02-WLAN Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C WX Series Access Controllers Configuration Guides(R3308 R2308)-6W10702-WLAN Configuration Guide
01-WLAN Interface Configuration
01-WLAN Interface Configuration 82.60 KB
Configuring WLAN interfaces
WLAN-ESS interface
The interface that allows the wireless local area net to cover all the WLAN-ESS interfaces is a virtual Layer 2 interface. This interface operates like Layer 2 access Ethernet ports with Layer 2 attributes. It also supports multiple Layer 2 protocols. A WLAN-ESS interface can also be used as a template for configuring WLAN-DBSS interfaces. A WLAN-DBSS interfaces created on a WLAN-ESS interface adopts the configuration of the WLAN-ESS interface.
Entering WLAN-ESS interface view
Step
Remarks
N/A
2.     Enter WLAN-ESS interface view.
interface wlan-ess interface-number
If the WLAN-ESS interface does not exist, this command creates the WLAN-ESS interface first.
3.     Restore the default settings of the WLAN-ESS interface.
default
Optional
Configuring a WLAN-ESS interface
You can configure the description of a WLAN-ESS interface and assign the interface to a common VLAN or multicast VLAN. This section provides general information on features supported on WLAN-ESS interfaces. For more information about these features and commands, see the corresponding chapters in the configuration guide and command reference.
To configure a WLAN-ESS interface:
Step
1.     Configure the description of the interfaceN/A
description
2.     Configure the VLAN.
·     port access vlan
·     port hybrid vlan
·     port hybrid pvid vlan
·     port link-type
3.     Configure multicast.
·     Configure multicast VLAN:
port multicast-vlan
·     Configure IPv6 multicast VLAN:
port multicast-vlan ipv6
4.     Configure a MAC authentication guest VLAN.
mac-authentication guest-vlan
·     Before executing the port access vlan command, make sure the VLAN specified by the vlanid argument already exists. You can use the vlan command to create a VLAN. For more information about the port access vlan command, see Layer 2 Command Reference.
·     Some configurations made on (only VLAN-related configurations) a WLAN-ESS interface with WLAN-DBSS interfaces created on it cannot be modified, and the WLAN-ESS interface cannot be removed either.
WLAN-DBSS interface
WLAN-DBSS interfaces are virtual Layer 2 interfaces. They operate like Layer 2 Ethernet ports of the access link type. They also support multiple Layer 2 protocols and 802.1X. A WLAN-DBSS interface that has been created on a WLAN-ESS interface adopts the configuration of the WLAN-ESS interface. On a wireless switch, the WLAN module dynamically creates a WLAN-DBSS interface for each wireless access service and removes the interface after the service expires.
WLAN mesh interface
WLAN mesh interfaces are Layer 2 virtual interfaces. You can use them as configuration templates to make and save settings for WLAN mesh link interfaces. After a WLAN mesh link interface is created, you are not allowed to change the settings on its associated WLAN mesh interface.
Entering WLAN mesh interface view
Step
Remarks
N/A
2.     Enter WLAN mesh interface view.
interface wlan-mesh interface-number
If the specified WLAN mesh interface does not exist, this command creates the WLAN mesh interface first.
3.     Restore the default settings of the WLAN mesh interface.
default
Optional.
Configuring a WLAN mesh interface
Step
1.     Configure the description of the WLAN mesh interface.
description
2.     Configure VLAN settings.
·     port link-type
·     port access
·     port trunk
·     port hybrid
WLAN mesh link interfaces are similar to Layer 2 virtual Ethernet interfaces and have the features of Layer 2 interfaces. They are dynamically created or deleted by the WLAN module and are responsible for local data forwarding on the mesh network.
WLAN mesh link interfaces use the settings you made on their corresponding WLAN mesh interfaces and are not configurable.
Displaying and maintaining a WLAN interface
Remarks
Display information about WLAN-ESS interfaces.
display interface [ wlan-ess ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface wlan-ess interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display information about WLAN-DBSS interfaces.
display interface [ wlan-dbss ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface wlan-dbss interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
Display information about WLAN-Mesh interfaces.
display interface [ wlan-mesh ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface wlan-mesh interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
