07-IP Multicast Configuration Guide
HomeSupportSwitchesH3C S7500X Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500X Switch Series Configuration Guides-R757X-6W10007-IP Multicast Configuration Guide
12-IPv6 multicast VLAN configuration
12-IPv6 multicast VLAN configuration 143.78 KB
Configuring IPv6 multicast VLANs
Overview
As shown in Figure 1, Host A, Host B, and Host C are in different VLANs and the same IPv6 multicast group. When Switch A (Layer 3 device) receives IPv6 multicast data for that group, it forwards three copies of the data to Switch B (Layer 2 device). This occupies a large amount of bandwidth and increases the burden on the Layer 3 device.
Figure 1 Multicast transmission without the IPv6 multicast VLAN feature
After an IPv6 multicast VLAN is configured on Switch B, Switch A sends one copy of the IPv6 multicast data to the IPv6 multicast VLAN on Switch B. This saves network bandwidth and lessens the burden on the Layer 3 device.
IPv6 multicast VLANs include sub-VLAN-based IPv6 multicast VLANs and port-based IPv6 multicast VLANs.
Sub-VLAN-based IPv6 multicast VLAN
As shown in Figure 2:
·     Host A, Host B, and Host C are in VLAN 2 through VLAN 4, respectively.
·     On Switch B, VLAN 10 is an IPv6 multicast VLAN. VLAN 2 through VLAN 4 are sub-VLANs of VLAN 10.
·     MLD snooping is enabled for the multicast VLAN and its sub-VLANs.
Figure 2 Sub-VLAN-based multicast VLAN
MLD snooping manages router ports in the IPv6 multicast VLAN and member ports in each sub-VLAN. When Switch A receives IPv6 multicast data from the IPv6 multicast source, it sends only one copy of the IPv6 multicast data to the IPv6 multicast VLAN on Switch B. Then, Switch B sends a separate copy to each sub-VLAN of the IPv6 multicast VLAN.
Port-based IPv6 multicast VLAN
As shown in Figure 3:
·     Host A, Host B, and Host C are in VLAN 2 through VLAN 4, respectively. All the user ports (ports with attached hosts) on Switch B are hybrid ports.
·     On Switch B, VLAN 10 is an IPv6 multicast VLAN. All the user ports are assigned to VLAN 10.
·     MLD snooping is enabled for the IPv6 multicast VLAN and its sub-VLANs.
Figure 3 Port-based IPv6 multicast VLAN
MLD snooping manages the router ports and member ports in the IPv6 multicast VLAN. When Switch A receives IPv6 multicast data from the IPv6 multicast source, it sends only one copy of the IPv6 multicast data to the IPv6 multicast VLAN on Switch B. Then, Switch B sends a separate copy to each user port in the IPv6 multicast VLAN.
IPv6 multicast VLAN configuration task list
Tasks at a glance
(Required.) Perform one of the following tasks:
·     Configuring a sub-VLAN-based IPv6 multicast VLAN
·     Configuring a port-based IPv6 multicast VLAN:
¡     Configuring user port attributes
¡     Assigning user ports to an IPv6 multicast VLAN
(Optional.) Setting the maximum number of IPv6 multicast VLAN forwarding entries
When you configure the IPv6 multicast VLANs, follow these guidelines:
·     If you have configured both a sub-VLAN-based IPv6 multicast VLAN and a port-based IPv6 multicast VLAN on a device, the port-based IPv6 multicast VLAN configuration takes effect.
·     Do not configure an IPv6 multicast VLAN on a device that is enabled with IPv6 multicast routing enabled. Otherwise, the system displays errors.
·     Do not enable IPv6 multicast routing on a device that is configured with IPv6 multicast VLANs. Otherwise, IPv6 multicast forwarding exceptions occur.
·     Do not configure a VLAN as an IPv6 multicast VLAN or an IPv6 sub-VLAN if the VLAN interface is enabled with IPv6 PIM or MLD. Otherwise, the system displays errors.
·     Do not enable IPv6 PIM or MLD on a VLAN interface if the VLAN interface belongs to an IPv6 multicast VLAN or an IPv6 multicast sub-VLAN. Otherwise, IPv6 multicast forwarding exceptions occur.
·     The IPv6 multicast VLAN feature does not take effect on secondary VLANs. As a best practice, do not configure the IPv6 multicast VLAN feature for secondary VLANs. For more information about secondary VLAN, see Layer 2—LAN Switching Configuration Guide.
To configure a sub-VLAN-based IPv6 multicast VLAN, configure a VLAN as an IPv6 multicast VLAN, and assign the VLANs that contain multicast receivers to the IPv6 multicast VLAN as sub-VLANs.
Configuration prerequisites
Before you configure a sub-VLAN-based IPv6 multicast VLAN, complete the following tasks:
·     Create VLANs as required.
·     Enable MLD snooping for the VLAN to be configured as the IPv6 multicast VLAN, and for the VLANs to be configured as sub-VLANs.
Configuration guidelines
When you configure a sub-VLAN-based IPv6 multicast VLAN, follow these guidelines:
·     The VLAN to be configured as the IPv6 multicast VLAN must exist.
·     A VLAN to be configured as a sub-VLAN must exist and cannot be an IPv6 multicast VLAN or a sub-VLAN of any other IPv6 multicast VLANs.
·     You can configure a maximum number of five IPv6 multicast VLANs.
Configuration procedure
To configure a sub-VLAN-based IPv6 multicast VLAN:
Step
Remarks
N/A
2.     Configure a VLAN as an IPv6 multicast VLAN and enter its view.
ipv6 multicast-vlan vlan-id
By default, a VLAN is not an IPv6 multicast VLAN.
3.     Assign the specified VLANs to the IPv6 multicast VLAN as sub-VLANs.
subvlan vlan-list
By default, an IPv6 multicast VLAN does not have any sub-VLANs.
You can assign only Layer 2 Ethernet interfaces or Layer 2 aggregate interfaces as user ports to an IPv6 multicast VLAN.
Before you configure a port-based IPv6 multicast VLAN, complete the following tasks:
·     Enable MLD snooping for the VLAN to be configured as the IPv6 multicast VLAN.
·     Enable MLD snooping for all the VLANs that contain the multicast receivers.
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Configure the link type of the user port as hybrid.
port link-type hybrid
The default setting is access.
For more information about this command, see Layer 2—LAN Switching Command Reference.
4.     Specify the PVID of the current user port as the VLAN to which the user port belongs.
port hybrid pvid vlan vlan-id
By default, the PVID for a hybrid port is VLAN 1.
5.     Configure the current user port to permit IPv6 multicast VLAN and to untag the packets.
port hybrid vlan vlan-id-list untagged
By default, a hybrid port permits only VLAN 1.
You can assign user ports to an IPv6 multicast VLAN in IPv6 multicast VLAN view or assign a user port to an IPv6 multicast VLAN in interface view.
When you perform this task, follow these restrictions and guidelines:
·     The VLAN to be configured as an IPv6 multicast VLAN must exist.
·     A port can belong to only one IPv6 multicast VLAN.
To assign user ports to an IPv6 multicast VLAN in IPv6 multicast VLAN view:
Step
Remarks
N/A
2.     Configure an IPv6 VLAN as an IPv6 multicast VLAN and enter its view.
3.     Assign ports to the IPv6 multicast VLAN.
port interface-list
By default, an IPv6 multicast VLAN does not have any user ports.
To assign a user port to an IPv6 multicast VLAN in interface view:
Step
Remarks
N/A
3.     Return to system view.
N/A
4.     Enter interface view.
N/A
5.     Assign the current port to the IPv6 multicast VLAN.
ipv6 port multicast-vlan vlan-id
By default, a user port does not belong to any IPv6 multicast VLAN.
You can set the maximum number of IPv6 multicast VLAN forwarding entries on the device. When the upper limit is reached, the device does not create IPv6 multicast VLAN forwarding entries until some entries age out or are manually removed.
If the total number of entries exceeds the upper limit value that you are setting, the system does not automatically remove existing entries or create new entries. In this case, remove excessive entries manually.
To set the maximum number of IPv6 multicast VLAN forwarding entries:
Step
Remarks
N/A
2.     Set the maximum number of IPv6 multicast VLAN forwarding entries.
ipv6 multicast-vlan entry-limit limit
By default, the maximum number of IPv6 multicast VLAN forwarding entries is 8192.
Displaying and maintaining IPv6 multicast VLANs
Display information about IPv6 multicast VLANs.
display ipv6 multicast-vlan [ vlan-id ]
(In standalone mode.) Display information about information about IPv6 multicast group entries in IPv6 multicast VLANs.
display ipv6 multicast-vlan group [ ipv6-source-address | ipv6-group-address | slot slot-number | verbose | vlan vlan-id ] *
(In IRF mode.) Display information about information about IPv6 multicast group entries in IPv6 multicast VLANs.
display ipv6 multicast-vlan group [ ipv6-source-address | ipv6-group-address | chassis chassis-number slot slot-number | verbose | vlan vlan-id ] *
(In standalone mode.) Display IPv6 multicast VLAN forwarding entries.
display ipv6 multicast-vlan forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | slot slot-number | subvlan vlan-id | vlan vlan-id ] *
(In IRF mode.) Display IPv6 multicast VLAN forwarding entries.
display ipv6 multicast-vlan forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | chassis chassis-number slot slot-number | subvlan vlan-id | vlan vlan-id ] *
Clear IPv6 multicast group entries in IPv6 multicast VLANs.
reset ipv6 multicast-vlan group [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | vlan vlan-id ] *
IPv6 multicast VLAN configuration examples
Sub-VLAN-based IPv6 multicast VLAN configuration example
Network requirements
As shown in Figure 4:
·     Layer 3 device Switch A runs MLD and acts as the MLD querier. Layer 2 device Switch B runs MLDv1 snooping.
·     The IPv6 multicast source sends IPv6 multicast data to IPv6 multicast group FF1E::101. Receivers Host A, Host B, and Host C belong to VLAN 2, VLAN 3, and VLAN 4, respectively.
Configure a sub-VLAN-based IPv6 multicast VLAN on Switch B to meet the following requirements:
·     Switch A sends the IPv6 multicast data to Switch B through the IPv6 multicast VLAN.
·     Switch B forwards the IPv6 multicast data to the receivers in different user VLANs.
Figure 4 Network diagram
1.     Configure Switch A:
# Enable IPv6 multicast routing.
[SwitchA-mrib6] quit
# Create VLAN 20, and assign GigabitEthernet 1/0/2 to the VLAN.
[SwitchA] vlan 20
[SwitchA-vlan20] port gigabitethernet 1/0/2
[SwitchA-vlan20] quit
# Assign an IPv6 address to VLAN-interface 20, and enable IPv6 PIM-DM on the interface.
[SwitchA-Vlan-interface20] ipv6 address 1::2 64
[SwitchA-Vlan-interface20] ipv6 pim dm
# Create VLAN 10.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
# Configure GigabitEthernet 1/0/1 as a hybrid port, and assign the port to VLAN 10 as a tagged VLAN member.
[SwitchA-GigabitEthernet1/0/1] port link-type hybrid
[SwitchA-GigabitEthernet1/0/1] port hybrid vlan 10 tagged
[SwitchA-GigabitEthernet1/0/1] quit
# Assign an IPv6 address to VLAN-interface 10, and enable MLD on the interface.
[SwitchA-Vlan-interface10] ipv6 address 2001::1 64
[SwitchA-Vlan-interface10] mld enable
2.     Configure Switch B:
# Enable MLD snooping globally.
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
# Create VLAN 2, assign GigabitEthernet 1/0/2 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 2
[SwitchB-vlan2] port gigabitethernet 1/0/2
[SwitchB-vlan2] mld-snooping enable
[SwitchB-vlan2] quit
# Create VLAN 3, assign GigabitEthernet 1/0/3 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 3
[SwitchB-vlan3] port gigabitethernet 1/0/3
[SwitchB-vlan3] mld-snooping enable
[SwitchB-vlan3] quit
# Create VLAN 4, assign GigabitEthernet 1/0/4 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 4
[SwitchB-vlan4] port gigabitethernet 1/0/4
[SwitchB-vlan4] mld-snooping enable
[SwitchB-vlan4] quit
# Create VLAN 10, and enable MLD snooping for the VLAN.
[SwitchB] vlan 10
[SwitchB-vlan10] mld-snooping enable
[SwitchB-vlan10] quit
[SwitchB-GigabitEthernet1/0/1] port link-type hybrid
[SwitchB-GigabitEthernet1/0/1] port hybrid vlan 10 tagged
# Configure VLAN 10 as an IPv6 multicast VLAN, and assign VLAN 2 through VLAN 4 as sub-VLANs to multicast VLAN 10.
[SwitchB] ipv6 multicast-vlan 10
[SwitchB-ipv6-mvlan-10] subvlan 2 to 4
[SwitchB-ipv6-mvlan-10] quit
# Display information about all IPv6 multicast VLANs on Switch B.
[SwitchB] display ipv6 multicast-vlan
Total 1 IPv6 multicast VLANs.
IPv6 multicast VLAN 10:
  Sub-VLAN list(3 in total):
     2-4
  Port list(0 in total):
# Display information about IPv6 multicast groups in IPv6 multicast VLANs on Switch B.
[SwitchB] display ipv6 multicast-vlan group
Total 1 entries.
IPv6 multicast VLAN 10: Total 1 entries.
  (::, FF1E::101)
    Sub-VLANs (3 in total):
      VLAN 2
      VLAN 3
      VLAN 4
The output shows that IPv6 multicast group FF1E::101 belongs to IPv6 multicast VLAN 10. IPv6 multicast VLAN 10 contains sub-VLANs VLAN 2 through VLAN 4. Switch B will replicate the IPv6 multicast data of VLAN 10 to VLAN 2 through VLAN 4.
Port-based IPv6 multicast VLAN configuration example
As shown in Figure 5:
·     Layer 3 device Switch A runs MLDv1 and acts as the MLD querier. Layer 2 device Switch B runs MLDv1 snooping.
Configure a port-based IPv6 multicast VLAN on Switch B to meet the following requirements:
·     Switch A sends IPv6 multicast data to Switch B through the IPv6 multicast VLAN.
Figure 5 Network diagram
[SwitchA] vlan 20
# Create VLAN 10, and assign GigabitEthernet 1/0/1 to the VLAN.
[SwitchA] vlan 10
[SwitchA-vlan10] port gigabitethernet 1/0/1
# Create VLAN 10, assign GigabitEthernet 1/0/1 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 10
[SwitchB-vlan10] port gigabitethernet 1/0/1
# Create VLAN 2, and enable MLD snooping for the VLAN.
[SwitchB] vlan 2
# Create VLAN 3, and enable MLD snooping for the VLAN.
[SwitchB] vlan 3
# Create VLAN 4, and enable MLD snooping for the VLAN.
[SwitchB] vlan 4
# Configure GigabitEthernet 1/0/2 as a hybrid port, and configure VLAN 2 as the PVID of the hybrid port.
[SwitchB] interface gigabitethernet 1/0/2
[SwitchB-GigabitEthernet1/0/2] port link-type hybrid
[SwitchB-GigabitEthernet1/0/2] port hybrid pvid vlan 2
# Assign GigabitEthernet 1/0/2 to VLAN 2 and VLAN 10 as an untagged VLAN member.
[SwitchB-GigabitEthernet1/0/2] port hybrid vlan 2 untagged
[SwitchB-GigabitEthernet1/0/2] port hybrid vlan 10 untagged
# Configure GigabitEthernet 1/0/3 as a hybrid port, and configure VLAN 3 as the PVID of the hybrid port.
[SwitchB] interface gigabitethernet 1/0/3
[SwitchB-GigabitEthernet1/0/3] port link-type hybrid
[SwitchB-GigabitEthernet1/0/3] port hybrid pvid vlan 3
# Assign GigabitEthernet 1/0/3 to VLAN 3 and VLAN 10 as an untagged VLAN member.
[SwitchB-GigabitEthernet1/0/3] port hybrid vlan 3 untagged
[SwitchB-GigabitEthernet1/0/3] port hybrid vlan 10 untagged
[SwitchB-GigabitEthernet1/0/3] quit
# Configure GigabitEthernet 1/0/4 as a hybrid port, and configure VLAN 4 as the PVID of the hybrid port.
[SwitchB] interface gigabitethernet 1/0/4
[SwitchB-GigabitEthernet1/0/4] port link-type hybrid
[SwitchB-GigabitEthernet1/0/4] port hybrid pvid vlan 4
# Assign GigabitEthernet 1/0/4 to VLAN 4 and VLAN 10 as an untagged VLAN member.
[SwitchB-GigabitEthernet1/0/4] port hybrid vlan 4 untagged
[SwitchB-GigabitEthernet1/0/4] port hybrid vlan 10 untagged
[SwitchB-GigabitEthernet1/0/4] quit
# Configure VLAN 10 as an IPv6 multicast VLAN.
# Assign GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 to VLAN 10.
[SwitchB-ipv6-mvlan-10] port gigabitethernet 1/0/2 to gigabitethernet 1/0/3
# Assign GigabitEthernet 1/0/4 to VLAN 10.
[SwitchB-GigabitEthernet1/0/4] ipv6 port multicast-vlan 10
# Display information about IPv6 multicast VLANs on Switch B.
  Sub-VLAN list(0 in total):
  Port list(3 in total):
    GE1/0/2
    GE1/0/3
    GE1/0/4
# Display dynamic MLD snooping forwarding entries on Switch B.
[SwitchB] display mld-snooping group
Total 1 entries.
  (::, FF1E::101)
    Host slots (0 in total):
    Host ports (3 in total):
      GE1/0/2         (00:03:23)
      GE1/0/3         (00:04:07)
      GE1/0/4         (00:04:16)
The output shows that MLD snooping maintains the user ports in the multicast VLAN (VLAN 10). Switch B will forward the IPv6 multicast data of VLAN 10 through these user ports.
