-Label     : 3
State        : Active
Nexthop      : 127.0.0.1
Out-Interface: -
Protocol     : RSVP
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1025
State        : Active
Out-Label    : 1150
Nexthop      : 30.1.1.1
Destination  : 30.1.1.1
FEC          : 30.1.1.1
Protocol     : Local
LSR Type     : Ingress
Service      : -
NHLFE ID     : 1024
State        : Active
Nexthop      : 30.1.1.1
FEC          : Tunnel1
Protocol     : Local
LSR Type     : Ingress
Service      : -
State        : Active
CRLSP backup configuration example
Switch A, Switch B, Switch C, and Switch D run IS-IS and IS-IS TE.
Use RSVP-TE to establish an MPLS TE tunnel from Switch A to Switch C to transmit data between the two IP networks. Enable CRLSP hot backup for the tunnel to simultaneously establish a primary CRLSP and a backup CRLSP. When the primary CRLSP fails, traffic is switched to the backup CRLSP.
Figure 11 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.9/32
Switch D
Loop0
4.4.4.9/32
Vlan-int1
10.1.1.1/24
Vlan-int4
30.1.1.2/24
Vlan-int4
30.1.1.1/24
Vlan-int3
40.1.1.1/24
Vlan-int10
100.1.1.1/24
Switch C
Loop0
3.3.3.9/32
Switch B
Loop0
2.2.2.9/32
Vlan-int2
20.1.1.2/24
Vlan-int1
10.1.1.2/24
Vlan-int3
40.1.1.2/24
Vlan-int2
20.1.1.1/24
Vlan-int10
100.1.2.1/24
Before configuration, disable the spanning tree feature globally or map each VLAN to an MSTI. For more information, see Layer 2—LAN Switching Configuration Guide.
2.     Configure IS-IS to advertise interface addresses, including the loopback interface address, and configure IS-IS TE. (Details not shown.)
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchA] interface vlan-interface 4
[SwitchA-Vlan-interface4] mpls enable
[SwitchA-Vlan-interface4] mpls te enable
[SwitchA-Vlan-interface4] rsvp enable
[SwitchA-Vlan-interface4] quit
# Configure Switch B, Switch C, and Switch D in the same way that Switch A is configured. (Details not shown.)
4.     Configure an MPLS TE tunnel on Switch A:
# Configure MPLS TE tunnel interface Tunnel 3.
[SwitchA] interface tunnel 3 mode mpls-te
[SwitchA-Tunnel3] ip address 9.1.1.1 24
[SwitchA-Tunnel3] destination 3.3.3.9
[SwitchA-Tunnel3] mpls te signaling rsvp-te
# Enable CRLSP hot backup for the tunnel.
[SwitchA-Tunnel3] mpls te backup hot-standby
[SwitchA-Tunnel3] quit
5.     Configure a static route on Switch A to direct the traffic destined for subnet 100.1.2.0/24 to MPLS TE tunnel 3.
[SwitchA] ip route-static 100.1.2.0 24 tunnel 3 preference 1
# Verify that the tunnel interface Tunnel 3 is up on Switch A.
Tunnel3
Current state: UP
Description: Tunnel3 Interface
Bandwidth: 64kbps
Internet address: 9.1.1.1/24 (primary)
Tunnel source unknown, destination 3.3.3.9
Tunnel TTL 255
# Verify that two CRLSPs exist on Switch A, one with the output interface VLAN-interface 1 and the other with the output interface VLAN-interface 4.
1.1.1.9/3/34311             RSVP     -/1150          Vlan1
1.1.1.9/3/34312             RSVP     -/1151          Vlan4
10.1.1.2                    Local    -/-             Vlan1
30.1.1.2                    Local    -/-             Vlan4
Tunnel3                     Local    -/-             NHLFE1026
Backup                               -/-             NHLFE1028
# Display the paths used by the two CRLSPs on Switch A.
[SwitchA] display rsvp lsp verbose
Tunnel name: SwitchA_t3
Destination: 3.3.3.9                      Source: 1.1.1.9
Tunnel ID: 3                              LSP ID: 30106
LSR type: Ingress                         Direction: Unidirectional
Setup priority: 7                         Holding priority: 7
In-Label: -                               Out-Label: 1137
In-Interface: -                           Out-Interface: Vlan1
Nexthop: 10.1.1.2                         Exclude-any: 0
Include-Any: 0                            Include-all: 0
Mean rate (CIR): 0 kbps                   Mean burst size (CBS): 1000.00 bytes
Path MTU: 1500                            Class type: CT0
RRO number: 6
  10.1.1.1/32        Flag: 0x00 (No FRR)
  10.1.1.2/32        Flag: 0x00 (No FRR/In-Int)
  2.2.2.9/32         Flag: 0x20 (No FRR/Node-ID)
  20.1.1.1/32        Flag: 0x00 (No FRR)
  20.1.1.2/32        Flag: 0x00 (No FRR/In-Int)
  3.3.3.9/32         Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: None
Tunnel name: Tunnel3
Tunnel ID: 3                              LSP ID: 30107
In-Label: -                               Out-Label: 1150
In-Interface: -                           Out-Interface: Vlan4
Nexthop: 30.1.1.2                         Exclude-any: 0
RRO number: 6
  30.1.1.1/32        Flag: 0x00 (No FRR)
  30.1.1.2/32        Flag: 0x00 (No FRR/In-Int)
  4.4.4.9/32         Flag: 0x20 (No FRR/Node-ID)
  40.1.1.1/32        Flag: 0x00 (No FRR)
  40.1.1.2/32        Flag: 0x00 (No FRR/In-Int)
# Trace the path that MPLS TE tunnel 3 traverses. The output shows that the used CRLSP is the one that traverses Switch B.
[SwitchA] tracert mpls te tunnel 3
MPLS trace route TE tunnel Tunnel3
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   10.1.1.2/[1147]
  1     10.1.1.2           1 ms    Transit   20.1.1.2/[3]
  2     20.1.1.2           2 ms    Egress
# Shut down interface VLAN-interface 2 on Switch B, and then tracert tunnel 3. The output shows that packets are forwarded on the CRLSP that traverses Switch D.
  0                                Ingress   30.1.1.2/[1148]
  1     30.1.1.2           2 ms    Transit   40.1.1.2/[3]
  2     40.1.1.2           3 ms    Egress
# Verify that only one CRLSP exists on Switch A.
1.1.1.9/3/34313             RSVP     -/1150          Vlan4
Tunnel3                     Local    -/-             NHLFE1029
# Execute the display ip routing-table command on Switch A. The output shows a static route entry with interface Tunnel 3 as the output interface. (Details not shown.)
Manual bypass tunnel for FRR configuration example
On the primary CRLSP Switch A—Switch B—Switch C—Switch D, use FRR to protect the link Switch B—Switch C.
Use RSVP-TE to establish the primary CRLSP and bypass tunnel based on the constraints of the explicit paths to transmit data between the two IP networks. The bypass tunnel uses path Switch B—Switch E—Switch C. Switch B is the PLR and Switch C is the MP.
Configure BFD for RSVP-TE between Switch B and Switch C. When the link between Switch B and Switch C fails, BFD can detect the failure quickly and notify RSVP-TE of the failure, so RSVP-TE can switch traffic to the bypass tunnel.
Figure 12 Network diagram
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.1/32
Switch B
Loop0
2.2.2.2/32
Vlan-int1
2.1.1.1/24
Vlan-int1
2.1.1.2/24
Vlan-int10
100.1.1.1/24
Vlan-int2
3.1.1.1/24
Switch D
Loop0
4.4.4.4/32
Vlan-int4
3.2.1.1/24
Vlan-int3
4.1.1.2/24
Switch C
Loop0
3.3.3.3/32
Vlan-int10
100.1.1.1/24
Vlan-int3
4.1.1.1/24
Switch E
Loop0
5.5.5.5/32
Vlan-int2
3.1.1.2/24
Vlan-int4
3.2.1.2/24
Vlan-int5
3.3.1.2/24
Vlan-int5
3.3.1.1/24
2.     Configure IS-IS to advertise interface addresses, including the loopback interface address. (Details not shown.)
3.     Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE on each switch. Enable BFD for RSVP-TE on Switch B and Switch C:
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchB-Vlan-interface2] rsvp bfd enable
[SwitchB] interface vlan-interface 4
[SwitchB-Vlan-interface4] mpls enable
[SwitchB-Vlan-interface4] mpls te enable
[SwitchB-Vlan-interface4] rsvp enable
[SwitchB-Vlan-interface4] quit
# Configure Switch C in the same way that Switch B is configured. Configure Switch D and Switch E in the same way that Switch A is configured. (Details not shown.)
4.     Configure an MPLS TE tunnel on Switch A, the ingress node of the primary CRLSP:
# Configure an explicit path for the primary CRLSP.
[SwitchA] explicit-path pri-path
[SwitchA-explicit-path-pri-path] nexthop 2.1.1.2
[SwitchA-explicit-path-pri-path] nexthop 3.1.1.2
[SwitchA-explicit-path-pri-path] nexthop 4.1.1.2
[SwitchA-explicit-path-pri-path] nexthop 4.4.4.4
[SwitchA-explicit-path-pri-path] quit
# Create MPLS TE tunnel interface Tunnel 4 for the primary CRLSP.
[SwitchA] interface tunnel 4 mode mpls-te
[SwitchA-Tunnel4] ip address 10.1.1.1 255.255.255.0
[SwitchA-Tunnel4] destination 4.4.4.4
# Specify the tunnel signaling protocol as RSVP-TE.
[SwitchA-Tunnel4] mpls te signaling rsvp-te
# Specify the explicit path to be used as pri-path.
[SwitchA-Tunnel4] mpls te path preference 1 explicit-path pri-path
# Enable FRR for the MPLS TE tunnel.
[SwitchA-Tunnel4] mpls te fast-reroute
[SwitchA-Tunnel4] quit
# Verify that the tunnel interface Tunnel 4 is up on Switch A.
Tunnel4
Current state: UP
Bandwidth: 64kbps
Tunnel source unknown, destination 4.4.4.4
Tunnel TTL 255
Last 300 seconds output rate: 1911 bytes/sec, 15288 bits/sec, 0 packets/sec
Output: 1526 packets output, 22356852 bytes, 0 drops
Tunnel Attributes      :
  LSP ID               : 48960           Tunnel ID            : 4
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : pri-path
  Metric Type          : TE
  Record Route         : Enabled         Record Label         : Enabled
  FRR Flag             : Enabled         Bandwidth Protection : Disabled
5.     Configure a bypass tunnel on Switch B (the PLR):
# Configure an explicit path for the bypass tunnel.
[SwitchB] explicit-path by-path
[SwitchB-explicit-path-by-path] nexthop 3.2.1.2
[SwitchB-explicit-path-by-path] nexthop 3.3.1.2
[SwitchB-explicit-path-by-path] nexthop 3.3.3.3
[SwitchB-explicit-path-by-path] quit
# Create MPLS TE tunnel interface Tunnel 5 for the bypass tunnel.
[SwitchB] interface tunnel 5 mode mpls-te
[SwitchB-Tunnel5] ip address 11.1.1.1 255.255.255.0
# Specify the tunnel destination address as LSR ID of Switch C.
[SwitchB-Tunnel5] destination 3.3.3.3
[SwitchB-Tunnel5] mpls te signaling rsvp-te
# Specify the explicit path to be used as by-path.
[SwitchB-Tunnel5] mpls te path preference 1 explicit-path by-path
# Set the bandwidth that the bypass tunnel can protect.
[SwitchB-Tunnel5] mpls te backup bandwidth un-limited
[SwitchB-Tunnel5] quit
# Bind the bypass tunnel to the protected interface.
[SwitchB-Vlan-interface2] mpls te fast-reroute bypass-tunnel tunnel 5
# Execute the display interface tunnel command on Switch B to verify that the tunnel interface Tunnel 5 is up. (Details not shown.)
6.     Configure a static route on Switch A to direct the traffic destined for subnet 100.1.2.0/24 to MPLS TE tunnel 4.
[SwitchA] ip route-static 100.1.2.0 24 tunnel 4 preference 1
# Display LSP entries on each switch to verify that Switch B and Switch C each have two CRLSPs and the bypass tunnel backs up the primary CRLSP.
1.1.1.1/4/61400             RSVP     -/1245          Vlan1
1.1.1.1/4/614000            RSVP     1245/3          Vlan2
Backup                               1245/3          Tun5
2.2.2.2/5/30914             RSVP     -/1150          Vlan2
3.2.1.2                     Local    -/-             Vlan4
3.1.1.2                     Local    -/-             Vlan2
[SwitchE] display mpls lsp
2.2.2.2/5/30914             RSVP     1150/3          Vlan5
3.3.1.2                     Local    -/-             Vlan5
# Shut down the protected interface VLAN-interface 2 on the PLR (Switch B).
[SwitchB-Vlan-interface2] shutdown
# Execute the display interface tunnel 4 command on Switch A to display information about the primary CRLSP. The output shows that the tunnel interface is still up. (Details not shown.)
# Display detailed information about the tunnel interface on Switch A.
Tunnel State           : Up (Main CRLSP up. Shared-resource CRLSP being set up)
Tunnel Attributes      :
  LSP ID               : 18753           Tunnel ID            : 4
  Resv Style           : SE
  Tunnel mode          : -
  Metric Type          : TE
If you execute the display mpls te tunnel-interface command immediately after an FRR, you can see two CRLSPs in up state. This is because FRR uses the make-before-break mechanism to set up a new LSP, and the old LSP is deleted after the new one has been established for a while.
# Verify that the bypass tunnel is in use on Switch B.
1.1.1.1/4/61400             RSVP     1136/3          Tun5
2.2.2.2/5/30914             RSVP     -/1149          Vlan4
# On the PLR, configure the interval for selecting an optimal bypass tunnel as 5 seconds.
[SwitchB] mpls te
[SwitchB-te] fast-reroute timer 5
[SwitchB-te] quit
# On the PLR, bring up the protected interface VLAN-interface 2.
[SwitchB-Vlan-interface2] undo shutdown
# Execute the display interface tunnel 4 command on Switch A to display information about the primary CRLSP. The output shows that the tunnel interface is in up state. (Details not shown.)
# Wait for about 5 seconds, execute the display mpls lsp verbose command on Switch B. The output shows that Tunnel 5 is bound to interface VLAN-interface 2 but not in use. (Details not shown.)
# Execute the display ip routing-table command on Switch A. The output shows a static route entry with interface Tunnel 4 as the output interface. (Details not shown.)
Auto FRR configuration example
Use RSVP-TE to set up a primary CRLSP that explicitly uses path Switch A—Switch B—Switch C—Switch D.
Configure auto FRR on Switch B to automatically set up bypass tunnels for the primary CRLSP.
Figure 13 Network diagram
Table 7 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Loop0
1.1.1.1/32
Switch E
Loop0
5.5.5.5/32
Vlan-int1
2.1.1.1/24
Vlan-int4
3.2.1.2/24
Switch B
Loop0
2.2.2.2/32
Vlan-int5
3.4.1.1/24
Vlan-int1
2.1.1.2/24
Switch C
Loop0
3.3.3.3/32
Vlan-int2
3.1.1.1/24
Vlan-int3
4.1.1.1/24
Vlan-int4
3.2.1.1/24
Vlan-int2
3.1.1.2/24
Vlan-int6
3.3.1.1/24
Vlan-int5
3.4.1.2/24
Switch D
Loop0
4.4.4.4/32
Switch F
Loop0
6.6.6.6/32
Vlan-int3
4.1.1.2/24
Vlan-int6
3.3.1.2/24
Vlan-int7
4.2.1.2/24
Vlan-int7
4.2.1.1/24
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchB] mpls te
[SwitchB-te] quit
[SwitchB] rsvp
[SwitchB-rsvp] quit
[SwitchB] interface vlan-interface 6
[SwitchB-Vlan-interface6] mpls enable
[SwitchB-Vlan-interface6] mpls te enable
[SwitchB-Vlan-interface6] rsvp enable
[SwitchB-Vlan-interface6] quit
# Configure Switch C in the same way that Switch B is configured. Configure Switch D, Switch E, and Switch F in the same way that Switch A is configured. (Details not shown.)
# Configure an explicit path named pri-path for the primary CRLSP.
# Configure an MPLS TE tunnel.
[SwitchA-Tunnel1] ip address 10.1.1.1 255.255.255.0
[SwitchA-Tunnel1] destination 4.4.4.4
# Specify the explicit path as pri-path.
[SwitchA-Tunnel1] mpls te path preference 1 explicit-path pri-path
[SwitchA-Tunnel1] mpls te fast-reroute
# Verify that the MPLS TE interface Tunnel1 is up on Switch A.
Tunnel1
Current state: UP
Bandwidth: 64kbps
Tunnel TTL 255
# Display detailed information about the MPLS TE tunnel interface on Switch A.
Tunnel Attributes      :
  LSP ID               : 16802           Tunnel ID            : 1
  Ingress LSR ID       : 2.2.2.2         Egress LSR ID        : 4.4.4.4
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : exp1
  Metric Type          : TE
5.     Configure auto FRR on Switch B (the PLR):
# Enable the automatic bypass tunnel setup feature globally.
[SwitchB] mpls te
[SwitchB-te] auto-tunnel backup
# Specify interface numbers 50 to 100 for the automatically created bypass tunnels.
[SwitchB-te-auto-bk] tunnel-number min 50 max 100
[SwitchB-te-auto-bk] quit
# Verify that two tunnels have been created automatically on Switch B.
[SwitchB] display interface tunnel brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Tun50                UP   DOWN     --
Tun51                UP   DOWN     --
# Display information about Tunnel 50 and Tunnel 51 on Switch B. The output shows that Tunnel 50 and Tunnel 51 are automatically created bypass tunnels. Tunnel 50 is a node-protection bypass tunnel (egress LSR ID is 4.4.4.4, the LSR ID of Switch D). Tunnel 51 is a link-protection bypass tunnel (egress LSR ID is 3.3.3.3, the LSR ID of Switch C).
[SwitchB] display mpls te tunnel-interface tunnel 50
Tunnel Name            : Tunnel 50
Tunnel Attributes      :
  LSP ID               : 16802           Tunnel ID            : 50
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : -
  Metric Type          : TE
  Record Route         : Enabled         Record Label         : Disabled
  Bypass Tunnel        : Yes             Auto Created         : Yes
[SwitchB] display mpls te tunnel-interface tunnel 51
Tunnel Name            : Tunnel 51
Tunnel Attributes      :
  LSP ID               : 16802           Tunnel ID            : 51
  Ingress LSR ID       : 2.2.2.2         Egress LSR ID        : 3.3.3.3
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : -
  Metric Type          : TE
# Verify that the current bypass tunnel that protects the primary CRLSP is tunnel 50.
2.2.2.2/51/16802            RSVP     -/3             Vlan4
2.2.2.2/1/16802             RSVP     -/1151          Vlan2
Backup                               -/3             Tun50
2.2.2.2/50/16802            RSVP     -/3             Vlan6
3.2.1.2                     Local    -/-             Vlan6
3.3.1.2                     Local    -/-             Vlan6
# Display detailed information about MPLS TE Tunnel1 (the tunnel for the primary CRLSP) on Switch A. The output shows that Tunnel1 is protected by the bypass tunnel Tunnel50, and the protected node is 3.1.1.1.
[SwitchA] display rsvp lsp tunnel-id 1 verbose
Tunnel name: Tunnel1
Destination: 4.4.4.4                      Source: 1.1.1.1
Tunnel ID: 1                              LSP ID: 16802
Nexthop: 2.1.1.2                          Exclude-any: 0
Average bitrate: 0 kbps                   Maximum burst: 1000.00 bytes
RRO number: 12
  2.1.1.1/32         Flag: 0x00 (No FRR)
  2.1.1.2/32         Flag: 0x00 (No FRR)
  1150               Flag: 0x01 (Global label)
  2.2.2.2/32         Flag: 0x20 (No FRR/Node-ID)
  3.1.1.1/32         Flag: 0x09 (FRR Avail/Node-Prot)
  3.1.1.2/32         Flag: 0x00 (No FRR)
  1151               Flag: 0x01 (Global label)
  3.3.3.3/32         Flag: 0x20 (No FRR/Node-ID)
  4.1.1.1/32         Flag: 0x00 (No FRR)
  4.1.1.2/32         Flag: 0x00 (No FRR)
  3                  Flag: 0x01 (Global label)
  4.4.4.4/32         Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: Ready
  FRR inner label: 3           Bypass tunnel: Tunnel50
Troubleshooting MPLS TE
No TE LSA generated
Symptom
OSPF TE is configured but no TE LSAs can be generated to describe MPLS TE attributes.
Analysis
For TE LSAs to be generated, a minimum of one OSPF neighbor must reach FULL state.
Solution
1.     To resolve the problem:
a.     Use the display current-configuration command to verify that MPLS TE is configured on involved interfaces.
b.     Use the debugging ospf mpls-te command to verify that OSPF can receive the TE LINK establishment message.
c.     Use the display ospf peer command to verify that OSPF neighbors are established correctly.
2.     If the problem persists, contact H3C Support.
