- 02-WLAN Configuration Guide
- 01-WLAN Interface Configuration
- 02-WLAN Service Configuration
- 03-WLAN Security Configuration
- 04-WLAN Roaming Configuration
- 05-WLAN RRM Configuration
- 06-WLAN IDS Configuration
- 07-WLAN QoS Configuration
- 08-WLAN Mesh Link Configuration
- 09-WLAN Optimization Configuration
- 10-Advanced WLAN Configuration
| 00-Preface | 104.06 KB |
Preface
The H3C WX documentation set includes 11 configuration guides, which describe the software features for the H3C WX series access controllers and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The WLAN Configuration Guide describes WLAN service, WLAN security, WLAN roaming, WLAN RRM, WLAN QoS, WLAN IDS, WLAN mesh link, WLAN optimization, and advanced WLAN configurations.
NOTE: Support of the H3C WX series access controllers for features may vary by device model. For the feature matrixes, see About the WX Series Access Controllers Configuration Guides. |
This preface includes:
· Audience
Audience
· Field technical support and servicing engineers
· Network administrators working with the WX series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access controller, an access controller module, or a switching engine on a wireless switch. |
Represents an access point. |
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
Documentation feedback
We appreciate your comments.
